Date/Time: Tue, 11 Mar 2025 01:17:14 +0000
Line study
View Count: 552
[2022-04-19 17:40:47] |
User731023 - Posts: 143 |
Is there something I can do to get line study to show at 0? I had to use .01 to get it to show up. |
[2022-04-20 13:38:52] |
John - SC Support - Posts: 38547 |
0 is a special value. In general it is used to hide a subgraph when you do not want it displayed. There is an option on some studies to allow Zero values to display. The Line study does not have this. One of the studies that you can use to do this is the Spreadsheet Study. Just enter a formula of "=0" and ensure the option for "Draw Zero Values" is set to "Yes". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-24 20:37:49] |
The "Line" study absolutely does support drawing a value at 0. You should not have any trouble with this.
