Date/Time: Mon, 10 Mar 2025 23:11:59 +0000
copy trades
View Count: 1827
[2022-04-18 07:19:45] |
Galmik - Posts: 37 |
Hi John I would like to ask you if i can copy trades, meaning when i open a position to trade on my sierra account at the same time this to be done to another sierra account. Also can u please tell me if AMP will add TETON? Have you had any news on that? Thanx again, Mike |
[2022-04-18 14:59:04] |
Yes. Refer to: Order Allocation to Trade Accounts AMP is intending to be supporting Teton but we do not know when. That is unknown. Our advice is to move to a different broker for now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-18 14:59:15
[2022-04-19 06:10:50] |
Can you tell me how to add 3 accounts on one laptop please? I have 2 other accounts on other laptops and i want to control all accounts and copy trades from one laptop. Thank you |
[2022-04-19 15:15:25] |
John - SC Support - Posts: 38547 |
If you are asking how to install separate Sierra Charts to have access to 3 different accounts in 3 different installations on one computer, then refer to the following for how to install additional Sierra Charts: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart But, you need to be aware that since you are using the Denali Exchange Data Feed that you can only get data to 2 installations of Sierra Chart on one computer. Refer to the information on connections with the Denali Exchange Data Feed here: Denali Exchange Data Feed: Connections If you are asking about how to have access to 3 different trading accounts from within a single instance of Sierra Chart, then that is dependent on how your accounts are setup with your broker. If the accounts are setup under a single login, then they should be able to access all of them from any Sierra Chart installation. Refer to the following for how to change your Trading Account: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-19 17:08:19] |
My accounts are not under a single login. So if you can't connect them through Sierra charts then i should talk to my broker on how to do that? Thank you John Mike |
[2022-04-19 17:48:01] |
If you are wanting them available from a single Sierra Chart either with or without using the Order Allocation to Trade Accounts, then you need to have your broker set that up for you.
