Date/Time: Mon, 10 Mar 2025 23:12:00 +0000
Link Chart Drawings of Two Different Symbols
View Count: 623
[2022-04-20 12:03:29] |
User703411 - Posts: 19 |
Hi, Is there a way to link chart drawings from one symbol to another? E.g. I want to link drawings from the current ES futures month chart (F.US.EPM22), to the SPY chart (SPY-NQTV). Note: I've tried the normal way, for the same symbols, but this doesn't work. Can this be done? Thanks, Alan. Date Time Of Last Edit: 2022-04-20 12:05:35
[2022-04-20 15:54:37] |
John - SC Support - Posts: 38547 |
You can copy drawings between charts that do not have the same symbol. Refer to the information here Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) Just keep in mind that when you copy the drawing it is going to be at the same level as it was on the source chart. So if your charts have very different scales, you may not be able to see it on the destination chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
