Date/Time: Sat, 19 Sep 2026 15:02:40 +0000
Associated watchlist integrated with barchart .csv files
View Count: 1397
| [2022-04-18 18:23:20] |
| jeden8l - Posts: 48 |
Good morning. Can we hope for integrating the Sierra Chart Associated Watchlist with Barchart screened US stocks? Barchart has an option to download a list of stocks (after screening) into .csv file. This would be a huge improvement for us as there are quite a lot of US stocks from all market caps to be backtested or alerted, it's time and effort consuming to add them all manually into Sierras watchlist. Please consider this. |
| [2022-04-18 20:28:24] |
| John - SC Support - Posts: 47939 |
You can import a list of symbols for the Associated Watchlist. Refer to the following: Changing the Symbol of a Chart: Importing a List of Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-04-18 21:14:51] |
Thanks John. For all other that been brought here by google- open .csv from Barchart, convert to .txt, in .txt replace all ',' with ';', convert back to .csv, in excel delete all columns except column A, then use simple formula to add "-NQTV" to all tickers in column A. Copy column A, paste into .txt, import to Sierra Associated Watchlist. Hope that helps. |
