Date/Time: Mon, 10 Mar 2025 23:14:04 +0000
I'm trying to trade micro contracts but minis are being traded instead
View Count: 738
[2022-04-18 14:43:44]
brainscan132 - Posts: 5
I'm trying to trade S&P micro contracts and set up the trade symbol to reflect this as per the screenshot. When I sold 1 contract, it was a mini instead i.e. 10x larger than I'd wanted.
The instructions on the site say (for Trade and Current Quote Symbol): "When this option is selected, then the symbol entered in the Trade and Current Quote Symbol box will only be used for trading purposes" though this does not appear to have happened.
Please advise. Thanks
imagemicro trading query.png / V - Attached On 2022-04-18 14:40:58 UTC - Size: 170.68 KB - 159 views
[2022-04-18 16:52:11]
John - SC Support - Posts: 38547
You also need to adjust the Currency Value per Tick to match the symbol entered in the Trade and Current Quote Symbol. Refer to the information here:
Chart Settings: Updating Currency Value per Tick for Trade Symbol
[2022-04-18 19:41:06]
Make sure you have set the Trade and Current Quote Symbol on the specific chart or Trading DOM you are trading from . Refer to:
Chart Settings
