Date/Time: Tue, 26 Nov 2024 22:07:30 +0000
target quantities move
View Count: 518
[2022-04-20 16:58:56]
Technical - Posts: 158
I have a saved configuration which is set to:
Target 1 = Qty:2
Target 2 = Qty:1
Target 3 = Qty:1
It works for a while then it resets itself to:
Target 1 = Qty:1 <<
Target 2 = Qty:1
Target 3 = Qty:2 <<
How can I prevent this reset?
[2022-04-20 17:37:46]
John - SC Support - Posts: 36309
The only things we can think of that would cause this would be the following:
- Changing the configuration file that is in use by selecting it through a Control Bar button. Refer to the following:
Control Bar: Control Bar Trade Window Configuration Buttons
- The Trade Window is linked with another chart and the other chart trade window was changed. Refer to the following:
Basic Trading and the Trade Window: Linking Trade Window Configuration Between Charts
- You are actually looking at a trade window for a different chart and the original trade window is still correct. Refer to the following:
Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM
[2022-04-20 17:47:34]
Thank you. I am on 2383
I do not use the control bar to open a trade window, I leave it open.
I only have two charts in this chart book, and only one has a trade window.
There is only one trade window open. When I delete the associated chart (only for this discussion) that trade window closes.
[2022-04-20 22:38:39]
Sierra_Chart Engineering - Posts: 17185
This would happen when changing the parent order quantity.
[2022-04-21 12:15:06]
I see. This negatively impacts ones ability to scale in or out without altering the target values.
Can this be fixed?
[2024-09-06 13:35:57]
drw112 - Posts: 24
I know this is an old thread but this same behavior still exists when switching quantities as far as I can tell. Is there a way to lock targets per quantity?
[2024-09-06 15:35:56]
There is not a way to "lock" the quantities to particular targets. The solution is to use an Order Configuration when making a change to ensure that the quantities for the attached orders are setup the way you want them to be. Refer to the following:
Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations
