Date/Time: Tue, 11 Mar 2025 02:22:05 +0000
Point Right Offset Draw Style
View Count: 625
[2022-04-19 08:00:43]
kas64h - Posts: 87
Under the Subgraphs Tab, would it be possible to add a Point Right Offset Draw Style (i.e. DRAWSTYLE_POINT_RIGHT_OFFSET in code), similar to the existing Triangle Right Offset (DRAWSTYLE_TRIANGLE_RIGHT_OFFSET in code) and Square Offset Right (DRAWSTYLE_SQUARE_OFFSET_RIGHT in code) Options?
Thank you.
[2022-04-19 15:55:35]
Yes we will add this.
Date Time Of Last Edit: 2022-04-19 15:55:48
[2022-04-25 18:50:31]
Sierra_Chart Engineering - Posts: 18738
This is either in the latest prerelease or will be out in the next release.
