Date/Time: Mon, 10 Mar 2025 23:28:24 +0000
How run 2 instances of sierra ?
View Count: 435
[2022-04-18 16:31:48] |
SniperWal216 - Posts: 2 |
Hello, I just took a subscription on oneup trader and they told me "You would need the data feed for the Sierra chart and run 2 instances of Sierra, 1 connected to the Denali feed for the historical chart and the other connected to Rithmic so your trades can reflect in your OneUp Trader account". So I want to know how I can do that ? |
[2022-04-18 17:21:01] |
John - SC Support - Posts: 38547 |
It looks like you have a live trading account, separate from the OneUp account. As such, it is easier to have two installations of Sierra Chart, one that is connected to your live account and the other connected to OneUp. To install a second Sierra Chart follow these instructions: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
