Date/Time: Mon, 10 Mar 2025 23:13:51 +0000
New Feature Request: Copy & Paste Drawing Settings
View Count: 619
[2022-04-20 12:53:34] |
User656492 - Posts: 146 |
I'd like to add to my chart shortcut menu the ability to right click on a drawing, copy it's settings and then select a different drawing and paste those settings to the selected drawing. Ex: from one horizontal ray, copy colors, text, alerts, et al and paste to another. Further, copy settings and save all those settings as a new drawing configuration. Further, save those settings as a new button on my active tool bar. Thanks for the consideration. |
[2022-04-20 16:18:06] |
John - SC Support - Posts: 38547 |
You can do this for a single drawing type. Get the settings as you want then save to a configuration. If you want to then copy that configuration to another configuration slot, load the first configuration, make any changes, and then save the configuration to a different number. Refer to the following: Chart Drawing Tools: Using Multiple Drawing Tool Configurations Refer to the following for assigning a tool and configuration to a control bar button: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-20 16:33:13] |
Hi John- Thanks for the quick response, but I'm looking for a simple ad hoc copy & paste.
[2022-04-20 17:21:43] |
As you have seen, there is not one. Just what we described previously.
[2022-04-20 17:25:02] |
I understand. That's why I titled it "New Feature Request" for when the team is looking for something to do. :-)
