Date/Time: Mon, 10 Mar 2025 23:25:00 +0000
How to plot a graph of ask volume bid volume average?or make a histogram of it?
View Count: 543
[2022-04-19 05:22:54] |
User487407 - Posts: 4 |
I cannot find any studies that has pre built for it. Any method I can achieve this? The only thing I get close is making a subgraph studies to show the difference on top of every bar. |
[2022-04-19 14:46:28] |
John - SC Support - Posts: 38547 |
What is available will depend on what you want exactly. If you want the Ask Volume Average and Bid Volume Average for an entire bar then there are a couple of items available in the Numbers Bars Calculated Values 2 study. Namely the Average Non-Zero Ask Volume, Average Non-Zero Bid Volume, and the Average Ask Volume per Price,Average Bid Volume per Price. If you are wanting the average ask/bid volume per trade at each price level, then this is not available through built-in studies. You would have to create a custom study to do this. Refer to the information starting here: Advanced Custom Study Interface and Language (ACSIL) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
