Date/Time: Mon, 10 Mar 2025 23:09:29 +0000
'use evening session
View Count: 658
[2022-04-19 17:54:34]
the white rabbit - Posts: 22
Hi
Im trading the US session time, however recently the over night session data keep on loading in my chart.
When i select no is the Use evening session field in chart settings, it reverts back to YES and re-load the overnight session back into my charts.
is there any solution for this?
Im using sierra chart version 2383 currently.
[2022-04-20 13:40:47]
John - SC Support - Posts: 38547
The only reason something like that would occur is if there is another chart being referenced by that chart for which there is a requirement that they have the same session times. Refer to the following:
Chart Session Times: Session Times Automatically Changing Unexpectedly
[2022-04-20 16:04:40]
Thank you for your response John
it was indeed a referenced chart
