Date/Time: Mon, 10 Mar 2025 23:04:52 +0000
downloading chart
View Count: 389
[2022-04-20 00:29:57]
User946378 - Posts: 2
I'm having a problem while downloading thr charts. for exemple, If i have the software closed fora day or half a day, when i open it, it will not download the part when the software was closed.
If i open a new market, i can't download the previous days. it starts from zero even if i choose (in the chart settings) to load the last 30 days, for exemple.
Is it possible for you to fix the problem by teamviewer? Or please tell me what can i do.
Thank you
Best Regards
[2022-04-20 15:22:00]
John - SC Support - Posts: 38547
Our servers indicate you are using Rithmic for your data. Refer to the information at the following link for an explanation of what you are seeing:
Rithmic Trading Platform Service: Rithmic Support Policy
