Date/Time: Mon, 10 Mar 2025 23:13:18 +0000
[Programming Help] - Simple MACD Crossover Automation not Reversing
View Count: 621
[2022-04-20 02:28:02] |
Ankn - Posts: 11 |
Hello, I am using the MACD Crossover System and the Spreadsheet System for Trading studies. Goal is to simply have an automated MACD system that reverses at each crossover after the initial entry. The arrows are appearing on the chart were the entries should occur but when I run the replay the orders are not actually being entered properly, specifically it seems during reversals. I have Support Reversals on "yes". The attached image shows the correct long entry but then only the long exit and no reversal. I have consulted formula for MACD crossover system in spreadsheet The Sell Entry column has a 1 were the entry should occur but the system is not reversing. If I am missing something obvious I apologize I have looked multiple times and cannot see the mistake. Thanks. |
[2022-04-20 03:17:49] |
Sawtooth - Posts: 4181 |
1. Ln:15,16,22,23 need to be Yes.2. For reversals at each crossover, use only columns K and M. |
[2022-04-20 14:26:57] |
Ankn - Posts: 11 |
Same issue seems to be persisting. I had all those options checked to Yes other than LN15. They are all on Yes now. I'm not getting any trade service log errors either. |
