Date/Time: Mon, 10 Mar 2025 22:09:55 +0000
Yesterday's VbP on DOM
View Count: 527
[2022-04-18 11:09:35] |
User293778 - Posts: 21 |
Hi, Is it possible to display yesterday's VbP on the DOM? Or last week's or last month's? Because it seems that the few settings that work for VbP on DOM include all bars until the current one. Thanks. |
[2022-04-18 14:58:03] |
You really need a standard chart for this. Not a Trading DOM. So the answer is no this is not supported. Just use the chart DOM instead: Chart Trading and the Chart DOM: Using the Chart DOM / Order Entry Ladder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-18 14:58:44
