Date/Time: Mon, 10 Mar 2025 23:05:05 +0000
wrong daily volume of the current day
View Count: 458
[2022-04-18 19:54:40] |
natanibz - Posts: 139 |
Hello, I use Denali Exchange Data Feed and i have wrong volume of the current day in the daily charts. The daily volume is always greater than reality. Then the next day it is corrected, but during the day it is greater than reality. This for NQ, ES and YM. Thanks
Date Time Of Last Edit: 2022-04-18 20:26:35
[2022-04-18 20:56:06] |
John - SC Support - Posts: 38547 |
We are not sure what you are looking at, so it's hard for us to comment, but review the information at the following link and see if it answers your questions: Differences With Data and Chart Bars Between Services / Connections / Chart Types: 43.7 - Comparing Daily Volume to Intraday Chart Bar Volume For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-19 16:03:13] |
User372414 - Posts: 25 |
Exactly the same thing is happening to me on Historical daily charts quite often. Then I fix this with Reload and Recalculate.
