Date/Time: Tue, 11 Mar 2025 02:34:09 +0000
Not receiving Daily candles of the NQTV stocks
View Count: 1120
[2022-04-17 12:08:32]
user8888 - Posts: 159
What would be the reason for this?
It stopped getting daily data, past day April 8th. 9 days ago.
but it downloads lower TF data, like in 30 minutes or 240m
I'm paying for the Datafeed.
I'm in v2384
By the way, at least the indexes, often, end with and extra daily candle, in my chartbook.
I've found that, weirdly enought, if I replicate the chart, then that extra candle dissapears.
But I would not want to go replicating the chart that often because I have the charts sorted in a certain way.
Is there any way to avoid this?
Attached a chart of the ZOOM stock, with the missing candles, and another one of the emini SP500, with the double candle.
imageStock.PNG / V - Attached On 2022-04-17 11:53:15 UTC - Size: 29.31 KB - 134 views
imageSp500.PNG / V - Attached On 2022-04-17 12:08:15 UTC - Size: 9.53 KB - 133 views
[2022-04-17 12:22:52]
I've tried it with a bunch of stocks, all the same problem.
This appears for a brief moment while trying to load the daily chart
imageStock-2.PNG / V - Attached On 2022-04-17 12:22:41 UTC - Size: 4.76 KB - 142 views
[2022-04-17 12:57:04]
Tried to load the chartbook of the stocks again.
I got another message.
But they exists in the list.
Thank you
imageStock-3.PNG / V - Attached On 2022-04-17 12:56:30 UTC - Size: 2.05 KB - 135 views
[2022-04-17 17:44:13]
Confirmed: Intraday data downloads, Daily don't
Tried with a more traded symbol, NVDA.
Some lines from the Message Log:
Symbol Error - NVDA-NQTV is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2022-04-17 18:30:26.227
SC Data - All Services | Real-time data for symbol NVDA-NQTV is currently unavailable. | 2022-04-17 18:30:42.671
HD Request # 152 | Downloading Intraday chart data for NVDA-NQTV to the file NVDA-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-17 18:31:18.370
HD Request # 152 | Download start date-time: 2022-04-15 00:59:58.000000. File last date-time: 2022-04-15 00:59:58.601000 | 2022-04-17 18:31:18.370
HD Request # 152 | Using server: ds25.sierracharts.com port 10150 | 2022-04-17 18:31:18.370
HD Request # 152 | Intraday data download complete for NVDA-NQTV. Unique request ID: 150 | 2022-04-17 18:31:30.372
Removing historical data download ID 150. | 2022-04-17 18:31:30.372
Real-time Intraday chart data file updates started for NVDA-NQTV | 2022-04-17 18:31:30.372
Intraday chart data file opened for NVDA-NQTV | 2022-04-17 18:31:30.372
HD Request # 152 | Enabling Intraday chart updating for symbol. | 2022-04-17 18:31:30.372
[2022-04-17 18:26:14]
Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download".
After about a minute provide a copy of the Message Log following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
Regarding the duplicate bar, refer to:
Historical Chart Prices: 12.12 - Duplicate Bar in Historical Chart
We need the exact symbol of that chart and post an image of the chart following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage
[2022-04-17 19:57:15]
here the chart of that one stock, but happens aswell with a bunch of others
imageStock-4.PNG / V - Attached On 2022-04-17 19:57:04 UTC - Size: 27.93 KB - 137 views
[2022-04-17 20:00:46]
and regarding the duplicate bar, I notice it, with the symbols I open more often, the index futures of
F.US.EPM22
F.US.ENQM22
F.US.YMM22
F.US.RTYM22
attached is, again, a piece of the chart of the F.US.EPM22
imageSp500.PNG / V - Attached On 2022-04-17 20:00:39 UTC - Size: 9.53 KB - 136 views
[2022-04-17 22:04:19]
We do not see any log with the requested information in post #5.
Regarding post #8,:
Disable the use of Custom Symbol Settings Values.
Date Time Of Last Edit: 2022-04-17 22:04:31
[2022-04-17 22:14:48]
I'm sorry, I assumed that you could see hidden post. it's visible now. Thank you
And, I've updated the Symbols Settings as instructed.
Date Time Of Last Edit: 2022-04-17 22:27:00
[2022-04-17 22:47:15]
Ok, Daily data downloads now, at least from some stocks that I've tried. Thanks.
[2022-04-25 14:20:37]
michelh - Posts: 159
Hi Sierra,
Same problem. intraday chart and the daily chart have different prices. The daily doesnt have a new bar for the day.
I have delete and download data
I have also updated symbol settings
neither of these worked
here is what i did
i shut down sierra.
then deleted the dly from the data folder and restarted sierra.
now it works but this is a nuisance if to be done frequently.
please please fix.
also, when will the NQTV feed have accurate colume? sucks that I get different prices from IB and the feed. But I do appreciate the rapid intraday data download.
Date Time Of Last Edit: 2022-04-25 14:22:08
[2022-04-25 16:48:38]
John - SC Support - Posts: 38547
When you are having this issue, then we need to know the exact symbol for the chart for which you are having the issue and we would need to see your Message Log by following these instructions:
[2022-04-25 17:43:54]
Created the DTC Protocol server. | 2022-04-25 10:13:37.862
DTC Protocol Server listening on port 11099. | 2022-04-25 10:13:37.863
Reading Internal Order ID file. | 2022-04-25 10:13:37.863
Reading Trade Orders file. | 2022-04-25 10:13:37.946
Reading Trade Positions file. | 2022-04-25 10:13:37.947
Reading Trade Account Data files. | 2022-04-25 10:13:37.947
UDPListener (1436). Port 22903 | Listening on UDP port 22903. | 2022-04-25 10:13:37.971
Software version: 2383 64-bit | 2022-04-25 10:13:37.972
Primary Thread ID: 21208 | 2022-04-25 10:13:37.972
Usage end date: 2022-06-03 | 2022-04-25 10:13:37.972
Enabled for: Sierra Chart Historical Data Service. | 2022-04-25 10:13:37.972
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-04-25 10:13:37.972
Enabled for: Delayed Denali Exchange Data Feed. | 2022-04-25 10:13:37.972
Enabled for exchange2: CME (Trading Account Required) | 2022-04-25 10:13:37.972
Enabled for exchange2: CBOT (Trading Account Required) | 2022-04-25 10:13:37.972
Enabled for exchange2: COMEX (Trading Account Required) | 2022-04-25 10:13:37.972
Enabled for exchange2: NYMEX (Trading Account Required) | 2022-04-25 10:13:37.972
Enabled for exchange2: fairx_exchange.data | 2022-04-25 10:13:37.972
Enabled for exchange2: NASDAQ US stock data | 2022-04-25 10:13:37.972
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-04-25 10:13:37.972
Current selected Data/Trading service: Interactive Brokers | 2022-04-25 10:13:37.972
Custom symbol settings values: disabled | 2022-04-25 10:13:37.972
Chart Update Interval: 250 | 2022-04-25 10:13:37.972
Intraday Data Storage Time Unit: 0 | 2022-04-25 10:13:37.972
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-04-25 10:13:37.972
2022-04-25 14:13:37 Local computer time in UTC | 2022-04-25 10:13:37.972
2022-04-25 10:13:37 Local computer time in SC Time Zone | 2022-04-25 10:13:37.972
2022-04-25 14:13:34 Server time in UTC | 2022-04-25 10:13:37.972
Local computer UTC time and Server UTC time difference: 3 seconds. | 2022-04-25 10:13:37.972
Program path: C:\SierraChart\ | 2022-04-25 10:13:37.972
Data Files path: C:\SierraChart\Data\ | 2022-04-25 10:13:37.972
OS Version Number: 10.0 | 2022-04-25 10:13:37.972
Locale Setting: C | 2022-04-25 10:13:37.972
DLLs: AdaptiveIndicators_64.dll, astro_64.dll, AwodeleCompositeCycles_64.dll, AwodeleComposite_64.dll, Awodele_64.dll, BarCounter_64.dll, CompositeIndex_64.dll, CycleSolutions_64.dll, CycleTools_64.dll, DecyclerDetrend_64.dll, Detrender_64.dll, detrend_64.dll, DFTCompositeCycles_64.dll, DFTCompositeEnhanced_64.dll, DFTCyclesEnhanced_64.dll, DFTCycles_64.dll, DisplaySymbolText_64.dll, DTOscillator_64.dll, Ehlersbettersine_64.dll, EhlersDecyclerOscillator_64.dll, EhlersDecycler_64.dll, EhlersDominantCycleModified_64.dll | 2022-04-25 10:13:37.980
Allowed protected custom studies: | 2022-04-25 10:13:37.980
Crash reporter started: true | 2022-04-25 10:13:37.980
Created the DTC Protocol historical data server. | 2022-04-25 10:13:37.980
HD Server Manager | Listening on port 11098. | 2022-04-25 10:13:37.981
Checking for new symbol settings. Requested symbol settings MD5 for service code interactive_brokers.trading. Request ID: 1. | 2022-04-25 10:13:37.982
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:13:38.042
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-04-25 10:13:38.371
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-04-25 10:13:38.371
Received 5 login tokens. | 2022-04-25 10:13:39.013
Symbol settings MD5 received. Request ID: 1. | 2022-04-25 10:13:40.829
Symbol settings are up-to-date for interactive_brokers.trading. | 2022-04-25 10:13:40.829
Files to Open on Startup | Opening file: MACRO.Cht | 2022-04-25 10:13:43.406
Loading DLL: C:\SierraChart\Data\MACDMichel.dll (MACDMichel_64.dll). Handle: 66000000 | 2022-04-25 10:13:43.412
Loading DLL: C:\SierraChart\Data\CompositeIndex.dll (CompositeIndex_64.dll). Handle: 5f60000 | 2022-04-25 10:13:43.415
Loading DLL: C:\SierraChart\Data\RSImichel.dll (RSImichel_64.dll). Handle: 6050000 | 2022-04-25 10:13:43.417
Loading DLL: C:\SierraChart\Data\lvt95.dll (lvt95_64.dll). Handle: 7ffd31320000 | 2022-04-25 10:13:43.418
Loading DLL: C:\SierraChart\Data\ExhaustionBar.dll (ExhaustionBar_64.dll). Handle: 7ffd31310000 | 2022-04-25 10:13:43.419
AUS200 64 Day #7 | Reloading chart. | 2022-04-25 10:13:43.426
SPX500 4 Day #8 | Reloading chart. | 2022-04-25 10:13:43.439
NAS100 16 Day #9 | Reloading chart. | 2022-04-25 10:13:43.452
US30 Daily #10 | Reloading chart. | 2022-04-25 10:13:43.465
XAUUSD 2 Day #1 | Reloading chart. | 2022-04-25 10:13:43.478
AUDUSD 16 Day #2 | Reloading chart. | 2022-04-25 10:13:43.490
NGAS 4 Day #3 | Reloading chart. | 2022-04-25 10:13:43.502
WHEATF 2 Day #4 | Reloading chart. | 2022-04-25 10:13:43.514
DIA-NQTV Daily #5 | Reloading chart. | 2022-04-25 10:13:43.527
SPY-NQTV Daily #6 | Reloading chart. | 2022-04-25 10:13:43.553
QQQ-NQTV 4 Day #11 | Reloading chart. | 2022-04-25 10:13:43.566
QQQ-NQTV 128 Min #12 | Reloading chart. | 2022-04-25 10:13:43.577
Files to Open on Startup | Opening file: SCREENING.Cht | 2022-04-25 10:13:43.584
Files to Open on Startup | Opening file: ACTION.Cht | 2022-04-25 10:13:43.627
SPY-NQTV 2 Day #1 | Reloading chart. | 2022-04-25 10:13:43.647
Files to Open on Startup | Opening file: AGGS.Cht | 2022-04-25 10:13:43.653
ZW-202207-ECBOT [CS] 4 Day #15 | Reloading chart. | 2022-04-25 10:13:43.678
ZW-202207-ECBOT [CS] 4 Day #15 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:13:43.678
ZW-202207-ECBOT [CS] 4 Day #15 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:13:43.678
ZW-202207-ECBOT [CS] 4 Day #15 | Performing continuous chart historical Daily data download for symbol ZW-197207-ECBOT starting at 1971-06-17. | 2022-04-25 10:13:43.683
Starting DelayedDownloadMonitoringTimer | 2022-04-25 10:13:43.683
Starting HDTimeoutTimer | 2022-04-25 10:13:43.683
Added historical Daily data request for ZW-197207-ECBOT to the queue. | 2022-04-25 10:13:43.683
Triggering next historical data download in queue. | 2022-04-25 10:13:43.683
ZW-202207-ECBOT [CS] 4 Day #15 | Performing continuous chart historical Daily data download for symbol ZW-197307-ECBOT starting at 1972-06-19. | 2022-04-25 10:13:43.685
Added historical Daily data request for ZW-197307-ECBOT to the queue. | 2022-04-25 10:13:43.685
ZW-202207-ECBOT [CS] 4 Day #15 | Performing continuous chart historical Daily data download for symbol ZW-197407-ECBOT starting at 1973-06-18. | 2022-04-25 10:13:43.686
Added historical Daily data request for ZW-197407-ECBOT to the queue. | 2022-04-25 10:13:43.686
ZW-202207-ECBOT [CS] 4 Day #15 | Performing continuous chart historical Daily data download for symbol ZW-197507-ECBOT starting at 1974-06-17. | 2022-04-25 10:13:43.687
Added historical Daily data request for ZW-197507-ECBOT to the queue. | 2022-04-25 10:13:43.687
ZW-202207-ECBOT [CS] 4 Day #15 | Performing continuous chart historical Daily data download for symbol ZW-197607-ECBOT starting at 1975-06-17. | 2022-04-25 10:13:43.688
Added historical Daily data request for ZW-197607-ECBOT to the queue. | 2022-04-25 10:13:43.688
ZW-202207-ECBOT [CS] 4 Day #15 | Performing continuous chart historical Daily data download for symbol ZW-197707-ECBOT starting at 1976-06-17. | 2022-04-25 10:13:43.689
Added historical Daily data request for ZW-197707-ECBOT to the queue. | 2022-04-25 10:13:43.689
ZW-202207-ECBOT [CS] 4 Day #15 | Performing continuous chart historical Daily data download for symbol ZW-202207-ECBOT starting at last date in file. | 2022-04-25 10:13:43.736
Added historical Daily data request for ZW-202207-ECBOT to the queue. | 2022-04-25 10:13:43.736
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-200107-ECBOT.dly has a volume of 0 at 2000-06-20. | 2022-04-25 10:13:44.766
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-200007-ECBOT.dly has a volume of 0 at 1999-06-18. | 2022-04-25 10:13:44.809
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-200007-ECBOT.dly has a volume of 0 at 2000-06-19. | 2022-04-25 10:13:44.809
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199907-ECBOT.dly has a volume of 0 at 1998-06-18. | 2022-04-25 10:13:44.855
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199907-ECBOT.dly has a volume of 0 at 1999-06-17. | 2022-04-25 10:13:44.855
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199807-ECBOT.dly has a volume of 0 at 1997-06-18. | 2022-04-25 10:13:44.899
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199807-ECBOT.dly has a volume of 0 at 1998-06-17. | 2022-04-25 10:13:44.899
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199707-ECBOT.dly has a volume of 0 at 1996-06-18. | 2022-04-25 10:13:44.944
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199707-ECBOT.dly has a volume of 0 at 1997-06-17. | 2022-04-25 10:13:44.944
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199607-ECBOT.dly has a volume of 0 at 1995-06-20. | 2022-04-25 10:13:44.988
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199607-ECBOT.dly has a volume of 0 at 1996-06-17. | 2022-04-25 10:13:44.988
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199507-ECBOT.dly has a volume of 0 at 1994-06-20. | 2022-04-25 10:13:45.032
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199507-ECBOT.dly has a volume of 0 at 1995-06-19. | 2022-04-25 10:13:45.032
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199407-ECBOT.dly has a volume of 0 at 1993-06-18. | 2022-04-25 10:13:45.076
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199407-ECBOT.dly has a volume of 0 at 1994-06-17. | 2022-04-25 10:13:45.076
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199307-ECBOT.dly has a volume of 0 at 1992-06-18. | 2022-04-25 10:13:45.120
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199307-ECBOT.dly has a volume of 0 at 1993-06-17. | 2022-04-25 10:13:45.120
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199207-ECBOT.dly has a volume of 0 at 1991-06-18. | 2022-04-25 10:13:45.164
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199207-ECBOT.dly has a volume of 0 at 1992-06-17. | 2022-04-25 10:13:45.164
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199107-ECBOT.dly has a volume of 0 at 1990-06-19. | 2022-04-25 10:13:45.209
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199107-ECBOT.dly has a volume of 0 at 1991-06-17. | 2022-04-25 10:13:45.209
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199007-ECBOT.dly has a volume of 0 at 1989-06-20. | 2022-04-25 10:13:45.253
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199007-ECBOT.dly has a volume of 0 at 1990-06-18. | 2022-04-25 10:13:45.253
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198907-ECBOT.dly has a volume of 0 at 1988-06-20. | 2022-04-25 10:13:45.297
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198907-ECBOT.dly has a volume of 0 at 1989-06-19. | 2022-04-25 10:13:45.297
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198807-ECBOT.dly has a volume of 0 at 1987-06-18. | 2022-04-25 10:13:45.341
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198807-ECBOT.dly has a volume of 0 at 1988-06-17. | 2022-04-25 10:13:45.341
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198707-ECBOT.dly has a volume of 0 at 1986-06-18. | 2022-04-25 10:13:45.386
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198707-ECBOT.dly has a volume of 0 at 1987-06-17. | 2022-04-25 10:13:45.386
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198607-ECBOT.dly has a volume of 0 at 1985-06-18. | 2022-04-25 10:13:45.430
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198607-ECBOT.dly has a volume of 0 at 1986-06-17. | 2022-04-25 10:13:45.430
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198507-ECBOT.dly has a volume of 0 at 1984-06-19. | 2022-04-25 10:13:45.475
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198507-ECBOT.dly has a volume of 0 at 1985-06-17. | 2022-04-25 10:13:45.475
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198407-ECBOT.dly has a volume of 0 at 1983-06-20. | 2022-04-25 10:13:45.519
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198407-ECBOT.dly has a volume of 0 at 1984-06-18. | 2022-04-25 10:13:45.519
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198307-ECBOT.dly has a volume of 0 at 1982-06-18. | 2022-04-25 10:13:45.563
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198307-ECBOT.dly has a volume of 0 at 1983-06-17. | 2022-04-25 10:13:45.563
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198207-ECBOT.dly has a volume of 0 at 1981-06-18. | 2022-04-25 10:13:45.607
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198207-ECBOT.dly has a volume of 0 at 1982-06-17. | 2022-04-25 10:13:45.607
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198107-ECBOT.dly has a volume of 0 at 1980-06-18. | 2022-04-25 10:13:45.651
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198107-ECBOT.dly has a volume of 0 at 1981-06-17. | 2022-04-25 10:13:45.651
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198007-ECBOT.dly has a volume of 0 at 1979-06-19. | 2022-04-25 10:13:45.695
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198007-ECBOT.dly has a volume of 0 at 1980-06-17. | 2022-04-25 10:13:45.695
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-197907-ECBOT.dly has a volume of 0 at 1978-06-20. | 2022-04-25 10:13:45.740
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-197907-ECBOT.dly has a volume of 0 at 1979-06-18. | 2022-04-25 10:13:45.740
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-197807-ECBOT.dly has a volume of 0 at 1977-06-20. | 2022-04-25 10:13:45.787
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-197807-ECBOT.dly has a volume of 0 at 1978-06-19. | 2022-04-25 10:13:45.787
ZW-202207-ECBOT [CS] 4 Day #15 | Dates not found while checking for invalid data in continuous contract data files. ZW-197707-ECBOT | 2022-04-25 10:13:45.830 *
ZW-202207-ECBOT [CS] 4 Day #15 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, 6, 7, | 2022-04-25 10:13:45.830
ZW-202207-ECBOT [CS] Daily #4 | Reloading chart. | 2022-04-25 10:13:45.844
ZW-202207-ECBOT [CS] Daily #4 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:13:45.844
ZW-202207-ECBOT [CS] Daily #4 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:13:45.844
ZW-202207-ECBOT [CS] Daily #4 | File ZW-200107-ECBOT.dly has a volume of 0 at 2000-06-20. | 2022-04-25 10:13:46.936
ZW-202207-ECBOT [CS] Daily #4 | File ZW-200007-ECBOT.dly has a volume of 0 at 1999-06-18. | 2022-04-25 10:13:46.981
ZW-202207-ECBOT [CS] Daily #4 | File ZW-200007-ECBOT.dly has a volume of 0 at 2000-06-19. | 2022-04-25 10:13:46.981
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199907-ECBOT.dly has a volume of 0 at 1998-06-18. | 2022-04-25 10:13:47.025
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199907-ECBOT.dly has a volume of 0 at 1999-06-17. | 2022-04-25 10:13:47.025
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199807-ECBOT.dly has a volume of 0 at 1997-06-18. | 2022-04-25 10:13:47.071
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199807-ECBOT.dly has a volume of 0 at 1998-06-17. | 2022-04-25 10:13:47.071
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199707-ECBOT.dly has a volume of 0 at 1996-06-18. | 2022-04-25 10:13:47.116
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199707-ECBOT.dly has a volume of 0 at 1997-06-17. | 2022-04-25 10:13:47.116
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199607-ECBOT.dly has a volume of 0 at 1995-06-20. | 2022-04-25 10:13:47.160
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199607-ECBOT.dly has a volume of 0 at 1996-06-17. | 2022-04-25 10:13:47.160
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199507-ECBOT.dly has a volume of 0 at 1994-06-20. | 2022-04-25 10:13:47.204
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199507-ECBOT.dly has a volume of 0 at 1995-06-19. | 2022-04-25 10:13:47.204
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199407-ECBOT.dly has a volume of 0 at 1993-06-18. | 2022-04-25 10:13:47.249
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199407-ECBOT.dly has a volume of 0 at 1994-06-17. | 2022-04-25 10:13:47.249
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199307-ECBOT.dly has a volume of 0 at 1992-06-18. | 2022-04-25 10:13:47.294
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199307-ECBOT.dly has a volume of 0 at 1993-06-17. | 2022-04-25 10:13:47.294
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199207-ECBOT.dly has a volume of 0 at 1991-06-18. | 2022-04-25 10:13:47.339
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199207-ECBOT.dly has a volume of 0 at 1992-06-17. | 2022-04-25 10:13:47.339
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199107-ECBOT.dly has a volume of 0 at 1990-06-19. | 2022-04-25 10:13:47.384
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199107-ECBOT.dly has a volume of 0 at 1991-06-17. | 2022-04-25 10:13:47.384
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199007-ECBOT.dly has a volume of 0 at 1989-06-20. | 2022-04-25 10:13:47.429
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199007-ECBOT.dly has a volume of 0 at 1990-06-18. | 2022-04-25 10:13:47.429
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198907-ECBOT.dly has a volume of 0 at 1988-06-20. | 2022-04-25 10:13:47.474
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198907-ECBOT.dly has a volume of 0 at 1989-06-19. | 2022-04-25 10:13:47.474
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198807-ECBOT.dly has a volume of 0 at 1987-06-18. | 2022-04-25 10:13:47.519
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198807-ECBOT.dly has a volume of 0 at 1988-06-17. | 2022-04-25 10:13:47.519
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198707-ECBOT.dly has a volume of 0 at 1986-06-18. | 2022-04-25 10:13:47.564
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198707-ECBOT.dly has a volume of 0 at 1987-06-17. | 2022-04-25 10:13:47.564
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198607-ECBOT.dly has a volume of 0 at 1985-06-18. | 2022-04-25 10:13:47.607
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198607-ECBOT.dly has a volume of 0 at 1986-06-17. | 2022-04-25 10:13:47.607
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198507-ECBOT.dly has a volume of 0 at 1984-06-19. | 2022-04-25 10:13:47.652
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198507-ECBOT.dly has a volume of 0 at 1985-06-17. | 2022-04-25 10:13:47.652
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198407-ECBOT.dly has a volume of 0 at 1983-06-20. | 2022-04-25 10:13:47.696
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198407-ECBOT.dly has a volume of 0 at 1984-06-18. | 2022-04-25 10:13:47.696
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198307-ECBOT.dly has a volume of 0 at 1982-06-18. | 2022-04-25 10:13:47.739
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198307-ECBOT.dly has a volume of 0 at 1983-06-17. | 2022-04-25 10:13:47.739
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198207-ECBOT.dly has a volume of 0 at 1981-06-18. | 2022-04-25 10:13:47.783
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198207-ECBOT.dly has a volume of 0 at 1982-06-17. | 2022-04-25 10:13:47.783
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198107-ECBOT.dly has a volume of 0 at 1980-06-18. | 2022-04-25 10:13:47.828
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198107-ECBOT.dly has a volume of 0 at 1981-06-17. | 2022-04-25 10:13:47.828
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198007-ECBOT.dly has a volume of 0 at 1979-06-19. | 2022-04-25 10:13:47.872
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198007-ECBOT.dly has a volume of 0 at 1980-06-17. | 2022-04-25 10:13:47.872
ZW-202207-ECBOT [CS] Daily #4 | File ZW-197907-ECBOT.dly has a volume of 0 at 1978-06-20. | 2022-04-25 10:13:47.917
ZW-202207-ECBOT [CS] Daily #4 | File ZW-197907-ECBOT.dly has a volume of 0 at 1979-06-18. | 2022-04-25 10:13:47.917
ZW-202207-ECBOT [CS] Daily #4 | File ZW-197807-ECBOT.dly has a volume of 0 at 1977-06-20. | 2022-04-25 10:13:47.962
ZW-202207-ECBOT [CS] Daily #4 | File ZW-197807-ECBOT.dly has a volume of 0 at 1978-06-19. | 2022-04-25 10:13:47.962
ZW-202207-ECBOT [CS] Daily #4 | Dates not found while checking for invalid data in continuous contract data files. ZW-197707-ECBOT | 2022-04-25 10:13:48.004 *
ZW-202207-ECBOT [CS] Daily #4 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, 6, 7, | 2022-04-25 10:13:48.004
ZW-202207-ECBOT 512 Min #1 | Reloading chart. | 2022-04-25 10:13:48.016
ZW-202207-ECBOT 128 Min #11 | Reloading chart. | 2022-04-25 10:13:48.028
ZW-202207-ECBOT 1 Day #16 | Reloading chart. | 2022-04-25 10:13:48.041
ZS-202207-ECBOT [CS] 2 Day #6 | Reloading chart. | 2022-04-25 10:13:48.055
ZS-202207-ECBOT [CS] 2 Day #6 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:13:48.055
ZS-202207-ECBOT [CS] 2 Day #6 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:13:48.055
ZS-202207-ECBOT [CS] 2 Day #6 | Performing continuous chart historical Daily data download for symbol ZS-197207-ECBOT starting at 1971-06-27. | 2022-04-25 10:13:48.060
Added historical Daily data request for ZS-197207-ECBOT to the queue. | 2022-04-25 10:13:48.060
ZS-202207-ECBOT [CS] 2 Day #6 | Performing continuous chart historical Daily data download for symbol ZS-197307-ECBOT starting at 1972-06-27. | 2022-04-25 10:13:48.061
Added historical Daily data request for ZS-197307-ECBOT to the queue. | 2022-04-25 10:13:48.061
ZS-202207-ECBOT [CS] 2 Day #6 | Performing continuous chart historical Daily data download for symbol ZS-197407-ECBOT starting at 1973-06-26. | 2022-04-25 10:13:48.063
Added historical Daily data request for ZS-197407-ECBOT to the queue. | 2022-04-25 10:13:48.063
ZS-202207-ECBOT [CS] 2 Day #6 | Performing continuous chart historical Daily data download for symbol ZS-197507-ECBOT starting at 1974-06-25. | 2022-04-25 10:13:48.064
Added historical Daily data request for ZS-197507-ECBOT to the queue. | 2022-04-25 10:13:48.064
ZS-202207-ECBOT [CS] 2 Day #6 | Performing continuous chart historical Daily data download for symbol ZS-202207-ECBOT starting at last date in file. | 2022-04-25 10:13:48.111
Added historical Daily data request for ZS-202207-ECBOT to the queue. | 2022-04-25 10:13:48.111
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-200107-ECBOT.dly has a volume of 0 at 2000-06-28. | 2022-04-25 10:13:49.141
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-200007-ECBOT.dly has a volume of 0 at 1999-06-28. | 2022-04-25 10:13:49.184
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-200007-ECBOT.dly has a volume of 0 at 2000-06-27. | 2022-04-25 10:13:49.184
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199907-ECBOT.dly has a volume of 0 at 1998-06-26. | 2022-04-25 10:13:49.227
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199907-ECBOT.dly has a volume of 0 at 1999-06-25. | 2022-04-25 10:13:49.227
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199807-ECBOT.dly has a volume of 0 at 1997-06-26. | 2022-04-25 10:13:49.270
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199807-ECBOT.dly has a volume of 0 at 1998-06-25. | 2022-04-25 10:13:49.270
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199707-ECBOT.dly has a volume of 0 at 1996-06-26. | 2022-04-25 10:13:49.313
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199707-ECBOT.dly has a volume of 0 at 1997-06-25. | 2022-04-25 10:13:49.313
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199607-ECBOT.dly has a volume of 0 at 1995-06-28. | 2022-04-25 10:13:49.356
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199607-ECBOT.dly has a volume of 0 at 1996-06-25. | 2022-04-25 10:13:49.356
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199507-ECBOT.dly has a volume of 0 at 1994-06-28. | 2022-04-25 10:13:49.399
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199507-ECBOT.dly has a volume of 0 at 1995-06-27. | 2022-04-25 10:13:49.399
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199407-ECBOT.dly has a volume of 0 at 1993-06-28. | 2022-04-25 10:13:49.441
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199407-ECBOT.dly has a volume of 0 at 1994-06-27. | 2022-04-25 10:13:49.441
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199307-ECBOT.dly has a volume of 0 at 1992-06-26. | 2022-04-25 10:13:49.485
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199307-ECBOT.dly has a volume of 0 at 1993-06-25. | 2022-04-25 10:13:49.485
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199207-ECBOT.dly has a volume of 0 at 1991-06-26. | 2022-04-25 10:13:49.527
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199207-ECBOT.dly has a volume of 0 at 1992-06-25. | 2022-04-25 10:13:49.527
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199107-ECBOT.dly has a volume of 0 at 1990-06-27. | 2022-04-25 10:13:49.570
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199107-ECBOT.dly has a volume of 0 at 1991-06-25. | 2022-04-25 10:13:49.570
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199007-ECBOT.dly has a volume of 0 at 1989-06-28. | 2022-04-25 10:13:49.613
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199007-ECBOT.dly has a volume of 0 at 1990-06-26. | 2022-04-25 10:13:49.613
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198907-ECBOT.dly has a volume of 0 at 1988-06-28. | 2022-04-25 10:13:49.656
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198907-ECBOT.dly has a volume of 0 at 1989-06-27. | 2022-04-25 10:13:49.656
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198807-ECBOT.dly has a volume of 0 at 1987-06-26. | 2022-04-25 10:13:49.699
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198807-ECBOT.dly has a volume of 0 at 1988-06-27. | 2022-04-25 10:13:49.699
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198707-ECBOT.dly has a volume of 0 at 1986-06-26. | 2022-04-25 10:13:49.743
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198707-ECBOT.dly has a volume of 0 at 1987-06-25. | 2022-04-25 10:13:49.743
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198607-ECBOT.dly has a volume of 0 at 1985-06-26. | 2022-04-25 10:13:49.787
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198607-ECBOT.dly has a volume of 0 at 1986-06-25. | 2022-04-25 10:13:49.787
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198507-ECBOT.dly has a volume of 0 at 1984-06-27. | 2022-04-25 10:13:49.830
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198507-ECBOT.dly has a volume of 0 at 1985-06-25. | 2022-04-25 10:13:49.830
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198407-ECBOT.dly has a volume of 0 at 1983-06-28. | 2022-04-25 10:13:49.873
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198407-ECBOT.dly has a volume of 0 at 1984-06-26. | 2022-04-25 10:13:49.873
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198307-ECBOT.dly has a volume of 0 at 1982-06-28. | 2022-04-25 10:13:49.916
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198307-ECBOT.dly has a volume of 0 at 1983-06-27. | 2022-04-25 10:13:49.916
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198207-ECBOT.dly has a volume of 0 at 1981-06-26. | 2022-04-25 10:13:49.959
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198207-ECBOT.dly has a volume of 0 at 1982-06-25. | 2022-04-25 10:13:49.959
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198107-ECBOT.dly has a volume of 0 at 1980-06-26. | 2022-04-25 10:13:50.002
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198107-ECBOT.dly has a volume of 0 at 1981-06-25. | 2022-04-25 10:13:50.002
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198007-ECBOT.dly has a volume of 0 at 1979-06-27. | 2022-04-25 10:13:50.044
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198007-ECBOT.dly has a volume of 0 at 1980-06-25. | 2022-04-25 10:13:50.044
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-197907-ECBOT.dly has a volume of 0 at 1978-06-28. | 2022-04-25 10:13:50.087
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-197907-ECBOT.dly has a volume of 0 at 1979-06-26. | 2022-04-25 10:13:50.087
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-197807-ECBOT.dly has a volume of 0 at 1977-06-28. | 2022-04-25 10:13:50.130
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-197807-ECBOT.dly has a volume of 0 at 1978-06-27. | 2022-04-25 10:13:50.130
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-197707-ECBOT.dly has a volume of 0 at 1976-06-28. | 2022-04-25 10:13:50.173
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-197707-ECBOT.dly has a volume of 0 at 1977-06-27. | 2022-04-25 10:13:50.173
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-197607-ECBOT.dly has a volume of 0 at 1975-06-26. | 2022-04-25 10:13:50.216
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-197607-ECBOT.dly has a volume of 0 at 1976-06-25. | 2022-04-25 10:13:50.216
ZS-202207-ECBOT [CS] 2 Day #6 | Dates not found while checking for invalid data in continuous contract data files. ZS-197507-ECBOT | 2022-04-25 10:13:50.255 *
ZS-202207-ECBOT [CS] 2 Day #6 | Waiting for historical downloads to complete with the IDs: 8, 9, 10, 11, 12, | 2022-04-25 10:13:50.255
ZS-202207-ECBOT [CS] 4 Day #5 | Reloading chart. | 2022-04-25 10:13:50.266
ZS-202207-ECBOT [CS] 4 Day #5 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:13:50.266
ZS-202207-ECBOT [CS] 4 Day #5 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:13:50.266
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-200107-ECBOT.dly has a volume of 0 at 2000-06-28. | 2022-04-25 10:13:51.339
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-200007-ECBOT.dly has a volume of 0 at 1999-06-28. | 2022-04-25 10:13:51.381
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-200007-ECBOT.dly has a volume of 0 at 2000-06-27. | 2022-04-25 10:13:51.381
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199907-ECBOT.dly has a volume of 0 at 1998-06-26. | 2022-04-25 10:13:51.423
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199907-ECBOT.dly has a volume of 0 at 1999-06-25. | 2022-04-25 10:13:51.423
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199807-ECBOT.dly has a volume of 0 at 1997-06-26. | 2022-04-25 10:13:51.466
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199807-ECBOT.dly has a volume of 0 at 1998-06-25. | 2022-04-25 10:13:51.466
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199707-ECBOT.dly has a volume of 0 at 1996-06-26. | 2022-04-25 10:13:51.509
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199707-ECBOT.dly has a volume of 0 at 1997-06-25. | 2022-04-25 10:13:51.509
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199607-ECBOT.dly has a volume of 0 at 1995-06-28. | 2022-04-25 10:13:51.551
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199607-ECBOT.dly has a volume of 0 at 1996-06-25. | 2022-04-25 10:13:51.551
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199507-ECBOT.dly has a volume of 0 at 1994-06-28. | 2022-04-25 10:13:51.594
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199507-ECBOT.dly has a volume of 0 at 1995-06-27. | 2022-04-25 10:13:51.594
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199407-ECBOT.dly has a volume of 0 at 1993-06-28. | 2022-04-25 10:13:51.636
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199407-ECBOT.dly has a volume of 0 at 1994-06-27. | 2022-04-25 10:13:51.636
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199307-ECBOT.dly has a volume of 0 at 1992-06-26. | 2022-04-25 10:13:51.679
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199307-ECBOT.dly has a volume of 0 at 1993-06-25. | 2022-04-25 10:13:51.679
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199207-ECBOT.dly has a volume of 0 at 1991-06-26. | 2022-04-25 10:13:51.722
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199207-ECBOT.dly has a volume of 0 at 1992-06-25. | 2022-04-25 10:13:51.722
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199107-ECBOT.dly has a volume of 0 at 1990-06-27. | 2022-04-25 10:13:51.765
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199107-ECBOT.dly has a volume of 0 at 1991-06-25. | 2022-04-25 10:13:51.765
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199007-ECBOT.dly has a volume of 0 at 1989-06-28. | 2022-04-25 10:13:51.808
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199007-ECBOT.dly has a volume of 0 at 1990-06-26. | 2022-04-25 10:13:51.808
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198907-ECBOT.dly has a volume of 0 at 1988-06-28. | 2022-04-25 10:13:51.850
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198907-ECBOT.dly has a volume of 0 at 1989-06-27. | 2022-04-25 10:13:51.850
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198807-ECBOT.dly has a volume of 0 at 1987-06-26. | 2022-04-25 10:13:51.893
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198807-ECBOT.dly has a volume of 0 at 1988-06-27. | 2022-04-25 10:13:51.893
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198707-ECBOT.dly has a volume of 0 at 1986-06-26. | 2022-04-25 10:13:51.936
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198707-ECBOT.dly has a volume of 0 at 1987-06-25. | 2022-04-25 10:13:51.936
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198607-ECBOT.dly has a volume of 0 at 1985-06-26. | 2022-04-25 10:13:51.979
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198607-ECBOT.dly has a volume of 0 at 1986-06-25. | 2022-04-25 10:13:51.979
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198507-ECBOT.dly has a volume of 0 at 1984-06-27. | 2022-04-25 10:13:52.022
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198507-ECBOT.dly has a volume of 0 at 1985-06-25. | 2022-04-25 10:13:52.022
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198407-ECBOT.dly has a volume of 0 at 1983-06-28. | 2022-04-25 10:13:52.065
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198407-ECBOT.dly has a volume of 0 at 1984-06-26. | 2022-04-25 10:13:52.065
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198307-ECBOT.dly has a volume of 0 at 1982-06-28. | 2022-04-25 10:13:52.107
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198307-ECBOT.dly has a volume of 0 at 1983-06-27. | 2022-04-25 10:13:52.107
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198207-ECBOT.dly has a volume of 0 at 1981-06-26. | 2022-04-25 10:13:52.150
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198207-ECBOT.dly has a volume of 0 at 1982-06-25. | 2022-04-25 10:13:52.150
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198107-ECBOT.dly has a volume of 0 at 1980-06-26. | 2022-04-25 10:13:52.193
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198107-ECBOT.dly has a volume of 0 at 1981-06-25. | 2022-04-25 10:13:52.193
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198007-ECBOT.dly has a volume of 0 at 1979-06-27. | 2022-04-25 10:13:52.235
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198007-ECBOT.dly has a volume of 0 at 1980-06-25. | 2022-04-25 10:13:52.235
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-197907-ECBOT.dly has a volume of 0 at 1978-06-28. | 2022-04-25 10:13:52.278
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-197907-ECBOT.dly has a volume of 0 at 1979-06-26. | 2022-04-25 10:13:52.278
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-197807-ECBOT.dly has a volume of 0 at 1977-06-28. | 2022-04-25 10:13:52.320
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-197807-ECBOT.dly has a volume of 0 at 1978-06-27. | 2022-04-25 10:13:52.320
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-197707-ECBOT.dly has a volume of 0 at 1976-06-28. | 2022-04-25 10:13:52.363
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-197707-ECBOT.dly has a volume of 0 at 1977-06-27. | 2022-04-25 10:13:52.363
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-197607-ECBOT.dly has a volume of 0 at 1975-06-26. | 2022-04-25 10:13:52.406
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-197607-ECBOT.dly has a volume of 0 at 1976-06-25. | 2022-04-25 10:13:52.406
ZS-202207-ECBOT [CS] 4 Day #5 | Dates not found while checking for invalid data in continuous contract data files. ZS-197507-ECBOT | 2022-04-25 10:13:52.445 *
ZS-202207-ECBOT [CS] 4 Day #5 | Waiting for historical downloads to complete with the IDs: 8, 9, 10, 11, 12, | 2022-04-25 10:13:52.445
YK-202205-ECBOT-USD-1000 512 Min #12 | Reloading chart. | 2022-04-25 10:13:52.456
YK-202205-ECBOT-USD-1000 512 Min #13 | Reloading chart. | 2022-04-25 10:13:52.468
YK-202205-ECBOT-USD-1000 512 Min #23 | Reloading chart. | 2022-04-25 10:13:52.480
ZC-202207-ECBOT [CS] Daily #19 | Reloading chart. | 2022-04-25 10:13:52.494
ZC-202207-ECBOT [CS] Daily #19 | Performing continuous chart historical Daily data download for symbol ZC-202207-ECBOT starting at last date in file. | 2022-04-25 10:13:52.525
Added historical Daily data request for ZC-202207-ECBOT to the queue. | 2022-04-25 10:13:52.525
ZC-202207-ECBOT [CS] Daily #19 | File ZC-200107-ECBOT.dly has a volume of 0 at 2000-06-28. | 2022-04-25 10:13:53.527
ZC-202207-ECBOT [CS] Daily #19 | File ZC-200007-ECBOT.dly has a volume of 0 at 1999-06-28. | 2022-04-25 10:13:53.569
ZC-202207-ECBOT [CS] Daily #19 | File ZC-200007-ECBOT.dly has a volume of 0 at 2000-06-27. | 2022-04-25 10:13:53.569
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199907-ECBOT.dly has a volume of 0 at 1998-06-26. | 2022-04-25 10:13:53.612
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199907-ECBOT.dly has a volume of 0 at 1999-06-25. | 2022-04-25 10:13:53.612
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199807-ECBOT.dly has a volume of 0 at 1997-06-26. | 2022-04-25 10:13:53.655
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199807-ECBOT.dly has a volume of 0 at 1998-06-25. | 2022-04-25 10:13:53.655
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199707-ECBOT.dly has a volume of 0 at 1996-06-26. | 2022-04-25 10:13:53.697
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199707-ECBOT.dly has a volume of 0 at 1997-06-25. | 2022-04-25 10:13:53.697
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199607-ECBOT.dly has a volume of 0 at 1995-06-28. | 2022-04-25 10:13:53.739
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199607-ECBOT.dly has a volume of 0 at 1996-06-25. | 2022-04-25 10:13:53.739
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199507-ECBOT.dly has a volume of 0 at 1994-06-28. | 2022-04-25 10:13:53.782
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199507-ECBOT.dly has a volume of 0 at 1995-06-27. | 2022-04-25 10:13:53.782
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199407-ECBOT.dly has a volume of 0 at 1993-06-28. | 2022-04-25 10:13:53.825
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199407-ECBOT.dly has a volume of 0 at 1994-06-27. | 2022-04-25 10:13:53.825
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199307-ECBOT.dly has a volume of 0 at 1992-06-26. | 2022-04-25 10:13:53.868
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199307-ECBOT.dly has a volume of 0 at 1993-06-25. | 2022-04-25 10:13:53.868
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199207-ECBOT.dly has a volume of 0 at 1991-06-26. | 2022-04-25 10:13:53.911
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199207-ECBOT.dly has a volume of 0 at 1992-06-25. | 2022-04-25 10:13:53.911
ZC-202207-ECBOT [CS] Daily #19 | Waiting for historical downloads to complete with the IDs: 13, | 2022-04-25 10:13:53.911
ZC-202207-ECBOT 512 Min #3 | Reloading chart. | 2022-04-25 10:13:53.939
Files to Open on Startup | Opening file: INDICES.Cht | 2022-04-25 10:13:53.946
US30 Daily #1 | Reloading chart. | 2022-04-25 10:13:53.973
YM-202206-ECBOT [C] Daily #3 | Reloading chart. | 2022-04-25 10:13:53.987
YM-202206-ECBOT [C] Daily #3 | Performing continuous chart historical Daily data download for symbol YM-200206-ECBOT starting at 2002-03-07. | 2022-04-25 10:13:54.007
Added historical Daily data request for YM-200206-ECBOT to the queue. | 2022-04-25 10:13:54.007
YM-202206-ECBOT [C] Daily #3 | Performing continuous chart historical Daily data download for symbol YM-202206-ECBOT starting at last date in file. | 2022-04-25 10:13:54.095
Added historical Daily data request for YM-202206-ECBOT to the queue. | 2022-04-25 10:13:54.095
YM-202206-ECBOT [C] Daily #3 | File YM-200212-ECBOT.dly has a volume of 0 at 2002-09-12. | 2022-04-25 10:13:55.198
YM-202206-ECBOT [C] Daily #3 | File YM-200209-ECBOT.dly has a volume of 0 at 2002-06-13. | 2022-04-25 10:13:55.212
YM-202206-ECBOT [C] Daily #3 | Dates not found while checking for invalid data in continuous contract data files. YM-200206-ECBOT | 2022-04-25 10:13:55.223 *
YM-202206-ECBOT [C] Daily #3 | Waiting for historical downloads to complete with the IDs: 14, 15, | 2022-04-25 10:13:55.223
YM-202206-ECBOT [C] Daily #2 | Reloading chart. | 2022-04-25 10:13:55.238
YM-202206-ECBOT [C] Daily #2 | File YM-200212-ECBOT.dly has a volume of 0 at 2002-09-12. | 2022-04-25 10:13:56.453
YM-202206-ECBOT [C] Daily #2 | File YM-200209-ECBOT.dly has a volume of 0 at 2002-06-13. | 2022-04-25 10:13:56.467
YM-202206-ECBOT [C] Daily #2 | Dates not found while checking for invalid data in continuous contract data files. YM-200206-ECBOT | 2022-04-25 10:13:56.478 *
YM-202206-ECBOT [C] Daily #2 | Waiting for historical downloads to complete with the IDs: 14, 15, | 2022-04-25 10:13:56.478
YM-202206-ECBOT [C] 2 Day #10 | Reloading chart. | 2022-04-25 10:13:56.489
YM-202206-ECBOT [C] 2 Day #10 | File YM-200212-ECBOT.dly has a volume of 0 at 2002-09-12. | 2022-04-25 10:13:57.695
YM-202206-ECBOT [C] 2 Day #10 | File YM-200209-ECBOT.dly has a volume of 0 at 2002-06-13. | 2022-04-25 10:13:57.708
YM-202206-ECBOT [C] 2 Day #10 | Dates not found while checking for invalid data in continuous contract data files. YM-200206-ECBOT | 2022-04-25 10:13:57.719 *
YM-202206-ECBOT [C] 2 Day #10 | Waiting for historical downloads to complete with the IDs: 14, 15, | 2022-04-25 10:13:57.719
MYM-202206-ECBOT-USD [C] 768 Min #4 | Reloading chart. | 2022-04-25 10:13:57.731
MYM-202206-ECBOT-USD [C] 24 Min #26 | Reloading chart. | 2022-04-25 10:13:57.743
NAS100 Daily #5 | Reloading chart. | 2022-04-25 10:13:57.756
NQ-202206-GLOBEX [C] Daily #11 | Reloading chart. | 2022-04-25 10:13:57.772
NQ-202206-GLOBEX [C] Daily #11 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:13:57.772
NQ-202206-GLOBEX [C] Daily #11 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:13:57.772
NQ-202206-GLOBEX [C] Daily #11 | Performing continuous chart historical Daily data download for symbol NQ-199909-GLOBEX starting at 1999-06-09. | 2022-04-25 10:13:57.838
Added historical Daily data request for NQ-199909-GLOBEX to the queue. | 2022-04-25 10:13:57.838
NQ-202206-GLOBEX [C] Daily #11 | Performing continuous chart historical Daily data download for symbol NQ-202206-GLOBEX starting at last date in file. | 2022-04-25 10:13:57.937
Added historical Daily data request for NQ-202206-GLOBEX to the queue. | 2022-04-25 10:13:57.937
NQ-202206-GLOBEX [C] Daily #11 | File NQ-200103-GLOBEX.dly has a volume of 0 at 2000-12-08. | 2022-04-25 10:13:59.131
NQ-202206-GLOBEX [C] Daily #11 | File NQ-200012-GLOBEX.dly has a volume of 0 at 2000-09-08. | 2022-04-25 10:13:59.145
NQ-202206-GLOBEX [C] Daily #11 | File NQ-200012-GLOBEX.dly has a volume of 0 at 2000-12-07. | 2022-04-25 10:13:59.145
NQ-202206-GLOBEX [C] Daily #11 | File NQ-200009-GLOBEX.dly has a volume of 0 at 2000-06-08. | 2022-04-25 10:13:59.158
NQ-202206-GLOBEX [C] Daily #11 | File NQ-200009-GLOBEX.dly has a volume of 0 at 2000-09-07. | 2022-04-25 10:13:59.158
NQ-202206-GLOBEX [C] Daily #11 | File NQ-200006-GLOBEX.dly has a volume of 0 at 2000-03-09. | 2022-04-25 10:13:59.171
NQ-202206-GLOBEX [C] Daily #11 | File NQ-200006-GLOBEX.dly has a volume of 0 at 2000-06-07. | 2022-04-25 10:13:59.171
NQ-202206-GLOBEX [C] Daily #11 | File NQ-200003-GLOBEX.dly has a volume of 0 at 1999-12-09. | 2022-04-25 10:13:59.184
NQ-202206-GLOBEX [C] Daily #11 | File NQ-200003-GLOBEX.dly has a volume of 0 at 2000-03-08. | 2022-04-25 10:13:59.184
NQ-202206-GLOBEX [C] Daily #11 | File NQ-199912-GLOBEX.dly has a volume of 0 at 1999-09-09. | 2022-04-25 10:13:59.197
NQ-202206-GLOBEX [C] Daily #11 | File NQ-199912-GLOBEX.dly has a volume of 0 at 1999-12-08. | 2022-04-25 10:13:59.197
NQ-202206-GLOBEX [C] Daily #11 | Dates not found while checking for invalid data in continuous contract data files. NQ-199909-GLOBEX | 2022-04-25 10:13:59.209 *
NQ-202206-GLOBEX [C] Daily #11 | Waiting for historical downloads to complete with the IDs: 16, 17, | 2022-04-25 10:13:59.209
NQ-202206-GLOBEX [C] Daily #6 | Reloading chart. | 2022-04-25 10:13:59.224
NQ-202206-GLOBEX [C] Daily #6 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:13:59.224
NQ-202206-GLOBEX [C] Daily #6 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:13:59.224
NQ-202206-GLOBEX [C] Daily #6 | File NQ-200103-GLOBEX.dly has a volume of 0 at 2000-12-08. | 2022-04-25 10:14:00.579
NQ-202206-GLOBEX [C] Daily #6 | File NQ-200012-GLOBEX.dly has a volume of 0 at 2000-09-08. | 2022-04-25 10:14:00.592
NQ-202206-GLOBEX [C] Daily #6 | File NQ-200012-GLOBEX.dly has a volume of 0 at 2000-12-07. | 2022-04-25 10:14:00.592
NQ-202206-GLOBEX [C] Daily #6 | File NQ-200009-GLOBEX.dly has a volume of 0 at 2000-06-08. | 2022-04-25 10:14:00.606
NQ-202206-GLOBEX [C] Daily #6 | File NQ-200009-GLOBEX.dly has a volume of 0 at 2000-09-07. | 2022-04-25 10:14:00.606
NQ-202206-GLOBEX [C] Daily #6 | File NQ-200006-GLOBEX.dly has a volume of 0 at 2000-03-09. | 2022-04-25 10:14:00.619
NQ-202206-GLOBEX [C] Daily #6 | File NQ-200006-GLOBEX.dly has a volume of 0 at 2000-06-07. | 2022-04-25 10:14:00.619
NQ-202206-GLOBEX [C] Daily #6 | File NQ-200003-GLOBEX.dly has a volume of 0 at 1999-12-09. | 2022-04-25 10:14:00.632
NQ-202206-GLOBEX [C] Daily #6 | File NQ-200003-GLOBEX.dly has a volume of 0 at 2000-03-08. | 2022-04-25 10:14:00.632
NQ-202206-GLOBEX [C] Daily #6 | File NQ-199912-GLOBEX.dly has a volume of 0 at 1999-09-09. | 2022-04-25 10:14:00.646
NQ-202206-GLOBEX [C] Daily #6 | File NQ-199912-GLOBEX.dly has a volume of 0 at 1999-12-08. | 2022-04-25 10:14:00.646
NQ-202206-GLOBEX [C] Daily #6 | Dates not found while checking for invalid data in continuous contract data files. NQ-199909-GLOBEX | 2022-04-25 10:14:00.658 *
NQ-202206-GLOBEX [C] Daily #6 | Waiting for historical downloads to complete with the IDs: 16, 17, | 2022-04-25 10:14:00.658
NQ-202206-GLOBEX [C] 4 Day #14 | Reloading chart. | 2022-04-25 10:14:00.670
NQ-202206-GLOBEX [C] 4 Day #14 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:00.670
NQ-202206-GLOBEX [C] 4 Day #14 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:00.670
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-200103-GLOBEX.dly has a volume of 0 at 2000-12-08. | 2022-04-25 10:14:01.992
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-200012-GLOBEX.dly has a volume of 0 at 2000-09-08. | 2022-04-25 10:14:02.004
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-200012-GLOBEX.dly has a volume of 0 at 2000-12-07. | 2022-04-25 10:14:02.004
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-200009-GLOBEX.dly has a volume of 0 at 2000-06-08. | 2022-04-25 10:14:02.017
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-200009-GLOBEX.dly has a volume of 0 at 2000-09-07. | 2022-04-25 10:14:02.017
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-200006-GLOBEX.dly has a volume of 0 at 2000-03-09. | 2022-04-25 10:14:02.030
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-200006-GLOBEX.dly has a volume of 0 at 2000-06-07. | 2022-04-25 10:14:02.030
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-200003-GLOBEX.dly has a volume of 0 at 1999-12-09. | 2022-04-25 10:14:02.043
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-200003-GLOBEX.dly has a volume of 0 at 2000-03-08. | 2022-04-25 10:14:02.043
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-199912-GLOBEX.dly has a volume of 0 at 1999-09-09. | 2022-04-25 10:14:02.056
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-199912-GLOBEX.dly has a volume of 0 at 1999-12-08. | 2022-04-25 10:14:02.056
NQ-202206-GLOBEX [C] 4 Day #14 | Dates not found while checking for invalid data in continuous contract data files. NQ-199909-GLOBEX | 2022-04-25 10:14:02.067 *
NQ-202206-GLOBEX [C] 4 Day #14 | Waiting for historical downloads to complete with the IDs: 16, 17, | 2022-04-25 10:14:02.067
MNQ-202206-GLOBEX-USD 768 Min #25 | Reloading chart. | 2022-04-25 10:14:02.080
MNQ-202206-GLOBEX-USD 6 Min #13 | Reloading chart. | 2022-04-25 10:14:02.092
MNQ-202206-GLOBEX-USD 1 Day #7 | Reloading chart. | 2022-04-25 10:14:02.105
MNQ-202206-GLOBEX-USD 24 Min #18 | Reloading chart. | 2022-04-25 10:14:02.133
ZN-202206-ECBOT [C] Daily #23 | Reloading chart. | 2022-04-25 10:14:02.145
ZN-202206-ECBOT [C] Daily #23 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:02.146
ZN-202206-ECBOT [C] Daily #23 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:02.146
ZN-202206-ECBOT [C] Daily #23 | Performing continuous chart historical Daily data download for symbol ZN-198206-ECBOT starting at 1982-02-25. | 2022-04-25 10:14:02.179
Added historical Daily data request for ZN-198206-ECBOT to the queue. | 2022-04-25 10:14:02.179
ZN-202206-ECBOT [C] Daily #23 | Performing continuous chart historical Daily data download for symbol ZN-202206-ECBOT starting at last date in file. | 2022-04-25 10:14:02.340
Added historical Daily data request for ZN-202206-ECBOT to the queue. | 2022-04-25 10:14:02.340
ZN-202206-ECBOT [C] Daily #23 | File ZN-200103-ECBOT.dly has a volume of 0 at 2000-11-30. | 2022-04-25 10:14:03.631
ZN-202206-ECBOT [C] Daily #23 | File ZN-200012-ECBOT.dly has a volume of 0 at 2000-08-31. | 2022-04-25 10:14:03.644
ZN-202206-ECBOT [C] Daily #23 | File ZN-200012-ECBOT.dly has a volume of 0 at 2000-11-29. | 2022-04-25 10:14:03.644
ZN-202206-ECBOT [C] Daily #23 | File ZN-200009-ECBOT.dly has a volume of 0 at 2000-05-31. | 2022-04-25 10:14:03.657
ZN-202206-ECBOT [C] Daily #23 | File ZN-200009-ECBOT.dly has a volume of 0 at 2000-08-30. | 2022-04-25 10:14:03.657
ZN-202206-ECBOT [C] Daily #23 | File ZN-200006-ECBOT.dly has a volume of 0 at 2000-02-29. | 2022-04-25 10:14:03.670
ZN-202206-ECBOT [C] Daily #23 | File ZN-200006-ECBOT.dly has a volume of 0 at 2000-05-30. | 2022-04-25 10:14:03.670
ZN-202206-ECBOT [C] Daily #23 | File ZN-200003-ECBOT.dly has a volume of 0 at 1999-11-30. | 2022-04-25 10:14:03.683
ZN-202206-ECBOT [C] Daily #23 | File ZN-200003-ECBOT.dly has a volume of 0 at 2000-02-28. | 2022-04-25 10:14:03.683
ZN-202206-ECBOT [C] Daily #23 | File ZN-199912-ECBOT.dly has a volume of 0 at 1999-08-31. | 2022-04-25 10:14:03.696
ZN-202206-ECBOT [C] Daily #23 | File ZN-199912-ECBOT.dly has a volume of 0 at 1999-11-29. | 2022-04-25 10:14:03.696
ZN-202206-ECBOT [C] Daily #23 | File ZN-199909-ECBOT.dly has a volume of 0 at 1999-05-31. | 2022-04-25 10:14:03.711
ZN-202206-ECBOT [C] Daily #23 | File ZN-199909-ECBOT.dly has a volume of 0 at 1999-08-30. | 2022-04-25 10:14:03.711
ZN-202206-ECBOT [C] Daily #23 | File ZN-199906-ECBOT.dly has a volume of 0 at 1999-02-26. | 2022-04-25 10:14:03.725
ZN-202206-ECBOT [C] Daily #23 | File ZN-199906-ECBOT.dly has a volume of 0 at 1999-05-28. | 2022-04-25 10:14:03.725
ZN-202206-ECBOT [C] Daily #23 | File ZN-199903-ECBOT.dly has a volume of 0 at 1998-11-30. | 2022-04-25 10:14:03.739
ZN-202206-ECBOT [C] Daily #23 | File ZN-199903-ECBOT.dly has a volume of 0 at 1999-02-25. | 2022-04-25 10:14:03.739
ZN-202206-ECBOT [C] Daily #23 | File ZN-199812-ECBOT.dly has a volume of 0 at 1998-08-31. | 2022-04-25 10:14:03.752
ZN-202206-ECBOT [C] Daily #23 | File ZN-199812-ECBOT.dly has a volume of 0 at 1998-11-27. | 2022-04-25 10:14:03.752
ZN-202206-ECBOT [C] Daily #23 | File ZN-199809-ECBOT.dly has a volume of 0 at 1998-05-29. | 2022-04-25 10:14:03.765
ZN-202206-ECBOT [C] Daily #23 | File ZN-199809-ECBOT.dly has a volume of 0 at 1998-08-28. | 2022-04-25 10:14:03.765
ZN-202206-ECBOT [C] Daily #23 | File ZN-199806-ECBOT.dly has a volume of 0 at 1998-02-27. | 2022-04-25 10:14:03.779
ZN-202206-ECBOT [C] Daily #23 | File ZN-199806-ECBOT.dly has a volume of 0 at 1998-05-28. | 2022-04-25 10:14:03.779
ZN-202206-ECBOT [C] Daily #23 | File ZN-199803-ECBOT.dly has a volume of 0 at 1997-11-28. | 2022-04-25 10:14:03.792
ZN-202206-ECBOT [C] Daily #23 | File ZN-199803-ECBOT.dly has a volume of 0 at 1998-02-26. | 2022-04-25 10:14:03.792
ZN-202206-ECBOT [C] Daily #23 | File ZN-199712-ECBOT.dly has a volume of 0 at 1997-08-29. | 2022-04-25 10:14:03.805
ZN-202206-ECBOT [C] Daily #23 | File ZN-199712-ECBOT.dly has a volume of 0 at 1997-11-27. | 2022-04-25 10:14:03.805
ZN-202206-ECBOT [C] Daily #23 | File ZN-199709-ECBOT.dly has a volume of 0 at 1997-05-30. | 2022-04-25 10:14:03.819
ZN-202206-ECBOT [C] Daily #23 | File ZN-199709-ECBOT.dly has a volume of 0 at 1997-08-28. | 2022-04-25 10:14:03.819
ZN-202206-ECBOT [C] Daily #23 | File ZN-199706-ECBOT.dly has a volume of 0 at 1997-02-28. | 2022-04-25 10:14:03.832
ZN-202206-ECBOT [C] Daily #23 | File ZN-199706-ECBOT.dly has a volume of 0 at 1997-05-29. | 2022-04-25 10:14:03.832
ZN-202206-ECBOT [C] Daily #23 | File ZN-199703-ECBOT.dly has a volume of 0 at 1996-11-29. | 2022-04-25 10:14:03.845
ZN-202206-ECBOT [C] Daily #23 | File ZN-199703-ECBOT.dly has a volume of 0 at 1997-02-27. | 2022-04-25 10:14:03.845
ZN-202206-ECBOT [C] Daily #23 | File ZN-199612-ECBOT.dly has a volume of 0 at 1996-08-30. | 2022-04-25 10:14:03.859
ZN-202206-ECBOT [C] Daily #23 | File ZN-199612-ECBOT.dly has a volume of 0 at 1996-11-28. | 2022-04-25 10:14:03.859
ZN-202206-ECBOT [C] Daily #23 | File ZN-199609-ECBOT.dly has a volume of 0 at 1996-05-31. | 2022-04-25 10:14:03.882
ZN-202206-ECBOT [C] Daily #23 | File ZN-199609-ECBOT.dly has a volume of 0 at 1996-08-29. | 2022-04-25 10:14:03.882
ZN-202206-ECBOT [C] Daily #23 | File ZN-199606-ECBOT.dly has a volume of 0 at 1996-02-29. | 2022-04-25 10:14:03.905
ZN-202206-ECBOT [C] Daily #23 | File ZN-199606-ECBOT.dly has a volume of 0 at 1996-05-30. | 2022-04-25 10:14:03.905
ZN-202206-ECBOT [C] Daily #23 | File ZN-199603-ECBOT.dly has a volume of 0 at 1995-11-30. | 2022-04-25 10:14:03.927
ZN-202206-ECBOT [C] Daily #23 | File ZN-199603-ECBOT.dly has a volume of 0 at 1996-02-28. | 2022-04-25 10:14:03.927
ZN-202206-ECBOT [C] Daily #23 | File ZN-199512-ECBOT.dly has a volume of 0 at 1995-08-31. | 2022-04-25 10:14:03.948
ZN-202206-ECBOT [C] Daily #23 | File ZN-199512-ECBOT.dly has a volume of 0 at 1995-11-29. | 2022-04-25 10:14:03.948
ZN-202206-ECBOT [C] Daily #23 | File ZN-199509-ECBOT.dly has a volume of 0 at 1995-05-31. | 2022-04-25 10:14:03.971
ZN-202206-ECBOT [C] Daily #23 | File ZN-199509-ECBOT.dly has a volume of 0 at 1995-08-30. | 2022-04-25 10:14:03.971
ZN-202206-ECBOT [C] Daily #23 | File ZN-199506-ECBOT.dly has a volume of 0 at 1995-02-28. | 2022-04-25 10:14:03.993
ZN-202206-ECBOT [C] Daily #23 | File ZN-199506-ECBOT.dly has a volume of 0 at 1995-05-30. | 2022-04-25 10:14:03.993
ZN-202206-ECBOT [C] Daily #23 | File ZN-199503-ECBOT.dly has a volume of 0 at 1994-11-30. | 2022-04-25 10:14:04.015
ZN-202206-ECBOT [C] Daily #23 | File ZN-199503-ECBOT.dly has a volume of 0 at 1995-02-27. | 2022-04-25 10:14:04.015
ZN-202206-ECBOT [C] Daily #23 | File ZN-199412-ECBOT.dly has a volume of 0 at 1994-08-31. | 2022-04-25 10:14:04.037
ZN-202206-ECBOT [C] Daily #23 | File ZN-199412-ECBOT.dly has a volume of 0 at 1994-11-29. | 2022-04-25 10:14:04.037
ZN-202206-ECBOT [C] Daily #23 | File ZN-199409-ECBOT.dly has a volume of 0 at 1994-05-31. | 2022-04-25 10:14:04.051
ZN-202206-ECBOT [C] Daily #23 | File ZN-199409-ECBOT.dly has a volume of 0 at 1994-08-30. | 2022-04-25 10:14:04.051
ZN-202206-ECBOT [C] Daily #23 | File ZN-199406-ECBOT.dly has a volume of 0 at 1994-02-28. | 2022-04-25 10:14:04.064
ZN-202206-ECBOT [C] Daily #23 | File ZN-199406-ECBOT.dly has a volume of 0 at 1994-05-30. | 2022-04-25 10:14:04.064
ZN-202206-ECBOT [C] Daily #23 | File ZN-199403-ECBOT.dly has a volume of 0 at 1993-11-30. | 2022-04-25 10:14:04.078
ZN-202206-ECBOT [C] Daily #23 | File ZN-199403-ECBOT.dly has a volume of 0 at 1994-02-25. | 2022-04-25 10:14:04.078
ZN-202206-ECBOT [C] Daily #23 | File ZN-199312-ECBOT.dly has a volume of 0 at 1993-08-31. | 2022-04-25 10:14:04.091
ZN-202206-ECBOT [C] Daily #23 | File ZN-199312-ECBOT.dly has a volume of 0 at 1993-11-29. | 2022-04-25 10:14:04.091
ZN-202206-ECBOT [C] Daily #23 | File ZN-199309-ECBOT.dly has a volume of 0 at 1993-05-31. | 2022-04-25 10:14:04.105
ZN-202206-ECBOT [C] Daily #23 | File ZN-199309-ECBOT.dly has a volume of 0 at 1993-08-30. | 2022-04-25 10:14:04.105
ZN-202206-ECBOT [C] Daily #23 | File ZN-199306-ECBOT.dly has a volume of 0 at 1993-02-26. | 2022-04-25 10:14:04.118
ZN-202206-ECBOT [C] Daily #23 | File ZN-199306-ECBOT.dly has a volume of 0 at 1993-05-28. | 2022-04-25 10:14:04.118
ZN-202206-ECBOT [C] Daily #23 | File ZN-199303-ECBOT.dly has a volume of 0 at 1992-11-30. | 2022-04-25 10:14:04.131
ZN-202206-ECBOT [C] Daily #23 | File ZN-199303-ECBOT.dly has a volume of 0 at 1993-02-25. | 2022-04-25 10:14:04.131
ZN-202206-ECBOT [C] Daily #23 | File ZN-199212-ECBOT.dly has a volume of 0 at 1992-08-31. | 2022-04-25 10:14:04.145
ZN-202206-ECBOT [C] Daily #23 | File ZN-199212-ECBOT.dly has a volume of 0 at 1992-11-27. | 2022-04-25 10:14:04.145
ZN-202206-ECBOT [C] Daily #23 | File ZN-199209-ECBOT.dly has a volume of 0 at 1992-05-29. | 2022-04-25 10:14:04.159
ZN-202206-ECBOT [C] Daily #23 | File ZN-199209-ECBOT.dly has a volume of 0 at 1992-08-28. | 2022-04-25 10:14:04.159
ZN-202206-ECBOT [C] Daily #23 | File ZN-199206-ECBOT.dly has a volume of 0 at 1992-02-28. | 2022-04-25 10:14:04.173
ZN-202206-ECBOT [C] Daily #23 | File ZN-199206-ECBOT.dly has a volume of 0 at 1992-05-28. | 2022-04-25 10:14:04.173
ZN-202206-ECBOT [C] Daily #23 | File ZN-199203-ECBOT.dly has a volume of 0 at 1991-11-29. | 2022-04-25 10:14:04.187
ZN-202206-ECBOT [C] Daily #23 | File ZN-199203-ECBOT.dly has a volume of 0 at 1992-02-27. | 2022-04-25 10:14:04.187
ZN-202206-ECBOT [C] Daily #23 | File ZN-199112-ECBOT.dly has a volume of 0 at 1991-08-30. | 2022-04-25 10:14:04.201
ZN-202206-ECBOT [C] Daily #23 | File ZN-199112-ECBOT.dly has a volume of 0 at 1991-11-28. | 2022-04-25 10:14:04.201
ZN-202206-ECBOT [C] Daily #23 | File ZN-199109-ECBOT.dly has a volume of 0 at 1991-05-31. | 2022-04-25 10:14:04.215
ZN-202206-ECBOT [C] Daily #23 | File ZN-199109-ECBOT.dly has a volume of 0 at 1991-08-29. | 2022-04-25 10:14:04.215
ZN-202206-ECBOT [C] Daily #23 | File ZN-199106-ECBOT.dly has a volume of 0 at 1991-02-28. | 2022-04-25 10:14:04.229
ZN-202206-ECBOT [C] Daily #23 | File ZN-199106-ECBOT.dly has a volume of 0 at 1991-05-30. | 2022-04-25 10:14:04.229
ZN-202206-ECBOT [C] Daily #23 | File ZN-199103-ECBOT.dly has a volume of 0 at 1990-11-30. | 2022-04-25 10:14:04.242
ZN-202206-ECBOT [C] Daily #23 | File ZN-199103-ECBOT.dly has a volume of 0 at 1991-02-27. | 2022-04-25 10:14:04.242
ZN-202206-ECBOT [C] Daily #23 | File ZN-199012-ECBOT.dly has a volume of 0 at 1990-08-31. | 2022-04-25 10:14:04.256
ZN-202206-ECBOT [C] Daily #23 | File ZN-199012-ECBOT.dly has a volume of 0 at 1990-11-29. | 2022-04-25 10:14:04.256
ZN-202206-ECBOT [C] Daily #23 | File ZN-199009-ECBOT.dly has a volume of 0 at 1990-05-31. | 2022-04-25 10:14:04.268
ZN-202206-ECBOT [C] Daily #23 | File ZN-199009-ECBOT.dly has a volume of 0 at 1990-08-30. | 2022-04-25 10:14:04.268
ZN-202206-ECBOT [C] Daily #23 | File ZN-199006-ECBOT.dly has a volume of 0 at 1990-02-28. | 2022-04-25 10:14:04.282
ZN-202206-ECBOT [C] Daily #23 | File ZN-199006-ECBOT.dly has a volume of 0 at 1990-05-30. | 2022-04-25 10:14:04.282
ZN-202206-ECBOT [C] Daily #23 | File ZN-199003-ECBOT.dly has a volume of 0 at 1989-11-30. | 2022-04-25 10:14:04.294
ZN-202206-ECBOT [C] Daily #23 | File ZN-199003-ECBOT.dly has a volume of 0 at 1990-02-27. | 2022-04-25 10:14:04.294
ZN-202206-ECBOT [C] Daily #23 | File ZN-198912-ECBOT.dly has a volume of 0 at 1989-08-31. | 2022-04-25 10:14:04.307
ZN-202206-ECBOT [C] Daily #23 | File ZN-198912-ECBOT.dly has a volume of 0 at 1989-11-29. | 2022-04-25 10:14:04.307
ZN-202206-ECBOT [C] Daily #23 | File ZN-198909-ECBOT.dly has a volume of 0 at 1989-05-31. | 2022-04-25 10:14:04.320
ZN-202206-ECBOT [C] Daily #23 | File ZN-198909-ECBOT.dly has a volume of 0 at 1989-08-30. | 2022-04-25 10:14:04.320
ZN-202206-ECBOT [C] Daily #23 | File ZN-198906-ECBOT.dly has a volume of 0 at 1989-02-28. | 2022-04-25 10:14:04.333
ZN-202206-ECBOT [C] Daily #23 | File ZN-198906-ECBOT.dly has a volume of 0 at 1989-05-30. | 2022-04-25 10:14:04.333
ZN-202206-ECBOT [C] Daily #23 | File ZN-198903-ECBOT.dly has a volume of 0 at 1988-11-30. | 2022-04-25 10:14:04.346
ZN-202206-ECBOT [C] Daily #23 | File ZN-198903-ECBOT.dly has a volume of 0 at 1989-02-27. | 2022-04-25 10:14:04.346
ZN-202206-ECBOT [C] Daily #23 | File ZN-198812-ECBOT.dly has a volume of 0 at 1988-08-31. | 2022-04-25 10:14:04.359
ZN-202206-ECBOT [C] Daily #23 | File ZN-198812-ECBOT.dly has a volume of 0 at 1988-11-29. | 2022-04-25 10:14:04.359
ZN-202206-ECBOT [C] Daily #23 | File ZN-198809-ECBOT.dly has a volume of 0 at 1988-05-31. | 2022-04-25 10:14:04.372
ZN-202206-ECBOT [C] Daily #23 | File ZN-198809-ECBOT.dly has a volume of 0 at 1988-08-30. | 2022-04-25 10:14:04.372
ZN-202206-ECBOT [C] Daily #23 | File ZN-198806-ECBOT.dly has a volume of 0 at 1988-02-29. | 2022-04-25 10:14:04.385
ZN-202206-ECBOT [C] Daily #23 | File ZN-198806-ECBOT.dly has a volume of 0 at 1988-05-30. | 2022-04-25 10:14:04.385
ZN-202206-ECBOT [C] Daily #23 | File ZN-198803-ECBOT.dly has a volume of 0 at 1987-11-30. | 2022-04-25 10:14:04.399
ZN-202206-ECBOT [C] Daily #23 | File ZN-198803-ECBOT.dly has a volume of 0 at 1988-02-26. | 2022-04-25 10:14:04.399
ZN-202206-ECBOT [C] Daily #23 | File ZN-198712-ECBOT.dly has a volume of 0 at 1987-08-31. | 2022-04-25 10:14:04.413
ZN-202206-ECBOT [C] Daily #23 | File ZN-198712-ECBOT.dly has a volume of 0 at 1987-11-27. | 2022-04-25 10:14:04.413
ZN-202206-ECBOT [C] Daily #23 | File ZN-198709-ECBOT.dly has a volume of 0 at 1987-05-29. | 2022-04-25 10:14:04.427
ZN-202206-ECBOT [C] Daily #23 | File ZN-198709-ECBOT.dly has a volume of 0 at 1987-08-28. | 2022-04-25 10:14:04.427
ZN-202206-ECBOT [C] Daily #23 | File ZN-198706-ECBOT.dly has a volume of 0 at 1987-02-27. | 2022-04-25 10:14:04.442
ZN-202206-ECBOT [C] Daily #23 | File ZN-198706-ECBOT.dly has a volume of 0 at 1987-05-28. | 2022-04-25 10:14:04.442
ZN-202206-ECBOT [C] Daily #23 | File ZN-198703-ECBOT.dly has a volume of 0 at 1986-11-28. | 2022-04-25 10:14:04.456
ZN-202206-ECBOT [C] Daily #23 | File ZN-198703-ECBOT.dly has a volume of 0 at 1987-02-26. | 2022-04-25 10:14:04.456
ZN-202206-ECBOT [C] Daily #23 | File ZN-198612-ECBOT.dly has a volume of 0 at 1986-08-29. | 2022-04-25 10:14:04.470
ZN-202206-ECBOT [C] Daily #23 | File ZN-198612-ECBOT.dly has a volume of 0 at 1986-11-27. | 2022-04-25 10:14:04.470
ZN-202206-ECBOT [C] Daily #23 | File ZN-198609-ECBOT.dly has a volume of 0 at 1986-05-30. | 2022-04-25 10:14:04.484
ZN-202206-ECBOT [C] Daily #23 | File ZN-198609-ECBOT.dly has a volume of 0 at 1986-08-28. | 2022-04-25 10:14:04.484
ZN-202206-ECBOT [C] Daily #23 | File ZN-198606-ECBOT.dly has a volume of 0 at 1986-02-28. | 2022-04-25 10:14:04.497
ZN-202206-ECBOT [C] Daily #23 | File ZN-198606-ECBOT.dly has a volume of 0 at 1986-05-29. | 2022-04-25 10:14:04.497
ZN-202206-ECBOT [C] Daily #23 | File ZN-198603-ECBOT.dly has a volume of 0 at 1985-11-29. | 2022-04-25 10:14:04.510
ZN-202206-ECBOT [C] Daily #23 | File ZN-198603-ECBOT.dly has a volume of 0 at 1986-02-27. | 2022-04-25 10:14:04.510
ZN-202206-ECBOT [C] Daily #23 | File ZN-198512-ECBOT.dly has a volume of 0 at 1985-08-30. | 2022-04-25 10:14:04.523
ZN-202206-ECBOT [C] Daily #23 | File ZN-198512-ECBOT.dly has a volume of 0 at 1985-11-28. | 2022-04-25 10:14:04.523
ZN-202206-ECBOT [C] Daily #23 | File ZN-198509-ECBOT.dly has a volume of 0 at 1985-05-31. | 2022-04-25 10:14:04.536
ZN-202206-ECBOT [C] Daily #23 | File ZN-198509-ECBOT.dly has a volume of 0 at 1985-08-29. | 2022-04-25 10:14:04.536
ZN-202206-ECBOT [C] Daily #23 | File ZN-198506-ECBOT.dly has a volume of 0 at 1985-02-28. | 2022-04-25 10:14:04.549
ZN-202206-ECBOT [C] Daily #23 | File ZN-198506-ECBOT.dly has a volume of 0 at 1985-05-30. | 2022-04-25 10:14:04.549
ZN-202206-ECBOT [C] Daily #23 | File ZN-198503-ECBOT.dly has a volume of 0 at 1984-11-30. | 2022-04-25 10:14:04.562
ZN-202206-ECBOT [C] Daily #23 | File ZN-198503-ECBOT.dly has a volume of 0 at 1985-02-27. | 2022-04-25 10:14:04.562
ZN-202206-ECBOT [C] Daily #23 | File ZN-198412-ECBOT.dly has a volume of 0 at 1984-08-31. | 2022-04-25 10:14:04.575
ZN-202206-ECBOT [C] Daily #23 | File ZN-198412-ECBOT.dly has a volume of 0 at 1984-11-29. | 2022-04-25 10:14:04.575
ZN-202206-ECBOT [C] Daily #23 | File ZN-198409-ECBOT.dly has a volume of 0 at 1984-05-31. | 2022-04-25 10:14:04.588
ZN-202206-ECBOT [C] Daily #23 | File ZN-198409-ECBOT.dly has a volume of 0 at 1984-08-30. | 2022-04-25 10:14:04.588
ZN-202206-ECBOT [C] Daily #23 | File ZN-198406-ECBOT.dly has a volume of 0 at 1984-02-29. | 2022-04-25 10:14:04.601
ZN-202206-ECBOT [C] Daily #23 | File ZN-198406-ECBOT.dly has a volume of 0 at 1984-05-30. | 2022-04-25 10:14:04.601
ZN-202206-ECBOT [C] Daily #23 | File ZN-198403-ECBOT.dly has a volume of 0 at 1983-11-30. | 2022-04-25 10:14:04.614
ZN-202206-ECBOT [C] Daily #23 | File ZN-198403-ECBOT.dly has a volume of 0 at 1984-02-28. | 2022-04-25 10:14:04.614
ZN-202206-ECBOT [C] Daily #23 | File ZN-198312-ECBOT.dly has a volume of 0 at 1983-08-31. | 2022-04-25 10:14:04.627
ZN-202206-ECBOT [C] Daily #23 | File ZN-198312-ECBOT.dly has a volume of 0 at 1983-11-29. | 2022-04-25 10:14:04.627
ZN-202206-ECBOT [C] Daily #23 | File ZN-198309-ECBOT.dly has a volume of 0 at 1983-05-31. | 2022-04-25 10:14:04.640
ZN-202206-ECBOT [C] Daily #23 | File ZN-198309-ECBOT.dly has a volume of 0 at 1983-08-30. | 2022-04-25 10:14:04.640
ZN-202206-ECBOT [C] Daily #23 | File ZN-198306-ECBOT.dly has a volume of 0 at 1983-02-28. | 2022-04-25 10:14:04.654
ZN-202206-ECBOT [C] Daily #23 | File ZN-198306-ECBOT.dly has a volume of 0 at 1983-05-30. | 2022-04-25 10:14:04.654
ZN-202206-ECBOT [C] Daily #23 | File ZN-198303-ECBOT.dly has a volume of 0 at 1982-11-30. | 2022-04-25 10:14:04.668
ZN-202206-ECBOT [C] Daily #23 | File ZN-198303-ECBOT.dly has a volume of 0 at 1983-02-25. | 2022-04-25 10:14:04.668
ZN-202206-ECBOT [C] Daily #23 | File ZN-198212-ECBOT.dly has a volume of 0 at 1982-08-31. | 2022-04-25 10:14:04.682
ZN-202206-ECBOT [C] Daily #23 | File ZN-198212-ECBOT.dly has a volume of 0 at 1982-11-29. | 2022-04-25 10:14:04.682
ZN-202206-ECBOT [C] Daily #23 | File ZN-198209-ECBOT.dly has a volume of 0 at 1982-05-31. | 2022-04-25 10:14:04.696
ZN-202206-ECBOT [C] Daily #23 | File ZN-198209-ECBOT.dly has a volume of 0 at 1982-08-30. | 2022-04-25 10:14:04.696
ZN-202206-ECBOT [C] Daily #23 | Dates not found while checking for invalid data in continuous contract data files. ZN-198206-ECBOT | 2022-04-25 10:14:04.703 *
ZN-202206-ECBOT [C] Daily #23 | Waiting for historical downloads to complete with the IDs: 18, 19, | 2022-04-25 10:14:04.703
ZN-202206-ECBOT [C] 4 Day #19 | Reloading chart. | 2022-04-25 10:14:04.715
ZN-202206-ECBOT [C] 4 Day #19 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:04.715
ZN-202206-ECBOT [C] 4 Day #19 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:04.715
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-200103-ECBOT.dly has a volume of 0 at 2000-11-30. | 2022-04-25 10:14:06.197
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-200012-ECBOT.dly has a volume of 0 at 2000-08-31. | 2022-04-25 10:14:06.210
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-200012-ECBOT.dly has a volume of 0 at 2000-11-29. | 2022-04-25 10:14:06.210
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-200009-ECBOT.dly has a volume of 0 at 2000-05-31. | 2022-04-25 10:14:06.223
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-200009-ECBOT.dly has a volume of 0 at 2000-08-30. | 2022-04-25 10:14:06.223
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-200006-ECBOT.dly has a volume of 0 at 2000-02-29. | 2022-04-25 10:14:06.236
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-200006-ECBOT.dly has a volume of 0 at 2000-05-30. | 2022-04-25 10:14:06.236
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-200003-ECBOT.dly has a volume of 0 at 1999-11-30. | 2022-04-25 10:14:06.250
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-200003-ECBOT.dly has a volume of 0 at 2000-02-28. | 2022-04-25 10:14:06.250
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199912-ECBOT.dly has a volume of 0 at 1999-08-31. | 2022-04-25 10:14:06.263
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199912-ECBOT.dly has a volume of 0 at 1999-11-29. | 2022-04-25 10:14:06.263
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199909-ECBOT.dly has a volume of 0 at 1999-05-31. | 2022-04-25 10:14:06.276
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199909-ECBOT.dly has a volume of 0 at 1999-08-30. | 2022-04-25 10:14:06.276
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199906-ECBOT.dly has a volume of 0 at 1999-02-26. | 2022-04-25 10:14:06.290
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199906-ECBOT.dly has a volume of 0 at 1999-05-28. | 2022-04-25 10:14:06.290
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199903-ECBOT.dly has a volume of 0 at 1998-11-30. | 2022-04-25 10:14:06.303
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199903-ECBOT.dly has a volume of 0 at 1999-02-25. | 2022-04-25 10:14:06.303
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199812-ECBOT.dly has a volume of 0 at 1998-08-31. | 2022-04-25 10:14:06.316
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199812-ECBOT.dly has a volume of 0 at 1998-11-27. | 2022-04-25 10:14:06.316
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199809-ECBOT.dly has a volume of 0 at 1998-05-29. | 2022-04-25 10:14:06.330
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199809-ECBOT.dly has a volume of 0 at 1998-08-28. | 2022-04-25 10:14:06.330
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199806-ECBOT.dly has a volume of 0 at 1998-02-27. | 2022-04-25 10:14:06.344
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199806-ECBOT.dly has a volume of 0 at 1998-05-28. | 2022-04-25 10:14:06.344
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199803-ECBOT.dly has a volume of 0 at 1997-11-28. | 2022-04-25 10:14:06.358
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199803-ECBOT.dly has a volume of 0 at 1998-02-26. | 2022-04-25 10:14:06.358
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199712-ECBOT.dly has a volume of 0 at 1997-08-29. | 2022-04-25 10:14:06.372
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199712-ECBOT.dly has a volume of 0 at 1997-11-27. | 2022-04-25 10:14:06.372
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199709-ECBOT.dly has a volume of 0 at 1997-05-30. | 2022-04-25 10:14:06.385
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199709-ECBOT.dly has a volume of 0 at 1997-08-28. | 2022-04-25 10:14:06.385
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199706-ECBOT.dly has a volume of 0 at 1997-02-28. | 2022-04-25 10:14:06.398
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199706-ECBOT.dly has a volume of 0 at 1997-05-29. | 2022-04-25 10:14:06.398
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199703-ECBOT.dly has a volume of 0 at 1996-11-29. | 2022-04-25 10:14:06.411
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199703-ECBOT.dly has a volume of 0 at 1997-02-27. | 2022-04-25 10:14:06.411
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199612-ECBOT.dly has a volume of 0 at 1996-08-30. | 2022-04-25 10:14:06.425
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199612-ECBOT.dly has a volume of 0 at 1996-11-28. | 2022-04-25 10:14:06.425
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199609-ECBOT.dly has a volume of 0 at 1996-05-31. | 2022-04-25 10:14:06.438
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199609-ECBOT.dly has a volume of 0 at 1996-08-29. | 2022-04-25 10:14:06.438
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199606-ECBOT.dly has a volume of 0 at 1996-02-29. | 2022-04-25 10:14:06.451
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199606-ECBOT.dly has a volume of 0 at 1996-05-30. | 2022-04-25 10:14:06.451
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199603-ECBOT.dly has a volume of 0 at 1995-11-30. | 2022-04-25 10:14:06.466
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199603-ECBOT.dly has a volume of 0 at 1996-02-28. | 2022-04-25 10:14:06.466
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199512-ECBOT.dly has a volume of 0 at 1995-08-31. | 2022-04-25 10:14:06.479
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199512-ECBOT.dly has a volume of 0 at 1995-11-29. | 2022-04-25 10:14:06.479
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199509-ECBOT.dly has a volume of 0 at 1995-05-31. | 2022-04-25 10:14:06.493
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199509-ECBOT.dly has a volume of 0 at 1995-08-30. | 2022-04-25 10:14:06.493
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199506-ECBOT.dly has a volume of 0 at 1995-02-28. | 2022-04-25 10:14:06.506
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199506-ECBOT.dly has a volume of 0 at 1995-05-30. | 2022-04-25 10:14:06.506
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199503-ECBOT.dly has a volume of 0 at 1994-11-30. | 2022-04-25 10:14:06.519
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199503-ECBOT.dly has a volume of 0 at 1995-02-27. | 2022-04-25 10:14:06.519
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199412-ECBOT.dly has a volume of 0 at 1994-08-31. | 2022-04-25 10:14:06.532
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199412-ECBOT.dly has a volume of 0 at 1994-11-29. | 2022-04-25 10:14:06.532
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199409-ECBOT.dly has a volume of 0 at 1994-05-31. | 2022-04-25 10:14:06.546
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199409-ECBOT.dly has a volume of 0 at 1994-08-30. | 2022-04-25 10:14:06.546
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199406-ECBOT.dly has a volume of 0 at 1994-02-28. | 2022-04-25 10:14:06.559
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199406-ECBOT.dly has a volume of 0 at 1994-05-30. | 2022-04-25 10:14:06.559
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199403-ECBOT.dly has a volume of 0 at 1993-11-30. | 2022-04-25 10:14:06.573
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199403-ECBOT.dly has a volume of 0 at 1994-02-25. | 2022-04-25 10:14:06.573
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199312-ECBOT.dly has a volume of 0 at 1993-08-31. | 2022-04-25 10:14:06.586
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199312-ECBOT.dly has a volume of 0 at 1993-11-29. | 2022-04-25 10:14:06.586
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199309-ECBOT.dly has a volume of 0 at 1993-05-31. | 2022-04-25 10:14:06.599
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199309-ECBOT.dly has a volume of 0 at 1993-08-30. | 2022-04-25 10:14:06.599
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199306-ECBOT.dly has a volume of 0 at 1993-02-26. | 2022-04-25 10:14:06.613
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199306-ECBOT.dly has a volume of 0 at 1993-05-28. | 2022-04-25 10:14:06.613
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199303-ECBOT.dly has a volume of 0 at 1992-11-30. | 2022-04-25 10:14:06.626
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199303-ECBOT.dly has a volume of 0 at 1993-02-25. | 2022-04-25 10:14:06.626
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199212-ECBOT.dly has a volume of 0 at 1992-08-31. | 2022-04-25 10:14:06.639
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199212-ECBOT.dly has a volume of 0 at 1992-11-27. | 2022-04-25 10:14:06.639
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199209-ECBOT.dly has a volume of 0 at 1992-05-29. | 2022-04-25 10:14:06.652
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199209-ECBOT.dly has a volume of 0 at 1992-08-28. | 2022-04-25 10:14:06.652
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199206-ECBOT.dly has a volume of 0 at 1992-02-28. | 2022-04-25 10:14:06.665
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199206-ECBOT.dly has a volume of 0 at 1992-05-28. | 2022-04-25 10:14:06.665
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199203-ECBOT.dly has a volume of 0 at 1991-11-29. | 2022-04-25 10:14:06.678
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199203-ECBOT.dly has a volume of 0 at 1992-02-27. | 2022-04-25 10:14:06.678
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199112-ECBOT.dly has a volume of 0 at 1991-08-30. | 2022-04-25 10:14:06.691
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199112-ECBOT.dly has a volume of 0 at 1991-11-28. | 2022-04-25 10:14:06.691
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199109-ECBOT.dly has a volume of 0 at 1991-05-31. | 2022-04-25 10:14:06.704
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199109-ECBOT.dly has a volume of 0 at 1991-08-29. | 2022-04-25 10:14:06.704
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199106-ECBOT.dly has a volume of 0 at 1991-02-28. | 2022-04-25 10:14:06.717
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199106-ECBOT.dly has a volume of 0 at 1991-05-30. | 2022-04-25 10:14:06.717
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199103-ECBOT.dly has a volume of 0 at 1990-11-30. | 2022-04-25 10:14:06.729
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199103-ECBOT.dly has a volume of 0 at 1991-02-27. | 2022-04-25 10:14:06.729
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199012-ECBOT.dly has a volume of 0 at 1990-08-31. | 2022-04-25 10:14:06.741
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199012-ECBOT.dly has a volume of 0 at 1990-11-29. | 2022-04-25 10:14:06.741
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199009-ECBOT.dly has a volume of 0 at 1990-05-31. | 2022-04-25 10:14:06.754
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199009-ECBOT.dly has a volume of 0 at 1990-08-30. | 2022-04-25 10:14:06.754
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199006-ECBOT.dly has a volume of 0 at 1990-02-28. | 2022-04-25 10:14:06.767
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199006-ECBOT.dly has a volume of 0 at 1990-05-30. | 2022-04-25 10:14:06.767
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199003-ECBOT.dly has a volume of 0 at 1989-11-30. | 2022-04-25 10:14:06.779
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199003-ECBOT.dly has a volume of 0 at 1990-02-27. | 2022-04-25 10:14:06.779
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198912-ECBOT.dly has a volume of 0 at 1989-08-31. | 2022-04-25 10:14:06.792
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198912-ECBOT.dly has a volume of 0 at 1989-11-29. | 2022-04-25 10:14:06.792
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198909-ECBOT.dly has a volume of 0 at 1989-05-31. | 2022-04-25 10:14:06.805
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198909-ECBOT.dly has a volume of 0 at 1989-08-30. | 2022-04-25 10:14:06.805
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198906-ECBOT.dly has a volume of 0 at 1989-02-28. | 2022-04-25 10:14:06.817
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198906-ECBOT.dly has a volume of 0 at 1989-05-30. | 2022-04-25 10:14:06.817
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198903-ECBOT.dly has a volume of 0 at 1988-11-30. | 2022-04-25 10:14:06.830
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198903-ECBOT.dly has a volume of 0 at 1989-02-27. | 2022-04-25 10:14:06.830
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198812-ECBOT.dly has a volume of 0 at 1988-08-31. | 2022-04-25 10:14:06.843
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198812-ECBOT.dly has a volume of 0 at 1988-11-29. | 2022-04-25 10:14:06.843
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198809-ECBOT.dly has a volume of 0 at 1988-05-31. | 2022-04-25 10:14:06.855
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198809-ECBOT.dly has a volume of 0 at 1988-08-30. | 2022-04-25 10:14:06.855
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198806-ECBOT.dly has a volume of 0 at 1988-02-29. | 2022-04-25 10:14:06.868
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198806-ECBOT.dly has a volume of 0 at 1988-05-30. | 2022-04-25 10:14:06.868
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198803-ECBOT.dly has a volume of 0 at 1987-11-30. | 2022-04-25 10:14:06.881
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198803-ECBOT.dly has a volume of 0 at 1988-02-26. | 2022-04-25 10:14:06.881
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198712-ECBOT.dly has a volume of 0 at 1987-08-31. | 2022-04-25 10:14:06.894
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198712-ECBOT.dly has a volume of 0 at 1987-11-27. | 2022-04-25 10:14:06.894
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198709-ECBOT.dly has a volume of 0 at 1987-05-29. | 2022-04-25 10:14:06.907
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198709-ECBOT.dly has a volume of 0 at 1987-08-28. | 2022-04-25 10:14:06.907
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198706-ECBOT.dly has a volume of 0 at 1987-02-27. | 2022-04-25 10:14:06.919
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198706-ECBOT.dly has a volume of 0 at 1987-05-28. | 2022-04-25 10:14:06.919
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198703-ECBOT.dly has a volume of 0 at 1986-11-28. | 2022-04-25 10:14:06.932
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198703-ECBOT.dly has a volume of 0 at 1987-02-26. | 2022-04-25 10:14:06.932
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198612-ECBOT.dly has a volume of 0 at 1986-08-29. | 2022-04-25 10:14:06.945
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198612-ECBOT.dly has a volume of 0 at 1986-11-27. | 2022-04-25 10:14:06.945
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198609-ECBOT.dly has a volume of 0 at 1986-05-30. | 2022-04-25 10:14:06.959
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198609-ECBOT.dly has a volume of 0 at 1986-08-28. | 2022-04-25 10:14:06.959
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198606-ECBOT.dly has a volume of 0 at 1986-02-28. | 2022-04-25 10:14:06.971
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198606-ECBOT.dly has a volume of 0 at 1986-05-29. | 2022-04-25 10:14:06.971
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198603-ECBOT.dly has a volume of 0 at 1985-11-29. | 2022-04-25 10:14:06.984
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198603-ECBOT.dly has a volume of 0 at 1986-02-27. | 2022-04-25 10:14:06.984
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198512-ECBOT.dly has a volume of 0 at 1985-08-30. | 2022-04-25 10:14:06.996
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198512-ECBOT.dly has a volume of 0 at 1985-11-28. | 2022-04-25 10:14:06.996
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198509-ECBOT.dly has a volume of 0 at 1985-05-31. | 2022-04-25 10:14:07.009
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198509-ECBOT.dly has a volume of 0 at 1985-08-29. | 2022-04-25 10:14:07.009
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198506-ECBOT.dly has a volume of 0 at 1985-02-28. | 2022-04-25 10:14:07.022
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198506-ECBOT.dly has a volume of 0 at 1985-05-30. | 2022-04-25 10:14:07.022
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198503-ECBOT.dly has a volume of 0 at 1984-11-30. | 2022-04-25 10:14:07.034
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198503-ECBOT.dly has a volume of 0 at 1985-02-27. | 2022-04-25 10:14:07.034
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198412-ECBOT.dly has a volume of 0 at 1984-08-31. | 2022-04-25 10:14:07.047
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198412-ECBOT.dly has a volume of 0 at 1984-11-29. | 2022-04-25 10:14:07.047
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198409-ECBOT.dly has a volume of 0 at 1984-05-31. | 2022-04-25 10:14:07.059
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198409-ECBOT.dly has a volume of 0 at 1984-08-30. | 2022-04-25 10:14:07.059
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198406-ECBOT.dly has a volume of 0 at 1984-02-29. | 2022-04-25 10:14:07.072
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198406-ECBOT.dly has a volume of 0 at 1984-05-30. | 2022-04-25 10:14:07.072
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198403-ECBOT.dly has a volume of 0 at 1983-11-30. | 2022-04-25 10:14:07.084
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198403-ECBOT.dly has a volume of 0 at 1984-02-28. | 2022-04-25 10:14:07.084
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198312-ECBOT.dly has a volume of 0 at 1983-08-31. | 2022-04-25 10:14:07.097
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198312-ECBOT.dly has a volume of 0 at 1983-11-29. | 2022-04-25 10:14:07.097
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198309-ECBOT.dly has a volume of 0 at 1983-05-31. | 2022-04-25 10:14:07.110
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198309-ECBOT.dly has a volume of 0 at 1983-08-30. | 2022-04-25 10:14:07.110
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198306-ECBOT.dly has a volume of 0 at 1983-02-28. | 2022-04-25 10:14:07.122
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198306-ECBOT.dly has a volume of 0 at 1983-05-30. | 2022-04-25 10:14:07.122
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198303-ECBOT.dly has a volume of 0 at 1982-11-30. | 2022-04-25 10:14:07.135
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198303-ECBOT.dly has a volume of 0 at 1983-02-25. | 2022-04-25 10:14:07.135
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198212-ECBOT.dly has a volume of 0 at 1982-08-31. | 2022-04-25 10:14:07.148
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198212-ECBOT.dly has a volume of 0 at 1982-11-29. | 2022-04-25 10:14:07.148
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198209-ECBOT.dly has a volume of 0 at 1982-05-31. | 2022-04-25 10:14:07.161
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198209-ECBOT.dly has a volume of 0 at 1982-08-30. | 2022-04-25 10:14:07.161
ZN-202206-ECBOT [C] 4 Day #19 | Dates not found while checking for invalid data in continuous contract data files. ZN-198206-ECBOT | 2022-04-25 10:14:07.167 *
ZN-202206-ECBOT [C] 4 Day #19 | Waiting for historical downloads to complete with the IDs: 18, 19, | 2022-04-25 10:14:07.167
ZN-202206-ECBOT 1 Day #21 | Reloading chart. | 2022-04-25 10:14:07.178
ZN-202112-ECBOT 384 Min #22 | Reloading chart. | 2022-04-25 10:14:07.190
Files to Open on Startup | Opening file: METALS.Cht | 2022-04-25 10:14:07.198
XAUUSD 2 Day #11 | Reloading chart. | 2022-04-25 10:14:07.284
GC-202206-NYMEX [C] 4 Day #5 | Reloading chart. | 2022-04-25 10:14:07.298
GC-202206-NYMEX [C] 4 Day #5 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:07.298
GC-202206-NYMEX [C] 4 Day #5 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:07.298
GC-202206-NYMEX [C] 4 Day #5 | Performing continuous chart historical Daily data download for symbol GC-197502-NYMEX starting at 1974-11-27. | 2022-04-25 10:14:07.329
Added historical Daily data request for GC-197502-NYMEX to the queue. | 2022-04-25 10:14:07.329
GC-202206-NYMEX [C] 4 Day #5 | Performing continuous chart historical Daily data download for symbol GC-202206-NYMEX starting at last date in file. | 2022-04-25 10:14:07.582
Added historical Daily data request for GC-202206-NYMEX to the queue. | 2022-04-25 10:14:07.582
GC-202206-NYMEX [C] 4 Day #5 | File GC-200102-NYMEX.dly has a volume of 0 at 2000-11-29. | 2022-04-25 10:14:09.040
GC-202206-NYMEX [C] 4 Day #5 | File GC-200012-NYMEX.dly has a volume of 0 at 2000-07-28. | 2022-04-25 10:14:09.057
GC-202206-NYMEX [C] 4 Day #5 | File GC-200012-NYMEX.dly has a volume of 0 at 2000-11-28. | 2022-04-25 10:14:09.057
GC-202206-NYMEX [C] 4 Day #5 | File GC-200008-NYMEX.dly has a volume of 0 at 2000-05-30. | 2022-04-25 10:14:09.068
GC-202206-NYMEX [C] 4 Day #5 | File GC-200008-NYMEX.dly has a volume of 0 at 2000-07-27. | 2022-04-25 10:14:09.068
GC-202206-NYMEX [C] 4 Day #5 | File GC-200006-NYMEX.dly has a volume of 0 at 2000-03-30. | 2022-04-25 10:14:09.079
GC-202206-NYMEX [C] 4 Day #5 | File GC-200006-NYMEX.dly has a volume of 0 at 2000-05-29. | 2022-04-25 10:14:09.079
GC-202206-NYMEX [C] 4 Day #5 | File GC-200004-NYMEX.dly has a volume of 0 at 2000-01-28. | 2022-04-25 10:14:09.090
GC-202206-NYMEX [C] 4 Day #5 | File GC-200004-NYMEX.dly has a volume of 0 at 2000-03-29. | 2022-04-25 10:14:09.090
GC-202206-NYMEX [C] 4 Day #5 | File GC-200002-NYMEX.dly has a volume of 0 at 1999-11-29. | 2022-04-25 10:14:09.101
GC-202206-NYMEX [C] 4 Day #5 | File GC-200002-NYMEX.dly has a volume of 0 at 2000-01-27. | 2022-04-25 10:14:09.101
GC-202206-NYMEX [C] 4 Day #5 | File GC-199912-NYMEX.dly has a volume of 0 at 1999-07-29. | 2022-04-25 10:14:09.119
GC-202206-NYMEX [C] 4 Day #5 | File GC-199912-NYMEX.dly has a volume of 0 at 1999-11-26. | 2022-04-25 10:14:09.119
GC-202206-NYMEX [C] 4 Day #5 | File GC-199908-NYMEX.dly has a volume of 0 at 1999-05-28. | 2022-04-25 10:14:09.130
GC-202206-NYMEX [C] 4 Day #5 | File GC-199908-NYMEX.dly has a volume of 0 at 1999-07-28. | 2022-04-25 10:14:09.130
GC-202206-NYMEX [C] 4 Day #5 | File GC-199906-NYMEX.dly has a volume of 0 at 1999-03-30. | 2022-04-25 10:14:09.141
GC-202206-NYMEX [C] 4 Day #5 | File GC-199906-NYMEX.dly has a volume of 0 at 1999-05-27. | 2022-04-25 10:14:09.141
GC-202206-NYMEX [C] 4 Day #5 | File GC-199904-NYMEX.dly has a volume of 0 at 1999-01-28. | 2022-04-25 10:14:09.152
GC-202206-NYMEX [C] 4 Day #5 | File GC-199904-NYMEX.dly has a volume of 0 at 1999-03-29. | 2022-04-25 10:14:09.152
GC-202206-NYMEX [C] 4 Day #5 | File GC-199902-NYMEX.dly has a volume of 0 at 1998-11-27. | 2022-04-25 10:14:09.162
GC-202206-NYMEX [C] 4 Day #5 | File GC-199902-NYMEX.dly has a volume of 0 at 1999-01-27. | 2022-04-25 10:14:09.162
GC-202206-NYMEX [C] 4 Day #5 | File GC-199812-NYMEX.dly has a volume of 0 at 1998-07-30. | 2022-04-25 10:14:09.180
GC-202206-NYMEX [C] 4 Day #5 | File GC-199812-NYMEX.dly has a volume of 0 at 1998-11-26. | 2022-04-25 10:14:09.180
GC-202206-NYMEX [C] 4 Day #5 | File GC-199808-NYMEX.dly has a volume of 0 at 1998-05-28. | 2022-04-25 10:14:09.191
GC-202206-NYMEX [C] 4 Day #5 | File GC-199808-NYMEX.dly has a volume of 0 at 1998-07-29. | 2022-04-25 10:14:09.191
GC-202206-NYMEX [C] 4 Day #5 | File GC-199806-NYMEX.dly has a volume of 0 at 1998-03-30. | 2022-04-25 10:14:09.202
GC-202206-NYMEX [C] 4 Day #5 | File GC-199806-NYMEX.dly has a volume of 0 at 1998-05-27. | 2022-04-25 10:14:09.202
GC-202206-NYMEX [C] 4 Day #5 | File GC-199804-NYMEX.dly has a volume of 0 at 1998-01-29. | 2022-04-25 10:14:09.213
GC-202206-NYMEX [C] 4 Day #5 | File GC-199804-NYMEX.dly has a volume of 0 at 1998-03-27. | 2022-04-25 10:14:09.213
GC-202206-NYMEX [C] 4 Day #5 | File GC-199802-NYMEX.dly has a volume of 0 at 1997-11-27. | 2022-04-25 10:14:09.223
GC-202206-NYMEX [C] 4 Day #5 | File GC-199802-NYMEX.dly has a volume of 0 at 1998-01-28. | 2022-04-25 10:14:09.223
GC-202206-NYMEX [C] 4 Day #5 | File GC-199712-NYMEX.dly has a volume of 0 at 1997-07-30. | 2022-04-25 10:14:09.240
GC-202206-NYMEX [C] 4 Day #5 | File GC-199712-NYMEX.dly has a volume of 0 at 1997-11-26. | 2022-04-25 10:14:09.240
GC-202206-NYMEX [C] 4 Day #5 | File GC-199708-NYMEX.dly has a volume of 0 at 1997-05-29. | 2022-04-25 10:14:09.251
GC-202206-NYMEX [C] 4 Day #5 | File GC-199708-NYMEX.dly has a volume of 0 at 1997-07-29. | 2022-04-25 10:14:09.251
GC-202206-NYMEX [C] 4 Day #5 | File GC-199706-NYMEX.dly has a volume of 0 at 1997-03-28. | 2022-04-25 10:14:09.263
GC-202206-NYMEX [C] 4 Day #5 | File GC-199706-NYMEX.dly has a volume of 0 at 1997-05-28. | 2022-04-25 10:14:09.263
GC-202206-NYMEX [C] 4 Day #5 | File GC-199704-NYMEX.dly has a volume of 0 at 1997-01-30. | 2022-04-25 10:14:09.274
GC-202206-NYMEX [C] 4 Day #5 | File GC-199704-NYMEX.dly has a volume of 0 at 1997-03-27. | 2022-04-25 10:14:09.274
GC-202206-NYMEX [C] 4 Day #5 | File GC-199702-NYMEX.dly has a volume of 0 at 1996-11-28. | 2022-04-25 10:14:09.284
GC-202206-NYMEX [C] 4 Day #5 | File GC-199702-NYMEX.dly has a volume of 0 at 1997-01-29. | 2022-04-25 10:14:09.284
GC-202206-NYMEX [C] 4 Day #5 | File GC-199612-NYMEX.dly has a volume of 0 at 1996-07-30. | 2022-04-25 10:14:09.302
GC-202206-NYMEX [C] 4 Day #5 | File GC-199612-NYMEX.dly has a volume of 0 at 1996-11-27. | 2022-04-25 10:14:09.302
GC-202206-NYMEX [C] 4 Day #5 | File GC-199608-NYMEX.dly has a volume of 0 at 1996-05-30. | 2022-04-25 10:14:09.313
GC-202206-NYMEX [C] 4 Day #5 | File GC-199608-NYMEX.dly has a volume of 0 at 1996-07-29. | 2022-04-25 10:14:09.313
GC-202206-NYMEX [C] 4 Day #5 | File GC-199606-NYMEX.dly has a volume of 0 at 1996-03-28. | 2022-04-25 10:14:09.324
GC-202206-NYMEX [C] 4 Day #5 | File GC-199606-NYMEX.dly has a volume of 0 at 1996-05-29. | 2022-04-25 10:14:09.324
GC-202206-NYMEX [C] 4 Day #5 | File GC-199604-NYMEX.dly has a volume of 0 at 1996-01-30. | 2022-04-25 10:14:09.335
GC-202206-NYMEX [C] 4 Day #5 | File GC-199604-NYMEX.dly has a volume of 0 at 1996-03-27. | 2022-04-25 10:14:09.335
GC-202206-NYMEX [C] 4 Day #5 | File GC-199602-NYMEX.dly has a volume of 0 at 1995-11-29. | 2022-04-25 10:14:09.345
GC-202206-NYMEX [C] 4 Day #5 | File GC-199602-NYMEX.dly has a volume of 0 at 1996-01-29. | 2022-04-25 10:14:09.345
GC-202206-NYMEX [C] 4 Day #5 | File GC-199512-NYMEX.dly has a volume of 0 at 1995-07-28. | 2022-04-25 10:14:09.362
GC-202206-NYMEX [C] 4 Day #5 | File GC-199512-NYMEX.dly has a volume of 0 at 1995-11-28. | 2022-04-25 10:14:09.362
GC-202206-NYMEX [C] 4 Day #5 | File GC-199508-NYMEX.dly has a volume of 0 at 1995-05-30. | 2022-04-25 10:14:09.373
GC-202206-NYMEX [C] 4 Day #5 | File GC-199508-NYMEX.dly has a volume of 0 at 1995-07-27. | 2022-04-25 10:14:09.373
GC-202206-NYMEX [C] 4 Day #5 | File GC-199506-NYMEX.dly has a volume of 0 at 1995-03-30. | 2022-04-25 10:14:09.384
GC-202206-NYMEX [C] 4 Day #5 | File GC-199506-NYMEX.dly has a volume of 0 at 1995-05-29. | 2022-04-25 10:14:09.384
GC-202206-NYMEX [C] 4 Day #5 | File GC-199504-NYMEX.dly has a volume of 0 at 1995-01-30. | 2022-04-25 10:14:09.394
GC-202206-NYMEX [C] 4 Day #5 | File GC-199504-NYMEX.dly has a volume of 0 at 1995-03-29. | 2022-04-25 10:14:09.394
GC-202206-NYMEX [C] 4 Day #5 | File GC-199502-NYMEX.dly has a volume of 0 at 1994-11-29. | 2022-04-25 10:14:09.405
GC-202206-NYMEX [C] 4 Day #5 | File GC-199502-NYMEX.dly has a volume of 0 at 1995-01-27. | 2022-04-25 10:14:09.405
GC-202206-NYMEX [C] 4 Day #5 | File GC-199412-NYMEX.dly has a volume of 0 at 1994-07-28. | 2022-04-25 10:14:09.422
GC-202206-NYMEX [C] 4 Day #5 | File GC-199412-NYMEX.dly has a volume of 0 at 1994-11-28. | 2022-04-25 10:14:09.422
GC-202206-NYMEX [C] 4 Day #5 | File GC-199408-NYMEX.dly has a volume of 0 at 1994-05-30. | 2022-04-25 10:14:09.433
GC-202206-NYMEX [C] 4 Day #5 | File GC-199408-NYMEX.dly has a volume of 0 at 1994-07-27. | 2022-04-25 10:14:09.433
GC-202206-NYMEX [C] 4 Day #5 | File GC-199406-NYMEX.dly has a volume of 0 at 1994-03-30. | 2022-04-25 10:14:09.444
GC-202206-NYMEX [C] 4 Day #5 | File GC-199406-NYMEX.dly has a volume of 0 at 1994-05-27. | 2022-04-25 10:14:09.444
GC-202206-NYMEX [C] 4 Day #5 | File GC-199404-NYMEX.dly has a volume of 0 at 1994-01-28. | 2022-04-25 10:14:09.454
GC-202206-NYMEX [C] 4 Day #5 | File GC-199404-NYMEX.dly has a volume of 0 at 1994-03-29. | 2022-04-25 10:14:09.454
GC-202206-NYMEX [C] 4 Day #5 | File GC-199402-NYMEX.dly has a volume of 0 at 1993-11-29. | 2022-04-25 10:14:09.465
GC-202206-NYMEX [C] 4 Day #5 | File GC-199402-NYMEX.dly has a volume of 0 at 1994-01-27. | 2022-04-25 10:14:09.465
GC-202206-NYMEX [C] 4 Day #5 | File GC-199312-NYMEX.dly has a volume of 0 at 1993-07-29. | 2022-04-25 10:14:09.482
GC-202206-NYMEX [C] 4 Day #5 | File GC-199312-NYMEX.dly has a volume of 0 at 1993-11-26. | 2022-04-25 10:14:09.482
GC-202206-NYMEX [C] 4 Day #5 | File GC-199308-NYMEX.dly has a volume of 0 at 1993-05-28. | 2022-04-25 10:14:09.493
GC-202206-NYMEX [C] 4 Day #5 | File GC-199308-NYMEX.dly has a volume of 0 at 1993-07-28. | 2022-04-25 10:14:09.493
GC-202206-NYMEX [C] 4 Day #5 | File GC-199306-NYMEX.dly has a volume of 0 at 1993-03-30. | 2022-04-25 10:14:09.503
GC-202206-NYMEX [C] 4 Day #5 | File GC-199306-NYMEX.dly has a volume of 0 at 1993-05-27. | 2022-04-25 10:14:09.503
GC-202206-NYMEX [C] 4 Day #5 | File GC-199304-NYMEX.dly has a volume of 0 at 1993-01-28. | 2022-04-25 10:14:09.514
GC-202206-NYMEX [C] 4 Day #5 | File GC-199304-NYMEX.dly has a volume of 0 at 1993-03-29. | 2022-04-25 10:14:09.514
GC-202206-NYMEX [C] 4 Day #5 | File GC-199302-NYMEX.dly has a volume of 0 at 1992-11-27. | 2022-04-25 10:14:09.524
GC-202206-NYMEX [C] 4 Day #5 | File GC-199302-NYMEX.dly has a volume of 0 at 1993-01-27. | 2022-04-25 10:14:09.524
GC-202206-NYMEX [C] 4 Day #5 | File GC-199212-NYMEX.dly has a volume of 0 at 1992-07-30. | 2022-04-25 10:14:09.541
GC-202206-NYMEX [C] 4 Day #5 | File GC-199212-NYMEX.dly has a volume of 0 at 1992-11-26. | 2022-04-25 10:14:09.541
GC-202206-NYMEX [C] 4 Day #5 | File GC-199208-NYMEX.dly has a volume of 0 at 1992-05-28. | 2022-04-25 10:14:09.552
GC-202206-NYMEX [C] 4 Day #5 | File GC-199208-NYMEX.dly has a volume of 0 at 1992-07-29. | 2022-04-25 10:14:09.552
GC-202206-NYMEX [C] 4 Day #5 | File GC-199206-NYMEX.dly has a volume of 0 at 1992-03-30. | 2022-04-25 10:14:09.563
GC-202206-NYMEX [C] 4 Day #5 | File GC-199206-NYMEX.dly has a volume of 0 at 1992-05-27. | 2022-04-25 10:14:09.563
GC-202206-NYMEX [C] 4 Day #5 | File GC-199204-NYMEX.dly has a volume of 0 at 1992-01-30. | 2022-04-25 10:14:09.573
GC-202206-NYMEX [C] 4 Day #5 | File GC-199204-NYMEX.dly has a volume of 0 at 1992-03-27. | 2022-04-25 10:14:09.573
GC-202206-NYMEX [C] 4 Day #5 | File GC-199202-NYMEX.dly has a volume of 0 at 1991-11-28. | 2022-04-25 10:14:09.584
GC-202206-NYMEX [C] 4 Day #5 | File GC-199202-NYMEX.dly has a volume of 0 at 1992-01-29. | 2022-04-25 10:14:09.584
GC-202206-NYMEX [C] 4 Day #5 | File GC-199112-NYMEX.dly has a volume of 0 at 1991-07-30. | 2022-04-25 10:14:09.601
GC-202206-NYMEX [C] 4 Day #5 | File GC-199112-NYMEX.dly has a volume of 0 at 1991-11-27. | 2022-04-25 10:14:09.601
GC-202206-NYMEX [C] 4 Day #5 | File GC-199108-NYMEX.dly has a volume of 0 at 1991-05-30. | 2022-04-25 10:14:09.611
GC-202206-NYMEX [C] 4 Day #5 | File GC-199108-NYMEX.dly has a volume of 0 at 1991-07-29. | 2022-04-25 10:14:09.611
GC-202206-NYMEX [C] 4 Day #5 | File GC-199106-NYMEX.dly has a volume of 0 at 1991-03-28. | 2022-04-25 10:14:09.622
GC-202206-NYMEX [C] 4 Day #5 | File GC-199106-NYMEX.dly has a volume of 0 at 1991-05-29. | 2022-04-25 10:14:09.622
GC-202206-NYMEX [C] 4 Day #5 | File GC-199104-NYMEX.dly has a volume of 0 at 1991-01-30. | 2022-04-25 10:14:09.632
GC-202206-NYMEX [C] 4 Day #5 | File GC-199104-NYMEX.dly has a volume of 0 at 1991-03-27. | 2022-04-25 10:14:09.632
GC-202206-NYMEX [C] 4 Day #5 | File GC-199102-NYMEX.dly has a volume of 0 at 1990-11-29. | 2022-04-25 10:14:09.642
GC-202206-NYMEX [C] 4 Day #5 | File GC-199102-NYMEX.dly has a volume of 0 at 1991-01-29. | 2022-04-25 10:14:09.642
GC-202206-NYMEX [C] 4 Day #5 | File GC-199012-NYMEX.dly has a volume of 0 at 1990-07-30. | 2022-04-25 10:14:09.659
GC-202206-NYMEX [C] 4 Day #5 | File GC-199012-NYMEX.dly has a volume of 0 at 1990-11-28. | 2022-04-25 10:14:09.659
GC-202206-NYMEX [C] 4 Day #5 | File GC-199008-NYMEX.dly has a volume of 0 at 1990-05-30. | 2022-04-25 10:14:09.670
GC-202206-NYMEX [C] 4 Day #5 | File GC-199008-NYMEX.dly has a volume of 0 at 1990-07-27. | 2022-04-25 10:14:09.670
GC-202206-NYMEX [C] 4 Day #5 | File GC-199006-NYMEX.dly has a volume of 0 at 1990-03-29. | 2022-04-25 10:14:09.681
GC-202206-NYMEX [C] 4 Day #5 | File GC-199006-NYMEX.dly has a volume of 0 at 1990-05-29. | 2022-04-25 10:14:09.681
GC-202206-NYMEX [C] 4 Day #5 | File GC-199004-NYMEX.dly has a volume of 0 at 1990-01-30. | 2022-04-25 10:14:09.691
GC-202206-NYMEX [C] 4 Day #5 | File GC-199004-NYMEX.dly has a volume of 0 at 1990-03-28. | 2022-04-25 10:14:09.691
GC-202206-NYMEX [C] 4 Day #5 | File GC-199002-NYMEX.dly has a volume of 0 at 1989-11-29. | 2022-04-25 10:14:09.701
GC-202206-NYMEX [C] 4 Day #5 | File GC-199002-NYMEX.dly has a volume of 0 at 1990-01-29. | 2022-04-25 10:14:09.701
GC-202206-NYMEX [C] 4 Day #5 | File GC-198912-NYMEX.dly has a volume of 0 at 1989-07-28. | 2022-04-25 10:14:09.719
GC-202206-NYMEX [C] 4 Day #5 | File GC-198912-NYMEX.dly has a volume of 0 at 1989-11-28. | 2022-04-25 10:14:09.719
GC-202206-NYMEX [C] 4 Day #5 | File GC-198908-NYMEX.dly has a volume of 0 at 1989-05-30. | 2022-04-25 10:14:09.730
GC-202206-NYMEX [C] 4 Day #5 | File GC-198908-NYMEX.dly has a volume of 0 at 1989-07-27. | 2022-04-25 10:14:09.730
GC-202206-NYMEX [C] 4 Day #5 | File GC-198906-NYMEX.dly has a volume of 0 at 1989-03-30. | 2022-04-25 10:14:09.740
GC-202206-NYMEX [C] 4 Day #5 | File GC-198906-NYMEX.dly has a volume of 0 at 1989-05-29. | 2022-04-25 10:14:09.740
GC-202206-NYMEX [C] 4 Day #5 | File GC-198904-NYMEX.dly has a volume of 0 at 1989-01-30. | 2022-04-25 10:14:09.751
GC-202206-NYMEX [C] 4 Day #5 | File GC-198904-NYMEX.dly has a volume of 0 at 1989-03-29. | 2022-04-25 10:14:09.751
GC-202206-NYMEX [C] 4 Day #5 | File GC-198902-NYMEX.dly has a volume of 0 at 1988-11-29. | 2022-04-25 10:14:09.761
GC-202206-NYMEX [C] 4 Day #5 | File GC-198902-NYMEX.dly has a volume of 0 at 1989-01-27. | 2022-04-25 10:14:09.761
GC-202206-NYMEX [C] 4 Day #5 | File GC-198812-NYMEX.dly has a volume of 0 at 1988-07-28. | 2022-04-25 10:14:09.778
GC-202206-NYMEX [C] 4 Day #5 | File GC-198812-NYMEX.dly has a volume of 0 at 1988-11-28. | 2022-04-25 10:14:09.778
GC-202206-NYMEX [C] 4 Day #5 | File GC-198808-NYMEX.dly has a volume of 0 at 1988-05-30. | 2022-04-25 10:14:09.789
GC-202206-NYMEX [C] 4 Day #5 | File GC-198808-NYMEX.dly has a volume of 0 at 1988-07-27. | 2022-04-25 10:14:09.789
GC-202206-NYMEX [C] 4 Day #5 | File GC-198806-NYMEX.dly has a volume of 0 at 1988-03-30. | 2022-04-25 10:14:09.800
GC-202206-NYMEX [C] 4 Day #5 | File GC-198806-NYMEX.dly has a volume of 0 at 1988-05-27. | 2022-04-25 10:14:09.800
GC-202206-NYMEX [C] 4 Day #5 | File GC-198804-NYMEX.dly has a volume of 0 at 1988-01-28. | 2022-04-25 10:14:09.811
GC-202206-NYMEX [C] 4 Day #5 | File GC-198804-NYMEX.dly has a volume of 0 at 1988-03-29. | 2022-04-25 10:14:09.811
GC-202206-NYMEX [C] 4 Day #5 | File GC-198802-NYMEX.dly has a volume of 0 at 1987-11-27. | 2022-04-25 10:14:09.821
GC-202206-NYMEX [C] 4 Day #5 | File GC-198802-NYMEX.dly has a volume of 0 at 1988-01-27. | 2022-04-25 10:14:09.821
GC-202206-NYMEX [C] 4 Day #5 | File GC-198712-NYMEX.dly has a volume of 0 at 1987-07-30. | 2022-04-25 10:14:09.839
GC-202206-NYMEX [C] 4 Day #5 | File GC-198712-NYMEX.dly has a volume of 0 at 1987-11-26. | 2022-04-25 10:14:09.839
GC-202206-NYMEX [C] 4 Day #5 | File GC-198708-NYMEX.dly has a volume of 0 at 1987-05-28. | 2022-04-25 10:14:09.850
GC-202206-NYMEX [C] 4 Day #5 | File GC-198708-NYMEX.dly has a volume of 0 at 1987-07-29. | 2022-04-25 10:14:09.850
GC-202206-NYMEX [C] 4 Day #5 | File GC-198706-NYMEX.dly has a volume of 0 at 1987-03-30. | 2022-04-25 10:14:09.860
GC-202206-NYMEX [C] 4 Day #5 | File GC-198706-NYMEX.dly has a volume of 0 at 1987-05-27. | 2022-04-25 10:14:09.860
GC-202206-NYMEX [C] 4 Day #5 | File GC-198704-NYMEX.dly has a volume of 0 at 1987-01-29. | 2022-04-25 10:14:09.871
GC-202206-NYMEX [C] 4 Day #5 | File GC-198704-NYMEX.dly has a volume of 0 at 1987-03-27. | 2022-04-25 10:14:09.871
GC-202206-NYMEX [C] 4 Day #5 | File GC-198702-NYMEX.dly has a volume of 0 at 1986-11-27. | 2022-04-25 10:14:09.881
GC-202206-NYMEX [C] 4 Day #5 | File GC-198702-NYMEX.dly has a volume of 0 at 1987-01-28. | 2022-04-25 10:14:09.881
GC-202206-NYMEX [C] 4 Day #5 | File GC-198612-NYMEX.dly has a volume of 0 at 1986-07-30. | 2022-04-25 10:14:09.898
GC-202206-NYMEX [C] 4 Day #5 | File GC-198612-NYMEX.dly has a volume of 0 at 1986-11-26. | 2022-04-25 10:14:09.898
GC-202206-NYMEX [C] 4 Day #5 | File GC-198608-NYMEX.dly has a volume of 0 at 1986-05-29. | 2022-04-25 10:14:09.909
GC-202206-NYMEX [C] 4 Day #5 | File GC-198608-NYMEX.dly has a volume of 0 at 1986-07-29. | 2022-04-25 10:14:09.909
GC-202206-NYMEX [C] 4 Day #5 | File GC-198606-NYMEX.dly has a volume of 0 at 1986-03-28. | 2022-04-25 10:14:09.920
GC-202206-NYMEX [C] 4 Day #5 | File GC-198606-NYMEX.dly has a volume of 0 at 1986-05-28. | 2022-04-25 10:14:09.920
GC-202206-NYMEX [C] 4 Day #5 | File GC-198604-NYMEX.dly has a volume of 0 at 1986-01-30. | 2022-04-25 10:14:09.930
GC-202206-NYMEX [C] 4 Day #5 | File GC-198604-NYMEX.dly has a volume of 0 at 1986-03-27. | 2022-04-25 10:14:09.930
GC-202206-NYMEX [C] 4 Day #5 | File GC-198602-NYMEX.dly has a volume of 0 at 1985-11-28. | 2022-04-25 10:14:09.940
GC-202206-NYMEX [C] 4 Day #5 | File GC-198602-NYMEX.dly has a volume of 0 at 1986-01-29. | 2022-04-25 10:14:09.940
GC-202206-NYMEX [C] 4 Day #5 | File GC-198512-NYMEX.dly has a volume of 0 at 1985-07-30. | 2022-04-25 10:14:09.958
GC-202206-NYMEX [C] 4 Day #5 | File GC-198512-NYMEX.dly has a volume of 0 at 1985-11-27. | 2022-04-25 10:14:09.958
GC-202206-NYMEX [C] 4 Day #5 | File GC-198508-NYMEX.dly has a volume of 0 at 1985-05-30. | 2022-04-25 10:14:09.968
GC-202206-NYMEX [C] 4 Day #5 | File GC-198508-NYMEX.dly has a volume of 0 at 1985-07-29. | 2022-04-25 10:14:09.968
GC-202206-NYMEX [C] 4 Day #5 | File GC-198506-NYMEX.dly has a volume of 0 at 1985-03-28. | 2022-04-25 10:14:09.979
GC-202206-NYMEX [C] 4 Day #5 | File GC-198506-NYMEX.dly has a volume of 0 at 1985-05-29. | 2022-04-25 10:14:09.979
GC-202206-NYMEX [C] 4 Day #5 | File GC-198504-NYMEX.dly has a volume of 0 at 1985-01-30. | 2022-04-25 10:14:09.989
GC-202206-NYMEX [C] 4 Day #5 | File GC-198504-NYMEX.dly has a volume of 0 at 1985-03-27. | 2022-04-25 10:14:09.989
GC-202206-NYMEX [C] 4 Day #5 | File GC-198502-NYMEX.dly has a volume of 0 at 1984-11-29. | 2022-04-25 10:14:09.999
GC-202206-NYMEX [C] 4 Day #5 | File GC-198502-NYMEX.dly has a volume of 0 at 1985-01-29. | 2022-04-25 10:14:09.999
GC-202206-NYMEX [C] 4 Day #5 | File GC-198412-NYMEX.dly has a volume of 0 at 1984-07-30. | 2022-04-25 10:14:10.016
GC-202206-NYMEX [C] 4 Day #5 | File GC-198412-NYMEX.dly has a volume of 0 at 1984-11-28. | 2022-04-25 10:14:10.016
GC-202206-NYMEX [C] 4 Day #5 | File GC-198408-NYMEX.dly has a volume of 0 at 1984-05-30. | 2022-04-25 10:14:10.027
GC-202206-NYMEX [C] 4 Day #5 | File GC-198408-NYMEX.dly has a volume of 0 at 1984-07-27. | 2022-04-25 10:14:10.027
GC-202206-NYMEX [C] 4 Day #5 | File GC-198406-NYMEX.dly has a volume of 0 at 1984-03-29. | 2022-04-25 10:14:10.037
GC-202206-NYMEX [C] 4 Day #5 | File GC-198406-NYMEX.dly has a volume of 0 at 1984-05-29. | 2022-04-25 10:14:10.037
GC-202206-NYMEX [C] 4 Day #5 | File GC-198404-NYMEX.dly has a volume of 0 at 1984-01-30. | 2022-04-25 10:14:10.048
GC-202206-NYMEX [C] 4 Day #5 | File GC-198404-NYMEX.dly has a volume of 0 at 1984-03-28. | 2022-04-25 10:14:10.048
GC-202206-NYMEX [C] 4 Day #5 | File GC-198402-NYMEX.dly has a volume of 0 at 1983-11-29. | 2022-04-25 10:14:10.058
GC-202206-NYMEX [C] 4 Day #5 | File GC-198402-NYMEX.dly has a volume of 0 at 1984-01-27. | 2022-04-25 10:14:10.058
GC-202206-NYMEX [C] 4 Day #5 | File GC-198312-NYMEX.dly has a volume of 0 at 1983-07-28. | 2022-04-25 10:14:10.075
GC-202206-NYMEX [C] 4 Day #5 | File GC-198312-NYMEX.dly has a volume of 0 at 1983-11-28. | 2022-04-25 10:14:10.075
GC-202206-NYMEX [C] 4 Day #5 | File GC-198308-NYMEX.dly has a volume of 0 at 1983-05-30. | 2022-04-25 10:14:10.086
GC-202206-NYMEX [C] 4 Day #5 | File GC-198308-NYMEX.dly has a volume of 0 at 1983-07-27. | 2022-04-25 10:14:10.086
GC-202206-NYMEX [C] 4 Day #5 | File GC-198306-NYMEX.dly has a volume of 0 at 1983-03-30. | 2022-04-25 10:14:10.097
GC-202206-NYMEX [C] 4 Day #5 | File GC-198306-NYMEX.dly has a volume of 0 at 1983-05-27. | 2022-04-25 10:14:10.097
GC-202206-NYMEX [C] 4 Day #5 | File GC-198304-NYMEX.dly has a volume of 0 at 1983-01-28. | 2022-04-25 10:14:10.107
GC-202206-NYMEX [C] 4 Day #5 | File GC-198304-NYMEX.dly has a volume of 0 at 1983-03-29. | 2022-04-25 10:14:10.107
GC-202206-NYMEX [C] 4 Day #5 | File GC-198302-NYMEX.dly has a volume of 0 at 1982-11-29. | 2022-04-25 10:14:10.117
GC-202206-NYMEX [C] 4 Day #5 | File GC-198302-NYMEX.dly has a volume of 0 at 1983-01-27. | 2022-04-25 10:14:10.117
GC-202206-NYMEX [C] 4 Day #5 | File GC-198212-NYMEX.dly has a volume of 0 at 1982-07-29. | 2022-04-25 10:14:10.134
GC-202206-NYMEX [C] 4 Day #5 | File GC-198212-NYMEX.dly has a volume of 0 at 1982-11-26. | 2022-04-25 10:14:10.134
GC-202206-NYMEX [C] 4 Day #5 | File GC-198208-NYMEX.dly has a volume of 0 at 1982-05-28. | 2022-04-25 10:14:10.144
GC-202206-NYMEX [C] 4 Day #5 | File GC-198208-NYMEX.dly has a volume of 0 at 1982-07-28. | 2022-04-25 10:14:10.144
GC-202206-NYMEX [C] 4 Day #5 | File GC-198206-NYMEX.dly has a volume of 0 at 1982-03-30. | 2022-04-25 10:14:10.155
GC-202206-NYMEX [C] 4 Day #5 | File GC-198206-NYMEX.dly has a volume of 0 at 1982-05-27. | 2022-04-25 10:14:10.155
GC-202206-NYMEX [C] 4 Day #5 | File GC-198204-NYMEX.dly has a volume of 0 at 1982-01-28. | 2022-04-25 10:14:10.165
GC-202206-NYMEX [C] 4 Day #5 | File GC-198204-NYMEX.dly has a volume of 0 at 1982-03-29. | 2022-04-25 10:14:10.165
GC-202206-NYMEX [C] 4 Day #5 | File GC-198202-NYMEX.dly has a volume of 0 at 1981-11-27. | 2022-04-25 10:14:10.175
GC-202206-NYMEX [C] 4 Day #5 | File GC-198202-NYMEX.dly has a volume of 0 at 1982-01-27. | 2022-04-25 10:14:10.175
GC-202206-NYMEX [C] 4 Day #5 | File GC-198112-NYMEX.dly has a volume of 0 at 1981-07-30. | 2022-04-25 10:14:10.192
GC-202206-NYMEX [C] 4 Day #5 | File GC-198112-NYMEX.dly has a volume of 0 at 1981-11-26. | 2022-04-25 10:14:10.192
GC-202206-NYMEX [C] 4 Day #5 | File GC-198108-NYMEX.dly has a volume of 0 at 1981-05-28. | 2022-04-25 10:14:10.203
GC-202206-NYMEX [C] 4 Day #5 | File GC-198108-NYMEX.dly has a volume of 0 at 1981-07-29. | 2022-04-25 10:14:10.203
GC-202206-NYMEX [C] 4 Day #5 | File GC-198106-NYMEX.dly has a volume of 0 at 1981-03-30. | 2022-04-25 10:14:10.214
GC-202206-NYMEX [C] 4 Day #5 | File GC-198106-NYMEX.dly has a volume of 0 at 1981-05-27. | 2022-04-25 10:14:10.214
GC-202206-NYMEX [C] 4 Day #5 | File GC-198104-NYMEX.dly has a volume of 0 at 1981-01-29. | 2022-04-25 10:14:10.224
GC-202206-NYMEX [C] 4 Day #5 | File GC-198104-NYMEX.dly has a volume of 0 at 1981-03-27. | 2022-04-25 10:14:10.224
GC-202206-NYMEX [C] 4 Day #5 | File GC-198102-NYMEX.dly has a volume of 0 at 1980-11-27. | 2022-04-25 10:14:10.234
GC-202206-NYMEX [C] 4 Day #5 | File GC-198102-NYMEX.dly has a volume of 0 at 1981-01-28. | 2022-04-25 10:14:10.234
GC-202206-NYMEX [C] 4 Day #5 | File GC-198012-NYMEX.dly has a volume of 0 at 1980-07-30. | 2022-04-25 10:14:10.251
GC-202206-NYMEX [C] 4 Day #5 | File GC-198012-NYMEX.dly has a volume of 0 at 1980-11-26. | 2022-04-25 10:14:10.251
GC-202206-NYMEX [C] 4 Day #5 | File GC-198008-NYMEX.dly has a volume of 0 at 1980-05-29. | 2022-04-25 10:14:10.261
GC-202206-NYMEX [C] 4 Day #5 | File GC-198008-NYMEX.dly has a volume of 0 at 1980-07-29. | 2022-04-25 10:14:10.261
GC-202206-NYMEX [C] 4 Day #5 | File GC-198006-NYMEX.dly has a volume of 0 at 1980-03-28. | 2022-04-25 10:14:10.271
GC-202206-NYMEX [C] 4 Day #5 | File GC-198006-NYMEX.dly has a volume of 0 at 1980-05-28. | 2022-04-25 10:14:10.271
GC-202206-NYMEX [C] 4 Day #5 | File GC-198004-NYMEX.dly has a volume of 0 at 1980-01-30. | 2022-04-25 10:14:10.282
GC-202206-NYMEX [C] 4 Day #5 | File GC-198004-NYMEX.dly has a volume of 0 at 1980-03-27. | 2022-04-25 10:14:10.282
GC-202206-NYMEX [C] 4 Day #5 | File GC-198002-NYMEX.dly has a volume of 0 at 1979-11-29. | 2022-04-25 10:14:10.292
GC-202206-NYMEX [C] 4 Day #5 | File GC-198002-NYMEX.dly has a volume of 0 at 1980-01-29. | 2022-04-25 10:14:10.292
GC-202206-NYMEX [C] 4 Day #5 | File GC-197912-NYMEX.dly has a volume of 0 at 1979-07-30. | 2022-04-25 10:14:10.309
GC-202206-NYMEX [C] 4 Day #5 | File GC-197912-NYMEX.dly has a volume of 0 at 1979-11-28. | 2022-04-25 10:14:10.309
GC-202206-NYMEX [C] 4 Day #5 | File GC-197908-NYMEX.dly has a volume of 0 at 1979-05-30. | 2022-04-25 10:14:10.320
GC-202206-NYMEX [C] 4 Day #5 | File GC-197908-NYMEX.dly has a volume of 0 at 1979-07-27. | 2022-04-25 10:14:10.320
GC-202206-NYMEX [C] 4 Day #5 | File GC-197906-NYMEX.dly has a volume of 0 at 1979-03-29. | 2022-04-25 10:14:10.330
GC-202206-NYMEX [C] 4 Day #5 | File GC-197906-NYMEX.dly has a volume of 0 at 1979-05-29. | 2022-04-25 10:14:10.330
GC-202206-NYMEX [C] 4 Day #5 | File GC-197904-NYMEX.dly has a volume of 0 at 1979-01-30. | 2022-04-25 10:14:10.341
GC-202206-NYMEX [C] 4 Day #5 | File GC-197904-NYMEX.dly has a volume of 0 at 1979-03-28. | 2022-04-25 10:14:10.341
GC-202206-NYMEX [C] 4 Day #5 | File GC-197902-NYMEX.dly has a volume of 0 at 1978-11-29. | 2022-04-25 10:14:10.351
GC-202206-NYMEX [C] 4 Day #5 | File GC-197902-NYMEX.dly has a volume of 0 at 1979-01-29. | 2022-04-25 10:14:10.351
GC-202206-NYMEX [C] 4 Day #5 | File GC-197812-NYMEX.dly has a volume of 0 at 1978-07-28. | 2022-04-25 10:14:10.368
GC-202206-NYMEX [C] 4 Day #5 | File GC-197812-NYMEX.dly has a volume of 0 at 1978-11-28. | 2022-04-25 10:14:10.368
GC-202206-NYMEX [C] 4 Day #5 | File GC-197808-NYMEX.dly has a volume of 0 at 1978-05-30. | 2022-04-25 10:14:10.378
GC-202206-NYMEX [C] 4 Day #5 | File GC-197808-NYMEX.dly has a volume of 0 at 1978-07-27. | 2022-04-25 10:14:10.379
GC-202206-NYMEX [C] 4 Day #5 | File GC-197806-NYMEX.dly has a volume of 0 at 1978-03-30. | 2022-04-25 10:14:10.389
GC-202206-NYMEX [C] 4 Day #5 | File GC-197806-NYMEX.dly has a volume of 0 at 1978-05-29. | 2022-04-25 10:14:10.389
GC-202206-NYMEX [C] 4 Day #5 | File GC-197804-NYMEX.dly has a volume of 0 at 1978-01-30. | 2022-04-25 10:14:10.399
GC-202206-NYMEX [C] 4 Day #5 | File GC-197804-NYMEX.dly has a volume of 0 at 1978-03-29. | 2022-04-25 10:14:10.399
GC-202206-NYMEX [C] 4 Day #5 | File GC-197802-NYMEX.dly has a volume of 0 at 1977-11-29. | 2022-04-25 10:14:10.409
GC-202206-NYMEX [C] 4 Day #5 | File GC-197802-NYMEX.dly has a volume of 0 at 1978-01-27. | 2022-04-25 10:14:10.409
GC-202206-NYMEX [C] 4 Day #5 | File GC-197712-NYMEX.dly has a volume of 0 at 1977-07-28. | 2022-04-25 10:14:10.426
GC-202206-NYMEX [C] 4 Day #5 | File GC-197712-NYMEX.dly has a volume of 0 at 1977-11-28. | 2022-04-25 10:14:10.426
GC-202206-NYMEX [C] 4 Day #5 | File GC-197708-NYMEX.dly has a volume of 0 at 1977-05-30. | 2022-04-25 10:14:10.437
GC-202206-NYMEX [C] 4 Day #5 | File GC-197708-NYMEX.dly has a volume of 0 at 1977-07-27. | 2022-04-25 10:14:10.437
GC-202206-NYMEX [C] 4 Day #5 | File GC-197706-NYMEX.dly has a volume of 0 at 1977-03-30. | 2022-04-25 10:14:10.447
GC-202206-NYMEX [C] 4 Day #5 | File GC-197706-NYMEX.dly has a volume of 0 at 1977-05-27. | 2022-04-25 10:14:10.447
GC-202206-NYMEX [C] 4 Day #5 | File GC-197704-NYMEX.dly has a volume of 0 at 1977-01-28. | 2022-04-25 10:14:10.458
GC-202206-NYMEX [C] 4 Day #5 | File GC-197704-NYMEX.dly has a volume of 0 at 1977-03-29. | 2022-04-25 10:14:10.458
GC-202206-NYMEX [C] 4 Day #5 | File GC-197702-NYMEX.dly has a volume of 0 at 1976-11-29. | 2022-04-25 10:14:10.468
GC-202206-NYMEX [C] 4 Day #5 | File GC-197702-NYMEX.dly has a volume of 0 at 1977-01-27. | 2022-04-25 10:14:10.468
GC-202206-NYMEX [C] 4 Day #5 | File GC-197612-NYMEX.dly has a volume of 0 at 1976-07-29. | 2022-04-25 10:14:10.485
GC-202206-NYMEX [C] 4 Day #5 | File GC-197612-NYMEX.dly has a volume of 0 at 1976-11-26. | 2022-04-25 10:14:10.485
GC-202206-NYMEX [C] 4 Day #5 | File GC-197608-NYMEX.dly has a volume of 0 at 1976-05-28. | 2022-04-25 10:14:10.496
GC-202206-NYMEX [C] 4 Day #5 | File GC-197608-NYMEX.dly has a volume of 0 at 1976-07-28. | 2022-04-25 10:14:10.496
GC-202206-NYMEX [C] 4 Day #5 | File GC-197606-NYMEX.dly has a volume of 0 at 1976-03-30. | 2022-04-25 10:14:10.506
GC-202206-NYMEX [C] 4 Day #5 | File GC-197606-NYMEX.dly has a volume of 0 at 1976-05-27. | 2022-04-25 10:14:10.506
GC-202206-NYMEX [C] 4 Day #5 | File GC-197604-NYMEX.dly has a volume of 0 at 1976-01-29. | 2022-04-25 10:14:10.517
GC-202206-NYMEX [C] 4 Day #5 | File GC-197604-NYMEX.dly has a volume of 0 at 1976-03-29. | 2022-04-25 10:14:10.517
GC-202206-NYMEX [C] 4 Day #5 | File GC-197602-NYMEX.dly has a volume of 0 at 1975-11-27. | 2022-04-25 10:14:10.527
GC-202206-NYMEX [C] 4 Day #5 | File GC-197602-NYMEX.dly has a volume of 0 at 1976-01-28. | 2022-04-25 10:14:10.527
GC-202206-NYMEX [C] 4 Day #5 | File GC-197512-NYMEX.dly has a volume of 0 at 1975-07-30. | 2022-04-25 10:14:10.544
GC-202206-NYMEX [C] 4 Day #5 | File GC-197512-NYMEX.dly has a volume of 0 at 1975-11-26. | 2022-04-25 10:14:10.544
GC-202206-NYMEX [C] 4 Day #5 | File GC-197508-NYMEX.dly has a volume of 0 at 1975-05-29. | 2022-04-25 10:14:10.554
GC-202206-NYMEX [C] 4 Day #5 | File GC-197508-NYMEX.dly has a volume of 0 at 1975-07-29. | 2022-04-25 10:14:10.554
GC-202206-NYMEX [C] 4 Day #5 | File GC-197506-NYMEX.dly has a volume of 0 at 1975-03-28. | 2022-04-25 10:14:10.565
GC-202206-NYMEX [C] 4 Day #5 | File GC-197506-NYMEX.dly has a volume of 0 at 1975-05-28. | 2022-04-25 10:14:10.565
GC-202206-NYMEX [C] 4 Day #5 | File GC-197504-NYMEX.dly has a volume of 0 at 1975-01-30. | 2022-04-25 10:14:10.575
GC-202206-NYMEX [C] 4 Day #5 | File GC-197504-NYMEX.dly has a volume of 0 at 1975-03-27. | 2022-04-25 10:14:10.575
GC-202206-NYMEX [C] 4 Day #5 | Dates not found while checking for invalid data in continuous contract data files. GC-197502-NYMEX | 2022-04-25 10:14:10.582 *
GC-202206-NYMEX [C] 4 Day #5 | Waiting for historical downloads to complete with the IDs: 20, 21, | 2022-04-25 10:14:10.582
GC-202206-NYMEX [C] Daily #3 | Reloading chart. | 2022-04-25 10:14:10.596
GC-202206-NYMEX [C] Daily #3 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:10.596
GC-202206-NYMEX [C] Daily #3 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:10.596
GC-202206-NYMEX [C] Daily #3 | File GC-200102-NYMEX.dly has a volume of 0 at 2000-11-29. | 2022-04-25 10:14:12.269
GC-202206-NYMEX [C] Daily #3 | File GC-200012-NYMEX.dly has a volume of 0 at 2000-07-28. | 2022-04-25 10:14:12.286
GC-202206-NYMEX [C] Daily #3 | File GC-200012-NYMEX.dly has a volume of 0 at 2000-11-28. | 2022-04-25 10:14:12.286
GC-202206-NYMEX [C] Daily #3 | File GC-200008-NYMEX.dly has a volume of 0 at 2000-05-30. | 2022-04-25 10:14:12.297
GC-202206-NYMEX [C] Daily #3 | File GC-200008-NYMEX.dly has a volume of 0 at 2000-07-27. | 2022-04-25 10:14:12.297
GC-202206-NYMEX [C] Daily #3 | File GC-200006-NYMEX.dly has a volume of 0 at 2000-03-30. | 2022-04-25 10:14:12.308
GC-202206-NYMEX [C] Daily #3 | File GC-200006-NYMEX.dly has a volume of 0 at 2000-05-29. | 2022-04-25 10:14:12.308
GC-202206-NYMEX [C] Daily #3 | File GC-200004-NYMEX.dly has a volume of 0 at 2000-01-28. | 2022-04-25 10:14:12.318
GC-202206-NYMEX [C] Daily #3 | File GC-200004-NYMEX.dly has a volume of 0 at 2000-03-29. | 2022-04-25 10:14:12.318
GC-202206-NYMEX [C] Daily #3 | File GC-200002-NYMEX.dly has a volume of 0 at 1999-11-29. | 2022-04-25 10:14:12.328
GC-202206-NYMEX [C] Daily #3 | File GC-200002-NYMEX.dly has a volume of 0 at 2000-01-27. | 2022-04-25 10:14:12.328
GC-202206-NYMEX [C] Daily #3 | File GC-199912-NYMEX.dly has a volume of 0 at 1999-07-29. | 2022-04-25 10:14:12.345
GC-202206-NYMEX [C] Daily #3 | File GC-199912-NYMEX.dly has a volume of 0 at 1999-11-26. | 2022-04-25 10:14:12.345
GC-202206-NYMEX [C] Daily #3 | File GC-199908-NYMEX.dly has a volume of 0 at 1999-05-28. | 2022-04-25 10:14:12.356
GC-202206-NYMEX [C] Daily #3 | File GC-199908-NYMEX.dly has a volume of 0 at 1999-07-28. | 2022-04-25 10:14:12.356
GC-202206-NYMEX [C] Daily #3 | File GC-199906-NYMEX.dly has a volume of 0 at 1999-03-30. | 2022-04-25 10:14:12.367
GC-202206-NYMEX [C] Daily #3 | File GC-199906-NYMEX.dly has a volume of 0 at 1999-05-27. | 2022-04-25 10:14:12.367
GC-202206-NYMEX [C] Daily #3 | File GC-199904-NYMEX.dly has a volume of 0 at 1999-01-28. | 2022-04-25 10:14:12.377
GC-202206-NYMEX [C] Daily #3 | File GC-199904-NYMEX.dly has a volume of 0 at 1999-03-29. | 2022-04-25 10:14:12.377
GC-202206-NYMEX [C] Daily #3 | File GC-199902-NYMEX.dly has a volume of 0 at 1998-11-27. | 2022-04-25 10:14:12.387
GC-202206-NYMEX [C] Daily #3 | File GC-199902-NYMEX.dly has a volume of 0 at 1999-01-27. | 2022-04-25 10:14:12.387
GC-202206-NYMEX [C] Daily #3 | File GC-199812-NYMEX.dly has a volume of 0 at 1998-07-30. | 2022-04-25 10:14:12.405
GC-202206-NYMEX [C] Daily #3 | File GC-199812-NYMEX.dly has a volume of 0 at 1998-11-26. | 2022-04-25 10:14:12.405
GC-202206-NYMEX [C] Daily #3 | File GC-199808-NYMEX.dly has a volume of 0 at 1998-05-28. | 2022-04-25 10:14:12.416
GC-202206-NYMEX [C] Daily #3 | File GC-199808-NYMEX.dly has a volume of 0 at 1998-07-29. | 2022-04-25 10:14:12.416
GC-202206-NYMEX [C] Daily #3 | File GC-199806-NYMEX.dly has a volume of 0 at 1998-03-30. | 2022-04-25 10:14:12.426
GC-202206-NYMEX [C] Daily #3 | File GC-199806-NYMEX.dly has a volume of 0 at 1998-05-27. | 2022-04-25 10:14:12.426
GC-202206-NYMEX [C] Daily #3 | File GC-199804-NYMEX.dly has a volume of 0 at 1998-01-29. | 2022-04-25 10:14:12.437
GC-202206-NYMEX [C] Daily #3 | File GC-199804-NYMEX.dly has a volume of 0 at 1998-03-27. | 2022-04-25 10:14:12.437
GC-202206-NYMEX [C] Daily #3 | File GC-199802-NYMEX.dly has a volume of 0 at 1997-11-27. | 2022-04-25 10:14:12.447
GC-202206-NYMEX [C] Daily #3 | File GC-199802-NYMEX.dly has a volume of 0 at 1998-01-28. | 2022-04-25 10:14:12.447
GC-202206-NYMEX [C] Daily #3 | File GC-199712-NYMEX.dly has a volume of 0 at 1997-07-30. | 2022-04-25 10:14:12.464
GC-202206-NYMEX [C] Daily #3 | File GC-199712-NYMEX.dly has a volume of 0 at 1997-11-26. | 2022-04-25 10:14:12.464
GC-202206-NYMEX [C] Daily #3 | File GC-199708-NYMEX.dly has a volume of 0 at 1997-05-29. | 2022-04-25 10:14:12.474
GC-202206-NYMEX [C] Daily #3 | File GC-199708-NYMEX.dly has a volume of 0 at 1997-07-29. | 2022-04-25 10:14:12.474
GC-202206-NYMEX [C] Daily #3 | File GC-199706-NYMEX.dly has a volume of 0 at 1997-03-28. | 2022-04-25 10:14:12.485
GC-202206-NYMEX [C] Daily #3 | File GC-199706-NYMEX.dly has a volume of 0 at 1997-05-28. | 2022-04-25 10:14:12.485
GC-202206-NYMEX [C] Daily #3 | File GC-199704-NYMEX.dly has a volume of 0 at 1997-01-30. | 2022-04-25 10:14:12.496
GC-202206-NYMEX [C] Daily #3 | File GC-199704-NYMEX.dly has a volume of 0 at 1997-03-27. | 2022-04-25 10:14:12.496
GC-202206-NYMEX [C] Daily #3 | File GC-199702-NYMEX.dly has a volume of 0 at 1996-11-28. | 2022-04-25 10:14:12.506
GC-202206-NYMEX [C] Daily #3 | File GC-199702-NYMEX.dly has a volume of 0 at 1997-01-29. | 2022-04-25 10:14:12.506
GC-202206-NYMEX [C] Daily #3 | File GC-199612-NYMEX.dly has a volume of 0 at 1996-07-30. | 2022-04-25 10:14:12.523
GC-202206-NYMEX [C] Daily #3 | File GC-199612-NYMEX.dly has a volume of 0 at 1996-11-27. | 2022-04-25 10:14:12.523
GC-202206-NYMEX [C] Daily #3 | File GC-199608-NYMEX.dly has a volume of 0 at 1996-05-30. | 2022-04-25 10:14:12.534
GC-202206-NYMEX [C] Daily #3 | File GC-199608-NYMEX.dly has a volume of 0 at 1996-07-29. | 2022-04-25 10:14:12.534
GC-202206-NYMEX [C] Daily #3 | File GC-199606-NYMEX.dly has a volume of 0 at 1996-03-28. | 2022-04-25 10:14:12.545
GC-202206-NYMEX [C] Daily #3 | File GC-199606-NYMEX.dly has a volume of 0 at 1996-05-29. | 2022-04-25 10:14:12.545
GC-202206-NYMEX [C] Daily #3 | File GC-199604-NYMEX.dly has a volume of 0 at 1996-01-30. | 2022-04-25 10:14:12.556
GC-202206-NYMEX [C] Daily #3 | File GC-199604-NYMEX.dly has a volume of 0 at 1996-03-27. | 2022-04-25 10:14:12.556
GC-202206-NYMEX [C] Daily #3 | File GC-199602-NYMEX.dly has a volume of 0 at 1995-11-29. | 2022-04-25 10:14:12.566
GC-202206-NYMEX [C] Daily #3 | File GC-199602-NYMEX.dly has a volume of 0 at 1996-01-29. | 2022-04-25 10:14:12.566
GC-202206-NYMEX [C] Daily #3 | File GC-199512-NYMEX.dly has a volume of 0 at 1995-07-28. | 2022-04-25 10:14:12.583
GC-202206-NYMEX [C] Daily #3 | File GC-199512-NYMEX.dly has a volume of 0 at 1995-11-28. | 2022-04-25 10:14:12.583
GC-202206-NYMEX [C] Daily #3 | File GC-199508-NYMEX.dly has a volume of 0 at 1995-05-30. | 2022-04-25 10:14:12.594
GC-202206-NYMEX [C] Daily #3 | File GC-199508-NYMEX.dly has a volume of 0 at 1995-07-27. | 2022-04-25 10:14:12.594
GC-202206-NYMEX [C] Daily #3 | File GC-199506-NYMEX.dly has a volume of 0 at 1995-03-30. | 2022-04-25 10:14:12.604
GC-202206-NYMEX [C] Daily #3 | File GC-199506-NYMEX.dly has a volume of 0 at 1995-05-29. | 2022-04-25 10:14:12.604
GC-202206-NYMEX [C] Daily #3 | File GC-199504-NYMEX.dly has a volume of 0 at 1995-01-30. | 2022-04-25 10:14:12.614
GC-202206-NYMEX [C] Daily #3 | File GC-199504-NYMEX.dly has a volume of 0 at 1995-03-29. | 2022-04-25 10:14:12.614
GC-202206-NYMEX [C] Daily #3 | File GC-199502-NYMEX.dly has a volume of 0 at 1994-11-29. | 2022-04-25 10:14:12.625
GC-202206-NYMEX [C] Daily #3 | File GC-199502-NYMEX.dly has a volume of 0 at 1995-01-27. | 2022-04-25 10:14:12.625
GC-202206-NYMEX [C] Daily #3 | File GC-199412-NYMEX.dly has a volume of 0 at 1994-07-28. | 2022-04-25 10:14:12.642
GC-202206-NYMEX [C] Daily #3 | File GC-199412-NYMEX.dly has a volume of 0 at 1994-11-28. | 2022-04-25 10:14:12.642
GC-202206-NYMEX [C] Daily #3 | File GC-199408-NYMEX.dly has a volume of 0 at 1994-05-30. | 2022-04-25 10:14:12.653
GC-202206-NYMEX [C] Daily #3 | File GC-199408-NYMEX.dly has a volume of 0 at 1994-07-27. | 2022-04-25 10:14:12.653
GC-202206-NYMEX [C] Daily #3 | File GC-199406-NYMEX.dly has a volume of 0 at 1994-03-30. | 2022-04-25 10:14:12.663
GC-202206-NYMEX [C] Daily #3 | File GC-199406-NYMEX.dly has a volume of 0 at 1994-05-27. | 2022-04-25 10:14:12.663
GC-202206-NYMEX [C] Daily #3 | File GC-199404-NYMEX.dly has a volume of 0 at 1994-01-28. | 2022-04-25 10:14:12.673
GC-202206-NYMEX [C] Daily #3 | File GC-199404-NYMEX.dly has a volume of 0 at 1994-03-29. | 2022-04-25 10:14:12.673
GC-202206-NYMEX [C] Daily #3 | File GC-199402-NYMEX.dly has a volume of 0 at 1993-11-29. | 2022-04-25 10:14:12.684
GC-202206-NYMEX [C] Daily #3 | File GC-199402-NYMEX.dly has a volume of 0 at 1994-01-27. | 2022-04-25 10:14:12.684
GC-202206-NYMEX [C] Daily #3 | File GC-199312-NYMEX.dly has a volume of 0 at 1993-07-29. | 2022-04-25 10:14:12.701
GC-202206-NYMEX [C] Daily #3 | File GC-199312-NYMEX.dly has a volume of 0 at 1993-11-26. | 2022-04-25 10:14:12.701
GC-202206-NYMEX [C] Daily #3 | File GC-199308-NYMEX.dly has a volume of 0 at 1993-05-28. | 2022-04-25 10:14:12.712
GC-202206-NYMEX [C] Daily #3 | File GC-199308-NYMEX.dly has a volume of 0 at 1993-07-28. | 2022-04-25 10:14:12.712
GC-202206-NYMEX [C] Daily #3 | File GC-199306-NYMEX.dly has a volume of 0 at 1993-03-30. | 2022-04-25 10:14:12.723
GC-202206-NYMEX [C] Daily #3 | File GC-199306-NYMEX.dly has a volume of 0 at 1993-05-27. | 2022-04-25 10:14:12.723
GC-202206-NYMEX [C] Daily #3 | File GC-199304-NYMEX.dly has a volume of 0 at 1993-01-28. | 2022-04-25 10:14:12.733
GC-202206-NYMEX [C] Daily #3 | File GC-199304-NYMEX.dly has a volume of 0 at 1993-03-29. | 2022-04-25 10:14:12.733
GC-202206-NYMEX [C] Daily #3 | File GC-199302-NYMEX.dly has a volume of 0 at 1992-11-27. | 2022-04-25 10:14:12.744
GC-202206-NYMEX [C] Daily #3 | File GC-199302-NYMEX.dly has a volume of 0 at 1993-01-27. | 2022-04-25 10:14:12.744
GC-202206-NYMEX [C] Daily #3 | File GC-199212-NYMEX.dly has a volume of 0 at 1992-07-30. | 2022-04-25 10:14:12.761
GC-202206-NYMEX [C] Daily #3 | File GC-199212-NYMEX.dly has a volume of 0 at 1992-11-26. | 2022-04-25 10:14:12.761
GC-202206-NYMEX [C] Daily #3 | File GC-199208-NYMEX.dly has a volume of 0 at 1992-05-28. | 2022-04-25 10:14:12.772
GC-202206-NYMEX [C] Daily #3 | File GC-199208-NYMEX.dly has a volume of 0 at 1992-07-29. | 2022-04-25 10:14:12.772
GC-202206-NYMEX [C] Daily #3 | File GC-199206-NYMEX.dly has a volume of 0 at 1992-03-30. | 2022-04-25 10:14:12.783
GC-202206-NYMEX [C] Daily #3 | File GC-199206-NYMEX.dly has a volume of 0 at 1992-05-27. | 2022-04-25 10:14:12.783
GC-202206-NYMEX [C] Daily #3 | File GC-199204-NYMEX.dly has a volume of 0 at 1992-01-30. | 2022-04-25 10:14:12.793
GC-202206-NYMEX [C] Daily #3 | File GC-199204-NYMEX.dly has a volume of 0 at 1992-03-27. | 2022-04-25 10:14:12.793
GC-202206-NYMEX [C] Daily #3 | File GC-199202-NYMEX.dly has a volume of 0 at 1991-11-28. | 2022-04-25 10:14:12.803
GC-202206-NYMEX [C] Daily #3 | File GC-199202-NYMEX.dly has a volume of 0 at 1992-01-29. | 2022-04-25 10:14:12.803
GC-202206-NYMEX [C] Daily #3 | File GC-199112-NYMEX.dly has a volume of 0 at 1991-07-30. | 2022-04-25 10:14:12.821
GC-202206-NYMEX [C] Daily #3 | File GC-199112-NYMEX.dly has a volume of 0 at 1991-11-27. | 2022-04-25 10:14:12.821
GC-202206-NYMEX [C] Daily #3 | File GC-199108-NYMEX.dly has a volume of 0 at 1991-05-30. | 2022-04-25 10:14:12.832
GC-202206-NYMEX [C] Daily #3 | File GC-199108-NYMEX.dly has a volume of 0 at 1991-07-29. | 2022-04-25 10:14:12.832
GC-202206-NYMEX [C] Daily #3 | File GC-199106-NYMEX.dly has a volume of 0 at 1991-03-28. | 2022-04-25 10:14:12.842
GC-202206-NYMEX [C] Daily #3 | File GC-199106-NYMEX.dly has a volume of 0 at 1991-05-29. | 2022-04-25 10:14:12.842
GC-202206-NYMEX [C] Daily #3 | File GC-199104-NYMEX.dly has a volume of 0 at 1991-01-30. | 2022-04-25 10:14:12.853
GC-202206-NYMEX [C] Daily #3 | File GC-199104-NYMEX.dly has a volume of 0 at 1991-03-27. | 2022-04-25 10:14:12.853
GC-202206-NYMEX [C] Daily #3 | File GC-199102-NYMEX.dly has a volume of 0 at 1990-11-29. | 2022-04-25 10:14:12.863
GC-202206-NYMEX [C] Daily #3 | File GC-199102-NYMEX.dly has a volume of 0 at 1991-01-29. | 2022-04-25 10:14:12.863
GC-202206-NYMEX [C] Daily #3 | File GC-199012-NYMEX.dly has a volume of 0 at 1990-07-30. | 2022-04-25 10:14:12.880
GC-202206-NYMEX [C] Daily #3 | File GC-199012-NYMEX.dly has a volume of 0 at 1990-11-28. | 2022-04-25 10:14:12.880
GC-202206-NYMEX [C] Daily #3 | File GC-199008-NYMEX.dly has a volume of 0 at 1990-05-30. | 2022-04-25 10:14:12.891
GC-202206-NYMEX [C] Daily #3 | File GC-199008-NYMEX.dly has a volume of 0 at 1990-07-27. | 2022-04-25 10:14:12.891
GC-202206-NYMEX [C] Daily #3 | File GC-199006-NYMEX.dly has a volume of 0 at 1990-03-29. | 2022-04-25 10:14:12.901
GC-202206-NYMEX [C] Daily #3 | File GC-199006-NYMEX.dly has a volume of 0 at 1990-05-29. | 2022-04-25 10:14:12.901
GC-202206-NYMEX [C] Daily #3 | File GC-199004-NYMEX.dly has a volume of 0 at 1990-01-30. | 2022-04-25 10:14:12.912
GC-202206-NYMEX [C] Daily #3 | File GC-199004-NYMEX.dly has a volume of 0 at 1990-03-28. | 2022-04-25 10:14:12.912
GC-202206-NYMEX [C] Daily #3 | File GC-199002-NYMEX.dly has a volume of 0 at 1989-11-29. | 2022-04-25 10:14:12.922
GC-202206-NYMEX [C] Daily #3 | File GC-199002-NYMEX.dly has a volume of 0 at 1990-01-29. | 2022-04-25 10:14:12.922
GC-202206-NYMEX [C] Daily #3 | File GC-198912-NYMEX.dly has a volume of 0 at 1989-07-28. | 2022-04-25 10:14:12.939
GC-202206-NYMEX [C] Daily #3 | File GC-198912-NYMEX.dly has a volume of 0 at 1989-11-28. | 2022-04-25 10:14:12.939
GC-202206-NYMEX [C] Daily #3 | File GC-198908-NYMEX.dly has a volume of 0 at 1989-05-30. | 2022-04-25 10:14:12.951
GC-202206-NYMEX [C] Daily #3 | File GC-198908-NYMEX.dly has a volume of 0 at 1989-07-27. | 2022-04-25 10:14:12.951
GC-202206-NYMEX [C] Daily #3 | File GC-198906-NYMEX.dly has a volume of 0 at 1989-03-30. | 2022-04-25 10:14:12.961
GC-202206-NYMEX [C] Daily #3 | File GC-198906-NYMEX.dly has a volume of 0 at 1989-05-29. | 2022-04-25 10:14:12.961
GC-202206-NYMEX [C] Daily #3 | File GC-198904-NYMEX.dly has a volume of 0 at 1989-01-30. | 2022-04-25 10:14:12.972
GC-202206-NYMEX [C] Daily #3 | File GC-198904-NYMEX.dly has a volume of 0 at 1989-03-29. | 2022-04-25 10:14:12.972
GC-202206-NYMEX [C] Daily #3 | File GC-198902-NYMEX.dly has a volume of 0 at 1988-11-29. | 2022-04-25 10:14:12.982
GC-202206-NYMEX [C] Daily #3 | File GC-198902-NYMEX.dly has a volume of 0 at 1989-01-27. | 2022-04-25 10:14:12.982
GC-202206-NYMEX [C] Daily #3 | File GC-198812-NYMEX.dly has a volume of 0 at 1988-07-28. | 2022-04-25 10:14:12.999
GC-202206-NYMEX [C] Daily #3 | File GC-198812-NYMEX.dly has a volume of 0 at 1988-11-28. | 2022-04-25 10:14:12.999
GC-202206-NYMEX [C] Daily #3 | File GC-198808-NYMEX.dly has a volume of 0 at 1988-05-30. | 2022-04-25 10:14:13.010
GC-202206-NYMEX [C] Daily #3 | File GC-198808-NYMEX.dly has a volume of 0 at 1988-07-27. | 2022-04-25 10:14:13.010
GC-202206-NYMEX [C] Daily #3 | File GC-198806-NYMEX.dly has a volume of 0 at 1988-03-30. | 2022-04-25 10:14:13.021
GC-202206-NYMEX [C] Daily #3 | File GC-198806-NYMEX.dly has a volume of 0 at 1988-05-27. | 2022-04-25 10:14:13.021
GC-202206-NYMEX [C] Daily #3 | File GC-198804-NYMEX.dly has a volume of 0 at 1988-01-28. | 2022-04-25 10:14:13.032
GC-202206-NYMEX [C] Daily #3 | File GC-198804-NYMEX.dly has a volume of 0 at 1988-03-29. | 2022-04-25 10:14:13.032
GC-202206-NYMEX [C] Daily #3 | File GC-198802-NYMEX.dly has a volume of 0 at 1987-11-27. | 2022-04-25 10:14:13.042
GC-202206-NYMEX [C] Daily #3 | File GC-198802-NYMEX.dly has a volume of 0 at 1988-01-27. | 2022-04-25 10:14:13.042
GC-202206-NYMEX [C] Daily #3 | File GC-198712-NYMEX.dly has a volume of 0 at 1987-07-30. | 2022-04-25 10:14:13.060
GC-202206-NYMEX [C] Daily #3 | File GC-198712-NYMEX.dly has a volume of 0 at 1987-11-26. | 2022-04-25 10:14:13.060
GC-202206-NYMEX [C] Daily #3 | File GC-198708-NYMEX.dly has a volume of 0 at 1987-05-28. | 2022-04-25 10:14:13.071
GC-202206-NYMEX [C] Daily #3 | File GC-198708-NYMEX.dly has a volume of 0 at 1987-07-29. | 2022-04-25 10:14:13.071
GC-202206-NYMEX [C] Daily #3 | File GC-198706-NYMEX.dly has a volume of 0 at 1987-03-30. | 2022-04-25 10:14:13.081
GC-202206-NYMEX [C] Daily #3 | File GC-198706-NYMEX.dly has a volume of 0 at 1987-05-27. | 2022-04-25 10:14:13.081
GC-202206-NYMEX [C] Daily #3 | File GC-198704-NYMEX.dly has a volume of 0 at 1987-01-29. | 2022-04-25 10:14:13.092
GC-202206-NYMEX [C] Daily #3 | File GC-198704-NYMEX.dly has a volume of 0 at 1987-03-27. | 2022-04-25 10:14:13.092
GC-202206-NYMEX [C] Daily #3 | File GC-198702-NYMEX.dly has a volume of 0 at 1986-11-27. | 2022-04-25 10:14:13.102
GC-202206-NYMEX [C] Daily #3 | File GC-198702-NYMEX.dly has a volume of 0 at 1987-01-28. | 2022-04-25 10:14:13.102
GC-202206-NYMEX [C] Daily #3 | File GC-198612-NYMEX.dly has a volume of 0 at 1986-07-30. | 2022-04-25 10:14:13.119
GC-202206-NYMEX [C] Daily #3 | File GC-198612-NYMEX.dly has a volume of 0 at 1986-11-26. | 2022-04-25 10:14:13.119
GC-202206-NYMEX [C] Daily #3 | File GC-198608-NYMEX.dly has a volume of 0 at 1986-05-29. | 2022-04-25 10:14:13.130
GC-202206-NYMEX [C] Daily #3 | File GC-198608-NYMEX.dly has a volume of 0 at 1986-07-29. | 2022-04-25 10:14:13.130
GC-202206-NYMEX [C] Daily #3 | File GC-198606-NYMEX.dly has a volume of 0 at 1986-03-28. | 2022-04-25 10:14:13.141
GC-202206-NYMEX [C] Daily #3 | File GC-198606-NYMEX.dly has a volume of 0 at 1986-05-28. | 2022-04-25 10:14:13.141
GC-202206-NYMEX [C] Daily #3 | File GC-198604-NYMEX.dly has a volume of 0 at 1986-01-30. | 2022-04-25 10:14:13.151
GC-202206-NYMEX [C] Daily #3 | File GC-198604-NYMEX.dly has a volume of 0 at 1986-03-27. | 2022-04-25 10:14:13.151
GC-202206-NYMEX [C] Daily #3 | File GC-198602-NYMEX.dly has a volume of 0 at 1985-11-28. | 2022-04-25 10:14:13.162
GC-202206-NYMEX [C] Daily #3 | File GC-198602-NYMEX.dly has a volume of 0 at 1986-01-29. | 2022-04-25 10:14:13.162
GC-202206-NYMEX [C] Daily #3 | File GC-198512-NYMEX.dly has a volume of 0 at 1985-07-30. | 2022-04-25 10:14:13.179
GC-202206-NYMEX [C] Daily #3 | File GC-198512-NYMEX.dly has a volume of 0 at 1985-11-27. | 2022-04-25 10:14:13.179
GC-202206-NYMEX [C] Daily #3 | File GC-198508-NYMEX.dly has a volume of 0 at 1985-05-30. | 2022-04-25 10:14:13.190
GC-202206-NYMEX [C] Daily #3 | File GC-198508-NYMEX.dly has a volume of 0 at 1985-07-29. | 2022-04-25 10:14:13.190
GC-202206-NYMEX [C] Daily #3 | File GC-198506-NYMEX.dly has a volume of 0 at 1985-03-28. | 2022-04-25 10:14:13.201
GC-202206-NYMEX [C] Daily #3 | File GC-198506-NYMEX.dly has a volume of 0 at 1985-05-29. | 2022-04-25 10:14:13.201
GC-202206-NYMEX [C] Daily #3 | File GC-198504-NYMEX.dly has a volume of 0 at 1985-01-30. | 2022-04-25 10:14:13.211
GC-202206-NYMEX [C] Daily #3 | File GC-198504-NYMEX.dly has a volume of 0 at 1985-03-27. | 2022-04-25 10:14:13.211
GC-202206-NYMEX [C] Daily #3 | File GC-198502-NYMEX.dly has a volume of 0 at 1984-11-29. | 2022-04-25 10:14:13.221
GC-202206-NYMEX [C] Daily #3 | File GC-198502-NYMEX.dly has a volume of 0 at 1985-01-29. | 2022-04-25 10:14:13.221
GC-202206-NYMEX [C] Daily #3 | File GC-198412-NYMEX.dly has a volume of 0 at 1984-07-30. | 2022-04-25 10:14:13.238
GC-202206-NYMEX [C] Daily #3 | File GC-198412-NYMEX.dly has a volume of 0 at 1984-11-28. | 2022-04-25 10:14:13.238
GC-202206-NYMEX [C] Daily #3 | File GC-198408-NYMEX.dly has a volume of 0 at 1984-05-30. | 2022-04-25 10:14:13.249
GC-202206-NYMEX [C] Daily #3 | File GC-198408-NYMEX.dly has a volume of 0 at 1984-07-27. | 2022-04-25 10:14:13.249
GC-202206-NYMEX [C] Daily #3 | File GC-198406-NYMEX.dly has a volume of 0 at 1984-03-29. | 2022-04-25 10:14:13.260
GC-202206-NYMEX [C] Daily #3 | File GC-198406-NYMEX.dly has a volume of 0 at 1984-05-29. | 2022-04-25 10:14:13.260
GC-202206-NYMEX [C] Daily #3 | File GC-198404-NYMEX.dly has a volume of 0 at 1984-01-30. | 2022-04-25 10:14:13.270
GC-202206-NYMEX [C] Daily #3 | File GC-198404-NYMEX.dly has a volume of 0 at 1984-03-28. | 2022-04-25 10:14:13.270
GC-202206-NYMEX [C] Daily #3 | File GC-198402-NYMEX.dly has a volume of 0 at 1983-11-29. | 2022-04-25 10:14:13.281
GC-202206-NYMEX [C] Daily #3 | File GC-198402-NYMEX.dly has a volume of 0 at 1984-01-27. | 2022-04-25 10:14:13.281
GC-202206-NYMEX [C] Daily #3 | File GC-198312-NYMEX.dly has a volume of 0 at 1983-07-28. | 2022-04-25 10:14:13.298
GC-202206-NYMEX [C] Daily #3 | File GC-198312-NYMEX.dly has a volume of 0 at 1983-11-28. | 2022-04-25 10:14:13.298
GC-202206-NYMEX [C] Daily #3 | File GC-198308-NYMEX.dly has a volume of 0 at 1983-05-30. | 2022-04-25 10:14:13.309
GC-202206-NYMEX [C] Daily #3 | File GC-198308-NYMEX.dly has a volume of 0 at 1983-07-27. | 2022-04-25 10:14:13.309
GC-202206-NYMEX [C] Daily #3 | File GC-198306-NYMEX.dly has a volume of 0 at 1983-03-30. | 2022-04-25 10:14:13.320
GC-202206-NYMEX [C] Daily #3 | File GC-198306-NYMEX.dly has a volume of 0 at 1983-05-27. | 2022-04-25 10:14:13.320
GC-202206-NYMEX [C] Daily #3 | File GC-198304-NYMEX.dly has a volume of 0 at 1983-01-28. | 2022-04-25 10:14:13.330
GC-202206-NYMEX [C] Daily #3 | File GC-198304-NYMEX.dly has a volume of 0 at 1983-03-29. | 2022-04-25 10:14:13.330
GC-202206-NYMEX [C] Daily #3 | File GC-198302-NYMEX.dly has a volume of 0 at 1982-11-29. | 2022-04-25 10:14:13.340
GC-202206-NYMEX [C] Daily #3 | File GC-198302-NYMEX.dly has a volume of 0 at 1983-01-27. | 2022-04-25 10:14:13.340
GC-202206-NYMEX [C] Daily #3 | File GC-198212-NYMEX.dly has a volume of 0 at 1982-07-29. | 2022-04-25 10:14:13.357
GC-202206-NYMEX [C] Daily #3 | File GC-198212-NYMEX.dly has a volume of 0 at 1982-11-26. | 2022-04-25 10:14:13.357
GC-202206-NYMEX [C] Daily #3 | File GC-198208-NYMEX.dly has a volume of 0 at 1982-05-28. | 2022-04-25 10:14:13.368
GC-202206-NYMEX [C] Daily #3 | File GC-198208-NYMEX.dly has a volume of 0 at 1982-07-28. | 2022-04-25 10:14:13.368
GC-202206-NYMEX [C] Daily #3 | File GC-198206-NYMEX.dly has a volume of 0 at 1982-03-30. | 2022-04-25 10:14:13.378
GC-202206-NYMEX [C] Daily #3 | File GC-198206-NYMEX.dly has a volume of 0 at 1982-05-27. | 2022-04-25 10:14:13.378
GC-202206-NYMEX [C] Daily #3 | File GC-198204-NYMEX.dly has a volume of 0 at 1982-01-28. | 2022-04-25 10:14:13.390
GC-202206-NYMEX [C] Daily #3 | File GC-198204-NYMEX.dly has a volume of 0 at 1982-03-29. | 2022-04-25 10:14:13.390
GC-202206-NYMEX [C] Daily #3 | File GC-198202-NYMEX.dly has a volume of 0 at 1981-11-27. | 2022-04-25 10:14:13.400
GC-202206-NYMEX [C] Daily #3 | File GC-198202-NYMEX.dly has a volume of 0 at 1982-01-27. | 2022-04-25 10:14:13.400
GC-202206-NYMEX [C] Daily #3 | File GC-198112-NYMEX.dly has a volume of 0 at 1981-07-30. | 2022-04-25 10:14:13.417
GC-202206-NYMEX [C] Daily #3 | File GC-198112-NYMEX.dly has a volume of 0 at 1981-11-26. | 2022-04-25 10:14:13.417
GC-202206-NYMEX [C] Daily #3 | File GC-198108-NYMEX.dly has a volume of 0 at 1981-05-28. | 2022-04-25 10:14:13.428
GC-202206-NYMEX [C] Daily #3 | File GC-198108-NYMEX.dly has a volume of 0 at 1981-07-29. | 2022-04-25 10:14:13.428
GC-202206-NYMEX [C] Daily #3 | File GC-198106-NYMEX.dly has a volume of 0 at 1981-03-30. | 2022-04-25 10:14:13.439
GC-202206-NYMEX [C] Daily #3 | File GC-198106-NYMEX.dly has a volume of 0 at 1981-05-27. | 2022-04-25 10:14:13.439
GC-202206-NYMEX [C] Daily #3 | File GC-198104-NYMEX.dly has a volume of 0 at 1981-01-29. | 2022-04-25 10:14:13.449
GC-202206-NYMEX [C] Daily #3 | File GC-198104-NYMEX.dly has a volume of 0 at 1981-03-27. | 2022-04-25 10:14:13.449
GC-202206-NYMEX [C] Daily #3 | File GC-198102-NYMEX.dly has a volume of 0 at 1980-11-27. | 2022-04-25 10:14:13.459
GC-202206-NYMEX [C] Daily #3 | File GC-198102-NYMEX.dly has a volume of 0 at 1981-01-28. | 2022-04-25 10:14:13.459
GC-202206-NYMEX [C] Daily #3 | File GC-198012-NYMEX.dly has a volume of 0 at 1980-07-30. | 2022-04-25 10:14:13.476
GC-202206-NYMEX [C] Daily #3 | File GC-198012-NYMEX.dly has a volume of 0 at 1980-11-26. | 2022-04-25 10:14:13.476
GC-202206-NYMEX [C] Daily #3 | File GC-198008-NYMEX.dly has a volume of 0 at 1980-05-29. | 2022-04-25 10:14:13.487
GC-202206-NYMEX [C] Daily #3 | File GC-198008-NYMEX.dly has a volume of 0 at 1980-07-29. | 2022-04-25 10:14:13.487
GC-202206-NYMEX [C] Daily #3 | File GC-198006-NYMEX.dly has a volume of 0 at 1980-03-28. | 2022-04-25 10:14:13.497
GC-202206-NYMEX [C] Daily #3 | File GC-198006-NYMEX.dly has a volume of 0 at 1980-05-28. | 2022-04-25 10:14:13.497
GC-202206-NYMEX [C] Daily #3 | File GC-198004-NYMEX.dly has a volume of 0 at 1980-01-30. | 2022-04-25 10:14:13.508
GC-202206-NYMEX [C] Daily #3 | File GC-198004-NYMEX.dly has a volume of 0 at 1980-03-27. | 2022-04-25 10:14:13.508
GC-202206-NYMEX [C] Daily #3 | File GC-198002-NYMEX.dly has a volume of 0 at 1979-11-29. | 2022-04-25 10:14:13.518
GC-202206-NYMEX [C] Daily #3 | File GC-198002-NYMEX.dly has a volume of 0 at 1980-01-29. | 2022-04-25 10:14:13.518
GC-202206-NYMEX [C] Daily #3 | File GC-197912-NYMEX.dly has a volume of 0 at 1979-07-30. | 2022-04-25 10:14:13.535
GC-202206-NYMEX [C] Daily #3 | File GC-197912-NYMEX.dly has a volume of 0 at 1979-11-28. | 2022-04-25 10:14:13.535
GC-202206-NYMEX [C] Daily #3 | File GC-197908-NYMEX.dly has a volume of 0 at 1979-05-30. | 2022-04-25 10:14:13.546
GC-202206-NYMEX [C] Daily #3 | File GC-197908-NYMEX.dly has a volume of 0 at 1979-07-27. | 2022-04-25 10:14:13.546
GC-202206-NYMEX [C] Daily #3 | File GC-197906-NYMEX.dly has a volume of 0 at 1979-03-29. | 2022-04-25 10:14:13.557
GC-202206-NYMEX [C] Daily #3 | File GC-197906-NYMEX.dly has a volume of 0 at 1979-05-29. | 2022-04-25 10:14:13.557
GC-202206-NYMEX [C] Daily #3 | File GC-197904-NYMEX.dly has a volume of 0 at 1979-01-30. | 2022-04-25 10:14:13.567
GC-202206-NYMEX [C] Daily #3 | File GC-197904-NYMEX.dly has a volume of 0 at 1979-03-28. | 2022-04-25 10:14:13.567
GC-202206-NYMEX [C] Daily #3 | File GC-197902-NYMEX.dly has a volume of 0 at 1978-11-29. | 2022-04-25 10:14:13.577
GC-202206-NYMEX [C] Daily #3 | File GC-197902-NYMEX.dly has a volume of 0 at 1979-01-29. | 2022-04-25 10:14:13.577
GC-202206-NYMEX [C] Daily #3 | File GC-197812-NYMEX.dly has a volume of 0 at 1978-07-28. | 2022-04-25 10:14:13.608
GC-202206-NYMEX [C] Daily #3 | File GC-197812-NYMEX.dly has a volume of 0 at 1978-11-28. | 2022-04-25 10:14:13.608
GC-202206-NYMEX [C] Daily #3 | File GC-197808-NYMEX.dly has a volume of 0 at 1978-05-30. | 2022-04-25 10:14:13.619
GC-202206-NYMEX [C] Daily #3 | File GC-197808-NYMEX.dly has a volume of 0 at 1978-07-27. | 2022-04-25 10:14:13.619
GC-202206-NYMEX [C] Daily #3 | File GC-197806-NYMEX.dly has a volume of 0 at 1978-03-30. | 2022-04-25 10:14:13.630
GC-202206-NYMEX [C] Daily #3 | File GC-197806-NYMEX.dly has a volume of 0 at 1978-05-29. | 2022-04-25 10:14:13.630
GC-202206-NYMEX [C] Daily #3 | File GC-197804-NYMEX.dly has a volume of 0 at 1978-01-30. | 2022-04-25 10:14:13.640
GC-202206-NYMEX [C] Daily #3 | File GC-197804-NYMEX.dly has a volume of 0 at 1978-03-29. | 2022-04-25 10:14:13.640
GC-202206-NYMEX [C] Daily #3 | File GC-197802-NYMEX.dly has a volume of 0 at 1977-11-29. | 2022-04-25 10:14:13.650
GC-202206-NYMEX [C] Daily #3 | File GC-197802-NYMEX.dly has a volume of 0 at 1978-01-27. | 2022-04-25 10:14:13.650
GC-202206-NYMEX [C] Daily #3 | File GC-197712-NYMEX.dly has a volume of 0 at 1977-07-28. | 2022-04-25 10:14:13.668
GC-202206-NYMEX [C] Daily #3 | File GC-197712-NYMEX.dly has a volume of 0 at 1977-11-28. | 2022-04-25 10:14:13.668
GC-202206-NYMEX [C] Daily #3 | File GC-197708-NYMEX.dly has a volume of 0 at 1977-05-30. | 2022-04-25 10:14:13.679
GC-202206-NYMEX [C] Daily #3 | File GC-197708-NYMEX.dly has a volume of 0 at 1977-07-27. | 2022-04-25 10:14:13.679
GC-202206-NYMEX [C] Daily #3 | File GC-197706-NYMEX.dly has a volume of 0 at 1977-03-30. | 2022-04-25 10:14:13.690
GC-202206-NYMEX [C] Daily #3 | File GC-197706-NYMEX.dly has a volume of 0 at 1977-05-27. | 2022-04-25 10:14:13.690
GC-202206-NYMEX [C] Daily #3 | File GC-197704-NYMEX.dly has a volume of 0 at 1977-01-28. | 2022-04-25 10:14:13.701
GC-202206-NYMEX [C] Daily #3 | File GC-197704-NYMEX.dly has a volume of 0 at 1977-03-29. | 2022-04-25 10:14:13.701
GC-202206-NYMEX [C] Daily #3 | File GC-197702-NYMEX.dly has a volume of 0 at 1976-11-29. | 2022-04-25 10:14:13.711
GC-202206-NYMEX [C] Daily #3 | File GC-197702-NYMEX.dly has a volume of 0 at 1977-01-27. | 2022-04-25 10:14:13.711
GC-202206-NYMEX [C] Daily #3 | File GC-197612-NYMEX.dly has a volume of 0 at 1976-07-29. | 2022-04-25 10:14:13.728
GC-202206-NYMEX [C] Daily #3 | File GC-197612-NYMEX.dly has a volume of 0 at 1976-11-26. | 2022-04-25 10:14:13.728
GC-202206-NYMEX [C] Daily #3 | File GC-197608-NYMEX.dly has a volume of 0 at 1976-05-28. | 2022-04-25 10:14:13.739
GC-202206-NYMEX [C] Daily #3 | File GC-197608-NYMEX.dly has a volume of 0 at 1976-07-28. | 2022-04-25 10:14:13.739
GC-202206-NYMEX [C] Daily #3 | File GC-197606-NYMEX.dly has a volume of 0 at 1976-03-30. | 2022-04-25 10:14:13.750
GC-202206-NYMEX [C] Daily #3 | File GC-197606-NYMEX.dly has a volume of 0 at 1976-05-27. | 2022-04-25 10:14:13.750
GC-202206-NYMEX [C] Daily #3 | File GC-197604-NYMEX.dly has a volume of 0 at 1976-01-29. | 2022-04-25 10:14:13.760
GC-202206-NYMEX [C] Daily #3 | File GC-197604-NYMEX.dly has a volume of 0 at 1976-03-29. | 2022-04-25 10:14:13.760
GC-202206-NYMEX [C] Daily #3 | File GC-197602-NYMEX.dly has a volume of 0 at 1975-11-27. | 2022-04-25 10:14:13.770
GC-202206-NYMEX [C] Daily #3 | File GC-197602-NYMEX.dly has a volume of 0 at 1976-01-28. | 2022-04-25 10:14:13.770
GC-202206-NYMEX [C] Daily #3 | File GC-197512-NYMEX.dly has a volume of 0 at 1975-07-30. | 2022-04-25 10:14:13.787
GC-202206-NYMEX [C] Daily #3 | File GC-197512-NYMEX.dly has a volume of 0 at 1975-11-26. | 2022-04-25 10:14:13.787
GC-202206-NYMEX [C] Daily #3 | File GC-197508-NYMEX.dly has a volume of 0 at 1975-05-29. | 2022-04-25 10:14:13.798
GC-202206-NYMEX [C] Daily #3 | File GC-197508-NYMEX.dly has a volume of 0 at 1975-07-29. | 2022-04-25 10:14:13.798
GC-202206-NYMEX [C] Daily #3 | File GC-197506-NYMEX.dly has a volume of 0 at 1975-03-28. | 2022-04-25 10:14:13.809
GC-202206-NYMEX [C] Daily #3 | File GC-197506-NYMEX.dly has a volume of 0 at 1975-05-28. | 2022-04-25 10:14:13.809
GC-202206-NYMEX [C] Daily #3 | File GC-197504-NYMEX.dly has a volume of 0 at 1975-01-30. | 2022-04-25 10:14:13.819
GC-202206-NYMEX [C] Daily #3 | File GC-197504-NYMEX.dly has a volume of 0 at 1975-03-27. | 2022-04-25 10:14:13.819
GC-202206-NYMEX [C] Daily #3 | Dates not found while checking for invalid data in continuous contract data files. GC-197502-NYMEX | 2022-04-25 10:14:13.826 *
GC-202206-NYMEX [C] Daily #3 | Waiting for historical downloads to complete with the IDs: 20, 21, | 2022-04-25 10:14:13.826
GC-202206-NYMEX [C] 4 Day #4 | Reloading chart. | 2022-04-25 10:14:13.837
GC-202206-NYMEX [C] 4 Day #4 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:13.837
GC-202206-NYMEX [C] 4 Day #4 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:13.837
GC-202206-NYMEX [C] 4 Day #4 | File GC-200102-NYMEX.dly has a volume of 0 at 2000-11-29. | 2022-04-25 10:14:15.507
GC-202206-NYMEX [C] 4 Day #4 | File GC-200012-NYMEX.dly has a volume of 0 at 2000-07-28. | 2022-04-25 10:14:15.524
GC-202206-NYMEX [C] 4 Day #4 | File GC-200012-NYMEX.dly has a volume of 0 at 2000-11-28. | 2022-04-25 10:14:15.524
GC-202206-NYMEX [C] 4 Day #4 | File GC-200008-NYMEX.dly has a volume of 0 at 2000-05-30. | 2022-04-25 10:14:15.535
GC-202206-NYMEX [C] 4 Day #4 | File GC-200008-NYMEX.dly has a volume of 0 at 2000-07-27. | 2022-04-25 10:14:15.535
GC-202206-NYMEX [C] 4 Day #4 | File GC-200006-NYMEX.dly has a volume of 0 at 2000-03-30. | 2022-04-25 10:14:15.546
GC-202206-NYMEX [C] 4 Day #4 | File GC-200006-NYMEX.dly has a volume of 0 at 2000-05-29. | 2022-04-25 10:14:15.546
GC-202206-NYMEX [C] 4 Day #4 | File GC-200004-NYMEX.dly has a volume of 0 at 2000-01-28. | 2022-04-25 10:14:15.556
GC-202206-NYMEX [C] 4 Day #4 | File GC-200004-NYMEX.dly has a volume of 0 at 2000-03-29. | 2022-04-25 10:14:15.556
GC-202206-NYMEX [C] 4 Day #4 | File GC-200002-NYMEX.dly has a volume of 0 at 1999-11-29. | 2022-04-25 10:14:15.566
GC-202206-NYMEX [C] 4 Day #4 | File GC-200002-NYMEX.dly has a volume of 0 at 2000-01-27. | 2022-04-25 10:14:15.566
GC-202206-NYMEX [C] 4 Day #4 | File GC-199912-NYMEX.dly has a volume of 0 at 1999-07-29. | 2022-04-25 10:14:15.584
GC-202206-NYMEX [C] 4 Day #4 | File GC-199912-NYMEX.dly has a volume of 0 at 1999-11-26. | 2022-04-25 10:14:15.584
GC-202206-NYMEX [C] 4 Day #4 | File GC-199908-NYMEX.dly has a volume of 0 at 1999-05-28. | 2022-04-25 10:14:15.595
GC-202206-NYMEX [C] 4 Day #4 | File GC-199908-NYMEX.dly has a volume of 0 at 1999-07-28. | 2022-04-25 10:14:15.595
GC-202206-NYMEX [C] 4 Day #4 | File GC-199906-NYMEX.dly has a volume of 0 at 1999-03-30. | 2022-04-25 10:14:15.605
GC-202206-NYMEX [C] 4 Day #4 | File GC-199906-NYMEX.dly has a volume of 0 at 1999-05-27. | 2022-04-25 10:14:15.605
GC-202206-NYMEX [C] 4 Day #4 | File GC-199904-NYMEX.dly has a volume of 0 at 1999-01-28. | 2022-04-25 10:14:15.616
GC-202206-NYMEX [C] 4 Day #4 | File GC-199904-NYMEX.dly has a volume of 0 at 1999-03-29. | 2022-04-25 10:14:15.616
GC-202206-NYMEX [C] 4 Day #4 | File GC-199902-NYMEX.dly has a volume of 0 at 1998-11-27. | 2022-04-25 10:14:15.626
GC-202206-NYMEX [C] 4 Day #4 | File GC-199902-NYMEX.dly has a volume of 0 at 1999-01-27. | 2022-04-25 10:14:15.626
GC-202206-NYMEX [C] 4 Day #4 | File GC-199812-NYMEX.dly has a volume of 0 at 1998-07-30. | 2022-04-25 10:14:15.643
GC-202206-NYMEX [C] 4 Day #4 | File GC-199812-NYMEX.dly has a volume of 0 at 1998-11-26. | 2022-04-25 10:14:15.643
GC-202206-NYMEX [C] 4 Day #4 | File GC-199808-NYMEX.dly has a volume of 0 at 1998-05-28. | 2022-04-25 10:14:15.654
GC-202206-NYMEX [C] 4 Day #4 | File GC-199808-NYMEX.dly has a volume of 0 at 1998-07-29. | 2022-04-25 10:14:15.654
GC-202206-NYMEX [C] 4 Day #4 | File GC-199806-NYMEX.dly has a volume of 0 at 1998-03-30. | 2022-04-25 10:14:15.665
GC-202206-NYMEX [C] 4 Day #4 | File GC-199806-NYMEX.dly has a volume of 0 at 1998-05-27. | 2022-04-25 10:14:15.665
GC-202206-NYMEX [C] 4 Day #4 | File GC-199804-NYMEX.dly has a volume of 0 at 1998-01-29. | 2022-04-25 10:14:15.675
GC-202206-NYMEX [C] 4 Day #4 | File GC-199804-NYMEX.dly has a volume of 0 at 1998-03-27. | 2022-04-25 10:14:15.675
GC-202206-NYMEX [C] 4 Day #4 | File GC-199802-NYMEX.dly has a volume of 0 at 1997-11-27. | 2022-04-25 10:14:15.686
GC-202206-NYMEX [C] 4 Day #4 | File GC-199802-NYMEX.dly has a volume of 0 at 1998-01-28. | 2022-04-25 10:14:15.686
GC-202206-NYMEX [C] 4 Day #4 | File GC-199712-NYMEX.dly has a volume of 0 at 1997-07-30. | 2022-04-25 10:14:15.703
GC-202206-NYMEX [C] 4 Day #4 | File GC-199712-NYMEX.dly has a volume of 0 at 1997-11-26. | 2022-04-25 10:14:15.703
GC-202206-NYMEX [C] 4 Day #4 | File GC-199708-NYMEX.dly has a volume of 0 at 1997-05-29. | 2022-04-25 10:14:15.713
GC-202206-NYMEX [C] 4 Day #4 | File GC-199708-NYMEX.dly has a volume of 0 at 1997-07-29. | 2022-04-25 10:14:15.713
GC-202206-NYMEX [C] 4 Day #4 | File GC-199706-NYMEX.dly has a volume of 0 at 1997-03-28. | 2022-04-25 10:14:15.724
GC-202206-NYMEX [C] 4 Day #4 | File GC-199706-NYMEX.dly has a volume of 0 at 1997-05-28. | 2022-04-25 10:14:15.724
GC-202206-NYMEX [C] 4 Day #4 | File GC-199704-NYMEX.dly has a volume of 0 at 1997-01-30. | 2022-04-25 10:14:15.735
GC-202206-NYMEX [C] 4 Day #4 | File GC-199704-NYMEX.dly has a volume of 0 at 1997-03-27. | 2022-04-25 10:14:15.735
GC-202206-NYMEX [C] 4 Day #4 | File GC-199702-NYMEX.dly has a volume of 0 at 1996-11-28. | 2022-04-25 10:14:15.745
GC-202206-NYMEX [C] 4 Day #4 | File GC-199702-NYMEX.dly has a volume of 0 at 1997-01-29. | 2022-04-25 10:14:15.745
GC-202206-NYMEX [C] 4 Day #4 | File GC-199612-NYMEX.dly has a volume of 0 at 1996-07-30. | 2022-04-25 10:14:15.762
GC-202206-NYMEX [C] 4 Day #4 | File GC-199612-NYMEX.dly has a volume of 0 at 1996-11-27. | 2022-04-25 10:14:15.762
GC-202206-NYMEX [C] 4 Day #4 | File GC-199608-NYMEX.dly has a volume of 0 at 1996-05-30. | 2022-04-25 10:14:15.773
GC-202206-NYMEX [C] 4 Day #4 | File GC-199608-NYMEX.dly has a volume of 0 at 1996-07-29. | 2022-04-25 10:14:15.773
GC-202206-NYMEX [C] 4 Day #4 | File GC-199606-NYMEX.dly has a volume of 0 at 1996-03-28. | 2022-04-25 10:14:15.784
GC-202206-NYMEX [C] 4 Day #4 | File GC-199606-NYMEX.dly has a volume of 0 at 1996-05-29. | 2022-04-25 10:14:15.784
GC-202206-NYMEX [C] 4 Day #4 | File GC-199604-NYMEX.dly has a volume of 0 at 1996-01-30. | 2022-04-25 10:14:15.795
GC-202206-NYMEX [C] 4 Day #4 | File GC-199604-NYMEX.dly has a volume of 0 at 1996-03-27. | 2022-04-25 10:14:15.795
GC-202206-NYMEX [C] 4 Day #4 | File GC-199602-NYMEX.dly has a volume of 0 at 1995-11-29. | 2022-04-25 10:14:15.805
GC-202206-NYMEX [C] 4 Day #4 | File GC-199602-NYMEX.dly has a volume of 0 at 1996-01-29. | 2022-04-25 10:14:15.805
GC-202206-NYMEX [C] 4 Day #4 | File GC-199512-NYMEX.dly has a volume of 0 at 1995-07-28. | 2022-04-25 10:14:15.822
GC-202206-NYMEX [C] 4 Day #4 | File GC-199512-NYMEX.dly has a volume of 0 at 1995-11-28. | 2022-04-25 10:14:15.822
GC-202206-NYMEX [C] 4 Day #4 | File GC-199508-NYMEX.dly has a volume of 0 at 1995-05-30. | 2022-04-25 10:14:15.833
GC-202206-NYMEX [C] 4 Day #4 | File GC-199508-NYMEX.dly has a volume of 0 at 1995-07-27. | 2022-04-25 10:14:15.833
GC-202206-NYMEX [C] 4 Day #4 | File GC-199506-NYMEX.dly has a volume of 0 at 1995-03-30. | 2022-04-25 10:14:15.844
GC-202206-NYMEX [C] 4 Day #4 | File GC-199506-NYMEX.dly has a volume of 0 at 1995-05-29. | 2022-04-25 10:14:15.844
GC-202206-NYMEX [C] 4 Day #4 | File GC-199504-NYMEX.dly has a volume of 0 at 1995-01-30. | 2022-04-25 10:14:15.854
GC-202206-NYMEX [C] 4 Day #4 | File GC-199504-NYMEX.dly has a volume of 0 at 1995-03-29. | 2022-04-25 10:14:15.854
GC-202206-NYMEX [C] 4 Day #4 | File GC-199502-NYMEX.dly has a volume of 0 at 1994-11-29. | 2022-04-25 10:14:15.865
GC-202206-NYMEX [C] 4 Day #4 | File GC-199502-NYMEX.dly has a volume of 0 at 1995-01-27. | 2022-04-25 10:14:15.865
GC-202206-NYMEX [C] 4 Day #4 | File GC-199412-NYMEX.dly has a volume of 0 at 1994-07-28. | 2022-04-25 10:14:15.882
GC-202206-NYMEX [C] 4 Day #4 | File GC-199412-NYMEX.dly has a volume of 0 at 1994-11-28. | 2022-04-25 10:14:15.882
GC-202206-NYMEX [C] 4 Day #4 | File GC-199408-NYMEX.dly has a volume of 0 at 1994-05-30. | 2022-04-25 10:14:15.893
GC-202206-NYMEX [C] 4 Day #4 | File GC-199408-NYMEX.dly has a volume of 0 at 1994-07-27. | 2022-04-25 10:14:15.893
GC-202206-NYMEX [C] 4 Day #4 | File GC-199406-NYMEX.dly has a volume of 0 at 1994-03-30. | 2022-04-25 10:14:15.903
GC-202206-NYMEX [C] 4 Day #4 | File GC-199406-NYMEX.dly has a volume of 0 at 1994-05-27. | 2022-04-25 10:14:15.903
GC-202206-NYMEX [C] 4 Day #4 | File GC-199404-NYMEX.dly has a volume of 0 at 1994-01-28. | 2022-04-25 10:14:15.914
GC-202206-NYMEX [C] 4 Day #4 | File GC-199404-NYMEX.dly has a volume of 0 at 1994-03-29. | 2022-04-25 10:14:15.914
GC-202206-NYMEX [C] 4 Day #4 | File GC-199402-NYMEX.dly has a volume of 0 at 1993-11-29. | 2022-04-25 10:14:15.924
GC-202206-NYMEX [C] 4 Day #4 | File GC-199402-NYMEX.dly has a volume of 0 at 1994-01-27. | 2022-04-25 10:14:15.924
GC-202206-NYMEX [C] 4 Day #4 | File GC-199312-NYMEX.dly has a volume of 0 at 1993-07-29. | 2022-04-25 10:14:15.941
GC-202206-NYMEX [C] 4 Day #4 | File GC-199312-NYMEX.dly has a volume of 0 at 1993-11-26. | 2022-04-25 10:14:15.941
GC-202206-NYMEX [C] 4 Day #4 | File GC-199308-NYMEX.dly has a volume of 0 at 1993-05-28. | 2022-04-25 10:14:15.952
GC-202206-NYMEX [C] 4 Day #4 | File GC-199308-NYMEX.dly has a volume of 0 at 1993-07-28. | 2022-04-25 10:14:15.952
GC-202206-NYMEX [C] 4 Day #4 | File GC-199306-NYMEX.dly has a volume of 0 at 1993-03-30. | 2022-04-25 10:14:15.963
GC-202206-NYMEX [C] 4 Day #4 | File GC-199306-NYMEX.dly has a volume of 0 at 1993-05-27. | 2022-04-25 10:14:15.963
GC-202206-NYMEX [C] 4 Day #4 | File GC-199304-NYMEX.dly has a volume of 0 at 1993-01-28. | 2022-04-25 10:14:15.974
GC-202206-NYMEX [C] 4 Day #4 | File GC-199304-NYMEX.dly has a volume of 0 at 1993-03-29. | 2022-04-25 10:14:15.974
GC-202206-NYMEX [C] 4 Day #4 | File GC-199302-NYMEX.dly has a volume of 0 at 1992-11-27. | 2022-04-25 10:14:15.984
GC-202206-NYMEX [C] 4 Day #4 | File GC-199302-NYMEX.dly has a volume of 0 at 1993-01-27. | 2022-04-25 10:14:15.984
GC-202206-NYMEX [C] 4 Day #4 | File GC-199212-NYMEX.dly has a volume of 0 at 1992-07-30. | 2022-04-25 10:14:16.001
GC-202206-NYMEX [C] 4 Day #4 | File GC-199212-NYMEX.dly has a volume of 0 at 1992-11-26. | 2022-04-25 10:14:16.001
GC-202206-NYMEX [C] 4 Day #4 | File GC-199208-NYMEX.dly has a volume of 0 at 1992-05-28. | 2022-04-25 10:14:16.012
GC-202206-NYMEX [C] 4 Day #4 | File GC-199208-NYMEX.dly has a volume of 0 at 1992-07-29. | 2022-04-25 10:14:16.012
GC-202206-NYMEX [C] 4 Day #4 | File GC-199206-NYMEX.dly has a volume of 0 at 1992-03-30. | 2022-04-25 10:14:16.023
GC-202206-NYMEX [C] 4 Day #4 | File GC-199206-NYMEX.dly has a volume of 0 at 1992-05-27. | 2022-04-25 10:14:16.023
GC-202206-NYMEX [C] 4 Day #4 | File GC-199204-NYMEX.dly has a volume of 0 at 1992-01-30. | 2022-04-25 10:14:16.033
GC-202206-NYMEX [C] 4 Day #4 | File GC-199204-NYMEX.dly has a volume of 0 at 1992-03-27. | 2022-04-25 10:14:16.033
GC-202206-NYMEX [C] 4 Day #4 | File GC-199202-NYMEX.dly has a volume of 0 at 1991-11-28. | 2022-04-25 10:14:16.044
GC-202206-NYMEX [C] 4 Day #4 | File GC-199202-NYMEX.dly has a volume of 0 at 1992-01-29. | 2022-04-25 10:14:16.044
GC-202206-NYMEX [C] 4 Day #4 | File GC-199112-NYMEX.dly has a volume of 0 at 1991-07-30. | 2022-04-25 10:14:16.061
GC-202206-NYMEX [C] 4 Day #4 | File GC-199112-NYMEX.dly has a volume of 0 at 1991-11-27. | 2022-04-25 10:14:16.061
GC-202206-NYMEX [C] 4 Day #4 | File GC-199108-NYMEX.dly has a volume of 0 at 1991-05-30. | 2022-04-25 10:14:16.072
GC-202206-NYMEX [C] 4 Day #4 | File GC-199108-NYMEX.dly has a volume of 0 at 1991-07-29. | 2022-04-25 10:14:16.072
GC-202206-NYMEX [C] 4 Day #4 | File GC-199106-NYMEX.dly has a volume of 0 at 1991-03-28. | 2022-04-25 10:14:16.083
GC-202206-NYMEX [C] 4 Day #4 | File GC-199106-NYMEX.dly has a volume of 0 at 1991-05-29. | 2022-04-25 10:14:16.083
GC-202206-NYMEX [C] 4 Day #4 | File GC-199104-NYMEX.dly has a volume of 0 at 1991-01-30. | 2022-04-25 10:14:16.093
GC-202206-NYMEX [C] 4 Day #4 | File GC-199104-NYMEX.dly has a volume of 0 at 1991-03-27. | 2022-04-25 10:14:16.093
GC-202206-NYMEX [C] 4 Day #4 | File GC-199102-NYMEX.dly has a volume of 0 at 1990-11-29. | 2022-04-25 10:14:16.103
GC-202206-NYMEX [C] 4 Day #4 | File GC-199102-NYMEX.dly has a volume of 0 at 1991-01-29. | 2022-04-25 10:14:16.103
GC-202206-NYMEX [C] 4 Day #4 | File GC-199012-NYMEX.dly has a volume of 0 at 1990-07-30. | 2022-04-25 10:14:16.120
GC-202206-NYMEX [C] 4 Day #4 | File GC-199012-NYMEX.dly has a volume of 0 at 1990-11-28. | 2022-04-25 10:14:16.120
GC-202206-NYMEX [C] 4 Day #4 | File GC-199008-NYMEX.dly has a volume of 0 at 1990-05-30. | 2022-04-25 10:14:16.131
GC-202206-NYMEX [C] 4 Day #4 | File GC-199008-NYMEX.dly has a volume of 0 at 1990-07-27. | 2022-04-25 10:14:16.131
GC-202206-NYMEX [C] 4 Day #4 | File GC-199006-NYMEX.dly has a volume of 0 at 1990-03-29. | 2022-04-25 10:14:16.142
GC-202206-NYMEX [C] 4 Day #4 | File GC-199006-NYMEX.dly has a volume of 0 at 1990-05-29. | 2022-04-25 10:14:16.142
GC-202206-NYMEX [C] 4 Day #4 | File GC-199004-NYMEX.dly has a volume of 0 at 1990-01-30. | 2022-04-25 10:14:16.153
GC-202206-NYMEX [C] 4 Day #4 | File GC-199004-NYMEX.dly has a volume of 0 at 1990-03-28. | 2022-04-25 10:14:16.153
GC-202206-NYMEX [C] 4 Day #4 | File GC-199002-NYMEX.dly has a volume of 0 at 1989-11-29. | 2022-04-25 10:14:16.163
GC-202206-NYMEX [C] 4 Day #4 | File GC-199002-NYMEX.dly has a volume of 0 at 1990-01-29. | 2022-04-25 10:14:16.163
GC-202206-NYMEX [C] 4 Day #4 | File GC-198912-NYMEX.dly has a volume of 0 at 1989-07-28. | 2022-04-25 10:14:16.180
GC-202206-NYMEX [C] 4 Day #4 | File GC-198912-NYMEX.dly has a volume of 0 at 1989-11-28. | 2022-04-25 10:14:16.180
GC-202206-NYMEX [C] 4 Day #4 | File GC-198908-NYMEX.dly has a volume of 0 at 1989-05-30. | 2022-04-25 10:14:16.191
GC-202206-NYMEX [C] 4 Day #4 | File GC-198908-NYMEX.dly has a volume of 0 at 1989-07-27. | 2022-04-25 10:14:16.191
GC-202206-NYMEX [C] 4 Day #4 | File GC-198906-NYMEX.dly has a volume of 0 at 1989-03-30. | 2022-04-25 10:14:16.202
GC-202206-NYMEX [C] 4 Day #4 | File GC-198906-NYMEX.dly has a volume of 0 at 1989-05-29. | 2022-04-25 10:14:16.202
GC-202206-NYMEX [C] 4 Day #4 | File GC-198904-NYMEX.dly has a volume of 0 at 1989-01-30. | 2022-04-25 10:14:16.212
GC-202206-NYMEX [C] 4 Day #4 | File GC-198904-NYMEX.dly has a volume of 0 at 1989-03-29. | 2022-04-25 10:14:16.212
GC-202206-NYMEX [C] 4 Day #4 | File GC-198902-NYMEX.dly has a volume of 0 at 1988-11-29. | 2022-04-25 10:14:16.223
GC-202206-NYMEX [C] 4 Day #4 | File GC-198902-NYMEX.dly has a volume of 0 at 1989-01-27. | 2022-04-25 10:14:16.223
GC-202206-NYMEX [C] 4 Day #4 | File GC-198812-NYMEX.dly has a volume of 0 at 1988-07-28. | 2022-04-25 10:14:16.240
GC-202206-NYMEX [C] 4 Day #4 | File GC-198812-NYMEX.dly has a volume of 0 at 1988-11-28. | 2022-04-25 10:14:16.240
GC-202206-NYMEX [C] 4 Day #4 | File GC-198808-NYMEX.dly has a volume of 0 at 1988-05-30. | 2022-04-25 10:14:16.251
GC-202206-NYMEX [C] 4 Day #4 | File GC-198808-NYMEX.dly has a volume of 0 at 1988-07-27. | 2022-04-25 10:14:16.251
GC-202206-NYMEX [C] 4 Day #4 | File GC-198806-NYMEX.dly has a volume of 0 at 1988-03-30. | 2022-04-25 10:14:16.262
GC-202206-NYMEX [C] 4 Day #4 | File GC-198806-NYMEX.dly has a volume of 0 at 1988-05-27. | 2022-04-25 10:14:16.262
GC-202206-NYMEX [C] 4 Day #4 | File GC-198804-NYMEX.dly has a volume of 0 at 1988-01-28. | 2022-04-25 10:14:16.272
GC-202206-NYMEX [C] 4 Day #4 | File GC-198804-NYMEX.dly has a volume of 0 at 1988-03-29. | 2022-04-25 10:14:16.272
GC-202206-NYMEX [C] 4 Day #4 | File GC-198802-NYMEX.dly has a volume of 0 at 1987-11-27. | 2022-04-25 10:14:16.283
GC-202206-NYMEX [C] 4 Day #4 | File GC-198802-NYMEX.dly has a volume of 0 at 1988-01-27. | 2022-04-25 10:14:16.283
GC-202206-NYMEX [C] 4 Day #4 | File GC-198712-NYMEX.dly has a volume of 0 at 1987-07-30. | 2022-04-25 10:14:16.300
GC-202206-NYMEX [C] 4 Day #4 | File GC-198712-NYMEX.dly has a volume of 0 at 1987-11-26. | 2022-04-25 10:14:16.300
GC-202206-NYMEX [C] 4 Day #4 | File GC-198708-NYMEX.dly has a volume of 0 at 1987-05-28. | 2022-04-25 10:14:16.311
GC-202206-NYMEX [C] 4 Day #4 | File GC-198708-NYMEX.dly has a volume of 0 at 1987-07-29. | 2022-04-25 10:14:16.311
GC-202206-NYMEX [C] 4 Day #4 | File GC-198706-NYMEX.dly has a volume of 0 at 1987-03-30. | 2022-04-25 10:14:16.321
GC-202206-NYMEX [C] 4 Day #4 | File GC-198706-NYMEX.dly has a volume of 0 at 1987-05-27. | 2022-04-25 10:14:16.321
GC-202206-NYMEX [C] 4 Day #4 | File GC-198704-NYMEX.dly has a volume of 0 at 1987-01-29. | 2022-04-25 10:14:16.332
GC-202206-NYMEX [C] 4 Day #4 | File GC-198704-NYMEX.dly has a volume of 0 at 1987-03-27. | 2022-04-25 10:14:16.332
GC-202206-NYMEX [C] 4 Day #4 | File GC-198702-NYMEX.dly has a volume of 0 at 1986-11-27. | 2022-04-25 10:14:16.342
GC-202206-NYMEX [C] 4 Day #4 | File GC-198702-NYMEX.dly has a volume of 0 at 1987-01-28. | 2022-04-25 10:14:16.342
GC-202206-NYMEX [C] 4 Day #4 | File GC-198612-NYMEX.dly has a volume of 0 at 1986-07-30. | 2022-04-25 10:14:16.359
GC-202206-NYMEX [C] 4 Day #4 | File GC-198612-NYMEX.dly has a volume of 0 at 1986-11-26. | 2022-04-25 10:14:16.359
GC-202206-NYMEX [C] 4 Day #4 | File GC-198608-NYMEX.dly has a volume of 0 at 1986-05-29. | 2022-04-25 10:14:16.369
GC-202206-NYMEX [C] 4 Day #4 | File GC-198608-NYMEX.dly has a volume of 0 at 1986-07-29. | 2022-04-25 10:14:16.369
GC-202206-NYMEX [C] 4 Day #4 | File GC-198606-NYMEX.dly has a volume of 0 at 1986-03-28. | 2022-04-25 10:14:16.380
GC-202206-NYMEX [C] 4 Day #4 | File GC-198606-NYMEX.dly has a volume of 0 at 1986-05-28. | 2022-04-25 10:14:16.380
GC-202206-NYMEX [C] 4 Day #4 | File GC-198604-NYMEX.dly has a volume of 0 at 1986-01-30. | 2022-04-25 10:14:16.391
GC-202206-NYMEX [C] 4 Day #4 | File GC-198604-NYMEX.dly has a volume of 0 at 1986-03-27. | 2022-04-25 10:14:16.391
GC-202206-NYMEX [C] 4 Day #4 | File GC-198602-NYMEX.dly has a volume of 0 at 1985-11-28. | 2022-04-25 10:14:16.401
GC-202206-NYMEX [C] 4 Day #4 | File GC-198602-NYMEX.dly has a volume of 0 at 1986-01-29. | 2022-04-25 10:14:16.401
GC-202206-NYMEX [C] 4 Day #4 | File GC-198512-NYMEX.dly has a volume of 0 at 1985-07-30. | 2022-04-25 10:14:16.418
GC-202206-NYMEX [C] 4 Day #4 | File GC-198512-NYMEX.dly has a volume of 0 at 1985-11-27. | 2022-04-25 10:14:16.418
GC-202206-NYMEX [C] 4 Day #4 | File GC-198508-NYMEX.dly has a volume of 0 at 1985-05-30. | 2022-04-25 10:14:16.429
GC-202206-NYMEX [C] 4 Day #4 | File GC-198508-NYMEX.dly has a volume of 0 at 1985-07-29. | 2022-04-25 10:14:16.429
GC-202206-NYMEX [C] 4 Day #4 | File GC-198506-NYMEX.dly has a volume of 0 at 1985-03-28. | 2022-04-25 10:14:16.440
GC-202206-NYMEX [C] 4 Day #4 | File GC-198506-NYMEX.dly has a volume of 0 at 1985-05-29. | 2022-04-25 10:14:16.440
GC-202206-NYMEX [C] 4 Day #4 | File GC-198504-NYMEX.dly has a volume of 0 at 1985-01-30. | 2022-04-25 10:14:16.450
GC-202206-NYMEX [C] 4 Day #4 | File GC-198504-NYMEX.dly has a volume of 0 at 1985-03-27. | 2022-04-25 10:14:16.450
GC-202206-NYMEX [C] 4 Day #4 | File GC-198502-NYMEX.dly has a volume of 0 at 1984-11-29. | 2022-04-25 10:14:16.460
GC-202206-NYMEX [C] 4 Day #4 | File GC-198502-NYMEX.dly has a volume of 0 at 1985-01-29. | 2022-04-25 10:14:16.460
GC-202206-NYMEX [C] 4 Day #4 | File GC-198412-NYMEX.dly has a volume of 0 at 1984-07-30. | 2022-04-25 10:14:16.477
GC-202206-NYMEX [C] 4 Day #4 | File GC-198412-NYMEX.dly has a volume of 0 at 1984-11-28. | 2022-04-25 10:14:16.477
GC-202206-NYMEX [C] 4 Day #4 | File GC-198408-NYMEX.dly has a volume of 0 at 1984-05-30. | 2022-04-25 10:14:16.488
GC-202206-NYMEX [C] 4 Day #4 | File GC-198408-NYMEX.dly has a volume of 0 at 1984-07-27. | 2022-04-25 10:14:16.488
GC-202206-NYMEX [C] 4 Day #4 | File GC-198406-NYMEX.dly has a volume of 0 at 1984-03-29. | 2022-04-25 10:14:16.499
GC-202206-NYMEX [C] 4 Day #4 | File GC-198406-NYMEX.dly has a volume of 0 at 1984-05-29. | 2022-04-25 10:14:16.499
GC-202206-NYMEX [C] 4 Day #4 | File GC-198404-NYMEX.dly has a volume of 0 at 1984-01-30. | 2022-04-25 10:14:16.509
GC-202206-NYMEX [C] 4 Day #4 | File GC-198404-NYMEX.dly has a volume of 0 at 1984-03-28. | 2022-04-25 10:14:16.509
GC-202206-NYMEX [C] 4 Day #4 | File GC-198402-NYMEX.dly has a volume of 0 at 1983-11-29. | 2022-04-25 10:14:16.520
GC-202206-NYMEX [C] 4 Day #4 | File GC-198402-NYMEX.dly has a volume of 0 at 1984-01-27. | 2022-04-25 10:14:16.520
GC-202206-NYMEX [C] 4 Day #4 | File GC-198312-NYMEX.dly has a volume of 0 at 1983-07-28. | 2022-04-25 10:14:16.537
GC-202206-NYMEX [C] 4 Day #4 | File GC-198312-NYMEX.dly has a volume of 0 at 1983-11-28. | 2022-04-25 10:14:16.537
GC-202206-NYMEX [C] 4 Day #4 | File GC-198308-NYMEX.dly has a volume of 0 at 1983-05-30. | 2022-04-25 10:14:16.548
GC-202206-NYMEX [C] 4 Day #4 | File GC-198308-NYMEX.dly has a volume of 0 at 1983-07-27. | 2022-04-25 10:14:16.548
GC-202206-NYMEX [C] 4 Day #4 | File GC-198306-NYMEX.dly has a volume of 0 at 1983-03-30. | 2022-04-25 10:14:16.558
GC-202206-NYMEX [C] 4 Day #4 | File GC-198306-NYMEX.dly has a volume of 0 at 1983-05-27. | 2022-04-25 10:14:16.558
GC-202206-NYMEX [C] 4 Day #4 | File GC-198304-NYMEX.dly has a volume of 0 at 1983-01-28. | 2022-04-25 10:14:16.569
GC-202206-NYMEX [C] 4 Day #4 | File GC-198304-NYMEX.dly has a volume of 0 at 1983-03-29. | 2022-04-25 10:14:16.569
GC-202206-NYMEX [C] 4 Day #4 | File GC-198302-NYMEX.dly has a volume of 0 at 1982-11-29. | 2022-04-25 10:14:16.579
GC-202206-NYMEX [C] 4 Day #4 | File GC-198302-NYMEX.dly has a volume of 0 at 1983-01-27. | 2022-04-25 10:14:16.579
GC-202206-NYMEX [C] 4 Day #4 | File GC-198212-NYMEX.dly has a volume of 0 at 1982-07-29. | 2022-04-25 10:14:16.596
GC-202206-NYMEX [C] 4 Day #4 | File GC-198212-NYMEX.dly has a volume of 0 at 1982-11-26. | 2022-04-25 10:14:16.596
GC-202206-NYMEX [C] 4 Day #4 | File GC-198208-NYMEX.dly has a volume of 0 at 1982-05-28. | 2022-04-25 10:14:16.607
GC-202206-NYMEX [C] 4 Day #4 | File GC-198208-NYMEX.dly has a volume of 0 at 1982-07-28. | 2022-04-25 10:14:16.607
GC-202206-NYMEX [C] 4 Day #4 | File GC-198206-NYMEX.dly has a volume of 0 at 1982-03-30. | 2022-04-25 10:14:16.617
GC-202206-NYMEX [C] 4 Day #4 | File GC-198206-NYMEX.dly has a volume of 0 at 1982-05-27. | 2022-04-25 10:14:16.617
GC-202206-NYMEX [C] 4 Day #4 | File GC-198204-NYMEX.dly has a volume of 0 at 1982-01-28. | 2022-04-25 10:14:16.628
GC-202206-NYMEX [C] 4 Day #4 | File GC-198204-NYMEX.dly has a volume of 0 at 1982-03-29. | 2022-04-25 10:14:16.628
GC-202206-NYMEX [C] 4 Day #4 | File GC-198202-NYMEX.dly has a volume of 0 at 1981-11-27. | 2022-04-25 10:14:16.638
GC-202206-NYMEX [C] 4 Day #4 | File GC-198202-NYMEX.dly has a volume of 0 at 1982-01-27. | 2022-04-25 10:14:16.638
GC-202206-NYMEX [C] 4 Day #4 | File GC-198112-NYMEX.dly has a volume of 0 at 1981-07-30. | 2022-04-25 10:14:16.655
GC-202206-NYMEX [C] 4 Day #4 | File GC-198112-NYMEX.dly has a volume of 0 at 1981-11-26. | 2022-04-25 10:14:16.655
GC-202206-NYMEX [C] 4 Day #4 | File GC-198108-NYMEX.dly has a volume of 0 at 1981-05-28. | 2022-04-25 10:14:16.666
GC-202206-NYMEX [C] 4 Day #4 | File GC-198108-NYMEX.dly has a volume of 0 at 1981-07-29. | 2022-04-25 10:14:16.666
GC-202206-NYMEX [C] 4 Day #4 | File GC-198106-NYMEX.dly has a volume of 0 at 1981-03-30. | 2022-04-25 10:14:16.676
GC-202206-NYMEX [C] 4 Day #4 | File GC-198106-NYMEX.dly has a volume of 0 at 1981-05-27. | 2022-04-25 10:14:16.676
GC-202206-NYMEX [C] 4 Day #4 | File GC-198104-NYMEX.dly has a volume of 0 at 1981-01-29. | 2022-04-25 10:14:16.687
GC-202206-NYMEX [C] 4 Day #4 | File GC-198104-NYMEX.dly has a volume of 0 at 1981-03-27. | 2022-04-25 10:14:16.687
GC-202206-NYMEX [C] 4 Day #4 | File GC-198102-NYMEX.dly has a volume of 0 at 1980-11-27. | 2022-04-25 10:14:16.697
GC-202206-NYMEX [C] 4 Day #4 | File GC-198102-NYMEX.dly has a volume of 0 at 1981-01-28. | 2022-04-25 10:14:16.697
GC-202206-NYMEX [C] 4 Day #4 | File GC-198012-NYMEX.dly has a volume of 0 at 1980-07-30. | 2022-04-25 10:14:16.714
GC-202206-NYMEX [C] 4 Day #4 | File GC-198012-NYMEX.dly has a volume of 0 at 1980-11-26. | 2022-04-25 10:14:16.714
GC-202206-NYMEX [C] 4 Day #4 | File GC-198008-NYMEX.dly has a volume of 0 at 1980-05-29. | 2022-04-25 10:14:16.724
GC-202206-NYMEX [C] 4 Day #4 | File GC-198008-NYMEX.dly has a volume of 0 at 1980-07-29. | 2022-04-25 10:14:16.724
GC-202206-NYMEX [C] 4 Day #4 | File GC-198006-NYMEX.dly has a volume of 0 at 1980-03-28. | 2022-04-25 10:14:16.735
GC-202206-NYMEX [C] 4 Day #4 | File GC-198006-NYMEX.dly has a volume of 0 at 1980-05-28. | 2022-04-25 10:14:16.735
GC-202206-NYMEX [C] 4 Day #4 | File GC-198004-NYMEX.dly has a volume of 0 at 1980-01-30. | 2022-04-25 10:14:16.745
GC-202206-NYMEX [C] 4 Day #4 | File GC-198004-NYMEX.dly has a volume of 0 at 1980-03-27. | 2022-04-25 10:14:16.745
GC-202206-NYMEX [C] 4 Day #4 | File GC-198002-NYMEX.dly has a volume of 0 at 1979-11-29. | 2022-04-25 10:14:16.755
GC-202206-NYMEX [C] 4 Day #4 | File GC-198002-NYMEX.dly has a volume of 0 at 1980-01-29. | 2022-04-25 10:14:16.755
GC-202206-NYMEX [C] 4 Day #4 | File GC-197912-NYMEX.dly has a volume of 0 at 1979-07-30. | 2022-04-25 10:14:16.772
GC-202206-NYMEX [C] 4 Day #4 | File GC-197912-NYMEX.dly has a volume of 0 at 1979-11-28. | 2022-04-25 10:14:16.772
GC-202206-NYMEX [C] 4 Day #4 | File GC-197908-NYMEX.dly has a volume of 0 at 1979-05-30. | 2022-04-25 10:14:16.783
GC-202206-NYMEX [C] 4 Day #4 | File GC-197908-NYMEX.dly has a volume of 0 at 1979-07-27. | 2022-04-25 10:14:16.783
GC-202206-NYMEX [C] 4 Day #4 | File GC-197906-NYMEX.dly has a volume of 0 at 1979-03-29. | 2022-04-25 10:14:16.793
GC-202206-NYMEX [C] 4 Day #4 | File GC-197906-NYMEX.dly has a volume of 0 at 1979-05-29. | 2022-04-25 10:14:16.793
GC-202206-NYMEX [C] 4 Day #4 | File GC-197904-NYMEX.dly has a volume of 0 at 1979-01-30. | 2022-04-25 10:14:16.804
GC-202206-NYMEX [C] 4 Day #4 | File GC-197904-NYMEX.dly has a volume of 0 at 1979-03-28. | 2022-04-25 10:14:16.804
GC-202206-NYMEX [C] 4 Day #4 | File GC-197902-NYMEX.dly has a volume of 0 at 1978-11-29. | 2022-04-25 10:14:16.814
GC-202206-NYMEX [C] 4 Day #4 | File GC-197902-NYMEX.dly has a volume of 0 at 1979-01-29. | 2022-04-25 10:14:16.814
GC-202206-NYMEX [C] 4 Day #4 | File GC-197812-NYMEX.dly has a volume of 0 at 1978-07-28. | 2022-04-25 10:14:16.830
GC-202206-NYMEX [C] 4 Day #4 | File GC-197812-NYMEX.dly has a volume of 0 at 1978-11-28. | 2022-04-25 10:14:16.830
GC-202206-NYMEX [C] 4 Day #4 | File GC-197808-NYMEX.dly has a volume of 0 at 1978-05-30. | 2022-04-25 10:14:16.841
GC-202206-NYMEX [C] 4 Day #4 | File GC-197808-NYMEX.dly has a volume of 0 at 1978-07-27. | 2022-04-25 10:14:16.841
GC-202206-NYMEX [C] 4 Day #4 | File GC-197806-NYMEX.dly has a volume of 0 at 1978-03-30. | 2022-04-25 10:14:16.852
GC-202206-NYMEX [C] 4 Day #4 | File GC-197806-NYMEX.dly has a volume of 0 at 1978-05-29. | 2022-04-25 10:14:16.852
GC-202206-NYMEX [C] 4 Day #4 | File GC-197804-NYMEX.dly has a volume of 0 at 1978-01-30. | 2022-04-25 10:14:16.862
GC-202206-NYMEX [C] 4 Day #4 | File GC-197804-NYMEX.dly has a volume of 0 at 1978-03-29. | 2022-04-25 10:14:16.862
GC-202206-NYMEX [C] 4 Day #4 | File GC-197802-NYMEX.dly has a volume of 0 at 1977-11-29. | 2022-04-25 10:14:16.872
GC-202206-NYMEX [C] 4 Day #4 | File GC-197802-NYMEX.dly has a volume of 0 at 1978-01-27. | 2022-04-25 10:14:16.872
GC-202206-NYMEX [C] 4 Day #4 | File GC-197712-NYMEX.dly has a volume of 0 at 1977-07-28. | 2022-04-25 10:14:16.889
GC-202206-NYMEX [C] 4 Day #4 | File GC-197712-NYMEX.dly has a volume of 0 at 1977-11-28. | 2022-04-25 10:14:16.889
GC-202206-NYMEX [C] 4 Day #4 | File GC-197708-NYMEX.dly has a volume of 0 at 1977-05-30. | 2022-04-25 10:14:16.899
GC-202206-NYMEX [C] 4 Day #4 | File GC-197708-NYMEX.dly has a volume of 0 at 1977-07-27. | 2022-04-25 10:14:16.899
GC-202206-NYMEX [C] 4 Day #4 | File GC-197706-NYMEX.dly has a volume of 0 at 1977-03-30. | 2022-04-25 10:14:16.910
GC-202206-NYMEX [C] 4 Day #4 | File GC-197706-NYMEX.dly has a volume of 0 at 1977-05-27. | 2022-04-25 10:14:16.910
GC-202206-NYMEX [C] 4 Day #4 | File GC-197704-NYMEX.dly has a volume of 0 at 1977-01-28. | 2022-04-25 10:14:16.920
GC-202206-NYMEX [C] 4 Day #4 | File GC-197704-NYMEX.dly has a volume of 0 at 1977-03-29. | 2022-04-25 10:14:16.920
GC-202206-NYMEX [C] 4 Day #4 | File GC-197702-NYMEX.dly has a volume of 0 at 1976-11-29. | 2022-04-25 10:14:16.930
GC-202206-NYMEX [C] 4 Day #4 | File GC-197702-NYMEX.dly has a volume of 0 at 1977-01-27. | 2022-04-25 10:14:16.930
GC-202206-NYMEX [C] 4 Day #4 | File GC-197612-NYMEX.dly has a volume of 0 at 1976-07-29. | 2022-04-25 10:14:16.947
GC-202206-NYMEX [C] 4 Day #4 | File GC-197612-NYMEX.dly has a volume of 0 at 1976-11-26. | 2022-04-25 10:14:16.947
GC-202206-NYMEX [C] 4 Day #4 | File GC-197608-NYMEX.dly has a volume of 0 at 1976-05-28. | 2022-04-25 10:14:16.958
GC-202206-NYMEX [C] 4 Day #4 | File GC-197608-NYMEX.dly has a volume of 0 at 1976-07-28. | 2022-04-25 10:14:16.958
GC-202206-NYMEX [C] 4 Day #4 | File GC-197606-NYMEX.dly has a volume of 0 at 1976-03-30. | 2022-04-25 10:14:16.968
GC-202206-NYMEX [C] 4 Day #4 | File GC-197606-NYMEX.dly has a volume of 0 at 1976-05-27. | 2022-04-25 10:14:16.968
GC-202206-NYMEX [C] 4 Day #4 | File GC-197604-NYMEX.dly has a volume of 0 at 1976-01-29. | 2022-04-25 10:14:16.978
GC-202206-NYMEX [C] 4 Day #4 | File GC-197604-NYMEX.dly has a volume of 0 at 1976-03-29. | 2022-04-25 10:14:16.978
GC-202206-NYMEX [C] 4 Day #4 | File GC-197602-NYMEX.dly has a volume of 0 at 1975-11-27. | 2022-04-25 10:14:16.988
GC-202206-NYMEX [C] 4 Day #4 | File GC-197602-NYMEX.dly has a volume of 0 at 1976-01-28. | 2022-04-25 10:14:16.988
GC-202206-NYMEX [C] 4 Day #4 | File GC-197512-NYMEX.dly has a volume of 0 at 1975-07-30. | 2022-04-25 10:14:17.005
GC-202206-NYMEX [C] 4 Day #4 | File GC-197512-NYMEX.dly has a volume of 0 at 1975-11-26. | 2022-04-25 10:14:17.005
GC-202206-NYMEX [C] 4 Day #4 | File GC-197508-NYMEX.dly has a volume of 0 at 1975-05-29. | 2022-04-25 10:14:17.016
GC-202206-NYMEX [C] 4 Day #4 | File GC-197508-NYMEX.dly has a volume of 0 at 1975-07-29. | 2022-04-25 10:14:17.016
GC-202206-NYMEX [C] 4 Day #4 | File GC-197506-NYMEX.dly has a volume of 0 at 1975-03-28. | 2022-04-25 10:14:17.027
GC-202206-NYMEX [C] 4 Day #4 | File GC-197506-NYMEX.dly has a volume of 0 at 1975-05-28. | 2022-04-25 10:14:17.027
GC-202206-NYMEX [C] 4 Day #4 | File GC-197504-NYMEX.dly has a volume of 0 at 1975-01-30. | 2022-04-25 10:14:17.037
GC-202206-NYMEX [C] 4 Day #4 | File GC-197504-NYMEX.dly has a volume of 0 at 1975-03-27. | 2022-04-25 10:14:17.037
GC-202206-NYMEX [C] 4 Day #4 | Dates not found while checking for invalid data in continuous contract data files. GC-197502-NYMEX | 2022-04-25 10:14:17.044 *
GC-202206-NYMEX [C] 4 Day #4 | Waiting for historical downloads to complete with the IDs: 20, 21, | 2022-04-25 10:14:17.044
MGC-202206-NYMEX-USD-10 [C] 768 Min #16 | Reloading chart. | 2022-04-25 10:14:17.054
MGC-202206-NYMEX-USD-10 [C] 768 Min #15 | Reloading chart. | 2022-04-25 10:14:17.067
MGC-202206-NYMEX-USD-10 [C] 384 Min #2 | Reloading chart. | 2022-04-25 10:14:17.092
Files to Open on Startup | Opening file: ENERGY.Cht | 2022-04-25 10:14:17.101
NGAS 2 Day #14 | Reloading chart. | 2022-04-25 10:14:17.126
NG-202206-NYMEX [C] 64 Day #9 | Reloading chart. | 2022-04-25 10:14:17.140
NG-202206-NYMEX [C] 64 Day #9 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:17.140
NG-202206-NYMEX [C] 64 Day #9 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:17.140
NG-202206-NYMEX [C] 64 Day #9 | Performing continuous chart historical Daily data download for symbol NG-202206-NYMEX starting at last date in file. | 2022-04-25 10:14:17.649
Added historical Daily data request for NG-202206-NYMEX to the queue. | 2022-04-25 10:14:17.649
NG-202206-NYMEX [C] 64 Day #9 | File NG-200102-NYMEX.dly has a volume of 0 at 2000-12-19. | 2022-04-25 10:14:18.971
NG-202206-NYMEX [C] 64 Day #9 | File NG-200101-NYMEX.dly has a volume of 0 at 2000-11-20. | 2022-04-25 10:14:18.975
NG-202206-NYMEX [C] 64 Day #9 | File NG-200101-NYMEX.dly has a volume of 0 at 2000-12-18. | 2022-04-25 10:14:18.975
NG-202206-NYMEX [C] 64 Day #9 | File NG-200012-NYMEX.dly has a volume of 0 at 2000-10-19. | 2022-04-25 10:14:18.980
NG-202206-NYMEX [C] 64 Day #9 | File NG-200012-NYMEX.dly has a volume of 0 at 2000-11-17. | 2022-04-25 10:14:18.980
NG-202206-NYMEX [C] 64 Day #9 | File NG-200011-NYMEX.dly has a volume of 0 at 2000-09-19. | 2022-04-25 10:14:18.985
NG-202206-NYMEX [C] 64 Day #9 | File NG-200011-NYMEX.dly has a volume of 0 at 2000-10-18. | 2022-04-25 10:14:18.985
NG-202206-NYMEX [C] 64 Day #9 | File NG-200010-NYMEX.dly has a volume of 0 at 2000-08-21. | 2022-04-25 10:14:18.989
NG-202206-NYMEX [C] 64 Day #9 | File NG-200010-NYMEX.dly has a volume of 0 at 2000-09-18. | 2022-04-25 10:14:18.989
NG-202206-NYMEX [C] 64 Day #9 | File NG-200009-NYMEX.dly has a volume of 0 at 2000-07-19. | 2022-04-25 10:14:18.994
NG-202206-NYMEX [C] 64 Day #9 | File NG-200009-NYMEX.dly has a volume of 0 at 2000-08-18. | 2022-04-25 10:14:18.994
NG-202206-NYMEX [C] 64 Day #9 | File NG-200008-NYMEX.dly has a volume of 0 at 2000-06-20. | 2022-04-25 10:14:18.999
NG-202206-NYMEX [C] 64 Day #9 | File NG-200008-NYMEX.dly has a volume of 0 at 2000-07-18. | 2022-04-25 10:14:18.999
NG-202206-NYMEX [C] 64 Day #9 | File NG-200007-NYMEX.dly has a volume of 0 at 2000-05-19. | 2022-04-25 10:14:19.003
NG-202206-NYMEX [C] 64 Day #9 | File NG-200007-NYMEX.dly has a volume of 0 at 2000-06-19. | 2022-04-25 10:14:19.003
NG-202206-NYMEX [C] 64 Day #9 | File NG-200006-NYMEX.dly has a volume of 0 at 2000-04-18. | 2022-04-25 10:14:19.008
NG-202206-NYMEX [C] 64 Day #9 | File NG-200006-NYMEX.dly has a volume of 0 at 2000-05-18. | 2022-04-25 10:14:19.008
NG-202206-NYMEX [C] 64 Day #9 | File NG-200005-NYMEX.dly has a volume of 0 at 2000-03-21. | 2022-04-25 10:14:19.013
NG-202206-NYMEX [C] 64 Day #9 | File NG-200005-NYMEX.dly has a volume of 0 at 2000-04-17. | 2022-04-25 10:14:19.013
NG-202206-NYMEX [C] 64 Day #9 | File NG-200004-NYMEX.dly has a volume of 0 at 2000-02-17. | 2022-04-25 10:14:19.017
NG-202206-NYMEX [C] 64 Day #9 | File NG-200004-NYMEX.dly has a volume of 0 at 2000-03-20. | 2022-04-25 10:14:19.017
NG-202206-NYMEX [C] 64 Day #9 | File NG-200003-NYMEX.dly has a volume of 0 at 2000-01-19. | 2022-04-25 10:14:19.022
NG-202206-NYMEX [C] 64 Day #9 | File NG-200003-NYMEX.dly has a volume of 0 at 2000-02-16. | 2022-04-25 10:14:19.022
NG-202206-NYMEX [C] 64 Day #9 | File NG-200002-NYMEX.dly has a volume of 0 at 1999-12-21. | 2022-04-25 10:14:19.026
NG-202206-NYMEX [C] 64 Day #9 | File NG-200002-NYMEX.dly has a volume of 0 at 2000-01-18. | 2022-04-25 10:14:19.026
NG-202206-NYMEX [C] 64 Day #9 | File NG-200001-NYMEX.dly has a volume of 0 at 1999-11-18. | 2022-04-25 10:14:19.031
NG-202206-NYMEX [C] 64 Day #9 | File NG-200001-NYMEX.dly has a volume of 0 at 1999-12-20. | 2022-04-25 10:14:19.031
NG-202206-NYMEX [C] 64 Day #9 | File NG-199912-NYMEX.dly has a volume of 0 at 1999-10-19. | 2022-04-25 10:14:19.035
NG-202206-NYMEX [C] 64 Day #9 | File NG-199912-NYMEX.dly has a volume of 0 at 1999-11-17. | 2022-04-25 10:14:19.035
NG-202206-NYMEX [C] 64 Day #9 | File NG-199911-NYMEX.dly has a volume of 0 at 1999-09-20. | 2022-04-25 10:14:19.040
NG-202206-NYMEX [C] 64 Day #9 | File NG-199911-NYMEX.dly has a volume of 0 at 1999-10-18. | 2022-04-25 10:14:19.040
NG-202206-NYMEX [C] 64 Day #9 | File NG-199910-NYMEX.dly has a volume of 0 at 1999-08-19. | 2022-04-25 10:14:19.045
NG-202206-NYMEX [C] 64 Day #9 | File NG-199910-NYMEX.dly has a volume of 0 at 1999-09-17. | 2022-04-25 10:14:19.045
NG-202206-NYMEX [C] 64 Day #9 | File NG-199909-NYMEX.dly has a volume of 0 at 1999-07-20. | 2022-04-25 10:14:19.050
NG-202206-NYMEX [C] 64 Day #9 | File NG-199909-NYMEX.dly has a volume of 0 at 1999-08-18. | 2022-04-25 10:14:19.050
NG-202206-NYMEX [C] 64 Day #9 | File NG-199908-NYMEX.dly has a volume of 0 at 1999-06-18. | 2022-04-25 10:14:19.054
NG-202206-NYMEX [C] 64 Day #9 | File NG-199908-NYMEX.dly has a volume of 0 at 1999-07-19. | 2022-04-25 10:14:19.054
NG-202206-NYMEX [C] 64 Day #9 | File NG-199907-NYMEX.dly has a volume of 0 at 1999-05-19. | 2022-04-25 10:14:19.059
NG-202206-NYMEX [C] 64 Day #9 | File NG-199907-NYMEX.dly has a volume of 0 at 1999-06-17. | 2022-04-25 10:14:19.059
NG-202206-NYMEX [C] 64 Day #9 | File NG-199906-NYMEX.dly has a volume of 0 at 1999-04-20. | 2022-04-25 10:14:19.064
NG-202206-NYMEX [C] 64 Day #9 | File NG-199906-NYMEX.dly has a volume of 0 at 1999-05-18. | 2022-04-25 10:14:19.064
NG-202206-NYMEX [C] 64 Day #9 | File NG-199905-NYMEX.dly has a volume of 0 at 1999-03-19. | 2022-04-25 10:14:19.068
NG-202206-NYMEX [C] 64 Day #9 | File NG-199905-NYMEX.dly has a volume of 0 at 1999-04-19. | 2022-04-25 10:14:19.068
NG-202206-NYMEX [C] 64 Day #9 | File NG-199904-NYMEX.dly has a volume of 0 at 1999-02-16. | 2022-04-25 10:14:19.073
NG-202206-NYMEX [C] 64 Day #9 | File NG-199904-NYMEX.dly has a volume of 0 at 1999-03-18. | 2022-04-25 10:14:19.073
NG-202206-NYMEX [C] 64 Day #9 | File NG-199903-NYMEX.dly has a volume of 0 at 1999-01-19. | 2022-04-25 10:14:19.078
NG-202206-NYMEX [C] 64 Day #9 | File NG-199903-NYMEX.dly has a volume of 0 at 1999-02-15. | 2022-04-25 10:14:19.078
NG-202206-NYMEX [C] 64 Day #9 | File NG-199902-NYMEX.dly has a volume of 0 at 1998-12-21. | 2022-04-25 10:14:19.082
NG-202206-NYMEX [C] 64 Day #9 | File NG-199902-NYMEX.dly has a volume of 0 at 1999-01-18. | 2022-04-25 10:14:19.082
NG-202206-NYMEX [C] 64 Day #9 | File NG-199901-NYMEX.dly has a volume of 0 at 1998-11-18. | 2022-04-25 10:14:19.086
NG-202206-NYMEX [C] 64 Day #9 | File NG-199901-NYMEX.dly has a volume of 0 at 1998-12-18. | 2022-04-25 10:14:19.086
NG-202206-NYMEX [C] 64 Day #9 | File NG-199812-NYMEX.dly has a volume of 0 at 1998-10-20. | 2022-04-25 10:14:19.091
NG-202206-NYMEX [C] 64 Day #9 | File NG-199812-NYMEX.dly has a volume of 0 at 1998-11-17. | 2022-04-25 10:14:19.091
NG-202206-NYMEX [C] 64 Day #9 | File NG-199811-NYMEX.dly has a volume of 0 at 1998-09-18. | 2022-04-25 10:14:19.096
NG-202206-NYMEX [C] 64 Day #9 | File NG-199811-NYMEX.dly has a volume of 0 at 1998-10-19. | 2022-04-25 10:14:19.096
NG-202206-NYMEX [C] 64 Day #9 | File NG-199810-NYMEX.dly has a volume of 0 at 1998-08-19. | 2022-04-25 10:14:19.100
NG-202206-NYMEX [C] 64 Day #9 | File NG-199810-NYMEX.dly has a volume of 0 at 1998-09-17. | 2022-04-25 10:14:19.100
NG-202206-NYMEX [C] 64 Day #9 | File NG-199809-NYMEX.dly has a volume of 0 at 1998-07-21. | 2022-04-25 10:14:19.105
NG-202206-NYMEX [C] 64 Day #9 | File NG-199809-NYMEX.dly has a volume of 0 at 1998-08-18. | 2022-04-25 10:14:19.105
NG-202206-NYMEX [C] 64 Day #9 | File NG-199808-NYMEX.dly has a volume of 0 at 1998-06-18. | 2022-04-25 10:14:19.110
NG-202206-NYMEX [C] 64 Day #9 | File NG-199808-NYMEX.dly has a volume of 0 at 1998-07-20. | 2022-04-25 10:14:19.110
NG-202206-NYMEX [C] 64 Day #9 | File NG-199807-NYMEX.dly has a volume of 0 at 1998-05-19. | 2022-04-25 10:14:19.115
NG-202206-NYMEX [C] 64 Day #9 | File NG-199807-NYMEX.dly has a volume of 0 at 1998-06-17. | 2022-04-25 10:14:19.115
NG-202206-NYMEX [C] 64 Day #9 | File NG-199806-NYMEX.dly has a volume of 0 at 1998-04-20. | 2022-04-25 10:14:19.119
NG-202206-NYMEX [C] 64 Day #9 | File NG-199806-NYMEX.dly has a volume of 0 at 1998-05-18. | 2022-04-25 10:14:19.119
NG-202206-NYMEX [C] 64 Day #9 | File NG-199805-NYMEX.dly has a volume of 0 at 1998-03-19. | 2022-04-25 10:14:19.124
NG-202206-NYMEX [C] 64 Day #9 | File NG-199805-NYMEX.dly has a volume of 0 at 1998-04-17. | 2022-04-25 10:14:19.124
NG-202206-NYMEX [C] 64 Day #9 | File NG-199804-NYMEX.dly has a volume of 0 at 1998-02-17. | 2022-04-25 10:14:19.129
NG-202206-NYMEX [C] 64 Day #9 | File NG-199804-NYMEX.dly has a volume of 0 at 1998-03-18. | 2022-04-25 10:14:19.129
NG-202206-NYMEX [C] 64 Day #9 | File NG-199803-NYMEX.dly has a volume of 0 at 1998-01-20. | 2022-04-25 10:14:19.133
NG-202206-NYMEX [C] 64 Day #9 | File NG-199803-NYMEX.dly has a volume of 0 at 1998-02-16. | 2022-04-25 10:14:19.133
NG-202206-NYMEX [C] 64 Day #9 | File NG-199802-NYMEX.dly has a volume of 0 at 1997-12-19. | 2022-04-25 10:14:19.138
NG-202206-NYMEX [C] 64 Day #9 | File NG-199802-NYMEX.dly has a volume of 0 at 1998-01-19. | 2022-04-25 10:14:19.138
NG-202206-NYMEX [C] 64 Day #9 | File NG-199801-NYMEX.dly has a volume of 0 at 1997-11-18. | 2022-04-25 10:14:19.143
NG-202206-NYMEX [C] 64 Day #9 | File NG-199801-NYMEX.dly has a volume of 0 at 1997-12-18. | 2022-04-25 10:14:19.143
NG-202206-NYMEX [C] 64 Day #9 | File NG-199712-NYMEX.dly has a volume of 0 at 1997-10-21. | 2022-04-25 10:14:19.147
NG-202206-NYMEX [C] 64 Day #9 | File NG-199712-NYMEX.dly has a volume of 0 at 1997-11-17. | 2022-04-25 10:14:19.147
NG-202206-NYMEX [C] 64 Day #9 | File NG-199711-NYMEX.dly has a volume of 0 at 1997-09-18. | 2022-04-25 10:14:19.152
NG-202206-NYMEX [C] 64 Day #9 | File NG-199711-NYMEX.dly has a volume of 0 at 1997-10-20. | 2022-04-25 10:14:19.152
NG-202206-NYMEX [C] 64 Day #9 | File NG-199710-NYMEX.dly has a volume of 0 at 1997-08-19. | 2022-04-25 10:14:19.156
NG-202206-NYMEX [C] 64 Day #9 | File NG-199710-NYMEX.dly has a volume of 0 at 1997-09-17. | 2022-04-25 10:14:19.156
NG-202206-NYMEX [C] 64 Day #9 | File NG-199709-NYMEX.dly has a volume of 0 at 1997-07-21. | 2022-04-25 10:14:19.161
NG-202206-NYMEX [C] 64 Day #9 | File NG-199709-NYMEX.dly has a volume of 0 at 1997-08-18. | 2022-04-25 10:14:19.161
NG-202206-NYMEX [C] 64 Day #9 | File NG-199708-NYMEX.dly has a volume of 0 at 1997-06-18. | 2022-04-25 10:14:19.166
NG-202206-NYMEX [C] 64 Day #9 | File NG-199708-NYMEX.dly has a volume of 0 at 1997-07-18. | 2022-04-25 10:14:19.166
NG-202206-NYMEX [C] 64 Day #9 | File NG-199707-NYMEX.dly has a volume of 0 at 1997-05-20. | 2022-04-25 10:14:19.170
NG-202206-NYMEX [C] 64 Day #9 | File NG-199707-NYMEX.dly has a volume of 0 at 1997-06-17. | 2022-04-25 10:14:19.170
NG-202206-NYMEX [C] 64 Day #9 | File NG-199706-NYMEX.dly has a volume of 0 at 1997-04-18. | 2022-04-25 10:14:19.175
NG-202206-NYMEX [C] 64 Day #9 | File NG-199706-NYMEX.dly has a volume of 0 at 1997-05-19. | 2022-04-25 10:14:19.175
NG-202206-NYMEX [C] 64 Day #9 | File NG-199705-NYMEX.dly has a volume of 0 at 1997-03-19. | 2022-04-25 10:14:19.180
NG-202206-NYMEX [C] 64 Day #9 | File NG-199705-NYMEX.dly has a volume of 0 at 1997-04-17. | 2022-04-25 10:14:19.180
NG-202206-NYMEX [C] 64 Day #9 | File NG-199704-NYMEX.dly has a volume of 0 at 1997-02-18. | 2022-04-25 10:14:19.184
NG-202206-NYMEX [C] 64 Day #9 | File NG-199704-NYMEX.dly has a volume of 0 at 1997-03-18. | 2022-04-25 10:14:19.184
NG-202206-NYMEX [C] 64 Day #9 | File NG-199703-NYMEX.dly has a volume of 0 at 1997-01-21. | 2022-04-25 10:14:19.188
NG-202206-NYMEX [C] 64 Day #9 | File NG-199703-NYMEX.dly has a volume of 0 at 1997-02-17. | 2022-04-25 10:14:19.188
NG-202206-NYMEX [C] 64 Day #9 | File NG-199702-NYMEX.dly has a volume of 0 at 1996-12-19. | 2022-04-25 10:14:19.193
NG-202206-NYMEX [C] 64 Day #9 | File NG-199702-NYMEX.dly has a volume of 0 at 1997-01-20. | 2022-04-25 10:14:19.193
NG-202206-NYMEX [C] 64 Day #9 | File NG-199701-NYMEX.dly has a volume of 0 at 1996-11-19. | 2022-04-25 10:14:19.197
NG-202206-NYMEX [C] 64 Day #9 | File NG-199701-NYMEX.dly has a volume of 0 at 1996-12-18. | 2022-04-25 10:14:19.197
NG-202206-NYMEX [C] 64 Day #9 | File NG-199612-NYMEX.dly has a volume of 0 at 1996-10-21. | 2022-04-25 10:14:19.201
NG-202206-NYMEX [C] 64 Day #9 | File NG-199612-NYMEX.dly has a volume of 0 at 1996-11-18. | 2022-04-25 10:14:19.201
NG-202206-NYMEX [C] 64 Day #9 | File NG-199611-NYMEX.dly has a volume of 0 at 1996-09-18. | 2022-04-25 10:14:19.206
NG-202206-NYMEX [C] 64 Day #9 | File NG-199611-NYMEX.dly has a volume of 0 at 1996-10-18. | 2022-04-25 10:14:19.206
NG-202206-NYMEX [C] 64 Day #9 | File NG-199610-NYMEX.dly has a volume of 0 at 1996-08-20. | 2022-04-25 10:14:19.210
NG-202206-NYMEX [C] 64 Day #9 | File NG-199610-NYMEX.dly has a volume of 0 at 1996-09-17. | 2022-04-25 10:14:19.210
NG-202206-NYMEX [C] 64 Day #9 | File NG-199609-NYMEX.dly has a volume of 0 at 1996-07-19. | 2022-04-25 10:14:19.215
NG-202206-NYMEX [C] 64 Day #9 | File NG-199609-NYMEX.dly has a volume of 0 at 1996-08-19. | 2022-04-25 10:14:19.215
NG-202206-NYMEX [C] 64 Day #9 | File NG-199608-NYMEX.dly has a volume of 0 at 1996-06-18. | 2022-04-25 10:14:19.219
NG-202206-NYMEX [C] 64 Day #9 | File NG-199608-NYMEX.dly has a volume of 0 at 1996-07-18. | 2022-04-25 10:14:19.219
NG-202206-NYMEX [C] 64 Day #9 | File NG-199607-NYMEX.dly has a volume of 0 at 1996-05-21. | 2022-04-25 10:14:19.223
NG-202206-NYMEX [C] 64 Day #9 | File NG-199607-NYMEX.dly has a volume of 0 at 1996-06-17. | 2022-04-25 10:14:19.223
NG-202206-NYMEX [C] 64 Day #9 | File NG-199606-NYMEX.dly has a volume of 0 at 1996-04-18. | 2022-04-25 10:14:19.228
NG-202206-NYMEX [C] 64 Day #9 | File NG-199606-NYMEX.dly has a volume of 0 at 1996-05-20. | 2022-04-25 10:14:19.228
NG-202206-NYMEX [C] 64 Day #9 | File NG-199605-NYMEX.dly has a volume of 0 at 1996-03-19. | 2022-04-25 10:14:19.232
NG-202206-NYMEX [C] 64 Day #9 | File NG-199605-NYMEX.dly has a volume of 0 at 1996-04-17. | 2022-04-25 10:14:19.232
NG-202206-NYMEX [C] 64 Day #9 | File NG-199604-NYMEX.dly has a volume of 0 at 1996-02-19. | 2022-04-25 10:14:19.237
NG-202206-NYMEX [C] 64 Day #9 | File NG-199604-NYMEX.dly has a volume of 0 at 1996-03-18. | 2022-04-25 10:14:19.237
NG-202206-NYMEX [C] 64 Day #9 | File NG-199603-NYMEX.dly has a volume of 0 at 1996-01-19. | 2022-04-25 10:14:19.241
NG-202206-NYMEX [C] 64 Day #9 | File NG-199603-NYMEX.dly has a volume of 0 at 1996-02-16. | 2022-04-25 10:14:19.241
NG-202206-NYMEX [C] 64 Day #9 | File NG-199602-NYMEX.dly has a volume of 0 at 1995-12-19. | 2022-04-25 10:14:19.245
NG-202206-NYMEX [C] 64 Day #9 | File NG-199602-NYMEX.dly has a volume of 0 at 1996-01-18. | 2022-04-25 10:14:19.245
NG-202206-NYMEX [C] 64 Day #9 | File NG-199601-NYMEX.dly has a volume of 0 at 1995-11-20. | 2022-04-25 10:14:19.249
NG-202206-NYMEX [C] 64 Day #9 | File NG-199601-NYMEX.dly has a volume of 0 at 1995-12-18. | 2022-04-25 10:14:19.249
NG-202206-NYMEX [C] 64 Day #9 | File NG-199512-NYMEX.dly has a volume of 0 at 1995-10-19. | 2022-04-25 10:14:19.253
NG-202206-NYMEX [C] 64 Day #9 | File NG-199512-NYMEX.dly has a volume of 0 at 1995-11-17. | 2022-04-25 10:14:19.253
NG-202206-NYMEX [C] 64 Day #9 | File NG-199511-NYMEX.dly has a volume of 0 at 1995-09-19. | 2022-04-25 10:14:19.258
NG-202206-NYMEX [C] 64 Day #9 | File NG-199511-NYMEX.dly has a volume of 0 at 1995-10-18. | 2022-04-25 10:14:19.258
NG-202206-NYMEX [C] 64 Day #9 | File NG-199510-NYMEX.dly has a volume of 0 at 1995-08-21. | 2022-04-25 10:14:19.262
NG-202206-NYMEX [C] 64 Day #9 | File NG-199510-NYMEX.dly has a volume of 0 at 1995-09-18. | 2022-04-25 10:14:19.262
NG-202206-NYMEX [C] 64 Day #9 | File NG-199509-NYMEX.dly has a volume of 0 at 1995-07-19. | 2022-04-25 10:14:19.266
NG-202206-NYMEX [C] 64 Day #9 | File NG-199509-NYMEX.dly has a volume of 0 at 1995-08-18. | 2022-04-25 10:14:19.266
NG-202206-NYMEX [C] 64 Day #9 | File NG-199508-NYMEX.dly has a volume of 0 at 1995-06-20. | 2022-04-25 10:14:19.270
NG-202206-NYMEX [C] 64 Day #9 | File NG-199508-NYMEX.dly has a volume of 0 at 1995-07-18. | 2022-04-25 10:14:19.270
NG-202206-NYMEX [C] 64 Day #9 | File NG-199507-NYMEX.dly has a volume of 0 at 1995-05-19. | 2022-04-25 10:14:19.275
NG-202206-NYMEX [C] 64 Day #9 | File NG-199507-NYMEX.dly has a volume of 0 at 1995-06-19. | 2022-04-25 10:14:19.275
NG-202206-NYMEX [C] 64 Day #9 | File NG-199506-NYMEX.dly has a volume of 0 at 1995-04-18. | 2022-04-25 10:14:19.279
NG-202206-NYMEX [C] 64 Day #9 | File NG-199506-NYMEX.dly has a volume of 0 at 1995-05-18. | 2022-04-25 10:14:19.279
NG-202206-NYMEX [C] 64 Day #9 | File NG-199505-NYMEX.dly has a volume of 0 at 1995-03-21. | 2022-04-25 10:14:19.283
NG-202206-NYMEX [C] 64 Day #9 | File NG-199505-NYMEX.dly has a volume of 0 at 1995-04-17. | 2022-04-25 10:14:19.283
NG-202206-NYMEX [C] 64 Day #9 | File NG-199504-NYMEX.dly has a volume of 0 at 1995-02-16. | 2022-04-25 10:14:19.288
NG-202206-NYMEX [C] 64 Day #9 | File NG-199504-NYMEX.dly has a volume of 0 at 1995-03-20. | 2022-04-25 10:14:19.288
NG-202206-NYMEX [C] 64 Day #9 | File NG-199503-NYMEX.dly has a volume of 0 at 1995-01-19. | 2022-04-25 10:14:19.292
NG-202206-NYMEX [C] 64 Day #9 | File NG-199503-NYMEX.dly has a volume of 0 at 1995-02-15. | 2022-04-25 10:14:19.292
NG-202206-NYMEX [C] 64 Day #9 | File NG-199502-NYMEX.dly has a volume of 0 at 1994-12-20. | 2022-04-25 10:14:19.296
NG-202206-NYMEX [C] 64 Day #9 | File NG-199502-NYMEX.dly has a volume of 0 at 1995-01-18. | 2022-04-25 10:14:19.296
NG-202206-NYMEX [C] 64 Day #9 | File NG-199501-NYMEX.dly has a volume of 0 at 1994-11-18. | 2022-04-25 10:14:19.300
NG-202206-NYMEX [C] 64 Day #9 | File NG-199501-NYMEX.dly has a volume of 0 at 1994-12-19. | 2022-04-25 10:14:19.300
NG-202206-NYMEX [C] 64 Day #9 | File NG-199412-NYMEX.dly has a volume of 0 at 1994-10-19. | 2022-04-25 10:14:19.304
NG-202206-NYMEX [C] 64 Day #9 | File NG-199412-NYMEX.dly has a volume of 0 at 1994-11-17. | 2022-04-25 10:14:19.304
NG-202206-NYMEX [C] 64 Day #9 | File NG-199411-NYMEX.dly has a volume of 0 at 1994-09-20. | 2022-04-25 10:14:19.308
NG-202206-NYMEX [C] 64 Day #9 | File NG-199411-NYMEX.dly has a volume of 0 at 1994-10-18. | 2022-04-25 10:14:19.308
NG-202206-NYMEX [C] 64 Day #9 | File NG-199410-NYMEX.dly has a volume of 0 at 1994-08-19. | 2022-04-25 10:14:19.312
NG-202206-NYMEX [C] 64 Day #9 | File NG-199410-NYMEX.dly has a volume of 0 at 1994-09-19. | 2022-04-25 10:14:19.312
NG-202206-NYMEX [C] 64 Day #9 | File NG-199409-NYMEX.dly has a volume of 0 at 1994-07-19. | 2022-04-25 10:14:19.316
NG-202206-NYMEX [C] 64 Day #9 | File NG-199409-NYMEX.dly has a volume of 0 at 1994-08-18. | 2022-04-25 10:14:19.316
NG-202206-NYMEX [C] 64 Day #9 | File NG-199408-NYMEX.dly has a volume of 0 at 1994-06-20. | 2022-04-25 10:14:19.321
NG-202206-NYMEX [C] 64 Day #9 | File NG-199408-NYMEX.dly has a volume of 0 at 1994-07-18. | 2022-04-25 10:14:19.321
NG-202206-NYMEX [C] 64 Day #9 | File NG-199407-NYMEX.dly has a volume of 0 at 1994-05-19. | 2022-04-25 10:14:19.325
NG-202206-NYMEX [C] 64 Day #9 | File NG-199407-NYMEX.dly has a volume of 0 at 1994-06-17. | 2022-04-25 10:14:19.325
NG-202206-NYMEX [C] 64 Day #9 | File NG-199406-NYMEX.dly has a volume of 0 at 1994-04-19. | 2022-04-25 10:14:19.329
NG-202206-NYMEX [C] 64 Day #9 | File NG-199406-NYMEX.dly has a volume of 0 at 1994-05-18. | 2022-04-25 10:14:19.329
NG-202206-NYMEX [C] 64 Day #9 | File NG-199405-NYMEX.dly has a volume of 0 at 1994-03-21. | 2022-04-25 10:14:19.333
NG-202206-NYMEX [C] 64 Day #9 | File NG-199405-NYMEX.dly has a volume of 0 at 1994-04-18. | 2022-04-25 10:14:19.333
NG-202206-NYMEX [C] 64 Day #9 | File NG-199404-NYMEX.dly has a volume of 0 at 1994-02-16. | 2022-04-25 10:14:19.337
NG-202206-NYMEX [C] 64 Day #9 | File NG-199404-NYMEX.dly has a volume of 0 at 1994-03-18. | 2022-04-25 10:14:19.337
NG-202206-NYMEX [C] 64 Day #9 | File NG-199403-NYMEX.dly has a volume of 0 at 1994-01-19. | 2022-04-25 10:14:19.341
NG-202206-NYMEX [C] 64 Day #9 | File NG-199403-NYMEX.dly has a volume of 0 at 1994-02-15. | 2022-04-25 10:14:19.341
NG-202206-NYMEX [C] 64 Day #9 | File NG-199402-NYMEX.dly has a volume of 0 at 1993-12-21. | 2022-04-25 10:14:19.345
NG-202206-NYMEX [C] 64 Day #9 | File NG-199402-NYMEX.dly has a volume of 0 at 1994-01-18. | 2022-04-25 10:14:19.345
NG-202206-NYMEX [C] 64 Day #9 | File NG-199401-NYMEX.dly has a volume of 0 at 1993-11-18. | 2022-04-25 10:14:19.349
NG-202206-NYMEX [C] 64 Day #9 | File NG-199401-NYMEX.dly has a volume of 0 at 1993-12-20. | 2022-04-25 10:14:19.349
NG-202206-NYMEX [C] 64 Day #9 | File NG-199312-NYMEX.dly has a volume of 0 at 1993-10-19. | 2022-04-25 10:14:19.353
NG-202206-NYMEX [C] 64 Day #9 | File NG-199312-NYMEX.dly has a volume of 0 at 1993-11-17. | 2022-04-25 10:14:19.353
NG-202206-NYMEX [C] 64 Day #9 | File NG-199311-NYMEX.dly has a volume of 0 at 1993-09-20. | 2022-04-25 10:14:19.357
NG-202206-NYMEX [C] 64 Day #9 | File NG-199311-NYMEX.dly has a volume of 0 at 1993-10-18. | 2022-04-25 10:14:19.357
NG-202206-NYMEX [C] 64 Day #9 | File NG-199310-NYMEX.dly has a volume of 0 at 1993-08-19. | 2022-04-25 10:14:19.362
NG-202206-NYMEX [C] 64 Day #9 | File NG-199310-NYMEX.dly has a volume of 0 at 1993-09-17. | 2022-04-25 10:14:19.362
NG-202206-NYMEX [C] 64 Day #9 | File NG-199309-NYMEX.dly has a volume of 0 at 1993-07-20. | 2022-04-25 10:14:19.366
NG-202206-NYMEX [C] 64 Day #9 | File NG-199309-NYMEX.dly has a volume of 0 at 1993-08-18. | 2022-04-25 10:14:19.366
NG-202206-NYMEX [C] 64 Day #9 | File NG-199308-NYMEX.dly has a volume of 0 at 1993-06-18. | 2022-04-25 10:14:19.370
NG-202206-NYMEX [C] 64 Day #9 | File NG-199308-NYMEX.dly has a volume of 0 at 1993-07-19. | 2022-04-25 10:14:19.370
NG-202206-NYMEX [C] 64 Day #9 | File NG-199307-NYMEX.dly has a volume of 0 at 1993-05-19. | 2022-04-25 10:14:19.374
NG-202206-NYMEX [C] 64 Day #9 | File NG-199307-NYMEX.dly has a volume of 0 at 1993-06-17. | 2022-04-25 10:14:19.374
NG-202206-NYMEX [C] 64 Day #9 | File NG-199306-NYMEX.dly has a volume of 0 at 1993-04-20. | 2022-04-25 10:14:19.378
NG-202206-NYMEX [C] 64 Day #9 | File NG-199306-NYMEX.dly has a volume of 0 at 1993-05-18. | 2022-04-25 10:14:19.378
NG-202206-NYMEX [C] 64 Day #9 | File NG-199305-NYMEX.dly has a volume of 0 at 1993-03-19. | 2022-04-25 10:14:19.382
NG-202206-NYMEX [C] 64 Day #9 | File NG-199305-NYMEX.dly has a volume of 0 at 1993-04-19. | 2022-04-25 10:14:19.382
NG-202206-NYMEX [C] 64 Day #9 | File NG-199304-NYMEX.dly has a volume of 0 at 1993-02-16. | 2022-04-25 10:14:19.387
NG-202206-NYMEX [C] 64 Day #9 | File NG-199304-NYMEX.dly has a volume of 0 at 1993-03-18. | 2022-04-25 10:14:19.387
NG-202206-NYMEX [C] 64 Day #9 | File NG-199303-NYMEX.dly has a volume of 0 at 1993-01-19. | 2022-04-25 10:14:19.391
NG-202206-NYMEX [C] 64 Day #9 | File NG-199303-NYMEX.dly has a volume of 0 at 1993-02-15. | 2022-04-25 10:14:19.391
NG-202206-NYMEX [C] 64 Day #9 | File NG-199302-NYMEX.dly has a volume of 0 at 1992-12-21. | 2022-04-25 10:14:19.394
NG-202206-NYMEX [C] 64 Day #9 | File NG-199302-NYMEX.dly has a volume of 0 at 1993-01-18. | 2022-04-25 10:14:19.394
NG-202206-NYMEX [C] 64 Day #9 | File NG-199301-NYMEX.dly has a volume of 0 at 1992-11-18. | 2022-04-25 10:14:19.398
NG-202206-NYMEX [C] 64 Day #9 | File NG-199301-NYMEX.dly has a volume of 0 at 1992-12-18. | 2022-04-25 10:14:19.398
NG-202206-NYMEX [C] 64 Day #9 | File NG-199212-NYMEX.dly has a volume of 0 at 1992-10-20. | 2022-04-25 10:14:19.402
NG-202206-NYMEX [C] 64 Day #9 | File NG-199212-NYMEX.dly has a volume of 0 at 1992-11-17. | 2022-04-25 10:14:19.402
NG-202206-NYMEX [C] 64 Day #9 | File NG-199211-NYMEX.dly has a volume of 0 at 1992-09-18. | 2022-04-25 10:14:19.407
NG-202206-NYMEX [C] 64 Day #9 | File NG-199211-NYMEX.dly has a volume of 0 at 1992-10-19. | 2022-04-25 10:14:19.407
NG-202206-NYMEX [C] 64 Day #9 | File NG-199210-NYMEX.dly has a volume of 0 at 1992-08-19. | 2022-04-25 10:14:19.411
NG-202206-NYMEX [C] 64 Day #9 | File NG-199210-NYMEX.dly has a volume of 0 at 1992-09-17. | 2022-04-25 10:14:19.411
NG-202206-NYMEX [C] 64 Day #9 | File NG-199209-NYMEX.dly has a volume of 0 at 1992-07-21. | 2022-04-25 10:14:19.415
NG-202206-NYMEX [C] 64 Day #9 | File NG-199209-NYMEX.dly has a volume of 0 at 1992-08-18. | 2022-04-25 10:14:19.415
NG-202206-NYMEX [C] 64 Day #9 | File NG-199208-NYMEX.dly has a volume of 0 at 1992-06-18. | 2022-04-25 10:14:19.419
NG-202206-NYMEX [C] 64 Day #9 | File NG-199208-NYMEX.dly has a volume of 0 at 1992-07-20. | 2022-04-25 10:14:19.419
NG-202206-NYMEX [C] 64 Day #9 | File NG-199207-NYMEX.dly has a volume of 0 at 1992-05-19. | 2022-04-25 10:14:19.423
NG-202206-NYMEX [C] 64 Day #9 | File NG-199207-NYMEX.dly has a volume of 0 at 1992-06-17. | 2022-04-25 10:14:19.423
NG-202206-NYMEX [C] 64 Day #9 | File NG-199206-NYMEX.dly has a volume of 0 at 1992-04-20. | 2022-04-25 10:14:19.428
NG-202206-NYMEX [C] 64 Day #9 | File NG-199206-NYMEX.dly has a volume of 0 at 1992-05-18. | 2022-04-25 10:14:19.428
NG-202206-NYMEX [C] 64 Day #9 | File NG-199205-NYMEX.dly has a volume of 0 at 1992-03-19. | 2022-04-25 10:14:19.432
NG-202206-NYMEX [C] 64 Day #9 | File NG-199205-NYMEX.dly has a volume of 0 at 1992-04-17. | 2022-04-25 10:14:19.432
NG-202206-NYMEX [C] 64 Day #9 | File NG-199204-NYMEX.dly has a volume of 0 at 1992-02-18. | 2022-04-25 10:14:19.436
NG-202206-NYMEX [C] 64 Day #9 | File NG-199204-NYMEX.dly has a volume of 0 at 1992-03-18. | 2022-04-25 10:14:19.436
NG-202206-NYMEX [C] 64 Day #9 | File NG-199203-NYMEX.dly has a volume of 0 at 1992-01-21. | 2022-04-25 10:14:19.440
NG-202206-NYMEX [C] 64 Day #9 | File NG-199203-NYMEX.dly has a volume of 0 at 1992-02-17. | 2022-04-25 10:14:19.440
NG-202206-NYMEX [C] 64 Day #9 | File NG-199202-NYMEX.dly has a volume of 0 at 1991-12-19. | 2022-04-25 10:14:19.444
NG-202206-NYMEX [C] 64 Day #9 | File NG-199202-NYMEX.dly has a volume of 0 at 1992-01-20. | 2022-04-25 10:14:19.444
NG-202206-NYMEX [C] 64 Day #9 | File NG-199201-NYMEX.dly has a volume of 0 at 1991-11-19. | 2022-04-25 10:14:19.448
NG-202206-NYMEX [C] 64 Day #9 | File NG-199201-NYMEX.dly has a volume of 0 at 1991-12-18. | 2022-04-25 10:14:19.448
NG-202206-NYMEX [C] 64 Day #9 | File NG-199112-NYMEX.dly has a volume of 0 at 1991-10-21. | 2022-04-25 10:14:19.452
NG-202206-NYMEX [C] 64 Day #9 | File NG-199112-NYMEX.dly has a volume of 0 at 1991-11-18. | 2022-04-25 10:14:19.452
NG-202206-NYMEX [C] 64 Day #9 | File NG-199111-NYMEX.dly has a volume of 0 at 1991-09-18. | 2022-04-25 10:14:19.457
NG-202206-NYMEX [C] 64 Day #9 | File NG-199111-NYMEX.dly has a volume of 0 at 1991-10-18. | 2022-04-25 10:14:19.457
NG-202206-NYMEX [C] 64 Day #9 | File NG-199110-NYMEX.dly has a volume of 0 at 1991-08-20. | 2022-04-25 10:14:19.461
NG-202206-NYMEX [C] 64 Day #9 | File NG-199110-NYMEX.dly has a volume of 0 at 1991-09-17. | 2022-04-25 10:14:19.461
NG-202206-NYMEX [C] 64 Day #9 | File NG-199109-NYMEX.dly has a volume of 0 at 1991-07-19. | 2022-04-25 10:14:19.465
NG-202206-NYMEX [C] 64 Day #9 | File NG-199109-NYMEX.dly has a volume of 0 at 1991-08-19. | 2022-04-25 10:14:19.465
NG-202206-NYMEX [C] 64 Day #9 | File NG-199108-NYMEX.dly has a volume of 0 at 1991-06-18. | 2022-04-25 10:14:19.469
NG-202206-NYMEX [C] 64 Day #9 | File NG-199108-NYMEX.dly has a volume of 0 at 1991-07-18. | 2022-04-25 10:14:19.469
NG-202206-NYMEX [C] 64 Day #9 | File NG-199107-NYMEX.dly has a volume of 0 at 1991-05-21. | 2022-04-25 10:14:19.473
NG-202206-NYMEX [C] 64 Day #9 | File NG-199107-NYMEX.dly has a volume of 0 at 1991-06-17. | 2022-04-25 10:14:19.473
NG-202206-NYMEX [C] 64 Day #9 | File NG-199106-NYMEX.dly has a volume of 0 at 1991-04-18. | 2022-04-25 10:14:19.477
NG-202206-NYMEX [C] 64 Day #9 | File NG-199106-NYMEX.dly has a volume of 0 at 1991-05-20. | 2022-04-25 10:14:19.477
NG-202206-NYMEX [C] 64 Day #9 | File NG-199105-NYMEX.dly has a volume of 0 at 1991-03-19. | 2022-04-25 10:14:19.481
NG-202206-NYMEX [C] 64 Day #9 | File NG-199105-NYMEX.dly has a volume of 0 at 1991-04-17. | 2022-04-25 10:14:19.481
NG-202206-NYMEX [C] 64 Day #9 | File NG-199104-NYMEX.dly has a volume of 0 at 1991-02-18. | 2022-04-25 10:14:19.485
NG-202206-NYMEX [C] 64 Day #9 | File NG-199104-NYMEX.dly has a volume of 0 at 1991-03-18. | 2022-04-25 10:14:19.485
NG-202206-NYMEX [C] 64 Day #9 | File NG-199103-NYMEX.dly has a volume of 0 at 1991-01-21. | 2022-04-25 10:14:19.488
NG-202206-NYMEX [C] 64 Day #9 | File NG-199103-NYMEX.dly has a volume of 0 at 1991-02-15. | 2022-04-25 10:14:19.488
NG-202206-NYMEX [C] 64 Day #9 | File NG-199102-NYMEX.dly has a volume of 0 at 1990-12-19. | 2022-04-25 10:14:19.492
NG-202206-NYMEX [C] 64 Day #9 | File NG-199102-NYMEX.dly has a volume of 0 at 1991-01-18. | 2022-04-25 10:14:19.492
NG-202206-NYMEX [C] 64 Day #9 | File NG-199101-NYMEX.dly has a volume of 0 at 1990-11-20. | 2022-04-25 10:14:19.496
NG-202206-NYMEX [C] 64 Day #9 | File NG-199101-NYMEX.dly has a volume of 0 at 1990-12-18. | 2022-04-25 10:14:19.496
NG-202206-NYMEX [C] 64 Day #9 | File NG-199012-NYMEX.dly has a volume of 0 at 1990-10-19. | 2022-04-25 10:14:19.500
NG-202206-NYMEX [C] 64 Day #9 | File NG-199012-NYMEX.dly has a volume of 0 at 1990-11-19. | 2022-04-25 10:14:19.500
NG-202206-NYMEX [C] 64 Day #9 | File NG-199011-NYMEX.dly has a volume of 0 at 1990-09-18. | 2022-04-25 10:14:19.504
NG-202206-NYMEX [C] 64 Day #9 | File NG-199011-NYMEX.dly has a volume of 0 at 1990-10-18. | 2022-04-25 10:14:19.504
NG-202206-NYMEX [C] 64 Day #9 | File NG-199010-NYMEX.dly has a volume of 0 at 1990-08-21. | 2022-04-25 10:14:19.507
NG-202206-NYMEX [C] 64 Day #9 | File NG-199010-NYMEX.dly has a volume of 0 at 1990-09-17. | 2022-04-25 10:14:19.507
NG-202206-NYMEX [C] 64 Day #9 | File NG-199009-NYMEX.dly has a volume of 0 at 1990-07-19. | 2022-04-25 10:14:19.512
NG-202206-NYMEX [C] 64 Day #9 | File NG-199009-NYMEX.dly has a volume of 0 at 1990-08-20. | 2022-04-25 10:14:19.512
NG-202206-NYMEX [C] 64 Day #9 | File NG-199008-NYMEX.dly has a volume of 0 at 1990-06-19. | 2022-04-25 10:14:19.516
NG-202206-NYMEX [C] 64 Day #9 | File NG-199008-NYMEX.dly has a volume of 0 at 1990-07-18. | 2022-04-25 10:14:19.516
NG-202206-NYMEX [C] 64 Day #9 | File NG-199007-NYMEX.dly has a volume of 0 at 1990-05-21. | 2022-04-25 10:14:19.519
NG-202206-NYMEX [C] 64 Day #9 | File NG-199007-NYMEX.dly has a volume of 0 at 1990-06-18. | 2022-04-25 10:14:19.519
NG-202206-NYMEX [C] 64 Day #9 | File NG-199006-NYMEX.dly has a volume of 0 at 1990-04-18. | 2022-04-25 10:14:19.523
NG-202206-NYMEX [C] 64 Day #9 | File NG-199006-NYMEX.dly has a volume of 0 at 1990-05-18. | 2022-04-25 10:14:19.523
NG-202206-NYMEX [C] 64 Day #9 | Waiting for historical downloads to complete with the IDs: 22, | 2022-04-25 10:14:19.655
NG-202206-NYMEX [C] 32 Day #1 | Reloading chart. | 2022-04-25 10:14:19.669
NG-202206-NYMEX [C] 32 Day #1 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:19.669
NG-202206-NYMEX [C] 32 Day #1 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:19.669
NG-202206-NYMEX [C] 32 Day #1 | File NG-200102-NYMEX.dly has a volume of 0 at 2000-12-19. | 2022-04-25 10:14:21.443
NG-202206-NYMEX [C] 32 Day #1 | File NG-200101-NYMEX.dly has a volume of 0 at 2000-11-20. | 2022-04-25 10:14:21.448
NG-202206-NYMEX [C] 32 Day #1 | File NG-200101-NYMEX.dly has a volume of 0 at 2000-12-18. | 2022-04-25 10:14:21.448
NG-202206-NYMEX [C] 32 Day #1 | File NG-200012-NYMEX.dly has a volume of 0 at 2000-10-19. | 2022-04-25 10:14:21.452
NG-202206-NYMEX [C] 32 Day #1 | File NG-200012-NYMEX.dly has a volume of 0 at 2000-11-17. | 2022-04-25 10:14:21.452
NG-202206-NYMEX [C] 32 Day #1 | File NG-200011-NYMEX.dly has a volume of 0 at 2000-09-19. | 2022-04-25 10:14:21.457
NG-202206-NYMEX [C] 32 Day #1 | File NG-200011-NYMEX.dly has a volume of 0 at 2000-10-18. | 2022-04-25 10:14:21.457
NG-202206-NYMEX [C] 32 Day #1 | File NG-200010-NYMEX.dly has a volume of 0 at 2000-08-21. | 2022-04-25 10:14:21.462
NG-202206-NYMEX [C] 32 Day #1 | File NG-200010-NYMEX.dly has a volume of 0 at 2000-09-18. | 2022-04-25 10:14:21.462
NG-202206-NYMEX [C] 32 Day #1 | File NG-200009-NYMEX.dly has a volume of 0 at 2000-07-19. | 2022-04-25 10:14:21.467
NG-202206-NYMEX [C] 32 Day #1 | File NG-200009-NYMEX.dly has a volume of 0 at 2000-08-18. | 2022-04-25 10:14:21.467
NG-202206-NYMEX [C] 32 Day #1 | File NG-200008-NYMEX.dly has a volume of 0 at 2000-06-20. | 2022-04-25 10:14:21.471
NG-202206-NYMEX [C] 32 Day #1 | File NG-200008-NYMEX.dly has a volume of 0 at 2000-07-18. | 2022-04-25 10:14:21.471
NG-202206-NYMEX [C] 32 Day #1 | File NG-200007-NYMEX.dly has a volume of 0 at 2000-05-19. | 2022-04-25 10:14:21.476
NG-202206-NYMEX [C] 32 Day #1 | File NG-200007-NYMEX.dly has a volume of 0 at 2000-06-19. | 2022-04-25 10:14:21.476
NG-202206-NYMEX [C] 32 Day #1 | File NG-200006-NYMEX.dly has a volume of 0 at 2000-04-18. | 2022-04-25 10:14:21.481
NG-202206-NYMEX [C] 32 Day #1 | File NG-200006-NYMEX.dly has a volume of 0 at 2000-05-18. | 2022-04-25 10:14:21.481
NG-202206-NYMEX [C] 32 Day #1 | File NG-200005-NYMEX.dly has a volume of 0 at 2000-03-21. | 2022-04-25 10:14:21.485
NG-202206-NYMEX [C] 32 Day #1 | File NG-200005-NYMEX.dly has a volume of 0 at 2000-04-17. | 2022-04-25 10:14:21.485
NG-202206-NYMEX [C] 32 Day #1 | File NG-200004-NYMEX.dly has a volume of 0 at 2000-02-17. | 2022-04-25 10:14:21.490
NG-202206-NYMEX [C] 32 Day #1 | File NG-200004-NYMEX.dly has a volume of 0 at 2000-03-20. | 2022-04-25 10:14:21.490
NG-202206-NYMEX [C] 32 Day #1 | File NG-200003-NYMEX.dly has a volume of 0 at 2000-01-19. | 2022-04-25 10:14:21.495
NG-202206-NYMEX [C] 32 Day #1 | File NG-200003-NYMEX.dly has a volume of 0 at 2000-02-16. | 2022-04-25 10:14:21.495
NG-202206-NYMEX [C] 32 Day #1 | File NG-200002-NYMEX.dly has a volume of 0 at 1999-12-21. | 2022-04-25 10:14:21.499
NG-202206-NYMEX [C] 32 Day #1 | File NG-200002-NYMEX.dly has a volume of 0 at 2000-01-18. | 2022-04-25 10:14:21.499
NG-202206-NYMEX [C] 32 Day #1 | File NG-200001-NYMEX.dly has a volume of 0 at 1999-11-18. | 2022-04-25 10:14:21.503
NG-202206-NYMEX [C] 32 Day #1 | File NG-200001-NYMEX.dly has a volume of 0 at 1999-12-20. | 2022-04-25 10:14:21.503
NG-202206-NYMEX [C] 32 Day #1 | File NG-199912-NYMEX.dly has a volume of 0 at 1999-10-19. | 2022-04-25 10:14:21.508
NG-202206-NYMEX [C] 32 Day #1 | File NG-199912-NYMEX.dly has a volume of 0 at 1999-11-17. | 2022-04-25 10:14:21.508
NG-202206-NYMEX [C] 32 Day #1 | File NG-199911-NYMEX.dly has a volume of 0 at 1999-09-20. | 2022-04-25 10:14:21.513
NG-202206-NYMEX [C] 32 Day #1 | File NG-199911-NYMEX.dly has a volume of 0 at 1999-10-18. | 2022-04-25 10:14:21.513
NG-202206-NYMEX [C] 32 Day #1 | File NG-199910-NYMEX.dly has a volume of 0 at 1999-08-19. | 2022-04-25 10:14:21.517
NG-202206-NYMEX [C] 32 Day #1 | File NG-199910-NYMEX.dly has a volume of 0 at 1999-09-17. | 2022-04-25 10:14:21.517
NG-202206-NYMEX [C] 32 Day #1 | File NG-199909-NYMEX.dly has a volume of 0 at 1999-07-20. | 2022-04-25 10:14:21.522
NG-202206-NYMEX [C] 32 Day #1 | File NG-199909-NYMEX.dly has a volume of 0 at 1999-08-18. | 2022-04-25 10:14:21.522
NG-202206-NYMEX [C] 32 Day #1 | File NG-199908-NYMEX.dly has a volume of 0 at 1999-06-18. | 2022-04-25 10:14:21.527
NG-202206-NYMEX [C] 32 Day #1 | File NG-199908-NYMEX.dly has a volume of 0 at 1999-07-19. | 2022-04-25 10:14:21.527
NG-202206-NYMEX [C] 32 Day #1 | File NG-199907-NYMEX.dly has a volume of 0 at 1999-05-19. | 2022-04-25 10:14:21.532
NG-202206-NYMEX [C] 32 Day #1 | File NG-199907-NYMEX.dly has a volume of 0 at 1999-06-17. | 2022-04-25 10:14:21.532
NG-202206-NYMEX [C] 32 Day #1 | File NG-199906-NYMEX.dly has a volume of 0 at 1999-04-20. | 2022-04-25 10:14:21.536
NG-202206-NYMEX [C] 32 Day #1 | File NG-199906-NYMEX.dly has a volume of 0 at 1999-05-18. | 2022-04-25 10:14:21.536
NG-202206-NYMEX [C] 32 Day #1 | File NG-199905-NYMEX.dly has a volume of 0 at 1999-03-19. | 2022-04-25 10:14:21.541
NG-202206-NYMEX [C] 32 Day #1 | File NG-199905-NYMEX.dly has a volume of 0 at 1999-04-19. | 2022-04-25 10:14:21.541
NG-202206-NYMEX [C] 32 Day #1 | File NG-199904-NYMEX.dly has a volume of 0 at 1999-02-16. | 2022-04-25 10:14:21.546
NG-202206-NYMEX [C] 32 Day #1 | File NG-199904-NYMEX.dly has a volume of 0 at 1999-03-18. | 2022-04-25 10:14:21.546
NG-202206-NYMEX [C] 32 Day #1 | File NG-199903-NYMEX.dly has a volume of 0 at 1999-01-19. | 2022-04-25 10:14:21.550
NG-202206-NYMEX [C] 32 Day #1 | File NG-199903-NYMEX.dly has a volume of 0 at 1999-02-15. | 2022-04-25 10:14:21.550
NG-202206-NYMEX [C] 32 Day #1 | File NG-199902-NYMEX.dly has a volume of 0 at 1998-12-21. | 2022-04-25 10:14:21.554
NG-202206-NYMEX [C] 32 Day #1 | File NG-199902-NYMEX.dly has a volume of 0 at 1999-01-18. | 2022-04-25 10:14:21.554
NG-202206-NYMEX [C] 32 Day #1 | File NG-199901-NYMEX.dly has a volume of 0 at 1998-11-18. | 2022-04-25 10:14:21.559
NG-202206-NYMEX [C] 32 Day #1 | File NG-199901-NYMEX.dly has a volume of 0 at 1998-12-18. | 2022-04-25 10:14:21.559
NG-202206-NYMEX [C] 32 Day #1 | File NG-199812-NYMEX.dly has a volume of 0 at 1998-10-20. | 2022-04-25 10:14:21.563
NG-202206-NYMEX [C] 32 Day #1 | File NG-199812-NYMEX.dly has a volume of 0 at 1998-11-17. | 2022-04-25 10:14:21.563
NG-202206-NYMEX [C] 32 Day #1 | File NG-199811-NYMEX.dly has a volume of 0 at 1998-09-18. | 2022-04-25 10:14:21.568
NG-202206-NYMEX [C] 32 Day #1 | File NG-199811-NYMEX.dly has a volume of 0 at 1998-10-19. | 2022-04-25 10:14:21.568
NG-202206-NYMEX [C] 32 Day #1 | File NG-199810-NYMEX.dly has a volume of 0 at 1998-08-19. | 2022-04-25 10:14:21.573
NG-202206-NYMEX [C] 32 Day #1 | File NG-199810-NYMEX.dly has a volume of 0 at 1998-09-17. | 2022-04-25 10:14:21.573
NG-202206-NYMEX [C] 32 Day #1 | File NG-199809-NYMEX.dly has a volume of 0 at 1998-07-21. | 2022-04-25 10:14:21.577
NG-202206-NYMEX [C] 32 Day #1 | File NG-199809-NYMEX.dly has a volume of 0 at 1998-08-18. | 2022-04-25 10:14:21.577
NG-202206-NYMEX [C] 32 Day #1 | File NG-199808-NYMEX.dly has a volume of 0 at 1998-06-18. | 2022-04-25 10:14:21.582
NG-202206-NYMEX [C] 32 Day #1 | File NG-199808-NYMEX.dly has a volume of 0 at 1998-07-20. | 2022-04-25 10:14:21.582
NG-202206-NYMEX [C] 32 Day #1 | File NG-199807-NYMEX.dly has a volume of 0 at 1998-05-19. | 2022-04-25 10:14:21.587
NG-202206-NYMEX [C] 32 Day #1 | File NG-199807-NYMEX.dly has a volume of 0 at 1998-06-17. | 2022-04-25 10:14:21.587
NG-202206-NYMEX [C] 32 Day #1 | File NG-199806-NYMEX.dly has a volume of 0 at 1998-04-20. | 2022-04-25 10:14:21.592
NG-202206-NYMEX [C] 32 Day #1 | File NG-199806-NYMEX.dly has a volume of 0 at 1998-05-18. | 2022-04-25 10:14:21.592
NG-202206-NYMEX [C] 32 Day #1 | File NG-199805-NYMEX.dly has a volume of 0 at 1998-03-19. | 2022-04-25 10:14:21.596
NG-202206-NYMEX [C] 32 Day #1 | File NG-199805-NYMEX.dly has a volume of 0 at 1998-04-17. | 2022-04-25 10:14:21.596
NG-202206-NYMEX [C] 32 Day #1 | File NG-199804-NYMEX.dly has a volume of 0 at 1998-02-17. | 2022-04-25 10:14:21.601
NG-202206-NYMEX [C] 32 Day #1 | File NG-199804-NYMEX.dly has a volume of 0 at 1998-03-18. | 2022-04-25 10:14:21.601
NG-202206-NYMEX [C] 32 Day #1 | File NG-199803-NYMEX.dly has a volume of 0 at 1998-01-20. | 2022-04-25 10:14:21.606
NG-202206-NYMEX [C] 32 Day #1 | File NG-199803-NYMEX.dly has a volume of 0 at 1998-02-16. | 2022-04-25 10:14:21.606
NG-202206-NYMEX [C] 32 Day #1 | File NG-199802-NYMEX.dly has a volume of 0 at 1997-12-19. | 2022-04-25 10:14:21.610
NG-202206-NYMEX [C] 32 Day #1 | File NG-199802-NYMEX.dly has a volume of 0 at 1998-01-19. | 2022-04-25 10:14:21.610
NG-202206-NYMEX [C] 32 Day #1 | File NG-199801-NYMEX.dly has a volume of 0 at 1997-11-18. | 2022-04-25 10:14:21.615
NG-202206-NYMEX [C] 32 Day #1 | File NG-199801-NYMEX.dly has a volume of 0 at 1997-12-18. | 2022-04-25 10:14:21.615
NG-202206-NYMEX [C] 32 Day #1 | File NG-199712-NYMEX.dly has a volume of 0 at 1997-10-21. | 2022-04-25 10:14:21.619
NG-202206-NYMEX [C] 32 Day #1 | File NG-199712-NYMEX.dly has a volume of 0 at 1997-11-17. | 2022-04-25 10:14:21.619
NG-202206-NYMEX [C] 32 Day #1 | File NG-199711-NYMEX.dly has a volume of 0 at 1997-09-18. | 2022-04-25 10:14:21.624
NG-202206-NYMEX [C] 32 Day #1 | File NG-199711-NYMEX.dly has a volume of 0 at 1997-10-20. | 2022-04-25 10:14:21.624
NG-202206-NYMEX [C] 32 Day #1 | File NG-199710-NYMEX.dly has a volume of 0 at 1997-08-19. | 2022-04-25 10:14:21.629
NG-202206-NYMEX [C] 32 Day #1 | File NG-199710-NYMEX.dly has a volume of 0 at 1997-09-17. | 2022-04-25 10:14:21.629
NG-202206-NYMEX [C] 32 Day #1 | File NG-199709-NYMEX.dly has a volume of 0 at 1997-07-21. | 2022-04-25 10:14:21.633
NG-202206-NYMEX [C] 32 Day #1 | File NG-199709-NYMEX.dly has a volume of 0 at 1997-08-18. | 2022-04-25 10:14:21.633
NG-202206-NYMEX [C] 32 Day #1 | File NG-199708-NYMEX.dly has a volume of 0 at 1997-06-18. | 2022-04-25 10:14:21.638
NG-202206-NYMEX [C] 32 Day #1 | File NG-199708-NYMEX.dly has a volume of 0 at 1997-07-18. | 2022-04-25 10:14:21.638
NG-202206-NYMEX [C] 32 Day #1 | File NG-199707-NYMEX.dly has a volume of 0 at 1997-05-20. | 2022-04-25 10:14:21.643
NG-202206-NYMEX [C] 32 Day #1 | File NG-199707-NYMEX.dly has a volume of 0 at 1997-06-17. | 2022-04-25 10:14:21.643
NG-202206-NYMEX [C] 32 Day #1 | File NG-199706-NYMEX.dly has a volume of 0 at 1997-04-18. | 2022-04-25 10:14:21.648
NG-202206-NYMEX [C] 32 Day #1 | File NG-199706-NYMEX.dly has a volume of 0 at 1997-05-19. | 2022-04-25 10:14:21.648
NG-202206-NYMEX [C] 32 Day #1 | File NG-199705-NYMEX.dly has a volume of 0 at 1997-03-19. | 2022-04-25 10:14:21.652
NG-202206-NYMEX [C] 32 Day #1 | File NG-199705-NYMEX.dly has a volume of 0 at 1997-04-17. | 2022-04-25 10:14:21.652
NG-202206-NYMEX [C] 32 Day #1 | File NG-199704-NYMEX.dly has a volume of 0 at 1997-02-18. | 2022-04-25 10:14:21.657
NG-202206-NYMEX [C] 32 Day #1 | File NG-199704-NYMEX.dly has a volume of 0 at 1997-03-18. | 2022-04-25 10:14:21.657
NG-202206-NYMEX [C] 32 Day #1 | File NG-199703-NYMEX.dly has a volume of 0 at 1997-01-21. | 2022-04-25 10:14:21.661
NG-202206-NYMEX [C] 32 Day #1 | File NG-199703-NYMEX.dly has a volume of 0 at 1997-02-17. | 2022-04-25 10:14:21.661
NG-202206-NYMEX [C] 32 Day #1 | File NG-199702-NYMEX.dly has a volume of 0 at 1996-12-19. | 2022-04-25 10:14:21.665
NG-202206-NYMEX [C] 32 Day #1 | File NG-199702-NYMEX.dly has a volume of 0 at 1997-01-20. | 2022-04-25 10:14:21.665
NG-202206-NYMEX [C] 32 Day #1 | File NG-199701-NYMEX.dly has a volume of 0 at 1996-11-19. | 2022-04-25 10:14:21.669
NG-202206-NYMEX [C] 32 Day #1 | File NG-199701-NYMEX.dly has a volume of 0 at 1996-12-18. | 2022-04-25 10:14:21.669
NG-202206-NYMEX [C] 32 Day #1 | File NG-199612-NYMEX.dly has a volume of 0 at 1996-10-21. | 2022-04-25 10:14:21.673
NG-202206-NYMEX [C] 32 Day #1 | File NG-199612-NYMEX.dly has a volume of 0 at 1996-11-18. | 2022-04-25 10:14:21.673
NG-202206-NYMEX [C] 32 Day #1 | File NG-199611-NYMEX.dly has a volume of 0 at 1996-09-18. | 2022-04-25 10:14:21.678
NG-202206-NYMEX [C] 32 Day #1 | File NG-199611-NYMEX.dly has a volume of 0 at 1996-10-18. | 2022-04-25 10:14:21.678
NG-202206-NYMEX [C] 32 Day #1 | File NG-199610-NYMEX.dly has a volume of 0 at 1996-08-20. | 2022-04-25 10:14:21.682
NG-202206-NYMEX [C] 32 Day #1 | File NG-199610-NYMEX.dly has a volume of 0 at 1996-09-17. | 2022-04-25 10:14:21.682
NG-202206-NYMEX [C] 32 Day #1 | File NG-199609-NYMEX.dly has a volume of 0 at 1996-07-19. | 2022-04-25 10:14:21.687
NG-202206-NYMEX [C] 32 Day #1 | File NG-199609-NYMEX.dly has a volume of 0 at 1996-08-19. | 2022-04-25 10:14:21.687
NG-202206-NYMEX [C] 32 Day #1 | File NG-199608-NYMEX.dly has a volume of 0 at 1996-06-18. | 2022-04-25 10:14:21.691
NG-202206-NYMEX [C] 32 Day #1 | File NG-199608-NYMEX.dly has a volume of 0 at 1996-07-18. | 2022-04-25 10:14:21.691
NG-202206-NYMEX [C] 32 Day #1 | File NG-199607-NYMEX.dly has a volume of 0 at 1996-05-21. | 2022-04-25 10:14:21.695
NG-202206-NYMEX [C] 32 Day #1 | File NG-199607-NYMEX.dly has a volume of 0 at 1996-06-17. | 2022-04-25 10:14:21.695
NG-202206-NYMEX [C] 32 Day #1 | File NG-199606-NYMEX.dly has a volume of 0 at 1996-04-18. | 2022-04-25 10:14:21.700
NG-202206-NYMEX [C] 32 Day #1 | File NG-199606-NYMEX.dly has a volume of 0 at 1996-05-20. | 2022-04-25 10:14:21.700
NG-202206-NYMEX [C] 32 Day #1 | File NG-199605-NYMEX.dly has a volume of 0 at 1996-03-19. | 2022-04-25 10:14:21.704
NG-202206-NYMEX [C] 32 Day #1 | File NG-199605-NYMEX.dly has a volume of 0 at 1996-04-17. | 2022-04-25 10:14:21.704
NG-202206-NYMEX [C] 32 Day #1 | File NG-199604-NYMEX.dly has a volume of 0 at 1996-02-19. | 2022-04-25 10:14:21.708
NG-202206-NYMEX [C] 32 Day #1 | File NG-199604-NYMEX.dly has a volume of 0 at 1996-03-18. | 2022-04-25 10:14:21.708
NG-202206-NYMEX [C] 32 Day #1 | File NG-199603-NYMEX.dly has a volume of 0 at 1996-01-19. | 2022-04-25 10:14:21.713
NG-202206-NYMEX [C] 32 Day #1 | File NG-199603-NYMEX.dly has a volume of 0 at 1996-02-16. | 2022-04-25 10:14:21.713
NG-202206-NYMEX [C] 32 Day #1 | File NG-199602-NYMEX.dly has a volume of 0 at 1995-12-19. | 2022-04-25 10:14:21.717
NG-202206-NYMEX [C] 32 Day #1 | File NG-199602-NYMEX.dly has a volume of 0 at 1996-01-18. | 2022-04-25 10:14:21.717
NG-202206-NYMEX [C] 32 Day #1 | File NG-199601-NYMEX.dly has a volume of 0 at 1995-11-20. | 2022-04-25 10:14:21.721
NG-202206-NYMEX [C] 32 Day #1 | File NG-199601-NYMEX.dly has a volume of 0 at 1995-12-18. | 2022-04-25 10:14:21.721
NG-202206-NYMEX [C] 32 Day #1 | File NG-199512-NYMEX.dly has a volume of 0 at 1995-10-19. | 2022-04-25 10:14:21.725
NG-202206-NYMEX [C] 32 Day #1 | File NG-199512-NYMEX.dly has a volume of 0 at 1995-11-17. | 2022-04-25 10:14:21.725
NG-202206-NYMEX [C] 32 Day #1 | File NG-199511-NYMEX.dly has a volume of 0 at 1995-09-19. | 2022-04-25 10:14:21.729
NG-202206-NYMEX [C] 32 Day #1 | File NG-199511-NYMEX.dly has a volume of 0 at 1995-10-18. | 2022-04-25 10:14:21.729
NG-202206-NYMEX [C] 32 Day #1 | File NG-199510-NYMEX.dly has a volume of 0 at 1995-08-21. | 2022-04-25 10:14:21.733
NG-202206-NYMEX [C] 32 Day #1 | File NG-199510-NYMEX.dly has a volume of 0 at 1995-09-18. | 2022-04-25 10:14:21.733
NG-202206-NYMEX [C] 32 Day #1 | File NG-199509-NYMEX.dly has a volume of 0 at 1995-07-19. | 2022-04-25 10:14:21.738
NG-202206-NYMEX [C] 32 Day #1 | File NG-199509-NYMEX.dly has a volume of 0 at 1995-08-18. | 2022-04-25 10:14:21.738
NG-202206-NYMEX [C] 32 Day #1 | File NG-199508-NYMEX.dly has a volume of 0 at 1995-06-20. | 2022-04-25 10:14:21.742
NG-202206-NYMEX [C] 32 Day #1 | File NG-199508-NYMEX.dly has a volume of 0 at 1995-07-18. | 2022-04-25 10:14:21.742
NG-202206-NYMEX [C] 32 Day #1 | File NG-199507-NYMEX.dly has a volume of 0 at 1995-05-19. | 2022-04-25 10:14:21.746
NG-202206-NYMEX [C] 32 Day #1 | File NG-199507-NYMEX.dly has a volume of 0 at 1995-06-19. | 2022-04-25 10:14:21.746
NG-202206-NYMEX [C] 32 Day #1 | File NG-199506-NYMEX.dly has a volume of 0 at 1995-04-18. | 2022-04-25 10:14:21.751
NG-202206-NYMEX [C] 32 Day #1 | File NG-199506-NYMEX.dly has a volume of 0 at 1995-05-18. | 2022-04-25 10:14:21.751
NG-202206-NYMEX [C] 32 Day #1 | File NG-199505-NYMEX.dly has a volume of 0 at 1995-03-21. | 2022-04-25 10:14:21.755
NG-202206-NYMEX [C] 32 Day #1 | File NG-199505-NYMEX.dly has a volume of 0 at 1995-04-17. | 2022-04-25 10:14:21.755
NG-202206-NYMEX [C] 32 Day #1 | File NG-199504-NYMEX.dly has a volume of 0 at 1995-02-16. | 2022-04-25 10:14:21.759
NG-202206-NYMEX [C] 32 Day #1 | File NG-199504-NYMEX.dly has a volume of 0 at 1995-03-20. | 2022-04-25 10:14:21.759
NG-202206-NYMEX [C] 32 Day #1 | File NG-199503-NYMEX.dly has a volume of 0 at 1995-01-19. | 2022-04-25 10:14:21.763
NG-202206-NYMEX [C] 32 Day #1 | File NG-199503-NYMEX.dly has a volume of 0 at 1995-02-15. | 2022-04-25 10:14:21.763
NG-202206-NYMEX [C] 32 Day #1 | File NG-199502-NYMEX.dly has a volume of 0 at 1994-12-20. | 2022-04-25 10:14:21.767
NG-202206-NYMEX [C] 32 Day #1 | File NG-199502-NYMEX.dly has a volume of 0 at 1995-01-18. | 2022-04-25 10:14:21.767
NG-202206-NYMEX [C] 32 Day #1 | File NG-199501-NYMEX.dly has a volume of 0 at 1994-11-18. | 2022-04-25 10:14:21.771
NG-202206-NYMEX [C] 32 Day #1 | File NG-199501-NYMEX.dly has a volume of 0 at 1994-12-19. | 2022-04-25 10:14:21.771
NG-202206-NYMEX [C] 32 Day #1 | File NG-199412-NYMEX.dly has a volume of 0 at 1994-10-19. | 2022-04-25 10:14:21.775
NG-202206-NYMEX [C] 32 Day #1 | File NG-199412-NYMEX.dly has a volume of 0 at 1994-11-17. | 2022-04-25 10:14:21.775
NG-202206-NYMEX [C] 32 Day #1 | File NG-199411-NYMEX.dly has a volume of 0 at 1994-09-20. | 2022-04-25 10:14:21.779
NG-202206-NYMEX [C] 32 Day #1 | File NG-199411-NYMEX.dly has a volume of 0 at 1994-10-18. | 2022-04-25 10:14:21.779
NG-202206-NYMEX [C] 32 Day #1 | File NG-199410-NYMEX.dly has a volume of 0 at 1994-08-19. | 2022-04-25 10:14:21.783
NG-202206-NYMEX [C] 32 Day #1 | File NG-199410-NYMEX.dly has a volume of 0 at 1994-09-19. | 2022-04-25 10:14:21.783
NG-202206-NYMEX [C] 32 Day #1 | File NG-199409-NYMEX.dly has a volume of 0 at 1994-07-19. | 2022-04-25 10:14:21.788
NG-202206-NYMEX [C] 32 Day #1 | File NG-199409-NYMEX.dly has a volume of 0 at 1994-08-18. | 2022-04-25 10:14:21.788
NG-202206-NYMEX [C] 32 Day #1 | File NG-199408-NYMEX.dly has a volume of 0 at 1994-06-20. | 2022-04-25 10:14:21.792
NG-202206-NYMEX [C] 32 Day #1 | File NG-199408-NYMEX.dly has a volume of 0 at 1994-07-18. | 2022-04-25 10:14:21.792
NG-202206-NYMEX [C] 32 Day #1 | File NG-199407-NYMEX.dly has a volume of 0 at 1994-05-19. | 2022-04-25 10:14:21.796
NG-202206-NYMEX [C] 32 Day #1 | File NG-199407-NYMEX.dly has a volume of 0 at 1994-06-17. | 2022-04-25 10:14:21.796
NG-202206-NYMEX [C] 32 Day #1 | File NG-199406-NYMEX.dly has a volume of 0 at 1994-04-19. | 2022-04-25 10:14:21.800
NG-202206-NYMEX [C] 32 Day #1 | File NG-199406-NYMEX.dly has a volume of 0 at 1994-05-18. | 2022-04-25 10:14:21.800
NG-202206-NYMEX [C] 32 Day #1 | File NG-199405-NYMEX.dly has a volume of 0 at 1994-03-21. | 2022-04-25 10:14:21.804
NG-202206-NYMEX [C] 32 Day #1 | File NG-199405-NYMEX.dly has a volume of 0 at 1994-04-18. | 2022-04-25 10:14:21.804
NG-202206-NYMEX [C] 32 Day #1 | File NG-199404-NYMEX.dly has a volume of 0 at 1994-02-16. | 2022-04-25 10:14:21.809
NG-202206-NYMEX [C] 32 Day #1 | File NG-199404-NYMEX.dly has a volume of 0 at 1994-03-18. | 2022-04-25 10:14:21.809
NG-202206-NYMEX [C] 32 Day #1 | File NG-199403-NYMEX.dly has a volume of 0 at 1994-01-19. | 2022-04-25 10:14:21.813
NG-202206-NYMEX [C] 32 Day #1 | File NG-199403-NYMEX.dly has a volume of 0 at 1994-02-15. | 2022-04-25 10:14:21.813
NG-202206-NYMEX [C] 32 Day #1 | File NG-199402-NYMEX.dly has a volume of 0 at 1993-12-21. | 2022-04-25 10:14:21.817
NG-202206-NYMEX [C] 32 Day #1 | File NG-199402-NYMEX.dly has a volume of 0 at 1994-01-18. | 2022-04-25 10:14:21.817
NG-202206-NYMEX [C] 32 Day #1 | File NG-199401-NYMEX.dly has a volume of 0 at 1993-11-18. | 2022-04-25 10:14:21.821
NG-202206-NYMEX [C] 32 Day #1 | File NG-199401-NYMEX.dly has a volume of 0 at 1993-12-20. | 2022-04-25 10:14:21.821
NG-202206-NYMEX [C] 32 Day #1 | File NG-199312-NYMEX.dly has a volume of 0 at 1993-10-19. | 2022-04-25 10:14:21.825
NG-202206-NYMEX [C] 32 Day #1 | File NG-199312-NYMEX.dly has a volume of 0 at 1993-11-17. | 2022-04-25 10:14:21.825
NG-202206-NYMEX [C] 32 Day #1 | File NG-199311-NYMEX.dly has a volume of 0 at 1993-09-20. | 2022-04-25 10:14:21.829
NG-202206-NYMEX [C] 32 Day #1 | File NG-199311-NYMEX.dly has a volume of 0 at 1993-10-18. | 2022-04-25 10:14:21.829
NG-202206-NYMEX [C] 32 Day #1 | File NG-199310-NYMEX.dly has a volume of 0 at 1993-08-19. | 2022-04-25 10:14:21.833
NG-202206-NYMEX [C] 32 Day #1 | File NG-199310-NYMEX.dly has a volume of 0 at 1993-09-17. | 2022-04-25 10:14:21.833
NG-202206-NYMEX [C] 32 Day #1 | File NG-199309-NYMEX.dly has a volume of 0 at 1993-07-20. | 2022-04-25 10:14:21.838
NG-202206-NYMEX [C] 32 Day #1 | File NG-199309-NYMEX.dly has a volume of 0 at 1993-08-18. | 2022-04-25 10:14:21.838
NG-202206-NYMEX [C] 32 Day #1 | File NG-199308-NYMEX.dly has a volume of 0 at 1993-06-18. | 2022-04-25 10:14:21.842
NG-202206-NYMEX [C] 32 Day #1 | File NG-199308-NYMEX.dly has a volume of 0 at 1993-07-19. | 2022-04-25 10:14:21.842
NG-202206-NYMEX [C] 32 Day #1 | File NG-199307-NYMEX.dly has a volume of 0 at 1993-05-19. | 2022-04-25 10:14:21.846
NG-202206-NYMEX [C] 32 Day #1 | File NG-199307-NYMEX.dly has a volume of 0 at 1993-06-17. | 2022-04-25 10:14:21.846
NG-202206-NYMEX [C] 32 Day #1 | File NG-199306-NYMEX.dly has a volume of 0 at 1993-04-20. | 2022-04-25 10:14:21.850
NG-202206-NYMEX [C] 32 Day #1 | File NG-199306-NYMEX.dly has a volume of 0 at 1993-05-18. | 2022-04-25 10:14:21.850
NG-202206-NYMEX [C] 32 Day #1 | File NG-199305-NYMEX.dly has a volume of 0 at 1993-03-19. | 2022-04-25 10:14:21.854
NG-202206-NYMEX [C] 32 Day #1 | File NG-199305-NYMEX.dly has a volume of 0 at 1993-04-19. | 2022-04-25 10:14:21.854
NG-202206-NYMEX [C] 32 Day #1 | File NG-199304-NYMEX.dly has a volume of 0 at 1993-02-16. | 2022-04-25 10:14:21.858
NG-202206-NYMEX [C] 32 Day #1 | File NG-199304-NYMEX.dly has a volume of 0 at 1993-03-18. | 2022-04-25 10:14:21.858
NG-202206-NYMEX [C] 32 Day #1 | File NG-199303-NYMEX.dly has a volume of 0 at 1993-01-19. | 2022-04-25 10:14:21.862
NG-202206-NYMEX [C] 32 Day #1 | File NG-199303-NYMEX.dly has a volume of 0 at 1993-02-15. | 2022-04-25 10:14:21.862
NG-202206-NYMEX [C] 32 Day #1 | File NG-199302-NYMEX.dly has a volume of 0 at 1992-12-21. | 2022-04-25 10:14:21.866
NG-202206-NYMEX [C] 32 Day #1 | File NG-199302-NYMEX.dly has a volume of 0 at 1993-01-18. | 2022-04-25 10:14:21.866
NG-202206-NYMEX [C] 32 Day #1 | File NG-199301-NYMEX.dly has a volume of 0 at 1992-11-18. | 2022-04-25 10:14:21.870
NG-202206-NYMEX [C] 32 Day #1 | File NG-199301-NYMEX.dly has a volume of 0 at 1992-12-18. | 2022-04-25 10:14:21.870
NG-202206-NYMEX [C] 32 Day #1 | File NG-199212-NYMEX.dly has a volume of 0 at 1992-10-20. | 2022-04-25 10:14:21.874
NG-202206-NYMEX [C] 32 Day #1 | File NG-199212-NYMEX.dly has a volume of 0 at 1992-11-17. | 2022-04-25 10:14:21.874
NG-202206-NYMEX [C] 32 Day #1 | File NG-199211-NYMEX.dly has a volume of 0 at 1992-09-18. | 2022-04-25 10:14:21.879
NG-202206-NYMEX [C] 32 Day #1 | File NG-199211-NYMEX.dly has a volume of 0 at 1992-10-19. | 2022-04-25 10:14:21.879
NG-202206-NYMEX [C] 32 Day #1 | File NG-199210-NYMEX.dly has a volume of 0 at 1992-08-19. | 2022-04-25 10:14:21.883
NG-202206-NYMEX [C] 32 Day #1 | File NG-199210-NYMEX.dly has a volume of 0 at 1992-09-17. | 2022-04-25 10:14:21.883
NG-202206-NYMEX [C] 32 Day #1 | File NG-199209-NYMEX.dly has a volume of 0 at 1992-07-21. | 2022-04-25 10:14:21.887
NG-202206-NYMEX [C] 32 Day #1 | File NG-199209-NYMEX.dly has a volume of 0 at 1992-08-18. | 2022-04-25 10:14:21.887
NG-202206-NYMEX [C] 32 Day #1 | File NG-199208-NYMEX.dly has a volume of 0 at 1992-06-18. | 2022-04-25 10:14:21.891
NG-202206-NYMEX [C] 32 Day #1 | File NG-199208-NYMEX.dly has a volume of 0 at 1992-07-20. | 2022-04-25 10:14:21.891
NG-202206-NYMEX [C] 32 Day #1 | File NG-199207-NYMEX.dly has a volume of 0 at 1992-05-19. | 2022-04-25 10:14:21.895
NG-202206-NYMEX [C] 32 Day #1 | File NG-199207-NYMEX.dly has a volume of 0 at 1992-06-17. | 2022-04-25 10:14:21.895
NG-202206-NYMEX [C] 32 Day #1 | File NG-199206-NYMEX.dly has a volume of 0 at 1992-04-20. | 2022-04-25 10:14:21.899
NG-202206-NYMEX [C] 32 Day #1 | File NG-199206-NYMEX.dly has a volume of 0 at 1992-05-18. | 2022-04-25 10:14:21.899
NG-202206-NYMEX [C] 32 Day #1 | File NG-199205-NYMEX.dly has a volume of 0 at 1992-03-19. | 2022-04-25 10:14:21.904
NG-202206-NYMEX [C] 32 Day #1 | File NG-199205-NYMEX.dly has a volume of 0 at 1992-04-17. | 2022-04-25 10:14:21.904
NG-202206-NYMEX [C] 32 Day #1 | File NG-199204-NYMEX.dly has a volume of 0 at 1992-02-18. | 2022-04-25 10:14:21.908
NG-202206-NYMEX [C] 32 Day #1 | File NG-199204-NYMEX.dly has a volume of 0 at 1992-03-18. | 2022-04-25 10:14:21.908
NG-202206-NYMEX [C] 32 Day #1 | File NG-199203-NYMEX.dly has a volume of 0 at 1992-01-21. | 2022-04-25 10:14:21.912
NG-202206-NYMEX [C] 32 Day #1 | File NG-199203-NYMEX.dly has a volume of 0 at 1992-02-17. | 2022-04-25 10:14:21.912
NG-202206-NYMEX [C] 32 Day #1 | File NG-199202-NYMEX.dly has a volume of 0 at 1991-12-19. | 2022-04-25 10:14:21.916
NG-202206-NYMEX [C] 32 Day #1 | File NG-199202-NYMEX.dly has a volume of 0 at 1992-01-20. | 2022-04-25 10:14:21.916
NG-202206-NYMEX [C] 32 Day #1 | File NG-199201-NYMEX.dly has a volume of 0 at 1991-11-19. | 2022-04-25 10:14:21.920
NG-202206-NYMEX [C] 32 Day #1 | File NG-199201-NYMEX.dly has a volume of 0 at 1991-12-18. | 2022-04-25 10:14:21.920
NG-202206-NYMEX [C] 32 Day #1 | File NG-199112-NYMEX.dly has a volume of 0 at 1991-10-21. | 2022-04-25 10:14:21.924
NG-202206-NYMEX [C] 32 Day #1 | File NG-199112-NYMEX.dly has a volume of 0 at 1991-11-18. | 2022-04-25 10:14:21.924
NG-202206-NYMEX [C] 32 Day #1 | File NG-199111-NYMEX.dly has a volume of 0 at 1991-09-18. | 2022-04-25 10:14:21.929
NG-202206-NYMEX [C] 32 Day #1 | File NG-199111-NYMEX.dly has a volume of 0 at 1991-10-18. | 2022-04-25 10:14:21.929
NG-202206-NYMEX [C] 32 Day #1 | File NG-199110-NYMEX.dly has a volume of 0 at 1991-08-20. | 2022-04-25 10:14:21.933
NG-202206-NYMEX [C] 32 Day #1 | File NG-199110-NYMEX.dly has a volume of 0 at 1991-09-17. | 2022-04-25 10:14:21.933
NG-202206-NYMEX [C] 32 Day #1 | File NG-199109-NYMEX.dly has a volume of 0 at 1991-07-19. | 2022-04-25 10:14:21.937
NG-202206-NYMEX [C] 32 Day #1 | File NG-199109-NYMEX.dly has a volume of 0 at 1991-08-19. | 2022-04-25 10:14:21.937
NG-202206-NYMEX [C] 32 Day #1 | File NG-199108-NYMEX.dly has a volume of 0 at 1991-06-18. | 2022-04-25 10:14:21.941
NG-202206-NYMEX [C] 32 Day #1 | File NG-199108-NYMEX.dly has a volume of 0 at 1991-07-18. | 2022-04-25 10:14:21.941
NG-202206-NYMEX [C] 32 Day #1 | File NG-199107-NYMEX.dly has a volume of 0 at 1991-05-21. | 2022-04-25 10:14:21.945
NG-202206-NYMEX [C] 32 Day #1 | File NG-199107-NYMEX.dly has a volume of 0 at 1991-06-17. | 2022-04-25 10:14:21.945
NG-202206-NYMEX [C] 32 Day #1 | File NG-199106-NYMEX.dly has a volume of 0 at 1991-04-18. | 2022-04-25 10:14:21.949
NG-202206-NYMEX [C] 32 Day #1 | File NG-199106-NYMEX.dly has a volume of 0 at 1991-05-20. | 2022-04-25 10:14:21.949
NG-202206-NYMEX [C] 32 Day #1 | File NG-199105-NYMEX.dly has a volume of 0 at 1991-03-19. | 2022-04-25 10:14:21.953
NG-202206-NYMEX [C] 32 Day #1 | File NG-199105-NYMEX.dly has a volume of 0 at 1991-04-17. | 2022-04-25 10:14:21.953
NG-202206-NYMEX [C] 32 Day #1 | File NG-199104-NYMEX.dly has a volume of 0 at 1991-02-18. | 2022-04-25 10:14:21.957
NG-202206-NYMEX [C] 32 Day #1 | File NG-199104-NYMEX.dly has a volume of 0 at 1991-03-18. | 2022-04-25 10:14:21.957
NG-202206-NYMEX [C] 32 Day #1 | File NG-199103-NYMEX.dly has a volume of 0 at 1991-01-21. | 2022-04-25 10:14:21.961
NG-202206-NYMEX [C] 32 Day #1 | File NG-199103-NYMEX.dly has a volume of 0 at 1991-02-15. | 2022-04-25 10:14:21.961
NG-202206-NYMEX [C] 32 Day #1 | File NG-199102-NYMEX.dly has a volume of 0 at 1990-12-19. | 2022-04-25 10:14:21.965
NG-202206-NYMEX [C] 32 Day #1 | File NG-199102-NYMEX.dly has a volume of 0 at 1991-01-18. | 2022-04-25 10:14:21.965
NG-202206-NYMEX [C] 32 Day #1 | File NG-199101-NYMEX.dly has a volume of 0 at 1990-11-20. | 2022-04-25 10:14:21.968
NG-202206-NYMEX [C] 32 Day #1 | File NG-199101-NYMEX.dly has a volume of 0 at 1990-12-18. | 2022-04-25 10:14:21.968
NG-202206-NYMEX [C] 32 Day #1 | File NG-199012-NYMEX.dly has a volume of 0 at 1990-10-19. | 2022-04-25 10:14:21.972
NG-202206-NYMEX [C] 32 Day #1 | File NG-199012-NYMEX.dly has a volume of 0 at 1990-11-19. | 2022-04-25 10:14:21.972
NG-202206-NYMEX [C] 32 Day #1 | File NG-199011-NYMEX.dly has a volume of 0 at 1990-09-18. | 2022-04-25 10:14:21.976
NG-202206-NYMEX [C] 32 Day #1 | File NG-199011-NYMEX.dly has a volume of 0 at 1990-10-18. | 2022-04-25 10:14:21.976
NG-202206-NYMEX [C] 32 Day #1 | File NG-199010-NYMEX.dly has a volume of 0 at 1990-08-21. | 2022-04-25 10:14:21.980
NG-202206-NYMEX [C] 32 Day #1 | File NG-199010-NYMEX.dly has a volume of 0 at 1990-09-17. | 2022-04-25 10:14:21.980
NG-202206-NYMEX [C] 32 Day #1 | File NG-199009-NYMEX.dly has a volume of 0 at 1990-07-19. | 2022-04-25 10:14:21.984
NG-202206-NYMEX [C] 32 Day #1 | File NG-199009-NYMEX.dly has a volume of 0 at 1990-08-20. | 2022-04-25 10:14:21.984
NG-202206-NYMEX [C] 32 Day #1 | File NG-199008-NYMEX.dly has a volume of 0 at 1990-06-19. | 2022-04-25 10:14:21.988
NG-202206-NYMEX [C] 32 Day #1 | File NG-199008-NYMEX.dly has a volume of 0 at 1990-07-18. | 2022-04-25 10:14:21.988
NG-202206-NYMEX [C] 32 Day #1 | File NG-199007-NYMEX.dly has a volume of 0 at 1990-05-21. | 2022-04-25 10:14:21.992
NG-202206-NYMEX [C] 32 Day #1 | File NG-199007-NYMEX.dly has a volume of 0 at 1990-06-18. | 2022-04-25 10:14:21.992
NG-202206-NYMEX [C] 32 Day #1 | File NG-199006-NYMEX.dly has a volume of 0 at 1990-04-18. | 2022-04-25 10:14:21.996
NG-202206-NYMEX [C] 32 Day #1 | File NG-199006-NYMEX.dly has a volume of 0 at 1990-05-18. | 2022-04-25 10:14:21.996
NG-202206-NYMEX [C] 32 Day #1 | Waiting for historical downloads to complete with the IDs: 22, | 2022-04-25 10:14:22.127
NG-202206-NYMEX [C] 4 Day #4 | Reloading chart. | 2022-04-25 10:14:22.138
NG-202206-NYMEX [C] 4 Day #4 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:22.138
NG-202206-NYMEX [C] 4 Day #4 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:22.138
NG-202206-NYMEX [C] 4 Day #4 | File NG-200102-NYMEX.dly has a volume of 0 at 2000-12-19. | 2022-04-25 10:14:23.913
NG-202206-NYMEX [C] 4 Day #4 | File NG-200101-NYMEX.dly has a volume of 0 at 2000-11-20. | 2022-04-25 10:14:23.917
NG-202206-NYMEX [C] 4 Day #4 | File NG-200101-NYMEX.dly has a volume of 0 at 2000-12-18. | 2022-04-25 10:14:23.917
NG-202206-NYMEX [C] 4 Day #4 | File NG-200012-NYMEX.dly has a volume of 0 at 2000-10-19. | 2022-04-25 10:14:23.922
NG-202206-NYMEX [C] 4 Day #4 | File NG-200012-NYMEX.dly has a volume of 0 at 2000-11-17. | 2022-04-25 10:14:23.922
NG-202206-NYMEX [C] 4 Day #4 | File NG-200011-NYMEX.dly has a volume of 0 at 2000-09-19. | 2022-04-25 10:14:23.927
NG-202206-NYMEX [C] 4 Day #4 | File NG-200011-NYMEX.dly has a volume of 0 at 2000-10-18. | 2022-04-25 10:14:23.927
NG-202206-NYMEX [C] 4 Day #4 | File NG-200010-NYMEX.dly has a volume of 0 at 2000-08-21. | 2022-04-25 10:14:23.931
NG-202206-NYMEX [C] 4 Day #4 | File NG-200010-NYMEX.dly has a volume of 0 at 2000-09-18. | 2022-04-25 10:14:23.931
NG-202206-NYMEX [C] 4 Day #4 | File NG-200009-NYMEX.dly has a volume of 0 at 2000-07-19. | 2022-04-25 10:14:23.936
NG-202206-NYMEX [C] 4 Day #4 | File NG-200009-NYMEX.dly has a volume of 0 at 2000-08-18. | 2022-04-25 10:14:23.936
NG-202206-NYMEX [C] 4 Day #4 | File NG-200008-NYMEX.dly has a volume of 0 at 2000-06-20. | 2022-04-25 10:14:23.941
NG-202206-NYMEX [C] 4 Day #4 | File NG-200008-NYMEX.dly has a volume of 0 at 2000-07-18. | 2022-04-25 10:14:23.941
NG-202206-NYMEX [C] 4 Day #4 | File NG-200007-NYMEX.dly has a volume of 0 at 2000-05-19. | 2022-04-25 10:14:23.945
NG-202206-NYMEX [C] 4 Day #4 | File NG-200007-NYMEX.dly has a volume of 0 at 2000-06-19. | 2022-04-25 10:14:23.945
NG-202206-NYMEX [C] 4 Day #4 | File NG-200006-NYMEX.dly has a volume of 0 at 2000-04-18. | 2022-04-25 10:14:23.950
NG-202206-NYMEX [C] 4 Day #4 | File NG-200006-NYMEX.dly has a volume of 0 at 2000-05-18. | 2022-04-25 10:14:23.950
NG-202206-NYMEX [C] 4 Day #4 | File NG-200005-NYMEX.dly has a volume of 0 at 2000-03-21. | 2022-04-25 10:14:23.955
NG-202206-NYMEX [C] 4 Day #4 | File NG-200005-NYMEX.dly has a volume of 0 at 2000-04-17. | 2022-04-25 10:14:23.955
NG-202206-NYMEX [C] 4 Day #4 | File NG-200004-NYMEX.dly has a volume of 0 at 2000-02-17. | 2022-04-25 10:14:23.959
NG-202206-NYMEX [C] 4 Day #4 | File NG-200004-NYMEX.dly has a volume of 0 at 2000-03-20. | 2022-04-25 10:14:23.959
NG-202206-NYMEX [C] 4 Day #4 | File NG-200003-NYMEX.dly has a volume of 0 at 2000-01-19. | 2022-04-25 10:14:23.964
NG-202206-NYMEX [C] 4 Day #4 | File NG-200003-NYMEX.dly has a volume of 0 at 2000-02-16. | 2022-04-25 10:14:23.964
NG-202206-NYMEX [C] 4 Day #4 | File NG-200002-NYMEX.dly has a volume of 0 at 1999-12-21. | 2022-04-25 10:14:23.968
NG-202206-NYMEX [C] 4 Day #4 | File NG-200002-NYMEX.dly has a volume of 0 at 2000-01-18. | 2022-04-25 10:14:23.968
NG-202206-NYMEX [C] 4 Day #4 | File NG-200001-NYMEX.dly has a volume of 0 at 1999-11-18. | 2022-04-25 10:14:23.973
NG-202206-NYMEX [C] 4 Day #4 | File NG-200001-NYMEX.dly has a volume of 0 at 1999-12-20. | 2022-04-25 10:14:23.973
NG-202206-NYMEX [C] 4 Day #4 | File NG-199912-NYMEX.dly has a volume of 0 at 1999-10-19. | 2022-04-25 10:14:23.977
NG-202206-NYMEX [C] 4 Day #4 | File NG-199912-NYMEX.dly has a volume of 0 at 1999-11-17. | 2022-04-25 10:14:23.977
NG-202206-NYMEX [C] 4 Day #4 | File NG-199911-NYMEX.dly has a volume of 0 at 1999-09-20. | 2022-04-25 10:14:23.982
NG-202206-NYMEX [C] 4 Day #4 | File NG-199911-NYMEX.dly has a volume of 0 at 1999-10-18. | 2022-04-25 10:14:23.982
NG-202206-NYMEX [C] 4 Day #4 | File NG-199910-NYMEX.dly has a volume of 0 at 1999-08-19. | 2022-04-25 10:14:23.987
NG-202206-NYMEX [C] 4 Day #4 | File NG-199910-NYMEX.dly has a volume of 0 at 1999-09-17. | 2022-04-25 10:14:23.987
NG-202206-NYMEX [C] 4 Day #4 | File NG-199909-NYMEX.dly has a volume of 0 at 1999-07-20. | 2022-04-25 10:14:23.991
NG-202206-NYMEX [C] 4 Day #4 | File NG-199909-NYMEX.dly has a volume of 0 at 1999-08-18. | 2022-04-25 10:14:23.992
NG-202206-NYMEX [C] 4 Day #4 | File NG-199908-NYMEX.dly has a volume of 0 at 1999-06-18. | 2022-04-25 10:14:23.996
NG-202206-NYMEX [C] 4 Day #4 | File NG-199908-NYMEX.dly has a volume of 0 at 1999-07-19. | 2022-04-25 10:14:23.996
NG-202206-NYMEX [C] 4 Day #4 | File NG-199907-NYMEX.dly has a volume of 0 at 1999-05-19. | 2022-04-25 10:14:24.001
NG-202206-NYMEX [C] 4 Day #4 | File NG-199907-NYMEX.dly has a volume of 0 at 1999-06-17. | 2022-04-25 10:14:24.001
NG-202206-NYMEX [C] 4 Day #4 | File NG-199906-NYMEX.dly has a volume of 0 at 1999-04-20. | 2022-04-25 10:14:24.006
NG-202206-NYMEX [C] 4 Day #4 | File NG-199906-NYMEX.dly has a volume of 0 at 1999-05-18. | 2022-04-25 10:14:24.006
NG-202206-NYMEX [C] 4 Day #4 | File NG-199905-NYMEX.dly has a volume of 0 at 1999-03-19. | 2022-04-25 10:14:24.010
NG-202206-NYMEX [C] 4 Day #4 | File NG-199905-NYMEX.dly has a volume of 0 at 1999-04-19. | 2022-04-25 10:14:24.010
NG-202206-NYMEX [C] 4 Day #4 | File NG-199904-NYMEX.dly has a volume of 0 at 1999-02-16. | 2022-04-25 10:14:24.015
NG-202206-NYMEX [C] 4 Day #4 | File NG-199904-NYMEX.dly has a volume of 0 at 1999-03-18. | 2022-04-25 10:14:24.015
NG-202206-NYMEX [C] 4 Day #4 | File NG-199903-NYMEX.dly has a volume of 0 at 1999-01-19. | 2022-04-25 10:14:24.020
NG-202206-NYMEX [C] 4 Day #4 | File NG-199903-NYMEX.dly has a volume of 0 at 1999-02-15. | 2022-04-25 10:14:24.020
NG-202206-NYMEX [C] 4 Day #4 | File NG-199902-NYMEX.dly has a volume of 0 at 1998-12-21. | 2022-04-25 10:14:24.024
NG-202206-NYMEX [C] 4 Day #4 | File NG-199902-NYMEX.dly has a volume of 0 at 1999-01-18. | 2022-04-25 10:14:24.024
NG-202206-NYMEX [C] 4 Day #4 | File NG-199901-NYMEX.dly has a volume of 0 at 1998-11-18. | 2022-04-25 10:14:24.028
NG-202206-NYMEX [C] 4 Day #4 | File NG-199901-NYMEX.dly has a volume of 0 at 1998-12-18. | 2022-04-25 10:14:24.028
NG-202206-NYMEX [C] 4 Day #4 | File NG-199812-NYMEX.dly has a volume of 0 at 1998-10-20. | 2022-04-25 10:14:24.033
NG-202206-NYMEX [C] 4 Day #4 | File NG-199812-NYMEX.dly has a volume of 0 at 1998-11-17. | 2022-04-25 10:14:24.033
NG-202206-NYMEX [C] 4 Day #4 | File NG-199811-NYMEX.dly has a volume of 0 at 1998-09-18. | 2022-04-25 10:14:24.038
NG-202206-NYMEX [C] 4 Day #4 | File NG-199811-NYMEX.dly has a volume of 0 at 1998-10-19. | 2022-04-25 10:14:24.038
NG-202206-NYMEX [C] 4 Day #4 | File NG-199810-NYMEX.dly has a volume of 0 at 1998-08-19. | 2022-04-25 10:14:24.042
NG-202206-NYMEX [C] 4 Day #4 | File NG-199810-NYMEX.dly has a volume of 0 at 1998-09-17. | 2022-04-25 10:14:24.042
NG-202206-NYMEX [C] 4 Day #4 | File NG-199809-NYMEX.dly has a volume of 0 at 1998-07-21. | 2022-04-25 10:14:24.047
NG-202206-NYMEX [C] 4 Day #4 | File NG-199809-NYMEX.dly has a volume of 0 at 1998-08-18. | 2022-04-25 10:14:24.047
NG-202206-NYMEX [C] 4 Day #4 | File NG-199808-NYMEX.dly has a volume of 0 at 1998-06-18. | 2022-04-25 10:14:24.052
NG-202206-NYMEX [C] 4 Day #4 | File NG-199808-NYMEX.dly has a volume of 0 at 1998-07-20. | 2022-04-25 10:14:24.052
NG-202206-NYMEX [C] 4 Day #4 | File NG-199807-NYMEX.dly has a volume of 0 at 1998-05-19. | 2022-04-25 10:14:24.057
NG-202206-NYMEX [C] 4 Day #4 | File NG-199807-NYMEX.dly has a volume of 0 at 1998-06-17. | 2022-04-25 10:14:24.057
NG-202206-NYMEX [C] 4 Day #4 | File NG-199806-NYMEX.dly has a volume of 0 at 1998-04-20. | 2022-04-25 10:14:24.061
NG-202206-NYMEX [C] 4 Day #4 | File NG-199806-NYMEX.dly has a volume of 0 at 1998-05-18. | 2022-04-25 10:14:24.061
NG-202206-NYMEX [C] 4 Day #4 | File NG-199805-NYMEX.dly has a volume of 0 at 1998-03-19. | 2022-04-25 10:14:24.066
NG-202206-NYMEX [C] 4 Day #4 | File NG-199805-NYMEX.dly has a volume of 0 at 1998-04-17. | 2022-04-25 10:14:24.066
NG-202206-NYMEX [C] 4 Day #4 | File NG-199804-NYMEX.dly has a volume of 0 at 1998-02-17. | 2022-04-25 10:14:24.071
NG-202206-NYMEX [C] 4 Day #4 | File NG-199804-NYMEX.dly has a volume of 0 at 1998-03-18. | 2022-04-25 10:14:24.071
NG-202206-NYMEX [C] 4 Day #4 | File NG-199803-NYMEX.dly has a volume of 0 at 1998-01-20. | 2022-04-25 10:14:24.076
NG-202206-NYMEX [C] 4 Day #4 | File NG-199803-NYMEX.dly has a volume of 0 at 1998-02-16. | 2022-04-25 10:14:24.076
NG-202206-NYMEX [C] 4 Day #4 | File NG-199802-NYMEX.dly has a volume of 0 at 1997-12-19. | 2022-04-25 10:14:24.080
NG-202206-NYMEX [C] 4 Day #4 | File NG-199802-NYMEX.dly has a volume of 0 at 1998-01-19. | 2022-04-25 10:14:24.080
NG-202206-NYMEX [C] 4 Day #4 | File NG-199801-NYMEX.dly has a volume of 0 at 1997-11-18. | 2022-04-25 10:14:24.085
NG-202206-NYMEX [C] 4 Day #4 | File NG-199801-NYMEX.dly has a volume of 0 at 1997-12-18. | 2022-04-25 10:14:24.085
NG-202206-NYMEX [C] 4 Day #4 | File NG-199712-NYMEX.dly has a volume of 0 at 1997-10-21. | 2022-04-25 10:14:24.089
NG-202206-NYMEX [C] 4 Day #4 | File NG-199712-NYMEX.dly has a volume of 0 at 1997-11-17. | 2022-04-25 10:14:24.089
NG-202206-NYMEX [C] 4 Day #4 | File NG-199711-NYMEX.dly has a volume of 0 at 1997-09-18. | 2022-04-25 10:14:24.094
NG-202206-NYMEX [C] 4 Day #4 | File NG-199711-NYMEX.dly has a volume of 0 at 1997-10-20. | 2022-04-25 10:14:24.094
NG-202206-NYMEX [C] 4 Day #4 | File NG-199710-NYMEX.dly has a volume of 0 at 1997-08-19. | 2022-04-25 10:14:24.098
NG-202206-NYMEX [C] 4 Day #4 | File NG-199710-NYMEX.dly has a volume of 0 at 1997-09-17. | 2022-04-25 10:14:24.098
NG-202206-NYMEX [C] 4 Day #4 | File NG-199709-NYMEX.dly has a volume of 0 at 1997-07-21. | 2022-04-25 10:14:24.103
NG-202206-NYMEX [C] 4 Day #4 | File NG-199709-NYMEX.dly has a volume of 0 at 1997-08-18. | 2022-04-25 10:14:24.103
NG-202206-NYMEX [C] 4 Day #4 | File NG-199708-NYMEX.dly has a volume of 0 at 1997-06-18. | 2022-04-25 10:14:24.108
NG-202206-NYMEX [C] 4 Day #4 | File NG-199708-NYMEX.dly has a volume of 0 at 1997-07-18. | 2022-04-25 10:14:24.108
NG-202206-NYMEX [C] 4 Day #4 | File NG-199707-NYMEX.dly has a volume of 0 at 1997-05-20. | 2022-04-25 10:14:24.113
NG-202206-NYMEX [C] 4 Day #4 | File NG-199707-NYMEX.dly has a volume of 0 at 1997-06-17. | 2022-04-25 10:14:24.113
NG-202206-NYMEX [C] 4 Day #4 | File NG-199706-NYMEX.dly has a volume of 0 at 1997-04-18. | 2022-04-25 10:14:24.117
NG-202206-NYMEX [C] 4 Day #4 | File NG-199706-NYMEX.dly has a volume of 0 at 1997-05-19. | 2022-04-25 10:14:24.117
NG-202206-NYMEX [C] 4 Day #4 | File NG-199705-NYMEX.dly has a volume of 0 at 1997-03-19. | 2022-04-25 10:14:24.122
NG-202206-NYMEX [C] 4 Day #4 | File NG-199705-NYMEX.dly has a volume of 0 at 1997-04-17. | 2022-04-25 10:14:24.122
NG-202206-NYMEX [C] 4 Day #4 | File NG-199704-NYMEX.dly has a volume of 0 at 1997-02-18. | 2022-04-25 10:14:24.126
NG-202206-NYMEX [C] 4 Day #4 | File NG-199704-NYMEX.dly has a volume of 0 at 1997-03-18. | 2022-04-25 10:14:24.126
NG-202206-NYMEX [C] 4 Day #4 | File NG-199703-NYMEX.dly has a volume of 0 at 1997-01-21. | 2022-04-25 10:14:24.130
NG-202206-NYMEX [C] 4 Day #4 | File NG-199703-NYMEX.dly has a volume of 0 at 1997-02-17. | 2022-04-25 10:14:24.130
NG-202206-NYMEX [C] 4 Day #4 | File NG-199702-NYMEX.dly has a volume of 0 at 1996-12-19. | 2022-04-25 10:14:24.135
NG-202206-NYMEX [C] 4 Day #4 | File NG-199702-NYMEX.dly has a volume of 0 at 1997-01-20. | 2022-04-25 10:14:24.135
NG-202206-NYMEX [C] 4 Day #4 | File NG-199701-NYMEX.dly has a volume of 0 at 1996-11-19. | 2022-04-25 10:14:24.139
NG-202206-NYMEX [C] 4 Day #4 | File NG-199701-NYMEX.dly has a volume of 0 at 1996-12-18. | 2022-04-25 10:14:24.139
NG-202206-NYMEX [C] 4 Day #4 | File NG-199612-NYMEX.dly has a volume of 0 at 1996-10-21. | 2022-04-25 10:14:24.143
NG-202206-NYMEX [C] 4 Day #4 | File NG-199612-NYMEX.dly has a volume of 0 at 1996-11-18. | 2022-04-25 10:14:24.143
NG-202206-NYMEX [C] 4 Day #4 | File NG-199611-NYMEX.dly has a volume of 0 at 1996-09-18. | 2022-04-25 10:14:24.148
NG-202206-NYMEX [C] 4 Day #4 | File NG-199611-NYMEX.dly has a volume of 0 at 1996-10-18. | 2022-04-25 10:14:24.148
NG-202206-NYMEX [C] 4 Day #4 | File NG-199610-NYMEX.dly has a volume of 0 at 1996-08-20. | 2022-04-25 10:14:24.152
NG-202206-NYMEX [C] 4 Day #4 | File NG-199610-NYMEX.dly has a volume of 0 at 1996-09-17. | 2022-04-25 10:14:24.152
NG-202206-NYMEX [C] 4 Day #4 | File NG-199609-NYMEX.dly has a volume of 0 at 1996-07-19. | 2022-04-25 10:14:24.156
NG-202206-NYMEX [C] 4 Day #4 | File NG-199609-NYMEX.dly has a volume of 0 at 1996-08-19. | 2022-04-25 10:14:24.156
NG-202206-NYMEX [C] 4 Day #4 | File NG-199608-NYMEX.dly has a volume of 0 at 1996-06-18. | 2022-04-25 10:14:24.161
NG-202206-NYMEX [C] 4 Day #4 | File NG-199608-NYMEX.dly has a volume of 0 at 1996-07-18. | 2022-04-25 10:14:24.161
NG-202206-NYMEX [C] 4 Day #4 | File NG-199607-NYMEX.dly has a volume of 0 at 1996-05-21. | 2022-04-25 10:14:24.165
NG-202206-NYMEX [C] 4 Day #4 | File NG-199607-NYMEX.dly has a volume of 0 at 1996-06-17. | 2022-04-25 10:14:24.165
NG-202206-NYMEX [C] 4 Day #4 | File NG-199606-NYMEX.dly has a volume of 0 at 1996-04-18. | 2022-04-25 10:14:24.170
NG-202206-NYMEX [C] 4 Day #4 | File NG-199606-NYMEX.dly has a volume of 0 at 1996-05-20. | 2022-04-25 10:14:24.170
NG-202206-NYMEX [C] 4 Day #4 | File NG-199605-NYMEX.dly has a volume of 0 at 1996-03-19. | 2022-04-25 10:14:24.174
NG-202206-NYMEX [C] 4 Day #4 | File NG-199605-NYMEX.dly has a volume of 0 at 1996-04-17. | 2022-04-25 10:14:24.174
NG-202206-NYMEX [C] 4 Day #4 | File NG-199604-NYMEX.dly has a volume of 0 at 1996-02-19. | 2022-04-25 10:14:24.179
NG-202206-NYMEX [C] 4 Day #4 | File NG-199604-NYMEX.dly has a volume of 0 at 1996-03-18. | 2022-04-25 10:14:24.179
NG-202206-NYMEX [C] 4 Day #4 | File NG-199603-NYMEX.dly has a volume of 0 at 1996-01-19. | 2022-04-25 10:14:24.183
NG-202206-NYMEX [C] 4 Day #4 | File NG-199603-NYMEX.dly has a volume of 0 at 1996-02-16. | 2022-04-25 10:14:24.183
NG-202206-NYMEX [C] 4 Day #4 | File NG-199602-NYMEX.dly has a volume of 0 at 1995-12-19. | 2022-04-25 10:14:24.187
NG-202206-NYMEX [C] 4 Day #4 | File NG-199602-NYMEX.dly has a volume of 0 at 1996-01-18. | 2022-04-25 10:14:24.187
NG-202206-NYMEX [C] 4 Day #4 | File NG-199601-NYMEX.dly has a volume of 0 at 1995-11-20. | 2022-04-25 10:14:24.191
NG-202206-NYMEX [C] 4 Day #4 | File NG-199601-NYMEX.dly has a volume of 0 at 1995-12-18. | 2022-04-25 10:14:24.191
NG-202206-NYMEX [C] 4 Day #4 | File NG-199512-NYMEX.dly has a volume of 0 at 1995-10-19. | 2022-04-25 10:14:24.195
NG-202206-NYMEX [C] 4 Day #4 | File NG-199512-NYMEX.dly has a volume of 0 at 1995-11-17. | 2022-04-25 10:14:24.195
NG-202206-NYMEX [C] 4 Day #4 | File NG-199511-NYMEX.dly has a volume of 0 at 1995-09-19. | 2022-04-25 10:14:24.200
NG-202206-NYMEX [C] 4 Day #4 | File NG-199511-NYMEX.dly has a volume of 0 at 1995-10-18. | 2022-04-25 10:14:24.200
NG-202206-NYMEX [C] 4 Day #4 | File NG-199510-NYMEX.dly has a volume of 0 at 1995-08-21. | 2022-04-25 10:14:24.204
NG-202206-NYMEX [C] 4 Day #4 | File NG-199510-NYMEX.dly has a volume of 0 at 1995-09-18. | 2022-04-25 10:14:24.204
NG-202206-NYMEX [C] 4 Day #4 | File NG-199509-NYMEX.dly has a volume of 0 at 1995-07-19. | 2022-04-25 10:14:24.208
NG-202206-NYMEX [C] 4 Day #4 | File NG-199509-NYMEX.dly has a volume of 0 at 1995-08-18. | 2022-04-25 10:14:24.208
NG-202206-NYMEX [C] 4 Day #4 | File NG-199508-NYMEX.dly has a volume of 0 at 1995-06-20. | 2022-04-25 10:14:24.213
NG-202206-NYMEX [C] 4 Day #4 | File NG-199508-NYMEX.dly has a volume of 0 at 1995-07-18. | 2022-04-25 10:14:24.213
NG-202206-NYMEX [C] 4 Day #4 | File NG-199507-NYMEX.dly has a volume of 0 at 1995-05-19. | 2022-04-25 10:14:24.217
NG-202206-NYMEX [C] 4 Day #4 | File NG-199507-NYMEX.dly has a volume of 0 at 1995-06-19. | 2022-04-25 10:14:24.217
NG-202206-NYMEX [C] 4 Day #4 | File NG-199506-NYMEX.dly has a volume of 0 at 1995-04-18. | 2022-04-25 10:14:24.221
NG-202206-NYMEX [C] 4 Day #4 | File NG-199506-NYMEX.dly has a volume of 0 at 1995-05-18. | 2022-04-25 10:14:24.221
NG-202206-NYMEX [C] 4 Day #4 | File NG-199505-NYMEX.dly has a volume of 0 at 1995-03-21. | 2022-04-25 10:14:24.225
NG-202206-NYMEX [C] 4 Day #4 | File NG-199505-NYMEX.dly has a volume of 0 at 1995-04-17. | 2022-04-25 10:14:24.225
NG-202206-NYMEX [C] 4 Day #4 | File NG-199504-NYMEX.dly has a volume of 0 at 1995-02-16. | 2022-04-25 10:14:24.230
NG-202206-NYMEX [C] 4 Day #4 | File NG-199504-NYMEX.dly has a volume of 0 at 1995-03-20. | 2022-04-25 10:14:24.230
NG-202206-NYMEX [C] 4 Day #4 | File NG-199503-NYMEX.dly has a volume of 0 at 1995-01-19. | 2022-04-25 10:14:24.234
NG-202206-NYMEX [C] 4 Day #4 | File NG-199503-NYMEX.dly has a volume of 0 at 1995-02-15. | 2022-04-25 10:14:24.234
NG-202206-NYMEX [C] 4 Day #4 | File NG-199502-NYMEX.dly has a volume of 0 at 1994-12-20. | 2022-04-25 10:14:24.238
NG-202206-NYMEX [C] 4 Day #4 | File NG-199502-NYMEX.dly has a volume of 0 at 1995-01-18. | 2022-04-25 10:14:24.238
NG-202206-NYMEX [C] 4 Day #4 | File NG-199501-NYMEX.dly has a volume of 0 at 1994-11-18. | 2022-04-25 10:14:24.241
NG-202206-NYMEX [C] 4 Day #4 | File NG-199501-NYMEX.dly has a volume of 0 at 1994-12-19. | 2022-04-25 10:14:24.242
NG-202206-NYMEX [C] 4 Day #4 | File NG-199412-NYMEX.dly has a volume of 0 at 1994-10-19. | 2022-04-25 10:14:24.246
NG-202206-NYMEX [C] 4 Day #4 | File NG-199412-NYMEX.dly has a volume of 0 at 1994-11-17. | 2022-04-25 10:14:24.246
NG-202206-NYMEX [C] 4 Day #4 | File NG-199411-NYMEX.dly has a volume of 0 at 1994-09-20. | 2022-04-25 10:14:24.250
NG-202206-NYMEX [C] 4 Day #4 | File NG-199411-NYMEX.dly has a volume of 0 at 1994-10-18. | 2022-04-25 10:14:24.250
NG-202206-NYMEX [C] 4 Day #4 | File NG-199410-NYMEX.dly has a volume of 0 at 1994-08-19. | 2022-04-25 10:14:24.254
NG-202206-NYMEX [C] 4 Day #4 | File NG-199410-NYMEX.dly has a volume of 0 at 1994-09-19. | 2022-04-25 10:14:24.254
NG-202206-NYMEX [C] 4 Day #4 | File NG-199409-NYMEX.dly has a volume of 0 at 1994-07-19. | 2022-04-25 10:14:24.258
NG-202206-NYMEX [C] 4 Day #4 | File NG-199409-NYMEX.dly has a volume of 0 at 1994-08-18. | 2022-04-25 10:14:24.258
NG-202206-NYMEX [C] 4 Day #4 | File NG-199408-NYMEX.dly has a volume of 0 at 1994-06-20. | 2022-04-25 10:14:24.263
NG-202206-NYMEX [C] 4 Day #4 | File NG-199408-NYMEX.dly has a volume of 0 at 1994-07-18. | 2022-04-25 10:14:24.263
NG-202206-NYMEX [C] 4 Day #4 | File NG-199407-NYMEX.dly has a volume of 0 at 1994-05-19. | 2022-04-25 10:14:24.267
NG-202206-NYMEX [C] 4 Day #4 | File NG-199407-NYMEX.dly has a volume of 0 at 1994-06-17. | 2022-04-25 10:14:24.267
NG-202206-NYMEX [C] 4 Day #4 | File NG-199406-NYMEX.dly has a volume of 0 at 1994-04-19. | 2022-04-25 10:14:24.271
NG-202206-NYMEX [C] 4 Day #4 | File NG-199406-NYMEX.dly has a volume of 0 at 1994-05-18. | 2022-04-25 10:14:24.271
NG-202206-NYMEX [C] 4 Day #4 | File NG-199405-NYMEX.dly has a volume of 0 at 1994-03-21. | 2022-04-25 10:14:24.275
NG-202206-NYMEX [C] 4 Day #4 | File NG-199405-NYMEX.dly has a volume of 0 at 1994-04-18. | 2022-04-25 10:14:24.275
NG-202206-NYMEX [C] 4 Day #4 | File NG-199404-NYMEX.dly has a volume of 0 at 1994-02-16. | 2022-04-25 10:14:24.279
NG-202206-NYMEX [C] 4 Day #4 | File NG-199404-NYMEX.dly has a volume of 0 at 1994-03-18. | 2022-04-25 10:14:24.279
NG-202206-NYMEX [C] 4 Day #4 | File NG-199403-NYMEX.dly has a volume of 0 at 1994-01-19. | 2022-04-25 10:14:24.283
NG-202206-NYMEX [C] 4 Day #4 | File NG-199403-NYMEX.dly has a volume of 0 at 1994-02-15. | 2022-04-25 10:14:24.283
NG-202206-NYMEX [C] 4 Day #4 | File NG-199402-NYMEX.dly has a volume of 0 at 1993-12-21. | 2022-04-25 10:14:24.287
NG-202206-NYMEX [C] 4 Day #4 | File NG-199402-NYMEX.dly has a volume of 0 at 1994-01-18. | 2022-04-25 10:14:24.287
NG-202206-NYMEX [C] 4 Day #4 | File NG-199401-NYMEX.dly has a volume of 0 at 1993-11-18. | 2022-04-25 10:14:24.291
NG-202206-NYMEX [C] 4 Day #4 | File NG-199401-NYMEX.dly has a volume of 0 at 1993-12-20. | 2022-04-25 10:14:24.291
NG-202206-NYMEX [C] 4 Day #4 | File NG-199312-NYMEX.dly has a volume of 0 at 1993-10-19. | 2022-04-25 10:14:24.295
NG-202206-NYMEX [C] 4 Day #4 | File NG-199312-NYMEX.dly has a volume of 0 at 1993-11-17. | 2022-04-25 10:14:24.295
NG-202206-NYMEX [C] 4 Day #4 | File NG-199311-NYMEX.dly has a volume of 0 at 1993-09-20. | 2022-04-25 10:14:24.300
NG-202206-NYMEX [C] 4 Day #4 | File NG-199311-NYMEX.dly has a volume of 0 at 1993-10-18. | 2022-04-25 10:14:24.300
NG-202206-NYMEX [C] 4 Day #4 | File NG-199310-NYMEX.dly has a volume of 0 at 1993-08-19. | 2022-04-25 10:14:24.304
NG-202206-NYMEX [C] 4 Day #4 | File NG-199310-NYMEX.dly has a volume of 0 at 1993-09-17. | 2022-04-25 10:14:24.304
NG-202206-NYMEX [C] 4 Day #4 | File NG-199309-NYMEX.dly has a volume of 0 at 1993-07-20. | 2022-04-25 10:14:24.308
NG-202206-NYMEX [C] 4 Day #4 | File NG-199309-NYMEX.dly has a volume of 0 at 1993-08-18. | 2022-04-25 10:14:24.308
NG-202206-NYMEX [C] 4 Day #4 | File NG-199308-NYMEX.dly has a volume of 0 at 1993-06-18. | 2022-04-25 10:14:24.313
NG-202206-NYMEX [C] 4 Day #4 | File NG-199308-NYMEX.dly has a volume of 0 at 1993-07-19. | 2022-04-25 10:14:24.313
NG-202206-NYMEX [C] 4 Day #4 | File NG-199307-NYMEX.dly has a volume of 0 at 1993-05-19. | 2022-04-25 10:14:24.317
NG-202206-NYMEX [C] 4 Day #4 | File NG-199307-NYMEX.dly has a volume of 0 at 1993-06-17. | 2022-04-25 10:14:24.317
NG-202206-NYMEX [C] 4 Day #4 | File NG-199306-NYMEX.dly has a volume of 0 at 1993-04-20. | 2022-04-25 10:14:24.321
NG-202206-NYMEX [C] 4 Day #4 | File NG-199306-NYMEX.dly has a volume of 0 at 1993-05-18. | 2022-04-25 10:14:24.321
NG-202206-NYMEX [C] 4 Day #4 | File NG-199305-NYMEX.dly has a volume of 0 at 1993-03-19. | 2022-04-25 10:14:24.325
NG-202206-NYMEX [C] 4 Day #4 | File NG-199305-NYMEX.dly has a volume of 0 at 1993-04-19. | 2022-04-25 10:14:24.325
NG-202206-NYMEX [C] 4 Day #4 | File NG-199304-NYMEX.dly has a volume of 0 at 1993-02-16. | 2022-04-25 10:14:24.329
NG-202206-NYMEX [C] 4 Day #4 | File NG-199304-NYMEX.dly has a volume of 0 at 1993-03-18. | 2022-04-25 10:14:24.329
NG-202206-NYMEX [C] 4 Day #4 | File NG-199303-NYMEX.dly has a volume of 0 at 1993-01-19. | 2022-04-25 10:14:24.333
NG-202206-NYMEX [C] 4 Day #4 | File NG-199303-NYMEX.dly has a volume of 0 at 1993-02-15. | 2022-04-25 10:14:24.333
NG-202206-NYMEX [C] 4 Day #4 | File NG-199302-NYMEX.dly has a volume of 0 at 1992-12-21. | 2022-04-25 10:14:24.337
NG-202206-NYMEX [C] 4 Day #4 | File NG-199302-NYMEX.dly has a volume of 0 at 1993-01-18. | 2022-04-25 10:14:24.337
NG-202206-NYMEX [C] 4 Day #4 | File NG-199301-NYMEX.dly has a volume of 0 at 1992-11-18. | 2022-04-25 10:14:24.341
NG-202206-NYMEX [C] 4 Day #4 | File NG-199301-NYMEX.dly has a volume of 0 at 1992-12-18. | 2022-04-25 10:14:24.341
NG-202206-NYMEX [C] 4 Day #4 | File NG-199212-NYMEX.dly has a volume of 0 at 1992-10-20. | 2022-04-25 10:14:24.345
NG-202206-NYMEX [C] 4 Day #4 | File NG-199212-NYMEX.dly has a volume of 0 at 1992-11-17. | 2022-04-25 10:14:24.345
NG-202206-NYMEX [C] 4 Day #4 | File NG-199211-NYMEX.dly has a volume of 0 at 1992-09-18. | 2022-04-25 10:14:24.350
NG-202206-NYMEX [C] 4 Day #4 | File NG-199211-NYMEX.dly has a volume of 0 at 1992-10-19. | 2022-04-25 10:14:24.350
NG-202206-NYMEX [C] 4 Day #4 | File NG-199210-NYMEX.dly has a volume of 0 at 1992-08-19. | 2022-04-25 10:14:24.354
NG-202206-NYMEX [C] 4 Day #4 | File NG-199210-NYMEX.dly has a volume of 0 at 1992-09-17. | 2022-04-25 10:14:24.354
NG-202206-NYMEX [C] 4 Day #4 | File NG-199209-NYMEX.dly has a volume of 0 at 1992-07-21. | 2022-04-25 10:14:24.358
NG-202206-NYMEX [C] 4 Day #4 | File NG-199209-NYMEX.dly has a volume of 0 at 1992-08-18. | 2022-04-25 10:14:24.358
NG-202206-NYMEX [C] 4 Day #4 | File NG-199208-NYMEX.dly has a volume of 0 at 1992-06-18. | 2022-04-25 10:14:24.362
NG-202206-NYMEX [C] 4 Day #4 | File NG-199208-NYMEX.dly has a volume of 0 at 1992-07-20. | 2022-04-25 10:14:24.362
NG-202206-NYMEX [C] 4 Day #4 | File NG-199207-NYMEX.dly has a volume of 0 at 1992-05-19. | 2022-04-25 10:14:24.366
NG-202206-NYMEX [C] 4 Day #4 | File NG-199207-NYMEX.dly has a volume of 0 at 1992-06-17. | 2022-04-25 10:14:24.366
NG-202206-NYMEX [C] 4 Day #4 | File NG-199206-NYMEX.dly has a volume of 0 at 1992-04-20. | 2022-04-25 10:14:24.370
NG-202206-NYMEX [C] 4 Day #4 | File NG-199206-NYMEX.dly has a volume of 0 at 1992-05-18. | 2022-04-25 10:14:24.370
NG-202206-NYMEX [C] 4 Day #4 | File NG-199205-NYMEX.dly has a volume of 0 at 1992-03-19. | 2022-04-25 10:14:24.375
NG-202206-NYMEX [C] 4 Day #4 | File NG-199205-NYMEX.dly has a volume of 0 at 1992-04-17. | 2022-04-25 10:14:24.375
NG-202206-NYMEX [C] 4 Day #4 | File NG-199204-NYMEX.dly has a volume of 0 at 1992-02-18. | 2022-04-25 10:14:24.379
NG-202206-NYMEX [C] 4 Day #4 | File NG-199204-NYMEX.dly has a volume of 0 at 1992-03-18. | 2022-04-25 10:14:24.379
NG-202206-NYMEX [C] 4 Day #4 | File NG-199203-NYMEX.dly has a volume of 0 at 1992-01-21. | 2022-04-25 10:14:24.383
NG-202206-NYMEX [C] 4 Day #4 | File NG-199203-NYMEX.dly has a volume of 0 at 1992-02-17. | 2022-04-25 10:14:24.383
NG-202206-NYMEX [C] 4 Day #4 | File NG-199202-NYMEX.dly has a volume of 0 at 1991-12-19. | 2022-04-25 10:14:24.387
NG-202206-NYMEX [C] 4 Day #4 | File NG-199202-NYMEX.dly has a volume of 0 at 1992-01-20. | 2022-04-25 10:14:24.387
NG-202206-NYMEX [C] 4 Day #4 | File NG-199201-NYMEX.dly has a volume of 0 at 1991-11-19. | 2022-04-25 10:14:24.391
NG-202206-NYMEX [C] 4 Day #4 | File NG-199201-NYMEX.dly has a volume of 0 at 1991-12-18. | 2022-04-25 10:14:24.391
NG-202206-NYMEX [C] 4 Day #4 | File NG-199112-NYMEX.dly has a volume of 0 at 1991-10-21. | 2022-04-25 10:14:24.395
NG-202206-NYMEX [C] 4 Day #4 | File NG-199112-NYMEX.dly has a volume of 0 at 1991-11-18. | 2022-04-25 10:14:24.395
NG-202206-NYMEX [C] 4 Day #4 | File NG-199111-NYMEX.dly has a volume of 0 at 1991-09-18. | 2022-04-25 10:14:24.400
NG-202206-NYMEX [C] 4 Day #4 | File NG-199111-NYMEX.dly has a volume of 0 at 1991-10-18. | 2022-04-25 10:14:24.400
NG-202206-NYMEX [C] 4 Day #4 | File NG-199110-NYMEX.dly has a volume of 0 at 1991-08-20. | 2022-04-25 10:14:24.404
NG-202206-NYMEX [C] 4 Day #4 | File NG-199110-NYMEX.dly has a volume of 0 at 1991-09-17. | 2022-04-25 10:14:24.404
NG-202206-NYMEX [C] 4 Day #4 | File NG-199109-NYMEX.dly has a volume of 0 at 1991-07-19. | 2022-04-25 10:14:24.408
NG-202206-NYMEX [C] 4 Day #4 | File NG-199109-NYMEX.dly has a volume of 0 at 1991-08-19. | 2022-04-25 10:14:24.408
NG-202206-NYMEX [C] 4 Day #4 | File NG-199108-NYMEX.dly has a volume of 0 at 1991-06-18. | 2022-04-25 10:14:24.412
NG-202206-NYMEX [C] 4 Day #4 | File NG-199108-NYMEX.dly has a volume of 0 at 1991-07-18. | 2022-04-25 10:14:24.412
NG-202206-NYMEX [C] 4 Day #4 | File NG-199107-NYMEX.dly has a volume of 0 at 1991-05-21. | 2022-04-25 10:14:24.416
NG-202206-NYMEX [C] 4 Day #4 | File NG-199107-NYMEX.dly has a volume of 0 at 1991-06-17. | 2022-04-25 10:14:24.416
NG-202206-NYMEX [C] 4 Day #4 | File NG-199106-NYMEX.dly has a volume of 0 at 1991-04-18. | 2022-04-25 10:14:24.420
NG-202206-NYMEX [C] 4 Day #4 | File NG-199106-NYMEX.dly has a volume of 0 at 1991-05-20. | 2022-04-25 10:14:24.420
NG-202206-NYMEX [C] 4 Day #4 | File NG-199105-NYMEX.dly has a volume of 0 at 1991-03-19. | 2022-04-25 10:14:24.424
NG-202206-NYMEX [C] 4 Day #4 | File NG-199105-NYMEX.dly has a volume of 0 at 1991-04-17. | 2022-04-25 10:14:24.424
NG-202206-NYMEX [C] 4 Day #4 | File NG-199104-NYMEX.dly has a volume of 0 at 1991-02-18. | 2022-04-25 10:14:24.428
NG-202206-NYMEX [C] 4 Day #4 | File NG-199104-NYMEX.dly has a volume of 0 at 1991-03-18. | 2022-04-25 10:14:24.428
NG-202206-NYMEX [C] 4 Day #4 | File NG-199103-NYMEX.dly has a volume of 0 at 1991-01-21. | 2022-04-25 10:14:24.431
NG-202206-NYMEX [C] 4 Day #4 | File NG-199103-NYMEX.dly has a volume of 0 at 1991-02-15. | 2022-04-25 10:14:24.431
NG-202206-NYMEX [C] 4 Day #4 | File NG-199102-NYMEX.dly has a volume of 0 at 1990-12-19. | 2022-04-25 10:14:24.435
NG-202206-NYMEX [C] 4 Day #4 | File NG-199102-NYMEX.dly has a volume of 0 at 1991-01-18. | 2022-04-25 10:14:24.435
NG-202206-NYMEX [C] 4 Day #4 | File NG-199101-NYMEX.dly has a volume of 0 at 1990-11-20. | 2022-04-25 10:14:24.439
NG-202206-NYMEX [C] 4 Day #4 | File NG-199101-NYMEX.dly has a volume of 0 at 1990-12-18. | 2022-04-25 10:14:24.439
NG-202206-NYMEX [C] 4 Day #4 | File NG-199012-NYMEX.dly has a volume of 0 at 1990-10-19. | 2022-04-25 10:14:24.443
NG-202206-NYMEX [C] 4 Day #4 | File NG-199012-NYMEX.dly has a volume of 0 at 1990-11-19. | 2022-04-25 10:14:24.443
NG-202206-NYMEX [C] 4 Day #4 | File NG-199011-NYMEX.dly has a volume of 0 at 1990-09-18. | 2022-04-25 10:14:24.447
NG-202206-NYMEX [C] 4 Day #4 | File NG-199011-NYMEX.dly has a volume of 0 at 1990-10-18. | 2022-04-25 10:14:24.447
NG-202206-NYMEX [C] 4 Day #4 | File NG-199010-NYMEX.dly has a volume of 0 at 1990-08-21. | 2022-04-25 10:14:24.451
NG-202206-NYMEX [C] 4 Day #4 | File NG-199010-NYMEX.dly has a volume of 0 at 1990-09-17. | 2022-04-25 10:14:24.451
NG-202206-NYMEX [C] 4 Day #4 | File NG-199009-NYMEX.dly has a volume of 0 at 1990-07-19. | 2022-04-25 10:14:24.455
NG-202206-NYMEX [C] 4 Day #4 | File NG-199009-NYMEX.dly has a volume of 0 at 1990-08-20. | 2022-04-25 10:14:24.455
NG-202206-NYMEX [C] 4 Day #4 | File NG-199008-NYMEX.dly has a volume of 0 at 1990-06-19. | 2022-04-25 10:14:24.459
NG-202206-NYMEX [C] 4 Day #4 | File NG-199008-NYMEX.dly has a volume of 0 at 1990-07-18. | 2022-04-25 10:14:24.459
NG-202206-NYMEX [C] 4 Day #4 | File NG-199007-NYMEX.dly has a volume of 0 at 1990-05-21. | 2022-04-25 10:14:24.463
NG-202206-NYMEX [C] 4 Day #4 | File NG-199007-NYMEX.dly has a volume of 0 at 1990-06-18. | 2022-04-25 10:14:24.463
NG-202206-NYMEX [C] 4 Day #4 | File NG-199006-NYMEX.dly has a volume of 0 at 1990-04-18. | 2022-04-25 10:14:24.467
NG-202206-NYMEX [C] 4 Day #4 | File NG-199006-NYMEX.dly has a volume of 0 at 1990-05-18. | 2022-04-25 10:14:24.467
NG-202206-NYMEX [C] 4 Day #4 | Waiting for historical downloads to complete with the IDs: 22, | 2022-04-25 10:14:24.598
QG-202206-NYMEX Daily #2 | Reloading chart. | 2022-04-25 10:14:24.609
QG-202204-NYMEX 384 Min #5 | Reloading chart. | 2022-04-25 10:14:24.633
QG-202204-NYMEX 384 Min #11 | Reloading chart. | 2022-04-25 10:14:24.644
USOil 4 Day #13 | Reloading chart. | 2022-04-25 10:14:24.656
CL-202206-NYMEX [C] 16 Day #10 | Reloading chart. | 2022-04-25 10:14:24.668
CL-202206-NYMEX [C] 16 Day #10 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:24.668
CL-202206-NYMEX [C] 16 Day #10 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:24.668
CL-202206-NYMEX [C] 16 Day #10 | Performing continuous chart historical Daily data download for symbol CL-198501-NYMEX starting at last date in file. | 2022-04-25 10:14:24.797
Added historical Daily data request for CL-198501-NYMEX to the queue. | 2022-04-25 10:14:24.797
CL-202206-NYMEX [C] 16 Day #10 | Performing continuous chart historical Daily data download for symbol CL-202206-NYMEX starting at last date in file. | 2022-04-25 10:14:25.238
Added historical Daily data request for CL-202206-NYMEX to the queue. | 2022-04-25 10:14:25.238
CL-202206-NYMEX [C] 16 Day #10 | File CL-200102-NYMEX.dly has a volume of 0 at 2000-12-18. | 2022-04-25 10:14:26.432
CL-202206-NYMEX [C] 16 Day #10 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-11-17. | 2022-04-25 10:14:26.436
CL-202206-NYMEX [C] 16 Day #10 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-12-15. | 2022-04-25 10:14:26.436
CL-202206-NYMEX [C] 16 Day #10 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-10-18. | 2022-04-25 10:14:26.440
CL-202206-NYMEX [C] 16 Day #10 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-11-16. | 2022-04-25 10:14:26.440
CL-202206-NYMEX [C] 16 Day #10 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-09-18. | 2022-04-25 10:14:26.445
CL-202206-NYMEX [C] 16 Day #10 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-10-17. | 2022-04-25 10:14:26.445
CL-202206-NYMEX [C] 16 Day #10 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-08-18. | 2022-04-25 10:14:26.449
CL-202206-NYMEX [C] 16 Day #10 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-09-15. | 2022-04-25 10:14:26.449
CL-202206-NYMEX [C] 16 Day #10 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-07-18. | 2022-04-25 10:14:26.454
CL-202206-NYMEX [C] 16 Day #10 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-08-17. | 2022-04-25 10:14:26.454
CL-202206-NYMEX [C] 16 Day #10 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-06-16. | 2022-04-25 10:14:26.458
CL-202206-NYMEX [C] 16 Day #10 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-07-17. | 2022-04-25 10:14:26.458
CL-202206-NYMEX [C] 16 Day #10 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-05-18. | 2022-04-25 10:14:26.462
CL-202206-NYMEX [C] 16 Day #10 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-06-15. | 2022-04-25 10:14:26.462
CL-202206-NYMEX [C] 16 Day #10 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-04-18. | 2022-04-25 10:14:26.466
CL-202206-NYMEX [C] 16 Day #10 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-05-17. | 2022-04-25 10:14:26.466
CL-202206-NYMEX [C] 16 Day #10 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-03-17. | 2022-04-25 10:14:26.471
CL-202206-NYMEX [C] 16 Day #10 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-04-17. | 2022-04-25 10:14:26.471
CL-202206-NYMEX [C] 16 Day #10 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-02-18. | 2022-04-25 10:14:26.475
CL-202206-NYMEX [C] 16 Day #10 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-03-16. | 2022-04-25 10:14:26.475
CL-202206-NYMEX [C] 16 Day #10 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-01-18. | 2022-04-25 10:14:26.479
CL-202206-NYMEX [C] 16 Day #10 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-02-17. | 2022-04-25 10:14:26.479
CL-202206-NYMEX [C] 16 Day #10 | File CL-200002-NYMEX.dly has a volume of 0 at 1999-12-17. | 2022-04-25 10:14:26.483
CL-202206-NYMEX [C] 16 Day #10 | File CL-200002-NYMEX.dly has a volume of 0 at 2000-01-17. | 2022-04-25 10:14:26.483
CL-202206-NYMEX [C] 16 Day #10 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-11-18. | 2022-04-25 10:14:26.487
CL-202206-NYMEX [C] 16 Day #10 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-12-16. | 2022-04-25 10:14:26.487
CL-202206-NYMEX [C] 16 Day #10 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-10-18. | 2022-04-25 10:14:26.492
CL-202206-NYMEX [C] 16 Day #10 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-11-17. | 2022-04-25 10:14:26.492
CL-202206-NYMEX [C] 16 Day #10 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-09-17. | 2022-04-25 10:14:26.496
CL-202206-NYMEX [C] 16 Day #10 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-10-15. | 2022-04-25 10:14:26.496
CL-202206-NYMEX [C] 16 Day #10 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-08-18. | 2022-04-25 10:14:26.501
CL-202206-NYMEX [C] 16 Day #10 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-09-16. | 2022-04-25 10:14:26.501
CL-202206-NYMEX [C] 16 Day #10 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-07-16. | 2022-04-25 10:14:26.505
CL-202206-NYMEX [C] 16 Day #10 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-08-17. | 2022-04-25 10:14:26.505
CL-202206-NYMEX [C] 16 Day #10 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-06-18. | 2022-04-25 10:14:26.510
CL-202206-NYMEX [C] 16 Day #10 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-07-15. | 2022-04-25 10:14:26.510
CL-202206-NYMEX [C] 16 Day #10 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-05-18. | 2022-04-25 10:14:26.514
CL-202206-NYMEX [C] 16 Day #10 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-06-17. | 2022-04-25 10:14:26.514
CL-202206-NYMEX [C] 16 Day #10 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-04-16. | 2022-04-25 10:14:26.519
CL-202206-NYMEX [C] 16 Day #10 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-05-17. | 2022-04-25 10:14:26.519
CL-202206-NYMEX [C] 16 Day #10 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-03-18. | 2022-04-25 10:14:26.523
CL-202206-NYMEX [C] 16 Day #10 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-04-15. | 2022-04-25 10:14:26.523
CL-202206-NYMEX [C] 16 Day #10 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-02-18. | 2022-04-25 10:14:26.527
CL-202206-NYMEX [C] 16 Day #10 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-03-17. | 2022-04-25 10:14:26.527
CL-202206-NYMEX [C] 16 Day #10 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-01-18. | 2022-04-25 10:14:26.531
CL-202206-NYMEX [C] 16 Day #10 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-02-17. | 2022-04-25 10:14:26.531
CL-202206-NYMEX [C] 16 Day #10 | File CL-199902-NYMEX.dly has a volume of 0 at 1998-12-18. | 2022-04-25 10:14:26.535
CL-202206-NYMEX [C] 16 Day #10 | File CL-199902-NYMEX.dly has a volume of 0 at 1999-01-15. | 2022-04-25 10:14:26.535
CL-202206-NYMEX [C] 16 Day #10 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-11-18. | 2022-04-25 10:14:26.540
CL-202206-NYMEX [C] 16 Day #10 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-12-17. | 2022-04-25 10:14:26.540
CL-202206-NYMEX [C] 16 Day #10 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-10-16. | 2022-04-25 10:14:26.544
CL-202206-NYMEX [C] 16 Day #10 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-11-17. | 2022-04-25 10:14:26.544
CL-202206-NYMEX [C] 16 Day #10 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-09-18. | 2022-04-25 10:14:26.549
CL-202206-NYMEX [C] 16 Day #10 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-10-15. | 2022-04-25 10:14:26.549
CL-202206-NYMEX [C] 16 Day #10 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-08-18. | 2022-04-25 10:14:26.553
CL-202206-NYMEX [C] 16 Day #10 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-09-17. | 2022-04-25 10:14:26.553
CL-202206-NYMEX [C] 16 Day #10 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-07-17. | 2022-04-25 10:14:26.557
CL-202206-NYMEX [C] 16 Day #10 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-08-17. | 2022-04-25 10:14:26.557
CL-202206-NYMEX [C] 16 Day #10 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-06-18. | 2022-04-25 10:14:26.561
CL-202206-NYMEX [C] 16 Day #10 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-07-16. | 2022-04-25 10:14:26.561
CL-202206-NYMEX [C] 16 Day #10 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-05-18. | 2022-04-25 10:14:26.566
CL-202206-NYMEX [C] 16 Day #10 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-06-17. | 2022-04-25 10:14:26.566
CL-202206-NYMEX [C] 16 Day #10 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-04-17. | 2022-04-25 10:14:26.570
CL-202206-NYMEX [C] 16 Day #10 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-05-15. | 2022-04-25 10:14:26.570
CL-202206-NYMEX [C] 16 Day #10 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-03-18. | 2022-04-25 10:14:26.574
CL-202206-NYMEX [C] 16 Day #10 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-04-16. | 2022-04-25 10:14:26.574
CL-202206-NYMEX [C] 16 Day #10 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-02-18. | 2022-04-25 10:14:26.578
CL-202206-NYMEX [C] 16 Day #10 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-03-17. | 2022-04-25 10:14:26.578
CL-202206-NYMEX [C] 16 Day #10 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-01-16. | 2022-04-25 10:14:26.583
CL-202206-NYMEX [C] 16 Day #10 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-02-17. | 2022-04-25 10:14:26.583
CL-202206-NYMEX [C] 16 Day #10 | File CL-199802-NYMEX.dly has a volume of 0 at 1997-12-18. | 2022-04-25 10:14:26.587
CL-202206-NYMEX [C] 16 Day #10 | File CL-199802-NYMEX.dly has a volume of 0 at 1998-01-15. | 2022-04-25 10:14:26.587
CL-202206-NYMEX [C] 16 Day #10 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-11-18. | 2022-04-25 10:14:26.591
CL-202206-NYMEX [C] 16 Day #10 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-12-17. | 2022-04-25 10:14:26.591
CL-202206-NYMEX [C] 16 Day #10 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-10-17. | 2022-04-25 10:14:26.595
CL-202206-NYMEX [C] 16 Day #10 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-11-17. | 2022-04-25 10:14:26.595
CL-202206-NYMEX [C] 16 Day #10 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-09-18. | 2022-04-25 10:14:26.599
CL-202206-NYMEX [C] 16 Day #10 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-10-16. | 2022-04-25 10:14:26.600
CL-202206-NYMEX [C] 16 Day #10 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-08-18. | 2022-04-25 10:14:26.604
CL-202206-NYMEX [C] 16 Day #10 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-09-17. | 2022-04-25 10:14:26.604
CL-202206-NYMEX [C] 16 Day #10 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-07-18. | 2022-04-25 10:14:26.608
CL-202206-NYMEX [C] 16 Day #10 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-08-15. | 2022-04-25 10:14:26.608
CL-202206-NYMEX [C] 16 Day #10 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-06-18. | 2022-04-25 10:14:26.612
CL-202206-NYMEX [C] 16 Day #10 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-07-17. | 2022-04-25 10:14:26.612
CL-202206-NYMEX [C] 16 Day #10 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-05-16. | 2022-04-25 10:14:26.617
CL-202206-NYMEX [C] 16 Day #10 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-06-17. | 2022-04-25 10:14:26.617
CL-202206-NYMEX [C] 16 Day #10 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-04-18. | 2022-04-25 10:14:26.621
CL-202206-NYMEX [C] 16 Day #10 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-05-15. | 2022-04-25 10:14:26.621
CL-202206-NYMEX [C] 16 Day #10 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-03-18. | 2022-04-25 10:14:26.625
CL-202206-NYMEX [C] 16 Day #10 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-04-17. | 2022-04-25 10:14:26.625
CL-202206-NYMEX [C] 16 Day #10 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-02-18. | 2022-04-25 10:14:26.630
CL-202206-NYMEX [C] 16 Day #10 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-03-17. | 2022-04-25 10:14:26.630
CL-202206-NYMEX [C] 16 Day #10 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-01-17. | 2022-04-25 10:14:26.634
CL-202206-NYMEX [C] 16 Day #10 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-02-17. | 2022-04-25 10:14:26.634
CL-202206-NYMEX [C] 16 Day #10 | File CL-199702-NYMEX.dly has a volume of 0 at 1996-12-18. | 2022-04-25 10:14:26.638
CL-202206-NYMEX [C] 16 Day #10 | File CL-199702-NYMEX.dly has a volume of 0 at 1997-01-16. | 2022-04-25 10:14:26.638
CL-202206-NYMEX [C] 16 Day #10 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-11-18. | 2022-04-25 10:14:26.642
CL-202206-NYMEX [C] 16 Day #10 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-12-17. | 2022-04-25 10:14:26.642
CL-202206-NYMEX [C] 16 Day #10 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-10-18. | 2022-04-25 10:14:26.647
CL-202206-NYMEX [C] 16 Day #10 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-11-15. | 2022-04-25 10:14:26.647
CL-202206-NYMEX [C] 16 Day #10 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-09-18. | 2022-04-25 10:14:26.651
CL-202206-NYMEX [C] 16 Day #10 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-10-17. | 2022-04-25 10:14:26.651
CL-202206-NYMEX [C] 16 Day #10 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-08-16. | 2022-04-25 10:14:26.655
CL-202206-NYMEX [C] 16 Day #10 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-09-17. | 2022-04-25 10:14:26.655
CL-202206-NYMEX [C] 16 Day #10 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-07-18. | 2022-04-25 10:14:26.660
CL-202206-NYMEX [C] 16 Day #10 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-08-15. | 2022-04-25 10:14:26.660
CL-202206-NYMEX [C] 16 Day #10 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-06-18. | 2022-04-25 10:14:26.664
CL-202206-NYMEX [C] 16 Day #10 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-07-17. | 2022-04-25 10:14:26.664
CL-202206-NYMEX [C] 16 Day #10 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-05-17. | 2022-04-25 10:14:26.668
CL-202206-NYMEX [C] 16 Day #10 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-06-17. | 2022-04-25 10:14:26.668
CL-202206-NYMEX [C] 16 Day #10 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-04-18. | 2022-04-25 10:14:26.673
CL-202206-NYMEX [C] 16 Day #10 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-05-16. | 2022-04-25 10:14:26.673
CL-202206-NYMEX [C] 16 Day #10 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-03-18. | 2022-04-25 10:14:26.677
CL-202206-NYMEX [C] 16 Day #10 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-04-17. | 2022-04-25 10:14:26.677
CL-202206-NYMEX [C] 16 Day #10 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-02-16. | 2022-04-25 10:14:26.681
CL-202206-NYMEX [C] 16 Day #10 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-03-15. | 2022-04-25 10:14:26.681
CL-202206-NYMEX [C] 16 Day #10 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-01-18. | 2022-04-25 10:14:26.686
CL-202206-NYMEX [C] 16 Day #10 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-02-15. | 2022-04-25 10:14:26.686
CL-202206-NYMEX [C] 16 Day #10 | File CL-199602-NYMEX.dly has a volume of 0 at 1995-12-18. | 2022-04-25 10:14:26.690
CL-202206-NYMEX [C] 16 Day #10 | File CL-199602-NYMEX.dly has a volume of 0 at 1996-01-17. | 2022-04-25 10:14:26.690
CL-202206-NYMEX [C] 16 Day #10 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-11-17. | 2022-04-25 10:14:26.694
CL-202206-NYMEX [C] 16 Day #10 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-12-15. | 2022-04-25 10:14:26.694
CL-202206-NYMEX [C] 16 Day #10 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-10-18. | 2022-04-25 10:14:26.698
CL-202206-NYMEX [C] 16 Day #10 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-11-16. | 2022-04-25 10:14:26.698
CL-202206-NYMEX [C] 16 Day #10 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-09-18. | 2022-04-25 10:14:26.703
CL-202206-NYMEX [C] 16 Day #10 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-10-17. | 2022-04-25 10:14:26.703
CL-202206-NYMEX [C] 16 Day #10 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-08-18. | 2022-04-25 10:14:26.707
CL-202206-NYMEX [C] 16 Day #10 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-09-15. | 2022-04-25 10:14:26.707
CL-202206-NYMEX [C] 16 Day #10 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-07-18. | 2022-04-25 10:14:26.712
CL-202206-NYMEX [C] 16 Day #10 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-08-17. | 2022-04-25 10:14:26.712
CL-202206-NYMEX [C] 16 Day #10 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-06-16. | 2022-04-25 10:14:26.716
CL-202206-NYMEX [C] 16 Day #10 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-07-17. | 2022-04-25 10:14:26.716
CL-202206-NYMEX [C] 16 Day #10 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-05-18. | 2022-04-25 10:14:26.720
CL-202206-NYMEX [C] 16 Day #10 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-06-15. | 2022-04-25 10:14:26.720
CL-202206-NYMEX [C] 16 Day #10 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-04-18. | 2022-04-25 10:14:26.724
CL-202206-NYMEX [C] 16 Day #10 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-05-17. | 2022-04-25 10:14:26.724
CL-202206-NYMEX [C] 16 Day #10 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-03-17. | 2022-04-25 10:14:26.729
CL-202206-NYMEX [C] 16 Day #10 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-04-17. | 2022-04-25 10:14:26.729
CL-202206-NYMEX [C] 16 Day #10 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-02-17. | 2022-04-25 10:14:26.733
CL-202206-NYMEX [C] 16 Day #10 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-03-16. | 2022-04-25 10:14:26.733
CL-202206-NYMEX [C] 16 Day #10 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-01-18. | 2022-04-25 10:14:26.737
CL-202206-NYMEX [C] 16 Day #10 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-02-16. | 2022-04-25 10:14:26.737
CL-202206-NYMEX [C] 16 Day #10 | File CL-199502-NYMEX.dly has a volume of 0 at 1994-12-16. | 2022-04-25 10:14:26.741
CL-202206-NYMEX [C] 16 Day #10 | File CL-199502-NYMEX.dly has a volume of 0 at 1995-01-17. | 2022-04-25 10:14:26.741
CL-202206-NYMEX [C] 16 Day #10 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-11-18. | 2022-04-25 10:14:26.745
CL-202206-NYMEX [C] 16 Day #10 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-12-15. | 2022-04-25 10:14:26.745
CL-202206-NYMEX [C] 16 Day #10 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-10-18. | 2022-04-25 10:14:26.750
CL-202206-NYMEX [C] 16 Day #10 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-11-17. | 2022-04-25 10:14:26.750
CL-202206-NYMEX [C] 16 Day #10 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-09-16. | 2022-04-25 10:14:26.754
CL-202206-NYMEX [C] 16 Day #10 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-10-17. | 2022-04-25 10:14:26.754
CL-202206-NYMEX [C] 16 Day #10 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-08-18. | 2022-04-25 10:14:26.758
CL-202206-NYMEX [C] 16 Day #10 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-09-15. | 2022-04-25 10:14:26.758
CL-202206-NYMEX [C] 16 Day #10 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-07-18. | 2022-04-25 10:14:26.763
CL-202206-NYMEX [C] 16 Day #10 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-08-17. | 2022-04-25 10:14:26.763
CL-202206-NYMEX [C] 16 Day #10 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-06-17. | 2022-04-25 10:14:26.767
CL-202206-NYMEX [C] 16 Day #10 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-07-15. | 2022-04-25 10:14:26.767
CL-202206-NYMEX [C] 16 Day #10 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-05-18. | 2022-04-25 10:14:26.771
CL-202206-NYMEX [C] 16 Day #10 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-06-16. | 2022-04-25 10:14:26.771
CL-202206-NYMEX [C] 16 Day #10 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-04-18. | 2022-04-25 10:14:26.776
CL-202206-NYMEX [C] 16 Day #10 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-05-17. | 2022-04-25 10:14:26.776
CL-202206-NYMEX [C] 16 Day #10 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-03-18. | 2022-04-25 10:14:26.780
CL-202206-NYMEX [C] 16 Day #10 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-04-15. | 2022-04-25 10:14:26.780
CL-202206-NYMEX [C] 16 Day #10 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-02-18. | 2022-04-25 10:14:26.784
CL-202206-NYMEX [C] 16 Day #10 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-03-17. | 2022-04-25 10:14:26.784
CL-202206-NYMEX [C] 16 Day #10 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-01-18. | 2022-04-25 10:14:26.788
CL-202206-NYMEX [C] 16 Day #10 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-02-17. | 2022-04-25 10:14:26.788
CL-202206-NYMEX [C] 16 Day #10 | File CL-199402-NYMEX.dly has a volume of 0 at 1993-12-17. | 2022-04-25 10:14:26.793
CL-202206-NYMEX [C] 16 Day #10 | File CL-199402-NYMEX.dly has a volume of 0 at 1994-01-17. | 2022-04-25 10:14:26.793
CL-202206-NYMEX [C] 16 Day #10 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-11-18. | 2022-04-25 10:14:26.797
CL-202206-NYMEX [C] 16 Day #10 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-12-16. | 2022-04-25 10:14:26.797
CL-202206-NYMEX [C] 16 Day #10 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-10-18. | 2022-04-25 10:14:26.801
CL-202206-NYMEX [C] 16 Day #10 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-11-17. | 2022-04-25 10:14:26.801
CL-202206-NYMEX [C] 16 Day #10 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-09-17. | 2022-04-25 10:14:26.805
CL-202206-NYMEX [C] 16 Day #10 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-10-15. | 2022-04-25 10:14:26.805
CL-202206-NYMEX [C] 16 Day #10 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-08-18. | 2022-04-25 10:14:26.810
CL-202206-NYMEX [C] 16 Day #10 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-09-16. | 2022-04-25 10:14:26.810
CL-202206-NYMEX [C] 16 Day #10 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-07-16. | 2022-04-25 10:14:26.814
CL-202206-NYMEX [C] 16 Day #10 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-08-17. | 2022-04-25 10:14:26.814
CL-202206-NYMEX [C] 16 Day #10 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-06-18. | 2022-04-25 10:14:26.818
CL-202206-NYMEX [C] 16 Day #10 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-07-15. | 2022-04-25 10:14:26.818
CL-202206-NYMEX [C] 16 Day #10 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-05-18. | 2022-04-25 10:14:26.823
CL-202206-NYMEX [C] 16 Day #10 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-06-17. | 2022-04-25 10:14:26.823
CL-202206-NYMEX [C] 16 Day #10 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-04-16. | 2022-04-25 10:14:26.827
CL-202206-NYMEX [C] 16 Day #10 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-05-17. | 2022-04-25 10:14:26.827
CL-202206-NYMEX [C] 16 Day #10 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-03-18. | 2022-04-25 10:14:26.831
CL-202206-NYMEX [C] 16 Day #10 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-04-15. | 2022-04-25 10:14:26.831
CL-202206-NYMEX [C] 16 Day #10 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-02-18. | 2022-04-25 10:14:26.835
CL-202206-NYMEX [C] 16 Day #10 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-03-17. | 2022-04-25 10:14:26.835
CL-202206-NYMEX [C] 16 Day #10 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-01-18. | 2022-04-25 10:14:26.840
CL-202206-NYMEX [C] 16 Day #10 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-02-17. | 2022-04-25 10:14:26.840
CL-202206-NYMEX [C] 16 Day #10 | File CL-199302-NYMEX.dly has a volume of 0 at 1992-12-18. | 2022-04-25 10:14:26.844
CL-202206-NYMEX [C] 16 Day #10 | File CL-199302-NYMEX.dly has a volume of 0 at 1993-01-15. | 2022-04-25 10:14:26.844
CL-202206-NYMEX [C] 16 Day #10 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-11-18. | 2022-04-25 10:14:26.848
CL-202206-NYMEX [C] 16 Day #10 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-12-17. | 2022-04-25 10:14:26.848
CL-202206-NYMEX [C] 16 Day #10 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-10-16. | 2022-04-25 10:14:26.853
CL-202206-NYMEX [C] 16 Day #10 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-11-17. | 2022-04-25 10:14:26.853
CL-202206-NYMEX [C] 16 Day #10 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-09-18. | 2022-04-25 10:14:26.857
CL-202206-NYMEX [C] 16 Day #10 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-10-15. | 2022-04-25 10:14:26.857
CL-202206-NYMEX [C] 16 Day #10 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-08-18. | 2022-04-25 10:14:26.862
CL-202206-NYMEX [C] 16 Day #10 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-09-17. | 2022-04-25 10:14:26.862
CL-202206-NYMEX [C] 16 Day #10 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-07-17. | 2022-04-25 10:14:26.866
CL-202206-NYMEX [C] 16 Day #10 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-08-17. | 2022-04-25 10:14:26.866
CL-202206-NYMEX [C] 16 Day #10 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-06-18. | 2022-04-25 10:14:26.871
CL-202206-NYMEX [C] 16 Day #10 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-07-16. | 2022-04-25 10:14:26.871
CL-202206-NYMEX [C] 16 Day #10 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-05-18. | 2022-04-25 10:14:26.875
CL-202206-NYMEX [C] 16 Day #10 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-06-17. | 2022-04-25 10:14:26.875
CL-202206-NYMEX [C] 16 Day #10 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-04-17. | 2022-04-25 10:14:26.879
CL-202206-NYMEX [C] 16 Day #10 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-05-15. | 2022-04-25 10:14:26.879
CL-202206-NYMEX [C] 16 Day #10 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-03-18. | 2022-04-25 10:14:26.883
CL-202206-NYMEX [C] 16 Day #10 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-04-16. | 2022-04-25 10:14:26.883
CL-202206-NYMEX [C] 16 Day #10 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-02-18. | 2022-04-25 10:14:26.888
CL-202206-NYMEX [C] 16 Day #10 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-03-17. | 2022-04-25 10:14:26.888
CL-202206-NYMEX [C] 16 Day #10 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-01-17. | 2022-04-25 10:14:26.892
CL-202206-NYMEX [C] 16 Day #10 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-02-17. | 2022-04-25 10:14:26.892
CL-202206-NYMEX [C] 16 Day #10 | File CL-199202-NYMEX.dly has a volume of 0 at 1991-12-18. | 2022-04-25 10:14:26.896
CL-202206-NYMEX [C] 16 Day #10 | File CL-199202-NYMEX.dly has a volume of 0 at 1992-01-16. | 2022-04-25 10:14:26.896
CL-202206-NYMEX [C] 16 Day #10 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-11-18. | 2022-04-25 10:14:26.900
CL-202206-NYMEX [C] 16 Day #10 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-12-17. | 2022-04-25 10:14:26.900
CL-202206-NYMEX [C] 16 Day #10 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-10-18. | 2022-04-25 10:14:26.905
CL-202206-NYMEX [C] 16 Day #10 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-11-15. | 2022-04-25 10:14:26.905
CL-202206-NYMEX [C] 16 Day #10 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-09-18. | 2022-04-25 10:14:26.909
CL-202206-NYMEX [C] 16 Day #10 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-10-17. | 2022-04-25 10:14:26.909
CL-202206-NYMEX [C] 16 Day #10 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-08-16. | 2022-04-25 10:14:26.913
CL-202206-NYMEX [C] 16 Day #10 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-09-17. | 2022-04-25 10:14:26.913
CL-202206-NYMEX [C] 16 Day #10 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-07-18. | 2022-04-25 10:14:26.918
CL-202206-NYMEX [C] 16 Day #10 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-08-15. | 2022-04-25 10:14:26.918
CL-202206-NYMEX [C] 16 Day #10 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-06-18. | 2022-04-25 10:14:26.922
CL-202206-NYMEX [C] 16 Day #10 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-07-17. | 2022-04-25 10:14:26.922
CL-202206-NYMEX [C] 16 Day #10 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-05-17. | 2022-04-25 10:14:26.926
CL-202206-NYMEX [C] 16 Day #10 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-06-17. | 2022-04-25 10:14:26.926
CL-202206-NYMEX [C] 16 Day #10 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-04-18. | 2022-04-25 10:14:26.931
CL-202206-NYMEX [C] 16 Day #10 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-05-16. | 2022-04-25 10:14:26.931
CL-202206-NYMEX [C] 16 Day #10 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-03-18. | 2022-04-25 10:14:26.935
CL-202206-NYMEX [C] 16 Day #10 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-04-17. | 2022-04-25 10:14:26.935
CL-202206-NYMEX [C] 16 Day #10 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-02-18. | 2022-04-25 10:14:26.939
CL-202206-NYMEX [C] 16 Day #10 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-03-15. | 2022-04-25 10:14:26.939
CL-202206-NYMEX [C] 16 Day #10 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-01-18. | 2022-04-25 10:14:26.944
CL-202206-NYMEX [C] 16 Day #10 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-02-15. | 2022-04-25 10:14:26.944
CL-202206-NYMEX [C] 16 Day #10 | File CL-199102-NYMEX.dly has a volume of 0 at 1990-12-18. | 2022-04-25 10:14:26.948
CL-202206-NYMEX [C] 16 Day #10 | File CL-199102-NYMEX.dly has a volume of 0 at 1991-01-17. | 2022-04-25 10:14:26.948
CL-202206-NYMEX [C] 16 Day #10 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-11-16. | 2022-04-25 10:14:26.952
CL-202206-NYMEX [C] 16 Day #10 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-12-17. | 2022-04-25 10:14:26.952
CL-202206-NYMEX [C] 16 Day #10 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-10-18. | 2022-04-25 10:14:26.956
CL-202206-NYMEX [C] 16 Day #10 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-11-15. | 2022-04-25 10:14:26.956
CL-202206-NYMEX [C] 16 Day #10 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-09-18. | 2022-04-25 10:14:26.961
CL-202206-NYMEX [C] 16 Day #10 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-10-17. | 2022-04-25 10:14:26.961
CL-202206-NYMEX [C] 16 Day #10 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-08-17. | 2022-04-25 10:14:26.965
CL-202206-NYMEX [C] 16 Day #10 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-09-17. | 2022-04-25 10:14:26.965
CL-202206-NYMEX [C] 16 Day #10 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-07-18. | 2022-04-25 10:14:26.969
CL-202206-NYMEX [C] 16 Day #10 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-08-16. | 2022-04-25 10:14:26.969
CL-202206-NYMEX [C] 16 Day #10 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-06-18. | 2022-04-25 10:14:26.973
CL-202206-NYMEX [C] 16 Day #10 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-07-17. | 2022-04-25 10:14:26.973
CL-202206-NYMEX [C] 16 Day #10 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-05-18. | 2022-04-25 10:14:26.978
CL-202206-NYMEX [C] 16 Day #10 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-06-15. | 2022-04-25 10:14:26.978
CL-202206-NYMEX [C] 16 Day #10 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-04-18. | 2022-04-25 10:14:26.982
CL-202206-NYMEX [C] 16 Day #10 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-05-17. | 2022-04-25 10:14:26.982
CL-202206-NYMEX [C] 16 Day #10 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-03-16. | 2022-04-25 10:14:26.986
CL-202206-NYMEX [C] 16 Day #10 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-04-17. | 2022-04-25 10:14:26.986
CL-202206-NYMEX [C] 16 Day #10 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-02-16. | 2022-04-25 10:14:26.990
CL-202206-NYMEX [C] 16 Day #10 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-03-15. | 2022-04-25 10:14:26.990
CL-202206-NYMEX [C] 16 Day #10 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-01-18. | 2022-04-25 10:14:26.995
CL-202206-NYMEX [C] 16 Day #10 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-02-15. | 2022-04-25 10:14:26.995
CL-202206-NYMEX [C] 16 Day #10 | File CL-199002-NYMEX.dly has a volume of 0 at 1989-12-18. | 2022-04-25 10:14:26.999
CL-202206-NYMEX [C] 16 Day #10 | File CL-199002-NYMEX.dly has a volume of 0 at 1990-01-17. | 2022-04-25 10:14:26.999
CL-202206-NYMEX [C] 16 Day #10 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-11-17. | 2022-04-25 10:14:27.003
CL-202206-NYMEX [C] 16 Day #10 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-12-15. | 2022-04-25 10:14:27.003
CL-202206-NYMEX [C] 16 Day #10 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-10-18. | 2022-04-25 10:14:27.007
CL-202206-NYMEX [C] 16 Day #10 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-11-16. | 2022-04-25 10:14:27.007
CL-202206-NYMEX [C] 16 Day #10 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-09-18. | 2022-04-25 10:14:27.012
CL-202206-NYMEX [C] 16 Day #10 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-10-17. | 2022-04-25 10:14:27.012
CL-202206-NYMEX [C] 16 Day #10 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-08-18. | 2022-04-25 10:14:27.016
CL-202206-NYMEX [C] 16 Day #10 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-09-15. | 2022-04-25 10:14:27.016
CL-202206-NYMEX [C] 16 Day #10 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-07-18. | 2022-04-25 10:14:27.021
CL-202206-NYMEX [C] 16 Day #10 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-08-17. | 2022-04-25 10:14:27.021
CL-202206-NYMEX [C] 16 Day #10 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-06-16. | 2022-04-25 10:14:27.025
CL-202206-NYMEX [C] 16 Day #10 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-07-17. | 2022-04-25 10:14:27.025
CL-202206-NYMEX [C] 16 Day #10 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-05-18. | 2022-04-25 10:14:27.030
CL-202206-NYMEX [C] 16 Day #10 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-06-15. | 2022-04-25 10:14:27.030
CL-202206-NYMEX [C] 16 Day #10 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-04-18. | 2022-04-25 10:14:27.034
CL-202206-NYMEX [C] 16 Day #10 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-05-17. | 2022-04-25 10:14:27.034
CL-202206-NYMEX [C] 16 Day #10 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-03-17. | 2022-04-25 10:14:27.038
CL-202206-NYMEX [C] 16 Day #10 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-04-17. | 2022-04-25 10:14:27.038
CL-202206-NYMEX [C] 16 Day #10 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-02-17. | 2022-04-25 10:14:27.042
CL-202206-NYMEX [C] 16 Day #10 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-03-16. | 2022-04-25 10:14:27.042
CL-202206-NYMEX [C] 16 Day #10 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-01-18. | 2022-04-25 10:14:27.047
CL-202206-NYMEX [C] 16 Day #10 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-02-16. | 2022-04-25 10:14:27.047
CL-202206-NYMEX [C] 16 Day #10 | File CL-198902-NYMEX.dly has a volume of 0 at 1988-12-16. | 2022-04-25 10:14:27.051
CL-202206-NYMEX [C] 16 Day #10 | File CL-198902-NYMEX.dly has a volume of 0 at 1989-01-17. | 2022-04-25 10:14:27.051
CL-202206-NYMEX [C] 16 Day #10 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-11-18. | 2022-04-25 10:14:27.055
CL-202206-NYMEX [C] 16 Day #10 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-12-15. | 2022-04-25 10:14:27.055
CL-202206-NYMEX [C] 16 Day #10 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-10-18. | 2022-04-25 10:14:27.059
CL-202206-NYMEX [C] 16 Day #10 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-11-17. | 2022-04-25 10:14:27.059
CL-202206-NYMEX [C] 16 Day #10 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-09-16. | 2022-04-25 10:14:27.064
CL-202206-NYMEX [C] 16 Day #10 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-10-17. | 2022-04-25 10:14:27.064
CL-202206-NYMEX [C] 16 Day #10 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-08-18. | 2022-04-25 10:14:27.068
CL-202206-NYMEX [C] 16 Day #10 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-09-15. | 2022-04-25 10:14:27.068
CL-202206-NYMEX [C] 16 Day #10 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-07-18. | 2022-04-25 10:14:27.073
CL-202206-NYMEX [C] 16 Day #10 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-08-17. | 2022-04-25 10:14:27.073
CL-202206-NYMEX [C] 16 Day #10 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-06-17. | 2022-04-25 10:14:27.077
CL-202206-NYMEX [C] 16 Day #10 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-07-15. | 2022-04-25 10:14:27.077
CL-202206-NYMEX [C] 16 Day #10 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-05-18. | 2022-04-25 10:14:27.081
CL-202206-NYMEX [C] 16 Day #10 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-06-16. | 2022-04-25 10:14:27.081
CL-202206-NYMEX [C] 16 Day #10 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-04-18. | 2022-04-25 10:14:27.086
CL-202206-NYMEX [C] 16 Day #10 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-05-17. | 2022-04-25 10:14:27.086
CL-202206-NYMEX [C] 16 Day #10 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-03-18. | 2022-04-25 10:14:27.090
CL-202206-NYMEX [C] 16 Day #10 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-04-15. | 2022-04-25 10:14:27.090
CL-202206-NYMEX [C] 16 Day #10 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-02-18. | 2022-04-25 10:14:27.094
CL-202206-NYMEX [C] 16 Day #10 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-03-17. | 2022-04-25 10:14:27.094
CL-202206-NYMEX [C] 16 Day #10 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-01-18. | 2022-04-25 10:14:27.099
CL-202206-NYMEX [C] 16 Day #10 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-02-17. | 2022-04-25 10:14:27.099
CL-202206-NYMEX [C] 16 Day #10 | File CL-198802-NYMEX.dly has a volume of 0 at 1987-12-18. | 2022-04-25 10:14:27.103
CL-202206-NYMEX [C] 16 Day #10 | File CL-198802-NYMEX.dly has a volume of 0 at 1988-01-15. | 2022-04-25 10:14:27.103
CL-202206-NYMEX [C] 16 Day #10 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-11-18. | 2022-04-25 10:14:27.107
CL-202206-NYMEX [C] 16 Day #10 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-12-17. | 2022-04-25 10:14:27.107
CL-202206-NYMEX [C] 16 Day #10 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-10-16. | 2022-04-25 10:14:27.112
CL-202206-NYMEX [C] 16 Day #10 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-11-17. | 2022-04-25 10:14:27.112
CL-202206-NYMEX [C] 16 Day #10 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-09-18. | 2022-04-25 10:14:27.116
CL-202206-NYMEX [C] 16 Day #10 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-10-15. | 2022-04-25 10:14:27.116
CL-202206-NYMEX [C] 16 Day #10 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-08-18. | 2022-04-25 10:14:27.120
CL-202206-NYMEX [C] 16 Day #10 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-09-17. | 2022-04-25 10:14:27.120
CL-202206-NYMEX [C] 16 Day #10 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-07-17. | 2022-04-25 10:14:27.125
CL-202206-NYMEX [C] 16 Day #10 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-08-17. | 2022-04-25 10:14:27.125
CL-202206-NYMEX [C] 16 Day #10 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-06-18. | 2022-04-25 10:14:27.129
CL-202206-NYMEX [C] 16 Day #10 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-07-16. | 2022-04-25 10:14:27.129
CL-202206-NYMEX [C] 16 Day #10 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-05-18. | 2022-04-25 10:14:27.133
CL-202206-NYMEX [C] 16 Day #10 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-06-17. | 2022-04-25 10:14:27.133
CL-202206-NYMEX [C] 16 Day #10 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-04-17. | 2022-04-25 10:14:27.137
CL-202206-NYMEX [C] 16 Day #10 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-05-15. | 2022-04-25 10:14:27.137
CL-202206-NYMEX [C] 16 Day #10 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-03-18. | 2022-04-25 10:14:27.142
CL-202206-NYMEX [C] 16 Day #10 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-04-16. | 2022-04-25 10:14:27.142
CL-202206-NYMEX [C] 16 Day #10 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-02-18. | 2022-04-25 10:14:27.146
CL-202206-NYMEX [C] 16 Day #10 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-03-17. | 2022-04-25 10:14:27.146
CL-202206-NYMEX [C] 16 Day #10 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-01-16. | 2022-04-25 10:14:27.151
CL-202206-NYMEX [C] 16 Day #10 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-02-17. | 2022-04-25 10:14:27.151
CL-202206-NYMEX [C] 16 Day #10 | File CL-198702-NYMEX.dly has a volume of 0 at 1986-12-18. | 2022-04-25 10:14:27.155
CL-202206-NYMEX [C] 16 Day #10 | File CL-198702-NYMEX.dly has a volume of 0 at 1987-01-15. | 2022-04-25 10:14:27.155
CL-202206-NYMEX [C] 16 Day #10 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-11-18. | 2022-04-25 10:14:27.159
CL-202206-NYMEX [C] 16 Day #10 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-12-17. | 2022-04-25 10:14:27.159
CL-202206-NYMEX [C] 16 Day #10 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-10-17. | 2022-04-25 10:14:27.163
CL-202206-NYMEX [C] 16 Day #10 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-11-17. | 2022-04-25 10:14:27.163
CL-202206-NYMEX [C] 16 Day #10 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-09-18. | 2022-04-25 10:14:27.168
CL-202206-NYMEX [C] 16 Day #10 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-10-16. | 2022-04-25 10:14:27.168
CL-202206-NYMEX [C] 16 Day #10 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-08-18. | 2022-04-25 10:14:27.172
CL-202206-NYMEX [C] 16 Day #10 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-09-17. | 2022-04-25 10:14:27.172
CL-202206-NYMEX [C] 16 Day #10 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-07-18. | 2022-04-25 10:14:27.176
CL-202206-NYMEX [C] 16 Day #10 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-08-15. | 2022-04-25 10:14:27.176
CL-202206-NYMEX [C] 16 Day #10 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-06-18. | 2022-04-25 10:14:27.180
CL-202206-NYMEX [C] 16 Day #10 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-07-17. | 2022-04-25 10:14:27.180
CL-202206-NYMEX [C] 16 Day #10 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-05-16. | 2022-04-25 10:14:27.185
CL-202206-NYMEX [C] 16 Day #10 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-06-17. | 2022-04-25 10:14:27.185
CL-202206-NYMEX [C] 16 Day #10 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-04-18. | 2022-04-25 10:14:27.189
CL-202206-NYMEX [C] 16 Day #10 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-05-15. | 2022-04-25 10:14:27.189
CL-202206-NYMEX [C] 16 Day #10 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-03-18. | 2022-04-25 10:14:27.194
CL-202206-NYMEX [C] 16 Day #10 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-04-17. | 2022-04-25 10:14:27.194
CL-202206-NYMEX [C] 16 Day #10 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-02-18. | 2022-04-25 10:14:27.198
CL-202206-NYMEX [C] 16 Day #10 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-03-17. | 2022-04-25 10:14:27.198
CL-202206-NYMEX [C] 16 Day #10 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-01-17. | 2022-04-25 10:14:27.202
CL-202206-NYMEX [C] 16 Day #10 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-02-17. | 2022-04-25 10:14:27.202
CL-202206-NYMEX [C] 16 Day #10 | File CL-198602-NYMEX.dly has a volume of 0 at 1985-12-18. | 2022-04-25 10:14:27.206
CL-202206-NYMEX [C] 16 Day #10 | File CL-198602-NYMEX.dly has a volume of 0 at 1986-01-16. | 2022-04-25 10:14:27.206
CL-202206-NYMEX [C] 16 Day #10 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-11-18. | 2022-04-25 10:14:27.210
CL-202206-NYMEX [C] 16 Day #10 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-12-17. | 2022-04-25 10:14:27.210
CL-202206-NYMEX [C] 16 Day #10 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-10-18. | 2022-04-25 10:14:27.215
CL-202206-NYMEX [C] 16 Day #10 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-11-15. | 2022-04-25 10:14:27.215
CL-202206-NYMEX [C] 16 Day #10 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-09-18. | 2022-04-25 10:14:27.219
CL-202206-NYMEX [C] 16 Day #10 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-10-17. | 2022-04-25 10:14:27.219
CL-202206-NYMEX [C] 16 Day #10 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-08-16. | 2022-04-25 10:14:27.223
CL-202206-NYMEX [C] 16 Day #10 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-09-17. | 2022-04-25 10:14:27.223
CL-202206-NYMEX [C] 16 Day #10 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-07-18. | 2022-04-25 10:14:27.228
CL-202206-NYMEX [C] 16 Day #10 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-08-15. | 2022-04-25 10:14:27.228
CL-202206-NYMEX [C] 16 Day #10 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-06-18. | 2022-04-25 10:14:27.232
CL-202206-NYMEX [C] 16 Day #10 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-07-17. | 2022-04-25 10:14:27.232
CL-202206-NYMEX [C] 16 Day #10 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-05-17. | 2022-04-25 10:14:27.236
CL-202206-NYMEX [C] 16 Day #10 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-06-17. | 2022-04-25 10:14:27.236
CL-202206-NYMEX [C] 16 Day #10 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-04-18. | 2022-04-25 10:14:27.240
CL-202206-NYMEX [C] 16 Day #10 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-05-16. | 2022-04-25 10:14:27.240
CL-202206-NYMEX [C] 16 Day #10 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-03-18. | 2022-04-25 10:14:27.245
CL-202206-NYMEX [C] 16 Day #10 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-04-17. | 2022-04-25 10:14:27.245
CL-202206-NYMEX [C] 16 Day #10 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-02-18. | 2022-04-25 10:14:27.249
CL-202206-NYMEX [C] 16 Day #10 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-03-15. | 2022-04-25 10:14:27.249
CL-202206-NYMEX [C] 16 Day #10 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-01-18. | 2022-04-25 10:14:27.253
CL-202206-NYMEX [C] 16 Day #10 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-02-15. | 2022-04-25 10:14:27.253
CL-202206-NYMEX [C] 16 Day #10 | File CL-198502-NYMEX.dly has a volume of 0 at 1984-12-18. | 2022-04-25 10:14:27.257
CL-202206-NYMEX [C] 16 Day #10 | File CL-198502-NYMEX.dly has a volume of 0 at 1985-01-17. | 2022-04-25 10:14:27.257
CL-202206-NYMEX [C] 16 Day #10 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-11-16. | 2022-04-25 10:14:27.260
CL-202206-NYMEX [C] 16 Day #10 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-12-17. | 2022-04-25 10:14:27.260
CL-202206-NYMEX [C] 16 Day #10 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-10-18. | 2022-04-25 10:14:27.264
CL-202206-NYMEX [C] 16 Day #10 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-11-15. | 2022-04-25 10:14:27.264
CL-202206-NYMEX [C] 16 Day #10 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-09-18. | 2022-04-25 10:14:27.268
CL-202206-NYMEX [C] 16 Day #10 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-10-17. | 2022-04-25 10:14:27.268
CL-202206-NYMEX [C] 16 Day #10 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-08-17. | 2022-04-25 10:14:27.272
CL-202206-NYMEX [C] 16 Day #10 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-09-17. | 2022-04-25 10:14:27.272
CL-202206-NYMEX [C] 16 Day #10 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-07-18. | 2022-04-25 10:14:27.276
CL-202206-NYMEX [C] 16 Day #10 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-08-16. | 2022-04-25 10:14:27.276
CL-202206-NYMEX [C] 16 Day #10 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-06-18. | 2022-04-25 10:14:27.280
CL-202206-NYMEX [C] 16 Day #10 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-07-17. | 2022-04-25 10:14:27.280
CL-202206-NYMEX [C] 16 Day #10 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-05-18. | 2022-04-25 10:14:27.284
CL-202206-NYMEX [C] 16 Day #10 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-06-15. | 2022-04-25 10:14:27.284
CL-202206-NYMEX [C] 16 Day #10 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-04-18. | 2022-04-25 10:14:27.288
CL-202206-NYMEX [C] 16 Day #10 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-05-17. | 2022-04-25 10:14:27.288
CL-202206-NYMEX [C] 16 Day #10 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-03-16. | 2022-04-25 10:14:27.293
CL-202206-NYMEX [C] 16 Day #10 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-04-17. | 2022-04-25 10:14:27.293
CL-202206-NYMEX [C] 16 Day #10 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-02-17. | 2022-04-25 10:14:27.296
CL-202206-NYMEX [C] 16 Day #10 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-03-15. | 2022-04-25 10:14:27.296
CL-202206-NYMEX [C] 16 Day #10 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-01-18. | 2022-04-25 10:14:27.300
CL-202206-NYMEX [C] 16 Day #10 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-02-16. | 2022-04-25 10:14:27.300
CL-202206-NYMEX [C] 16 Day #10 | File CL-198402-NYMEX.dly has a volume of 0 at 1983-12-16. | 2022-04-25 10:14:27.305
CL-202206-NYMEX [C] 16 Day #10 | File CL-198402-NYMEX.dly has a volume of 0 at 1984-01-17. | 2022-04-25 10:14:27.305
CL-202206-NYMEX [C] 16 Day #10 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-11-18. | 2022-04-25 10:14:27.308
CL-202206-NYMEX [C] 16 Day #10 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-12-15. | 2022-04-25 10:14:27.308
CL-202206-NYMEX [C] 16 Day #10 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-10-18. | 2022-04-25 10:14:27.312
CL-202206-NYMEX [C] 16 Day #10 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-11-17. | 2022-04-25 10:14:27.312
CL-202206-NYMEX [C] 16 Day #10 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-09-16. | 2022-04-25 10:14:27.317
CL-202206-NYMEX [C] 16 Day #10 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-10-17. | 2022-04-25 10:14:27.317
CL-202206-NYMEX [C] 16 Day #10 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-08-18. | 2022-04-25 10:14:27.321
CL-202206-NYMEX [C] 16 Day #10 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-09-15. | 2022-04-25 10:14:27.321
CL-202206-NYMEX [C] 16 Day #10 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-07-18. | 2022-04-25 10:14:27.325
CL-202206-NYMEX [C] 16 Day #10 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-08-17. | 2022-04-25 10:14:27.325
CL-202206-NYMEX [C] 16 Day #10 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-06-17. | 2022-04-25 10:14:27.329
CL-202206-NYMEX [C] 16 Day #10 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-07-15. | 2022-04-25 10:14:27.329
CL-202206-NYMEX [C] 16 Day #10 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-05-18. | 2022-04-25 10:14:27.333
CL-202206-NYMEX [C] 16 Day #10 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-06-16. | 2022-04-25 10:14:27.333
CL-202206-NYMEX [C] 16 Day #10 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-04-18. | 2022-04-25 10:14:27.337
CL-202206-NYMEX [C] 16 Day #10 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-05-17. | 2022-04-25 10:14:27.337
CL-202206-NYMEX [C] 16 Day #10 | Waiting for historical downloads to complete with the IDs: 23, 24, | 2022-04-25 10:14:27.435
CL-202206-NYMEX [C] 2 Day #3 | Reloading chart. | 2022-04-25 10:14:27.446
CL-202206-NYMEX [C] 2 Day #3 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:27.446
CL-202206-NYMEX [C] 2 Day #3 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:27.446
CL-202206-NYMEX [C] 2 Day #3 | File CL-200102-NYMEX.dly has a volume of 0 at 2000-12-18. | 2022-04-25 10:14:29.185
CL-202206-NYMEX [C] 2 Day #3 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-11-17. | 2022-04-25 10:14:29.189
CL-202206-NYMEX [C] 2 Day #3 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-12-15. | 2022-04-25 10:14:29.189
CL-202206-NYMEX [C] 2 Day #3 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-10-18. | 2022-04-25 10:14:29.193
CL-202206-NYMEX [C] 2 Day #3 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-11-16. | 2022-04-25 10:14:29.193
CL-202206-NYMEX [C] 2 Day #3 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-09-18. | 2022-04-25 10:14:29.198
CL-202206-NYMEX [C] 2 Day #3 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-10-17. | 2022-04-25 10:14:29.198
CL-202206-NYMEX [C] 2 Day #3 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-08-18. | 2022-04-25 10:14:29.202
CL-202206-NYMEX [C] 2 Day #3 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-09-15. | 2022-04-25 10:14:29.202
CL-202206-NYMEX [C] 2 Day #3 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-07-18. | 2022-04-25 10:14:29.207
CL-202206-NYMEX [C] 2 Day #3 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-08-17. | 2022-04-25 10:14:29.207
CL-202206-NYMEX [C] 2 Day #3 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-06-16. | 2022-04-25 10:14:29.211
CL-202206-NYMEX [C] 2 Day #3 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-07-17. | 2022-04-25 10:14:29.211
CL-202206-NYMEX [C] 2 Day #3 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-05-18. | 2022-04-25 10:14:29.215
CL-202206-NYMEX [C] 2 Day #3 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-06-15. | 2022-04-25 10:14:29.215
CL-202206-NYMEX [C] 2 Day #3 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-04-18. | 2022-04-25 10:14:29.219
CL-202206-NYMEX [C] 2 Day #3 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-05-17. | 2022-04-25 10:14:29.219
CL-202206-NYMEX [C] 2 Day #3 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-03-17. | 2022-04-25 10:14:29.224
CL-202206-NYMEX [C] 2 Day #3 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-04-17. | 2022-04-25 10:14:29.224
CL-202206-NYMEX [C] 2 Day #3 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-02-18. | 2022-04-25 10:14:29.228
CL-202206-NYMEX [C] 2 Day #3 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-03-16. | 2022-04-25 10:14:29.228
CL-202206-NYMEX [C] 2 Day #3 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-01-18. | 2022-04-25 10:14:29.232
CL-202206-NYMEX [C] 2 Day #3 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-02-17. | 2022-04-25 10:14:29.232
CL-202206-NYMEX [C] 2 Day #3 | File CL-200002-NYMEX.dly has a volume of 0 at 1999-12-17. | 2022-04-25 10:14:29.236
CL-202206-NYMEX [C] 2 Day #3 | File CL-200002-NYMEX.dly has a volume of 0 at 2000-01-17. | 2022-04-25 10:14:29.236
CL-202206-NYMEX [C] 2 Day #3 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-11-18. | 2022-04-25 10:14:29.241
CL-202206-NYMEX [C] 2 Day #3 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-12-16. | 2022-04-25 10:14:29.241
CL-202206-NYMEX [C] 2 Day #3 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-10-18. | 2022-04-25 10:14:29.246
CL-202206-NYMEX [C] 2 Day #3 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-11-17. | 2022-04-25 10:14:29.246
CL-202206-NYMEX [C] 2 Day #3 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-09-17. | 2022-04-25 10:14:29.250
CL-202206-NYMEX [C] 2 Day #3 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-10-15. | 2022-04-25 10:14:29.250
CL-202206-NYMEX [C] 2 Day #3 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-08-18. | 2022-04-25 10:14:29.254
CL-202206-NYMEX [C] 2 Day #3 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-09-16. | 2022-04-25 10:14:29.254
CL-202206-NYMEX [C] 2 Day #3 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-07-16. | 2022-04-25 10:14:29.259
CL-202206-NYMEX [C] 2 Day #3 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-08-17. | 2022-04-25 10:14:29.259
CL-202206-NYMEX [C] 2 Day #3 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-06-18. | 2022-04-25 10:14:29.263
CL-202206-NYMEX [C] 2 Day #3 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-07-15. | 2022-04-25 10:14:29.263
CL-202206-NYMEX [C] 2 Day #3 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-05-18. | 2022-04-25 10:14:29.268
CL-202206-NYMEX [C] 2 Day #3 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-06-17. | 2022-04-25 10:14:29.268
CL-202206-NYMEX [C] 2 Day #3 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-04-16. | 2022-04-25 10:14:29.272
CL-202206-NYMEX [C] 2 Day #3 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-05-17. | 2022-04-25 10:14:29.272
CL-202206-NYMEX [C] 2 Day #3 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-03-18. | 2022-04-25 10:14:29.276
CL-202206-NYMEX [C] 2 Day #3 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-04-15. | 2022-04-25 10:14:29.276
CL-202206-NYMEX [C] 2 Day #3 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-02-18. | 2022-04-25 10:14:29.280
CL-202206-NYMEX [C] 2 Day #3 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-03-17. | 2022-04-25 10:14:29.280
CL-202206-NYMEX [C] 2 Day #3 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-01-18. | 2022-04-25 10:14:29.285
CL-202206-NYMEX [C] 2 Day #3 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-02-17. | 2022-04-25 10:14:29.285
CL-202206-NYMEX [C] 2 Day #3 | File CL-199902-NYMEX.dly has a volume of 0 at 1998-12-18. | 2022-04-25 10:14:29.289
CL-202206-NYMEX [C] 2 Day #3 | File CL-199902-NYMEX.dly has a volume of 0 at 1999-01-15. | 2022-04-25 10:14:29.289
CL-202206-NYMEX [C] 2 Day #3 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-11-18. | 2022-04-25 10:14:29.293
CL-202206-NYMEX [C] 2 Day #3 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-12-17. | 2022-04-25 10:14:29.293
CL-202206-NYMEX [C] 2 Day #3 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-10-16. | 2022-04-25 10:14:29.298
CL-202206-NYMEX [C] 2 Day #3 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-11-17. | 2022-04-25 10:14:29.298
CL-202206-NYMEX [C] 2 Day #3 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-09-18. | 2022-04-25 10:14:29.302
CL-202206-NYMEX [C] 2 Day #3 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-10-15. | 2022-04-25 10:14:29.302
CL-202206-NYMEX [C] 2 Day #3 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-08-18. | 2022-04-25 10:14:29.306
CL-202206-NYMEX [C] 2 Day #3 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-09-17. | 2022-04-25 10:14:29.306
CL-202206-NYMEX [C] 2 Day #3 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-07-17. | 2022-04-25 10:14:29.311
CL-202206-NYMEX [C] 2 Day #3 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-08-17. | 2022-04-25 10:14:29.311
CL-202206-NYMEX [C] 2 Day #3 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-06-18. | 2022-04-25 10:14:29.315
CL-202206-NYMEX [C] 2 Day #3 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-07-16. | 2022-04-25 10:14:29.315
CL-202206-NYMEX [C] 2 Day #3 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-05-18. | 2022-04-25 10:14:29.319
CL-202206-NYMEX [C] 2 Day #3 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-06-17. | 2022-04-25 10:14:29.319
CL-202206-NYMEX [C] 2 Day #3 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-04-17. | 2022-04-25 10:14:29.324
CL-202206-NYMEX [C] 2 Day #3 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-05-15. | 2022-04-25 10:14:29.324
CL-202206-NYMEX [C] 2 Day #3 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-03-18. | 2022-04-25 10:14:29.328
CL-202206-NYMEX [C] 2 Day #3 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-04-16. | 2022-04-25 10:14:29.328
CL-202206-NYMEX [C] 2 Day #3 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-02-18. | 2022-04-25 10:14:29.332
CL-202206-NYMEX [C] 2 Day #3 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-03-17. | 2022-04-25 10:14:29.332
CL-202206-NYMEX [C] 2 Day #3 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-01-16. | 2022-04-25 10:14:29.337
CL-202206-NYMEX [C] 2 Day #3 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-02-17. | 2022-04-25 10:14:29.337
CL-202206-NYMEX [C] 2 Day #3 | File CL-199802-NYMEX.dly has a volume of 0 at 1997-12-18. | 2022-04-25 10:14:29.341
CL-202206-NYMEX [C] 2 Day #3 | File CL-199802-NYMEX.dly has a volume of 0 at 1998-01-15. | 2022-04-25 10:14:29.341
CL-202206-NYMEX [C] 2 Day #3 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-11-18. | 2022-04-25 10:14:29.345
CL-202206-NYMEX [C] 2 Day #3 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-12-17. | 2022-04-25 10:14:29.345
CL-202206-NYMEX [C] 2 Day #3 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-10-17. | 2022-04-25 10:14:29.349
CL-202206-NYMEX [C] 2 Day #3 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-11-17. | 2022-04-25 10:14:29.349
CL-202206-NYMEX [C] 2 Day #3 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-09-18. | 2022-04-25 10:14:29.353
CL-202206-NYMEX [C] 2 Day #3 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-10-16. | 2022-04-25 10:14:29.353
CL-202206-NYMEX [C] 2 Day #3 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-08-18. | 2022-04-25 10:14:29.358
CL-202206-NYMEX [C] 2 Day #3 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-09-17. | 2022-04-25 10:14:29.358
CL-202206-NYMEX [C] 2 Day #3 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-07-18. | 2022-04-25 10:14:29.362
CL-202206-NYMEX [C] 2 Day #3 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-08-15. | 2022-04-25 10:14:29.362
CL-202206-NYMEX [C] 2 Day #3 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-06-18. | 2022-04-25 10:14:29.367
CL-202206-NYMEX [C] 2 Day #3 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-07-17. | 2022-04-25 10:14:29.367
CL-202206-NYMEX [C] 2 Day #3 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-05-16. | 2022-04-25 10:14:29.371
CL-202206-NYMEX [C] 2 Day #3 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-06-17. | 2022-04-25 10:14:29.371
CL-202206-NYMEX [C] 2 Day #3 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-04-18. | 2022-04-25 10:14:29.375
CL-202206-NYMEX [C] 2 Day #3 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-05-15. | 2022-04-25 10:14:29.375
CL-202206-NYMEX [C] 2 Day #3 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-03-18. | 2022-04-25 10:14:29.380
CL-202206-NYMEX [C] 2 Day #3 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-04-17. | 2022-04-25 10:14:29.380
CL-202206-NYMEX [C] 2 Day #3 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-02-18. | 2022-04-25 10:14:29.384
CL-202206-NYMEX [C] 2 Day #3 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-03-17. | 2022-04-25 10:14:29.384
CL-202206-NYMEX [C] 2 Day #3 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-01-17. | 2022-04-25 10:14:29.388
CL-202206-NYMEX [C] 2 Day #3 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-02-17. | 2022-04-25 10:14:29.388
CL-202206-NYMEX [C] 2 Day #3 | File CL-199702-NYMEX.dly has a volume of 0 at 1996-12-18. | 2022-04-25 10:14:29.392
CL-202206-NYMEX [C] 2 Day #3 | File CL-199702-NYMEX.dly has a volume of 0 at 1997-01-16. | 2022-04-25 10:14:29.392
CL-202206-NYMEX [C] 2 Day #3 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-11-18. | 2022-04-25 10:14:29.396
CL-202206-NYMEX [C] 2 Day #3 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-12-17. | 2022-04-25 10:14:29.396
CL-202206-NYMEX [C] 2 Day #3 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-10-18. | 2022-04-25 10:14:29.401
CL-202206-NYMEX [C] 2 Day #3 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-11-15. | 2022-04-25 10:14:29.401
CL-202206-NYMEX [C] 2 Day #3 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-09-18. | 2022-04-25 10:14:29.405
CL-202206-NYMEX [C] 2 Day #3 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-10-17. | 2022-04-25 10:14:29.405
CL-202206-NYMEX [C] 2 Day #3 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-08-16. | 2022-04-25 10:14:29.409
CL-202206-NYMEX [C] 2 Day #3 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-09-17. | 2022-04-25 10:14:29.409
CL-202206-NYMEX [C] 2 Day #3 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-07-18. | 2022-04-25 10:14:29.414
CL-202206-NYMEX [C] 2 Day #3 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-08-15. | 2022-04-25 10:14:29.414
CL-202206-NYMEX [C] 2 Day #3 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-06-18. | 2022-04-25 10:14:29.418
CL-202206-NYMEX [C] 2 Day #3 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-07-17. | 2022-04-25 10:14:29.418
CL-202206-NYMEX [C] 2 Day #3 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-05-17. | 2022-04-25 10:14:29.422
CL-202206-NYMEX [C] 2 Day #3 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-06-17. | 2022-04-25 10:14:29.422
CL-202206-NYMEX [C] 2 Day #3 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-04-18. | 2022-04-25 10:14:29.427
CL-202206-NYMEX [C] 2 Day #3 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-05-16. | 2022-04-25 10:14:29.427
CL-202206-NYMEX [C] 2 Day #3 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-03-18. | 2022-04-25 10:14:29.432
CL-202206-NYMEX [C] 2 Day #3 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-04-17. | 2022-04-25 10:14:29.432
CL-202206-NYMEX [C] 2 Day #3 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-02-16. | 2022-04-25 10:14:29.436
CL-202206-NYMEX [C] 2 Day #3 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-03-15. | 2022-04-25 10:14:29.436
CL-202206-NYMEX [C] 2 Day #3 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-01-18. | 2022-04-25 10:14:29.440
CL-202206-NYMEX [C] 2 Day #3 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-02-15. | 2022-04-25 10:14:29.440
CL-202206-NYMEX [C] 2 Day #3 | File CL-199602-NYMEX.dly has a volume of 0 at 1995-12-18. | 2022-04-25 10:14:29.444
CL-202206-NYMEX [C] 2 Day #3 | File CL-199602-NYMEX.dly has a volume of 0 at 1996-01-17. | 2022-04-25 10:14:29.444
CL-202206-NYMEX [C] 2 Day #3 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-11-17. | 2022-04-25 10:14:29.448
CL-202206-NYMEX [C] 2 Day #3 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-12-15. | 2022-04-25 10:14:29.448
CL-202206-NYMEX [C] 2 Day #3 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-10-18. | 2022-04-25 10:14:29.453
CL-202206-NYMEX [C] 2 Day #3 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-11-16. | 2022-04-25 10:14:29.453
CL-202206-NYMEX [C] 2 Day #3 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-09-18. | 2022-04-25 10:14:29.457
CL-202206-NYMEX [C] 2 Day #3 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-10-17. | 2022-04-25 10:14:29.457
CL-202206-NYMEX [C] 2 Day #3 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-08-18. | 2022-04-25 10:14:29.461
CL-202206-NYMEX [C] 2 Day #3 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-09-15. | 2022-04-25 10:14:29.461
CL-202206-NYMEX [C] 2 Day #3 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-07-18. | 2022-04-25 10:14:29.466
CL-202206-NYMEX [C] 2 Day #3 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-08-17. | 2022-04-25 10:14:29.466
CL-202206-NYMEX [C] 2 Day #3 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-06-16. | 2022-04-25 10:14:29.470
CL-202206-NYMEX [C] 2 Day #3 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-07-17. | 2022-04-25 10:14:29.470
CL-202206-NYMEX [C] 2 Day #3 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-05-18. | 2022-04-25 10:14:29.474
CL-202206-NYMEX [C] 2 Day #3 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-06-15. | 2022-04-25 10:14:29.474
CL-202206-NYMEX [C] 2 Day #3 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-04-18. | 2022-04-25 10:14:29.479
CL-202206-NYMEX [C] 2 Day #3 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-05-17. | 2022-04-25 10:14:29.479
CL-202206-NYMEX [C] 2 Day #3 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-03-17. | 2022-04-25 10:14:29.483
CL-202206-NYMEX [C] 2 Day #3 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-04-17. | 2022-04-25 10:14:29.483
CL-202206-NYMEX [C] 2 Day #3 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-02-17. | 2022-04-25 10:14:29.487
CL-202206-NYMEX [C] 2 Day #3 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-03-16. | 2022-04-25 10:14:29.487
CL-202206-NYMEX [C] 2 Day #3 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-01-18. | 2022-04-25 10:14:29.492
CL-202206-NYMEX [C] 2 Day #3 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-02-16. | 2022-04-25 10:14:29.492
CL-202206-NYMEX [C] 2 Day #3 | File CL-199502-NYMEX.dly has a volume of 0 at 1994-12-16. | 2022-04-25 10:14:29.496
CL-202206-NYMEX [C] 2 Day #3 | File CL-199502-NYMEX.dly has a volume of 0 at 1995-01-17. | 2022-04-25 10:14:29.496
CL-202206-NYMEX [C] 2 Day #3 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-11-18. | 2022-04-25 10:14:29.500
CL-202206-NYMEX [C] 2 Day #3 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-12-15. | 2022-04-25 10:14:29.500
CL-202206-NYMEX [C] 2 Day #3 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-10-18. | 2022-04-25 10:14:29.504
CL-202206-NYMEX [C] 2 Day #3 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-11-17. | 2022-04-25 10:14:29.504
CL-202206-NYMEX [C] 2 Day #3 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-09-16. | 2022-04-25 10:14:29.509
CL-202206-NYMEX [C] 2 Day #3 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-10-17. | 2022-04-25 10:14:29.509
CL-202206-NYMEX [C] 2 Day #3 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-08-18. | 2022-04-25 10:14:29.513
CL-202206-NYMEX [C] 2 Day #3 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-09-15. | 2022-04-25 10:14:29.513
CL-202206-NYMEX [C] 2 Day #3 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-07-18. | 2022-04-25 10:14:29.517
CL-202206-NYMEX [C] 2 Day #3 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-08-17. | 2022-04-25 10:14:29.517
CL-202206-NYMEX [C] 2 Day #3 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-06-17. | 2022-04-25 10:14:29.522
CL-202206-NYMEX [C] 2 Day #3 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-07-15. | 2022-04-25 10:14:29.522
CL-202206-NYMEX [C] 2 Day #3 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-05-18. | 2022-04-25 10:14:29.526
CL-202206-NYMEX [C] 2 Day #3 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-06-16. | 2022-04-25 10:14:29.526
CL-202206-NYMEX [C] 2 Day #3 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-04-18. | 2022-04-25 10:14:29.530
CL-202206-NYMEX [C] 2 Day #3 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-05-17. | 2022-04-25 10:14:29.530
CL-202206-NYMEX [C] 2 Day #3 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-03-18. | 2022-04-25 10:14:29.535
CL-202206-NYMEX [C] 2 Day #3 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-04-15. | 2022-04-25 10:14:29.535
CL-202206-NYMEX [C] 2 Day #3 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-02-18. | 2022-04-25 10:14:29.539
CL-202206-NYMEX [C] 2 Day #3 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-03-17. | 2022-04-25 10:14:29.539
CL-202206-NYMEX [C] 2 Day #3 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-01-18. | 2022-04-25 10:14:29.543
CL-202206-NYMEX [C] 2 Day #3 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-02-17. | 2022-04-25 10:14:29.543
CL-202206-NYMEX [C] 2 Day #3 | File CL-199402-NYMEX.dly has a volume of 0 at 1993-12-17. | 2022-04-25 10:14:29.547
CL-202206-NYMEX [C] 2 Day #3 | File CL-199402-NYMEX.dly has a volume of 0 at 1994-01-17. | 2022-04-25 10:14:29.547
CL-202206-NYMEX [C] 2 Day #3 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-11-18. | 2022-04-25 10:14:29.551
CL-202206-NYMEX [C] 2 Day #3 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-12-16. | 2022-04-25 10:14:29.551
CL-202206-NYMEX [C] 2 Day #3 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-10-18. | 2022-04-25 10:14:29.556
CL-202206-NYMEX [C] 2 Day #3 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-11-17. | 2022-04-25 10:14:29.556
CL-202206-NYMEX [C] 2 Day #3 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-09-17. | 2022-04-25 10:14:29.560
CL-202206-NYMEX [C] 2 Day #3 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-10-15. | 2022-04-25 10:14:29.560
CL-202206-NYMEX [C] 2 Day #3 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-08-18. | 2022-04-25 10:14:29.564
CL-202206-NYMEX [C] 2 Day #3 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-09-16. | 2022-04-25 10:14:29.564
CL-202206-NYMEX [C] 2 Day #3 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-07-16. | 2022-04-25 10:14:29.569
CL-202206-NYMEX [C] 2 Day #3 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-08-17. | 2022-04-25 10:14:29.569
CL-202206-NYMEX [C] 2 Day #3 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-06-18. | 2022-04-25 10:14:29.573
CL-202206-NYMEX [C] 2 Day #3 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-07-15. | 2022-04-25 10:14:29.573
CL-202206-NYMEX [C] 2 Day #3 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-05-18. | 2022-04-25 10:14:29.577
CL-202206-NYMEX [C] 2 Day #3 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-06-17. | 2022-04-25 10:14:29.577
CL-202206-NYMEX [C] 2 Day #3 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-04-16. | 2022-04-25 10:14:29.582
CL-202206-NYMEX [C] 2 Day #3 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-05-17. | 2022-04-25 10:14:29.582
CL-202206-NYMEX [C] 2 Day #3 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-03-18. | 2022-04-25 10:14:29.586
CL-202206-NYMEX [C] 2 Day #3 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-04-15. | 2022-04-25 10:14:29.586
CL-202206-NYMEX [C] 2 Day #3 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-02-18. | 2022-04-25 10:14:29.590
CL-202206-NYMEX [C] 2 Day #3 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-03-17. | 2022-04-25 10:14:29.590
CL-202206-NYMEX [C] 2 Day #3 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-01-18. | 2022-04-25 10:14:29.595
CL-202206-NYMEX [C] 2 Day #3 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-02-17. | 2022-04-25 10:14:29.595
CL-202206-NYMEX [C] 2 Day #3 | File CL-199302-NYMEX.dly has a volume of 0 at 1992-12-18. | 2022-04-25 10:14:29.599
CL-202206-NYMEX [C] 2 Day #3 | File CL-199302-NYMEX.dly has a volume of 0 at 1993-01-15. | 2022-04-25 10:14:29.599
CL-202206-NYMEX [C] 2 Day #3 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-11-18. | 2022-04-25 10:14:29.603
CL-202206-NYMEX [C] 2 Day #3 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-12-17. | 2022-04-25 10:14:29.603
CL-202206-NYMEX [C] 2 Day #3 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-10-16. | 2022-04-25 10:14:29.608
CL-202206-NYMEX [C] 2 Day #3 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-11-17. | 2022-04-25 10:14:29.608
CL-202206-NYMEX [C] 2 Day #3 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-09-18. | 2022-04-25 10:14:29.612
CL-202206-NYMEX [C] 2 Day #3 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-10-15. | 2022-04-25 10:14:29.612
CL-202206-NYMEX [C] 2 Day #3 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-08-18. | 2022-04-25 10:14:29.617
CL-202206-NYMEX [C] 2 Day #3 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-09-17. | 2022-04-25 10:14:29.617
CL-202206-NYMEX [C] 2 Day #3 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-07-17. | 2022-04-25 10:14:29.621
CL-202206-NYMEX [C] 2 Day #3 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-08-17. | 2022-04-25 10:14:29.621
CL-202206-NYMEX [C] 2 Day #3 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-06-18. | 2022-04-25 10:14:29.625
CL-202206-NYMEX [C] 2 Day #3 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-07-16. | 2022-04-25 10:14:29.625
CL-202206-NYMEX [C] 2 Day #3 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-05-18. | 2022-04-25 10:14:29.630
CL-202206-NYMEX [C] 2 Day #3 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-06-17. | 2022-04-25 10:14:29.630
CL-202206-NYMEX [C] 2 Day #3 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-04-17. | 2022-04-25 10:14:29.634
CL-202206-NYMEX [C] 2 Day #3 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-05-15. | 2022-04-25 10:14:29.634
CL-202206-NYMEX [C] 2 Day #3 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-03-18. | 2022-04-25 10:14:29.638
CL-202206-NYMEX [C] 2 Day #3 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-04-16. | 2022-04-25 10:14:29.638
CL-202206-NYMEX [C] 2 Day #3 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-02-18. | 2022-04-25 10:14:29.642
CL-202206-NYMEX [C] 2 Day #3 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-03-17. | 2022-04-25 10:14:29.642
CL-202206-NYMEX [C] 2 Day #3 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-01-17. | 2022-04-25 10:14:29.647
CL-202206-NYMEX [C] 2 Day #3 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-02-17. | 2022-04-25 10:14:29.647
CL-202206-NYMEX [C] 2 Day #3 | File CL-199202-NYMEX.dly has a volume of 0 at 1991-12-18. | 2022-04-25 10:14:29.651
CL-202206-NYMEX [C] 2 Day #3 | File CL-199202-NYMEX.dly has a volume of 0 at 1992-01-16. | 2022-04-25 10:14:29.651
CL-202206-NYMEX [C] 2 Day #3 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-11-18. | 2022-04-25 10:14:29.655
CL-202206-NYMEX [C] 2 Day #3 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-12-17. | 2022-04-25 10:14:29.655
CL-202206-NYMEX [C] 2 Day #3 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-10-18. | 2022-04-25 10:14:29.659
CL-202206-NYMEX [C] 2 Day #3 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-11-15. | 2022-04-25 10:14:29.659
CL-202206-NYMEX [C] 2 Day #3 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-09-18. | 2022-04-25 10:14:29.663
CL-202206-NYMEX [C] 2 Day #3 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-10-17. | 2022-04-25 10:14:29.663
CL-202206-NYMEX [C] 2 Day #3 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-08-16. | 2022-04-25 10:14:29.668
CL-202206-NYMEX [C] 2 Day #3 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-09-17. | 2022-04-25 10:14:29.668
CL-202206-NYMEX [C] 2 Day #3 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-07-18. | 2022-04-25 10:14:29.672
CL-202206-NYMEX [C] 2 Day #3 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-08-15. | 2022-04-25 10:14:29.672
CL-202206-NYMEX [C] 2 Day #3 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-06-18. | 2022-04-25 10:14:29.676
CL-202206-NYMEX [C] 2 Day #3 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-07-17. | 2022-04-25 10:14:29.676
CL-202206-NYMEX [C] 2 Day #3 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-05-17. | 2022-04-25 10:14:29.681
CL-202206-NYMEX [C] 2 Day #3 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-06-17. | 2022-04-25 10:14:29.681
CL-202206-NYMEX [C] 2 Day #3 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-04-18. | 2022-04-25 10:14:29.685
CL-202206-NYMEX [C] 2 Day #3 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-05-16. | 2022-04-25 10:14:29.685
CL-202206-NYMEX [C] 2 Day #3 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-03-18. | 2022-04-25 10:14:29.689
CL-202206-NYMEX [C] 2 Day #3 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-04-17. | 2022-04-25 10:14:29.689
CL-202206-NYMEX [C] 2 Day #3 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-02-18. | 2022-04-25 10:14:29.693
CL-202206-NYMEX [C] 2 Day #3 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-03-15. | 2022-04-25 10:14:29.693
CL-202206-NYMEX [C] 2 Day #3 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-01-18. | 2022-04-25 10:14:29.698
CL-202206-NYMEX [C] 2 Day #3 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-02-15. | 2022-04-25 10:14:29.698
CL-202206-NYMEX [C] 2 Day #3 | File CL-199102-NYMEX.dly has a volume of 0 at 1990-12-18. | 2022-04-25 10:14:29.702
CL-202206-NYMEX [C] 2 Day #3 | File CL-199102-NYMEX.dly has a volume of 0 at 1991-01-17. | 2022-04-25 10:14:29.702
CL-202206-NYMEX [C] 2 Day #3 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-11-16. | 2022-04-25 10:14:29.706
CL-202206-NYMEX [C] 2 Day #3 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-12-17. | 2022-04-25 10:14:29.706
CL-202206-NYMEX [C] 2 Day #3 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-10-18. | 2022-04-25 10:14:29.710
CL-202206-NYMEX [C] 2 Day #3 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-11-15. | 2022-04-25 10:14:29.710
CL-202206-NYMEX [C] 2 Day #3 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-09-18. | 2022-04-25 10:14:29.714
CL-202206-NYMEX [C] 2 Day #3 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-10-17. | 2022-04-25 10:14:29.714
CL-202206-NYMEX [C] 2 Day #3 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-08-17. | 2022-04-25 10:14:29.719
CL-202206-NYMEX [C] 2 Day #3 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-09-17. | 2022-04-25 10:14:29.719
CL-202206-NYMEX [C] 2 Day #3 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-07-18. | 2022-04-25 10:14:29.723
CL-202206-NYMEX [C] 2 Day #3 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-08-16. | 2022-04-25 10:14:29.723
CL-202206-NYMEX [C] 2 Day #3 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-06-18. | 2022-04-25 10:14:29.727
CL-202206-NYMEX [C] 2 Day #3 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-07-17. | 2022-04-25 10:14:29.727
CL-202206-NYMEX [C] 2 Day #3 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-05-18. | 2022-04-25 10:14:29.731
CL-202206-NYMEX [C] 2 Day #3 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-06-15. | 2022-04-25 10:14:29.731
CL-202206-NYMEX [C] 2 Day #3 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-04-18. | 2022-04-25 10:14:29.736
CL-202206-NYMEX [C] 2 Day #3 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-05-17. | 2022-04-25 10:14:29.736
CL-202206-NYMEX [C] 2 Day #3 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-03-16. | 2022-04-25 10:14:29.740
CL-202206-NYMEX [C] 2 Day #3 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-04-17. | 2022-04-25 10:14:29.740
CL-202206-NYMEX [C] 2 Day #3 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-02-16. | 2022-04-25 10:14:29.744
CL-202206-NYMEX [C] 2 Day #3 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-03-15. | 2022-04-25 10:14:29.744
CL-202206-NYMEX [C] 2 Day #3 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-01-18. | 2022-04-25 10:14:29.748
CL-202206-NYMEX [C] 2 Day #3 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-02-15. | 2022-04-25 10:14:29.748
CL-202206-NYMEX [C] 2 Day #3 | File CL-199002-NYMEX.dly has a volume of 0 at 1989-12-18. | 2022-04-25 10:14:29.753
CL-202206-NYMEX [C] 2 Day #3 | File CL-199002-NYMEX.dly has a volume of 0 at 1990-01-17. | 2022-04-25 10:14:29.753
CL-202206-NYMEX [C] 2 Day #3 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-11-17. | 2022-04-25 10:14:29.757
CL-202206-NYMEX [C] 2 Day #3 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-12-15. | 2022-04-25 10:14:29.757
CL-202206-NYMEX [C] 2 Day #3 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-10-18. | 2022-04-25 10:14:29.761
CL-202206-NYMEX [C] 2 Day #3 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-11-16. | 2022-04-25 10:14:29.761
CL-202206-NYMEX [C] 2 Day #3 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-09-18. | 2022-04-25 10:14:29.766
CL-202206-NYMEX [C] 2 Day #3 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-10-17. | 2022-04-25 10:14:29.766
CL-202206-NYMEX [C] 2 Day #3 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-08-18. | 2022-04-25 10:14:29.770
CL-202206-NYMEX [C] 2 Day #3 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-09-15. | 2022-04-25 10:14:29.770
CL-202206-NYMEX [C] 2 Day #3 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-07-18. | 2022-04-25 10:14:29.775
CL-202206-NYMEX [C] 2 Day #3 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-08-17. | 2022-04-25 10:14:29.775
CL-202206-NYMEX [C] 2 Day #3 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-06-16. | 2022-04-25 10:14:29.779
CL-202206-NYMEX [C] 2 Day #3 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-07-17. | 2022-04-25 10:14:29.779
CL-202206-NYMEX [C] 2 Day #3 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-05-18. | 2022-04-25 10:14:29.783
CL-202206-NYMEX [C] 2 Day #3 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-06-15. | 2022-04-25 10:14:29.783
CL-202206-NYMEX [C] 2 Day #3 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-04-18. | 2022-04-25 10:14:29.788
CL-202206-NYMEX [C] 2 Day #3 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-05-17. | 2022-04-25 10:14:29.788
CL-202206-NYMEX [C] 2 Day #3 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-03-17. | 2022-04-25 10:14:29.792
CL-202206-NYMEX [C] 2 Day #3 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-04-17. | 2022-04-25 10:14:29.792
CL-202206-NYMEX [C] 2 Day #3 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-02-17. | 2022-04-25 10:14:29.796
CL-202206-NYMEX [C] 2 Day #3 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-03-16. | 2022-04-25 10:14:29.796
CL-202206-NYMEX [C] 2 Day #3 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-01-18. | 2022-04-25 10:14:29.800
CL-202206-NYMEX [C] 2 Day #3 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-02-16. | 2022-04-25 10:14:29.800
CL-202206-NYMEX [C] 2 Day #3 | File CL-198902-NYMEX.dly has a volume of 0 at 1988-12-16. | 2022-04-25 10:14:29.805
CL-202206-NYMEX [C] 2 Day #3 | File CL-198902-NYMEX.dly has a volume of 0 at 1989-01-17. | 2022-04-25 10:14:29.805
CL-202206-NYMEX [C] 2 Day #3 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-11-18. | 2022-04-25 10:14:29.809
CL-202206-NYMEX [C] 2 Day #3 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-12-15. | 2022-04-25 10:14:29.809
CL-202206-NYMEX [C] 2 Day #3 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-10-18. | 2022-04-25 10:14:29.813
CL-202206-NYMEX [C] 2 Day #3 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-11-17. | 2022-04-25 10:14:29.813
CL-202206-NYMEX [C] 2 Day #3 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-09-16. | 2022-04-25 10:14:29.817
CL-202206-NYMEX [C] 2 Day #3 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-10-17. | 2022-04-25 10:14:29.817
CL-202206-NYMEX [C] 2 Day #3 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-08-18. | 2022-04-25 10:14:29.822
CL-202206-NYMEX [C] 2 Day #3 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-09-15. | 2022-04-25 10:14:29.822
CL-202206-NYMEX [C] 2 Day #3 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-07-18. | 2022-04-25 10:14:29.826
CL-202206-NYMEX [C] 2 Day #3 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-08-17. | 2022-04-25 10:14:29.826
CL-202206-NYMEX [C] 2 Day #3 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-06-17. | 2022-04-25 10:14:29.830
CL-202206-NYMEX [C] 2 Day #3 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-07-15. | 2022-04-25 10:14:29.830
CL-202206-NYMEX [C] 2 Day #3 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-05-18. | 2022-04-25 10:14:29.835
CL-202206-NYMEX [C] 2 Day #3 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-06-16. | 2022-04-25 10:14:29.835
CL-202206-NYMEX [C] 2 Day #3 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-04-18. | 2022-04-25 10:14:29.839
CL-202206-NYMEX [C] 2 Day #3 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-05-17. | 2022-04-25 10:14:29.839
CL-202206-NYMEX [C] 2 Day #3 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-03-18. | 2022-04-25 10:14:29.843
CL-202206-NYMEX [C] 2 Day #3 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-04-15. | 2022-04-25 10:14:29.843
CL-202206-NYMEX [C] 2 Day #3 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-02-18. | 2022-04-25 10:14:29.848
CL-202206-NYMEX [C] 2 Day #3 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-03-17. | 2022-04-25 10:14:29.848
CL-202206-NYMEX [C] 2 Day #3 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-01-18. | 2022-04-25 10:14:29.852
CL-202206-NYMEX [C] 2 Day #3 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-02-17. | 2022-04-25 10:14:29.852
CL-202206-NYMEX [C] 2 Day #3 | File CL-198802-NYMEX.dly has a volume of 0 at 1987-12-18. | 2022-04-25 10:14:29.856
CL-202206-NYMEX [C] 2 Day #3 | File CL-198802-NYMEX.dly has a volume of 0 at 1988-01-15. | 2022-04-25 10:14:29.856
CL-202206-NYMEX [C] 2 Day #3 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-11-18. | 2022-04-25 10:14:29.860
CL-202206-NYMEX [C] 2 Day #3 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-12-17. | 2022-04-25 10:14:29.860
CL-202206-NYMEX [C] 2 Day #3 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-10-16. | 2022-04-25 10:14:29.865
CL-202206-NYMEX [C] 2 Day #3 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-11-17. | 2022-04-25 10:14:29.865
CL-202206-NYMEX [C] 2 Day #3 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-09-18. | 2022-04-25 10:14:29.869
CL-202206-NYMEX [C] 2 Day #3 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-10-15. | 2022-04-25 10:14:29.869
CL-202206-NYMEX [C] 2 Day #3 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-08-18. | 2022-04-25 10:14:29.873
CL-202206-NYMEX [C] 2 Day #3 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-09-17. | 2022-04-25 10:14:29.873
CL-202206-NYMEX [C] 2 Day #3 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-07-17. | 2022-04-25 10:14:29.878
CL-202206-NYMEX [C] 2 Day #3 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-08-17. | 2022-04-25 10:14:29.878
CL-202206-NYMEX [C] 2 Day #3 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-06-18. | 2022-04-25 10:14:29.882
CL-202206-NYMEX [C] 2 Day #3 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-07-16. | 2022-04-25 10:14:29.882
CL-202206-NYMEX [C] 2 Day #3 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-05-18. | 2022-04-25 10:14:29.887
CL-202206-NYMEX [C] 2 Day #3 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-06-17. | 2022-04-25 10:14:29.887
CL-202206-NYMEX [C] 2 Day #3 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-04-17. | 2022-04-25 10:14:29.891
CL-202206-NYMEX [C] 2 Day #3 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-05-15. | 2022-04-25 10:14:29.891
CL-202206-NYMEX [C] 2 Day #3 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-03-18. | 2022-04-25 10:14:29.895
CL-202206-NYMEX [C] 2 Day #3 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-04-16. | 2022-04-25 10:14:29.895
CL-202206-NYMEX [C] 2 Day #3 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-02-18. | 2022-04-25 10:14:29.899
CL-202206-NYMEX [C] 2 Day #3 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-03-17. | 2022-04-25 10:14:29.899
CL-202206-NYMEX [C] 2 Day #3 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-01-16. | 2022-04-25 10:14:29.904
CL-202206-NYMEX [C] 2 Day #3 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-02-17. | 2022-04-25 10:14:29.904
CL-202206-NYMEX [C] 2 Day #3 | File CL-198702-NYMEX.dly has a volume of 0 at 1986-12-18. | 2022-04-25 10:14:29.908
CL-202206-NYMEX [C] 2 Day #3 | File CL-198702-NYMEX.dly has a volume of 0 at 1987-01-15. | 2022-04-25 10:14:29.908
CL-202206-NYMEX [C] 2 Day #3 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-11-18. | 2022-04-25 10:14:29.912
CL-202206-NYMEX [C] 2 Day #3 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-12-17. | 2022-04-25 10:14:29.912
CL-202206-NYMEX [C] 2 Day #3 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-10-17. | 2022-04-25 10:14:29.917
CL-202206-NYMEX [C] 2 Day #3 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-11-17. | 2022-04-25 10:14:29.917
CL-202206-NYMEX [C] 2 Day #3 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-09-18. | 2022-04-25 10:14:29.921
CL-202206-NYMEX [C] 2 Day #3 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-10-16. | 2022-04-25 10:14:29.921
CL-202206-NYMEX [C] 2 Day #3 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-08-18. | 2022-04-25 10:14:29.925
CL-202206-NYMEX [C] 2 Day #3 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-09-17. | 2022-04-25 10:14:29.925
CL-202206-NYMEX [C] 2 Day #3 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-07-18. | 2022-04-25 10:14:29.930
CL-202206-NYMEX [C] 2 Day #3 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-08-15. | 2022-04-25 10:14:29.930
CL-202206-NYMEX [C] 2 Day #3 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-06-18. | 2022-04-25 10:14:29.934
CL-202206-NYMEX [C] 2 Day #3 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-07-17. | 2022-04-25 10:14:29.934
CL-202206-NYMEX [C] 2 Day #3 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-05-16. | 2022-04-25 10:14:29.938
CL-202206-NYMEX [C] 2 Day #3 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-06-17. | 2022-04-25 10:14:29.938
CL-202206-NYMEX [C] 2 Day #3 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-04-18. | 2022-04-25 10:14:29.942
CL-202206-NYMEX [C] 2 Day #3 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-05-15. | 2022-04-25 10:14:29.942
CL-202206-NYMEX [C] 2 Day #3 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-03-18. | 2022-04-25 10:14:29.947
CL-202206-NYMEX [C] 2 Day #3 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-04-17. | 2022-04-25 10:14:29.947
CL-202206-NYMEX [C] 2 Day #3 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-02-18. | 2022-04-25 10:14:29.951
CL-202206-NYMEX [C] 2 Day #3 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-03-17. | 2022-04-25 10:14:29.951
CL-202206-NYMEX [C] 2 Day #3 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-01-17. | 2022-04-25 10:14:29.955
CL-202206-NYMEX [C] 2 Day #3 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-02-17. | 2022-04-25 10:14:29.955
CL-202206-NYMEX [C] 2 Day #3 | File CL-198602-NYMEX.dly has a volume of 0 at 1985-12-18. | 2022-04-25 10:14:29.959
CL-202206-NYMEX [C] 2 Day #3 | File CL-198602-NYMEX.dly has a volume of 0 at 1986-01-16. | 2022-04-25 10:14:29.959
CL-202206-NYMEX [C] 2 Day #3 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-11-18. | 2022-04-25 10:14:29.964
CL-202206-NYMEX [C] 2 Day #3 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-12-17. | 2022-04-25 10:14:29.964
CL-202206-NYMEX [C] 2 Day #3 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-10-18. | 2022-04-25 10:14:29.968
CL-202206-NYMEX [C] 2 Day #3 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-11-15. | 2022-04-25 10:14:29.968
CL-202206-NYMEX [C] 2 Day #3 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-09-18. | 2022-04-25 10:14:29.972
CL-202206-NYMEX [C] 2 Day #3 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-10-17. | 2022-04-25 10:14:29.972
CL-202206-NYMEX [C] 2 Day #3 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-08-16. | 2022-04-25 10:14:29.977
CL-202206-NYMEX [C] 2 Day #3 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-09-17. | 2022-04-25 10:14:29.977
CL-202206-NYMEX [C] 2 Day #3 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-07-18. | 2022-04-25 10:14:29.981
CL-202206-NYMEX [C] 2 Day #3 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-08-15. | 2022-04-25 10:14:29.981
CL-202206-NYMEX [C] 2 Day #3 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-06-18. | 2022-04-25 10:14:29.985
CL-202206-NYMEX [C] 2 Day #3 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-07-17. | 2022-04-25 10:14:29.985
CL-202206-NYMEX [C] 2 Day #3 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-05-17. | 2022-04-25 10:14:29.989
CL-202206-NYMEX [C] 2 Day #3 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-06-17. | 2022-04-25 10:14:29.989
CL-202206-NYMEX [C] 2 Day #3 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-04-18. | 2022-04-25 10:14:29.994
CL-202206-NYMEX [C] 2 Day #3 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-05-16. | 2022-04-25 10:14:29.994
CL-202206-NYMEX [C] 2 Day #3 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-03-18. | 2022-04-25 10:14:29.998
CL-202206-NYMEX [C] 2 Day #3 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-04-17. | 2022-04-25 10:14:29.998
CL-202206-NYMEX [C] 2 Day #3 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-02-18. | 2022-04-25 10:14:30.002
CL-202206-NYMEX [C] 2 Day #3 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-03-15. | 2022-04-25 10:14:30.002
CL-202206-NYMEX [C] 2 Day #3 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-01-18. | 2022-04-25 10:14:30.006
CL-202206-NYMEX [C] 2 Day #3 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-02-15. | 2022-04-25 10:14:30.006
CL-202206-NYMEX [C] 2 Day #3 | File CL-198502-NYMEX.dly has a volume of 0 at 1984-12-18. | 2022-04-25 10:14:30.010
CL-202206-NYMEX [C] 2 Day #3 | File CL-198502-NYMEX.dly has a volume of 0 at 1985-01-17. | 2022-04-25 10:14:30.010
CL-202206-NYMEX [C] 2 Day #3 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-11-16. | 2022-04-25 10:14:30.014
CL-202206-NYMEX [C] 2 Day #3 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-12-17. | 2022-04-25 10:14:30.014
CL-202206-NYMEX [C] 2 Day #3 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-10-18. | 2022-04-25 10:14:30.017
CL-202206-NYMEX [C] 2 Day #3 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-11-15. | 2022-04-25 10:14:30.017
CL-202206-NYMEX [C] 2 Day #3 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-09-18. | 2022-04-25 10:14:30.021
CL-202206-NYMEX [C] 2 Day #3 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-10-17. | 2022-04-25 10:14:30.021
CL-202206-NYMEX [C] 2 Day #3 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-08-17. | 2022-04-25 10:14:30.025
CL-202206-NYMEX [C] 2 Day #3 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-09-17. | 2022-04-25 10:14:30.025
CL-202206-NYMEX [C] 2 Day #3 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-07-18. | 2022-04-25 10:14:30.029
CL-202206-NYMEX [C] 2 Day #3 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-08-16. | 2022-04-25 10:14:30.029
CL-202206-NYMEX [C] 2 Day #3 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-06-18. | 2022-04-25 10:14:30.034
CL-202206-NYMEX [C] 2 Day #3 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-07-17. | 2022-04-25 10:14:30.034
CL-202206-NYMEX [C] 2 Day #3 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-05-18. | 2022-04-25 10:14:30.038
CL-202206-NYMEX [C] 2 Day #3 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-06-15. | 2022-04-25 10:14:30.038
CL-202206-NYMEX [C] 2 Day #3 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-04-18. | 2022-04-25 10:14:30.042
CL-202206-NYMEX [C] 2 Day #3 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-05-17. | 2022-04-25 10:14:30.042
CL-202206-NYMEX [C] 2 Day #3 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-03-16. | 2022-04-25 10:14:30.046
CL-202206-NYMEX [C] 2 Day #3 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-04-17. | 2022-04-25 10:14:30.046
CL-202206-NYMEX [C] 2 Day #3 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-02-17. | 2022-04-25 10:14:30.050
CL-202206-NYMEX [C] 2 Day #3 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-03-15. | 2022-04-25 10:14:30.050
CL-202206-NYMEX [C] 2 Day #3 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-01-18. | 2022-04-25 10:14:30.054
CL-202206-NYMEX [C] 2 Day #3 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-02-16. | 2022-04-25 10:14:30.054
CL-202206-NYMEX [C] 2 Day #3 | File CL-198402-NYMEX.dly has a volume of 0 at 1983-12-16. | 2022-04-25 10:14:30.058
CL-202206-NYMEX [C] 2 Day #3 | File CL-198402-NYMEX.dly has a volume of 0 at 1984-01-17. | 2022-04-25 10:14:30.058
CL-202206-NYMEX [C] 2 Day #3 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-11-18. | 2022-04-25 10:14:30.062
CL-202206-NYMEX [C] 2 Day #3 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-12-15. | 2022-04-25 10:14:30.062
CL-202206-NYMEX [C] 2 Day #3 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-10-18. | 2022-04-25 10:14:30.066
CL-202206-NYMEX [C] 2 Day #3 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-11-17. | 2022-04-25 10:14:30.066
CL-202206-NYMEX [C] 2 Day #3 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-09-16. | 2022-04-25 10:14:30.070
CL-202206-NYMEX [C] 2 Day #3 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-10-17. | 2022-04-25 10:14:30.070
CL-202206-NYMEX [C] 2 Day #3 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-08-18. | 2022-04-25 10:14:30.074
CL-202206-NYMEX [C] 2 Day #3 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-09-15. | 2022-04-25 10:14:30.074
CL-202206-NYMEX [C] 2 Day #3 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-07-18. | 2022-04-25 10:14:30.079
CL-202206-NYMEX [C] 2 Day #3 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-08-17. | 2022-04-25 10:14:30.079
CL-202206-NYMEX [C] 2 Day #3 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-06-17. | 2022-04-25 10:14:30.083
CL-202206-NYMEX [C] 2 Day #3 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-07-15. | 2022-04-25 10:14:30.083
CL-202206-NYMEX [C] 2 Day #3 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-05-18. | 2022-04-25 10:14:30.087
CL-202206-NYMEX [C] 2 Day #3 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-06-16. | 2022-04-25 10:14:30.087
CL-202206-NYMEX [C] 2 Day #3 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-04-18. | 2022-04-25 10:14:30.091
CL-202206-NYMEX [C] 2 Day #3 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-05-17. | 2022-04-25 10:14:30.091
CL-202206-NYMEX [C] 2 Day #3 | Waiting for historical downloads to complete with the IDs: 23, 24, | 2022-04-25 10:14:30.189
CL-202206-NYMEX [C] 2 Day #6 | Reloading chart. | 2022-04-25 10:14:30.201
CL-202206-NYMEX [C] 2 Day #6 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:30.201
CL-202206-NYMEX [C] 2 Day #6 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:30.201
CL-202206-NYMEX [C] 2 Day #6 | File CL-200102-NYMEX.dly has a volume of 0 at 2000-12-18. | 2022-04-25 10:14:31.936
CL-202206-NYMEX [C] 2 Day #6 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-11-17. | 2022-04-25 10:14:31.940
CL-202206-NYMEX [C] 2 Day #6 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-12-15. | 2022-04-25 10:14:31.940
CL-202206-NYMEX [C] 2 Day #6 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-10-18. | 2022-04-25 10:14:31.945
CL-202206-NYMEX [C] 2 Day #6 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-11-16. | 2022-04-25 10:14:31.945
CL-202206-NYMEX [C] 2 Day #6 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-09-18. | 2022-04-25 10:14:31.949
CL-202206-NYMEX [C] 2 Day #6 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-10-17. | 2022-04-25 10:14:31.949
CL-202206-NYMEX [C] 2 Day #6 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-08-18. | 2022-04-25 10:14:31.953
CL-202206-NYMEX [C] 2 Day #6 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-09-15. | 2022-04-25 10:14:31.953
CL-202206-NYMEX [C] 2 Day #6 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-07-18. | 2022-04-25 10:14:31.958
CL-202206-NYMEX [C] 2 Day #6 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-08-17. | 2022-04-25 10:14:31.958
CL-202206-NYMEX [C] 2 Day #6 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-06-16. | 2022-04-25 10:14:31.962
CL-202206-NYMEX [C] 2 Day #6 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-07-17. | 2022-04-25 10:14:31.962
CL-202206-NYMEX [C] 2 Day #6 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-05-18. | 2022-04-25 10:14:31.966
CL-202206-NYMEX [C] 2 Day #6 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-06-15. | 2022-04-25 10:14:31.966
CL-202206-NYMEX [C] 2 Day #6 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-04-18. | 2022-04-25 10:14:31.971
CL-202206-NYMEX [C] 2 Day #6 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-05-17. | 2022-04-25 10:14:31.971
CL-202206-NYMEX [C] 2 Day #6 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-03-17. | 2022-04-25 10:14:31.975
CL-202206-NYMEX [C] 2 Day #6 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-04-17. | 2022-04-25 10:14:31.975
CL-202206-NYMEX [C] 2 Day #6 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-02-18. | 2022-04-25 10:14:31.979
CL-202206-NYMEX [C] 2 Day #6 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-03-16. | 2022-04-25 10:14:31.979
CL-202206-NYMEX [C] 2 Day #6 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-01-18. | 2022-04-25 10:14:31.983
CL-202206-NYMEX [C] 2 Day #6 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-02-17. | 2022-04-25 10:14:31.983
CL-202206-NYMEX [C] 2 Day #6 | File CL-200002-NYMEX.dly has a volume of 0 at 1999-12-17. | 2022-04-25 10:14:31.987
CL-202206-NYMEX [C] 2 Day #6 | File CL-200002-NYMEX.dly has a volume of 0 at 2000-01-17. | 2022-04-25 10:14:31.987
CL-202206-NYMEX [C] 2 Day #6 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-11-18. | 2022-04-25 10:14:31.991
CL-202206-NYMEX [C] 2 Day #6 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-12-16. | 2022-04-25 10:14:31.991
CL-202206-NYMEX [C] 2 Day #6 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-10-18. | 2022-04-25 10:14:31.996
CL-202206-NYMEX [C] 2 Day #6 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-11-17. | 2022-04-25 10:14:31.996
CL-202206-NYMEX [C] 2 Day #6 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-09-17. | 2022-04-25 10:14:32.000
CL-202206-NYMEX [C] 2 Day #6 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-10-15. | 2022-04-25 10:14:32.000
CL-202206-NYMEX [C] 2 Day #6 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-08-18. | 2022-04-25 10:14:32.005
CL-202206-NYMEX [C] 2 Day #6 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-09-16. | 2022-04-25 10:14:32.005
CL-202206-NYMEX [C] 2 Day #6 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-07-16. | 2022-04-25 10:14:32.010
CL-202206-NYMEX [C] 2 Day #6 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-08-17. | 2022-04-25 10:14:32.010
CL-202206-NYMEX [C] 2 Day #6 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-06-18. | 2022-04-25 10:14:32.014
CL-202206-NYMEX [C] 2 Day #6 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-07-15. | 2022-04-25 10:14:32.014
CL-202206-NYMEX [C] 2 Day #6 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-05-18. | 2022-04-25 10:14:32.018
CL-202206-NYMEX [C] 2 Day #6 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-06-17. | 2022-04-25 10:14:32.018
CL-202206-NYMEX [C] 2 Day #6 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-04-16. | 2022-04-25 10:14:32.022
CL-202206-NYMEX [C] 2 Day #6 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-05-17. | 2022-04-25 10:14:32.022
CL-202206-NYMEX [C] 2 Day #6 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-03-18. | 2022-04-25 10:14:32.027
CL-202206-NYMEX [C] 2 Day #6 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-04-15. | 2022-04-25 10:14:32.027
CL-202206-NYMEX [C] 2 Day #6 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-02-18. | 2022-04-25 10:14:32.031
CL-202206-NYMEX [C] 2 Day #6 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-03-17. | 2022-04-25 10:14:32.031
CL-202206-NYMEX [C] 2 Day #6 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-01-18. | 2022-04-25 10:14:32.035
CL-202206-NYMEX [C] 2 Day #6 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-02-17. | 2022-04-25 10:14:32.035
CL-202206-NYMEX [C] 2 Day #6 | File CL-199902-NYMEX.dly has a volume of 0 at 1998-12-18. | 2022-04-25 10:14:32.039
CL-202206-NYMEX [C] 2 Day #6 | File CL-199902-NYMEX.dly has a volume of 0 at 1999-01-15. | 2022-04-25 10:14:32.039
CL-202206-NYMEX [C] 2 Day #6 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-11-18. | 2022-04-25 10:14:32.043
CL-202206-NYMEX [C] 2 Day #6 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-12-17. | 2022-04-25 10:14:32.043
CL-202206-NYMEX [C] 2 Day #6 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-10-16. | 2022-04-25 10:14:32.048
CL-202206-NYMEX [C] 2 Day #6 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-11-17. | 2022-04-25 10:14:32.048
CL-202206-NYMEX [C] 2 Day #6 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-09-18. | 2022-04-25 10:14:32.053
CL-202206-NYMEX [C] 2 Day #6 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-10-15. | 2022-04-25 10:14:32.053
CL-202206-NYMEX [C] 2 Day #6 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-08-18. | 2022-04-25 10:14:32.057
CL-202206-NYMEX [C] 2 Day #6 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-09-17. | 2022-04-25 10:14:32.057
CL-202206-NYMEX [C] 2 Day #6 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-07-17. | 2022-04-25 10:14:32.061
CL-202206-NYMEX [C] 2 Day #6 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-08-17. | 2022-04-25 10:14:32.061
CL-202206-NYMEX [C] 2 Day #6 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-06-18. | 2022-04-25 10:14:32.066
CL-202206-NYMEX [C] 2 Day #6 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-07-16. | 2022-04-25 10:14:32.066
CL-202206-NYMEX [C] 2 Day #6 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-05-18. | 2022-04-25 10:14:32.070
CL-202206-NYMEX [C] 2 Day #6 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-06-17. | 2022-04-25 10:14:32.070
CL-202206-NYMEX [C] 2 Day #6 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-04-17. | 2022-04-25 10:14:32.074
CL-202206-NYMEX [C] 2 Day #6 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-05-15. | 2022-04-25 10:14:32.074
CL-202206-NYMEX [C] 2 Day #6 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-03-18. | 2022-04-25 10:14:32.078
CL-202206-NYMEX [C] 2 Day #6 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-04-16. | 2022-04-25 10:14:32.078
CL-202206-NYMEX [C] 2 Day #6 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-02-18. | 2022-04-25 10:14:32.083
CL-202206-NYMEX [C] 2 Day #6 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-03-17. | 2022-04-25 10:14:32.083
CL-202206-NYMEX [C] 2 Day #6 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-01-16. | 2022-04-25 10:14:32.087
CL-202206-NYMEX [C] 2 Day #6 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-02-17. | 2022-04-25 10:14:32.087
CL-202206-NYMEX [C] 2 Day #6 | File CL-199802-NYMEX.dly has a volume of 0 at 1997-12-18. | 2022-04-25 10:14:32.091
CL-202206-NYMEX [C] 2 Day #6 | File CL-199802-NYMEX.dly has a volume of 0 at 1998-01-15. | 2022-04-25 10:14:32.091
CL-202206-NYMEX [C] 2 Day #6 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-11-18. | 2022-04-25 10:14:32.095
CL-202206-NYMEX [C] 2 Day #6 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-12-17. | 2022-04-25 10:14:32.095
CL-202206-NYMEX [C] 2 Day #6 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-10-17. | 2022-04-25 10:14:32.100
CL-202206-NYMEX [C] 2 Day #6 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-11-17. | 2022-04-25 10:14:32.100
CL-202206-NYMEX [C] 2 Day #6 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-09-18. | 2022-04-25 10:14:32.104
CL-202206-NYMEX [C] 2 Day #6 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-10-16. | 2022-04-25 10:14:32.104
CL-202206-NYMEX [C] 2 Day #6 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-08-18. | 2022-04-25 10:14:32.109
CL-202206-NYMEX [C] 2 Day #6 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-09-17. | 2022-04-25 10:14:32.109
CL-202206-NYMEX [C] 2 Day #6 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-07-18. | 2022-04-25 10:14:32.113
CL-202206-NYMEX [C] 2 Day #6 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-08-15. | 2022-04-25 10:14:32.113
CL-202206-NYMEX [C] 2 Day #6 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-06-18. | 2022-04-25 10:14:32.117
CL-202206-NYMEX [C] 2 Day #6 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-07-17. | 2022-04-25 10:14:32.117
CL-202206-NYMEX [C] 2 Day #6 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-05-16. | 2022-04-25 10:14:32.121
CL-202206-NYMEX [C] 2 Day #6 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-06-17. | 2022-04-25 10:14:32.121
CL-202206-NYMEX [C] 2 Day #6 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-04-18. | 2022-04-25 10:14:32.126
CL-202206-NYMEX [C] 2 Day #6 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-05-15. | 2022-04-25 10:14:32.126
CL-202206-NYMEX [C] 2 Day #6 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-03-18. | 2022-04-25 10:14:32.130
CL-202206-NYMEX [C] 2 Day #6 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-04-17. | 2022-04-25 10:14:32.130
CL-202206-NYMEX [C] 2 Day #6 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-02-18. | 2022-04-25 10:14:32.134
CL-202206-NYMEX [C] 2 Day #6 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-03-17. | 2022-04-25 10:14:32.134
CL-202206-NYMEX [C] 2 Day #6 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-01-17. | 2022-04-25 10:14:32.138
CL-202206-NYMEX [C] 2 Day #6 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-02-17. | 2022-04-25 10:14:32.138
CL-202206-NYMEX [C] 2 Day #6 | File CL-199702-NYMEX.dly has a volume of 0 at 1996-12-18. | 2022-04-25 10:14:32.143
CL-202206-NYMEX [C] 2 Day #6 | File CL-199702-NYMEX.dly has a volume of 0 at 1997-01-16. | 2022-04-25 10:14:32.143
CL-202206-NYMEX [C] 2 Day #6 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-11-18. | 2022-04-25 10:14:32.147
CL-202206-NYMEX [C] 2 Day #6 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-12-17. | 2022-04-25 10:14:32.147
CL-202206-NYMEX [C] 2 Day #6 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-10-18. | 2022-04-25 10:14:32.151
CL-202206-NYMEX [C] 2 Day #6 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-11-15. | 2022-04-25 10:14:32.151
CL-202206-NYMEX [C] 2 Day #6 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-09-18. | 2022-04-25 10:14:32.155
CL-202206-NYMEX [C] 2 Day #6 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-10-17. | 2022-04-25 10:14:32.155
CL-202206-NYMEX [C] 2 Day #6 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-08-16. | 2022-04-25 10:14:32.160
CL-202206-NYMEX [C] 2 Day #6 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-09-17. | 2022-04-25 10:14:32.160
CL-202206-NYMEX [C] 2 Day #6 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-07-18. | 2022-04-25 10:14:32.164
CL-202206-NYMEX [C] 2 Day #6 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-08-15. | 2022-04-25 10:14:32.164
CL-202206-NYMEX [C] 2 Day #6 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-06-18. | 2022-04-25 10:14:32.168
CL-202206-NYMEX [C] 2 Day #6 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-07-17. | 2022-04-25 10:14:32.168
CL-202206-NYMEX [C] 2 Day #6 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-05-17. | 2022-04-25 10:14:32.173
CL-202206-NYMEX [C] 2 Day #6 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-06-17. | 2022-04-25 10:14:32.173
CL-202206-NYMEX [C] 2 Day #6 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-04-18. | 2022-04-25 10:14:32.177
CL-202206-NYMEX [C] 2 Day #6 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-05-16. | 2022-04-25 10:14:32.177
CL-202206-NYMEX [C] 2 Day #6 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-03-18. | 2022-04-25 10:14:32.182
CL-202206-NYMEX [C] 2 Day #6 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-04-17. | 2022-04-25 10:14:32.182
CL-202206-NYMEX [C] 2 Day #6 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-02-16. | 2022-04-25 10:14:32.186
CL-202206-NYMEX [C] 2 Day #6 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-03-15. | 2022-04-25 10:14:32.186
CL-202206-NYMEX [C] 2 Day #6 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-01-18. | 2022-04-25 10:14:32.190
CL-202206-NYMEX [C] 2 Day #6 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-02-15. | 2022-04-25 10:14:32.190
CL-202206-NYMEX [C] 2 Day #6 | File CL-199602-NYMEX.dly has a volume of 0 at 1995-12-18. | 2022-04-25 10:14:32.195
CL-202206-NYMEX [C] 2 Day #6 | File CL-199602-NYMEX.dly has a volume of 0 at 1996-01-17. | 2022-04-25 10:14:32.195
CL-202206-NYMEX [C] 2 Day #6 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-11-17. | 2022-04-25 10:14:32.199
CL-202206-NYMEX [C] 2 Day #6 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-12-15. | 2022-04-25 10:14:32.199
CL-202206-NYMEX [C] 2 Day #6 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-10-18. | 2022-04-25 10:14:32.203
CL-202206-NYMEX [C] 2 Day #6 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-11-16. | 2022-04-25 10:14:32.203
CL-202206-NYMEX [C] 2 Day #6 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-09-18. | 2022-04-25 10:14:32.207
CL-202206-NYMEX [C] 2 Day #6 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-10-17. | 2022-04-25 10:14:32.207
CL-202206-NYMEX [C] 2 Day #6 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-08-18. | 2022-04-25 10:14:32.212
CL-202206-NYMEX [C] 2 Day #6 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-09-15. | 2022-04-25 10:14:32.212
CL-202206-NYMEX [C] 2 Day #6 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-07-18. | 2022-04-25 10:14:32.216
CL-202206-NYMEX [C] 2 Day #6 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-08-17. | 2022-04-25 10:14:32.216
CL-202206-NYMEX [C] 2 Day #6 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-06-16. | 2022-04-25 10:14:32.220
CL-202206-NYMEX [C] 2 Day #6 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-07-17. | 2022-04-25 10:14:32.220
CL-202206-NYMEX [C] 2 Day #6 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-05-18. | 2022-04-25 10:14:32.225
CL-202206-NYMEX [C] 2 Day #6 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-06-15. | 2022-04-25 10:14:32.225
CL-202206-NYMEX [C] 2 Day #6 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-04-18. | 2022-04-25 10:14:32.229
CL-202206-NYMEX [C] 2 Day #6 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-05-17. | 2022-04-25 10:14:32.229
CL-202206-NYMEX [C] 2 Day #6 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-03-17. | 2022-04-25 10:14:32.233
CL-202206-NYMEX [C] 2 Day #6 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-04-17. | 2022-04-25 10:14:32.233
CL-202206-NYMEX [C] 2 Day #6 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-02-17. | 2022-04-25 10:14:32.237
CL-202206-NYMEX [C] 2 Day #6 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-03-16. | 2022-04-25 10:14:32.237
CL-202206-NYMEX [C] 2 Day #6 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-01-18. | 2022-04-25 10:14:32.242
CL-202206-NYMEX [C] 2 Day #6 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-02-16. | 2022-04-25 10:14:32.242
CL-202206-NYMEX [C] 2 Day #6 | File CL-199502-NYMEX.dly has a volume of 0 at 1994-12-16. | 2022-04-25 10:14:32.246
CL-202206-NYMEX [C] 2 Day #6 | File CL-199502-NYMEX.dly has a volume of 0 at 1995-01-17. | 2022-04-25 10:14:32.246
CL-202206-NYMEX [C] 2 Day #6 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-11-18. | 2022-04-25 10:14:32.250
CL-202206-NYMEX [C] 2 Day #6 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-12-15. | 2022-04-25 10:14:32.250
CL-202206-NYMEX [C] 2 Day #6 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-10-18. | 2022-04-25 10:14:32.254
CL-202206-NYMEX [C] 2 Day #6 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-11-17. | 2022-04-25 10:14:32.254
CL-202206-NYMEX [C] 2 Day #6 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-09-16. | 2022-04-25 10:14:32.259
CL-202206-NYMEX [C] 2 Day #6 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-10-17. | 2022-04-25 10:14:32.259
CL-202206-NYMEX [C] 2 Day #6 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-08-18. | 2022-04-25 10:14:32.263
CL-202206-NYMEX [C] 2 Day #6 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-09-15. | 2022-04-25 10:14:32.263
CL-202206-NYMEX [C] 2 Day #6 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-07-18. | 2022-04-25 10:14:32.268
CL-202206-NYMEX [C] 2 Day #6 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-08-17. | 2022-04-25 10:14:32.268
CL-202206-NYMEX [C] 2 Day #6 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-06-17. | 2022-04-25 10:14:32.272
CL-202206-NYMEX [C] 2 Day #6 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-07-15. | 2022-04-25 10:14:32.272
CL-202206-NYMEX [C] 2 Day #6 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-05-18. | 2022-04-25 10:14:32.276
CL-202206-NYMEX [C] 2 Day #6 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-06-16. | 2022-04-25 10:14:32.276
CL-202206-NYMEX [C] 2 Day #6 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-04-18. | 2022-04-25 10:14:32.281
CL-202206-NYMEX [C] 2 Day #6 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-05-17. | 2022-04-25 10:14:32.281
CL-202206-NYMEX [C] 2 Day #6 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-03-18. | 2022-04-25 10:14:32.285
CL-202206-NYMEX [C] 2 Day #6 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-04-15. | 2022-04-25 10:14:32.285
CL-202206-NYMEX [C] 2 Day #6 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-02-18. | 2022-04-25 10:14:32.289
CL-202206-NYMEX [C] 2 Day #6 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-03-17. | 2022-04-25 10:14:32.289
CL-202206-NYMEX [C] 2 Day #6 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-01-18. | 2022-04-25 10:14:32.293
CL-202206-NYMEX [C] 2 Day #6 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-02-17. | 2022-04-25 10:14:32.293
CL-202206-NYMEX [C] 2 Day #6 | File CL-199402-NYMEX.dly has a volume of 0 at 1993-12-17. | 2022-04-25 10:14:32.298
CL-202206-NYMEX [C] 2 Day #6 | File CL-199402-NYMEX.dly has a volume of 0 at 1994-01-17. | 2022-04-25 10:14:32.298
CL-202206-NYMEX [C] 2 Day #6 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-11-18. | 2022-04-25 10:14:32.302
CL-202206-NYMEX [C] 2 Day #6 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-12-16. | 2022-04-25 10:14:32.302
CL-202206-NYMEX [C] 2 Day #6 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-10-18. | 2022-04-25 10:14:32.306
CL-202206-NYMEX [C] 2 Day #6 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-11-17. | 2022-04-25 10:14:32.306
CL-202206-NYMEX [C] 2 Day #6 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-09-17. | 2022-04-25 10:14:32.310
CL-202206-NYMEX [C] 2 Day #6 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-10-15. | 2022-04-25 10:14:32.310
CL-202206-NYMEX [C] 2 Day #6 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-08-18. | 2022-04-25 10:14:32.315
CL-202206-NYMEX [C] 2 Day #6 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-09-16. | 2022-04-25 10:14:32.315
CL-202206-NYMEX [C] 2 Day #6 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-07-16. | 2022-04-25 10:14:32.319
CL-202206-NYMEX [C] 2 Day #6 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-08-17. | 2022-04-25 10:14:32.319
CL-202206-NYMEX [C] 2 Day #6 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-06-18. | 2022-04-25 10:14:32.324
CL-202206-NYMEX [C] 2 Day #6 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-07-15. | 2022-04-25 10:14:32.324
CL-202206-NYMEX [C] 2 Day #6 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-05-18. | 2022-04-25 10:14:32.328
CL-202206-NYMEX [C] 2 Day #6 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-06-17. | 2022-04-25 10:14:32.328
CL-202206-NYMEX [C] 2 Day #6 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-04-16. | 2022-04-25 10:14:32.332
CL-202206-NYMEX [C] 2 Day #6 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-05-17. | 2022-04-25 10:14:32.332
CL-202206-NYMEX [C] 2 Day #6 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-03-18. | 2022-04-25 10:14:32.337
CL-202206-NYMEX [C] 2 Day #6 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-04-15. | 2022-04-25 10:14:32.337
CL-202206-NYMEX [C] 2 Day #6 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-02-18. | 2022-04-25 10:14:32.341
CL-202206-NYMEX [C] 2 Day #6 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-03-17. | 2022-04-25 10:14:32.341
CL-202206-NYMEX [C] 2 Day #6 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-01-18. | 2022-04-25 10:14:32.346
CL-202206-NYMEX [C] 2 Day #6 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-02-17. | 2022-04-25 10:14:32.346
CL-202206-NYMEX [C] 2 Day #6 | File CL-199302-NYMEX.dly has a volume of 0 at 1992-12-18. | 2022-04-25 10:14:32.350
CL-202206-NYMEX [C] 2 Day #6 | File CL-199302-NYMEX.dly has a volume of 0 at 1993-01-15. | 2022-04-25 10:14:32.350
CL-202206-NYMEX [C] 2 Day #6 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-11-18. | 2022-04-25 10:14:32.354
CL-202206-NYMEX [C] 2 Day #6 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-12-17. | 2022-04-25 10:14:32.354
CL-202206-NYMEX [C] 2 Day #6 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-10-16. | 2022-04-25 10:14:32.359
CL-202206-NYMEX [C] 2 Day #6 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-11-17. | 2022-04-25 10:14:32.359
CL-202206-NYMEX [C] 2 Day #6 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-09-18. | 2022-04-25 10:14:32.363
CL-202206-NYMEX [C] 2 Day #6 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-10-15. | 2022-04-25 10:14:32.363
CL-202206-NYMEX [C] 2 Day #6 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-08-18. | 2022-04-25 10:14:32.367
CL-202206-NYMEX [C] 2 Day #6 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-09-17. | 2022-04-25 10:14:32.367
CL-202206-NYMEX [C] 2 Day #6 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-07-17. | 2022-04-25 10:14:32.372
CL-202206-NYMEX [C] 2 Day #6 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-08-17. | 2022-04-25 10:14:32.372
CL-202206-NYMEX [C] 2 Day #6 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-06-18. | 2022-04-25 10:14:32.376
CL-202206-NYMEX [C] 2 Day #6 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-07-16. | 2022-04-25 10:14:32.376
CL-202206-NYMEX [C] 2 Day #6 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-05-18. | 2022-04-25 10:14:32.381
CL-202206-NYMEX [C] 2 Day #6 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-06-17. | 2022-04-25 10:14:32.381
CL-202206-NYMEX [C] 2 Day #6 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-04-17. | 2022-04-25 10:14:32.385
CL-202206-NYMEX [C] 2 Day #6 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-05-15. | 2022-04-25 10:14:32.385
CL-202206-NYMEX [C] 2 Day #6 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-03-18. | 2022-04-25 10:14:32.389
CL-202206-NYMEX [C] 2 Day #6 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-04-16. | 2022-04-25 10:14:32.389
CL-202206-NYMEX [C] 2 Day #6 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-02-18. | 2022-04-25 10:14:32.393
CL-202206-NYMEX [C] 2 Day #6 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-03-17. | 2022-04-25 10:14:32.393
CL-202206-NYMEX [C] 2 Day #6 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-01-17. | 2022-04-25 10:14:32.398
CL-202206-NYMEX [C] 2 Day #6 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-02-17. | 2022-04-25 10:14:32.398
CL-202206-NYMEX [C] 2 Day #6 | File CL-199202-NYMEX.dly has a volume of 0 at 1991-12-18. | 2022-04-25 10:14:32.402
CL-202206-NYMEX [C] 2 Day #6 | File CL-199202-NYMEX.dly has a volume of 0 at 1992-01-16. | 2022-04-25 10:14:32.402
CL-202206-NYMEX [C] 2 Day #6 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-11-18. | 2022-04-25 10:14:32.406
CL-202206-NYMEX [C] 2 Day #6 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-12-17. | 2022-04-25 10:14:32.406
CL-202206-NYMEX [C] 2 Day #6 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-10-18. | 2022-04-25 10:14:32.410
CL-202206-NYMEX [C] 2 Day #6 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-11-15. | 2022-04-25 10:14:32.410
CL-202206-NYMEX [C] 2 Day #6 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-09-18. | 2022-04-25 10:14:32.414
CL-202206-NYMEX [C] 2 Day #6 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-10-17. | 2022-04-25 10:14:32.414
CL-202206-NYMEX [C] 2 Day #6 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-08-16. | 2022-04-25 10:14:32.419
CL-202206-NYMEX [C] 2 Day #6 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-09-17. | 2022-04-25 10:14:32.419
CL-202206-NYMEX [C] 2 Day #6 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-07-18. | 2022-04-25 10:14:32.423
CL-202206-NYMEX [C] 2 Day #6 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-08-15. | 2022-04-25 10:14:32.423
CL-202206-NYMEX [C] 2 Day #6 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-06-18. | 2022-04-25 10:14:32.427
CL-202206-NYMEX [C] 2 Day #6 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-07-17. | 2022-04-25 10:14:32.427
CL-202206-NYMEX [C] 2 Day #6 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-05-17. | 2022-04-25 10:14:32.432
CL-202206-NYMEX [C] 2 Day #6 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-06-17. | 2022-04-25 10:14:32.432
CL-202206-NYMEX [C] 2 Day #6 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-04-18. | 2022-04-25 10:14:32.436
CL-202206-NYMEX [C] 2 Day #6 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-05-16. | 2022-04-25 10:14:32.436
CL-202206-NYMEX [C] 2 Day #6 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-03-18. | 2022-04-25 10:14:32.440
CL-202206-NYMEX [C] 2 Day #6 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-04-17. | 2022-04-25 10:14:32.440
CL-202206-NYMEX [C] 2 Day #6 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-02-18. | 2022-04-25 10:14:32.444
CL-202206-NYMEX [C] 2 Day #6 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-03-15. | 2022-04-25 10:14:32.444
CL-202206-NYMEX [C] 2 Day #6 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-01-18. | 2022-04-25 10:14:32.449
CL-202206-NYMEX [C] 2 Day #6 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-02-15. | 2022-04-25 10:14:32.449
CL-202206-NYMEX [C] 2 Day #6 | File CL-199102-NYMEX.dly has a volume of 0 at 1990-12-18. | 2022-04-25 10:14:32.453
CL-202206-NYMEX [C] 2 Day #6 | File CL-199102-NYMEX.dly has a volume of 0 at 1991-01-17. | 2022-04-25 10:14:32.453
CL-202206-NYMEX [C] 2 Day #6 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-11-16. | 2022-04-25 10:14:32.457
CL-202206-NYMEX [C] 2 Day #6 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-12-17. | 2022-04-25 10:14:32.457
CL-202206-NYMEX [C] 2 Day #6 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-10-18. | 2022-04-25 10:14:32.461
CL-202206-NYMEX [C] 2 Day #6 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-11-15. | 2022-04-25 10:14:32.461
CL-202206-NYMEX [C] 2 Day #6 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-09-18. | 2022-04-25 10:14:32.465
CL-202206-NYMEX [C] 2 Day #6 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-10-17. | 2022-04-25 10:14:32.465
CL-202206-NYMEX [C] 2 Day #6 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-08-17. | 2022-04-25 10:14:32.470
CL-202206-NYMEX [C] 2 Day #6 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-09-17. | 2022-04-25 10:14:32.470
CL-202206-NYMEX [C] 2 Day #6 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-07-18. | 2022-04-25 10:14:32.474
CL-202206-NYMEX [C] 2 Day #6 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-08-16. | 2022-04-25 10:14:32.474
CL-202206-NYMEX [C] 2 Day #6 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-06-18. | 2022-04-25 10:14:32.478
CL-202206-NYMEX [C] 2 Day #6 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-07-17. | 2022-04-25 10:14:32.478
CL-202206-NYMEX [C] 2 Day #6 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-05-18. | 2022-04-25 10:14:32.482
CL-202206-NYMEX [C] 2 Day #6 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-06-15. | 2022-04-25 10:14:32.482
CL-202206-NYMEX [C] 2 Day #6 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-04-18. | 2022-04-25 10:14:32.487
CL-202206-NYMEX [C] 2 Day #6 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-05-17. | 2022-04-25 10:14:32.487
CL-202206-NYMEX [C] 2 Day #6 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-03-16. | 2022-04-25 10:14:32.491
CL-202206-NYMEX [C] 2 Day #6 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-04-17. | 2022-04-25 10:14:32.491
CL-202206-NYMEX [C] 2 Day #6 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-02-16. | 2022-04-25 10:14:32.495
CL-202206-NYMEX [C] 2 Day #6 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-03-15. | 2022-04-25 10:14:32.495
CL-202206-NYMEX [C] 2 Day #6 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-01-18. | 2022-04-25 10:14:32.499
CL-202206-NYMEX [C] 2 Day #6 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-02-15. | 2022-04-25 10:14:32.499
CL-202206-NYMEX [C] 2 Day #6 | File CL-199002-NYMEX.dly has a volume of 0 at 1989-12-18. | 2022-04-25 10:14:32.504
CL-202206-NYMEX [C] 2 Day #6 | File CL-199002-NYMEX.dly has a volume of 0 at 1990-01-17. | 2022-04-25 10:14:32.504
CL-202206-NYMEX [C] 2 Day #6 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-11-17. | 2022-04-25 10:14:32.508
CL-202206-NYMEX [C] 2 Day #6 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-12-15. | 2022-04-25 10:14:32.508
CL-202206-NYMEX [C] 2 Day #6 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-10-18. | 2022-04-25 10:14:32.512
CL-202206-NYMEX [C] 2 Day #6 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-11-16. | 2022-04-25 10:14:32.512
CL-202206-NYMEX [C] 2 Day #6 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-09-18. | 2022-04-25 10:14:32.517
CL-202206-NYMEX [C] 2 Day #6 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-10-17. | 2022-04-25 10:14:32.517
CL-202206-NYMEX [C] 2 Day #6 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-08-18. | 2022-04-25 10:14:32.521
CL-202206-NYMEX [C] 2 Day #6 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-09-15. | 2022-04-25 10:14:32.521
CL-202206-NYMEX [C] 2 Day #6 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-07-18. | 2022-04-25 10:14:32.526
CL-202206-NYMEX [C] 2 Day #6 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-08-17. | 2022-04-25 10:14:32.526
CL-202206-NYMEX [C] 2 Day #6 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-06-16. | 2022-04-25 10:14:32.530
CL-202206-NYMEX [C] 2 Day #6 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-07-17. | 2022-04-25 10:14:32.530
CL-202206-NYMEX [C] 2 Day #6 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-05-18. | 2022-04-25 10:14:32.534
CL-202206-NYMEX [C] 2 Day #6 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-06-15. | 2022-04-25 10:14:32.534
CL-202206-NYMEX [C] 2 Day #6 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-04-18. | 2022-04-25 10:14:32.538
CL-202206-NYMEX [C] 2 Day #6 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-05-17. | 2022-04-25 10:14:32.538
CL-202206-NYMEX [C] 2 Day #6 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-03-17. | 2022-04-25 10:14:32.543
CL-202206-NYMEX [C] 2 Day #6 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-04-17. | 2022-04-25 10:14:32.543
CL-202206-NYMEX [C] 2 Day #6 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-02-17. | 2022-04-25 10:14:32.547
CL-202206-NYMEX [C] 2 Day #6 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-03-16. | 2022-04-25 10:14:32.547
CL-202206-NYMEX [C] 2 Day #6 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-01-18. | 2022-04-25 10:14:32.551
CL-202206-NYMEX [C] 2 Day #6 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-02-16. | 2022-04-25 10:14:32.551
CL-202206-NYMEX [C] 2 Day #6 | File CL-198902-NYMEX.dly has a volume of 0 at 1988-12-16. | 2022-04-25 10:14:32.555
CL-202206-NYMEX [C] 2 Day #6 | File CL-198902-NYMEX.dly has a volume of 0 at 1989-01-17. | 2022-04-25 10:14:32.555
CL-202206-NYMEX [C] 2 Day #6 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-11-18. | 2022-04-25 10:14:32.559
CL-202206-NYMEX [C] 2 Day #6 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-12-15. | 2022-04-25 10:14:32.559
CL-202206-NYMEX [C] 2 Day #6 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-10-18. | 2022-04-25 10:14:32.564
CL-202206-NYMEX [C] 2 Day #6 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-11-17. | 2022-04-25 10:14:32.564
CL-202206-NYMEX [C] 2 Day #6 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-09-16. | 2022-04-25 10:14:32.568
CL-202206-NYMEX [C] 2 Day #6 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-10-17. | 2022-04-25 10:14:32.568
CL-202206-NYMEX [C] 2 Day #6 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-08-18. | 2022-04-25 10:14:32.572
CL-202206-NYMEX [C] 2 Day #6 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-09-15. | 2022-04-25 10:14:32.572
CL-202206-NYMEX [C] 2 Day #6 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-07-18. | 2022-04-25 10:14:32.577
CL-202206-NYMEX [C] 2 Day #6 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-08-17. | 2022-04-25 10:14:32.577
CL-202206-NYMEX [C] 2 Day #6 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-06-17. | 2022-04-25 10:14:32.581
CL-202206-NYMEX [C] 2 Day #6 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-07-15. | 2022-04-25 10:14:32.581
CL-202206-NYMEX [C] 2 Day #6 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-05-18. | 2022-04-25 10:14:32.585
CL-202206-NYMEX [C] 2 Day #6 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-06-16. | 2022-04-25 10:14:32.585
CL-202206-NYMEX [C] 2 Day #6 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-04-18. | 2022-04-25 10:14:32.590
CL-202206-NYMEX [C] 2 Day #6 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-05-17. | 2022-04-25 10:14:32.590
CL-202206-NYMEX [C] 2 Day #6 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-03-18. | 2022-04-25 10:14:32.594
CL-202206-NYMEX [C] 2 Day #6 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-04-15. | 2022-04-25 10:14:32.594
CL-202206-NYMEX [C] 2 Day #6 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-02-18. | 2022-04-25 10:14:32.598
CL-202206-NYMEX [C] 2 Day #6 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-03-17. | 2022-04-25 10:14:32.598
CL-202206-NYMEX [C] 2 Day #6 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-01-18. | 2022-04-25 10:14:32.602
CL-202206-NYMEX [C] 2 Day #6 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-02-17. | 2022-04-25 10:14:32.602
CL-202206-NYMEX [C] 2 Day #6 | File CL-198802-NYMEX.dly has a volume of 0 at 1987-12-18. | 2022-04-25 10:14:32.607
CL-202206-NYMEX [C] 2 Day #6 | File CL-198802-NYMEX.dly has a volume of 0 at 1988-01-15. | 2022-04-25 10:14:32.607
CL-202206-NYMEX [C] 2 Day #6 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-11-18. | 2022-04-25 10:14:32.611
CL-202206-NYMEX [C] 2 Day #6 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-12-17. | 2022-04-25 10:14:32.611
CL-202206-NYMEX [C] 2 Day #6 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-10-16. | 2022-04-25 10:14:32.615
CL-202206-NYMEX [C] 2 Day #6 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-11-17. | 2022-04-25 10:14:32.615
CL-202206-NYMEX [C] 2 Day #6 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-09-18. | 2022-04-25 10:14:32.620
CL-202206-NYMEX [C] 2 Day #6 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-10-15. | 2022-04-25 10:14:32.620
CL-202206-NYMEX [C] 2 Day #6 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-08-18. | 2022-04-25 10:14:32.624
CL-202206-NYMEX [C] 2 Day #6 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-09-17. | 2022-04-25 10:14:32.624
CL-202206-NYMEX [C] 2 Day #6 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-07-17. | 2022-04-25 10:14:32.628
CL-202206-NYMEX [C] 2 Day #6 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-08-17. | 2022-04-25 10:14:32.628
CL-202206-NYMEX [C] 2 Day #6 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-06-18. | 2022-04-25 10:14:32.633
CL-202206-NYMEX [C] 2 Day #6 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-07-16. | 2022-04-25 10:14:32.633
CL-202206-NYMEX [C] 2 Day #6 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-05-18. | 2022-04-25 10:14:32.637
CL-202206-NYMEX [C] 2 Day #6 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-06-17. | 2022-04-25 10:14:32.637
CL-202206-NYMEX [C] 2 Day #6 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-04-17. | 2022-04-25 10:14:32.641
CL-202206-NYMEX [C] 2 Day #6 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-05-15. | 2022-04-25 10:14:32.641
CL-202206-NYMEX [C] 2 Day #6 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-03-18. | 2022-04-25 10:14:32.645
CL-202206-NYMEX [C] 2 Day #6 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-04-16. | 2022-04-25 10:14:32.645
CL-202206-NYMEX [C] 2 Day #6 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-02-18. | 2022-04-25 10:14:32.649
CL-202206-NYMEX [C] 2 Day #6 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-03-17. | 2022-04-25 10:14:32.649
CL-202206-NYMEX [C] 2 Day #6 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-01-16. | 2022-04-25 10:14:32.654
CL-202206-NYMEX [C] 2 Day #6 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-02-17. | 2022-04-25 10:14:32.654
CL-202206-NYMEX [C] 2 Day #6 | File CL-198702-NYMEX.dly has a volume of 0 at 1986-12-18. | 2022-04-25 10:14:32.658
CL-202206-NYMEX [C] 2 Day #6 | File CL-198702-NYMEX.dly has a volume of 0 at 1987-01-15. | 2022-04-25 10:14:32.658
CL-202206-NYMEX [C] 2 Day #6 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-11-18. | 2022-04-25 10:14:32.662
CL-202206-NYMEX [C] 2 Day #6 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-12-17. | 2022-04-25 10:14:32.662
CL-202206-NYMEX [C] 2 Day #6 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-10-17. | 2022-04-25 10:14:32.667
CL-202206-NYMEX [C] 2 Day #6 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-11-17. | 2022-04-25 10:14:32.667
CL-202206-NYMEX [C] 2 Day #6 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-09-18. | 2022-04-25 10:14:32.671
CL-202206-NYMEX [C] 2 Day #6 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-10-16. | 2022-04-25 10:14:32.671
CL-202206-NYMEX [C] 2 Day #6 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-08-18. | 2022-04-25 10:14:32.676
CL-202206-NYMEX [C] 2 Day #6 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-09-17. | 2022-04-25 10:14:32.676
CL-202206-NYMEX [C] 2 Day #6 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-07-18. | 2022-04-25 10:14:32.680
CL-202206-NYMEX [C] 2 Day #6 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-08-15. | 2022-04-25 10:14:32.680
CL-202206-NYMEX [C] 2 Day #6 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-06-18. | 2022-04-25 10:14:32.684
CL-202206-NYMEX [C] 2 Day #6 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-07-17. | 2022-04-25 10:14:32.684
CL-202206-NYMEX [C] 2 Day #6 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-05-16. | 2022-04-25 10:14:32.688
CL-202206-NYMEX [C] 2 Day #6 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-06-17. | 2022-04-25 10:14:32.688
CL-202206-NYMEX [C] 2 Day #6 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-04-18. | 2022-04-25 10:14:32.693
CL-202206-NYMEX [C] 2 Day #6 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-05-15. | 2022-04-25 10:14:32.693
CL-202206-NYMEX [C] 2 Day #6 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-03-18. | 2022-04-25 10:14:32.697
CL-202206-NYMEX [C] 2 Day #6 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-04-17. | 2022-04-25 10:14:32.697
CL-202206-NYMEX [C] 2 Day #6 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-02-18. | 2022-04-25 10:14:32.701
CL-202206-NYMEX [C] 2 Day #6 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-03-17. | 2022-04-25 10:14:32.701
CL-202206-NYMEX [C] 2 Day #6 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-01-17. | 2022-04-25 10:14:32.705
CL-202206-NYMEX [C] 2 Day #6 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-02-17. | 2022-04-25 10:14:32.705
CL-202206-NYMEX [C] 2 Day #6 | File CL-198602-NYMEX.dly has a volume of 0 at 1985-12-18. | 2022-04-25 10:14:32.710
CL-202206-NYMEX [C] 2 Day #6 | File CL-198602-NYMEX.dly has a volume of 0 at 1986-01-16. | 2022-04-25 10:14:32.710
CL-202206-NYMEX [C] 2 Day #6 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-11-18. | 2022-04-25 10:14:32.714
CL-202206-NYMEX [C] 2 Day #6 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-12-17. | 2022-04-25 10:14:32.714
CL-202206-NYMEX [C] 2 Day #6 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-10-18. | 2022-04-25 10:14:32.718
CL-202206-NYMEX [C] 2 Day #6 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-11-15. | 2022-04-25 10:14:32.718
CL-202206-NYMEX [C] 2 Day #6 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-09-18. | 2022-04-25 10:14:32.722
CL-202206-NYMEX [C] 2 Day #6 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-10-17. | 2022-04-25 10:14:32.722
CL-202206-NYMEX [C] 2 Day #6 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-08-16. | 2022-04-25 10:14:32.727
CL-202206-NYMEX [C] 2 Day #6 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-09-17. | 2022-04-25 10:14:32.727
CL-202206-NYMEX [C] 2 Day #6 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-07-18. | 2022-04-25 10:14:32.731
CL-202206-NYMEX [C] 2 Day #6 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-08-15. | 2022-04-25 10:14:32.731
CL-202206-NYMEX [C] 2 Day #6 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-06-18. | 2022-04-25 10:14:32.735
CL-202206-NYMEX [C] 2 Day #6 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-07-17. | 2022-04-25 10:14:32.735
CL-202206-NYMEX [C] 2 Day #6 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-05-17. | 2022-04-25 10:14:32.739
CL-202206-NYMEX [C] 2 Day #6 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-06-17. | 2022-04-25 10:14:32.739
CL-202206-NYMEX [C] 2 Day #6 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-04-18. | 2022-04-25 10:14:32.744
CL-202206-NYMEX [C] 2 Day #6 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-05-16. | 2022-04-25 10:14:32.744
CL-202206-NYMEX [C] 2 Day #6 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-03-18. | 2022-04-25 10:14:32.748
CL-202206-NYMEX [C] 2 Day #6 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-04-17. | 2022-04-25 10:14:32.748
CL-202206-NYMEX [C] 2 Day #6 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-02-18. | 2022-04-25 10:14:32.752
CL-202206-NYMEX [C] 2 Day #6 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-03-15. | 2022-04-25 10:14:32.752
CL-202206-NYMEX [C] 2 Day #6 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-01-18. | 2022-04-25 10:14:32.756
CL-202206-NYMEX [C] 2 Day #6 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-02-15. | 2022-04-25 10:14:32.756
CL-202206-NYMEX [C] 2 Day #6 | File CL-198502-NYMEX.dly has a volume of 0 at 1984-12-18. | 2022-04-25 10:14:32.760
CL-202206-NYMEX [C] 2 Day #6 | File CL-198502-NYMEX.dly has a volume of 0 at 1985-01-17. | 2022-04-25 10:14:32.760
CL-202206-NYMEX [C] 2 Day #6 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-11-16. | 2022-04-25 10:14:32.763
CL-202206-NYMEX [C] 2 Day #6 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-12-17. | 2022-04-25 10:14:32.763
CL-202206-NYMEX [C] 2 Day #6 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-10-18. | 2022-04-25 10:14:32.767
CL-202206-NYMEX [C] 2 Day #6 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-11-15. | 2022-04-25 10:14:32.767
CL-202206-NYMEX [C] 2 Day #6 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-09-18. | 2022-04-25 10:14:32.771
CL-202206-NYMEX [C] 2 Day #6 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-10-17. | 2022-04-25 10:14:32.771
CL-202206-NYMEX [C] 2 Day #6 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-08-17. | 2022-04-25 10:14:32.775
CL-202206-NYMEX [C] 2 Day #6 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-09-17. | 2022-04-25 10:14:32.775
CL-202206-NYMEX [C] 2 Day #6 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-07-18. | 2022-04-25 10:14:32.779
CL-202206-NYMEX [C] 2 Day #6 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-08-16. | 2022-04-25 10:14:32.779
CL-202206-NYMEX [C] 2 Day #6 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-06-18. | 2022-04-25 10:14:32.783
CL-202206-NYMEX [C] 2 Day #6 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-07-17. | 2022-04-25 10:14:32.783
CL-202206-NYMEX [C] 2 Day #6 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-05-18. | 2022-04-25 10:14:32.787
CL-202206-NYMEX [C] 2 Day #6 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-06-15. | 2022-04-25 10:14:32.787
CL-202206-NYMEX [C] 2 Day #6 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-04-18. | 2022-04-25 10:14:32.792
CL-202206-NYMEX [C] 2 Day #6 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-05-17. | 2022-04-25 10:14:32.792
CL-202206-NYMEX [C] 2 Day #6 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-03-16. | 2022-04-25 10:14:32.796
CL-202206-NYMEX [C] 2 Day #6 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-04-17. | 2022-04-25 10:14:32.796
CL-202206-NYMEX [C] 2 Day #6 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-02-17. | 2022-04-25 10:14:32.799
CL-202206-NYMEX [C] 2 Day #6 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-03-15. | 2022-04-25 10:14:32.799
CL-202206-NYMEX [C] 2 Day #6 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-01-18. | 2022-04-25 10:14:32.804
CL-202206-NYMEX [C] 2 Day #6 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-02-16. | 2022-04-25 10:14:32.804
CL-202206-NYMEX [C] 2 Day #6 | File CL-198402-NYMEX.dly has a volume of 0 at 1983-12-16. | 2022-04-25 10:14:32.808
CL-202206-NYMEX [C] 2 Day #6 | File CL-198402-NYMEX.dly has a volume of 0 at 1984-01-17. | 2022-04-25 10:14:32.808
CL-202206-NYMEX [C] 2 Day #6 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-11-18. | 2022-04-25 10:14:32.811
CL-202206-NYMEX [C] 2 Day #6 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-12-15. | 2022-04-25 10:14:32.811
CL-202206-NYMEX [C] 2 Day #6 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-10-18. | 2022-04-25 10:14:32.815
CL-202206-NYMEX [C] 2 Day #6 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-11-17. | 2022-04-25 10:14:32.815
CL-202206-NYMEX [C] 2 Day #6 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-09-16. | 2022-04-25 10:14:32.819
CL-202206-NYMEX [C] 2 Day #6 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-10-17. | 2022-04-25 10:14:32.819
CL-202206-NYMEX [C] 2 Day #6 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-08-18. | 2022-04-25 10:14:32.824
CL-202206-NYMEX [C] 2 Day #6 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-09-15. | 2022-04-25 10:14:32.824
CL-202206-NYMEX [C] 2 Day #6 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-07-18. | 2022-04-25 10:14:32.828
CL-202206-NYMEX [C] 2 Day #6 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-08-17. | 2022-04-25 10:14:32.828
CL-202206-NYMEX [C] 2 Day #6 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-06-17. | 2022-04-25 10:14:32.832
CL-202206-NYMEX [C] 2 Day #6 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-07-15. | 2022-04-25 10:14:32.832
CL-202206-NYMEX [C] 2 Day #6 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-05-18. | 2022-04-25 10:14:32.836
CL-202206-NYMEX [C] 2 Day #6 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-06-16. | 2022-04-25 10:14:32.836
CL-202206-NYMEX [C] 2 Day #6 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-04-18. | 2022-04-25 10:14:32.840
CL-202206-NYMEX [C] 2 Day #6 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-05-17. | 2022-04-25 10:14:32.840
CL-202206-NYMEX [C] 2 Day #6 | Waiting for historical downloads to complete with the IDs: 23, 24, | 2022-04-25 10:14:32.938
QM-202206-NYMEX 384 Min #8 | Reloading chart. | 2022-04-25 10:14:32.949
QM-202206-NYMEX 768 Min #12 | Reloading chart. | 2022-04-25 10:14:32.960
Files to Open on Startup | Opening file: CRYPTO.Cht | 2022-04-25 10:14:32.968
BRR-202203-CMECRYPTO-USD-5 [C] 8 Day #1 | Reloading chart. | 2022-04-25 10:14:33.094
BRR-202203-CMECRYPTO-USD-5 [C] 8 Day #1 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:33.094
BRR-202203-CMECRYPTO-USD-5 [C] 8 Day #1 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:33.094
BRR-202203-CMECRYPTO-USD-5 [C] 8 Day #1 | Performing continuous chart historical Daily data download for symbol BRR-201805-CMECRYPTO-USD-5 starting at last date in file. | 2022-04-25 10:14:33.390
Added historical Daily data request for BRR-201805-CMECRYPTO-USD-5 to the queue. | 2022-04-25 10:14:33.390
BRR-202203-CMECRYPTO-USD-5 [C] 8 Day #1 | Performing continuous chart historical Daily data download for symbol BRR-201901-CMECRYPTO-USD-5 starting at last date in file. | 2022-04-25 10:14:33.399
Added historical Daily data request for BRR-201901-CMECRYPTO-USD-5 to the queue. | 2022-04-25 10:14:33.399
BRR-202203-CMECRYPTO-USD-5 [C] 8 Day #1 | Performing continuous chart historical Daily data download for symbol BRR-201902-CMECRYPTO-USD-5 starting at last date in file. | 2022-04-25 10:14:33.400
Added historical Daily data request for BRR-201902-CMECRYPTO-USD-5 to the queue. | 2022-04-25 10:14:33.400
BRR-202203-CMECRYPTO-USD-5 [C] 8 Day #1 | Performing continuous chart historical Daily data download for symbol BRR-201910-CMECRYPTO-USD-5 starting at last date in file. | 2022-04-25 10:14:33.408
Added historical Daily data request for BRR-201910-CMECRYPTO-USD-5 to the queue. | 2022-04-25 10:14:33.408
BRR-202203-CMECRYPTO-USD-5 [C] 8 Day #1 | Performing continuous chart historical Daily data download for symbol BRR-202004-CMECRYPTO-USD-5 starting at last date in file. | 2022-04-25 10:14:33.415
Added historical Daily data request for BRR-202004-CMECRYPTO-USD-5 to the queue. | 2022-04-25 10:14:33.415
BRR-202203-CMECRYPTO-USD-5 [C] 8 Day #1 | Performing continuous chart historical Daily data download for symbol BRR-202012-CMECRYPTO-USD-5 starting at last date in file. | 2022-04-25 10:14:33.424
Added historical Daily data request for BRR-202012-CMECRYPTO-USD-5 to the queue. | 2022-04-25 10:14:33.424
BRR-202203-CMECRYPTO-USD-5 [C] 8 Day #1 | Performing continuous chart historical Daily data download for symbol BRR-202109-CMECRYPTO-USD-5 starting at last date in file. | 2022-04-25 10:14:33.434
Added historical Daily data request for BRR-202109-CMECRYPTO-USD-5 to the queue. | 2022-04-25 10:14:33.434
BRR-202203-CMECRYPTO-USD-5 [C] 8 Day #1 | Performing continuous chart historical Daily data download for symbol BRR-202203-CMECRYPTO-USD-5 starting at last date in file. | 2022-04-25 10:14:33.440
Added historical Daily data request for BRR-202203-CMECRYPTO-USD-5 to the queue. | 2022-04-25 10:14:33.440
BRR-202203-CMECRYPTO-USD-5 [C] 8 Day #1 | Waiting for historical downloads to complete with the IDs: 25, 26, 27, 28, 29, 30, 31, 32, | 2022-04-25 10:14:33.946
BRR-202203-CMECRYPTO-USD-5 [C] 16 Day #2 | Reloading chart. | 2022-04-25 10:14:33.959
BRR-202203-CMECRYPTO-USD-5 [C] 16 Day #2 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:33.959
BRR-202203-CMECRYPTO-USD-5 [C] 16 Day #2 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:33.959
BRR-202203-CMECRYPTO-USD-5 [C] 16 Day #2 | Waiting for historical downloads to complete with the IDs: 25, 26, 27, 28, 29, 30, 31, 32, | 2022-04-25 10:14:34.786
BRR-202203-CMECRYPTO-USD-5 [C] 2 Day #3 | Reloading chart. | 2022-04-25 10:14:34.809
BRR-202203-CMECRYPTO-USD-5 [C] 2 Day #3 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:34.809
BRR-202203-CMECRYPTO-USD-5 [C] 2 Day #3 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:34.809
BRR-202203-CMECRYPTO-USD-5 [C] 2 Day #3 | Waiting for historical downloads to complete with the IDs: 25, 26, 27, 28, 29, 30, 31, 32, | 2022-04-25 10:14:35.635
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Reloading chart. | 2022-04-25 10:14:35.653
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201606-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.766
Added historical Daily data request for MBT-201606-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.766
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201607-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.766
Added historical Daily data request for MBT-201607-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.766
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201608-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.767
Added historical Daily data request for MBT-201608-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.767
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201609-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.768
Added historical Daily data request for MBT-201609-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.768
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201610-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.769
Added historical Daily data request for MBT-201610-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.769
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201611-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.770
Added historical Daily data request for MBT-201611-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.770
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201612-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.771
Added historical Daily data request for MBT-201612-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.771
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201701-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.772
Added historical Daily data request for MBT-201701-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.772
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201702-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.773
Added historical Daily data request for MBT-201702-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.773
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201703-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.774
Added historical Daily data request for MBT-201703-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.774
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201704-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.775
Added historical Daily data request for MBT-201704-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.775
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201705-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.776
Added historical Daily data request for MBT-201705-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.776
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201706-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.777
Added historical Daily data request for MBT-201706-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.777
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201707-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.777
Added historical Daily data request for MBT-201707-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.777
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201708-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.778
Added historical Daily data request for MBT-201708-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.778
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201709-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.779
Added historical Daily data request for MBT-201709-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.779
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201710-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.780
Added historical Daily data request for MBT-201710-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.780
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201711-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.781
Added historical Daily data request for MBT-201711-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.781
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201712-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.782
Added historical Daily data request for MBT-201712-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.782
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201801-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.783
Added historical Daily data request for MBT-201801-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.783
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201802-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.784
Added historical Daily data request for MBT-201802-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.784
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201803-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.785
Added historical Daily data request for MBT-201803-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.785
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201804-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.786
Added historical Daily data request for MBT-201804-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.786
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201805-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.787
Added historical Daily data request for MBT-201805-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.787
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201806-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.788
Added historical Daily data request for MBT-201806-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.788
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201807-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.789
Added historical Daily data request for MBT-201807-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.789
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201808-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.790
Added historical Daily data request for MBT-201808-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.790
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201809-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.791
Added historical Daily data request for MBT-201809-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.791
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201810-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.792
Added historical Daily data request for MBT-201810-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.792
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201811-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.792
Added historical Daily data request for MBT-201811-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.792
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201812-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.793
Added historical Daily data request for MBT-201812-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.793
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201901-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.794
Added historical Daily data request for MBT-201901-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.794
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201902-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.795
Added historical Daily data request for MBT-201902-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.795
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201903-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.796
Added historical Daily data request for MBT-201903-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.796
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201904-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.797
Added historical Daily data request for MBT-201904-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.797
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201905-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.798
Added historical Daily data request for MBT-201905-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.798
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201906-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.799
Added historical Daily data request for MBT-201906-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.799
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201907-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.800
Added historical Daily data request for MBT-201907-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.800
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201908-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.801
Added historical Daily data request for MBT-201908-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.801
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201909-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.802
Added historical Daily data request for MBT-201909-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.802
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201910-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.802
Added historical Daily data request for MBT-201910-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.803
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201911-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.803
Added historical Daily data request for MBT-201911-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.803
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-201912-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.804
Added historical Daily data request for MBT-201912-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.804
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-202001-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.805
Added historical Daily data request for MBT-202001-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.805
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-202002-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.806
Added historical Daily data request for MBT-202002-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.806
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-202003-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.807
Added historical Daily data request for MBT-202003-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.807
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-202004-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.807
Added historical Daily data request for MBT-202004-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.807
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-202005-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.808
Added historical Daily data request for MBT-202005-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.808
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-202006-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.809
Added historical Daily data request for MBT-202006-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.809
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-202007-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.810
Added historical Daily data request for MBT-202007-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.810
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-202008-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.811
Added historical Daily data request for MBT-202008-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.811
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-202009-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.812
Added historical Daily data request for MBT-202009-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.812
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-202010-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.813
Added historical Daily data request for MBT-202010-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.813
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-202011-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.813
Added historical Daily data request for MBT-202011-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.813
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-202012-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.814
Added historical Daily data request for MBT-202012-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.814
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-202101-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.815
Added historical Daily data request for MBT-202101-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.815
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-202102-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.816
Added historical Daily data request for MBT-202102-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.816
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-202103-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.817
Added historical Daily data request for MBT-202103-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.817
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-202104-CMECRYPTO-USD-0.1 starting at 2021-03-24. | 2022-04-25 10:14:35.818
Added historical Daily data request for MBT-202104-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.818
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-202109-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.823
Added historical Daily data request for MBT-202109-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.823
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Performing continuous chart historical Daily data download for symbol MBT-202203-CMECRYPTO-USD-0.1 starting at last date in file. | 2022-04-25 10:14:35.830
Added historical Daily data request for MBT-202203-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.830
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Dates not found while checking for invalid data in continuous contract data files. MBT-202105-CMECRYPTO-USD-0.1 | 2022-04-25 10:14:35.885 *
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Waiting for historical downloads to complete with the IDs: 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, | 2022-04-25 10:14:35.885
MBT-202203-CMECRYPTO-USD-0.1 Daily #5 | Reloading chart. | 2022-04-25 10:14:35.895
MBT-202203-CMECRYPTO-USD-0.1 [C] 384 Min #6 | Reloading chart. | 2022-04-25 10:14:35.907
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2022-04-25 10:14:35.908
Starting DelayedDownloadMonitoringTimer | 2022-04-25 10:14:35.908
Starting HDTimeoutTimer | 2022-04-25 10:14:35.908
IB TWS socket (1) | Creating socket. | 2022-04-25 10:14:35.908
IB TWS socket (1) | New receive buffer size: 5242880 | 2022-04-25 10:14:35.908
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2022-04-25 10:14:35.908
Added historical Intraday data request for MBT-202109-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:35.908
Triggering next historical data download in queue. | 2022-04-25 10:14:35.908
MBT-202203-CMECRYPTO-USD-0.1 [C] 384 Min #6 | Waiting for historical downloads to complete with the IDs: 94, | 2022-04-25 10:14:35.909
BTC-USD 4 Day #7 | Reloading chart. | 2022-04-25 10:14:35.921
Files to Open on Startup | Opening file: FOREX.Cht | 2022-04-25 10:14:35.928
USDOLLAR 4 Day #6 | Reloading chart. | 2022-04-25 10:14:36.003
AUD-202206-GLOBEX [C] 16 Day #2 | Reloading chart. | 2022-04-25 10:14:36.014
AUD-202206-GLOBEX [C] 16 Day #2 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:36.014
AUD-202206-GLOBEX [C] 16 Day #2 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:36.014
AUD-202206-GLOBEX [C] 16 Day #2 | Performing continuous chart historical Daily data download for symbol AUD-198703-GLOBEX starting at 1986-12-11. | 2022-04-25 10:14:36.061
Added historical Daily data request for AUD-198703-GLOBEX to the queue. | 2022-04-25 10:14:36.061
AUD-202206-GLOBEX [C] 16 Day #2 | Performing continuous chart historical Daily data download for symbol AUD-202206-GLOBEX starting at last date in file. | 2022-04-25 10:14:36.194
Added historical Daily data request for AUD-202206-GLOBEX to the queue. | 2022-04-25 10:14:36.194
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-200103-GLOBEX.dly has a volume of 0 at 2000-12-15. | 2022-04-25 10:14:37.130
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-200012-GLOBEX.dly has a volume of 0 at 2000-09-15. | 2022-04-25 10:14:37.140
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-200012-GLOBEX.dly has a volume of 0 at 2000-12-14. | 2022-04-25 10:14:37.140
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-200009-GLOBEX.dly has a volume of 0 at 2000-06-16. | 2022-04-25 10:14:37.150
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-200009-GLOBEX.dly has a volume of 0 at 2000-09-14. | 2022-04-25 10:14:37.150
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-200006-GLOBEX.dly has a volume of 0 at 2000-03-10. | 2022-04-25 10:14:37.160
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-200006-GLOBEX.dly has a volume of 0 at 2000-06-15. | 2022-04-25 10:14:37.160
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-200003-GLOBEX.dly has a volume of 0 at 1999-12-10. | 2022-04-25 10:14:37.170
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-200003-GLOBEX.dly has a volume of 0 at 2000-03-09. | 2022-04-25 10:14:37.170
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199912-GLOBEX.dly has a volume of 0 at 1999-09-10. | 2022-04-25 10:14:37.180
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199912-GLOBEX.dly has a volume of 0 at 1999-12-09. | 2022-04-25 10:14:37.181
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199909-GLOBEX.dly has a volume of 0 at 1999-06-11. | 2022-04-25 10:14:37.190
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199909-GLOBEX.dly has a volume of 0 at 1999-09-09. | 2022-04-25 10:14:37.190
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199906-GLOBEX.dly has a volume of 0 at 1999-03-12. | 2022-04-25 10:14:37.200
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199906-GLOBEX.dly has a volume of 0 at 1999-06-10. | 2022-04-25 10:14:37.200
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199903-GLOBEX.dly has a volume of 0 at 1998-12-11. | 2022-04-25 10:14:37.210
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199903-GLOBEX.dly has a volume of 0 at 1999-03-11. | 2022-04-25 10:14:37.210
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199812-GLOBEX.dly has a volume of 0 at 1998-09-11. | 2022-04-25 10:14:37.220
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199812-GLOBEX.dly has a volume of 0 at 1998-12-10. | 2022-04-25 10:14:37.220
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199809-GLOBEX.dly has a volume of 0 at 1998-06-12. | 2022-04-25 10:14:37.230
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199809-GLOBEX.dly has a volume of 0 at 1998-09-10. | 2022-04-25 10:14:37.230
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199806-GLOBEX.dly has a volume of 0 at 1998-03-13. | 2022-04-25 10:14:37.239
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199806-GLOBEX.dly has a volume of 0 at 1998-06-11. | 2022-04-25 10:14:37.239
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199803-GLOBEX.dly has a volume of 0 at 1997-12-12. | 2022-04-25 10:14:37.249
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199803-GLOBEX.dly has a volume of 0 at 1998-03-12. | 2022-04-25 10:14:37.249
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199712-GLOBEX.dly has a volume of 0 at 1997-09-12. | 2022-04-25 10:14:37.259
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199712-GLOBEX.dly has a volume of 0 at 1997-12-11. | 2022-04-25 10:14:37.259
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199709-GLOBEX.dly has a volume of 0 at 1997-06-13. | 2022-04-25 10:14:37.270
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199709-GLOBEX.dly has a volume of 0 at 1997-09-11. | 2022-04-25 10:14:37.270
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199706-GLOBEX.dly has a volume of 0 at 1997-03-14. | 2022-04-25 10:14:37.279
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199706-GLOBEX.dly has a volume of 0 at 1997-06-12. | 2022-04-25 10:14:37.279
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199703-GLOBEX.dly has a volume of 0 at 1996-12-13. | 2022-04-25 10:14:37.289
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199703-GLOBEX.dly has a volume of 0 at 1997-03-13. | 2022-04-25 10:14:37.289
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199612-GLOBEX.dly has a volume of 0 at 1996-09-13. | 2022-04-25 10:14:37.299
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199612-GLOBEX.dly has a volume of 0 at 1996-12-12. | 2022-04-25 10:14:37.299
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199609-GLOBEX.dly has a volume of 0 at 1996-06-14. | 2022-04-25 10:14:37.310
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199609-GLOBEX.dly has a volume of 0 at 1996-09-12. | 2022-04-25 10:14:37.310
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199606-GLOBEX.dly has a volume of 0 at 1996-03-15. | 2022-04-25 10:14:37.320
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199606-GLOBEX.dly has a volume of 0 at 1996-06-13. | 2022-04-25 10:14:37.320
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199603-GLOBEX.dly has a volume of 0 at 1995-12-15. | 2022-04-25 10:14:37.330
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199603-GLOBEX.dly has a volume of 0 at 1996-03-14. | 2022-04-25 10:14:37.330
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199512-GLOBEX.dly has a volume of 0 at 1995-09-15. | 2022-04-25 10:14:37.340
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199512-GLOBEX.dly has a volume of 0 at 1995-12-14. | 2022-04-25 10:14:37.340
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199509-GLOBEX.dly has a volume of 0 at 1995-06-16. | 2022-04-25 10:14:37.349
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199509-GLOBEX.dly has a volume of 0 at 1995-09-14. | 2022-04-25 10:14:37.349
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199506-GLOBEX.dly has a volume of 0 at 1995-03-10. | 2022-04-25 10:14:37.360
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199506-GLOBEX.dly has a volume of 0 at 1995-06-15. | 2022-04-25 10:14:37.360
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199503-GLOBEX.dly has a volume of 0 at 1994-12-16. | 2022-04-25 10:14:37.369
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199503-GLOBEX.dly has a volume of 0 at 1995-03-09. | 2022-04-25 10:14:37.369
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199412-GLOBEX.dly has a volume of 0 at 1994-09-16. | 2022-04-25 10:14:37.379
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199412-GLOBEX.dly has a volume of 0 at 1994-12-15. | 2022-04-25 10:14:37.379
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199409-GLOBEX.dly has a volume of 0 at 1994-06-10. | 2022-04-25 10:14:37.389
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199409-GLOBEX.dly has a volume of 0 at 1994-09-15. | 2022-04-25 10:14:37.389
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199406-GLOBEX.dly has a volume of 0 at 1994-03-11. | 2022-04-25 10:14:37.399
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199406-GLOBEX.dly has a volume of 0 at 1994-06-09. | 2022-04-25 10:14:37.399
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199403-GLOBEX.dly has a volume of 0 at 1993-12-10. | 2022-04-25 10:14:37.409
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199403-GLOBEX.dly has a volume of 0 at 1994-03-10. | 2022-04-25 10:14:37.409
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199312-GLOBEX.dly has a volume of 0 at 1993-09-10. | 2022-04-25 10:14:37.419
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199312-GLOBEX.dly has a volume of 0 at 1993-12-09. | 2022-04-25 10:14:37.419
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199309-GLOBEX.dly has a volume of 0 at 1993-06-11. | 2022-04-25 10:14:37.429
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199309-GLOBEX.dly has a volume of 0 at 1993-09-09. | 2022-04-25 10:14:37.429
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199306-GLOBEX.dly has a volume of 0 at 1993-03-12. | 2022-04-25 10:14:37.438
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199306-GLOBEX.dly has a volume of 0 at 1993-06-10. | 2022-04-25 10:14:37.438
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199303-GLOBEX.dly has a volume of 0 at 1992-12-11. | 2022-04-25 10:14:37.448
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199303-GLOBEX.dly has a volume of 0 at 1993-03-11. | 2022-04-25 10:14:37.448
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199212-GLOBEX.dly has a volume of 0 at 1992-09-11. | 2022-04-25 10:14:37.458
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199212-GLOBEX.dly has a volume of 0 at 1992-12-10. | 2022-04-25 10:14:37.458
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199209-GLOBEX.dly has a volume of 0 at 1992-06-12. | 2022-04-25 10:14:37.468
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199209-GLOBEX.dly has a volume of 0 at 1992-09-10. | 2022-04-25 10:14:37.468
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199206-GLOBEX.dly has a volume of 0 at 1992-03-13. | 2022-04-25 10:14:37.477
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199206-GLOBEX.dly has a volume of 0 at 1992-06-11. | 2022-04-25 10:14:37.477
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199203-GLOBEX.dly has a volume of 0 at 1991-12-13. | 2022-04-25 10:14:37.487
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199203-GLOBEX.dly has a volume of 0 at 1992-03-12. | 2022-04-25 10:14:37.487
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199112-GLOBEX.dly has a volume of 0 at 1991-09-13. | 2022-04-25 10:14:37.497
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199112-GLOBEX.dly has a volume of 0 at 1991-12-12. | 2022-04-25 10:14:37.497
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199109-GLOBEX.dly has a volume of 0 at 1991-06-14. | 2022-04-25 10:14:37.507
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199109-GLOBEX.dly has a volume of 0 at 1991-09-12. | 2022-04-25 10:14:37.507
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199106-GLOBEX.dly has a volume of 0 at 1991-03-15. | 2022-04-25 10:14:37.517
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199106-GLOBEX.dly has a volume of 0 at 1991-06-13. | 2022-04-25 10:14:37.517
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199103-GLOBEX.dly has a volume of 0 at 1990-12-14. | 2022-04-25 10:14:37.527
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199103-GLOBEX.dly has a volume of 0 at 1991-03-14. | 2022-04-25 10:14:37.527
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199012-GLOBEX.dly has a volume of 0 at 1990-09-14. | 2022-04-25 10:14:37.537
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199012-GLOBEX.dly has a volume of 0 at 1990-12-13. | 2022-04-25 10:14:37.537
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199009-GLOBEX.dly has a volume of 0 at 1990-06-15. | 2022-04-25 10:14:37.547
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199009-GLOBEX.dly has a volume of 0 at 1990-09-13. | 2022-04-25 10:14:37.547
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199006-GLOBEX.dly has a volume of 0 at 1990-03-16. | 2022-04-25 10:14:37.557
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199006-GLOBEX.dly has a volume of 0 at 1990-06-14. | 2022-04-25 10:14:37.557
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199003-GLOBEX.dly has a volume of 0 at 1989-12-15. | 2022-04-25 10:14:37.566
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199003-GLOBEX.dly has a volume of 0 at 1990-03-15. | 2022-04-25 10:14:37.566
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198912-GLOBEX.dly has a volume of 0 at 1989-09-15. | 2022-04-25 10:14:37.577
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198912-GLOBEX.dly has a volume of 0 at 1989-12-14. | 2022-04-25 10:14:37.577
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198909-GLOBEX.dly has a volume of 0 at 1989-06-16. | 2022-04-25 10:14:37.587
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198909-GLOBEX.dly has a volume of 0 at 1989-09-14. | 2022-04-25 10:14:37.587
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198906-GLOBEX.dly has a volume of 0 at 1989-03-10. | 2022-04-25 10:14:37.597
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198906-GLOBEX.dly has a volume of 0 at 1989-06-15. | 2022-04-25 10:14:37.597
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198903-GLOBEX.dly has a volume of 0 at 1988-12-16. | 2022-04-25 10:14:37.606
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198903-GLOBEX.dly has a volume of 0 at 1989-03-09. | 2022-04-25 10:14:37.606
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198812-GLOBEX.dly has a volume of 0 at 1988-09-16. | 2022-04-25 10:14:37.616
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198812-GLOBEX.dly has a volume of 0 at 1988-12-15. | 2022-04-25 10:14:37.616
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198809-GLOBEX.dly has a volume of 0 at 1988-06-10. | 2022-04-25 10:14:37.627
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198809-GLOBEX.dly has a volume of 0 at 1988-09-15. | 2022-04-25 10:14:37.627
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198806-GLOBEX.dly has a volume of 0 at 1988-03-11. | 2022-04-25 10:14:37.637
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198806-GLOBEX.dly has a volume of 0 at 1988-06-09. | 2022-04-25 10:14:37.637
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198803-GLOBEX.dly has a volume of 0 at 1987-12-11. | 2022-04-25 10:14:37.647
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198803-GLOBEX.dly has a volume of 0 at 1988-03-10. | 2022-04-25 10:14:37.647
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198712-GLOBEX.dly has a volume of 0 at 1987-09-11. | 2022-04-25 10:14:37.657
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198712-GLOBEX.dly has a volume of 0 at 1987-12-10. | 2022-04-25 10:14:37.657
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198709-GLOBEX.dly has a volume of 0 at 1987-06-12. | 2022-04-25 10:14:37.667
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198709-GLOBEX.dly has a volume of 0 at 1987-09-10. | 2022-04-25 10:14:37.667
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198706-GLOBEX.dly has a volume of 0 at 1987-03-13. | 2022-04-25 10:14:37.676
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198706-GLOBEX.dly has a volume of 0 at 1987-06-11. | 2022-04-25 10:14:37.676
AUD-202206-GLOBEX [C] 16 Day #2 | Dates not found while checking for invalid data in continuous contract data files. AUD-198703-GLOBEX | 2022-04-25 10:14:37.683 *
AUD-202206-GLOBEX [C] 16 Day #2 | Waiting for historical downloads to complete with the IDs: 95, 96, | 2022-04-25 10:14:37.683
AUD-202206-GLOBEX [C] 768 Min #4 | Reloading chart. | 2022-04-25 10:14:37.698
AUD-202206-GLOBEX [C] 768 Min #5 | Reloading chart. | 2022-04-25 10:14:37.709
AUD-202206-GLOBEX [C] 384 Min #10 | Reloading chart. | 2022-04-25 10:14:37.720
GBPUSD Daily #12 | Reloading chart. | 2022-04-25 10:14:37.732
GBP-202206-GLOBEX [C] 64 Day #8 | Reloading chart. | 2022-04-25 10:14:37.754
GBP-202206-GLOBEX [C] 64 Day #8 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:37.754
GBP-202206-GLOBEX [C] 64 Day #8 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:37.754
GBP-202206-GLOBEX [C] 64 Day #8 | Performing continuous chart historical Daily data download for symbol GBP-202206-GLOBEX starting at last date in file. | 2022-04-25 10:14:37.966
Added historical Daily data request for GBP-202206-GLOBEX to the queue. | 2022-04-25 10:14:37.966
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-200103-GLOBEX.dly has a volume of 0 at 2000-12-15. | 2022-04-25 10:14:38.937
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-200012-GLOBEX.dly has a volume of 0 at 2000-09-15. | 2022-04-25 10:14:38.947
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-200012-GLOBEX.dly has a volume of 0 at 2000-12-14. | 2022-04-25 10:14:38.947
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-200009-GLOBEX.dly has a volume of 0 at 2000-06-16. | 2022-04-25 10:14:38.957
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-200009-GLOBEX.dly has a volume of 0 at 2000-09-14. | 2022-04-25 10:14:38.957
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-200006-GLOBEX.dly has a volume of 0 at 2000-03-10. | 2022-04-25 10:14:38.968
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-200006-GLOBEX.dly has a volume of 0 at 2000-06-15. | 2022-04-25 10:14:38.968
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-200003-GLOBEX.dly has a volume of 0 at 1999-12-10. | 2022-04-25 10:14:38.978
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-200003-GLOBEX.dly has a volume of 0 at 2000-03-09. | 2022-04-25 10:14:38.978
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199912-GLOBEX.dly has a volume of 0 at 1999-09-10. | 2022-04-25 10:14:38.988
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199912-GLOBEX.dly has a volume of 0 at 1999-12-09. | 2022-04-25 10:14:38.988
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199909-GLOBEX.dly has a volume of 0 at 1999-06-11. | 2022-04-25 10:14:38.998
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199909-GLOBEX.dly has a volume of 0 at 1999-09-09. | 2022-04-25 10:14:38.998
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199906-GLOBEX.dly has a volume of 0 at 1999-03-12. | 2022-04-25 10:14:39.008
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199906-GLOBEX.dly has a volume of 0 at 1999-06-10. | 2022-04-25 10:14:39.008
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199903-GLOBEX.dly has a volume of 0 at 1998-12-11. | 2022-04-25 10:14:39.018
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199903-GLOBEX.dly has a volume of 0 at 1999-03-11. | 2022-04-25 10:14:39.018
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199812-GLOBEX.dly has a volume of 0 at 1998-09-11. | 2022-04-25 10:14:39.028
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199812-GLOBEX.dly has a volume of 0 at 1998-12-10. | 2022-04-25 10:14:39.028
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199809-GLOBEX.dly has a volume of 0 at 1998-06-12. | 2022-04-25 10:14:39.038
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199809-GLOBEX.dly has a volume of 0 at 1998-09-10. | 2022-04-25 10:14:39.038
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199806-GLOBEX.dly has a volume of 0 at 1998-03-13. | 2022-04-25 10:14:39.048
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199806-GLOBEX.dly has a volume of 0 at 1998-06-11. | 2022-04-25 10:14:39.048
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199803-GLOBEX.dly has a volume of 0 at 1997-12-12. | 2022-04-25 10:14:39.058
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199803-GLOBEX.dly has a volume of 0 at 1998-03-12. | 2022-04-25 10:14:39.058
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199712-GLOBEX.dly has a volume of 0 at 1997-09-12. | 2022-04-25 10:14:39.069
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199712-GLOBEX.dly has a volume of 0 at 1997-12-11. | 2022-04-25 10:14:39.069
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199709-GLOBEX.dly has a volume of 0 at 1997-06-13. | 2022-04-25 10:14:39.079
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199709-GLOBEX.dly has a volume of 0 at 1997-09-11. | 2022-04-25 10:14:39.079
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199706-GLOBEX.dly has a volume of 0 at 1997-03-14. | 2022-04-25 10:14:39.089
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199706-GLOBEX.dly has a volume of 0 at 1997-06-12. | 2022-04-25 10:14:39.089
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199703-GLOBEX.dly has a volume of 0 at 1996-12-13. | 2022-04-25 10:14:39.099
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199703-GLOBEX.dly has a volume of 0 at 1997-03-13. | 2022-04-25 10:14:39.099
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199612-GLOBEX.dly has a volume of 0 at 1996-09-13. | 2022-04-25 10:14:39.109
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199612-GLOBEX.dly has a volume of 0 at 1996-12-12. | 2022-04-25 10:14:39.109
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199609-GLOBEX.dly has a volume of 0 at 1996-06-14. | 2022-04-25 10:14:39.120
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199609-GLOBEX.dly has a volume of 0 at 1996-09-12. | 2022-04-25 10:14:39.120
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199606-GLOBEX.dly has a volume of 0 at 1996-03-15. | 2022-04-25 10:14:39.130
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199606-GLOBEX.dly has a volume of 0 at 1996-06-13. | 2022-04-25 10:14:39.130
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199603-GLOBEX.dly has a volume of 0 at 1995-12-15. | 2022-04-25 10:14:39.140
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199603-GLOBEX.dly has a volume of 0 at 1996-03-14. | 2022-04-25 10:14:39.140
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199512-GLOBEX.dly has a volume of 0 at 1995-09-15. | 2022-04-25 10:14:39.150
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199512-GLOBEX.dly has a volume of 0 at 1995-12-14. | 2022-04-25 10:14:39.150
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199509-GLOBEX.dly has a volume of 0 at 1995-06-16. | 2022-04-25 10:14:39.159
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199509-GLOBEX.dly has a volume of 0 at 1995-09-14. | 2022-04-25 10:14:39.159
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199506-GLOBEX.dly has a volume of 0 at 1995-03-10. | 2022-04-25 10:14:39.170
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199506-GLOBEX.dly has a volume of 0 at 1995-06-15. | 2022-04-25 10:14:39.170
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199503-GLOBEX.dly has a volume of 0 at 1994-12-16. | 2022-04-25 10:14:39.179
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199503-GLOBEX.dly has a volume of 0 at 1995-03-09. | 2022-04-25 10:14:39.179
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199412-GLOBEX.dly has a volume of 0 at 1994-09-16. | 2022-04-25 10:14:39.189
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199412-GLOBEX.dly has a volume of 0 at 1994-12-15. | 2022-04-25 10:14:39.189
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199409-GLOBEX.dly has a volume of 0 at 1994-06-10. | 2022-04-25 10:14:39.200
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199409-GLOBEX.dly has a volume of 0 at 1994-09-15. | 2022-04-25 10:14:39.200
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199406-GLOBEX.dly has a volume of 0 at 1994-03-11. | 2022-04-25 10:14:39.210
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199406-GLOBEX.dly has a volume of 0 at 1994-06-09. | 2022-04-25 10:14:39.210
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199403-GLOBEX.dly has a volume of 0 at 1993-12-10. | 2022-04-25 10:14:39.219
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199403-GLOBEX.dly has a volume of 0 at 1994-03-10. | 2022-04-25 10:14:39.219
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199312-GLOBEX.dly has a volume of 0 at 1993-09-10. | 2022-04-25 10:14:39.230
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199312-GLOBEX.dly has a volume of 0 at 1993-12-09. | 2022-04-25 10:14:39.230
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199309-GLOBEX.dly has a volume of 0 at 1993-06-11. | 2022-04-25 10:14:39.239
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199309-GLOBEX.dly has a volume of 0 at 1993-09-09. | 2022-04-25 10:14:39.239
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199306-GLOBEX.dly has a volume of 0 at 1993-03-12. | 2022-04-25 10:14:39.249
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199306-GLOBEX.dly has a volume of 0 at 1993-06-10. | 2022-04-25 10:14:39.249
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199303-GLOBEX.dly has a volume of 0 at 1992-12-11. | 2022-04-25 10:14:39.259
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199303-GLOBEX.dly has a volume of 0 at 1993-03-11. | 2022-04-25 10:14:39.259
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199212-GLOBEX.dly has a volume of 0 at 1992-09-11. | 2022-04-25 10:14:39.269
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199212-GLOBEX.dly has a volume of 0 at 1992-12-10. | 2022-04-25 10:14:39.269
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199209-GLOBEX.dly has a volume of 0 at 1992-06-12. | 2022-04-25 10:14:39.278
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199209-GLOBEX.dly has a volume of 0 at 1992-09-10. | 2022-04-25 10:14:39.278
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199206-GLOBEX.dly has a volume of 0 at 1992-03-13. | 2022-04-25 10:14:39.288
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199206-GLOBEX.dly has a volume of 0 at 1992-06-11. | 2022-04-25 10:14:39.288
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199203-GLOBEX.dly has a volume of 0 at 1991-12-13. | 2022-04-25 10:14:39.298
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199203-GLOBEX.dly has a volume of 0 at 1992-03-12. | 2022-04-25 10:14:39.298
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199112-GLOBEX.dly has a volume of 0 at 1991-09-13. | 2022-04-25 10:14:39.308
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199112-GLOBEX.dly has a volume of 0 at 1991-12-12. | 2022-04-25 10:14:39.308
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199109-GLOBEX.dly has a volume of 0 at 1991-06-14. | 2022-04-25 10:14:39.318
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199109-GLOBEX.dly has a volume of 0 at 1991-09-12. | 2022-04-25 10:14:39.318
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199106-GLOBEX.dly has a volume of 0 at 1991-03-15. | 2022-04-25 10:14:39.327
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199106-GLOBEX.dly has a volume of 0 at 1991-06-13. | 2022-04-25 10:14:39.327
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199103-GLOBEX.dly has a volume of 0 at 1990-12-14. | 2022-04-25 10:14:39.337
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199103-GLOBEX.dly has a volume of 0 at 1991-03-14. | 2022-04-25 10:14:39.337
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199012-GLOBEX.dly has a volume of 0 at 1990-09-14. | 2022-04-25 10:14:39.347
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199012-GLOBEX.dly has a volume of 0 at 1990-12-13. | 2022-04-25 10:14:39.347
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199009-GLOBEX.dly has a volume of 0 at 1990-06-15. | 2022-04-25 10:14:39.357
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199009-GLOBEX.dly has a volume of 0 at 1990-09-13. | 2022-04-25 10:14:39.357
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199006-GLOBEX.dly has a volume of 0 at 1990-03-16. | 2022-04-25 10:14:39.367
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199006-GLOBEX.dly has a volume of 0 at 1990-06-14. | 2022-04-25 10:14:39.367
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199003-GLOBEX.dly has a volume of 0 at 1989-12-15. | 2022-04-25 10:14:39.376
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199003-GLOBEX.dly has a volume of 0 at 1990-03-15. | 2022-04-25 10:14:39.376
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198912-GLOBEX.dly has a volume of 0 at 1989-09-15. | 2022-04-25 10:14:39.386
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198912-GLOBEX.dly has a volume of 0 at 1989-12-14. | 2022-04-25 10:14:39.386
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198909-GLOBEX.dly has a volume of 0 at 1989-06-16. | 2022-04-25 10:14:39.396
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198909-GLOBEX.dly has a volume of 0 at 1989-09-14. | 2022-04-25 10:14:39.396
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198906-GLOBEX.dly has a volume of 0 at 1989-03-10. | 2022-04-25 10:14:39.406
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198906-GLOBEX.dly has a volume of 0 at 1989-06-15. | 2022-04-25 10:14:39.406
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198903-GLOBEX.dly has a volume of 0 at 1988-12-16. | 2022-04-25 10:14:39.415
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198903-GLOBEX.dly has a volume of 0 at 1989-03-09. | 2022-04-25 10:14:39.415
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198812-GLOBEX.dly has a volume of 0 at 1988-09-16. | 2022-04-25 10:14:39.425
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198812-GLOBEX.dly has a volume of 0 at 1988-12-15. | 2022-04-25 10:14:39.425
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198809-GLOBEX.dly has a volume of 0 at 1988-06-10. | 2022-04-25 10:14:39.436
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198809-GLOBEX.dly has a volume of 0 at 1988-09-15. | 2022-04-25 10:14:39.436
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198806-GLOBEX.dly has a volume of 0 at 1988-03-11. | 2022-04-25 10:14:39.445
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198806-GLOBEX.dly has a volume of 0 at 1988-06-09. | 2022-04-25 10:14:39.445
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198803-GLOBEX.dly has a volume of 0 at 1987-12-11. | 2022-04-25 10:14:39.455
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198803-GLOBEX.dly has a volume of 0 at 1988-03-10. | 2022-04-25 10:14:39.455
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198712-GLOBEX.dly has a volume of 0 at 1987-09-11. | 2022-04-25 10:14:39.465
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198712-GLOBEX.dly has a volume of 0 at 1987-12-10. | 2022-04-25 10:14:39.465
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198709-GLOBEX.dly has a volume of 0 at 1987-06-12. | 2022-04-25 10:14:39.475
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198709-GLOBEX.dly has a volume of 0 at 1987-09-10. | 2022-04-25 10:14:39.475
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198706-GLOBEX.dly has a volume of 0 at 1987-03-13. | 2022-04-25 10:14:39.484
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198706-GLOBEX.dly has a volume of 0 at 1987-06-11. | 2022-04-25 10:14:39.484
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198703-GLOBEX.dly has a volume of 0 at 1986-12-12. | 2022-04-25 10:14:39.494
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198703-GLOBEX.dly has a volume of 0 at 1987-03-12. | 2022-04-25 10:14:39.494
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198612-GLOBEX.dly has a volume of 0 at 1986-09-12. | 2022-04-25 10:14:39.504
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198612-GLOBEX.dly has a volume of 0 at 1986-12-11. | 2022-04-25 10:14:39.504
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198609-GLOBEX.dly has a volume of 0 at 1986-06-13. | 2022-04-25 10:14:39.514
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198609-GLOBEX.dly has a volume of 0 at 1986-09-11. | 2022-04-25 10:14:39.514
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198606-GLOBEX.dly has a volume of 0 at 1986-03-14. | 2022-04-25 10:14:39.524
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198606-GLOBEX.dly has a volume of 0 at 1986-06-12. | 2022-04-25 10:14:39.524
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198603-GLOBEX.dly has a volume of 0 at 1985-12-13. | 2022-04-25 10:14:39.534
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198603-GLOBEX.dly has a volume of 0 at 1986-03-13. | 2022-04-25 10:14:39.534
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198512-GLOBEX.dly has a volume of 0 at 1985-09-13. | 2022-04-25 10:14:39.544
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198512-GLOBEX.dly has a volume of 0 at 1985-12-12. | 2022-04-25 10:14:39.544
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198509-GLOBEX.dly has a volume of 0 at 1985-06-14. | 2022-04-25 10:14:39.553
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198509-GLOBEX.dly has a volume of 0 at 1985-09-12. | 2022-04-25 10:14:39.553
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198506-GLOBEX.dly has a volume of 0 at 1985-03-15. | 2022-04-25 10:14:39.563
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198506-GLOBEX.dly has a volume of 0 at 1985-06-13. | 2022-04-25 10:14:39.563
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198503-GLOBEX.dly has a volume of 0 at 1984-12-14. | 2022-04-25 10:14:39.573
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198503-GLOBEX.dly has a volume of 0 at 1985-03-14. | 2022-04-25 10:14:39.573
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198412-GLOBEX.dly has a volume of 0 at 1984-09-14. | 2022-04-25 10:14:39.583
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198412-GLOBEX.dly has a volume of 0 at 1984-12-13. | 2022-04-25 10:14:39.583
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198409-GLOBEX.dly has a volume of 0 at 1984-06-15. | 2022-04-25 10:14:39.593
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198409-GLOBEX.dly has a volume of 0 at 1984-09-13. | 2022-04-25 10:14:39.593
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198406-GLOBEX.dly has a volume of 0 at 1984-03-16. | 2022-04-25 10:14:39.602
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198406-GLOBEX.dly has a volume of 0 at 1984-06-14. | 2022-04-25 10:14:39.602
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198403-GLOBEX.dly has a volume of 0 at 1983-12-16. | 2022-04-25 10:14:39.612
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198403-GLOBEX.dly has a volume of 0 at 1984-03-15. | 2022-04-25 10:14:39.612
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198312-GLOBEX.dly has a volume of 0 at 1983-09-16. | 2022-04-25 10:14:39.622
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198312-GLOBEX.dly has a volume of 0 at 1983-12-15. | 2022-04-25 10:14:39.622
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198309-GLOBEX.dly has a volume of 0 at 1983-06-10. | 2022-04-25 10:14:39.632
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198309-GLOBEX.dly has a volume of 0 at 1983-09-15. | 2022-04-25 10:14:39.632
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198306-GLOBEX.dly has a volume of 0 at 1983-03-11. | 2022-04-25 10:14:39.642
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198306-GLOBEX.dly has a volume of 0 at 1983-06-09. | 2022-04-25 10:14:39.642
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198303-GLOBEX.dly has a volume of 0 at 1982-12-10. | 2022-04-25 10:14:39.652
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198303-GLOBEX.dly has a volume of 0 at 1983-03-10. | 2022-04-25 10:14:39.652
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198212-GLOBEX.dly has a volume of 0 at 1982-09-10. | 2022-04-25 10:14:39.662
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198212-GLOBEX.dly has a volume of 0 at 1982-12-09. | 2022-04-25 10:14:39.662
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198209-GLOBEX.dly has a volume of 0 at 1982-06-11. | 2022-04-25 10:14:39.672
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198209-GLOBEX.dly has a volume of 0 at 1982-09-09. | 2022-04-25 10:14:39.672
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198206-GLOBEX.dly has a volume of 0 at 1982-03-12. | 2022-04-25 10:14:39.681
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198206-GLOBEX.dly has a volume of 0 at 1982-06-10. | 2022-04-25 10:14:39.681
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198203-GLOBEX.dly has a volume of 0 at 1981-12-11. | 2022-04-25 10:14:39.691
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198203-GLOBEX.dly has a volume of 0 at 1982-03-11. | 2022-04-25 10:14:39.691
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198112-GLOBEX.dly has a volume of 0 at 1981-09-11. | 2022-04-25 10:14:39.701
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198112-GLOBEX.dly has a volume of 0 at 1981-12-10. | 2022-04-25 10:14:39.701
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198109-GLOBEX.dly has a volume of 0 at 1981-06-12. | 2022-04-25 10:14:39.711
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198109-GLOBEX.dly has a volume of 0 at 1981-09-10. | 2022-04-25 10:14:39.711
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198106-GLOBEX.dly has a volume of 0 at 1981-03-13. | 2022-04-25 10:14:39.721
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198106-GLOBEX.dly has a volume of 0 at 1981-06-11. | 2022-04-25 10:14:39.721
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198103-GLOBEX.dly has a volume of 0 at 1980-12-12. | 2022-04-25 10:14:39.730
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198103-GLOBEX.dly has a volume of 0 at 1981-03-12. | 2022-04-25 10:14:39.730
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198012-GLOBEX.dly has a volume of 0 at 1980-09-12. | 2022-04-25 10:14:39.740
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198012-GLOBEX.dly has a volume of 0 at 1980-12-11. | 2022-04-25 10:14:39.740
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198009-GLOBEX.dly has a volume of 0 at 1980-06-13. | 2022-04-25 10:14:39.750
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198009-GLOBEX.dly has a volume of 0 at 1980-09-11. | 2022-04-25 10:14:39.750
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198006-GLOBEX.dly has a volume of 0 at 1980-03-14. | 2022-04-25 10:14:39.760
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198006-GLOBEX.dly has a volume of 0 at 1980-06-12. | 2022-04-25 10:14:39.760
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198003-GLOBEX.dly has a volume of 0 at 1979-12-14. | 2022-04-25 10:14:39.769
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198003-GLOBEX.dly has a volume of 0 at 1980-03-13. | 2022-04-25 10:14:39.769
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197912-GLOBEX.dly has a volume of 0 at 1979-09-14. | 2022-04-25 10:14:39.780
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197912-GLOBEX.dly has a volume of 0 at 1979-12-13. | 2022-04-25 10:14:39.780
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197909-GLOBEX.dly has a volume of 0 at 1979-06-15. | 2022-04-25 10:14:39.790
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197909-GLOBEX.dly has a volume of 0 at 1979-09-13. | 2022-04-25 10:14:39.790
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197906-GLOBEX.dly has a volume of 0 at 1979-03-16. | 2022-04-25 10:14:39.800
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197906-GLOBEX.dly has a volume of 0 at 1979-06-14. | 2022-04-25 10:14:39.800
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197903-GLOBEX.dly has a volume of 0 at 1978-12-15. | 2022-04-25 10:14:39.810
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197903-GLOBEX.dly has a volume of 0 at 1979-03-15. | 2022-04-25 10:14:39.810
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197812-GLOBEX.dly has a volume of 0 at 1978-09-15. | 2022-04-25 10:14:39.820
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197812-GLOBEX.dly has a volume of 0 at 1978-12-14. | 2022-04-25 10:14:39.820
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197809-GLOBEX.dly has a volume of 0 at 1978-06-16. | 2022-04-25 10:14:39.830
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197809-GLOBEX.dly has a volume of 0 at 1978-09-14. | 2022-04-25 10:14:39.830
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197806-GLOBEX.dly has a volume of 0 at 1978-03-10. | 2022-04-25 10:14:39.840
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197806-GLOBEX.dly has a volume of 0 at 1978-06-15. | 2022-04-25 10:14:39.840
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197803-GLOBEX.dly has a volume of 0 at 1977-12-16. | 2022-04-25 10:14:39.849
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197803-GLOBEX.dly has a volume of 0 at 1978-03-09. | 2022-04-25 10:14:39.849
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197712-GLOBEX.dly has a volume of 0 at 1977-09-16. | 2022-04-25 10:14:39.859
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197712-GLOBEX.dly has a volume of 0 at 1977-12-15. | 2022-04-25 10:14:39.859
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197709-GLOBEX.dly has a volume of 0 at 1977-06-10. | 2022-04-25 10:14:39.870
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197709-GLOBEX.dly has a volume of 0 at 1977-09-15. | 2022-04-25 10:14:39.870
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197706-GLOBEX.dly has a volume of 0 at 1977-03-11. | 2022-04-25 10:14:39.880
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197706-GLOBEX.dly has a volume of 0 at 1977-06-09. | 2022-04-25 10:14:39.880
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197703-GLOBEX.dly has a volume of 0 at 1976-12-10. | 2022-04-25 10:14:39.889
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197703-GLOBEX.dly has a volume of 0 at 1977-03-10. | 2022-04-25 10:14:39.889
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197612-GLOBEX.dly has a volume of 0 at 1976-09-10. | 2022-04-25 10:14:39.899
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197612-GLOBEX.dly has a volume of 0 at 1976-12-09. | 2022-04-25 10:14:39.899
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197609-GLOBEX.dly has a volume of 0 at 1976-06-11. | 2022-04-25 10:14:39.909
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197609-GLOBEX.dly has a volume of 0 at 1976-09-09. | 2022-04-25 10:14:39.909
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197606-GLOBEX.dly has a volume of 0 at 1976-03-12. | 2022-04-25 10:14:39.919
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197606-GLOBEX.dly has a volume of 0 at 1976-06-10. | 2022-04-25 10:14:39.919
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197603-GLOBEX.dly has a volume of 0 at 1975-12-12. | 2022-04-25 10:14:39.928
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197603-GLOBEX.dly has a volume of 0 at 1976-03-11. | 2022-04-25 10:14:39.928
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197512-GLOBEX.dly has a volume of 0 at 1975-09-12. | 2022-04-25 10:14:39.938
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197512-GLOBEX.dly has a volume of 0 at 1975-12-11. | 2022-04-25 10:14:39.938
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197509-GLOBEX.dly has a volume of 0 at 1975-06-13. | 2022-04-25 10:14:39.948
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197509-GLOBEX.dly has a volume of 0 at 1975-09-11. | 2022-04-25 10:14:39.948
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197506-GLOBEX.dly has a volume of 0 at 1975-03-14. | 2022-04-25 10:14:39.958
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197506-GLOBEX.dly has a volume of 0 at 1975-06-12. | 2022-04-25 10:14:39.958
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197503-GLOBEX.dly has a volume of 0 at 1974-12-13. | 2022-04-25 10:14:39.967
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197503-GLOBEX.dly has a volume of 0 at 1975-03-13. | 2022-04-25 10:14:39.967
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197412-GLOBEX.dly has a volume of 0 at 1974-09-13. | 2022-04-25 10:14:39.977
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197412-GLOBEX.dly has a volume of 0 at 1974-12-12. | 2022-04-25 10:14:39.977
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197409-GLOBEX.dly has a volume of 0 at 1974-06-14. | 2022-04-25 10:14:39.987
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197409-GLOBEX.dly has a volume of 0 at 1974-09-12. | 2022-04-25 10:14:39.987
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197406-GLOBEX.dly has a volume of 0 at 1974-03-15. | 2022-04-25 10:14:39.997
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197406-GLOBEX.dly has a volume of 0 at 1974-06-13. | 2022-04-25 10:14:39.997
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197403-GLOBEX.dly has a volume of 0 at 1973-12-14. | 2022-04-25 10:14:40.006
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197403-GLOBEX.dly has a volume of 0 at 1974-03-14. | 2022-04-25 10:14:40.006
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197312-GLOBEX.dly has a volume of 0 at 1973-09-14. | 2022-04-25 10:14:40.016
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197312-GLOBEX.dly has a volume of 0 at 1973-12-13. | 2022-04-25 10:14:40.016
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197309-GLOBEX.dly has a volume of 0 at 1973-06-15. | 2022-04-25 10:14:40.026
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197309-GLOBEX.dly has a volume of 0 at 1973-09-13. | 2022-04-25 10:14:40.026
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197306-GLOBEX.dly has a volume of 0 at 1973-03-16. | 2022-04-25 10:14:40.036
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197306-GLOBEX.dly has a volume of 0 at 1973-06-14. | 2022-04-25 10:14:40.036
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197303-GLOBEX.dly has a volume of 0 at 1972-12-15. | 2022-04-25 10:14:40.046
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197303-GLOBEX.dly has a volume of 0 at 1973-03-15. | 2022-04-25 10:14:40.046
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197212-GLOBEX.dly has a volume of 0 at 1972-09-15. | 2022-04-25 10:14:40.055
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197212-GLOBEX.dly has a volume of 0 at 1972-12-14. | 2022-04-25 10:14:40.055
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197209-GLOBEX.dly has a volume of 0 at 1972-06-16. | 2022-04-25 10:14:40.065
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197209-GLOBEX.dly has a volume of 0 at 1972-09-14. | 2022-04-25 10:14:40.065
GBP-202206-GLOBEX [C] 64 Day #8 | Waiting for historical downloads to complete with the IDs: 97, | 2022-04-25 10:14:40.081
GBP-202206-GLOBEX 96 Min #9 | Reloading chart. | 2022-04-25 10:14:40.098
Files to Open on Startup | Opening file: AAA.Cht | 2022-04-25 10:14:40.105
SPY-NQTV 2 Day #1 | Reloading chart. | 2022-04-25 10:14:40.134
AJG-NQTV 8 Day #19 | Reloading chart. | 2022-04-25 10:14:40.146
ACHC-NQTV 8 Day #11 | Reloading chart. | 2022-04-25 10:14:40.158
AMX-NQTV 2 Day #20 | Reloading chart. | 2022-04-25 10:14:40.179
Loading DLL: C:\SierraChart\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ffd07290000 | 2022-04-25 10:14:40.188
AMX-NQTV 256 Min #3 | Reloading chart. | 2022-04-25 10:14:40.192
AMH-NQTV 4 Day #6 | Reloading chart. | 2022-04-25 10:14:40.202
ACRS-NQTV/ACRSn-CFD-SMART-USD 2 Day #2 | Reloading chart. | 2022-04-25 10:14:40.214
ACRS-NQTV/ACRSn-CFD-SMART-USD 32 Min #8 | Reloading chart. | 2022-04-25 10:14:40.225
AMR-NQTV Daily #5 | Reloading chart. | 2022-04-25 10:14:40.237
AA-NQTV Daily #9 | Reloading chart. | 2022-04-25 10:14:40.248
AA-NQTV 128 Min #4 | Reloading chart. | 2022-04-25 10:14:40.259
Files to Open on Startup | Opening file: BBB.Cht | 2022-04-25 10:14:40.266
SPY-NQTV 2 Day #1 | Reloading chart. | 2022-04-25 10:14:40.360
BJ-NQTV 4 Day #2 | Reloading chart. | 2022-04-25 10:14:40.371
BJ-NQTV 128 Min #7 | Reloading chart. | 2022-04-25 10:14:40.392
Files to Open on Startup | Opening file: CCC.Cht | 2022-04-25 10:14:40.400
SPY-NQTV Daily #1 | Reloading chart. | 2022-04-25 10:14:40.418
CLH-NQTV 2 Day #8 | Reloading chart. | 2022-04-25 10:14:40.431
CLH-NQTV 2 Day #3 | Reloading chart. | 2022-04-25 10:14:40.443
CLH-NQTV/CLHn-CFD-SMART-USD 64 Min #4 | Reloading chart. | 2022-04-25 10:14:40.455
CUBE-NQTV 4 Day #10 | Reloading chart. | 2022-04-25 10:14:40.466
CUBE-NQTV 256 Min #5 | Reloading chart. | 2022-04-25 10:14:40.477
COST-NQTV 4 Day #12 | Reloading chart. | 2022-04-25 10:14:40.489
COST-NQTV 4 Min #2 | Reloading chart. | 2022-04-25 10:14:40.501
CALM-NQTV Daily #6 | Reloading chart. | 2022-04-25 10:14:40.524
CALM-NQTV 256 Min #7 | Reloading chart. | 2022-04-25 10:14:40.536
Files to Open on Startup | Opening file: DDD.Cht | 2022-04-25 10:14:40.543
Loading DLL: C:\SierraChart\Data\PocketPivots.dll (PocketPivots_64.dll). Handle: 7ffd312f0000 | 2022-04-25 10:14:40.570
Loading DLL: C:\SierraChart\Data\TDIndicators.dll (TDIndicators_64.dll). Handle: 7ffd311e0000 | 2022-04-25 10:14:40.573
SPY-NQTV Daily #1 | Reloading chart. | 2022-04-25 10:14:40.580
DAR-NQTV 16 Day #6 | Reloading chart. | 2022-04-25 10:14:40.592
DRE-NQTV 4 Day #2 | Reloading chart. | 2022-04-25 10:14:40.605
DRE-NQTV 2 Day #3 | Reloading chart. | 2022-04-25 10:14:40.618
DKL-NQTV 8 Day #4 | Reloading chart. | 2022-04-25 10:14:40.641
Files to Open on Startup | Opening file: EEE.Cht | 2022-04-25 10:14:40.648
SPY-NQTV Daily #1 | Reloading chart. | 2022-04-25 10:14:40.670
EVH-NQTV 2 Day #10 | Reloading chart. | 2022-04-25 10:14:40.692
EVH-NQTV 128 Min #5 | Reloading chart. | 2022-04-25 10:14:40.703
EW-NQTV 4 Day #19 | Reloading chart. | 2022-04-25 10:14:40.714
EXR-NQTV 4 Day #6 | Reloading chart. | 2022-04-25 10:14:40.726
EXR-NQTV 256 Min #2 | Reloading chart. | 2022-04-25 10:14:40.737
Files to Open on Startup | Opening file: FFF.Cht | 2022-04-25 10:14:40.744
SPY-NQTV 2 Day #1 | Reloading chart. | 2022-04-25 10:14:40.801
FWONK-NQTV 16 Day #3 | Reloading chart. | 2022-04-25 10:14:40.813
FWONK-NQTV 128 Min #2 | Reloading chart. | 2022-04-25 10:14:40.824
FR-NQTV 8 Day #4 | Reloading chart. | 2022-04-25 10:14:40.847
FR-NQTV 256 Min #5 | Reloading chart. | 2022-04-25 10:14:40.858
Files to Open on Startup | Opening file: GGG.Cht | 2022-04-25 10:14:40.865
SPY-NQTV Daily #1 | Reloading chart. | 2022-04-25 10:14:40.895
GCBC-NQTV 2 Day #2 | Reloading chart. | 2022-04-25 10:14:40.906
GCBC-NQTV 256 Min #3 | Reloading chart. | 2022-04-25 10:14:40.917
GNK-NQTV 8 Day #4 | Reloading chart. | 2022-04-25 10:14:40.927
GNK-NQTV 256 Min #6 | Reloading chart. | 2022-04-25 10:14:40.949
Files to Open on Startup | Opening file: HHH.Cht | 2022-04-25 10:14:40.955
SPY-NQTV 2 Day #1 | Reloading chart. | 2022-04-25 10:14:40.976
HESM Daily #7 | Reloading chart. | 2022-04-25 10:14:40.988
HESM-NQTV/HESMn-CFD-SMART-USD Daily #8 | Reloading chart. | 2022-04-25 10:14:41.009
Enabling compression for file: C:\SierraChart\Data\HESM-NQTV.dly. This may take a while. | 2022-04-25 10:14:41.010
File compression enabled. C:\SierraChart\Data\HESM-NQTV.dly. CompressionState=0 | 2022-04-25 10:14:41.010
HESM-NQTV/HESMn-CFD-SMART-USD 120 Min #11 | Reloading chart. | 2022-04-25 10:14:41.019
HCC-NQTV Daily #3 | Reloading chart. | 2022-04-25 10:14:41.029
HCC-NQTV 64 Min #5 | Reloading chart. | 2022-04-25 10:14:41.040
HZNP-NQTV 4 Day #2 | Reloading chart. | 2022-04-25 10:14:41.052
HCA-NQTV 16 Day #6 | Reloading chart. | 2022-04-25 10:14:41.065
Files to Open on Startup | Opening file: III.Cht | 2022-04-25 10:14:41.073
SPY-NQTV Daily #1 | Reloading chart. | 2022-04-25 10:14:41.141
IT-NQTV 16 Day #2 | Reloading chart. | 2022-04-25 10:14:41.163
Files to Open on Startup | Opening file: KKK.Cht | 2022-04-25 10:14:41.170
SPY-NQTV 4 Day #1 | Reloading chart. | 2022-04-25 10:14:41.189
KO-NQTV 4 Day #4 | Reloading chart. | 2022-04-25 10:14:41.210
KO-NQTV 256 Min #2 | Reloading chart. | 2022-04-25 10:14:41.221
Files to Open on Startup | Opening file: LLL.Cht | 2022-04-25 10:14:41.227
SPY-NQTV Daily #1 | Reloading chart. | 2022-04-25 10:14:41.256
LLY-NQTV 4 Day #5 | Reloading chart. | 2022-04-25 10:14:41.268
LAC-NQTV Daily #2 | Reloading chart. | 2022-04-25 10:14:41.279
LAC-NQTV 128 Min #3 | Reloading chart. | 2022-04-25 10:14:41.290
LSI-NQTV 4 Day #4 | Reloading chart. | 2022-04-25 10:14:41.311
Files to Open on Startup | Opening file: MMM.Cht | 2022-04-25 10:14:41.319
SPY-NQTV 16 Day #1 | Reloading chart. | 2022-04-25 10:14:41.340
MGP-NQTV 4 Day #2 | Reloading chart. | 2022-04-25 10:14:41.362
Files to Open on Startup | Opening file: NNN.Cht | 2022-04-25 10:14:41.369
SPY-NQTV Daily #1 | Reloading chart. | 2022-04-25 10:14:41.394
NEM-NQTV 8 Day #10 | Reloading chart. | 2022-04-25 10:14:41.407
NSA-NQTV 4 Day #2 | Reloading chart. | 2022-04-25 10:14:41.429
NVO-NQTV 2 Day #3 | Reloading chart. | 2022-04-25 10:14:41.442
Files to Open on Startup | Opening file: OOO.Cht | 2022-04-25 10:14:41.450
SPY-NQTV 4 Day #1 | Reloading chart. | 2022-04-25 10:14:41.478
ORLY-NQTV 4 Day #2 | Reloading chart. | 2022-04-25 10:14:41.489
ORLY-NQTV 256 Min #3 | Reloading chart. | 2022-04-25 10:14:41.500
OLN-NQTV 8 Day #4 | Reloading chart. | 2022-04-25 10:14:41.523
Files to Open on Startup | Opening file: PPP.Cht | 2022-04-25 10:14:41.530
SPY-NQTV 4 Day #1 | Reloading chart. | 2022-04-25 10:14:41.551
PFE-NQTV Daily #3 | Reloading chart. | 2022-04-25 10:14:41.563
PFE-NQTV 256 Min #5 | Reloading chart. | 2022-04-25 10:14:41.574
PFG-NQTV 64 Day #14 | Reloading chart. | 2022-04-25 10:14:41.585
PFG-NQTV 256 Min #6 | Reloading chart. | 2022-04-25 10:14:41.597
PAYX-NQTV 8 Day #2 | Reloading chart. | 2022-04-25 10:14:41.608
PWR-NQTV 4 Day #4 | Reloading chart. | 2022-04-25 10:14:41.620
PG-NQTV 4 Day #7 | Reloading chart. | 2022-04-25 10:14:41.633
PLD-NQTV 2 Day #8 | Reloading chart. | 2022-04-25 10:14:41.659
Files to Open on Startup | Opening file: RRR.Cht | 2022-04-25 10:14:41.667
SPY-NQTV 128 Day #1 | Reloading chart. | 2022-04-25 10:14:41.702
REXR-NQTV Daily #6 | Reloading chart. | 2022-04-25 10:14:41.716
REXR-NQTV 256 Min #3 | Reloading chart. | 2022-04-25 10:14:41.727
RADA-NQTV 16 Day #2 | Reloading chart. | 2022-04-25 10:14:41.738
Files to Open on Startup | Opening file: SSS.Cht | 2022-04-25 10:14:41.745
SPY-NQTV Daily #1 | Reloading chart. | 2022-04-25 10:14:41.796
SWCH-NQTV Daily #3 | Reloading chart. | 2022-04-25 10:14:41.808
SMPL-NQTV 4 Day #4 | Reloading chart. | 2022-04-25 10:14:41.832
STLD-NQTV 4 Day #2 | Reloading chart. | 2022-04-25 10:14:41.844
Files to Open on Startup | Opening file: TTT.Cht | 2022-04-25 10:14:41.851
SPY-NQTV 256 Min #1 | Reloading chart. | 2022-04-25 10:14:41.892
TXT-NQTV 2 Day #13 | Reloading chart. | 2022-04-25 10:14:41.904
TSN-NQTV 4 Day #7 | Reloading chart. | 2022-04-25 10:14:41.917
TSN-NQTV 256 Min #3 | Reloading chart. | 2022-04-25 10:14:41.927
TSLA-NQTV 4 Day #2 | Reloading chart. | 2022-04-25 10:14:41.940
TSLA-NQTV 256 Min #10 | Reloading chart. | 2022-04-25 10:14:41.951
TMST-NQTV Daily #4 | Reloading chart. | 2022-04-25 10:14:41.962
TMST-NQTV 256 Min #8 | Reloading chart. | 2022-04-25 10:14:41.974
TNET-NQTV 4 Day #6 | Reloading chart. | 2022-04-25 10:14:41.986
TNET-NQTV 256 Min #9 | Reloading chart. | 2022-04-25 10:14:41.999
Files to Open on Startup | Opening file: UUU.Cht | 2022-04-25 10:14:42.006
SPY-NQTV Daily #1 | Reloading chart. | 2022-04-25 10:14:42.133
Files to Open on Startup | Opening file: VVV.Cht | 2022-04-25 10:14:42.141
SPY-NQTV Daily #1 | Reloading chart. | 2022-04-25 10:14:42.163
VIRT-NQTV 2 Day #4 | Reloading chart. | 2022-04-25 10:14:42.174
VIRT-NQTV 256 Min #3 | Reloading chart. | 2022-04-25 10:14:42.190
VET-NQTV 8 Day #2 | Reloading chart. | 2022-04-25 10:14:42.213
Files to Open on Startup | Opening file: WWW.Cht | 2022-04-25 10:14:42.221
SPY-NQTV Daily #1 | Reloading chart. | 2022-04-25 10:14:42.248
WCN-NQTV 8 Day #6 | Reloading chart. | 2022-04-25 10:14:42.259
WCN-NQTV 256 Min #2 | Reloading chart. | 2022-04-25 10:14:42.271
WMT-NQTV 2 Day #4 | Reloading chart. | 2022-04-25 10:14:42.295
Files to Open on Startup | Opening file: XXX.Cht | 2022-04-25 10:14:42.302
SPY-NQTV Daily #1 | Reloading chart. | 2022-04-25 10:14:42.326
XOM-NQTV 4 Day #3 | Reloading chart. | 2022-04-25 10:14:42.338
XOM-NQTV 256 Min #4 | Reloading chart. | 2022-04-25 10:14:42.350
XEC-NQTV 4 Day #2 | Reloading chart. | 2022-04-25 10:14:42.372
X-NQTV 8 Day #5 | Reloading chart. | 2022-04-25 10:14:42.386
Files to Open on Startup | Opening file: ZZZ.Cht | 2022-04-25 10:14:42.393
SPY-NQTV Daily #1 | Reloading chart. | 2022-04-25 10:14:42.437
NAS100 16 Day #9 | StartDateTimeForLoadingOrderFills: 2011-01-03 00:00:00 | 2022-04-25 10:14:42.451
US30 Daily #10 | StartDateTimeForLoadingOrderFills: 2011-01-03 00:00:00 | 2022-04-25 10:14:42.454
Mapping ZW-197207-ECBOT to ZWN72. Service code: cbot | 2022-04-25 10:14:42.500
Using symbol data fast lookup vector | 2022-04-25 10:14:42.500
HD Request # 1 | Downloading Historical Daily chart data for ZW-197207-ECBOT. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:14:42.500
ZW-202207-ECBOT 512 Min #1 | StartDateTimeForLoadingOrderFills: 2021-10-11 04:32:00 | 2022-04-25 10:14:42.508
ZW-202207-ECBOT 128 Min #11 | StartDateTimeForLoadingOrderFills: 2021-10-11 10:56:00 | 2022-04-25 10:14:42.510
ZW-202207-ECBOT 1 Day #16 | StartDateTimeForLoadingOrderFills: 2021-10-10 20:00:00 | 2022-04-25 10:14:42.513
YK-202205-ECBOT-USD-1000 512 Min #12 | StartDateTimeForLoadingOrderFills: 2021-08-30 08:32:00 | 2022-04-25 10:14:42.515
YK-202205-ECBOT-USD-1000 512 Min #13 | StartDateTimeForLoadingOrderFills: 2021-08-30 08:32:00 | 2022-04-25 10:14:42.516
YK-202205-ECBOT-USD-1000 512 Min #23 | StartDateTimeForLoadingOrderFills: 2021-08-30 08:32:00 | 2022-04-25 10:14:42.518
MGC-202206-NYMEX-USD-10 [C] 768 Min #16 | StartDateTimeForLoadingOrderFills: 2021-06-29 18:00:00 | 2022-04-25 10:14:42.600
MGC-202206-NYMEX-USD-10 [C] 384 Min #2 | StartDateTimeForLoadingOrderFills: 2021-06-29 18:00:00 | 2022-04-25 10:14:42.603
QG-202206-NYMEX Daily #2 | StartDateTimeForLoadingOrderFills: 2016-11-28 00:00:00 | 2022-04-25 10:14:42.606
QG-202204-NYMEX 384 Min #5 | StartDateTimeForLoadingOrderFills: 2021-08-17 00:24:00 | 2022-04-25 10:14:42.609
QG-202204-NYMEX 384 Min #11 | StartDateTimeForLoadingOrderFills: 2021-08-17 00:24:00 | 2022-04-25 10:14:42.611
QM-202206-NYMEX 384 Min #8 | StartDateTimeForLoadingOrderFills: 2021-10-14 06:48:00 | 2022-04-25 10:14:42.616
QM-202206-NYMEX 768 Min #12 | StartDateTimeForLoadingOrderFills: 2021-10-14 06:48:00 | 2022-04-25 10:14:42.617
MBT-202203-CMECRYPTO-USD-0.1 Daily #5 | StartDateTimeForLoadingOrderFills: 2021-09-24 00:00:00 | 2022-04-25 10:14:42.619
Mapping MBT-202109-CMECRYPTO-USD-0.1 to MBTU21. Service code: cme | 2022-04-25 10:14:42.619
HD Request # 2 | Downloading Intraday chart data for MBT-202109-CMECRYPTO-USD-0.1 to the file MBT-202109-CMECRYPTO-USD-0.1.scid. Service: cme | 2022-04-25 10:14:42.619
HD Request # 2 | Download start date-time: 2021-09-24 10:58:49.000000. File last date-time: 2021-09-24 10:58:49.617000 | 2022-04-25 10:14:42.620
HD Request # 2 | Using server: ds23.sierracharts.com port 10149 | 2022-04-25 10:14:42.620
Socket (3) | Creating socket. | 2022-04-25 10:14:42.620
Socket (3) | New receive buffer size: 5242880 | 2022-04-25 10:14:42.620
Socket (3) | Connecting to IP: 216.1.90.130. | 2022-04-25 10:14:42.620
HD Request # 2 | Setting DTC encoding to Binary VLS | 2022-04-25 10:14:43.079
HD Request # 2 | Sending historical data logon request message. | 2022-04-25 10:14:43.079
Interactive Brokers | Sending API sign: API | 2022-04-25 10:14:43.133
Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2022-04-25 10:14:43.134
AUD-202206-GLOBEX [C] 768 Min #4 | StartDateTimeForLoadingOrderFills: 2021-06-29 18:00:00 | 2022-04-25 10:14:43.150
AUD-202206-GLOBEX [C] 768 Min #5 | StartDateTimeForLoadingOrderFills: 2021-06-29 18:00:00 | 2022-04-25 10:14:43.152
AUD-202206-GLOBEX [C] 384 Min #10 | StartDateTimeForLoadingOrderFills: 2021-06-29 18:00:00 | 2022-04-25 10:14:43.154
ACRS-NQTV/ACRSn-CFD-SMART-USD 2 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:14:43.171
ACRS-NQTV/ACRSn-CFD-SMART-USD 32 Min #8 | StartDateTimeForLoadingOrderFills: 2021-10-18 09:30:00 | 2022-04-25 10:14:43.179
GBP-202206-GLOBEX 96 Min #9 | StartDateTimeForLoadingOrderFills: 2021-09-21 21:12:00 | 2022-04-25 10:14:43.183
CLH-NQTV/CLHn-CFD-SMART-USD 64 Min #4 | StartDateTimeForLoadingOrderFills: 2021-10-18 09:30:00 | 2022-04-25 10:14:43.207
HESM-NQTV/HESMn-CFD-SMART-USD Daily #8 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\HESM-NQTV.dly | 2022-04-25 10:14:43.380
HESM-NQTV/HESMn-CFD-SMART-USD 120 Min #11 | StartDateTimeForLoadingOrderFills: 2021-09-23 11:30:00 | 2022-04-25 10:14:43.390
WCN-NQTV 256 Min #2 | StartDateTimeForLoadingOrderFills: 2021-10-01 09:30:00 | 2022-04-25 10:14:43.589
Interactive Brokers | TWS server version: 136 | 2022-04-25 10:14:43.698
Interactive Brokers | TWS time: 20220426 00:14:40 AEST | 2022-04-25 10:14:43.698
HD Request # 2 | Requesting Intraday data. Start date-time: 2021-09-24 10:58:49. Record interval: 0. Symbol: MBTU21 | 2022-04-25 10:14:43.763
Interactive Brokers | Connected. Sending Start API command. | 2022-04-25 10:14:43.961
Interactive Brokers | Waiting for account information. | 2022-04-25 10:14:43.961
HD Request # 2 | Decompressing data. | 2022-04-25 10:14:43.981
HD Request # 2 | Receiving Intraday data for MBT-202109-CMECRYPTO-USD-0.1 starting at 2021-09-24 10:58:49.605000 | 2022-04-25 10:14:43.981
Socket (3) | CloseSocket call. | 2022-04-25 10:14:43.981
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:14:43.981
IB Account information received. | 2022-04-25 10:14:43.982
Interactive Brokers | Received 1 Trade Accounts from TWS. | 2022-04-25 10:14:43.982
Interactive Brokers | Connected to Live account. | 2022-04-25 10:14:43.982
Updated verified funded futures trading account ending date to: 2022-05-25 14:14:43 | 2022-04-25 10:14:43.982
Interactive Brokers | Connected to server complete. | 2022-04-25 10:14:43.982
Triggering next historical data download in queue. | 2022-04-25 10:14:43.982
Next valid order ID: 941 | 2022-04-25 10:14:44.025
Message from IB: Market data farm connection is OK:usfarm.nj. IB Error Code: 2104. Request ID: -1. | 2022-04-25 10:14:44.025
Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2022-04-25 10:14:44.025
Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2022-04-25 10:14:44.025
Message from IB: HMDS data farm connection is OK:cashhmds. IB Error Code: 2106. Request ID: -1. | 2022-04-25 10:14:44.025
Message from IB: HMDS data farm connection is OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2022-04-25 10:14:44.025
Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2022-04-25 10:14:44.025
Message from IB: Sec-def data farm connection is OK:secdefil. IB Error Code: 2158. Request ID: -1. | 2022-04-25 10:14:44.025
Historical data download thread signaled to stop. | 2022-04-25 10:14:44.025
HD Request # 2 | Received 2 Intraday data records from 2021-09-24 10:58:49.605000 to 2021-09-24 10:58:49.617000 (0.0 seconds) and wrote 0 records for MBT-202109-CMECRYPTO-USD-0.1 | 2022-04-25 10:14:44.025
HD Request # 2 | Completion time: 2s | 2022-04-25 10:14:44.025
HD Request # 2 | Intraday data download complete for MBT-202109-CMECRYPTO-USD-0.1. Unique request ID: 94 | 2022-04-25 10:14:44.026
Removing historical data download ID 94. | 2022-04-25 10:14:44.026
HD Request # 2 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:14:44.026
Initiating new historical data download for MBT-202109-CMECRYPTO-USD-0.1 to get the latest data since the download was started while not connected to primary service. | 2022-04-25 10:14:44.026
Added historical Intraday data request for MBT-202109-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:44.026
No download requests in the queue to start downloads for. | 2022-04-25 10:14:44.026
Mapping MBT-202109-CMECRYPTO-USD-0.1 to MBTU21. Service code: cme | 2022-04-25 10:14:44.026
Using symbol data fast lookup vector | 2022-04-25 10:14:44.026
HD Request # 3 | Downloading Intraday chart data for MBT-202109-CMECRYPTO-USD-0.1 to the file MBT-202109-CMECRYPTO-USD-0.1.scid. Service: cme | 2022-04-25 10:14:44.026
HD Request # 3 | Download start date-time: 2021-09-24 10:58:49.000000. File last date-time: 2021-09-24 10:58:49.617000 | 2022-04-25 10:14:44.026
HD Request # 3 | Using server: ds21.sierracharts.com port 10150 | 2022-04-25 10:14:44.026
Next valid order ID: 941 | 2022-04-25 10:14:44.026
Socket (4) | Creating socket. | 2022-04-25 10:14:44.027
Socket (4) | New receive buffer size: 5242880 | 2022-04-25 10:14:44.027
Socket (4) | Connecting to IP: 216.1.90.129. | 2022-04-25 10:14:44.027
Next valid order ID: 941 | 2022-04-25 10:14:44.031
Added historical Daily data request for AUS200 to the queue. | 2022-04-25 10:14:44.096
Triggering next historical data download in queue. | 2022-04-25 10:14:44.096
Using Bid/Ask average for last trade price for AUS200 | 2022-04-25 10:14:44.096
SC DTC Data with Market Depth | Starting real-time market data updates for: AUS200. ID: 2 Service code: fxcm | 2022-04-25 10:14:44.096
SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2022-04-25 10:14:44.096
SC DTC Data with Market Depth | Requesting security definition data for: AUS200. ID: 2 | 2022-04-25 10:14:44.096
DTC Client socket (5) | Creating socket. | 2022-04-25 10:14:44.096
Added historical Daily data request for SPX500 to the queue. | 2022-04-25 10:14:44.096
Using Bid/Ask average for last trade price for SPX500 | 2022-04-25 10:14:44.096
DTC Client socket (5) | New receive buffer size: 5242880 | 2022-04-25 10:14:44.096
DTC Client socket (5) | Connecting to IP: 204.15.197.14. | 2022-04-25 10:14:44.096
SC DTC Data with Market Depth | Starting real-time market data updates for: SPX500. ID: 3 Service code: fxcm | 2022-04-25 10:14:44.097
SC DTC Data with Market Depth | Requesting security definition data for: SPX500. ID: 3 | 2022-04-25 10:14:44.097
Added historical Daily data request for US30 to the queue. | 2022-04-25 10:14:44.097
Triggering next historical data download in queue. | 2022-04-25 10:14:44.097
Using Bid/Ask average for last trade price for US30 | 2022-04-25 10:14:44.097
SC DTC Data with Market Depth | Starting real-time market data updates for: US30. ID: 4 Service code: fxcm | 2022-04-25 10:14:44.097
SC DTC Data with Market Depth | Requesting security definition data for: US30. ID: 4 | 2022-04-25 10:14:44.097
Added historical Daily data request for NAS100 to the queue. | 2022-04-25 10:14:44.097
Using Bid/Ask average for last trade price for NAS100 | 2022-04-25 10:14:44.097
SC DTC Data with Market Depth | Starting real-time market data updates for: NAS100. ID: 5 Service code: fxcm | 2022-04-25 10:14:44.098
SC DTC Data with Market Depth | Requesting security definition data for: NAS100. ID: 5 | 2022-04-25 10:14:44.098
Added historical Daily data request for XAUUSD to the queue. | 2022-04-25 10:14:44.108
Triggering next historical data download in queue. | 2022-04-25 10:14:44.108
Using Bid/Ask average for last trade price for XAUUSD | 2022-04-25 10:14:44.108
SC DTC Data with Market Depth | Starting real-time market data updates for: XAUUSD. ID: 6 Service code: fxcm | 2022-04-25 10:14:44.108
SC DTC Data with Market Depth | Requesting security definition data for: XAUUSD. ID: 6 | 2022-04-25 10:14:44.108
Added historical Daily data request for AUDUSD to the queue. | 2022-04-25 10:14:44.109
Triggering next historical data download in queue. | 2022-04-25 10:14:44.109
Using Bid/Ask average for last trade price for AUDUSD | 2022-04-25 10:14:44.109
SC DTC Data with Market Depth | Starting real-time market data updates for: AUDUSD. ID: 7 Service code: fxcm | 2022-04-25 10:14:44.109
SC DTC Data with Market Depth | Requesting security definition data for: AUDUSD. ID: 7 | 2022-04-25 10:14:44.109
Added historical Daily data request for WHEATF to the queue. | 2022-04-25 10:14:44.109
Using Bid/Ask average for last trade price for WHEATF | 2022-04-25 10:14:44.109
SC DTC Data with Market Depth | Starting real-time market data updates for: WHEATF. ID: 8 Service code: fxcm | 2022-04-25 10:14:44.109
SC DTC Data with Market Depth | Requesting security definition data for: WHEATF. ID: 8 | 2022-04-25 10:14:44.109
Added historical Daily data request for NGAS to the queue. | 2022-04-25 10:14:44.110
Triggering next historical data download in queue. | 2022-04-25 10:14:44.110
Using Bid/Ask average for last trade price for NGAS | 2022-04-25 10:14:44.110
SC DTC Data with Market Depth | Starting real-time market data updates for: NGAS. ID: 9 Service code: fxcm | 2022-04-25 10:14:44.110
SC DTC Data with Market Depth | Requesting security definition data for: NGAS. ID: 9 | 2022-04-25 10:14:44.110
Added historical Daily data request for DIA-NQTV to the queue. | 2022-04-25 10:14:44.110
Mapping DIA-NQTV to DIA-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.110
SC Data - All Services | Starting real-time market data updates for: DIA-NQTV (DIA-NQTV). ID: 10 Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.110
SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 443 | 2022-04-25 10:14:44.110
SC Data - All Services | Requesting security definition data for: DIA-NQTV (DIA-NQTV). ID: 10 | 2022-04-25 10:14:44.110
DTC Client socket (6) | Creating socket. | 2022-04-25 10:14:44.111
DTC Client socket (6) | New receive buffer size: 5242880 | 2022-04-25 10:14:44.111
DTC Client socket (6) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:14:44.111
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 10. Symbol: DIA-NQTV | 2022-04-25 10:14:44.113
Added historical Daily data request for SPY-NQTV to the queue. | 2022-04-25 10:14:44.114
Triggering next historical data download in queue. | 2022-04-25 10:14:44.114
Mapping SPY-NQTV to SPY-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.115
SC Data - All Services | Starting real-time market data updates for: SPY-NQTV (SPY-NQTV). ID: 11 Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.115
SC Data - All Services | Requesting security definition data for: SPY-NQTV (SPY-NQTV). ID: 11 | 2022-04-25 10:14:44.115
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 11. Symbol: SPY-NQTV | 2022-04-25 10:14:44.161
Added historical Daily data request for QQQ-NQTV to the queue. | 2022-04-25 10:14:44.161
Triggering next historical data download in queue. | 2022-04-25 10:14:44.161
Mapping QQQ-NQTV to QQQ-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.161
SC Data - All Services | Starting real-time market data updates for: QQQ-NQTV (QQQ-NQTV). ID: 12 Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.161
SC Data - All Services | Requesting security definition data for: QQQ-NQTV (QQQ-NQTV). ID: 12 | 2022-04-25 10:14:44.161
Added historical Intraday data request for QQQ-NQTV to the queue. | 2022-04-25 10:14:44.162
Intraday data recording state for symbol QQQ-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.162
Triggering next historical data download in queue. | 2022-04-25 10:14:44.162
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 12. Symbol: QQQ-NQTV | 2022-04-25 10:14:44.162
Mapping ZW-202207-ECBOT to ZWN22. Service code: cbot | 2022-04-25 10:14:44.163
SC Data - All Services | Starting real-time market data updates for: ZW-202207-ECBOT (ZWN22). ID: 13 Service code: cbot | 2022-04-25 10:14:44.163
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2022-04-25 10:14:44.163
SC Data - All Services | Requesting security definition data for: ZW-202207-ECBOT (ZWN22). ID: 13 | 2022-04-25 10:14:44.163
Added historical Intraday data request for ZW-202207-ECBOT to the queue. | 2022-04-25 10:14:44.164
Intraday data recording state for symbol ZW-202207-ECBOT is set to download 'Pending'. | 2022-04-25 10:14:44.164
Triggering next historical data download in queue. | 2022-04-25 10:14:44.164
DTC Client socket (8) | Creating socket. | 2022-04-25 10:14:44.164
DTC Client socket (8) | New receive buffer size: 5242880 | 2022-04-25 10:14:44.164
DTC Client socket (8) | Connecting to IP: 208.185.224.129. | 2022-04-25 10:14:44.164
Mapping YK-202205-ECBOT-USD-1000 to XKK22. Service code: cbot | 2022-04-25 10:14:44.165
SC Data - All Services | Starting real-time market data updates for: YK-202205-ECBOT-USD-1000 (XKK22). ID: 14 Service code: cbot | 2022-04-25 10:14:44.165
SC Data - All Services | Requesting security definition data for: YK-202205-ECBOT-USD-1000 (XKK22). ID: 14 | 2022-04-25 10:14:44.165
Added historical Intraday data request for YK-202205-ECBOT-USD-1000 to the queue. | 2022-04-25 10:14:44.165
Intraday data recording state for symbol YK-202205-ECBOT-USD-1000 is set to download 'Pending'. | 2022-04-25 10:14:44.165
Triggering next historical data download in queue. | 2022-04-25 10:14:44.165
Mapping ZC-202207-ECBOT to ZCN22. Service code: cbot | 2022-04-25 10:14:44.166
SC Data - All Services | Starting real-time market data updates for: ZC-202207-ECBOT (ZCN22). ID: 15 Service code: cbot | 2022-04-25 10:14:44.166
SC Data - All Services | Requesting security definition data for: ZC-202207-ECBOT (ZCN22). ID: 15 | 2022-04-25 10:14:44.166
Added historical Intraday data request for ZC-202207-ECBOT to the queue. | 2022-04-25 10:14:44.167
Intraday data recording state for symbol ZC-202207-ECBOT is set to download 'Pending'. | 2022-04-25 10:14:44.167
Triggering next historical data download in queue. | 2022-04-25 10:14:44.167
Mapping MYM-202206-ECBOT-USD to MYMM22. Service code: cbot | 2022-04-25 10:14:44.167
SC Data - All Services | Starting real-time market data updates for: MYM-202206-ECBOT-USD (MYMM22). ID: 16 Service code: cbot | 2022-04-25 10:14:44.167
SC Data - All Services | Requesting security definition data for: MYM-202206-ECBOT-USD (MYMM22). ID: 16 | 2022-04-25 10:14:44.167
Added historical Intraday data request for MYM-202206-ECBOT-USD to the queue. | 2022-04-25 10:14:44.168
Intraday data recording state for symbol MYM-202206-ECBOT-USD is set to download 'Pending'. | 2022-04-25 10:14:44.168
Triggering next historical data download in queue. | 2022-04-25 10:14:44.168
Mapping MNQ-202206-GLOBEX-USD to MNQM22. Service code: cme | 2022-04-25 10:14:44.169
SC Data - All Services | Starting real-time market data updates for: MNQ-202206-GLOBEX-USD (MNQM22). ID: 17 Service code: cme | 2022-04-25 10:14:44.169
SC Data - All Services | Requesting security definition data for: MNQ-202206-GLOBEX-USD (MNQM22). ID: 17 | 2022-04-25 10:14:44.169
Added historical Intraday data request for MNQ-202206-GLOBEX-USD to the queue. | 2022-04-25 10:14:44.169
Intraday data recording state for symbol MNQ-202206-GLOBEX-USD is set to download 'Pending'. | 2022-04-25 10:14:44.169
Triggering next historical data download in queue. | 2022-04-25 10:14:44.169
Mapping ZN-202112-ECBOT to ZNZ21. Service code: cbot | 2022-04-25 10:14:44.170
SC Data - All Services | Starting real-time market data updates for: ZN-202112-ECBOT (ZNZ21). ID: 18 Service code: cbot | 2022-04-25 10:14:44.170
SC Data - All Services | Requesting security definition data for: ZN-202112-ECBOT (ZNZ21). ID: 18 | 2022-04-25 10:14:44.170
Added historical Intraday data request for ZN-202112-ECBOT to the queue. | 2022-04-25 10:14:44.171
Intraday data recording state for symbol ZN-202112-ECBOT is set to download 'Pending'. | 2022-04-25 10:14:44.171
Triggering next historical data download in queue. | 2022-04-25 10:14:44.171
Mapping ZN-202206-ECBOT to ZNM22. Service code: cbot | 2022-04-25 10:14:44.172
SC Data - All Services | Starting real-time market data updates for: ZN-202206-ECBOT (ZNM22). ID: 19 Service code: cbot | 2022-04-25 10:14:44.172
SC Data - All Services | Requesting security definition data for: ZN-202206-ECBOT (ZNM22). ID: 19 | 2022-04-25 10:14:44.172
Added historical Intraday data request for ZN-202206-ECBOT to the queue. | 2022-04-25 10:14:44.172
Intraday data recording state for symbol ZN-202206-ECBOT is set to download 'Pending'. | 2022-04-25 10:14:44.172
Triggering next historical data download in queue. | 2022-04-25 10:14:44.172
Mapping MGC-202206-NYMEX-USD-10 to MGCM22. Service code: comex | 2022-04-25 10:14:44.173
SC Data - All Services | Starting real-time market data updates for: MGC-202206-NYMEX-USD-10 (MGCM22). ID: 20 Service code: comex | 2022-04-25 10:14:44.173
SC Data - All Services | Requesting security definition data for: MGC-202206-NYMEX-USD-10 (MGCM22). ID: 20 | 2022-04-25 10:14:44.173
Added historical Intraday data request for MGC-202206-NYMEX-USD-10 to the queue. | 2022-04-25 10:14:44.173
Intraday data recording state for symbol MGC-202206-NYMEX-USD-10 is set to download 'Pending'. | 2022-04-25 10:14:44.173
Triggering next historical data download in queue. | 2022-04-25 10:14:44.173
Added historical Daily data request for QG-202206-NYMEX to the queue. | 2022-04-25 10:14:44.174
Triggering next historical data download in queue. | 2022-04-25 10:14:44.174
Mapping QG-202206-NYMEX to QGM22. Service code: nymex | 2022-04-25 10:14:44.174
SC Data - All Services | Starting real-time market data updates for: QG-202206-NYMEX (QGM22). ID: 21 Service code: nymex | 2022-04-25 10:14:44.174
SC Data - All Services | Requesting security definition data for: QG-202206-NYMEX (QGM22). ID: 21 | 2022-04-25 10:14:44.174
Mapping QG-202204-NYMEX to QGJ22. Service code: nymex | 2022-04-25 10:14:44.175
SC Data - All Services | Starting real-time market data updates for: QG-202204-NYMEX (QGJ22). ID: 22 Service code: nymex | 2022-04-25 10:14:44.175
SC Data - All Services | Requesting security definition data for: QG-202204-NYMEX (QGJ22). ID: 22 | 2022-04-25 10:14:44.175
Added historical Intraday data request for QG-202204-NYMEX to the queue. | 2022-04-25 10:14:44.175
Intraday data recording state for symbol QG-202204-NYMEX is set to download 'Pending'. | 2022-04-25 10:14:44.175
Triggering next historical data download in queue. | 2022-04-25 10:14:44.175
Added historical Daily data request for USOil to the queue. | 2022-04-25 10:14:44.176
Triggering next historical data download in queue. | 2022-04-25 10:14:44.176
Using Bid/Ask average for last trade price for USOil | 2022-04-25 10:14:44.176
SC DTC Data with Market Depth | Starting real-time market data updates for: USOil. ID: 23 Service code: fxcm | 2022-04-25 10:14:44.176
SC DTC Data with Market Depth | Requesting security definition data for: USOil. ID: 23 | 2022-04-25 10:14:44.176
Mapping QM-202206-NYMEX to QMM22. Service code: nymex | 2022-04-25 10:14:44.176
SC Data - All Services | Starting real-time market data updates for: QM-202206-NYMEX (QMM22). ID: 24 Service code: nymex | 2022-04-25 10:14:44.176
SC Data - All Services | Requesting security definition data for: QM-202206-NYMEX (QMM22). ID: 24 | 2022-04-25 10:14:44.177
Added historical Intraday data request for QM-202206-NYMEX to the queue. | 2022-04-25 10:14:44.177
Intraday data recording state for symbol QM-202206-NYMEX is set to download 'Pending'. | 2022-04-25 10:14:44.177
Triggering next historical data download in queue. | 2022-04-25 10:14:44.177
Mapping MBT-202203-CMECRYPTO-USD-0.1 to MBTH22. Service code: cme | 2022-04-25 10:14:44.177
SC Data - All Services | Starting real-time market data updates for: MBT-202203-CMECRYPTO-USD-0.1 (MBTH22). ID: 25 Service code: cme | 2022-04-25 10:14:44.178
SC Data - All Services | Requesting security definition data for: MBT-202203-CMECRYPTO-USD-0.1 (MBTH22). ID: 25 | 2022-04-25 10:14:44.178
MBT-202203-CMECRYPTO-USD-0.1 [C] 384 Min #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:14:44.178
MBT-202203-CMECRYPTO-USD-0.1 [C] 384 Min #6 | Reloading chart. | 2022-04-25 10:14:44.178
Interactive Brokers | Using primary service for historical data for BTC-USD | 2022-04-25 10:14:44.181
Starting DelayedDownloadMonitoringTimer | 2022-04-25 10:14:44.181
Starting HDTimeoutTimer | 2022-04-25 10:14:44.181
Added historical Daily data request for BTC-USD to the queue. | 2022-04-25 10:14:44.181
Triggering next historical data download in queue. | 2022-04-25 10:14:44.181
Interactive Brokers | Starting real-time market data updates for: BTC-USD. ID: 26 | 2022-04-25 10:14:44.181
Interactive Brokers | Subscribing to real-time True Data for symbol: BTC SecurityType: USD Exchange: Currency: | 2022-04-25 10:14:44.181
Interactive Brokers | Subscribing to Symbol: BTC, SecurityType: USD, Expiration: , Exchange: , Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2022-04-25 10:14:44.181
Interactive Brokers | Requesting security definition data for: BTC-USD. ID: 26 | 2022-04-25 10:14:44.181
HD Request # 4 | Downloading Historical Daily chart data for BTC-USD. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:14:44.182
HD Request # 4 | Requesting 365 days of historical Daily data for BTC-USD with end date 2022-04-25 | 2022-04-25 10:14:44.182
Added historical Daily data request for USDOLLAR to the queue. | 2022-04-25 10:14:44.182
Triggering next historical data download in queue. | 2022-04-25 10:14:44.182
Using Bid/Ask average for last trade price for USDOLLAR | 2022-04-25 10:14:44.182
SC DTC Data with Market Depth | Starting real-time market data updates for: USDOLLAR. ID: 27 Service code: fxcm | 2022-04-25 10:14:44.182
SC DTC Data with Market Depth | Requesting security definition data for: USDOLLAR. ID: 27 | 2022-04-25 10:14:44.182
Message from IB: Error validating request.-'bX' : cause - Please enter exchange. IB Error Code: 321. Request ID: 26. Symbol: BTC-USD | 2022-04-25 10:14:44.182
Message from IB: Error validating request.-'bZ' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 26. Symbol: BTC-USD | 2022-04-25 10:14:44.183
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 26. Symbol: BTC-USD | 2022-04-25 10:14:44.183
HD Request # 4 | Message from IB: Error validating request.-'bT' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200942. | 2022-04-25 10:14:44.183
HD Request # 4 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for BTC-USD | 2022-04-25 10:14:44.183
HD Request # 4 | Completion time: 0s | 2022-04-25 10:14:44.183
HD Request # 4 | Daily data download complete for BTC-USD. Unique request ID: 123 | 2022-04-25 10:14:44.183
Removing historical data download ID 123. | 2022-04-25 10:14:44.183
Triggering next historical data download in queue. | 2022-04-25 10:14:44.184
No download requests in the queue to start downloads for. | 2022-04-25 10:14:44.184
Mapping AUD-202206-GLOBEX to 6AM22. Service code: cme | 2022-04-25 10:14:44.185
SC Data - All Services | Starting real-time market data updates for: AUD-202206-GLOBEX (6AM22). ID: 28 Service code: cme | 2022-04-25 10:14:44.185
SC Data - All Services | Requesting security definition data for: AUD-202206-GLOBEX (6AM22). ID: 28 | 2022-04-25 10:14:44.185
Added historical Intraday data request for AUD-202206-GLOBEX to the queue. | 2022-04-25 10:14:44.185
Intraday data recording state for symbol AUD-202206-GLOBEX is set to download 'Pending'. | 2022-04-25 10:14:44.185
Triggering next historical data download in queue. | 2022-04-25 10:14:44.185
Added historical Daily data request for GBPUSD to the queue. | 2022-04-25 10:14:44.185
Using Bid/Ask average for last trade price for GBPUSD | 2022-04-25 10:14:44.185
SC DTC Data with Market Depth | Starting real-time market data updates for: GBPUSD. ID: 29 Service code: fxcm | 2022-04-25 10:14:44.186
SC DTC Data with Market Depth | Requesting security definition data for: GBPUSD. ID: 29 | 2022-04-25 10:14:44.186
Message from IB: Error reading request.Message id 200943. Unable to parse data. java.lang.NumberFormatException: For input string: "FUT". IB Error Code: 320. Request ID: 200943. | 2022-04-25 10:14:44.186
IB TWS socket (1) | Socket gracefully closed by remote side. | 2022-04-25 10:14:44.186
IB TWS socket (1) | CloseSocket call. | 2022-04-25 10:14:44.187
Connection to the external service has been lost. | 2022-04-25 10:14:44.187
IB TWS socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-04-25 10:14:44.187
IB TWS socket (1) | Closed. | 2022-04-25 10:14:44.187
Socket (3) | Socket gracefully closed by remote side. | 2022-04-25 10:14:44.200
Socket (3) | Closed. | 2022-04-25 10:14:44.200
Mapping GBP-202206-GLOBEX to 6BM22. Service code: cme | 2022-04-25 10:14:44.219
Added historical Intraday data request for GBP-202206-GLOBEX to the queue. | 2022-04-25 10:14:44.220
Intraday data recording state for symbol GBP-202206-GLOBEX is set to download 'Pending'. | 2022-04-25 10:14:44.220
Triggering next historical data download in queue. | 2022-04-25 10:14:44.220
Added historical Daily data request for AJG-NQTV to the queue. | 2022-04-25 10:14:44.220
Mapping AJG-NQTV to AJG-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.220
Added historical Daily data request for ACHC-NQTV to the queue. | 2022-04-25 10:14:44.221
Triggering next historical data download in queue. | 2022-04-25 10:14:44.221
Mapping ACHC-NQTV to ACHC-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.221
Added historical Daily data request for AMX-NQTV to the queue. | 2022-04-25 10:14:44.221
Mapping AMX-NQTV to AMX-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.221
Added historical Intraday data request for AMX-NQTV to the queue. | 2022-04-25 10:14:44.222
Intraday data recording state for symbol AMX-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.222
Triggering next historical data download in queue. | 2022-04-25 10:14:44.222
Added historical Daily data request for ACRS-NQTV to the queue. | 2022-04-25 10:14:44.223
Triggering next historical data download in queue. | 2022-04-25 10:14:44.223
Mapping ACRS-NQTV to ACRS-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.223
Added historical Daily data request for AMH-NQTV to the queue. | 2022-04-25 10:14:44.223
Mapping AMH-NQTV to AMH-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.223
Added historical Intraday data request for ACRS-NQTV to the queue. | 2022-04-25 10:14:44.224
Intraday data recording state for symbol ACRS-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.224
Triggering next historical data download in queue. | 2022-04-25 10:14:44.224
Added historical Daily data request for AMR-NQTV to the queue. | 2022-04-25 10:14:44.224
Mapping AMR-NQTV to AMR-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.224
Mapping AA-NQTV to AA-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.225
Added historical Intraday data request for AA-NQTV to the queue. | 2022-04-25 10:14:44.225
Intraday data recording state for symbol AA-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.225
Triggering next historical data download in queue. | 2022-04-25 10:14:44.225
Added historical Daily data request for AA-NQTV to the queue. | 2022-04-25 10:14:44.226
Triggering next historical data download in queue. | 2022-04-25 10:14:44.226
Added historical Daily data request for BJ-NQTV to the queue. | 2022-04-25 10:14:44.226
Mapping BJ-NQTV to BJ-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.226
Added historical Intraday data request for BJ-NQTV to the queue. | 2022-04-25 10:14:44.227
Intraday data recording state for symbol BJ-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.227
Triggering next historical data download in queue. | 2022-04-25 10:14:44.227
Added historical Daily data request for CLH-NQTV to the queue. | 2022-04-25 10:14:44.227
Mapping CLH-NQTV to CLH-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.227
Added historical Daily data request for CUBE-NQTV to the queue. | 2022-04-25 10:14:44.228
Triggering next historical data download in queue. | 2022-04-25 10:14:44.228
Mapping CUBE-NQTV to CUBE-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.228
Added historical Intraday data request for CLH-NQTV to the queue. | 2022-04-25 10:14:44.229
Intraday data recording state for symbol CLH-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.229
Triggering next historical data download in queue. | 2022-04-25 10:14:44.230
Added historical Intraday data request for CUBE-NQTV to the queue. | 2022-04-25 10:14:44.230
Intraday data recording state for symbol CUBE-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.230
Added historical Daily data request for COST-NQTV to the queue. | 2022-04-25 10:14:44.230
Mapping COST-NQTV to COST-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.230
Added historical Intraday data request for COST-NQTV to the queue. | 2022-04-25 10:14:44.231
Intraday data recording state for symbol COST-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.231
Triggering next historical data download in queue. | 2022-04-25 10:14:44.231
Added historical Daily data request for CALM-NQTV to the queue. | 2022-04-25 10:14:44.231
Mapping CALM-NQTV to CALM-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.231
Added historical Intraday data request for CALM-NQTV to the queue. | 2022-04-25 10:14:44.232
Intraday data recording state for symbol CALM-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.232
Triggering next historical data download in queue. | 2022-04-25 10:14:44.232
Added historical Daily data request for DRE-NQTV to the queue. | 2022-04-25 10:14:44.232
Mapping DRE-NQTV to DRE-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.233
Added historical Daily data request for DAR-NQTV to the queue. | 2022-04-25 10:14:44.233
Triggering next historical data download in queue. | 2022-04-25 10:14:44.233
Mapping DAR-NQTV to DAR-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.233
Added historical Daily data request for DKL-NQTV to the queue. | 2022-04-25 10:14:44.234
Triggering next historical data download in queue. | 2022-04-25 10:14:44.234
Mapping DKL-NQTV to DKL-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.234
Added historical Daily data request for EVH-NQTV to the queue. | 2022-04-25 10:14:44.235
Triggering next historical data download in queue. | 2022-04-25 10:14:44.235
Mapping EVH-NQTV to EVH-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.235
Added historical Daily data request for EW-NQTV to the queue. | 2022-04-25 10:14:44.235
Mapping EW-NQTV to EW-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.235
Added historical Intraday data request for EVH-NQTV to the queue. | 2022-04-25 10:14:44.236
Intraday data recording state for symbol EVH-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.236
Triggering next historical data download in queue. | 2022-04-25 10:14:44.236
Added historical Daily data request for EXR-NQTV to the queue. | 2022-04-25 10:14:44.236
Mapping EXR-NQTV to EXR-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.236
Added historical Intraday data request for EXR-NQTV to the queue. | 2022-04-25 10:14:44.237
Intraday data recording state for symbol EXR-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.237
Triggering next historical data download in queue. | 2022-04-25 10:14:44.237
Mapping FWONK-NQTV to FWONK-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.238
Added historical Intraday data request for FWONK-NQTV to the queue. | 2022-04-25 10:14:44.238
Intraday data recording state for symbol FWONK-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.238
Triggering next historical data download in queue. | 2022-04-25 10:14:44.238
Added historical Daily data request for FWONK-NQTV to the queue. | 2022-04-25 10:14:44.238
Added historical Daily data request for FR-NQTV to the queue. | 2022-04-25 10:14:44.239
Triggering next historical data download in queue. | 2022-04-25 10:14:44.239
Mapping FR-NQTV to FR-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.239
Added historical Intraday data request for FR-NQTV to the queue. | 2022-04-25 10:14:44.239
Intraday data recording state for symbol FR-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.239
Mapping GCBC-NQTV to GCBC-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.240
Added historical Intraday data request for GCBC-NQTV to the queue. | 2022-04-25 10:14:44.240
Intraday data recording state for symbol GCBC-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.240
Triggering next historical data download in queue. | 2022-04-25 10:14:44.240
Added historical Daily data request for GCBC-NQTV to the queue. | 2022-04-25 10:14:44.240
Added historical Daily data request for GNK-NQTV to the queue. | 2022-04-25 10:14:44.241
Triggering next historical data download in queue. | 2022-04-25 10:14:44.241
Mapping GNK-NQTV to GNK-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.241
Added historical Intraday data request for GNK-NQTV to the queue. | 2022-04-25 10:14:44.241
Intraday data recording state for symbol GNK-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.241
Added historical Daily data request for HESM to the queue. | 2022-04-25 10:14:44.242
Triggering next historical data download in queue. | 2022-04-25 10:14:44.242
Added historical Daily data request for HESM-NQTV to the queue. | 2022-04-25 10:14:44.242
Mapping HESM-NQTV to HESM-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.243
Added historical Intraday data request for HESM-NQTV to the queue. | 2022-04-25 10:14:44.243
Intraday data recording state for symbol HESM-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.243
Triggering next historical data download in queue. | 2022-04-25 10:14:44.243
Mapping HCC-NQTV to HCC-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.243
Added historical Intraday data request for HCC-NQTV to the queue. | 2022-04-25 10:14:44.243
Intraday data recording state for symbol HCC-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.243
Added historical Daily data request for HCC-NQTV to the queue. | 2022-04-25 10:14:44.244
Triggering next historical data download in queue. | 2022-04-25 10:14:44.244
Added historical Daily data request for HZNP-NQTV to the queue. | 2022-04-25 10:14:44.244
Mapping HZNP-NQTV to HZNP-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.244
Added historical Daily data request for HCA-NQTV to the queue. | 2022-04-25 10:14:44.244
Mapping HCA-NQTV to HCA-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.244
Added historical Daily data request for IT-NQTV to the queue. | 2022-04-25 10:14:44.245
Triggering next historical data download in queue. | 2022-04-25 10:14:44.245
Mapping IT-NQTV to IT-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.245
Added historical Daily data request for KO-NQTV to the queue. | 2022-04-25 10:14:44.246
Triggering next historical data download in queue. | 2022-04-25 10:14:44.246
Mapping KO-NQTV to KO-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.246
Added historical Intraday data request for KO-NQTV to the queue. | 2022-04-25 10:14:44.247
Intraday data recording state for symbol KO-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.248
Triggering next historical data download in queue. | 2022-04-25 10:14:44.248
Added historical Daily data request for LAC-NQTV to the queue. | 2022-04-25 10:14:44.248
Mapping LAC-NQTV to LAC-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.248
Added historical Daily data request for LLY-NQTV to the queue. | 2022-04-25 10:14:44.249
Triggering next historical data download in queue. | 2022-04-25 10:14:44.249
Mapping LLY-NQTV to LLY-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.249
Added historical Intraday data request for LAC-NQTV to the queue. | 2022-04-25 10:14:44.249
Intraday data recording state for symbol LAC-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.249
Added historical Daily data request for LSI-NQTV to the queue. | 2022-04-25 10:14:44.250
Triggering next historical data download in queue. | 2022-04-25 10:14:44.250
Mapping LSI-NQTV to LSI-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.250
Added historical Daily data request for MGP-NQTV to the queue. | 2022-04-25 10:14:44.250
Mapping MGP-NQTV to MGP-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.250
Added historical Daily data request for NEM-NQTV to the queue. | 2022-04-25 10:14:44.251
Triggering next historical data download in queue. | 2022-04-25 10:14:44.251
Mapping NEM-NQTV to NEM-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.251
Added historical Daily data request for NSA-NQTV to the queue. | 2022-04-25 10:14:44.252
Triggering next historical data download in queue. | 2022-04-25 10:14:44.252
Mapping NSA-NQTV to NSA-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.252
Added historical Daily data request for NVO-NQTV to the queue. | 2022-04-25 10:14:44.252
Mapping NVO-NQTV to NVO-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.252
Added historical Daily data request for ORLY-NQTV to the queue. | 2022-04-25 10:14:44.253
Triggering next historical data download in queue. | 2022-04-25 10:14:44.253
Mapping ORLY-NQTV to ORLY-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.253
Added historical Intraday data request for ORLY-NQTV to the queue. | 2022-04-25 10:14:44.254
Intraday data recording state for symbol ORLY-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.254
Triggering next historical data download in queue. | 2022-04-25 10:14:44.254
Added historical Daily data request for OLN-NQTV to the queue. | 2022-04-25 10:14:44.254
Mapping OLN-NQTV to OLN-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.254
Mapping PFE-NQTV to PFE-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.255
Added historical Intraday data request for PFE-NQTV to the queue. | 2022-04-25 10:14:44.255
Intraday data recording state for symbol PFE-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.255
Triggering next historical data download in queue. | 2022-04-25 10:14:44.255
Added historical Daily data request for PFE-NQTV to the queue. | 2022-04-25 10:14:44.255
Added historical Daily data request for PFG-NQTV to the queue. | 2022-04-25 10:14:44.255
Mapping PFG-NQTV to PFG-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.255
Added historical Intraday data request for PFG-NQTV to the queue. | 2022-04-25 10:14:44.256
Intraday data recording state for symbol PFG-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.256
Triggering next historical data download in queue. | 2022-04-25 10:14:44.256
Added historical Daily data request for PWR-NQTV to the queue. | 2022-04-25 10:14:44.256
Mapping PWR-NQTV to PWR-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.257
Added historical Daily data request for PAYX-NQTV to the queue. | 2022-04-25 10:14:44.257
Triggering next historical data download in queue. | 2022-04-25 10:14:44.257
Mapping PAYX-NQTV to PAYX-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.257
Added historical Daily data request for PG-NQTV to the queue. | 2022-04-25 10:14:44.258
Triggering next historical data download in queue. | 2022-04-25 10:14:44.258
Mapping PG-NQTV to PG-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.258
Added historical Daily data request for PLD-NQTV to the queue. | 2022-04-25 10:14:44.258
Mapping PLD-NQTV to PLD-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.258
Added historical Daily data request for REXR-NQTV to the queue. | 2022-04-25 10:14:44.259
Triggering next historical data download in queue. | 2022-04-25 10:14:44.259
Mapping REXR-NQTV to REXR-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.259
Added historical Intraday data request for REXR-NQTV to the queue. | 2022-04-25 10:14:44.260
Intraday data recording state for symbol REXR-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.260
Triggering next historical data download in queue. | 2022-04-25 10:14:44.260
Added historical Daily data request for RADA-NQTV to the queue. | 2022-04-25 10:14:44.260
Mapping RADA-NQTV to RADA-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.260
Added historical Daily data request for SWCH-NQTV to the queue. | 2022-04-25 10:14:44.260
Mapping SWCH-NQTV to SWCH-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.261
Added historical Daily data request for SMPL-NQTV to the queue. | 2022-04-25 10:14:44.261
Triggering next historical data download in queue. | 2022-04-25 10:14:44.261
Mapping SMPL-NQTV to SMPL-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.261
Added historical Daily data request for STLD-NQTV to the queue. | 2022-04-25 10:14:44.262
Triggering next historical data download in queue. | 2022-04-25 10:14:44.262
Mapping STLD-NQTV to STLD-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.262
Added historical Daily data request for TXT-NQTV to the queue. | 2022-04-25 10:14:44.262
Mapping TXT-NQTV to TXT-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.262
Added historical Intraday data request for SPY-NQTV to the queue. | 2022-04-25 10:14:44.263
Intraday data recording state for symbol SPY-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.264
Triggering next historical data download in queue. | 2022-04-25 10:14:44.264
Added historical Daily data request for TSN-NQTV to the queue. | 2022-04-25 10:14:44.264
Mapping TSN-NQTV to TSN-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.264
Added historical Intraday data request for TSN-NQTV to the queue. | 2022-04-25 10:14:44.264
Intraday data recording state for symbol TSN-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.264
Mapping TSLA-NQTV to TSLA-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.264
Added historical Intraday data request for TSLA-NQTV to the queue. | 2022-04-25 10:14:44.265
Intraday data recording state for symbol TSLA-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.265
Triggering next historical data download in queue. | 2022-04-25 10:14:44.265
Added historical Daily data request for TSLA-NQTV to the queue. | 2022-04-25 10:14:44.265
Added historical Daily data request for TMST-NQTV to the queue. | 2022-04-25 10:14:44.265
Mapping TMST-NQTV to TMST-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.265
Added historical Intraday data request for TMST-NQTV to the queue. | 2022-04-25 10:14:44.266
Intraday data recording state for symbol TMST-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.266
Triggering next historical data download in queue. | 2022-04-25 10:14:44.266
Added historical Daily data request for TNET-NQTV to the queue. | 2022-04-25 10:14:44.266
Mapping TNET-NQTV to TNET-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.266
Added historical Intraday data request for TNET-NQTV to the queue. | 2022-04-25 10:14:44.267
Intraday data recording state for symbol TNET-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.267
Triggering next historical data download in queue. | 2022-04-25 10:14:44.267
Added historical Daily data request for VIRT-NQTV to the queue. | 2022-04-25 10:14:44.268
Triggering next historical data download in queue. | 2022-04-25 10:14:44.268
Mapping VIRT-NQTV to VIRT-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.268
Added historical Intraday data request for VIRT-NQTV to the queue. | 2022-04-25 10:14:44.268
Intraday data recording state for symbol VIRT-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.268
Added historical Daily data request for VET-NQTV to the queue. | 2022-04-25 10:14:44.268
Mapping VET-NQTV to VET-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.269
Added historical Daily data request for WCN-NQTV to the queue. | 2022-04-25 10:14:44.269
Triggering next historical data download in queue. | 2022-04-25 10:14:44.269
Mapping WCN-NQTV to WCN-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.269
Added historical Intraday data request for WCN-NQTV to the queue. | 2022-04-25 10:14:44.270
Intraday data recording state for symbol WCN-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.270
Triggering next historical data download in queue. | 2022-04-25 10:14:44.270
Added historical Daily data request for WMT-NQTV to the queue. | 2022-04-25 10:14:44.270
Mapping WMT-NQTV to WMT-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.270
Added historical Daily data request for XOM-NQTV to the queue. | 2022-04-25 10:14:44.271
Triggering next historical data download in queue. | 2022-04-25 10:14:44.271
Mapping XOM-NQTV to XOM-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.271
Added historical Intraday data request for XOM-NQTV to the queue. | 2022-04-25 10:14:44.272
Intraday data recording state for symbol XOM-NQTV is set to download 'Pending'. | 2022-04-25 10:14:44.272
Triggering next historical data download in queue. | 2022-04-25 10:14:44.272
Added historical Daily data request for XEC-NQTV to the queue. | 2022-04-25 10:14:44.273
Triggering next historical data download in queue. | 2022-04-25 10:14:44.273
Mapping XEC-NQTV to XEC-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.273
Added historical Daily data request for X-NQTV to the queue. | 2022-04-25 10:14:44.273
Mapping X-NQTV to X-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:44.273
SC DTC Data with Market Depth | Network connection to server complete. | 2022-04-25 10:14:44.321
SC DTC Data with Market Depth | Starting socket receive thread. | 2022-04-25 10:14:44.321
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-04-25 10:14:44.322
IB TWS socket (0) | CloseSocket call. | 2022-04-25 10:14:44.322
Interactive Brokers | Disconnected. | 2022-04-25 10:14:44.322
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-25 10:14:44.322
BTC-USD 4 Day #7 | Reloading chart. | 2022-04-25 10:14:44.324
SC Data - All Services | Network connection to server complete. | 2022-04-25 10:14:44.340
SC Data - All Services | Starting socket receive thread. | 2022-04-25 10:14:44.340
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-04-25 10:14:44.341
MBT-202203-CMECRYPTO-USD-0.1 [C] 384 Min #6 | StartDateTimeForLoadingOrderFills: 2021-09-06 18:00:00 | 2022-04-25 10:14:44.368
SC Data - All Services | Network connection to server complete. | 2022-04-25 10:14:44.372
SC Data - All Services | Starting socket receive thread. | 2022-04-25 10:14:44.372
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-04-25 10:14:44.373
MBT-202203-CMECRYPTO-USD-0.1 [C] 384 Min #6 | Reloading chart. | 2022-04-25 10:14:44.445
MBT-202203-CMECRYPTO-USD-0.1 [C] 384 Min #6 | Waiting for historical downloads to complete with the IDs: 98, | 2022-04-25 10:14:44.446
HD Request # 3 | Setting DTC encoding to Binary VLS | 2022-04-25 10:14:44.471
HD Request # 3 | Sending historical data logon request message. | 2022-04-25 10:14:44.471
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-04-25 10:14:44.560
SC DTC Data with Market Depth | Sending logon request message. | 2022-04-25 10:14:44.560
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-04-25 10:14:44.593
SC Data - All Services | Sending logon request message. | 2022-04-25 10:14:44.593
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-04-25 10:14:44.605
SC Data - All Services | Sending logon request message. | 2022-04-25 10:14:44.605
HD Request # 1 | Requesting historical Daily data for ZWN72 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:14:44.802
HD Request # 3 | Requesting Intraday data. Start date-time: 2021-09-24 10:58:49. Record interval: 0. Symbol: MBTU21 | 2022-04-25 10:14:45.184
HD Request # 3 | Decompressing data. | 2022-04-25 10:14:45.408
HD Request # 3 | Receiving Intraday data for MBT-202109-CMECRYPTO-USD-0.1 starting at 2021-09-24 10:58:49.605000 | 2022-04-25 10:14:45.408
Socket (4) | CloseSocket call. | 2022-04-25 10:14:45.408
Historical data download thread signaled to stop. | 2022-04-25 10:14:45.408
HD Request # 3 | Received 2 Intraday data records from 2021-09-24 10:58:49.605000 to 2021-09-24 10:58:49.617000 (0.0 seconds) and wrote 0 records for MBT-202109-CMECRYPTO-USD-0.1 | 2022-04-25 10:14:45.408
HD Request # 3 | Completion time: 1s | 2022-04-25 10:14:45.408
HD Request # 3 | Intraday data download complete for MBT-202109-CMECRYPTO-USD-0.1. Unique request ID: 98 | 2022-04-25 10:14:45.408
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:14:45.408
Removing historical data download ID 98. | 2022-04-25 10:14:45.408
HD Request # 3 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:14:45.408
Triggering next historical data download in queue. | 2022-04-25 10:14:45.409
HD Request # 5 | Downloading Historical Daily chart data for AUS200. Starting date: 2022-04-21. Service: fxcm | 2022-04-25 10:14:45.410
SC DTC Data with Market Depth | Received logon response. | 2022-04-25 10:14:45.410
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-04-25 10:14:45.411
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-04-25 10:14:45.411
SC DTC Data with Market Depth | Successfully connected. | 2022-04-25 10:14:45.411
SC DTC Data with Market Depth | Trading is not supported. | 2022-04-25 10:14:45.411
HD Request # 5 | Using server: ds12.sierracharts.com port 10149 | 2022-04-25 10:14:45.411
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDUSD | 2022-04-25 10:14:45.411
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUS200 | 2022-04-25 10:14:45.411
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPUSD | 2022-04-25 10:14:45.411
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NAS100 | 2022-04-25 10:14:45.411
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NGAS | 2022-04-25 10:14:45.411
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2022-04-25 10:14:45.411
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2022-04-25 10:14:45.411
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDOLLAR | 2022-04-25 10:14:45.411
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2022-04-25 10:14:45.411
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: WHEATF | 2022-04-25 10:14:45.411
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2022-04-25 10:14:45.411
Socket (2) | Creating socket. | 2022-04-25 10:14:45.411
Socket (2) | New receive buffer size: 5242880 | 2022-04-25 10:14:45.411
Socket (2) | Connecting to IP: 204.15.197.14. | 2022-04-25 10:14:45.411
SC Data - All Services | Received logon response. | 2022-04-25 10:14:45.468
SC Data - All Services | Server Name: SC Realtime Server. | 2022-04-25 10:14:45.468
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-04-25 10:14:45.468
SC Data - All Services | Successfully connected. | 2022-04-25 10:14:45.468
SC Data - All Services | Trading is not supported. | 2022-04-25 10:14:45.468
SC Data - All Services | Restarting real-time data updates for symbol: DIA-NQTV -> DIA-NQTV | 2022-04-25 10:14:45.468
SC Data - All Services | Restarting real-time data updates for symbol: QQQ-NQTV -> QQQ-NQTV | 2022-04-25 10:14:45.468
SC Data - All Services | Restarting real-time data updates for symbol: SPY-NQTV -> SPY-NQTV | 2022-04-25 10:14:45.468
MBT-202203-CMECRYPTO-USD-0.1 [C] 384 Min #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:14:45.481
MBT-202203-CMECRYPTO-USD-0.1 [C] 384 Min #6 | Reloading chart. | 2022-04-25 10:14:45.482
SC Data - All Services | Received logon response. | 2022-04-25 10:14:45.575
SC Data - All Services | Server Name: SC Realtime Server. | 2022-04-25 10:14:45.575
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-04-25 10:14:45.575
SC Data - All Services | Successfully connected. | 2022-04-25 10:14:45.575
SC Data - All Services | Trading is not supported. | 2022-04-25 10:14:45.575
SC Data - All Services | Restarting real-time data updates for symbol: AUD-202206-GLOBEX -> 6AM22 | 2022-04-25 10:14:45.575
SC Data - All Services | Restarting real-time data updates for symbol: MBT-202203-CMECRYPTO-USD-0.1 -> MBTH22 | 2022-04-25 10:14:45.575
SC Data - All Services | Restarting real-time data updates for symbol: MGC-202206-NYMEX-USD-10 -> MGCM22 | 2022-04-25 10:14:45.575
SC Data - All Services | Restarting real-time data updates for symbol: MNQ-202206-GLOBEX-USD -> MNQM22 | 2022-04-25 10:14:45.575
SC Data - All Services | Restarting real-time data updates for symbol: MYM-202206-ECBOT-USD -> MYMM22 | 2022-04-25 10:14:45.575
SC Data - All Services | Restarting real-time data updates for symbol: QG-202204-NYMEX -> QGJ22 | 2022-04-25 10:14:45.575
SC Data - All Services | Restarting real-time data updates for symbol: QG-202206-NYMEX -> QGM22 | 2022-04-25 10:14:45.575
SC Data - All Services | Restarting real-time data updates for symbol: QM-202206-NYMEX -> QMM22 | 2022-04-25 10:14:45.575
SC Data - All Services | Restarting real-time data updates for symbol: YK-202205-ECBOT-USD-1000 -> XKK22 | 2022-04-25 10:14:45.575
SC Data - All Services | Restarting real-time data updates for symbol: ZC-202207-ECBOT -> ZCN22 | 2022-04-25 10:14:45.575
SC Data - All Services | Restarting real-time data updates for symbol: ZN-202112-ECBOT -> ZNZ21 | 2022-04-25 10:14:45.575
SC Data - All Services | Restarting real-time data updates for symbol: ZN-202206-ECBOT -> ZNM22 | 2022-04-25 10:14:45.575
SC Data - All Services | Restarting real-time data updates for symbol: ZW-202207-ECBOT -> ZWN22 | 2022-04-25 10:14:45.575
Socket (4) | Socket gracefully closed by remote side. | 2022-04-25 10:14:45.630
Socket (4) | Closed. | 2022-04-25 10:14:45.630
MBT-202203-CMECRYPTO-USD-0.1 [C] 384 Min #6 | StartDateTimeForLoadingOrderFills: 2021-09-06 18:00:00 | 2022-04-25 10:14:45.670
SC DTC Data with Market Depth | Received security definition for symbol AUDUSD | 2022-04-25 10:14:45.720
SC DTC Data with Market Depth | Received security definition for symbol AUS200 | 2022-04-25 10:14:45.720
SC DTC Data with Market Depth | Received security definition for symbol GBPUSD | 2022-04-25 10:14:45.720
SC DTC Data with Market Depth | Received security definition for symbol NAS100 | 2022-04-25 10:14:45.720
SC DTC Data with Market Depth | Received security definition for symbol NGAS | 2022-04-25 10:14:45.720
SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2022-04-25 10:14:45.720
SC DTC Data with Market Depth | Received security definition for symbol US30 | 2022-04-25 10:14:45.720
SC DTC Data with Market Depth | Received security definition for symbol USDOLLAR | 2022-04-25 10:14:45.720
SC DTC Data with Market Depth | Received security definition for symbol USOil | 2022-04-25 10:14:45.720
SC DTC Data with Market Depth | Received security definition for symbol WHEATF | 2022-04-25 10:14:45.720
SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2022-04-25 10:14:45.720
MBT-202203-CMECRYPTO-USD-0.1 [C] 384 Min #6 | Reloading chart. | 2022-04-25 10:14:45.744
SC Data - All Services | Received security definition for symbol DIA-NQTV | 2022-04-25 10:14:45.781
SC Data - All Services | Received security definition for symbol QQQ-NQTV | 2022-04-25 10:14:45.781
SC Data - All Services | Received security definition for symbol SPY-NQTV | 2022-04-25 10:14:45.781
HD Request # 1 | Receiving historical Daily data for ZW-197207-ECBOT starting at 1972-04-25 | 2022-04-25 10:14:45.819
HD Request # 1 | Writing historical Daily data to the file ZW-197207-ECBOT.dly | 2022-04-25 10:14:45.819
HD Request # 1 | Bytes received: 2939 | 2022-04-25 10:14:45.820
HD Request # 1 | Received 62 Daily data records from 1972-04-25 00:00:00 to 1972-07-20 00:00:00 (87.0 days) and wrote 61 records for ZW-197207-ECBOT | 2022-04-25 10:14:45.820
HD Request # 1 | Completion time: 3s | 2022-04-25 10:14:45.820
HD Request # 1 | Daily data download complete for ZW-197207-ECBOT. Unique request ID: 1 | 2022-04-25 10:14:45.820
Removing historical data download ID 1. | 2022-04-25 10:14:45.820
Triggering next historical data download in queue. | 2022-04-25 10:14:45.820
Mapping ZW-197307-ECBOT to ZWN73. Service code: cbot | 2022-04-25 10:14:45.820
HD Request # 6 | Downloading Historical Daily chart data for ZW-197307-ECBOT. Starting date: 1972-06-19. Service: interactive_brokers.trading | 2022-04-25 10:14:45.820
SC Data - All Services | Received security definition for symbol AUD-202206-GLOBEX | 2022-04-25 10:14:45.888
SC Data - All Services | Real-time data for symbol MBT-202203-CMECRYPTO-USD-0.1 is currently unavailable. | 2022-04-25 10:14:45.888
SC Data - All Services | Received security definition for symbol MBT-202203-CMECRYPTO-USD-0.1 | 2022-04-25 10:14:45.888
SC Data - All Services | Received security definition for symbol MGC-202206-NYMEX-USD-10 | 2022-04-25 10:14:45.888
SC Data - All Services | Received security definition for symbol MNQ-202206-GLOBEX-USD | 2022-04-25 10:14:45.888
SC Data - All Services | Received security definition for symbol MYM-202206-ECBOT-USD | 2022-04-25 10:14:45.888
SC Data - All Services | Real-time data for symbol QG-202204-NYMEX is currently unavailable. | 2022-04-25 10:14:45.888
SC Data - All Services | Received security definition for symbol QG-202204-NYMEX | 2022-04-25 10:14:45.888
SC Data - All Services | Received security definition for symbol QG-202206-NYMEX | 2022-04-25 10:14:45.888
SC Data - All Services | Received security definition for symbol QM-202206-NYMEX | 2022-04-25 10:14:45.888
SC Data - All Services | Received security definition for symbol YK-202205-ECBOT-USD-1000 | 2022-04-25 10:14:45.888
SC Data - All Services | Received security definition for symbol ZC-202207-ECBOT | 2022-04-25 10:14:45.888
SC Data - All Services | Real-time data for symbol ZN-202112-ECBOT is currently unavailable. | 2022-04-25 10:14:45.888
SC Data - All Services | Received security definition for symbol ZN-202112-ECBOT | 2022-04-25 10:14:45.888
SC Data - All Services | Received security definition for symbol ZN-202206-ECBOT | 2022-04-25 10:14:45.888
SC Data - All Services | Received security definition for symbol ZW-202207-ECBOT | 2022-04-25 10:14:45.888
HD Request # 5 | Setting DTC encoding to Binary VLS | 2022-04-25 10:14:45.890
HD Request # 5 | Sending historical data logon request message. | 2022-04-25 10:14:45.890
MBT-202203-CMECRYPTO-USD-0.1 [C] 384 Min #6 | StartDateTimeForLoadingOrderFills: 2021-09-06 18:00:00 | 2022-04-25 10:14:45.933
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2022-04-25 10:14:46.330
IB TWS socket (1) | Creating socket. | 2022-04-25 10:14:46.330
IB TWS socket (1) | New receive buffer size: 5242880 | 2022-04-25 10:14:46.330
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2022-04-25 10:14:46.330
HD Request # 5 | Requesting historical Daily data starting at 2022-04-21. | 2022-04-25 10:14:46.643
Interactive Brokers | Sending API sign: API | 2022-04-25 10:14:46.841
Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2022-04-25 10:14:46.841
HD Request # 5 | Decompressing data. | 2022-04-25 10:14:46.870
HD Request # 5 | Receiving historical Daily data for AUS200 starting at 2022-04-21 | 2022-04-25 10:14:46.898
HD Request # 5 | Writing historical Daily data to the file AUS200.dly | 2022-04-25 10:14:46.898
Socket (2) | CloseSocket call. | 2022-04-25 10:14:46.960
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:14:46.960
Historical data download thread signaled to stop. | 2022-04-25 10:14:46.960
HD Request # 5 | Received 3 Daily data records from 2022-04-21 00:00:00 to 2022-04-25 00:00:00 (5.0 days) and wrote 3 records for AUS200 | 2022-04-25 10:14:46.960
HD Request # 5 | Completion time: 1s | 2022-04-25 10:14:46.960
HD Request # 5 | Daily data download complete for AUS200. Unique request ID: 99 | 2022-04-25 10:14:46.960
Removing historical data download ID 99. | 2022-04-25 10:14:46.960
Triggering next historical data download in queue. | 2022-04-25 10:14:46.960
HD Request # 7 | Downloading Historical Daily chart data for SPX500. Starting date: 2022-04-21. Service: fxcm | 2022-04-25 10:14:46.962
HD Request # 7 | Using server: ds4.sierracharts.com port 10150 | 2022-04-25 10:14:46.962
Socket (4) | Creating socket. | 2022-04-25 10:14:46.962
Socket (4) | New receive buffer size: 5242880 | 2022-04-25 10:14:46.962
Socket (4) | Connecting to IP: 192.81.56.146. | 2022-04-25 10:14:46.962
Interactive Brokers | TWS server version: 136 | 2022-04-25 10:14:47.075
Interactive Brokers | TWS time: 20220426 00:14:43 AEST | 2022-04-25 10:14:47.075
Socket (2) | Socket gracefully closed by remote side. | 2022-04-25 10:14:47.186
Socket (2) | Closed. | 2022-04-25 10:14:47.186
Interactive Brokers | Connected. Sending Start API command. | 2022-04-25 10:14:47.336
Interactive Brokers | Waiting for account information. | 2022-04-25 10:14:47.336
HD Request # 6 | Requesting historical Daily data for ZWN73 starting at 1972-06-18. SC External HD service. | 2022-04-25 10:14:47.336
IB Account information received. | 2022-04-25 10:14:47.338
Interactive Brokers | Received 1 Trade Accounts from TWS. | 2022-04-25 10:14:47.338
Interactive Brokers | Connected to Live account. | 2022-04-25 10:14:47.338
Updated verified funded futures trading account ending date to: 2022-05-25 14:14:47 | 2022-04-25 10:14:47.338
Interactive Brokers | Connected to server complete. | 2022-04-25 10:14:47.338
SC Data - All Services | Waiting for socket receive thread to end | 2022-04-25 10:14:47.339
DTC Client socket (8) | CloseSocket call. | 2022-04-25 10:14:47.339
DTC Client socket (8) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:14:47.339
SC Data - All Services | Disconnected from the server. | 2022-04-25 10:14:47.339
DTC Client socket (6) | CloseSocket call. | 2022-04-25 10:14:47.339
SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-04-25 10:14:47.339
DTC Client socket (6) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:14:47.339
DTC Client socket (5) | CloseSocket call. | 2022-04-25 10:14:47.339
SC DTC Data with Market Depth | Disconnected from the server. | 2022-04-25 10:14:47.339
DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:14:47.339
Triggering next historical data download in queue. | 2022-04-25 10:14:47.340
Updated verified funded futures trading account ending date to: 2022-05-25 14:14:47 | 2022-04-25 10:14:47.340
Next valid order ID: 941 | 2022-04-25 10:14:47.371
Message from IB: Market data farm connection is OK:usfarm.nj. IB Error Code: 2104. Request ID: -1. | 2022-04-25 10:14:47.371
Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2022-04-25 10:14:47.371
Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2022-04-25 10:14:47.371
Message from IB: HMDS data farm connection is OK:cashhmds. IB Error Code: 2106. Request ID: -1. | 2022-04-25 10:14:47.371
Message from IB: HMDS data farm connection is OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2022-04-25 10:14:47.371
Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2022-04-25 10:14:47.371
Message from IB: Sec-def data farm connection is OK:secdefil. IB Error Code: 2158. Request ID: -1. | 2022-04-25 10:14:47.371
No download requests in the queue to start downloads for. | 2022-04-25 10:14:47.371
Next valid order ID: 941 | 2022-04-25 10:14:47.372
Mapping SPY-NQTV to SPY-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.373
Using symbol data fast lookup vector | 2022-04-25 10:14:47.373
SC Data - All Services | Starting real-time market data updates for: SPY-NQTV (SPY-NQTV). ID: 1 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.373
SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 10048 | 2022-04-25 10:14:47.373
SC Data - All Services | Requesting security definition data for: SPY-NQTV (SPY-NQTV). ID: 1 | 2022-04-25 10:14:47.373
DTC Client socket (7) | Creating socket. | 2022-04-25 10:14:47.373
DTC Client socket (7) | New receive buffer size: 5242880 | 2022-04-25 10:14:47.373
DTC Client socket (7) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:14:47.373
Mapping ORLY-NQTV to ORLY-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.374
SC Data - All Services | Starting real-time market data updates for: ORLY-NQTV (ORLY-NQTV). ID: 2 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.374
SC Data - All Services | Requesting security definition data for: ORLY-NQTV (ORLY-NQTV). ID: 2 | 2022-04-25 10:14:47.374
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 1. Symbol: SPY-NQTV | 2022-04-25 10:14:47.374
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 2. Symbol: ORLY-NQTV | 2022-04-25 10:14:47.374
Mapping REXR-NQTV to REXR-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.376
SC Data - All Services | Starting real-time market data updates for: REXR-NQTV (REXR-NQTV). ID: 3 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.376
SC Data - All Services | Requesting security definition data for: REXR-NQTV (REXR-NQTV). ID: 3 | 2022-04-25 10:14:47.376
Mapping RADA-NQTV to RADA-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.376
SC Data - All Services | Starting real-time market data updates for: RADA-NQTV (RADA-NQTV). ID: 4 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.376
SC Data - All Services | Requesting security definition data for: RADA-NQTV (RADA-NQTV). ID: 4 | 2022-04-25 10:14:47.376
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 3. Symbol: REXR-NQTV | 2022-04-25 10:14:47.376
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 4. Symbol: RADA-NQTV | 2022-04-25 10:14:47.377
Mapping TMST-NQTV to TMST-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.377
SC Data - All Services | Starting real-time market data updates for: TMST-NQTV (TMST-NQTV). ID: 5 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.377
SC Data - All Services | Requesting security definition data for: TMST-NQTV (TMST-NQTV). ID: 5 | 2022-04-25 10:14:47.377
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 5. Symbol: TMST-NQTV | 2022-04-25 10:14:47.377
Mapping TNET-NQTV to TNET-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.378
SC Data - All Services | Starting real-time market data updates for: TNET-NQTV (TNET-NQTV). ID: 6 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.378
SC Data - All Services | Requesting security definition data for: TNET-NQTV (TNET-NQTV). ID: 6 | 2022-04-25 10:14:47.378
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 6. Symbol: TNET-NQTV | 2022-04-25 10:14:47.378
Mapping WCN-NQTV to WCN-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.381
SC Data - All Services | Starting real-time market data updates for: WCN-NQTV (WCN-NQTV). ID: 7 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.381
SC Data - All Services | Requesting security definition data for: WCN-NQTV (WCN-NQTV). ID: 7 | 2022-04-25 10:14:47.381
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 7. Symbol: WCN-NQTV | 2022-04-25 10:14:47.381
Mapping AUD-202206-GLOBEX to 6AM22. Service code: cme | 2022-04-25 10:14:47.382
SC Data - All Services | Starting real-time market data updates for: AUD-202206-GLOBEX (6AM22). ID: 8 Service code: cme | 2022-04-25 10:14:47.382
SC Data - All Services | Connecting to the server ds13.sierracharts.com. Port 10048 | 2022-04-25 10:14:47.382
SC Data - All Services | Requesting security definition data for: AUD-202206-GLOBEX (6AM22). ID: 8 | 2022-04-25 10:14:47.382
DTC Client socket (9) | Creating socket. | 2022-04-25 10:14:47.382
DTC Client socket (9) | New receive buffer size: 5242880 | 2022-04-25 10:14:47.382
DTC Client socket (9) | Connecting to IP: 64.38.174.178. | 2022-04-25 10:14:47.382
Using Bid/Ask average for last trade price for GBPUSD | 2022-04-25 10:14:47.383
SC DTC Data with Market Depth | Starting real-time market data updates for: GBPUSD. ID: 9 Service code: fxcm | 2022-04-25 10:14:47.383
SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2022-04-25 10:14:47.383
SC DTC Data with Market Depth | Requesting security definition data for: GBPUSD. ID: 9 | 2022-04-25 10:14:47.383
DTC Client socket (10) | Creating socket. | 2022-04-25 10:14:47.384
DTC Client socket (10) | New receive buffer size: 5242880 | 2022-04-25 10:14:47.384
DTC Client socket (10) | Connecting to IP: 192.81.56.146. | 2022-04-25 10:14:47.384
Interactive Brokers | Starting real-time market data updates for: ACRSn-CFD-SMART-USD. ID: 10 | 2022-04-25 10:14:47.384
Interactive Brokers | Subscribing to real-time True Data for symbol: ACRSn SecurityType: CFD Exchange: SMART Currency: USD | 2022-04-25 10:14:47.384
Interactive Brokers | Subscribing to Symbol: ACRSn, SecurityType: CFD, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2022-04-25 10:14:47.384
Interactive Brokers | Requesting security definition data for: ACRSn-CFD-SMART-USD. ID: 10 | 2022-04-25 10:14:47.384
Mapping ACRS-NQTV to ACRS-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.384
SC Data - All Services | Starting real-time market data updates for: ACRS-NQTV (ACRS-NQTV). ID: 11 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.384
SC Data - All Services | Requesting security definition data for: ACRS-NQTV (ACRS-NQTV). ID: 11 | 2022-04-25 10:14:47.384
Mapping AMR-NQTV to AMR-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.385
SC Data - All Services | Starting real-time market data updates for: AMR-NQTV (AMR-NQTV). ID: 12 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.385
SC Data - All Services | Requesting security definition data for: AMR-NQTV (AMR-NQTV). ID: 12 | 2022-04-25 10:14:47.385
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 11. Symbol: ACRS-NQTV | 2022-04-25 10:14:47.385
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 12. Symbol: AMR-NQTV | 2022-04-25 10:14:47.386
Mapping AA-NQTV to AA-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.387
SC Data - All Services | Starting real-time market data updates for: AA-NQTV (AA-NQTV). ID: 13 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.387
SC Data - All Services | Requesting security definition data for: AA-NQTV (AA-NQTV). ID: 13 | 2022-04-25 10:14:47.387
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 13. Symbol: AA-NQTV | 2022-04-25 10:14:47.387
Mapping CUBE-NQTV to CUBE-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.388
SC Data - All Services | Starting real-time market data updates for: CUBE-NQTV (CUBE-NQTV). ID: 14 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.388
SC Data - All Services | Requesting security definition data for: CUBE-NQTV (CUBE-NQTV). ID: 14 | 2022-04-25 10:14:47.388
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 14. Symbol: CUBE-NQTV | 2022-04-25 10:14:47.388
Mapping COST-NQTV to COST-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.389
SC Data - All Services | Starting real-time market data updates for: COST-NQTV (COST-NQTV). ID: 15 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.389
SC Data - All Services | Requesting security definition data for: COST-NQTV (COST-NQTV). ID: 15 | 2022-04-25 10:14:47.389
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 15. Symbol: COST-NQTV | 2022-04-25 10:14:47.389
Mapping EXR-NQTV to EXR-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.390
SC Data - All Services | Starting real-time market data updates for: EXR-NQTV (EXR-NQTV). ID: 16 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.390
SC Data - All Services | Requesting security definition data for: EXR-NQTV (EXR-NQTV). ID: 16 | 2022-04-25 10:14:47.390
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 16. Symbol: EXR-NQTV | 2022-04-25 10:14:47.391
Interactive Brokers | Starting real-time market data updates for: HESM. ID: 17 | 2022-04-25 10:14:47.392
Interactive Brokers | Subscribing to real-time True Data for symbol: HESM SecurityType: STK Exchange: SMART Currency: | 2022-04-25 10:14:47.392
Interactive Brokers | Subscribing to Symbol: HESM, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2022-04-25 10:14:47.392
Interactive Brokers | Requesting security definition data for: HESM. ID: 17 | 2022-04-25 10:14:47.392
Interactive Brokers | Starting real-time market data updates for: HESMn-CFD-SMART-USD. ID: 18 | 2022-04-25 10:14:47.392
Interactive Brokers | Subscribing to real-time True Data for symbol: HESMn SecurityType: CFD Exchange: SMART Currency: USD | 2022-04-25 10:14:47.392
Interactive Brokers | Subscribing to Symbol: HESMn, SecurityType: CFD, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2022-04-25 10:14:47.392
Interactive Brokers | Requesting security definition data for: HESMn-CFD-SMART-USD. ID: 18 | 2022-04-25 10:14:47.392
Mapping HESM-NQTV to HESM-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.392
Mapping KO-NQTV to KO-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.393
SC Data - All Services | Starting real-time market data updates for: KO-NQTV (KO-NQTV). ID: 20 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.393
SC Data - All Services | Requesting security definition data for: KO-NQTV (KO-NQTV). ID: 20 | 2022-04-25 10:14:47.393
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 20. Symbol: KO-NQTV | 2022-04-25 10:14:47.393
Mapping CALM-NQTV to CALM-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.397
SC Data - All Services | Starting real-time market data updates for: CALM-NQTV (CALM-NQTV). ID: 21 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.397
SC Data - All Services | Requesting security definition data for: CALM-NQTV (CALM-NQTV). ID: 21 | 2022-04-25 10:14:47.397
SC Data - All Services | Starting real-time market data updates for: HESM-NQTV (HESM-NQTV). ID: 19 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.397
SC Data - All Services | Requesting security definition data for: HESM-NQTV (HESM-NQTV). ID: 19 | 2022-04-25 10:14:47.397
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 21. Symbol: CALM-NQTV | 2022-04-25 10:14:47.397
Mapping LAC-NQTV to LAC-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.398
SC Data - All Services | Starting real-time market data updates for: LAC-NQTV (LAC-NQTV). ID: 22 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.398
SC Data - All Services | Requesting security definition data for: LAC-NQTV (LAC-NQTV). ID: 22 | 2022-04-25 10:14:47.398
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 19. Symbol: HESM-NQTV | 2022-04-25 10:14:47.398
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 22. Symbol: LAC-NQTV | 2022-04-25 10:14:47.398
Mapping LLY-NQTV to LLY-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.399
SC Data - All Services | Starting real-time market data updates for: LLY-NQTV (LLY-NQTV). ID: 23 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.399
SC Data - All Services | Requesting security definition data for: LLY-NQTV (LLY-NQTV). ID: 23 | 2022-04-25 10:14:47.399
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 23. Symbol: LLY-NQTV | 2022-04-25 10:14:47.399
Mapping OLN-NQTV to OLN-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.399
SC Data - All Services | Starting real-time market data updates for: OLN-NQTV (OLN-NQTV). ID: 24 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.400
SC Data - All Services | Requesting security definition data for: OLN-NQTV (OLN-NQTV). ID: 24 | 2022-04-25 10:14:47.400
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 24. Symbol: OLN-NQTV | 2022-04-25 10:14:47.400
Mapping QM-202206-NYMEX to QMM22. Service code: nymex | 2022-04-25 10:14:47.401
SC Data - All Services | Starting real-time market data updates for: QM-202206-NYMEX (QMM22). ID: 25 Service code: nymex | 2022-04-25 10:14:47.401
SC Data - All Services | Requesting security definition data for: QM-202206-NYMEX (QMM22). ID: 25 | 2022-04-25 10:14:47.401
Using Bid/Ask average for last trade price for USDOLLAR | 2022-04-25 10:14:47.402
SC DTC Data with Market Depth | Starting real-time market data updates for: USDOLLAR. ID: 26 Service code: fxcm | 2022-04-25 10:14:47.402
SC DTC Data with Market Depth | Requesting security definition data for: USDOLLAR. ID: 26 | 2022-04-25 10:14:47.402
Mapping HCC-NQTV to HCC-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.403
SC Data - All Services | Starting real-time market data updates for: HCC-NQTV (HCC-NQTV). ID: 27 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.403
SC Data - All Services | Requesting security definition data for: HCC-NQTV (HCC-NQTV). ID: 27 | 2022-04-25 10:14:47.403
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 27. Symbol: HCC-NQTV | 2022-04-25 10:14:47.403
Mapping HZNP-NQTV to HZNP-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.404
SC Data - All Services | Starting real-time market data updates for: HZNP-NQTV (HZNP-NQTV). ID: 28 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.405
SC Data - All Services | Requesting security definition data for: HZNP-NQTV (HZNP-NQTV). ID: 28 | 2022-04-25 10:14:47.405
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 28. Symbol: HZNP-NQTV | 2022-04-25 10:14:47.405
Mapping LSI-NQTV to LSI-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.405
SC Data - All Services | Starting real-time market data updates for: LSI-NQTV (LSI-NQTV). ID: 29 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.406
SC Data - All Services | Requesting security definition data for: LSI-NQTV (LSI-NQTV). ID: 29 | 2022-04-25 10:14:47.406
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 29. Symbol: LSI-NQTV | 2022-04-25 10:14:47.406
Mapping SWCH-NQTV to SWCH-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.407
SC Data - All Services | Starting real-time market data updates for: SWCH-NQTV (SWCH-NQTV). ID: 30 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.407
SC Data - All Services | Requesting security definition data for: SWCH-NQTV (SWCH-NQTV). ID: 30 | 2022-04-25 10:14:47.407
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 30. Symbol: SWCH-NQTV | 2022-04-25 10:14:47.407
Mapping WMT-NQTV to WMT-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.408
SC Data - All Services | Starting real-time market data updates for: WMT-NQTV (WMT-NQTV). ID: 31 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.408
SC Data - All Services | Requesting security definition data for: WMT-NQTV (WMT-NQTV). ID: 31 | 2022-04-25 10:14:47.408
Interactive Brokers | Starting real-time market data updates for: BTC-USD. ID: 32 | 2022-04-25 10:14:47.409
Interactive Brokers | Subscribing to real-time True Data for symbol: BTC SecurityType: USD Exchange: Currency: | 2022-04-25 10:14:47.409
Interactive Brokers | Subscribing to Symbol: BTC, SecurityType: USD, Expiration: , Exchange: , Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2022-04-25 10:14:47.409
Interactive Brokers | Requesting security definition data for: BTC-USD. ID: 32 | 2022-04-25 10:14:47.409
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 31. Symbol: WMT-NQTV | 2022-04-25 10:14:47.409
Message from IB: Error validating request.-'bX' : cause - Please enter exchange. IB Error Code: 321. Request ID: 32. Symbol: BTC-USD | 2022-04-25 10:14:47.409
Message from IB: Error validating request.-'bZ' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 32. Symbol: BTC-USD | 2022-04-25 10:14:47.409
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 32. Symbol: BTC-USD | 2022-04-25 10:14:47.410
HD Request # 7 | Setting DTC encoding to Binary VLS | 2022-04-25 10:14:47.411
HD Request # 7 | Sending historical data logon request message. | 2022-04-25 10:14:47.411
AUS200[M] 64 Day #7 | Reloading chart. | 2022-04-25 10:14:47.414
Using Bid/Ask average for last trade price for SPX500 | 2022-04-25 10:14:47.418
SC DTC Data with Market Depth | Starting real-time market data updates for: SPX500. ID: 33 Service code: fxcm | 2022-04-25 10:14:47.418
SC DTC Data with Market Depth | Requesting security definition data for: SPX500. ID: 33 | 2022-04-25 10:14:47.418
Using Bid/Ask average for last trade price for US30 | 2022-04-25 10:14:47.418
SC DTC Data with Market Depth | Starting real-time market data updates for: US30. ID: 34 Service code: fxcm | 2022-04-25 10:14:47.418
SC DTC Data with Market Depth | Requesting security definition data for: US30. ID: 34 | 2022-04-25 10:14:47.418
Using Bid/Ask average for last trade price for NAS100 | 2022-04-25 10:14:47.418
SC DTC Data with Market Depth | Starting real-time market data updates for: NAS100. ID: 35 Service code: fxcm | 2022-04-25 10:14:47.418
SC DTC Data with Market Depth | Requesting security definition data for: NAS100. ID: 35 | 2022-04-25 10:14:47.418
Using Bid/Ask average for last trade price for XAUUSD | 2022-04-25 10:14:47.419
SC DTC Data with Market Depth | Starting real-time market data updates for: XAUUSD. ID: 36 Service code: fxcm | 2022-04-25 10:14:47.419
SC DTC Data with Market Depth | Requesting security definition data for: XAUUSD. ID: 36 | 2022-04-25 10:14:47.419
Using Bid/Ask average for last trade price for AUDUSD | 2022-04-25 10:14:47.419
SC DTC Data with Market Depth | Starting real-time market data updates for: AUDUSD. ID: 37 Service code: fxcm | 2022-04-25 10:14:47.419
SC DTC Data with Market Depth | Requesting security definition data for: AUDUSD. ID: 37 | 2022-04-25 10:14:47.419
Using Bid/Ask average for last trade price for WHEATF | 2022-04-25 10:14:47.420
SC DTC Data with Market Depth | Starting real-time market data updates for: WHEATF. ID: 38 Service code: fxcm | 2022-04-25 10:14:47.420
SC DTC Data with Market Depth | Requesting security definition data for: WHEATF. ID: 38 | 2022-04-25 10:14:47.420
Using Bid/Ask average for last trade price for NGAS | 2022-04-25 10:14:47.420
SC DTC Data with Market Depth | Starting real-time market data updates for: NGAS. ID: 39 Service code: fxcm | 2022-04-25 10:14:47.420
SC DTC Data with Market Depth | Requesting security definition data for: NGAS. ID: 39 | 2022-04-25 10:14:47.420
Mapping DIA-NQTV to DIA-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.420
SC Data - All Services | Starting real-time market data updates for: DIA-NQTV (DIA-NQTV). ID: 40 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.420
SC Data - All Services | Requesting security definition data for: DIA-NQTV (DIA-NQTV). ID: 40 | 2022-04-25 10:14:47.420
Mapping QQQ-NQTV to QQQ-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.421
SC Data - All Services | Starting real-time market data updates for: QQQ-NQTV (QQQ-NQTV). ID: 41 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.421
SC Data - All Services | Requesting security definition data for: QQQ-NQTV (QQQ-NQTV). ID: 41 | 2022-04-25 10:14:47.421
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 40. Symbol: DIA-NQTV | 2022-04-25 10:14:47.421
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 41. Symbol: QQQ-NQTV | 2022-04-25 10:14:47.421
Mapping ZW-202207-ECBOT to ZWN22. Service code: cbot | 2022-04-25 10:14:47.423
SC Data - All Services | Starting real-time market data updates for: ZW-202207-ECBOT (ZWN22). ID: 42 Service code: cbot | 2022-04-25 10:14:47.423
SC Data - All Services | Requesting security definition data for: ZW-202207-ECBOT (ZWN22). ID: 42 | 2022-04-25 10:14:47.423
Mapping YK-202205-ECBOT-USD-1000 to XKK22. Service code: cbot | 2022-04-25 10:14:47.424
SC Data - All Services | Starting real-time market data updates for: YK-202205-ECBOT-USD-1000 (XKK22). ID: 43 Service code: cbot | 2022-04-25 10:14:47.424
SC Data - All Services | Requesting security definition data for: YK-202205-ECBOT-USD-1000 (XKK22). ID: 43 | 2022-04-25 10:14:47.424
Mapping ZC-202207-ECBOT to ZCN22. Service code: cbot | 2022-04-25 10:14:47.426
SC Data - All Services | Starting real-time market data updates for: ZC-202207-ECBOT (ZCN22). ID: 44 Service code: cbot | 2022-04-25 10:14:47.426
SC Data - All Services | Requesting security definition data for: ZC-202207-ECBOT (ZCN22). ID: 44 | 2022-04-25 10:14:47.426
Mapping MYM-202206-ECBOT-USD to MYMM22. Service code: cbot | 2022-04-25 10:14:47.427
SC Data - All Services | Starting real-time market data updates for: MYM-202206-ECBOT-USD (MYMM22). ID: 45 Service code: cbot | 2022-04-25 10:14:47.427
SC Data - All Services | Requesting security definition data for: MYM-202206-ECBOT-USD (MYMM22). ID: 45 | 2022-04-25 10:14:47.427
Mapping MNQ-202206-GLOBEX-USD to MNQM22. Service code: cme | 2022-04-25 10:14:47.428
SC Data - All Services | Starting real-time market data updates for: MNQ-202206-GLOBEX-USD (MNQM22). ID: 46 Service code: cme | 2022-04-25 10:14:47.428
SC Data - All Services | Requesting security definition data for: MNQ-202206-GLOBEX-USD (MNQM22). ID: 46 | 2022-04-25 10:14:47.428
Mapping ZN-202112-ECBOT to ZNZ21. Service code: cbot | 2022-04-25 10:14:47.430
SC Data - All Services | Starting real-time market data updates for: ZN-202112-ECBOT (ZNZ21). ID: 47 Service code: cbot | 2022-04-25 10:14:47.430
SC Data - All Services | Requesting security definition data for: ZN-202112-ECBOT (ZNZ21). ID: 47 | 2022-04-25 10:14:47.430
Mapping ZN-202206-ECBOT to ZNM22. Service code: cbot | 2022-04-25 10:14:47.430
SC Data - All Services | Starting real-time market data updates for: ZN-202206-ECBOT (ZNM22). ID: 48 Service code: cbot | 2022-04-25 10:14:47.430
SC Data - All Services | Requesting security definition data for: ZN-202206-ECBOT (ZNM22). ID: 48 | 2022-04-25 10:14:47.430
Mapping MGC-202206-NYMEX-USD-10 to MGCM22. Service code: comex | 2022-04-25 10:14:47.431
SC Data - All Services | Starting real-time market data updates for: MGC-202206-NYMEX-USD-10 (MGCM22). ID: 49 Service code: comex | 2022-04-25 10:14:47.431
SC Data - All Services | Requesting security definition data for: MGC-202206-NYMEX-USD-10 (MGCM22). ID: 49 | 2022-04-25 10:14:47.431
Mapping QG-202206-NYMEX to QGM22. Service code: nymex | 2022-04-25 10:14:47.432
SC Data - All Services | Starting real-time market data updates for: QG-202206-NYMEX (QGM22). ID: 50 Service code: nymex | 2022-04-25 10:14:47.432
SC Data - All Services | Requesting security definition data for: QG-202206-NYMEX (QGM22). ID: 50 | 2022-04-25 10:14:47.432
Mapping QG-202204-NYMEX to QGJ22. Service code: nymex | 2022-04-25 10:14:47.433
SC Data - All Services | Starting real-time market data updates for: QG-202204-NYMEX (QGJ22). ID: 51 Service code: nymex | 2022-04-25 10:14:47.433
SC Data - All Services | Requesting security definition data for: QG-202204-NYMEX (QGJ22). ID: 51 | 2022-04-25 10:14:47.433
Using Bid/Ask average for last trade price for USOil | 2022-04-25 10:14:47.434
SC DTC Data with Market Depth | Starting real-time market data updates for: USOil. ID: 52 Service code: fxcm | 2022-04-25 10:14:47.434
SC DTC Data with Market Depth | Requesting security definition data for: USOil. ID: 52 | 2022-04-25 10:14:47.434
Mapping FWONK-NQTV to FWONK-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.434
SC Data - All Services | Starting real-time market data updates for: FWONK-NQTV (FWONK-NQTV). ID: 53 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.435
SC Data - All Services | Requesting security definition data for: FWONK-NQTV (FWONK-NQTV). ID: 53 | 2022-04-25 10:14:47.435
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 53. Symbol: FWONK-NQTV | 2022-04-25 10:14:47.435
Mapping HCA-NQTV to HCA-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.435
SC Data - All Services | Starting real-time market data updates for: HCA-NQTV (HCA-NQTV). ID: 54 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.435
SC Data - All Services | Requesting security definition data for: HCA-NQTV (HCA-NQTV). ID: 54 | 2022-04-25 10:14:47.435
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 54. Symbol: HCA-NQTV | 2022-04-25 10:14:47.436
Mapping PFE-NQTV to PFE-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.436
SC Data - All Services | Starting real-time market data updates for: PFE-NQTV (PFE-NQTV). ID: 55 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.436
SC Data - All Services | Requesting security definition data for: PFE-NQTV (PFE-NQTV). ID: 55 | 2022-04-25 10:14:47.436
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 55. Symbol: PFE-NQTV | 2022-04-25 10:14:47.436
Mapping GBP-202206-GLOBEX to 6BM22. Service code: cme | 2022-04-25 10:14:47.438
SC Data - All Services | Starting real-time market data updates for: GBP-202206-GLOBEX (6BM22). ID: 56 Service code: cme | 2022-04-25 10:14:47.438
SC Data - All Services | Requesting security definition data for: GBP-202206-GLOBEX (6BM22). ID: 56 | 2022-04-25 10:14:47.439
Mapping BJ-NQTV to BJ-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.439
SC Data - All Services | Starting real-time market data updates for: BJ-NQTV (BJ-NQTV). ID: 57 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.439
SC Data - All Services | Requesting security definition data for: BJ-NQTV (BJ-NQTV). ID: 57 | 2022-04-25 10:14:47.439
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 57. Symbol: BJ-NQTV | 2022-04-25 10:14:47.440
Mapping DRE-NQTV to DRE-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.441
SC Data - All Services | Starting real-time market data updates for: DRE-NQTV (DRE-NQTV). ID: 58 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.441
SC Data - All Services | Requesting security definition data for: DRE-NQTV (DRE-NQTV). ID: 58 | 2022-04-25 10:14:47.441
Mapping DAR-NQTV to DAR-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.441
SC Data - All Services | Starting real-time market data updates for: DAR-NQTV (DAR-NQTV). ID: 59 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.441
SC Data - All Services | Requesting security definition data for: DAR-NQTV (DAR-NQTV). ID: 59 | 2022-04-25 10:14:47.441
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 58. Symbol: DRE-NQTV | 2022-04-25 10:14:47.442
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 59. Symbol: DAR-NQTV | 2022-04-25 10:14:47.442
Mapping FR-NQTV to FR-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.443
SC Data - All Services | Starting real-time market data updates for: FR-NQTV (FR-NQTV). ID: 60 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.443
SC Data - All Services | Requesting security definition data for: FR-NQTV (FR-NQTV). ID: 60 | 2022-04-25 10:14:47.443
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 60. Symbol: FR-NQTV | 2022-04-25 10:14:47.443
Mapping MGP-NQTV to MGP-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.444
SC Data - All Services | Starting real-time market data updates for: MGP-NQTV (MGP-NQTV). ID: 61 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.444
SC Data - All Services | Requesting security definition data for: MGP-NQTV (MGP-NQTV). ID: 61 | 2022-04-25 10:14:47.444
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 61. Symbol: MGP-NQTV | 2022-04-25 10:14:47.445
Mapping PFG-NQTV to PFG-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.445
SC Data - All Services | Starting real-time market data updates for: PFG-NQTV (PFG-NQTV). ID: 62 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.445
SC Data - All Services | Requesting security definition data for: PFG-NQTV (PFG-NQTV). ID: 62 | 2022-04-25 10:14:47.445
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 62. Symbol: PFG-NQTV | 2022-04-25 10:14:47.445
Mapping PWR-NQTV to PWR-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.446
SC Data - All Services | Starting real-time market data updates for: PWR-NQTV (PWR-NQTV). ID: 63 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.446
SC Data - All Services | Requesting security definition data for: PWR-NQTV (PWR-NQTV). ID: 63 | 2022-04-25 10:14:47.446
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 63. Symbol: PWR-NQTV | 2022-04-25 10:14:47.447
Mapping PAYX-NQTV to PAYX-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.448
SC Data - All Services | Starting real-time market data updates for: PAYX-NQTV (PAYX-NQTV). ID: 64 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.448
SC Data - All Services | Requesting security definition data for: PAYX-NQTV (PAYX-NQTV). ID: 64 | 2022-04-25 10:14:47.448
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 64. Symbol: PAYX-NQTV | 2022-04-25 10:14:47.448
Mapping PG-NQTV to PG-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.448
SC Data - All Services | Starting real-time market data updates for: PG-NQTV (PG-NQTV). ID: 65 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.448
SC Data - All Services | Requesting security definition data for: PG-NQTV (PG-NQTV). ID: 65 | 2022-04-25 10:14:47.448
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 65. Symbol: PG-NQTV | 2022-04-25 10:14:47.449
Mapping SMPL-NQTV to SMPL-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.449
SC Data - All Services | Starting real-time market data updates for: SMPL-NQTV (SMPL-NQTV). ID: 66 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.449
SC Data - All Services | Requesting security definition data for: SMPL-NQTV (SMPL-NQTV). ID: 66 | 2022-04-25 10:14:47.449
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 66. Symbol: SMPL-NQTV | 2022-04-25 10:14:47.449
Mapping STLD-NQTV to STLD-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.450
SC Data - All Services | Starting real-time market data updates for: STLD-NQTV (STLD-NQTV). ID: 67 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.450
SC Data - All Services | Requesting security definition data for: STLD-NQTV (STLD-NQTV). ID: 67 | 2022-04-25 10:14:47.450
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 67. Symbol: STLD-NQTV | 2022-04-25 10:14:47.450
Mapping XOM-NQTV to XOM-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.451
SC Data - All Services | Starting real-time market data updates for: XOM-NQTV (XOM-NQTV). ID: 68 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.451
SC Data - All Services | Requesting security definition data for: XOM-NQTV (XOM-NQTV). ID: 68 | 2022-04-25 10:14:47.451
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 68. Symbol: XOM-NQTV | 2022-04-25 10:14:47.451
Mapping XEC-NQTV to XEC-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.452
SC Data - All Services | Starting real-time market data updates for: XEC-NQTV (XEC-NQTV). ID: 69 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.452
SC Data - All Services | Requesting security definition data for: XEC-NQTV (XEC-NQTV). ID: 69 | 2022-04-25 10:14:47.452
Mapping X-NQTV to X-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.452
SC Data - All Services | Starting real-time market data updates for: X-NQTV (X-NQTV). ID: 70 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.452
SC Data - All Services | Requesting security definition data for: X-NQTV (X-NQTV). ID: 70 | 2022-04-25 10:14:47.453
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 69. Symbol: XEC-NQTV | 2022-04-25 10:14:47.453
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 70. Symbol: X-NQTV | 2022-04-25 10:14:47.453
Mapping MBT-202203-CMECRYPTO-USD-0.1 to MBTH22. Service code: cme | 2022-04-25 10:14:47.454
SC Data - All Services | Starting real-time market data updates for: MBT-202203-CMECRYPTO-USD-0.1 (MBTH22). ID: 71 Service code: cme | 2022-04-25 10:14:47.454
SC Data - All Services | Requesting security definition data for: MBT-202203-CMECRYPTO-USD-0.1 (MBTH22). ID: 71 | 2022-04-25 10:14:47.454
Mapping AJG-NQTV to AJG-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.455
SC Data - All Services | Starting real-time market data updates for: AJG-NQTV (AJG-NQTV). ID: 72 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.455
SC Data - All Services | Requesting security definition data for: AJG-NQTV (AJG-NQTV). ID: 72 | 2022-04-25 10:14:47.455
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 72. Symbol: AJG-NQTV | 2022-04-25 10:14:47.455
Mapping ACHC-NQTV to ACHC-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.456
SC Data - All Services | Starting real-time market data updates for: ACHC-NQTV (ACHC-NQTV). ID: 73 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.456
SC Data - All Services | Requesting security definition data for: ACHC-NQTV (ACHC-NQTV). ID: 73 | 2022-04-25 10:14:47.456
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 73. Symbol: ACHC-NQTV | 2022-04-25 10:14:47.456
Mapping DKL-NQTV to DKL-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.457
SC Data - All Services | Starting real-time market data updates for: DKL-NQTV (DKL-NQTV). ID: 74 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.457
SC Data - All Services | Requesting security definition data for: DKL-NQTV (DKL-NQTV). ID: 74 | 2022-04-25 10:14:47.457
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 74. Symbol: DKL-NQTV | 2022-04-25 10:14:47.457
Mapping GCBC-NQTV to GCBC-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.458
SC Data - All Services | Starting real-time market data updates for: GCBC-NQTV (GCBC-NQTV). ID: 75 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.458
SC Data - All Services | Requesting security definition data for: GCBC-NQTV (GCBC-NQTV). ID: 75 | 2022-04-25 10:14:47.458
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 75. Symbol: GCBC-NQTV | 2022-04-25 10:14:47.458
Mapping IT-NQTV to IT-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.459
SC Data - All Services | Starting real-time market data updates for: IT-NQTV (IT-NQTV). ID: 76 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.459
SC Data - All Services | Requesting security definition data for: IT-NQTV (IT-NQTV). ID: 76 | 2022-04-25 10:14:47.459
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 76. Symbol: IT-NQTV | 2022-04-25 10:14:47.460
Mapping NEM-NQTV to NEM-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.460
SC Data - All Services | Starting real-time market data updates for: NEM-NQTV (NEM-NQTV). ID: 77 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.461
SC Data - All Services | Requesting security definition data for: NEM-NQTV (NEM-NQTV). ID: 77 | 2022-04-25 10:14:47.461
Mapping PLD-NQTV to PLD-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.461
SC Data - All Services | Starting real-time market data updates for: PLD-NQTV (PLD-NQTV). ID: 78 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.461
SC Data - All Services | Requesting security definition data for: PLD-NQTV (PLD-NQTV). ID: 78 | 2022-04-25 10:14:47.461
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 77. Symbol: NEM-NQTV | 2022-04-25 10:14:47.461
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 78. Symbol: PLD-NQTV | 2022-04-25 10:14:47.462
Mapping TXT-NQTV to TXT-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.462
SC Data - All Services | Starting real-time market data updates for: TXT-NQTV (TXT-NQTV). ID: 79 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.462
SC Data - All Services | Requesting security definition data for: TXT-NQTV (TXT-NQTV). ID: 79 | 2022-04-25 10:14:47.462
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 79. Symbol: TXT-NQTV | 2022-04-25 10:14:47.463
Mapping TSN-NQTV to TSN-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.463
SC Data - All Services | Starting real-time market data updates for: TSN-NQTV (TSN-NQTV). ID: 80 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.464
SC Data - All Services | Requesting security definition data for: TSN-NQTV (TSN-NQTV). ID: 80 | 2022-04-25 10:14:47.464
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 80. Symbol: TSN-NQTV | 2022-04-25 10:14:47.464
Mapping AMX-NQTV to AMX-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.465
SC Data - All Services | Starting real-time market data updates for: AMX-NQTV (AMX-NQTV). ID: 81 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.465
SC Data - All Services | Requesting security definition data for: AMX-NQTV (AMX-NQTV). ID: 81 | 2022-04-25 10:14:47.465
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 81. Symbol: AMX-NQTV | 2022-04-25 10:14:47.465
Mapping CLH-NQTV to CLH-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.466
SC Data - All Services | Starting real-time market data updates for: CLH-NQTV (CLH-NQTV). ID: 82 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.466
SC Data - All Services | Requesting security definition data for: CLH-NQTV (CLH-NQTV). ID: 82 | 2022-04-25 10:14:47.466
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 82. Symbol: CLH-NQTV | 2022-04-25 10:14:47.466
Mapping GNK-NQTV to GNK-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.467
SC Data - All Services | Starting real-time market data updates for: GNK-NQTV (GNK-NQTV). ID: 83 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.467
SC Data - All Services | Requesting security definition data for: GNK-NQTV (GNK-NQTV). ID: 83 | 2022-04-25 10:14:47.467
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 83. Symbol: GNK-NQTV | 2022-04-25 10:14:47.468
Mapping NSA-NQTV to NSA-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.468
SC Data - All Services | Starting real-time market data updates for: NSA-NQTV (NSA-NQTV). ID: 84 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.468
SC Data - All Services | Requesting security definition data for: NSA-NQTV (NSA-NQTV). ID: 84 | 2022-04-25 10:14:47.468
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 84. Symbol: NSA-NQTV | 2022-04-25 10:14:47.468
Mapping VIRT-NQTV to VIRT-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.469
SC Data - All Services | Starting real-time market data updates for: VIRT-NQTV (VIRT-NQTV). ID: 85 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.469
SC Data - All Services | Requesting security definition data for: VIRT-NQTV (VIRT-NQTV). ID: 85 | 2022-04-25 10:14:47.469
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 85. Symbol: VIRT-NQTV | 2022-04-25 10:14:47.470
Added historical Intraday data request for MBT-202203-CMECRYPTO-USD-0.1 to the queue. | 2022-04-25 10:14:47.470
Intraday data recording state for symbol MBT-202203-CMECRYPTO-USD-0.1 is set to download 'Pending'. | 2022-04-25 10:14:47.470
Triggering next historical data download in queue. | 2022-04-25 10:14:47.470
Mapping AMH-NQTV to AMH-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.472
SC Data - All Services | Starting real-time market data updates for: AMH-NQTV (AMH-NQTV). ID: 86 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.472
SC Data - All Services | Requesting security definition data for: AMH-NQTV (AMH-NQTV). ID: 86 | 2022-04-25 10:14:47.472
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 86. Symbol: AMH-NQTV | 2022-04-25 10:14:47.472
Interactive Brokers | Starting real-time market data updates for: CLHn-CFD-SMART-USD. ID: 87 | 2022-04-25 10:14:47.473
Interactive Brokers | Subscribing to real-time True Data for symbol: CLHn SecurityType: CFD Exchange: SMART Currency: USD | 2022-04-25 10:14:47.473
Interactive Brokers | Subscribing to Symbol: CLHn, SecurityType: CFD, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2022-04-25 10:14:47.473
Interactive Brokers | Requesting security definition data for: CLHn-CFD-SMART-USD. ID: 87 | 2022-04-25 10:14:47.473
Mapping EVH-NQTV to EVH-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.474
SC Data - All Services | Starting real-time market data updates for: EVH-NQTV (EVH-NQTV). ID: 88 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.474
SC Data - All Services | Requesting security definition data for: EVH-NQTV (EVH-NQTV). ID: 88 | 2022-04-25 10:14:47.474
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 88. Symbol: EVH-NQTV | 2022-04-25 10:14:47.474
Mapping EW-NQTV to EW-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.474
SC Data - All Services | Starting real-time market data updates for: EW-NQTV (EW-NQTV). ID: 89 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.475
SC Data - All Services | Requesting security definition data for: EW-NQTV (EW-NQTV). ID: 89 | 2022-04-25 10:14:47.475
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 89. Symbol: EW-NQTV | 2022-04-25 10:14:47.475
Mapping NVO-NQTV to NVO-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.478
SC Data - All Services | Starting real-time market data updates for: NVO-NQTV (NVO-NQTV). ID: 90 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.478
SC Data - All Services | Requesting security definition data for: NVO-NQTV (NVO-NQTV). ID: 90 | 2022-04-25 10:14:47.478
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 90. Symbol: NVO-NQTV | 2022-04-25 10:14:47.478
Mapping TSLA-NQTV to TSLA-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.479
SC Data - All Services | Starting real-time market data updates for: TSLA-NQTV (TSLA-NQTV). ID: 91 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.480
SC Data - All Services | Requesting security definition data for: TSLA-NQTV (TSLA-NQTV). ID: 91 | 2022-04-25 10:14:47.480
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 91. Symbol: TSLA-NQTV | 2022-04-25 10:14:47.481
Mapping VET-NQTV to VET-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.482
SC Data - All Services | Starting real-time market data updates for: VET-NQTV (VET-NQTV). ID: 92 Service code: nasdaq_exchange.data | 2022-04-25 10:14:47.483
SC Data - All Services | Requesting security definition data for: VET-NQTV (VET-NQTV). ID: 92 | 2022-04-25 10:14:47.483
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 92. Symbol: VET-NQTV | 2022-04-25 10:14:47.529
SC Data - All Services | Network connection to server complete. | 2022-04-25 10:14:47.575
SC Data - All Services | Starting socket receive thread. | 2022-04-25 10:14:47.575
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-04-25 10:14:47.575
SC Data - All Services | Network connection to server complete. | 2022-04-25 10:14:47.600
SC Data - All Services | Starting socket receive thread. | 2022-04-25 10:14:47.600
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-04-25 10:14:47.601
SC DTC Data with Market Depth | Network connection to server complete. | 2022-04-25 10:14:47.608
SC DTC Data with Market Depth | Starting socket receive thread. | 2022-04-25 10:14:47.608
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-04-25 10:14:47.609
Symbol Error - ACRSn-CFD-SMART-USD is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2022-04-25 10:14:47.616
Interactive Brokers | Market data type is Live for HESM | 2022-04-25 10:14:47.618
Symbol Error - ACRSn-CFD-SMART-USD is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2022-04-25 10:14:47.619
Symbol Error - HESMn-CFD-SMART-USD is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2022-04-25 10:14:47.653
Symbol Error - HESMn-CFD-SMART-USD is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2022-04-25 10:14:47.654
Using Bid/Ask average for last trade price for AUS200 | 2022-04-25 10:14:47.663
SC DTC Data with Market Depth | Starting real-time market data updates for: AUS200. ID: 93 Service code: fxcm | 2022-04-25 10:14:47.663
SC DTC Data with Market Depth | Requesting security definition data for: AUS200. ID: 93 | 2022-04-25 10:14:47.663
Symbol Error - CLHn-CFD-SMART-USD is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2022-04-25 10:14:47.698
Symbol Error - CLHn-CFD-SMART-USD is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2022-04-25 10:14:47.699
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-04-25 10:14:47.775
SC Data - All Services | Sending logon request message. | 2022-04-25 10:14:47.775
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-04-25 10:14:47.843
SC Data - All Services | Sending logon request message. | 2022-04-25 10:14:47.843
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-04-25 10:14:47.864
SC DTC Data with Market Depth | Sending logon request message. | 2022-04-25 10:14:47.864
HD Request # 7 | Requesting historical Daily data starting at 2022-04-21. | 2022-04-25 10:14:48.164
HD Request # 6 | Receiving historical Daily data for ZW-197307-ECBOT starting at 1972-09-25 | 2022-04-25 10:14:48.170
HD Request # 6 | Writing historical Daily data to the file ZW-197307-ECBOT.dly | 2022-04-25 10:14:48.170
HD Request # 6 | Bytes received: 8846 | 2022-04-25 10:14:48.171
HD Request # 6 | Received 205 Daily data records from 1972-09-25 00:00:00 to 1973-07-20 00:00:00 (299.0 days) and wrote 205 records for ZW-197307-ECBOT | 2022-04-25 10:14:48.171
HD Request # 6 | Completion time: 3s | 2022-04-25 10:14:48.171
HD Request # 6 | Daily data download complete for ZW-197307-ECBOT. Unique request ID: 2 | 2022-04-25 10:14:48.171
Removing historical data download ID 2. | 2022-04-25 10:14:48.171
Triggering next historical data download in queue. | 2022-04-25 10:14:48.171
Mapping ZW-197407-ECBOT to ZWN74. Service code: cbot | 2022-04-25 10:14:48.171
HD Request # 8 | Downloading Historical Daily chart data for ZW-197407-ECBOT. Starting date: 1973-06-18. Service: interactive_brokers.trading | 2022-04-25 10:14:48.172
HD Request # 7 | Decompressing data. | 2022-04-25 10:14:48.389
HD Request # 7 | Receiving historical Daily data for SPX500 starting at 2022-04-21 | 2022-04-25 10:14:48.406
HD Request # 7 | Writing historical Daily data to the file SPX500.dly | 2022-04-25 10:14:48.407
Socket (4) | CloseSocket call. | 2022-04-25 10:14:48.468
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:14:48.468
Historical data download thread signaled to stop. | 2022-04-25 10:14:48.505
HD Request # 7 | Received 3 Daily data records from 2022-04-21 00:00:00 to 2022-04-25 00:00:00 (5.0 days) and wrote 3 records for SPX500 | 2022-04-25 10:14:48.505
HD Request # 7 | Completion time: 2s | 2022-04-25 10:14:48.505
HD Request # 7 | Daily data download complete for SPX500. Unique request ID: 100 | 2022-04-25 10:14:48.505
Removing historical data download ID 100. | 2022-04-25 10:14:48.505
Triggering next historical data download in queue. | 2022-04-25 10:14:48.505
HD Request # 9 | Downloading Historical Daily chart data for US30. Starting date: 2022-04-21. Service: fxcm | 2022-04-25 10:14:48.507
HD Request # 9 | Using server: ds12.sierracharts.com port 10149 | 2022-04-25 10:14:48.507
Socket (11) | Creating socket. | 2022-04-25 10:14:48.507
Socket (11) | New receive buffer size: 5242880 | 2022-04-25 10:14:48.507
Socket (11) | Connecting to IP: 204.15.197.14. | 2022-04-25 10:14:48.507
Socket (4) | Socket gracefully closed by remote side. | 2022-04-25 10:14:48.692
Socket (4) | Closed. | 2022-04-25 10:14:48.692
SPX500[M] 4 Day #8 | Reloading chart. | 2022-04-25 10:14:48.704
SC DTC Data with Market Depth | Received logon response. | 2022-04-25 10:14:48.709
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-04-25 10:14:48.709
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-04-25 10:14:48.709
SC DTC Data with Market Depth | Successfully connected. | 2022-04-25 10:14:48.709
SC DTC Data with Market Depth | Trading is not supported. | 2022-04-25 10:14:48.709
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDUSD | 2022-04-25 10:14:48.709
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUS200 | 2022-04-25 10:14:48.709
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPUSD | 2022-04-25 10:14:48.709
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NAS100 | 2022-04-25 10:14:48.709
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NGAS | 2022-04-25 10:14:48.709
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2022-04-25 10:14:48.709
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2022-04-25 10:14:48.709
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDOLLAR | 2022-04-25 10:14:48.709
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2022-04-25 10:14:48.709
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: WHEATF | 2022-04-25 10:14:48.709
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2022-04-25 10:14:48.709
SC Data - All Services | Received logon response. | 2022-04-25 10:14:48.719
SC Data - All Services | Server Name: SC Realtime Server. | 2022-04-25 10:14:48.719
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-04-25 10:14:48.719
SC Data - All Services | Successfully connected. | 2022-04-25 10:14:48.719
SC Data - All Services | Trading is not supported. | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: AA-NQTV -> AA-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: ACHC-NQTV -> ACHC-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: ACRS-NQTV -> ACRS-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: AJG-NQTV -> AJG-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: AMH-NQTV -> AMH-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: AMR-NQTV -> AMR-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: AMX-NQTV -> AMX-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: BJ-NQTV -> BJ-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: CALM-NQTV -> CALM-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: CLH-NQTV -> CLH-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: COST-NQTV -> COST-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: CUBE-NQTV -> CUBE-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: DAR-NQTV -> DAR-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: DIA-NQTV -> DIA-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: DKL-NQTV -> DKL-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: DRE-NQTV -> DRE-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: EVH-NQTV -> EVH-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: EW-NQTV -> EW-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: EXR-NQTV -> EXR-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: FR-NQTV -> FR-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: FWONK-NQTV -> FWONK-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: GCBC-NQTV -> GCBC-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: GNK-NQTV -> GNK-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: HCA-NQTV -> HCA-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: HCC-NQTV -> HCC-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: HESM-NQTV -> HESM-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: HZNP-NQTV -> HZNP-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: IT-NQTV -> IT-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: KO-NQTV -> KO-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: LAC-NQTV -> LAC-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: LLY-NQTV -> LLY-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: LSI-NQTV -> LSI-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: MGP-NQTV -> MGP-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: NEM-NQTV -> NEM-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: NSA-NQTV -> NSA-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: NVO-NQTV -> NVO-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: OLN-NQTV -> OLN-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: ORLY-NQTV -> ORLY-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: PAYX-NQTV -> PAYX-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: PFE-NQTV -> PFE-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: PFG-NQTV -> PFG-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: PG-NQTV -> PG-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: PLD-NQTV -> PLD-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: PWR-NQTV -> PWR-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: QQQ-NQTV -> QQQ-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: RADA-NQTV -> RADA-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: REXR-NQTV -> REXR-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: SMPL-NQTV -> SMPL-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: SPY-NQTV -> SPY-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: STLD-NQTV -> STLD-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: SWCH-NQTV -> SWCH-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: TMST-NQTV -> TMST-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: TNET-NQTV -> TNET-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: TSLA-NQTV -> TSLA-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: TSN-NQTV -> TSN-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: TXT-NQTV -> TXT-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: VET-NQTV -> VET-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: VIRT-NQTV -> VIRT-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: WCN-NQTV -> WCN-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: WMT-NQTV -> WMT-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: X-NQTV -> X-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: XEC-NQTV -> XEC-NQTV | 2022-04-25 10:14:48.719
SC Data - All Services | Restarting real-time data updates for symbol: XOM-NQTV -> XOM-NQTV | 2022-04-25 10:14:48.719
HD Request # 9 | Setting DTC encoding to Binary VLS | 2022-04-25 10:14:48.988
HD Request # 9 | Sending historical data logon request message. | 2022-04-25 10:14:48.988
SC DTC Data with Market Depth | Received security definition for symbol AUDUSD | 2022-04-25 10:14:49.048
SC DTC Data with Market Depth | Received security definition for symbol AUS200 | 2022-04-25 10:14:49.048
SC DTC Data with Market Depth | Received security definition for symbol GBPUSD | 2022-04-25 10:14:49.048
SC DTC Data with Market Depth | Received security definition for symbol NAS100 | 2022-04-25 10:14:49.048
SC DTC Data with Market Depth | Received security definition for symbol NGAS | 2022-04-25 10:14:49.048
SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2022-04-25 10:14:49.048
SC DTC Data with Market Depth | Received security definition for symbol US30 | 2022-04-25 10:14:49.048
SC DTC Data with Market Depth | Received security definition for symbol USDOLLAR | 2022-04-25 10:14:49.048
SC DTC Data with Market Depth | Received security definition for symbol USOil | 2022-04-25 10:14:49.048
SC DTC Data with Market Depth | Received security definition for symbol WHEATF | 2022-04-25 10:14:49.048
SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2022-04-25 10:14:49.048
SC Data - All Services | Received logon response. | 2022-04-25 10:14:49.048
SC Data - All Services | Server Name: SC Realtime Server. | 2022-04-25 10:14:49.048
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-04-25 10:14:49.048
SC Data - All Services | Successfully connected. | 2022-04-25 10:14:49.048
SC Data - All Services | Trading is not supported. | 2022-04-25 10:14:49.048
SC Data - All Services | Restarting real-time data updates for symbol: AUD-202206-GLOBEX -> 6AM22 | 2022-04-25 10:14:49.048
SC Data - All Services | Restarting real-time data updates for symbol: GBP-202206-GLOBEX -> 6BM22 | 2022-04-25 10:14:49.048
SC Data - All Services | Restarting real-time data updates for symbol: MBT-202203-CMECRYPTO-USD-0.1 -> MBTH22 | 2022-04-25 10:14:49.048
SC Data - All Services | Restarting real-time data updates for symbol: MGC-202206-NYMEX-USD-10 -> MGCM22 | 2022-04-25 10:14:49.048
SC Data - All Services | Restarting real-time data updates for symbol: MNQ-202206-GLOBEX-USD -> MNQM22 | 2022-04-25 10:14:49.048
SC Data - All Services | Restarting real-time data updates for symbol: MYM-202206-ECBOT-USD -> MYMM22 | 2022-04-25 10:14:49.048
SC Data - All Services | Restarting real-time data updates for symbol: QG-202204-NYMEX -> QGJ22 | 2022-04-25 10:14:49.048
SC Data - All Services | Restarting real-time data updates for symbol: QG-202206-NYMEX -> QGM22 | 2022-04-25 10:14:49.048
SC Data - All Services | Restarting real-time data updates for symbol: QM-202206-NYMEX -> QMM22 | 2022-04-25 10:14:49.048
SC Data - All Services | Restarting real-time data updates for symbol: YK-202205-ECBOT-USD-1000 -> XKK22 | 2022-04-25 10:14:49.048
SC Data - All Services | Restarting real-time data updates for symbol: ZC-202207-ECBOT -> ZCN22 | 2022-04-25 10:14:49.048
SC Data - All Services | Restarting real-time data updates for symbol: ZN-202112-ECBOT -> ZNZ21 | 2022-04-25 10:14:49.048
SC Data - All Services | Restarting real-time data updates for symbol: ZN-202206-ECBOT -> ZNM22 | 2022-04-25 10:14:49.048
SC Data - All Services | Restarting real-time data updates for symbol: ZW-202207-ECBOT -> ZWN22 | 2022-04-25 10:14:49.048
HD Request # 9 | Requesting historical Daily data starting at 2022-04-21. | 2022-04-25 10:14:49.213
SC Data - All Services | Received security definition for symbol AA-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol ACHC-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol ACRS-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol AJG-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol AMH-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol AMR-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol AMX-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol BJ-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol CALM-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol CLH-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol COST-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol CUBE-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol DAR-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol DIA-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol DKL-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol DRE-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol EVH-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol EW-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol EXR-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol FR-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol FWONK-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol GCBC-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol GNK-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol HCA-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol HCC-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol HESM-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol HZNP-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol IT-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol KO-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol LAC-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol LLY-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol LSI-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol MGP-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol NEM-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol NSA-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol NVO-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol OLN-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol ORLY-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol PAYX-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol PFE-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol PFG-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol PG-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol PLD-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol PWR-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol QQQ-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol RADA-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol REXR-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol SMPL-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol SPY-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol STLD-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol SWCH-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol TMST-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol TNET-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol TSLA-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol TSN-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol TXT-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol VET-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol VIRT-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol WCN-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol WMT-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol X-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Real-time data for symbol XEC-NQTV is currently unavailable. | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol XEC-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol XOM-NQTV | 2022-04-25 10:14:49.257
SC Data - All Services | Received security definition for symbol AUD-202206-GLOBEX | 2022-04-25 10:14:49.343
SC Data - All Services | Received security definition for symbol GBP-202206-GLOBEX | 2022-04-25 10:14:49.343
SC Data - All Services | Real-time data for symbol MBT-202203-CMECRYPTO-USD-0.1 is currently unavailable. | 2022-04-25 10:14:49.343
SC Data - All Services | Received security definition for symbol MBT-202203-CMECRYPTO-USD-0.1 | 2022-04-25 10:14:49.343
SC Data - All Services | Received security definition for symbol MGC-202206-NYMEX-USD-10 | 2022-04-25 10:14:49.343
SC Data - All Services | Received security definition for symbol MNQ-202206-GLOBEX-USD | 2022-04-25 10:14:49.343
SC Data - All Services | Received security definition for symbol MYM-202206-ECBOT-USD | 2022-04-25 10:14:49.343
SC Data - All Services | Real-time data for symbol QG-202204-NYMEX is currently unavailable. | 2022-04-25 10:14:49.343
SC Data - All Services | Received security definition for symbol QG-202204-NYMEX | 2022-04-25 10:14:49.343
SC Data - All Services | Received security definition for symbol QG-202206-NYMEX | 2022-04-25 10:14:49.343
SC Data - All Services | Received security definition for symbol QM-202206-NYMEX | 2022-04-25 10:14:49.343
SC Data - All Services | Received security definition for symbol YK-202205-ECBOT-USD-1000 | 2022-04-25 10:14:49.343
SC Data - All Services | Received security definition for symbol ZC-202207-ECBOT | 2022-04-25 10:14:49.343
SC Data - All Services | Real-time data for symbol ZN-202112-ECBOT is currently unavailable. | 2022-04-25 10:14:49.343
SC Data - All Services | Received security definition for symbol ZN-202112-ECBOT | 2022-04-25 10:14:49.343
SC Data - All Services | Received security definition for symbol ZN-202206-ECBOT | 2022-04-25 10:14:49.343
SC Data - All Services | Received security definition for symbol ZW-202207-ECBOT | 2022-04-25 10:14:49.343
HD Request # 9 | Decompressing data. | 2022-04-25 10:14:49.439
HD Request # 9 | Receiving historical Daily data for US30 starting at 2022-04-21 | 2022-04-25 10:14:49.456
HD Request # 9 | Writing historical Daily data to the file US30.dly | 2022-04-25 10:14:49.456
Socket (11) | CloseSocket call. | 2022-04-25 10:14:49.482
Socket (11) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:14:49.482
Historical data download thread signaled to stop. | 2022-04-25 10:14:49.482
HD Request # 9 | Received 3 Daily data records from 2022-04-21 00:00:00 to 2022-04-25 00:00:00 (5.0 days) and wrote 3 records for US30 | 2022-04-25 10:14:49.482
HD Request # 9 | Completion time: 1s | 2022-04-25 10:14:49.482
HD Request # 9 | Daily data download complete for US30. Unique request ID: 101 | 2022-04-25 10:14:49.482
Removing historical data download ID 101. | 2022-04-25 10:14:49.482
Triggering next historical data download in queue. | 2022-04-25 10:14:49.482
HD Request # 10 | Downloading Historical Daily chart data for NAS100. Starting date: 2022-04-21. Service: fxcm | 2022-04-25 10:14:49.484
HD Request # 10 | Using server: ds4.sierracharts.com port 10150 | 2022-04-25 10:14:49.484
Socket (2) | Creating socket. | 2022-04-25 10:14:49.484
Socket (2) | New receive buffer size: 5242880 | 2022-04-25 10:14:49.484
Socket (2) | Connecting to IP: 192.81.56.146. | 2022-04-25 10:14:49.484
HD Request # 8 | Requesting historical Daily data for ZWN74 starting at 1973-06-17. SC External HD service. | 2022-04-25 10:14:49.584
US30[M] Daily #10 | Reloading chart. | 2022-04-25 10:14:49.664
US30[M] Daily #1 | Reloading chart. | 2022-04-25 10:14:49.672
US30[M] Daily #10 | StartDateTimeForLoadingOrderFills: 2011-01-03 00:00:00 | 2022-04-25 10:14:49.699
Socket (11) | Socket gracefully closed by remote side. | 2022-04-25 10:14:49.709
Socket (11) | Closed. | 2022-04-25 10:14:49.709
HD Request # 10 | Setting DTC encoding to Binary VLS | 2022-04-25 10:14:49.937
HD Request # 10 | Sending historical data logon request message. | 2022-04-25 10:14:49.937
HD Request # 10 | Requesting historical Daily data starting at 2022-04-21. | 2022-04-25 10:14:50.163
HD Request # 8 | Receiving historical Daily data for ZW-197407-ECBOT starting at 1973-07-24 | 2022-04-25 10:14:50.342
HD Request # 8 | Writing historical Daily data to the file ZW-197407-ECBOT.dly | 2022-04-25 10:14:50.342
HD Request # 8 | Bytes received: 9501 | 2022-04-25 10:14:50.343
HD Request # 8 | Received 249 Daily data records from 1973-07-24 00:00:00 to 1974-07-22 00:00:00 (364.0 days) and wrote 249 records for ZW-197407-ECBOT | 2022-04-25 10:14:50.343
HD Request # 8 | Completion time: 2s | 2022-04-25 10:14:50.343
HD Request # 8 | Daily data download complete for ZW-197407-ECBOT. Unique request ID: 3 | 2022-04-25 10:14:50.343
Removing historical data download ID 3. | 2022-04-25 10:14:50.344
Triggering next historical data download in queue. | 2022-04-25 10:14:50.344
Mapping ZW-197507-ECBOT to ZWN75. Service code: cbot | 2022-04-25 10:14:50.344
HD Request # 11 | Downloading Historical Daily chart data for ZW-197507-ECBOT. Starting date: 1974-06-17. Service: interactive_brokers.trading | 2022-04-25 10:14:50.344
HD Request # 10 | Decompressing data. | 2022-04-25 10:14:50.387
Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates (6)) for account: U706* | 2022-04-25 10:14:50.390
Interactive Brokers | Begin Trade Positions processing. | 2022-04-25 10:14:50.392
Interactive Brokers | Received Trade Positions download end message for account U706* | 2022-04-25 10:14:50.392
Interactive Brokers | Received Trade Positions for all accounts. Performing final processing. | 2022-04-25 10:14:50.392
HD Request # 10 | Receiving historical Daily data for NAS100 starting at 2022-04-21 | 2022-04-25 10:14:50.393
HD Request # 10 | Writing historical Daily data to the file NAS100.dly | 2022-04-25 10:14:50.394
Socket (2) | CloseSocket call. | 2022-04-25 10:14:50.419
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:14:50.420
Historical data download thread signaled to stop. | 2022-04-25 10:14:50.420
HD Request # 10 | Received 3 Daily data records from 2022-04-21 00:00:00 to 2022-04-25 00:00:00 (5.0 days) and wrote 3 records for NAS100 | 2022-04-25 10:14:50.420
HD Request # 10 | Completion time: 1s | 2022-04-25 10:14:50.420
HD Request # 10 | Daily data download complete for NAS100. Unique request ID: 102 | 2022-04-25 10:14:50.420
Removing historical data download ID 102. | 2022-04-25 10:14:50.420
Triggering next historical data download in queue. | 2022-04-25 10:14:50.420
HD Request # 12 | Downloading Historical Daily chart data for XAUUSD. Starting date: 2022-04-21. Service: fxcm | 2022-04-25 10:14:50.421
HD Request # 12 | Using server: ds12.sierracharts.com port 10149 | 2022-04-25 10:14:50.421
Socket (11) | Creating socket. | 2022-04-25 10:14:50.421
Socket (11) | New receive buffer size: 5242880 | 2022-04-25 10:14:50.421
Socket (11) | Connecting to IP: 204.15.197.14. | 2022-04-25 10:14:50.421
NAS100[M] 16 Day #9 | Reloading chart. | 2022-04-25 10:14:50.434
NAS100[M] Daily #5 | Reloading chart. | 2022-04-25 10:14:50.442
NAS100[M] 16 Day #9 | StartDateTimeForLoadingOrderFills: 2011-01-03 00:00:00 | 2022-04-25 10:14:50.468
Socket (2) | Socket gracefully closed by remote side. | 2022-04-25 10:14:50.643
Socket (2) | Closed. | 2022-04-25 10:14:50.643
HD Request # 12 | Setting DTC encoding to Binary VLS | 2022-04-25 10:14:50.908
HD Request # 12 | Sending historical data logon request message. | 2022-04-25 10:14:50.908
HD Request # 12 | Requesting historical Daily data starting at 2022-04-21. | 2022-04-25 10:14:51.139
HD Request # 12 | Decompressing data. | 2022-04-25 10:14:51.372
HD Request # 12 | Receiving historical Daily data for XAUUSD starting at 2022-04-21 | 2022-04-25 10:14:51.410
HD Request # 12 | Writing historical Daily data to the file XAUUSD.dly | 2022-04-25 10:14:51.410
Socket (11) | CloseSocket call. | 2022-04-25 10:14:51.515
Socket (11) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:14:51.515
Historical data download thread signaled to stop. | 2022-04-25 10:14:51.515
HD Request # 12 | Received 3 Daily data records from 2022-04-21 00:00:00 to 2022-04-25 00:00:00 (5.0 days) and wrote 3 records for XAUUSD | 2022-04-25 10:14:51.515
HD Request # 12 | Completion time: 1s | 2022-04-25 10:14:51.515
HD Request # 12 | Daily data download complete for XAUUSD. Unique request ID: 103 | 2022-04-25 10:14:51.515
Removing historical data download ID 103. | 2022-04-25 10:14:51.515
Triggering next historical data download in queue. | 2022-04-25 10:14:51.515
HD Request # 13 | Downloading Historical Daily chart data for AUDUSD. Starting date: 2022-04-21. Service: fxcm | 2022-04-25 10:14:51.517
HD Request # 13 | Using server: ds4.sierracharts.com port 10150 | 2022-04-25 10:14:51.517
Socket (2) | Creating socket. | 2022-04-25 10:14:51.517
Socket (2) | New receive buffer size: 5242880 | 2022-04-25 10:14:51.517
Socket (2) | Connecting to IP: 192.81.56.146. | 2022-04-25 10:14:51.517
XAUUSD[M] 2 Day #1 | Reloading chart. | 2022-04-25 10:14:51.698
XAUUSD[M] 2 Day #11 | Reloading chart. | 2022-04-25 10:14:51.708
Socket (11) | Socket gracefully closed by remote side. | 2022-04-25 10:14:51.751
Socket (11) | Closed. | 2022-04-25 10:14:51.751
HD Request # 11 | Requesting historical Daily data for ZWN75 starting at 1974-06-16. SC External HD service. | 2022-04-25 10:14:51.758
HD Request # 13 | Setting DTC encoding to Binary VLS | 2022-04-25 10:14:51.993
HD Request # 13 | Sending historical data logon request message. | 2022-04-25 10:14:51.993
HD Request # 13 | Requesting historical Daily data starting at 2022-04-21. | 2022-04-25 10:14:52.224
HD Request # 13 | Decompressing data. | 2022-04-25 10:14:52.455
HD Request # 13 | Receiving historical Daily data for AUDUSD starting at 2022-04-21 | 2022-04-25 10:14:52.472
HD Request # 13 | Writing historical Daily data to the file AUDUSD.dly | 2022-04-25 10:14:52.473
Socket (2) | CloseSocket call. | 2022-04-25 10:14:52.537
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:14:52.537
Historical data download thread signaled to stop. | 2022-04-25 10:14:52.537
HD Request # 13 | Received 3 Daily data records from 2022-04-21 00:00:00 to 2022-04-25 00:00:00 (5.0 days) and wrote 3 records for AUDUSD | 2022-04-25 10:14:52.537
HD Request # 13 | Completion time: 1s | 2022-04-25 10:14:52.537
HD Request # 13 | Daily data download complete for AUDUSD. Unique request ID: 104 | 2022-04-25 10:14:52.537
Removing historical data download ID 104. | 2022-04-25 10:14:52.537
Triggering next historical data download in queue. | 2022-04-25 10:14:52.537
HD Request # 14 | Downloading Historical Daily chart data for WHEATF. Starting date: 2022-04-21. Service: fxcm | 2022-04-25 10:14:52.539
HD Request # 14 | Using server: ds12.sierracharts.com port 10149 | 2022-04-25 10:14:52.539
Socket (3) | Creating socket. | 2022-04-25 10:14:52.539
Socket (3) | New receive buffer size: 5242880 | 2022-04-25 10:14:52.539
Socket (3) | Connecting to IP: 204.15.197.14. | 2022-04-25 10:14:52.539
HD Request # 11 | Receiving historical Daily data for ZW-197507-ECBOT starting at 1974-07-29 | 2022-04-25 10:14:52.590
HD Request # 11 | Writing historical Daily data to the file ZW-197507-ECBOT.dly | 2022-04-25 10:14:52.590
HD Request # 11 | Bytes received: 9646 | 2022-04-25 10:14:52.591
HD Request # 11 | Received 248 Daily data records from 1974-07-29 00:00:00 to 1975-07-22 00:00:00 (359.0 days) and wrote 248 records for ZW-197507-ECBOT | 2022-04-25 10:14:52.591
HD Request # 11 | Completion time: 2s | 2022-04-25 10:14:52.591
HD Request # 11 | Daily data download complete for ZW-197507-ECBOT. Unique request ID: 4 | 2022-04-25 10:14:52.591
Removing historical data download ID 4. | 2022-04-25 10:14:52.591
Triggering next historical data download in queue. | 2022-04-25 10:14:52.591
Mapping ZW-197607-ECBOT to ZWN76. Service code: cbot | 2022-04-25 10:14:52.591
HD Request # 15 | Downloading Historical Daily chart data for ZW-197607-ECBOT. Starting date: 1975-06-17. Service: interactive_brokers.trading | 2022-04-25 10:14:52.591
AUDUSD[M] 16 Day #2 | Reloading chart. | 2022-04-25 10:14:52.703
Socket (2) | Socket gracefully closed by remote side. | 2022-04-25 10:14:52.770
Socket (2) | Closed. | 2022-04-25 10:14:52.770
HD Request # 14 | Setting DTC encoding to Binary VLS | 2022-04-25 10:14:53.010
HD Request # 14 | Sending historical data logon request message. | 2022-04-25 10:14:53.010
HD Request # 14 | Requesting historical Daily data starting at 2022-04-21. | 2022-04-25 10:14:53.233
HD Request # 14 | Decompressing data. | 2022-04-25 10:14:53.457
HD Request # 14 | Receiving historical Daily data for WHEATF starting at 2022-04-21 | 2022-04-25 10:14:53.462
HD Request # 14 | Writing historical Daily data to the file WHEATF.dly | 2022-04-25 10:14:53.462
Socket (3) | CloseSocket call. | 2022-04-25 10:14:53.467
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:14:53.468
Historical data download thread signaled to stop. | 2022-04-25 10:14:53.468
HD Request # 14 | Received 3 Daily data records from 2022-04-21 00:00:00 to 2022-04-25 00:00:00 (5.0 days) and wrote 3 records for WHEATF | 2022-04-25 10:14:53.468
HD Request # 14 | Completion time: 1s | 2022-04-25 10:14:53.468
HD Request # 14 | Daily data download complete for WHEATF. Unique request ID: 105 | 2022-04-25 10:14:53.468
Removing historical data download ID 105. | 2022-04-25 10:14:53.468
Triggering next historical data download in queue. | 2022-04-25 10:14:53.468
HD Request # 16 | Downloading Historical Daily chart data for NGAS. Starting date: 2022-04-21. Service: fxcm | 2022-04-25 10:14:53.469
HD Request # 16 | Using server: ds4.sierracharts.com port 10150 | 2022-04-25 10:14:53.469
Socket (2) | Creating socket. | 2022-04-25 10:14:53.469
Socket (2) | New receive buffer size: 5242880 | 2022-04-25 10:14:53.469
Socket (2) | Connecting to IP: 192.81.56.146. | 2022-04-25 10:14:53.469
Socket (3) | Socket gracefully closed by remote side. | 2022-04-25 10:14:53.690
Socket (3) | Closed. | 2022-04-25 10:14:53.690
WHEATF[M] 2 Day #4 | Reloading chart. | 2022-04-25 10:14:53.782
HD Request # 16 | Setting DTC encoding to Binary VLS | 2022-04-25 10:14:53.941
HD Request # 16 | Sending historical data logon request message. | 2022-04-25 10:14:53.941
HD Request # 15 | Requesting historical Daily data for ZWN76 starting at 1975-06-16. SC External HD service. | 2022-04-25 10:14:54.023
HD Request # 16 | Requesting historical Daily data starting at 2022-04-21. | 2022-04-25 10:14:54.173
HD Request # 16 | Decompressing data. | 2022-04-25 10:14:54.404
HD Request # 16 | Receiving historical Daily data for NGAS starting at 2022-04-21 | 2022-04-25 10:14:54.410
HD Request # 16 | Writing historical Daily data to the file NGAS.dly | 2022-04-25 10:14:54.410
Socket (2) | CloseSocket call. | 2022-04-25 10:14:54.431
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:14:54.431
Historical data download thread signaled to stop. | 2022-04-25 10:14:54.434
HD Request # 16 | Received 3 Daily data records from 2022-04-21 00:00:00 to 2022-04-25 00:00:00 (5.0 days) and wrote 3 records for NGAS | 2022-04-25 10:14:54.434
HD Request # 16 | Completion time: 1s | 2022-04-25 10:14:54.434
HD Request # 16 | Daily data download complete for NGAS. Unique request ID: 106 | 2022-04-25 10:14:54.434
Removing historical data download ID 106. | 2022-04-25 10:14:54.434
Triggering next historical data download in queue. | 2022-04-25 10:14:54.434
HD Request # 17 | Downloading Intraday chart data for QQQ-NQTV to the file QQQ-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:14:54.434
HD Request # 17 | Download start date-time: 2022-04-25 10:13:02.000000. File last date-time: 2022-04-25 10:13:02.286000 | 2022-04-25 10:14:54.434
HD Request # 17 | Using server: ds25.sierracharts.com port 10149 | 2022-04-25 10:14:54.434
Socket (4) | Creating socket. | 2022-04-25 10:14:54.434
Socket (4) | New receive buffer size: 5242880 | 2022-04-25 10:14:54.434
Socket (4) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:14:54.434
NGAS[M] 2 Day #14 | Reloading chart. | 2022-04-25 10:14:54.455
NGAS[M] 4 Day #3 | Reloading chart. | 2022-04-25 10:14:54.495
Socket (2) | Socket gracefully closed by remote side. | 2022-04-25 10:14:54.662
Socket (2) | Closed. | 2022-04-25 10:14:54.662
HD Request # 15 | Receiving historical Daily data for ZW-197607-ECBOT starting at 1975-08-01 | 2022-04-25 10:14:54.831
HD Request # 15 | Writing historical Daily data to the file ZW-197607-ECBOT.dly | 2022-04-25 10:14:54.831
HD Request # 15 | Bytes received: 9996 | 2022-04-25 10:14:54.832
HD Request # 15 | Received 245 Daily data records from 1975-08-01 00:00:00 to 1976-07-21 00:00:00 (356.0 days) and wrote 245 records for ZW-197607-ECBOT | 2022-04-25 10:14:54.832
HD Request # 15 | Completion time: 2s | 2022-04-25 10:14:54.833
HD Request # 15 | Daily data download complete for ZW-197607-ECBOT. Unique request ID: 5 | 2022-04-25 10:14:54.833
Removing historical data download ID 5. | 2022-04-25 10:14:54.833
Triggering next historical data download in queue. | 2022-04-25 10:14:54.833
Mapping ZW-197707-ECBOT to ZWN77. Service code: cbot | 2022-04-25 10:14:54.833
HD Request # 18 | Downloading Historical Daily chart data for ZW-197707-ECBOT. Starting date: 1976-06-17. Service: interactive_brokers.trading | 2022-04-25 10:14:54.833
HD Request # 17 | Setting DTC encoding to Binary VLS | 2022-04-25 10:14:54.888
HD Request # 17 | Sending historical data logon request message. | 2022-04-25 10:14:54.888
HD Request # 17 | Requesting Intraday data. Start date-time: 2022-04-25 10:13:02. Record interval: 0. Symbol: QQQ-NQTV | 2022-04-25 10:14:55.583
HD Request # 17 | Decompressing data. | 2022-04-25 10:14:55.814
HD Request # 17 | Receiving Intraday data for QQQ-NQTV starting at 2022-04-25 10:13:02.098000 | 2022-04-25 10:14:56.086
Socket (4) | CloseSocket call. | 2022-04-25 10:14:56.088
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:14:56.088
Historical data download thread signaled to stop. | 2022-04-25 10:14:56.088
HD Request # 17 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:02.294000 | 2022-04-25 10:14:56.088
HD Request # 17 | Received 1763 Intraday data records from 2022-04-25 10:13:02.098000 to 2022-04-25 10:14:48.485002 (106.4 seconds) and wrote 1750 records for QQQ-NQTV | 2022-04-25 10:14:56.088
HD Request # 17 | Completion time: 2s | 2022-04-25 10:14:56.088
HD Request # 17 | Intraday data download complete for QQQ-NQTV. Unique request ID: 110 | 2022-04-25 10:14:56.088
Removing historical data download ID 110. | 2022-04-25 10:14:56.088
Real-time Intraday chart data file updates started for QQQ-NQTV | 2022-04-25 10:14:56.088
Intraday chart data file opened for QQQ-NQTV | 2022-04-25 10:14:56.088
HD Request # 17 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:14:56.088
Triggering next historical data download in queue. | 2022-04-25 10:14:56.088
HD Request # 19 | Downloading Intraday chart data for ZW-202207-ECBOT to the file ZW-202207-ECBOT.scid. Service: cbot | 2022-04-25 10:14:56.088
HD Request # 19 | Download start date-time: 2022-04-25 10:13:01.000000. File last date-time: 2022-04-25 10:13:01.979000 | 2022-04-25 10:14:56.089
HD Request # 19 | Using server: ds23.sierracharts.com port 10150 | 2022-04-25 10:14:56.089
Socket (3) | Creating socket. | 2022-04-25 10:14:56.089
Socket (3) | New receive buffer size: 5242880 | 2022-04-25 10:14:56.089
Socket (3) | Connecting to IP: 216.1.90.130. | 2022-04-25 10:14:56.089
HD Request # 18 | Requesting historical Daily data for ZWN77 starting at 1976-06-16. SC External HD service. | 2022-04-25 10:14:56.268
Socket (4) | Socket gracefully closed by remote side. | 2022-04-25 10:14:56.313
Socket (4) | Closed. | 2022-04-25 10:14:56.313
HD Request # 19 | Setting DTC encoding to Binary VLS | 2022-04-25 10:14:56.553
HD Request # 19 | Sending historical data logon request message. | 2022-04-25 10:14:56.553
HD Request # 18 | Receiving historical Daily data for ZW-197707-ECBOT starting at 1976-07-06 | 2022-04-25 10:14:57.035
HD Request # 18 | Writing historical Daily data to the file ZW-197707-ECBOT.dly | 2022-04-25 10:14:57.035
HD Request # 18 | Bytes received: 11109 | 2022-04-25 10:14:57.037
HD Request # 18 | Received 262 Daily data records from 1976-07-06 00:00:00 to 1977-07-20 00:00:00 (380.0 days) and wrote 262 records for ZW-197707-ECBOT | 2022-04-25 10:14:57.037
HD Request # 18 | Completion time: 3s | 2022-04-25 10:14:57.037
HD Request # 18 | Daily data download complete for ZW-197707-ECBOT. Unique request ID: 6 | 2022-04-25 10:14:57.037
Removing historical data download ID 6. | 2022-04-25 10:14:57.037
Triggering next historical data download in queue. | 2022-04-25 10:14:57.037
HD Request # 20 | Downloading Historical Daily chart data for ZW-202207-ECBOT. Starting date: 2022-04-20. Service: interactive_brokers.trading | 2022-04-25 10:14:57.038
HD Request # 19 | Requesting Intraday data. Start date-time: 2022-04-25 10:13:01. Record interval: 0. Symbol: ZWN22 | 2022-04-25 10:14:57.225
HD Request # 19 | Decompressing data. | 2022-04-25 10:14:57.443
HD Request # 19 | Receiving Intraday data for ZW-202207-ECBOT starting at 2022-04-25 10:13:01.548000 | 2022-04-25 10:14:57.443
Socket (3) | CloseSocket call. | 2022-04-25 10:14:57.443
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:14:57.443
Historical data download thread signaled to stop. | 2022-04-25 10:14:57.474
HD Request # 19 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:04.123000 | 2022-04-25 10:14:57.474
HD Request # 19 | Received 74 Intraday data records from 2022-04-25 10:13:01.548000 to 2022-04-25 10:14:48.820000 (107.3 seconds) and wrote 72 records for ZW-202207-ECBOT | 2022-04-25 10:14:57.474
HD Request # 19 | Completion time: 1s | 2022-04-25 10:14:57.474
HD Request # 19 | Intraday data download complete for ZW-202207-ECBOT. Unique request ID: 111 | 2022-04-25 10:14:57.474
Removing historical data download ID 111. | 2022-04-25 10:14:57.474
Real-time Intraday chart data file updates started for ZW-202207-ECBOT | 2022-04-25 10:14:57.475
Intraday chart data file opened for ZW-202207-ECBOT | 2022-04-25 10:14:57.475
HD Request # 19 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:14:57.475
Triggering next historical data download in queue. | 2022-04-25 10:14:57.475
HD Request # 21 | Downloading Intraday chart data for YK-202205-ECBOT-USD-1000 to the file YK-202205-ECBOT-USD-1000.scid. Service: cbot | 2022-04-25 10:14:57.475
HD Request # 21 | Download start date-time: 2022-04-25 10:09:01.000000. File last date-time: 2022-04-25 10:09:01.724000 | 2022-04-25 10:14:57.475
HD Request # 21 | Using server: ds21.sierracharts.com port 10149 | 2022-04-25 10:14:57.475
Socket (4) | Creating socket. | 2022-04-25 10:14:57.475
Socket (4) | New receive buffer size: 5242880 | 2022-04-25 10:14:57.475
Socket (4) | Connecting to IP: 216.1.90.129. | 2022-04-25 10:14:57.475
Socket (3) | Socket gracefully closed by remote side. | 2022-04-25 10:14:57.671
Socket (3) | Closed. | 2022-04-25 10:14:57.671
HD Request # 21 | Setting DTC encoding to Binary VLS | 2022-04-25 10:14:57.926
HD Request # 21 | Sending historical data logon request message. | 2022-04-25 10:14:57.926
HD Request # 20 | Requesting historical Daily data for ZWN22 starting at 2022-04-19. SC External HD service. | 2022-04-25 10:14:58.443
Opened cached Intraday file: C:\SierraChart\Data\QQQ-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:14:58.555
Opened cached Intraday file: C:\SierraChart\Data\ZW-202207-ECBOT.scid. Thread ID: 19936 | 2022-04-25 10:14:58.556
HD Request # 21 | Requesting Intraday data. Start date-time: 2022-04-25 10:09:01. Record interval: 0. Symbol: XKK22 | 2022-04-25 10:14:58.610
HD Request # 21 | Decompressing data. | 2022-04-25 10:14:58.827
HD Request # 21 | Receiving Intraday data for YK-202205-ECBOT-USD-1000 starting at 2022-04-25 10:09:01.724000 | 2022-04-25 10:14:58.827
Socket (4) | CloseSocket call. | 2022-04-25 10:14:58.827
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:14:58.827
Historical data download thread signaled to stop. | 2022-04-25 10:14:58.831
HD Request # 21 | Received 1 Intraday data record from 2022-04-25 10:09:01.724000 to 2022-04-25 10:09:01.724000 (0.0 seconds) and wrote 0 records for YK-202205-ECBOT-USD-1000 | 2022-04-25 10:14:58.831
HD Request # 21 | Completion time: 1s | 2022-04-25 10:14:58.831
HD Request # 21 | Intraday data download complete for YK-202205-ECBOT-USD-1000. Unique request ID: 112 | 2022-04-25 10:14:58.831
Removing historical data download ID 112. | 2022-04-25 10:14:58.831
Real-time Intraday chart data file updates started for YK-202205-ECBOT-USD-1000 | 2022-04-25 10:14:58.831
Intraday chart data file opened for YK-202205-ECBOT-USD-1000 | 2022-04-25 10:14:58.831
HD Request # 21 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:14:58.831
Triggering next historical data download in queue. | 2022-04-25 10:14:58.831
HD Request # 22 | Downloading Intraday chart data for ZC-202207-ECBOT to the file ZC-202207-ECBOT.scid. Service: cbot | 2022-04-25 10:14:58.831
HD Request # 22 | Download start date-time: 2022-04-25 10:13:01.000000. File last date-time: 2022-04-25 10:13:01.524004 | 2022-04-25 10:14:58.831
HD Request # 22 | Using server: ds23.sierracharts.com port 10150 | 2022-04-25 10:14:58.831
Socket (11) | Creating socket. | 2022-04-25 10:14:58.831
Socket (11) | New receive buffer size: 5242880 | 2022-04-25 10:14:58.831
Socket (11) | Connecting to IP: 216.1.90.130. | 2022-04-25 10:14:58.831
Socket (4) | Socket gracefully closed by remote side. | 2022-04-25 10:14:59.055
Socket (4) | Closed. | 2022-04-25 10:14:59.055
HD Request # 20 | Receiving historical Daily data for ZW-202207-ECBOT starting at 2022-04-20 | 2022-04-25 10:14:59.207
HD Request # 20 | Writing historical Daily data to the file ZW-202207-ECBOT.dly | 2022-04-25 10:14:59.207
HD Request # 20 | Bytes received: 227 | 2022-04-25 10:14:59.213
HD Request # 20 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for ZW-202207-ECBOT | 2022-04-25 10:14:59.213
HD Request # 20 | Completion time: 2s | 2022-04-25 10:14:59.213
HD Request # 20 | Daily data download complete for ZW-202207-ECBOT. Unique request ID: 7 | 2022-04-25 10:14:59.213
Removing historical data download ID 7. | 2022-04-25 10:14:59.213
Triggering next historical data download in queue. | 2022-04-25 10:14:59.214
Mapping ZS-197207-ECBOT to ZSN72. Service code: cbot | 2022-04-25 10:14:59.214
HD Request # 23 | Downloading Historical Daily chart data for ZS-197207-ECBOT. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:14:59.214
HD Request # 22 | Setting DTC encoding to Binary VLS | 2022-04-25 10:14:59.326
HD Request # 22 | Sending historical data logon request message. | 2022-04-25 10:14:59.326
ZW-202207-ECBOT [CS] 4 Day #15 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:14:59.334
ZW-202207-ECBOT [CS] 4 Day #15 | Reloading chart. | 2022-04-25 10:14:59.335
ZW-202207-ECBOT [CS] Daily #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:14:59.347
ZW-202207-ECBOT [CS] Daily #4 | Reloading chart. | 2022-04-25 10:14:59.348
HD Request # 22 | Requesting Intraday data. Start date-time: 2022-04-25 10:13:01. Record interval: 0. Symbol: ZCN22 | 2022-04-25 10:14:59.543
ZW-202207-ECBOT [CS] 4 Day #15 | StartDateTimeForLoadingOrderFills: 1972-04-17 00:00:00 | 2022-04-25 10:14:59.590
ZW-202207-ECBOT [CS] Daily #4 | StartDateTimeForLoadingOrderFills: 1972-04-17 00:00:00 | 2022-04-25 10:14:59.595
ZW-202207-ECBOT [CS] 4 Day #15 | Reloading chart. | 2022-04-25 10:14:59.736
ZW-202207-ECBOT [CS] 4 Day #15 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:59.736
ZW-202207-ECBOT [CS] 4 Day #15 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:14:59.736
HD Request # 22 | Decompressing data. | 2022-04-25 10:14:59.768
HD Request # 22 | Receiving Intraday data for ZC-202207-ECBOT starting at 2022-04-25 10:13:01.342000 | 2022-04-25 10:14:59.769
Socket (11) | CloseSocket call. | 2022-04-25 10:14:59.770
Socket (11) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:14:59.770
Socket (11) | Socket gracefully closed by remote side. | 2022-04-25 10:15:00.018
Socket (11) | Closed. | 2022-04-25 10:15:00.018
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-200107-ECBOT.dly has a volume of 0 at 2000-06-20. | 2022-04-25 10:15:00.842
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-200007-ECBOT.dly has a volume of 0 at 1999-06-18. | 2022-04-25 10:15:00.886
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-200007-ECBOT.dly has a volume of 0 at 2000-06-19. | 2022-04-25 10:15:00.886
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199907-ECBOT.dly has a volume of 0 at 1998-06-18. | 2022-04-25 10:15:00.931
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199907-ECBOT.dly has a volume of 0 at 1999-06-17. | 2022-04-25 10:15:00.931
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199807-ECBOT.dly has a volume of 0 at 1997-06-18. | 2022-04-25 10:15:00.976
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199807-ECBOT.dly has a volume of 0 at 1998-06-17. | 2022-04-25 10:15:00.976
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199707-ECBOT.dly has a volume of 0 at 1996-06-18. | 2022-04-25 10:15:01.021
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199707-ECBOT.dly has a volume of 0 at 1997-06-17. | 2022-04-25 10:15:01.021
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199607-ECBOT.dly has a volume of 0 at 1995-06-20. | 2022-04-25 10:15:01.065
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199607-ECBOT.dly has a volume of 0 at 1996-06-17. | 2022-04-25 10:15:01.065
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199507-ECBOT.dly has a volume of 0 at 1994-06-20. | 2022-04-25 10:15:01.110
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199507-ECBOT.dly has a volume of 0 at 1995-06-19. | 2022-04-25 10:15:01.110
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199407-ECBOT.dly has a volume of 0 at 1993-06-18. | 2022-04-25 10:15:01.154
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199407-ECBOT.dly has a volume of 0 at 1994-06-17. | 2022-04-25 10:15:01.154
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199307-ECBOT.dly has a volume of 0 at 1992-06-18. | 2022-04-25 10:15:01.199
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199307-ECBOT.dly has a volume of 0 at 1993-06-17. | 2022-04-25 10:15:01.199
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199207-ECBOT.dly has a volume of 0 at 1991-06-18. | 2022-04-25 10:15:01.243
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199207-ECBOT.dly has a volume of 0 at 1992-06-17. | 2022-04-25 10:15:01.243
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199107-ECBOT.dly has a volume of 0 at 1990-06-19. | 2022-04-25 10:15:01.288
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199107-ECBOT.dly has a volume of 0 at 1991-06-17. | 2022-04-25 10:15:01.288
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199007-ECBOT.dly has a volume of 0 at 1989-06-20. | 2022-04-25 10:15:01.332
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-199007-ECBOT.dly has a volume of 0 at 1990-06-18. | 2022-04-25 10:15:01.332
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198907-ECBOT.dly has a volume of 0 at 1988-06-20. | 2022-04-25 10:15:01.376
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198907-ECBOT.dly has a volume of 0 at 1989-06-19. | 2022-04-25 10:15:01.376
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198807-ECBOT.dly has a volume of 0 at 1987-06-18. | 2022-04-25 10:15:01.420
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198807-ECBOT.dly has a volume of 0 at 1988-06-17. | 2022-04-25 10:15:01.420
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198707-ECBOT.dly has a volume of 0 at 1986-06-18. | 2022-04-25 10:15:01.465
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198707-ECBOT.dly has a volume of 0 at 1987-06-17. | 2022-04-25 10:15:01.465
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198607-ECBOT.dly has a volume of 0 at 1985-06-18. | 2022-04-25 10:15:01.510
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198607-ECBOT.dly has a volume of 0 at 1986-06-17. | 2022-04-25 10:15:01.510
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198507-ECBOT.dly has a volume of 0 at 1984-06-19. | 2022-04-25 10:15:01.555
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198507-ECBOT.dly has a volume of 0 at 1985-06-17. | 2022-04-25 10:15:01.555
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198407-ECBOT.dly has a volume of 0 at 1983-06-20. | 2022-04-25 10:15:01.600
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198407-ECBOT.dly has a volume of 0 at 1984-06-18. | 2022-04-25 10:15:01.600
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198307-ECBOT.dly has a volume of 0 at 1982-06-18. | 2022-04-25 10:15:01.645
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198307-ECBOT.dly has a volume of 0 at 1983-06-17. | 2022-04-25 10:15:01.645
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198207-ECBOT.dly has a volume of 0 at 1981-06-18. | 2022-04-25 10:15:01.690
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198207-ECBOT.dly has a volume of 0 at 1982-06-17. | 2022-04-25 10:15:01.690
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198107-ECBOT.dly has a volume of 0 at 1980-06-18. | 2022-04-25 10:15:01.735
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198107-ECBOT.dly has a volume of 0 at 1981-06-17. | 2022-04-25 10:15:01.735
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198007-ECBOT.dly has a volume of 0 at 1979-06-19. | 2022-04-25 10:15:01.779
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-198007-ECBOT.dly has a volume of 0 at 1980-06-17. | 2022-04-25 10:15:01.779
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-197907-ECBOT.dly has a volume of 0 at 1978-06-20. | 2022-04-25 10:15:01.824
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-197907-ECBOT.dly has a volume of 0 at 1979-06-18. | 2022-04-25 10:15:01.824
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-197807-ECBOT.dly has a volume of 0 at 1977-06-20. | 2022-04-25 10:15:01.868
ZW-202207-ECBOT [CS] 4 Day #15 | File ZW-197807-ECBOT.dly has a volume of 0 at 1978-06-19. | 2022-04-25 10:15:01.868
ZW-202207-ECBOT [CS] 4 Day #15 | Dates not found while checking for invalid data in continuous contract data files. ZW-197707-ECBOT | 2022-04-25 10:15:01.910 *
Historical data download thread signaled to stop. | 2022-04-25 10:15:01.917
HD Request # 22 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:02.665000 | 2022-04-25 10:15:01.917
HD Request # 22 | Received 484 Intraday data records from 2022-04-25 10:13:01.342000 to 2022-04-25 10:14:53.318001 (112.0 seconds) and wrote 477 records for ZC-202207-ECBOT | 2022-04-25 10:15:01.917
HD Request # 22 | Completion time: 3s | 2022-04-25 10:15:01.917
HD Request # 22 | Intraday data download complete for ZC-202207-ECBOT. Unique request ID: 113 | 2022-04-25 10:15:01.917
Removing historical data download ID 113. | 2022-04-25 10:15:01.917
Real-time Intraday chart data file updates started for ZC-202207-ECBOT | 2022-04-25 10:15:01.918
Intraday chart data file opened for ZC-202207-ECBOT | 2022-04-25 10:15:01.918
HD Request # 22 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:01.918
Triggering next historical data download in queue. | 2022-04-25 10:15:01.918
HD Request # 23 | Requesting historical Daily data for ZSN72 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:15:01.935
HD Request # 24 | Downloading Intraday chart data for MYM-202206-ECBOT-USD to the file MYM-202206-ECBOT-USD.scid. Service: cbot | 2022-04-25 10:15:01.935
HD Request # 24 | Download start date-time: 2022-04-25 10:13:02.000000. File last date-time: 2022-04-25 10:13:02.341000 | 2022-04-25 10:15:01.935
HD Request # 24 | Using server: ds21.sierracharts.com port 10149 | 2022-04-25 10:15:01.935
Socket (4) | Creating socket. | 2022-04-25 10:15:01.936
Socket (4) | New receive buffer size: 5242880 | 2022-04-25 10:15:01.936
Socket (4) | Connecting to IP: 216.1.90.129. | 2022-04-25 10:15:01.936
ZW-202207-ECBOT [CS] Daily #4 | Reloading chart. | 2022-04-25 10:15:02.040
ZW-202207-ECBOT [CS] Daily #4 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:02.040
ZW-202207-ECBOT [CS] Daily #4 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:02.040
HD Request # 24 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:02.384
HD Request # 24 | Sending historical data logon request message. | 2022-04-25 10:15:02.384
HD Request # 24 | Requesting Intraday data. Start date-time: 2022-04-25 10:13:02. Record interval: 0. Symbol: MYMM22 | 2022-04-25 10:15:02.603
HD Request # 24 | Decompressing data. | 2022-04-25 10:15:02.846
HD Request # 24 | Receiving Intraday data for MYM-202206-ECBOT-USD starting at 2022-04-25 10:13:02.152000 | 2022-04-25 10:15:02.846
Socket (4) | CloseSocket call. | 2022-04-25 10:15:03.083
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:03.083
ZW-202207-ECBOT [CS] Daily #4 | File ZW-200107-ECBOT.dly has a volume of 0 at 2000-06-20. | 2022-04-25 10:15:03.125
ZW-202207-ECBOT [CS] Daily #4 | File ZW-200007-ECBOT.dly has a volume of 0 at 1999-06-18. | 2022-04-25 10:15:03.169
ZW-202207-ECBOT [CS] Daily #4 | File ZW-200007-ECBOT.dly has a volume of 0 at 2000-06-19. | 2022-04-25 10:15:03.169
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199907-ECBOT.dly has a volume of 0 at 1998-06-18. | 2022-04-25 10:15:03.212
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199907-ECBOT.dly has a volume of 0 at 1999-06-17. | 2022-04-25 10:15:03.212
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199807-ECBOT.dly has a volume of 0 at 1997-06-18. | 2022-04-25 10:15:03.256
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199807-ECBOT.dly has a volume of 0 at 1998-06-17. | 2022-04-25 10:15:03.256
Socket (4) | Socket gracefully closed by remote side. | 2022-04-25 10:15:03.300
Socket (4) | Closed. | 2022-04-25 10:15:03.300
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199707-ECBOT.dly has a volume of 0 at 1996-06-18. | 2022-04-25 10:15:03.301
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199707-ECBOT.dly has a volume of 0 at 1997-06-17. | 2022-04-25 10:15:03.301
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199607-ECBOT.dly has a volume of 0 at 1995-06-20. | 2022-04-25 10:15:03.345
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199607-ECBOT.dly has a volume of 0 at 1996-06-17. | 2022-04-25 10:15:03.345
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199507-ECBOT.dly has a volume of 0 at 1994-06-20. | 2022-04-25 10:15:03.388
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199507-ECBOT.dly has a volume of 0 at 1995-06-19. | 2022-04-25 10:15:03.388
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199407-ECBOT.dly has a volume of 0 at 1993-06-18. | 2022-04-25 10:15:03.432
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199407-ECBOT.dly has a volume of 0 at 1994-06-17. | 2022-04-25 10:15:03.432
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199307-ECBOT.dly has a volume of 0 at 1992-06-18. | 2022-04-25 10:15:03.475
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199307-ECBOT.dly has a volume of 0 at 1993-06-17. | 2022-04-25 10:15:03.475
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199207-ECBOT.dly has a volume of 0 at 1991-06-18. | 2022-04-25 10:15:03.519
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199207-ECBOT.dly has a volume of 0 at 1992-06-17. | 2022-04-25 10:15:03.519
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199107-ECBOT.dly has a volume of 0 at 1990-06-19. | 2022-04-25 10:15:03.563
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199107-ECBOT.dly has a volume of 0 at 1991-06-17. | 2022-04-25 10:15:03.563
Opened cached Intraday file: C:\SierraChart\Data\ZC-202207-ECBOT.scid. Thread ID: 19936 | 2022-04-25 10:15:03.599
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199007-ECBOT.dly has a volume of 0 at 1989-06-20. | 2022-04-25 10:15:03.607
ZW-202207-ECBOT [CS] Daily #4 | File ZW-199007-ECBOT.dly has a volume of 0 at 1990-06-18. | 2022-04-25 10:15:03.607
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198907-ECBOT.dly has a volume of 0 at 1988-06-20. | 2022-04-25 10:15:03.650
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198907-ECBOT.dly has a volume of 0 at 1989-06-19. | 2022-04-25 10:15:03.650
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198807-ECBOT.dly has a volume of 0 at 1987-06-18. | 2022-04-25 10:15:03.694
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198807-ECBOT.dly has a volume of 0 at 1988-06-17. | 2022-04-25 10:15:03.694
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198707-ECBOT.dly has a volume of 0 at 1986-06-18. | 2022-04-25 10:15:03.738
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198707-ECBOT.dly has a volume of 0 at 1987-06-17. | 2022-04-25 10:15:03.738
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198607-ECBOT.dly has a volume of 0 at 1985-06-18. | 2022-04-25 10:15:03.782
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198607-ECBOT.dly has a volume of 0 at 1986-06-17. | 2022-04-25 10:15:03.782
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198507-ECBOT.dly has a volume of 0 at 1984-06-19. | 2022-04-25 10:15:03.826
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198507-ECBOT.dly has a volume of 0 at 1985-06-17. | 2022-04-25 10:15:03.826
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198407-ECBOT.dly has a volume of 0 at 1983-06-20. | 2022-04-25 10:15:03.870
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198407-ECBOT.dly has a volume of 0 at 1984-06-18. | 2022-04-25 10:15:03.870
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198307-ECBOT.dly has a volume of 0 at 1982-06-18. | 2022-04-25 10:15:03.913
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198307-ECBOT.dly has a volume of 0 at 1983-06-17. | 2022-04-25 10:15:03.913
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198207-ECBOT.dly has a volume of 0 at 1981-06-18. | 2022-04-25 10:15:03.957
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198207-ECBOT.dly has a volume of 0 at 1982-06-17. | 2022-04-25 10:15:03.957
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198107-ECBOT.dly has a volume of 0 at 1980-06-18. | 2022-04-25 10:15:04.001
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198107-ECBOT.dly has a volume of 0 at 1981-06-17. | 2022-04-25 10:15:04.001
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198007-ECBOT.dly has a volume of 0 at 1979-06-19. | 2022-04-25 10:15:04.045
ZW-202207-ECBOT [CS] Daily #4 | File ZW-198007-ECBOT.dly has a volume of 0 at 1980-06-17. | 2022-04-25 10:15:04.045
ZW-202207-ECBOT [CS] Daily #4 | File ZW-197907-ECBOT.dly has a volume of 0 at 1978-06-20. | 2022-04-25 10:15:04.089
ZW-202207-ECBOT [CS] Daily #4 | File ZW-197907-ECBOT.dly has a volume of 0 at 1979-06-18. | 2022-04-25 10:15:04.089
ZW-202207-ECBOT [CS] Daily #4 | File ZW-197807-ECBOT.dly has a volume of 0 at 1977-06-20. | 2022-04-25 10:15:04.133
ZW-202207-ECBOT [CS] Daily #4 | File ZW-197807-ECBOT.dly has a volume of 0 at 1978-06-19. | 2022-04-25 10:15:04.133
ZW-202207-ECBOT [CS] Daily #4 | Dates not found while checking for invalid data in continuous contract data files. ZW-197707-ECBOT | 2022-04-25 10:15:04.175 *
ZW-202207-ECBOT [CS] 4 Day #15 | StartDateTimeForLoadingOrderFills: 1972-04-17 00:00:00 | 2022-04-25 10:15:04.183
Historical data download thread signaled to stop. | 2022-04-25 10:15:04.188
HD Request # 24 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:02.782000 | 2022-04-25 10:15:04.188
HD Request # 24 | Received 869 Intraday data records from 2022-04-25 10:13:02.152000 to 2022-04-25 10:14:56.995001 (114.8 seconds) and wrote 862 records for MYM-202206-ECBOT-USD | 2022-04-25 10:15:04.188
HD Request # 24 | Completion time: 3s | 2022-04-25 10:15:04.188
HD Request # 24 | Intraday data download complete for MYM-202206-ECBOT-USD. Unique request ID: 114 | 2022-04-25 10:15:04.188
Removing historical data download ID 114. | 2022-04-25 10:15:04.188
Real-time Intraday chart data file updates started for MYM-202206-ECBOT-USD | 2022-04-25 10:15:04.188
Intraday chart data file opened for MYM-202206-ECBOT-USD | 2022-04-25 10:15:04.188
HD Request # 24 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:04.188
Triggering next historical data download in queue. | 2022-04-25 10:15:04.188
HD Request # 25 | Downloading Intraday chart data for MNQ-202206-GLOBEX-USD to the file MNQ-202206-GLOBEX-USD.scid. Service: cme | 2022-04-25 10:15:04.188
HD Request # 25 | Download start date-time: 2022-04-25 10:13:02.000000. File last date-time: 2022-04-25 10:13:02.636000 | 2022-04-25 10:15:04.188
HD Request # 25 | Using server: ds23.sierracharts.com port 10150 | 2022-04-25 10:15:04.188
Socket (4) | Creating socket. | 2022-04-25 10:15:04.188
Socket (4) | New receive buffer size: 5242880 | 2022-04-25 10:15:04.188
Socket (4) | Connecting to IP: 216.1.90.130. | 2022-04-25 10:15:04.188
ZW-202207-ECBOT [CS] Daily #4 | StartDateTimeForLoadingOrderFills: 1972-04-17 00:00:00 | 2022-04-25 10:15:04.421
HD Request # 25 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:04.717
HD Request # 25 | Sending historical data logon request message. | 2022-04-25 10:15:04.717
HD Request # 23 | Receiving historical Daily data for ZS-197207-ECBOT starting at 1972-04-25 | 2022-04-25 10:15:04.844
HD Request # 23 | Writing historical Daily data to the file ZS-197207-ECBOT.dly | 2022-04-25 10:15:04.844
HD Request # 23 | Bytes received: 2808 | 2022-04-25 10:15:04.845
HD Request # 23 | Received 62 Daily data records from 1972-04-25 00:00:00 to 1972-07-20 00:00:00 (87.0 days) and wrote 61 records for ZS-197207-ECBOT | 2022-04-25 10:15:04.845
HD Request # 23 | Completion time: 5s | 2022-04-25 10:15:04.845
HD Request # 23 | Daily data download complete for ZS-197207-ECBOT. Unique request ID: 8 | 2022-04-25 10:15:04.845
Removing historical data download ID 8. | 2022-04-25 10:15:04.845
Triggering next historical data download in queue. | 2022-04-25 10:15:04.845
Mapping ZS-197307-ECBOT to ZSN73. Service code: cbot | 2022-04-25 10:15:04.845
HD Request # 26 | Downloading Historical Daily chart data for ZS-197307-ECBOT. Starting date: 1972-06-27. Service: interactive_brokers.trading | 2022-04-25 10:15:04.845
HD Request # 25 | Requesting Intraday data. Start date-time: 2022-04-25 10:13:02. Record interval: 0. Symbol: MNQM22 | 2022-04-25 10:15:04.973
HD Request # 25 | Decompressing data. | 2022-04-25 10:15:05.213
HD Request # 25 | Receiving Intraday data for MNQ-202206-GLOBEX-USD starting at 2022-04-25 10:13:02.114000 | 2022-04-25 10:15:05.937
Socket (4) | CloseSocket call. | 2022-04-25 10:15:05.943
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:05.943
Historical data download thread signaled to stop. | 2022-04-25 10:15:05.943
HD Request # 25 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:02.644000 | 2022-04-25 10:15:05.943
HD Request # 25 | Received 7044 Intraday data records from 2022-04-25 10:13:02.114000 to 2022-04-25 10:15:01.669000 (119.6 seconds) and wrote 6945 records for MNQ-202206-GLOBEX-USD | 2022-04-25 10:15:05.943
HD Request # 25 | Completion time: 1s | 2022-04-25 10:15:05.944
HD Request # 25 | Intraday data download complete for MNQ-202206-GLOBEX-USD. Unique request ID: 115 | 2022-04-25 10:15:05.944
Removing historical data download ID 115. | 2022-04-25 10:15:05.944
Real-time Intraday chart data file updates started for MNQ-202206-GLOBEX-USD | 2022-04-25 10:15:05.944
Intraday chart data file opened for MNQ-202206-GLOBEX-USD | 2022-04-25 10:15:05.944
HD Request # 25 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:05.944
Triggering next historical data download in queue. | 2022-04-25 10:15:05.944
HD Request # 27 | Downloading Intraday chart data for ZN-202112-ECBOT to the file ZN-202112-ECBOT.scid. Service: cbot | 2022-04-25 10:15:05.944
HD Request # 27 | Download start date-time: 2021-12-21 12:57:42.000000. File last date-time: 2021-12-21 12:57:42.053002 | 2022-04-25 10:15:05.944
HD Request # 27 | Using server: ds21.sierracharts.com port 10149 | 2022-04-25 10:15:05.944
Socket (3) | Creating socket. | 2022-04-25 10:15:05.944
Socket (3) | New receive buffer size: 5242880 | 2022-04-25 10:15:05.944
Socket (3) | Connecting to IP: 216.1.90.129. | 2022-04-25 10:15:05.944
Socket (4) | Socket gracefully closed by remote side. | 2022-04-25 10:15:06.163
Socket (4) | Closed. | 2022-04-25 10:15:06.163
HD Request # 26 | Requesting historical Daily data for ZSN73 starting at 1972-06-26. SC External HD service. | 2022-04-25 10:15:06.277
HD Request # 27 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:06.400
HD Request # 27 | Sending historical data logon request message. | 2022-04-25 10:15:06.400
HD Request # 27 | Requesting Intraday data. Start date-time: 2021-12-21 12:57:42. Record interval: 0. Symbol: ZNZ21 | 2022-04-25 10:15:06.628
HD Request # 27 | Decompressing data. | 2022-04-25 10:15:06.876
HD Request # 27 | Receiving Intraday data for ZN-202112-ECBOT starting at 2021-12-21 12:57:42.053000 | 2022-04-25 10:15:06.876
Socket (3) | CloseSocket call. | 2022-04-25 10:15:06.876
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:06.876
Historical data download thread signaled to stop. | 2022-04-25 10:15:06.883
HD Request # 27 | Received 3 Intraday data records from 2021-12-21 12:57:42.053000 to 2021-12-21 12:57:42.053002 (0.0 seconds) and wrote 0 records for ZN-202112-ECBOT | 2022-04-25 10:15:06.883
HD Request # 27 | Completion time: 1s | 2022-04-25 10:15:06.884
HD Request # 27 | Intraday data download complete for ZN-202112-ECBOT. Unique request ID: 116 | 2022-04-25 10:15:06.884
Removing historical data download ID 116. | 2022-04-25 10:15:06.884
Real-time Intraday chart data file updates started for ZN-202112-ECBOT | 2022-04-25 10:15:06.884
Intraday chart data file opened for ZN-202112-ECBOT | 2022-04-25 10:15:06.884
HD Request # 27 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:06.884
Triggering next historical data download in queue. | 2022-04-25 10:15:06.884
HD Request # 28 | Downloading Intraday chart data for ZN-202206-ECBOT to the file ZN-202206-ECBOT.scid. Service: cbot | 2022-04-25 10:15:06.884
HD Request # 28 | Download start date-time: 2022-04-25 10:13:01.000000. File last date-time: 2022-04-25 10:13:01.005000 | 2022-04-25 10:15:06.884
HD Request # 28 | Using server: ds23.sierracharts.com port 10150 | 2022-04-25 10:15:06.884
Socket (2) | Creating socket. | 2022-04-25 10:15:06.884
Socket (2) | New receive buffer size: 5242880 | 2022-04-25 10:15:06.884
Socket (2) | Connecting to IP: 216.1.90.130. | 2022-04-25 10:15:06.884
HD Request # 26 | Receiving historical Daily data for ZS-197307-ECBOT starting at 1972-08-02 | 2022-04-25 10:15:07.028
HD Request # 26 | Writing historical Daily data to the file ZS-197307-ECBOT.dly | 2022-04-25 10:15:07.028
HD Request # 26 | Bytes received: 10339 | 2022-04-25 10:15:07.029
HD Request # 26 | Received 240 Daily data records from 1972-08-02 00:00:00 to 1973-07-20 00:00:00 (353.0 days) and wrote 240 records for ZS-197307-ECBOT | 2022-04-25 10:15:07.029
HD Request # 26 | Completion time: 3s | 2022-04-25 10:15:07.029
HD Request # 26 | Daily data download complete for ZS-197307-ECBOT. Unique request ID: 9 | 2022-04-25 10:15:07.029
Removing historical data download ID 9. | 2022-04-25 10:15:07.029
Triggering next historical data download in queue. | 2022-04-25 10:15:07.029
Mapping ZS-197407-ECBOT to ZSN74. Service code: cbot | 2022-04-25 10:15:07.030
HD Request # 29 | Downloading Historical Daily chart data for ZS-197407-ECBOT. Starting date: 1973-06-26. Service: interactive_brokers.trading | 2022-04-25 10:15:07.030
Socket (3) | Socket gracefully closed by remote side. | 2022-04-25 10:15:07.103
Socket (3) | Closed. | 2022-04-25 10:15:07.103
HD Request # 28 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:07.374
HD Request # 28 | Sending historical data logon request message. | 2022-04-25 10:15:07.374
HD Request # 28 | Requesting Intraday data. Start date-time: 2022-04-25 10:13:01. Record interval: 0. Symbol: ZNM22 | 2022-04-25 10:15:07.628
HD Request # 28 | Decompressing data. | 2022-04-25 10:15:07.881
HD Request # 28 | Receiving Intraday data for ZN-202206-ECBOT starting at 2022-04-25 10:13:01.005000 | 2022-04-25 10:15:07.882
HD Request # 29 | Requesting historical Daily data for ZSN74 starting at 1973-06-25. SC External HD service. | 2022-04-25 10:15:08.434
Opened cached Intraday file: C:\SierraChart\Data\YK-202205-ECBOT-USD-1000.scid. Thread ID: 19936 | 2022-04-25 10:15:08.638
Opened cached Intraday file: C:\SierraChart\Data\MYM-202206-ECBOT-USD.scid. Thread ID: 19936 | 2022-04-25 10:15:08.639
Opened cached Intraday file: C:\SierraChart\Data\MNQ-202206-GLOBEX-USD.scid. Thread ID: 19936 | 2022-04-25 10:15:08.639
Socket (2) | CloseSocket call. | 2022-04-25 10:15:08.676
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:08.676
Historical data download thread signaled to stop. | 2022-04-25 10:15:08.676
HD Request # 28 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:02.698000 | 2022-04-25 10:15:08.677
HD Request # 28 | Received 1341 Intraday data records from 2022-04-25 10:13:01.005000 to 2022-04-25 10:15:00.847001 (119.8 seconds) and wrote 1340 records for ZN-202206-ECBOT | 2022-04-25 10:15:08.677
HD Request # 28 | Completion time: 2s | 2022-04-25 10:15:08.677
HD Request # 28 | Intraday data download complete for ZN-202206-ECBOT. Unique request ID: 117 | 2022-04-25 10:15:08.677
Removing historical data download ID 117. | 2022-04-25 10:15:08.677
Real-time Intraday chart data file updates started for ZN-202206-ECBOT | 2022-04-25 10:15:08.677
Intraday chart data file opened for ZN-202206-ECBOT | 2022-04-25 10:15:08.677
HD Request # 28 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:08.677
Triggering next historical data download in queue. | 2022-04-25 10:15:08.677
HD Request # 30 | Downloading Intraday chart data for MGC-202206-NYMEX-USD-10 to the file MGC-202206-NYMEX-USD-10.scid. Service: comex | 2022-04-25 10:15:08.677
HD Request # 30 | Download start date-time: 2022-04-25 10:13:02.000000. File last date-time: 2022-04-25 10:13:02.163002 | 2022-04-25 10:15:08.677
HD Request # 30 | Using server: ds21.sierracharts.com port 10149 | 2022-04-25 10:15:08.677
Socket (4) | Creating socket. | 2022-04-25 10:15:08.677
Socket (4) | New receive buffer size: 5242880 | 2022-04-25 10:15:08.677
Socket (4) | Connecting to IP: 216.1.90.129. | 2022-04-25 10:15:08.677
Socket (2) | Socket gracefully closed by remote side. | 2022-04-25 10:15:08.903
Socket (2) | Closed. | 2022-04-25 10:15:08.904
HD Request # 30 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:09.135
HD Request # 30 | Sending historical data logon request message. | 2022-04-25 10:15:09.135
HD Request # 29 | Receiving historical Daily data for ZS-197407-ECBOT starting at 1973-07-23 | 2022-04-25 10:15:09.248
HD Request # 29 | Writing historical Daily data to the file ZS-197407-ECBOT.dly | 2022-04-25 10:15:09.248
HD Request # 29 | Bytes received: 9648 | 2022-04-25 10:15:09.249
HD Request # 29 | Received 250 Daily data records from 1973-07-23 00:00:00 to 1974-07-22 00:00:00 (365.0 days) and wrote 250 records for ZS-197407-ECBOT | 2022-04-25 10:15:09.249
HD Request # 29 | Completion time: 2s | 2022-04-25 10:15:09.249
HD Request # 29 | Daily data download complete for ZS-197407-ECBOT. Unique request ID: 10 | 2022-04-25 10:15:09.249
Removing historical data download ID 10. | 2022-04-25 10:15:09.249
Triggering next historical data download in queue. | 2022-04-25 10:15:09.249
Mapping ZS-197507-ECBOT to ZSN75. Service code: cbot | 2022-04-25 10:15:09.250
HD Request # 31 | Downloading Historical Daily chart data for ZS-197507-ECBOT. Starting date: 1974-06-25. Service: interactive_brokers.trading | 2022-04-25 10:15:09.250
HD Request # 30 | Requesting Intraday data. Start date-time: 2022-04-25 10:13:02. Record interval: 0. Symbol: MGCM22 | 2022-04-25 10:15:09.353
HD Request # 30 | Decompressing data. | 2022-04-25 10:15:09.573
HD Request # 30 | Receiving Intraday data for MGC-202206-NYMEX-USD-10 starting at 2022-04-25 10:13:02.163000 | 2022-04-25 10:15:09.574
Socket (4) | CloseSocket call. | 2022-04-25 10:15:09.574
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:09.574
Historical data download thread signaled to stop. | 2022-04-25 10:15:09.574
HD Request # 30 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:02.786000 | 2022-04-25 10:15:09.574
HD Request # 30 | Received 248 Intraday data records from 2022-04-25 10:13:02.163000 to 2022-04-25 10:15:05.318000 (2.1 minutes) and wrote 245 records for MGC-202206-NYMEX-USD-10 | 2022-04-25 10:15:09.574
HD Request # 30 | Completion time: 1s | 2022-04-25 10:15:09.575
HD Request # 30 | Intraday data download complete for MGC-202206-NYMEX-USD-10. Unique request ID: 118 | 2022-04-25 10:15:09.575
Removing historical data download ID 118. | 2022-04-25 10:15:09.575
Real-time Intraday chart data file updates started for MGC-202206-NYMEX-USD-10 | 2022-04-25 10:15:09.575
Intraday chart data file opened for MGC-202206-NYMEX-USD-10 | 2022-04-25 10:15:09.575
HD Request # 30 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:09.575
Triggering next historical data download in queue. | 2022-04-25 10:15:09.575
HD Request # 32 | Downloading Intraday chart data for QG-202204-NYMEX to the file QG-202204-NYMEX.scid. Service: nymex | 2022-04-25 10:15:09.575
HD Request # 32 | Download start date-time: 2022-03-28 14:11:40.000000. File last date-time: 2022-03-28 14:11:40.183001 | 2022-04-25 10:15:09.575
HD Request # 32 | Using server: ds23.sierracharts.com port 10150 | 2022-04-25 10:15:09.575
Socket (11) | Creating socket. | 2022-04-25 10:15:09.575
Socket (11) | New receive buffer size: 5242880 | 2022-04-25 10:15:09.575
Socket (11) | Connecting to IP: 216.1.90.130. | 2022-04-25 10:15:09.575
Socket (4) | Socket gracefully closed by remote side. | 2022-04-25 10:15:09.793
Socket (4) | Closed. | 2022-04-25 10:15:09.793
HD Request # 32 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:10.039
HD Request # 32 | Sending historical data logon request message. | 2022-04-25 10:15:10.039
HD Request # 32 | Requesting Intraday data. Start date-time: 2022-03-28 14:11:40. Record interval: 0. Symbol: QGJ22 | 2022-04-25 10:15:10.261
HD Request # 32 | Decompressing data. | 2022-04-25 10:15:10.481
HD Request # 32 | Receiving Intraday data for QG-202204-NYMEX starting at 2022-03-28 14:11:40.183000 | 2022-04-25 10:15:10.482
Socket (11) | CloseSocket call. | 2022-04-25 10:15:10.482
Socket (11) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:10.482
Historical data download thread signaled to stop. | 2022-04-25 10:15:10.482
HD Request # 32 | Received 2 Intraday data records from 2022-03-28 14:11:40.183000 to 2022-03-28 14:11:40.183001 (0.0 seconds) and wrote 0 records for QG-202204-NYMEX | 2022-04-25 10:15:10.482
HD Request # 32 | Completion time: 1s | 2022-04-25 10:15:10.482
HD Request # 32 | Intraday data download complete for QG-202204-NYMEX. Unique request ID: 120 | 2022-04-25 10:15:10.482
Removing historical data download ID 120. | 2022-04-25 10:15:10.482
Real-time Intraday chart data file updates started for QG-202204-NYMEX | 2022-04-25 10:15:10.482
Intraday chart data file opened for QG-202204-NYMEX | 2022-04-25 10:15:10.482
HD Request # 32 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:10.482
Triggering next historical data download in queue. | 2022-04-25 10:15:10.482
HD Request # 33 | Downloading Historical Daily chart data for USOil. Starting date: 2022-04-21. Service: fxcm | 2022-04-25 10:15:10.484
HD Request # 33 | Using server: ds12.sierracharts.com port 10149 | 2022-04-25 10:15:10.484
Socket (3) | Creating socket. | 2022-04-25 10:15:10.484
Socket (3) | New receive buffer size: 5242880 | 2022-04-25 10:15:10.484
Socket (3) | Connecting to IP: 204.15.197.14. | 2022-04-25 10:15:10.484
HD Request # 31 | Requesting historical Daily data for ZSN75 starting at 1974-06-24. SC External HD service. | 2022-04-25 10:15:10.656
Socket (11) | Socket gracefully closed by remote side. | 2022-04-25 10:15:10.699
Socket (11) | Closed. | 2022-04-25 10:15:10.699
HD Request # 33 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:10.970
HD Request # 33 | Sending historical data logon request message. | 2022-04-25 10:15:10.970
HD Request # 33 | Requesting historical Daily data starting at 2022-04-21. | 2022-04-25 10:15:11.208
HD Request # 33 | Decompressing data. | 2022-04-25 10:15:11.441
HD Request # 33 | Receiving historical Daily data for USOil starting at 2022-04-21 | 2022-04-25 10:15:11.458
HD Request # 33 | Writing historical Daily data to the file USOil.dly | 2022-04-25 10:15:11.458
Socket (3) | CloseSocket call. | 2022-04-25 10:15:11.483
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:11.483
Historical data download thread signaled to stop. | 2022-04-25 10:15:11.483
HD Request # 33 | Received 3 Daily data records from 2022-04-21 00:00:00 to 2022-04-25 00:00:00 (5.0 days) and wrote 3 records for USOil | 2022-04-25 10:15:11.483
HD Request # 33 | Completion time: 1s | 2022-04-25 10:15:11.483
HD Request # 33 | Daily data download complete for USOil. Unique request ID: 121 | 2022-04-25 10:15:11.483
Removing historical data download ID 121. | 2022-04-25 10:15:11.483
Triggering next historical data download in queue. | 2022-04-25 10:15:11.483
HD Request # 34 | Downloading Intraday chart data for QM-202206-NYMEX to the file QM-202206-NYMEX.scid. Service: nymex | 2022-04-25 10:15:11.483
HD Request # 34 | Download start date-time: 2022-04-25 10:12:52.000000. File last date-time: 2022-04-25 10:12:52.786000 | 2022-04-25 10:15:11.484
HD Request # 34 | Using server: ds21.sierracharts.com port 10150 | 2022-04-25 10:15:11.484
Socket (2) | Creating socket. | 2022-04-25 10:15:11.484
Socket (2) | New receive buffer size: 5242880 | 2022-04-25 10:15:11.484
Socket (2) | Connecting to IP: 216.1.90.129. | 2022-04-25 10:15:11.484
HD Request # 31 | Receiving historical Daily data for ZS-197507-ECBOT starting at 1974-08-01 | 2022-04-25 10:15:11.484
HD Request # 31 | Writing historical Daily data to the file ZS-197507-ECBOT.dly | 2022-04-25 10:15:11.484
HD Request # 31 | Bytes received: 9519 | 2022-04-25 10:15:11.486
HD Request # 31 | Received 245 Daily data records from 1974-08-01 00:00:00 to 1975-07-22 00:00:00 (356.0 days) and wrote 245 records for ZS-197507-ECBOT | 2022-04-25 10:15:11.486
HD Request # 31 | Completion time: 2s | 2022-04-25 10:15:11.486
HD Request # 31 | Daily data download complete for ZS-197507-ECBOT. Unique request ID: 11 | 2022-04-25 10:15:11.486
Removing historical data download ID 11. | 2022-04-25 10:15:11.486
Triggering next historical data download in queue. | 2022-04-25 10:15:11.486
Mapping ZS-202207-ECBOT to ZSN22. Service code: cbot | 2022-04-25 10:15:11.486
HD Request # 35 | Downloading Historical Daily chart data for ZS-202207-ECBOT. Starting date: 2022-04-20. Service: interactive_brokers.trading | 2022-04-25 10:15:11.488
Socket (3) | Socket gracefully closed by remote side. | 2022-04-25 10:15:11.716
Socket (3) | Closed. | 2022-04-25 10:15:11.716
USOil[M] 4 Day #13 | Reloading chart. | 2022-04-25 10:15:11.813
HD Request # 34 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:11.935
HD Request # 34 | Sending historical data logon request message. | 2022-04-25 10:15:11.935
HD Request # 34 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:52. Record interval: 0. Symbol: QMM22 | 2022-04-25 10:15:12.165
HD Request # 34 | Decompressing data. | 2022-04-25 10:15:12.390
HD Request # 34 | Receiving Intraday data for QM-202206-NYMEX starting at 2022-04-25 10:12:52.786000 | 2022-04-25 10:15:12.390
Socket (2) | CloseSocket call. | 2022-04-25 10:15:12.391
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:12.391
Historical data download thread signaled to stop. | 2022-04-25 10:15:12.391
HD Request # 34 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:07.744000 | 2022-04-25 10:15:12.391
HD Request # 34 | Received 63 Intraday data records from 2022-04-25 10:12:52.786000 to 2022-04-25 10:15:04.020000 (2.2 minutes) and wrote 62 records for QM-202206-NYMEX | 2022-04-25 10:15:12.391
HD Request # 34 | Completion time: 1s | 2022-04-25 10:15:12.391
HD Request # 34 | Intraday data download complete for QM-202206-NYMEX. Unique request ID: 122 | 2022-04-25 10:15:12.391
Removing historical data download ID 122. | 2022-04-25 10:15:12.391
Real-time Intraday chart data file updates started for QM-202206-NYMEX | 2022-04-25 10:15:12.391
Intraday chart data file opened for QM-202206-NYMEX | 2022-04-25 10:15:12.391
HD Request # 34 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:12.391
Triggering next historical data download in queue. | 2022-04-25 10:15:12.391
HD Request # 36 | Downloading Historical Daily chart data for USDOLLAR. Starting date: 2022-04-21. Service: fxcm | 2022-04-25 10:15:12.393
HD Request # 36 | Using server: ds4.sierracharts.com port 10149 | 2022-04-25 10:15:12.393
Socket (3) | Creating socket. | 2022-04-25 10:15:12.393
Socket (3) | New receive buffer size: 5242880 | 2022-04-25 10:15:12.393
Socket (3) | Connecting to IP: 192.81.56.146. | 2022-04-25 10:15:12.393
Socket (2) | Socket gracefully closed by remote side. | 2022-04-25 10:15:12.608
Socket (2) | Closed. | 2022-04-25 10:15:12.608
HD Request # 36 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:12.849
HD Request # 36 | Sending historical data logon request message. | 2022-04-25 10:15:12.849
HD Request # 35 | Requesting historical Daily data for ZSN22 starting at 2022-04-19. SC External HD service. | 2022-04-25 10:15:12.902
HD Request # 36 | Requesting historical Daily data starting at 2022-04-21. | 2022-04-25 10:15:13.609
Opened cached Intraday file: C:\SierraChart\Data\QM-202206-NYMEX.scid. Thread ID: 19936 | 2022-04-25 10:15:13.676
Opened cached Intraday file: C:\SierraChart\Data\ZN-202206-ECBOT.scid. Thread ID: 19936 | 2022-04-25 10:15:13.676
Opened cached Intraday file: C:\SierraChart\Data\MGC-202206-NYMEX-USD-10.scid. Thread ID: 19936 | 2022-04-25 10:15:13.676
HD Request # 35 | Receiving historical Daily data for ZS-202207-ECBOT starting at 2022-04-20 | 2022-04-25 10:15:13.720
HD Request # 35 | Writing historical Daily data to the file ZS-202207-ECBOT.dly | 2022-04-25 10:15:13.720
HD Request # 35 | Bytes received: 226 | 2022-04-25 10:15:13.727
HD Request # 35 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for ZS-202207-ECBOT | 2022-04-25 10:15:13.727
HD Request # 35 | Completion time: 2s | 2022-04-25 10:15:13.727
HD Request # 35 | Daily data download complete for ZS-202207-ECBOT. Unique request ID: 12 | 2022-04-25 10:15:13.727
Removing historical data download ID 12. | 2022-04-25 10:15:13.727
Triggering next historical data download in queue. | 2022-04-25 10:15:13.727
HD Request # 37 | Downloading Historical Daily chart data for ZC-202207-ECBOT. Starting date: 2022-04-20. Service: interactive_brokers.trading | 2022-04-25 10:15:13.728
HD Request # 36 | Decompressing data. | 2022-04-25 10:15:13.833
HD Request # 36 | Receiving historical Daily data for USDOLLAR starting at 2022-04-21 | 2022-04-25 10:15:13.841
HD Request # 36 | Writing historical Daily data to the file USDOLLAR.dly | 2022-04-25 10:15:13.841
Socket (3) | CloseSocket call. | 2022-04-25 10:15:13.865
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:13.865
Historical data download thread signaled to stop. | 2022-04-25 10:15:13.865
HD Request # 36 | Received 3 Daily data records from 2022-04-21 00:00:00 to 2022-04-25 00:00:00 (5.0 days) and wrote 3 records for USDOLLAR | 2022-04-25 10:15:13.866
HD Request # 36 | Completion time: 1s | 2022-04-25 10:15:13.866
HD Request # 36 | Daily data download complete for USDOLLAR. Unique request ID: 124 | 2022-04-25 10:15:13.866
Removing historical data download ID 124. | 2022-04-25 10:15:13.866
Triggering next historical data download in queue. | 2022-04-25 10:15:13.866
HD Request # 38 | Downloading Intraday chart data for AUD-202206-GLOBEX to the file AUD-202206-GLOBEX.scid. Service: cme | 2022-04-25 10:15:13.866
HD Request # 38 | Download start date-time: 2022-04-25 10:13:01.000000. File last date-time: 2022-04-25 10:13:01.331001 | 2022-04-25 10:15:13.866
HD Request # 38 | Using server: ds23.sierracharts.com port 10150 | 2022-04-25 10:15:13.866
Socket (11) | Creating socket. | 2022-04-25 10:15:13.866
Socket (11) | New receive buffer size: 5242880 | 2022-04-25 10:15:13.866
Socket (11) | Connecting to IP: 216.1.90.130. | 2022-04-25 10:15:13.866
USDOLLAR[M] 4 Day #6 | Reloading chart. | 2022-04-25 10:15:13.945
ZS-202207-ECBOT [CS] 2 Day #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:15:13.952
ZS-202207-ECBOT [CS] 2 Day #6 | Reloading chart. | 2022-04-25 10:15:13.953
ZS-202207-ECBOT [CS] 4 Day #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:15:13.961
ZS-202207-ECBOT [CS] 4 Day #5 | Reloading chart. | 2022-04-25 10:15:13.963
Socket (3) | Socket gracefully closed by remote side. | 2022-04-25 10:15:14.088
Socket (3) | Closed. | 2022-04-25 10:15:14.088
ZS-202207-ECBOT [CS] 4 Day #5 | StartDateTimeForLoadingOrderFills: 1972-04-17 00:00:00 | 2022-04-25 10:15:14.212
ZS-202207-ECBOT [CS] 4 Day #5 | Reloading chart. | 2022-04-25 10:15:14.218
ZS-202207-ECBOT [CS] 4 Day #5 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:14.218
ZS-202207-ECBOT [CS] 4 Day #5 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:14.218
HD Request # 38 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:14.323
HD Request # 38 | Sending historical data logon request message. | 2022-04-25 10:15:14.323
HD Request # 38 | Requesting Intraday data. Start date-time: 2022-04-25 10:13:01. Record interval: 0. Symbol: 6AM22 | 2022-04-25 10:15:14.542
HD Request # 38 | Decompressing data. | 2022-04-25 10:15:14.761
HD Request # 38 | Receiving Intraday data for AUD-202206-GLOBEX starting at 2022-04-25 10:13:01.026000 | 2022-04-25 10:15:14.763
Socket (11) | CloseSocket call. | 2022-04-25 10:15:14.763
Socket (11) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:14.763
Socket (11) | Socket gracefully closed by remote side. | 2022-04-25 10:15:14.984
Socket (11) | Closed. | 2022-04-25 10:15:14.984
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-200107-ECBOT.dly has a volume of 0 at 2000-06-28. | 2022-04-25 10:15:15.309
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-200007-ECBOT.dly has a volume of 0 at 1999-06-28. | 2022-04-25 10:15:15.352
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-200007-ECBOT.dly has a volume of 0 at 2000-06-27. | 2022-04-25 10:15:15.352
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199907-ECBOT.dly has a volume of 0 at 1998-06-26. | 2022-04-25 10:15:15.395
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199907-ECBOT.dly has a volume of 0 at 1999-06-25. | 2022-04-25 10:15:15.395
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199807-ECBOT.dly has a volume of 0 at 1997-06-26. | 2022-04-25 10:15:15.439
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199807-ECBOT.dly has a volume of 0 at 1998-06-25. | 2022-04-25 10:15:15.439
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199707-ECBOT.dly has a volume of 0 at 1996-06-26. | 2022-04-25 10:15:15.482
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199707-ECBOT.dly has a volume of 0 at 1997-06-25. | 2022-04-25 10:15:15.482
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199607-ECBOT.dly has a volume of 0 at 1995-06-28. | 2022-04-25 10:15:15.525
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199607-ECBOT.dly has a volume of 0 at 1996-06-25. | 2022-04-25 10:15:15.525
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199507-ECBOT.dly has a volume of 0 at 1994-06-28. | 2022-04-25 10:15:15.567
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199507-ECBOT.dly has a volume of 0 at 1995-06-27. | 2022-04-25 10:15:15.567
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199407-ECBOT.dly has a volume of 0 at 1993-06-28. | 2022-04-25 10:15:15.611
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199407-ECBOT.dly has a volume of 0 at 1994-06-27. | 2022-04-25 10:15:15.611
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199307-ECBOT.dly has a volume of 0 at 1992-06-26. | 2022-04-25 10:15:15.655
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199307-ECBOT.dly has a volume of 0 at 1993-06-25. | 2022-04-25 10:15:15.655
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199207-ECBOT.dly has a volume of 0 at 1991-06-26. | 2022-04-25 10:15:15.698
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199207-ECBOT.dly has a volume of 0 at 1992-06-25. | 2022-04-25 10:15:15.698
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199107-ECBOT.dly has a volume of 0 at 1990-06-27. | 2022-04-25 10:15:15.741
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199107-ECBOT.dly has a volume of 0 at 1991-06-25. | 2022-04-25 10:15:15.741
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199007-ECBOT.dly has a volume of 0 at 1989-06-28. | 2022-04-25 10:15:15.784
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-199007-ECBOT.dly has a volume of 0 at 1990-06-26. | 2022-04-25 10:15:15.784
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198907-ECBOT.dly has a volume of 0 at 1988-06-28. | 2022-04-25 10:15:15.827
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198907-ECBOT.dly has a volume of 0 at 1989-06-27. | 2022-04-25 10:15:15.827
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198807-ECBOT.dly has a volume of 0 at 1987-06-26. | 2022-04-25 10:15:15.870
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198807-ECBOT.dly has a volume of 0 at 1988-06-27. | 2022-04-25 10:15:15.870
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198707-ECBOT.dly has a volume of 0 at 1986-06-26. | 2022-04-25 10:15:15.913
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198707-ECBOT.dly has a volume of 0 at 1987-06-25. | 2022-04-25 10:15:15.913
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198607-ECBOT.dly has a volume of 0 at 1985-06-26. | 2022-04-25 10:15:15.957
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198607-ECBOT.dly has a volume of 0 at 1986-06-25. | 2022-04-25 10:15:15.957
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198507-ECBOT.dly has a volume of 0 at 1984-06-27. | 2022-04-25 10:15:16.000
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198507-ECBOT.dly has a volume of 0 at 1985-06-25. | 2022-04-25 10:15:16.000
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198407-ECBOT.dly has a volume of 0 at 1983-06-28. | 2022-04-25 10:15:16.042
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198407-ECBOT.dly has a volume of 0 at 1984-06-26. | 2022-04-25 10:15:16.042
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198307-ECBOT.dly has a volume of 0 at 1982-06-28. | 2022-04-25 10:15:16.085
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198307-ECBOT.dly has a volume of 0 at 1983-06-27. | 2022-04-25 10:15:16.085
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198207-ECBOT.dly has a volume of 0 at 1981-06-26. | 2022-04-25 10:15:16.128
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198207-ECBOT.dly has a volume of 0 at 1982-06-25. | 2022-04-25 10:15:16.128
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198107-ECBOT.dly has a volume of 0 at 1980-06-26. | 2022-04-25 10:15:16.171
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198107-ECBOT.dly has a volume of 0 at 1981-06-25. | 2022-04-25 10:15:16.171
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198007-ECBOT.dly has a volume of 0 at 1979-06-27. | 2022-04-25 10:15:16.214
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-198007-ECBOT.dly has a volume of 0 at 1980-06-25. | 2022-04-25 10:15:16.214
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-197907-ECBOT.dly has a volume of 0 at 1978-06-28. | 2022-04-25 10:15:16.256
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-197907-ECBOT.dly has a volume of 0 at 1979-06-26. | 2022-04-25 10:15:16.256
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-197807-ECBOT.dly has a volume of 0 at 1977-06-28. | 2022-04-25 10:15:16.300
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-197807-ECBOT.dly has a volume of 0 at 1978-06-27. | 2022-04-25 10:15:16.300
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-197707-ECBOT.dly has a volume of 0 at 1976-06-28. | 2022-04-25 10:15:16.343
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-197707-ECBOT.dly has a volume of 0 at 1977-06-27. | 2022-04-25 10:15:16.343
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-197607-ECBOT.dly has a volume of 0 at 1975-06-26. | 2022-04-25 10:15:16.386
ZS-202207-ECBOT [CS] 4 Day #5 | File ZS-197607-ECBOT.dly has a volume of 0 at 1976-06-25. | 2022-04-25 10:15:16.386
ZS-202207-ECBOT [CS] 4 Day #5 | Dates not found while checking for invalid data in continuous contract data files. ZS-197507-ECBOT | 2022-04-25 10:15:16.426 *
Historical data download thread signaled to stop. | 2022-04-25 10:15:16.433
HD Request # 38 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:02.992000 | 2022-04-25 10:15:16.433
HD Request # 38 | Received 226 Intraday data records from 2022-04-25 10:13:01.026000 to 2022-04-25 10:15:09.232001 (2.1 minutes) and wrote 221 records for AUD-202206-GLOBEX | 2022-04-25 10:15:16.433
HD Request # 38 | Completion time: 3s | 2022-04-25 10:15:16.433
HD Request # 38 | Intraday data download complete for AUD-202206-GLOBEX. Unique request ID: 125 | 2022-04-25 10:15:16.433
Removing historical data download ID 125. | 2022-04-25 10:15:16.433
Real-time Intraday chart data file updates started for AUD-202206-GLOBEX | 2022-04-25 10:15:16.433
Intraday chart data file opened for AUD-202206-GLOBEX | 2022-04-25 10:15:16.433
HD Request # 38 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:16.433
Triggering next historical data download in queue. | 2022-04-25 10:15:16.433
HD Request # 37 | Requesting historical Daily data for ZCN22 starting at 2022-04-19. SC External HD service. | 2022-04-25 10:15:16.433
HD Request # 39 | Downloading Historical Daily chart data for GBPUSD. Starting date: 2022-04-21. Service: fxcm | 2022-04-25 10:15:16.435
HD Request # 39 | Using server: ds12.sierracharts.com port 10149 | 2022-04-25 10:15:16.435
Socket (3) | Creating socket. | 2022-04-25 10:15:16.435
Socket (3) | New receive buffer size: 5242880 | 2022-04-25 10:15:16.436
Socket (3) | Connecting to IP: 204.15.197.14. | 2022-04-25 10:15:16.436
ZS-202207-ECBOT [CS] 2 Day #6 | Reloading chart. | 2022-04-25 10:15:16.499
ZS-202207-ECBOT [CS] 2 Day #6 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:16.499
ZS-202207-ECBOT [CS] 2 Day #6 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:16.499
HD Request # 39 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:16.923
HD Request # 39 | Sending historical data logon request message. | 2022-04-25 10:15:16.923
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-200107-ECBOT.dly has a volume of 0 at 2000-06-28. | 2022-04-25 10:15:17.584
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-200007-ECBOT.dly has a volume of 0 at 1999-06-28. | 2022-04-25 10:15:17.626
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-200007-ECBOT.dly has a volume of 0 at 2000-06-27. | 2022-04-25 10:15:17.626
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199907-ECBOT.dly has a volume of 0 at 1998-06-26. | 2022-04-25 10:15:17.669
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199907-ECBOT.dly has a volume of 0 at 1999-06-25. | 2022-04-25 10:15:17.669
HD Request # 39 | Requesting historical Daily data starting at 2022-04-21. | 2022-04-25 10:15:17.698
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199807-ECBOT.dly has a volume of 0 at 1997-06-26. | 2022-04-25 10:15:17.712
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199807-ECBOT.dly has a volume of 0 at 1998-06-25. | 2022-04-25 10:15:17.712
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199707-ECBOT.dly has a volume of 0 at 1996-06-26. | 2022-04-25 10:15:17.755
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199707-ECBOT.dly has a volume of 0 at 1997-06-25. | 2022-04-25 10:15:17.755
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199607-ECBOT.dly has a volume of 0 at 1995-06-28. | 2022-04-25 10:15:17.798
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199607-ECBOT.dly has a volume of 0 at 1996-06-25. | 2022-04-25 10:15:17.798
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199507-ECBOT.dly has a volume of 0 at 1994-06-28. | 2022-04-25 10:15:17.840
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199507-ECBOT.dly has a volume of 0 at 1995-06-27. | 2022-04-25 10:15:17.840
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199407-ECBOT.dly has a volume of 0 at 1993-06-28. | 2022-04-25 10:15:17.883
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199407-ECBOT.dly has a volume of 0 at 1994-06-27. | 2022-04-25 10:15:17.883
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199307-ECBOT.dly has a volume of 0 at 1992-06-26. | 2022-04-25 10:15:17.927
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199307-ECBOT.dly has a volume of 0 at 1993-06-25. | 2022-04-25 10:15:17.927
HD Request # 39 | Decompressing data. | 2022-04-25 10:15:17.932
HD Request # 39 | Receiving historical Daily data for GBPUSD starting at 2022-04-21 | 2022-04-25 10:15:17.960
HD Request # 39 | Writing historical Daily data to the file GBPUSD.dly | 2022-04-25 10:15:17.960
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199207-ECBOT.dly has a volume of 0 at 1991-06-26. | 2022-04-25 10:15:17.971
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199207-ECBOT.dly has a volume of 0 at 1992-06-25. | 2022-04-25 10:15:17.971
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199107-ECBOT.dly has a volume of 0 at 1990-06-27. | 2022-04-25 10:15:18.018
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199107-ECBOT.dly has a volume of 0 at 1991-06-25. | 2022-04-25 10:15:18.018
Socket (3) | CloseSocket call. | 2022-04-25 10:15:18.021
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:18.021
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199007-ECBOT.dly has a volume of 0 at 1989-06-28. | 2022-04-25 10:15:18.062
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-199007-ECBOT.dly has a volume of 0 at 1990-06-26. | 2022-04-25 10:15:18.062
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198907-ECBOT.dly has a volume of 0 at 1988-06-28. | 2022-04-25 10:15:18.105
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198907-ECBOT.dly has a volume of 0 at 1989-06-27. | 2022-04-25 10:15:18.105
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198807-ECBOT.dly has a volume of 0 at 1987-06-26. | 2022-04-25 10:15:18.148
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198807-ECBOT.dly has a volume of 0 at 1988-06-27. | 2022-04-25 10:15:18.148
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198707-ECBOT.dly has a volume of 0 at 1986-06-26. | 2022-04-25 10:15:18.192
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198707-ECBOT.dly has a volume of 0 at 1987-06-25. | 2022-04-25 10:15:18.192
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198607-ECBOT.dly has a volume of 0 at 1985-06-26. | 2022-04-25 10:15:18.235
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198607-ECBOT.dly has a volume of 0 at 1986-06-25. | 2022-04-25 10:15:18.235
Socket (3) | Socket gracefully closed by remote side. | 2022-04-25 10:15:18.256
Socket (3) | Closed. | 2022-04-25 10:15:18.256
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198507-ECBOT.dly has a volume of 0 at 1984-06-27. | 2022-04-25 10:15:18.278
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198507-ECBOT.dly has a volume of 0 at 1985-06-25. | 2022-04-25 10:15:18.278
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198407-ECBOT.dly has a volume of 0 at 1983-06-28. | 2022-04-25 10:15:18.321
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198407-ECBOT.dly has a volume of 0 at 1984-06-26. | 2022-04-25 10:15:18.321
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198307-ECBOT.dly has a volume of 0 at 1982-06-28. | 2022-04-25 10:15:18.364
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198307-ECBOT.dly has a volume of 0 at 1983-06-27. | 2022-04-25 10:15:18.364
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198207-ECBOT.dly has a volume of 0 at 1981-06-26. | 2022-04-25 10:15:18.407
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198207-ECBOT.dly has a volume of 0 at 1982-06-25. | 2022-04-25 10:15:18.407
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198107-ECBOT.dly has a volume of 0 at 1980-06-26. | 2022-04-25 10:15:18.450
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198107-ECBOT.dly has a volume of 0 at 1981-06-25. | 2022-04-25 10:15:18.450
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198007-ECBOT.dly has a volume of 0 at 1979-06-27. | 2022-04-25 10:15:18.493
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-198007-ECBOT.dly has a volume of 0 at 1980-06-25. | 2022-04-25 10:15:18.493
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-197907-ECBOT.dly has a volume of 0 at 1978-06-28. | 2022-04-25 10:15:18.535
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-197907-ECBOT.dly has a volume of 0 at 1979-06-26. | 2022-04-25 10:15:18.535
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-197807-ECBOT.dly has a volume of 0 at 1977-06-28. | 2022-04-25 10:15:18.578
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-197807-ECBOT.dly has a volume of 0 at 1978-06-27. | 2022-04-25 10:15:18.578
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-197707-ECBOT.dly has a volume of 0 at 1976-06-28. | 2022-04-25 10:15:18.621
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-197707-ECBOT.dly has a volume of 0 at 1977-06-27. | 2022-04-25 10:15:18.621
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-197607-ECBOT.dly has a volume of 0 at 1975-06-26. | 2022-04-25 10:15:18.663
ZS-202207-ECBOT [CS] 2 Day #6 | File ZS-197607-ECBOT.dly has a volume of 0 at 1976-06-25. | 2022-04-25 10:15:18.663
ZS-202207-ECBOT [CS] 2 Day #6 | Dates not found while checking for invalid data in continuous contract data files. ZS-197507-ECBOT | 2022-04-25 10:15:18.703 *
ZS-202207-ECBOT [CS] 4 Day #5 | StartDateTimeForLoadingOrderFills: 1972-04-17 00:00:00 | 2022-04-25 10:15:18.711
Historical data download thread signaled to stop. | 2022-04-25 10:15:18.715
HD Request # 39 | Received 3 Daily data records from 2022-04-21 00:00:00 to 2022-04-25 00:00:00 (5.0 days) and wrote 3 records for GBPUSD | 2022-04-25 10:15:18.715
HD Request # 39 | Completion time: 2s | 2022-04-25 10:15:18.715
HD Request # 39 | Daily data download complete for GBPUSD. Unique request ID: 126 | 2022-04-25 10:15:18.715
Removing historical data download ID 126. | 2022-04-25 10:15:18.715
Triggering next historical data download in queue. | 2022-04-25 10:15:18.715
HD Request # 40 | Downloading Intraday chart data for GBP-202206-GLOBEX to the file GBP-202206-GLOBEX.scid. Service: cme | 2022-04-25 10:15:18.715
HD Request # 40 | Download start date-time: 2022-04-25 10:13:01.000000. File last date-time: 2022-04-25 10:13:01.758006 | 2022-04-25 10:15:18.715
HD Request # 40 | Using server: ds21.sierracharts.com port 10150 | 2022-04-25 10:15:18.715
Socket (3) | Creating socket. | 2022-04-25 10:15:18.715
Socket (3) | New receive buffer size: 5242880 | 2022-04-25 10:15:18.716
Socket (3) | Connecting to IP: 216.1.90.129. | 2022-04-25 10:15:18.716
Opened cached Intraday file: C:\SierraChart\Data\AUD-202206-GLOBEX.scid. Thread ID: 19936 | 2022-04-25 10:15:18.729
GBPUSD[M] Daily #12 | Reloading chart. | 2022-04-25 10:15:18.798
SC Data - All Services | Starting real-time market data updates for: ZS-202207-ECBOT (ZSN22). ID: 102 Service code: cbot | 2022-04-25 10:15:18.835
SC Data - All Services | Requesting security definition data for: ZS-202207-ECBOT (ZSN22). ID: 102 | 2022-04-25 10:15:18.835
SC Data - All Services | Received security definition for symbol ZS-202207-ECBOT | 2022-04-25 10:15:19.063
HD Request # 40 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:19.172
HD Request # 40 | Sending historical data logon request message. | 2022-04-25 10:15:19.172
HD Request # 37 | Receiving historical Daily data for ZC-202207-ECBOT starting at 2022-04-20 | 2022-04-25 10:15:19.366
HD Request # 37 | Writing historical Daily data to the file ZC-202207-ECBOT.dly | 2022-04-25 10:15:19.366
HD Request # 37 | Bytes received: 205 | 2022-04-25 10:15:19.374
HD Request # 37 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for ZC-202207-ECBOT | 2022-04-25 10:15:19.374
HD Request # 37 | Completion time: 6s | 2022-04-25 10:15:19.374
HD Request # 37 | Daily data download complete for ZC-202207-ECBOT. Unique request ID: 13 | 2022-04-25 10:15:19.374
Removing historical data download ID 13. | 2022-04-25 10:15:19.374
Triggering next historical data download in queue. | 2022-04-25 10:15:19.374
Mapping YM-200206-ECBOT to YMM02. Service code: cbot | 2022-04-25 10:15:19.374
HD Request # 41 | Downloading Historical Daily chart data for YM-200206-ECBOT. Starting date: 2002-03-07. Service: interactive_brokers.trading | 2022-04-25 10:15:19.374
ZC-202207-ECBOT [CS] Daily #19 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:15:19.471
ZC-202207-ECBOT [CS] Daily #19 | Reloading chart. | 2022-04-25 10:15:19.472
ZC-202207-ECBOT [CS] Daily #19 | Reloading chart. | 2022-04-25 10:15:19.746
HD Request # 40 | Requesting Intraday data. Start date-time: 2022-04-25 10:13:01. Record interval: 0. Symbol: 6BM22 | 2022-04-25 10:15:19.889
HD Request # 40 | Decompressing data. | 2022-04-25 10:15:20.105
HD Request # 40 | Receiving Intraday data for GBP-202206-GLOBEX starting at 2022-04-25 10:13:01.758000 | 2022-04-25 10:15:20.106
Socket (3) | CloseSocket call. | 2022-04-25 10:15:20.107
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:20.107
Socket (3) | Socket gracefully closed by remote side. | 2022-04-25 10:15:20.340
Socket (3) | Closed. | 2022-04-25 10:15:20.340
ZC-202207-ECBOT [CS] Daily #19 | File ZC-200107-ECBOT.dly has a volume of 0 at 2000-06-28. | 2022-04-25 10:15:20.790
ZC-202207-ECBOT [CS] Daily #19 | File ZC-200007-ECBOT.dly has a volume of 0 at 1999-06-28. | 2022-04-25 10:15:20.832
ZC-202207-ECBOT [CS] Daily #19 | File ZC-200007-ECBOT.dly has a volume of 0 at 2000-06-27. | 2022-04-25 10:15:20.832
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199907-ECBOT.dly has a volume of 0 at 1998-06-26. | 2022-04-25 10:15:20.875
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199907-ECBOT.dly has a volume of 0 at 1999-06-25. | 2022-04-25 10:15:20.875
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199807-ECBOT.dly has a volume of 0 at 1997-06-26. | 2022-04-25 10:15:20.918
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199807-ECBOT.dly has a volume of 0 at 1998-06-25. | 2022-04-25 10:15:20.918
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199707-ECBOT.dly has a volume of 0 at 1996-06-26. | 2022-04-25 10:15:20.961
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199707-ECBOT.dly has a volume of 0 at 1997-06-25. | 2022-04-25 10:15:20.961
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199607-ECBOT.dly has a volume of 0 at 1995-06-28. | 2022-04-25 10:15:21.003
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199607-ECBOT.dly has a volume of 0 at 1996-06-25. | 2022-04-25 10:15:21.003
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199507-ECBOT.dly has a volume of 0 at 1994-06-28. | 2022-04-25 10:15:21.046
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199507-ECBOT.dly has a volume of 0 at 1995-06-27. | 2022-04-25 10:15:21.046
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199407-ECBOT.dly has a volume of 0 at 1993-06-28. | 2022-04-25 10:15:21.088
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199407-ECBOT.dly has a volume of 0 at 1994-06-27. | 2022-04-25 10:15:21.088
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199307-ECBOT.dly has a volume of 0 at 1992-06-26. | 2022-04-25 10:15:21.132
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199307-ECBOT.dly has a volume of 0 at 1993-06-25. | 2022-04-25 10:15:21.132
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199207-ECBOT.dly has a volume of 0 at 1991-06-26. | 2022-04-25 10:15:21.175
ZC-202207-ECBOT [CS] Daily #19 | File ZC-199207-ECBOT.dly has a volume of 0 at 1992-06-25. | 2022-04-25 10:15:21.175
Historical data download thread signaled to stop. | 2022-04-25 10:15:21.180
HD Request # 40 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:03.017000 | 2022-04-25 10:15:21.180
HD Request # 40 | Received 261 Intraday data records from 2022-04-25 10:13:01.758000 to 2022-04-25 10:15:15.491002 (2.2 minutes) and wrote 254 records for GBP-202206-GLOBEX | 2022-04-25 10:15:21.181
HD Request # 40 | Completion time: 3s | 2022-04-25 10:15:21.181
HD Request # 40 | Intraday data download complete for GBP-202206-GLOBEX. Unique request ID: 127 | 2022-04-25 10:15:21.181
Removing historical data download ID 127. | 2022-04-25 10:15:21.181
Real-time Intraday chart data file updates started for GBP-202206-GLOBEX | 2022-04-25 10:15:21.181
Intraday chart data file opened for GBP-202206-GLOBEX | 2022-04-25 10:15:21.181
HD Request # 40 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:21.181
Triggering next historical data download in queue. | 2022-04-25 10:15:21.181
HD Request # 41 | Requesting historical Daily data for YMM02 starting at 2002-03-06. SC External HD service. | 2022-04-25 10:15:21.181
HD Request # 42 | Downloading Intraday chart data for AMX-NQTV to the file AMX-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:21.181
HD Request # 42 | Download start date-time: 2022-04-25 10:12:53.000000. File last date-time: 2022-04-25 10:12:53.642001 | 2022-04-25 10:15:21.181
HD Request # 42 | Using server: ds25.sierracharts.com port 10149 | 2022-04-25 10:15:21.181
Socket (3) | Creating socket. | 2022-04-25 10:15:21.182
Socket (3) | New receive buffer size: 5242880 | 2022-04-25 10:15:21.182
Socket (3) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:21.182
HD Request # 42 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:21.639
HD Request # 42 | Sending historical data logon request message. | 2022-04-25 10:15:21.639
HD Request # 42 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:53. Record interval: 0. Symbol: AMX-NQTV | 2022-04-25 10:15:21.865
HD Request # 41 | Receiving historical Daily data for YM-200206-ECBOT starting at 2002-04-02 | 2022-04-25 10:15:21.998
HD Request # 41 | Writing historical Daily data to the file YM-200206-ECBOT.dly | 2022-04-25 10:15:21.998
HD Request # 41 | Bytes received: 2797 | 2022-04-25 10:15:21.999
HD Request # 41 | Received 58 Daily data records from 2002-04-02 00:00:00 to 2002-06-21 00:00:00 (81.0 days) and wrote 58 records for YM-200206-ECBOT | 2022-04-25 10:15:21.999
HD Request # 41 | Completion time: 2s | 2022-04-25 10:15:21.999
HD Request # 41 | Daily data download complete for YM-200206-ECBOT. Unique request ID: 14 | 2022-04-25 10:15:21.999
Removing historical data download ID 14. | 2022-04-25 10:15:21.999
Triggering next historical data download in queue. | 2022-04-25 10:15:21.999
Mapping YM-202206-ECBOT to YMM22. Service code: cbot | 2022-04-25 10:15:21.999
HD Request # 43 | Downloading Historical Daily chart data for YM-202206-ECBOT. Starting date: 2022-04-20. Service: interactive_brokers.trading | 2022-04-25 10:15:22.001
HD Request # 42 | Decompressing data. | 2022-04-25 10:15:22.090
HD Request # 42 | Receiving Intraday data for AMX-NQTV starting at 2022-04-25 10:12:53.642000 | 2022-04-25 10:15:22.091
Socket (3) | CloseSocket call. | 2022-04-25 10:15:22.091
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:22.091
Historical data download thread signaled to stop. | 2022-04-25 10:15:22.091
HD Request # 42 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:13.391000 | 2022-04-25 10:15:22.091
HD Request # 42 | Received 9 Intraday data records from 2022-04-25 10:12:53.642000 to 2022-04-25 10:15:02.801000 (2.2 minutes) and wrote 7 records for AMX-NQTV | 2022-04-25 10:15:22.091
HD Request # 42 | Completion time: 1s | 2022-04-25 10:15:22.091
HD Request # 42 | Intraday data download complete for AMX-NQTV. Unique request ID: 131 | 2022-04-25 10:15:22.091
Removing historical data download ID 131. | 2022-04-25 10:15:22.091
Real-time Intraday chart data file updates started for AMX-NQTV | 2022-04-25 10:15:22.091
Intraday chart data file opened for AMX-NQTV | 2022-04-25 10:15:22.091
HD Request # 42 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:22.091
Triggering next historical data download in queue. | 2022-04-25 10:15:22.091
HD Request # 44 | Downloading Intraday chart data for ACRS-NQTV to the file ACRS-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:22.091
HD Request # 44 | Download start date-time: 2022-04-25 10:12:27.000000. File last date-time: 2022-04-25 10:12:27.407000 | 2022-04-25 10:15:22.092
HD Request # 44 | Using server: ds25.sierracharts.com port 10150 | 2022-04-25 10:15:22.092
Socket (11) | Creating socket. | 2022-04-25 10:15:22.092
Socket (11) | New receive buffer size: 5242880 | 2022-04-25 10:15:22.092
Socket (11) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:22.092
Socket (3) | Socket gracefully closed by remote side. | 2022-04-25 10:15:22.315
Socket (3) | Closed. | 2022-04-25 10:15:22.315
HD Request # 44 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:22.549
HD Request # 44 | Sending historical data logon request message. | 2022-04-25 10:15:22.549
HD Request # 44 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:27. Record interval: 0. Symbol: ACRS-NQTV | 2022-04-25 10:15:22.774
HD Request # 44 | Decompressing data. | 2022-04-25 10:15:23.004
HD Request # 44 | Receiving Intraday data for ACRS-NQTV starting at 2022-04-25 10:12:27.407000 | 2022-04-25 10:15:23.004
Socket (11) | CloseSocket call. | 2022-04-25 10:15:23.004
Socket (11) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:23.004
Historical data download thread signaled to stop. | 2022-04-25 10:15:23.004
HD Request # 44 | Timestamp of first Intraday data file record written: 2022-04-25 10:14:53.295000 | 2022-04-25 10:15:23.004
HD Request # 44 | Received 2 Intraday data records from 2022-04-25 10:12:27.407000 to 2022-04-25 10:14:53.295000 (2.4 minutes) and wrote 1 record for ACRS-NQTV | 2022-04-25 10:15:23.004
HD Request # 44 | Completion time: 1s | 2022-04-25 10:15:23.005
HD Request # 44 | Intraday data download complete for ACRS-NQTV. Unique request ID: 134 | 2022-04-25 10:15:23.005
Removing historical data download ID 134. | 2022-04-25 10:15:23.005
Real-time Intraday chart data file updates started for ACRS-NQTV | 2022-04-25 10:15:23.005
Intraday chart data file opened for ACRS-NQTV | 2022-04-25 10:15:23.005
HD Request # 44 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:23.005
Triggering next historical data download in queue. | 2022-04-25 10:15:23.005
HD Request # 45 | Downloading Intraday chart data for AA-NQTV to the file AA-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:23.005
HD Request # 45 | Download start date-time: 2022-04-25 10:12:50.000000. File last date-time: 2022-04-25 10:12:50.329002 | 2022-04-25 10:15:23.005
HD Request # 45 | Using server: ds25.sierracharts.com port 10149 | 2022-04-25 10:15:23.005
Socket (2) | Creating socket. | 2022-04-25 10:15:23.005
Socket (2) | New receive buffer size: 5242880 | 2022-04-25 10:15:23.005
Socket (2) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:23.005
Socket (11) | Socket gracefully closed by remote side. | 2022-04-25 10:15:23.228
Socket (11) | Closed. | 2022-04-25 10:15:23.228
HD Request # 43 | Requesting historical Daily data for YMM22 starting at 2022-04-19. SC External HD service. | 2022-04-25 10:15:23.424
HD Request # 45 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:23.469
HD Request # 45 | Sending historical data logon request message. | 2022-04-25 10:15:23.469
HD Request # 45 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:50. Record interval: 0. Symbol: AA-NQTV | 2022-04-25 10:15:23.700
Opened cached Intraday file: C:\SierraChart\Data\GBP-202206-GLOBEX.scid. Thread ID: 19936 | 2022-04-25 10:15:23.753
HD Request # 45 | Decompressing data. | 2022-04-25 10:15:23.929
HD Request # 45 | Receiving Intraday data for AA-NQTV starting at 2022-04-25 10:12:50.312000 | 2022-04-25 10:15:23.929
Socket (2) | CloseSocket call. | 2022-04-25 10:15:23.930
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:23.930
Historical data download thread signaled to stop. | 2022-04-25 10:15:23.930
HD Request # 45 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:13.432000 | 2022-04-25 10:15:23.930
HD Request # 45 | Received 100 Intraday data records from 2022-04-25 10:12:50.312000 to 2022-04-25 10:15:12.828002 (2.4 minutes) and wrote 94 records for AA-NQTV | 2022-04-25 10:15:23.930
HD Request # 45 | Completion time: 0s | 2022-04-25 10:15:23.930
HD Request # 45 | Intraday data download complete for AA-NQTV. Unique request ID: 136 | 2022-04-25 10:15:23.930
Removing historical data download ID 136. | 2022-04-25 10:15:23.930
Real-time Intraday chart data file updates started for AA-NQTV | 2022-04-25 10:15:23.930
Intraday chart data file opened for AA-NQTV | 2022-04-25 10:15:23.930
HD Request # 45 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:23.930
Triggering next historical data download in queue. | 2022-04-25 10:15:23.930
HD Request # 46 | Downloading Intraday chart data for BJ-NQTV to the file BJ-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:23.930
HD Request # 46 | Download start date-time: 2022-04-25 10:13:02.000000. File last date-time: 2022-04-25 10:13:02.128001 | 2022-04-25 10:15:23.930
HD Request # 46 | Using server: ds25.sierracharts.com port 10150 | 2022-04-25 10:15:23.930
Socket (11) | Creating socket. | 2022-04-25 10:15:23.930
Socket (11) | New receive buffer size: 5242880 | 2022-04-25 10:15:23.930
Socket (11) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:23.930
Socket (2) | Socket gracefully closed by remote side. | 2022-04-25 10:15:24.154
Socket (2) | Closed. | 2022-04-25 10:15:24.154
HD Request # 43 | Receiving historical Daily data for YM-202206-ECBOT starting at 2022-04-20 | 2022-04-25 10:15:24.240
HD Request # 43 | Writing historical Daily data to the file YM-202206-ECBOT.dly | 2022-04-25 10:15:24.240
HD Request # 43 | Bytes received: 216 | 2022-04-25 10:15:24.242
HD Request # 43 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for YM-202206-ECBOT | 2022-04-25 10:15:24.242
HD Request # 43 | Completion time: 3s | 2022-04-25 10:15:24.242
HD Request # 43 | Daily data download complete for YM-202206-ECBOT. Unique request ID: 15 | 2022-04-25 10:15:24.242
Removing historical data download ID 15. | 2022-04-25 10:15:24.242
Triggering next historical data download in queue. | 2022-04-25 10:15:24.242
Mapping NQ-199909-GLOBEX to NQU99. Service code: cme | 2022-04-25 10:15:24.242
HD Request # 47 | Downloading Historical Daily chart data for NQ-199909-GLOBEX. Starting date: 1999-06-09. Service: interactive_brokers.trading | 2022-04-25 10:15:24.242
YM-202206-ECBOT [C] Daily #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:15:24.343
YM-202206-ECBOT [C] Daily #3 | Reloading chart. | 2022-04-25 10:15:24.344
YM-202206-ECBOT [C] Daily #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:15:24.355
YM-202206-ECBOT [C] Daily #2 | Reloading chart. | 2022-04-25 10:15:24.356
YM-202206-ECBOT [C] 2 Day #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:15:24.370
YM-202206-ECBOT [C] 2 Day #10 | Reloading chart. | 2022-04-25 10:15:24.371
HD Request # 46 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:24.392
HD Request # 46 | Sending historical data logon request message. | 2022-04-25 10:15:24.392
YM-202206-ECBOT [C] 2 Day #10 | Reloading chart. | 2022-04-25 10:15:24.621
HD Request # 46 | Requesting Intraday data. Start date-time: 2022-04-25 10:13:02. Record interval: 0. Symbol: BJ-NQTV | 2022-04-25 10:15:25.090
HD Request # 46 | Decompressing data. | 2022-04-25 10:15:25.315
HD Request # 46 | Receiving Intraday data for BJ-NQTV starting at 2022-04-25 10:13:02.128000 | 2022-04-25 10:15:25.316
Socket (11) | CloseSocket call. | 2022-04-25 10:15:25.316
Socket (11) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:25.316
Socket (11) | Socket gracefully closed by remote side. | 2022-04-25 10:15:25.543
Socket (11) | Closed. | 2022-04-25 10:15:25.543
YM-202206-ECBOT [C] 2 Day #10 | File YM-200212-ECBOT.dly has a volume of 0 at 2002-09-12. | 2022-04-25 10:15:25.818
YM-202206-ECBOT [C] 2 Day #10 | File YM-200209-ECBOT.dly has a volume of 0 at 2002-06-13. | 2022-04-25 10:15:25.831
YM-202206-ECBOT [C] 2 Day #10 | Dates not found while checking for invalid data in continuous contract data files. YM-200206-ECBOT | 2022-04-25 10:15:25.842 *
Historical data download thread signaled to stop. | 2022-04-25 10:15:25.854
HD Request # 46 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:25.416000 | 2022-04-25 10:15:25.854
HD Request # 46 | Received 16 Intraday data records from 2022-04-25 10:13:02.128000 to 2022-04-25 10:15:16.932000 (2.2 minutes) and wrote 14 records for BJ-NQTV | 2022-04-25 10:15:25.854
HD Request # 46 | Completion time: 2s | 2022-04-25 10:15:25.854
HD Request # 46 | Intraday data download complete for BJ-NQTV. Unique request ID: 139 | 2022-04-25 10:15:25.854
Removing historical data download ID 139. | 2022-04-25 10:15:25.854
Real-time Intraday chart data file updates started for BJ-NQTV | 2022-04-25 10:15:25.854
Intraday chart data file opened for BJ-NQTV | 2022-04-25 10:15:25.854
HD Request # 46 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:25.854
Triggering next historical data download in queue. | 2022-04-25 10:15:25.854
HD Request # 47 | Requesting historical Daily data for NQU99 starting at 1999-06-08. SC External HD service. | 2022-04-25 10:15:25.854
HD Request # 48 | Downloading Intraday chart data for CLH-NQTV to the file CLH-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:25.854
HD Request # 48 | Download start date-time: 2022-04-25 10:12:45.000000. File last date-time: 2022-04-25 10:12:45.137000 | 2022-04-25 10:15:25.854
HD Request # 48 | Using server: ds25.sierracharts.com port 10149 | 2022-04-25 10:15:25.854
Socket (4) | Creating socket. | 2022-04-25 10:15:25.855
Socket (4) | New receive buffer size: 5242880 | 2022-04-25 10:15:25.855
Socket (4) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:25.855
YM-202206-ECBOT [C] Daily #2 | Reloading chart. | 2022-04-25 10:15:26.125
HD Request # 48 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:26.315
HD Request # 48 | Sending historical data logon request message. | 2022-04-25 10:15:26.315
HD Request # 48 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:45. Record interval: 0. Symbol: CLH-NQTV | 2022-04-25 10:15:26.546
HD Request # 48 | Decompressing data. | 2022-04-25 10:15:26.772
HD Request # 48 | Receiving Intraday data for CLH-NQTV starting at 2022-04-25 10:12:45.137000 | 2022-04-25 10:15:26.772
Socket (4) | CloseSocket call. | 2022-04-25 10:15:26.773
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:26.773
Socket (4) | Socket gracefully closed by remote side. | 2022-04-25 10:15:26.998
Socket (4) | Closed. | 2022-04-25 10:15:26.998
YM-202206-ECBOT [C] Daily #2 | File YM-200212-ECBOT.dly has a volume of 0 at 2002-09-12. | 2022-04-25 10:15:27.317
YM-202206-ECBOT [C] Daily #2 | File YM-200209-ECBOT.dly has a volume of 0 at 2002-06-13. | 2022-04-25 10:15:27.330
YM-202206-ECBOT [C] Daily #2 | Dates not found while checking for invalid data in continuous contract data files. YM-200206-ECBOT | 2022-04-25 10:15:27.341 *
HD Request # 47 | Receiving historical Daily data for NQ-199909-GLOBEX starting at 1999-06-21 | 2022-04-25 10:15:27.353
HD Request # 47 | Writing historical Daily data to the file NQ-199909-GLOBEX.dly | 2022-04-25 10:15:27.353
HD Request # 47 | Bytes received: 2722 | 2022-04-25 10:15:27.353
HD Request # 47 | Received 62 Daily data records from 1999-06-21 00:00:00 to 1999-09-17 00:00:00 (89.0 days) and wrote 62 records for NQ-199909-GLOBEX | 2022-04-25 10:15:27.353
HD Request # 47 | Completion time: 3s | 2022-04-25 10:15:27.354
HD Request # 47 | Daily data download complete for NQ-199909-GLOBEX. Unique request ID: 16 | 2022-04-25 10:15:27.354
Removing historical data download ID 16. | 2022-04-25 10:15:27.354
Triggering next historical data download in queue. | 2022-04-25 10:15:27.354
Historical data download thread signaled to stop. | 2022-04-25 10:15:27.354
HD Request # 48 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:46.406000 | 2022-04-25 10:15:27.354
HD Request # 48 | Received 9 Intraday data records from 2022-04-25 10:12:45.137000 to 2022-04-25 10:15:14.635003 (2.5 minutes) and wrote 8 records for CLH-NQTV | 2022-04-25 10:15:27.354
HD Request # 48 | Completion time: 2s | 2022-04-25 10:15:27.354
HD Request # 48 | Intraday data download complete for CLH-NQTV. Unique request ID: 142 | 2022-04-25 10:15:27.354
Removing historical data download ID 142. | 2022-04-25 10:15:27.354
Real-time Intraday chart data file updates started for CLH-NQTV | 2022-04-25 10:15:27.354
Intraday chart data file opened for CLH-NQTV | 2022-04-25 10:15:27.354
HD Request # 48 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:27.354
Mapping NQ-202206-GLOBEX to NQM22. Service code: cme | 2022-04-25 10:15:27.354
HD Request # 49 | Downloading Historical Daily chart data for NQ-202206-GLOBEX. Starting date: 2022-04-20. Service: interactive_brokers.trading | 2022-04-25 10:15:27.356
HD Request # 50 | Downloading Intraday chart data for CUBE-NQTV to the file CUBE-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:27.356
HD Request # 50 | Download start date-time: 2022-04-25 10:12:44.000000. File last date-time: 2022-04-25 10:12:44.755001 | 2022-04-25 10:15:27.356
HD Request # 50 | Using server: ds25.sierracharts.com port 10150 | 2022-04-25 10:15:27.356
Socket (11) | Creating socket. | 2022-04-25 10:15:27.356
Socket (11) | New receive buffer size: 5242880 | 2022-04-25 10:15:27.356
Socket (11) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:27.356
YM-202206-ECBOT [C] Daily #3 | Reloading chart. | 2022-04-25 10:15:27.358
HD Request # 50 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:27.814
HD Request # 50 | Sending historical data logon request message. | 2022-04-25 10:15:27.814
HD Request # 50 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:44. Record interval: 0. Symbol: CUBE-NQTV | 2022-04-25 10:15:28.039
HD Request # 50 | Decompressing data. | 2022-04-25 10:15:28.264
HD Request # 50 | Receiving Intraday data for CUBE-NQTV starting at 2022-04-25 10:12:44.755000 | 2022-04-25 10:15:28.264
Socket (11) | CloseSocket call. | 2022-04-25 10:15:28.264
Socket (11) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:28.264
Socket (11) | Socket gracefully closed by remote side. | 2022-04-25 10:15:28.490
Socket (11) | Closed. | 2022-04-25 10:15:28.490
YM-202206-ECBOT [C] Daily #3 | File YM-200212-ECBOT.dly has a volume of 0 at 2002-09-12. | 2022-04-25 10:15:28.586
YM-202206-ECBOT [C] Daily #3 | File YM-200209-ECBOT.dly has a volume of 0 at 2002-06-13. | 2022-04-25 10:15:28.600
YM-202206-ECBOT [C] Daily #3 | Dates not found while checking for invalid data in continuous contract data files. YM-200206-ECBOT | 2022-04-25 10:15:28.611 *
Historical data download thread signaled to stop. | 2022-04-25 10:15:28.629
HD Request # 50 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:35.852000 | 2022-04-25 10:15:28.630
HD Request # 50 | Received 9 Intraday data records from 2022-04-25 10:12:44.755000 to 2022-04-25 10:15:02.517002 (2.3 minutes) and wrote 7 records for CUBE-NQTV | 2022-04-25 10:15:28.630
HD Request # 50 | Completion time: 1s | 2022-04-25 10:15:28.630
HD Request # 50 | Intraday data download complete for CUBE-NQTV. Unique request ID: 143 | 2022-04-25 10:15:28.630
Removing historical data download ID 143. | 2022-04-25 10:15:28.630
Real-time Intraday chart data file updates started for CUBE-NQTV | 2022-04-25 10:15:28.630
Intraday chart data file opened for CUBE-NQTV | 2022-04-25 10:15:28.630
HD Request # 50 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:28.630
Triggering next historical data download in queue. | 2022-04-25 10:15:28.630
HD Request # 51 | Downloading Intraday chart data for COST-NQTV to the file COST-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:28.630
HD Request # 51 | Download start date-time: 2022-04-25 10:13:02.000000. File last date-time: 2022-04-25 10:13:02.207000 | 2022-04-25 10:15:28.630
HD Request # 51 | Using server: ds25.sierracharts.com port 10149 | 2022-04-25 10:15:28.630
Socket (11) | Creating socket. | 2022-04-25 10:15:28.630
Socket (11) | New receive buffer size: 5242880 | 2022-04-25 10:15:28.630
Socket (11) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:28.630
Opened cached Intraday file: C:\SierraChart\Data\AA-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:15:28.783
Opened cached Intraday file: C:\SierraChart\Data\BJ-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:15:28.783
SC Data - All Services | Starting real-time market data updates for: YM-202206-ECBOT (YMM22). ID: 104 Service code: cbot | 2022-04-25 10:15:28.905
SC Data - All Services | Requesting security definition data for: YM-202206-ECBOT (YMM22). ID: 104 | 2022-04-25 10:15:28.905
HD Request # 51 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:29.089
HD Request # 51 | Sending historical data logon request message. | 2022-04-25 10:15:29.089
SC Data - All Services | Received security definition for symbol YM-202206-ECBOT | 2022-04-25 10:15:29.246
HD Request # 51 | Requesting Intraday data. Start date-time: 2022-04-25 10:13:02. Record interval: 0. Symbol: COST-NQTV | 2022-04-25 10:15:29.316
HD Request # 51 | Decompressing data. | 2022-04-25 10:15:29.543
HD Request # 51 | Receiving Intraday data for COST-NQTV starting at 2022-04-25 10:13:02.207000 | 2022-04-25 10:15:29.544
Socket (11) | CloseSocket call. | 2022-04-25 10:15:29.544
Socket (11) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:29.544
Historical data download thread signaled to stop. | 2022-04-25 10:15:29.544
HD Request # 51 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:25.978000 | 2022-04-25 10:15:29.544
HD Request # 51 | Received 155 Intraday data records from 2022-04-25 10:13:02.207000 to 2022-04-25 10:15:23.549000 (2.4 minutes) and wrote 154 records for COST-NQTV | 2022-04-25 10:15:29.545
HD Request # 51 | Completion time: 1s | 2022-04-25 10:15:29.545
HD Request # 51 | Intraday data download complete for COST-NQTV. Unique request ID: 145 | 2022-04-25 10:15:29.545
Removing historical data download ID 145. | 2022-04-25 10:15:29.545
Real-time Intraday chart data file updates started for COST-NQTV | 2022-04-25 10:15:29.545
Intraday chart data file opened for COST-NQTV | 2022-04-25 10:15:29.545
HD Request # 51 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:29.545
Triggering next historical data download in queue. | 2022-04-25 10:15:29.545
HD Request # 52 | Downloading Intraday chart data for CALM-NQTV to the file CALM-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:29.545
HD Request # 52 | Download start date-time: 2022-04-25 10:12:57.000000. File last date-time: 2022-04-25 10:12:57.195001 | 2022-04-25 10:15:29.545
HD Request # 52 | Using server: ds25.sierracharts.com port 10150 | 2022-04-25 10:15:29.545
Socket (2) | Creating socket. | 2022-04-25 10:15:29.545
Socket (2) | New receive buffer size: 5242880 | 2022-04-25 10:15:29.545
Socket (2) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:29.545
HD Request # 49 | Requesting historical Daily data for NQM22 starting at 2022-04-19. SC External HD service. | 2022-04-25 10:15:29.712
Socket (11) | Socket gracefully closed by remote side. | 2022-04-25 10:15:29.769
Socket (11) | Closed. | 2022-04-25 10:15:29.769
HD Request # 52 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:30.004
HD Request # 52 | Sending historical data logon request message. | 2022-04-25 10:15:30.004
HD Request # 52 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:57. Record interval: 0. Symbol: CALM-NQTV | 2022-04-25 10:15:30.235
HD Request # 52 | Decompressing data. | 2022-04-25 10:15:30.461
HD Request # 52 | Receiving Intraday data for CALM-NQTV starting at 2022-04-25 10:12:57.195000 | 2022-04-25 10:15:30.461
Socket (2) | CloseSocket call. | 2022-04-25 10:15:30.461
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:30.461
Historical data download thread signaled to stop. | 2022-04-25 10:15:30.465
HD Request # 52 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:04.667000 | 2022-04-25 10:15:30.465
HD Request # 52 | Received 9 Intraday data records from 2022-04-25 10:12:57.195000 to 2022-04-25 10:15:16.520000 (2.3 minutes) and wrote 7 records for CALM-NQTV | 2022-04-25 10:15:30.465
HD Request # 52 | Completion time: 1s | 2022-04-25 10:15:30.465
HD Request # 52 | Intraday data download complete for CALM-NQTV. Unique request ID: 147 | 2022-04-25 10:15:30.465
Removing historical data download ID 147. | 2022-04-25 10:15:30.465
Real-time Intraday chart data file updates started for CALM-NQTV | 2022-04-25 10:15:30.465
Intraday chart data file opened for CALM-NQTV | 2022-04-25 10:15:30.465
HD Request # 52 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:30.465
Triggering next historical data download in queue. | 2022-04-25 10:15:30.465
HD Request # 53 | Downloading Intraday chart data for EVH-NQTV to the file EVH-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:30.465
HD Request # 53 | Download start date-time: 2022-04-25 10:12:45.000000. File last date-time: 2022-04-25 10:12:45.516009 | 2022-04-25 10:15:30.466
HD Request # 53 | Using server: ds25.sierracharts.com port 10149 | 2022-04-25 10:15:30.466
Socket (11) | Creating socket. | 2022-04-25 10:15:30.466
Socket (11) | New receive buffer size: 5242880 | 2022-04-25 10:15:30.466
Socket (11) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:30.466
HD Request # 49 | Receiving historical Daily data for NQ-202206-GLOBEX starting at 2022-04-20 | 2022-04-25 10:15:30.615
HD Request # 49 | Writing historical Daily data to the file NQ-202206-GLOBEX.dly | 2022-04-25 10:15:30.615
HD Request # 49 | Bytes received: 241 | 2022-04-25 10:15:30.618
HD Request # 49 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for NQ-202206-GLOBEX | 2022-04-25 10:15:30.618
HD Request # 49 | Completion time: 3s | 2022-04-25 10:15:30.618
HD Request # 49 | Daily data download complete for NQ-202206-GLOBEX. Unique request ID: 17 | 2022-04-25 10:15:30.618
Removing historical data download ID 17. | 2022-04-25 10:15:30.618
Triggering next historical data download in queue. | 2022-04-25 10:15:30.618
Mapping ZN-198206-ECBOT to ZNM82. Service code: cbot | 2022-04-25 10:15:30.618
HD Request # 54 | Downloading Historical Daily chart data for ZN-198206-ECBOT. Starting date: 1982-02-25. Service: interactive_brokers.trading | 2022-04-25 10:15:30.618
NQ-202206-GLOBEX [C] Daily #11 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:15:30.627
NQ-202206-GLOBEX [C] Daily #11 | Reloading chart. | 2022-04-25 10:15:30.628
NQ-202206-GLOBEX [C] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:15:30.647
NQ-202206-GLOBEX [C] Daily #6 | Reloading chart. | 2022-04-25 10:15:30.648
NQ-202206-GLOBEX [C] 4 Day #14 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:15:30.671
NQ-202206-GLOBEX [C] 4 Day #14 | Reloading chart. | 2022-04-25 10:15:30.673
Socket (2) | Socket gracefully closed by remote side. | 2022-04-25 10:15:30.686
Socket (2) | Closed. | 2022-04-25 10:15:30.686
NQ-202206-GLOBEX [C] Daily #11 | Reloading chart. | 2022-04-25 10:15:30.886
NQ-202206-GLOBEX [C] Daily #11 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:30.886
NQ-202206-GLOBEX [C] Daily #11 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:30.887
HD Request # 53 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:30.920
HD Request # 53 | Sending historical data logon request message. | 2022-04-25 10:15:30.920
HD Request # 53 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:45. Record interval: 0. Symbol: EVH-NQTV | 2022-04-25 10:15:31.145
HD Request # 53 | Decompressing data. | 2022-04-25 10:15:31.372
HD Request # 53 | Receiving Intraday data for EVH-NQTV starting at 2022-04-25 10:12:45.516000 | 2022-04-25 10:15:31.372
Socket (11) | CloseSocket call. | 2022-04-25 10:15:31.373
Socket (11) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:31.373
Socket (11) | Socket gracefully closed by remote side. | 2022-04-25 10:15:31.599
Socket (11) | Closed. | 2022-04-25 10:15:31.599
NQ-202206-GLOBEX [C] Daily #11 | File NQ-200103-GLOBEX.dly has a volume of 0 at 2000-12-08. | 2022-04-25 10:15:32.183
NQ-202206-GLOBEX [C] Daily #11 | File NQ-200012-GLOBEX.dly has a volume of 0 at 2000-09-08. | 2022-04-25 10:15:32.196
NQ-202206-GLOBEX [C] Daily #11 | File NQ-200012-GLOBEX.dly has a volume of 0 at 2000-12-07. | 2022-04-25 10:15:32.196
NQ-202206-GLOBEX [C] Daily #11 | File NQ-200009-GLOBEX.dly has a volume of 0 at 2000-06-08. | 2022-04-25 10:15:32.209
NQ-202206-GLOBEX [C] Daily #11 | File NQ-200009-GLOBEX.dly has a volume of 0 at 2000-09-07. | 2022-04-25 10:15:32.209
NQ-202206-GLOBEX [C] Daily #11 | File NQ-200006-GLOBEX.dly has a volume of 0 at 2000-03-09. | 2022-04-25 10:15:32.222
NQ-202206-GLOBEX [C] Daily #11 | File NQ-200006-GLOBEX.dly has a volume of 0 at 2000-06-07. | 2022-04-25 10:15:32.222
NQ-202206-GLOBEX [C] Daily #11 | File NQ-200003-GLOBEX.dly has a volume of 0 at 1999-12-09. | 2022-04-25 10:15:32.235
NQ-202206-GLOBEX [C] Daily #11 | File NQ-200003-GLOBEX.dly has a volume of 0 at 2000-03-08. | 2022-04-25 10:15:32.235
NQ-202206-GLOBEX [C] Daily #11 | File NQ-199912-GLOBEX.dly has a volume of 0 at 1999-09-09. | 2022-04-25 10:15:32.248
NQ-202206-GLOBEX [C] Daily #11 | File NQ-199912-GLOBEX.dly has a volume of 0 at 1999-12-08. | 2022-04-25 10:15:32.248
NQ-202206-GLOBEX [C] Daily #11 | Dates not found while checking for invalid data in continuous contract data files. NQ-199909-GLOBEX | 2022-04-25 10:15:32.259 *
Restarting the loading process. | 2022-04-25 10:15:32.259
Historical data download thread signaled to stop. | 2022-04-25 10:15:32.274
HD Request # 53 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:24.677000 | 2022-04-25 10:15:32.274
HD Request # 53 | Received 19 Intraday data records from 2022-04-25 10:12:45.516000 to 2022-04-25 10:14:03.319000 (77.8 seconds) and wrote 9 records for EVH-NQTV | 2022-04-25 10:15:32.274
HD Request # 53 | Completion time: 2s | 2022-04-25 10:15:32.274
HD Request # 53 | Intraday data download complete for EVH-NQTV. Unique request ID: 153 | 2022-04-25 10:15:32.274
Removing historical data download ID 153. | 2022-04-25 10:15:32.274
Real-time Intraday chart data file updates started for EVH-NQTV | 2022-04-25 10:15:32.274
Intraday chart data file opened for EVH-NQTV | 2022-04-25 10:15:32.274
HD Request # 53 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:32.274
Triggering next historical data download in queue. | 2022-04-25 10:15:32.274
HD Request # 55 | Downloading Intraday chart data for EXR-NQTV to the file EXR-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:32.274
HD Request # 55 | Download start date-time: 2022-04-25 10:12:47.000000. File last date-time: 2022-04-25 10:12:47.492001 | 2022-04-25 10:15:32.275
HD Request # 55 | Using server: ds25.sierracharts.com port 10150 | 2022-04-25 10:15:32.275
Socket (2) | Creating socket. | 2022-04-25 10:15:32.275
Socket (2) | New receive buffer size: 5242880 | 2022-04-25 10:15:32.275
Socket (2) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:32.275
NQ-202206-GLOBEX [C] Daily #6 | Reloading chart. | 2022-04-25 10:15:32.276
NQ-202206-GLOBEX [C] Daily #6 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:32.276
NQ-202206-GLOBEX [C] Daily #6 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:32.276
HD Request # 55 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:32.732
HD Request # 55 | Sending historical data logon request message. | 2022-04-25 10:15:32.732
HD Request # 55 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:47. Record interval: 0. Symbol: EXR-NQTV | 2022-04-25 10:15:32.959
HD Request # 55 | Decompressing data. | 2022-04-25 10:15:33.187
HD Request # 55 | Receiving Intraday data for EXR-NQTV starting at 2022-04-25 10:12:47.491000 | 2022-04-25 10:15:33.189
Socket (2) | CloseSocket call. | 2022-04-25 10:15:33.189
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:33.189
Socket (2) | Socket gracefully closed by remote side. | 2022-04-25 10:15:33.414
Socket (2) | Closed. | 2022-04-25 10:15:33.414
NQ-202206-GLOBEX [C] Daily #6 | File NQ-200103-GLOBEX.dly has a volume of 0 at 2000-12-08. | 2022-04-25 10:15:33.627
NQ-202206-GLOBEX [C] Daily #6 | File NQ-200012-GLOBEX.dly has a volume of 0 at 2000-09-08. | 2022-04-25 10:15:33.640
NQ-202206-GLOBEX [C] Daily #6 | File NQ-200012-GLOBEX.dly has a volume of 0 at 2000-12-07. | 2022-04-25 10:15:33.640
NQ-202206-GLOBEX [C] Daily #6 | File NQ-200009-GLOBEX.dly has a volume of 0 at 2000-06-08. | 2022-04-25 10:15:33.653
NQ-202206-GLOBEX [C] Daily #6 | File NQ-200009-GLOBEX.dly has a volume of 0 at 2000-09-07. | 2022-04-25 10:15:33.653
NQ-202206-GLOBEX [C] Daily #6 | File NQ-200006-GLOBEX.dly has a volume of 0 at 2000-03-09. | 2022-04-25 10:15:33.666
NQ-202206-GLOBEX [C] Daily #6 | File NQ-200006-GLOBEX.dly has a volume of 0 at 2000-06-07. | 2022-04-25 10:15:33.666
NQ-202206-GLOBEX [C] Daily #6 | File NQ-200003-GLOBEX.dly has a volume of 0 at 1999-12-09. | 2022-04-25 10:15:33.678
NQ-202206-GLOBEX [C] Daily #6 | File NQ-200003-GLOBEX.dly has a volume of 0 at 2000-03-08. | 2022-04-25 10:15:33.678
NQ-202206-GLOBEX [C] Daily #6 | File NQ-199912-GLOBEX.dly has a volume of 0 at 1999-09-09. | 2022-04-25 10:15:33.691
NQ-202206-GLOBEX [C] Daily #6 | File NQ-199912-GLOBEX.dly has a volume of 0 at 1999-12-08. | 2022-04-25 10:15:33.691
NQ-202206-GLOBEX [C] Daily #6 | Dates not found while checking for invalid data in continuous contract data files. NQ-199909-GLOBEX | 2022-04-25 10:15:33.703 *
Historical data download thread signaled to stop. | 2022-04-25 10:15:33.729
HD Request # 55 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:07.412000 | 2022-04-25 10:15:33.730
HD Request # 55 | Received 17 Intraday data records from 2022-04-25 10:12:47.491000 to 2022-04-25 10:15:19.204000 (2.5 minutes) and wrote 14 records for EXR-NQTV | 2022-04-25 10:15:33.730
HD Request # 55 | Completion time: 1s | 2022-04-25 10:15:33.730
HD Request # 55 | Intraday data download complete for EXR-NQTV. Unique request ID: 155 | 2022-04-25 10:15:33.730
Removing historical data download ID 155. | 2022-04-25 10:15:33.730
Real-time Intraday chart data file updates started for EXR-NQTV | 2022-04-25 10:15:33.730
Intraday chart data file opened for EXR-NQTV | 2022-04-25 10:15:33.730
HD Request # 55 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:33.730
Triggering next historical data download in queue. | 2022-04-25 10:15:33.730
HD Request # 54 | Requesting historical Daily data for ZNM82 starting at 1982-02-24. SC External HD service. | 2022-04-25 10:15:33.730
HD Request # 56 | Downloading Intraday chart data for FWONK-NQTV to the file FWONK-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:33.730
HD Request # 56 | Download start date-time: 2022-04-25 10:12:04.000000. File last date-time: 2022-04-25 10:12:04.410002 | 2022-04-25 10:15:33.730
HD Request # 56 | Using server: ds25.sierracharts.com port 10149 | 2022-04-25 10:15:33.730
Socket (3) | Creating socket. | 2022-04-25 10:15:33.731
Socket (3) | New receive buffer size: 5242880 | 2022-04-25 10:15:33.731
Socket (3) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:33.731
NQ-202206-GLOBEX [C] 4 Day #14 | Reloading chart. | 2022-04-25 10:15:33.772
NQ-202206-GLOBEX [C] 4 Day #14 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:33.772
NQ-202206-GLOBEX [C] 4 Day #14 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:33.772
Opened cached Intraday file: C:\SierraChart\Data\COST-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:15:33.807
HD Request # 56 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:34.190
HD Request # 56 | Sending historical data logon request message. | 2022-04-25 10:15:34.190
HD Request # 56 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:04. Record interval: 0. Symbol: FWONK-NQTV | 2022-04-25 10:15:34.416
HD Request # 56 | Decompressing data. | 2022-04-25 10:15:34.642
HD Request # 56 | Receiving Intraday data for FWONK-NQTV starting at 2022-04-25 10:12:04.410000 | 2022-04-25 10:15:34.642
Socket (3) | CloseSocket call. | 2022-04-25 10:15:34.643
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:34.643
Socket (3) | Socket gracefully closed by remote side. | 2022-04-25 10:15:34.872
Socket (3) | Closed. | 2022-04-25 10:15:34.872
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-200103-GLOBEX.dly has a volume of 0 at 2000-12-08. | 2022-04-25 10:15:35.119
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-200012-GLOBEX.dly has a volume of 0 at 2000-09-08. | 2022-04-25 10:15:35.132
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-200012-GLOBEX.dly has a volume of 0 at 2000-12-07. | 2022-04-25 10:15:35.132
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-200009-GLOBEX.dly has a volume of 0 at 2000-06-08. | 2022-04-25 10:15:35.145
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-200009-GLOBEX.dly has a volume of 0 at 2000-09-07. | 2022-04-25 10:15:35.145
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-200006-GLOBEX.dly has a volume of 0 at 2000-03-09. | 2022-04-25 10:15:35.158
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-200006-GLOBEX.dly has a volume of 0 at 2000-06-07. | 2022-04-25 10:15:35.158
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-200003-GLOBEX.dly has a volume of 0 at 1999-12-09. | 2022-04-25 10:15:35.171
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-200003-GLOBEX.dly has a volume of 0 at 2000-03-08. | 2022-04-25 10:15:35.171
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-199912-GLOBEX.dly has a volume of 0 at 1999-09-09. | 2022-04-25 10:15:35.184
NQ-202206-GLOBEX [C] 4 Day #14 | File NQ-199912-GLOBEX.dly has a volume of 0 at 1999-12-08. | 2022-04-25 10:15:35.184
NQ-202206-GLOBEX [C] 4 Day #14 | Dates not found while checking for invalid data in continuous contract data files. NQ-199909-GLOBEX | 2022-04-25 10:15:35.196 *
Historical data download thread signaled to stop. | 2022-04-25 10:15:35.222
HD Request # 56 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:17.169000 | 2022-04-25 10:15:35.223
HD Request # 56 | Received 11 Intraday data records from 2022-04-25 10:12:04.410000 to 2022-04-25 10:15:21.208000 (3.3 minutes) and wrote 8 records for FWONK-NQTV | 2022-04-25 10:15:35.223
HD Request # 56 | Completion time: 2s | 2022-04-25 10:15:35.223
HD Request # 56 | Intraday data download complete for FWONK-NQTV. Unique request ID: 156 | 2022-04-25 10:15:35.223
Removing historical data download ID 156. | 2022-04-25 10:15:35.223
Real-time Intraday chart data file updates started for FWONK-NQTV | 2022-04-25 10:15:35.223
Intraday chart data file opened for FWONK-NQTV | 2022-04-25 10:15:35.223
HD Request # 56 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:35.223
Triggering next historical data download in queue. | 2022-04-25 10:15:35.223
HD Request # 57 | Downloading Intraday chart data for FR-NQTV to the file FR-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:35.223
HD Request # 57 | Download start date-time: 2022-04-25 10:12:53.000000. File last date-time: 2022-04-25 10:12:53.668001 | 2022-04-25 10:15:35.223
HD Request # 57 | Using server: ds25.sierracharts.com port 10150 | 2022-04-25 10:15:35.223
Socket (3) | Creating socket. | 2022-04-25 10:15:35.223
Socket (3) | New receive buffer size: 5242880 | 2022-04-25 10:15:35.223
Socket (3) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:35.223
HD Request # 57 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:35.679
HD Request # 57 | Sending historical data logon request message. | 2022-04-25 10:15:35.679
SC Data - All Services | Starting real-time market data updates for: NQ-202206-GLOBEX (NQM22). ID: 106 Service code: cme | 2022-04-25 10:15:35.775
SC Data - All Services | Requesting security definition data for: NQ-202206-GLOBEX (NQM22). ID: 106 | 2022-04-25 10:15:35.775
HD Request # 54 | Receiving historical Daily data for ZN-198206-ECBOT starting at 1982-05-03 | 2022-04-25 10:15:35.863
HD Request # 54 | Writing historical Daily data to the file ZN-198206-ECBOT.dly | 2022-04-25 10:15:35.863
HD Request # 54 | Bytes received: 1820 | 2022-04-25 10:15:35.864
HD Request # 54 | Received 35 Daily data records from 1982-05-03 00:00:00 to 1982-06-21 00:00:00 (50.0 days) and wrote 35 records for ZN-198206-ECBOT | 2022-04-25 10:15:35.864
HD Request # 54 | Completion time: 5s | 2022-04-25 10:15:35.864
HD Request # 54 | Daily data download complete for ZN-198206-ECBOT. Unique request ID: 18 | 2022-04-25 10:15:35.864
Removing historical data download ID 18. | 2022-04-25 10:15:35.864
Triggering next historical data download in queue. | 2022-04-25 10:15:35.864
HD Request # 58 | Downloading Historical Daily chart data for ZN-202206-ECBOT. Starting date: 2022-04-20. Service: interactive_brokers.trading | 2022-04-25 10:15:35.866
HD Request # 57 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:53. Record interval: 0. Symbol: FR-NQTV | 2022-04-25 10:15:35.905
SC Data - All Services | Received security definition for symbol NQ-202206-GLOBEX | 2022-04-25 10:15:35.976
HD Request # 57 | Decompressing data. | 2022-04-25 10:15:36.131
HD Request # 57 | Receiving Intraday data for FR-NQTV starting at 2022-04-25 10:12:53.668000 | 2022-04-25 10:15:36.131
Socket (3) | CloseSocket call. | 2022-04-25 10:15:36.131
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:36.131
Historical data download thread signaled to stop. | 2022-04-25 10:15:36.134
HD Request # 57 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:03.907000 | 2022-04-25 10:15:36.135
HD Request # 57 | Received 12 Intraday data records from 2022-04-25 10:12:53.668000 to 2022-04-25 10:14:02.647000 (69.0 seconds) and wrote 10 records for FR-NQTV | 2022-04-25 10:15:36.135
HD Request # 57 | Completion time: 1s | 2022-04-25 10:15:36.135
HD Request # 57 | Intraday data download complete for FR-NQTV. Unique request ID: 159 | 2022-04-25 10:15:36.135
Removing historical data download ID 159. | 2022-04-25 10:15:36.135
Real-time Intraday chart data file updates started for FR-NQTV | 2022-04-25 10:15:36.135
Intraday chart data file opened for FR-NQTV | 2022-04-25 10:15:36.135
HD Request # 57 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:36.135
Triggering next historical data download in queue. | 2022-04-25 10:15:36.135
HD Request # 59 | Downloading Intraday chart data for GCBC-NQTV to the file GCBC-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:36.135
HD Request # 59 | Download start date-time: 2022-04-25 10:04:06.000000. File last date-time: 2022-04-25 10:04:06.703000 | 2022-04-25 10:15:36.135
HD Request # 59 | Using server: ds25.sierracharts.com port 10149 | 2022-04-25 10:15:36.135
Socket (12) | Creating socket. | 2022-04-25 10:15:36.135
Socket (12) | New receive buffer size: 5242880 | 2022-04-25 10:15:36.135
Socket (12) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:36.135
Socket (3) | Socket gracefully closed by remote side. | 2022-04-25 10:15:36.360
Socket (3) | Closed. | 2022-04-25 10:15:36.360
HD Request # 59 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:36.595
HD Request # 59 | Sending historical data logon request message. | 2022-04-25 10:15:36.595
HD Request # 59 | Requesting Intraday data. Start date-time: 2022-04-25 10:04:06. Record interval: 0. Symbol: GCBC-NQTV | 2022-04-25 10:15:36.821
HD Request # 59 | Decompressing data. | 2022-04-25 10:15:37.049
HD Request # 59 | Receiving Intraday data for GCBC-NQTV starting at 2022-04-25 10:04:06.703000 | 2022-04-25 10:15:37.049
Socket (12) | CloseSocket call. | 2022-04-25 10:15:37.049
Historical data download thread signaled to stop. | 2022-04-25 10:15:37.049
HD Request # 59 | Received 1 Intraday data record from 2022-04-25 10:04:06.703000 to 2022-04-25 10:04:06.703000 (0.0 seconds) and wrote 0 records for GCBC-NQTV | 2022-04-25 10:15:37.049
HD Request # 59 | Completion time: 1s | 2022-04-25 10:15:37.049
HD Request # 59 | Intraday data download complete for GCBC-NQTV. Unique request ID: 160 | 2022-04-25 10:15:37.049
Removing historical data download ID 160. | 2022-04-25 10:15:37.049
Socket (12) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:37.049
Real-time Intraday chart data file updates started for GCBC-NQTV | 2022-04-25 10:15:37.049
Intraday chart data file opened for GCBC-NQTV | 2022-04-25 10:15:37.049
HD Request # 59 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:37.049
Triggering next historical data download in queue. | 2022-04-25 10:15:37.049
HD Request # 60 | Downloading Intraday chart data for GNK-NQTV to the file GNK-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:37.049
HD Request # 60 | Download start date-time: 2022-04-25 10:13:00.000000. File last date-time: 2022-04-25 10:13:00.215000 | 2022-04-25 10:15:37.049
HD Request # 60 | Using server: ds25.sierracharts.com port 10150 | 2022-04-25 10:15:37.049
Socket (2) | Creating socket. | 2022-04-25 10:15:37.049
Socket (2) | New receive buffer size: 5242880 | 2022-04-25 10:15:37.049
Socket (2) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:37.049
Socket (12) | Socket gracefully closed by remote side. | 2022-04-25 10:15:37.274
Socket (12) | Closed. | 2022-04-25 10:15:37.274
HD Request # 58 | Requesting historical Daily data for ZNM22 starting at 2022-04-19. SC External HD service. | 2022-04-25 10:15:37.277
HD Request # 60 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:37.510
HD Request # 60 | Sending historical data logon request message. | 2022-04-25 10:15:37.510
HD Request # 60 | Requesting Intraday data. Start date-time: 2022-04-25 10:13:00. Record interval: 0. Symbol: GNK-NQTV | 2022-04-25 10:15:37.737
HD Request # 60 | Decompressing data. | 2022-04-25 10:15:37.964
HD Request # 60 | Receiving Intraday data for GNK-NQTV starting at 2022-04-25 10:13:00.215000 | 2022-04-25 10:15:37.964
Socket (2) | CloseSocket call. | 2022-04-25 10:15:37.964
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:37.964
Historical data download thread signaled to stop. | 2022-04-25 10:15:37.964
HD Request # 60 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:06.674000 | 2022-04-25 10:15:37.964
HD Request # 60 | Received 39 Intraday data records from 2022-04-25 10:13:00.215000 to 2022-04-25 10:15:30.315000 (2.5 minutes) and wrote 38 records for GNK-NQTV | 2022-04-25 10:15:37.965
HD Request # 60 | Completion time: 0s | 2022-04-25 10:15:37.965
HD Request # 60 | Intraday data download complete for GNK-NQTV. Unique request ID: 163 | 2022-04-25 10:15:37.965
Removing historical data download ID 163. | 2022-04-25 10:15:37.965
Real-time Intraday chart data file updates started for GNK-NQTV | 2022-04-25 10:15:37.965
Intraday chart data file opened for GNK-NQTV | 2022-04-25 10:15:37.965
HD Request # 60 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:37.965
Triggering next historical data download in queue. | 2022-04-25 10:15:37.965
HD Request # 61 | Downloading Intraday chart data for HESM-NQTV to the file HESM-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:37.965
HD Request # 61 | Download start date-time: 2022-04-25 10:09:45.000000. File last date-time: 2022-04-25 10:09:45.643001 | 2022-04-25 10:15:37.965
HD Request # 61 | Using server: ds25.sierracharts.com port 10149 | 2022-04-25 10:15:37.965
Socket (11) | Creating socket. | 2022-04-25 10:15:37.965
Socket (11) | New receive buffer size: 5242880 | 2022-04-25 10:15:37.965
Socket (11) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:37.965
HD Request # 58 | Receiving historical Daily data for ZN-202206-ECBOT starting at 2022-04-20 | 2022-04-25 10:15:38.091
HD Request # 58 | Writing historical Daily data to the file ZN-202206-ECBOT.dly | 2022-04-25 10:15:38.091
HD Request # 58 | Bytes received: 287 | 2022-04-25 10:15:38.092
HD Request # 58 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for ZN-202206-ECBOT | 2022-04-25 10:15:38.092
HD Request # 58 | Completion time: 3s | 2022-04-25 10:15:38.092
HD Request # 58 | Daily data download complete for ZN-202206-ECBOT. Unique request ID: 19 | 2022-04-25 10:15:38.092
Removing historical data download ID 19. | 2022-04-25 10:15:38.092
Triggering next historical data download in queue. | 2022-04-25 10:15:38.092
Mapping GC-197502-NYMEX to GCG75. Service code: comex | 2022-04-25 10:15:38.092
HD Request # 62 | Downloading Historical Daily chart data for GC-197502-NYMEX. Starting date: 1974-11-27. Service: interactive_brokers.trading | 2022-04-25 10:15:38.093
Socket (2) | Socket gracefully closed by remote side. | 2022-04-25 10:15:38.189
Socket (2) | Closed. | 2022-04-25 10:15:38.189
ZN-202206-ECBOT [C] Daily #23 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:15:38.308
ZN-202206-ECBOT [C] Daily #23 | Reloading chart. | 2022-04-25 10:15:38.309
ZN-202206-ECBOT [C] 4 Day #19 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:15:38.328
ZN-202206-ECBOT [C] 4 Day #19 | Reloading chart. | 2022-04-25 10:15:38.329
HD Request # 61 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:38.438
HD Request # 61 | Sending historical data logon request message. | 2022-04-25 10:15:38.438
ZN-202206-ECBOT [C] Daily #23 | Reloading chart. | 2022-04-25 10:15:38.562
ZN-202206-ECBOT [C] Daily #23 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:38.562
ZN-202206-ECBOT [C] Daily #23 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:38.562
HD Request # 61 | Requesting Intraday data. Start date-time: 2022-04-25 10:09:45. Record interval: 0. Symbol: HESM-NQTV | 2022-04-25 10:15:38.664
Opened cached Intraday file: C:\SierraChart\Data\EVH-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:15:38.858
HD Request # 61 | Decompressing data. | 2022-04-25 10:15:38.891
HD Request # 61 | Receiving Intraday data for HESM-NQTV starting at 2022-04-25 10:09:45.643000 | 2022-04-25 10:15:38.891
Socket (11) | CloseSocket call. | 2022-04-25 10:15:38.891
Socket (11) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:38.891
Socket (11) | Socket gracefully closed by remote side. | 2022-04-25 10:15:39.116
Socket (11) | Closed. | 2022-04-25 10:15:39.116
ZN-202206-ECBOT [C] Daily #23 | File ZN-200103-ECBOT.dly has a volume of 0 at 2000-11-30. | 2022-04-25 10:15:40.021
ZN-202206-ECBOT [C] Daily #23 | File ZN-200012-ECBOT.dly has a volume of 0 at 2000-08-31. | 2022-04-25 10:15:40.033
ZN-202206-ECBOT [C] Daily #23 | File ZN-200012-ECBOT.dly has a volume of 0 at 2000-11-29. | 2022-04-25 10:15:40.033
ZN-202206-ECBOT [C] Daily #23 | File ZN-200009-ECBOT.dly has a volume of 0 at 2000-05-31. | 2022-04-25 10:15:40.046
ZN-202206-ECBOT [C] Daily #23 | File ZN-200009-ECBOT.dly has a volume of 0 at 2000-08-30. | 2022-04-25 10:15:40.046
ZN-202206-ECBOT [C] Daily #23 | File ZN-200006-ECBOT.dly has a volume of 0 at 2000-02-29. | 2022-04-25 10:15:40.059
ZN-202206-ECBOT [C] Daily #23 | File ZN-200006-ECBOT.dly has a volume of 0 at 2000-05-30. | 2022-04-25 10:15:40.059
ZN-202206-ECBOT [C] Daily #23 | File ZN-200003-ECBOT.dly has a volume of 0 at 1999-11-30. | 2022-04-25 10:15:40.072
ZN-202206-ECBOT [C] Daily #23 | File ZN-200003-ECBOT.dly has a volume of 0 at 2000-02-28. | 2022-04-25 10:15:40.072
ZN-202206-ECBOT [C] Daily #23 | File ZN-199912-ECBOT.dly has a volume of 0 at 1999-08-31. | 2022-04-25 10:15:40.085
ZN-202206-ECBOT [C] Daily #23 | File ZN-199912-ECBOT.dly has a volume of 0 at 1999-11-29. | 2022-04-25 10:15:40.085
ZN-202206-ECBOT [C] Daily #23 | File ZN-199909-ECBOT.dly has a volume of 0 at 1999-05-31. | 2022-04-25 10:15:40.098
ZN-202206-ECBOT [C] Daily #23 | File ZN-199909-ECBOT.dly has a volume of 0 at 1999-08-30. | 2022-04-25 10:15:40.098
ZN-202206-ECBOT [C] Daily #23 | File ZN-199906-ECBOT.dly has a volume of 0 at 1999-02-26. | 2022-04-25 10:15:40.112
ZN-202206-ECBOT [C] Daily #23 | File ZN-199906-ECBOT.dly has a volume of 0 at 1999-05-28. | 2022-04-25 10:15:40.112
ZN-202206-ECBOT [C] Daily #23 | File ZN-199903-ECBOT.dly has a volume of 0 at 1998-11-30. | 2022-04-25 10:15:40.125
ZN-202206-ECBOT [C] Daily #23 | File ZN-199903-ECBOT.dly has a volume of 0 at 1999-02-25. | 2022-04-25 10:15:40.125
ZN-202206-ECBOT [C] Daily #23 | File ZN-199812-ECBOT.dly has a volume of 0 at 1998-08-31. | 2022-04-25 10:15:40.137
ZN-202206-ECBOT [C] Daily #23 | File ZN-199812-ECBOT.dly has a volume of 0 at 1998-11-27. | 2022-04-25 10:15:40.137
ZN-202206-ECBOT [C] Daily #23 | File ZN-199809-ECBOT.dly has a volume of 0 at 1998-05-29. | 2022-04-25 10:15:40.150
ZN-202206-ECBOT [C] Daily #23 | File ZN-199809-ECBOT.dly has a volume of 0 at 1998-08-28. | 2022-04-25 10:15:40.150
ZN-202206-ECBOT [C] Daily #23 | File ZN-199806-ECBOT.dly has a volume of 0 at 1998-02-27. | 2022-04-25 10:15:40.163
ZN-202206-ECBOT [C] Daily #23 | File ZN-199806-ECBOT.dly has a volume of 0 at 1998-05-28. | 2022-04-25 10:15:40.163
ZN-202206-ECBOT [C] Daily #23 | File ZN-199803-ECBOT.dly has a volume of 0 at 1997-11-28. | 2022-04-25 10:15:40.176
ZN-202206-ECBOT [C] Daily #23 | File ZN-199803-ECBOT.dly has a volume of 0 at 1998-02-26. | 2022-04-25 10:15:40.176
ZN-202206-ECBOT [C] Daily #23 | File ZN-199712-ECBOT.dly has a volume of 0 at 1997-08-29. | 2022-04-25 10:15:40.189
ZN-202206-ECBOT [C] Daily #23 | File ZN-199712-ECBOT.dly has a volume of 0 at 1997-11-27. | 2022-04-25 10:15:40.189
ZN-202206-ECBOT [C] Daily #23 | File ZN-199709-ECBOT.dly has a volume of 0 at 1997-05-30. | 2022-04-25 10:15:40.202
ZN-202206-ECBOT [C] Daily #23 | File ZN-199709-ECBOT.dly has a volume of 0 at 1997-08-28. | 2022-04-25 10:15:40.202
ZN-202206-ECBOT [C] Daily #23 | File ZN-199706-ECBOT.dly has a volume of 0 at 1997-02-28. | 2022-04-25 10:15:40.215
ZN-202206-ECBOT [C] Daily #23 | File ZN-199706-ECBOT.dly has a volume of 0 at 1997-05-29. | 2022-04-25 10:15:40.215
ZN-202206-ECBOT [C] Daily #23 | File ZN-199703-ECBOT.dly has a volume of 0 at 1996-11-29. | 2022-04-25 10:15:40.228
ZN-202206-ECBOT [C] Daily #23 | File ZN-199703-ECBOT.dly has a volume of 0 at 1997-02-27. | 2022-04-25 10:15:40.228
ZN-202206-ECBOT [C] Daily #23 | File ZN-199612-ECBOT.dly has a volume of 0 at 1996-08-30. | 2022-04-25 10:15:40.240
ZN-202206-ECBOT [C] Daily #23 | File ZN-199612-ECBOT.dly has a volume of 0 at 1996-11-28. | 2022-04-25 10:15:40.240
ZN-202206-ECBOT [C] Daily #23 | File ZN-199609-ECBOT.dly has a volume of 0 at 1996-05-31. | 2022-04-25 10:15:40.253
ZN-202206-ECBOT [C] Daily #23 | File ZN-199609-ECBOT.dly has a volume of 0 at 1996-08-29. | 2022-04-25 10:15:40.253
ZN-202206-ECBOT [C] Daily #23 | File ZN-199606-ECBOT.dly has a volume of 0 at 1996-02-29. | 2022-04-25 10:15:40.266
ZN-202206-ECBOT [C] Daily #23 | File ZN-199606-ECBOT.dly has a volume of 0 at 1996-05-30. | 2022-04-25 10:15:40.266
ZN-202206-ECBOT [C] Daily #23 | File ZN-199603-ECBOT.dly has a volume of 0 at 1995-11-30. | 2022-04-25 10:15:40.279
ZN-202206-ECBOT [C] Daily #23 | File ZN-199603-ECBOT.dly has a volume of 0 at 1996-02-28. | 2022-04-25 10:15:40.279
ZN-202206-ECBOT [C] Daily #23 | File ZN-199512-ECBOT.dly has a volume of 0 at 1995-08-31. | 2022-04-25 10:15:40.292
ZN-202206-ECBOT [C] Daily #23 | File ZN-199512-ECBOT.dly has a volume of 0 at 1995-11-29. | 2022-04-25 10:15:40.292
ZN-202206-ECBOT [C] Daily #23 | File ZN-199509-ECBOT.dly has a volume of 0 at 1995-05-31. | 2022-04-25 10:15:40.305
ZN-202206-ECBOT [C] Daily #23 | File ZN-199509-ECBOT.dly has a volume of 0 at 1995-08-30. | 2022-04-25 10:15:40.305
ZN-202206-ECBOT [C] Daily #23 | File ZN-199506-ECBOT.dly has a volume of 0 at 1995-02-28. | 2022-04-25 10:15:40.318
ZN-202206-ECBOT [C] Daily #23 | File ZN-199506-ECBOT.dly has a volume of 0 at 1995-05-30. | 2022-04-25 10:15:40.318
ZN-202206-ECBOT [C] Daily #23 | File ZN-199503-ECBOT.dly has a volume of 0 at 1994-11-30. | 2022-04-25 10:15:40.331
ZN-202206-ECBOT [C] Daily #23 | File ZN-199503-ECBOT.dly has a volume of 0 at 1995-02-27. | 2022-04-25 10:15:40.331
ZN-202206-ECBOT [C] Daily #23 | File ZN-199412-ECBOT.dly has a volume of 0 at 1994-08-31. | 2022-04-25 10:15:40.343
ZN-202206-ECBOT [C] Daily #23 | File ZN-199412-ECBOT.dly has a volume of 0 at 1994-11-29. | 2022-04-25 10:15:40.343
ZN-202206-ECBOT [C] Daily #23 | File ZN-199409-ECBOT.dly has a volume of 0 at 1994-05-31. | 2022-04-25 10:15:40.357
ZN-202206-ECBOT [C] Daily #23 | File ZN-199409-ECBOT.dly has a volume of 0 at 1994-08-30. | 2022-04-25 10:15:40.357
ZN-202206-ECBOT [C] Daily #23 | File ZN-199406-ECBOT.dly has a volume of 0 at 1994-02-28. | 2022-04-25 10:15:40.370
ZN-202206-ECBOT [C] Daily #23 | File ZN-199406-ECBOT.dly has a volume of 0 at 1994-05-30. | 2022-04-25 10:15:40.370
ZN-202206-ECBOT [C] Daily #23 | File ZN-199403-ECBOT.dly has a volume of 0 at 1993-11-30. | 2022-04-25 10:15:40.383
ZN-202206-ECBOT [C] Daily #23 | File ZN-199403-ECBOT.dly has a volume of 0 at 1994-02-25. | 2022-04-25 10:15:40.383
ZN-202206-ECBOT [C] Daily #23 | File ZN-199312-ECBOT.dly has a volume of 0 at 1993-08-31. | 2022-04-25 10:15:40.396
ZN-202206-ECBOT [C] Daily #23 | File ZN-199312-ECBOT.dly has a volume of 0 at 1993-11-29. | 2022-04-25 10:15:40.396
ZN-202206-ECBOT [C] Daily #23 | File ZN-199309-ECBOT.dly has a volume of 0 at 1993-05-31. | 2022-04-25 10:15:40.409
ZN-202206-ECBOT [C] Daily #23 | File ZN-199309-ECBOT.dly has a volume of 0 at 1993-08-30. | 2022-04-25 10:15:40.409
ZN-202206-ECBOT [C] Daily #23 | File ZN-199306-ECBOT.dly has a volume of 0 at 1993-02-26. | 2022-04-25 10:15:40.422
ZN-202206-ECBOT [C] Daily #23 | File ZN-199306-ECBOT.dly has a volume of 0 at 1993-05-28. | 2022-04-25 10:15:40.422
ZN-202206-ECBOT [C] Daily #23 | File ZN-199303-ECBOT.dly has a volume of 0 at 1992-11-30. | 2022-04-25 10:15:40.435
ZN-202206-ECBOT [C] Daily #23 | File ZN-199303-ECBOT.dly has a volume of 0 at 1993-02-25. | 2022-04-25 10:15:40.435
ZN-202206-ECBOT [C] Daily #23 | File ZN-199212-ECBOT.dly has a volume of 0 at 1992-08-31. | 2022-04-25 10:15:40.448
ZN-202206-ECBOT [C] Daily #23 | File ZN-199212-ECBOT.dly has a volume of 0 at 1992-11-27. | 2022-04-25 10:15:40.448
ZN-202206-ECBOT [C] Daily #23 | File ZN-199209-ECBOT.dly has a volume of 0 at 1992-05-29. | 2022-04-25 10:15:40.462
ZN-202206-ECBOT [C] Daily #23 | File ZN-199209-ECBOT.dly has a volume of 0 at 1992-08-28. | 2022-04-25 10:15:40.462
ZN-202206-ECBOT [C] Daily #23 | File ZN-199206-ECBOT.dly has a volume of 0 at 1992-02-28. | 2022-04-25 10:15:40.475
ZN-202206-ECBOT [C] Daily #23 | File ZN-199206-ECBOT.dly has a volume of 0 at 1992-05-28. | 2022-04-25 10:15:40.475
ZN-202206-ECBOT [C] Daily #23 | File ZN-199203-ECBOT.dly has a volume of 0 at 1991-11-29. | 2022-04-25 10:15:40.487
ZN-202206-ECBOT [C] Daily #23 | File ZN-199203-ECBOT.dly has a volume of 0 at 1992-02-27. | 2022-04-25 10:15:40.487
ZN-202206-ECBOT [C] Daily #23 | File ZN-199112-ECBOT.dly has a volume of 0 at 1991-08-30. | 2022-04-25 10:15:40.500
ZN-202206-ECBOT [C] Daily #23 | File ZN-199112-ECBOT.dly has a volume of 0 at 1991-11-28. | 2022-04-25 10:15:40.500
ZN-202206-ECBOT [C] Daily #23 | File ZN-199109-ECBOT.dly has a volume of 0 at 1991-05-31. | 2022-04-25 10:15:40.513
ZN-202206-ECBOT [C] Daily #23 | File ZN-199109-ECBOT.dly has a volume of 0 at 1991-08-29. | 2022-04-25 10:15:40.513
ZN-202206-ECBOT [C] Daily #23 | File ZN-199106-ECBOT.dly has a volume of 0 at 1991-02-28. | 2022-04-25 10:15:40.526
ZN-202206-ECBOT [C] Daily #23 | File ZN-199106-ECBOT.dly has a volume of 0 at 1991-05-30. | 2022-04-25 10:15:40.526
ZN-202206-ECBOT [C] Daily #23 | File ZN-199103-ECBOT.dly has a volume of 0 at 1990-11-30. | 2022-04-25 10:15:40.538
ZN-202206-ECBOT [C] Daily #23 | File ZN-199103-ECBOT.dly has a volume of 0 at 1991-02-27. | 2022-04-25 10:15:40.538
ZN-202206-ECBOT [C] Daily #23 | File ZN-199012-ECBOT.dly has a volume of 0 at 1990-08-31. | 2022-04-25 10:15:40.551
ZN-202206-ECBOT [C] Daily #23 | File ZN-199012-ECBOT.dly has a volume of 0 at 1990-11-29. | 2022-04-25 10:15:40.551
ZN-202206-ECBOT [C] Daily #23 | File ZN-199009-ECBOT.dly has a volume of 0 at 1990-05-31. | 2022-04-25 10:15:40.563
ZN-202206-ECBOT [C] Daily #23 | File ZN-199009-ECBOT.dly has a volume of 0 at 1990-08-30. | 2022-04-25 10:15:40.563
ZN-202206-ECBOT [C] Daily #23 | File ZN-199006-ECBOT.dly has a volume of 0 at 1990-02-28. | 2022-04-25 10:15:40.576
ZN-202206-ECBOT [C] Daily #23 | File ZN-199006-ECBOT.dly has a volume of 0 at 1990-05-30. | 2022-04-25 10:15:40.576
ZN-202206-ECBOT [C] Daily #23 | File ZN-199003-ECBOT.dly has a volume of 0 at 1989-11-30. | 2022-04-25 10:15:40.588
ZN-202206-ECBOT [C] Daily #23 | File ZN-199003-ECBOT.dly has a volume of 0 at 1990-02-27. | 2022-04-25 10:15:40.588
ZN-202206-ECBOT [C] Daily #23 | File ZN-198912-ECBOT.dly has a volume of 0 at 1989-08-31. | 2022-04-25 10:15:40.601
ZN-202206-ECBOT [C] Daily #23 | File ZN-198912-ECBOT.dly has a volume of 0 at 1989-11-29. | 2022-04-25 10:15:40.601
ZN-202206-ECBOT [C] Daily #23 | File ZN-198909-ECBOT.dly has a volume of 0 at 1989-05-31. | 2022-04-25 10:15:40.614
ZN-202206-ECBOT [C] Daily #23 | File ZN-198909-ECBOT.dly has a volume of 0 at 1989-08-30. | 2022-04-25 10:15:40.614
ZN-202206-ECBOT [C] Daily #23 | File ZN-198906-ECBOT.dly has a volume of 0 at 1989-02-28. | 2022-04-25 10:15:40.626
ZN-202206-ECBOT [C] Daily #23 | File ZN-198906-ECBOT.dly has a volume of 0 at 1989-05-30. | 2022-04-25 10:15:40.626
ZN-202206-ECBOT [C] Daily #23 | File ZN-198903-ECBOT.dly has a volume of 0 at 1988-11-30. | 2022-04-25 10:15:40.639
ZN-202206-ECBOT [C] Daily #23 | File ZN-198903-ECBOT.dly has a volume of 0 at 1989-02-27. | 2022-04-25 10:15:40.639
ZN-202206-ECBOT [C] Daily #23 | File ZN-198812-ECBOT.dly has a volume of 0 at 1988-08-31. | 2022-04-25 10:15:40.651
ZN-202206-ECBOT [C] Daily #23 | File ZN-198812-ECBOT.dly has a volume of 0 at 1988-11-29. | 2022-04-25 10:15:40.651
ZN-202206-ECBOT [C] Daily #23 | File ZN-198809-ECBOT.dly has a volume of 0 at 1988-05-31. | 2022-04-25 10:15:40.664
ZN-202206-ECBOT [C] Daily #23 | File ZN-198809-ECBOT.dly has a volume of 0 at 1988-08-30. | 2022-04-25 10:15:40.664
ZN-202206-ECBOT [C] Daily #23 | File ZN-198806-ECBOT.dly has a volume of 0 at 1988-02-29. | 2022-04-25 10:15:40.677
ZN-202206-ECBOT [C] Daily #23 | File ZN-198806-ECBOT.dly has a volume of 0 at 1988-05-30. | 2022-04-25 10:15:40.677
ZN-202206-ECBOT [C] Daily #23 | File ZN-198803-ECBOT.dly has a volume of 0 at 1987-11-30. | 2022-04-25 10:15:40.690
ZN-202206-ECBOT [C] Daily #23 | File ZN-198803-ECBOT.dly has a volume of 0 at 1988-02-26. | 2022-04-25 10:15:40.690
ZN-202206-ECBOT [C] Daily #23 | File ZN-198712-ECBOT.dly has a volume of 0 at 1987-08-31. | 2022-04-25 10:15:40.703
ZN-202206-ECBOT [C] Daily #23 | File ZN-198712-ECBOT.dly has a volume of 0 at 1987-11-27. | 2022-04-25 10:15:40.703
ZN-202206-ECBOT [C] Daily #23 | File ZN-198709-ECBOT.dly has a volume of 0 at 1987-05-29. | 2022-04-25 10:15:40.716
ZN-202206-ECBOT [C] Daily #23 | File ZN-198709-ECBOT.dly has a volume of 0 at 1987-08-28. | 2022-04-25 10:15:40.716
ZN-202206-ECBOT [C] Daily #23 | File ZN-198706-ECBOT.dly has a volume of 0 at 1987-02-27. | 2022-04-25 10:15:40.728
ZN-202206-ECBOT [C] Daily #23 | File ZN-198706-ECBOT.dly has a volume of 0 at 1987-05-28. | 2022-04-25 10:15:40.728
ZN-202206-ECBOT [C] Daily #23 | File ZN-198703-ECBOT.dly has a volume of 0 at 1986-11-28. | 2022-04-25 10:15:40.741
ZN-202206-ECBOT [C] Daily #23 | File ZN-198703-ECBOT.dly has a volume of 0 at 1987-02-26. | 2022-04-25 10:15:40.741
ZN-202206-ECBOT [C] Daily #23 | File ZN-198612-ECBOT.dly has a volume of 0 at 1986-08-29. | 2022-04-25 10:15:40.754
ZN-202206-ECBOT [C] Daily #23 | File ZN-198612-ECBOT.dly has a volume of 0 at 1986-11-27. | 2022-04-25 10:15:40.754
ZN-202206-ECBOT [C] Daily #23 | File ZN-198609-ECBOT.dly has a volume of 0 at 1986-05-30. | 2022-04-25 10:15:40.767
ZN-202206-ECBOT [C] Daily #23 | File ZN-198609-ECBOT.dly has a volume of 0 at 1986-08-28. | 2022-04-25 10:15:40.767
ZN-202206-ECBOT [C] Daily #23 | File ZN-198606-ECBOT.dly has a volume of 0 at 1986-02-28. | 2022-04-25 10:15:40.780
ZN-202206-ECBOT [C] Daily #23 | File ZN-198606-ECBOT.dly has a volume of 0 at 1986-05-29. | 2022-04-25 10:15:40.780
ZN-202206-ECBOT [C] Daily #23 | File ZN-198603-ECBOT.dly has a volume of 0 at 1985-11-29. | 2022-04-25 10:15:40.792
ZN-202206-ECBOT [C] Daily #23 | File ZN-198603-ECBOT.dly has a volume of 0 at 1986-02-27. | 2022-04-25 10:15:40.792
ZN-202206-ECBOT [C] Daily #23 | File ZN-198512-ECBOT.dly has a volume of 0 at 1985-08-30. | 2022-04-25 10:15:40.805
ZN-202206-ECBOT [C] Daily #23 | File ZN-198512-ECBOT.dly has a volume of 0 at 1985-11-28. | 2022-04-25 10:15:40.805
ZN-202206-ECBOT [C] Daily #23 | File ZN-198509-ECBOT.dly has a volume of 0 at 1985-05-31. | 2022-04-25 10:15:40.817
ZN-202206-ECBOT [C] Daily #23 | File ZN-198509-ECBOT.dly has a volume of 0 at 1985-08-29. | 2022-04-25 10:15:40.817
ZN-202206-ECBOT [C] Daily #23 | File ZN-198506-ECBOT.dly has a volume of 0 at 1985-02-28. | 2022-04-25 10:15:40.830
ZN-202206-ECBOT [C] Daily #23 | File ZN-198506-ECBOT.dly has a volume of 0 at 1985-05-30. | 2022-04-25 10:15:40.830
ZN-202206-ECBOT [C] Daily #23 | File ZN-198503-ECBOT.dly has a volume of 0 at 1984-11-30. | 2022-04-25 10:15:40.842
ZN-202206-ECBOT [C] Daily #23 | File ZN-198503-ECBOT.dly has a volume of 0 at 1985-02-27. | 2022-04-25 10:15:40.842
ZN-202206-ECBOT [C] Daily #23 | File ZN-198412-ECBOT.dly has a volume of 0 at 1984-08-31. | 2022-04-25 10:15:40.855
ZN-202206-ECBOT [C] Daily #23 | File ZN-198412-ECBOT.dly has a volume of 0 at 1984-11-29. | 2022-04-25 10:15:40.855
ZN-202206-ECBOT [C] Daily #23 | File ZN-198409-ECBOT.dly has a volume of 0 at 1984-05-31. | 2022-04-25 10:15:40.867
ZN-202206-ECBOT [C] Daily #23 | File ZN-198409-ECBOT.dly has a volume of 0 at 1984-08-30. | 2022-04-25 10:15:40.867
ZN-202206-ECBOT [C] Daily #23 | File ZN-198406-ECBOT.dly has a volume of 0 at 1984-02-29. | 2022-04-25 10:15:40.880
ZN-202206-ECBOT [C] Daily #23 | File ZN-198406-ECBOT.dly has a volume of 0 at 1984-05-30. | 2022-04-25 10:15:40.880
ZN-202206-ECBOT [C] Daily #23 | File ZN-198403-ECBOT.dly has a volume of 0 at 1983-11-30. | 2022-04-25 10:15:40.893
ZN-202206-ECBOT [C] Daily #23 | File ZN-198403-ECBOT.dly has a volume of 0 at 1984-02-28. | 2022-04-25 10:15:40.893
ZN-202206-ECBOT [C] Daily #23 | File ZN-198312-ECBOT.dly has a volume of 0 at 1983-08-31. | 2022-04-25 10:15:40.905
ZN-202206-ECBOT [C] Daily #23 | File ZN-198312-ECBOT.dly has a volume of 0 at 1983-11-29. | 2022-04-25 10:15:40.905
ZN-202206-ECBOT [C] Daily #23 | File ZN-198309-ECBOT.dly has a volume of 0 at 1983-05-31. | 2022-04-25 10:15:40.918
ZN-202206-ECBOT [C] Daily #23 | File ZN-198309-ECBOT.dly has a volume of 0 at 1983-08-30. | 2022-04-25 10:15:40.918
ZN-202206-ECBOT [C] Daily #23 | File ZN-198306-ECBOT.dly has a volume of 0 at 1983-02-28. | 2022-04-25 10:15:40.931
ZN-202206-ECBOT [C] Daily #23 | File ZN-198306-ECBOT.dly has a volume of 0 at 1983-05-30. | 2022-04-25 10:15:40.931
ZN-202206-ECBOT [C] Daily #23 | File ZN-198303-ECBOT.dly has a volume of 0 at 1982-11-30. | 2022-04-25 10:15:40.944
ZN-202206-ECBOT [C] Daily #23 | File ZN-198303-ECBOT.dly has a volume of 0 at 1983-02-25. | 2022-04-25 10:15:40.944
ZN-202206-ECBOT [C] Daily #23 | File ZN-198212-ECBOT.dly has a volume of 0 at 1982-08-31. | 2022-04-25 10:15:40.956
ZN-202206-ECBOT [C] Daily #23 | File ZN-198212-ECBOT.dly has a volume of 0 at 1982-11-29. | 2022-04-25 10:15:40.956
ZN-202206-ECBOT [C] Daily #23 | File ZN-198209-ECBOT.dly has a volume of 0 at 1982-05-31. | 2022-04-25 10:15:40.969
ZN-202206-ECBOT [C] Daily #23 | File ZN-198209-ECBOT.dly has a volume of 0 at 1982-08-30. | 2022-04-25 10:15:40.969
ZN-202206-ECBOT [C] Daily #23 | Dates not found while checking for invalid data in continuous contract data files. ZN-198206-ECBOT | 2022-04-25 10:15:40.975 *
Restarting the loading process. | 2022-04-25 10:15:40.975
Historical data download thread signaled to stop. | 2022-04-25 10:15:40.982
HD Request # 61 | Timestamp of first Intraday data file record written: 2022-04-25 10:14:19.683000 | 2022-04-25 10:15:40.982
HD Request # 61 | Received 6 Intraday data records from 2022-04-25 10:09:45.643000 to 2022-04-25 10:14:55.006001 (5.2 minutes) and wrote 4 records for HESM-NQTV | 2022-04-25 10:15:40.982
HD Request # 61 | Completion time: 3s | 2022-04-25 10:15:40.982
HD Request # 61 | Intraday data download complete for HESM-NQTV. Unique request ID: 166 | 2022-04-25 10:15:40.982
Removing historical data download ID 166. | 2022-04-25 10:15:40.982
Real-time Intraday chart data file updates started for HESM-NQTV | 2022-04-25 10:15:40.982
Intraday chart data file opened for HESM-NQTV | 2022-04-25 10:15:40.982
HD Request # 61 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:40.982
Triggering next historical data download in queue. | 2022-04-25 10:15:40.982
HD Request # 62 | Requesting historical Daily data for GCG75 starting at 1974-11-26. SC External HD service. | 2022-04-25 10:15:40.982
HD Request # 63 | Downloading Intraday chart data for HCC-NQTV to the file HCC-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:40.983
HD Request # 63 | Download start date-time: 2022-04-25 10:12:47.000000. File last date-time: 2022-04-25 10:12:47.648000 | 2022-04-25 10:15:40.983
HD Request # 63 | Using server: ds25.sierracharts.com port 10150 | 2022-04-25 10:15:40.983
Socket (3) | Creating socket. | 2022-04-25 10:15:40.983
Socket (3) | New receive buffer size: 5242880 | 2022-04-25 10:15:40.983
Socket (3) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:40.983
ZN-202206-ECBOT [C] 4 Day #19 | Reloading chart. | 2022-04-25 10:15:41.074
ZN-202206-ECBOT [C] 4 Day #19 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:41.074
ZN-202206-ECBOT [C] 4 Day #19 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:41.074
HD Request # 63 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:41.441
HD Request # 63 | Sending historical data logon request message. | 2022-04-25 10:15:41.441
HD Request # 63 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:47. Record interval: 0. Symbol: HCC-NQTV | 2022-04-25 10:15:41.672
HD Request # 63 | Decompressing data. | 2022-04-25 10:15:41.902
HD Request # 63 | Receiving Intraday data for HCC-NQTV starting at 2022-04-25 10:12:47.648000 | 2022-04-25 10:15:41.903
Socket (3) | CloseSocket call. | 2022-04-25 10:15:41.903
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:41.903
Socket (3) | Socket gracefully closed by remote side. | 2022-04-25 10:15:42.129
Socket (3) | Closed. | 2022-04-25 10:15:42.129
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-200103-ECBOT.dly has a volume of 0 at 2000-11-30. | 2022-04-25 10:15:42.551
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-200012-ECBOT.dly has a volume of 0 at 2000-08-31. | 2022-04-25 10:15:42.564
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-200012-ECBOT.dly has a volume of 0 at 2000-11-29. | 2022-04-25 10:15:42.564
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-200009-ECBOT.dly has a volume of 0 at 2000-05-31. | 2022-04-25 10:15:42.576
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-200009-ECBOT.dly has a volume of 0 at 2000-08-30. | 2022-04-25 10:15:42.576
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-200006-ECBOT.dly has a volume of 0 at 2000-02-29. | 2022-04-25 10:15:42.590
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-200006-ECBOT.dly has a volume of 0 at 2000-05-30. | 2022-04-25 10:15:42.590
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-200003-ECBOT.dly has a volume of 0 at 1999-11-30. | 2022-04-25 10:15:42.602
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-200003-ECBOT.dly has a volume of 0 at 2000-02-28. | 2022-04-25 10:15:42.602
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199912-ECBOT.dly has a volume of 0 at 1999-08-31. | 2022-04-25 10:15:42.615
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199912-ECBOT.dly has a volume of 0 at 1999-11-29. | 2022-04-25 10:15:42.615
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199909-ECBOT.dly has a volume of 0 at 1999-05-31. | 2022-04-25 10:15:42.628
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199909-ECBOT.dly has a volume of 0 at 1999-08-30. | 2022-04-25 10:15:42.628
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199906-ECBOT.dly has a volume of 0 at 1999-02-26. | 2022-04-25 10:15:42.642
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199906-ECBOT.dly has a volume of 0 at 1999-05-28. | 2022-04-25 10:15:42.642
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199903-ECBOT.dly has a volume of 0 at 1998-11-30. | 2022-04-25 10:15:42.655
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199903-ECBOT.dly has a volume of 0 at 1999-02-25. | 2022-04-25 10:15:42.655
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199812-ECBOT.dly has a volume of 0 at 1998-08-31. | 2022-04-25 10:15:42.667
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199812-ECBOT.dly has a volume of 0 at 1998-11-27. | 2022-04-25 10:15:42.667
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199809-ECBOT.dly has a volume of 0 at 1998-05-29. | 2022-04-25 10:15:42.680
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199809-ECBOT.dly has a volume of 0 at 1998-08-28. | 2022-04-25 10:15:42.680
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199806-ECBOT.dly has a volume of 0 at 1998-02-27. | 2022-04-25 10:15:42.693
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199806-ECBOT.dly has a volume of 0 at 1998-05-28. | 2022-04-25 10:15:42.693
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199803-ECBOT.dly has a volume of 0 at 1997-11-28. | 2022-04-25 10:15:42.706
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199803-ECBOT.dly has a volume of 0 at 1998-02-26. | 2022-04-25 10:15:42.706
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199712-ECBOT.dly has a volume of 0 at 1997-08-29. | 2022-04-25 10:15:42.719
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199712-ECBOT.dly has a volume of 0 at 1997-11-27. | 2022-04-25 10:15:42.719
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199709-ECBOT.dly has a volume of 0 at 1997-05-30. | 2022-04-25 10:15:42.732
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199709-ECBOT.dly has a volume of 0 at 1997-08-28. | 2022-04-25 10:15:42.732
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199706-ECBOT.dly has a volume of 0 at 1997-02-28. | 2022-04-25 10:15:42.745
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199706-ECBOT.dly has a volume of 0 at 1997-05-29. | 2022-04-25 10:15:42.745
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199703-ECBOT.dly has a volume of 0 at 1996-11-29. | 2022-04-25 10:15:42.757
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199703-ECBOT.dly has a volume of 0 at 1997-02-27. | 2022-04-25 10:15:42.757
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199612-ECBOT.dly has a volume of 0 at 1996-08-30. | 2022-04-25 10:15:42.770
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199612-ECBOT.dly has a volume of 0 at 1996-11-28. | 2022-04-25 10:15:42.770
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199609-ECBOT.dly has a volume of 0 at 1996-05-31. | 2022-04-25 10:15:42.783
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199609-ECBOT.dly has a volume of 0 at 1996-08-29. | 2022-04-25 10:15:42.783
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199606-ECBOT.dly has a volume of 0 at 1996-02-29. | 2022-04-25 10:15:42.796
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199606-ECBOT.dly has a volume of 0 at 1996-05-30. | 2022-04-25 10:15:42.796
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199603-ECBOT.dly has a volume of 0 at 1995-11-30. | 2022-04-25 10:15:42.809
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199603-ECBOT.dly has a volume of 0 at 1996-02-28. | 2022-04-25 10:15:42.809
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199512-ECBOT.dly has a volume of 0 at 1995-08-31. | 2022-04-25 10:15:42.822
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199512-ECBOT.dly has a volume of 0 at 1995-11-29. | 2022-04-25 10:15:42.822
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199509-ECBOT.dly has a volume of 0 at 1995-05-31. | 2022-04-25 10:15:42.835
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199509-ECBOT.dly has a volume of 0 at 1995-08-30. | 2022-04-25 10:15:42.835
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199506-ECBOT.dly has a volume of 0 at 1995-02-28. | 2022-04-25 10:15:42.848
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199506-ECBOT.dly has a volume of 0 at 1995-05-30. | 2022-04-25 10:15:42.848
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199503-ECBOT.dly has a volume of 0 at 1994-11-30. | 2022-04-25 10:15:42.861
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199503-ECBOT.dly has a volume of 0 at 1995-02-27. | 2022-04-25 10:15:42.861
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199412-ECBOT.dly has a volume of 0 at 1994-08-31. | 2022-04-25 10:15:42.873
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199412-ECBOT.dly has a volume of 0 at 1994-11-29. | 2022-04-25 10:15:42.873
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199409-ECBOT.dly has a volume of 0 at 1994-05-31. | 2022-04-25 10:15:42.887
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199409-ECBOT.dly has a volume of 0 at 1994-08-30. | 2022-04-25 10:15:42.887
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199406-ECBOT.dly has a volume of 0 at 1994-02-28. | 2022-04-25 10:15:42.900
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199406-ECBOT.dly has a volume of 0 at 1994-05-30. | 2022-04-25 10:15:42.900
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199403-ECBOT.dly has a volume of 0 at 1993-11-30. | 2022-04-25 10:15:42.913
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199403-ECBOT.dly has a volume of 0 at 1994-02-25. | 2022-04-25 10:15:42.913
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199312-ECBOT.dly has a volume of 0 at 1993-08-31. | 2022-04-25 10:15:42.926
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199312-ECBOT.dly has a volume of 0 at 1993-11-29. | 2022-04-25 10:15:42.926
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199309-ECBOT.dly has a volume of 0 at 1993-05-31. | 2022-04-25 10:15:42.939
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199309-ECBOT.dly has a volume of 0 at 1993-08-30. | 2022-04-25 10:15:42.939
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199306-ECBOT.dly has a volume of 0 at 1993-02-26. | 2022-04-25 10:15:42.952
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199306-ECBOT.dly has a volume of 0 at 1993-05-28. | 2022-04-25 10:15:42.952
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199303-ECBOT.dly has a volume of 0 at 1992-11-30. | 2022-04-25 10:15:42.965
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199303-ECBOT.dly has a volume of 0 at 1993-02-25. | 2022-04-25 10:15:42.965
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199212-ECBOT.dly has a volume of 0 at 1992-08-31. | 2022-04-25 10:15:42.978
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199212-ECBOT.dly has a volume of 0 at 1992-11-27. | 2022-04-25 10:15:42.978
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199209-ECBOT.dly has a volume of 0 at 1992-05-29. | 2022-04-25 10:15:42.992
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199209-ECBOT.dly has a volume of 0 at 1992-08-28. | 2022-04-25 10:15:42.992
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199206-ECBOT.dly has a volume of 0 at 1992-02-28. | 2022-04-25 10:15:43.005
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199206-ECBOT.dly has a volume of 0 at 1992-05-28. | 2022-04-25 10:15:43.005
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199203-ECBOT.dly has a volume of 0 at 1991-11-29. | 2022-04-25 10:15:43.018
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199203-ECBOT.dly has a volume of 0 at 1992-02-27. | 2022-04-25 10:15:43.018
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199112-ECBOT.dly has a volume of 0 at 1991-08-30. | 2022-04-25 10:15:43.031
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199112-ECBOT.dly has a volume of 0 at 1991-11-28. | 2022-04-25 10:15:43.031
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199109-ECBOT.dly has a volume of 0 at 1991-05-31. | 2022-04-25 10:15:43.044
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199109-ECBOT.dly has a volume of 0 at 1991-08-29. | 2022-04-25 10:15:43.044
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199106-ECBOT.dly has a volume of 0 at 1991-02-28. | 2022-04-25 10:15:43.056
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199106-ECBOT.dly has a volume of 0 at 1991-05-30. | 2022-04-25 10:15:43.056
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199103-ECBOT.dly has a volume of 0 at 1990-11-30. | 2022-04-25 10:15:43.068
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199103-ECBOT.dly has a volume of 0 at 1991-02-27. | 2022-04-25 10:15:43.068
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199012-ECBOT.dly has a volume of 0 at 1990-08-31. | 2022-04-25 10:15:43.081
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199012-ECBOT.dly has a volume of 0 at 1990-11-29. | 2022-04-25 10:15:43.081
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199009-ECBOT.dly has a volume of 0 at 1990-05-31. | 2022-04-25 10:15:43.094
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199009-ECBOT.dly has a volume of 0 at 1990-08-30. | 2022-04-25 10:15:43.094
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199006-ECBOT.dly has a volume of 0 at 1990-02-28. | 2022-04-25 10:15:43.107
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199006-ECBOT.dly has a volume of 0 at 1990-05-30. | 2022-04-25 10:15:43.107
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199003-ECBOT.dly has a volume of 0 at 1989-11-30. | 2022-04-25 10:15:43.119
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-199003-ECBOT.dly has a volume of 0 at 1990-02-27. | 2022-04-25 10:15:43.119
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198912-ECBOT.dly has a volume of 0 at 1989-08-31. | 2022-04-25 10:15:43.132
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198912-ECBOT.dly has a volume of 0 at 1989-11-29. | 2022-04-25 10:15:43.132
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198909-ECBOT.dly has a volume of 0 at 1989-05-31. | 2022-04-25 10:15:43.144
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198909-ECBOT.dly has a volume of 0 at 1989-08-30. | 2022-04-25 10:15:43.144
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198906-ECBOT.dly has a volume of 0 at 1989-02-28. | 2022-04-25 10:15:43.157
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198906-ECBOT.dly has a volume of 0 at 1989-05-30. | 2022-04-25 10:15:43.157
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198903-ECBOT.dly has a volume of 0 at 1988-11-30. | 2022-04-25 10:15:43.170
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198903-ECBOT.dly has a volume of 0 at 1989-02-27. | 2022-04-25 10:15:43.170
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198812-ECBOT.dly has a volume of 0 at 1988-08-31. | 2022-04-25 10:15:43.182
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198812-ECBOT.dly has a volume of 0 at 1988-11-29. | 2022-04-25 10:15:43.182
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198809-ECBOT.dly has a volume of 0 at 1988-05-31. | 2022-04-25 10:15:43.195
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198809-ECBOT.dly has a volume of 0 at 1988-08-30. | 2022-04-25 10:15:43.195
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198806-ECBOT.dly has a volume of 0 at 1988-02-29. | 2022-04-25 10:15:43.208
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198806-ECBOT.dly has a volume of 0 at 1988-05-30. | 2022-04-25 10:15:43.208
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198803-ECBOT.dly has a volume of 0 at 1987-11-30. | 2022-04-25 10:15:43.221
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198803-ECBOT.dly has a volume of 0 at 1988-02-26. | 2022-04-25 10:15:43.221
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198712-ECBOT.dly has a volume of 0 at 1987-08-31. | 2022-04-25 10:15:43.233
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198712-ECBOT.dly has a volume of 0 at 1987-11-27. | 2022-04-25 10:15:43.233
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198709-ECBOT.dly has a volume of 0 at 1987-05-29. | 2022-04-25 10:15:43.246
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198709-ECBOT.dly has a volume of 0 at 1987-08-28. | 2022-04-25 10:15:43.246
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198706-ECBOT.dly has a volume of 0 at 1987-02-27. | 2022-04-25 10:15:43.259
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198706-ECBOT.dly has a volume of 0 at 1987-05-28. | 2022-04-25 10:15:43.259
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198703-ECBOT.dly has a volume of 0 at 1986-11-28. | 2022-04-25 10:15:43.272
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198703-ECBOT.dly has a volume of 0 at 1987-02-26. | 2022-04-25 10:15:43.272
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198612-ECBOT.dly has a volume of 0 at 1986-08-29. | 2022-04-25 10:15:43.285
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198612-ECBOT.dly has a volume of 0 at 1986-11-27. | 2022-04-25 10:15:43.285
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198609-ECBOT.dly has a volume of 0 at 1986-05-30. | 2022-04-25 10:15:43.298
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198609-ECBOT.dly has a volume of 0 at 1986-08-28. | 2022-04-25 10:15:43.298
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198606-ECBOT.dly has a volume of 0 at 1986-02-28. | 2022-04-25 10:15:43.311
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198606-ECBOT.dly has a volume of 0 at 1986-05-29. | 2022-04-25 10:15:43.311
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198603-ECBOT.dly has a volume of 0 at 1985-11-29. | 2022-04-25 10:15:43.323
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198603-ECBOT.dly has a volume of 0 at 1986-02-27. | 2022-04-25 10:15:43.323
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198512-ECBOT.dly has a volume of 0 at 1985-08-30. | 2022-04-25 10:15:43.336
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198512-ECBOT.dly has a volume of 0 at 1985-11-28. | 2022-04-25 10:15:43.336
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198509-ECBOT.dly has a volume of 0 at 1985-05-31. | 2022-04-25 10:15:43.348
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198509-ECBOT.dly has a volume of 0 at 1985-08-29. | 2022-04-25 10:15:43.348
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198506-ECBOT.dly has a volume of 0 at 1985-02-28. | 2022-04-25 10:15:43.361
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198506-ECBOT.dly has a volume of 0 at 1985-05-30. | 2022-04-25 10:15:43.361
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198503-ECBOT.dly has a volume of 0 at 1984-11-30. | 2022-04-25 10:15:43.373
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198503-ECBOT.dly has a volume of 0 at 1985-02-27. | 2022-04-25 10:15:43.373
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198412-ECBOT.dly has a volume of 0 at 1984-08-31. | 2022-04-25 10:15:43.386
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198412-ECBOT.dly has a volume of 0 at 1984-11-29. | 2022-04-25 10:15:43.386
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198409-ECBOT.dly has a volume of 0 at 1984-05-31. | 2022-04-25 10:15:43.398
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198409-ECBOT.dly has a volume of 0 at 1984-08-30. | 2022-04-25 10:15:43.398
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198406-ECBOT.dly has a volume of 0 at 1984-02-29. | 2022-04-25 10:15:43.411
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198406-ECBOT.dly has a volume of 0 at 1984-05-30. | 2022-04-25 10:15:43.411
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198403-ECBOT.dly has a volume of 0 at 1983-11-30. | 2022-04-25 10:15:43.423
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198403-ECBOT.dly has a volume of 0 at 1984-02-28. | 2022-04-25 10:15:43.423
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198312-ECBOT.dly has a volume of 0 at 1983-08-31. | 2022-04-25 10:15:43.436
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198312-ECBOT.dly has a volume of 0 at 1983-11-29. | 2022-04-25 10:15:43.436
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198309-ECBOT.dly has a volume of 0 at 1983-05-31. | 2022-04-25 10:15:43.448
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198309-ECBOT.dly has a volume of 0 at 1983-08-30. | 2022-04-25 10:15:43.448
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198306-ECBOT.dly has a volume of 0 at 1983-02-28. | 2022-04-25 10:15:43.461
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198306-ECBOT.dly has a volume of 0 at 1983-05-30. | 2022-04-25 10:15:43.461
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198303-ECBOT.dly has a volume of 0 at 1982-11-30. | 2022-04-25 10:15:43.474
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198303-ECBOT.dly has a volume of 0 at 1983-02-25. | 2022-04-25 10:15:43.474
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198212-ECBOT.dly has a volume of 0 at 1982-08-31. | 2022-04-25 10:15:43.486
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198212-ECBOT.dly has a volume of 0 at 1982-11-29. | 2022-04-25 10:15:43.486
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198209-ECBOT.dly has a volume of 0 at 1982-05-31. | 2022-04-25 10:15:43.499
ZN-202206-ECBOT [C] 4 Day #19 | File ZN-198209-ECBOT.dly has a volume of 0 at 1982-08-30. | 2022-04-25 10:15:43.499
ZN-202206-ECBOT [C] 4 Day #19 | Dates not found while checking for invalid data in continuous contract data files. ZN-198206-ECBOT | 2022-04-25 10:15:43.505 *
Historical data download thread signaled to stop. | 2022-04-25 10:15:43.538
HD Request # 63 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:13.471000 | 2022-04-25 10:15:43.538
HD Request # 63 | Received 2 Intraday data records from 2022-04-25 10:12:47.648000 to 2022-04-25 10:13:13.471000 (25.8 seconds) and wrote 1 record for HCC-NQTV | 2022-04-25 10:15:43.538
HD Request # 63 | Completion time: 3s | 2022-04-25 10:15:43.538
HD Request # 63 | Intraday data download complete for HCC-NQTV. Unique request ID: 167 | 2022-04-25 10:15:43.538
Removing historical data download ID 167. | 2022-04-25 10:15:43.538
Real-time Intraday chart data file updates started for HCC-NQTV | 2022-04-25 10:15:43.538
Intraday chart data file opened for HCC-NQTV | 2022-04-25 10:15:43.538
HD Request # 63 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:43.538
Triggering next historical data download in queue. | 2022-04-25 10:15:43.538
HD Request # 64 | Downloading Intraday chart data for KO-NQTV to the file KO-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:43.538
HD Request # 64 | Download start date-time: 2022-04-25 10:12:57.000000. File last date-time: 2022-04-25 10:12:57.280001 | 2022-04-25 10:15:43.539
HD Request # 64 | Using server: ds25.sierracharts.com port 10149 | 2022-04-25 10:15:43.539
Socket (3) | Creating socket. | 2022-04-25 10:15:43.539
Socket (3) | New receive buffer size: 5242880 | 2022-04-25 10:15:43.539
Socket (3) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:43.539
HD Request # 64 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:43.994
HD Request # 64 | Sending historical data logon request message. | 2022-04-25 10:15:43.994
HD Request # 62 | Receiving historical Daily data for GC-197502-NYMEX starting at 1974-12-31 | 2022-04-25 10:15:44.174
HD Request # 62 | Writing historical Daily data to the file GC-197502-NYMEX.dly | 2022-04-25 10:15:44.174
HD Request # 62 | Bytes received: 1636 | 2022-04-25 10:15:44.174
HD Request # 62 | Received 38 Daily data records from 1974-12-31 00:00:00 to 1975-02-25 00:00:00 (57.0 days) and wrote 38 records for GC-197502-NYMEX | 2022-04-25 10:15:44.174
HD Request # 62 | Completion time: 6s | 2022-04-25 10:15:44.174
HD Request # 62 | Daily data download complete for GC-197502-NYMEX. Unique request ID: 20 | 2022-04-25 10:15:44.174
Removing historical data download ID 20. | 2022-04-25 10:15:44.174
Triggering next historical data download in queue. | 2022-04-25 10:15:44.174
Mapping GC-202206-NYMEX to GCM22. Service code: comex | 2022-04-25 10:15:44.175
HD Request # 65 | Downloading Historical Daily chart data for GC-202206-NYMEX. Starting date: 2022-04-20. Service: interactive_brokers.trading | 2022-04-25 10:15:44.176
HD Request # 64 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:57. Record interval: 0. Symbol: KO-NQTV | 2022-04-25 10:15:44.219
HD Request # 64 | Decompressing data. | 2022-04-25 10:15:44.445
HD Request # 64 | Receiving Intraday data for KO-NQTV starting at 2022-04-25 10:12:57.279000 | 2022-04-25 10:15:44.446
Socket (3) | CloseSocket call. | 2022-04-25 10:15:44.446
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:44.446
Historical data download thread signaled to stop. | 2022-04-25 10:15:44.455
HD Request # 64 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:02.593000 | 2022-04-25 10:15:44.455
HD Request # 64 | Received 152 Intraday data records from 2022-04-25 10:12:57.279000 to 2022-04-25 10:15:31.914001 (2.6 minutes) and wrote 147 records for KO-NQTV | 2022-04-25 10:15:44.455
HD Request # 64 | Completion time: 1s | 2022-04-25 10:15:44.455
HD Request # 64 | Intraday data download complete for KO-NQTV. Unique request ID: 173 | 2022-04-25 10:15:44.455
Removing historical data download ID 173. | 2022-04-25 10:15:44.455
Real-time Intraday chart data file updates started for KO-NQTV | 2022-04-25 10:15:44.455
Intraday chart data file opened for KO-NQTV | 2022-04-25 10:15:44.455
HD Request # 64 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:44.455
Triggering next historical data download in queue. | 2022-04-25 10:15:44.455
HD Request # 66 | Downloading Intraday chart data for LAC-NQTV to the file LAC-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:44.455
HD Request # 66 | Download start date-time: 2022-04-25 10:12:58.000000. File last date-time: 2022-04-25 10:12:58.811000 | 2022-04-25 10:15:44.455
HD Request # 66 | Using server: ds25.sierracharts.com port 10150 | 2022-04-25 10:15:44.455
Socket (11) | Creating socket. | 2022-04-25 10:15:44.455
Socket (11) | New receive buffer size: 5242880 | 2022-04-25 10:15:44.455
Socket (11) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:44.455
Socket (3) | Socket gracefully closed by remote side. | 2022-04-25 10:15:44.670
Socket (3) | Closed. | 2022-04-25 10:15:44.670
HD Request # 66 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:44.911
HD Request # 66 | Sending historical data logon request message. | 2022-04-25 10:15:44.911
HD Request # 66 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:58. Record interval: 0. Symbol: LAC-NQTV | 2022-04-25 10:15:45.138
HD Request # 66 | Decompressing data. | 2022-04-25 10:15:45.364
HD Request # 66 | Receiving Intraday data for LAC-NQTV starting at 2022-04-25 10:12:58.811000 | 2022-04-25 10:15:45.364
Socket (11) | CloseSocket call. | 2022-04-25 10:15:45.364
Socket (11) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:45.364
Historical data download thread signaled to stop. | 2022-04-25 10:15:45.364
HD Request # 66 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:04.755000 | 2022-04-25 10:15:45.364
HD Request # 66 | Received 23 Intraday data records from 2022-04-25 10:12:58.811000 to 2022-04-25 10:15:12.290001 (2.2 minutes) and wrote 22 records for LAC-NQTV | 2022-04-25 10:15:45.365
HD Request # 66 | Completion time: 1s | 2022-04-25 10:15:45.365
HD Request # 66 | Intraday data download complete for LAC-NQTV. Unique request ID: 176 | 2022-04-25 10:15:45.365
Removing historical data download ID 176. | 2022-04-25 10:15:45.365
Real-time Intraday chart data file updates started for LAC-NQTV | 2022-04-25 10:15:45.365
Intraday chart data file opened for LAC-NQTV | 2022-04-25 10:15:45.365
HD Request # 66 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:45.365
Triggering next historical data download in queue. | 2022-04-25 10:15:45.365
HD Request # 67 | Downloading Intraday chart data for ORLY-NQTV to the file ORLY-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:45.365
HD Request # 67 | Download start date-time: 2022-04-25 10:11:54.000000. File last date-time: 2022-04-25 10:11:54.878000 | 2022-04-25 10:15:45.365
HD Request # 67 | Using server: ds25.sierracharts.com port 10149 | 2022-04-25 10:15:45.365
Socket (2) | Creating socket. | 2022-04-25 10:15:45.365
Socket (2) | New receive buffer size: 5242880 | 2022-04-25 10:15:45.365
Socket (2) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:45.365
Socket (11) | Socket gracefully closed by remote side. | 2022-04-25 10:15:45.589
Socket (11) | Closed. | 2022-04-25 10:15:45.589
HD Request # 65 | Requesting historical Daily data for GCM22 starting at 2022-04-19. SC External HD service. | 2022-04-25 10:15:45.594
HD Request # 67 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:45.824
HD Request # 67 | Sending historical data logon request message. | 2022-04-25 10:15:45.824
HD Request # 67 | Requesting Intraday data. Start date-time: 2022-04-25 10:11:54. Record interval: 0. Symbol: ORLY-NQTV | 2022-04-25 10:15:46.051
HD Request # 67 | Decompressing data. | 2022-04-25 10:15:46.277
HD Request # 67 | Receiving Intraday data for ORLY-NQTV starting at 2022-04-25 10:11:54.877000 | 2022-04-25 10:15:46.277
Socket (2) | CloseSocket call. | 2022-04-25 10:15:46.278
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:46.278
Historical data download thread signaled to stop. | 2022-04-25 10:15:46.278
HD Request # 67 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:12.933000 | 2022-04-25 10:15:46.278
HD Request # 67 | Received 41 Intraday data records from 2022-04-25 10:11:54.877000 to 2022-04-25 10:15:27.941001 (3.6 minutes) and wrote 39 records for ORLY-NQTV | 2022-04-25 10:15:46.278
HD Request # 67 | Completion time: 1s | 2022-04-25 10:15:46.278
HD Request # 67 | Intraday data download complete for ORLY-NQTV. Unique request ID: 183 | 2022-04-25 10:15:46.278
Removing historical data download ID 183. | 2022-04-25 10:15:46.278
Real-time Intraday chart data file updates started for ORLY-NQTV | 2022-04-25 10:15:46.278
Intraday chart data file opened for ORLY-NQTV | 2022-04-25 10:15:46.278
HD Request # 67 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:46.278
Triggering next historical data download in queue. | 2022-04-25 10:15:46.278
HD Request # 68 | Downloading Intraday chart data for PFE-NQTV to the file PFE-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:46.278
HD Request # 68 | Download start date-time: 2022-04-25 10:12:59.000000. File last date-time: 2022-04-25 10:12:59.513000 | 2022-04-25 10:15:46.278
HD Request # 68 | Using server: ds25.sierracharts.com port 10150 | 2022-04-25 10:15:46.278
Socket (4) | Creating socket. | 2022-04-25 10:15:46.278
Socket (4) | New receive buffer size: 5242880 | 2022-04-25 10:15:46.278
Socket (4) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:46.278
HD Request # 65 | Receiving historical Daily data for GC-202206-NYMEX starting at 2022-04-20 | 2022-04-25 10:15:46.410
HD Request # 65 | Writing historical Daily data to the file GC-202206-NYMEX.dly | 2022-04-25 10:15:46.410
HD Request # 65 | Bytes received: 226 | 2022-04-25 10:15:46.422
HD Request # 65 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for GC-202206-NYMEX | 2022-04-25 10:15:46.422
HD Request # 65 | Completion time: 2s | 2022-04-25 10:15:46.422
HD Request # 65 | Daily data download complete for GC-202206-NYMEX. Unique request ID: 21 | 2022-04-25 10:15:46.422
Removing historical data download ID 21. | 2022-04-25 10:15:46.422
Triggering next historical data download in queue. | 2022-04-25 10:15:46.422
Mapping NG-202206-NYMEX to NGM22. Service code: nymex | 2022-04-25 10:15:46.422
HD Request # 69 | Downloading Historical Daily chart data for NG-202206-NYMEX. Starting date: 2022-04-20. Service: interactive_brokers.trading | 2022-04-25 10:15:46.424
Socket (2) | Socket gracefully closed by remote side. | 2022-04-25 10:15:46.503
Socket (2) | Closed. | 2022-04-25 10:15:46.503
GC-202206-NYMEX [C] 4 Day #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:15:46.583
GC-202206-NYMEX [C] 4 Day #5 | Reloading chart. | 2022-04-25 10:15:46.585
GC-202206-NYMEX [C] Daily #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:15:46.607
GC-202206-NYMEX [C] Daily #3 | Reloading chart. | 2022-04-25 10:15:46.608
GC-202206-NYMEX [C] 4 Day #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:15:46.644
GC-202206-NYMEX [C] 4 Day #4 | Reloading chart. | 2022-04-25 10:15:46.646
HD Request # 68 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:46.739
HD Request # 68 | Sending historical data logon request message. | 2022-04-25 10:15:46.739
GC-202206-NYMEX [C] 4 Day #5 | Reloading chart. | 2022-04-25 10:15:46.928
GC-202206-NYMEX [C] 4 Day #5 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:46.928
GC-202206-NYMEX [C] 4 Day #5 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:46.928
HD Request # 68 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:59. Record interval: 0. Symbol: PFE-NQTV | 2022-04-25 10:15:46.966
HD Request # 68 | Decompressing data. | 2022-04-25 10:15:47.194
HD Request # 68 | Receiving Intraday data for PFE-NQTV starting at 2022-04-25 10:12:59.513000 | 2022-04-25 10:15:47.194
Socket (4) | CloseSocket call. | 2022-04-25 10:15:47.195
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:47.195
Socket (4) | Socket gracefully closed by remote side. | 2022-04-25 10:15:47.422
Socket (4) | Closed. | 2022-04-25 10:15:47.422
GC-202206-NYMEX [C] 4 Day #5 | File GC-200102-NYMEX.dly has a volume of 0 at 2000-11-29. | 2022-04-25 10:15:48.795
GC-202206-NYMEX [C] 4 Day #5 | File GC-200012-NYMEX.dly has a volume of 0 at 2000-07-28. | 2022-04-25 10:15:48.813
GC-202206-NYMEX [C] 4 Day #5 | File GC-200012-NYMEX.dly has a volume of 0 at 2000-11-28. | 2022-04-25 10:15:48.813
GC-202206-NYMEX [C] 4 Day #5 | File GC-200008-NYMEX.dly has a volume of 0 at 2000-05-30. | 2022-04-25 10:15:48.823
GC-202206-NYMEX [C] 4 Day #5 | File GC-200008-NYMEX.dly has a volume of 0 at 2000-07-27. | 2022-04-25 10:15:48.823
GC-202206-NYMEX [C] 4 Day #5 | File GC-200006-NYMEX.dly has a volume of 0 at 2000-03-30. | 2022-04-25 10:15:48.834
GC-202206-NYMEX [C] 4 Day #5 | File GC-200006-NYMEX.dly has a volume of 0 at 2000-05-29. | 2022-04-25 10:15:48.834
GC-202206-NYMEX [C] 4 Day #5 | File GC-200004-NYMEX.dly has a volume of 0 at 2000-01-28. | 2022-04-25 10:15:48.845
GC-202206-NYMEX [C] 4 Day #5 | File GC-200004-NYMEX.dly has a volume of 0 at 2000-03-29. | 2022-04-25 10:15:48.845
GC-202206-NYMEX [C] 4 Day #5 | File GC-200002-NYMEX.dly has a volume of 0 at 1999-11-29. | 2022-04-25 10:15:48.855
GC-202206-NYMEX [C] 4 Day #5 | File GC-200002-NYMEX.dly has a volume of 0 at 2000-01-27. | 2022-04-25 10:15:48.855
GC-202206-NYMEX [C] 4 Day #5 | File GC-199912-NYMEX.dly has a volume of 0 at 1999-07-29. | 2022-04-25 10:15:48.872
GC-202206-NYMEX [C] 4 Day #5 | File GC-199912-NYMEX.dly has a volume of 0 at 1999-11-26. | 2022-04-25 10:15:48.872
GC-202206-NYMEX [C] 4 Day #5 | File GC-199908-NYMEX.dly has a volume of 0 at 1999-05-28. | 2022-04-25 10:15:48.883
GC-202206-NYMEX [C] 4 Day #5 | File GC-199908-NYMEX.dly has a volume of 0 at 1999-07-28. | 2022-04-25 10:15:48.883
GC-202206-NYMEX [C] 4 Day #5 | File GC-199906-NYMEX.dly has a volume of 0 at 1999-03-30. | 2022-04-25 10:15:48.893
GC-202206-NYMEX [C] 4 Day #5 | File GC-199906-NYMEX.dly has a volume of 0 at 1999-05-27. | 2022-04-25 10:15:48.893
GC-202206-NYMEX [C] 4 Day #5 | File GC-199904-NYMEX.dly has a volume of 0 at 1999-01-28. | 2022-04-25 10:15:48.904
GC-202206-NYMEX [C] 4 Day #5 | File GC-199904-NYMEX.dly has a volume of 0 at 1999-03-29. | 2022-04-25 10:15:48.904
GC-202206-NYMEX [C] 4 Day #5 | File GC-199902-NYMEX.dly has a volume of 0 at 1998-11-27. | 2022-04-25 10:15:48.914
GC-202206-NYMEX [C] 4 Day #5 | File GC-199902-NYMEX.dly has a volume of 0 at 1999-01-27. | 2022-04-25 10:15:48.914
Opened cached Intraday file: C:\SierraChart\Data\KO-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:15:48.926
Opened cached Intraday file: C:\SierraChart\Data\CALM-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:15:48.926
GC-202206-NYMEX [C] 4 Day #5 | File GC-199812-NYMEX.dly has a volume of 0 at 1998-07-30. | 2022-04-25 10:15:48.931
GC-202206-NYMEX [C] 4 Day #5 | File GC-199812-NYMEX.dly has a volume of 0 at 1998-11-26. | 2022-04-25 10:15:48.931
GC-202206-NYMEX [C] 4 Day #5 | File GC-199808-NYMEX.dly has a volume of 0 at 1998-05-28. | 2022-04-25 10:15:48.942
GC-202206-NYMEX [C] 4 Day #5 | File GC-199808-NYMEX.dly has a volume of 0 at 1998-07-29. | 2022-04-25 10:15:48.942
GC-202206-NYMEX [C] 4 Day #5 | File GC-199806-NYMEX.dly has a volume of 0 at 1998-03-30. | 2022-04-25 10:15:48.953
GC-202206-NYMEX [C] 4 Day #5 | File GC-199806-NYMEX.dly has a volume of 0 at 1998-05-27. | 2022-04-25 10:15:48.953
GC-202206-NYMEX [C] 4 Day #5 | File GC-199804-NYMEX.dly has a volume of 0 at 1998-01-29. | 2022-04-25 10:15:48.963
GC-202206-NYMEX [C] 4 Day #5 | File GC-199804-NYMEX.dly has a volume of 0 at 1998-03-27. | 2022-04-25 10:15:48.963
GC-202206-NYMEX [C] 4 Day #5 | File GC-199802-NYMEX.dly has a volume of 0 at 1997-11-27. | 2022-04-25 10:15:48.973
GC-202206-NYMEX [C] 4 Day #5 | File GC-199802-NYMEX.dly has a volume of 0 at 1998-01-28. | 2022-04-25 10:15:48.973
GC-202206-NYMEX [C] 4 Day #5 | File GC-199712-NYMEX.dly has a volume of 0 at 1997-07-30. | 2022-04-25 10:15:48.990
GC-202206-NYMEX [C] 4 Day #5 | File GC-199712-NYMEX.dly has a volume of 0 at 1997-11-26. | 2022-04-25 10:15:48.990
GC-202206-NYMEX [C] 4 Day #5 | File GC-199708-NYMEX.dly has a volume of 0 at 1997-05-29. | 2022-04-25 10:15:49.001
GC-202206-NYMEX [C] 4 Day #5 | File GC-199708-NYMEX.dly has a volume of 0 at 1997-07-29. | 2022-04-25 10:15:49.001
GC-202206-NYMEX [C] 4 Day #5 | File GC-199706-NYMEX.dly has a volume of 0 at 1997-03-28. | 2022-04-25 10:15:49.012
GC-202206-NYMEX [C] 4 Day #5 | File GC-199706-NYMEX.dly has a volume of 0 at 1997-05-28. | 2022-04-25 10:15:49.012
GC-202206-NYMEX [C] 4 Day #5 | File GC-199704-NYMEX.dly has a volume of 0 at 1997-01-30. | 2022-04-25 10:15:49.023
GC-202206-NYMEX [C] 4 Day #5 | File GC-199704-NYMEX.dly has a volume of 0 at 1997-03-27. | 2022-04-25 10:15:49.023
GC-202206-NYMEX [C] 4 Day #5 | File GC-199702-NYMEX.dly has a volume of 0 at 1996-11-28. | 2022-04-25 10:15:49.033
GC-202206-NYMEX [C] 4 Day #5 | File GC-199702-NYMEX.dly has a volume of 0 at 1997-01-29. | 2022-04-25 10:15:49.033
GC-202206-NYMEX [C] 4 Day #5 | File GC-199612-NYMEX.dly has a volume of 0 at 1996-07-30. | 2022-04-25 10:15:49.051
GC-202206-NYMEX [C] 4 Day #5 | File GC-199612-NYMEX.dly has a volume of 0 at 1996-11-27. | 2022-04-25 10:15:49.051
GC-202206-NYMEX [C] 4 Day #5 | File GC-199608-NYMEX.dly has a volume of 0 at 1996-05-30. | 2022-04-25 10:15:49.062
GC-202206-NYMEX [C] 4 Day #5 | File GC-199608-NYMEX.dly has a volume of 0 at 1996-07-29. | 2022-04-25 10:15:49.062
GC-202206-NYMEX [C] 4 Day #5 | File GC-199606-NYMEX.dly has a volume of 0 at 1996-03-28. | 2022-04-25 10:15:49.073
GC-202206-NYMEX [C] 4 Day #5 | File GC-199606-NYMEX.dly has a volume of 0 at 1996-05-29. | 2022-04-25 10:15:49.073
GC-202206-NYMEX [C] 4 Day #5 | File GC-199604-NYMEX.dly has a volume of 0 at 1996-01-30. | 2022-04-25 10:15:49.084
GC-202206-NYMEX [C] 4 Day #5 | File GC-199604-NYMEX.dly has a volume of 0 at 1996-03-27. | 2022-04-25 10:15:49.084
GC-202206-NYMEX [C] 4 Day #5 | File GC-199602-NYMEX.dly has a volume of 0 at 1995-11-29. | 2022-04-25 10:15:49.094
GC-202206-NYMEX [C] 4 Day #5 | File GC-199602-NYMEX.dly has a volume of 0 at 1996-01-29. | 2022-04-25 10:15:49.094
GC-202206-NYMEX [C] 4 Day #5 | File GC-199512-NYMEX.dly has a volume of 0 at 1995-07-28. | 2022-04-25 10:15:49.111
GC-202206-NYMEX [C] 4 Day #5 | File GC-199512-NYMEX.dly has a volume of 0 at 1995-11-28. | 2022-04-25 10:15:49.111
GC-202206-NYMEX [C] 4 Day #5 | File GC-199508-NYMEX.dly has a volume of 0 at 1995-05-30. | 2022-04-25 10:15:49.122
GC-202206-NYMEX [C] 4 Day #5 | File GC-199508-NYMEX.dly has a volume of 0 at 1995-07-27. | 2022-04-25 10:15:49.122
GC-202206-NYMEX [C] 4 Day #5 | File GC-199506-NYMEX.dly has a volume of 0 at 1995-03-30. | 2022-04-25 10:15:49.133
GC-202206-NYMEX [C] 4 Day #5 | File GC-199506-NYMEX.dly has a volume of 0 at 1995-05-29. | 2022-04-25 10:15:49.133
GC-202206-NYMEX [C] 4 Day #5 | File GC-199504-NYMEX.dly has a volume of 0 at 1995-01-30. | 2022-04-25 10:15:49.143
GC-202206-NYMEX [C] 4 Day #5 | File GC-199504-NYMEX.dly has a volume of 0 at 1995-03-29. | 2022-04-25 10:15:49.143
GC-202206-NYMEX [C] 4 Day #5 | File GC-199502-NYMEX.dly has a volume of 0 at 1994-11-29. | 2022-04-25 10:15:49.154
GC-202206-NYMEX [C] 4 Day #5 | File GC-199502-NYMEX.dly has a volume of 0 at 1995-01-27. | 2022-04-25 10:15:49.154
GC-202206-NYMEX [C] 4 Day #5 | File GC-199412-NYMEX.dly has a volume of 0 at 1994-07-28. | 2022-04-25 10:15:49.171
GC-202206-NYMEX [C] 4 Day #5 | File GC-199412-NYMEX.dly has a volume of 0 at 1994-11-28. | 2022-04-25 10:15:49.171
GC-202206-NYMEX [C] 4 Day #5 | File GC-199408-NYMEX.dly has a volume of 0 at 1994-05-30. | 2022-04-25 10:15:49.182
GC-202206-NYMEX [C] 4 Day #5 | File GC-199408-NYMEX.dly has a volume of 0 at 1994-07-27. | 2022-04-25 10:15:49.182
GC-202206-NYMEX [C] 4 Day #5 | File GC-199406-NYMEX.dly has a volume of 0 at 1994-03-30. | 2022-04-25 10:15:49.192
GC-202206-NYMEX [C] 4 Day #5 | File GC-199406-NYMEX.dly has a volume of 0 at 1994-05-27. | 2022-04-25 10:15:49.192
GC-202206-NYMEX [C] 4 Day #5 | File GC-199404-NYMEX.dly has a volume of 0 at 1994-01-28. | 2022-04-25 10:15:49.202
GC-202206-NYMEX [C] 4 Day #5 | File GC-199404-NYMEX.dly has a volume of 0 at 1994-03-29. | 2022-04-25 10:15:49.202
GC-202206-NYMEX [C] 4 Day #5 | File GC-199402-NYMEX.dly has a volume of 0 at 1993-11-29. | 2022-04-25 10:15:49.213
GC-202206-NYMEX [C] 4 Day #5 | File GC-199402-NYMEX.dly has a volume of 0 at 1994-01-27. | 2022-04-25 10:15:49.213
GC-202206-NYMEX [C] 4 Day #5 | File GC-199312-NYMEX.dly has a volume of 0 at 1993-07-29. | 2022-04-25 10:15:49.230
GC-202206-NYMEX [C] 4 Day #5 | File GC-199312-NYMEX.dly has a volume of 0 at 1993-11-26. | 2022-04-25 10:15:49.230
GC-202206-NYMEX [C] 4 Day #5 | File GC-199308-NYMEX.dly has a volume of 0 at 1993-05-28. | 2022-04-25 10:15:49.241
GC-202206-NYMEX [C] 4 Day #5 | File GC-199308-NYMEX.dly has a volume of 0 at 1993-07-28. | 2022-04-25 10:15:49.241
GC-202206-NYMEX [C] 4 Day #5 | File GC-199306-NYMEX.dly has a volume of 0 at 1993-03-30. | 2022-04-25 10:15:49.252
GC-202206-NYMEX [C] 4 Day #5 | File GC-199306-NYMEX.dly has a volume of 0 at 1993-05-27. | 2022-04-25 10:15:49.252
GC-202206-NYMEX [C] 4 Day #5 | File GC-199304-NYMEX.dly has a volume of 0 at 1993-01-28. | 2022-04-25 10:15:49.263
GC-202206-NYMEX [C] 4 Day #5 | File GC-199304-NYMEX.dly has a volume of 0 at 1993-03-29. | 2022-04-25 10:15:49.263
GC-202206-NYMEX [C] 4 Day #5 | File GC-199302-NYMEX.dly has a volume of 0 at 1992-11-27. | 2022-04-25 10:15:49.273
GC-202206-NYMEX [C] 4 Day #5 | File GC-199302-NYMEX.dly has a volume of 0 at 1993-01-27. | 2022-04-25 10:15:49.273
GC-202206-NYMEX [C] 4 Day #5 | File GC-199212-NYMEX.dly has a volume of 0 at 1992-07-30. | 2022-04-25 10:15:49.290
GC-202206-NYMEX [C] 4 Day #5 | File GC-199212-NYMEX.dly has a volume of 0 at 1992-11-26. | 2022-04-25 10:15:49.290
GC-202206-NYMEX [C] 4 Day #5 | File GC-199208-NYMEX.dly has a volume of 0 at 1992-05-28. | 2022-04-25 10:15:49.301
GC-202206-NYMEX [C] 4 Day #5 | File GC-199208-NYMEX.dly has a volume of 0 at 1992-07-29. | 2022-04-25 10:15:49.301
GC-202206-NYMEX [C] 4 Day #5 | File GC-199206-NYMEX.dly has a volume of 0 at 1992-03-30. | 2022-04-25 10:15:49.312
GC-202206-NYMEX [C] 4 Day #5 | File GC-199206-NYMEX.dly has a volume of 0 at 1992-05-27. | 2022-04-25 10:15:49.312
GC-202206-NYMEX [C] 4 Day #5 | File GC-199204-NYMEX.dly has a volume of 0 at 1992-01-30. | 2022-04-25 10:15:49.322
GC-202206-NYMEX [C] 4 Day #5 | File GC-199204-NYMEX.dly has a volume of 0 at 1992-03-27. | 2022-04-25 10:15:49.322
GC-202206-NYMEX [C] 4 Day #5 | File GC-199202-NYMEX.dly has a volume of 0 at 1991-11-28. | 2022-04-25 10:15:49.333
GC-202206-NYMEX [C] 4 Day #5 | File GC-199202-NYMEX.dly has a volume of 0 at 1992-01-29. | 2022-04-25 10:15:49.333
GC-202206-NYMEX [C] 4 Day #5 | File GC-199112-NYMEX.dly has a volume of 0 at 1991-07-30. | 2022-04-25 10:15:49.350
GC-202206-NYMEX [C] 4 Day #5 | File GC-199112-NYMEX.dly has a volume of 0 at 1991-11-27. | 2022-04-25 10:15:49.350
GC-202206-NYMEX [C] 4 Day #5 | File GC-199108-NYMEX.dly has a volume of 0 at 1991-05-30. | 2022-04-25 10:15:49.360
GC-202206-NYMEX [C] 4 Day #5 | File GC-199108-NYMEX.dly has a volume of 0 at 1991-07-29. | 2022-04-25 10:15:49.360
GC-202206-NYMEX [C] 4 Day #5 | File GC-199106-NYMEX.dly has a volume of 0 at 1991-03-28. | 2022-04-25 10:15:49.371
GC-202206-NYMEX [C] 4 Day #5 | File GC-199106-NYMEX.dly has a volume of 0 at 1991-05-29. | 2022-04-25 10:15:49.371
GC-202206-NYMEX [C] 4 Day #5 | File GC-199104-NYMEX.dly has a volume of 0 at 1991-01-30. | 2022-04-25 10:15:49.381
GC-202206-NYMEX [C] 4 Day #5 | File GC-199104-NYMEX.dly has a volume of 0 at 1991-03-27. | 2022-04-25 10:15:49.381
GC-202206-NYMEX [C] 4 Day #5 | File GC-199102-NYMEX.dly has a volume of 0 at 1990-11-29. | 2022-04-25 10:15:49.391
GC-202206-NYMEX [C] 4 Day #5 | File GC-199102-NYMEX.dly has a volume of 0 at 1991-01-29. | 2022-04-25 10:15:49.391
GC-202206-NYMEX [C] 4 Day #5 | File GC-199012-NYMEX.dly has a volume of 0 at 1990-07-30. | 2022-04-25 10:15:49.408
GC-202206-NYMEX [C] 4 Day #5 | File GC-199012-NYMEX.dly has a volume of 0 at 1990-11-28. | 2022-04-25 10:15:49.408
GC-202206-NYMEX [C] 4 Day #5 | File GC-199008-NYMEX.dly has a volume of 0 at 1990-05-30. | 2022-04-25 10:15:49.419
GC-202206-NYMEX [C] 4 Day #5 | File GC-199008-NYMEX.dly has a volume of 0 at 1990-07-27. | 2022-04-25 10:15:49.419
GC-202206-NYMEX [C] 4 Day #5 | File GC-199006-NYMEX.dly has a volume of 0 at 1990-03-29. | 2022-04-25 10:15:49.430
GC-202206-NYMEX [C] 4 Day #5 | File GC-199006-NYMEX.dly has a volume of 0 at 1990-05-29. | 2022-04-25 10:15:49.430
GC-202206-NYMEX [C] 4 Day #5 | File GC-199004-NYMEX.dly has a volume of 0 at 1990-01-30. | 2022-04-25 10:15:49.440
GC-202206-NYMEX [C] 4 Day #5 | File GC-199004-NYMEX.dly has a volume of 0 at 1990-03-28. | 2022-04-25 10:15:49.440
GC-202206-NYMEX [C] 4 Day #5 | File GC-199002-NYMEX.dly has a volume of 0 at 1989-11-29. | 2022-04-25 10:15:49.450
GC-202206-NYMEX [C] 4 Day #5 | File GC-199002-NYMEX.dly has a volume of 0 at 1990-01-29. | 2022-04-25 10:15:49.450
GC-202206-NYMEX [C] 4 Day #5 | File GC-198912-NYMEX.dly has a volume of 0 at 1989-07-28. | 2022-04-25 10:15:49.467
GC-202206-NYMEX [C] 4 Day #5 | File GC-198912-NYMEX.dly has a volume of 0 at 1989-11-28. | 2022-04-25 10:15:49.467
GC-202206-NYMEX [C] 4 Day #5 | File GC-198908-NYMEX.dly has a volume of 0 at 1989-05-30. | 2022-04-25 10:15:49.478
GC-202206-NYMEX [C] 4 Day #5 | File GC-198908-NYMEX.dly has a volume of 0 at 1989-07-27. | 2022-04-25 10:15:49.478
GC-202206-NYMEX [C] 4 Day #5 | File GC-198906-NYMEX.dly has a volume of 0 at 1989-03-30. | 2022-04-25 10:15:49.489
GC-202206-NYMEX [C] 4 Day #5 | File GC-198906-NYMEX.dly has a volume of 0 at 1989-05-29. | 2022-04-25 10:15:49.489
GC-202206-NYMEX [C] 4 Day #5 | File GC-198904-NYMEX.dly has a volume of 0 at 1989-01-30. | 2022-04-25 10:15:49.499
GC-202206-NYMEX [C] 4 Day #5 | File GC-198904-NYMEX.dly has a volume of 0 at 1989-03-29. | 2022-04-25 10:15:49.499
GC-202206-NYMEX [C] 4 Day #5 | File GC-198902-NYMEX.dly has a volume of 0 at 1988-11-29. | 2022-04-25 10:15:49.509
GC-202206-NYMEX [C] 4 Day #5 | File GC-198902-NYMEX.dly has a volume of 0 at 1989-01-27. | 2022-04-25 10:15:49.509
GC-202206-NYMEX [C] 4 Day #5 | File GC-198812-NYMEX.dly has a volume of 0 at 1988-07-28. | 2022-04-25 10:15:49.527
GC-202206-NYMEX [C] 4 Day #5 | File GC-198812-NYMEX.dly has a volume of 0 at 1988-11-28. | 2022-04-25 10:15:49.527
GC-202206-NYMEX [C] 4 Day #5 | File GC-198808-NYMEX.dly has a volume of 0 at 1988-05-30. | 2022-04-25 10:15:49.537
GC-202206-NYMEX [C] 4 Day #5 | File GC-198808-NYMEX.dly has a volume of 0 at 1988-07-27. | 2022-04-25 10:15:49.537
GC-202206-NYMEX [C] 4 Day #5 | File GC-198806-NYMEX.dly has a volume of 0 at 1988-03-30. | 2022-04-25 10:15:49.548
GC-202206-NYMEX [C] 4 Day #5 | File GC-198806-NYMEX.dly has a volume of 0 at 1988-05-27. | 2022-04-25 10:15:49.548
GC-202206-NYMEX [C] 4 Day #5 | File GC-198804-NYMEX.dly has a volume of 0 at 1988-01-28. | 2022-04-25 10:15:49.559
GC-202206-NYMEX [C] 4 Day #5 | File GC-198804-NYMEX.dly has a volume of 0 at 1988-03-29. | 2022-04-25 10:15:49.559
GC-202206-NYMEX [C] 4 Day #5 | File GC-198802-NYMEX.dly has a volume of 0 at 1987-11-27. | 2022-04-25 10:15:49.569
GC-202206-NYMEX [C] 4 Day #5 | File GC-198802-NYMEX.dly has a volume of 0 at 1988-01-27. | 2022-04-25 10:15:49.569
GC-202206-NYMEX [C] 4 Day #5 | File GC-198712-NYMEX.dly has a volume of 0 at 1987-07-30. | 2022-04-25 10:15:49.586
GC-202206-NYMEX [C] 4 Day #5 | File GC-198712-NYMEX.dly has a volume of 0 at 1987-11-26. | 2022-04-25 10:15:49.586
GC-202206-NYMEX [C] 4 Day #5 | File GC-198708-NYMEX.dly has a volume of 0 at 1987-05-28. | 2022-04-25 10:15:49.597
GC-202206-NYMEX [C] 4 Day #5 | File GC-198708-NYMEX.dly has a volume of 0 at 1987-07-29. | 2022-04-25 10:15:49.597
GC-202206-NYMEX [C] 4 Day #5 | File GC-198706-NYMEX.dly has a volume of 0 at 1987-03-30. | 2022-04-25 10:15:49.607
GC-202206-NYMEX [C] 4 Day #5 | File GC-198706-NYMEX.dly has a volume of 0 at 1987-05-27. | 2022-04-25 10:15:49.607
GC-202206-NYMEX [C] 4 Day #5 | File GC-198704-NYMEX.dly has a volume of 0 at 1987-01-29. | 2022-04-25 10:15:49.618
GC-202206-NYMEX [C] 4 Day #5 | File GC-198704-NYMEX.dly has a volume of 0 at 1987-03-27. | 2022-04-25 10:15:49.618
GC-202206-NYMEX [C] 4 Day #5 | File GC-198702-NYMEX.dly has a volume of 0 at 1986-11-27. | 2022-04-25 10:15:49.628
GC-202206-NYMEX [C] 4 Day #5 | File GC-198702-NYMEX.dly has a volume of 0 at 1987-01-28. | 2022-04-25 10:15:49.628
GC-202206-NYMEX [C] 4 Day #5 | File GC-198612-NYMEX.dly has a volume of 0 at 1986-07-30. | 2022-04-25 10:15:49.645
GC-202206-NYMEX [C] 4 Day #5 | File GC-198612-NYMEX.dly has a volume of 0 at 1986-11-26. | 2022-04-25 10:15:49.645
GC-202206-NYMEX [C] 4 Day #5 | File GC-198608-NYMEX.dly has a volume of 0 at 1986-05-29. | 2022-04-25 10:15:49.656
GC-202206-NYMEX [C] 4 Day #5 | File GC-198608-NYMEX.dly has a volume of 0 at 1986-07-29. | 2022-04-25 10:15:49.656
GC-202206-NYMEX [C] 4 Day #5 | File GC-198606-NYMEX.dly has a volume of 0 at 1986-03-28. | 2022-04-25 10:15:49.667
GC-202206-NYMEX [C] 4 Day #5 | File GC-198606-NYMEX.dly has a volume of 0 at 1986-05-28. | 2022-04-25 10:15:49.667
GC-202206-NYMEX [C] 4 Day #5 | File GC-198604-NYMEX.dly has a volume of 0 at 1986-01-30. | 2022-04-25 10:15:49.677
GC-202206-NYMEX [C] 4 Day #5 | File GC-198604-NYMEX.dly has a volume of 0 at 1986-03-27. | 2022-04-25 10:15:49.677
GC-202206-NYMEX [C] 4 Day #5 | File GC-198602-NYMEX.dly has a volume of 0 at 1985-11-28. | 2022-04-25 10:15:49.687
GC-202206-NYMEX [C] 4 Day #5 | File GC-198602-NYMEX.dly has a volume of 0 at 1986-01-29. | 2022-04-25 10:15:49.687
GC-202206-NYMEX [C] 4 Day #5 | File GC-198512-NYMEX.dly has a volume of 0 at 1985-07-30. | 2022-04-25 10:15:49.704
GC-202206-NYMEX [C] 4 Day #5 | File GC-198512-NYMEX.dly has a volume of 0 at 1985-11-27. | 2022-04-25 10:15:49.704
GC-202206-NYMEX [C] 4 Day #5 | File GC-198508-NYMEX.dly has a volume of 0 at 1985-05-30. | 2022-04-25 10:15:49.715
GC-202206-NYMEX [C] 4 Day #5 | File GC-198508-NYMEX.dly has a volume of 0 at 1985-07-29. | 2022-04-25 10:15:49.715
GC-202206-NYMEX [C] 4 Day #5 | File GC-198506-NYMEX.dly has a volume of 0 at 1985-03-28. | 2022-04-25 10:15:49.726
GC-202206-NYMEX [C] 4 Day #5 | File GC-198506-NYMEX.dly has a volume of 0 at 1985-05-29. | 2022-04-25 10:15:49.726
GC-202206-NYMEX [C] 4 Day #5 | File GC-198504-NYMEX.dly has a volume of 0 at 1985-01-30. | 2022-04-25 10:15:49.736
GC-202206-NYMEX [C] 4 Day #5 | File GC-198504-NYMEX.dly has a volume of 0 at 1985-03-27. | 2022-04-25 10:15:49.736
GC-202206-NYMEX [C] 4 Day #5 | File GC-198502-NYMEX.dly has a volume of 0 at 1984-11-29. | 2022-04-25 10:15:49.746
GC-202206-NYMEX [C] 4 Day #5 | File GC-198502-NYMEX.dly has a volume of 0 at 1985-01-29. | 2022-04-25 10:15:49.746
GC-202206-NYMEX [C] 4 Day #5 | File GC-198412-NYMEX.dly has a volume of 0 at 1984-07-30. | 2022-04-25 10:15:49.763
GC-202206-NYMEX [C] 4 Day #5 | File GC-198412-NYMEX.dly has a volume of 0 at 1984-11-28. | 2022-04-25 10:15:49.763
GC-202206-NYMEX [C] 4 Day #5 | File GC-198408-NYMEX.dly has a volume of 0 at 1984-05-30. | 2022-04-25 10:15:49.774
GC-202206-NYMEX [C] 4 Day #5 | File GC-198408-NYMEX.dly has a volume of 0 at 1984-07-27. | 2022-04-25 10:15:49.774
GC-202206-NYMEX [C] 4 Day #5 | File GC-198406-NYMEX.dly has a volume of 0 at 1984-03-29. | 2022-04-25 10:15:49.784
GC-202206-NYMEX [C] 4 Day #5 | File GC-198406-NYMEX.dly has a volume of 0 at 1984-05-29. | 2022-04-25 10:15:49.784
GC-202206-NYMEX [C] 4 Day #5 | File GC-198404-NYMEX.dly has a volume of 0 at 1984-01-30. | 2022-04-25 10:15:49.796
GC-202206-NYMEX [C] 4 Day #5 | File GC-198404-NYMEX.dly has a volume of 0 at 1984-03-28. | 2022-04-25 10:15:49.796
GC-202206-NYMEX [C] 4 Day #5 | File GC-198402-NYMEX.dly has a volume of 0 at 1983-11-29. | 2022-04-25 10:15:49.807
GC-202206-NYMEX [C] 4 Day #5 | File GC-198402-NYMEX.dly has a volume of 0 at 1984-01-27. | 2022-04-25 10:15:49.807
GC-202206-NYMEX [C] 4 Day #5 | File GC-198312-NYMEX.dly has a volume of 0 at 1983-07-28. | 2022-04-25 10:15:49.824
GC-202206-NYMEX [C] 4 Day #5 | File GC-198312-NYMEX.dly has a volume of 0 at 1983-11-28. | 2022-04-25 10:15:49.824
GC-202206-NYMEX [C] 4 Day #5 | File GC-198308-NYMEX.dly has a volume of 0 at 1983-05-30. | 2022-04-25 10:15:49.836
GC-202206-NYMEX [C] 4 Day #5 | File GC-198308-NYMEX.dly has a volume of 0 at 1983-07-27. | 2022-04-25 10:15:49.836
GC-202206-NYMEX [C] 4 Day #5 | File GC-198306-NYMEX.dly has a volume of 0 at 1983-03-30. | 2022-04-25 10:15:49.846
GC-202206-NYMEX [C] 4 Day #5 | File GC-198306-NYMEX.dly has a volume of 0 at 1983-05-27. | 2022-04-25 10:15:49.846
GC-202206-NYMEX [C] 4 Day #5 | File GC-198304-NYMEX.dly has a volume of 0 at 1983-01-28. | 2022-04-25 10:15:49.856
GC-202206-NYMEX [C] 4 Day #5 | File GC-198304-NYMEX.dly has a volume of 0 at 1983-03-29. | 2022-04-25 10:15:49.856
GC-202206-NYMEX [C] 4 Day #5 | File GC-198302-NYMEX.dly has a volume of 0 at 1982-11-29. | 2022-04-25 10:15:49.866
GC-202206-NYMEX [C] 4 Day #5 | File GC-198302-NYMEX.dly has a volume of 0 at 1983-01-27. | 2022-04-25 10:15:49.866
GC-202206-NYMEX [C] 4 Day #5 | File GC-198212-NYMEX.dly has a volume of 0 at 1982-07-29. | 2022-04-25 10:15:49.883
GC-202206-NYMEX [C] 4 Day #5 | File GC-198212-NYMEX.dly has a volume of 0 at 1982-11-26. | 2022-04-25 10:15:49.883
GC-202206-NYMEX [C] 4 Day #5 | File GC-198208-NYMEX.dly has a volume of 0 at 1982-05-28. | 2022-04-25 10:15:49.894
GC-202206-NYMEX [C] 4 Day #5 | File GC-198208-NYMEX.dly has a volume of 0 at 1982-07-28. | 2022-04-25 10:15:49.894
GC-202206-NYMEX [C] 4 Day #5 | File GC-198206-NYMEX.dly has a volume of 0 at 1982-03-30. | 2022-04-25 10:15:49.905
GC-202206-NYMEX [C] 4 Day #5 | File GC-198206-NYMEX.dly has a volume of 0 at 1982-05-27. | 2022-04-25 10:15:49.905
GC-202206-NYMEX [C] 4 Day #5 | File GC-198204-NYMEX.dly has a volume of 0 at 1982-01-28. | 2022-04-25 10:15:49.915
GC-202206-NYMEX [C] 4 Day #5 | File GC-198204-NYMEX.dly has a volume of 0 at 1982-03-29. | 2022-04-25 10:15:49.915
GC-202206-NYMEX [C] 4 Day #5 | File GC-198202-NYMEX.dly has a volume of 0 at 1981-11-27. | 2022-04-25 10:15:49.925
GC-202206-NYMEX [C] 4 Day #5 | File GC-198202-NYMEX.dly has a volume of 0 at 1982-01-27. | 2022-04-25 10:15:49.925
GC-202206-NYMEX [C] 4 Day #5 | File GC-198112-NYMEX.dly has a volume of 0 at 1981-07-30. | 2022-04-25 10:15:49.942
GC-202206-NYMEX [C] 4 Day #5 | File GC-198112-NYMEX.dly has a volume of 0 at 1981-11-26. | 2022-04-25 10:15:49.942
GC-202206-NYMEX [C] 4 Day #5 | File GC-198108-NYMEX.dly has a volume of 0 at 1981-05-28. | 2022-04-25 10:15:49.953
GC-202206-NYMEX [C] 4 Day #5 | File GC-198108-NYMEX.dly has a volume of 0 at 1981-07-29. | 2022-04-25 10:15:49.953
GC-202206-NYMEX [C] 4 Day #5 | File GC-198106-NYMEX.dly has a volume of 0 at 1981-03-30. | 2022-04-25 10:15:49.963
GC-202206-NYMEX [C] 4 Day #5 | File GC-198106-NYMEX.dly has a volume of 0 at 1981-05-27. | 2022-04-25 10:15:49.963
GC-202206-NYMEX [C] 4 Day #5 | File GC-198104-NYMEX.dly has a volume of 0 at 1981-01-29. | 2022-04-25 10:15:49.974
GC-202206-NYMEX [C] 4 Day #5 | File GC-198104-NYMEX.dly has a volume of 0 at 1981-03-27. | 2022-04-25 10:15:49.974
GC-202206-NYMEX [C] 4 Day #5 | File GC-198102-NYMEX.dly has a volume of 0 at 1980-11-27. | 2022-04-25 10:15:49.984
GC-202206-NYMEX [C] 4 Day #5 | File GC-198102-NYMEX.dly has a volume of 0 at 1981-01-28. | 2022-04-25 10:15:49.984
GC-202206-NYMEX [C] 4 Day #5 | File GC-198012-NYMEX.dly has a volume of 0 at 1980-07-30. | 2022-04-25 10:15:50.001
GC-202206-NYMEX [C] 4 Day #5 | File GC-198012-NYMEX.dly has a volume of 0 at 1980-11-26. | 2022-04-25 10:15:50.001
GC-202206-NYMEX [C] 4 Day #5 | File GC-198008-NYMEX.dly has a volume of 0 at 1980-05-29. | 2022-04-25 10:15:50.011
GC-202206-NYMEX [C] 4 Day #5 | File GC-198008-NYMEX.dly has a volume of 0 at 1980-07-29. | 2022-04-25 10:15:50.011
GC-202206-NYMEX [C] 4 Day #5 | File GC-198006-NYMEX.dly has a volume of 0 at 1980-03-28. | 2022-04-25 10:15:50.022
GC-202206-NYMEX [C] 4 Day #5 | File GC-198006-NYMEX.dly has a volume of 0 at 1980-05-28. | 2022-04-25 10:15:50.022
GC-202206-NYMEX [C] 4 Day #5 | File GC-198004-NYMEX.dly has a volume of 0 at 1980-01-30. | 2022-04-25 10:15:50.032
GC-202206-NYMEX [C] 4 Day #5 | File GC-198004-NYMEX.dly has a volume of 0 at 1980-03-27. | 2022-04-25 10:15:50.032
GC-202206-NYMEX [C] 4 Day #5 | File GC-198002-NYMEX.dly has a volume of 0 at 1979-11-29. | 2022-04-25 10:15:50.042
GC-202206-NYMEX [C] 4 Day #5 | File GC-198002-NYMEX.dly has a volume of 0 at 1980-01-29. | 2022-04-25 10:15:50.042
GC-202206-NYMEX [C] 4 Day #5 | File GC-197912-NYMEX.dly has a volume of 0 at 1979-07-30. | 2022-04-25 10:15:50.059
GC-202206-NYMEX [C] 4 Day #5 | File GC-197912-NYMEX.dly has a volume of 0 at 1979-11-28. | 2022-04-25 10:15:50.059
GC-202206-NYMEX [C] 4 Day #5 | File GC-197908-NYMEX.dly has a volume of 0 at 1979-05-30. | 2022-04-25 10:15:50.070
GC-202206-NYMEX [C] 4 Day #5 | File GC-197908-NYMEX.dly has a volume of 0 at 1979-07-27. | 2022-04-25 10:15:50.070
GC-202206-NYMEX [C] 4 Day #5 | File GC-197906-NYMEX.dly has a volume of 0 at 1979-03-29. | 2022-04-25 10:15:50.081
GC-202206-NYMEX [C] 4 Day #5 | File GC-197906-NYMEX.dly has a volume of 0 at 1979-05-29. | 2022-04-25 10:15:50.081
GC-202206-NYMEX [C] 4 Day #5 | File GC-197904-NYMEX.dly has a volume of 0 at 1979-01-30. | 2022-04-25 10:15:50.090
GC-202206-NYMEX [C] 4 Day #5 | File GC-197904-NYMEX.dly has a volume of 0 at 1979-03-28. | 2022-04-25 10:15:50.090
GC-202206-NYMEX [C] 4 Day #5 | File GC-197902-NYMEX.dly has a volume of 0 at 1978-11-29. | 2022-04-25 10:15:50.101
GC-202206-NYMEX [C] 4 Day #5 | File GC-197902-NYMEX.dly has a volume of 0 at 1979-01-29. | 2022-04-25 10:15:50.101
GC-202206-NYMEX [C] 4 Day #5 | File GC-197812-NYMEX.dly has a volume of 0 at 1978-07-28. | 2022-04-25 10:15:50.117
GC-202206-NYMEX [C] 4 Day #5 | File GC-197812-NYMEX.dly has a volume of 0 at 1978-11-28. | 2022-04-25 10:15:50.117
GC-202206-NYMEX [C] 4 Day #5 | File GC-197808-NYMEX.dly has a volume of 0 at 1978-05-30. | 2022-04-25 10:15:50.128
GC-202206-NYMEX [C] 4 Day #5 | File GC-197808-NYMEX.dly has a volume of 0 at 1978-07-27. | 2022-04-25 10:15:50.128
GC-202206-NYMEX [C] 4 Day #5 | File GC-197806-NYMEX.dly has a volume of 0 at 1978-03-30. | 2022-04-25 10:15:50.139
GC-202206-NYMEX [C] 4 Day #5 | File GC-197806-NYMEX.dly has a volume of 0 at 1978-05-29. | 2022-04-25 10:15:50.139
GC-202206-NYMEX [C] 4 Day #5 | File GC-197804-NYMEX.dly has a volume of 0 at 1978-01-30. | 2022-04-25 10:15:50.149
GC-202206-NYMEX [C] 4 Day #5 | File GC-197804-NYMEX.dly has a volume of 0 at 1978-03-29. | 2022-04-25 10:15:50.149
GC-202206-NYMEX [C] 4 Day #5 | File GC-197802-NYMEX.dly has a volume of 0 at 1977-11-29. | 2022-04-25 10:15:50.159
GC-202206-NYMEX [C] 4 Day #5 | File GC-197802-NYMEX.dly has a volume of 0 at 1978-01-27. | 2022-04-25 10:15:50.159
GC-202206-NYMEX [C] 4 Day #5 | File GC-197712-NYMEX.dly has a volume of 0 at 1977-07-28. | 2022-04-25 10:15:50.176
GC-202206-NYMEX [C] 4 Day #5 | File GC-197712-NYMEX.dly has a volume of 0 at 1977-11-28. | 2022-04-25 10:15:50.176
GC-202206-NYMEX [C] 4 Day #5 | File GC-197708-NYMEX.dly has a volume of 0 at 1977-05-30. | 2022-04-25 10:15:50.187
GC-202206-NYMEX [C] 4 Day #5 | File GC-197708-NYMEX.dly has a volume of 0 at 1977-07-27. | 2022-04-25 10:15:50.187
GC-202206-NYMEX [C] 4 Day #5 | File GC-197706-NYMEX.dly has a volume of 0 at 1977-03-30. | 2022-04-25 10:15:50.197
GC-202206-NYMEX [C] 4 Day #5 | File GC-197706-NYMEX.dly has a volume of 0 at 1977-05-27. | 2022-04-25 10:15:50.197
GC-202206-NYMEX [C] 4 Day #5 | File GC-197704-NYMEX.dly has a volume of 0 at 1977-01-28. | 2022-04-25 10:15:50.208
GC-202206-NYMEX [C] 4 Day #5 | File GC-197704-NYMEX.dly has a volume of 0 at 1977-03-29. | 2022-04-25 10:15:50.208
GC-202206-NYMEX [C] 4 Day #5 | File GC-197702-NYMEX.dly has a volume of 0 at 1976-11-29. | 2022-04-25 10:15:50.218
GC-202206-NYMEX [C] 4 Day #5 | File GC-197702-NYMEX.dly has a volume of 0 at 1977-01-27. | 2022-04-25 10:15:50.218
GC-202206-NYMEX [C] 4 Day #5 | File GC-197612-NYMEX.dly has a volume of 0 at 1976-07-29. | 2022-04-25 10:15:50.235
GC-202206-NYMEX [C] 4 Day #5 | File GC-197612-NYMEX.dly has a volume of 0 at 1976-11-26. | 2022-04-25 10:15:50.235
GC-202206-NYMEX [C] 4 Day #5 | File GC-197608-NYMEX.dly has a volume of 0 at 1976-05-28. | 2022-04-25 10:15:50.245
GC-202206-NYMEX [C] 4 Day #5 | File GC-197608-NYMEX.dly has a volume of 0 at 1976-07-28. | 2022-04-25 10:15:50.245
GC-202206-NYMEX [C] 4 Day #5 | File GC-197606-NYMEX.dly has a volume of 0 at 1976-03-30. | 2022-04-25 10:15:50.256
GC-202206-NYMEX [C] 4 Day #5 | File GC-197606-NYMEX.dly has a volume of 0 at 1976-05-27. | 2022-04-25 10:15:50.256
GC-202206-NYMEX [C] 4 Day #5 | File GC-197604-NYMEX.dly has a volume of 0 at 1976-01-29. | 2022-04-25 10:15:50.266
GC-202206-NYMEX [C] 4 Day #5 | File GC-197604-NYMEX.dly has a volume of 0 at 1976-03-29. | 2022-04-25 10:15:50.266
GC-202206-NYMEX [C] 4 Day #5 | File GC-197602-NYMEX.dly has a volume of 0 at 1975-11-27. | 2022-04-25 10:15:50.277
GC-202206-NYMEX [C] 4 Day #5 | File GC-197602-NYMEX.dly has a volume of 0 at 1976-01-28. | 2022-04-25 10:15:50.277
GC-202206-NYMEX [C] 4 Day #5 | File GC-197512-NYMEX.dly has a volume of 0 at 1975-07-30. | 2022-04-25 10:15:50.293
GC-202206-NYMEX [C] 4 Day #5 | File GC-197512-NYMEX.dly has a volume of 0 at 1975-11-26. | 2022-04-25 10:15:50.293
GC-202206-NYMEX [C] 4 Day #5 | File GC-197508-NYMEX.dly has a volume of 0 at 1975-05-29. | 2022-04-25 10:15:50.304
GC-202206-NYMEX [C] 4 Day #5 | File GC-197508-NYMEX.dly has a volume of 0 at 1975-07-29. | 2022-04-25 10:15:50.304
GC-202206-NYMEX [C] 4 Day #5 | File GC-197506-NYMEX.dly has a volume of 0 at 1975-03-28. | 2022-04-25 10:15:50.315
GC-202206-NYMEX [C] 4 Day #5 | File GC-197506-NYMEX.dly has a volume of 0 at 1975-05-28. | 2022-04-25 10:15:50.315
GC-202206-NYMEX [C] 4 Day #5 | File GC-197504-NYMEX.dly has a volume of 0 at 1975-01-30. | 2022-04-25 10:15:50.325
GC-202206-NYMEX [C] 4 Day #5 | File GC-197504-NYMEX.dly has a volume of 0 at 1975-03-27. | 2022-04-25 10:15:50.325
GC-202206-NYMEX [C] 4 Day #5 | Dates not found while checking for invalid data in continuous contract data files. GC-197502-NYMEX | 2022-04-25 10:15:50.331 *
Historical data download thread signaled to stop. | 2022-04-25 10:15:50.332
HD Request # 68 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:10.309000 | 2022-04-25 10:15:50.332
HD Request # 68 | Received 287 Intraday data records from 2022-04-25 10:12:59.513000 to 2022-04-25 10:15:41.400003 (2.7 minutes) and wrote 286 records for PFE-NQTV | 2022-04-25 10:15:50.332
HD Request # 68 | Completion time: 4s | 2022-04-25 10:15:50.332
HD Request # 68 | Intraday data download complete for PFE-NQTV. Unique request ID: 185 | 2022-04-25 10:15:50.332
Removing historical data download ID 185. | 2022-04-25 10:15:50.332
Real-time Intraday chart data file updates started for PFE-NQTV | 2022-04-25 10:15:50.332
Intraday chart data file opened for PFE-NQTV | 2022-04-25 10:15:50.332
HD Request # 68 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:50.332
Triggering next historical data download in queue. | 2022-04-25 10:15:50.332
HD Request # 69 | Requesting historical Daily data for NGM22 starting at 2022-04-19. SC External HD service. | 2022-04-25 10:15:50.332
Restarting the loading process. | 2022-04-25 10:15:50.332
HD Request # 70 | Downloading Intraday chart data for PFG-NQTV to the file PFG-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:50.356
HD Request # 70 | Download start date-time: 2022-04-25 10:12:44.000000. File last date-time: 2022-04-25 10:12:44.006001 | 2022-04-25 10:15:50.357
HD Request # 70 | Using server: ds25.sierracharts.com port 10149 | 2022-04-25 10:15:50.357
Socket (3) | Creating socket. | 2022-04-25 10:15:50.357
Socket (3) | New receive buffer size: 5242880 | 2022-04-25 10:15:50.357
Socket (3) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:50.357
GC-202206-NYMEX [C] Daily #3 | Reloading chart. | 2022-04-25 10:15:50.463
GC-202206-NYMEX [C] Daily #3 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:50.463
GC-202206-NYMEX [C] Daily #3 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:50.463
HD Request # 70 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:50.815
HD Request # 70 | Sending historical data logon request message. | 2022-04-25 10:15:50.815
HD Request # 70 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:44. Record interval: 0. Symbol: PFG-NQTV | 2022-04-25 10:15:51.044
HD Request # 70 | Decompressing data. | 2022-04-25 10:15:51.269
HD Request # 70 | Receiving Intraday data for PFG-NQTV starting at 2022-04-25 10:12:44.006000 | 2022-04-25 10:15:51.270
Socket (3) | CloseSocket call. | 2022-04-25 10:15:51.270
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:51.270
Socket (3) | Socket gracefully closed by remote side. | 2022-04-25 10:15:51.495
Socket (3) | Closed. | 2022-04-25 10:15:51.495
GC-202206-NYMEX [C] Daily #3 | File GC-200102-NYMEX.dly has a volume of 0 at 2000-11-29. | 2022-04-25 10:15:52.261
GC-202206-NYMEX [C] Daily #3 | File GC-200012-NYMEX.dly has a volume of 0 at 2000-07-28. | 2022-04-25 10:15:52.279
GC-202206-NYMEX [C] Daily #3 | File GC-200012-NYMEX.dly has a volume of 0 at 2000-11-28. | 2022-04-25 10:15:52.279
GC-202206-NYMEX [C] Daily #3 | File GC-200008-NYMEX.dly has a volume of 0 at 2000-05-30. | 2022-04-25 10:15:52.290
GC-202206-NYMEX [C] Daily #3 | File GC-200008-NYMEX.dly has a volume of 0 at 2000-07-27. | 2022-04-25 10:15:52.290
GC-202206-NYMEX [C] Daily #3 | File GC-200006-NYMEX.dly has a volume of 0 at 2000-03-30. | 2022-04-25 10:15:52.300
GC-202206-NYMEX [C] Daily #3 | File GC-200006-NYMEX.dly has a volume of 0 at 2000-05-29. | 2022-04-25 10:15:52.300
GC-202206-NYMEX [C] Daily #3 | File GC-200004-NYMEX.dly has a volume of 0 at 2000-01-28. | 2022-04-25 10:15:52.311
GC-202206-NYMEX [C] Daily #3 | File GC-200004-NYMEX.dly has a volume of 0 at 2000-03-29. | 2022-04-25 10:15:52.311
GC-202206-NYMEX [C] Daily #3 | File GC-200002-NYMEX.dly has a volume of 0 at 1999-11-29. | 2022-04-25 10:15:52.321
GC-202206-NYMEX [C] Daily #3 | File GC-200002-NYMEX.dly has a volume of 0 at 2000-01-27. | 2022-04-25 10:15:52.321
GC-202206-NYMEX [C] Daily #3 | File GC-199912-NYMEX.dly has a volume of 0 at 1999-07-29. | 2022-04-25 10:15:52.339
GC-202206-NYMEX [C] Daily #3 | File GC-199912-NYMEX.dly has a volume of 0 at 1999-11-26. | 2022-04-25 10:15:52.339
GC-202206-NYMEX [C] Daily #3 | File GC-199908-NYMEX.dly has a volume of 0 at 1999-05-28. | 2022-04-25 10:15:52.350
GC-202206-NYMEX [C] Daily #3 | File GC-199908-NYMEX.dly has a volume of 0 at 1999-07-28. | 2022-04-25 10:15:52.350
GC-202206-NYMEX [C] Daily #3 | File GC-199906-NYMEX.dly has a volume of 0 at 1999-03-30. | 2022-04-25 10:15:52.360
GC-202206-NYMEX [C] Daily #3 | File GC-199906-NYMEX.dly has a volume of 0 at 1999-05-27. | 2022-04-25 10:15:52.360
GC-202206-NYMEX [C] Daily #3 | File GC-199904-NYMEX.dly has a volume of 0 at 1999-01-28. | 2022-04-25 10:15:52.371
GC-202206-NYMEX [C] Daily #3 | File GC-199904-NYMEX.dly has a volume of 0 at 1999-03-29. | 2022-04-25 10:15:52.371
GC-202206-NYMEX [C] Daily #3 | File GC-199902-NYMEX.dly has a volume of 0 at 1998-11-27. | 2022-04-25 10:15:52.381
GC-202206-NYMEX [C] Daily #3 | File GC-199902-NYMEX.dly has a volume of 0 at 1999-01-27. | 2022-04-25 10:15:52.381
GC-202206-NYMEX [C] Daily #3 | File GC-199812-NYMEX.dly has a volume of 0 at 1998-07-30. | 2022-04-25 10:15:52.398
GC-202206-NYMEX [C] Daily #3 | File GC-199812-NYMEX.dly has a volume of 0 at 1998-11-26. | 2022-04-25 10:15:52.398
GC-202206-NYMEX [C] Daily #3 | File GC-199808-NYMEX.dly has a volume of 0 at 1998-05-28. | 2022-04-25 10:15:52.409
GC-202206-NYMEX [C] Daily #3 | File GC-199808-NYMEX.dly has a volume of 0 at 1998-07-29. | 2022-04-25 10:15:52.409
GC-202206-NYMEX [C] Daily #3 | File GC-199806-NYMEX.dly has a volume of 0 at 1998-03-30. | 2022-04-25 10:15:52.420
GC-202206-NYMEX [C] Daily #3 | File GC-199806-NYMEX.dly has a volume of 0 at 1998-05-27. | 2022-04-25 10:15:52.420
GC-202206-NYMEX [C] Daily #3 | File GC-199804-NYMEX.dly has a volume of 0 at 1998-01-29. | 2022-04-25 10:15:52.430
GC-202206-NYMEX [C] Daily #3 | File GC-199804-NYMEX.dly has a volume of 0 at 1998-03-27. | 2022-04-25 10:15:52.430
GC-202206-NYMEX [C] Daily #3 | File GC-199802-NYMEX.dly has a volume of 0 at 1997-11-27. | 2022-04-25 10:15:52.440
GC-202206-NYMEX [C] Daily #3 | File GC-199802-NYMEX.dly has a volume of 0 at 1998-01-28. | 2022-04-25 10:15:52.440
GC-202206-NYMEX [C] Daily #3 | File GC-199712-NYMEX.dly has a volume of 0 at 1997-07-30. | 2022-04-25 10:15:52.457
GC-202206-NYMEX [C] Daily #3 | File GC-199712-NYMEX.dly has a volume of 0 at 1997-11-26. | 2022-04-25 10:15:52.457
GC-202206-NYMEX [C] Daily #3 | File GC-199708-NYMEX.dly has a volume of 0 at 1997-05-29. | 2022-04-25 10:15:52.468
GC-202206-NYMEX [C] Daily #3 | File GC-199708-NYMEX.dly has a volume of 0 at 1997-07-29. | 2022-04-25 10:15:52.468
GC-202206-NYMEX [C] Daily #3 | File GC-199706-NYMEX.dly has a volume of 0 at 1997-03-28. | 2022-04-25 10:15:52.479
GC-202206-NYMEX [C] Daily #3 | File GC-199706-NYMEX.dly has a volume of 0 at 1997-05-28. | 2022-04-25 10:15:52.479
GC-202206-NYMEX [C] Daily #3 | File GC-199704-NYMEX.dly has a volume of 0 at 1997-01-30. | 2022-04-25 10:15:52.490
GC-202206-NYMEX [C] Daily #3 | File GC-199704-NYMEX.dly has a volume of 0 at 1997-03-27. | 2022-04-25 10:15:52.490
GC-202206-NYMEX [C] Daily #3 | File GC-199702-NYMEX.dly has a volume of 0 at 1996-11-28. | 2022-04-25 10:15:52.500
GC-202206-NYMEX [C] Daily #3 | File GC-199702-NYMEX.dly has a volume of 0 at 1997-01-29. | 2022-04-25 10:15:52.500
GC-202206-NYMEX [C] Daily #3 | File GC-199612-NYMEX.dly has a volume of 0 at 1996-07-30. | 2022-04-25 10:15:52.517
GC-202206-NYMEX [C] Daily #3 | File GC-199612-NYMEX.dly has a volume of 0 at 1996-11-27. | 2022-04-25 10:15:52.517
GC-202206-NYMEX [C] Daily #3 | File GC-199608-NYMEX.dly has a volume of 0 at 1996-05-30. | 2022-04-25 10:15:52.528
GC-202206-NYMEX [C] Daily #3 | File GC-199608-NYMEX.dly has a volume of 0 at 1996-07-29. | 2022-04-25 10:15:52.528
GC-202206-NYMEX [C] Daily #3 | File GC-199606-NYMEX.dly has a volume of 0 at 1996-03-28. | 2022-04-25 10:15:52.540
GC-202206-NYMEX [C] Daily #3 | File GC-199606-NYMEX.dly has a volume of 0 at 1996-05-29. | 2022-04-25 10:15:52.540
GC-202206-NYMEX [C] Daily #3 | File GC-199604-NYMEX.dly has a volume of 0 at 1996-01-30. | 2022-04-25 10:15:52.551
GC-202206-NYMEX [C] Daily #3 | File GC-199604-NYMEX.dly has a volume of 0 at 1996-03-27. | 2022-04-25 10:15:52.551
GC-202206-NYMEX [C] Daily #3 | File GC-199602-NYMEX.dly has a volume of 0 at 1995-11-29. | 2022-04-25 10:15:52.561
GC-202206-NYMEX [C] Daily #3 | File GC-199602-NYMEX.dly has a volume of 0 at 1996-01-29. | 2022-04-25 10:15:52.561
GC-202206-NYMEX [C] Daily #3 | File GC-199512-NYMEX.dly has a volume of 0 at 1995-07-28. | 2022-04-25 10:15:52.578
GC-202206-NYMEX [C] Daily #3 | File GC-199512-NYMEX.dly has a volume of 0 at 1995-11-28. | 2022-04-25 10:15:52.578
GC-202206-NYMEX [C] Daily #3 | File GC-199508-NYMEX.dly has a volume of 0 at 1995-05-30. | 2022-04-25 10:15:52.589
GC-202206-NYMEX [C] Daily #3 | File GC-199508-NYMEX.dly has a volume of 0 at 1995-07-27. | 2022-04-25 10:15:52.589
GC-202206-NYMEX [C] Daily #3 | File GC-199506-NYMEX.dly has a volume of 0 at 1995-03-30. | 2022-04-25 10:15:52.600
GC-202206-NYMEX [C] Daily #3 | File GC-199506-NYMEX.dly has a volume of 0 at 1995-05-29. | 2022-04-25 10:15:52.600
GC-202206-NYMEX [C] Daily #3 | File GC-199504-NYMEX.dly has a volume of 0 at 1995-01-30. | 2022-04-25 10:15:52.611
GC-202206-NYMEX [C] Daily #3 | File GC-199504-NYMEX.dly has a volume of 0 at 1995-03-29. | 2022-04-25 10:15:52.611
GC-202206-NYMEX [C] Daily #3 | File GC-199502-NYMEX.dly has a volume of 0 at 1994-11-29. | 2022-04-25 10:15:52.622
GC-202206-NYMEX [C] Daily #3 | File GC-199502-NYMEX.dly has a volume of 0 at 1995-01-27. | 2022-04-25 10:15:52.622
GC-202206-NYMEX [C] Daily #3 | File GC-199412-NYMEX.dly has a volume of 0 at 1994-07-28. | 2022-04-25 10:15:52.639
GC-202206-NYMEX [C] Daily #3 | File GC-199412-NYMEX.dly has a volume of 0 at 1994-11-28. | 2022-04-25 10:15:52.639
GC-202206-NYMEX [C] Daily #3 | File GC-199408-NYMEX.dly has a volume of 0 at 1994-05-30. | 2022-04-25 10:15:52.650
GC-202206-NYMEX [C] Daily #3 | File GC-199408-NYMEX.dly has a volume of 0 at 1994-07-27. | 2022-04-25 10:15:52.650
GC-202206-NYMEX [C] Daily #3 | File GC-199406-NYMEX.dly has a volume of 0 at 1994-03-30. | 2022-04-25 10:15:52.661
GC-202206-NYMEX [C] Daily #3 | File GC-199406-NYMEX.dly has a volume of 0 at 1994-05-27. | 2022-04-25 10:15:52.661
GC-202206-NYMEX [C] Daily #3 | File GC-199404-NYMEX.dly has a volume of 0 at 1994-01-28. | 2022-04-25 10:15:52.672
GC-202206-NYMEX [C] Daily #3 | File GC-199404-NYMEX.dly has a volume of 0 at 1994-03-29. | 2022-04-25 10:15:52.672
GC-202206-NYMEX [C] Daily #3 | File GC-199402-NYMEX.dly has a volume of 0 at 1993-11-29. | 2022-04-25 10:15:52.682
GC-202206-NYMEX [C] Daily #3 | File GC-199402-NYMEX.dly has a volume of 0 at 1994-01-27. | 2022-04-25 10:15:52.682
GC-202206-NYMEX [C] Daily #3 | File GC-199312-NYMEX.dly has a volume of 0 at 1993-07-29. | 2022-04-25 10:15:52.700
GC-202206-NYMEX [C] Daily #3 | File GC-199312-NYMEX.dly has a volume of 0 at 1993-11-26. | 2022-04-25 10:15:52.700
GC-202206-NYMEX [C] Daily #3 | File GC-199308-NYMEX.dly has a volume of 0 at 1993-05-28. | 2022-04-25 10:15:52.711
GC-202206-NYMEX [C] Daily #3 | File GC-199308-NYMEX.dly has a volume of 0 at 1993-07-28. | 2022-04-25 10:15:52.711
GC-202206-NYMEX [C] Daily #3 | File GC-199306-NYMEX.dly has a volume of 0 at 1993-03-30. | 2022-04-25 10:15:52.722
GC-202206-NYMEX [C] Daily #3 | File GC-199306-NYMEX.dly has a volume of 0 at 1993-05-27. | 2022-04-25 10:15:52.722
GC-202206-NYMEX [C] Daily #3 | File GC-199304-NYMEX.dly has a volume of 0 at 1993-01-28. | 2022-04-25 10:15:52.733
GC-202206-NYMEX [C] Daily #3 | File GC-199304-NYMEX.dly has a volume of 0 at 1993-03-29. | 2022-04-25 10:15:52.733
GC-202206-NYMEX [C] Daily #3 | File GC-199302-NYMEX.dly has a volume of 0 at 1992-11-27. | 2022-04-25 10:15:52.744
GC-202206-NYMEX [C] Daily #3 | File GC-199302-NYMEX.dly has a volume of 0 at 1993-01-27. | 2022-04-25 10:15:52.744
GC-202206-NYMEX [C] Daily #3 | File GC-199212-NYMEX.dly has a volume of 0 at 1992-07-30. | 2022-04-25 10:15:52.761
GC-202206-NYMEX [C] Daily #3 | File GC-199212-NYMEX.dly has a volume of 0 at 1992-11-26. | 2022-04-25 10:15:52.761
GC-202206-NYMEX [C] Daily #3 | File GC-199208-NYMEX.dly has a volume of 0 at 1992-05-28. | 2022-04-25 10:15:52.772
GC-202206-NYMEX [C] Daily #3 | File GC-199208-NYMEX.dly has a volume of 0 at 1992-07-29. | 2022-04-25 10:15:52.772
GC-202206-NYMEX [C] Daily #3 | File GC-199206-NYMEX.dly has a volume of 0 at 1992-03-30. | 2022-04-25 10:15:52.783
GC-202206-NYMEX [C] Daily #3 | File GC-199206-NYMEX.dly has a volume of 0 at 1992-05-27. | 2022-04-25 10:15:52.783
GC-202206-NYMEX [C] Daily #3 | File GC-199204-NYMEX.dly has a volume of 0 at 1992-01-30. | 2022-04-25 10:15:52.794
GC-202206-NYMEX [C] Daily #3 | File GC-199204-NYMEX.dly has a volume of 0 at 1992-03-27. | 2022-04-25 10:15:52.794
GC-202206-NYMEX [C] Daily #3 | File GC-199202-NYMEX.dly has a volume of 0 at 1991-11-28. | 2022-04-25 10:15:52.804
GC-202206-NYMEX [C] Daily #3 | File GC-199202-NYMEX.dly has a volume of 0 at 1992-01-29. | 2022-04-25 10:15:52.804
GC-202206-NYMEX [C] Daily #3 | File GC-199112-NYMEX.dly has a volume of 0 at 1991-07-30. | 2022-04-25 10:15:52.822
GC-202206-NYMEX [C] Daily #3 | File GC-199112-NYMEX.dly has a volume of 0 at 1991-11-27. | 2022-04-25 10:15:52.822
GC-202206-NYMEX [C] Daily #3 | File GC-199108-NYMEX.dly has a volume of 0 at 1991-05-30. | 2022-04-25 10:15:52.833
GC-202206-NYMEX [C] Daily #3 | File GC-199108-NYMEX.dly has a volume of 0 at 1991-07-29. | 2022-04-25 10:15:52.833
GC-202206-NYMEX [C] Daily #3 | File GC-199106-NYMEX.dly has a volume of 0 at 1991-03-28. | 2022-04-25 10:15:52.844
GC-202206-NYMEX [C] Daily #3 | File GC-199106-NYMEX.dly has a volume of 0 at 1991-05-29. | 2022-04-25 10:15:52.844
GC-202206-NYMEX [C] Daily #3 | File GC-199104-NYMEX.dly has a volume of 0 at 1991-01-30. | 2022-04-25 10:15:52.855
GC-202206-NYMEX [C] Daily #3 | File GC-199104-NYMEX.dly has a volume of 0 at 1991-03-27. | 2022-04-25 10:15:52.855
GC-202206-NYMEX [C] Daily #3 | File GC-199102-NYMEX.dly has a volume of 0 at 1990-11-29. | 2022-04-25 10:15:52.865
GC-202206-NYMEX [C] Daily #3 | File GC-199102-NYMEX.dly has a volume of 0 at 1991-01-29. | 2022-04-25 10:15:52.865
GC-202206-NYMEX [C] Daily #3 | File GC-199012-NYMEX.dly has a volume of 0 at 1990-07-30. | 2022-04-25 10:15:52.882
GC-202206-NYMEX [C] Daily #3 | File GC-199012-NYMEX.dly has a volume of 0 at 1990-11-28. | 2022-04-25 10:15:52.882
GC-202206-NYMEX [C] Daily #3 | File GC-199008-NYMEX.dly has a volume of 0 at 1990-05-30. | 2022-04-25 10:15:52.893
GC-202206-NYMEX [C] Daily #3 | File GC-199008-NYMEX.dly has a volume of 0 at 1990-07-27. | 2022-04-25 10:15:52.893
GC-202206-NYMEX [C] Daily #3 | File GC-199006-NYMEX.dly has a volume of 0 at 1990-03-29. | 2022-04-25 10:15:52.904
GC-202206-NYMEX [C] Daily #3 | File GC-199006-NYMEX.dly has a volume of 0 at 1990-05-29. | 2022-04-25 10:15:52.904
GC-202206-NYMEX [C] Daily #3 | File GC-199004-NYMEX.dly has a volume of 0 at 1990-01-30. | 2022-04-25 10:15:52.915
GC-202206-NYMEX [C] Daily #3 | File GC-199004-NYMEX.dly has a volume of 0 at 1990-03-28. | 2022-04-25 10:15:52.915
GC-202206-NYMEX [C] Daily #3 | File GC-199002-NYMEX.dly has a volume of 0 at 1989-11-29. | 2022-04-25 10:15:52.925
GC-202206-NYMEX [C] Daily #3 | File GC-199002-NYMEX.dly has a volume of 0 at 1990-01-29. | 2022-04-25 10:15:52.925
GC-202206-NYMEX [C] Daily #3 | File GC-198912-NYMEX.dly has a volume of 0 at 1989-07-28. | 2022-04-25 10:15:52.942
GC-202206-NYMEX [C] Daily #3 | File GC-198912-NYMEX.dly has a volume of 0 at 1989-11-28. | 2022-04-25 10:15:52.942
GC-202206-NYMEX [C] Daily #3 | File GC-198908-NYMEX.dly has a volume of 0 at 1989-05-30. | 2022-04-25 10:15:52.953
GC-202206-NYMEX [C] Daily #3 | File GC-198908-NYMEX.dly has a volume of 0 at 1989-07-27. | 2022-04-25 10:15:52.953
GC-202206-NYMEX [C] Daily #3 | File GC-198906-NYMEX.dly has a volume of 0 at 1989-03-30. | 2022-04-25 10:15:52.964
GC-202206-NYMEX [C] Daily #3 | File GC-198906-NYMEX.dly has a volume of 0 at 1989-05-29. | 2022-04-25 10:15:52.964
GC-202206-NYMEX [C] Daily #3 | File GC-198904-NYMEX.dly has a volume of 0 at 1989-01-30. | 2022-04-25 10:15:52.974
GC-202206-NYMEX [C] Daily #3 | File GC-198904-NYMEX.dly has a volume of 0 at 1989-03-29. | 2022-04-25 10:15:52.974
GC-202206-NYMEX [C] Daily #3 | File GC-198902-NYMEX.dly has a volume of 0 at 1988-11-29. | 2022-04-25 10:15:52.985
GC-202206-NYMEX [C] Daily #3 | File GC-198902-NYMEX.dly has a volume of 0 at 1989-01-27. | 2022-04-25 10:15:52.985
GC-202206-NYMEX [C] Daily #3 | File GC-198812-NYMEX.dly has a volume of 0 at 1988-07-28. | 2022-04-25 10:15:53.002
GC-202206-NYMEX [C] Daily #3 | File GC-198812-NYMEX.dly has a volume of 0 at 1988-11-28. | 2022-04-25 10:15:53.002
GC-202206-NYMEX [C] Daily #3 | File GC-198808-NYMEX.dly has a volume of 0 at 1988-05-30. | 2022-04-25 10:15:53.013
GC-202206-NYMEX [C] Daily #3 | File GC-198808-NYMEX.dly has a volume of 0 at 1988-07-27. | 2022-04-25 10:15:53.013
GC-202206-NYMEX [C] Daily #3 | File GC-198806-NYMEX.dly has a volume of 0 at 1988-03-30. | 2022-04-25 10:15:53.024
GC-202206-NYMEX [C] Daily #3 | File GC-198806-NYMEX.dly has a volume of 0 at 1988-05-27. | 2022-04-25 10:15:53.024
GC-202206-NYMEX [C] Daily #3 | File GC-198804-NYMEX.dly has a volume of 0 at 1988-01-28. | 2022-04-25 10:15:53.035
GC-202206-NYMEX [C] Daily #3 | File GC-198804-NYMEX.dly has a volume of 0 at 1988-03-29. | 2022-04-25 10:15:53.035
GC-202206-NYMEX [C] Daily #3 | File GC-198802-NYMEX.dly has a volume of 0 at 1987-11-27. | 2022-04-25 10:15:53.045
GC-202206-NYMEX [C] Daily #3 | File GC-198802-NYMEX.dly has a volume of 0 at 1988-01-27. | 2022-04-25 10:15:53.045
GC-202206-NYMEX [C] Daily #3 | File GC-198712-NYMEX.dly has a volume of 0 at 1987-07-30. | 2022-04-25 10:15:53.063
GC-202206-NYMEX [C] Daily #3 | File GC-198712-NYMEX.dly has a volume of 0 at 1987-11-26. | 2022-04-25 10:15:53.063
GC-202206-NYMEX [C] Daily #3 | File GC-198708-NYMEX.dly has a volume of 0 at 1987-05-28. | 2022-04-25 10:15:53.074
GC-202206-NYMEX [C] Daily #3 | File GC-198708-NYMEX.dly has a volume of 0 at 1987-07-29. | 2022-04-25 10:15:53.074
GC-202206-NYMEX [C] Daily #3 | File GC-198706-NYMEX.dly has a volume of 0 at 1987-03-30. | 2022-04-25 10:15:53.085
GC-202206-NYMEX [C] Daily #3 | File GC-198706-NYMEX.dly has a volume of 0 at 1987-05-27. | 2022-04-25 10:15:53.085
GC-202206-NYMEX [C] Daily #3 | File GC-198704-NYMEX.dly has a volume of 0 at 1987-01-29. | 2022-04-25 10:15:53.095
GC-202206-NYMEX [C] Daily #3 | File GC-198704-NYMEX.dly has a volume of 0 at 1987-03-27. | 2022-04-25 10:15:53.095
GC-202206-NYMEX [C] Daily #3 | File GC-198702-NYMEX.dly has a volume of 0 at 1986-11-27. | 2022-04-25 10:15:53.106
GC-202206-NYMEX [C] Daily #3 | File GC-198702-NYMEX.dly has a volume of 0 at 1987-01-28. | 2022-04-25 10:15:53.106
GC-202206-NYMEX [C] Daily #3 | File GC-198612-NYMEX.dly has a volume of 0 at 1986-07-30. | 2022-04-25 10:15:53.123
GC-202206-NYMEX [C] Daily #3 | File GC-198612-NYMEX.dly has a volume of 0 at 1986-11-26. | 2022-04-25 10:15:53.123
GC-202206-NYMEX [C] Daily #3 | File GC-198608-NYMEX.dly has a volume of 0 at 1986-05-29. | 2022-04-25 10:15:53.134
GC-202206-NYMEX [C] Daily #3 | File GC-198608-NYMEX.dly has a volume of 0 at 1986-07-29. | 2022-04-25 10:15:53.134
GC-202206-NYMEX [C] Daily #3 | File GC-198606-NYMEX.dly has a volume of 0 at 1986-03-28. | 2022-04-25 10:15:53.145
GC-202206-NYMEX [C] Daily #3 | File GC-198606-NYMEX.dly has a volume of 0 at 1986-05-28. | 2022-04-25 10:15:53.145
GC-202206-NYMEX [C] Daily #3 | File GC-198604-NYMEX.dly has a volume of 0 at 1986-01-30. | 2022-04-25 10:15:53.155
GC-202206-NYMEX [C] Daily #3 | File GC-198604-NYMEX.dly has a volume of 0 at 1986-03-27. | 2022-04-25 10:15:53.155
GC-202206-NYMEX [C] Daily #3 | File GC-198602-NYMEX.dly has a volume of 0 at 1985-11-28. | 2022-04-25 10:15:53.166
GC-202206-NYMEX [C] Daily #3 | File GC-198602-NYMEX.dly has a volume of 0 at 1986-01-29. | 2022-04-25 10:15:53.166
GC-202206-NYMEX [C] Daily #3 | File GC-198512-NYMEX.dly has a volume of 0 at 1985-07-30. | 2022-04-25 10:15:53.183
GC-202206-NYMEX [C] Daily #3 | File GC-198512-NYMEX.dly has a volume of 0 at 1985-11-27. | 2022-04-25 10:15:53.183
GC-202206-NYMEX [C] Daily #3 | File GC-198508-NYMEX.dly has a volume of 0 at 1985-05-30. | 2022-04-25 10:15:53.194
GC-202206-NYMEX [C] Daily #3 | File GC-198508-NYMEX.dly has a volume of 0 at 1985-07-29. | 2022-04-25 10:15:53.194
GC-202206-NYMEX [C] Daily #3 | File GC-198506-NYMEX.dly has a volume of 0 at 1985-03-28. | 2022-04-25 10:15:53.205
GC-202206-NYMEX [C] Daily #3 | File GC-198506-NYMEX.dly has a volume of 0 at 1985-05-29. | 2022-04-25 10:15:53.205
GC-202206-NYMEX [C] Daily #3 | File GC-198504-NYMEX.dly has a volume of 0 at 1985-01-30. | 2022-04-25 10:15:53.215
GC-202206-NYMEX [C] Daily #3 | File GC-198504-NYMEX.dly has a volume of 0 at 1985-03-27. | 2022-04-25 10:15:53.215
GC-202206-NYMEX [C] Daily #3 | File GC-198502-NYMEX.dly has a volume of 0 at 1984-11-29. | 2022-04-25 10:15:53.225
GC-202206-NYMEX [C] Daily #3 | File GC-198502-NYMEX.dly has a volume of 0 at 1985-01-29. | 2022-04-25 10:15:53.225
GC-202206-NYMEX [C] Daily #3 | File GC-198412-NYMEX.dly has a volume of 0 at 1984-07-30. | 2022-04-25 10:15:53.242
GC-202206-NYMEX [C] Daily #3 | File GC-198412-NYMEX.dly has a volume of 0 at 1984-11-28. | 2022-04-25 10:15:53.242
GC-202206-NYMEX [C] Daily #3 | File GC-198408-NYMEX.dly has a volume of 0 at 1984-05-30. | 2022-04-25 10:15:53.254
GC-202206-NYMEX [C] Daily #3 | File GC-198408-NYMEX.dly has a volume of 0 at 1984-07-27. | 2022-04-25 10:15:53.254
GC-202206-NYMEX [C] Daily #3 | File GC-198406-NYMEX.dly has a volume of 0 at 1984-03-29. | 2022-04-25 10:15:53.264
GC-202206-NYMEX [C] Daily #3 | File GC-198406-NYMEX.dly has a volume of 0 at 1984-05-29. | 2022-04-25 10:15:53.264
GC-202206-NYMEX [C] Daily #3 | File GC-198404-NYMEX.dly has a volume of 0 at 1984-01-30. | 2022-04-25 10:15:53.274
GC-202206-NYMEX [C] Daily #3 | File GC-198404-NYMEX.dly has a volume of 0 at 1984-03-28. | 2022-04-25 10:15:53.274
GC-202206-NYMEX [C] Daily #3 | File GC-198402-NYMEX.dly has a volume of 0 at 1983-11-29. | 2022-04-25 10:15:53.285
GC-202206-NYMEX [C] Daily #3 | File GC-198402-NYMEX.dly has a volume of 0 at 1984-01-27. | 2022-04-25 10:15:53.285
GC-202206-NYMEX [C] Daily #3 | File GC-198312-NYMEX.dly has a volume of 0 at 1983-07-28. | 2022-04-25 10:15:53.302
GC-202206-NYMEX [C] Daily #3 | File GC-198312-NYMEX.dly has a volume of 0 at 1983-11-28. | 2022-04-25 10:15:53.302
GC-202206-NYMEX [C] Daily #3 | File GC-198308-NYMEX.dly has a volume of 0 at 1983-05-30. | 2022-04-25 10:15:53.313
GC-202206-NYMEX [C] Daily #3 | File GC-198308-NYMEX.dly has a volume of 0 at 1983-07-27. | 2022-04-25 10:15:53.313
GC-202206-NYMEX [C] Daily #3 | File GC-198306-NYMEX.dly has a volume of 0 at 1983-03-30. | 2022-04-25 10:15:53.323
GC-202206-NYMEX [C] Daily #3 | File GC-198306-NYMEX.dly has a volume of 0 at 1983-05-27. | 2022-04-25 10:15:53.323
GC-202206-NYMEX [C] Daily #3 | File GC-198304-NYMEX.dly has a volume of 0 at 1983-01-28. | 2022-04-25 10:15:53.334
GC-202206-NYMEX [C] Daily #3 | File GC-198304-NYMEX.dly has a volume of 0 at 1983-03-29. | 2022-04-25 10:15:53.334
GC-202206-NYMEX [C] Daily #3 | File GC-198302-NYMEX.dly has a volume of 0 at 1982-11-29. | 2022-04-25 10:15:53.344
GC-202206-NYMEX [C] Daily #3 | File GC-198302-NYMEX.dly has a volume of 0 at 1983-01-27. | 2022-04-25 10:15:53.344
GC-202206-NYMEX [C] Daily #3 | File GC-198212-NYMEX.dly has a volume of 0 at 1982-07-29. | 2022-04-25 10:15:53.361
GC-202206-NYMEX [C] Daily #3 | File GC-198212-NYMEX.dly has a volume of 0 at 1982-11-26. | 2022-04-25 10:15:53.361
GC-202206-NYMEX [C] Daily #3 | File GC-198208-NYMEX.dly has a volume of 0 at 1982-05-28. | 2022-04-25 10:15:53.372
GC-202206-NYMEX [C] Daily #3 | File GC-198208-NYMEX.dly has a volume of 0 at 1982-07-28. | 2022-04-25 10:15:53.372
GC-202206-NYMEX [C] Daily #3 | File GC-198206-NYMEX.dly has a volume of 0 at 1982-03-30. | 2022-04-25 10:15:53.382
GC-202206-NYMEX [C] Daily #3 | File GC-198206-NYMEX.dly has a volume of 0 at 1982-05-27. | 2022-04-25 10:15:53.382
GC-202206-NYMEX [C] Daily #3 | File GC-198204-NYMEX.dly has a volume of 0 at 1982-01-28. | 2022-04-25 10:15:53.392
GC-202206-NYMEX [C] Daily #3 | File GC-198204-NYMEX.dly has a volume of 0 at 1982-03-29. | 2022-04-25 10:15:53.392
GC-202206-NYMEX [C] Daily #3 | File GC-198202-NYMEX.dly has a volume of 0 at 1981-11-27. | 2022-04-25 10:15:53.402
GC-202206-NYMEX [C] Daily #3 | File GC-198202-NYMEX.dly has a volume of 0 at 1982-01-27. | 2022-04-25 10:15:53.402
GC-202206-NYMEX [C] Daily #3 | File GC-198112-NYMEX.dly has a volume of 0 at 1981-07-30. | 2022-04-25 10:15:53.419
GC-202206-NYMEX [C] Daily #3 | File GC-198112-NYMEX.dly has a volume of 0 at 1981-11-26. | 2022-04-25 10:15:53.419
GC-202206-NYMEX [C] Daily #3 | File GC-198108-NYMEX.dly has a volume of 0 at 1981-05-28. | 2022-04-25 10:15:53.430
GC-202206-NYMEX [C] Daily #3 | File GC-198108-NYMEX.dly has a volume of 0 at 1981-07-29. | 2022-04-25 10:15:53.430
GC-202206-NYMEX [C] Daily #3 | File GC-198106-NYMEX.dly has a volume of 0 at 1981-03-30. | 2022-04-25 10:15:53.440
GC-202206-NYMEX [C] Daily #3 | File GC-198106-NYMEX.dly has a volume of 0 at 1981-05-27. | 2022-04-25 10:15:53.440
GC-202206-NYMEX [C] Daily #3 | File GC-198104-NYMEX.dly has a volume of 0 at 1981-01-29. | 2022-04-25 10:15:53.451
GC-202206-NYMEX [C] Daily #3 | File GC-198104-NYMEX.dly has a volume of 0 at 1981-03-27. | 2022-04-25 10:15:53.451
GC-202206-NYMEX [C] Daily #3 | File GC-198102-NYMEX.dly has a volume of 0 at 1980-11-27. | 2022-04-25 10:15:53.461
GC-202206-NYMEX [C] Daily #3 | File GC-198102-NYMEX.dly has a volume of 0 at 1981-01-28. | 2022-04-25 10:15:53.461
GC-202206-NYMEX [C] Daily #3 | File GC-198012-NYMEX.dly has a volume of 0 at 1980-07-30. | 2022-04-25 10:15:53.477
GC-202206-NYMEX [C] Daily #3 | File GC-198012-NYMEX.dly has a volume of 0 at 1980-11-26. | 2022-04-25 10:15:53.477
GC-202206-NYMEX [C] Daily #3 | File GC-198008-NYMEX.dly has a volume of 0 at 1980-05-29. | 2022-04-25 10:15:53.488
GC-202206-NYMEX [C] Daily #3 | File GC-198008-NYMEX.dly has a volume of 0 at 1980-07-29. | 2022-04-25 10:15:53.488
GC-202206-NYMEX [C] Daily #3 | File GC-198006-NYMEX.dly has a volume of 0 at 1980-03-28. | 2022-04-25 10:15:53.498
GC-202206-NYMEX [C] Daily #3 | File GC-198006-NYMEX.dly has a volume of 0 at 1980-05-28. | 2022-04-25 10:15:53.498
GC-202206-NYMEX [C] Daily #3 | File GC-198004-NYMEX.dly has a volume of 0 at 1980-01-30. | 2022-04-25 10:15:53.509
GC-202206-NYMEX [C] Daily #3 | File GC-198004-NYMEX.dly has a volume of 0 at 1980-03-27. | 2022-04-25 10:15:53.509
GC-202206-NYMEX [C] Daily #3 | File GC-198002-NYMEX.dly has a volume of 0 at 1979-11-29. | 2022-04-25 10:15:53.519
GC-202206-NYMEX [C] Daily #3 | File GC-198002-NYMEX.dly has a volume of 0 at 1980-01-29. | 2022-04-25 10:15:53.519
GC-202206-NYMEX [C] Daily #3 | File GC-197912-NYMEX.dly has a volume of 0 at 1979-07-30. | 2022-04-25 10:15:53.535
GC-202206-NYMEX [C] Daily #3 | File GC-197912-NYMEX.dly has a volume of 0 at 1979-11-28. | 2022-04-25 10:15:53.535
GC-202206-NYMEX [C] Daily #3 | File GC-197908-NYMEX.dly has a volume of 0 at 1979-05-30. | 2022-04-25 10:15:53.546
GC-202206-NYMEX [C] Daily #3 | File GC-197908-NYMEX.dly has a volume of 0 at 1979-07-27. | 2022-04-25 10:15:53.546
GC-202206-NYMEX [C] Daily #3 | File GC-197906-NYMEX.dly has a volume of 0 at 1979-03-29. | 2022-04-25 10:15:53.557
GC-202206-NYMEX [C] Daily #3 | File GC-197906-NYMEX.dly has a volume of 0 at 1979-05-29. | 2022-04-25 10:15:53.557
GC-202206-NYMEX [C] Daily #3 | File GC-197904-NYMEX.dly has a volume of 0 at 1979-01-30. | 2022-04-25 10:15:53.567
GC-202206-NYMEX [C] Daily #3 | File GC-197904-NYMEX.dly has a volume of 0 at 1979-03-28. | 2022-04-25 10:15:53.567
GC-202206-NYMEX [C] Daily #3 | File GC-197902-NYMEX.dly has a volume of 0 at 1978-11-29. | 2022-04-25 10:15:53.577
GC-202206-NYMEX [C] Daily #3 | File GC-197902-NYMEX.dly has a volume of 0 at 1979-01-29. | 2022-04-25 10:15:53.577
GC-202206-NYMEX [C] Daily #3 | File GC-197812-NYMEX.dly has a volume of 0 at 1978-07-28. | 2022-04-25 10:15:53.594
GC-202206-NYMEX [C] Daily #3 | File GC-197812-NYMEX.dly has a volume of 0 at 1978-11-28. | 2022-04-25 10:15:53.594
GC-202206-NYMEX [C] Daily #3 | File GC-197808-NYMEX.dly has a volume of 0 at 1978-05-30. | 2022-04-25 10:15:53.605
GC-202206-NYMEX [C] Daily #3 | File GC-197808-NYMEX.dly has a volume of 0 at 1978-07-27. | 2022-04-25 10:15:53.605
GC-202206-NYMEX [C] Daily #3 | File GC-197806-NYMEX.dly has a volume of 0 at 1978-03-30. | 2022-04-25 10:15:53.615
GC-202206-NYMEX [C] Daily #3 | File GC-197806-NYMEX.dly has a volume of 0 at 1978-05-29. | 2022-04-25 10:15:53.615
GC-202206-NYMEX [C] Daily #3 | File GC-197804-NYMEX.dly has a volume of 0 at 1978-01-30. | 2022-04-25 10:15:53.625
GC-202206-NYMEX [C] Daily #3 | File GC-197804-NYMEX.dly has a volume of 0 at 1978-03-29. | 2022-04-25 10:15:53.625
GC-202206-NYMEX [C] Daily #3 | File GC-197802-NYMEX.dly has a volume of 0 at 1977-11-29. | 2022-04-25 10:15:53.635
GC-202206-NYMEX [C] Daily #3 | File GC-197802-NYMEX.dly has a volume of 0 at 1978-01-27. | 2022-04-25 10:15:53.635
GC-202206-NYMEX [C] Daily #3 | File GC-197712-NYMEX.dly has a volume of 0 at 1977-07-28. | 2022-04-25 10:15:53.652
GC-202206-NYMEX [C] Daily #3 | File GC-197712-NYMEX.dly has a volume of 0 at 1977-11-28. | 2022-04-25 10:15:53.652
GC-202206-NYMEX [C] Daily #3 | File GC-197708-NYMEX.dly has a volume of 0 at 1977-05-30. | 2022-04-25 10:15:53.663
GC-202206-NYMEX [C] Daily #3 | File GC-197708-NYMEX.dly has a volume of 0 at 1977-07-27. | 2022-04-25 10:15:53.663
GC-202206-NYMEX [C] Daily #3 | File GC-197706-NYMEX.dly has a volume of 0 at 1977-03-30. | 2022-04-25 10:15:53.673
GC-202206-NYMEX [C] Daily #3 | File GC-197706-NYMEX.dly has a volume of 0 at 1977-05-27. | 2022-04-25 10:15:53.673
GC-202206-NYMEX [C] Daily #3 | File GC-197704-NYMEX.dly has a volume of 0 at 1977-01-28. | 2022-04-25 10:15:53.684
GC-202206-NYMEX [C] Daily #3 | File GC-197704-NYMEX.dly has a volume of 0 at 1977-03-29. | 2022-04-25 10:15:53.684
GC-202206-NYMEX [C] Daily #3 | File GC-197702-NYMEX.dly has a volume of 0 at 1976-11-29. | 2022-04-25 10:15:53.694
GC-202206-NYMEX [C] Daily #3 | File GC-197702-NYMEX.dly has a volume of 0 at 1977-01-27. | 2022-04-25 10:15:53.694
GC-202206-NYMEX [C] Daily #3 | File GC-197612-NYMEX.dly has a volume of 0 at 1976-07-29. | 2022-04-25 10:15:53.711
GC-202206-NYMEX [C] Daily #3 | File GC-197612-NYMEX.dly has a volume of 0 at 1976-11-26. | 2022-04-25 10:15:53.711
GC-202206-NYMEX [C] Daily #3 | File GC-197608-NYMEX.dly has a volume of 0 at 1976-05-28. | 2022-04-25 10:15:53.722
GC-202206-NYMEX [C] Daily #3 | File GC-197608-NYMEX.dly has a volume of 0 at 1976-07-28. | 2022-04-25 10:15:53.722
GC-202206-NYMEX [C] Daily #3 | File GC-197606-NYMEX.dly has a volume of 0 at 1976-03-30. | 2022-04-25 10:15:53.732
GC-202206-NYMEX [C] Daily #3 | File GC-197606-NYMEX.dly has a volume of 0 at 1976-05-27. | 2022-04-25 10:15:53.732
GC-202206-NYMEX [C] Daily #3 | File GC-197604-NYMEX.dly has a volume of 0 at 1976-01-29. | 2022-04-25 10:15:53.743
GC-202206-NYMEX [C] Daily #3 | File GC-197604-NYMEX.dly has a volume of 0 at 1976-03-29. | 2022-04-25 10:15:53.743
GC-202206-NYMEX [C] Daily #3 | File GC-197602-NYMEX.dly has a volume of 0 at 1975-11-27. | 2022-04-25 10:15:53.753
GC-202206-NYMEX [C] Daily #3 | File GC-197602-NYMEX.dly has a volume of 0 at 1976-01-28. | 2022-04-25 10:15:53.753
GC-202206-NYMEX [C] Daily #3 | File GC-197512-NYMEX.dly has a volume of 0 at 1975-07-30. | 2022-04-25 10:15:53.769
GC-202206-NYMEX [C] Daily #3 | File GC-197512-NYMEX.dly has a volume of 0 at 1975-11-26. | 2022-04-25 10:15:53.769
GC-202206-NYMEX [C] Daily #3 | File GC-197508-NYMEX.dly has a volume of 0 at 1975-05-29. | 2022-04-25 10:15:53.780
GC-202206-NYMEX [C] Daily #3 | File GC-197508-NYMEX.dly has a volume of 0 at 1975-07-29. | 2022-04-25 10:15:53.780
GC-202206-NYMEX [C] Daily #3 | File GC-197506-NYMEX.dly has a volume of 0 at 1975-03-28. | 2022-04-25 10:15:53.791
GC-202206-NYMEX [C] Daily #3 | File GC-197506-NYMEX.dly has a volume of 0 at 1975-05-28. | 2022-04-25 10:15:53.791
GC-202206-NYMEX [C] Daily #3 | File GC-197504-NYMEX.dly has a volume of 0 at 1975-01-30. | 2022-04-25 10:15:53.801
GC-202206-NYMEX [C] Daily #3 | File GC-197504-NYMEX.dly has a volume of 0 at 1975-03-27. | 2022-04-25 10:15:53.801
GC-202206-NYMEX [C] Daily #3 | Dates not found while checking for invalid data in continuous contract data files. GC-197502-NYMEX | 2022-04-25 10:15:53.808 *
Historical data download thread signaled to stop. | 2022-04-25 10:15:53.830
HD Request # 70 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:02.988000 | 2022-04-25 10:15:53.830
HD Request # 70 | Received 53 Intraday data records from 2022-04-25 10:12:44.006000 to 2022-04-25 10:15:36.104002 (2.9 minutes) and wrote 51 records for PFG-NQTV | 2022-04-25 10:15:53.830
HD Request # 70 | Completion time: 3s | 2022-04-25 10:15:53.830
HD Request # 70 | Intraday data download complete for PFG-NQTV. Unique request ID: 188 | 2022-04-25 10:15:53.830
Removing historical data download ID 188. | 2022-04-25 10:15:53.830
Real-time Intraday chart data file updates started for PFG-NQTV | 2022-04-25 10:15:53.830
Intraday chart data file opened for PFG-NQTV | 2022-04-25 10:15:53.830
HD Request # 70 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:53.830
Triggering next historical data download in queue. | 2022-04-25 10:15:53.831
HD Request # 71 | Downloading Intraday chart data for REXR-NQTV to the file REXR-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:53.835
HD Request # 71 | Download start date-time: 2022-04-25 10:12:43.000000. File last date-time: 2022-04-25 10:12:43.750002 | 2022-04-25 10:15:53.836
HD Request # 71 | Using server: ds25.sierracharts.com port 10150 | 2022-04-25 10:15:53.836
Socket (3) | Creating socket. | 2022-04-25 10:15:53.836
Socket (3) | New receive buffer size: 5242880 | 2022-04-25 10:15:53.836
Socket (3) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:53.836
GC-202206-NYMEX [C] 4 Day #4 | Reloading chart. | 2022-04-25 10:15:53.893
GC-202206-NYMEX [C] 4 Day #4 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:53.893
GC-202206-NYMEX [C] 4 Day #4 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:53.893
Opened cached Intraday file: C:\SierraChart\Data\LAC-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:15:53.971
Opened cached Intraday file: C:\SierraChart\Data\PFE-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:15:53.972
HD Request # 71 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:54.289
HD Request # 71 | Sending historical data logon request message. | 2022-04-25 10:15:54.289
HD Request # 71 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:43. Record interval: 0. Symbol: REXR-NQTV | 2022-04-25 10:15:54.515
HD Request # 71 | Decompressing data. | 2022-04-25 10:15:54.741
HD Request # 71 | Receiving Intraday data for REXR-NQTV starting at 2022-04-25 10:12:43.750000 | 2022-04-25 10:15:54.741
Socket (3) | CloseSocket call. | 2022-04-25 10:15:54.741
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:54.741
Socket (3) | Socket gracefully closed by remote side. | 2022-04-25 10:15:54.966
Socket (3) | Closed. | 2022-04-25 10:15:54.966
GC-202206-NYMEX [C] 4 Day #4 | File GC-200102-NYMEX.dly has a volume of 0 at 2000-11-29. | 2022-04-25 10:15:55.702
GC-202206-NYMEX [C] 4 Day #4 | File GC-200012-NYMEX.dly has a volume of 0 at 2000-07-28. | 2022-04-25 10:15:55.720
GC-202206-NYMEX [C] 4 Day #4 | File GC-200012-NYMEX.dly has a volume of 0 at 2000-11-28. | 2022-04-25 10:15:55.720
GC-202206-NYMEX [C] 4 Day #4 | File GC-200008-NYMEX.dly has a volume of 0 at 2000-05-30. | 2022-04-25 10:15:55.731
GC-202206-NYMEX [C] 4 Day #4 | File GC-200008-NYMEX.dly has a volume of 0 at 2000-07-27. | 2022-04-25 10:15:55.731
GC-202206-NYMEX [C] 4 Day #4 | File GC-200006-NYMEX.dly has a volume of 0 at 2000-03-30. | 2022-04-25 10:15:55.741
GC-202206-NYMEX [C] 4 Day #4 | File GC-200006-NYMEX.dly has a volume of 0 at 2000-05-29. | 2022-04-25 10:15:55.741
GC-202206-NYMEX [C] 4 Day #4 | File GC-200004-NYMEX.dly has a volume of 0 at 2000-01-28. | 2022-04-25 10:15:55.752
GC-202206-NYMEX [C] 4 Day #4 | File GC-200004-NYMEX.dly has a volume of 0 at 2000-03-29. | 2022-04-25 10:15:55.752
GC-202206-NYMEX [C] 4 Day #4 | File GC-200002-NYMEX.dly has a volume of 0 at 1999-11-29. | 2022-04-25 10:15:55.762
GC-202206-NYMEX [C] 4 Day #4 | File GC-200002-NYMEX.dly has a volume of 0 at 2000-01-27. | 2022-04-25 10:15:55.762
GC-202206-NYMEX [C] 4 Day #4 | File GC-199912-NYMEX.dly has a volume of 0 at 1999-07-29. | 2022-04-25 10:15:55.780
GC-202206-NYMEX [C] 4 Day #4 | File GC-199912-NYMEX.dly has a volume of 0 at 1999-11-26. | 2022-04-25 10:15:55.780
GC-202206-NYMEX [C] 4 Day #4 | File GC-199908-NYMEX.dly has a volume of 0 at 1999-05-28. | 2022-04-25 10:15:55.791
GC-202206-NYMEX [C] 4 Day #4 | File GC-199908-NYMEX.dly has a volume of 0 at 1999-07-28. | 2022-04-25 10:15:55.791
GC-202206-NYMEX [C] 4 Day #4 | File GC-199906-NYMEX.dly has a volume of 0 at 1999-03-30. | 2022-04-25 10:15:55.802
GC-202206-NYMEX [C] 4 Day #4 | File GC-199906-NYMEX.dly has a volume of 0 at 1999-05-27. | 2022-04-25 10:15:55.802
GC-202206-NYMEX [C] 4 Day #4 | File GC-199904-NYMEX.dly has a volume of 0 at 1999-01-28. | 2022-04-25 10:15:55.812
GC-202206-NYMEX [C] 4 Day #4 | File GC-199904-NYMEX.dly has a volume of 0 at 1999-03-29. | 2022-04-25 10:15:55.812
GC-202206-NYMEX [C] 4 Day #4 | File GC-199902-NYMEX.dly has a volume of 0 at 1998-11-27. | 2022-04-25 10:15:55.823
GC-202206-NYMEX [C] 4 Day #4 | File GC-199902-NYMEX.dly has a volume of 0 at 1999-01-27. | 2022-04-25 10:15:55.823
GC-202206-NYMEX [C] 4 Day #4 | File GC-199812-NYMEX.dly has a volume of 0 at 1998-07-30. | 2022-04-25 10:15:55.840
GC-202206-NYMEX [C] 4 Day #4 | File GC-199812-NYMEX.dly has a volume of 0 at 1998-11-26. | 2022-04-25 10:15:55.840
GC-202206-NYMEX [C] 4 Day #4 | File GC-199808-NYMEX.dly has a volume of 0 at 1998-05-28. | 2022-04-25 10:15:55.851
GC-202206-NYMEX [C] 4 Day #4 | File GC-199808-NYMEX.dly has a volume of 0 at 1998-07-29. | 2022-04-25 10:15:55.851
GC-202206-NYMEX [C] 4 Day #4 | File GC-199806-NYMEX.dly has a volume of 0 at 1998-03-30. | 2022-04-25 10:15:55.862
GC-202206-NYMEX [C] 4 Day #4 | File GC-199806-NYMEX.dly has a volume of 0 at 1998-05-27. | 2022-04-25 10:15:55.862
GC-202206-NYMEX [C] 4 Day #4 | File GC-199804-NYMEX.dly has a volume of 0 at 1998-01-29. | 2022-04-25 10:15:55.872
GC-202206-NYMEX [C] 4 Day #4 | File GC-199804-NYMEX.dly has a volume of 0 at 1998-03-27. | 2022-04-25 10:15:55.872
GC-202206-NYMEX [C] 4 Day #4 | File GC-199802-NYMEX.dly has a volume of 0 at 1997-11-27. | 2022-04-25 10:15:55.882
GC-202206-NYMEX [C] 4 Day #4 | File GC-199802-NYMEX.dly has a volume of 0 at 1998-01-28. | 2022-04-25 10:15:55.882
GC-202206-NYMEX [C] 4 Day #4 | File GC-199712-NYMEX.dly has a volume of 0 at 1997-07-30. | 2022-04-25 10:15:55.900
GC-202206-NYMEX [C] 4 Day #4 | File GC-199712-NYMEX.dly has a volume of 0 at 1997-11-26. | 2022-04-25 10:15:55.900
GC-202206-NYMEX [C] 4 Day #4 | File GC-199708-NYMEX.dly has a volume of 0 at 1997-05-29. | 2022-04-25 10:15:55.911
GC-202206-NYMEX [C] 4 Day #4 | File GC-199708-NYMEX.dly has a volume of 0 at 1997-07-29. | 2022-04-25 10:15:55.911
GC-202206-NYMEX [C] 4 Day #4 | File GC-199706-NYMEX.dly has a volume of 0 at 1997-03-28. | 2022-04-25 10:15:55.922
GC-202206-NYMEX [C] 4 Day #4 | File GC-199706-NYMEX.dly has a volume of 0 at 1997-05-28. | 2022-04-25 10:15:55.922
GC-202206-NYMEX [C] 4 Day #4 | File GC-199704-NYMEX.dly has a volume of 0 at 1997-01-30. | 2022-04-25 10:15:55.932
GC-202206-NYMEX [C] 4 Day #4 | File GC-199704-NYMEX.dly has a volume of 0 at 1997-03-27. | 2022-04-25 10:15:55.932
GC-202206-NYMEX [C] 4 Day #4 | File GC-199702-NYMEX.dly has a volume of 0 at 1996-11-28. | 2022-04-25 10:15:55.942
GC-202206-NYMEX [C] 4 Day #4 | File GC-199702-NYMEX.dly has a volume of 0 at 1997-01-29. | 2022-04-25 10:15:55.942
GC-202206-NYMEX [C] 4 Day #4 | File GC-199612-NYMEX.dly has a volume of 0 at 1996-07-30. | 2022-04-25 10:15:55.959
GC-202206-NYMEX [C] 4 Day #4 | File GC-199612-NYMEX.dly has a volume of 0 at 1996-11-27. | 2022-04-25 10:15:55.959
GC-202206-NYMEX [C] 4 Day #4 | File GC-199608-NYMEX.dly has a volume of 0 at 1996-05-30. | 2022-04-25 10:15:55.970
GC-202206-NYMEX [C] 4 Day #4 | File GC-199608-NYMEX.dly has a volume of 0 at 1996-07-29. | 2022-04-25 10:15:55.970
GC-202206-NYMEX [C] 4 Day #4 | File GC-199606-NYMEX.dly has a volume of 0 at 1996-03-28. | 2022-04-25 10:15:55.981
GC-202206-NYMEX [C] 4 Day #4 | File GC-199606-NYMEX.dly has a volume of 0 at 1996-05-29. | 2022-04-25 10:15:55.981
GC-202206-NYMEX [C] 4 Day #4 | File GC-199604-NYMEX.dly has a volume of 0 at 1996-01-30. | 2022-04-25 10:15:55.992
GC-202206-NYMEX [C] 4 Day #4 | File GC-199604-NYMEX.dly has a volume of 0 at 1996-03-27. | 2022-04-25 10:15:55.992
GC-202206-NYMEX [C] 4 Day #4 | File GC-199602-NYMEX.dly has a volume of 0 at 1995-11-29. | 2022-04-25 10:15:56.003
GC-202206-NYMEX [C] 4 Day #4 | File GC-199602-NYMEX.dly has a volume of 0 at 1996-01-29. | 2022-04-25 10:15:56.003
GC-202206-NYMEX [C] 4 Day #4 | File GC-199512-NYMEX.dly has a volume of 0 at 1995-07-28. | 2022-04-25 10:15:56.020
GC-202206-NYMEX [C] 4 Day #4 | File GC-199512-NYMEX.dly has a volume of 0 at 1995-11-28. | 2022-04-25 10:15:56.020
GC-202206-NYMEX [C] 4 Day #4 | File GC-199508-NYMEX.dly has a volume of 0 at 1995-05-30. | 2022-04-25 10:15:56.031
GC-202206-NYMEX [C] 4 Day #4 | File GC-199508-NYMEX.dly has a volume of 0 at 1995-07-27. | 2022-04-25 10:15:56.032
GC-202206-NYMEX [C] 4 Day #4 | File GC-199506-NYMEX.dly has a volume of 0 at 1995-03-30. | 2022-04-25 10:15:56.042
GC-202206-NYMEX [C] 4 Day #4 | File GC-199506-NYMEX.dly has a volume of 0 at 1995-05-29. | 2022-04-25 10:15:56.042
GC-202206-NYMEX [C] 4 Day #4 | File GC-199504-NYMEX.dly has a volume of 0 at 1995-01-30. | 2022-04-25 10:15:56.053
GC-202206-NYMEX [C] 4 Day #4 | File GC-199504-NYMEX.dly has a volume of 0 at 1995-03-29. | 2022-04-25 10:15:56.053
GC-202206-NYMEX [C] 4 Day #4 | File GC-199502-NYMEX.dly has a volume of 0 at 1994-11-29. | 2022-04-25 10:15:56.063
GC-202206-NYMEX [C] 4 Day #4 | File GC-199502-NYMEX.dly has a volume of 0 at 1995-01-27. | 2022-04-25 10:15:56.063
GC-202206-NYMEX [C] 4 Day #4 | File GC-199412-NYMEX.dly has a volume of 0 at 1994-07-28. | 2022-04-25 10:15:56.080
GC-202206-NYMEX [C] 4 Day #4 | File GC-199412-NYMEX.dly has a volume of 0 at 1994-11-28. | 2022-04-25 10:15:56.080
GC-202206-NYMEX [C] 4 Day #4 | File GC-199408-NYMEX.dly has a volume of 0 at 1994-05-30. | 2022-04-25 10:15:56.091
GC-202206-NYMEX [C] 4 Day #4 | File GC-199408-NYMEX.dly has a volume of 0 at 1994-07-27. | 2022-04-25 10:15:56.091
GC-202206-NYMEX [C] 4 Day #4 | File GC-199406-NYMEX.dly has a volume of 0 at 1994-03-30. | 2022-04-25 10:15:56.102
GC-202206-NYMEX [C] 4 Day #4 | File GC-199406-NYMEX.dly has a volume of 0 at 1994-05-27. | 2022-04-25 10:15:56.102
GC-202206-NYMEX [C] 4 Day #4 | File GC-199404-NYMEX.dly has a volume of 0 at 1994-01-28. | 2022-04-25 10:15:56.112
GC-202206-NYMEX [C] 4 Day #4 | File GC-199404-NYMEX.dly has a volume of 0 at 1994-03-29. | 2022-04-25 10:15:56.112
GC-202206-NYMEX [C] 4 Day #4 | File GC-199402-NYMEX.dly has a volume of 0 at 1993-11-29. | 2022-04-25 10:15:56.123
GC-202206-NYMEX [C] 4 Day #4 | File GC-199402-NYMEX.dly has a volume of 0 at 1994-01-27. | 2022-04-25 10:15:56.123
GC-202206-NYMEX [C] 4 Day #4 | File GC-199312-NYMEX.dly has a volume of 0 at 1993-07-29. | 2022-04-25 10:15:56.140
GC-202206-NYMEX [C] 4 Day #4 | File GC-199312-NYMEX.dly has a volume of 0 at 1993-11-26. | 2022-04-25 10:15:56.140
GC-202206-NYMEX [C] 4 Day #4 | File GC-199308-NYMEX.dly has a volume of 0 at 1993-05-28. | 2022-04-25 10:15:56.151
GC-202206-NYMEX [C] 4 Day #4 | File GC-199308-NYMEX.dly has a volume of 0 at 1993-07-28. | 2022-04-25 10:15:56.151
GC-202206-NYMEX [C] 4 Day #4 | File GC-199306-NYMEX.dly has a volume of 0 at 1993-03-30. | 2022-04-25 10:15:56.162
GC-202206-NYMEX [C] 4 Day #4 | File GC-199306-NYMEX.dly has a volume of 0 at 1993-05-27. | 2022-04-25 10:15:56.162
GC-202206-NYMEX [C] 4 Day #4 | File GC-199304-NYMEX.dly has a volume of 0 at 1993-01-28. | 2022-04-25 10:15:56.172
GC-202206-NYMEX [C] 4 Day #4 | File GC-199304-NYMEX.dly has a volume of 0 at 1993-03-29. | 2022-04-25 10:15:56.172
GC-202206-NYMEX [C] 4 Day #4 | File GC-199302-NYMEX.dly has a volume of 0 at 1992-11-27. | 2022-04-25 10:15:56.183
GC-202206-NYMEX [C] 4 Day #4 | File GC-199302-NYMEX.dly has a volume of 0 at 1993-01-27. | 2022-04-25 10:15:56.183
GC-202206-NYMEX [C] 4 Day #4 | File GC-199212-NYMEX.dly has a volume of 0 at 1992-07-30. | 2022-04-25 10:15:56.200
GC-202206-NYMEX [C] 4 Day #4 | File GC-199212-NYMEX.dly has a volume of 0 at 1992-11-26. | 2022-04-25 10:15:56.200
GC-202206-NYMEX [C] 4 Day #4 | File GC-199208-NYMEX.dly has a volume of 0 at 1992-05-28. | 2022-04-25 10:15:56.211
GC-202206-NYMEX [C] 4 Day #4 | File GC-199208-NYMEX.dly has a volume of 0 at 1992-07-29. | 2022-04-25 10:15:56.211
GC-202206-NYMEX [C] 4 Day #4 | File GC-199206-NYMEX.dly has a volume of 0 at 1992-03-30. | 2022-04-25 10:15:56.221
GC-202206-NYMEX [C] 4 Day #4 | File GC-199206-NYMEX.dly has a volume of 0 at 1992-05-27. | 2022-04-25 10:15:56.221
GC-202206-NYMEX [C] 4 Day #4 | File GC-199204-NYMEX.dly has a volume of 0 at 1992-01-30. | 2022-04-25 10:15:56.232
GC-202206-NYMEX [C] 4 Day #4 | File GC-199204-NYMEX.dly has a volume of 0 at 1992-03-27. | 2022-04-25 10:15:56.232
GC-202206-NYMEX [C] 4 Day #4 | File GC-199202-NYMEX.dly has a volume of 0 at 1991-11-28. | 2022-04-25 10:15:56.242
GC-202206-NYMEX [C] 4 Day #4 | File GC-199202-NYMEX.dly has a volume of 0 at 1992-01-29. | 2022-04-25 10:15:56.242
GC-202206-NYMEX [C] 4 Day #4 | File GC-199112-NYMEX.dly has a volume of 0 at 1991-07-30. | 2022-04-25 10:15:56.259
GC-202206-NYMEX [C] 4 Day #4 | File GC-199112-NYMEX.dly has a volume of 0 at 1991-11-27. | 2022-04-25 10:15:56.259
GC-202206-NYMEX [C] 4 Day #4 | File GC-199108-NYMEX.dly has a volume of 0 at 1991-05-30. | 2022-04-25 10:15:56.270
GC-202206-NYMEX [C] 4 Day #4 | File GC-199108-NYMEX.dly has a volume of 0 at 1991-07-29. | 2022-04-25 10:15:56.270
GC-202206-NYMEX [C] 4 Day #4 | File GC-199106-NYMEX.dly has a volume of 0 at 1991-03-28. | 2022-04-25 10:15:56.281
GC-202206-NYMEX [C] 4 Day #4 | File GC-199106-NYMEX.dly has a volume of 0 at 1991-05-29. | 2022-04-25 10:15:56.281
GC-202206-NYMEX [C] 4 Day #4 | File GC-199104-NYMEX.dly has a volume of 0 at 1991-01-30. | 2022-04-25 10:15:56.292
GC-202206-NYMEX [C] 4 Day #4 | File GC-199104-NYMEX.dly has a volume of 0 at 1991-03-27. | 2022-04-25 10:15:56.292
GC-202206-NYMEX [C] 4 Day #4 | File GC-199102-NYMEX.dly has a volume of 0 at 1990-11-29. | 2022-04-25 10:15:56.302
GC-202206-NYMEX [C] 4 Day #4 | File GC-199102-NYMEX.dly has a volume of 0 at 1991-01-29. | 2022-04-25 10:15:56.302
GC-202206-NYMEX [C] 4 Day #4 | File GC-199012-NYMEX.dly has a volume of 0 at 1990-07-30. | 2022-04-25 10:15:56.319
GC-202206-NYMEX [C] 4 Day #4 | File GC-199012-NYMEX.dly has a volume of 0 at 1990-11-28. | 2022-04-25 10:15:56.319
GC-202206-NYMEX [C] 4 Day #4 | File GC-199008-NYMEX.dly has a volume of 0 at 1990-05-30. | 2022-04-25 10:15:56.330
GC-202206-NYMEX [C] 4 Day #4 | File GC-199008-NYMEX.dly has a volume of 0 at 1990-07-27. | 2022-04-25 10:15:56.330
GC-202206-NYMEX [C] 4 Day #4 | File GC-199006-NYMEX.dly has a volume of 0 at 1990-03-29. | 2022-04-25 10:15:56.341
GC-202206-NYMEX [C] 4 Day #4 | File GC-199006-NYMEX.dly has a volume of 0 at 1990-05-29. | 2022-04-25 10:15:56.341
GC-202206-NYMEX [C] 4 Day #4 | File GC-199004-NYMEX.dly has a volume of 0 at 1990-01-30. | 2022-04-25 10:15:56.351
GC-202206-NYMEX [C] 4 Day #4 | File GC-199004-NYMEX.dly has a volume of 0 at 1990-03-28. | 2022-04-25 10:15:56.351
GC-202206-NYMEX [C] 4 Day #4 | File GC-199002-NYMEX.dly has a volume of 0 at 1989-11-29. | 2022-04-25 10:15:56.361
GC-202206-NYMEX [C] 4 Day #4 | File GC-199002-NYMEX.dly has a volume of 0 at 1990-01-29. | 2022-04-25 10:15:56.361
GC-202206-NYMEX [C] 4 Day #4 | File GC-198912-NYMEX.dly has a volume of 0 at 1989-07-28. | 2022-04-25 10:15:56.379
GC-202206-NYMEX [C] 4 Day #4 | File GC-198912-NYMEX.dly has a volume of 0 at 1989-11-28. | 2022-04-25 10:15:56.379
GC-202206-NYMEX [C] 4 Day #4 | File GC-198908-NYMEX.dly has a volume of 0 at 1989-05-30. | 2022-04-25 10:15:56.390
GC-202206-NYMEX [C] 4 Day #4 | File GC-198908-NYMEX.dly has a volume of 0 at 1989-07-27. | 2022-04-25 10:15:56.390
GC-202206-NYMEX [C] 4 Day #4 | File GC-198906-NYMEX.dly has a volume of 0 at 1989-03-30. | 2022-04-25 10:15:56.401
GC-202206-NYMEX [C] 4 Day #4 | File GC-198906-NYMEX.dly has a volume of 0 at 1989-05-29. | 2022-04-25 10:15:56.401
GC-202206-NYMEX [C] 4 Day #4 | File GC-198904-NYMEX.dly has a volume of 0 at 1989-01-30. | 2022-04-25 10:15:56.411
GC-202206-NYMEX [C] 4 Day #4 | File GC-198904-NYMEX.dly has a volume of 0 at 1989-03-29. | 2022-04-25 10:15:56.411
GC-202206-NYMEX [C] 4 Day #4 | File GC-198902-NYMEX.dly has a volume of 0 at 1988-11-29. | 2022-04-25 10:15:56.421
GC-202206-NYMEX [C] 4 Day #4 | File GC-198902-NYMEX.dly has a volume of 0 at 1989-01-27. | 2022-04-25 10:15:56.421
GC-202206-NYMEX [C] 4 Day #4 | File GC-198812-NYMEX.dly has a volume of 0 at 1988-07-28. | 2022-04-25 10:15:56.439
GC-202206-NYMEX [C] 4 Day #4 | File GC-198812-NYMEX.dly has a volume of 0 at 1988-11-28. | 2022-04-25 10:15:56.439
GC-202206-NYMEX [C] 4 Day #4 | File GC-198808-NYMEX.dly has a volume of 0 at 1988-05-30. | 2022-04-25 10:15:56.450
GC-202206-NYMEX [C] 4 Day #4 | File GC-198808-NYMEX.dly has a volume of 0 at 1988-07-27. | 2022-04-25 10:15:56.450
GC-202206-NYMEX [C] 4 Day #4 | File GC-198806-NYMEX.dly has a volume of 0 at 1988-03-30. | 2022-04-25 10:15:56.460
GC-202206-NYMEX [C] 4 Day #4 | File GC-198806-NYMEX.dly has a volume of 0 at 1988-05-27. | 2022-04-25 10:15:56.460
GC-202206-NYMEX [C] 4 Day #4 | File GC-198804-NYMEX.dly has a volume of 0 at 1988-01-28. | 2022-04-25 10:15:56.471
GC-202206-NYMEX [C] 4 Day #4 | File GC-198804-NYMEX.dly has a volume of 0 at 1988-03-29. | 2022-04-25 10:15:56.471
GC-202206-NYMEX [C] 4 Day #4 | File GC-198802-NYMEX.dly has a volume of 0 at 1987-11-27. | 2022-04-25 10:15:56.482
GC-202206-NYMEX [C] 4 Day #4 | File GC-198802-NYMEX.dly has a volume of 0 at 1988-01-27. | 2022-04-25 10:15:56.482
GC-202206-NYMEX [C] 4 Day #4 | File GC-198712-NYMEX.dly has a volume of 0 at 1987-07-30. | 2022-04-25 10:15:56.499
GC-202206-NYMEX [C] 4 Day #4 | File GC-198712-NYMEX.dly has a volume of 0 at 1987-11-26. | 2022-04-25 10:15:56.499
GC-202206-NYMEX [C] 4 Day #4 | File GC-198708-NYMEX.dly has a volume of 0 at 1987-05-28. | 2022-04-25 10:15:56.510
GC-202206-NYMEX [C] 4 Day #4 | File GC-198708-NYMEX.dly has a volume of 0 at 1987-07-29. | 2022-04-25 10:15:56.510
GC-202206-NYMEX [C] 4 Day #4 | File GC-198706-NYMEX.dly has a volume of 0 at 1987-03-30. | 2022-04-25 10:15:56.521
GC-202206-NYMEX [C] 4 Day #4 | File GC-198706-NYMEX.dly has a volume of 0 at 1987-05-27. | 2022-04-25 10:15:56.521
GC-202206-NYMEX [C] 4 Day #4 | File GC-198704-NYMEX.dly has a volume of 0 at 1987-01-29. | 2022-04-25 10:15:56.531
GC-202206-NYMEX [C] 4 Day #4 | File GC-198704-NYMEX.dly has a volume of 0 at 1987-03-27. | 2022-04-25 10:15:56.531
GC-202206-NYMEX [C] 4 Day #4 | File GC-198702-NYMEX.dly has a volume of 0 at 1986-11-27. | 2022-04-25 10:15:56.542
GC-202206-NYMEX [C] 4 Day #4 | File GC-198702-NYMEX.dly has a volume of 0 at 1987-01-28. | 2022-04-25 10:15:56.542
GC-202206-NYMEX [C] 4 Day #4 | File GC-198612-NYMEX.dly has a volume of 0 at 1986-07-30. | 2022-04-25 10:15:56.559
GC-202206-NYMEX [C] 4 Day #4 | File GC-198612-NYMEX.dly has a volume of 0 at 1986-11-26. | 2022-04-25 10:15:56.559
GC-202206-NYMEX [C] 4 Day #4 | File GC-198608-NYMEX.dly has a volume of 0 at 1986-05-29. | 2022-04-25 10:15:56.570
GC-202206-NYMEX [C] 4 Day #4 | File GC-198608-NYMEX.dly has a volume of 0 at 1986-07-29. | 2022-04-25 10:15:56.570
GC-202206-NYMEX [C] 4 Day #4 | File GC-198606-NYMEX.dly has a volume of 0 at 1986-03-28. | 2022-04-25 10:15:56.580
GC-202206-NYMEX [C] 4 Day #4 | File GC-198606-NYMEX.dly has a volume of 0 at 1986-05-28. | 2022-04-25 10:15:56.580
GC-202206-NYMEX [C] 4 Day #4 | File GC-198604-NYMEX.dly has a volume of 0 at 1986-01-30. | 2022-04-25 10:15:56.591
GC-202206-NYMEX [C] 4 Day #4 | File GC-198604-NYMEX.dly has a volume of 0 at 1986-03-27. | 2022-04-25 10:15:56.591
GC-202206-NYMEX [C] 4 Day #4 | File GC-198602-NYMEX.dly has a volume of 0 at 1985-11-28. | 2022-04-25 10:15:56.601
GC-202206-NYMEX [C] 4 Day #4 | File GC-198602-NYMEX.dly has a volume of 0 at 1986-01-29. | 2022-04-25 10:15:56.601
GC-202206-NYMEX [C] 4 Day #4 | File GC-198512-NYMEX.dly has a volume of 0 at 1985-07-30. | 2022-04-25 10:15:56.619
GC-202206-NYMEX [C] 4 Day #4 | File GC-198512-NYMEX.dly has a volume of 0 at 1985-11-27. | 2022-04-25 10:15:56.619
GC-202206-NYMEX [C] 4 Day #4 | File GC-198508-NYMEX.dly has a volume of 0 at 1985-05-30. | 2022-04-25 10:15:56.629
GC-202206-NYMEX [C] 4 Day #4 | File GC-198508-NYMEX.dly has a volume of 0 at 1985-07-29. | 2022-04-25 10:15:56.629
GC-202206-NYMEX [C] 4 Day #4 | File GC-198506-NYMEX.dly has a volume of 0 at 1985-03-28. | 2022-04-25 10:15:56.640
GC-202206-NYMEX [C] 4 Day #4 | File GC-198506-NYMEX.dly has a volume of 0 at 1985-05-29. | 2022-04-25 10:15:56.640
GC-202206-NYMEX [C] 4 Day #4 | File GC-198504-NYMEX.dly has a volume of 0 at 1985-01-30. | 2022-04-25 10:15:56.650
GC-202206-NYMEX [C] 4 Day #4 | File GC-198504-NYMEX.dly has a volume of 0 at 1985-03-27. | 2022-04-25 10:15:56.650
GC-202206-NYMEX [C] 4 Day #4 | File GC-198502-NYMEX.dly has a volume of 0 at 1984-11-29. | 2022-04-25 10:15:56.660
GC-202206-NYMEX [C] 4 Day #4 | File GC-198502-NYMEX.dly has a volume of 0 at 1985-01-29. | 2022-04-25 10:15:56.660
GC-202206-NYMEX [C] 4 Day #4 | File GC-198412-NYMEX.dly has a volume of 0 at 1984-07-30. | 2022-04-25 10:15:56.677
GC-202206-NYMEX [C] 4 Day #4 | File GC-198412-NYMEX.dly has a volume of 0 at 1984-11-28. | 2022-04-25 10:15:56.677
GC-202206-NYMEX [C] 4 Day #4 | File GC-198408-NYMEX.dly has a volume of 0 at 1984-05-30. | 2022-04-25 10:15:56.688
GC-202206-NYMEX [C] 4 Day #4 | File GC-198408-NYMEX.dly has a volume of 0 at 1984-07-27. | 2022-04-25 10:15:56.688
GC-202206-NYMEX [C] 4 Day #4 | File GC-198406-NYMEX.dly has a volume of 0 at 1984-03-29. | 2022-04-25 10:15:56.699
GC-202206-NYMEX [C] 4 Day #4 | File GC-198406-NYMEX.dly has a volume of 0 at 1984-05-29. | 2022-04-25 10:15:56.699
GC-202206-NYMEX [C] 4 Day #4 | File GC-198404-NYMEX.dly has a volume of 0 at 1984-01-30. | 2022-04-25 10:15:56.709
GC-202206-NYMEX [C] 4 Day #4 | File GC-198404-NYMEX.dly has a volume of 0 at 1984-03-28. | 2022-04-25 10:15:56.709
GC-202206-NYMEX [C] 4 Day #4 | File GC-198402-NYMEX.dly has a volume of 0 at 1983-11-29. | 2022-04-25 10:15:56.719
GC-202206-NYMEX [C] 4 Day #4 | File GC-198402-NYMEX.dly has a volume of 0 at 1984-01-27. | 2022-04-25 10:15:56.719
GC-202206-NYMEX [C] 4 Day #4 | File GC-198312-NYMEX.dly has a volume of 0 at 1983-07-28. | 2022-04-25 10:15:56.737
GC-202206-NYMEX [C] 4 Day #4 | File GC-198312-NYMEX.dly has a volume of 0 at 1983-11-28. | 2022-04-25 10:15:56.737
GC-202206-NYMEX [C] 4 Day #4 | File GC-198308-NYMEX.dly has a volume of 0 at 1983-05-30. | 2022-04-25 10:15:56.748
GC-202206-NYMEX [C] 4 Day #4 | File GC-198308-NYMEX.dly has a volume of 0 at 1983-07-27. | 2022-04-25 10:15:56.748
GC-202206-NYMEX [C] 4 Day #4 | File GC-198306-NYMEX.dly has a volume of 0 at 1983-03-30. | 2022-04-25 10:15:56.758
GC-202206-NYMEX [C] 4 Day #4 | File GC-198306-NYMEX.dly has a volume of 0 at 1983-05-27. | 2022-04-25 10:15:56.758
GC-202206-NYMEX [C] 4 Day #4 | File GC-198304-NYMEX.dly has a volume of 0 at 1983-01-28. | 2022-04-25 10:15:56.769
GC-202206-NYMEX [C] 4 Day #4 | File GC-198304-NYMEX.dly has a volume of 0 at 1983-03-29. | 2022-04-25 10:15:56.769
GC-202206-NYMEX [C] 4 Day #4 | File GC-198302-NYMEX.dly has a volume of 0 at 1982-11-29. | 2022-04-25 10:15:56.779
GC-202206-NYMEX [C] 4 Day #4 | File GC-198302-NYMEX.dly has a volume of 0 at 1983-01-27. | 2022-04-25 10:15:56.779
GC-202206-NYMEX [C] 4 Day #4 | File GC-198212-NYMEX.dly has a volume of 0 at 1982-07-29. | 2022-04-25 10:15:56.796
GC-202206-NYMEX [C] 4 Day #4 | File GC-198212-NYMEX.dly has a volume of 0 at 1982-11-26. | 2022-04-25 10:15:56.796
GC-202206-NYMEX [C] 4 Day #4 | File GC-198208-NYMEX.dly has a volume of 0 at 1982-05-28. | 2022-04-25 10:15:56.807
GC-202206-NYMEX [C] 4 Day #4 | File GC-198208-NYMEX.dly has a volume of 0 at 1982-07-28. | 2022-04-25 10:15:56.807
GC-202206-NYMEX [C] 4 Day #4 | File GC-198206-NYMEX.dly has a volume of 0 at 1982-03-30. | 2022-04-25 10:15:56.817
GC-202206-NYMEX [C] 4 Day #4 | File GC-198206-NYMEX.dly has a volume of 0 at 1982-05-27. | 2022-04-25 10:15:56.817
GC-202206-NYMEX [C] 4 Day #4 | File GC-198204-NYMEX.dly has a volume of 0 at 1982-01-28. | 2022-04-25 10:15:56.828
GC-202206-NYMEX [C] 4 Day #4 | File GC-198204-NYMEX.dly has a volume of 0 at 1982-03-29. | 2022-04-25 10:15:56.828
GC-202206-NYMEX [C] 4 Day #4 | File GC-198202-NYMEX.dly has a volume of 0 at 1981-11-27. | 2022-04-25 10:15:56.838
GC-202206-NYMEX [C] 4 Day #4 | File GC-198202-NYMEX.dly has a volume of 0 at 1982-01-27. | 2022-04-25 10:15:56.838
GC-202206-NYMEX [C] 4 Day #4 | File GC-198112-NYMEX.dly has a volume of 0 at 1981-07-30. | 2022-04-25 10:15:56.855
GC-202206-NYMEX [C] 4 Day #4 | File GC-198112-NYMEX.dly has a volume of 0 at 1981-11-26. | 2022-04-25 10:15:56.855
GC-202206-NYMEX [C] 4 Day #4 | File GC-198108-NYMEX.dly has a volume of 0 at 1981-05-28. | 2022-04-25 10:15:56.866
GC-202206-NYMEX [C] 4 Day #4 | File GC-198108-NYMEX.dly has a volume of 0 at 1981-07-29. | 2022-04-25 10:15:56.866
GC-202206-NYMEX [C] 4 Day #4 | File GC-198106-NYMEX.dly has a volume of 0 at 1981-03-30. | 2022-04-25 10:15:56.877
GC-202206-NYMEX [C] 4 Day #4 | File GC-198106-NYMEX.dly has a volume of 0 at 1981-05-27. | 2022-04-25 10:15:56.877
GC-202206-NYMEX [C] 4 Day #4 | File GC-198104-NYMEX.dly has a volume of 0 at 1981-01-29. | 2022-04-25 10:15:56.887
GC-202206-NYMEX [C] 4 Day #4 | File GC-198104-NYMEX.dly has a volume of 0 at 1981-03-27. | 2022-04-25 10:15:56.887
GC-202206-NYMEX [C] 4 Day #4 | File GC-198102-NYMEX.dly has a volume of 0 at 1980-11-27. | 2022-04-25 10:15:56.897
GC-202206-NYMEX [C] 4 Day #4 | File GC-198102-NYMEX.dly has a volume of 0 at 1981-01-28. | 2022-04-25 10:15:56.897
GC-202206-NYMEX [C] 4 Day #4 | File GC-198012-NYMEX.dly has a volume of 0 at 1980-07-30. | 2022-04-25 10:15:56.914
GC-202206-NYMEX [C] 4 Day #4 | File GC-198012-NYMEX.dly has a volume of 0 at 1980-11-26. | 2022-04-25 10:15:56.914
GC-202206-NYMEX [C] 4 Day #4 | File GC-198008-NYMEX.dly has a volume of 0 at 1980-05-29. | 2022-04-25 10:15:56.925
GC-202206-NYMEX [C] 4 Day #4 | File GC-198008-NYMEX.dly has a volume of 0 at 1980-07-29. | 2022-04-25 10:15:56.925
GC-202206-NYMEX [C] 4 Day #4 | File GC-198006-NYMEX.dly has a volume of 0 at 1980-03-28. | 2022-04-25 10:15:56.935
GC-202206-NYMEX [C] 4 Day #4 | File GC-198006-NYMEX.dly has a volume of 0 at 1980-05-28. | 2022-04-25 10:15:56.935
GC-202206-NYMEX [C] 4 Day #4 | File GC-198004-NYMEX.dly has a volume of 0 at 1980-01-30. | 2022-04-25 10:15:56.945
GC-202206-NYMEX [C] 4 Day #4 | File GC-198004-NYMEX.dly has a volume of 0 at 1980-03-27. | 2022-04-25 10:15:56.945
GC-202206-NYMEX [C] 4 Day #4 | File GC-198002-NYMEX.dly has a volume of 0 at 1979-11-29. | 2022-04-25 10:15:56.956
GC-202206-NYMEX [C] 4 Day #4 | File GC-198002-NYMEX.dly has a volume of 0 at 1980-01-29. | 2022-04-25 10:15:56.956
GC-202206-NYMEX [C] 4 Day #4 | File GC-197912-NYMEX.dly has a volume of 0 at 1979-07-30. | 2022-04-25 10:15:56.972
GC-202206-NYMEX [C] 4 Day #4 | File GC-197912-NYMEX.dly has a volume of 0 at 1979-11-28. | 2022-04-25 10:15:56.972
GC-202206-NYMEX [C] 4 Day #4 | File GC-197908-NYMEX.dly has a volume of 0 at 1979-05-30. | 2022-04-25 10:15:56.983
GC-202206-NYMEX [C] 4 Day #4 | File GC-197908-NYMEX.dly has a volume of 0 at 1979-07-27. | 2022-04-25 10:15:56.983
GC-202206-NYMEX [C] 4 Day #4 | File GC-197906-NYMEX.dly has a volume of 0 at 1979-03-29. | 2022-04-25 10:15:56.994
GC-202206-NYMEX [C] 4 Day #4 | File GC-197906-NYMEX.dly has a volume of 0 at 1979-05-29. | 2022-04-25 10:15:56.994
GC-202206-NYMEX [C] 4 Day #4 | File GC-197904-NYMEX.dly has a volume of 0 at 1979-01-30. | 2022-04-25 10:15:57.004
GC-202206-NYMEX [C] 4 Day #4 | File GC-197904-NYMEX.dly has a volume of 0 at 1979-03-28. | 2022-04-25 10:15:57.004
GC-202206-NYMEX [C] 4 Day #4 | File GC-197902-NYMEX.dly has a volume of 0 at 1978-11-29. | 2022-04-25 10:15:57.014
GC-202206-NYMEX [C] 4 Day #4 | File GC-197902-NYMEX.dly has a volume of 0 at 1979-01-29. | 2022-04-25 10:15:57.014
GC-202206-NYMEX [C] 4 Day #4 | File GC-197812-NYMEX.dly has a volume of 0 at 1978-07-28. | 2022-04-25 10:15:57.031
GC-202206-NYMEX [C] 4 Day #4 | File GC-197812-NYMEX.dly has a volume of 0 at 1978-11-28. | 2022-04-25 10:15:57.031
GC-202206-NYMEX [C] 4 Day #4 | File GC-197808-NYMEX.dly has a volume of 0 at 1978-05-30. | 2022-04-25 10:15:57.042
GC-202206-NYMEX [C] 4 Day #4 | File GC-197808-NYMEX.dly has a volume of 0 at 1978-07-27. | 2022-04-25 10:15:57.042
GC-202206-NYMEX [C] 4 Day #4 | File GC-197806-NYMEX.dly has a volume of 0 at 1978-03-30. | 2022-04-25 10:15:57.052
GC-202206-NYMEX [C] 4 Day #4 | File GC-197806-NYMEX.dly has a volume of 0 at 1978-05-29. | 2022-04-25 10:15:57.052
GC-202206-NYMEX [C] 4 Day #4 | File GC-197804-NYMEX.dly has a volume of 0 at 1978-01-30. | 2022-04-25 10:15:57.062
GC-202206-NYMEX [C] 4 Day #4 | File GC-197804-NYMEX.dly has a volume of 0 at 1978-03-29. | 2022-04-25 10:15:57.062
GC-202206-NYMEX [C] 4 Day #4 | File GC-197802-NYMEX.dly has a volume of 0 at 1977-11-29. | 2022-04-25 10:15:57.072
GC-202206-NYMEX [C] 4 Day #4 | File GC-197802-NYMEX.dly has a volume of 0 at 1978-01-27. | 2022-04-25 10:15:57.072
GC-202206-NYMEX [C] 4 Day #4 | File GC-197712-NYMEX.dly has a volume of 0 at 1977-07-28. | 2022-04-25 10:15:57.090
GC-202206-NYMEX [C] 4 Day #4 | File GC-197712-NYMEX.dly has a volume of 0 at 1977-11-28. | 2022-04-25 10:15:57.090
GC-202206-NYMEX [C] 4 Day #4 | File GC-197708-NYMEX.dly has a volume of 0 at 1977-05-30. | 2022-04-25 10:15:57.100
GC-202206-NYMEX [C] 4 Day #4 | File GC-197708-NYMEX.dly has a volume of 0 at 1977-07-27. | 2022-04-25 10:15:57.100
GC-202206-NYMEX [C] 4 Day #4 | File GC-197706-NYMEX.dly has a volume of 0 at 1977-03-30. | 2022-04-25 10:15:57.110
GC-202206-NYMEX [C] 4 Day #4 | File GC-197706-NYMEX.dly has a volume of 0 at 1977-05-27. | 2022-04-25 10:15:57.110
GC-202206-NYMEX [C] 4 Day #4 | File GC-197704-NYMEX.dly has a volume of 0 at 1977-01-28. | 2022-04-25 10:15:57.121
GC-202206-NYMEX [C] 4 Day #4 | File GC-197704-NYMEX.dly has a volume of 0 at 1977-03-29. | 2022-04-25 10:15:57.121
GC-202206-NYMEX [C] 4 Day #4 | File GC-197702-NYMEX.dly has a volume of 0 at 1976-11-29. | 2022-04-25 10:15:57.131
GC-202206-NYMEX [C] 4 Day #4 | File GC-197702-NYMEX.dly has a volume of 0 at 1977-01-27. | 2022-04-25 10:15:57.131
GC-202206-NYMEX [C] 4 Day #4 | File GC-197612-NYMEX.dly has a volume of 0 at 1976-07-29. | 2022-04-25 10:15:57.148
GC-202206-NYMEX [C] 4 Day #4 | File GC-197612-NYMEX.dly has a volume of 0 at 1976-11-26. | 2022-04-25 10:15:57.148
GC-202206-NYMEX [C] 4 Day #4 | File GC-197608-NYMEX.dly has a volume of 0 at 1976-05-28. | 2022-04-25 10:15:57.159
GC-202206-NYMEX [C] 4 Day #4 | File GC-197608-NYMEX.dly has a volume of 0 at 1976-07-28. | 2022-04-25 10:15:57.159
GC-202206-NYMEX [C] 4 Day #4 | File GC-197606-NYMEX.dly has a volume of 0 at 1976-03-30. | 2022-04-25 10:15:57.169
GC-202206-NYMEX [C] 4 Day #4 | File GC-197606-NYMEX.dly has a volume of 0 at 1976-05-27. | 2022-04-25 10:15:57.169
GC-202206-NYMEX [C] 4 Day #4 | File GC-197604-NYMEX.dly has a volume of 0 at 1976-01-29. | 2022-04-25 10:15:57.180
GC-202206-NYMEX [C] 4 Day #4 | File GC-197604-NYMEX.dly has a volume of 0 at 1976-03-29. | 2022-04-25 10:15:57.180
GC-202206-NYMEX [C] 4 Day #4 | File GC-197602-NYMEX.dly has a volume of 0 at 1975-11-27. | 2022-04-25 10:15:57.190
GC-202206-NYMEX [C] 4 Day #4 | File GC-197602-NYMEX.dly has a volume of 0 at 1976-01-28. | 2022-04-25 10:15:57.190
GC-202206-NYMEX [C] 4 Day #4 | File GC-197512-NYMEX.dly has a volume of 0 at 1975-07-30. | 2022-04-25 10:15:57.206
GC-202206-NYMEX [C] 4 Day #4 | File GC-197512-NYMEX.dly has a volume of 0 at 1975-11-26. | 2022-04-25 10:15:57.206
GC-202206-NYMEX [C] 4 Day #4 | File GC-197508-NYMEX.dly has a volume of 0 at 1975-05-29. | 2022-04-25 10:15:57.217
GC-202206-NYMEX [C] 4 Day #4 | File GC-197508-NYMEX.dly has a volume of 0 at 1975-07-29. | 2022-04-25 10:15:57.217
GC-202206-NYMEX [C] 4 Day #4 | File GC-197506-NYMEX.dly has a volume of 0 at 1975-03-28. | 2022-04-25 10:15:57.228
GC-202206-NYMEX [C] 4 Day #4 | File GC-197506-NYMEX.dly has a volume of 0 at 1975-05-28. | 2022-04-25 10:15:57.228
GC-202206-NYMEX [C] 4 Day #4 | File GC-197504-NYMEX.dly has a volume of 0 at 1975-01-30. | 2022-04-25 10:15:57.238
GC-202206-NYMEX [C] 4 Day #4 | File GC-197504-NYMEX.dly has a volume of 0 at 1975-03-27. | 2022-04-25 10:15:57.238
GC-202206-NYMEX [C] 4 Day #4 | Dates not found while checking for invalid data in continuous contract data files. GC-197502-NYMEX | 2022-04-25 10:15:57.244 *
HD Request # 69 | Receiving historical Daily data for NG-202206-NYMEX starting at 2022-04-20 | 2022-04-25 10:15:57.266
HD Request # 69 | Writing historical Daily data to the file NG-202206-NYMEX.dly | 2022-04-25 10:15:57.266
HD Request # 69 | Bytes received: 215 | 2022-04-25 10:15:57.293
HD Request # 69 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for NG-202206-NYMEX | 2022-04-25 10:15:57.293
HD Request # 69 | Completion time: 11s | 2022-04-25 10:15:57.293
HD Request # 69 | Daily data download complete for NG-202206-NYMEX. Unique request ID: 22 | 2022-04-25 10:15:57.293
Removing historical data download ID 22. | 2022-04-25 10:15:57.293
Triggering next historical data download in queue. | 2022-04-25 10:15:57.293
Historical data download thread signaled to stop. | 2022-04-25 10:15:57.293
HD Request # 71 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:30.695000 | 2022-04-25 10:15:57.293
HD Request # 71 | Received 23 Intraday data records from 2022-04-25 10:12:43.750000 to 2022-04-25 10:14:32.183001 (108.4 seconds) and wrote 20 records for REXR-NQTV | 2022-04-25 10:15:57.293
HD Request # 71 | Completion time: 4s | 2022-04-25 10:15:57.293
HD Request # 71 | Intraday data download complete for REXR-NQTV. Unique request ID: 194 | 2022-04-25 10:15:57.293
Removing historical data download ID 194. | 2022-04-25 10:15:57.293
Real-time Intraday chart data file updates started for REXR-NQTV | 2022-04-25 10:15:57.293
Intraday chart data file opened for REXR-NQTV | 2022-04-25 10:15:57.293
HD Request # 71 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:15:57.293
Mapping CL-198501-NYMEX to CLF85. Service code: nymex | 2022-04-25 10:15:57.309
HD Request # 72 | Downloading Historical Daily chart data for CL-198501-NYMEX. Starting date: 1984-12-12. Service: interactive_brokers.trading | 2022-04-25 10:15:57.311
HD Request # 73 | Downloading Intraday chart data for SPY-NQTV to the file SPY-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:15:57.311
HD Request # 73 | Download start date-time: 2022-04-25 10:13:02.000000. File last date-time: 2022-04-25 10:13:02.286000 | 2022-04-25 10:15:57.311
HD Request # 73 | Using server: ds25.sierracharts.com port 10149 | 2022-04-25 10:15:57.311
Socket (4) | Creating socket. | 2022-04-25 10:15:57.311
Socket (4) | New receive buffer size: 5242880 | 2022-04-25 10:15:57.311
Socket (4) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:15:57.311
NG-202206-NYMEX [C] 4 Day #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:15:57.479
NG-202206-NYMEX [C] 4 Day #4 | Reloading chart. | 2022-04-25 10:15:57.480
NG-202206-NYMEX [C] 64 Day #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:15:57.546
NG-202206-NYMEX [C] 64 Day #9 | Reloading chart. | 2022-04-25 10:15:57.547
NG-202206-NYMEX [C] 32 Day #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:15:57.611
NG-202206-NYMEX [C] 32 Day #1 | Reloading chart. | 2022-04-25 10:15:57.612
SC Data - All Services | Starting real-time market data updates for: GC-202206-NYMEX (GCM22). ID: 109 Service code: comex | 2022-04-25 10:15:57.711
SC Data - All Services | Requesting security definition data for: GC-202206-NYMEX (GCM22). ID: 109 | 2022-04-25 10:15:57.711
HD Request # 73 | Setting DTC encoding to Binary VLS | 2022-04-25 10:15:57.776
HD Request # 73 | Sending historical data logon request message. | 2022-04-25 10:15:57.777
NG-202206-NYMEX [C] 4 Day #4 | Reloading chart. | 2022-04-25 10:15:57.812
NG-202206-NYMEX [C] 4 Day #4 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:57.812
NG-202206-NYMEX [C] 4 Day #4 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:15:57.812
HD Request # 73 | Requesting Intraday data. Start date-time: 2022-04-25 10:13:02. Record interval: 0. Symbol: SPY-NQTV | 2022-04-25 10:15:58.469
HD Request # 73 | Decompressing data. | 2022-04-25 10:15:58.696
Opened cached Intraday file: C:\SierraChart\Data\FR-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:15:58.996
HD Request # 73 | Receiving Intraday data for SPY-NQTV starting at 2022-04-25 10:13:02.110000 | 2022-04-25 10:15:59.152
Socket (4) | CloseSocket call. | 2022-04-25 10:15:59.154
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:15:59.154
Socket (4) | Socket gracefully closed by remote side. | 2022-04-25 10:15:59.384
Socket (4) | Closed. | 2022-04-25 10:15:59.384
NG-202206-NYMEX [C] 4 Day #4 | File NG-200102-NYMEX.dly has a volume of 0 at 2000-12-19. | 2022-04-25 10:15:59.939
NG-202206-NYMEX [C] 4 Day #4 | File NG-200101-NYMEX.dly has a volume of 0 at 2000-11-20. | 2022-04-25 10:15:59.944
NG-202206-NYMEX [C] 4 Day #4 | File NG-200101-NYMEX.dly has a volume of 0 at 2000-12-18. | 2022-04-25 10:15:59.944
NG-202206-NYMEX [C] 4 Day #4 | File NG-200012-NYMEX.dly has a volume of 0 at 2000-10-19. | 2022-04-25 10:15:59.950
NG-202206-NYMEX [C] 4 Day #4 | File NG-200012-NYMEX.dly has a volume of 0 at 2000-11-17. | 2022-04-25 10:15:59.950
NG-202206-NYMEX [C] 4 Day #4 | File NG-200011-NYMEX.dly has a volume of 0 at 2000-09-19. | 2022-04-25 10:15:59.956
NG-202206-NYMEX [C] 4 Day #4 | File NG-200011-NYMEX.dly has a volume of 0 at 2000-10-18. | 2022-04-25 10:15:59.956
NG-202206-NYMEX [C] 4 Day #4 | File NG-200010-NYMEX.dly has a volume of 0 at 2000-08-21. | 2022-04-25 10:15:59.961
NG-202206-NYMEX [C] 4 Day #4 | File NG-200010-NYMEX.dly has a volume of 0 at 2000-09-18. | 2022-04-25 10:15:59.961
NG-202206-NYMEX [C] 4 Day #4 | File NG-200009-NYMEX.dly has a volume of 0 at 2000-07-19. | 2022-04-25 10:15:59.967
NG-202206-NYMEX [C] 4 Day #4 | File NG-200009-NYMEX.dly has a volume of 0 at 2000-08-18. | 2022-04-25 10:15:59.967
NG-202206-NYMEX [C] 4 Day #4 | File NG-200008-NYMEX.dly has a volume of 0 at 2000-06-20. | 2022-04-25 10:15:59.972
NG-202206-NYMEX [C] 4 Day #4 | File NG-200008-NYMEX.dly has a volume of 0 at 2000-07-18. | 2022-04-25 10:15:59.972
NG-202206-NYMEX [C] 4 Day #4 | File NG-200007-NYMEX.dly has a volume of 0 at 2000-05-19. | 2022-04-25 10:15:59.978
NG-202206-NYMEX [C] 4 Day #4 | File NG-200007-NYMEX.dly has a volume of 0 at 2000-06-19. | 2022-04-25 10:15:59.978
NG-202206-NYMEX [C] 4 Day #4 | File NG-200006-NYMEX.dly has a volume of 0 at 2000-04-18. | 2022-04-25 10:15:59.984
NG-202206-NYMEX [C] 4 Day #4 | File NG-200006-NYMEX.dly has a volume of 0 at 2000-05-18. | 2022-04-25 10:15:59.984
NG-202206-NYMEX [C] 4 Day #4 | File NG-200005-NYMEX.dly has a volume of 0 at 2000-03-21. | 2022-04-25 10:15:59.989
NG-202206-NYMEX [C] 4 Day #4 | File NG-200005-NYMEX.dly has a volume of 0 at 2000-04-17. | 2022-04-25 10:15:59.989
NG-202206-NYMEX [C] 4 Day #4 | File NG-200004-NYMEX.dly has a volume of 0 at 2000-02-17. | 2022-04-25 10:15:59.995
NG-202206-NYMEX [C] 4 Day #4 | File NG-200004-NYMEX.dly has a volume of 0 at 2000-03-20. | 2022-04-25 10:15:59.995
NG-202206-NYMEX [C] 4 Day #4 | File NG-200003-NYMEX.dly has a volume of 0 at 2000-01-19. | 2022-04-25 10:16:00.001
NG-202206-NYMEX [C] 4 Day #4 | File NG-200003-NYMEX.dly has a volume of 0 at 2000-02-16. | 2022-04-25 10:16:00.001
NG-202206-NYMEX [C] 4 Day #4 | File NG-200002-NYMEX.dly has a volume of 0 at 1999-12-21. | 2022-04-25 10:16:00.005
NG-202206-NYMEX [C] 4 Day #4 | File NG-200002-NYMEX.dly has a volume of 0 at 2000-01-18. | 2022-04-25 10:16:00.005
NG-202206-NYMEX [C] 4 Day #4 | File NG-200001-NYMEX.dly has a volume of 0 at 1999-11-18. | 2022-04-25 10:16:00.011
NG-202206-NYMEX [C] 4 Day #4 | File NG-200001-NYMEX.dly has a volume of 0 at 1999-12-20. | 2022-04-25 10:16:00.011
NG-202206-NYMEX [C] 4 Day #4 | File NG-199912-NYMEX.dly has a volume of 0 at 1999-10-19. | 2022-04-25 10:16:00.016
NG-202206-NYMEX [C] 4 Day #4 | File NG-199912-NYMEX.dly has a volume of 0 at 1999-11-17. | 2022-04-25 10:16:00.016
NG-202206-NYMEX [C] 4 Day #4 | File NG-199911-NYMEX.dly has a volume of 0 at 1999-09-20. | 2022-04-25 10:16:00.022
NG-202206-NYMEX [C] 4 Day #4 | File NG-199911-NYMEX.dly has a volume of 0 at 1999-10-18. | 2022-04-25 10:16:00.022
NG-202206-NYMEX [C] 4 Day #4 | File NG-199910-NYMEX.dly has a volume of 0 at 1999-08-19. | 2022-04-25 10:16:00.028
NG-202206-NYMEX [C] 4 Day #4 | File NG-199910-NYMEX.dly has a volume of 0 at 1999-09-17. | 2022-04-25 10:16:00.028
NG-202206-NYMEX [C] 4 Day #4 | File NG-199909-NYMEX.dly has a volume of 0 at 1999-07-20. | 2022-04-25 10:16:00.033
NG-202206-NYMEX [C] 4 Day #4 | File NG-199909-NYMEX.dly has a volume of 0 at 1999-08-18. | 2022-04-25 10:16:00.033
NG-202206-NYMEX [C] 4 Day #4 | File NG-199908-NYMEX.dly has a volume of 0 at 1999-06-18. | 2022-04-25 10:16:00.039
NG-202206-NYMEX [C] 4 Day #4 | File NG-199908-NYMEX.dly has a volume of 0 at 1999-07-19. | 2022-04-25 10:16:00.039
NG-202206-NYMEX [C] 4 Day #4 | File NG-199907-NYMEX.dly has a volume of 0 at 1999-05-19. | 2022-04-25 10:16:00.045
NG-202206-NYMEX [C] 4 Day #4 | File NG-199907-NYMEX.dly has a volume of 0 at 1999-06-17. | 2022-04-25 10:16:00.045
NG-202206-NYMEX [C] 4 Day #4 | File NG-199906-NYMEX.dly has a volume of 0 at 1999-04-20. | 2022-04-25 10:16:00.050
NG-202206-NYMEX [C] 4 Day #4 | File NG-199906-NYMEX.dly has a volume of 0 at 1999-05-18. | 2022-04-25 10:16:00.050
NG-202206-NYMEX [C] 4 Day #4 | File NG-199905-NYMEX.dly has a volume of 0 at 1999-03-19. | 2022-04-25 10:16:00.056
NG-202206-NYMEX [C] 4 Day #4 | File NG-199905-NYMEX.dly has a volume of 0 at 1999-04-19. | 2022-04-25 10:16:00.056
NG-202206-NYMEX [C] 4 Day #4 | File NG-199904-NYMEX.dly has a volume of 0 at 1999-02-16. | 2022-04-25 10:16:00.062
NG-202206-NYMEX [C] 4 Day #4 | File NG-199904-NYMEX.dly has a volume of 0 at 1999-03-18. | 2022-04-25 10:16:00.062
NG-202206-NYMEX [C] 4 Day #4 | File NG-199903-NYMEX.dly has a volume of 0 at 1999-01-19. | 2022-04-25 10:16:00.067
NG-202206-NYMEX [C] 4 Day #4 | File NG-199903-NYMEX.dly has a volume of 0 at 1999-02-15. | 2022-04-25 10:16:00.067
NG-202206-NYMEX [C] 4 Day #4 | File NG-199902-NYMEX.dly has a volume of 0 at 1998-12-21. | 2022-04-25 10:16:00.072
NG-202206-NYMEX [C] 4 Day #4 | File NG-199902-NYMEX.dly has a volume of 0 at 1999-01-18. | 2022-04-25 10:16:00.072
NG-202206-NYMEX [C] 4 Day #4 | File NG-199901-NYMEX.dly has a volume of 0 at 1998-11-18. | 2022-04-25 10:16:00.078
NG-202206-NYMEX [C] 4 Day #4 | File NG-199901-NYMEX.dly has a volume of 0 at 1998-12-18. | 2022-04-25 10:16:00.078
NG-202206-NYMEX [C] 4 Day #4 | File NG-199812-NYMEX.dly has a volume of 0 at 1998-10-20. | 2022-04-25 10:16:00.083
NG-202206-NYMEX [C] 4 Day #4 | File NG-199812-NYMEX.dly has a volume of 0 at 1998-11-17. | 2022-04-25 10:16:00.083
NG-202206-NYMEX [C] 4 Day #4 | File NG-199811-NYMEX.dly has a volume of 0 at 1998-09-18. | 2022-04-25 10:16:00.089
NG-202206-NYMEX [C] 4 Day #4 | File NG-199811-NYMEX.dly has a volume of 0 at 1998-10-19. | 2022-04-25 10:16:00.089
NG-202206-NYMEX [C] 4 Day #4 | File NG-199810-NYMEX.dly has a volume of 0 at 1998-08-19. | 2022-04-25 10:16:00.094
NG-202206-NYMEX [C] 4 Day #4 | File NG-199810-NYMEX.dly has a volume of 0 at 1998-09-17. | 2022-04-25 10:16:00.094
NG-202206-NYMEX [C] 4 Day #4 | File NG-199809-NYMEX.dly has a volume of 0 at 1998-07-21. | 2022-04-25 10:16:00.100
NG-202206-NYMEX [C] 4 Day #4 | File NG-199809-NYMEX.dly has a volume of 0 at 1998-08-18. | 2022-04-25 10:16:00.100
NG-202206-NYMEX [C] 4 Day #4 | File NG-199808-NYMEX.dly has a volume of 0 at 1998-06-18. | 2022-04-25 10:16:00.106
NG-202206-NYMEX [C] 4 Day #4 | File NG-199808-NYMEX.dly has a volume of 0 at 1998-07-20. | 2022-04-25 10:16:00.106
NG-202206-NYMEX [C] 4 Day #4 | File NG-199807-NYMEX.dly has a volume of 0 at 1998-05-19. | 2022-04-25 10:16:00.111
NG-202206-NYMEX [C] 4 Day #4 | File NG-199807-NYMEX.dly has a volume of 0 at 1998-06-17. | 2022-04-25 10:16:00.111
NG-202206-NYMEX [C] 4 Day #4 | File NG-199806-NYMEX.dly has a volume of 0 at 1998-04-20. | 2022-04-25 10:16:00.117
NG-202206-NYMEX [C] 4 Day #4 | File NG-199806-NYMEX.dly has a volume of 0 at 1998-05-18. | 2022-04-25 10:16:00.117
NG-202206-NYMEX [C] 4 Day #4 | File NG-199805-NYMEX.dly has a volume of 0 at 1998-03-19. | 2022-04-25 10:16:00.122
NG-202206-NYMEX [C] 4 Day #4 | File NG-199805-NYMEX.dly has a volume of 0 at 1998-04-17. | 2022-04-25 10:16:00.122
NG-202206-NYMEX [C] 4 Day #4 | File NG-199804-NYMEX.dly has a volume of 0 at 1998-02-17. | 2022-04-25 10:16:00.128
NG-202206-NYMEX [C] 4 Day #4 | File NG-199804-NYMEX.dly has a volume of 0 at 1998-03-18. | 2022-04-25 10:16:00.128
NG-202206-NYMEX [C] 4 Day #4 | File NG-199803-NYMEX.dly has a volume of 0 at 1998-01-20. | 2022-04-25 10:16:00.134
NG-202206-NYMEX [C] 4 Day #4 | File NG-199803-NYMEX.dly has a volume of 0 at 1998-02-16. | 2022-04-25 10:16:00.134
NG-202206-NYMEX [C] 4 Day #4 | File NG-199802-NYMEX.dly has a volume of 0 at 1997-12-19. | 2022-04-25 10:16:00.139
NG-202206-NYMEX [C] 4 Day #4 | File NG-199802-NYMEX.dly has a volume of 0 at 1998-01-19. | 2022-04-25 10:16:00.139
NG-202206-NYMEX [C] 4 Day #4 | File NG-199801-NYMEX.dly has a volume of 0 at 1997-11-18. | 2022-04-25 10:16:00.145
NG-202206-NYMEX [C] 4 Day #4 | File NG-199801-NYMEX.dly has a volume of 0 at 1997-12-18. | 2022-04-25 10:16:00.145
NG-202206-NYMEX [C] 4 Day #4 | File NG-199712-NYMEX.dly has a volume of 0 at 1997-10-21. | 2022-04-25 10:16:00.150
NG-202206-NYMEX [C] 4 Day #4 | File NG-199712-NYMEX.dly has a volume of 0 at 1997-11-17. | 2022-04-25 10:16:00.150
NG-202206-NYMEX [C] 4 Day #4 | File NG-199711-NYMEX.dly has a volume of 0 at 1997-09-18. | 2022-04-25 10:16:00.155
NG-202206-NYMEX [C] 4 Day #4 | File NG-199711-NYMEX.dly has a volume of 0 at 1997-10-20. | 2022-04-25 10:16:00.155
NG-202206-NYMEX [C] 4 Day #4 | File NG-199710-NYMEX.dly has a volume of 0 at 1997-08-19. | 2022-04-25 10:16:00.161
NG-202206-NYMEX [C] 4 Day #4 | File NG-199710-NYMEX.dly has a volume of 0 at 1997-09-17. | 2022-04-25 10:16:00.161
NG-202206-NYMEX [C] 4 Day #4 | File NG-199709-NYMEX.dly has a volume of 0 at 1997-07-21. | 2022-04-25 10:16:00.166
NG-202206-NYMEX [C] 4 Day #4 | File NG-199709-NYMEX.dly has a volume of 0 at 1997-08-18. | 2022-04-25 10:16:00.167
NG-202206-NYMEX [C] 4 Day #4 | File NG-199708-NYMEX.dly has a volume of 0 at 1997-06-18. | 2022-04-25 10:16:00.172
NG-202206-NYMEX [C] 4 Day #4 | File NG-199708-NYMEX.dly has a volume of 0 at 1997-07-18. | 2022-04-25 10:16:00.172
NG-202206-NYMEX [C] 4 Day #4 | File NG-199707-NYMEX.dly has a volume of 0 at 1997-05-20. | 2022-04-25 10:16:00.178
NG-202206-NYMEX [C] 4 Day #4 | File NG-199707-NYMEX.dly has a volume of 0 at 1997-06-17. | 2022-04-25 10:16:00.178
NG-202206-NYMEX [C] 4 Day #4 | File NG-199706-NYMEX.dly has a volume of 0 at 1997-04-18. | 2022-04-25 10:16:00.183
NG-202206-NYMEX [C] 4 Day #4 | File NG-199706-NYMEX.dly has a volume of 0 at 1997-05-19. | 2022-04-25 10:16:00.183
NG-202206-NYMEX [C] 4 Day #4 | File NG-199705-NYMEX.dly has a volume of 0 at 1997-03-19. | 2022-04-25 10:16:00.189
NG-202206-NYMEX [C] 4 Day #4 | File NG-199705-NYMEX.dly has a volume of 0 at 1997-04-17. | 2022-04-25 10:16:00.189
NG-202206-NYMEX [C] 4 Day #4 | File NG-199704-NYMEX.dly has a volume of 0 at 1997-02-18. | 2022-04-25 10:16:00.194
NG-202206-NYMEX [C] 4 Day #4 | File NG-199704-NYMEX.dly has a volume of 0 at 1997-03-18. | 2022-04-25 10:16:00.194
NG-202206-NYMEX [C] 4 Day #4 | File NG-199703-NYMEX.dly has a volume of 0 at 1997-01-21. | 2022-04-25 10:16:00.199
NG-202206-NYMEX [C] 4 Day #4 | File NG-199703-NYMEX.dly has a volume of 0 at 1997-02-17. | 2022-04-25 10:16:00.199
NG-202206-NYMEX [C] 4 Day #4 | File NG-199702-NYMEX.dly has a volume of 0 at 1996-12-19. | 2022-04-25 10:16:00.204
NG-202206-NYMEX [C] 4 Day #4 | File NG-199702-NYMEX.dly has a volume of 0 at 1997-01-20. | 2022-04-25 10:16:00.204
NG-202206-NYMEX [C] 4 Day #4 | File NG-199701-NYMEX.dly has a volume of 0 at 1996-11-19. | 2022-04-25 10:16:00.209
NG-202206-NYMEX [C] 4 Day #4 | File NG-199701-NYMEX.dly has a volume of 0 at 1996-12-18. | 2022-04-25 10:16:00.209
NG-202206-NYMEX [C] 4 Day #4 | File NG-199612-NYMEX.dly has a volume of 0 at 1996-10-21. | 2022-04-25 10:16:00.214
NG-202206-NYMEX [C] 4 Day #4 | File NG-199612-NYMEX.dly has a volume of 0 at 1996-11-18. | 2022-04-25 10:16:00.214
NG-202206-NYMEX [C] 4 Day #4 | File NG-199611-NYMEX.dly has a volume of 0 at 1996-09-18. | 2022-04-25 10:16:00.220
NG-202206-NYMEX [C] 4 Day #4 | File NG-199611-NYMEX.dly has a volume of 0 at 1996-10-18. | 2022-04-25 10:16:00.220
NG-202206-NYMEX [C] 4 Day #4 | File NG-199610-NYMEX.dly has a volume of 0 at 1996-08-20. | 2022-04-25 10:16:00.225
NG-202206-NYMEX [C] 4 Day #4 | File NG-199610-NYMEX.dly has a volume of 0 at 1996-09-17. | 2022-04-25 10:16:00.225
NG-202206-NYMEX [C] 4 Day #4 | File NG-199609-NYMEX.dly has a volume of 0 at 1996-07-19. | 2022-04-25 10:16:00.230
NG-202206-NYMEX [C] 4 Day #4 | File NG-199609-NYMEX.dly has a volume of 0 at 1996-08-19. | 2022-04-25 10:16:00.230
NG-202206-NYMEX [C] 4 Day #4 | File NG-199608-NYMEX.dly has a volume of 0 at 1996-06-18. | 2022-04-25 10:16:00.236
NG-202206-NYMEX [C] 4 Day #4 | File NG-199608-NYMEX.dly has a volume of 0 at 1996-07-18. | 2022-04-25 10:16:00.236
NG-202206-NYMEX [C] 4 Day #4 | File NG-199607-NYMEX.dly has a volume of 0 at 1996-05-21. | 2022-04-25 10:16:00.240
NG-202206-NYMEX [C] 4 Day #4 | File NG-199607-NYMEX.dly has a volume of 0 at 1996-06-17. | 2022-04-25 10:16:00.241
NG-202206-NYMEX [C] 4 Day #4 | File NG-199606-NYMEX.dly has a volume of 0 at 1996-04-18. | 2022-04-25 10:16:00.246
NG-202206-NYMEX [C] 4 Day #4 | File NG-199606-NYMEX.dly has a volume of 0 at 1996-05-20. | 2022-04-25 10:16:00.246
NG-202206-NYMEX [C] 4 Day #4 | File NG-199605-NYMEX.dly has a volume of 0 at 1996-03-19. | 2022-04-25 10:16:00.251
NG-202206-NYMEX [C] 4 Day #4 | File NG-199605-NYMEX.dly has a volume of 0 at 1996-04-17. | 2022-04-25 10:16:00.251
NG-202206-NYMEX [C] 4 Day #4 | File NG-199604-NYMEX.dly has a volume of 0 at 1996-02-19. | 2022-04-25 10:16:00.257
NG-202206-NYMEX [C] 4 Day #4 | File NG-199604-NYMEX.dly has a volume of 0 at 1996-03-18. | 2022-04-25 10:16:00.257
NG-202206-NYMEX [C] 4 Day #4 | File NG-199603-NYMEX.dly has a volume of 0 at 1996-01-19. | 2022-04-25 10:16:00.262
NG-202206-NYMEX [C] 4 Day #4 | File NG-199603-NYMEX.dly has a volume of 0 at 1996-02-16. | 2022-04-25 10:16:00.262
NG-202206-NYMEX [C] 4 Day #4 | File NG-199602-NYMEX.dly has a volume of 0 at 1995-12-19. | 2022-04-25 10:16:00.267
NG-202206-NYMEX [C] 4 Day #4 | File NG-199602-NYMEX.dly has a volume of 0 at 1996-01-18. | 2022-04-25 10:16:00.267
NG-202206-NYMEX [C] 4 Day #4 | File NG-199601-NYMEX.dly has a volume of 0 at 1995-11-20. | 2022-04-25 10:16:00.271
NG-202206-NYMEX [C] 4 Day #4 | File NG-199601-NYMEX.dly has a volume of 0 at 1995-12-18. | 2022-04-25 10:16:00.271
NG-202206-NYMEX [C] 4 Day #4 | File NG-199512-NYMEX.dly has a volume of 0 at 1995-10-19. | 2022-04-25 10:16:00.276
NG-202206-NYMEX [C] 4 Day #4 | File NG-199512-NYMEX.dly has a volume of 0 at 1995-11-17. | 2022-04-25 10:16:00.276
NG-202206-NYMEX [C] 4 Day #4 | File NG-199511-NYMEX.dly has a volume of 0 at 1995-09-19. | 2022-04-25 10:16:00.282
NG-202206-NYMEX [C] 4 Day #4 | File NG-199511-NYMEX.dly has a volume of 0 at 1995-10-18. | 2022-04-25 10:16:00.282
NG-202206-NYMEX [C] 4 Day #4 | File NG-199510-NYMEX.dly has a volume of 0 at 1995-08-21. | 2022-04-25 10:16:00.287
NG-202206-NYMEX [C] 4 Day #4 | File NG-199510-NYMEX.dly has a volume of 0 at 1995-09-18. | 2022-04-25 10:16:00.287
NG-202206-NYMEX [C] 4 Day #4 | File NG-199509-NYMEX.dly has a volume of 0 at 1995-07-19. | 2022-04-25 10:16:00.292
NG-202206-NYMEX [C] 4 Day #4 | File NG-199509-NYMEX.dly has a volume of 0 at 1995-08-18. | 2022-04-25 10:16:00.292
NG-202206-NYMEX [C] 4 Day #4 | File NG-199508-NYMEX.dly has a volume of 0 at 1995-06-20. | 2022-04-25 10:16:00.297
NG-202206-NYMEX [C] 4 Day #4 | File NG-199508-NYMEX.dly has a volume of 0 at 1995-07-18. | 2022-04-25 10:16:00.297
NG-202206-NYMEX [C] 4 Day #4 | File NG-199507-NYMEX.dly has a volume of 0 at 1995-05-19. | 2022-04-25 10:16:00.302
NG-202206-NYMEX [C] 4 Day #4 | File NG-199507-NYMEX.dly has a volume of 0 at 1995-06-19. | 2022-04-25 10:16:00.302
NG-202206-NYMEX [C] 4 Day #4 | File NG-199506-NYMEX.dly has a volume of 0 at 1995-04-18. | 2022-04-25 10:16:00.307
NG-202206-NYMEX [C] 4 Day #4 | File NG-199506-NYMEX.dly has a volume of 0 at 1995-05-18. | 2022-04-25 10:16:00.307
NG-202206-NYMEX [C] 4 Day #4 | File NG-199505-NYMEX.dly has a volume of 0 at 1995-03-21. | 2022-04-25 10:16:00.312
NG-202206-NYMEX [C] 4 Day #4 | File NG-199505-NYMEX.dly has a volume of 0 at 1995-04-17. | 2022-04-25 10:16:00.312
NG-202206-NYMEX [C] 4 Day #4 | File NG-199504-NYMEX.dly has a volume of 0 at 1995-02-16. | 2022-04-25 10:16:00.317
NG-202206-NYMEX [C] 4 Day #4 | File NG-199504-NYMEX.dly has a volume of 0 at 1995-03-20. | 2022-04-25 10:16:00.317
NG-202206-NYMEX [C] 4 Day #4 | File NG-199503-NYMEX.dly has a volume of 0 at 1995-01-19. | 2022-04-25 10:16:00.322
NG-202206-NYMEX [C] 4 Day #4 | File NG-199503-NYMEX.dly has a volume of 0 at 1995-02-15. | 2022-04-25 10:16:00.322
NG-202206-NYMEX [C] 4 Day #4 | File NG-199502-NYMEX.dly has a volume of 0 at 1994-12-20. | 2022-04-25 10:16:00.327
NG-202206-NYMEX [C] 4 Day #4 | File NG-199502-NYMEX.dly has a volume of 0 at 1995-01-18. | 2022-04-25 10:16:00.327
NG-202206-NYMEX [C] 4 Day #4 | File NG-199501-NYMEX.dly has a volume of 0 at 1994-11-18. | 2022-04-25 10:16:00.332
NG-202206-NYMEX [C] 4 Day #4 | File NG-199501-NYMEX.dly has a volume of 0 at 1994-12-19. | 2022-04-25 10:16:00.332
NG-202206-NYMEX [C] 4 Day #4 | File NG-199412-NYMEX.dly has a volume of 0 at 1994-10-19. | 2022-04-25 10:16:00.337
NG-202206-NYMEX [C] 4 Day #4 | File NG-199412-NYMEX.dly has a volume of 0 at 1994-11-17. | 2022-04-25 10:16:00.337
NG-202206-NYMEX [C] 4 Day #4 | File NG-199411-NYMEX.dly has a volume of 0 at 1994-09-20. | 2022-04-25 10:16:00.342
NG-202206-NYMEX [C] 4 Day #4 | File NG-199411-NYMEX.dly has a volume of 0 at 1994-10-18. | 2022-04-25 10:16:00.342
NG-202206-NYMEX [C] 4 Day #4 | File NG-199410-NYMEX.dly has a volume of 0 at 1994-08-19. | 2022-04-25 10:16:00.346
NG-202206-NYMEX [C] 4 Day #4 | File NG-199410-NYMEX.dly has a volume of 0 at 1994-09-19. | 2022-04-25 10:16:00.346
NG-202206-NYMEX [C] 4 Day #4 | File NG-199409-NYMEX.dly has a volume of 0 at 1994-07-19. | 2022-04-25 10:16:00.352
NG-202206-NYMEX [C] 4 Day #4 | File NG-199409-NYMEX.dly has a volume of 0 at 1994-08-18. | 2022-04-25 10:16:00.352
NG-202206-NYMEX [C] 4 Day #4 | File NG-199408-NYMEX.dly has a volume of 0 at 1994-06-20. | 2022-04-25 10:16:00.357
NG-202206-NYMEX [C] 4 Day #4 | File NG-199408-NYMEX.dly has a volume of 0 at 1994-07-18. | 2022-04-25 10:16:00.357
NG-202206-NYMEX [C] 4 Day #4 | File NG-199407-NYMEX.dly has a volume of 0 at 1994-05-19. | 2022-04-25 10:16:00.362
NG-202206-NYMEX [C] 4 Day #4 | File NG-199407-NYMEX.dly has a volume of 0 at 1994-06-17. | 2022-04-25 10:16:00.362
NG-202206-NYMEX [C] 4 Day #4 | File NG-199406-NYMEX.dly has a volume of 0 at 1994-04-19. | 2022-04-25 10:16:00.367
NG-202206-NYMEX [C] 4 Day #4 | File NG-199406-NYMEX.dly has a volume of 0 at 1994-05-18. | 2022-04-25 10:16:00.367
NG-202206-NYMEX [C] 4 Day #4 | File NG-199405-NYMEX.dly has a volume of 0 at 1994-03-21. | 2022-04-25 10:16:00.371
NG-202206-NYMEX [C] 4 Day #4 | File NG-199405-NYMEX.dly has a volume of 0 at 1994-04-18. | 2022-04-25 10:16:00.371
NG-202206-NYMEX [C] 4 Day #4 | File NG-199404-NYMEX.dly has a volume of 0 at 1994-02-16. | 2022-04-25 10:16:00.377
NG-202206-NYMEX [C] 4 Day #4 | File NG-199404-NYMEX.dly has a volume of 0 at 1994-03-18. | 2022-04-25 10:16:00.377
NG-202206-NYMEX [C] 4 Day #4 | File NG-199403-NYMEX.dly has a volume of 0 at 1994-01-19. | 2022-04-25 10:16:00.382
NG-202206-NYMEX [C] 4 Day #4 | File NG-199403-NYMEX.dly has a volume of 0 at 1994-02-15. | 2022-04-25 10:16:00.382
NG-202206-NYMEX [C] 4 Day #4 | File NG-199402-NYMEX.dly has a volume of 0 at 1993-12-21. | 2022-04-25 10:16:00.386
NG-202206-NYMEX [C] 4 Day #4 | File NG-199402-NYMEX.dly has a volume of 0 at 1994-01-18. | 2022-04-25 10:16:00.386
NG-202206-NYMEX [C] 4 Day #4 | File NG-199401-NYMEX.dly has a volume of 0 at 1993-11-18. | 2022-04-25 10:16:00.391
NG-202206-NYMEX [C] 4 Day #4 | File NG-199401-NYMEX.dly has a volume of 0 at 1993-12-20. | 2022-04-25 10:16:00.391
NG-202206-NYMEX [C] 4 Day #4 | File NG-199312-NYMEX.dly has a volume of 0 at 1993-10-19. | 2022-04-25 10:16:00.396
NG-202206-NYMEX [C] 4 Day #4 | File NG-199312-NYMEX.dly has a volume of 0 at 1993-11-17. | 2022-04-25 10:16:00.396
NG-202206-NYMEX [C] 4 Day #4 | File NG-199311-NYMEX.dly has a volume of 0 at 1993-09-20. | 2022-04-25 10:16:00.401
NG-202206-NYMEX [C] 4 Day #4 | File NG-199311-NYMEX.dly has a volume of 0 at 1993-10-18. | 2022-04-25 10:16:00.401
NG-202206-NYMEX [C] 4 Day #4 | File NG-199310-NYMEX.dly has a volume of 0 at 1993-08-19. | 2022-04-25 10:16:00.406
NG-202206-NYMEX [C] 4 Day #4 | File NG-199310-NYMEX.dly has a volume of 0 at 1993-09-17. | 2022-04-25 10:16:00.406
NG-202206-NYMEX [C] 4 Day #4 | File NG-199309-NYMEX.dly has a volume of 0 at 1993-07-20. | 2022-04-25 10:16:00.412
NG-202206-NYMEX [C] 4 Day #4 | File NG-199309-NYMEX.dly has a volume of 0 at 1993-08-18. | 2022-04-25 10:16:00.412
NG-202206-NYMEX [C] 4 Day #4 | File NG-199308-NYMEX.dly has a volume of 0 at 1993-06-18. | 2022-04-25 10:16:00.417
NG-202206-NYMEX [C] 4 Day #4 | File NG-199308-NYMEX.dly has a volume of 0 at 1993-07-19. | 2022-04-25 10:16:00.417
NG-202206-NYMEX [C] 4 Day #4 | File NG-199307-NYMEX.dly has a volume of 0 at 1993-05-19. | 2022-04-25 10:16:00.421
NG-202206-NYMEX [C] 4 Day #4 | File NG-199307-NYMEX.dly has a volume of 0 at 1993-06-17. | 2022-04-25 10:16:00.421
NG-202206-NYMEX [C] 4 Day #4 | File NG-199306-NYMEX.dly has a volume of 0 at 1993-04-20. | 2022-04-25 10:16:00.426
NG-202206-NYMEX [C] 4 Day #4 | File NG-199306-NYMEX.dly has a volume of 0 at 1993-05-18. | 2022-04-25 10:16:00.426
NG-202206-NYMEX [C] 4 Day #4 | File NG-199305-NYMEX.dly has a volume of 0 at 1993-03-19. | 2022-04-25 10:16:00.431
NG-202206-NYMEX [C] 4 Day #4 | File NG-199305-NYMEX.dly has a volume of 0 at 1993-04-19. | 2022-04-25 10:16:00.431
NG-202206-NYMEX [C] 4 Day #4 | File NG-199304-NYMEX.dly has a volume of 0 at 1993-02-16. | 2022-04-25 10:16:00.437
NG-202206-NYMEX [C] 4 Day #4 | File NG-199304-NYMEX.dly has a volume of 0 at 1993-03-18. | 2022-04-25 10:16:00.437
NG-202206-NYMEX [C] 4 Day #4 | File NG-199303-NYMEX.dly has a volume of 0 at 1993-01-19. | 2022-04-25 10:16:00.441
NG-202206-NYMEX [C] 4 Day #4 | File NG-199303-NYMEX.dly has a volume of 0 at 1993-02-15. | 2022-04-25 10:16:00.441
NG-202206-NYMEX [C] 4 Day #4 | File NG-199302-NYMEX.dly has a volume of 0 at 1992-12-21. | 2022-04-25 10:16:00.446
NG-202206-NYMEX [C] 4 Day #4 | File NG-199302-NYMEX.dly has a volume of 0 at 1993-01-18. | 2022-04-25 10:16:00.446
NG-202206-NYMEX [C] 4 Day #4 | File NG-199301-NYMEX.dly has a volume of 0 at 1992-11-18. | 2022-04-25 10:16:00.451
NG-202206-NYMEX [C] 4 Day #4 | File NG-199301-NYMEX.dly has a volume of 0 at 1992-12-18. | 2022-04-25 10:16:00.451
NG-202206-NYMEX [C] 4 Day #4 | File NG-199212-NYMEX.dly has a volume of 0 at 1992-10-20. | 2022-04-25 10:16:00.456
NG-202206-NYMEX [C] 4 Day #4 | File NG-199212-NYMEX.dly has a volume of 0 at 1992-11-17. | 2022-04-25 10:16:00.456
NG-202206-NYMEX [C] 4 Day #4 | File NG-199211-NYMEX.dly has a volume of 0 at 1992-09-18. | 2022-04-25 10:16:00.461
NG-202206-NYMEX [C] 4 Day #4 | File NG-199211-NYMEX.dly has a volume of 0 at 1992-10-19. | 2022-04-25 10:16:00.461
NG-202206-NYMEX [C] 4 Day #4 | File NG-199210-NYMEX.dly has a volume of 0 at 1992-08-19. | 2022-04-25 10:16:00.466
NG-202206-NYMEX [C] 4 Day #4 | File NG-199210-NYMEX.dly has a volume of 0 at 1992-09-17. | 2022-04-25 10:16:00.466
NG-202206-NYMEX [C] 4 Day #4 | File NG-199209-NYMEX.dly has a volume of 0 at 1992-07-21. | 2022-04-25 10:16:00.471
NG-202206-NYMEX [C] 4 Day #4 | File NG-199209-NYMEX.dly has a volume of 0 at 1992-08-18. | 2022-04-25 10:16:00.471
NG-202206-NYMEX [C] 4 Day #4 | File NG-199208-NYMEX.dly has a volume of 0 at 1992-06-18. | 2022-04-25 10:16:00.476
NG-202206-NYMEX [C] 4 Day #4 | File NG-199208-NYMEX.dly has a volume of 0 at 1992-07-20. | 2022-04-25 10:16:00.476
NG-202206-NYMEX [C] 4 Day #4 | File NG-199207-NYMEX.dly has a volume of 0 at 1992-05-19. | 2022-04-25 10:16:00.481
NG-202206-NYMEX [C] 4 Day #4 | File NG-199207-NYMEX.dly has a volume of 0 at 1992-06-17. | 2022-04-25 10:16:00.481
NG-202206-NYMEX [C] 4 Day #4 | File NG-199206-NYMEX.dly has a volume of 0 at 1992-04-20. | 2022-04-25 10:16:00.486
NG-202206-NYMEX [C] 4 Day #4 | File NG-199206-NYMEX.dly has a volume of 0 at 1992-05-18. | 2022-04-25 10:16:00.486
NG-202206-NYMEX [C] 4 Day #4 | File NG-199205-NYMEX.dly has a volume of 0 at 1992-03-19. | 2022-04-25 10:16:00.491
NG-202206-NYMEX [C] 4 Day #4 | File NG-199205-NYMEX.dly has a volume of 0 at 1992-04-17. | 2022-04-25 10:16:00.491
NG-202206-NYMEX [C] 4 Day #4 | File NG-199204-NYMEX.dly has a volume of 0 at 1992-02-18. | 2022-04-25 10:16:00.496
NG-202206-NYMEX [C] 4 Day #4 | File NG-199204-NYMEX.dly has a volume of 0 at 1992-03-18. | 2022-04-25 10:16:00.496
NG-202206-NYMEX [C] 4 Day #4 | File NG-199203-NYMEX.dly has a volume of 0 at 1992-01-21. | 2022-04-25 10:16:00.501
NG-202206-NYMEX [C] 4 Day #4 | File NG-199203-NYMEX.dly has a volume of 0 at 1992-02-17. | 2022-04-25 10:16:00.501
NG-202206-NYMEX [C] 4 Day #4 | File NG-199202-NYMEX.dly has a volume of 0 at 1991-12-19. | 2022-04-25 10:16:00.506
NG-202206-NYMEX [C] 4 Day #4 | File NG-199202-NYMEX.dly has a volume of 0 at 1992-01-20. | 2022-04-25 10:16:00.506
NG-202206-NYMEX [C] 4 Day #4 | File NG-199201-NYMEX.dly has a volume of 0 at 1991-11-19. | 2022-04-25 10:16:00.510
NG-202206-NYMEX [C] 4 Day #4 | File NG-199201-NYMEX.dly has a volume of 0 at 1991-12-18. | 2022-04-25 10:16:00.510
NG-202206-NYMEX [C] 4 Day #4 | File NG-199112-NYMEX.dly has a volume of 0 at 1991-10-21. | 2022-04-25 10:16:00.515
NG-202206-NYMEX [C] 4 Day #4 | File NG-199112-NYMEX.dly has a volume of 0 at 1991-11-18. | 2022-04-25 10:16:00.515
NG-202206-NYMEX [C] 4 Day #4 | File NG-199111-NYMEX.dly has a volume of 0 at 1991-09-18. | 2022-04-25 10:16:00.521
NG-202206-NYMEX [C] 4 Day #4 | File NG-199111-NYMEX.dly has a volume of 0 at 1991-10-18. | 2022-04-25 10:16:00.521
NG-202206-NYMEX [C] 4 Day #4 | File NG-199110-NYMEX.dly has a volume of 0 at 1991-08-20. | 2022-04-25 10:16:00.526
NG-202206-NYMEX [C] 4 Day #4 | File NG-199110-NYMEX.dly has a volume of 0 at 1991-09-17. | 2022-04-25 10:16:00.526
NG-202206-NYMEX [C] 4 Day #4 | File NG-199109-NYMEX.dly has a volume of 0 at 1991-07-19. | 2022-04-25 10:16:00.530
NG-202206-NYMEX [C] 4 Day #4 | File NG-199109-NYMEX.dly has a volume of 0 at 1991-08-19. | 2022-04-25 10:16:00.530
NG-202206-NYMEX [C] 4 Day #4 | File NG-199108-NYMEX.dly has a volume of 0 at 1991-06-18. | 2022-04-25 10:16:00.535
NG-202206-NYMEX [C] 4 Day #4 | File NG-199108-NYMEX.dly has a volume of 0 at 1991-07-18. | 2022-04-25 10:16:00.535
NG-202206-NYMEX [C] 4 Day #4 | File NG-199107-NYMEX.dly has a volume of 0 at 1991-05-21. | 2022-04-25 10:16:00.540
NG-202206-NYMEX [C] 4 Day #4 | File NG-199107-NYMEX.dly has a volume of 0 at 1991-06-17. | 2022-04-25 10:16:00.540
NG-202206-NYMEX [C] 4 Day #4 | File NG-199106-NYMEX.dly has a volume of 0 at 1991-04-18. | 2022-04-25 10:16:00.545
NG-202206-NYMEX [C] 4 Day #4 | File NG-199106-NYMEX.dly has a volume of 0 at 1991-05-20. | 2022-04-25 10:16:00.545
NG-202206-NYMEX [C] 4 Day #4 | File NG-199105-NYMEX.dly has a volume of 0 at 1991-03-19. | 2022-04-25 10:16:00.550
NG-202206-NYMEX [C] 4 Day #4 | File NG-199105-NYMEX.dly has a volume of 0 at 1991-04-17. | 2022-04-25 10:16:00.550
NG-202206-NYMEX [C] 4 Day #4 | File NG-199104-NYMEX.dly has a volume of 0 at 1991-02-18. | 2022-04-25 10:16:00.554
NG-202206-NYMEX [C] 4 Day #4 | File NG-199104-NYMEX.dly has a volume of 0 at 1991-03-18. | 2022-04-25 10:16:00.554
NG-202206-NYMEX [C] 4 Day #4 | File NG-199103-NYMEX.dly has a volume of 0 at 1991-01-21. | 2022-04-25 10:16:00.559
NG-202206-NYMEX [C] 4 Day #4 | File NG-199103-NYMEX.dly has a volume of 0 at 1991-02-15. | 2022-04-25 10:16:00.559
NG-202206-NYMEX [C] 4 Day #4 | File NG-199102-NYMEX.dly has a volume of 0 at 1990-12-19. | 2022-04-25 10:16:00.564
NG-202206-NYMEX [C] 4 Day #4 | File NG-199102-NYMEX.dly has a volume of 0 at 1991-01-18. | 2022-04-25 10:16:00.564
NG-202206-NYMEX [C] 4 Day #4 | File NG-199101-NYMEX.dly has a volume of 0 at 1990-11-20. | 2022-04-25 10:16:00.568
NG-202206-NYMEX [C] 4 Day #4 | File NG-199101-NYMEX.dly has a volume of 0 at 1990-12-18. | 2022-04-25 10:16:00.568
NG-202206-NYMEX [C] 4 Day #4 | File NG-199012-NYMEX.dly has a volume of 0 at 1990-10-19. | 2022-04-25 10:16:00.572
NG-202206-NYMEX [C] 4 Day #4 | File NG-199012-NYMEX.dly has a volume of 0 at 1990-11-19. | 2022-04-25 10:16:00.572
NG-202206-NYMEX [C] 4 Day #4 | File NG-199011-NYMEX.dly has a volume of 0 at 1990-09-18. | 2022-04-25 10:16:00.577
NG-202206-NYMEX [C] 4 Day #4 | File NG-199011-NYMEX.dly has a volume of 0 at 1990-10-18. | 2022-04-25 10:16:00.577
NG-202206-NYMEX [C] 4 Day #4 | File NG-199010-NYMEX.dly has a volume of 0 at 1990-08-21. | 2022-04-25 10:16:00.582
NG-202206-NYMEX [C] 4 Day #4 | File NG-199010-NYMEX.dly has a volume of 0 at 1990-09-17. | 2022-04-25 10:16:00.582
NG-202206-NYMEX [C] 4 Day #4 | File NG-199009-NYMEX.dly has a volume of 0 at 1990-07-19. | 2022-04-25 10:16:00.587
NG-202206-NYMEX [C] 4 Day #4 | File NG-199009-NYMEX.dly has a volume of 0 at 1990-08-20. | 2022-04-25 10:16:00.587
NG-202206-NYMEX [C] 4 Day #4 | File NG-199008-NYMEX.dly has a volume of 0 at 1990-06-19. | 2022-04-25 10:16:00.592
NG-202206-NYMEX [C] 4 Day #4 | File NG-199008-NYMEX.dly has a volume of 0 at 1990-07-18. | 2022-04-25 10:16:00.592
NG-202206-NYMEX [C] 4 Day #4 | File NG-199007-NYMEX.dly has a volume of 0 at 1990-05-21. | 2022-04-25 10:16:00.596
NG-202206-NYMEX [C] 4 Day #4 | File NG-199007-NYMEX.dly has a volume of 0 at 1990-06-18. | 2022-04-25 10:16:00.596
NG-202206-NYMEX [C] 4 Day #4 | File NG-199006-NYMEX.dly has a volume of 0 at 1990-04-18. | 2022-04-25 10:16:00.601
NG-202206-NYMEX [C] 4 Day #4 | File NG-199006-NYMEX.dly has a volume of 0 at 1990-05-18. | 2022-04-25 10:16:00.601
NG-202206-NYMEX [C] 4 Day #4 | Chart Data Loading Thread: Load canceled. | 2022-04-25 10:16:00.753
HD Request # 72 | Requesting historical Daily data for CLF85 starting at 1984-12-11. SC External HD service. | 2022-04-25 10:16:00.759
Historical data download thread signaled to stop. | 2022-04-25 10:16:00.759
HD Request # 73 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:02.295000 | 2022-04-25 10:16:00.759
HD Request # 73 | Received 2190 Intraday data records from 2022-04-25 10:13:02.110000 to 2022-04-25 10:15:55.155002 (2.9 minutes) and wrote 2178 records for SPY-NQTV | 2022-04-25 10:16:00.759
HD Request # 73 | Completion time: 3s | 2022-04-25 10:16:00.759
HD Request # 73 | Intraday data download complete for SPY-NQTV. Unique request ID: 200 | 2022-04-25 10:16:00.759
Removing historical data download ID 200. | 2022-04-25 10:16:00.759
Real-time Intraday chart data file updates started for SPY-NQTV | 2022-04-25 10:16:00.759
Intraday chart data file opened for SPY-NQTV | 2022-04-25 10:16:00.759
HD Request # 73 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:16:00.759
Triggering next historical data download in queue. | 2022-04-25 10:16:00.759
SC Data - All Services | Received security definition for symbol GC-202206-NYMEX | 2022-04-25 10:16:00.759
Restarting the loading process. | 2022-04-25 10:16:00.759
HD Request # 74 | Downloading Intraday chart data for TSN-NQTV to the file TSN-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:16:00.762
HD Request # 74 | Download start date-time: 2022-04-25 10:12:44.000000. File last date-time: 2022-04-25 10:12:44.263000 | 2022-04-25 10:16:00.762
HD Request # 74 | Using server: ds25.sierracharts.com port 10150 | 2022-04-25 10:16:00.762
Socket (4) | Creating socket. | 2022-04-25 10:16:00.762
Socket (4) | New receive buffer size: 5242880 | 2022-04-25 10:16:00.762
Socket (4) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:16:00.762
NG-202206-NYMEX [C] 64 Day #9 | Reloading chart. | 2022-04-25 10:16:00.881
NG-202206-NYMEX [C] 64 Day #9 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:16:00.881
NG-202206-NYMEX [C] 64 Day #9 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:16:00.881
HD Request # 74 | Setting DTC encoding to Binary VLS | 2022-04-25 10:16:01.222
HD Request # 74 | Sending historical data logon request message. | 2022-04-25 10:16:01.222
HD Request # 74 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:44. Record interval: 0. Symbol: TSN-NQTV | 2022-04-25 10:16:01.447
HD Request # 74 | Decompressing data. | 2022-04-25 10:16:01.674
HD Request # 74 | Receiving Intraday data for TSN-NQTV starting at 2022-04-25 10:12:44.263000 | 2022-04-25 10:16:01.674
Socket (4) | CloseSocket call. | 2022-04-25 10:16:01.674
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:16:01.674
Socket (4) | Socket gracefully closed by remote side. | 2022-04-25 10:16:01.903
Socket (4) | Closed. | 2022-04-25 10:16:01.903
NG-202206-NYMEX [C] 64 Day #9 | File NG-200102-NYMEX.dly has a volume of 0 at 2000-12-19. | 2022-04-25 10:16:02.916
NG-202206-NYMEX [C] 64 Day #9 | File NG-200101-NYMEX.dly has a volume of 0 at 2000-11-20. | 2022-04-25 10:16:02.920
NG-202206-NYMEX [C] 64 Day #9 | File NG-200101-NYMEX.dly has a volume of 0 at 2000-12-18. | 2022-04-25 10:16:02.920
NG-202206-NYMEX [C] 64 Day #9 | File NG-200012-NYMEX.dly has a volume of 0 at 2000-10-19. | 2022-04-25 10:16:02.926
NG-202206-NYMEX [C] 64 Day #9 | File NG-200012-NYMEX.dly has a volume of 0 at 2000-11-17. | 2022-04-25 10:16:02.926
NG-202206-NYMEX [C] 64 Day #9 | File NG-200011-NYMEX.dly has a volume of 0 at 2000-09-19. | 2022-04-25 10:16:02.931
NG-202206-NYMEX [C] 64 Day #9 | File NG-200011-NYMEX.dly has a volume of 0 at 2000-10-18. | 2022-04-25 10:16:02.931
NG-202206-NYMEX [C] 64 Day #9 | File NG-200010-NYMEX.dly has a volume of 0 at 2000-08-21. | 2022-04-25 10:16:02.936
NG-202206-NYMEX [C] 64 Day #9 | File NG-200010-NYMEX.dly has a volume of 0 at 2000-09-18. | 2022-04-25 10:16:02.936
NG-202206-NYMEX [C] 64 Day #9 | File NG-200009-NYMEX.dly has a volume of 0 at 2000-07-19. | 2022-04-25 10:16:02.942
NG-202206-NYMEX [C] 64 Day #9 | File NG-200009-NYMEX.dly has a volume of 0 at 2000-08-18. | 2022-04-25 10:16:02.942
NG-202206-NYMEX [C] 64 Day #9 | File NG-200008-NYMEX.dly has a volume of 0 at 2000-06-20. | 2022-04-25 10:16:02.947
NG-202206-NYMEX [C] 64 Day #9 | File NG-200008-NYMEX.dly has a volume of 0 at 2000-07-18. | 2022-04-25 10:16:02.947
NG-202206-NYMEX [C] 64 Day #9 | File NG-200007-NYMEX.dly has a volume of 0 at 2000-05-19. | 2022-04-25 10:16:02.952
NG-202206-NYMEX [C] 64 Day #9 | File NG-200007-NYMEX.dly has a volume of 0 at 2000-06-19. | 2022-04-25 10:16:02.952
NG-202206-NYMEX [C] 64 Day #9 | File NG-200006-NYMEX.dly has a volume of 0 at 2000-04-18. | 2022-04-25 10:16:02.957
NG-202206-NYMEX [C] 64 Day #9 | File NG-200006-NYMEX.dly has a volume of 0 at 2000-05-18. | 2022-04-25 10:16:02.957
NG-202206-NYMEX [C] 64 Day #9 | File NG-200005-NYMEX.dly has a volume of 0 at 2000-03-21. | 2022-04-25 10:16:02.962
NG-202206-NYMEX [C] 64 Day #9 | File NG-200005-NYMEX.dly has a volume of 0 at 2000-04-17. | 2022-04-25 10:16:02.962
NG-202206-NYMEX [C] 64 Day #9 | File NG-200004-NYMEX.dly has a volume of 0 at 2000-02-17. | 2022-04-25 10:16:02.967
NG-202206-NYMEX [C] 64 Day #9 | File NG-200004-NYMEX.dly has a volume of 0 at 2000-03-20. | 2022-04-25 10:16:02.967
NG-202206-NYMEX [C] 64 Day #9 | File NG-200003-NYMEX.dly has a volume of 0 at 2000-01-19. | 2022-04-25 10:16:02.973
NG-202206-NYMEX [C] 64 Day #9 | File NG-200003-NYMEX.dly has a volume of 0 at 2000-02-16. | 2022-04-25 10:16:02.973
NG-202206-NYMEX [C] 64 Day #9 | File NG-200002-NYMEX.dly has a volume of 0 at 1999-12-21. | 2022-04-25 10:16:02.977
NG-202206-NYMEX [C] 64 Day #9 | File NG-200002-NYMEX.dly has a volume of 0 at 2000-01-18. | 2022-04-25 10:16:02.977
NG-202206-NYMEX [C] 64 Day #9 | File NG-200001-NYMEX.dly has a volume of 0 at 1999-11-18. | 2022-04-25 10:16:02.982
NG-202206-NYMEX [C] 64 Day #9 | File NG-200001-NYMEX.dly has a volume of 0 at 1999-12-20. | 2022-04-25 10:16:02.982
NG-202206-NYMEX [C] 64 Day #9 | File NG-199912-NYMEX.dly has a volume of 0 at 1999-10-19. | 2022-04-25 10:16:02.987
NG-202206-NYMEX [C] 64 Day #9 | File NG-199912-NYMEX.dly has a volume of 0 at 1999-11-17. | 2022-04-25 10:16:02.987
NG-202206-NYMEX [C] 64 Day #9 | File NG-199911-NYMEX.dly has a volume of 0 at 1999-09-20. | 2022-04-25 10:16:02.992
NG-202206-NYMEX [C] 64 Day #9 | File NG-199911-NYMEX.dly has a volume of 0 at 1999-10-18. | 2022-04-25 10:16:02.992
NG-202206-NYMEX [C] 64 Day #9 | File NG-199910-NYMEX.dly has a volume of 0 at 1999-08-19. | 2022-04-25 10:16:02.998
NG-202206-NYMEX [C] 64 Day #9 | File NG-199910-NYMEX.dly has a volume of 0 at 1999-09-17. | 2022-04-25 10:16:02.998
NG-202206-NYMEX [C] 64 Day #9 | File NG-199909-NYMEX.dly has a volume of 0 at 1999-07-20. | 2022-04-25 10:16:03.003
NG-202206-NYMEX [C] 64 Day #9 | File NG-199909-NYMEX.dly has a volume of 0 at 1999-08-18. | 2022-04-25 10:16:03.003
NG-202206-NYMEX [C] 64 Day #9 | File NG-199908-NYMEX.dly has a volume of 0 at 1999-06-18. | 2022-04-25 10:16:03.008
NG-202206-NYMEX [C] 64 Day #9 | File NG-199908-NYMEX.dly has a volume of 0 at 1999-07-19. | 2022-04-25 10:16:03.008
NG-202206-NYMEX [C] 64 Day #9 | File NG-199907-NYMEX.dly has a volume of 0 at 1999-05-19. | 2022-04-25 10:16:03.014
NG-202206-NYMEX [C] 64 Day #9 | File NG-199907-NYMEX.dly has a volume of 0 at 1999-06-17. | 2022-04-25 10:16:03.014
NG-202206-NYMEX [C] 64 Day #9 | File NG-199906-NYMEX.dly has a volume of 0 at 1999-04-20. | 2022-04-25 10:16:03.019
NG-202206-NYMEX [C] 64 Day #9 | File NG-199906-NYMEX.dly has a volume of 0 at 1999-05-18. | 2022-04-25 10:16:03.019
NG-202206-NYMEX [C] 64 Day #9 | File NG-199905-NYMEX.dly has a volume of 0 at 1999-03-19. | 2022-04-25 10:16:03.024
NG-202206-NYMEX [C] 64 Day #9 | File NG-199905-NYMEX.dly has a volume of 0 at 1999-04-19. | 2022-04-25 10:16:03.024
NG-202206-NYMEX [C] 64 Day #9 | File NG-199904-NYMEX.dly has a volume of 0 at 1999-02-16. | 2022-04-25 10:16:03.029
NG-202206-NYMEX [C] 64 Day #9 | File NG-199904-NYMEX.dly has a volume of 0 at 1999-03-18. | 2022-04-25 10:16:03.029
NG-202206-NYMEX [C] 64 Day #9 | File NG-199903-NYMEX.dly has a volume of 0 at 1999-01-19. | 2022-04-25 10:16:03.034
NG-202206-NYMEX [C] 64 Day #9 | File NG-199903-NYMEX.dly has a volume of 0 at 1999-02-15. | 2022-04-25 10:16:03.034
NG-202206-NYMEX [C] 64 Day #9 | File NG-199902-NYMEX.dly has a volume of 0 at 1998-12-21. | 2022-04-25 10:16:03.039
NG-202206-NYMEX [C] 64 Day #9 | File NG-199902-NYMEX.dly has a volume of 0 at 1999-01-18. | 2022-04-25 10:16:03.039
NG-202206-NYMEX [C] 64 Day #9 | File NG-199901-NYMEX.dly has a volume of 0 at 1998-11-18. | 2022-04-25 10:16:03.044
NG-202206-NYMEX [C] 64 Day #9 | File NG-199901-NYMEX.dly has a volume of 0 at 1998-12-18. | 2022-04-25 10:16:03.044
NG-202206-NYMEX [C] 64 Day #9 | File NG-199812-NYMEX.dly has a volume of 0 at 1998-10-20. | 2022-04-25 10:16:03.049
NG-202206-NYMEX [C] 64 Day #9 | File NG-199812-NYMEX.dly has a volume of 0 at 1998-11-17. | 2022-04-25 10:16:03.049
NG-202206-NYMEX [C] 64 Day #9 | File NG-199811-NYMEX.dly has a volume of 0 at 1998-09-18. | 2022-04-25 10:16:03.054
NG-202206-NYMEX [C] 64 Day #9 | File NG-199811-NYMEX.dly has a volume of 0 at 1998-10-19. | 2022-04-25 10:16:03.054
NG-202206-NYMEX [C] 64 Day #9 | File NG-199810-NYMEX.dly has a volume of 0 at 1998-08-19. | 2022-04-25 10:16:03.059
NG-202206-NYMEX [C] 64 Day #9 | File NG-199810-NYMEX.dly has a volume of 0 at 1998-09-17. | 2022-04-25 10:16:03.059
NG-202206-NYMEX [C] 64 Day #9 | File NG-199809-NYMEX.dly has a volume of 0 at 1998-07-21. | 2022-04-25 10:16:03.064
NG-202206-NYMEX [C] 64 Day #9 | File NG-199809-NYMEX.dly has a volume of 0 at 1998-08-18. | 2022-04-25 10:16:03.064
NG-202206-NYMEX [C] 64 Day #9 | File NG-199808-NYMEX.dly has a volume of 0 at 1998-06-18. | 2022-04-25 10:16:03.070
NG-202206-NYMEX [C] 64 Day #9 | File NG-199808-NYMEX.dly has a volume of 0 at 1998-07-20. | 2022-04-25 10:16:03.070
NG-202206-NYMEX [C] 64 Day #9 | File NG-199807-NYMEX.dly has a volume of 0 at 1998-05-19. | 2022-04-25 10:16:03.075
NG-202206-NYMEX [C] 64 Day #9 | File NG-199807-NYMEX.dly has a volume of 0 at 1998-06-17. | 2022-04-25 10:16:03.075
NG-202206-NYMEX [C] 64 Day #9 | File NG-199806-NYMEX.dly has a volume of 0 at 1998-04-20. | 2022-04-25 10:16:03.080
NG-202206-NYMEX [C] 64 Day #9 | File NG-199806-NYMEX.dly has a volume of 0 at 1998-05-18. | 2022-04-25 10:16:03.080
NG-202206-NYMEX [C] 64 Day #9 | File NG-199805-NYMEX.dly has a volume of 0 at 1998-03-19. | 2022-04-25 10:16:03.085
NG-202206-NYMEX [C] 64 Day #9 | File NG-199805-NYMEX.dly has a volume of 0 at 1998-04-17. | 2022-04-25 10:16:03.085
NG-202206-NYMEX [C] 64 Day #9 | File NG-199804-NYMEX.dly has a volume of 0 at 1998-02-17. | 2022-04-25 10:16:03.091
NG-202206-NYMEX [C] 64 Day #9 | File NG-199804-NYMEX.dly has a volume of 0 at 1998-03-18. | 2022-04-25 10:16:03.091
NG-202206-NYMEX [C] 64 Day #9 | File NG-199803-NYMEX.dly has a volume of 0 at 1998-01-20. | 2022-04-25 10:16:03.096
NG-202206-NYMEX [C] 64 Day #9 | File NG-199803-NYMEX.dly has a volume of 0 at 1998-02-16. | 2022-04-25 10:16:03.096
NG-202206-NYMEX [C] 64 Day #9 | File NG-199802-NYMEX.dly has a volume of 0 at 1997-12-19. | 2022-04-25 10:16:03.101
NG-202206-NYMEX [C] 64 Day #9 | File NG-199802-NYMEX.dly has a volume of 0 at 1998-01-19. | 2022-04-25 10:16:03.101
NG-202206-NYMEX [C] 64 Day #9 | File NG-199801-NYMEX.dly has a volume of 0 at 1997-11-18. | 2022-04-25 10:16:03.106
NG-202206-NYMEX [C] 64 Day #9 | File NG-199801-NYMEX.dly has a volume of 0 at 1997-12-18. | 2022-04-25 10:16:03.106
NG-202206-NYMEX [C] 64 Day #9 | File NG-199712-NYMEX.dly has a volume of 0 at 1997-10-21. | 2022-04-25 10:16:03.110
NG-202206-NYMEX [C] 64 Day #9 | File NG-199712-NYMEX.dly has a volume of 0 at 1997-11-17. | 2022-04-25 10:16:03.110
NG-202206-NYMEX [C] 64 Day #9 | File NG-199711-NYMEX.dly has a volume of 0 at 1997-09-18. | 2022-04-25 10:16:03.116
NG-202206-NYMEX [C] 64 Day #9 | File NG-199711-NYMEX.dly has a volume of 0 at 1997-10-20. | 2022-04-25 10:16:03.116
NG-202206-NYMEX [C] 64 Day #9 | File NG-199710-NYMEX.dly has a volume of 0 at 1997-08-19. | 2022-04-25 10:16:03.121
NG-202206-NYMEX [C] 64 Day #9 | File NG-199710-NYMEX.dly has a volume of 0 at 1997-09-17. | 2022-04-25 10:16:03.121
NG-202206-NYMEX [C] 64 Day #9 | File NG-199709-NYMEX.dly has a volume of 0 at 1997-07-21. | 2022-04-25 10:16:03.126
NG-202206-NYMEX [C] 64 Day #9 | File NG-199709-NYMEX.dly has a volume of 0 at 1997-08-18. | 2022-04-25 10:16:03.126
NG-202206-NYMEX [C] 64 Day #9 | File NG-199708-NYMEX.dly has a volume of 0 at 1997-06-18. | 2022-04-25 10:16:03.132
NG-202206-NYMEX [C] 64 Day #9 | File NG-199708-NYMEX.dly has a volume of 0 at 1997-07-18. | 2022-04-25 10:16:03.132
NG-202206-NYMEX [C] 64 Day #9 | File NG-199707-NYMEX.dly has a volume of 0 at 1997-05-20. | 2022-04-25 10:16:03.137
NG-202206-NYMEX [C] 64 Day #9 | File NG-199707-NYMEX.dly has a volume of 0 at 1997-06-17. | 2022-04-25 10:16:03.137
NG-202206-NYMEX [C] 64 Day #9 | File NG-199706-NYMEX.dly has a volume of 0 at 1997-04-18. | 2022-04-25 10:16:03.142
NG-202206-NYMEX [C] 64 Day #9 | File NG-199706-NYMEX.dly has a volume of 0 at 1997-05-19. | 2022-04-25 10:16:03.142
NG-202206-NYMEX [C] 64 Day #9 | File NG-199705-NYMEX.dly has a volume of 0 at 1997-03-19. | 2022-04-25 10:16:03.147
NG-202206-NYMEX [C] 64 Day #9 | File NG-199705-NYMEX.dly has a volume of 0 at 1997-04-17. | 2022-04-25 10:16:03.147
NG-202206-NYMEX [C] 64 Day #9 | File NG-199704-NYMEX.dly has a volume of 0 at 1997-02-18. | 2022-04-25 10:16:03.152
NG-202206-NYMEX [C] 64 Day #9 | File NG-199704-NYMEX.dly has a volume of 0 at 1997-03-18. | 2022-04-25 10:16:03.152
NG-202206-NYMEX [C] 64 Day #9 | File NG-199703-NYMEX.dly has a volume of 0 at 1997-01-21. | 2022-04-25 10:16:03.156
NG-202206-NYMEX [C] 64 Day #9 | File NG-199703-NYMEX.dly has a volume of 0 at 1997-02-17. | 2022-04-25 10:16:03.156
NG-202206-NYMEX [C] 64 Day #9 | File NG-199702-NYMEX.dly has a volume of 0 at 1996-12-19. | 2022-04-25 10:16:03.161
NG-202206-NYMEX [C] 64 Day #9 | File NG-199702-NYMEX.dly has a volume of 0 at 1997-01-20. | 2022-04-25 10:16:03.161
NG-202206-NYMEX [C] 64 Day #9 | File NG-199701-NYMEX.dly has a volume of 0 at 1996-11-19. | 2022-04-25 10:16:03.166
NG-202206-NYMEX [C] 64 Day #9 | File NG-199701-NYMEX.dly has a volume of 0 at 1996-12-18. | 2022-04-25 10:16:03.166
NG-202206-NYMEX [C] 64 Day #9 | File NG-199612-NYMEX.dly has a volume of 0 at 1996-10-21. | 2022-04-25 10:16:03.170
NG-202206-NYMEX [C] 64 Day #9 | File NG-199612-NYMEX.dly has a volume of 0 at 1996-11-18. | 2022-04-25 10:16:03.170
NG-202206-NYMEX [C] 64 Day #9 | File NG-199611-NYMEX.dly has a volume of 0 at 1996-09-18. | 2022-04-25 10:16:03.176
NG-202206-NYMEX [C] 64 Day #9 | File NG-199611-NYMEX.dly has a volume of 0 at 1996-10-18. | 2022-04-25 10:16:03.176
NG-202206-NYMEX [C] 64 Day #9 | File NG-199610-NYMEX.dly has a volume of 0 at 1996-08-20. | 2022-04-25 10:16:03.180
NG-202206-NYMEX [C] 64 Day #9 | File NG-199610-NYMEX.dly has a volume of 0 at 1996-09-17. | 2022-04-25 10:16:03.180
NG-202206-NYMEX [C] 64 Day #9 | File NG-199609-NYMEX.dly has a volume of 0 at 1996-07-19. | 2022-04-25 10:16:03.185
NG-202206-NYMEX [C] 64 Day #9 | File NG-199609-NYMEX.dly has a volume of 0 at 1996-08-19. | 2022-04-25 10:16:03.185
NG-202206-NYMEX [C] 64 Day #9 | File NG-199608-NYMEX.dly has a volume of 0 at 1996-06-18. | 2022-04-25 10:16:03.190
NG-202206-NYMEX [C] 64 Day #9 | File NG-199608-NYMEX.dly has a volume of 0 at 1996-07-18. | 2022-04-25 10:16:03.190
NG-202206-NYMEX [C] 64 Day #9 | File NG-199607-NYMEX.dly has a volume of 0 at 1996-05-21. | 2022-04-25 10:16:03.195
NG-202206-NYMEX [C] 64 Day #9 | File NG-199607-NYMEX.dly has a volume of 0 at 1996-06-17. | 2022-04-25 10:16:03.195
NG-202206-NYMEX [C] 64 Day #9 | File NG-199606-NYMEX.dly has a volume of 0 at 1996-04-18. | 2022-04-25 10:16:03.200
NG-202206-NYMEX [C] 64 Day #9 | File NG-199606-NYMEX.dly has a volume of 0 at 1996-05-20. | 2022-04-25 10:16:03.200
NG-202206-NYMEX [C] 64 Day #9 | File NG-199605-NYMEX.dly has a volume of 0 at 1996-03-19. | 2022-04-25 10:16:03.205
NG-202206-NYMEX [C] 64 Day #9 | File NG-199605-NYMEX.dly has a volume of 0 at 1996-04-17. | 2022-04-25 10:16:03.205
NG-202206-NYMEX [C] 64 Day #9 | File NG-199604-NYMEX.dly has a volume of 0 at 1996-02-19. | 2022-04-25 10:16:03.210
NG-202206-NYMEX [C] 64 Day #9 | File NG-199604-NYMEX.dly has a volume of 0 at 1996-03-18. | 2022-04-25 10:16:03.210
NG-202206-NYMEX [C] 64 Day #9 | File NG-199603-NYMEX.dly has a volume of 0 at 1996-01-19. | 2022-04-25 10:16:03.215
NG-202206-NYMEX [C] 64 Day #9 | File NG-199603-NYMEX.dly has a volume of 0 at 1996-02-16. | 2022-04-25 10:16:03.215
NG-202206-NYMEX [C] 64 Day #9 | File NG-199602-NYMEX.dly has a volume of 0 at 1995-12-19. | 2022-04-25 10:16:03.220
NG-202206-NYMEX [C] 64 Day #9 | File NG-199602-NYMEX.dly has a volume of 0 at 1996-01-18. | 2022-04-25 10:16:03.220
NG-202206-NYMEX [C] 64 Day #9 | File NG-199601-NYMEX.dly has a volume of 0 at 1995-11-20. | 2022-04-25 10:16:03.224
NG-202206-NYMEX [C] 64 Day #9 | File NG-199601-NYMEX.dly has a volume of 0 at 1995-12-18. | 2022-04-25 10:16:03.224
NG-202206-NYMEX [C] 64 Day #9 | File NG-199512-NYMEX.dly has a volume of 0 at 1995-10-19. | 2022-04-25 10:16:03.228
NG-202206-NYMEX [C] 64 Day #9 | File NG-199512-NYMEX.dly has a volume of 0 at 1995-11-17. | 2022-04-25 10:16:03.228
NG-202206-NYMEX [C] 64 Day #9 | File NG-199511-NYMEX.dly has a volume of 0 at 1995-09-19. | 2022-04-25 10:16:03.233
NG-202206-NYMEX [C] 64 Day #9 | File NG-199511-NYMEX.dly has a volume of 0 at 1995-10-18. | 2022-04-25 10:16:03.233
NG-202206-NYMEX [C] 64 Day #9 | File NG-199510-NYMEX.dly has a volume of 0 at 1995-08-21. | 2022-04-25 10:16:03.238
NG-202206-NYMEX [C] 64 Day #9 | File NG-199510-NYMEX.dly has a volume of 0 at 1995-09-18. | 2022-04-25 10:16:03.238
NG-202206-NYMEX [C] 64 Day #9 | File NG-199509-NYMEX.dly has a volume of 0 at 1995-07-19. | 2022-04-25 10:16:03.243
NG-202206-NYMEX [C] 64 Day #9 | File NG-199509-NYMEX.dly has a volume of 0 at 1995-08-18. | 2022-04-25 10:16:03.243
NG-202206-NYMEX [C] 64 Day #9 | File NG-199508-NYMEX.dly has a volume of 0 at 1995-06-20. | 2022-04-25 10:16:03.247
NG-202206-NYMEX [C] 64 Day #9 | File NG-199508-NYMEX.dly has a volume of 0 at 1995-07-18. | 2022-04-25 10:16:03.247
NG-202206-NYMEX [C] 64 Day #9 | File NG-199507-NYMEX.dly has a volume of 0 at 1995-05-19. | 2022-04-25 10:16:03.252
NG-202206-NYMEX [C] 64 Day #9 | File NG-199507-NYMEX.dly has a volume of 0 at 1995-06-19. | 2022-04-25 10:16:03.252
NG-202206-NYMEX [C] 64 Day #9 | File NG-199506-NYMEX.dly has a volume of 0 at 1995-04-18. | 2022-04-25 10:16:03.257
NG-202206-NYMEX [C] 64 Day #9 | File NG-199506-NYMEX.dly has a volume of 0 at 1995-05-18. | 2022-04-25 10:16:03.257
NG-202206-NYMEX [C] 64 Day #9 | File NG-199505-NYMEX.dly has a volume of 0 at 1995-03-21. | 2022-04-25 10:16:03.261
NG-202206-NYMEX [C] 64 Day #9 | File NG-199505-NYMEX.dly has a volume of 0 at 1995-04-17. | 2022-04-25 10:16:03.261
NG-202206-NYMEX [C] 64 Day #9 | File NG-199504-NYMEX.dly has a volume of 0 at 1995-02-16. | 2022-04-25 10:16:03.266
NG-202206-NYMEX [C] 64 Day #9 | File NG-199504-NYMEX.dly has a volume of 0 at 1995-03-20. | 2022-04-25 10:16:03.266
NG-202206-NYMEX [C] 64 Day #9 | File NG-199503-NYMEX.dly has a volume of 0 at 1995-01-19. | 2022-04-25 10:16:03.271
NG-202206-NYMEX [C] 64 Day #9 | File NG-199503-NYMEX.dly has a volume of 0 at 1995-02-15. | 2022-04-25 10:16:03.271
NG-202206-NYMEX [C] 64 Day #9 | File NG-199502-NYMEX.dly has a volume of 0 at 1994-12-20. | 2022-04-25 10:16:03.275
NG-202206-NYMEX [C] 64 Day #9 | File NG-199502-NYMEX.dly has a volume of 0 at 1995-01-18. | 2022-04-25 10:16:03.275
NG-202206-NYMEX [C] 64 Day #9 | File NG-199501-NYMEX.dly has a volume of 0 at 1994-11-18. | 2022-04-25 10:16:03.280
NG-202206-NYMEX [C] 64 Day #9 | File NG-199501-NYMEX.dly has a volume of 0 at 1994-12-19. | 2022-04-25 10:16:03.280
NG-202206-NYMEX [C] 64 Day #9 | File NG-199412-NYMEX.dly has a volume of 0 at 1994-10-19. | 2022-04-25 10:16:03.284
NG-202206-NYMEX [C] 64 Day #9 | File NG-199412-NYMEX.dly has a volume of 0 at 1994-11-17. | 2022-04-25 10:16:03.284
NG-202206-NYMEX [C] 64 Day #9 | File NG-199411-NYMEX.dly has a volume of 0 at 1994-09-20. | 2022-04-25 10:16:03.289
NG-202206-NYMEX [C] 64 Day #9 | File NG-199411-NYMEX.dly has a volume of 0 at 1994-10-18. | 2022-04-25 10:16:03.289
NG-202206-NYMEX [C] 64 Day #9 | File NG-199410-NYMEX.dly has a volume of 0 at 1994-08-19. | 2022-04-25 10:16:03.293
NG-202206-NYMEX [C] 64 Day #9 | File NG-199410-NYMEX.dly has a volume of 0 at 1994-09-19. | 2022-04-25 10:16:03.293
NG-202206-NYMEX [C] 64 Day #9 | File NG-199409-NYMEX.dly has a volume of 0 at 1994-07-19. | 2022-04-25 10:16:03.299
NG-202206-NYMEX [C] 64 Day #9 | File NG-199409-NYMEX.dly has a volume of 0 at 1994-08-18. | 2022-04-25 10:16:03.299
NG-202206-NYMEX [C] 64 Day #9 | File NG-199408-NYMEX.dly has a volume of 0 at 1994-06-20. | 2022-04-25 10:16:03.303
NG-202206-NYMEX [C] 64 Day #9 | File NG-199408-NYMEX.dly has a volume of 0 at 1994-07-18. | 2022-04-25 10:16:03.303
NG-202206-NYMEX [C] 64 Day #9 | File NG-199407-NYMEX.dly has a volume of 0 at 1994-05-19. | 2022-04-25 10:16:03.308
NG-202206-NYMEX [C] 64 Day #9 | File NG-199407-NYMEX.dly has a volume of 0 at 1994-06-17. | 2022-04-25 10:16:03.308
NG-202206-NYMEX [C] 64 Day #9 | File NG-199406-NYMEX.dly has a volume of 0 at 1994-04-19. | 2022-04-25 10:16:03.312
NG-202206-NYMEX [C] 64 Day #9 | File NG-199406-NYMEX.dly has a volume of 0 at 1994-05-18. | 2022-04-25 10:16:03.312
NG-202206-NYMEX [C] 64 Day #9 | File NG-199405-NYMEX.dly has a volume of 0 at 1994-03-21. | 2022-04-25 10:16:03.317
NG-202206-NYMEX [C] 64 Day #9 | File NG-199405-NYMEX.dly has a volume of 0 at 1994-04-18. | 2022-04-25 10:16:03.317
NG-202206-NYMEX [C] 64 Day #9 | File NG-199404-NYMEX.dly has a volume of 0 at 1994-02-16. | 2022-04-25 10:16:03.322
NG-202206-NYMEX [C] 64 Day #9 | File NG-199404-NYMEX.dly has a volume of 0 at 1994-03-18. | 2022-04-25 10:16:03.322
NG-202206-NYMEX [C] 64 Day #9 | File NG-199403-NYMEX.dly has a volume of 0 at 1994-01-19. | 2022-04-25 10:16:03.326
NG-202206-NYMEX [C] 64 Day #9 | File NG-199403-NYMEX.dly has a volume of 0 at 1994-02-15. | 2022-04-25 10:16:03.326
NG-202206-NYMEX [C] 64 Day #9 | File NG-199402-NYMEX.dly has a volume of 0 at 1993-12-21. | 2022-04-25 10:16:03.331
NG-202206-NYMEX [C] 64 Day #9 | File NG-199402-NYMEX.dly has a volume of 0 at 1994-01-18. | 2022-04-25 10:16:03.331
NG-202206-NYMEX [C] 64 Day #9 | File NG-199401-NYMEX.dly has a volume of 0 at 1993-11-18. | 2022-04-25 10:16:03.335
NG-202206-NYMEX [C] 64 Day #9 | File NG-199401-NYMEX.dly has a volume of 0 at 1993-12-20. | 2022-04-25 10:16:03.335
NG-202206-NYMEX [C] 64 Day #9 | File NG-199312-NYMEX.dly has a volume of 0 at 1993-10-19. | 2022-04-25 10:16:03.340
NG-202206-NYMEX [C] 64 Day #9 | File NG-199312-NYMEX.dly has a volume of 0 at 1993-11-17. | 2022-04-25 10:16:03.340
NG-202206-NYMEX [C] 64 Day #9 | File NG-199311-NYMEX.dly has a volume of 0 at 1993-09-20. | 2022-04-25 10:16:03.344
NG-202206-NYMEX [C] 64 Day #9 | File NG-199311-NYMEX.dly has a volume of 0 at 1993-10-18. | 2022-04-25 10:16:03.344
NG-202206-NYMEX [C] 64 Day #9 | File NG-199310-NYMEX.dly has a volume of 0 at 1993-08-19. | 2022-04-25 10:16:03.349
NG-202206-NYMEX [C] 64 Day #9 | File NG-199310-NYMEX.dly has a volume of 0 at 1993-09-17. | 2022-04-25 10:16:03.349
NG-202206-NYMEX [C] 64 Day #9 | File NG-199309-NYMEX.dly has a volume of 0 at 1993-07-20. | 2022-04-25 10:16:03.354
NG-202206-NYMEX [C] 64 Day #9 | File NG-199309-NYMEX.dly has a volume of 0 at 1993-08-18. | 2022-04-25 10:16:03.354
NG-202206-NYMEX [C] 64 Day #9 | File NG-199308-NYMEX.dly has a volume of 0 at 1993-06-18. | 2022-04-25 10:16:03.359
NG-202206-NYMEX [C] 64 Day #9 | File NG-199308-NYMEX.dly has a volume of 0 at 1993-07-19. | 2022-04-25 10:16:03.359
NG-202206-NYMEX [C] 64 Day #9 | File NG-199307-NYMEX.dly has a volume of 0 at 1993-05-19. | 2022-04-25 10:16:03.363
NG-202206-NYMEX [C] 64 Day #9 | File NG-199307-NYMEX.dly has a volume of 0 at 1993-06-17. | 2022-04-25 10:16:03.363
NG-202206-NYMEX [C] 64 Day #9 | File NG-199306-NYMEX.dly has a volume of 0 at 1993-04-20. | 2022-04-25 10:16:03.367
NG-202206-NYMEX [C] 64 Day #9 | File NG-199306-NYMEX.dly has a volume of 0 at 1993-05-18. | 2022-04-25 10:16:03.367
NG-202206-NYMEX [C] 64 Day #9 | File NG-199305-NYMEX.dly has a volume of 0 at 1993-03-19. | 2022-04-25 10:16:03.372
NG-202206-NYMEX [C] 64 Day #9 | File NG-199305-NYMEX.dly has a volume of 0 at 1993-04-19. | 2022-04-25 10:16:03.372
NG-202206-NYMEX [C] 64 Day #9 | File NG-199304-NYMEX.dly has a volume of 0 at 1993-02-16. | 2022-04-25 10:16:03.377
NG-202206-NYMEX [C] 64 Day #9 | File NG-199304-NYMEX.dly has a volume of 0 at 1993-03-18. | 2022-04-25 10:16:03.377
NG-202206-NYMEX [C] 64 Day #9 | File NG-199303-NYMEX.dly has a volume of 0 at 1993-01-19. | 2022-04-25 10:16:03.381
NG-202206-NYMEX [C] 64 Day #9 | File NG-199303-NYMEX.dly has a volume of 0 at 1993-02-15. | 2022-04-25 10:16:03.381
NG-202206-NYMEX [C] 64 Day #9 | File NG-199302-NYMEX.dly has a volume of 0 at 1992-12-21. | 2022-04-25 10:16:03.386
NG-202206-NYMEX [C] 64 Day #9 | File NG-199302-NYMEX.dly has a volume of 0 at 1993-01-18. | 2022-04-25 10:16:03.386
NG-202206-NYMEX [C] 64 Day #9 | File NG-199301-NYMEX.dly has a volume of 0 at 1992-11-18. | 2022-04-25 10:16:03.390
NG-202206-NYMEX [C] 64 Day #9 | File NG-199301-NYMEX.dly has a volume of 0 at 1992-12-18. | 2022-04-25 10:16:03.390
NG-202206-NYMEX [C] 64 Day #9 | File NG-199212-NYMEX.dly has a volume of 0 at 1992-10-20. | 2022-04-25 10:16:03.395
NG-202206-NYMEX [C] 64 Day #9 | File NG-199212-NYMEX.dly has a volume of 0 at 1992-11-17. | 2022-04-25 10:16:03.395
NG-202206-NYMEX [C] 64 Day #9 | File NG-199211-NYMEX.dly has a volume of 0 at 1992-09-18. | 2022-04-25 10:16:03.399
NG-202206-NYMEX [C] 64 Day #9 | File NG-199211-NYMEX.dly has a volume of 0 at 1992-10-19. | 2022-04-25 10:16:03.399
NG-202206-NYMEX [C] 64 Day #9 | File NG-199210-NYMEX.dly has a volume of 0 at 1992-08-19. | 2022-04-25 10:16:03.404
NG-202206-NYMEX [C] 64 Day #9 | File NG-199210-NYMEX.dly has a volume of 0 at 1992-09-17. | 2022-04-25 10:16:03.404
NG-202206-NYMEX [C] 64 Day #9 | File NG-199209-NYMEX.dly has a volume of 0 at 1992-07-21. | 2022-04-25 10:16:03.408
NG-202206-NYMEX [C] 64 Day #9 | File NG-199209-NYMEX.dly has a volume of 0 at 1992-08-18. | 2022-04-25 10:16:03.408
NG-202206-NYMEX [C] 64 Day #9 | File NG-199208-NYMEX.dly has a volume of 0 at 1992-06-18. | 2022-04-25 10:16:03.413
NG-202206-NYMEX [C] 64 Day #9 | File NG-199208-NYMEX.dly has a volume of 0 at 1992-07-20. | 2022-04-25 10:16:03.413
NG-202206-NYMEX [C] 64 Day #9 | File NG-199207-NYMEX.dly has a volume of 0 at 1992-05-19. | 2022-04-25 10:16:03.418
NG-202206-NYMEX [C] 64 Day #9 | File NG-199207-NYMEX.dly has a volume of 0 at 1992-06-17. | 2022-04-25 10:16:03.418
NG-202206-NYMEX [C] 64 Day #9 | File NG-199206-NYMEX.dly has a volume of 0 at 1992-04-20. | 2022-04-25 10:16:03.422
NG-202206-NYMEX [C] 64 Day #9 | File NG-199206-NYMEX.dly has a volume of 0 at 1992-05-18. | 2022-04-25 10:16:03.422
NG-202206-NYMEX [C] 64 Day #9 | File NG-199205-NYMEX.dly has a volume of 0 at 1992-03-19. | 2022-04-25 10:16:03.427
NG-202206-NYMEX [C] 64 Day #9 | File NG-199205-NYMEX.dly has a volume of 0 at 1992-04-17. | 2022-04-25 10:16:03.427
NG-202206-NYMEX [C] 64 Day #9 | File NG-199204-NYMEX.dly has a volume of 0 at 1992-02-18. | 2022-04-25 10:16:03.432
NG-202206-NYMEX [C] 64 Day #9 | File NG-199204-NYMEX.dly has a volume of 0 at 1992-03-18. | 2022-04-25 10:16:03.432
NG-202206-NYMEX [C] 64 Day #9 | File NG-199203-NYMEX.dly has a volume of 0 at 1992-01-21. | 2022-04-25 10:16:03.436
NG-202206-NYMEX [C] 64 Day #9 | File NG-199203-NYMEX.dly has a volume of 0 at 1992-02-17. | 2022-04-25 10:16:03.436
NG-202206-NYMEX [C] 64 Day #9 | File NG-199202-NYMEX.dly has a volume of 0 at 1991-12-19. | 2022-04-25 10:16:03.441
NG-202206-NYMEX [C] 64 Day #9 | File NG-199202-NYMEX.dly has a volume of 0 at 1992-01-20. | 2022-04-25 10:16:03.441
NG-202206-NYMEX [C] 64 Day #9 | File NG-199201-NYMEX.dly has a volume of 0 at 1991-11-19. | 2022-04-25 10:16:03.445
NG-202206-NYMEX [C] 64 Day #9 | File NG-199201-NYMEX.dly has a volume of 0 at 1991-12-18. | 2022-04-25 10:16:03.445
NG-202206-NYMEX [C] 64 Day #9 | File NG-199112-NYMEX.dly has a volume of 0 at 1991-10-21. | 2022-04-25 10:16:03.449
NG-202206-NYMEX [C] 64 Day #9 | File NG-199112-NYMEX.dly has a volume of 0 at 1991-11-18. | 2022-04-25 10:16:03.449
NG-202206-NYMEX [C] 64 Day #9 | File NG-199111-NYMEX.dly has a volume of 0 at 1991-09-18. | 2022-04-25 10:16:03.454
NG-202206-NYMEX [C] 64 Day #9 | File NG-199111-NYMEX.dly has a volume of 0 at 1991-10-18. | 2022-04-25 10:16:03.454
NG-202206-NYMEX [C] 64 Day #9 | File NG-199110-NYMEX.dly has a volume of 0 at 1991-08-20. | 2022-04-25 10:16:03.459
NG-202206-NYMEX [C] 64 Day #9 | File NG-199110-NYMEX.dly has a volume of 0 at 1991-09-17. | 2022-04-25 10:16:03.459
NG-202206-NYMEX [C] 64 Day #9 | File NG-199109-NYMEX.dly has a volume of 0 at 1991-07-19. | 2022-04-25 10:16:03.463
NG-202206-NYMEX [C] 64 Day #9 | File NG-199109-NYMEX.dly has a volume of 0 at 1991-08-19. | 2022-04-25 10:16:03.463
NG-202206-NYMEX [C] 64 Day #9 | File NG-199108-NYMEX.dly has a volume of 0 at 1991-06-18. | 2022-04-25 10:16:03.468
NG-202206-NYMEX [C] 64 Day #9 | File NG-199108-NYMEX.dly has a volume of 0 at 1991-07-18. | 2022-04-25 10:16:03.468
NG-202206-NYMEX [C] 64 Day #9 | File NG-199107-NYMEX.dly has a volume of 0 at 1991-05-21. | 2022-04-25 10:16:03.472
NG-202206-NYMEX [C] 64 Day #9 | File NG-199107-NYMEX.dly has a volume of 0 at 1991-06-17. | 2022-04-25 10:16:03.472
NG-202206-NYMEX [C] 64 Day #9 | File NG-199106-NYMEX.dly has a volume of 0 at 1991-04-18. | 2022-04-25 10:16:03.477
NG-202206-NYMEX [C] 64 Day #9 | File NG-199106-NYMEX.dly has a volume of 0 at 1991-05-20. | 2022-04-25 10:16:03.477
NG-202206-NYMEX [C] 64 Day #9 | File NG-199105-NYMEX.dly has a volume of 0 at 1991-03-19. | 2022-04-25 10:16:03.481
NG-202206-NYMEX [C] 64 Day #9 | File NG-199105-NYMEX.dly has a volume of 0 at 1991-04-17. | 2022-04-25 10:16:03.481
NG-202206-NYMEX [C] 64 Day #9 | File NG-199104-NYMEX.dly has a volume of 0 at 1991-02-18. | 2022-04-25 10:16:03.485
NG-202206-NYMEX [C] 64 Day #9 | File NG-199104-NYMEX.dly has a volume of 0 at 1991-03-18. | 2022-04-25 10:16:03.485
NG-202206-NYMEX [C] 64 Day #9 | File NG-199103-NYMEX.dly has a volume of 0 at 1991-01-21. | 2022-04-25 10:16:03.490
NG-202206-NYMEX [C] 64 Day #9 | File NG-199103-NYMEX.dly has a volume of 0 at 1991-02-15. | 2022-04-25 10:16:03.490
NG-202206-NYMEX [C] 64 Day #9 | File NG-199102-NYMEX.dly has a volume of 0 at 1990-12-19. | 2022-04-25 10:16:03.494
NG-202206-NYMEX [C] 64 Day #9 | File NG-199102-NYMEX.dly has a volume of 0 at 1991-01-18. | 2022-04-25 10:16:03.494
NG-202206-NYMEX [C] 64 Day #9 | File NG-199101-NYMEX.dly has a volume of 0 at 1990-11-20. | 2022-04-25 10:16:03.498
NG-202206-NYMEX [C] 64 Day #9 | File NG-199101-NYMEX.dly has a volume of 0 at 1990-12-18. | 2022-04-25 10:16:03.498
NG-202206-NYMEX [C] 64 Day #9 | File NG-199012-NYMEX.dly has a volume of 0 at 1990-10-19. | 2022-04-25 10:16:03.502
NG-202206-NYMEX [C] 64 Day #9 | File NG-199012-NYMEX.dly has a volume of 0 at 1990-11-19. | 2022-04-25 10:16:03.502
NG-202206-NYMEX [C] 64 Day #9 | File NG-199011-NYMEX.dly has a volume of 0 at 1990-09-18. | 2022-04-25 10:16:03.506
NG-202206-NYMEX [C] 64 Day #9 | File NG-199011-NYMEX.dly has a volume of 0 at 1990-10-18. | 2022-04-25 10:16:03.506
NG-202206-NYMEX [C] 64 Day #9 | File NG-199010-NYMEX.dly has a volume of 0 at 1990-08-21. | 2022-04-25 10:16:03.511
NG-202206-NYMEX [C] 64 Day #9 | File NG-199010-NYMEX.dly has a volume of 0 at 1990-09-17. | 2022-04-25 10:16:03.511
NG-202206-NYMEX [C] 64 Day #9 | File NG-199009-NYMEX.dly has a volume of 0 at 1990-07-19. | 2022-04-25 10:16:03.515
NG-202206-NYMEX [C] 64 Day #9 | File NG-199009-NYMEX.dly has a volume of 0 at 1990-08-20. | 2022-04-25 10:16:03.515
NG-202206-NYMEX [C] 64 Day #9 | File NG-199008-NYMEX.dly has a volume of 0 at 1990-06-19. | 2022-04-25 10:16:03.519
NG-202206-NYMEX [C] 64 Day #9 | File NG-199008-NYMEX.dly has a volume of 0 at 1990-07-18. | 2022-04-25 10:16:03.519
NG-202206-NYMEX [C] 64 Day #9 | File NG-199007-NYMEX.dly has a volume of 0 at 1990-05-21. | 2022-04-25 10:16:03.524
NG-202206-NYMEX [C] 64 Day #9 | File NG-199007-NYMEX.dly has a volume of 0 at 1990-06-18. | 2022-04-25 10:16:03.524
NG-202206-NYMEX [C] 64 Day #9 | File NG-199006-NYMEX.dly has a volume of 0 at 1990-04-18. | 2022-04-25 10:16:03.528
NG-202206-NYMEX [C] 64 Day #9 | File NG-199006-NYMEX.dly has a volume of 0 at 1990-05-18. | 2022-04-25 10:16:03.528
Historical data download thread signaled to stop. | 2022-04-25 10:16:03.673
HD Request # 74 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:08.428000 | 2022-04-25 10:16:03.673
HD Request # 74 | Received 21 Intraday data records from 2022-04-25 10:12:44.263000 to 2022-04-25 10:15:45.163002 (3.0 minutes) and wrote 20 records for TSN-NQTV | 2022-04-25 10:16:03.673
HD Request # 74 | Completion time: 3s | 2022-04-25 10:16:03.673
HD Request # 74 | Intraday data download complete for TSN-NQTV. Unique request ID: 202 | 2022-04-25 10:16:03.673
Removing historical data download ID 202. | 2022-04-25 10:16:03.673
Real-time Intraday chart data file updates started for TSN-NQTV | 2022-04-25 10:16:03.674
Intraday chart data file opened for TSN-NQTV | 2022-04-25 10:16:03.674
HD Request # 74 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:16:03.674
Triggering next historical data download in queue. | 2022-04-25 10:16:03.674
Restarting the loading process. | 2022-04-25 10:16:03.674
HD Request # 75 | Downloading Intraday chart data for TSLA-NQTV to the file TSLA-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:16:03.678
HD Request # 75 | Download start date-time: 2022-04-25 10:13:01.000000. File last date-time: 2022-04-25 10:13:01.327001 | 2022-04-25 10:16:03.678
HD Request # 75 | Using server: ds25.sierracharts.com port 10149 | 2022-04-25 10:16:03.678
Socket (4) | Creating socket. | 2022-04-25 10:16:03.678
Socket (4) | New receive buffer size: 5242880 | 2022-04-25 10:16:03.679
Socket (4) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:16:03.679
NG-202206-NYMEX [C] 32 Day #1 | Reloading chart. | 2022-04-25 10:16:03.737
NG-202206-NYMEX [C] 32 Day #1 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:16:03.737
NG-202206-NYMEX [C] 32 Day #1 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:16:03.737
Opened cached Intraday file: C:\SierraChart\Data\SPY-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:16:04.037
Opened cached Intraday file: C:\SierraChart\Data\ORLY-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:16:04.037
Opened cached Intraday file: C:\SierraChart\Data\REXR-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:16:04.037
Opened cached Intraday file: C:\SierraChart\Data\CUBE-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:16:04.037
Opened cached Intraday file: C:\SierraChart\Data\EXR-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:16:04.037
Opened cached Intraday file: C:\SierraChart\Data\PFG-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:16:04.038
HD Request # 75 | Setting DTC encoding to Binary VLS | 2022-04-25 10:16:04.131
HD Request # 75 | Sending historical data logon request message. | 2022-04-25 10:16:04.131
HD Request # 75 | Requesting Intraday data. Start date-time: 2022-04-25 10:13:01. Record interval: 0. Symbol: TSLA-NQTV | 2022-04-25 10:16:04.355
HD Request # 75 | Decompressing data. | 2022-04-25 10:16:04.580
HD Request # 75 | Receiving Intraday data for TSLA-NQTV starting at 2022-04-25 10:13:01.327000 | 2022-04-25 10:16:04.812
Socket (4) | CloseSocket call. | 2022-04-25 10:16:04.813
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:16:04.814
Socket (4) | Socket gracefully closed by remote side. | 2022-04-25 10:16:05.041
Socket (4) | Closed. | 2022-04-25 10:16:05.041
NG-202206-NYMEX [C] 32 Day #1 | File NG-200102-NYMEX.dly has a volume of 0 at 2000-12-19. | 2022-04-25 10:16:05.764
NG-202206-NYMEX [C] 32 Day #1 | File NG-200101-NYMEX.dly has a volume of 0 at 2000-11-20. | 2022-04-25 10:16:05.769
NG-202206-NYMEX [C] 32 Day #1 | File NG-200101-NYMEX.dly has a volume of 0 at 2000-12-18. | 2022-04-25 10:16:05.769
NG-202206-NYMEX [C] 32 Day #1 | File NG-200012-NYMEX.dly has a volume of 0 at 2000-10-19. | 2022-04-25 10:16:05.774
NG-202206-NYMEX [C] 32 Day #1 | File NG-200012-NYMEX.dly has a volume of 0 at 2000-11-17. | 2022-04-25 10:16:05.774
NG-202206-NYMEX [C] 32 Day #1 | File NG-200011-NYMEX.dly has a volume of 0 at 2000-09-19. | 2022-04-25 10:16:05.780
NG-202206-NYMEX [C] 32 Day #1 | File NG-200011-NYMEX.dly has a volume of 0 at 2000-10-18. | 2022-04-25 10:16:05.780
NG-202206-NYMEX [C] 32 Day #1 | File NG-200010-NYMEX.dly has a volume of 0 at 2000-08-21. | 2022-04-25 10:16:05.785
NG-202206-NYMEX [C] 32 Day #1 | File NG-200010-NYMEX.dly has a volume of 0 at 2000-09-18. | 2022-04-25 10:16:05.785
NG-202206-NYMEX [C] 32 Day #1 | File NG-200009-NYMEX.dly has a volume of 0 at 2000-07-19. | 2022-04-25 10:16:05.790
NG-202206-NYMEX [C] 32 Day #1 | File NG-200009-NYMEX.dly has a volume of 0 at 2000-08-18. | 2022-04-25 10:16:05.790
NG-202206-NYMEX [C] 32 Day #1 | File NG-200008-NYMEX.dly has a volume of 0 at 2000-06-20. | 2022-04-25 10:16:05.795
NG-202206-NYMEX [C] 32 Day #1 | File NG-200008-NYMEX.dly has a volume of 0 at 2000-07-18. | 2022-04-25 10:16:05.795
NG-202206-NYMEX [C] 32 Day #1 | File NG-200007-NYMEX.dly has a volume of 0 at 2000-05-19. | 2022-04-25 10:16:05.800
NG-202206-NYMEX [C] 32 Day #1 | File NG-200007-NYMEX.dly has a volume of 0 at 2000-06-19. | 2022-04-25 10:16:05.800
NG-202206-NYMEX [C] 32 Day #1 | File NG-200006-NYMEX.dly has a volume of 0 at 2000-04-18. | 2022-04-25 10:16:05.806
NG-202206-NYMEX [C] 32 Day #1 | File NG-200006-NYMEX.dly has a volume of 0 at 2000-05-18. | 2022-04-25 10:16:05.806
NG-202206-NYMEX [C] 32 Day #1 | File NG-200005-NYMEX.dly has a volume of 0 at 2000-03-21. | 2022-04-25 10:16:05.811
NG-202206-NYMEX [C] 32 Day #1 | File NG-200005-NYMEX.dly has a volume of 0 at 2000-04-17. | 2022-04-25 10:16:05.811
NG-202206-NYMEX [C] 32 Day #1 | File NG-200004-NYMEX.dly has a volume of 0 at 2000-02-17. | 2022-04-25 10:16:05.816
NG-202206-NYMEX [C] 32 Day #1 | File NG-200004-NYMEX.dly has a volume of 0 at 2000-03-20. | 2022-04-25 10:16:05.816
NG-202206-NYMEX [C] 32 Day #1 | File NG-200003-NYMEX.dly has a volume of 0 at 2000-01-19. | 2022-04-25 10:16:05.821
NG-202206-NYMEX [C] 32 Day #1 | File NG-200003-NYMEX.dly has a volume of 0 at 2000-02-16. | 2022-04-25 10:16:05.821
NG-202206-NYMEX [C] 32 Day #1 | File NG-200002-NYMEX.dly has a volume of 0 at 1999-12-21. | 2022-04-25 10:16:05.826
NG-202206-NYMEX [C] 32 Day #1 | File NG-200002-NYMEX.dly has a volume of 0 at 2000-01-18. | 2022-04-25 10:16:05.826
NG-202206-NYMEX [C] 32 Day #1 | File NG-200001-NYMEX.dly has a volume of 0 at 1999-11-18. | 2022-04-25 10:16:05.831
NG-202206-NYMEX [C] 32 Day #1 | File NG-200001-NYMEX.dly has a volume of 0 at 1999-12-20. | 2022-04-25 10:16:05.831
NG-202206-NYMEX [C] 32 Day #1 | File NG-199912-NYMEX.dly has a volume of 0 at 1999-10-19. | 2022-04-25 10:16:05.836
NG-202206-NYMEX [C] 32 Day #1 | File NG-199912-NYMEX.dly has a volume of 0 at 1999-11-17. | 2022-04-25 10:16:05.836
NG-202206-NYMEX [C] 32 Day #1 | File NG-199911-NYMEX.dly has a volume of 0 at 1999-09-20. | 2022-04-25 10:16:05.841
NG-202206-NYMEX [C] 32 Day #1 | File NG-199911-NYMEX.dly has a volume of 0 at 1999-10-18. | 2022-04-25 10:16:05.841
NG-202206-NYMEX [C] 32 Day #1 | File NG-199910-NYMEX.dly has a volume of 0 at 1999-08-19. | 2022-04-25 10:16:05.846
NG-202206-NYMEX [C] 32 Day #1 | File NG-199910-NYMEX.dly has a volume of 0 at 1999-09-17. | 2022-04-25 10:16:05.846
NG-202206-NYMEX [C] 32 Day #1 | File NG-199909-NYMEX.dly has a volume of 0 at 1999-07-20. | 2022-04-25 10:16:05.851
NG-202206-NYMEX [C] 32 Day #1 | File NG-199909-NYMEX.dly has a volume of 0 at 1999-08-18. | 2022-04-25 10:16:05.851
NG-202206-NYMEX [C] 32 Day #1 | File NG-199908-NYMEX.dly has a volume of 0 at 1999-06-18. | 2022-04-25 10:16:05.856
NG-202206-NYMEX [C] 32 Day #1 | File NG-199908-NYMEX.dly has a volume of 0 at 1999-07-19. | 2022-04-25 10:16:05.856
NG-202206-NYMEX [C] 32 Day #1 | File NG-199907-NYMEX.dly has a volume of 0 at 1999-05-19. | 2022-04-25 10:16:05.862
NG-202206-NYMEX [C] 32 Day #1 | File NG-199907-NYMEX.dly has a volume of 0 at 1999-06-17. | 2022-04-25 10:16:05.862
NG-202206-NYMEX [C] 32 Day #1 | File NG-199906-NYMEX.dly has a volume of 0 at 1999-04-20. | 2022-04-25 10:16:05.867
NG-202206-NYMEX [C] 32 Day #1 | File NG-199906-NYMEX.dly has a volume of 0 at 1999-05-18. | 2022-04-25 10:16:05.867
NG-202206-NYMEX [C] 32 Day #1 | File NG-199905-NYMEX.dly has a volume of 0 at 1999-03-19. | 2022-04-25 10:16:05.872
NG-202206-NYMEX [C] 32 Day #1 | File NG-199905-NYMEX.dly has a volume of 0 at 1999-04-19. | 2022-04-25 10:16:05.872
NG-202206-NYMEX [C] 32 Day #1 | File NG-199904-NYMEX.dly has a volume of 0 at 1999-02-16. | 2022-04-25 10:16:05.877
NG-202206-NYMEX [C] 32 Day #1 | File NG-199904-NYMEX.dly has a volume of 0 at 1999-03-18. | 2022-04-25 10:16:05.877
NG-202206-NYMEX [C] 32 Day #1 | File NG-199903-NYMEX.dly has a volume of 0 at 1999-01-19. | 2022-04-25 10:16:05.882
NG-202206-NYMEX [C] 32 Day #1 | File NG-199903-NYMEX.dly has a volume of 0 at 1999-02-15. | 2022-04-25 10:16:05.882
NG-202206-NYMEX [C] 32 Day #1 | File NG-199902-NYMEX.dly has a volume of 0 at 1998-12-21. | 2022-04-25 10:16:05.887
NG-202206-NYMEX [C] 32 Day #1 | File NG-199902-NYMEX.dly has a volume of 0 at 1999-01-18. | 2022-04-25 10:16:05.887
NG-202206-NYMEX [C] 32 Day #1 | File NG-199901-NYMEX.dly has a volume of 0 at 1998-11-18. | 2022-04-25 10:16:05.892
NG-202206-NYMEX [C] 32 Day #1 | File NG-199901-NYMEX.dly has a volume of 0 at 1998-12-18. | 2022-04-25 10:16:05.892
NG-202206-NYMEX [C] 32 Day #1 | File NG-199812-NYMEX.dly has a volume of 0 at 1998-10-20. | 2022-04-25 10:16:05.897
NG-202206-NYMEX [C] 32 Day #1 | File NG-199812-NYMEX.dly has a volume of 0 at 1998-11-17. | 2022-04-25 10:16:05.897
NG-202206-NYMEX [C] 32 Day #1 | File NG-199811-NYMEX.dly has a volume of 0 at 1998-09-18. | 2022-04-25 10:16:05.902
NG-202206-NYMEX [C] 32 Day #1 | File NG-199811-NYMEX.dly has a volume of 0 at 1998-10-19. | 2022-04-25 10:16:05.902
NG-202206-NYMEX [C] 32 Day #1 | File NG-199810-NYMEX.dly has a volume of 0 at 1998-08-19. | 2022-04-25 10:16:05.907
NG-202206-NYMEX [C] 32 Day #1 | File NG-199810-NYMEX.dly has a volume of 0 at 1998-09-17. | 2022-04-25 10:16:05.907
NG-202206-NYMEX [C] 32 Day #1 | File NG-199809-NYMEX.dly has a volume of 0 at 1998-07-21. | 2022-04-25 10:16:05.912
NG-202206-NYMEX [C] 32 Day #1 | File NG-199809-NYMEX.dly has a volume of 0 at 1998-08-18. | 2022-04-25 10:16:05.912
NG-202206-NYMEX [C] 32 Day #1 | File NG-199808-NYMEX.dly has a volume of 0 at 1998-06-18. | 2022-04-25 10:16:05.917
NG-202206-NYMEX [C] 32 Day #1 | File NG-199808-NYMEX.dly has a volume of 0 at 1998-07-20. | 2022-04-25 10:16:05.917
NG-202206-NYMEX [C] 32 Day #1 | File NG-199807-NYMEX.dly has a volume of 0 at 1998-05-19. | 2022-04-25 10:16:05.923
NG-202206-NYMEX [C] 32 Day #1 | File NG-199807-NYMEX.dly has a volume of 0 at 1998-06-17. | 2022-04-25 10:16:05.923
NG-202206-NYMEX [C] 32 Day #1 | File NG-199806-NYMEX.dly has a volume of 0 at 1998-04-20. | 2022-04-25 10:16:05.928
NG-202206-NYMEX [C] 32 Day #1 | File NG-199806-NYMEX.dly has a volume of 0 at 1998-05-18. | 2022-04-25 10:16:05.928
NG-202206-NYMEX [C] 32 Day #1 | File NG-199805-NYMEX.dly has a volume of 0 at 1998-03-19. | 2022-04-25 10:16:05.933
NG-202206-NYMEX [C] 32 Day #1 | File NG-199805-NYMEX.dly has a volume of 0 at 1998-04-17. | 2022-04-25 10:16:05.933
NG-202206-NYMEX [C] 32 Day #1 | File NG-199804-NYMEX.dly has a volume of 0 at 1998-02-17. | 2022-04-25 10:16:05.938
NG-202206-NYMEX [C] 32 Day #1 | File NG-199804-NYMEX.dly has a volume of 0 at 1998-03-18. | 2022-04-25 10:16:05.938
NG-202206-NYMEX [C] 32 Day #1 | File NG-199803-NYMEX.dly has a volume of 0 at 1998-01-20. | 2022-04-25 10:16:05.943
NG-202206-NYMEX [C] 32 Day #1 | File NG-199803-NYMEX.dly has a volume of 0 at 1998-02-16. | 2022-04-25 10:16:05.943
NG-202206-NYMEX [C] 32 Day #1 | File NG-199802-NYMEX.dly has a volume of 0 at 1997-12-19. | 2022-04-25 10:16:05.948
NG-202206-NYMEX [C] 32 Day #1 | File NG-199802-NYMEX.dly has a volume of 0 at 1998-01-19. | 2022-04-25 10:16:05.948
NG-202206-NYMEX [C] 32 Day #1 | File NG-199801-NYMEX.dly has a volume of 0 at 1997-11-18. | 2022-04-25 10:16:05.953
NG-202206-NYMEX [C] 32 Day #1 | File NG-199801-NYMEX.dly has a volume of 0 at 1997-12-18. | 2022-04-25 10:16:05.953
NG-202206-NYMEX [C] 32 Day #1 | File NG-199712-NYMEX.dly has a volume of 0 at 1997-10-21. | 2022-04-25 10:16:05.958
NG-202206-NYMEX [C] 32 Day #1 | File NG-199712-NYMEX.dly has a volume of 0 at 1997-11-17. | 2022-04-25 10:16:05.958
NG-202206-NYMEX [C] 32 Day #1 | File NG-199711-NYMEX.dly has a volume of 0 at 1997-09-18. | 2022-04-25 10:16:05.963
NG-202206-NYMEX [C] 32 Day #1 | File NG-199711-NYMEX.dly has a volume of 0 at 1997-10-20. | 2022-04-25 10:16:05.963
NG-202206-NYMEX [C] 32 Day #1 | File NG-199710-NYMEX.dly has a volume of 0 at 1997-08-19. | 2022-04-25 10:16:05.969
NG-202206-NYMEX [C] 32 Day #1 | File NG-199710-NYMEX.dly has a volume of 0 at 1997-09-17. | 2022-04-25 10:16:05.969
NG-202206-NYMEX [C] 32 Day #1 | File NG-199709-NYMEX.dly has a volume of 0 at 1997-07-21. | 2022-04-25 10:16:05.974
NG-202206-NYMEX [C] 32 Day #1 | File NG-199709-NYMEX.dly has a volume of 0 at 1997-08-18. | 2022-04-25 10:16:05.974
NG-202206-NYMEX [C] 32 Day #1 | File NG-199708-NYMEX.dly has a volume of 0 at 1997-06-18. | 2022-04-25 10:16:05.979
NG-202206-NYMEX [C] 32 Day #1 | File NG-199708-NYMEX.dly has a volume of 0 at 1997-07-18. | 2022-04-25 10:16:05.979
NG-202206-NYMEX [C] 32 Day #1 | File NG-199707-NYMEX.dly has a volume of 0 at 1997-05-20. | 2022-04-25 10:16:05.984
NG-202206-NYMEX [C] 32 Day #1 | File NG-199707-NYMEX.dly has a volume of 0 at 1997-06-17. | 2022-04-25 10:16:05.984
NG-202206-NYMEX [C] 32 Day #1 | File NG-199706-NYMEX.dly has a volume of 0 at 1997-04-18. | 2022-04-25 10:16:05.989
NG-202206-NYMEX [C] 32 Day #1 | File NG-199706-NYMEX.dly has a volume of 0 at 1997-05-19. | 2022-04-25 10:16:05.989
NG-202206-NYMEX [C] 32 Day #1 | File NG-199705-NYMEX.dly has a volume of 0 at 1997-03-19. | 2022-04-25 10:16:05.994
NG-202206-NYMEX [C] 32 Day #1 | File NG-199705-NYMEX.dly has a volume of 0 at 1997-04-17. | 2022-04-25 10:16:05.994
NG-202206-NYMEX [C] 32 Day #1 | File NG-199704-NYMEX.dly has a volume of 0 at 1997-02-18. | 2022-04-25 10:16:05.999
NG-202206-NYMEX [C] 32 Day #1 | File NG-199704-NYMEX.dly has a volume of 0 at 1997-03-18. | 2022-04-25 10:16:05.999
NG-202206-NYMEX [C] 32 Day #1 | File NG-199703-NYMEX.dly has a volume of 0 at 1997-01-21. | 2022-04-25 10:16:06.004
NG-202206-NYMEX [C] 32 Day #1 | File NG-199703-NYMEX.dly has a volume of 0 at 1997-02-17. | 2022-04-25 10:16:06.004
NG-202206-NYMEX [C] 32 Day #1 | File NG-199702-NYMEX.dly has a volume of 0 at 1996-12-19. | 2022-04-25 10:16:06.009
NG-202206-NYMEX [C] 32 Day #1 | File NG-199702-NYMEX.dly has a volume of 0 at 1997-01-20. | 2022-04-25 10:16:06.009
NG-202206-NYMEX [C] 32 Day #1 | File NG-199701-NYMEX.dly has a volume of 0 at 1996-11-19. | 2022-04-25 10:16:06.013
NG-202206-NYMEX [C] 32 Day #1 | File NG-199701-NYMEX.dly has a volume of 0 at 1996-12-18. | 2022-04-25 10:16:06.013
NG-202206-NYMEX [C] 32 Day #1 | File NG-199612-NYMEX.dly has a volume of 0 at 1996-10-21. | 2022-04-25 10:16:06.018
NG-202206-NYMEX [C] 32 Day #1 | File NG-199612-NYMEX.dly has a volume of 0 at 1996-11-18. | 2022-04-25 10:16:06.018
NG-202206-NYMEX [C] 32 Day #1 | File NG-199611-NYMEX.dly has a volume of 0 at 1996-09-18. | 2022-04-25 10:16:06.023
NG-202206-NYMEX [C] 32 Day #1 | File NG-199611-NYMEX.dly has a volume of 0 at 1996-10-18. | 2022-04-25 10:16:06.023
NG-202206-NYMEX [C] 32 Day #1 | File NG-199610-NYMEX.dly has a volume of 0 at 1996-08-20. | 2022-04-25 10:16:06.028
NG-202206-NYMEX [C] 32 Day #1 | File NG-199610-NYMEX.dly has a volume of 0 at 1996-09-17. | 2022-04-25 10:16:06.028
NG-202206-NYMEX [C] 32 Day #1 | File NG-199609-NYMEX.dly has a volume of 0 at 1996-07-19. | 2022-04-25 10:16:06.033
NG-202206-NYMEX [C] 32 Day #1 | File NG-199609-NYMEX.dly has a volume of 0 at 1996-08-19. | 2022-04-25 10:16:06.033
NG-202206-NYMEX [C] 32 Day #1 | File NG-199608-NYMEX.dly has a volume of 0 at 1996-06-18. | 2022-04-25 10:16:06.038
NG-202206-NYMEX [C] 32 Day #1 | File NG-199608-NYMEX.dly has a volume of 0 at 1996-07-18. | 2022-04-25 10:16:06.038
NG-202206-NYMEX [C] 32 Day #1 | File NG-199607-NYMEX.dly has a volume of 0 at 1996-05-21. | 2022-04-25 10:16:06.042
NG-202206-NYMEX [C] 32 Day #1 | File NG-199607-NYMEX.dly has a volume of 0 at 1996-06-17. | 2022-04-25 10:16:06.042
NG-202206-NYMEX [C] 32 Day #1 | File NG-199606-NYMEX.dly has a volume of 0 at 1996-04-18. | 2022-04-25 10:16:06.047
NG-202206-NYMEX [C] 32 Day #1 | File NG-199606-NYMEX.dly has a volume of 0 at 1996-05-20. | 2022-04-25 10:16:06.047
NG-202206-NYMEX [C] 32 Day #1 | File NG-199605-NYMEX.dly has a volume of 0 at 1996-03-19. | 2022-04-25 10:16:06.052
NG-202206-NYMEX [C] 32 Day #1 | File NG-199605-NYMEX.dly has a volume of 0 at 1996-04-17. | 2022-04-25 10:16:06.052
NG-202206-NYMEX [C] 32 Day #1 | File NG-199604-NYMEX.dly has a volume of 0 at 1996-02-19. | 2022-04-25 10:16:06.057
NG-202206-NYMEX [C] 32 Day #1 | File NG-199604-NYMEX.dly has a volume of 0 at 1996-03-18. | 2022-04-25 10:16:06.057
NG-202206-NYMEX [C] 32 Day #1 | File NG-199603-NYMEX.dly has a volume of 0 at 1996-01-19. | 2022-04-25 10:16:06.062
NG-202206-NYMEX [C] 32 Day #1 | File NG-199603-NYMEX.dly has a volume of 0 at 1996-02-16. | 2022-04-25 10:16:06.062
NG-202206-NYMEX [C] 32 Day #1 | File NG-199602-NYMEX.dly has a volume of 0 at 1995-12-19. | 2022-04-25 10:16:06.067
NG-202206-NYMEX [C] 32 Day #1 | File NG-199602-NYMEX.dly has a volume of 0 at 1996-01-18. | 2022-04-25 10:16:06.067
NG-202206-NYMEX [C] 32 Day #1 | File NG-199601-NYMEX.dly has a volume of 0 at 1995-11-20. | 2022-04-25 10:16:06.071
NG-202206-NYMEX [C] 32 Day #1 | File NG-199601-NYMEX.dly has a volume of 0 at 1995-12-18. | 2022-04-25 10:16:06.071
NG-202206-NYMEX [C] 32 Day #1 | File NG-199512-NYMEX.dly has a volume of 0 at 1995-10-19. | 2022-04-25 10:16:06.076
NG-202206-NYMEX [C] 32 Day #1 | File NG-199512-NYMEX.dly has a volume of 0 at 1995-11-17. | 2022-04-25 10:16:06.076
NG-202206-NYMEX [C] 32 Day #1 | File NG-199511-NYMEX.dly has a volume of 0 at 1995-09-19. | 2022-04-25 10:16:06.080
NG-202206-NYMEX [C] 32 Day #1 | File NG-199511-NYMEX.dly has a volume of 0 at 1995-10-18. | 2022-04-25 10:16:06.080
NG-202206-NYMEX [C] 32 Day #1 | File NG-199510-NYMEX.dly has a volume of 0 at 1995-08-21. | 2022-04-25 10:16:06.085
NG-202206-NYMEX [C] 32 Day #1 | File NG-199510-NYMEX.dly has a volume of 0 at 1995-09-18. | 2022-04-25 10:16:06.085
NG-202206-NYMEX [C] 32 Day #1 | File NG-199509-NYMEX.dly has a volume of 0 at 1995-07-19. | 2022-04-25 10:16:06.090
NG-202206-NYMEX [C] 32 Day #1 | File NG-199509-NYMEX.dly has a volume of 0 at 1995-08-18. | 2022-04-25 10:16:06.090
NG-202206-NYMEX [C] 32 Day #1 | File NG-199508-NYMEX.dly has a volume of 0 at 1995-06-20. | 2022-04-25 10:16:06.094
NG-202206-NYMEX [C] 32 Day #1 | File NG-199508-NYMEX.dly has a volume of 0 at 1995-07-18. | 2022-04-25 10:16:06.095
NG-202206-NYMEX [C] 32 Day #1 | File NG-199507-NYMEX.dly has a volume of 0 at 1995-05-19. | 2022-04-25 10:16:06.099
NG-202206-NYMEX [C] 32 Day #1 | File NG-199507-NYMEX.dly has a volume of 0 at 1995-06-19. | 2022-04-25 10:16:06.099
NG-202206-NYMEX [C] 32 Day #1 | File NG-199506-NYMEX.dly has a volume of 0 at 1995-04-18. | 2022-04-25 10:16:06.104
NG-202206-NYMEX [C] 32 Day #1 | File NG-199506-NYMEX.dly has a volume of 0 at 1995-05-18. | 2022-04-25 10:16:06.104
NG-202206-NYMEX [C] 32 Day #1 | File NG-199505-NYMEX.dly has a volume of 0 at 1995-03-21. | 2022-04-25 10:16:06.108
NG-202206-NYMEX [C] 32 Day #1 | File NG-199505-NYMEX.dly has a volume of 0 at 1995-04-17. | 2022-04-25 10:16:06.108
NG-202206-NYMEX [C] 32 Day #1 | File NG-199504-NYMEX.dly has a volume of 0 at 1995-02-16. | 2022-04-25 10:16:06.113
NG-202206-NYMEX [C] 32 Day #1 | File NG-199504-NYMEX.dly has a volume of 0 at 1995-03-20. | 2022-04-25 10:16:06.113
NG-202206-NYMEX [C] 32 Day #1 | File NG-199503-NYMEX.dly has a volume of 0 at 1995-01-19. | 2022-04-25 10:16:06.118
NG-202206-NYMEX [C] 32 Day #1 | File NG-199503-NYMEX.dly has a volume of 0 at 1995-02-15. | 2022-04-25 10:16:06.118
NG-202206-NYMEX [C] 32 Day #1 | File NG-199502-NYMEX.dly has a volume of 0 at 1994-12-20. | 2022-04-25 10:16:06.122
NG-202206-NYMEX [C] 32 Day #1 | File NG-199502-NYMEX.dly has a volume of 0 at 1995-01-18. | 2022-04-25 10:16:06.122
NG-202206-NYMEX [C] 32 Day #1 | File NG-199501-NYMEX.dly has a volume of 0 at 1994-11-18. | 2022-04-25 10:16:06.127
NG-202206-NYMEX [C] 32 Day #1 | File NG-199501-NYMEX.dly has a volume of 0 at 1994-12-19. | 2022-04-25 10:16:06.127
NG-202206-NYMEX [C] 32 Day #1 | File NG-199412-NYMEX.dly has a volume of 0 at 1994-10-19. | 2022-04-25 10:16:06.131
NG-202206-NYMEX [C] 32 Day #1 | File NG-199412-NYMEX.dly has a volume of 0 at 1994-11-17. | 2022-04-25 10:16:06.131
NG-202206-NYMEX [C] 32 Day #1 | File NG-199411-NYMEX.dly has a volume of 0 at 1994-09-20. | 2022-04-25 10:16:06.136
NG-202206-NYMEX [C] 32 Day #1 | File NG-199411-NYMEX.dly has a volume of 0 at 1994-10-18. | 2022-04-25 10:16:06.136
NG-202206-NYMEX [C] 32 Day #1 | File NG-199410-NYMEX.dly has a volume of 0 at 1994-08-19. | 2022-04-25 10:16:06.140
NG-202206-NYMEX [C] 32 Day #1 | File NG-199410-NYMEX.dly has a volume of 0 at 1994-09-19. | 2022-04-25 10:16:06.140
NG-202206-NYMEX [C] 32 Day #1 | File NG-199409-NYMEX.dly has a volume of 0 at 1994-07-19. | 2022-04-25 10:16:06.145
NG-202206-NYMEX [C] 32 Day #1 | File NG-199409-NYMEX.dly has a volume of 0 at 1994-08-18. | 2022-04-25 10:16:06.145
NG-202206-NYMEX [C] 32 Day #1 | File NG-199408-NYMEX.dly has a volume of 0 at 1994-06-20. | 2022-04-25 10:16:06.150
NG-202206-NYMEX [C] 32 Day #1 | File NG-199408-NYMEX.dly has a volume of 0 at 1994-07-18. | 2022-04-25 10:16:06.150
NG-202206-NYMEX [C] 32 Day #1 | File NG-199407-NYMEX.dly has a volume of 0 at 1994-05-19. | 2022-04-25 10:16:06.154
NG-202206-NYMEX [C] 32 Day #1 | File NG-199407-NYMEX.dly has a volume of 0 at 1994-06-17. | 2022-04-25 10:16:06.154
NG-202206-NYMEX [C] 32 Day #1 | File NG-199406-NYMEX.dly has a volume of 0 at 1994-04-19. | 2022-04-25 10:16:06.159
NG-202206-NYMEX [C] 32 Day #1 | File NG-199406-NYMEX.dly has a volume of 0 at 1994-05-18. | 2022-04-25 10:16:06.159
NG-202206-NYMEX [C] 32 Day #1 | File NG-199405-NYMEX.dly has a volume of 0 at 1994-03-21. | 2022-04-25 10:16:06.163
NG-202206-NYMEX [C] 32 Day #1 | File NG-199405-NYMEX.dly has a volume of 0 at 1994-04-18. | 2022-04-25 10:16:06.163
NG-202206-NYMEX [C] 32 Day #1 | File NG-199404-NYMEX.dly has a volume of 0 at 1994-02-16. | 2022-04-25 10:16:06.168
NG-202206-NYMEX [C] 32 Day #1 | File NG-199404-NYMEX.dly has a volume of 0 at 1994-03-18. | 2022-04-25 10:16:06.168
NG-202206-NYMEX [C] 32 Day #1 | File NG-199403-NYMEX.dly has a volume of 0 at 1994-01-19. | 2022-04-25 10:16:06.173
NG-202206-NYMEX [C] 32 Day #1 | File NG-199403-NYMEX.dly has a volume of 0 at 1994-02-15. | 2022-04-25 10:16:06.173
NG-202206-NYMEX [C] 32 Day #1 | File NG-199402-NYMEX.dly has a volume of 0 at 1993-12-21. | 2022-04-25 10:16:06.177
NG-202206-NYMEX [C] 32 Day #1 | File NG-199402-NYMEX.dly has a volume of 0 at 1994-01-18. | 2022-04-25 10:16:06.177
NG-202206-NYMEX [C] 32 Day #1 | File NG-199401-NYMEX.dly has a volume of 0 at 1993-11-18. | 2022-04-25 10:16:06.182
NG-202206-NYMEX [C] 32 Day #1 | File NG-199401-NYMEX.dly has a volume of 0 at 1993-12-20. | 2022-04-25 10:16:06.182
NG-202206-NYMEX [C] 32 Day #1 | File NG-199312-NYMEX.dly has a volume of 0 at 1993-10-19. | 2022-04-25 10:16:06.186
NG-202206-NYMEX [C] 32 Day #1 | File NG-199312-NYMEX.dly has a volume of 0 at 1993-11-17. | 2022-04-25 10:16:06.186
NG-202206-NYMEX [C] 32 Day #1 | File NG-199311-NYMEX.dly has a volume of 0 at 1993-09-20. | 2022-04-25 10:16:06.191
NG-202206-NYMEX [C] 32 Day #1 | File NG-199311-NYMEX.dly has a volume of 0 at 1993-10-18. | 2022-04-25 10:16:06.191
NG-202206-NYMEX [C] 32 Day #1 | File NG-199310-NYMEX.dly has a volume of 0 at 1993-08-19. | 2022-04-25 10:16:06.196
NG-202206-NYMEX [C] 32 Day #1 | File NG-199310-NYMEX.dly has a volume of 0 at 1993-09-17. | 2022-04-25 10:16:06.196
NG-202206-NYMEX [C] 32 Day #1 | File NG-199309-NYMEX.dly has a volume of 0 at 1993-07-20. | 2022-04-25 10:16:06.201
NG-202206-NYMEX [C] 32 Day #1 | File NG-199309-NYMEX.dly has a volume of 0 at 1993-08-18. | 2022-04-25 10:16:06.201
NG-202206-NYMEX [C] 32 Day #1 | File NG-199308-NYMEX.dly has a volume of 0 at 1993-06-18. | 2022-04-25 10:16:06.206
NG-202206-NYMEX [C] 32 Day #1 | File NG-199308-NYMEX.dly has a volume of 0 at 1993-07-19. | 2022-04-25 10:16:06.206
NG-202206-NYMEX [C] 32 Day #1 | File NG-199307-NYMEX.dly has a volume of 0 at 1993-05-19. | 2022-04-25 10:16:06.210
NG-202206-NYMEX [C] 32 Day #1 | File NG-199307-NYMEX.dly has a volume of 0 at 1993-06-17. | 2022-04-25 10:16:06.210
NG-202206-NYMEX [C] 32 Day #1 | File NG-199306-NYMEX.dly has a volume of 0 at 1993-04-20. | 2022-04-25 10:16:06.215
NG-202206-NYMEX [C] 32 Day #1 | File NG-199306-NYMEX.dly has a volume of 0 at 1993-05-18. | 2022-04-25 10:16:06.215
NG-202206-NYMEX [C] 32 Day #1 | File NG-199305-NYMEX.dly has a volume of 0 at 1993-03-19. | 2022-04-25 10:16:06.219
NG-202206-NYMEX [C] 32 Day #1 | File NG-199305-NYMEX.dly has a volume of 0 at 1993-04-19. | 2022-04-25 10:16:06.219
NG-202206-NYMEX [C] 32 Day #1 | File NG-199304-NYMEX.dly has a volume of 0 at 1993-02-16. | 2022-04-25 10:16:06.224
NG-202206-NYMEX [C] 32 Day #1 | File NG-199304-NYMEX.dly has a volume of 0 at 1993-03-18. | 2022-04-25 10:16:06.224
NG-202206-NYMEX [C] 32 Day #1 | File NG-199303-NYMEX.dly has a volume of 0 at 1993-01-19. | 2022-04-25 10:16:06.229
NG-202206-NYMEX [C] 32 Day #1 | File NG-199303-NYMEX.dly has a volume of 0 at 1993-02-15. | 2022-04-25 10:16:06.229
NG-202206-NYMEX [C] 32 Day #1 | File NG-199302-NYMEX.dly has a volume of 0 at 1992-12-21. | 2022-04-25 10:16:06.233
NG-202206-NYMEX [C] 32 Day #1 | File NG-199302-NYMEX.dly has a volume of 0 at 1993-01-18. | 2022-04-25 10:16:06.233
NG-202206-NYMEX [C] 32 Day #1 | File NG-199301-NYMEX.dly has a volume of 0 at 1992-11-18. | 2022-04-25 10:16:06.237
NG-202206-NYMEX [C] 32 Day #1 | File NG-199301-NYMEX.dly has a volume of 0 at 1992-12-18. | 2022-04-25 10:16:06.237
NG-202206-NYMEX [C] 32 Day #1 | File NG-199212-NYMEX.dly has a volume of 0 at 1992-10-20. | 2022-04-25 10:16:06.242
NG-202206-NYMEX [C] 32 Day #1 | File NG-199212-NYMEX.dly has a volume of 0 at 1992-11-17. | 2022-04-25 10:16:06.242
NG-202206-NYMEX [C] 32 Day #1 | File NG-199211-NYMEX.dly has a volume of 0 at 1992-09-18. | 2022-04-25 10:16:06.247
NG-202206-NYMEX [C] 32 Day #1 | File NG-199211-NYMEX.dly has a volume of 0 at 1992-10-19. | 2022-04-25 10:16:06.247
NG-202206-NYMEX [C] 32 Day #1 | File NG-199210-NYMEX.dly has a volume of 0 at 1992-08-19. | 2022-04-25 10:16:06.251
NG-202206-NYMEX [C] 32 Day #1 | File NG-199210-NYMEX.dly has a volume of 0 at 1992-09-17. | 2022-04-25 10:16:06.251
NG-202206-NYMEX [C] 32 Day #1 | File NG-199209-NYMEX.dly has a volume of 0 at 1992-07-21. | 2022-04-25 10:16:06.256
NG-202206-NYMEX [C] 32 Day #1 | File NG-199209-NYMEX.dly has a volume of 0 at 1992-08-18. | 2022-04-25 10:16:06.256
NG-202206-NYMEX [C] 32 Day #1 | File NG-199208-NYMEX.dly has a volume of 0 at 1992-06-18. | 2022-04-25 10:16:06.261
NG-202206-NYMEX [C] 32 Day #1 | File NG-199208-NYMEX.dly has a volume of 0 at 1992-07-20. | 2022-04-25 10:16:06.261
NG-202206-NYMEX [C] 32 Day #1 | File NG-199207-NYMEX.dly has a volume of 0 at 1992-05-19. | 2022-04-25 10:16:06.265
NG-202206-NYMEX [C] 32 Day #1 | File NG-199207-NYMEX.dly has a volume of 0 at 1992-06-17. | 2022-04-25 10:16:06.265
NG-202206-NYMEX [C] 32 Day #1 | File NG-199206-NYMEX.dly has a volume of 0 at 1992-04-20. | 2022-04-25 10:16:06.270
NG-202206-NYMEX [C] 32 Day #1 | File NG-199206-NYMEX.dly has a volume of 0 at 1992-05-18. | 2022-04-25 10:16:06.270
NG-202206-NYMEX [C] 32 Day #1 | File NG-199205-NYMEX.dly has a volume of 0 at 1992-03-19. | 2022-04-25 10:16:06.274
NG-202206-NYMEX [C] 32 Day #1 | File NG-199205-NYMEX.dly has a volume of 0 at 1992-04-17. | 2022-04-25 10:16:06.274
NG-202206-NYMEX [C] 32 Day #1 | File NG-199204-NYMEX.dly has a volume of 0 at 1992-02-18. | 2022-04-25 10:16:06.279
NG-202206-NYMEX [C] 32 Day #1 | File NG-199204-NYMEX.dly has a volume of 0 at 1992-03-18. | 2022-04-25 10:16:06.279
NG-202206-NYMEX [C] 32 Day #1 | File NG-199203-NYMEX.dly has a volume of 0 at 1992-01-21. | 2022-04-25 10:16:06.284
NG-202206-NYMEX [C] 32 Day #1 | File NG-199203-NYMEX.dly has a volume of 0 at 1992-02-17. | 2022-04-25 10:16:06.284
NG-202206-NYMEX [C] 32 Day #1 | File NG-199202-NYMEX.dly has a volume of 0 at 1991-12-19. | 2022-04-25 10:16:06.288
NG-202206-NYMEX [C] 32 Day #1 | File NG-199202-NYMEX.dly has a volume of 0 at 1992-01-20. | 2022-04-25 10:16:06.288
NG-202206-NYMEX [C] 32 Day #1 | File NG-199201-NYMEX.dly has a volume of 0 at 1991-11-19. | 2022-04-25 10:16:06.292
NG-202206-NYMEX [C] 32 Day #1 | File NG-199201-NYMEX.dly has a volume of 0 at 1991-12-18. | 2022-04-25 10:16:06.292
NG-202206-NYMEX [C] 32 Day #1 | File NG-199112-NYMEX.dly has a volume of 0 at 1991-10-21. | 2022-04-25 10:16:06.297
NG-202206-NYMEX [C] 32 Day #1 | File NG-199112-NYMEX.dly has a volume of 0 at 1991-11-18. | 2022-04-25 10:16:06.297
NG-202206-NYMEX [C] 32 Day #1 | File NG-199111-NYMEX.dly has a volume of 0 at 1991-09-18. | 2022-04-25 10:16:06.302
NG-202206-NYMEX [C] 32 Day #1 | File NG-199111-NYMEX.dly has a volume of 0 at 1991-10-18. | 2022-04-25 10:16:06.302
NG-202206-NYMEX [C] 32 Day #1 | File NG-199110-NYMEX.dly has a volume of 0 at 1991-08-20. | 2022-04-25 10:16:06.306
NG-202206-NYMEX [C] 32 Day #1 | File NG-199110-NYMEX.dly has a volume of 0 at 1991-09-17. | 2022-04-25 10:16:06.306
NG-202206-NYMEX [C] 32 Day #1 | File NG-199109-NYMEX.dly has a volume of 0 at 1991-07-19. | 2022-04-25 10:16:06.311
NG-202206-NYMEX [C] 32 Day #1 | File NG-199109-NYMEX.dly has a volume of 0 at 1991-08-19. | 2022-04-25 10:16:06.311
NG-202206-NYMEX [C] 32 Day #1 | File NG-199108-NYMEX.dly has a volume of 0 at 1991-06-18. | 2022-04-25 10:16:06.315
NG-202206-NYMEX [C] 32 Day #1 | File NG-199108-NYMEX.dly has a volume of 0 at 1991-07-18. | 2022-04-25 10:16:06.315
NG-202206-NYMEX [C] 32 Day #1 | File NG-199107-NYMEX.dly has a volume of 0 at 1991-05-21. | 2022-04-25 10:16:06.320
NG-202206-NYMEX [C] 32 Day #1 | File NG-199107-NYMEX.dly has a volume of 0 at 1991-06-17. | 2022-04-25 10:16:06.320
NG-202206-NYMEX [C] 32 Day #1 | File NG-199106-NYMEX.dly has a volume of 0 at 1991-04-18. | 2022-04-25 10:16:06.324
NG-202206-NYMEX [C] 32 Day #1 | File NG-199106-NYMEX.dly has a volume of 0 at 1991-05-20. | 2022-04-25 10:16:06.324
NG-202206-NYMEX [C] 32 Day #1 | File NG-199105-NYMEX.dly has a volume of 0 at 1991-03-19. | 2022-04-25 10:16:06.329
NG-202206-NYMEX [C] 32 Day #1 | File NG-199105-NYMEX.dly has a volume of 0 at 1991-04-17. | 2022-04-25 10:16:06.329
NG-202206-NYMEX [C] 32 Day #1 | File NG-199104-NYMEX.dly has a volume of 0 at 1991-02-18. | 2022-04-25 10:16:06.333
NG-202206-NYMEX [C] 32 Day #1 | File NG-199104-NYMEX.dly has a volume of 0 at 1991-03-18. | 2022-04-25 10:16:06.333
NG-202206-NYMEX [C] 32 Day #1 | File NG-199103-NYMEX.dly has a volume of 0 at 1991-01-21. | 2022-04-25 10:16:06.337
NG-202206-NYMEX [C] 32 Day #1 | File NG-199103-NYMEX.dly has a volume of 0 at 1991-02-15. | 2022-04-25 10:16:06.337
NG-202206-NYMEX [C] 32 Day #1 | File NG-199102-NYMEX.dly has a volume of 0 at 1990-12-19. | 2022-04-25 10:16:06.342
NG-202206-NYMEX [C] 32 Day #1 | File NG-199102-NYMEX.dly has a volume of 0 at 1991-01-18. | 2022-04-25 10:16:06.342
NG-202206-NYMEX [C] 32 Day #1 | File NG-199101-NYMEX.dly has a volume of 0 at 1990-11-20. | 2022-04-25 10:16:06.345
NG-202206-NYMEX [C] 32 Day #1 | File NG-199101-NYMEX.dly has a volume of 0 at 1990-12-18. | 2022-04-25 10:16:06.345
NG-202206-NYMEX [C] 32 Day #1 | File NG-199012-NYMEX.dly has a volume of 0 at 1990-10-19. | 2022-04-25 10:16:06.350
NG-202206-NYMEX [C] 32 Day #1 | File NG-199012-NYMEX.dly has a volume of 0 at 1990-11-19. | 2022-04-25 10:16:06.350
NG-202206-NYMEX [C] 32 Day #1 | File NG-199011-NYMEX.dly has a volume of 0 at 1990-09-18. | 2022-04-25 10:16:06.354
NG-202206-NYMEX [C] 32 Day #1 | File NG-199011-NYMEX.dly has a volume of 0 at 1990-10-18. | 2022-04-25 10:16:06.354
NG-202206-NYMEX [C] 32 Day #1 | File NG-199010-NYMEX.dly has a volume of 0 at 1990-08-21. | 2022-04-25 10:16:06.359
NG-202206-NYMEX [C] 32 Day #1 | File NG-199010-NYMEX.dly has a volume of 0 at 1990-09-17. | 2022-04-25 10:16:06.359
NG-202206-NYMEX [C] 32 Day #1 | File NG-199009-NYMEX.dly has a volume of 0 at 1990-07-19. | 2022-04-25 10:16:06.363
NG-202206-NYMEX [C] 32 Day #1 | File NG-199009-NYMEX.dly has a volume of 0 at 1990-08-20. | 2022-04-25 10:16:06.363
NG-202206-NYMEX [C] 32 Day #1 | File NG-199008-NYMEX.dly has a volume of 0 at 1990-06-19. | 2022-04-25 10:16:06.368
NG-202206-NYMEX [C] 32 Day #1 | File NG-199008-NYMEX.dly has a volume of 0 at 1990-07-18. | 2022-04-25 10:16:06.368
NG-202206-NYMEX [C] 32 Day #1 | File NG-199007-NYMEX.dly has a volume of 0 at 1990-05-21. | 2022-04-25 10:16:06.372
NG-202206-NYMEX [C] 32 Day #1 | File NG-199007-NYMEX.dly has a volume of 0 at 1990-06-18. | 2022-04-25 10:16:06.372
NG-202206-NYMEX [C] 32 Day #1 | File NG-199006-NYMEX.dly has a volume of 0 at 1990-04-18. | 2022-04-25 10:16:06.377
NG-202206-NYMEX [C] 32 Day #1 | File NG-199006-NYMEX.dly has a volume of 0 at 1990-05-18. | 2022-04-25 10:16:06.377
HD Request # 72 | Receiving historical Daily data for CL-198501-NYMEX starting at 1984-12-12 | 2022-04-25 10:16:06.571
HD Request # 72 | Writing historical Daily data to the file CL-198501-NYMEX.dly | 2022-04-25 10:16:06.571
HD Request # 72 | Bytes received: 179 | 2022-04-25 10:16:06.573
HD Request # 72 | Received 4 Daily data records from 1984-12-12 00:00:00 to 1984-12-14 00:00:00 (3.0 days) and wrote 3 records for CL-198501-NYMEX | 2022-04-25 10:16:06.573
HD Request # 72 | Completion time: 9s | 2022-04-25 10:16:06.574
HD Request # 72 | Daily data download complete for CL-198501-NYMEX. Unique request ID: 23 | 2022-04-25 10:16:06.574
Removing historical data download ID 23. | 2022-04-25 10:16:06.574
Triggering next historical data download in queue. | 2022-04-25 10:16:06.574
Historical data download thread signaled to stop. | 2022-04-25 10:16:06.574
HD Request # 75 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:02.848000 | 2022-04-25 10:16:06.574
HD Request # 75 | Received 1003 Intraday data records from 2022-04-25 10:13:01.327000 to 2022-04-25 10:15:59.315000 (3.0 minutes) and wrote 1001 records for TSLA-NQTV | 2022-04-25 10:16:06.574
HD Request # 75 | Completion time: 3s | 2022-04-25 10:16:06.574
HD Request # 75 | Intraday data download complete for TSLA-NQTV. Unique request ID: 203 | 2022-04-25 10:16:06.574
Removing historical data download ID 203. | 2022-04-25 10:16:06.574
Real-time Intraday chart data file updates started for TSLA-NQTV | 2022-04-25 10:16:06.574
Intraday chart data file opened for TSLA-NQTV | 2022-04-25 10:16:06.574
HD Request # 75 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:16:06.574
Mapping CL-202206-NYMEX to CLM22. Service code: nymex | 2022-04-25 10:16:06.578
HD Request # 76 | Downloading Historical Daily chart data for CL-202206-NYMEX. Starting date: 2022-04-20. Service: interactive_brokers.trading | 2022-04-25 10:16:06.580
HD Request # 77 | Downloading Intraday chart data for TMST-NQTV to the file TMST-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:16:06.580
HD Request # 77 | Download start date-time: 2022-04-25 10:12:25.000000. File last date-time: 2022-04-25 10:12:25.061000 | 2022-04-25 10:16:06.580
HD Request # 77 | Using server: ds25.sierracharts.com port 10150 | 2022-04-25 10:16:06.580
Socket (4) | Creating socket. | 2022-04-25 10:16:06.580
Socket (4) | New receive buffer size: 5242880 | 2022-04-25 10:16:06.581
Socket (4) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:16:06.581
SC Data - All Services | Starting real-time market data updates for: NG-202206-NYMEX (NGM22). ID: 110 Service code: nymex | 2022-04-25 10:16:06.763
SC Data - All Services | Requesting security definition data for: NG-202206-NYMEX (NGM22). ID: 110 | 2022-04-25 10:16:06.763
HD Request # 77 | Setting DTC encoding to Binary VLS | 2022-04-25 10:16:07.037
HD Request # 77 | Sending historical data logon request message. | 2022-04-25 10:16:07.037
SC Data - All Services | Received security definition for symbol NG-202206-NYMEX | 2022-04-25 10:16:07.083
HD Request # 77 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:25. Record interval: 0. Symbol: TMST-NQTV | 2022-04-25 10:16:07.264
HD Request # 77 | Decompressing data. | 2022-04-25 10:16:07.491
HD Request # 77 | Receiving Intraday data for TMST-NQTV starting at 2022-04-25 10:12:25.061000 | 2022-04-25 10:16:07.492
Socket (4) | CloseSocket call. | 2022-04-25 10:16:07.492
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:16:07.492
Historical data download thread signaled to stop. | 2022-04-25 10:16:07.492
HD Request # 77 | Timestamp of first Intraday data file record written: 2022-04-25 10:14:04.842000 | 2022-04-25 10:16:07.492
HD Request # 77 | Received 2 Intraday data records from 2022-04-25 10:12:25.061000 to 2022-04-25 10:14:04.842000 (99.8 seconds) and wrote 1 record for TMST-NQTV | 2022-04-25 10:16:07.492
HD Request # 77 | Completion time: 1s | 2022-04-25 10:16:07.492
HD Request # 77 | Intraday data download complete for TMST-NQTV. Unique request ID: 206 | 2022-04-25 10:16:07.492
Removing historical data download ID 206. | 2022-04-25 10:16:07.492
Real-time Intraday chart data file updates started for TMST-NQTV | 2022-04-25 10:16:07.492
Intraday chart data file opened for TMST-NQTV | 2022-04-25 10:16:07.492
HD Request # 77 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:16:07.492
Triggering next historical data download in queue. | 2022-04-25 10:16:07.492
HD Request # 78 | Downloading Intraday chart data for TNET-NQTV to the file TNET-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:16:07.492
HD Request # 78 | Download start date-time: 2022-04-25 10:09:59.000000. File last date-time: 2022-04-25 10:09:59.786001 | 2022-04-25 10:16:07.493
HD Request # 78 | Using server: ds25.sierracharts.com port 10149 | 2022-04-25 10:16:07.493
Socket (2) | Creating socket. | 2022-04-25 10:16:07.493
Socket (2) | New receive buffer size: 5242880 | 2022-04-25 10:16:07.493
Socket (2) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:16:07.493
Socket (4) | Socket gracefully closed by remote side. | 2022-04-25 10:16:07.717
Socket (4) | Closed. | 2022-04-25 10:16:07.717
HD Request # 78 | Setting DTC encoding to Binary VLS | 2022-04-25 10:16:07.955
HD Request # 78 | Sending historical data logon request message. | 2022-04-25 10:16:07.955
HD Request # 76 | Requesting historical Daily data for CLM22 starting at 2022-04-19. SC External HD service. | 2022-04-25 10:16:07.988
HD Request # 78 | Requesting Intraday data. Start date-time: 2022-04-25 10:09:59. Record interval: 0. Symbol: TNET-NQTV | 2022-04-25 10:16:08.184
HD Request # 78 | Decompressing data. | 2022-04-25 10:16:08.411
HD Request # 78 | Receiving Intraday data for TNET-NQTV starting at 2022-04-25 10:09:59.786000 | 2022-04-25 10:16:08.412
Socket (2) | CloseSocket call. | 2022-04-25 10:16:08.412
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:16:08.412
Historical data download thread signaled to stop. | 2022-04-25 10:16:08.412
HD Request # 78 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:30.770000 | 2022-04-25 10:16:08.412
HD Request # 78 | Received 21 Intraday data records from 2022-04-25 10:09:59.786000 to 2022-04-25 10:15:57.566006 (6.0 minutes) and wrote 19 records for TNET-NQTV | 2022-04-25 10:16:08.412
HD Request # 78 | Completion time: 1s | 2022-04-25 10:16:08.412
HD Request # 78 | Intraday data download complete for TNET-NQTV. Unique request ID: 208 | 2022-04-25 10:16:08.412
Removing historical data download ID 208. | 2022-04-25 10:16:08.412
Real-time Intraday chart data file updates started for TNET-NQTV | 2022-04-25 10:16:08.412
Intraday chart data file opened for TNET-NQTV | 2022-04-25 10:16:08.412
HD Request # 78 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:16:08.412
Triggering next historical data download in queue. | 2022-04-25 10:16:08.412
HD Request # 79 | Downloading Intraday chart data for VIRT-NQTV to the file VIRT-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:16:08.412
HD Request # 79 | Download start date-time: 2022-04-25 10:12:25.000000. File last date-time: 2022-04-25 10:12:25.910000 | 2022-04-25 10:16:08.413
HD Request # 79 | Using server: ds25.sierracharts.com port 10150 | 2022-04-25 10:16:08.413
Socket (11) | Creating socket. | 2022-04-25 10:16:08.413
Socket (11) | New receive buffer size: 5242880 | 2022-04-25 10:16:08.413
Socket (11) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:16:08.413
Socket (2) | Socket gracefully closed by remote side. | 2022-04-25 10:16:08.639
Socket (2) | Closed. | 2022-04-25 10:16:08.639
HD Request # 76 | Receiving historical Daily data for CL-202206-NYMEX starting at 2022-04-20 | 2022-04-25 10:16:08.745
HD Request # 76 | Writing historical Daily data to the file CL-202206-NYMEX.dly | 2022-04-25 10:16:08.745
HD Request # 76 | Bytes received: 234 | 2022-04-25 10:16:08.763
HD Request # 76 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for CL-202206-NYMEX | 2022-04-25 10:16:08.763
HD Request # 76 | Completion time: 2s | 2022-04-25 10:16:08.764
HD Request # 76 | Daily data download complete for CL-202206-NYMEX. Unique request ID: 24 | 2022-04-25 10:16:08.764
Removing historical data download ID 24. | 2022-04-25 10:16:08.764
Triggering next historical data download in queue. | 2022-04-25 10:16:08.764
Mapping BRR-201805-CMECRYPTO-USD-5 to BTCK18. Service code: cme | 2022-04-25 10:16:08.764
HD Request # 80 | Downloading Historical Daily chart data for BRR-201805-CMECRYPTO-USD-5. Starting date: 2018-05-23. Service: interactive_brokers.trading | 2022-04-25 10:16:08.766
CL-202206-NYMEX [C] 16 Day #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:16:08.789
CL-202206-NYMEX [C] 16 Day #10 | Reloading chart. | 2022-04-25 10:16:08.790
CL-202206-NYMEX [C] 2 Day #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:16:08.843
CL-202206-NYMEX [C] 2 Day #3 | Reloading chart. | 2022-04-25 10:16:08.844
HD Request # 79 | Setting DTC encoding to Binary VLS | 2022-04-25 10:16:08.872
HD Request # 79 | Sending historical data logon request message. | 2022-04-25 10:16:08.872
CL-202206-NYMEX [C] 2 Day #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:16:08.915
CL-202206-NYMEX [C] 2 Day #6 | Reloading chart. | 2022-04-25 10:16:08.916
Opened cached Intraday file: C:\SierraChart\Data\GNK-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:16:09.095
Opened cached Intraday file: C:\SierraChart\Data\TSLA-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:16:09.096
HD Request # 79 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:25. Record interval: 0. Symbol: VIRT-NQTV | 2022-04-25 10:16:09.102
CL-202206-NYMEX [C] 16 Day #10 | Reloading chart. | 2022-04-25 10:16:09.164
CL-202206-NYMEX [C] 16 Day #10 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:16:09.164
CL-202206-NYMEX [C] 16 Day #10 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:16:09.164
HD Request # 79 | Decompressing data. | 2022-04-25 10:16:09.330
HD Request # 79 | Receiving Intraday data for VIRT-NQTV starting at 2022-04-25 10:12:25.909000 | 2022-04-25 10:16:09.330
Socket (11) | CloseSocket call. | 2022-04-25 10:16:09.331
Socket (11) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:16:09.331
Socket (11) | Socket gracefully closed by remote side. | 2022-04-25 10:16:09.569
Socket (11) | Closed. | 2022-04-25 10:16:09.569
CL-202206-NYMEX [C] 16 Day #10 | File CL-200102-NYMEX.dly has a volume of 0 at 2000-12-18. | 2022-04-25 10:16:11.257
CL-202206-NYMEX [C] 16 Day #10 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-11-17. | 2022-04-25 10:16:11.261
CL-202206-NYMEX [C] 16 Day #10 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-12-15. | 2022-04-25 10:16:11.261
CL-202206-NYMEX [C] 16 Day #10 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-10-18. | 2022-04-25 10:16:11.266
CL-202206-NYMEX [C] 16 Day #10 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-11-16. | 2022-04-25 10:16:11.266
CL-202206-NYMEX [C] 16 Day #10 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-09-18. | 2022-04-25 10:16:11.271
CL-202206-NYMEX [C] 16 Day #10 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-10-17. | 2022-04-25 10:16:11.271
CL-202206-NYMEX [C] 16 Day #10 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-08-18. | 2022-04-25 10:16:11.276
CL-202206-NYMEX [C] 16 Day #10 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-09-15. | 2022-04-25 10:16:11.276
CL-202206-NYMEX [C] 16 Day #10 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-07-18. | 2022-04-25 10:16:11.282
CL-202206-NYMEX [C] 16 Day #10 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-08-17. | 2022-04-25 10:16:11.282
CL-202206-NYMEX [C] 16 Day #10 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-06-16. | 2022-04-25 10:16:11.287
CL-202206-NYMEX [C] 16 Day #10 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-07-17. | 2022-04-25 10:16:11.287
CL-202206-NYMEX [C] 16 Day #10 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-05-18. | 2022-04-25 10:16:11.292
CL-202206-NYMEX [C] 16 Day #10 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-06-15. | 2022-04-25 10:16:11.292
CL-202206-NYMEX [C] 16 Day #10 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-04-18. | 2022-04-25 10:16:11.297
CL-202206-NYMEX [C] 16 Day #10 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-05-17. | 2022-04-25 10:16:11.297
CL-202206-NYMEX [C] 16 Day #10 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-03-17. | 2022-04-25 10:16:11.302
CL-202206-NYMEX [C] 16 Day #10 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-04-17. | 2022-04-25 10:16:11.302
CL-202206-NYMEX [C] 16 Day #10 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-02-18. | 2022-04-25 10:16:11.307
CL-202206-NYMEX [C] 16 Day #10 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-03-16. | 2022-04-25 10:16:11.307
CL-202206-NYMEX [C] 16 Day #10 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-01-18. | 2022-04-25 10:16:11.312
CL-202206-NYMEX [C] 16 Day #10 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-02-17. | 2022-04-25 10:16:11.312
CL-202206-NYMEX [C] 16 Day #10 | File CL-200002-NYMEX.dly has a volume of 0 at 1999-12-17. | 2022-04-25 10:16:11.317
CL-202206-NYMEX [C] 16 Day #10 | File CL-200002-NYMEX.dly has a volume of 0 at 2000-01-17. | 2022-04-25 10:16:11.317
CL-202206-NYMEX [C] 16 Day #10 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-11-18. | 2022-04-25 10:16:11.322
CL-202206-NYMEX [C] 16 Day #10 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-12-16. | 2022-04-25 10:16:11.322
CL-202206-NYMEX [C] 16 Day #10 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-10-18. | 2022-04-25 10:16:11.327
CL-202206-NYMEX [C] 16 Day #10 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-11-17. | 2022-04-25 10:16:11.327
CL-202206-NYMEX [C] 16 Day #10 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-09-17. | 2022-04-25 10:16:11.333
CL-202206-NYMEX [C] 16 Day #10 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-10-15. | 2022-04-25 10:16:11.333
CL-202206-NYMEX [C] 16 Day #10 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-08-18. | 2022-04-25 10:16:11.338
CL-202206-NYMEX [C] 16 Day #10 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-09-16. | 2022-04-25 10:16:11.338
CL-202206-NYMEX [C] 16 Day #10 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-07-16. | 2022-04-25 10:16:11.343
CL-202206-NYMEX [C] 16 Day #10 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-08-17. | 2022-04-25 10:16:11.343
CL-202206-NYMEX [C] 16 Day #10 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-06-18. | 2022-04-25 10:16:11.348
CL-202206-NYMEX [C] 16 Day #10 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-07-15. | 2022-04-25 10:16:11.348
CL-202206-NYMEX [C] 16 Day #10 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-05-18. | 2022-04-25 10:16:11.353
CL-202206-NYMEX [C] 16 Day #10 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-06-17. | 2022-04-25 10:16:11.353
CL-202206-NYMEX [C] 16 Day #10 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-04-16. | 2022-04-25 10:16:11.359
CL-202206-NYMEX [C] 16 Day #10 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-05-17. | 2022-04-25 10:16:11.359
CL-202206-NYMEX [C] 16 Day #10 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-03-18. | 2022-04-25 10:16:11.364
CL-202206-NYMEX [C] 16 Day #10 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-04-15. | 2022-04-25 10:16:11.364
CL-202206-NYMEX [C] 16 Day #10 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-02-18. | 2022-04-25 10:16:11.368
CL-202206-NYMEX [C] 16 Day #10 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-03-17. | 2022-04-25 10:16:11.368
CL-202206-NYMEX [C] 16 Day #10 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-01-18. | 2022-04-25 10:16:11.374
CL-202206-NYMEX [C] 16 Day #10 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-02-17. | 2022-04-25 10:16:11.374
CL-202206-NYMEX [C] 16 Day #10 | File CL-199902-NYMEX.dly has a volume of 0 at 1998-12-18. | 2022-04-25 10:16:11.378
CL-202206-NYMEX [C] 16 Day #10 | File CL-199902-NYMEX.dly has a volume of 0 at 1999-01-15. | 2022-04-25 10:16:11.378
CL-202206-NYMEX [C] 16 Day #10 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-11-18. | 2022-04-25 10:16:11.383
CL-202206-NYMEX [C] 16 Day #10 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-12-17. | 2022-04-25 10:16:11.383
CL-202206-NYMEX [C] 16 Day #10 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-10-16. | 2022-04-25 10:16:11.389
CL-202206-NYMEX [C] 16 Day #10 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-11-17. | 2022-04-25 10:16:11.389
CL-202206-NYMEX [C] 16 Day #10 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-09-18. | 2022-04-25 10:16:11.394
CL-202206-NYMEX [C] 16 Day #10 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-10-15. | 2022-04-25 10:16:11.394
CL-202206-NYMEX [C] 16 Day #10 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-08-18. | 2022-04-25 10:16:11.399
CL-202206-NYMEX [C] 16 Day #10 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-09-17. | 2022-04-25 10:16:11.399
CL-202206-NYMEX [C] 16 Day #10 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-07-17. | 2022-04-25 10:16:11.404
CL-202206-NYMEX [C] 16 Day #10 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-08-17. | 2022-04-25 10:16:11.404
CL-202206-NYMEX [C] 16 Day #10 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-06-18. | 2022-04-25 10:16:11.409
CL-202206-NYMEX [C] 16 Day #10 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-07-16. | 2022-04-25 10:16:11.409
CL-202206-NYMEX [C] 16 Day #10 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-05-18. | 2022-04-25 10:16:11.414
CL-202206-NYMEX [C] 16 Day #10 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-06-17. | 2022-04-25 10:16:11.414
CL-202206-NYMEX [C] 16 Day #10 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-04-17. | 2022-04-25 10:16:11.419
CL-202206-NYMEX [C] 16 Day #10 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-05-15. | 2022-04-25 10:16:11.419
CL-202206-NYMEX [C] 16 Day #10 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-03-18. | 2022-04-25 10:16:11.424
CL-202206-NYMEX [C] 16 Day #10 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-04-16. | 2022-04-25 10:16:11.424
CL-202206-NYMEX [C] 16 Day #10 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-02-18. | 2022-04-25 10:16:11.429
CL-202206-NYMEX [C] 16 Day #10 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-03-17. | 2022-04-25 10:16:11.429
CL-202206-NYMEX [C] 16 Day #10 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-01-16. | 2022-04-25 10:16:11.435
CL-202206-NYMEX [C] 16 Day #10 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-02-17. | 2022-04-25 10:16:11.435
CL-202206-NYMEX [C] 16 Day #10 | File CL-199802-NYMEX.dly has a volume of 0 at 1997-12-18. | 2022-04-25 10:16:11.439
CL-202206-NYMEX [C] 16 Day #10 | File CL-199802-NYMEX.dly has a volume of 0 at 1998-01-15. | 2022-04-25 10:16:11.439
CL-202206-NYMEX [C] 16 Day #10 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-11-18. | 2022-04-25 10:16:11.444
CL-202206-NYMEX [C] 16 Day #10 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-12-17. | 2022-04-25 10:16:11.444
CL-202206-NYMEX [C] 16 Day #10 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-10-17. | 2022-04-25 10:16:11.449
CL-202206-NYMEX [C] 16 Day #10 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-11-17. | 2022-04-25 10:16:11.449
CL-202206-NYMEX [C] 16 Day #10 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-09-18. | 2022-04-25 10:16:11.455
CL-202206-NYMEX [C] 16 Day #10 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-10-16. | 2022-04-25 10:16:11.455
CL-202206-NYMEX [C] 16 Day #10 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-08-18. | 2022-04-25 10:16:11.460
CL-202206-NYMEX [C] 16 Day #10 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-09-17. | 2022-04-25 10:16:11.460
CL-202206-NYMEX [C] 16 Day #10 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-07-18. | 2022-04-25 10:16:11.465
CL-202206-NYMEX [C] 16 Day #10 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-08-15. | 2022-04-25 10:16:11.465
CL-202206-NYMEX [C] 16 Day #10 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-06-18. | 2022-04-25 10:16:11.470
CL-202206-NYMEX [C] 16 Day #10 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-07-17. | 2022-04-25 10:16:11.470
CL-202206-NYMEX [C] 16 Day #10 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-05-16. | 2022-04-25 10:16:11.475
CL-202206-NYMEX [C] 16 Day #10 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-06-17. | 2022-04-25 10:16:11.475
CL-202206-NYMEX [C] 16 Day #10 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-04-18. | 2022-04-25 10:16:11.480
CL-202206-NYMEX [C] 16 Day #10 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-05-15. | 2022-04-25 10:16:11.480
CL-202206-NYMEX [C] 16 Day #10 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-03-18. | 2022-04-25 10:16:11.486
CL-202206-NYMEX [C] 16 Day #10 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-04-17. | 2022-04-25 10:16:11.486
CL-202206-NYMEX [C] 16 Day #10 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-02-18. | 2022-04-25 10:16:11.491
CL-202206-NYMEX [C] 16 Day #10 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-03-17. | 2022-04-25 10:16:11.491
CL-202206-NYMEX [C] 16 Day #10 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-01-17. | 2022-04-25 10:16:11.496
CL-202206-NYMEX [C] 16 Day #10 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-02-17. | 2022-04-25 10:16:11.496
CL-202206-NYMEX [C] 16 Day #10 | File CL-199702-NYMEX.dly has a volume of 0 at 1996-12-18. | 2022-04-25 10:16:11.501
CL-202206-NYMEX [C] 16 Day #10 | File CL-199702-NYMEX.dly has a volume of 0 at 1997-01-16. | 2022-04-25 10:16:11.501
CL-202206-NYMEX [C] 16 Day #10 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-11-18. | 2022-04-25 10:16:11.505
CL-202206-NYMEX [C] 16 Day #10 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-12-17. | 2022-04-25 10:16:11.505
CL-202206-NYMEX [C] 16 Day #10 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-10-18. | 2022-04-25 10:16:11.510
CL-202206-NYMEX [C] 16 Day #10 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-11-15. | 2022-04-25 10:16:11.511
CL-202206-NYMEX [C] 16 Day #10 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-09-18. | 2022-04-25 10:16:11.516
CL-202206-NYMEX [C] 16 Day #10 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-10-17. | 2022-04-25 10:16:11.516
CL-202206-NYMEX [C] 16 Day #10 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-08-16. | 2022-04-25 10:16:11.521
CL-202206-NYMEX [C] 16 Day #10 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-09-17. | 2022-04-25 10:16:11.521
CL-202206-NYMEX [C] 16 Day #10 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-07-18. | 2022-04-25 10:16:11.526
CL-202206-NYMEX [C] 16 Day #10 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-08-15. | 2022-04-25 10:16:11.526
CL-202206-NYMEX [C] 16 Day #10 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-06-18. | 2022-04-25 10:16:11.531
CL-202206-NYMEX [C] 16 Day #10 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-07-17. | 2022-04-25 10:16:11.531
CL-202206-NYMEX [C] 16 Day #10 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-05-17. | 2022-04-25 10:16:11.536
CL-202206-NYMEX [C] 16 Day #10 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-06-17. | 2022-04-25 10:16:11.536
CL-202206-NYMEX [C] 16 Day #10 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-04-18. | 2022-04-25 10:16:11.542
CL-202206-NYMEX [C] 16 Day #10 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-05-16. | 2022-04-25 10:16:11.542
CL-202206-NYMEX [C] 16 Day #10 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-03-18. | 2022-04-25 10:16:11.547
CL-202206-NYMEX [C] 16 Day #10 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-04-17. | 2022-04-25 10:16:11.547
CL-202206-NYMEX [C] 16 Day #10 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-02-16. | 2022-04-25 10:16:11.552
CL-202206-NYMEX [C] 16 Day #10 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-03-15. | 2022-04-25 10:16:11.552
CL-202206-NYMEX [C] 16 Day #10 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-01-18. | 2022-04-25 10:16:11.557
CL-202206-NYMEX [C] 16 Day #10 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-02-15. | 2022-04-25 10:16:11.557
CL-202206-NYMEX [C] 16 Day #10 | File CL-199602-NYMEX.dly has a volume of 0 at 1995-12-18. | 2022-04-25 10:16:11.562
CL-202206-NYMEX [C] 16 Day #10 | File CL-199602-NYMEX.dly has a volume of 0 at 1996-01-17. | 2022-04-25 10:16:11.562
CL-202206-NYMEX [C] 16 Day #10 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-11-17. | 2022-04-25 10:16:11.567
CL-202206-NYMEX [C] 16 Day #10 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-12-15. | 2022-04-25 10:16:11.567
CL-202206-NYMEX [C] 16 Day #10 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-10-18. | 2022-04-25 10:16:11.572
CL-202206-NYMEX [C] 16 Day #10 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-11-16. | 2022-04-25 10:16:11.572
CL-202206-NYMEX [C] 16 Day #10 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-09-18. | 2022-04-25 10:16:11.577
CL-202206-NYMEX [C] 16 Day #10 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-10-17. | 2022-04-25 10:16:11.577
CL-202206-NYMEX [C] 16 Day #10 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-08-18. | 2022-04-25 10:16:11.582
CL-202206-NYMEX [C] 16 Day #10 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-09-15. | 2022-04-25 10:16:11.582
CL-202206-NYMEX [C] 16 Day #10 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-07-18. | 2022-04-25 10:16:11.588
CL-202206-NYMEX [C] 16 Day #10 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-08-17. | 2022-04-25 10:16:11.588
CL-202206-NYMEX [C] 16 Day #10 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-06-16. | 2022-04-25 10:16:11.593
CL-202206-NYMEX [C] 16 Day #10 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-07-17. | 2022-04-25 10:16:11.593
CL-202206-NYMEX [C] 16 Day #10 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-05-18. | 2022-04-25 10:16:11.598
CL-202206-NYMEX [C] 16 Day #10 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-06-15. | 2022-04-25 10:16:11.598
CL-202206-NYMEX [C] 16 Day #10 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-04-18. | 2022-04-25 10:16:11.603
CL-202206-NYMEX [C] 16 Day #10 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-05-17. | 2022-04-25 10:16:11.603
CL-202206-NYMEX [C] 16 Day #10 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-03-17. | 2022-04-25 10:16:11.608
CL-202206-NYMEX [C] 16 Day #10 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-04-17. | 2022-04-25 10:16:11.608
CL-202206-NYMEX [C] 16 Day #10 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-02-17. | 2022-04-25 10:16:11.613
CL-202206-NYMEX [C] 16 Day #10 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-03-16. | 2022-04-25 10:16:11.613
CL-202206-NYMEX [C] 16 Day #10 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-01-18. | 2022-04-25 10:16:11.618
CL-202206-NYMEX [C] 16 Day #10 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-02-16. | 2022-04-25 10:16:11.618
CL-202206-NYMEX [C] 16 Day #10 | File CL-199502-NYMEX.dly has a volume of 0 at 1994-12-16. | 2022-04-25 10:16:11.623
CL-202206-NYMEX [C] 16 Day #10 | File CL-199502-NYMEX.dly has a volume of 0 at 1995-01-17. | 2022-04-25 10:16:11.623
CL-202206-NYMEX [C] 16 Day #10 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-11-18. | 2022-04-25 10:16:11.628
CL-202206-NYMEX [C] 16 Day #10 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-12-15. | 2022-04-25 10:16:11.628
CL-202206-NYMEX [C] 16 Day #10 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-10-18. | 2022-04-25 10:16:11.633
CL-202206-NYMEX [C] 16 Day #10 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-11-17. | 2022-04-25 10:16:11.633
CL-202206-NYMEX [C] 16 Day #10 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-09-16. | 2022-04-25 10:16:11.638
CL-202206-NYMEX [C] 16 Day #10 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-10-17. | 2022-04-25 10:16:11.638
CL-202206-NYMEX [C] 16 Day #10 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-08-18. | 2022-04-25 10:16:11.643
CL-202206-NYMEX [C] 16 Day #10 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-09-15. | 2022-04-25 10:16:11.643
CL-202206-NYMEX [C] 16 Day #10 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-07-18. | 2022-04-25 10:16:11.649
CL-202206-NYMEX [C] 16 Day #10 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-08-17. | 2022-04-25 10:16:11.649
CL-202206-NYMEX [C] 16 Day #10 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-06-17. | 2022-04-25 10:16:11.654
CL-202206-NYMEX [C] 16 Day #10 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-07-15. | 2022-04-25 10:16:11.654
CL-202206-NYMEX [C] 16 Day #10 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-05-18. | 2022-04-25 10:16:11.659
CL-202206-NYMEX [C] 16 Day #10 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-06-16. | 2022-04-25 10:16:11.659
CL-202206-NYMEX [C] 16 Day #10 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-04-18. | 2022-04-25 10:16:11.664
CL-202206-NYMEX [C] 16 Day #10 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-05-17. | 2022-04-25 10:16:11.664
CL-202206-NYMEX [C] 16 Day #10 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-03-18. | 2022-04-25 10:16:11.669
CL-202206-NYMEX [C] 16 Day #10 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-04-15. | 2022-04-25 10:16:11.669
CL-202206-NYMEX [C] 16 Day #10 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-02-18. | 2022-04-25 10:16:11.674
CL-202206-NYMEX [C] 16 Day #10 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-03-17. | 2022-04-25 10:16:11.674
CL-202206-NYMEX [C] 16 Day #10 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-01-18. | 2022-04-25 10:16:11.679
CL-202206-NYMEX [C] 16 Day #10 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-02-17. | 2022-04-25 10:16:11.679
CL-202206-NYMEX [C] 16 Day #10 | File CL-199402-NYMEX.dly has a volume of 0 at 1993-12-17. | 2022-04-25 10:16:11.684
CL-202206-NYMEX [C] 16 Day #10 | File CL-199402-NYMEX.dly has a volume of 0 at 1994-01-17. | 2022-04-25 10:16:11.684
CL-202206-NYMEX [C] 16 Day #10 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-11-18. | 2022-04-25 10:16:11.689
CL-202206-NYMEX [C] 16 Day #10 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-12-16. | 2022-04-25 10:16:11.689
CL-202206-NYMEX [C] 16 Day #10 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-10-18. | 2022-04-25 10:16:11.694
CL-202206-NYMEX [C] 16 Day #10 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-11-17. | 2022-04-25 10:16:11.694
CL-202206-NYMEX [C] 16 Day #10 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-09-17. | 2022-04-25 10:16:11.700
CL-202206-NYMEX [C] 16 Day #10 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-10-15. | 2022-04-25 10:16:11.700
CL-202206-NYMEX [C] 16 Day #10 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-08-18. | 2022-04-25 10:16:11.705
CL-202206-NYMEX [C] 16 Day #10 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-09-16. | 2022-04-25 10:16:11.705
CL-202206-NYMEX [C] 16 Day #10 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-07-16. | 2022-04-25 10:16:11.710
CL-202206-NYMEX [C] 16 Day #10 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-08-17. | 2022-04-25 10:16:11.710
CL-202206-NYMEX [C] 16 Day #10 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-06-18. | 2022-04-25 10:16:11.715
CL-202206-NYMEX [C] 16 Day #10 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-07-15. | 2022-04-25 10:16:11.715
CL-202206-NYMEX [C] 16 Day #10 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-05-18. | 2022-04-25 10:16:11.721
CL-202206-NYMEX [C] 16 Day #10 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-06-17. | 2022-04-25 10:16:11.721
CL-202206-NYMEX [C] 16 Day #10 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-04-16. | 2022-04-25 10:16:11.726
CL-202206-NYMEX [C] 16 Day #10 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-05-17. | 2022-04-25 10:16:11.726
CL-202206-NYMEX [C] 16 Day #10 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-03-18. | 2022-04-25 10:16:11.731
CL-202206-NYMEX [C] 16 Day #10 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-04-15. | 2022-04-25 10:16:11.731
CL-202206-NYMEX [C] 16 Day #10 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-02-18. | 2022-04-25 10:16:11.736
CL-202206-NYMEX [C] 16 Day #10 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-03-17. | 2022-04-25 10:16:11.736
CL-202206-NYMEX [C] 16 Day #10 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-01-18. | 2022-04-25 10:16:11.741
CL-202206-NYMEX [C] 16 Day #10 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-02-17. | 2022-04-25 10:16:11.741
CL-202206-NYMEX [C] 16 Day #10 | File CL-199302-NYMEX.dly has a volume of 0 at 1992-12-18. | 2022-04-25 10:16:11.746
CL-202206-NYMEX [C] 16 Day #10 | File CL-199302-NYMEX.dly has a volume of 0 at 1993-01-15. | 2022-04-25 10:16:11.746
CL-202206-NYMEX [C] 16 Day #10 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-11-18. | 2022-04-25 10:16:11.751
CL-202206-NYMEX [C] 16 Day #10 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-12-17. | 2022-04-25 10:16:11.751
CL-202206-NYMEX [C] 16 Day #10 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-10-16. | 2022-04-25 10:16:11.757
CL-202206-NYMEX [C] 16 Day #10 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-11-17. | 2022-04-25 10:16:11.757
CL-202206-NYMEX [C] 16 Day #10 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-09-18. | 2022-04-25 10:16:11.762
CL-202206-NYMEX [C] 16 Day #10 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-10-15. | 2022-04-25 10:16:11.762
CL-202206-NYMEX [C] 16 Day #10 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-08-18. | 2022-04-25 10:16:11.767
CL-202206-NYMEX [C] 16 Day #10 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-09-17. | 2022-04-25 10:16:11.767
CL-202206-NYMEX [C] 16 Day #10 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-07-17. | 2022-04-25 10:16:11.773
CL-202206-NYMEX [C] 16 Day #10 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-08-17. | 2022-04-25 10:16:11.773
CL-202206-NYMEX [C] 16 Day #10 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-06-18. | 2022-04-25 10:16:11.778
CL-202206-NYMEX [C] 16 Day #10 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-07-16. | 2022-04-25 10:16:11.778
CL-202206-NYMEX [C] 16 Day #10 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-05-18. | 2022-04-25 10:16:11.783
CL-202206-NYMEX [C] 16 Day #10 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-06-17. | 2022-04-25 10:16:11.783
CL-202206-NYMEX [C] 16 Day #10 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-04-17. | 2022-04-25 10:16:11.788
CL-202206-NYMEX [C] 16 Day #10 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-05-15. | 2022-04-25 10:16:11.788
CL-202206-NYMEX [C] 16 Day #10 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-03-18. | 2022-04-25 10:16:11.793
CL-202206-NYMEX [C] 16 Day #10 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-04-16. | 2022-04-25 10:16:11.793
CL-202206-NYMEX [C] 16 Day #10 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-02-18. | 2022-04-25 10:16:11.799
CL-202206-NYMEX [C] 16 Day #10 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-03-17. | 2022-04-25 10:16:11.799
CL-202206-NYMEX [C] 16 Day #10 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-01-17. | 2022-04-25 10:16:11.804
CL-202206-NYMEX [C] 16 Day #10 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-02-17. | 2022-04-25 10:16:11.804
CL-202206-NYMEX [C] 16 Day #10 | File CL-199202-NYMEX.dly has a volume of 0 at 1991-12-18. | 2022-04-25 10:16:11.809
CL-202206-NYMEX [C] 16 Day #10 | File CL-199202-NYMEX.dly has a volume of 0 at 1992-01-16. | 2022-04-25 10:16:11.809
CL-202206-NYMEX [C] 16 Day #10 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-11-18. | 2022-04-25 10:16:11.814
CL-202206-NYMEX [C] 16 Day #10 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-12-17. | 2022-04-25 10:16:11.814
CL-202206-NYMEX [C] 16 Day #10 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-10-18. | 2022-04-25 10:16:11.819
CL-202206-NYMEX [C] 16 Day #10 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-11-15. | 2022-04-25 10:16:11.819
CL-202206-NYMEX [C] 16 Day #10 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-09-18. | 2022-04-25 10:16:11.825
CL-202206-NYMEX [C] 16 Day #10 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-10-17. | 2022-04-25 10:16:11.825
CL-202206-NYMEX [C] 16 Day #10 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-08-16. | 2022-04-25 10:16:11.830
CL-202206-NYMEX [C] 16 Day #10 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-09-17. | 2022-04-25 10:16:11.830
CL-202206-NYMEX [C] 16 Day #10 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-07-18. | 2022-04-25 10:16:11.835
CL-202206-NYMEX [C] 16 Day #10 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-08-15. | 2022-04-25 10:16:11.835
CL-202206-NYMEX [C] 16 Day #10 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-06-18. | 2022-04-25 10:16:11.840
CL-202206-NYMEX [C] 16 Day #10 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-07-17. | 2022-04-25 10:16:11.840
CL-202206-NYMEX [C] 16 Day #10 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-05-17. | 2022-04-25 10:16:11.845
CL-202206-NYMEX [C] 16 Day #10 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-06-17. | 2022-04-25 10:16:11.845
CL-202206-NYMEX [C] 16 Day #10 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-04-18. | 2022-04-25 10:16:11.850
CL-202206-NYMEX [C] 16 Day #10 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-05-16. | 2022-04-25 10:16:11.850
CL-202206-NYMEX [C] 16 Day #10 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-03-18. | 2022-04-25 10:16:11.856
CL-202206-NYMEX [C] 16 Day #10 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-04-17. | 2022-04-25 10:16:11.856
CL-202206-NYMEX [C] 16 Day #10 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-02-18. | 2022-04-25 10:16:11.861
CL-202206-NYMEX [C] 16 Day #10 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-03-15. | 2022-04-25 10:16:11.861
CL-202206-NYMEX [C] 16 Day #10 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-01-18. | 2022-04-25 10:16:11.866
CL-202206-NYMEX [C] 16 Day #10 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-02-15. | 2022-04-25 10:16:11.866
CL-202206-NYMEX [C] 16 Day #10 | File CL-199102-NYMEX.dly has a volume of 0 at 1990-12-18. | 2022-04-25 10:16:11.871
CL-202206-NYMEX [C] 16 Day #10 | File CL-199102-NYMEX.dly has a volume of 0 at 1991-01-17. | 2022-04-25 10:16:11.871
CL-202206-NYMEX [C] 16 Day #10 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-11-16. | 2022-04-25 10:16:11.876
CL-202206-NYMEX [C] 16 Day #10 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-12-17. | 2022-04-25 10:16:11.876
CL-202206-NYMEX [C] 16 Day #10 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-10-18. | 2022-04-25 10:16:11.881
CL-202206-NYMEX [C] 16 Day #10 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-11-15. | 2022-04-25 10:16:11.881
CL-202206-NYMEX [C] 16 Day #10 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-09-18. | 2022-04-25 10:16:11.886
CL-202206-NYMEX [C] 16 Day #10 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-10-17. | 2022-04-25 10:16:11.886
CL-202206-NYMEX [C] 16 Day #10 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-08-17. | 2022-04-25 10:16:11.891
CL-202206-NYMEX [C] 16 Day #10 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-09-17. | 2022-04-25 10:16:11.891
CL-202206-NYMEX [C] 16 Day #10 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-07-18. | 2022-04-25 10:16:11.896
CL-202206-NYMEX [C] 16 Day #10 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-08-16. | 2022-04-25 10:16:11.896
CL-202206-NYMEX [C] 16 Day #10 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-06-18. | 2022-04-25 10:16:11.902
CL-202206-NYMEX [C] 16 Day #10 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-07-17. | 2022-04-25 10:16:11.902
CL-202206-NYMEX [C] 16 Day #10 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-05-18. | 2022-04-25 10:16:11.907
CL-202206-NYMEX [C] 16 Day #10 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-06-15. | 2022-04-25 10:16:11.907
CL-202206-NYMEX [C] 16 Day #10 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-04-18. | 2022-04-25 10:16:11.912
CL-202206-NYMEX [C] 16 Day #10 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-05-17. | 2022-04-25 10:16:11.912
CL-202206-NYMEX [C] 16 Day #10 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-03-16. | 2022-04-25 10:16:11.917
CL-202206-NYMEX [C] 16 Day #10 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-04-17. | 2022-04-25 10:16:11.917
CL-202206-NYMEX [C] 16 Day #10 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-02-16. | 2022-04-25 10:16:11.922
CL-202206-NYMEX [C] 16 Day #10 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-03-15. | 2022-04-25 10:16:11.922
CL-202206-NYMEX [C] 16 Day #10 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-01-18. | 2022-04-25 10:16:11.927
CL-202206-NYMEX [C] 16 Day #10 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-02-15. | 2022-04-25 10:16:11.927
CL-202206-NYMEX [C] 16 Day #10 | File CL-199002-NYMEX.dly has a volume of 0 at 1989-12-18. | 2022-04-25 10:16:11.932
CL-202206-NYMEX [C] 16 Day #10 | File CL-199002-NYMEX.dly has a volume of 0 at 1990-01-17. | 2022-04-25 10:16:11.932
CL-202206-NYMEX [C] 16 Day #10 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-11-17. | 2022-04-25 10:16:11.937
CL-202206-NYMEX [C] 16 Day #10 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-12-15. | 2022-04-25 10:16:11.937
CL-202206-NYMEX [C] 16 Day #10 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-10-18. | 2022-04-25 10:16:11.942
CL-202206-NYMEX [C] 16 Day #10 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-11-16. | 2022-04-25 10:16:11.942
CL-202206-NYMEX [C] 16 Day #10 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-09-18. | 2022-04-25 10:16:11.948
CL-202206-NYMEX [C] 16 Day #10 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-10-17. | 2022-04-25 10:16:11.948
CL-202206-NYMEX [C] 16 Day #10 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-08-18. | 2022-04-25 10:16:11.953
CL-202206-NYMEX [C] 16 Day #10 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-09-15. | 2022-04-25 10:16:11.953
CL-202206-NYMEX [C] 16 Day #10 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-07-18. | 2022-04-25 10:16:11.959
CL-202206-NYMEX [C] 16 Day #10 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-08-17. | 2022-04-25 10:16:11.959
CL-202206-NYMEX [C] 16 Day #10 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-06-16. | 2022-04-25 10:16:11.964
CL-202206-NYMEX [C] 16 Day #10 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-07-17. | 2022-04-25 10:16:11.964
CL-202206-NYMEX [C] 16 Day #10 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-05-18. | 2022-04-25 10:16:11.969
CL-202206-NYMEX [C] 16 Day #10 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-06-15. | 2022-04-25 10:16:11.969
CL-202206-NYMEX [C] 16 Day #10 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-04-18. | 2022-04-25 10:16:11.974
CL-202206-NYMEX [C] 16 Day #10 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-05-17. | 2022-04-25 10:16:11.974
CL-202206-NYMEX [C] 16 Day #10 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-03-17. | 2022-04-25 10:16:11.979
CL-202206-NYMEX [C] 16 Day #10 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-04-17. | 2022-04-25 10:16:11.979
CL-202206-NYMEX [C] 16 Day #10 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-02-17. | 2022-04-25 10:16:11.984
CL-202206-NYMEX [C] 16 Day #10 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-03-16. | 2022-04-25 10:16:11.984
CL-202206-NYMEX [C] 16 Day #10 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-01-18. | 2022-04-25 10:16:11.989
CL-202206-NYMEX [C] 16 Day #10 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-02-16. | 2022-04-25 10:16:11.989
CL-202206-NYMEX [C] 16 Day #10 | File CL-198902-NYMEX.dly has a volume of 0 at 1988-12-16. | 2022-04-25 10:16:11.994
CL-202206-NYMEX [C] 16 Day #10 | File CL-198902-NYMEX.dly has a volume of 0 at 1989-01-17. | 2022-04-25 10:16:11.994
CL-202206-NYMEX [C] 16 Day #10 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-11-18. | 2022-04-25 10:16:11.999
CL-202206-NYMEX [C] 16 Day #10 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-12-15. | 2022-04-25 10:16:11.999
CL-202206-NYMEX [C] 16 Day #10 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-10-18. | 2022-04-25 10:16:12.004
CL-202206-NYMEX [C] 16 Day #10 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-11-17. | 2022-04-25 10:16:12.004
CL-202206-NYMEX [C] 16 Day #10 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-09-16. | 2022-04-25 10:16:12.010
CL-202206-NYMEX [C] 16 Day #10 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-10-17. | 2022-04-25 10:16:12.010
CL-202206-NYMEX [C] 16 Day #10 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-08-18. | 2022-04-25 10:16:12.014
CL-202206-NYMEX [C] 16 Day #10 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-09-15. | 2022-04-25 10:16:12.014
CL-202206-NYMEX [C] 16 Day #10 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-07-18. | 2022-04-25 10:16:12.020
CL-202206-NYMEX [C] 16 Day #10 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-08-17. | 2022-04-25 10:16:12.020
CL-202206-NYMEX [C] 16 Day #10 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-06-17. | 2022-04-25 10:16:12.025
CL-202206-NYMEX [C] 16 Day #10 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-07-15. | 2022-04-25 10:16:12.025
CL-202206-NYMEX [C] 16 Day #10 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-05-18. | 2022-04-25 10:16:12.030
CL-202206-NYMEX [C] 16 Day #10 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-06-16. | 2022-04-25 10:16:12.030
CL-202206-NYMEX [C] 16 Day #10 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-04-18. | 2022-04-25 10:16:12.036
CL-202206-NYMEX [C] 16 Day #10 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-05-17. | 2022-04-25 10:16:12.036
CL-202206-NYMEX [C] 16 Day #10 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-03-18. | 2022-04-25 10:16:12.041
CL-202206-NYMEX [C] 16 Day #10 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-04-15. | 2022-04-25 10:16:12.041
CL-202206-NYMEX [C] 16 Day #10 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-02-18. | 2022-04-25 10:16:12.046
CL-202206-NYMEX [C] 16 Day #10 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-03-17. | 2022-04-25 10:16:12.046
CL-202206-NYMEX [C] 16 Day #10 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-01-18. | 2022-04-25 10:16:12.051
CL-202206-NYMEX [C] 16 Day #10 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-02-17. | 2022-04-25 10:16:12.051
CL-202206-NYMEX [C] 16 Day #10 | File CL-198802-NYMEX.dly has a volume of 0 at 1987-12-18. | 2022-04-25 10:16:12.056
CL-202206-NYMEX [C] 16 Day #10 | File CL-198802-NYMEX.dly has a volume of 0 at 1988-01-15. | 2022-04-25 10:16:12.056
CL-202206-NYMEX [C] 16 Day #10 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-11-18. | 2022-04-25 10:16:12.061
CL-202206-NYMEX [C] 16 Day #10 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-12-17. | 2022-04-25 10:16:12.061
CL-202206-NYMEX [C] 16 Day #10 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-10-16. | 2022-04-25 10:16:12.067
CL-202206-NYMEX [C] 16 Day #10 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-11-17. | 2022-04-25 10:16:12.067
CL-202206-NYMEX [C] 16 Day #10 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-09-18. | 2022-04-25 10:16:12.072
CL-202206-NYMEX [C] 16 Day #10 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-10-15. | 2022-04-25 10:16:12.072
CL-202206-NYMEX [C] 16 Day #10 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-08-18. | 2022-04-25 10:16:12.077
CL-202206-NYMEX [C] 16 Day #10 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-09-17. | 2022-04-25 10:16:12.077
CL-202206-NYMEX [C] 16 Day #10 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-07-17. | 2022-04-25 10:16:12.082
CL-202206-NYMEX [C] 16 Day #10 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-08-17. | 2022-04-25 10:16:12.082
CL-202206-NYMEX [C] 16 Day #10 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-06-18. | 2022-04-25 10:16:12.087
CL-202206-NYMEX [C] 16 Day #10 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-07-16. | 2022-04-25 10:16:12.087
CL-202206-NYMEX [C] 16 Day #10 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-05-18. | 2022-04-25 10:16:12.093
CL-202206-NYMEX [C] 16 Day #10 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-06-17. | 2022-04-25 10:16:12.093
CL-202206-NYMEX [C] 16 Day #10 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-04-17. | 2022-04-25 10:16:12.098
CL-202206-NYMEX [C] 16 Day #10 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-05-15. | 2022-04-25 10:16:12.098
CL-202206-NYMEX [C] 16 Day #10 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-03-18. | 2022-04-25 10:16:12.103
CL-202206-NYMEX [C] 16 Day #10 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-04-16. | 2022-04-25 10:16:12.103
CL-202206-NYMEX [C] 16 Day #10 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-02-18. | 2022-04-25 10:16:12.108
CL-202206-NYMEX [C] 16 Day #10 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-03-17. | 2022-04-25 10:16:12.108
CL-202206-NYMEX [C] 16 Day #10 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-01-16. | 2022-04-25 10:16:12.114
CL-202206-NYMEX [C] 16 Day #10 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-02-17. | 2022-04-25 10:16:12.114
CL-202206-NYMEX [C] 16 Day #10 | File CL-198702-NYMEX.dly has a volume of 0 at 1986-12-18. | 2022-04-25 10:16:12.118
CL-202206-NYMEX [C] 16 Day #10 | File CL-198702-NYMEX.dly has a volume of 0 at 1987-01-15. | 2022-04-25 10:16:12.118
CL-202206-NYMEX [C] 16 Day #10 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-11-18. | 2022-04-25 10:16:12.123
CL-202206-NYMEX [C] 16 Day #10 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-12-17. | 2022-04-25 10:16:12.123
CL-202206-NYMEX [C] 16 Day #10 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-10-17. | 2022-04-25 10:16:12.129
CL-202206-NYMEX [C] 16 Day #10 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-11-17. | 2022-04-25 10:16:12.129
CL-202206-NYMEX [C] 16 Day #10 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-09-18. | 2022-04-25 10:16:12.134
CL-202206-NYMEX [C] 16 Day #10 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-10-16. | 2022-04-25 10:16:12.134
CL-202206-NYMEX [C] 16 Day #10 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-08-18. | 2022-04-25 10:16:12.139
CL-202206-NYMEX [C] 16 Day #10 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-09-17. | 2022-04-25 10:16:12.139
CL-202206-NYMEX [C] 16 Day #10 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-07-18. | 2022-04-25 10:16:12.144
CL-202206-NYMEX [C] 16 Day #10 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-08-15. | 2022-04-25 10:16:12.144
CL-202206-NYMEX [C] 16 Day #10 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-06-18. | 2022-04-25 10:16:12.149
CL-202206-NYMEX [C] 16 Day #10 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-07-17. | 2022-04-25 10:16:12.149
CL-202206-NYMEX [C] 16 Day #10 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-05-16. | 2022-04-25 10:16:12.154
CL-202206-NYMEX [C] 16 Day #10 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-06-17. | 2022-04-25 10:16:12.154
CL-202206-NYMEX [C] 16 Day #10 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-04-18. | 2022-04-25 10:16:12.159
CL-202206-NYMEX [C] 16 Day #10 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-05-15. | 2022-04-25 10:16:12.159
CL-202206-NYMEX [C] 16 Day #10 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-03-18. | 2022-04-25 10:16:12.165
CL-202206-NYMEX [C] 16 Day #10 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-04-17. | 2022-04-25 10:16:12.165
CL-202206-NYMEX [C] 16 Day #10 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-02-18. | 2022-04-25 10:16:12.170
CL-202206-NYMEX [C] 16 Day #10 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-03-17. | 2022-04-25 10:16:12.170
CL-202206-NYMEX [C] 16 Day #10 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-01-17. | 2022-04-25 10:16:12.175
CL-202206-NYMEX [C] 16 Day #10 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-02-17. | 2022-04-25 10:16:12.175
CL-202206-NYMEX [C] 16 Day #10 | File CL-198602-NYMEX.dly has a volume of 0 at 1985-12-18. | 2022-04-25 10:16:12.180
CL-202206-NYMEX [C] 16 Day #10 | File CL-198602-NYMEX.dly has a volume of 0 at 1986-01-16. | 2022-04-25 10:16:12.180
CL-202206-NYMEX [C] 16 Day #10 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-11-18. | 2022-04-25 10:16:12.185
CL-202206-NYMEX [C] 16 Day #10 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-12-17. | 2022-04-25 10:16:12.185
CL-202206-NYMEX [C] 16 Day #10 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-10-18. | 2022-04-25 10:16:12.190
CL-202206-NYMEX [C] 16 Day #10 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-11-15. | 2022-04-25 10:16:12.190
CL-202206-NYMEX [C] 16 Day #10 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-09-18. | 2022-04-25 10:16:12.195
CL-202206-NYMEX [C] 16 Day #10 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-10-17. | 2022-04-25 10:16:12.195
CL-202206-NYMEX [C] 16 Day #10 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-08-16. | 2022-04-25 10:16:12.201
CL-202206-NYMEX [C] 16 Day #10 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-09-17. | 2022-04-25 10:16:12.201
CL-202206-NYMEX [C] 16 Day #10 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-07-18. | 2022-04-25 10:16:12.206
CL-202206-NYMEX [C] 16 Day #10 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-08-15. | 2022-04-25 10:16:12.206
CL-202206-NYMEX [C] 16 Day #10 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-06-18. | 2022-04-25 10:16:12.211
CL-202206-NYMEX [C] 16 Day #10 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-07-17. | 2022-04-25 10:16:12.211
CL-202206-NYMEX [C] 16 Day #10 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-05-17. | 2022-04-25 10:16:12.216
CL-202206-NYMEX [C] 16 Day #10 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-06-17. | 2022-04-25 10:16:12.216
CL-202206-NYMEX [C] 16 Day #10 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-04-18. | 2022-04-25 10:16:12.221
CL-202206-NYMEX [C] 16 Day #10 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-05-16. | 2022-04-25 10:16:12.221
CL-202206-NYMEX [C] 16 Day #10 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-03-18. | 2022-04-25 10:16:12.226
CL-202206-NYMEX [C] 16 Day #10 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-04-17. | 2022-04-25 10:16:12.226
CL-202206-NYMEX [C] 16 Day #10 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-02-18. | 2022-04-25 10:16:12.231
CL-202206-NYMEX [C] 16 Day #10 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-03-15. | 2022-04-25 10:16:12.231
CL-202206-NYMEX [C] 16 Day #10 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-01-18. | 2022-04-25 10:16:12.236
CL-202206-NYMEX [C] 16 Day #10 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-02-15. | 2022-04-25 10:16:12.236
CL-202206-NYMEX [C] 16 Day #10 | File CL-198502-NYMEX.dly has a volume of 0 at 1984-12-18. | 2022-04-25 10:16:12.240
CL-202206-NYMEX [C] 16 Day #10 | File CL-198502-NYMEX.dly has a volume of 0 at 1985-01-17. | 2022-04-25 10:16:12.240
CL-202206-NYMEX [C] 16 Day #10 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-11-16. | 2022-04-25 10:16:12.245
CL-202206-NYMEX [C] 16 Day #10 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-12-17. | 2022-04-25 10:16:12.245
CL-202206-NYMEX [C] 16 Day #10 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-10-18. | 2022-04-25 10:16:12.249
CL-202206-NYMEX [C] 16 Day #10 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-11-15. | 2022-04-25 10:16:12.249
CL-202206-NYMEX [C] 16 Day #10 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-09-18. | 2022-04-25 10:16:12.254
CL-202206-NYMEX [C] 16 Day #10 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-10-17. | 2022-04-25 10:16:12.254
CL-202206-NYMEX [C] 16 Day #10 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-08-17. | 2022-04-25 10:16:12.259
CL-202206-NYMEX [C] 16 Day #10 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-09-17. | 2022-04-25 10:16:12.259
CL-202206-NYMEX [C] 16 Day #10 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-07-18. | 2022-04-25 10:16:12.264
CL-202206-NYMEX [C] 16 Day #10 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-08-16. | 2022-04-25 10:16:12.264
CL-202206-NYMEX [C] 16 Day #10 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-06-18. | 2022-04-25 10:16:12.268
CL-202206-NYMEX [C] 16 Day #10 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-07-17. | 2022-04-25 10:16:12.268
CL-202206-NYMEX [C] 16 Day #10 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-05-18. | 2022-04-25 10:16:12.273
CL-202206-NYMEX [C] 16 Day #10 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-06-15. | 2022-04-25 10:16:12.273
CL-202206-NYMEX [C] 16 Day #10 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-04-18. | 2022-04-25 10:16:12.278
CL-202206-NYMEX [C] 16 Day #10 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-05-17. | 2022-04-25 10:16:12.278
CL-202206-NYMEX [C] 16 Day #10 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-03-16. | 2022-04-25 10:16:12.283
CL-202206-NYMEX [C] 16 Day #10 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-04-17. | 2022-04-25 10:16:12.283
CL-202206-NYMEX [C] 16 Day #10 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-02-17. | 2022-04-25 10:16:12.287
CL-202206-NYMEX [C] 16 Day #10 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-03-15. | 2022-04-25 10:16:12.287
CL-202206-NYMEX [C] 16 Day #10 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-01-18. | 2022-04-25 10:16:12.292
CL-202206-NYMEX [C] 16 Day #10 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-02-16. | 2022-04-25 10:16:12.292
CL-202206-NYMEX [C] 16 Day #10 | File CL-198402-NYMEX.dly has a volume of 0 at 1983-12-16. | 2022-04-25 10:16:12.297
CL-202206-NYMEX [C] 16 Day #10 | File CL-198402-NYMEX.dly has a volume of 0 at 1984-01-17. | 2022-04-25 10:16:12.297
CL-202206-NYMEX [C] 16 Day #10 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-11-18. | 2022-04-25 10:16:12.301
CL-202206-NYMEX [C] 16 Day #10 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-12-15. | 2022-04-25 10:16:12.301
CL-202206-NYMEX [C] 16 Day #10 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-10-18. | 2022-04-25 10:16:12.306
CL-202206-NYMEX [C] 16 Day #10 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-11-17. | 2022-04-25 10:16:12.306
CL-202206-NYMEX [C] 16 Day #10 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-09-16. | 2022-04-25 10:16:12.311
CL-202206-NYMEX [C] 16 Day #10 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-10-17. | 2022-04-25 10:16:12.311
CL-202206-NYMEX [C] 16 Day #10 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-08-18. | 2022-04-25 10:16:12.315
CL-202206-NYMEX [C] 16 Day #10 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-09-15. | 2022-04-25 10:16:12.315
CL-202206-NYMEX [C] 16 Day #10 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-07-18. | 2022-04-25 10:16:12.320
CL-202206-NYMEX [C] 16 Day #10 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-08-17. | 2022-04-25 10:16:12.320
CL-202206-NYMEX [C] 16 Day #10 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-06-17. | 2022-04-25 10:16:12.325
CL-202206-NYMEX [C] 16 Day #10 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-07-15. | 2022-04-25 10:16:12.325
CL-202206-NYMEX [C] 16 Day #10 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-05-18. | 2022-04-25 10:16:12.330
CL-202206-NYMEX [C] 16 Day #10 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-06-16. | 2022-04-25 10:16:12.330
CL-202206-NYMEX [C] 16 Day #10 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-04-18. | 2022-04-25 10:16:12.335
CL-202206-NYMEX [C] 16 Day #10 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-05-17. | 2022-04-25 10:16:12.335
Historical data download thread signaled to stop. | 2022-04-25 10:16:12.439
HD Request # 79 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:39.532000 | 2022-04-25 10:16:12.440
HD Request # 79 | Received 47 Intraday data records from 2022-04-25 10:12:25.909000 to 2022-04-25 10:15:35.747001 (3.2 minutes) and wrote 40 records for VIRT-NQTV | 2022-04-25 10:16:12.440
HD Request # 79 | Completion time: 4s | 2022-04-25 10:16:12.440
HD Request # 79 | Intraday data download complete for VIRT-NQTV. Unique request ID: 210 | 2022-04-25 10:16:12.440
Removing historical data download ID 210. | 2022-04-25 10:16:12.440
Real-time Intraday chart data file updates started for VIRT-NQTV | 2022-04-25 10:16:12.440
Intraday chart data file opened for VIRT-NQTV | 2022-04-25 10:16:12.440
HD Request # 79 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:16:12.440
Triggering next historical data download in queue. | 2022-04-25 10:16:12.440
HD Request # 80 | Requesting historical Daily data for BTK18 starting at 2018-05-22. SC External HD service. | 2022-04-25 10:16:12.440
Restarting the loading process. | 2022-04-25 10:16:12.442
HD Request # 81 | Downloading Intraday chart data for WCN-NQTV to the file WCN-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:16:12.461
HD Request # 81 | Download start date-time: 2022-04-25 10:12:11.000000. File last date-time: 2022-04-25 10:12:11.168002 | 2022-04-25 10:16:12.461
HD Request # 81 | Using server: ds25.sierracharts.com port 10149 | 2022-04-25 10:16:12.461
Socket (4) | Creating socket. | 2022-04-25 10:16:12.461
Socket (4) | New receive buffer size: 5242880 | 2022-04-25 10:16:12.461
Socket (4) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:16:12.461
CL-202206-NYMEX [C] 2 Day #3 | Reloading chart. | 2022-04-25 10:16:12.721
CL-202206-NYMEX [C] 2 Day #3 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:16:12.721
CL-202206-NYMEX [C] 2 Day #3 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:16:12.721
HD Request # 81 | Setting DTC encoding to Binary VLS | 2022-04-25 10:16:12.924
HD Request # 81 | Sending historical data logon request message. | 2022-04-25 10:16:12.924
HD Request # 81 | Requesting Intraday data. Start date-time: 2022-04-25 10:12:11. Record interval: 0. Symbol: WCN-NQTV | 2022-04-25 10:16:13.151
HD Request # 81 | Decompressing data. | 2022-04-25 10:16:13.379
HD Request # 81 | Receiving Intraday data for WCN-NQTV starting at 2022-04-25 10:12:11.168000 | 2022-04-25 10:16:13.380
Socket (4) | CloseSocket call. | 2022-04-25 10:16:13.380
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:16:13.380
Socket (4) | Socket gracefully closed by remote side. | 2022-04-25 10:16:13.605
Socket (4) | Closed. | 2022-04-25 10:16:13.605
CL-202206-NYMEX [C] 2 Day #3 | File CL-200102-NYMEX.dly has a volume of 0 at 2000-12-18. | 2022-04-25 10:16:14.632
CL-202206-NYMEX [C] 2 Day #3 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-11-17. | 2022-04-25 10:16:14.636
CL-202206-NYMEX [C] 2 Day #3 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-12-15. | 2022-04-25 10:16:14.636
CL-202206-NYMEX [C] 2 Day #3 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-10-18. | 2022-04-25 10:16:14.641
CL-202206-NYMEX [C] 2 Day #3 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-11-16. | 2022-04-25 10:16:14.641
CL-202206-NYMEX [C] 2 Day #3 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-09-18. | 2022-04-25 10:16:14.646
CL-202206-NYMEX [C] 2 Day #3 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-10-17. | 2022-04-25 10:16:14.646
CL-202206-NYMEX [C] 2 Day #3 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-08-18. | 2022-04-25 10:16:14.650
CL-202206-NYMEX [C] 2 Day #3 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-09-15. | 2022-04-25 10:16:14.650
CL-202206-NYMEX [C] 2 Day #3 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-07-18. | 2022-04-25 10:16:14.656
CL-202206-NYMEX [C] 2 Day #3 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-08-17. | 2022-04-25 10:16:14.656
CL-202206-NYMEX [C] 2 Day #3 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-06-16. | 2022-04-25 10:16:14.660
CL-202206-NYMEX [C] 2 Day #3 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-07-17. | 2022-04-25 10:16:14.660
CL-202206-NYMEX [C] 2 Day #3 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-05-18. | 2022-04-25 10:16:14.665
CL-202206-NYMEX [C] 2 Day #3 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-06-15. | 2022-04-25 10:16:14.665
CL-202206-NYMEX [C] 2 Day #3 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-04-18. | 2022-04-25 10:16:14.670
CL-202206-NYMEX [C] 2 Day #3 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-05-17. | 2022-04-25 10:16:14.670
CL-202206-NYMEX [C] 2 Day #3 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-03-17. | 2022-04-25 10:16:14.674
CL-202206-NYMEX [C] 2 Day #3 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-04-17. | 2022-04-25 10:16:14.674
CL-202206-NYMEX [C] 2 Day #3 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-02-18. | 2022-04-25 10:16:14.679
CL-202206-NYMEX [C] 2 Day #3 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-03-16. | 2022-04-25 10:16:14.679
CL-202206-NYMEX [C] 2 Day #3 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-01-18. | 2022-04-25 10:16:14.684
CL-202206-NYMEX [C] 2 Day #3 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-02-17. | 2022-04-25 10:16:14.684
CL-202206-NYMEX [C] 2 Day #3 | File CL-200002-NYMEX.dly has a volume of 0 at 1999-12-17. | 2022-04-25 10:16:14.688
CL-202206-NYMEX [C] 2 Day #3 | File CL-200002-NYMEX.dly has a volume of 0 at 2000-01-17. | 2022-04-25 10:16:14.688
CL-202206-NYMEX [C] 2 Day #3 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-11-18. | 2022-04-25 10:16:14.693
CL-202206-NYMEX [C] 2 Day #3 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-12-16. | 2022-04-25 10:16:14.693
CL-202206-NYMEX [C] 2 Day #3 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-10-18. | 2022-04-25 10:16:14.698
CL-202206-NYMEX [C] 2 Day #3 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-11-17. | 2022-04-25 10:16:14.698
CL-202206-NYMEX [C] 2 Day #3 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-09-17. | 2022-04-25 10:16:14.703
CL-202206-NYMEX [C] 2 Day #3 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-10-15. | 2022-04-25 10:16:14.703
CL-202206-NYMEX [C] 2 Day #3 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-08-18. | 2022-04-25 10:16:14.708
CL-202206-NYMEX [C] 2 Day #3 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-09-16. | 2022-04-25 10:16:14.708
CL-202206-NYMEX [C] 2 Day #3 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-07-16. | 2022-04-25 10:16:14.713
CL-202206-NYMEX [C] 2 Day #3 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-08-17. | 2022-04-25 10:16:14.713
CL-202206-NYMEX [C] 2 Day #3 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-06-18. | 2022-04-25 10:16:14.718
CL-202206-NYMEX [C] 2 Day #3 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-07-15. | 2022-04-25 10:16:14.718
CL-202206-NYMEX [C] 2 Day #3 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-05-18. | 2022-04-25 10:16:14.723
CL-202206-NYMEX [C] 2 Day #3 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-06-17. | 2022-04-25 10:16:14.723
CL-202206-NYMEX [C] 2 Day #3 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-04-16. | 2022-04-25 10:16:14.728
CL-202206-NYMEX [C] 2 Day #3 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-05-17. | 2022-04-25 10:16:14.728
CL-202206-NYMEX [C] 2 Day #3 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-03-18. | 2022-04-25 10:16:14.732
CL-202206-NYMEX [C] 2 Day #3 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-04-15. | 2022-04-25 10:16:14.732
CL-202206-NYMEX [C] 2 Day #3 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-02-18. | 2022-04-25 10:16:14.737
CL-202206-NYMEX [C] 2 Day #3 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-03-17. | 2022-04-25 10:16:14.737
CL-202206-NYMEX [C] 2 Day #3 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-01-18. | 2022-04-25 10:16:14.742
CL-202206-NYMEX [C] 2 Day #3 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-02-17. | 2022-04-25 10:16:14.742
CL-202206-NYMEX [C] 2 Day #3 | File CL-199902-NYMEX.dly has a volume of 0 at 1998-12-18. | 2022-04-25 10:16:14.746
CL-202206-NYMEX [C] 2 Day #3 | File CL-199902-NYMEX.dly has a volume of 0 at 1999-01-15. | 2022-04-25 10:16:14.746
CL-202206-NYMEX [C] 2 Day #3 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-11-18. | 2022-04-25 10:16:14.751
CL-202206-NYMEX [C] 2 Day #3 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-12-17. | 2022-04-25 10:16:14.751
CL-202206-NYMEX [C] 2 Day #3 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-10-16. | 2022-04-25 10:16:14.756
CL-202206-NYMEX [C] 2 Day #3 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-11-17. | 2022-04-25 10:16:14.756
CL-202206-NYMEX [C] 2 Day #3 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-09-18. | 2022-04-25 10:16:14.761
CL-202206-NYMEX [C] 2 Day #3 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-10-15. | 2022-04-25 10:16:14.761
CL-202206-NYMEX [C] 2 Day #3 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-08-18. | 2022-04-25 10:16:14.766
CL-202206-NYMEX [C] 2 Day #3 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-09-17. | 2022-04-25 10:16:14.766
CL-202206-NYMEX [C] 2 Day #3 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-07-17. | 2022-04-25 10:16:14.771
CL-202206-NYMEX [C] 2 Day #3 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-08-17. | 2022-04-25 10:16:14.771
CL-202206-NYMEX [C] 2 Day #3 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-06-18. | 2022-04-25 10:16:14.775
CL-202206-NYMEX [C] 2 Day #3 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-07-16. | 2022-04-25 10:16:14.775
CL-202206-NYMEX [C] 2 Day #3 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-05-18. | 2022-04-25 10:16:14.780
CL-202206-NYMEX [C] 2 Day #3 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-06-17. | 2022-04-25 10:16:14.780
CL-202206-NYMEX [C] 2 Day #3 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-04-17. | 2022-04-25 10:16:14.785
CL-202206-NYMEX [C] 2 Day #3 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-05-15. | 2022-04-25 10:16:14.785
CL-202206-NYMEX [C] 2 Day #3 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-03-18. | 2022-04-25 10:16:14.790
CL-202206-NYMEX [C] 2 Day #3 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-04-16. | 2022-04-25 10:16:14.790
CL-202206-NYMEX [C] 2 Day #3 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-02-18. | 2022-04-25 10:16:14.794
CL-202206-NYMEX [C] 2 Day #3 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-03-17. | 2022-04-25 10:16:14.794
CL-202206-NYMEX [C] 2 Day #3 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-01-16. | 2022-04-25 10:16:14.799
CL-202206-NYMEX [C] 2 Day #3 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-02-17. | 2022-04-25 10:16:14.799
CL-202206-NYMEX [C] 2 Day #3 | File CL-199802-NYMEX.dly has a volume of 0 at 1997-12-18. | 2022-04-25 10:16:14.803
CL-202206-NYMEX [C] 2 Day #3 | File CL-199802-NYMEX.dly has a volume of 0 at 1998-01-15. | 2022-04-25 10:16:14.803
CL-202206-NYMEX [C] 2 Day #3 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-11-18. | 2022-04-25 10:16:14.808
CL-202206-NYMEX [C] 2 Day #3 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-12-17. | 2022-04-25 10:16:14.808
CL-202206-NYMEX [C] 2 Day #3 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-10-17. | 2022-04-25 10:16:14.813
CL-202206-NYMEX [C] 2 Day #3 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-11-17. | 2022-04-25 10:16:14.813
CL-202206-NYMEX [C] 2 Day #3 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-09-18. | 2022-04-25 10:16:14.818
CL-202206-NYMEX [C] 2 Day #3 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-10-16. | 2022-04-25 10:16:14.818
CL-202206-NYMEX [C] 2 Day #3 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-08-18. | 2022-04-25 10:16:14.823
CL-202206-NYMEX [C] 2 Day #3 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-09-17. | 2022-04-25 10:16:14.823
CL-202206-NYMEX [C] 2 Day #3 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-07-18. | 2022-04-25 10:16:14.827
CL-202206-NYMEX [C] 2 Day #3 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-08-15. | 2022-04-25 10:16:14.827
CL-202206-NYMEX [C] 2 Day #3 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-06-18. | 2022-04-25 10:16:14.832
CL-202206-NYMEX [C] 2 Day #3 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-07-17. | 2022-04-25 10:16:14.832
CL-202206-NYMEX [C] 2 Day #3 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-05-16. | 2022-04-25 10:16:14.837
CL-202206-NYMEX [C] 2 Day #3 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-06-17. | 2022-04-25 10:16:14.837
CL-202206-NYMEX [C] 2 Day #3 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-04-18. | 2022-04-25 10:16:14.842
CL-202206-NYMEX [C] 2 Day #3 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-05-15. | 2022-04-25 10:16:14.842
CL-202206-NYMEX [C] 2 Day #3 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-03-18. | 2022-04-25 10:16:14.847
CL-202206-NYMEX [C] 2 Day #3 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-04-17. | 2022-04-25 10:16:14.847
CL-202206-NYMEX [C] 2 Day #3 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-02-18. | 2022-04-25 10:16:14.851
CL-202206-NYMEX [C] 2 Day #3 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-03-17. | 2022-04-25 10:16:14.851
CL-202206-NYMEX [C] 2 Day #3 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-01-17. | 2022-04-25 10:16:14.856
CL-202206-NYMEX [C] 2 Day #3 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-02-17. | 2022-04-25 10:16:14.856
CL-202206-NYMEX [C] 2 Day #3 | File CL-199702-NYMEX.dly has a volume of 0 at 1996-12-18. | 2022-04-25 10:16:14.861
CL-202206-NYMEX [C] 2 Day #3 | File CL-199702-NYMEX.dly has a volume of 0 at 1997-01-16. | 2022-04-25 10:16:14.861
CL-202206-NYMEX [C] 2 Day #3 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-11-18. | 2022-04-25 10:16:14.865
CL-202206-NYMEX [C] 2 Day #3 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-12-17. | 2022-04-25 10:16:14.865
CL-202206-NYMEX [C] 2 Day #3 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-10-18. | 2022-04-25 10:16:14.870
CL-202206-NYMEX [C] 2 Day #3 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-11-15. | 2022-04-25 10:16:14.870
CL-202206-NYMEX [C] 2 Day #3 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-09-18. | 2022-04-25 10:16:14.875
CL-202206-NYMEX [C] 2 Day #3 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-10-17. | 2022-04-25 10:16:14.875
CL-202206-NYMEX [C] 2 Day #3 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-08-16. | 2022-04-25 10:16:14.880
CL-202206-NYMEX [C] 2 Day #3 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-09-17. | 2022-04-25 10:16:14.880
CL-202206-NYMEX [C] 2 Day #3 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-07-18. | 2022-04-25 10:16:14.885
CL-202206-NYMEX [C] 2 Day #3 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-08-15. | 2022-04-25 10:16:14.885
CL-202206-NYMEX [C] 2 Day #3 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-06-18. | 2022-04-25 10:16:14.889
CL-202206-NYMEX [C] 2 Day #3 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-07-17. | 2022-04-25 10:16:14.889
CL-202206-NYMEX [C] 2 Day #3 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-05-17. | 2022-04-25 10:16:14.894
CL-202206-NYMEX [C] 2 Day #3 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-06-17. | 2022-04-25 10:16:14.894
CL-202206-NYMEX [C] 2 Day #3 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-04-18. | 2022-04-25 10:16:14.899
CL-202206-NYMEX [C] 2 Day #3 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-05-16. | 2022-04-25 10:16:14.899
CL-202206-NYMEX [C] 2 Day #3 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-03-18. | 2022-04-25 10:16:14.904
CL-202206-NYMEX [C] 2 Day #3 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-04-17. | 2022-04-25 10:16:14.904
CL-202206-NYMEX [C] 2 Day #3 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-02-16. | 2022-04-25 10:16:14.909
CL-202206-NYMEX [C] 2 Day #3 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-03-15. | 2022-04-25 10:16:14.909
CL-202206-NYMEX [C] 2 Day #3 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-01-18. | 2022-04-25 10:16:14.914
CL-202206-NYMEX [C] 2 Day #3 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-02-15. | 2022-04-25 10:16:14.914
CL-202206-NYMEX [C] 2 Day #3 | File CL-199602-NYMEX.dly has a volume of 0 at 1995-12-18. | 2022-04-25 10:16:14.918
CL-202206-NYMEX [C] 2 Day #3 | File CL-199602-NYMEX.dly has a volume of 0 at 1996-01-17. | 2022-04-25 10:16:14.918
CL-202206-NYMEX [C] 2 Day #3 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-11-17. | 2022-04-25 10:16:14.923
CL-202206-NYMEX [C] 2 Day #3 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-12-15. | 2022-04-25 10:16:14.923
CL-202206-NYMEX [C] 2 Day #3 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-10-18. | 2022-04-25 10:16:14.927
CL-202206-NYMEX [C] 2 Day #3 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-11-16. | 2022-04-25 10:16:14.927
CL-202206-NYMEX [C] 2 Day #3 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-09-18. | 2022-04-25 10:16:14.932
CL-202206-NYMEX [C] 2 Day #3 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-10-17. | 2022-04-25 10:16:14.932
CL-202206-NYMEX [C] 2 Day #3 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-08-18. | 2022-04-25 10:16:14.937
CL-202206-NYMEX [C] 2 Day #3 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-09-15. | 2022-04-25 10:16:14.937
CL-202206-NYMEX [C] 2 Day #3 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-07-18. | 2022-04-25 10:16:14.942
CL-202206-NYMEX [C] 2 Day #3 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-08-17. | 2022-04-25 10:16:14.942
CL-202206-NYMEX [C] 2 Day #3 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-06-16. | 2022-04-25 10:16:14.947
CL-202206-NYMEX [C] 2 Day #3 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-07-17. | 2022-04-25 10:16:14.947
CL-202206-NYMEX [C] 2 Day #3 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-05-18. | 2022-04-25 10:16:14.951
CL-202206-NYMEX [C] 2 Day #3 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-06-15. | 2022-04-25 10:16:14.951
CL-202206-NYMEX [C] 2 Day #3 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-04-18. | 2022-04-25 10:16:14.956
CL-202206-NYMEX [C] 2 Day #3 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-05-17. | 2022-04-25 10:16:14.956
CL-202206-NYMEX [C] 2 Day #3 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-03-17. | 2022-04-25 10:16:14.961
CL-202206-NYMEX [C] 2 Day #3 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-04-17. | 2022-04-25 10:16:14.961
CL-202206-NYMEX [C] 2 Day #3 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-02-17. | 2022-04-25 10:16:14.966
CL-202206-NYMEX [C] 2 Day #3 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-03-16. | 2022-04-25 10:16:14.966
CL-202206-NYMEX [C] 2 Day #3 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-01-18. | 2022-04-25 10:16:14.970
CL-202206-NYMEX [C] 2 Day #3 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-02-16. | 2022-04-25 10:16:14.970
CL-202206-NYMEX [C] 2 Day #3 | File CL-199502-NYMEX.dly has a volume of 0 at 1994-12-16. | 2022-04-25 10:16:14.975
CL-202206-NYMEX [C] 2 Day #3 | File CL-199502-NYMEX.dly has a volume of 0 at 1995-01-17. | 2022-04-25 10:16:14.975
CL-202206-NYMEX [C] 2 Day #3 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-11-18. | 2022-04-25 10:16:14.979
CL-202206-NYMEX [C] 2 Day #3 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-12-15. | 2022-04-25 10:16:14.979
CL-202206-NYMEX [C] 2 Day #3 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-10-18. | 2022-04-25 10:16:14.984
CL-202206-NYMEX [C] 2 Day #3 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-11-17. | 2022-04-25 10:16:14.984
CL-202206-NYMEX [C] 2 Day #3 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-09-16. | 2022-04-25 10:16:14.989
CL-202206-NYMEX [C] 2 Day #3 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-10-17. | 2022-04-25 10:16:14.989
CL-202206-NYMEX [C] 2 Day #3 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-08-18. | 2022-04-25 10:16:14.994
CL-202206-NYMEX [C] 2 Day #3 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-09-15. | 2022-04-25 10:16:14.994
CL-202206-NYMEX [C] 2 Day #3 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-07-18. | 2022-04-25 10:16:14.999
CL-202206-NYMEX [C] 2 Day #3 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-08-17. | 2022-04-25 10:16:14.999
CL-202206-NYMEX [C] 2 Day #3 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-06-17. | 2022-04-25 10:16:15.003
CL-202206-NYMEX [C] 2 Day #3 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-07-15. | 2022-04-25 10:16:15.003
CL-202206-NYMEX [C] 2 Day #3 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-05-18. | 2022-04-25 10:16:15.008
CL-202206-NYMEX [C] 2 Day #3 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-06-16. | 2022-04-25 10:16:15.008
CL-202206-NYMEX [C] 2 Day #3 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-04-18. | 2022-04-25 10:16:15.013
CL-202206-NYMEX [C] 2 Day #3 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-05-17. | 2022-04-25 10:16:15.013
CL-202206-NYMEX [C] 2 Day #3 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-03-18. | 2022-04-25 10:16:15.017
CL-202206-NYMEX [C] 2 Day #3 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-04-15. | 2022-04-25 10:16:15.017
CL-202206-NYMEX [C] 2 Day #3 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-02-18. | 2022-04-25 10:16:15.022
CL-202206-NYMEX [C] 2 Day #3 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-03-17. | 2022-04-25 10:16:15.022
CL-202206-NYMEX [C] 2 Day #3 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-01-18. | 2022-04-25 10:16:15.027
CL-202206-NYMEX [C] 2 Day #3 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-02-17. | 2022-04-25 10:16:15.027
CL-202206-NYMEX [C] 2 Day #3 | File CL-199402-NYMEX.dly has a volume of 0 at 1993-12-17. | 2022-04-25 10:16:15.031
CL-202206-NYMEX [C] 2 Day #3 | File CL-199402-NYMEX.dly has a volume of 0 at 1994-01-17. | 2022-04-25 10:16:15.031
CL-202206-NYMEX [C] 2 Day #3 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-11-18. | 2022-04-25 10:16:15.036
CL-202206-NYMEX [C] 2 Day #3 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-12-16. | 2022-04-25 10:16:15.036
CL-202206-NYMEX [C] 2 Day #3 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-10-18. | 2022-04-25 10:16:15.040
CL-202206-NYMEX [C] 2 Day #3 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-11-17. | 2022-04-25 10:16:15.040
CL-202206-NYMEX [C] 2 Day #3 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-09-17. | 2022-04-25 10:16:15.045
CL-202206-NYMEX [C] 2 Day #3 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-10-15. | 2022-04-25 10:16:15.045
CL-202206-NYMEX [C] 2 Day #3 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-08-18. | 2022-04-25 10:16:15.050
CL-202206-NYMEX [C] 2 Day #3 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-09-16. | 2022-04-25 10:16:15.050
CL-202206-NYMEX [C] 2 Day #3 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-07-16. | 2022-04-25 10:16:15.055
CL-202206-NYMEX [C] 2 Day #3 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-08-17. | 2022-04-25 10:16:15.055
CL-202206-NYMEX [C] 2 Day #3 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-06-18. | 2022-04-25 10:16:15.060
CL-202206-NYMEX [C] 2 Day #3 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-07-15. | 2022-04-25 10:16:15.060
CL-202206-NYMEX [C] 2 Day #3 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-05-18. | 2022-04-25 10:16:15.064
CL-202206-NYMEX [C] 2 Day #3 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-06-17. | 2022-04-25 10:16:15.064
CL-202206-NYMEX [C] 2 Day #3 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-04-16. | 2022-04-25 10:16:15.069
CL-202206-NYMEX [C] 2 Day #3 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-05-17. | 2022-04-25 10:16:15.069
CL-202206-NYMEX [C] 2 Day #3 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-03-18. | 2022-04-25 10:16:15.074
CL-202206-NYMEX [C] 2 Day #3 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-04-15. | 2022-04-25 10:16:15.074
CL-202206-NYMEX [C] 2 Day #3 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-02-18. | 2022-04-25 10:16:15.078
CL-202206-NYMEX [C] 2 Day #3 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-03-17. | 2022-04-25 10:16:15.078
CL-202206-NYMEX [C] 2 Day #3 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-01-18. | 2022-04-25 10:16:15.083
CL-202206-NYMEX [C] 2 Day #3 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-02-17. | 2022-04-25 10:16:15.083
CL-202206-NYMEX [C] 2 Day #3 | File CL-199302-NYMEX.dly has a volume of 0 at 1992-12-18. | 2022-04-25 10:16:15.088
CL-202206-NYMEX [C] 2 Day #3 | File CL-199302-NYMEX.dly has a volume of 0 at 1993-01-15. | 2022-04-25 10:16:15.088
CL-202206-NYMEX [C] 2 Day #3 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-11-18. | 2022-04-25 10:16:15.092
CL-202206-NYMEX [C] 2 Day #3 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-12-17. | 2022-04-25 10:16:15.092
CL-202206-NYMEX [C] 2 Day #3 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-10-16. | 2022-04-25 10:16:15.097
CL-202206-NYMEX [C] 2 Day #3 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-11-17. | 2022-04-25 10:16:15.097
CL-202206-NYMEX [C] 2 Day #3 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-09-18. | 2022-04-25 10:16:15.102
CL-202206-NYMEX [C] 2 Day #3 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-10-15. | 2022-04-25 10:16:15.102
CL-202206-NYMEX [C] 2 Day #3 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-08-18. | 2022-04-25 10:16:15.107
CL-202206-NYMEX [C] 2 Day #3 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-09-17. | 2022-04-25 10:16:15.107
CL-202206-NYMEX [C] 2 Day #3 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-07-17. | 2022-04-25 10:16:15.112
CL-202206-NYMEX [C] 2 Day #3 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-08-17. | 2022-04-25 10:16:15.112
CL-202206-NYMEX [C] 2 Day #3 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-06-18. | 2022-04-25 10:16:15.117
CL-202206-NYMEX [C] 2 Day #3 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-07-16. | 2022-04-25 10:16:15.117
CL-202206-NYMEX [C] 2 Day #3 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-05-18. | 2022-04-25 10:16:15.121
CL-202206-NYMEX [C] 2 Day #3 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-06-17. | 2022-04-25 10:16:15.121
CL-202206-NYMEX [C] 2 Day #3 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-04-17. | 2022-04-25 10:16:15.126
CL-202206-NYMEX [C] 2 Day #3 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-05-15. | 2022-04-25 10:16:15.126
CL-202206-NYMEX [C] 2 Day #3 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-03-18. | 2022-04-25 10:16:15.131
CL-202206-NYMEX [C] 2 Day #3 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-04-16. | 2022-04-25 10:16:15.131
CL-202206-NYMEX [C] 2 Day #3 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-02-18. | 2022-04-25 10:16:15.135
CL-202206-NYMEX [C] 2 Day #3 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-03-17. | 2022-04-25 10:16:15.135
CL-202206-NYMEX [C] 2 Day #3 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-01-17. | 2022-04-25 10:16:15.140
CL-202206-NYMEX [C] 2 Day #3 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-02-17. | 2022-04-25 10:16:15.140
CL-202206-NYMEX [C] 2 Day #3 | File CL-199202-NYMEX.dly has a volume of 0 at 1991-12-18. | 2022-04-25 10:16:15.145
CL-202206-NYMEX [C] 2 Day #3 | File CL-199202-NYMEX.dly has a volume of 0 at 1992-01-16. | 2022-04-25 10:16:15.145
CL-202206-NYMEX [C] 2 Day #3 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-11-18. | 2022-04-25 10:16:15.149
CL-202206-NYMEX [C] 2 Day #3 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-12-17. | 2022-04-25 10:16:15.149
CL-202206-NYMEX [C] 2 Day #3 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-10-18. | 2022-04-25 10:16:15.154
CL-202206-NYMEX [C] 2 Day #3 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-11-15. | 2022-04-25 10:16:15.154
CL-202206-NYMEX [C] 2 Day #3 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-09-18. | 2022-04-25 10:16:15.159
CL-202206-NYMEX [C] 2 Day #3 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-10-17. | 2022-04-25 10:16:15.159
CL-202206-NYMEX [C] 2 Day #3 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-08-16. | 2022-04-25 10:16:15.163
CL-202206-NYMEX [C] 2 Day #3 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-09-17. | 2022-04-25 10:16:15.163
CL-202206-NYMEX [C] 2 Day #3 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-07-18. | 2022-04-25 10:16:15.168
CL-202206-NYMEX [C] 2 Day #3 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-08-15. | 2022-04-25 10:16:15.168
CL-202206-NYMEX [C] 2 Day #3 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-06-18. | 2022-04-25 10:16:15.173
CL-202206-NYMEX [C] 2 Day #3 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-07-17. | 2022-04-25 10:16:15.173
CL-202206-NYMEX [C] 2 Day #3 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-05-17. | 2022-04-25 10:16:15.177
CL-202206-NYMEX [C] 2 Day #3 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-06-17. | 2022-04-25 10:16:15.177
CL-202206-NYMEX [C] 2 Day #3 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-04-18. | 2022-04-25 10:16:15.182
CL-202206-NYMEX [C] 2 Day #3 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-05-16. | 2022-04-25 10:16:15.182
CL-202206-NYMEX [C] 2 Day #3 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-03-18. | 2022-04-25 10:16:15.187
CL-202206-NYMEX [C] 2 Day #3 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-04-17. | 2022-04-25 10:16:15.187
CL-202206-NYMEX [C] 2 Day #3 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-02-18. | 2022-04-25 10:16:15.192
CL-202206-NYMEX [C] 2 Day #3 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-03-15. | 2022-04-25 10:16:15.192
CL-202206-NYMEX [C] 2 Day #3 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-01-18. | 2022-04-25 10:16:15.196
CL-202206-NYMEX [C] 2 Day #3 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-02-15. | 2022-04-25 10:16:15.196
CL-202206-NYMEX [C] 2 Day #3 | File CL-199102-NYMEX.dly has a volume of 0 at 1990-12-18. | 2022-04-25 10:16:15.201
CL-202206-NYMEX [C] 2 Day #3 | File CL-199102-NYMEX.dly has a volume of 0 at 1991-01-17. | 2022-04-25 10:16:15.201
CL-202206-NYMEX [C] 2 Day #3 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-11-16. | 2022-04-25 10:16:15.205
CL-202206-NYMEX [C] 2 Day #3 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-12-17. | 2022-04-25 10:16:15.205
CL-202206-NYMEX [C] 2 Day #3 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-10-18. | 2022-04-25 10:16:15.210
CL-202206-NYMEX [C] 2 Day #3 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-11-15. | 2022-04-25 10:16:15.210
CL-202206-NYMEX [C] 2 Day #3 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-09-18. | 2022-04-25 10:16:15.215
CL-202206-NYMEX [C] 2 Day #3 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-10-17. | 2022-04-25 10:16:15.215
CL-202206-NYMEX [C] 2 Day #3 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-08-17. | 2022-04-25 10:16:15.220
CL-202206-NYMEX [C] 2 Day #3 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-09-17. | 2022-04-25 10:16:15.220
CL-202206-NYMEX [C] 2 Day #3 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-07-18. | 2022-04-25 10:16:15.225
CL-202206-NYMEX [C] 2 Day #3 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-08-16. | 2022-04-25 10:16:15.225
CL-202206-NYMEX [C] 2 Day #3 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-06-18. | 2022-04-25 10:16:15.229
CL-202206-NYMEX [C] 2 Day #3 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-07-17. | 2022-04-25 10:16:15.229
CL-202206-NYMEX [C] 2 Day #3 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-05-18. | 2022-04-25 10:16:15.234
CL-202206-NYMEX [C] 2 Day #3 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-06-15. | 2022-04-25 10:16:15.234
CL-202206-NYMEX [C] 2 Day #3 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-04-18. | 2022-04-25 10:16:15.239
CL-202206-NYMEX [C] 2 Day #3 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-05-17. | 2022-04-25 10:16:15.239
CL-202206-NYMEX [C] 2 Day #3 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-03-16. | 2022-04-25 10:16:15.244
CL-202206-NYMEX [C] 2 Day #3 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-04-17. | 2022-04-25 10:16:15.244
CL-202206-NYMEX [C] 2 Day #3 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-02-16. | 2022-04-25 10:16:15.248
CL-202206-NYMEX [C] 2 Day #3 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-03-15. | 2022-04-25 10:16:15.248
CL-202206-NYMEX [C] 2 Day #3 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-01-18. | 2022-04-25 10:16:15.253
CL-202206-NYMEX [C] 2 Day #3 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-02-15. | 2022-04-25 10:16:15.253
CL-202206-NYMEX [C] 2 Day #3 | File CL-199002-NYMEX.dly has a volume of 0 at 1989-12-18. | 2022-04-25 10:16:15.257
CL-202206-NYMEX [C] 2 Day #3 | File CL-199002-NYMEX.dly has a volume of 0 at 1990-01-17. | 2022-04-25 10:16:15.257
CL-202206-NYMEX [C] 2 Day #3 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-11-17. | 2022-04-25 10:16:15.262
CL-202206-NYMEX [C] 2 Day #3 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-12-15. | 2022-04-25 10:16:15.262
CL-202206-NYMEX [C] 2 Day #3 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-10-18. | 2022-04-25 10:16:15.267
CL-202206-NYMEX [C] 2 Day #3 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-11-16. | 2022-04-25 10:16:15.267
CL-202206-NYMEX [C] 2 Day #3 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-09-18. | 2022-04-25 10:16:15.272
CL-202206-NYMEX [C] 2 Day #3 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-10-17. | 2022-04-25 10:16:15.272
CL-202206-NYMEX [C] 2 Day #3 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-08-18. | 2022-04-25 10:16:15.276
CL-202206-NYMEX [C] 2 Day #3 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-09-15. | 2022-04-25 10:16:15.276
CL-202206-NYMEX [C] 2 Day #3 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-07-18. | 2022-04-25 10:16:15.282
CL-202206-NYMEX [C] 2 Day #3 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-08-17. | 2022-04-25 10:16:15.282
CL-202206-NYMEX [C] 2 Day #3 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-06-16. | 2022-04-25 10:16:15.286
CL-202206-NYMEX [C] 2 Day #3 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-07-17. | 2022-04-25 10:16:15.286
CL-202206-NYMEX [C] 2 Day #3 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-05-18. | 2022-04-25 10:16:15.291
CL-202206-NYMEX [C] 2 Day #3 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-06-15. | 2022-04-25 10:16:15.291
CL-202206-NYMEX [C] 2 Day #3 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-04-18. | 2022-04-25 10:16:15.296
CL-202206-NYMEX [C] 2 Day #3 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-05-17. | 2022-04-25 10:16:15.296
CL-202206-NYMEX [C] 2 Day #3 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-03-17. | 2022-04-25 10:16:15.301
CL-202206-NYMEX [C] 2 Day #3 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-04-17. | 2022-04-25 10:16:15.301
CL-202206-NYMEX [C] 2 Day #3 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-02-17. | 2022-04-25 10:16:15.305
CL-202206-NYMEX [C] 2 Day #3 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-03-16. | 2022-04-25 10:16:15.305
CL-202206-NYMEX [C] 2 Day #3 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-01-18. | 2022-04-25 10:16:15.310
CL-202206-NYMEX [C] 2 Day #3 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-02-16. | 2022-04-25 10:16:15.310
CL-202206-NYMEX [C] 2 Day #3 | File CL-198902-NYMEX.dly has a volume of 0 at 1988-12-16. | 2022-04-25 10:16:15.314
CL-202206-NYMEX [C] 2 Day #3 | File CL-198902-NYMEX.dly has a volume of 0 at 1989-01-17. | 2022-04-25 10:16:15.314
CL-202206-NYMEX [C] 2 Day #3 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-11-18. | 2022-04-25 10:16:15.319
CL-202206-NYMEX [C] 2 Day #3 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-12-15. | 2022-04-25 10:16:15.319
CL-202206-NYMEX [C] 2 Day #3 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-10-18. | 2022-04-25 10:16:15.324
CL-202206-NYMEX [C] 2 Day #3 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-11-17. | 2022-04-25 10:16:15.324
CL-202206-NYMEX [C] 2 Day #3 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-09-16. | 2022-04-25 10:16:15.329
CL-202206-NYMEX [C] 2 Day #3 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-10-17. | 2022-04-25 10:16:15.329
CL-202206-NYMEX [C] 2 Day #3 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-08-18. | 2022-04-25 10:16:15.333
CL-202206-NYMEX [C] 2 Day #3 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-09-15. | 2022-04-25 10:16:15.333
CL-202206-NYMEX [C] 2 Day #3 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-07-18. | 2022-04-25 10:16:15.339
CL-202206-NYMEX [C] 2 Day #3 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-08-17. | 2022-04-25 10:16:15.339
CL-202206-NYMEX [C] 2 Day #3 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-06-17. | 2022-04-25 10:16:15.343
CL-202206-NYMEX [C] 2 Day #3 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-07-15. | 2022-04-25 10:16:15.343
CL-202206-NYMEX [C] 2 Day #3 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-05-18. | 2022-04-25 10:16:15.348
CL-202206-NYMEX [C] 2 Day #3 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-06-16. | 2022-04-25 10:16:15.348
CL-202206-NYMEX [C] 2 Day #3 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-04-18. | 2022-04-25 10:16:15.353
CL-202206-NYMEX [C] 2 Day #3 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-05-17. | 2022-04-25 10:16:15.353
CL-202206-NYMEX [C] 2 Day #3 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-03-18. | 2022-04-25 10:16:15.357
CL-202206-NYMEX [C] 2 Day #3 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-04-15. | 2022-04-25 10:16:15.357
CL-202206-NYMEX [C] 2 Day #3 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-02-18. | 2022-04-25 10:16:15.362
CL-202206-NYMEX [C] 2 Day #3 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-03-17. | 2022-04-25 10:16:15.362
CL-202206-NYMEX [C] 2 Day #3 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-01-18. | 2022-04-25 10:16:15.367
CL-202206-NYMEX [C] 2 Day #3 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-02-17. | 2022-04-25 10:16:15.367
CL-202206-NYMEX [C] 2 Day #3 | File CL-198802-NYMEX.dly has a volume of 0 at 1987-12-18. | 2022-04-25 10:16:15.371
CL-202206-NYMEX [C] 2 Day #3 | File CL-198802-NYMEX.dly has a volume of 0 at 1988-01-15. | 2022-04-25 10:16:15.371
CL-202206-NYMEX [C] 2 Day #3 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-11-18. | 2022-04-25 10:16:15.376
CL-202206-NYMEX [C] 2 Day #3 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-12-17. | 2022-04-25 10:16:15.376
CL-202206-NYMEX [C] 2 Day #3 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-10-16. | 2022-04-25 10:16:15.381
CL-202206-NYMEX [C] 2 Day #3 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-11-17. | 2022-04-25 10:16:15.381
CL-202206-NYMEX [C] 2 Day #3 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-09-18. | 2022-04-25 10:16:15.386
CL-202206-NYMEX [C] 2 Day #3 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-10-15. | 2022-04-25 10:16:15.386
CL-202206-NYMEX [C] 2 Day #3 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-08-18. | 2022-04-25 10:16:15.391
CL-202206-NYMEX [C] 2 Day #3 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-09-17. | 2022-04-25 10:16:15.391
CL-202206-NYMEX [C] 2 Day #3 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-07-17. | 2022-04-25 10:16:15.395
CL-202206-NYMEX [C] 2 Day #3 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-08-17. | 2022-04-25 10:16:15.395
CL-202206-NYMEX [C] 2 Day #3 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-06-18. | 2022-04-25 10:16:15.400
CL-202206-NYMEX [C] 2 Day #3 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-07-16. | 2022-04-25 10:16:15.400
CL-202206-NYMEX [C] 2 Day #3 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-05-18. | 2022-04-25 10:16:15.405
CL-202206-NYMEX [C] 2 Day #3 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-06-17. | 2022-04-25 10:16:15.405
CL-202206-NYMEX [C] 2 Day #3 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-04-17. | 2022-04-25 10:16:15.410
CL-202206-NYMEX [C] 2 Day #3 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-05-15. | 2022-04-25 10:16:15.410
CL-202206-NYMEX [C] 2 Day #3 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-03-18. | 2022-04-25 10:16:15.414
CL-202206-NYMEX [C] 2 Day #3 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-04-16. | 2022-04-25 10:16:15.414
CL-202206-NYMEX [C] 2 Day #3 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-02-18. | 2022-04-25 10:16:15.419
CL-202206-NYMEX [C] 2 Day #3 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-03-17. | 2022-04-25 10:16:15.419
CL-202206-NYMEX [C] 2 Day #3 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-01-16. | 2022-04-25 10:16:15.424
CL-202206-NYMEX [C] 2 Day #3 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-02-17. | 2022-04-25 10:16:15.424
CL-202206-NYMEX [C] 2 Day #3 | File CL-198702-NYMEX.dly has a volume of 0 at 1986-12-18. | 2022-04-25 10:16:15.429
CL-202206-NYMEX [C] 2 Day #3 | File CL-198702-NYMEX.dly has a volume of 0 at 1987-01-15. | 2022-04-25 10:16:15.429
CL-202206-NYMEX [C] 2 Day #3 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-11-18. | 2022-04-25 10:16:15.433
CL-202206-NYMEX [C] 2 Day #3 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-12-17. | 2022-04-25 10:16:15.433
CL-202206-NYMEX [C] 2 Day #3 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-10-17. | 2022-04-25 10:16:15.438
CL-202206-NYMEX [C] 2 Day #3 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-11-17. | 2022-04-25 10:16:15.438
CL-202206-NYMEX [C] 2 Day #3 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-09-18. | 2022-04-25 10:16:15.443
CL-202206-NYMEX [C] 2 Day #3 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-10-16. | 2022-04-25 10:16:15.443
CL-202206-NYMEX [C] 2 Day #3 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-08-18. | 2022-04-25 10:16:15.448
CL-202206-NYMEX [C] 2 Day #3 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-09-17. | 2022-04-25 10:16:15.448
CL-202206-NYMEX [C] 2 Day #3 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-07-18. | 2022-04-25 10:16:15.452
CL-202206-NYMEX [C] 2 Day #3 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-08-15. | 2022-04-25 10:16:15.452
CL-202206-NYMEX [C] 2 Day #3 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-06-18. | 2022-04-25 10:16:15.457
CL-202206-NYMEX [C] 2 Day #3 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-07-17. | 2022-04-25 10:16:15.457
CL-202206-NYMEX [C] 2 Day #3 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-05-16. | 2022-04-25 10:16:15.462
CL-202206-NYMEX [C] 2 Day #3 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-06-17. | 2022-04-25 10:16:15.462
CL-202206-NYMEX [C] 2 Day #3 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-04-18. | 2022-04-25 10:16:15.466
CL-202206-NYMEX [C] 2 Day #3 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-05-15. | 2022-04-25 10:16:15.466
CL-202206-NYMEX [C] 2 Day #3 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-03-18. | 2022-04-25 10:16:15.471
CL-202206-NYMEX [C] 2 Day #3 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-04-17. | 2022-04-25 10:16:15.471
CL-202206-NYMEX [C] 2 Day #3 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-02-18. | 2022-04-25 10:16:15.476
CL-202206-NYMEX [C] 2 Day #3 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-03-17. | 2022-04-25 10:16:15.476
CL-202206-NYMEX [C] 2 Day #3 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-01-17. | 2022-04-25 10:16:15.481
CL-202206-NYMEX [C] 2 Day #3 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-02-17. | 2022-04-25 10:16:15.481
CL-202206-NYMEX [C] 2 Day #3 | File CL-198602-NYMEX.dly has a volume of 0 at 1985-12-18. | 2022-04-25 10:16:15.485
CL-202206-NYMEX [C] 2 Day #3 | File CL-198602-NYMEX.dly has a volume of 0 at 1986-01-16. | 2022-04-25 10:16:15.485
CL-202206-NYMEX [C] 2 Day #3 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-11-18. | 2022-04-25 10:16:15.490
CL-202206-NYMEX [C] 2 Day #3 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-12-17. | 2022-04-25 10:16:15.490
CL-202206-NYMEX [C] 2 Day #3 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-10-18. | 2022-04-25 10:16:15.495
CL-202206-NYMEX [C] 2 Day #3 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-11-15. | 2022-04-25 10:16:15.495
CL-202206-NYMEX [C] 2 Day #3 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-09-18. | 2022-04-25 10:16:15.499
CL-202206-NYMEX [C] 2 Day #3 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-10-17. | 2022-04-25 10:16:15.499
CL-202206-NYMEX [C] 2 Day #3 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-08-16. | 2022-04-25 10:16:15.504
CL-202206-NYMEX [C] 2 Day #3 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-09-17. | 2022-04-25 10:16:15.504
CL-202206-NYMEX [C] 2 Day #3 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-07-18. | 2022-04-25 10:16:15.509
CL-202206-NYMEX [C] 2 Day #3 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-08-15. | 2022-04-25 10:16:15.509
CL-202206-NYMEX [C] 2 Day #3 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-06-18. | 2022-04-25 10:16:15.514
CL-202206-NYMEX [C] 2 Day #3 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-07-17. | 2022-04-25 10:16:15.514
CL-202206-NYMEX [C] 2 Day #3 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-05-17. | 2022-04-25 10:16:15.518
CL-202206-NYMEX [C] 2 Day #3 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-06-17. | 2022-04-25 10:16:15.518
CL-202206-NYMEX [C] 2 Day #3 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-04-18. | 2022-04-25 10:16:15.523
CL-202206-NYMEX [C] 2 Day #3 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-05-16. | 2022-04-25 10:16:15.523
CL-202206-NYMEX [C] 2 Day #3 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-03-18. | 2022-04-25 10:16:15.528
CL-202206-NYMEX [C] 2 Day #3 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-04-17. | 2022-04-25 10:16:15.528
CL-202206-NYMEX [C] 2 Day #3 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-02-18. | 2022-04-25 10:16:15.533
CL-202206-NYMEX [C] 2 Day #3 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-03-15. | 2022-04-25 10:16:15.533
CL-202206-NYMEX [C] 2 Day #3 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-01-18. | 2022-04-25 10:16:15.538
CL-202206-NYMEX [C] 2 Day #3 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-02-15. | 2022-04-25 10:16:15.538
CL-202206-NYMEX [C] 2 Day #3 | File CL-198502-NYMEX.dly has a volume of 0 at 1984-12-18. | 2022-04-25 10:16:15.542
CL-202206-NYMEX [C] 2 Day #3 | File CL-198502-NYMEX.dly has a volume of 0 at 1985-01-17. | 2022-04-25 10:16:15.542
CL-202206-NYMEX [C] 2 Day #3 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-11-16. | 2022-04-25 10:16:15.545
CL-202206-NYMEX [C] 2 Day #3 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-12-17. | 2022-04-25 10:16:15.545
CL-202206-NYMEX [C] 2 Day #3 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-10-18. | 2022-04-25 10:16:15.549
CL-202206-NYMEX [C] 2 Day #3 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-11-15. | 2022-04-25 10:16:15.550
CL-202206-NYMEX [C] 2 Day #3 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-09-18. | 2022-04-25 10:16:15.554
CL-202206-NYMEX [C] 2 Day #3 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-10-17. | 2022-04-25 10:16:15.554
CL-202206-NYMEX [C] 2 Day #3 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-08-17. | 2022-04-25 10:16:15.559
CL-202206-NYMEX [C] 2 Day #3 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-09-17. | 2022-04-25 10:16:15.559
CL-202206-NYMEX [C] 2 Day #3 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-07-18. | 2022-04-25 10:16:15.563
CL-202206-NYMEX [C] 2 Day #3 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-08-16. | 2022-04-25 10:16:15.563
CL-202206-NYMEX [C] 2 Day #3 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-06-18. | 2022-04-25 10:16:15.568
CL-202206-NYMEX [C] 2 Day #3 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-07-17. | 2022-04-25 10:16:15.568
CL-202206-NYMEX [C] 2 Day #3 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-05-18. | 2022-04-25 10:16:15.573
CL-202206-NYMEX [C] 2 Day #3 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-06-15. | 2022-04-25 10:16:15.573
CL-202206-NYMEX [C] 2 Day #3 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-04-18. | 2022-04-25 10:16:15.577
CL-202206-NYMEX [C] 2 Day #3 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-05-17. | 2022-04-25 10:16:15.577
CL-202206-NYMEX [C] 2 Day #3 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-03-16. | 2022-04-25 10:16:15.582
CL-202206-NYMEX [C] 2 Day #3 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-04-17. | 2022-04-25 10:16:15.582
CL-202206-NYMEX [C] 2 Day #3 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-02-17. | 2022-04-25 10:16:15.586
CL-202206-NYMEX [C] 2 Day #3 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-03-15. | 2022-04-25 10:16:15.586
CL-202206-NYMEX [C] 2 Day #3 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-01-18. | 2022-04-25 10:16:15.591
CL-202206-NYMEX [C] 2 Day #3 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-02-16. | 2022-04-25 10:16:15.591
CL-202206-NYMEX [C] 2 Day #3 | File CL-198402-NYMEX.dly has a volume of 0 at 1983-12-16. | 2022-04-25 10:16:15.595
CL-202206-NYMEX [C] 2 Day #3 | File CL-198402-NYMEX.dly has a volume of 0 at 1984-01-17. | 2022-04-25 10:16:15.595
CL-202206-NYMEX [C] 2 Day #3 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-11-18. | 2022-04-25 10:16:15.599
CL-202206-NYMEX [C] 2 Day #3 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-12-15. | 2022-04-25 10:16:15.599
CL-202206-NYMEX [C] 2 Day #3 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-10-18. | 2022-04-25 10:16:15.604
CL-202206-NYMEX [C] 2 Day #3 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-11-17. | 2022-04-25 10:16:15.604
CL-202206-NYMEX [C] 2 Day #3 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-09-16. | 2022-04-25 10:16:15.609
CL-202206-NYMEX [C] 2 Day #3 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-10-17. | 2022-04-25 10:16:15.609
CL-202206-NYMEX [C] 2 Day #3 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-08-18. | 2022-04-25 10:16:15.613
CL-202206-NYMEX [C] 2 Day #3 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-09-15. | 2022-04-25 10:16:15.613
CL-202206-NYMEX [C] 2 Day #3 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-07-18. | 2022-04-25 10:16:15.618
CL-202206-NYMEX [C] 2 Day #3 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-08-17. | 2022-04-25 10:16:15.618
CL-202206-NYMEX [C] 2 Day #3 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-06-17. | 2022-04-25 10:16:15.623
CL-202206-NYMEX [C] 2 Day #3 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-07-15. | 2022-04-25 10:16:15.623
CL-202206-NYMEX [C] 2 Day #3 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-05-18. | 2022-04-25 10:16:15.627
CL-202206-NYMEX [C] 2 Day #3 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-06-16. | 2022-04-25 10:16:15.627
CL-202206-NYMEX [C] 2 Day #3 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-04-18. | 2022-04-25 10:16:15.632
CL-202206-NYMEX [C] 2 Day #3 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-05-17. | 2022-04-25 10:16:15.632
HD Request # 80 | Receiving historical Daily data for BRR-201805-CMECRYPTO-USD-5 starting at 2018-05-23 | 2022-04-25 10:16:15.792
HD Request # 80 | Writing historical Daily data to the file BRR-201805-CMECRYPTO-USD-5.dly | 2022-04-25 10:16:15.792
HD Request # 80 | Bytes received: 181 | 2022-04-25 10:16:15.792
HD Request # 80 | Received 4 Daily data records from 2018-05-23 00:00:00 to 2018-05-25 00:00:00 (3.0 days) and wrote 3 records for BRR-201805-CMECRYPTO-USD-5 | 2022-04-25 10:16:15.792
HD Request # 80 | Completion time: 7s | 2022-04-25 10:16:15.793
HD Request # 80 | Daily data download complete for BRR-201805-CMECRYPTO-USD-5. Unique request ID: 25 | 2022-04-25 10:16:15.793
Removing historical data download ID 25. | 2022-04-25 10:16:15.793
Triggering next historical data download in queue. | 2022-04-25 10:16:15.793
Historical data download thread signaled to stop. | 2022-04-25 10:16:15.793
HD Request # 81 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:02.562000 | 2022-04-25 10:16:15.793
HD Request # 81 | Received 24 Intraday data records from 2022-04-25 10:12:11.168000 to 2022-04-25 10:15:52.272001 (3.7 minutes) and wrote 21 records for WCN-NQTV | 2022-04-25 10:16:15.793
HD Request # 81 | Completion time: 3s | 2022-04-25 10:16:15.793
HD Request # 81 | Intraday data download complete for WCN-NQTV. Unique request ID: 213 | 2022-04-25 10:16:15.793
Removing historical data download ID 213. | 2022-04-25 10:16:15.793
Real-time Intraday chart data file updates started for WCN-NQTV | 2022-04-25 10:16:15.793
Intraday chart data file opened for WCN-NQTV | 2022-04-25 10:16:15.793
HD Request # 81 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:16:15.793
Mapping BRR-201901-CMECRYPTO-USD-5 to BTCF19. Service code: cme | 2022-04-25 10:16:15.795
HD Request # 82 | Downloading Historical Daily chart data for BRR-201901-CMECRYPTO-USD-5. Starting date: 2019-01-23. Service: interactive_brokers.trading | 2022-04-25 10:16:15.797
HD Request # 83 | Downloading Intraday chart data for XOM-NQTV to the file XOM-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 10:16:15.797
HD Request # 83 | Download start date-time: 2022-04-25 10:13:01.000000. File last date-time: 2022-04-25 10:13:01.118000 | 2022-04-25 10:16:15.797
HD Request # 83 | Using server: ds25.sierracharts.com port 10150 | 2022-04-25 10:16:15.797
Socket (4) | Creating socket. | 2022-04-25 10:16:15.797
Socket (4) | New receive buffer size: 5242880 | 2022-04-25 10:16:15.797
Socket (4) | Connecting to IP: 38.65.8.115. | 2022-04-25 10:16:15.797
CL-202206-NYMEX [C] 2 Day #6 | Reloading chart. | 2022-04-25 10:16:15.986
CL-202206-NYMEX [C] 2 Day #6 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:16:15.986
CL-202206-NYMEX [C] 2 Day #6 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:16:15.986
HD Request # 83 | Setting DTC encoding to Binary VLS | 2022-04-25 10:16:16.254
HD Request # 83 | Sending historical data logon request message. | 2022-04-25 10:16:16.254
HD Request # 83 | Requesting Intraday data. Start date-time: 2022-04-25 10:13:01. Record interval: 0. Symbol: XOM-NQTV | 2022-04-25 10:16:16.480
HD Request # 83 | Decompressing data. | 2022-04-25 10:16:16.707
HD Request # 83 | Receiving Intraday data for XOM-NQTV starting at 2022-04-25 10:13:01.118000 | 2022-04-25 10:16:16.935
Socket (4) | CloseSocket call. | 2022-04-25 10:16:16.935
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:16:16.935
Socket (4) | Socket gracefully closed by remote side. | 2022-04-25 10:16:17.161
Socket (4) | Closed. | 2022-04-25 10:16:17.161
CL-202206-NYMEX [C] 2 Day #6 | File CL-200102-NYMEX.dly has a volume of 0 at 2000-12-18. | 2022-04-25 10:16:17.911
CL-202206-NYMEX [C] 2 Day #6 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-11-17. | 2022-04-25 10:16:17.916
CL-202206-NYMEX [C] 2 Day #6 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-12-15. | 2022-04-25 10:16:17.916
CL-202206-NYMEX [C] 2 Day #6 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-10-18. | 2022-04-25 10:16:17.921
CL-202206-NYMEX [C] 2 Day #6 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-11-16. | 2022-04-25 10:16:17.921
CL-202206-NYMEX [C] 2 Day #6 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-09-18. | 2022-04-25 10:16:17.925
CL-202206-NYMEX [C] 2 Day #6 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-10-17. | 2022-04-25 10:16:17.925
CL-202206-NYMEX [C] 2 Day #6 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-08-18. | 2022-04-25 10:16:17.930
CL-202206-NYMEX [C] 2 Day #6 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-09-15. | 2022-04-25 10:16:17.930
CL-202206-NYMEX [C] 2 Day #6 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-07-18. | 2022-04-25 10:16:17.935
CL-202206-NYMEX [C] 2 Day #6 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-08-17. | 2022-04-25 10:16:17.935
CL-202206-NYMEX [C] 2 Day #6 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-06-16. | 2022-04-25 10:16:17.940
CL-202206-NYMEX [C] 2 Day #6 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-07-17. | 2022-04-25 10:16:17.940
CL-202206-NYMEX [C] 2 Day #6 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-05-18. | 2022-04-25 10:16:17.945
CL-202206-NYMEX [C] 2 Day #6 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-06-15. | 2022-04-25 10:16:17.945
CL-202206-NYMEX [C] 2 Day #6 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-04-18. | 2022-04-25 10:16:17.949
CL-202206-NYMEX [C] 2 Day #6 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-05-17. | 2022-04-25 10:16:17.949
CL-202206-NYMEX [C] 2 Day #6 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-03-17. | 2022-04-25 10:16:17.954
CL-202206-NYMEX [C] 2 Day #6 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-04-17. | 2022-04-25 10:16:17.954
CL-202206-NYMEX [C] 2 Day #6 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-02-18. | 2022-04-25 10:16:17.958
CL-202206-NYMEX [C] 2 Day #6 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-03-16. | 2022-04-25 10:16:17.958
CL-202206-NYMEX [C] 2 Day #6 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-01-18. | 2022-04-25 10:16:17.963
CL-202206-NYMEX [C] 2 Day #6 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-02-17. | 2022-04-25 10:16:17.963
CL-202206-NYMEX [C] 2 Day #6 | File CL-200002-NYMEX.dly has a volume of 0 at 1999-12-17. | 2022-04-25 10:16:17.968
CL-202206-NYMEX [C] 2 Day #6 | File CL-200002-NYMEX.dly has a volume of 0 at 2000-01-17. | 2022-04-25 10:16:17.968
CL-202206-NYMEX [C] 2 Day #6 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-11-18. | 2022-04-25 10:16:17.972
CL-202206-NYMEX [C] 2 Day #6 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-12-16. | 2022-04-25 10:16:17.972
CL-202206-NYMEX [C] 2 Day #6 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-10-18. | 2022-04-25 10:16:17.978
CL-202206-NYMEX [C] 2 Day #6 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-11-17. | 2022-04-25 10:16:17.978
CL-202206-NYMEX [C] 2 Day #6 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-09-17. | 2022-04-25 10:16:17.982
CL-202206-NYMEX [C] 2 Day #6 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-10-15. | 2022-04-25 10:16:17.982
CL-202206-NYMEX [C] 2 Day #6 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-08-18. | 2022-04-25 10:16:17.987
CL-202206-NYMEX [C] 2 Day #6 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-09-16. | 2022-04-25 10:16:17.987
CL-202206-NYMEX [C] 2 Day #6 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-07-16. | 2022-04-25 10:16:17.992
CL-202206-NYMEX [C] 2 Day #6 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-08-17. | 2022-04-25 10:16:17.992
CL-202206-NYMEX [C] 2 Day #6 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-06-18. | 2022-04-25 10:16:17.997
CL-202206-NYMEX [C] 2 Day #6 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-07-15. | 2022-04-25 10:16:17.997
CL-202206-NYMEX [C] 2 Day #6 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-05-18. | 2022-04-25 10:16:18.002
CL-202206-NYMEX [C] 2 Day #6 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-06-17. | 2022-04-25 10:16:18.002
CL-202206-NYMEX [C] 2 Day #6 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-04-16. | 2022-04-25 10:16:18.006
CL-202206-NYMEX [C] 2 Day #6 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-05-17. | 2022-04-25 10:16:18.006
CL-202206-NYMEX [C] 2 Day #6 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-03-18. | 2022-04-25 10:16:18.011
CL-202206-NYMEX [C] 2 Day #6 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-04-15. | 2022-04-25 10:16:18.011
CL-202206-NYMEX [C] 2 Day #6 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-02-18. | 2022-04-25 10:16:18.016
CL-202206-NYMEX [C] 2 Day #6 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-03-17. | 2022-04-25 10:16:18.016
CL-202206-NYMEX [C] 2 Day #6 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-01-18. | 2022-04-25 10:16:18.021
CL-202206-NYMEX [C] 2 Day #6 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-02-17. | 2022-04-25 10:16:18.021
CL-202206-NYMEX [C] 2 Day #6 | File CL-199902-NYMEX.dly has a volume of 0 at 1998-12-18. | 2022-04-25 10:16:18.025
CL-202206-NYMEX [C] 2 Day #6 | File CL-199902-NYMEX.dly has a volume of 0 at 1999-01-15. | 2022-04-25 10:16:18.025
CL-202206-NYMEX [C] 2 Day #6 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-11-18. | 2022-04-25 10:16:18.030
CL-202206-NYMEX [C] 2 Day #6 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-12-17. | 2022-04-25 10:16:18.030
CL-202206-NYMEX [C] 2 Day #6 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-10-16. | 2022-04-25 10:16:18.035
CL-202206-NYMEX [C] 2 Day #6 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-11-17. | 2022-04-25 10:16:18.035
CL-202206-NYMEX [C] 2 Day #6 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-09-18. | 2022-04-25 10:16:18.039
CL-202206-NYMEX [C] 2 Day #6 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-10-15. | 2022-04-25 10:16:18.039
CL-202206-NYMEX [C] 2 Day #6 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-08-18. | 2022-04-25 10:16:18.044
CL-202206-NYMEX [C] 2 Day #6 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-09-17. | 2022-04-25 10:16:18.044
CL-202206-NYMEX [C] 2 Day #6 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-07-17. | 2022-04-25 10:16:18.049
CL-202206-NYMEX [C] 2 Day #6 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-08-17. | 2022-04-25 10:16:18.049
CL-202206-NYMEX [C] 2 Day #6 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-06-18. | 2022-04-25 10:16:18.054
CL-202206-NYMEX [C] 2 Day #6 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-07-16. | 2022-04-25 10:16:18.054
CL-202206-NYMEX [C] 2 Day #6 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-05-18. | 2022-04-25 10:16:18.058
CL-202206-NYMEX [C] 2 Day #6 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-06-17. | 2022-04-25 10:16:18.058
CL-202206-NYMEX [C] 2 Day #6 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-04-17. | 2022-04-25 10:16:18.063
CL-202206-NYMEX [C] 2 Day #6 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-05-15. | 2022-04-25 10:16:18.063
CL-202206-NYMEX [C] 2 Day #6 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-03-18. | 2022-04-25 10:16:18.068
CL-202206-NYMEX [C] 2 Day #6 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-04-16. | 2022-04-25 10:16:18.068
CL-202206-NYMEX [C] 2 Day #6 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-02-18. | 2022-04-25 10:16:18.072
CL-202206-NYMEX [C] 2 Day #6 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-03-17. | 2022-04-25 10:16:18.072
CL-202206-NYMEX [C] 2 Day #6 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-01-16. | 2022-04-25 10:16:18.077
CL-202206-NYMEX [C] 2 Day #6 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-02-17. | 2022-04-25 10:16:18.077
CL-202206-NYMEX [C] 2 Day #6 | File CL-199802-NYMEX.dly has a volume of 0 at 1997-12-18. | 2022-04-25 10:16:18.082
CL-202206-NYMEX [C] 2 Day #6 | File CL-199802-NYMEX.dly has a volume of 0 at 1998-01-15. | 2022-04-25 10:16:18.082
CL-202206-NYMEX [C] 2 Day #6 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-11-18. | 2022-04-25 10:16:18.086
CL-202206-NYMEX [C] 2 Day #6 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-12-17. | 2022-04-25 10:16:18.086
CL-202206-NYMEX [C] 2 Day #6 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-10-17. | 2022-04-25 10:16:18.091
CL-202206-NYMEX [C] 2 Day #6 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-11-17. | 2022-04-25 10:16:18.091
CL-202206-NYMEX [C] 2 Day #6 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-09-18. | 2022-04-25 10:16:18.096
CL-202206-NYMEX [C] 2 Day #6 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-10-16. | 2022-04-25 10:16:18.096
CL-202206-NYMEX [C] 2 Day #6 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-08-18. | 2022-04-25 10:16:18.100
CL-202206-NYMEX [C] 2 Day #6 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-09-17. | 2022-04-25 10:16:18.100
CL-202206-NYMEX [C] 2 Day #6 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-07-18. | 2022-04-25 10:16:18.105
CL-202206-NYMEX [C] 2 Day #6 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-08-15. | 2022-04-25 10:16:18.105
CL-202206-NYMEX [C] 2 Day #6 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-06-18. | 2022-04-25 10:16:18.110
CL-202206-NYMEX [C] 2 Day #6 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-07-17. | 2022-04-25 10:16:18.110
CL-202206-NYMEX [C] 2 Day #6 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-05-16. | 2022-04-25 10:16:18.115
CL-202206-NYMEX [C] 2 Day #6 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-06-17. | 2022-04-25 10:16:18.115
CL-202206-NYMEX [C] 2 Day #6 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-04-18. | 2022-04-25 10:16:18.119
CL-202206-NYMEX [C] 2 Day #6 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-05-15. | 2022-04-25 10:16:18.119
CL-202206-NYMEX [C] 2 Day #6 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-03-18. | 2022-04-25 10:16:18.124
CL-202206-NYMEX [C] 2 Day #6 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-04-17. | 2022-04-25 10:16:18.124
CL-202206-NYMEX [C] 2 Day #6 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-02-18. | 2022-04-25 10:16:18.129
CL-202206-NYMEX [C] 2 Day #6 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-03-17. | 2022-04-25 10:16:18.129
CL-202206-NYMEX [C] 2 Day #6 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-01-17. | 2022-04-25 10:16:18.134
CL-202206-NYMEX [C] 2 Day #6 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-02-17. | 2022-04-25 10:16:18.134
CL-202206-NYMEX [C] 2 Day #6 | File CL-199702-NYMEX.dly has a volume of 0 at 1996-12-18. | 2022-04-25 10:16:18.138
CL-202206-NYMEX [C] 2 Day #6 | File CL-199702-NYMEX.dly has a volume of 0 at 1997-01-16. | 2022-04-25 10:16:18.138
CL-202206-NYMEX [C] 2 Day #6 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-11-18. | 2022-04-25 10:16:18.143
CL-202206-NYMEX [C] 2 Day #6 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-12-17. | 2022-04-25 10:16:18.143
CL-202206-NYMEX [C] 2 Day #6 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-10-18. | 2022-04-25 10:16:18.147
CL-202206-NYMEX [C] 2 Day #6 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-11-15. | 2022-04-25 10:16:18.147
CL-202206-NYMEX [C] 2 Day #6 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-09-18. | 2022-04-25 10:16:18.152
CL-202206-NYMEX [C] 2 Day #6 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-10-17. | 2022-04-25 10:16:18.152
CL-202206-NYMEX [C] 2 Day #6 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-08-16. | 2022-04-25 10:16:18.157
CL-202206-NYMEX [C] 2 Day #6 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-09-17. | 2022-04-25 10:16:18.157
CL-202206-NYMEX [C] 2 Day #6 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-07-18. | 2022-04-25 10:16:18.162
CL-202206-NYMEX [C] 2 Day #6 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-08-15. | 2022-04-25 10:16:18.162
CL-202206-NYMEX [C] 2 Day #6 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-06-18. | 2022-04-25 10:16:18.166
CL-202206-NYMEX [C] 2 Day #6 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-07-17. | 2022-04-25 10:16:18.166
CL-202206-NYMEX [C] 2 Day #6 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-05-17. | 2022-04-25 10:16:18.171
CL-202206-NYMEX [C] 2 Day #6 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-06-17. | 2022-04-25 10:16:18.171
CL-202206-NYMEX [C] 2 Day #6 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-04-18. | 2022-04-25 10:16:18.176
CL-202206-NYMEX [C] 2 Day #6 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-05-16. | 2022-04-25 10:16:18.176
CL-202206-NYMEX [C] 2 Day #6 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-03-18. | 2022-04-25 10:16:18.181
CL-202206-NYMEX [C] 2 Day #6 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-04-17. | 2022-04-25 10:16:18.181
CL-202206-NYMEX [C] 2 Day #6 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-02-16. | 2022-04-25 10:16:18.186
CL-202206-NYMEX [C] 2 Day #6 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-03-15. | 2022-04-25 10:16:18.186
CL-202206-NYMEX [C] 2 Day #6 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-01-18. | 2022-04-25 10:16:18.190
CL-202206-NYMEX [C] 2 Day #6 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-02-15. | 2022-04-25 10:16:18.190
CL-202206-NYMEX [C] 2 Day #6 | File CL-199602-NYMEX.dly has a volume of 0 at 1995-12-18. | 2022-04-25 10:16:18.195
CL-202206-NYMEX [C] 2 Day #6 | File CL-199602-NYMEX.dly has a volume of 0 at 1996-01-17. | 2022-04-25 10:16:18.195
CL-202206-NYMEX [C] 2 Day #6 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-11-17. | 2022-04-25 10:16:18.200
CL-202206-NYMEX [C] 2 Day #6 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-12-15. | 2022-04-25 10:16:18.200
CL-202206-NYMEX [C] 2 Day #6 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-10-18. | 2022-04-25 10:16:18.204
CL-202206-NYMEX [C] 2 Day #6 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-11-16. | 2022-04-25 10:16:18.204
CL-202206-NYMEX [C] 2 Day #6 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-09-18. | 2022-04-25 10:16:18.209
CL-202206-NYMEX [C] 2 Day #6 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-10-17. | 2022-04-25 10:16:18.209
CL-202206-NYMEX [C] 2 Day #6 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-08-18. | 2022-04-25 10:16:18.214
CL-202206-NYMEX [C] 2 Day #6 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-09-15. | 2022-04-25 10:16:18.214
CL-202206-NYMEX [C] 2 Day #6 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-07-18. | 2022-04-25 10:16:18.219
CL-202206-NYMEX [C] 2 Day #6 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-08-17. | 2022-04-25 10:16:18.219
CL-202206-NYMEX [C] 2 Day #6 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-06-16. | 2022-04-25 10:16:18.224
CL-202206-NYMEX [C] 2 Day #6 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-07-17. | 2022-04-25 10:16:18.224
CL-202206-NYMEX [C] 2 Day #6 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-05-18. | 2022-04-25 10:16:18.228
CL-202206-NYMEX [C] 2 Day #6 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-06-15. | 2022-04-25 10:16:18.228
CL-202206-NYMEX [C] 2 Day #6 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-04-18. | 2022-04-25 10:16:18.233
CL-202206-NYMEX [C] 2 Day #6 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-05-17. | 2022-04-25 10:16:18.233
CL-202206-NYMEX [C] 2 Day #6 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-03-17. | 2022-04-25 10:16:18.238
CL-202206-NYMEX [C] 2 Day #6 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-04-17. | 2022-04-25 10:16:18.238
CL-202206-NYMEX [C] 2 Day #6 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-02-17. | 2022-04-25 10:16:18.242
CL-202206-NYMEX [C] 2 Day #6 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-03-16. | 2022-04-25 10:16:18.242
CL-202206-NYMEX [C] 2 Day #6 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-01-18. | 2022-04-25 10:16:18.247
CL-202206-NYMEX [C] 2 Day #6 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-02-16. | 2022-04-25 10:16:18.247
CL-202206-NYMEX [C] 2 Day #6 | File CL-199502-NYMEX.dly has a volume of 0 at 1994-12-16. | 2022-04-25 10:16:18.252
CL-202206-NYMEX [C] 2 Day #6 | File CL-199502-NYMEX.dly has a volume of 0 at 1995-01-17. | 2022-04-25 10:16:18.252
CL-202206-NYMEX [C] 2 Day #6 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-11-18. | 2022-04-25 10:16:18.256
CL-202206-NYMEX [C] 2 Day #6 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-12-15. | 2022-04-25 10:16:18.256
CL-202206-NYMEX [C] 2 Day #6 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-10-18. | 2022-04-25 10:16:18.261
CL-202206-NYMEX [C] 2 Day #6 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-11-17. | 2022-04-25 10:16:18.261
CL-202206-NYMEX [C] 2 Day #6 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-09-16. | 2022-04-25 10:16:18.266
CL-202206-NYMEX [C] 2 Day #6 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-10-17. | 2022-04-25 10:16:18.266
CL-202206-NYMEX [C] 2 Day #6 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-08-18. | 2022-04-25 10:16:18.270
CL-202206-NYMEX [C] 2 Day #6 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-09-15. | 2022-04-25 10:16:18.270
CL-202206-NYMEX [C] 2 Day #6 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-07-18. | 2022-04-25 10:16:18.276
CL-202206-NYMEX [C] 2 Day #6 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-08-17. | 2022-04-25 10:16:18.276
CL-202206-NYMEX [C] 2 Day #6 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-06-17. | 2022-04-25 10:16:18.280
CL-202206-NYMEX [C] 2 Day #6 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-07-15. | 2022-04-25 10:16:18.280
CL-202206-NYMEX [C] 2 Day #6 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-05-18. | 2022-04-25 10:16:18.285
CL-202206-NYMEX [C] 2 Day #6 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-06-16. | 2022-04-25 10:16:18.285
CL-202206-NYMEX [C] 2 Day #6 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-04-18. | 2022-04-25 10:16:18.290
CL-202206-NYMEX [C] 2 Day #6 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-05-17. | 2022-04-25 10:16:18.290
CL-202206-NYMEX [C] 2 Day #6 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-03-18. | 2022-04-25 10:16:18.295
CL-202206-NYMEX [C] 2 Day #6 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-04-15. | 2022-04-25 10:16:18.295
CL-202206-NYMEX [C] 2 Day #6 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-02-18. | 2022-04-25 10:16:18.299
CL-202206-NYMEX [C] 2 Day #6 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-03-17. | 2022-04-25 10:16:18.299
CL-202206-NYMEX [C] 2 Day #6 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-01-18. | 2022-04-25 10:16:18.304
CL-202206-NYMEX [C] 2 Day #6 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-02-17. | 2022-04-25 10:16:18.304
CL-202206-NYMEX [C] 2 Day #6 | File CL-199402-NYMEX.dly has a volume of 0 at 1993-12-17. | 2022-04-25 10:16:18.309
CL-202206-NYMEX [C] 2 Day #6 | File CL-199402-NYMEX.dly has a volume of 0 at 1994-01-17. | 2022-04-25 10:16:18.309
CL-202206-NYMEX [C] 2 Day #6 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-11-18. | 2022-04-25 10:16:18.313
CL-202206-NYMEX [C] 2 Day #6 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-12-16. | 2022-04-25 10:16:18.313
CL-202206-NYMEX [C] 2 Day #6 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-10-18. | 2022-04-25 10:16:18.318
CL-202206-NYMEX [C] 2 Day #6 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-11-17. | 2022-04-25 10:16:18.318
CL-202206-NYMEX [C] 2 Day #6 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-09-17. | 2022-04-25 10:16:18.323
CL-202206-NYMEX [C] 2 Day #6 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-10-15. | 2022-04-25 10:16:18.323
CL-202206-NYMEX [C] 2 Day #6 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-08-18. | 2022-04-25 10:16:18.328
CL-202206-NYMEX [C] 2 Day #6 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-09-16. | 2022-04-25 10:16:18.328
CL-202206-NYMEX [C] 2 Day #6 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-07-16. | 2022-04-25 10:16:18.333
CL-202206-NYMEX [C] 2 Day #6 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-08-17. | 2022-04-25 10:16:18.333
CL-202206-NYMEX [C] 2 Day #6 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-06-18. | 2022-04-25 10:16:18.338
CL-202206-NYMEX [C] 2 Day #6 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-07-15. | 2022-04-25 10:16:18.338
CL-202206-NYMEX [C] 2 Day #6 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-05-18. | 2022-04-25 10:16:18.343
CL-202206-NYMEX [C] 2 Day #6 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-06-17. | 2022-04-25 10:16:18.343
CL-202206-NYMEX [C] 2 Day #6 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-04-16. | 2022-04-25 10:16:18.348
CL-202206-NYMEX [C] 2 Day #6 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-05-17. | 2022-04-25 10:16:18.348
CL-202206-NYMEX [C] 2 Day #6 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-03-18. | 2022-04-25 10:16:18.352
CL-202206-NYMEX [C] 2 Day #6 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-04-15. | 2022-04-25 10:16:18.352
CL-202206-NYMEX [C] 2 Day #6 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-02-18. | 2022-04-25 10:16:18.357
CL-202206-NYMEX [C] 2 Day #6 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-03-17. | 2022-04-25 10:16:18.357
CL-202206-NYMEX [C] 2 Day #6 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-01-18. | 2022-04-25 10:16:18.362
CL-202206-NYMEX [C] 2 Day #6 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-02-17. | 2022-04-25 10:16:18.362
CL-202206-NYMEX [C] 2 Day #6 | File CL-199302-NYMEX.dly has a volume of 0 at 1992-12-18. | 2022-04-25 10:16:18.367
CL-202206-NYMEX [C] 2 Day #6 | File CL-199302-NYMEX.dly has a volume of 0 at 1993-01-15. | 2022-04-25 10:16:18.367
CL-202206-NYMEX [C] 2 Day #6 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-11-18. | 2022-04-25 10:16:18.372
CL-202206-NYMEX [C] 2 Day #6 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-12-17. | 2022-04-25 10:16:18.372
CL-202206-NYMEX [C] 2 Day #6 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-10-16. | 2022-04-25 10:16:18.377
CL-202206-NYMEX [C] 2 Day #6 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-11-17. | 2022-04-25 10:16:18.377
CL-202206-NYMEX [C] 2 Day #6 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-09-18. | 2022-04-25 10:16:18.381
CL-202206-NYMEX [C] 2 Day #6 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-10-15. | 2022-04-25 10:16:18.381
CL-202206-NYMEX [C] 2 Day #6 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-08-18. | 2022-04-25 10:16:18.387
CL-202206-NYMEX [C] 2 Day #6 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-09-17. | 2022-04-25 10:16:18.387
CL-202206-NYMEX [C] 2 Day #6 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-07-17. | 2022-04-25 10:16:18.392
CL-202206-NYMEX [C] 2 Day #6 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-08-17. | 2022-04-25 10:16:18.392
CL-202206-NYMEX [C] 2 Day #6 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-06-18. | 2022-04-25 10:16:18.396
CL-202206-NYMEX [C] 2 Day #6 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-07-16. | 2022-04-25 10:16:18.396
CL-202206-NYMEX [C] 2 Day #6 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-05-18. | 2022-04-25 10:16:18.401
CL-202206-NYMEX [C] 2 Day #6 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-06-17. | 2022-04-25 10:16:18.401
CL-202206-NYMEX [C] 2 Day #6 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-04-17. | 2022-04-25 10:16:18.406
CL-202206-NYMEX [C] 2 Day #6 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-05-15. | 2022-04-25 10:16:18.406
CL-202206-NYMEX [C] 2 Day #6 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-03-18. | 2022-04-25 10:16:18.410
CL-202206-NYMEX [C] 2 Day #6 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-04-16. | 2022-04-25 10:16:18.410
CL-202206-NYMEX [C] 2 Day #6 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-02-18. | 2022-04-25 10:16:18.415
CL-202206-NYMEX [C] 2 Day #6 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-03-17. | 2022-04-25 10:16:18.415
CL-202206-NYMEX [C] 2 Day #6 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-01-17. | 2022-04-25 10:16:18.420
CL-202206-NYMEX [C] 2 Day #6 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-02-17. | 2022-04-25 10:16:18.420
CL-202206-NYMEX [C] 2 Day #6 | File CL-199202-NYMEX.dly has a volume of 0 at 1991-12-18. | 2022-04-25 10:16:18.424
CL-202206-NYMEX [C] 2 Day #6 | File CL-199202-NYMEX.dly has a volume of 0 at 1992-01-16. | 2022-04-25 10:16:18.424
CL-202206-NYMEX [C] 2 Day #6 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-11-18. | 2022-04-25 10:16:18.429
CL-202206-NYMEX [C] 2 Day #6 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-12-17. | 2022-04-25 10:16:18.429
CL-202206-NYMEX [C] 2 Day #6 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-10-18. | 2022-04-25 10:16:18.434
CL-202206-NYMEX [C] 2 Day #6 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-11-15. | 2022-04-25 10:16:18.434
CL-202206-NYMEX [C] 2 Day #6 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-09-18. | 2022-04-25 10:16:18.439
CL-202206-NYMEX [C] 2 Day #6 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-10-17. | 2022-04-25 10:16:18.439
CL-202206-NYMEX [C] 2 Day #6 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-08-16. | 2022-04-25 10:16:18.443
CL-202206-NYMEX [C] 2 Day #6 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-09-17. | 2022-04-25 10:16:18.443
CL-202206-NYMEX [C] 2 Day #6 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-07-18. | 2022-04-25 10:16:18.448
CL-202206-NYMEX [C] 2 Day #6 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-08-15. | 2022-04-25 10:16:18.448
CL-202206-NYMEX [C] 2 Day #6 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-06-18. | 2022-04-25 10:16:18.453
CL-202206-NYMEX [C] 2 Day #6 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-07-17. | 2022-04-25 10:16:18.453
CL-202206-NYMEX [C] 2 Day #6 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-05-17. | 2022-04-25 10:16:18.458
CL-202206-NYMEX [C] 2 Day #6 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-06-17. | 2022-04-25 10:16:18.458
CL-202206-NYMEX [C] 2 Day #6 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-04-18. | 2022-04-25 10:16:18.462
CL-202206-NYMEX [C] 2 Day #6 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-05-16. | 2022-04-25 10:16:18.462
CL-202206-NYMEX [C] 2 Day #6 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-03-18. | 2022-04-25 10:16:18.467
CL-202206-NYMEX [C] 2 Day #6 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-04-17. | 2022-04-25 10:16:18.467
CL-202206-NYMEX [C] 2 Day #6 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-02-18. | 2022-04-25 10:16:18.472
CL-202206-NYMEX [C] 2 Day #6 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-03-15. | 2022-04-25 10:16:18.472
CL-202206-NYMEX [C] 2 Day #6 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-01-18. | 2022-04-25 10:16:18.476
CL-202206-NYMEX [C] 2 Day #6 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-02-15. | 2022-04-25 10:16:18.476
CL-202206-NYMEX [C] 2 Day #6 | File CL-199102-NYMEX.dly has a volume of 0 at 1990-12-18. | 2022-04-25 10:16:18.481
CL-202206-NYMEX [C] 2 Day #6 | File CL-199102-NYMEX.dly has a volume of 0 at 1991-01-17. | 2022-04-25 10:16:18.481
CL-202206-NYMEX [C] 2 Day #6 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-11-16. | 2022-04-25 10:16:18.485
CL-202206-NYMEX [C] 2 Day #6 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-12-17. | 2022-04-25 10:16:18.485
CL-202206-NYMEX [C] 2 Day #6 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-10-18. | 2022-04-25 10:16:18.490
CL-202206-NYMEX [C] 2 Day #6 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-11-15. | 2022-04-25 10:16:18.490
CL-202206-NYMEX [C] 2 Day #6 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-09-18. | 2022-04-25 10:16:18.495
CL-202206-NYMEX [C] 2 Day #6 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-10-17. | 2022-04-25 10:16:18.495
CL-202206-NYMEX [C] 2 Day #6 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-08-17. | 2022-04-25 10:16:18.499
CL-202206-NYMEX [C] 2 Day #6 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-09-17. | 2022-04-25 10:16:18.499
CL-202206-NYMEX [C] 2 Day #6 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-07-18. | 2022-04-25 10:16:18.504
CL-202206-NYMEX [C] 2 Day #6 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-08-16. | 2022-04-25 10:16:18.504
CL-202206-NYMEX [C] 2 Day #6 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-06-18. | 2022-04-25 10:16:18.509
CL-202206-NYMEX [C] 2 Day #6 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-07-17. | 2022-04-25 10:16:18.509
CL-202206-NYMEX [C] 2 Day #6 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-05-18. | 2022-04-25 10:16:18.513
CL-202206-NYMEX [C] 2 Day #6 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-06-15. | 2022-04-25 10:16:18.513
CL-202206-NYMEX [C] 2 Day #6 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-04-18. | 2022-04-25 10:16:18.518
CL-202206-NYMEX [C] 2 Day #6 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-05-17. | 2022-04-25 10:16:18.518
CL-202206-NYMEX [C] 2 Day #6 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-03-16. | 2022-04-25 10:16:18.523
CL-202206-NYMEX [C] 2 Day #6 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-04-17. | 2022-04-25 10:16:18.523
CL-202206-NYMEX [C] 2 Day #6 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-02-16. | 2022-04-25 10:16:18.527
CL-202206-NYMEX [C] 2 Day #6 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-03-15. | 2022-04-25 10:16:18.527
CL-202206-NYMEX [C] 2 Day #6 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-01-18. | 2022-04-25 10:16:18.532
CL-202206-NYMEX [C] 2 Day #6 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-02-15. | 2022-04-25 10:16:18.532
CL-202206-NYMEX [C] 2 Day #6 | File CL-199002-NYMEX.dly has a volume of 0 at 1989-12-18. | 2022-04-25 10:16:18.537
CL-202206-NYMEX [C] 2 Day #6 | File CL-199002-NYMEX.dly has a volume of 0 at 1990-01-17. | 2022-04-25 10:16:18.537
CL-202206-NYMEX [C] 2 Day #6 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-11-17. | 2022-04-25 10:16:18.541
CL-202206-NYMEX [C] 2 Day #6 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-12-15. | 2022-04-25 10:16:18.541
CL-202206-NYMEX [C] 2 Day #6 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-10-18. | 2022-04-25 10:16:18.546
CL-202206-NYMEX [C] 2 Day #6 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-11-16. | 2022-04-25 10:16:18.546
CL-202206-NYMEX [C] 2 Day #6 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-09-18. | 2022-04-25 10:16:18.551
CL-202206-NYMEX [C] 2 Day #6 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-10-17. | 2022-04-25 10:16:18.551
CL-202206-NYMEX [C] 2 Day #6 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-08-18. | 2022-04-25 10:16:18.556
CL-202206-NYMEX [C] 2 Day #6 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-09-15. | 2022-04-25 10:16:18.556
CL-202206-NYMEX [C] 2 Day #6 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-07-18. | 2022-04-25 10:16:18.561
CL-202206-NYMEX [C] 2 Day #6 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-08-17. | 2022-04-25 10:16:18.561
CL-202206-NYMEX [C] 2 Day #6 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-06-16. | 2022-04-25 10:16:18.566
CL-202206-NYMEX [C] 2 Day #6 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-07-17. | 2022-04-25 10:16:18.566
CL-202206-NYMEX [C] 2 Day #6 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-05-18. | 2022-04-25 10:16:18.570
CL-202206-NYMEX [C] 2 Day #6 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-06-15. | 2022-04-25 10:16:18.570
CL-202206-NYMEX [C] 2 Day #6 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-04-18. | 2022-04-25 10:16:18.575
CL-202206-NYMEX [C] 2 Day #6 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-05-17. | 2022-04-25 10:16:18.575
CL-202206-NYMEX [C] 2 Day #6 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-03-17. | 2022-04-25 10:16:18.580
CL-202206-NYMEX [C] 2 Day #6 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-04-17. | 2022-04-25 10:16:18.580
CL-202206-NYMEX [C] 2 Day #6 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-02-17. | 2022-04-25 10:16:18.584
CL-202206-NYMEX [C] 2 Day #6 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-03-16. | 2022-04-25 10:16:18.584
CL-202206-NYMEX [C] 2 Day #6 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-01-18. | 2022-04-25 10:16:18.589
CL-202206-NYMEX [C] 2 Day #6 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-02-16. | 2022-04-25 10:16:18.589
CL-202206-NYMEX [C] 2 Day #6 | File CL-198902-NYMEX.dly has a volume of 0 at 1988-12-16. | 2022-04-25 10:16:18.594
CL-202206-NYMEX [C] 2 Day #6 | File CL-198902-NYMEX.dly has a volume of 0 at 1989-01-17. | 2022-04-25 10:16:18.594
CL-202206-NYMEX [C] 2 Day #6 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-11-18. | 2022-04-25 10:16:18.598
CL-202206-NYMEX [C] 2 Day #6 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-12-15. | 2022-04-25 10:16:18.598
CL-202206-NYMEX [C] 2 Day #6 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-10-18. | 2022-04-25 10:16:18.603
CL-202206-NYMEX [C] 2 Day #6 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-11-17. | 2022-04-25 10:16:18.603
CL-202206-NYMEX [C] 2 Day #6 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-09-16. | 2022-04-25 10:16:18.608
CL-202206-NYMEX [C] 2 Day #6 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-10-17. | 2022-04-25 10:16:18.608
CL-202206-NYMEX [C] 2 Day #6 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-08-18. | 2022-04-25 10:16:18.612
CL-202206-NYMEX [C] 2 Day #6 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-09-15. | 2022-04-25 10:16:18.612
CL-202206-NYMEX [C] 2 Day #6 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-07-18. | 2022-04-25 10:16:18.617
CL-202206-NYMEX [C] 2 Day #6 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-08-17. | 2022-04-25 10:16:18.617
CL-202206-NYMEX [C] 2 Day #6 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-06-17. | 2022-04-25 10:16:18.622
CL-202206-NYMEX [C] 2 Day #6 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-07-15. | 2022-04-25 10:16:18.622
CL-202206-NYMEX [C] 2 Day #6 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-05-18. | 2022-04-25 10:16:18.627
CL-202206-NYMEX [C] 2 Day #6 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-06-16. | 2022-04-25 10:16:18.627
CL-202206-NYMEX [C] 2 Day #6 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-04-18. | 2022-04-25 10:16:18.631
CL-202206-NYMEX [C] 2 Day #6 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-05-17. | 2022-04-25 10:16:18.631
CL-202206-NYMEX [C] 2 Day #6 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-03-18. | 2022-04-25 10:16:18.636
CL-202206-NYMEX [C] 2 Day #6 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-04-15. | 2022-04-25 10:16:18.636
CL-202206-NYMEX [C] 2 Day #6 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-02-18. | 2022-04-25 10:16:18.641
CL-202206-NYMEX [C] 2 Day #6 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-03-17. | 2022-04-25 10:16:18.641
CL-202206-NYMEX [C] 2 Day #6 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-01-18. | 2022-04-25 10:16:18.646
CL-202206-NYMEX [C] 2 Day #6 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-02-17. | 2022-04-25 10:16:18.646
CL-202206-NYMEX [C] 2 Day #6 | File CL-198802-NYMEX.dly has a volume of 0 at 1987-12-18. | 2022-04-25 10:16:18.650
CL-202206-NYMEX [C] 2 Day #6 | File CL-198802-NYMEX.dly has a volume of 0 at 1988-01-15. | 2022-04-25 10:16:18.650
CL-202206-NYMEX [C] 2 Day #6 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-11-18. | 2022-04-25 10:16:18.655
CL-202206-NYMEX [C] 2 Day #6 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-12-17. | 2022-04-25 10:16:18.655
CL-202206-NYMEX [C] 2 Day #6 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-10-16. | 2022-04-25 10:16:18.660
CL-202206-NYMEX [C] 2 Day #6 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-11-17. | 2022-04-25 10:16:18.660
CL-202206-NYMEX [C] 2 Day #6 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-09-18. | 2022-04-25 10:16:18.664
CL-202206-NYMEX [C] 2 Day #6 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-10-15. | 2022-04-25 10:16:18.664
CL-202206-NYMEX [C] 2 Day #6 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-08-18. | 2022-04-25 10:16:18.669
CL-202206-NYMEX [C] 2 Day #6 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-09-17. | 2022-04-25 10:16:18.669
CL-202206-NYMEX [C] 2 Day #6 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-07-17. | 2022-04-25 10:16:18.674
CL-202206-NYMEX [C] 2 Day #6 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-08-17. | 2022-04-25 10:16:18.674
CL-202206-NYMEX [C] 2 Day #6 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-06-18. | 2022-04-25 10:16:18.679
CL-202206-NYMEX [C] 2 Day #6 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-07-16. | 2022-04-25 10:16:18.679
CL-202206-NYMEX [C] 2 Day #6 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-05-18. | 2022-04-25 10:16:18.684
CL-202206-NYMEX [C] 2 Day #6 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-06-17. | 2022-04-25 10:16:18.684
CL-202206-NYMEX [C] 2 Day #6 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-04-17. | 2022-04-25 10:16:18.688
CL-202206-NYMEX [C] 2 Day #6 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-05-15. | 2022-04-25 10:16:18.688
CL-202206-NYMEX [C] 2 Day #6 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-03-18. | 2022-04-25 10:16:18.693
CL-202206-NYMEX [C] 2 Day #6 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-04-16. | 2022-04-25 10:16:18.693
CL-202206-NYMEX [C] 2 Day #6 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-02-18. | 2022-04-25 10:16:18.698
CL-202206-NYMEX [C] 2 Day #6 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-03-17. | 2022-04-25 10:16:18.698
CL-202206-NYMEX [C] 2 Day #6 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-01-16. | 2022-04-25 10:16:18.703
CL-202206-NYMEX [C] 2 Day #6 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-02-17. | 2022-04-25 10:16:18.703
CL-202206-NYMEX [C] 2 Day #6 | File CL-198702-NYMEX.dly has a volume of 0 at 1986-12-18. | 2022-04-25 10:16:18.707
CL-202206-NYMEX [C] 2 Day #6 | File CL-198702-NYMEX.dly has a volume of 0 at 1987-01-15. | 2022-04-25 10:16:18.707
CL-202206-NYMEX [C] 2 Day #6 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-11-18. | 2022-04-25 10:16:18.712
CL-202206-NYMEX [C] 2 Day #6 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-12-17. | 2022-04-25 10:16:18.712
CL-202206-NYMEX [C] 2 Day #6 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-10-17. | 2022-04-25 10:16:18.717
CL-202206-NYMEX [C] 2 Day #6 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-11-17. | 2022-04-25 10:16:18.717
CL-202206-NYMEX [C] 2 Day #6 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-09-18. | 2022-04-25 10:16:18.721
CL-202206-NYMEX [C] 2 Day #6 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-10-16. | 2022-04-25 10:16:18.721
CL-202206-NYMEX [C] 2 Day #6 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-08-18. | 2022-04-25 10:16:18.726
CL-202206-NYMEX [C] 2 Day #6 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-09-17. | 2022-04-25 10:16:18.726
CL-202206-NYMEX [C] 2 Day #6 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-07-18. | 2022-04-25 10:16:18.731
CL-202206-NYMEX [C] 2 Day #6 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-08-15. | 2022-04-25 10:16:18.731
CL-202206-NYMEX [C] 2 Day #6 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-06-18. | 2022-04-25 10:16:18.735
CL-202206-NYMEX [C] 2 Day #6 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-07-17. | 2022-04-25 10:16:18.735
CL-202206-NYMEX [C] 2 Day #6 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-05-16. | 2022-04-25 10:16:18.740
CL-202206-NYMEX [C] 2 Day #6 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-06-17. | 2022-04-25 10:16:18.740
CL-202206-NYMEX [C] 2 Day #6 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-04-18. | 2022-04-25 10:16:18.745
CL-202206-NYMEX [C] 2 Day #6 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-05-15. | 2022-04-25 10:16:18.745
CL-202206-NYMEX [C] 2 Day #6 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-03-18. | 2022-04-25 10:16:18.750
CL-202206-NYMEX [C] 2 Day #6 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-04-17. | 2022-04-25 10:16:18.750
CL-202206-NYMEX [C] 2 Day #6 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-02-18. | 2022-04-25 10:16:18.754
CL-202206-NYMEX [C] 2 Day #6 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-03-17. | 2022-04-25 10:16:18.754
CL-202206-NYMEX [C] 2 Day #6 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-01-17. | 2022-04-25 10:16:18.759
CL-202206-NYMEX [C] 2 Day #6 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-02-17. | 2022-04-25 10:16:18.759
CL-202206-NYMEX [C] 2 Day #6 | File CL-198602-NYMEX.dly has a volume of 0 at 1985-12-18. | 2022-04-25 10:16:18.764
CL-202206-NYMEX [C] 2 Day #6 | File CL-198602-NYMEX.dly has a volume of 0 at 1986-01-16. | 2022-04-25 10:16:18.764
CL-202206-NYMEX [C] 2 Day #6 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-11-18. | 2022-04-25 10:16:18.768
CL-202206-NYMEX [C] 2 Day #6 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-12-17. | 2022-04-25 10:16:18.768
CL-202206-NYMEX [C] 2 Day #6 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-10-18. | 2022-04-25 10:16:18.773
CL-202206-NYMEX [C] 2 Day #6 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-11-15. | 2022-04-25 10:16:18.773
CL-202206-NYMEX [C] 2 Day #6 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-09-18. | 2022-04-25 10:16:18.777
CL-202206-NYMEX [C] 2 Day #6 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-10-17. | 2022-04-25 10:16:18.777
CL-202206-NYMEX [C] 2 Day #6 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-08-16. | 2022-04-25 10:16:18.782
CL-202206-NYMEX [C] 2 Day #6 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-09-17. | 2022-04-25 10:16:18.782
CL-202206-NYMEX [C] 2 Day #6 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-07-18. | 2022-04-25 10:16:18.787
CL-202206-NYMEX [C] 2 Day #6 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-08-15. | 2022-04-25 10:16:18.787
CL-202206-NYMEX [C] 2 Day #6 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-06-18. | 2022-04-25 10:16:18.792
CL-202206-NYMEX [C] 2 Day #6 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-07-17. | 2022-04-25 10:16:18.792
CL-202206-NYMEX [C] 2 Day #6 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-05-17. | 2022-04-25 10:16:18.796
CL-202206-NYMEX [C] 2 Day #6 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-06-17. | 2022-04-25 10:16:18.796
CL-202206-NYMEX [C] 2 Day #6 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-04-18. | 2022-04-25 10:16:18.801
CL-202206-NYMEX [C] 2 Day #6 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-05-16. | 2022-04-25 10:16:18.801
CL-202206-NYMEX [C] 2 Day #6 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-03-18. | 2022-04-25 10:16:18.806
CL-202206-NYMEX [C] 2 Day #6 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-04-17. | 2022-04-25 10:16:18.806
CL-202206-NYMEX [C] 2 Day #6 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-02-18. | 2022-04-25 10:16:18.810
CL-202206-NYMEX [C] 2 Day #6 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-03-15. | 2022-04-25 10:16:18.810
CL-202206-NYMEX [C] 2 Day #6 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-01-18. | 2022-04-25 10:16:18.815
CL-202206-NYMEX [C] 2 Day #6 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-02-15. | 2022-04-25 10:16:18.815
CL-202206-NYMEX [C] 2 Day #6 | File CL-198502-NYMEX.dly has a volume of 0 at 1984-12-18. | 2022-04-25 10:16:18.819
CL-202206-NYMEX [C] 2 Day #6 | File CL-198502-NYMEX.dly has a volume of 0 at 1985-01-17. | 2022-04-25 10:16:18.819
CL-202206-NYMEX [C] 2 Day #6 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-11-16. | 2022-04-25 10:16:18.823
CL-202206-NYMEX [C] 2 Day #6 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-12-17. | 2022-04-25 10:16:18.823
CL-202206-NYMEX [C] 2 Day #6 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-10-18. | 2022-04-25 10:16:18.827
CL-202206-NYMEX [C] 2 Day #6 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-11-15. | 2022-04-25 10:16:18.827
CL-202206-NYMEX [C] 2 Day #6 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-09-18. | 2022-04-25 10:16:18.831
CL-202206-NYMEX [C] 2 Day #6 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-10-17. | 2022-04-25 10:16:18.831
CL-202206-NYMEX [C] 2 Day #6 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-08-17. | 2022-04-25 10:16:18.836
CL-202206-NYMEX [C] 2 Day #6 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-09-17. | 2022-04-25 10:16:18.836
CL-202206-NYMEX [C] 2 Day #6 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-07-18. | 2022-04-25 10:16:18.840
CL-202206-NYMEX [C] 2 Day #6 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-08-16. | 2022-04-25 10:16:18.840
CL-202206-NYMEX [C] 2 Day #6 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-06-18. | 2022-04-25 10:16:18.845
CL-202206-NYMEX [C] 2 Day #6 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-07-17. | 2022-04-25 10:16:18.845
CL-202206-NYMEX [C] 2 Day #6 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-05-18. | 2022-04-25 10:16:18.849
CL-202206-NYMEX [C] 2 Day #6 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-06-15. | 2022-04-25 10:16:18.849
CL-202206-NYMEX [C] 2 Day #6 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-04-18. | 2022-04-25 10:16:18.854
CL-202206-NYMEX [C] 2 Day #6 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-05-17. | 2022-04-25 10:16:18.854
CL-202206-NYMEX [C] 2 Day #6 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-03-16. | 2022-04-25 10:16:18.858
CL-202206-NYMEX [C] 2 Day #6 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-04-17. | 2022-04-25 10:16:18.858
CL-202206-NYMEX [C] 2 Day #6 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-02-17. | 2022-04-25 10:16:18.862
CL-202206-NYMEX [C] 2 Day #6 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-03-15. | 2022-04-25 10:16:18.862
CL-202206-NYMEX [C] 2 Day #6 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-01-18. | 2022-04-25 10:16:18.867
CL-202206-NYMEX [C] 2 Day #6 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-02-16. | 2022-04-25 10:16:18.867
CL-202206-NYMEX [C] 2 Day #6 | File CL-198402-NYMEX.dly has a volume of 0 at 1983-12-16. | 2022-04-25 10:16:18.872
CL-202206-NYMEX [C] 2 Day #6 | File CL-198402-NYMEX.dly has a volume of 0 at 1984-01-17. | 2022-04-25 10:16:18.872
CL-202206-NYMEX [C] 2 Day #6 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-11-18. | 2022-04-25 10:16:18.875
CL-202206-NYMEX [C] 2 Day #6 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-12-15. | 2022-04-25 10:16:18.875
CL-202206-NYMEX [C] 2 Day #6 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-10-18. | 2022-04-25 10:16:18.880
CL-202206-NYMEX [C] 2 Day #6 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-11-17. | 2022-04-25 10:16:18.880
CL-202206-NYMEX [C] 2 Day #6 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-09-16. | 2022-04-25 10:16:18.885
CL-202206-NYMEX [C] 2 Day #6 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-10-17. | 2022-04-25 10:16:18.885
CL-202206-NYMEX [C] 2 Day #6 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-08-18. | 2022-04-25 10:16:18.889
CL-202206-NYMEX [C] 2 Day #6 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-09-15. | 2022-04-25 10:16:18.889
CL-202206-NYMEX [C] 2 Day #6 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-07-18. | 2022-04-25 10:16:18.894
CL-202206-NYMEX [C] 2 Day #6 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-08-17. | 2022-04-25 10:16:18.894
CL-202206-NYMEX [C] 2 Day #6 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-06-17. | 2022-04-25 10:16:18.898
CL-202206-NYMEX [C] 2 Day #6 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-07-15. | 2022-04-25 10:16:18.898
CL-202206-NYMEX [C] 2 Day #6 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-05-18. | 2022-04-25 10:16:18.903
CL-202206-NYMEX [C] 2 Day #6 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-06-16. | 2022-04-25 10:16:18.903
CL-202206-NYMEX [C] 2 Day #6 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-04-18. | 2022-04-25 10:16:18.907
CL-202206-NYMEX [C] 2 Day #6 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-05-17. | 2022-04-25 10:16:18.907
Historical data download thread signaled to stop. | 2022-04-25 10:16:19.066
HD Request # 83 | Timestamp of first Intraday data file record written: 2022-04-25 10:13:02.753000 | 2022-04-25 10:16:19.066
HD Request # 83 | Received 749 Intraday data records from 2022-04-25 10:13:01.118000 to 2022-04-25 10:16:11.059001 (3.2 minutes) and wrote 748 records for XOM-NQTV | 2022-04-25 10:16:19.066
HD Request # 83 | Completion time: 4s | 2022-04-25 10:16:19.066
HD Request # 83 | Intraday data download complete for XOM-NQTV. Unique request ID: 216 | 2022-04-25 10:16:19.066
Removing historical data download ID 216. | 2022-04-25 10:16:19.066
Real-time Intraday chart data file updates started for XOM-NQTV | 2022-04-25 10:16:19.066
Intraday chart data file opened for XOM-NQTV | 2022-04-25 10:16:19.066
HD Request # 83 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:16:19.066
Triggering next historical data download in queue. | 2022-04-25 10:16:19.066
HD Request # 84 | Downloading Intraday chart data for MBT-202203-CMECRYPTO-USD-0.1 to the file MBT-202203-CMECRYPTO-USD-0.1.scid. Service: cme | 2022-04-25 10:16:19.066
HD Request # 84 | Download start date-time: 2022-03-25 11:57:22.000000. File last date-time: 2022-03-25 11:57:22.987000 | 2022-04-25 10:16:19.066
HD Request # 84 | Using server: ds23.sierracharts.com port 10149 | 2022-04-25 10:16:19.066
Socket (4) | Creating socket. | 2022-04-25 10:16:19.067
Socket (4) | New receive buffer size: 5242880 | 2022-04-25 10:16:19.067
Socket (4) | Connecting to IP: 216.1.90.130. | 2022-04-25 10:16:19.067
Opened cached Intraday file: C:\SierraChart\Data\FWONK-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:16:19.155
Opened cached Intraday file: C:\SierraChart\Data\VIRT-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:16:19.156
SC Data - All Services | Starting real-time market data updates for: CL-202206-NYMEX (CLM22). ID: 112 Service code: nymex | 2022-04-25 10:16:19.207
SC Data - All Services | Requesting security definition data for: CL-202206-NYMEX (CLM22). ID: 112 | 2022-04-25 10:16:19.207
SC Data - All Services | Received security definition for symbol CL-202206-NYMEX | 2022-04-25 10:16:19.433
HD Request # 84 | Setting DTC encoding to Binary VLS | 2022-04-25 10:16:19.522
HD Request # 84 | Sending historical data logon request message. | 2022-04-25 10:16:19.522
HD Request # 82 | Requesting historical Daily data for BTF19 starting at 2019-01-22. SC External HD service. | 2022-04-25 10:16:20.140
HD Request # 84 | Requesting Intraday data. Start date-time: 2022-03-25 11:57:22. Record interval: 0. Symbol: MBTH22 | 2022-04-25 10:16:20.233
HD Request # 84 | Decompressing data. | 2022-04-25 10:16:20.471
HD Request # 84 | Receiving Intraday data for MBT-202203-CMECRYPTO-USD-0.1 starting at 2022-03-25 11:57:22.987000 | 2022-04-25 10:16:20.472
Socket (4) | CloseSocket call. | 2022-04-25 10:16:20.472
Historical data download thread signaled to stop. | 2022-04-25 10:16:20.472
HD Request # 84 | Received 1 Intraday data record from 2022-03-25 11:57:22.987000 to 2022-03-25 11:57:22.987000 (0.0 seconds) and wrote 0 records for MBT-202203-CMECRYPTO-USD-0.1 | 2022-04-25 10:16:20.472
HD Request # 84 | Completion time: 1s | 2022-04-25 10:16:20.472
HD Request # 84 | Intraday data download complete for MBT-202203-CMECRYPTO-USD-0.1. Unique request ID: 219 | 2022-04-25 10:16:20.472
Removing historical data download ID 219. | 2022-04-25 10:16:20.472
Real-time Intraday chart data file updates started for MBT-202203-CMECRYPTO-USD-0.1 | 2022-04-25 10:16:20.472
Intraday chart data file opened for MBT-202203-CMECRYPTO-USD-0.1 | 2022-04-25 10:16:20.472
HD Request # 84 | Enabling Intraday chart updating for symbol. | 2022-04-25 10:16:20.472
Triggering next historical data download in queue. | 2022-04-25 10:16:20.472
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-04-25 10:16:20.472
No download requests in the queue to start downloads for. | 2022-04-25 10:16:20.472
Socket (4) | Socket gracefully closed by remote side. | 2022-04-25 10:16:20.689
Socket (4) | Closed. | 2022-04-25 10:16:20.689
HD Request # 82 | Receiving historical Daily data for BRR-201901-CMECRYPTO-USD-5 starting at 2019-01-23 | 2022-04-25 10:16:20.978
HD Request # 82 | Writing historical Daily data to the file BRR-201901-CMECRYPTO-USD-5.dly | 2022-04-25 10:16:20.978
HD Request # 82 | Bytes received: 183 | 2022-04-25 10:16:20.979
HD Request # 82 | Received 4 Daily data records from 2019-01-23 00:00:00 to 2019-01-25 00:00:00 (3.0 days) and wrote 3 records for BRR-201901-CMECRYPTO-USD-5 | 2022-04-25 10:16:20.979
HD Request # 82 | Completion time: 5s | 2022-04-25 10:16:20.979
HD Request # 82 | Daily data download complete for BRR-201901-CMECRYPTO-USD-5. Unique request ID: 26 | 2022-04-25 10:16:20.979
Removing historical data download ID 26. | 2022-04-25 10:16:20.979
Triggering next historical data download in queue. | 2022-04-25 10:16:20.979
Mapping BRR-201902-CMECRYPTO-USD-5 to BTCG19. Service code: cme | 2022-04-25 10:16:20.980
HD Request # 85 | Downloading Historical Daily chart data for BRR-201902-CMECRYPTO-USD-5. Starting date: 2019-02-20. Service: interactive_brokers.trading | 2022-04-25 10:16:20.982
HD Request # 85 | Requesting historical Daily data for BTG19 starting at 2019-02-19. SC External HD service. | 2022-04-25 10:16:22.402
HD Request # 85 | Receiving historical Daily data for BRR-201902-CMECRYPTO-USD-5 starting at 2019-02-20 | 2022-04-25 10:16:23.228
HD Request # 85 | Writing historical Daily data to the file BRR-201902-CMECRYPTO-USD-5.dly | 2022-04-25 10:16:23.228
HD Request # 85 | Bytes received: 184 | 2022-04-25 10:16:23.228
HD Request # 85 | Received 4 Daily data records from 2019-02-20 00:00:00 to 2019-02-22 00:00:00 (3.0 days) and wrote 3 records for BRR-201902-CMECRYPTO-USD-5 | 2022-04-25 10:16:23.228
HD Request # 85 | Completion time: 3s | 2022-04-25 10:16:23.229
HD Request # 85 | Daily data download complete for BRR-201902-CMECRYPTO-USD-5. Unique request ID: 27 | 2022-04-25 10:16:23.229
Removing historical data download ID 27. | 2022-04-25 10:16:23.229
Triggering next historical data download in queue. | 2022-04-25 10:16:23.229
Mapping BRR-201910-CMECRYPTO-USD-5 to BTCV19. Service code: cme | 2022-04-25 10:16:23.229
HD Request # 86 | Downloading Historical Daily chart data for BRR-201910-CMECRYPTO-USD-5. Starting date: 2019-10-23. Service: interactive_brokers.trading | 2022-04-25 10:16:23.231
Opened cached Intraday file: C:\SierraChart\Data\XOM-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:16:24.197
HD Request # 86 | Requesting historical Daily data for BTV19 starting at 2019-10-22. SC External HD service. | 2022-04-25 10:16:24.638
HD Request # 86 | Receiving historical Daily data for BRR-201910-CMECRYPTO-USD-5 starting at 2019-10-23 | 2022-04-25 10:16:25.466
HD Request # 86 | Writing historical Daily data to the file BRR-201910-CMECRYPTO-USD-5.dly | 2022-04-25 10:16:25.466
HD Request # 86 | Bytes received: 183 | 2022-04-25 10:16:25.467
HD Request # 86 | Received 4 Daily data records from 2019-10-23 00:00:00 to 2019-10-25 00:00:00 (3.0 days) and wrote 3 records for BRR-201910-CMECRYPTO-USD-5 | 2022-04-25 10:16:25.467
HD Request # 86 | Completion time: 2s | 2022-04-25 10:16:25.467
HD Request # 86 | Daily data download complete for BRR-201910-CMECRYPTO-USD-5. Unique request ID: 28 | 2022-04-25 10:16:25.467
Removing historical data download ID 28. | 2022-04-25 10:16:25.467
Triggering next historical data download in queue. | 2022-04-25 10:16:25.467
Mapping BRR-202004-CMECRYPTO-USD-5 to BTCJ20. Service code: cme | 2022-04-25 10:16:25.467
HD Request # 87 | Downloading Historical Daily chart data for BRR-202004-CMECRYPTO-USD-5. Starting date: 2020-04-22. Service: interactive_brokers.trading | 2022-04-25 10:16:25.469
HD Request # 87 | Requesting historical Daily data for BTJ20 starting at 2020-04-21. SC External HD service. | 2022-04-25 10:16:26.891
HD Request # 87 | Receiving historical Daily data for BRR-202004-CMECRYPTO-USD-5 starting at 2020-04-22 | 2022-04-25 10:16:27.707
HD Request # 87 | Writing historical Daily data to the file BRR-202004-CMECRYPTO-USD-5.dly | 2022-04-25 10:16:27.708
HD Request # 87 | Bytes received: 185 | 2022-04-25 10:16:27.709
HD Request # 87 | Received 4 Daily data records from 2020-04-22 00:00:00 to 2020-04-24 00:00:00 (3.0 days) and wrote 3 records for BRR-202004-CMECRYPTO-USD-5 | 2022-04-25 10:16:27.709
HD Request # 87 | Completion time: 2s | 2022-04-25 10:16:27.709
HD Request # 87 | Daily data download complete for BRR-202004-CMECRYPTO-USD-5. Unique request ID: 29 | 2022-04-25 10:16:27.709
Removing historical data download ID 29. | 2022-04-25 10:16:27.709
Triggering next historical data download in queue. | 2022-04-25 10:16:27.709
Mapping BRR-202012-CMECRYPTO-USD-5 to BTCZ20. Service code: cme | 2022-04-25 10:16:27.709
HD Request # 88 | Downloading Historical Daily chart data for BRR-202012-CMECRYPTO-USD-5. Starting date: 2020-12-22. Service: interactive_brokers.trading | 2022-04-25 10:16:27.711
HD Request # 88 | Requesting historical Daily data for BTZ20 starting at 2020-12-21. SC External HD service. | 2022-04-25 10:16:29.156
Opened cached Intraday file: C:\SierraChart\Data\ACRS-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:16:29.232
Opened cached Intraday file: C:\SierraChart\Data\TSN-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:16:29.233
HD Request # 88 | Receiving historical Daily data for BRR-202012-CMECRYPTO-USD-5 starting at 2020-12-22 | 2022-04-25 10:16:29.930
HD Request # 88 | Writing historical Daily data to the file BRR-202012-CMECRYPTO-USD-5.dly | 2022-04-25 10:16:29.930
HD Request # 88 | Bytes received: 202 | 2022-04-25 10:16:29.932
HD Request # 88 | Received 4 Daily data records from 2020-12-22 00:00:00 to 2020-12-24 00:00:00 (3.0 days) and wrote 3 records for BRR-202012-CMECRYPTO-USD-5 | 2022-04-25 10:16:29.932
HD Request # 88 | Completion time: 2s | 2022-04-25 10:16:29.932
HD Request # 88 | Daily data download complete for BRR-202012-CMECRYPTO-USD-5. Unique request ID: 30 | 2022-04-25 10:16:29.932
Removing historical data download ID 30. | 2022-04-25 10:16:29.932
Triggering next historical data download in queue. | 2022-04-25 10:16:29.932
Mapping BRR-202109-CMECRYPTO-USD-5 to BTCU21. Service code: cme | 2022-04-25 10:16:29.933
HD Request # 89 | Downloading Historical Daily chart data for BRR-202109-CMECRYPTO-USD-5. Starting date: 2021-09-22. Service: interactive_brokers.trading | 2022-04-25 10:16:29.934
HD Request # 89 | Requesting historical Daily data for BTU21 starting at 2021-09-21. SC External HD service. | 2022-04-25 10:16:31.365
HD Request # 89 | Receiving historical Daily data for BRR-202109-CMECRYPTO-USD-5 starting at 2021-09-22 | 2022-04-25 10:16:32.178
HD Request # 89 | Writing historical Daily data to the file BRR-202109-CMECRYPTO-USD-5.dly | 2022-04-25 10:16:32.178
HD Request # 89 | Bytes received: 201 | 2022-04-25 10:16:32.179
HD Request # 89 | Received 4 Daily data records from 2021-09-22 00:00:00 to 2021-09-24 00:00:00 (3.0 days) and wrote 3 records for BRR-202109-CMECRYPTO-USD-5 | 2022-04-25 10:16:32.179
HD Request # 89 | Completion time: 3s | 2022-04-25 10:16:32.179
HD Request # 89 | Daily data download complete for BRR-202109-CMECRYPTO-USD-5. Unique request ID: 31 | 2022-04-25 10:16:32.179
Removing historical data download ID 31. | 2022-04-25 10:16:32.179
Triggering next historical data download in queue. | 2022-04-25 10:16:32.179
Mapping BRR-202203-CMECRYPTO-USD-5 to BTCH22. Service code: cme | 2022-04-25 10:16:32.179
HD Request # 90 | Downloading Historical Daily chart data for BRR-202203-CMECRYPTO-USD-5. Starting date: 2022-03-23. Service: interactive_brokers.trading | 2022-04-25 10:16:32.181
HD Request # 90 | Requesting historical Daily data for BTH22 starting at 2022-03-22. SC External HD service. | 2022-04-25 10:16:33.602
Opened cached Intraday file: C:\SierraChart\Data\WCN-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:16:34.276
HD Request # 90 | Receiving historical Daily data for BRR-202203-CMECRYPTO-USD-5 starting at 2022-03-23 | 2022-04-25 10:16:34.424
HD Request # 90 | Writing historical Daily data to the file BRR-202203-CMECRYPTO-USD-5.dly | 2022-04-25 10:16:34.424
HD Request # 90 | Bytes received: 202 | 2022-04-25 10:16:34.425
HD Request # 90 | Received 4 Daily data records from 2022-03-23 00:00:00 to 2022-03-25 00:00:00 (3.0 days) and wrote 3 records for BRR-202203-CMECRYPTO-USD-5 | 2022-04-25 10:16:34.425
HD Request # 90 | Completion time: 2s | 2022-04-25 10:16:34.425
HD Request # 90 | Daily data download complete for BRR-202203-CMECRYPTO-USD-5. Unique request ID: 32 | 2022-04-25 10:16:34.425
Removing historical data download ID 32. | 2022-04-25 10:16:34.425
Triggering next historical data download in queue. | 2022-04-25 10:16:34.426
Mapping MBT-201606-CMECRYPTO-USD-0.1 to MBTM16. Service code: cme | 2022-04-25 10:16:34.426
HD Request # 91 | Downloading Historical Daily chart data for MBT-201606-CMECRYPTO-USD-0.1. Starting date: 2016-06-08. Service: interactive_brokers.trading | 2022-04-25 10:16:34.427
BRR-202203-CMECRYPTO-USD-5 [C] 2 Day #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:16:34.430
BRR-202203-CMECRYPTO-USD-5 [C] 2 Day #3 | Reloading chart. | 2022-04-25 10:16:34.431
BRR-202203-CMECRYPTO-USD-5 [C] 8 Day #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:16:34.487
BRR-202203-CMECRYPTO-USD-5 [C] 8 Day #1 | Reloading chart. | 2022-04-25 10:16:34.488
BRR-202203-CMECRYPTO-USD-5 [C] 16 Day #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:16:34.614
BRR-202203-CMECRYPTO-USD-5 [C] 16 Day #2 | Reloading chart. | 2022-04-25 10:16:34.615
BRR-202203-CMECRYPTO-USD-5 [C] 2 Day #3 | StartDateTimeForLoadingOrderFills: 2017-12-28 00:00:00 | 2022-04-25 10:16:34.670
BRR-202203-CMECRYPTO-USD-5 [C] 2 Day #3 | Reloading chart. | 2022-04-25 10:16:34.747
BRR-202203-CMECRYPTO-USD-5 [C] 2 Day #3 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:16:34.747
BRR-202203-CMECRYPTO-USD-5 [C] 2 Day #3 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:16:34.747
BRR-202203-CMECRYPTO-USD-5 [C] 8 Day #1 | Reloading chart. | 2022-04-25 10:16:35.636
BRR-202203-CMECRYPTO-USD-5 [C] 8 Day #1 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:16:35.636
BRR-202203-CMECRYPTO-USD-5 [C] 8 Day #1 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:16:35.636
BRR-202203-CMECRYPTO-USD-5 [C] 2 Day #3 | StartDateTimeForLoadingOrderFills: 2017-12-28 00:00:00 | 2022-04-25 10:16:36.541
BRR-202203-CMECRYPTO-USD-5 [C] 16 Day #2 | Reloading chart. | 2022-04-25 10:16:36.545
BRR-202203-CMECRYPTO-USD-5 [C] 16 Day #2 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:16:36.545
BRR-202203-CMECRYPTO-USD-5 [C] 16 Day #2 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:16:36.545
HD Request # 91 | Requesting historical Daily data for BAM16 starting at 2016-06-07. SC External HD service. | 2022-04-25 10:16:37.451
SC Data - All Services | Starting real-time market data updates for: BRR-202203-CMECRYPTO-USD-5 (BTCH22). ID: 120 Service code: cme | 2022-04-25 10:16:37.592
SC Data - All Services | Requesting security definition data for: BRR-202203-CMECRYPTO-USD-5 (BTCH22). ID: 120 | 2022-04-25 10:16:37.592
SC Data - All Services | Real-time data for symbol BRR-202203-CMECRYPTO-USD-5 is currently unavailable. | 2022-04-25 10:16:37.881
SC Data - All Services | Received security definition for symbol BRR-202203-CMECRYPTO-USD-5 | 2022-04-25 10:16:37.881
HD Request # 91 | Receiving historical Daily data for MBT-201606-CMECRYPTO-USD-0.1 starting at 2016-06-08 | 2022-04-25 10:16:38.356
HD Request # 91 | Writing historical Daily data to the file MBT-201606-CMECRYPTO-USD-0.1.dly | 2022-04-25 10:16:38.356
HD Request # 91 | Bytes received: 165 | 2022-04-25 10:16:38.356
HD Request # 91 | Received 4 Daily data records from 2016-06-08 00:00:00 to 2016-06-10 00:00:00 (3.0 days) and wrote 3 records for MBT-201606-CMECRYPTO-USD-0.1 | 2022-04-25 10:16:38.356
HD Request # 91 | Completion time: 4s | 2022-04-25 10:16:38.356
HD Request # 91 | Daily data download complete for MBT-201606-CMECRYPTO-USD-0.1. Unique request ID: 33 | 2022-04-25 10:16:38.356
Removing historical data download ID 33. | 2022-04-25 10:16:38.356
Triggering next historical data download in queue. | 2022-04-25 10:16:38.356
Mapping MBT-201607-CMECRYPTO-USD-0.1 to MBTN16. Service code: cme | 2022-04-25 10:16:38.356
HD Request # 92 | Downloading Historical Daily chart data for MBT-201607-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:16:38.357
HD Request # 92 | Requesting historical Daily data for BAN16 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:16:39.791
HD Request # 92 | Bytes received: 1 | 2022-04-25 10:16:40.612
HD Request # 92 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201607-CMECRYPTO-USD-0.1 | 2022-04-25 10:16:40.612
HD Request # 92 | Completion time: 2s | 2022-04-25 10:16:40.612
HD Request # 92 | Daily data download complete for MBT-201607-CMECRYPTO-USD-0.1. Unique request ID: 34 | 2022-04-25 10:16:40.612
Removing historical data download ID 34. | 2022-04-25 10:16:40.612
Triggering next historical data download in queue. | 2022-04-25 10:16:40.612
Mapping MBT-201608-CMECRYPTO-USD-0.1 to MBTQ16. Service code: cme | 2022-04-25 10:16:40.612
HD Request # 93 | Downloading Historical Daily chart data for MBT-201608-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:16:40.613
HD Request # 93 | Requesting historical Daily data for BAQ16 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:16:42.026
HD Request # 93 | Bytes received: 1 | 2022-04-25 10:16:42.782
HD Request # 93 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201608-CMECRYPTO-USD-0.1 | 2022-04-25 10:16:42.782
HD Request # 93 | Completion time: 2s | 2022-04-25 10:16:42.782
HD Request # 93 | Daily data download complete for MBT-201608-CMECRYPTO-USD-0.1. Unique request ID: 35 | 2022-04-25 10:16:42.782
Removing historical data download ID 35. | 2022-04-25 10:16:42.782
Triggering next historical data download in queue. | 2022-04-25 10:16:42.783
Mapping MBT-201609-CMECRYPTO-USD-0.1 to MBTU16. Service code: cme | 2022-04-25 10:16:42.783
HD Request # 94 | Downloading Historical Daily chart data for MBT-201609-CMECRYPTO-USD-0.1. Starting date: 2016-09-14. Service: interactive_brokers.trading | 2022-04-25 10:16:42.784
HD Request # 94 | Requesting historical Daily data for BAU16 starting at 2016-09-13. SC External HD service. | 2022-04-25 10:16:44.211
Opened cached Intraday file: C:\SierraChart\Data\HCC-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:16:44.386
Opened cached Intraday file: C:\SierraChart\Data\AMX-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:16:44.387
HD Request # 94 | Receiving historical Daily data for MBT-201609-CMECRYPTO-USD-0.1 starting at 2016-09-14 | 2022-04-25 10:16:45.023
HD Request # 94 | Writing historical Daily data to the file MBT-201609-CMECRYPTO-USD-0.1.dly | 2022-04-25 10:16:45.023
HD Request # 94 | Bytes received: 168 | 2022-04-25 10:16:45.024
HD Request # 94 | Received 4 Daily data records from 2016-09-14 00:00:00 to 2016-09-16 00:00:00 (3.0 days) and wrote 3 records for MBT-201609-CMECRYPTO-USD-0.1 | 2022-04-25 10:16:45.024
HD Request # 94 | Completion time: 3s | 2022-04-25 10:16:45.024
HD Request # 94 | Daily data download complete for MBT-201609-CMECRYPTO-USD-0.1. Unique request ID: 36 | 2022-04-25 10:16:45.024
Removing historical data download ID 36. | 2022-04-25 10:16:45.024
Triggering next historical data download in queue. | 2022-04-25 10:16:45.024
Mapping MBT-201610-CMECRYPTO-USD-0.1 to MBTV16. Service code: cme | 2022-04-25 10:16:45.024
HD Request # 95 | Downloading Historical Daily chart data for MBT-201610-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:16:45.025
HD Request # 95 | Requesting historical Daily data for BAV16 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:16:46.455
HD Request # 95 | Bytes received: 1 | 2022-04-25 10:16:47.282
HD Request # 95 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201610-CMECRYPTO-USD-0.1 | 2022-04-25 10:16:47.282
HD Request # 95 | Completion time: 2s | 2022-04-25 10:16:47.282
HD Request # 95 | Daily data download complete for MBT-201610-CMECRYPTO-USD-0.1. Unique request ID: 37 | 2022-04-25 10:16:47.282
Removing historical data download ID 37. | 2022-04-25 10:16:47.282
Triggering next historical data download in queue. | 2022-04-25 10:16:47.282
Mapping MBT-201611-CMECRYPTO-USD-0.1 to MBTX16. Service code: cme | 2022-04-25 10:16:47.282
HD Request # 96 | Downloading Historical Daily chart data for MBT-201611-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:16:47.283
HD Request # 96 | Requesting historical Daily data for BAX16 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:16:48.698
HD Request # 96 | Bytes received: 1 | 2022-04-25 10:16:49.473
HD Request # 96 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201611-CMECRYPTO-USD-0.1 | 2022-04-25 10:16:49.473
HD Request # 96 | Completion time: 2s | 2022-04-25 10:16:49.473
HD Request # 96 | Daily data download complete for MBT-201611-CMECRYPTO-USD-0.1. Unique request ID: 38 | 2022-04-25 10:16:49.473
Removing historical data download ID 38. | 2022-04-25 10:16:49.473
Triggering next historical data download in queue. | 2022-04-25 10:16:49.473
Mapping MBT-201612-CMECRYPTO-USD-0.1 to MBTZ16. Service code: cme | 2022-04-25 10:16:49.473
HD Request # 97 | Downloading Historical Daily chart data for MBT-201612-CMECRYPTO-USD-0.1. Starting date: 2016-12-14. Service: interactive_brokers.trading | 2022-04-25 10:16:49.475
HD Request # 97 | Requesting historical Daily data for BAZ16 starting at 2016-12-13. SC External HD service. | 2022-04-25 10:16:50.888
HD Request # 97 | Receiving historical Daily data for MBT-201612-CMECRYPTO-USD-0.1 starting at 2016-12-14 | 2022-04-25 10:16:51.648
HD Request # 97 | Writing historical Daily data to the file MBT-201612-CMECRYPTO-USD-0.1.dly | 2022-04-25 10:16:51.649
HD Request # 97 | Bytes received: 172 | 2022-04-25 10:16:51.651
HD Request # 97 | Received 4 Daily data records from 2016-12-14 00:00:00 to 2016-12-16 00:00:00 (3.0 days) and wrote 3 records for MBT-201612-CMECRYPTO-USD-0.1 | 2022-04-25 10:16:51.651
HD Request # 97 | Completion time: 2s | 2022-04-25 10:16:51.651
HD Request # 97 | Daily data download complete for MBT-201612-CMECRYPTO-USD-0.1. Unique request ID: 39 | 2022-04-25 10:16:51.651
Removing historical data download ID 39. | 2022-04-25 10:16:51.651
Triggering next historical data download in queue. | 2022-04-25 10:16:51.651
Mapping MBT-201701-CMECRYPTO-USD-0.1 to MBTF17. Service code: cme | 2022-04-25 10:16:51.651
HD Request # 98 | Downloading Historical Daily chart data for MBT-201701-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:16:51.652
HD Request # 98 | Requesting historical Daily data for BAF17 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:16:53.083
HD Request # 98 | Bytes received: 1 | 2022-04-25 10:16:53.914
HD Request # 98 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201701-CMECRYPTO-USD-0.1 | 2022-04-25 10:16:53.914
HD Request # 98 | Completion time: 2s | 2022-04-25 10:16:53.914
HD Request # 98 | Daily data download complete for MBT-201701-CMECRYPTO-USD-0.1. Unique request ID: 40 | 2022-04-25 10:16:53.914
Removing historical data download ID 40. | 2022-04-25 10:16:53.914
Triggering next historical data download in queue. | 2022-04-25 10:16:53.914
Mapping MBT-201702-CMECRYPTO-USD-0.1 to MBTG17. Service code: cme | 2022-04-25 10:16:53.914
HD Request # 99 | Downloading Historical Daily chart data for MBT-201702-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:16:53.915
HD Request # 99 | Requesting historical Daily data for BAG17 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:16:55.316
HD Request # 99 | Bytes received: 1 | 2022-04-25 10:16:56.143
HD Request # 99 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201702-CMECRYPTO-USD-0.1 | 2022-04-25 10:16:56.143
HD Request # 99 | Completion time: 3s | 2022-04-25 10:16:56.143
HD Request # 99 | Daily data download complete for MBT-201702-CMECRYPTO-USD-0.1. Unique request ID: 41 | 2022-04-25 10:16:56.143
Removing historical data download ID 41. | 2022-04-25 10:16:56.144
Triggering next historical data download in queue. | 2022-04-25 10:16:56.144
Mapping MBT-201703-CMECRYPTO-USD-0.1 to MBTH17. Service code: cme | 2022-04-25 10:16:56.144
HD Request # 100 | Downloading Historical Daily chart data for MBT-201703-CMECRYPTO-USD-0.1. Starting date: 2017-03-08. Service: interactive_brokers.trading | 2022-04-25 10:16:56.146
HD Request # 100 | Requesting historical Daily data for BAH17 starting at 2017-03-07. SC External HD service. | 2022-04-25 10:16:57.594
HD Request # 100 | Receiving historical Daily data for MBT-201703-CMECRYPTO-USD-0.1 starting at 2017-03-08 | 2022-04-25 10:16:58.352
HD Request # 100 | Writing historical Daily data to the file MBT-201703-CMECRYPTO-USD-0.1.dly | 2022-04-25 10:16:58.353
HD Request # 100 | Bytes received: 171 | 2022-04-25 10:16:58.354
HD Request # 100 | Received 4 Daily data records from 2017-03-08 00:00:00 to 2017-03-10 00:00:00 (3.0 days) and wrote 3 records for MBT-201703-CMECRYPTO-USD-0.1 | 2022-04-25 10:16:58.354
HD Request # 100 | Completion time: 2s | 2022-04-25 10:16:58.355
HD Request # 100 | Daily data download complete for MBT-201703-CMECRYPTO-USD-0.1. Unique request ID: 42 | 2022-04-25 10:16:58.355
Removing historical data download ID 42. | 2022-04-25 10:16:58.355
Triggering next historical data download in queue. | 2022-04-25 10:16:58.355
Mapping MBT-201704-CMECRYPTO-USD-0.1 to MBTJ17. Service code: cme | 2022-04-25 10:16:58.355
HD Request # 101 | Downloading Historical Daily chart data for MBT-201704-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:16:58.355
HD Request # 101 | Requesting historical Daily data for BAJ17 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:16:59.768
HD Request # 101 | Bytes received: 1 | 2022-04-25 10:17:00.598
HD Request # 101 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201704-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:00.598
HD Request # 101 | Completion time: 2s | 2022-04-25 10:17:00.598
HD Request # 101 | Daily data download complete for MBT-201704-CMECRYPTO-USD-0.1. Unique request ID: 43 | 2022-04-25 10:17:00.598
Removing historical data download ID 43. | 2022-04-25 10:17:00.598
Triggering next historical data download in queue. | 2022-04-25 10:17:00.598
Mapping MBT-201705-CMECRYPTO-USD-0.1 to MBTK17. Service code: cme | 2022-04-25 10:17:00.598
HD Request # 102 | Downloading Historical Daily chart data for MBT-201705-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:17:00.599
DTC Client socket (5) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-04-25 10:17:00.848
DTC Client socket (5) | Closed. | 2022-04-25 10:17:00.848
DTC Client socket (6) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-04-25 10:17:00.848
DTC Client socket (6) | Closed. | 2022-04-25 10:17:00.848
DTC Client socket (8) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-04-25 10:17:00.848
DTC Client socket (8) | Closed. | 2022-04-25 10:17:00.848
HD Request # 102 | Requesting historical Daily data for BAK17 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:17:02.016
HD Request # 102 | Bytes received: 1 | 2022-04-25 10:17:02.862
HD Request # 102 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201705-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:02.862
HD Request # 102 | Completion time: 2s | 2022-04-25 10:17:02.862
HD Request # 102 | Daily data download complete for MBT-201705-CMECRYPTO-USD-0.1. Unique request ID: 44 | 2022-04-25 10:17:02.862
Removing historical data download ID 44. | 2022-04-25 10:17:02.862
Triggering next historical data download in queue. | 2022-04-25 10:17:02.862
Mapping MBT-201706-CMECRYPTO-USD-0.1 to MBTM17. Service code: cme | 2022-04-25 10:17:02.862
HD Request # 103 | Downloading Historical Daily chart data for MBT-201706-CMECRYPTO-USD-0.1. Starting date: 2017-06-14. Service: interactive_brokers.trading | 2022-04-25 10:17:02.865
HD Request # 103 | Requesting historical Daily data for BAM17 starting at 2017-06-13. SC External HD service. | 2022-04-25 10:17:04.285
HD Request # 103 | Receiving historical Daily data for MBT-201706-CMECRYPTO-USD-0.1 starting at 2017-06-14 | 2022-04-25 10:17:05.106
HD Request # 103 | Writing historical Daily data to the file MBT-201706-CMECRYPTO-USD-0.1.dly | 2022-04-25 10:17:05.106
HD Request # 103 | Bytes received: 169 | 2022-04-25 10:17:05.109
HD Request # 103 | Received 4 Daily data records from 2017-06-14 00:00:00 to 2017-06-16 00:00:00 (3.0 days) and wrote 3 records for MBT-201706-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:05.109
HD Request # 103 | Completion time: 3s | 2022-04-25 10:17:05.109
HD Request # 103 | Daily data download complete for MBT-201706-CMECRYPTO-USD-0.1. Unique request ID: 45 | 2022-04-25 10:17:05.109
Removing historical data download ID 45. | 2022-04-25 10:17:05.109
Triggering next historical data download in queue. | 2022-04-25 10:17:05.109
Mapping MBT-201707-CMECRYPTO-USD-0.1 to MBTN17. Service code: cme | 2022-04-25 10:17:05.109
HD Request # 104 | Downloading Historical Daily chart data for MBT-201707-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:17:05.110
HD Request # 104 | Requesting historical Daily data for BAN17 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:17:06.538
HD Request # 104 | Bytes received: 1 | 2022-04-25 10:17:07.379
HD Request # 104 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201707-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:07.379
HD Request # 104 | Completion time: 2s | 2022-04-25 10:17:07.379
HD Request # 104 | Daily data download complete for MBT-201707-CMECRYPTO-USD-0.1. Unique request ID: 46 | 2022-04-25 10:17:07.379
Removing historical data download ID 46. | 2022-04-25 10:17:07.379
Triggering next historical data download in queue. | 2022-04-25 10:17:07.379
Mapping MBT-201708-CMECRYPTO-USD-0.1 to MBTQ17. Service code: cme | 2022-04-25 10:17:07.380
HD Request # 105 | Downloading Historical Daily chart data for MBT-201708-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:17:07.381
HD Request # 105 | Requesting historical Daily data for BAQ17 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:17:08.798
Opened cached Intraday file: C:\SierraChart\Data\HESM-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:17:09.597
HD Request # 105 | Bytes received: 1 | 2022-04-25 10:17:09.648
HD Request # 105 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201708-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:09.648
HD Request # 105 | Completion time: 2s | 2022-04-25 10:17:09.648
HD Request # 105 | Daily data download complete for MBT-201708-CMECRYPTO-USD-0.1. Unique request ID: 47 | 2022-04-25 10:17:09.648
Removing historical data download ID 47. | 2022-04-25 10:17:09.648
Triggering next historical data download in queue. | 2022-04-25 10:17:09.648
Mapping MBT-201709-CMECRYPTO-USD-0.1 to MBTU17. Service code: cme | 2022-04-25 10:17:09.648
HD Request # 106 | Downloading Historical Daily chart data for MBT-201709-CMECRYPTO-USD-0.1. Starting date: 2017-09-13. Service: interactive_brokers.trading | 2022-04-25 10:17:09.650
HD Request # 106 | Requesting historical Daily data for BAU17 starting at 2017-09-12. SC External HD service. | 2022-04-25 10:17:11.064
HD Request # 106 | Receiving historical Daily data for MBT-201709-CMECRYPTO-USD-0.1 starting at 2017-09-13 | 2022-04-25 10:17:11.823
HD Request # 106 | Writing historical Daily data to the file MBT-201709-CMECRYPTO-USD-0.1.dly | 2022-04-25 10:17:11.823
HD Request # 106 | Bytes received: 164 | 2022-04-25 10:17:11.825
HD Request # 106 | Received 4 Daily data records from 2017-09-13 00:00:00 to 2017-09-15 00:00:00 (3.0 days) and wrote 3 records for MBT-201709-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:11.825
HD Request # 106 | Completion time: 2s | 2022-04-25 10:17:11.825
HD Request # 106 | Daily data download complete for MBT-201709-CMECRYPTO-USD-0.1. Unique request ID: 48 | 2022-04-25 10:17:11.825
Removing historical data download ID 48. | 2022-04-25 10:17:11.825
Triggering next historical data download in queue. | 2022-04-25 10:17:11.825
Mapping MBT-201710-CMECRYPTO-USD-0.1 to MBTV17. Service code: cme | 2022-04-25 10:17:11.825
HD Request # 107 | Downloading Historical Daily chart data for MBT-201710-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:17:11.826
HD Request # 107 | Requesting historical Daily data for BAV17 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:17:13.244
HD Request # 107 | Bytes received: 1 | 2022-04-25 10:17:14.008
HD Request # 107 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201710-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:14.008
HD Request # 107 | Completion time: 3s | 2022-04-25 10:17:14.008
HD Request # 107 | Daily data download complete for MBT-201710-CMECRYPTO-USD-0.1. Unique request ID: 49 | 2022-04-25 10:17:14.008
Removing historical data download ID 49. | 2022-04-25 10:17:14.008
Triggering next historical data download in queue. | 2022-04-25 10:17:14.008
Mapping MBT-201711-CMECRYPTO-USD-0.1 to MBTX17. Service code: cme | 2022-04-25 10:17:14.008
HD Request # 108 | Downloading Historical Daily chart data for MBT-201711-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:17:14.009
HD Request # 108 | Requesting historical Daily data for BAX17 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:17:15.433
HD Request # 108 | Bytes received: 1 | 2022-04-25 10:17:16.282
HD Request # 108 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201711-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:16.282
HD Request # 108 | Completion time: 2s | 2022-04-25 10:17:16.282
HD Request # 108 | Daily data download complete for MBT-201711-CMECRYPTO-USD-0.1. Unique request ID: 50 | 2022-04-25 10:17:16.282
Removing historical data download ID 50. | 2022-04-25 10:17:16.282
Triggering next historical data download in queue. | 2022-04-25 10:17:16.282
Mapping MBT-201712-CMECRYPTO-USD-0.1 to MBTZ17. Service code: cme | 2022-04-25 10:17:16.282
HD Request # 109 | Downloading Historical Daily chart data for MBT-201712-CMECRYPTO-USD-0.1. Starting date: 2017-12-13. Service: interactive_brokers.trading | 2022-04-25 10:17:16.284
HD Request # 109 | Requesting historical Daily data for BAZ17 starting at 2017-12-12. SC External HD service. | 2022-04-25 10:17:17.696
HD Request # 109 | Receiving historical Daily data for MBT-201712-CMECRYPTO-USD-0.1 starting at 2017-12-13 | 2022-04-25 10:17:18.453
HD Request # 109 | Writing historical Daily data to the file MBT-201712-CMECRYPTO-USD-0.1.dly | 2022-04-25 10:17:18.454
HD Request # 109 | Bytes received: 164 | 2022-04-25 10:17:18.456
HD Request # 109 | Received 4 Daily data records from 2017-12-13 00:00:00 to 2017-12-15 00:00:00 (3.0 days) and wrote 3 records for MBT-201712-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:18.456
HD Request # 109 | Completion time: 2s | 2022-04-25 10:17:18.456
HD Request # 109 | Daily data download complete for MBT-201712-CMECRYPTO-USD-0.1. Unique request ID: 51 | 2022-04-25 10:17:18.456
Removing historical data download ID 51. | 2022-04-25 10:17:18.456
Triggering next historical data download in queue. | 2022-04-25 10:17:18.456
Mapping MBT-201801-CMECRYPTO-USD-0.1 to MBTF18. Service code: cme | 2022-04-25 10:17:18.457
HD Request # 110 | Downloading Historical Daily chart data for MBT-201801-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:17:18.457
Opened cached Intraday file: C:\SierraChart\Data\CLH-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:17:19.669
HD Request # 110 | Requesting historical Daily data for BAF18 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:17:19.887
HD Request # 110 | Bytes received: 1 | 2022-04-25 10:17:20.714
HD Request # 110 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201801-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:20.714
HD Request # 110 | Completion time: 2s | 2022-04-25 10:17:20.714
HD Request # 110 | Daily data download complete for MBT-201801-CMECRYPTO-USD-0.1. Unique request ID: 52 | 2022-04-25 10:17:20.714
Removing historical data download ID 52. | 2022-04-25 10:17:20.714
Triggering next historical data download in queue. | 2022-04-25 10:17:20.714
Mapping MBT-201802-CMECRYPTO-USD-0.1 to MBTG18. Service code: cme | 2022-04-25 10:17:20.714
HD Request # 111 | Downloading Historical Daily chart data for MBT-201802-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:17:20.715
HD Request # 111 | Requesting historical Daily data for BAG18 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:17:22.129
HD Request # 111 | Bytes received: 1 | 2022-04-25 10:17:22.955
HD Request # 111 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201802-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:22.955
HD Request # 111 | Completion time: 2s | 2022-04-25 10:17:22.955
HD Request # 111 | Daily data download complete for MBT-201802-CMECRYPTO-USD-0.1. Unique request ID: 53 | 2022-04-25 10:17:22.955
Removing historical data download ID 53. | 2022-04-25 10:17:22.955
Triggering next historical data download in queue. | 2022-04-25 10:17:22.955
Mapping MBT-201803-CMECRYPTO-USD-0.1 to MBTH18. Service code: cme | 2022-04-25 10:17:22.955
HD Request # 112 | Downloading Historical Daily chart data for MBT-201803-CMECRYPTO-USD-0.1. Starting date: 2018-03-14. Service: interactive_brokers.trading | 2022-04-25 10:17:22.957
HD Request # 112 | Requesting historical Daily data for BAH18 starting at 2018-03-13. SC External HD service. | 2022-04-25 10:17:24.386
HD Request # 112 | Receiving historical Daily data for MBT-201803-CMECRYPTO-USD-0.1 starting at 2018-03-14 | 2022-04-25 10:17:25.136
HD Request # 112 | Writing historical Daily data to the file MBT-201803-CMECRYPTO-USD-0.1.dly | 2022-04-25 10:17:25.136
HD Request # 112 | Bytes received: 164 | 2022-04-25 10:17:25.139
HD Request # 112 | Received 4 Daily data records from 2018-03-14 00:00:00 to 2018-03-16 00:00:00 (3.0 days) and wrote 3 records for MBT-201803-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:25.139
HD Request # 112 | Completion time: 3s | 2022-04-25 10:17:25.139
HD Request # 112 | Daily data download complete for MBT-201803-CMECRYPTO-USD-0.1. Unique request ID: 54 | 2022-04-25 10:17:25.139
Removing historical data download ID 54. | 2022-04-25 10:17:25.139
Triggering next historical data download in queue. | 2022-04-25 10:17:25.139
Mapping MBT-201804-CMECRYPTO-USD-0.1 to MBTJ18. Service code: cme | 2022-04-25 10:17:25.139
HD Request # 113 | Downloading Historical Daily chart data for MBT-201804-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:17:25.140
HD Request # 113 | Requesting historical Daily data for BAJ18 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:17:26.551
HD Request # 113 | Bytes received: 1 | 2022-04-25 10:17:27.380
HD Request # 113 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201804-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:27.380
HD Request # 113 | Completion time: 2s | 2022-04-25 10:17:27.380
HD Request # 113 | Daily data download complete for MBT-201804-CMECRYPTO-USD-0.1. Unique request ID: 55 | 2022-04-25 10:17:27.380
Removing historical data download ID 55. | 2022-04-25 10:17:27.380
Triggering next historical data download in queue. | 2022-04-25 10:17:27.380
Mapping MBT-201805-CMECRYPTO-USD-0.1 to MBTK18. Service code: cme | 2022-04-25 10:17:27.380
HD Request # 114 | Downloading Historical Daily chart data for MBT-201805-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:17:27.381
HD Request # 114 | Requesting historical Daily data for BAK18 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:17:28.796
HD Request # 114 | Bytes received: 1 | 2022-04-25 10:17:29.561
HD Request # 114 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201805-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:29.561
HD Request # 114 | Completion time: 2s | 2022-04-25 10:17:29.561
HD Request # 114 | Daily data download complete for MBT-201805-CMECRYPTO-USD-0.1. Unique request ID: 56 | 2022-04-25 10:17:29.561
Removing historical data download ID 56. | 2022-04-25 10:17:29.561
Triggering next historical data download in queue. | 2022-04-25 10:17:29.561
Mapping MBT-201806-CMECRYPTO-USD-0.1 to MBTM18. Service code: cme | 2022-04-25 10:17:29.561
HD Request # 115 | Downloading Historical Daily chart data for MBT-201806-CMECRYPTO-USD-0.1. Starting date: 2018-06-13. Service: interactive_brokers.trading | 2022-04-25 10:17:29.563
DTC Client socket (5) | Deleting network socket now after delay. | 2022-04-25 10:17:30.848
DTC Client socket (6) | Deleting network socket now after delay. | 2022-04-25 10:17:30.848
DTC Client socket (8) | Deleting network socket now after delay. | 2022-04-25 10:17:30.848
HD Request # 115 | Requesting historical Daily data for BAM18 starting at 2018-06-12. SC External HD service. | 2022-04-25 10:17:30.973
HD Request # 115 | Receiving historical Daily data for MBT-201806-CMECRYPTO-USD-0.1 starting at 2018-06-13 | 2022-04-25 10:17:31.783
HD Request # 115 | Writing historical Daily data to the file MBT-201806-CMECRYPTO-USD-0.1.dly | 2022-04-25 10:17:31.784
HD Request # 115 | Bytes received: 164 | 2022-04-25 10:17:31.786
HD Request # 115 | Received 4 Daily data records from 2018-06-13 00:00:00 to 2018-06-15 00:00:00 (3.0 days) and wrote 3 records for MBT-201806-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:31.786
HD Request # 115 | Completion time: 2s | 2022-04-25 10:17:31.786
HD Request # 115 | Daily data download complete for MBT-201806-CMECRYPTO-USD-0.1. Unique request ID: 57 | 2022-04-25 10:17:31.786
Removing historical data download ID 57. | 2022-04-25 10:17:31.787
Triggering next historical data download in queue. | 2022-04-25 10:17:31.787
Mapping MBT-201807-CMECRYPTO-USD-0.1 to MBTN18. Service code: cme | 2022-04-25 10:17:31.787
HD Request # 116 | Downloading Historical Daily chart data for MBT-201807-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:17:31.787
HD Request # 116 | Requesting historical Daily data for BAN18 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:17:33.224
HD Request # 116 | Bytes received: 1 | 2022-04-25 10:17:34.018
HD Request # 116 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201807-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:34.018
HD Request # 116 | Completion time: 3s | 2022-04-25 10:17:34.018
HD Request # 116 | Daily data download complete for MBT-201807-CMECRYPTO-USD-0.1. Unique request ID: 58 | 2022-04-25 10:17:34.018
Removing historical data download ID 58. | 2022-04-25 10:17:34.018
Triggering next historical data download in queue. | 2022-04-25 10:17:34.018
Mapping MBT-201808-CMECRYPTO-USD-0.1 to MBTQ18. Service code: cme | 2022-04-25 10:17:34.018
HD Request # 117 | Downloading Historical Daily chart data for MBT-201808-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:17:34.019
HD Request # 117 | Requesting historical Daily data for BAQ18 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:17:35.424
HD Request # 117 | Bytes received: 1 | 2022-04-25 10:17:36.262
HD Request # 117 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201808-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:36.262
HD Request # 117 | Completion time: 2s | 2022-04-25 10:17:36.262
HD Request # 117 | Daily data download complete for MBT-201808-CMECRYPTO-USD-0.1. Unique request ID: 59 | 2022-04-25 10:17:36.262
Removing historical data download ID 59. | 2022-04-25 10:17:36.262
Triggering next historical data download in queue. | 2022-04-25 10:17:36.263
Mapping MBT-201809-CMECRYPTO-USD-0.1 to MBTU18. Service code: cme | 2022-04-25 10:17:36.263
HD Request # 118 | Downloading Historical Daily chart data for MBT-201809-CMECRYPTO-USD-0.1. Starting date: 2018-09-12. Service: interactive_brokers.trading | 2022-04-25 10:17:36.265
HD Request # 118 | Requesting historical Daily data for BAU18 starting at 2018-09-11. SC External HD service. | 2022-04-25 10:17:37.699
HD Request # 118 | Receiving historical Daily data for MBT-201809-CMECRYPTO-USD-0.1 starting at 2018-09-12 | 2022-04-25 10:17:38.481
HD Request # 118 | Writing historical Daily data to the file MBT-201809-CMECRYPTO-USD-0.1.dly | 2022-04-25 10:17:38.482
HD Request # 118 | Bytes received: 164 | 2022-04-25 10:17:38.484
HD Request # 118 | Received 4 Daily data records from 2018-09-12 00:00:00 to 2018-09-14 00:00:00 (3.0 days) and wrote 3 records for MBT-201809-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:38.484
HD Request # 118 | Completion time: 2s | 2022-04-25 10:17:38.484
HD Request # 118 | Daily data download complete for MBT-201809-CMECRYPTO-USD-0.1. Unique request ID: 60 | 2022-04-25 10:17:38.484
Removing historical data download ID 60. | 2022-04-25 10:17:38.484
Triggering next historical data download in queue. | 2022-04-25 10:17:38.484
Mapping MBT-201810-CMECRYPTO-USD-0.1 to MBTV18. Service code: cme | 2022-04-25 10:17:38.484
HD Request # 119 | Downloading Historical Daily chart data for MBT-201810-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:17:38.485
HD Request # 119 | Requesting historical Daily data for BAV18 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:17:39.904
HD Request # 119 | Bytes received: 1 | 2022-04-25 10:17:40.728
HD Request # 119 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201810-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:40.728
HD Request # 119 | Completion time: 2s | 2022-04-25 10:17:40.728
HD Request # 119 | Daily data download complete for MBT-201810-CMECRYPTO-USD-0.1. Unique request ID: 61 | 2022-04-25 10:17:40.728
Removing historical data download ID 61. | 2022-04-25 10:17:40.728
Triggering next historical data download in queue. | 2022-04-25 10:17:40.728
Mapping MBT-201811-CMECRYPTO-USD-0.1 to MBTX18. Service code: cme | 2022-04-25 10:17:40.728
HD Request # 120 | Downloading Historical Daily chart data for MBT-201811-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:17:40.729
HD Request # 120 | Requesting historical Daily data for BAX18 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:17:42.136
HD Request # 120 | Bytes received: 1 | 2022-04-25 10:17:42.940
HD Request # 120 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201811-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:42.940
HD Request # 120 | Completion time: 2s | 2022-04-25 10:17:42.940
HD Request # 120 | Daily data download complete for MBT-201811-CMECRYPTO-USD-0.1. Unique request ID: 62 | 2022-04-25 10:17:42.940
Removing historical data download ID 62. | 2022-04-25 10:17:42.940
Triggering next historical data download in queue. | 2022-04-25 10:17:42.940
Mapping MBT-201812-CMECRYPTO-USD-0.1 to MBTZ18. Service code: cme | 2022-04-25 10:17:42.940
HD Request # 121 | Downloading Historical Daily chart data for MBT-201812-CMECRYPTO-USD-0.1. Starting date: 2018-12-12. Service: interactive_brokers.trading | 2022-04-25 10:17:42.942
HD Request # 121 | Requesting historical Daily data for BAZ18 starting at 2018-12-11. SC External HD service. | 2022-04-25 10:17:44.353
HD Request # 121 | Receiving historical Daily data for MBT-201812-CMECRYPTO-USD-0.1 starting at 2018-12-12 | 2022-04-25 10:17:45.165
HD Request # 121 | Writing historical Daily data to the file MBT-201812-CMECRYPTO-USD-0.1.dly | 2022-04-25 10:17:45.165
HD Request # 121 | Bytes received: 164 | 2022-04-25 10:17:45.168
HD Request # 121 | Received 4 Daily data records from 2018-12-12 00:00:00 to 2018-12-14 00:00:00 (3.0 days) and wrote 3 records for MBT-201812-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:45.168
HD Request # 121 | Completion time: 3s | 2022-04-25 10:17:45.168
HD Request # 121 | Daily data download complete for MBT-201812-CMECRYPTO-USD-0.1. Unique request ID: 63 | 2022-04-25 10:17:45.168
Removing historical data download ID 63. | 2022-04-25 10:17:45.168
Triggering next historical data download in queue. | 2022-04-25 10:17:45.168
Mapping MBT-201901-CMECRYPTO-USD-0.1 to MBTF19. Service code: cme | 2022-04-25 10:17:45.168
HD Request # 122 | Downloading Historical Daily chart data for MBT-201901-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:17:45.169
HD Request # 122 | Requesting historical Daily data for BAF19 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:17:46.579
HD Request # 122 | Bytes received: 1 | 2022-04-25 10:17:47.397
HD Request # 122 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201901-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:47.397
HD Request # 122 | Completion time: 2s | 2022-04-25 10:17:47.397
HD Request # 122 | Daily data download complete for MBT-201901-CMECRYPTO-USD-0.1. Unique request ID: 64 | 2022-04-25 10:17:47.397
Removing historical data download ID 64. | 2022-04-25 10:17:47.397
Triggering next historical data download in queue. | 2022-04-25 10:17:47.397
Mapping MBT-201902-CMECRYPTO-USD-0.1 to MBTG19. Service code: cme | 2022-04-25 10:17:47.398
HD Request # 123 | Downloading Historical Daily chart data for MBT-201902-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:17:47.398
HD Request # 123 | Requesting historical Daily data for BAG19 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:17:48.806
HD Request # 123 | Bytes received: 1 | 2022-04-25 10:17:49.587
HD Request # 123 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201902-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:49.587
HD Request # 123 | Completion time: 2s | 2022-04-25 10:17:49.587
HD Request # 123 | Daily data download complete for MBT-201902-CMECRYPTO-USD-0.1. Unique request ID: 65 | 2022-04-25 10:17:49.587
Removing historical data download ID 65. | 2022-04-25 10:17:49.587
Triggering next historical data download in queue. | 2022-04-25 10:17:49.587
Mapping MBT-201903-CMECRYPTO-USD-0.1 to MBTH19. Service code: cme | 2022-04-25 10:17:49.587
HD Request # 124 | Downloading Historical Daily chart data for MBT-201903-CMECRYPTO-USD-0.1. Starting date: 2019-03-13. Service: interactive_brokers.trading | 2022-04-25 10:17:49.589
Opened cached Intraday file: C:\SierraChart\Data\TNET-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:17:49.892
HD Request # 124 | Requesting historical Daily data for BAH19 starting at 2019-03-12. SC External HD service. | 2022-04-25 10:17:51.008
HD Request # 124 | Receiving historical Daily data for MBT-201903-CMECRYPTO-USD-0.1 starting at 2019-03-13 | 2022-04-25 10:17:51.769
HD Request # 124 | Writing historical Daily data to the file MBT-201903-CMECRYPTO-USD-0.1.dly | 2022-04-25 10:17:51.770
HD Request # 124 | Bytes received: 164 | 2022-04-25 10:17:51.772
HD Request # 124 | Received 4 Daily data records from 2019-03-13 00:00:00 to 2019-03-15 00:00:00 (3.0 days) and wrote 3 records for MBT-201903-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:51.772
HD Request # 124 | Completion time: 2s | 2022-04-25 10:17:51.772
HD Request # 124 | Daily data download complete for MBT-201903-CMECRYPTO-USD-0.1. Unique request ID: 66 | 2022-04-25 10:17:51.772
Removing historical data download ID 66. | 2022-04-25 10:17:51.772
Triggering next historical data download in queue. | 2022-04-25 10:17:51.772
Mapping MBT-201904-CMECRYPTO-USD-0.1 to MBTJ19. Service code: cme | 2022-04-25 10:17:51.773
HD Request # 125 | Downloading Historical Daily chart data for MBT-201904-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:17:51.773
HD Request # 125 | Requesting historical Daily data for BAJ19 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:17:53.205
HD Request # 125 | Bytes received: 1 | 2022-04-25 10:17:53.966
HD Request # 125 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201904-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:53.966
HD Request # 125 | Completion time: 2s | 2022-04-25 10:17:53.966
HD Request # 125 | Daily data download complete for MBT-201904-CMECRYPTO-USD-0.1. Unique request ID: 67 | 2022-04-25 10:17:53.966
Removing historical data download ID 67. | 2022-04-25 10:17:53.966
Triggering next historical data download in queue. | 2022-04-25 10:17:53.966
Mapping MBT-201905-CMECRYPTO-USD-0.1 to MBTK19. Service code: cme | 2022-04-25 10:17:53.967
HD Request # 126 | Downloading Historical Daily chart data for MBT-201905-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:17:53.968
HD Request # 126 | Requesting historical Daily data for BAK19 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:17:55.380
HD Request # 126 | Bytes received: 1 | 2022-04-25 10:17:56.204
HD Request # 126 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201905-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:56.204
HD Request # 126 | Completion time: 3s | 2022-04-25 10:17:56.204
HD Request # 126 | Daily data download complete for MBT-201905-CMECRYPTO-USD-0.1. Unique request ID: 68 | 2022-04-25 10:17:56.204
Removing historical data download ID 68. | 2022-04-25 10:17:56.204
Triggering next historical data download in queue. | 2022-04-25 10:17:56.205
Mapping MBT-201906-CMECRYPTO-USD-0.1 to MBTM19. Service code: cme | 2022-04-25 10:17:56.205
HD Request # 127 | Downloading Historical Daily chart data for MBT-201906-CMECRYPTO-USD-0.1. Starting date: 2019-03-13. Service: interactive_brokers.trading | 2022-04-25 10:17:56.206
HD Request # 127 | Requesting historical Daily data for BAM19 starting at 2019-03-12. SC External HD service. | 2022-04-25 10:17:57.611
HD Request # 127 | Receiving historical Daily data for MBT-201906-CMECRYPTO-USD-0.1 starting at 2019-03-13 | 2022-04-25 10:17:58.446
HD Request # 127 | Writing historical Daily data to the file MBT-201906-CMECRYPTO-USD-0.1.dly | 2022-04-25 10:17:58.446
HD Request # 127 | Bytes received: 164 | 2022-04-25 10:17:58.448
HD Request # 127 | Received 4 Daily data records from 2019-03-13 00:00:00 to 2019-03-15 00:00:00 (3.0 days) and wrote 3 records for MBT-201906-CMECRYPTO-USD-0.1 | 2022-04-25 10:17:58.448
HD Request # 127 | Completion time: 2s | 2022-04-25 10:17:58.448
HD Request # 127 | Daily data download complete for MBT-201906-CMECRYPTO-USD-0.1. Unique request ID: 69 | 2022-04-25 10:17:58.448
Removing historical data download ID 69. | 2022-04-25 10:17:58.448
Triggering next historical data download in queue. | 2022-04-25 10:17:58.448
Mapping MBT-201907-CMECRYPTO-USD-0.1 to MBTN19. Service code: cme | 2022-04-25 10:17:58.448
HD Request # 128 | Downloading Historical Daily chart data for MBT-201907-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:17:58.449
HD Request # 128 | Requesting historical Daily data for BAN19 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:17:59.857
HD Request # 128 | Bytes received: 1 | 2022-04-25 10:18:00.687
HD Request # 128 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201907-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:00.687
HD Request # 128 | Completion time: 2s | 2022-04-25 10:18:00.687
HD Request # 128 | Daily data download complete for MBT-201907-CMECRYPTO-USD-0.1. Unique request ID: 70 | 2022-04-25 10:18:00.687
Removing historical data download ID 70. | 2022-04-25 10:18:00.687
Triggering next historical data download in queue. | 2022-04-25 10:18:00.687
Mapping MBT-201908-CMECRYPTO-USD-0.1 to MBTQ19. Service code: cme | 2022-04-25 10:18:00.687
HD Request # 129 | Downloading Historical Daily chart data for MBT-201908-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:18:00.688
HD Request # 129 | Requesting historical Daily data for BAQ19 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:18:02.127
HD Request # 129 | Bytes received: 1 | 2022-04-25 10:18:02.907
HD Request # 129 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201908-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:02.907
HD Request # 129 | Completion time: 2s | 2022-04-25 10:18:02.907
HD Request # 129 | Daily data download complete for MBT-201908-CMECRYPTO-USD-0.1. Unique request ID: 71 | 2022-04-25 10:18:02.907
Removing historical data download ID 71. | 2022-04-25 10:18:02.907
Triggering next historical data download in queue. | 2022-04-25 10:18:02.907
Mapping MBT-201909-CMECRYPTO-USD-0.1 to MBTU19. Service code: cme | 2022-04-25 10:18:02.907
HD Request # 130 | Downloading Historical Daily chart data for MBT-201909-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:18:02.908
HD Request # 130 | Requesting historical Daily data for BAU19 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:18:04.326
HD Request # 130 | Bytes received: 1 | 2022-04-25 10:18:05.153
HD Request # 130 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201909-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:05.153
HD Request # 130 | Completion time: 3s | 2022-04-25 10:18:05.153
HD Request # 130 | Daily data download complete for MBT-201909-CMECRYPTO-USD-0.1. Unique request ID: 72 | 2022-04-25 10:18:05.153
Removing historical data download ID 72. | 2022-04-25 10:18:05.153
Triggering next historical data download in queue. | 2022-04-25 10:18:05.153
Mapping MBT-201910-CMECRYPTO-USD-0.1 to MBTV19. Service code: cme | 2022-04-25 10:18:05.153
HD Request # 131 | Downloading Historical Daily chart data for MBT-201910-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:18:05.154
HD Request # 131 | Requesting historical Daily data for BAV19 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:18:06.573
HD Request # 131 | Bytes received: 1 | 2022-04-25 10:18:07.340
HD Request # 131 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201910-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:07.340
HD Request # 131 | Completion time: 2s | 2022-04-25 10:18:07.340
HD Request # 131 | Daily data download complete for MBT-201910-CMECRYPTO-USD-0.1. Unique request ID: 73 | 2022-04-25 10:18:07.340
Removing historical data download ID 73. | 2022-04-25 10:18:07.340
Triggering next historical data download in queue. | 2022-04-25 10:18:07.340
Mapping MBT-201911-CMECRYPTO-USD-0.1 to MBTX19. Service code: cme | 2022-04-25 10:18:07.340
HD Request # 132 | Downloading Historical Daily chart data for MBT-201911-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:18:07.341
HD Request # 132 | Requesting historical Daily data for BAX19 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:18:08.750
HD Request # 132 | Bytes received: 1 | 2022-04-25 10:18:09.511
HD Request # 132 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201911-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:09.511
HD Request # 132 | Completion time: 2s | 2022-04-25 10:18:09.511
HD Request # 132 | Daily data download complete for MBT-201911-CMECRYPTO-USD-0.1. Unique request ID: 74 | 2022-04-25 10:18:09.511
Removing historical data download ID 74. | 2022-04-25 10:18:09.511
Triggering next historical data download in queue. | 2022-04-25 10:18:09.511
Mapping MBT-201912-CMECRYPTO-USD-0.1 to MBTZ19. Service code: cme | 2022-04-25 10:18:09.511
HD Request # 133 | Downloading Historical Daily chart data for MBT-201912-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:18:09.512
HD Request # 133 | Requesting historical Daily data for BAZ19 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:18:10.933
HD Request # 133 | Bytes received: 1 | 2022-04-25 10:18:11.764
HD Request # 133 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-201912-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:11.764
HD Request # 133 | Completion time: 2s | 2022-04-25 10:18:11.764
HD Request # 133 | Daily data download complete for MBT-201912-CMECRYPTO-USD-0.1. Unique request ID: 75 | 2022-04-25 10:18:11.764
Removing historical data download ID 75. | 2022-04-25 10:18:11.764
Triggering next historical data download in queue. | 2022-04-25 10:18:11.764
Mapping MBT-202001-CMECRYPTO-USD-0.1 to MBTF20. Service code: cme | 2022-04-25 10:18:11.764
HD Request # 134 | Downloading Historical Daily chart data for MBT-202001-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:18:11.765
HD Request # 134 | Requesting historical Daily data for BAF20 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:18:13.180
HD Request # 134 | Bytes received: 1 | 2022-04-25 10:18:14.002
HD Request # 134 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-202001-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:14.002
HD Request # 134 | Completion time: 3s | 2022-04-25 10:18:14.002
HD Request # 134 | Daily data download complete for MBT-202001-CMECRYPTO-USD-0.1. Unique request ID: 76 | 2022-04-25 10:18:14.002
Removing historical data download ID 76. | 2022-04-25 10:18:14.002
Triggering next historical data download in queue. | 2022-04-25 10:18:14.002
Mapping MBT-202002-CMECRYPTO-USD-0.1 to MBTG20. Service code: cme | 2022-04-25 10:18:14.002
HD Request # 135 | Downloading Historical Daily chart data for MBT-202002-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:18:14.003
HD Request # 135 | Requesting historical Daily data for BAG20 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:18:15.422
HD Request # 135 | Bytes received: 1 | 2022-04-25 10:18:16.192
HD Request # 135 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-202002-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:16.192
HD Request # 135 | Completion time: 2s | 2022-04-25 10:18:16.192
HD Request # 135 | Daily data download complete for MBT-202002-CMECRYPTO-USD-0.1. Unique request ID: 77 | 2022-04-25 10:18:16.192
Removing historical data download ID 77. | 2022-04-25 10:18:16.192
Triggering next historical data download in queue. | 2022-04-25 10:18:16.192
Mapping MBT-202003-CMECRYPTO-USD-0.1 to MBTH20. Service code: cme | 2022-04-25 10:18:16.192
HD Request # 136 | Downloading Historical Daily chart data for MBT-202003-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:18:16.193
HD Request # 136 | Requesting historical Daily data for BAH20 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:18:17.648
HD Request # 136 | Bytes received: 1 | 2022-04-25 10:18:18.455
HD Request # 136 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-202003-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:18.455
HD Request # 136 | Completion time: 2s | 2022-04-25 10:18:18.455
HD Request # 136 | Daily data download complete for MBT-202003-CMECRYPTO-USD-0.1. Unique request ID: 78 | 2022-04-25 10:18:18.455
Removing historical data download ID 78. | 2022-04-25 10:18:18.455
Triggering next historical data download in queue. | 2022-04-25 10:18:18.455
Mapping MBT-202004-CMECRYPTO-USD-0.1 to MBTJ20. Service code: cme | 2022-04-25 10:18:18.455
HD Request # 137 | Downloading Historical Daily chart data for MBT-202004-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:18:18.456
HD Request # 137 | Requesting historical Daily data for BAJ20 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:18:19.867
HD Request # 137 | Bytes received: 1 | 2022-04-25 10:18:20.635
HD Request # 137 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-202004-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:20.635
HD Request # 137 | Completion time: 2s | 2022-04-25 10:18:20.635
HD Request # 137 | Daily data download complete for MBT-202004-CMECRYPTO-USD-0.1. Unique request ID: 79 | 2022-04-25 10:18:20.635
Removing historical data download ID 79. | 2022-04-25 10:18:20.635
Triggering next historical data download in queue. | 2022-04-25 10:18:20.635
Mapping MBT-202005-CMECRYPTO-USD-0.1 to MBTK20. Service code: cme | 2022-04-25 10:18:20.635
HD Request # 138 | Downloading Historical Daily chart data for MBT-202005-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:18:20.636
HD Request # 138 | Requesting historical Daily data for BAK20 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:18:22.045
HD Request # 138 | Bytes received: 1 | 2022-04-25 10:18:22.910
HD Request # 138 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-202005-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:22.910
HD Request # 138 | Completion time: 2s | 2022-04-25 10:18:22.910
HD Request # 138 | Daily data download complete for MBT-202005-CMECRYPTO-USD-0.1. Unique request ID: 80 | 2022-04-25 10:18:22.910
Removing historical data download ID 80. | 2022-04-25 10:18:22.910
Triggering next historical data download in queue. | 2022-04-25 10:18:22.910
Mapping MBT-202006-CMECRYPTO-USD-0.1 to MBTM20. Service code: cme | 2022-04-25 10:18:22.910
HD Request # 139 | Downloading Historical Daily chart data for MBT-202006-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:18:22.911
HD Request # 139 | Requesting historical Daily data for BAM20 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:18:24.330
HD Request # 139 | Bytes received: 1 | 2022-04-25 10:18:25.125
HD Request # 139 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-202006-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:25.125
HD Request # 139 | Completion time: 3s | 2022-04-25 10:18:25.125
HD Request # 139 | Daily data download complete for MBT-202006-CMECRYPTO-USD-0.1. Unique request ID: 81 | 2022-04-25 10:18:25.125
Removing historical data download ID 81. | 2022-04-25 10:18:25.125
Triggering next historical data download in queue. | 2022-04-25 10:18:25.125
Mapping MBT-202007-CMECRYPTO-USD-0.1 to MBTN20. Service code: cme | 2022-04-25 10:18:25.125
HD Request # 140 | Downloading Historical Daily chart data for MBT-202007-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:18:25.126
HD Request # 140 | Requesting historical Daily data for BAN20 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:18:26.529
HD Request # 140 | Bytes received: 1 | 2022-04-25 10:18:27.318
HD Request # 140 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-202007-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:27.318
HD Request # 140 | Completion time: 2s | 2022-04-25 10:18:27.318
HD Request # 140 | Daily data download complete for MBT-202007-CMECRYPTO-USD-0.1. Unique request ID: 82 | 2022-04-25 10:18:27.318
Removing historical data download ID 82. | 2022-04-25 10:18:27.318
Triggering next historical data download in queue. | 2022-04-25 10:18:27.318
Mapping MBT-202008-CMECRYPTO-USD-0.1 to MBTQ20. Service code: cme | 2022-04-25 10:18:27.318
HD Request # 141 | Downloading Historical Daily chart data for MBT-202008-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:18:27.319
HD Request # 141 | Requesting historical Daily data for BAQ20 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:18:28.735
HD Request # 141 | Bytes received: 1 | 2022-04-25 10:18:29.494
HD Request # 141 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-202008-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:29.494
HD Request # 141 | Completion time: 2s | 2022-04-25 10:18:29.494
HD Request # 141 | Daily data download complete for MBT-202008-CMECRYPTO-USD-0.1. Unique request ID: 83 | 2022-04-25 10:18:29.494
Removing historical data download ID 83. | 2022-04-25 10:18:29.494
Triggering next historical data download in queue. | 2022-04-25 10:18:29.494
Mapping MBT-202009-CMECRYPTO-USD-0.1 to MBTU20. Service code: cme | 2022-04-25 10:18:29.494
HD Request # 142 | Downloading Historical Daily chart data for MBT-202009-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:18:29.495
HD Request # 142 | Requesting historical Daily data for BAU20 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:18:30.935
HD Request # 142 | Bytes received: 1 | 2022-04-25 10:18:31.692
HD Request # 142 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-202009-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:31.692
HD Request # 142 | Completion time: 2s | 2022-04-25 10:18:31.692
HD Request # 142 | Daily data download complete for MBT-202009-CMECRYPTO-USD-0.1. Unique request ID: 84 | 2022-04-25 10:18:31.692
Removing historical data download ID 84. | 2022-04-25 10:18:31.692
Triggering next historical data download in queue. | 2022-04-25 10:18:31.692
Mapping MBT-202010-CMECRYPTO-USD-0.1 to MBTV20. Service code: cme | 2022-04-25 10:18:31.693
HD Request # 143 | Downloading Historical Daily chart data for MBT-202010-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:18:31.693
HD Request # 143 | Requesting historical Daily data for BAV20 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:18:33.107
HD Request # 143 | Bytes received: 1 | 2022-04-25 10:18:33.936
HD Request # 143 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-202010-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:33.936
HD Request # 143 | Completion time: 2s | 2022-04-25 10:18:33.936
HD Request # 143 | Daily data download complete for MBT-202010-CMECRYPTO-USD-0.1. Unique request ID: 85 | 2022-04-25 10:18:33.936
Removing historical data download ID 85. | 2022-04-25 10:18:33.936
Triggering next historical data download in queue. | 2022-04-25 10:18:33.936
Mapping MBT-202011-CMECRYPTO-USD-0.1 to MBTX20. Service code: cme | 2022-04-25 10:18:33.936
HD Request # 144 | Downloading Historical Daily chart data for MBT-202011-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:18:33.937
HD Request # 144 | Requesting historical Daily data for BAX20 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:18:35.343
HD Request # 144 | Bytes received: 1 | 2022-04-25 10:18:36.147
HD Request # 144 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-202011-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:36.147
HD Request # 144 | Completion time: 3s | 2022-04-25 10:18:36.147
HD Request # 144 | Daily data download complete for MBT-202011-CMECRYPTO-USD-0.1. Unique request ID: 86 | 2022-04-25 10:18:36.147
Removing historical data download ID 86. | 2022-04-25 10:18:36.147
Triggering next historical data download in queue. | 2022-04-25 10:18:36.147
Mapping MBT-202012-CMECRYPTO-USD-0.1 to MBTZ20. Service code: cme | 2022-04-25 10:18:36.147
HD Request # 145 | Downloading Historical Daily chart data for MBT-202012-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:18:36.148
HD Request # 145 | Requesting historical Daily data for BAZ20 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:18:37.559
HD Request # 145 | Bytes received: 1 | 2022-04-25 10:18:38.389
HD Request # 145 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-202012-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:38.389
HD Request # 145 | Completion time: 2s | 2022-04-25 10:18:38.389
HD Request # 145 | Daily data download complete for MBT-202012-CMECRYPTO-USD-0.1. Unique request ID: 87 | 2022-04-25 10:18:38.389
Removing historical data download ID 87. | 2022-04-25 10:18:38.389
Triggering next historical data download in queue. | 2022-04-25 10:18:38.389
Mapping MBT-202101-CMECRYPTO-USD-0.1 to MBTF21. Service code: cme | 2022-04-25 10:18:38.389
HD Request # 146 | Downloading Historical Daily chart data for MBT-202101-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:18:38.390
HD Request # 146 | Requesting historical Daily data for BAF21 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:18:39.801
HD Request # 146 | Bytes received: 1 | 2022-04-25 10:18:40.628
HD Request # 146 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-202101-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:40.628
HD Request # 146 | Completion time: 2s | 2022-04-25 10:18:40.628
HD Request # 146 | Daily data download complete for MBT-202101-CMECRYPTO-USD-0.1. Unique request ID: 88 | 2022-04-25 10:18:40.628
Removing historical data download ID 88. | 2022-04-25 10:18:40.628
Triggering next historical data download in queue. | 2022-04-25 10:18:40.628
Mapping MBT-202102-CMECRYPTO-USD-0.1 to MBTG21. Service code: cme | 2022-04-25 10:18:40.629
HD Request # 147 | Downloading Historical Daily chart data for MBT-202102-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:18:40.629
HD Request # 147 | Requesting historical Daily data for BAG21 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:18:42.075
HD Request # 147 | Bytes received: 1 | 2022-04-25 10:18:42.834
HD Request # 147 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-202102-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:42.834
HD Request # 147 | Completion time: 2s | 2022-04-25 10:18:42.834
HD Request # 147 | Daily data download complete for MBT-202102-CMECRYPTO-USD-0.1. Unique request ID: 89 | 2022-04-25 10:18:42.834
Removing historical data download ID 89. | 2022-04-25 10:18:42.834
Triggering next historical data download in queue. | 2022-04-25 10:18:42.834
Mapping MBT-202103-CMECRYPTO-USD-0.1 to MBTH21. Service code: cme | 2022-04-25 10:18:42.834
HD Request # 148 | Downloading Historical Daily chart data for MBT-202103-CMECRYPTO-USD-0.1. Starting date: 1972-04-25. Service: interactive_brokers.trading | 2022-04-25 10:18:42.835
HD Request # 148 | Requesting historical Daily data for BAH21 starting at 1972-04-24. SC External HD service. | 2022-04-25 10:18:44.256
HD Request # 148 | Bytes received: 1 | 2022-04-25 10:18:45.081
HD Request # 148 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-202103-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:45.081
HD Request # 148 | Completion time: 3s | 2022-04-25 10:18:45.081
HD Request # 148 | Daily data download complete for MBT-202103-CMECRYPTO-USD-0.1. Unique request ID: 90 | 2022-04-25 10:18:45.081
Removing historical data download ID 90. | 2022-04-25 10:18:45.081
Triggering next historical data download in queue. | 2022-04-25 10:18:45.081
Mapping MBT-202104-CMECRYPTO-USD-0.1 to MBTJ21. Service code: cme | 2022-04-25 10:18:45.082
HD Request # 149 | Downloading Historical Daily chart data for MBT-202104-CMECRYPTO-USD-0.1. Starting date: 2021-03-24. Service: interactive_brokers.trading | 2022-04-25 10:18:45.082
HD Request # 149 | Requesting historical Daily data for BAJ21 starting at 2021-03-23. SC External HD service. | 2022-04-25 10:18:46.528
HD Request # 149 | Bytes received: 1 | 2022-04-25 10:18:47.325
HD Request # 149 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MBT-202104-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:47.325
HD Request # 149 | Completion time: 2s | 2022-04-25 10:18:47.325
HD Request # 149 | Daily data download complete for MBT-202104-CMECRYPTO-USD-0.1. Unique request ID: 91 | 2022-04-25 10:18:47.325
Removing historical data download ID 91. | 2022-04-25 10:18:47.325
Triggering next historical data download in queue. | 2022-04-25 10:18:47.325
Mapping MBT-202109-CMECRYPTO-USD-0.1 to MBTU21. Service code: cme | 2022-04-25 10:18:47.325
HD Request # 150 | Downloading Historical Daily chart data for MBT-202109-CMECRYPTO-USD-0.1. Starting date: 2021-09-22. Service: interactive_brokers.trading | 2022-04-25 10:18:47.327
HD Request # 150 | Requesting historical Daily data for BAU21 starting at 2021-09-21. SC External HD service. | 2022-04-25 10:18:48.763
HD Request # 150 | Receiving historical Daily data for MBT-202109-CMECRYPTO-USD-0.1 starting at 2021-09-22 | 2022-04-25 10:18:49.607
HD Request # 150 | Writing historical Daily data to the file MBT-202109-CMECRYPTO-USD-0.1.dly | 2022-04-25 10:18:49.607
HD Request # 150 | Bytes received: 207 | 2022-04-25 10:18:49.608
HD Request # 150 | Received 4 Daily data records from 2021-09-22 00:00:00 to 2021-09-24 00:00:00 (3.0 days) and wrote 3 records for MBT-202109-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:49.608
HD Request # 150 | Completion time: 2s | 2022-04-25 10:18:49.608
HD Request # 150 | Daily data download complete for MBT-202109-CMECRYPTO-USD-0.1. Unique request ID: 92 | 2022-04-25 10:18:49.608
Removing historical data download ID 92. | 2022-04-25 10:18:49.609
Triggering next historical data download in queue. | 2022-04-25 10:18:49.609
HD Request # 151 | Downloading Historical Daily chart data for MBT-202203-CMECRYPTO-USD-0.1. Starting date: 2022-03-23. Service: interactive_brokers.trading | 2022-04-25 10:18:49.610
HD Request # 151 | Requesting historical Daily data for BAH22 starting at 2022-03-22. SC External HD service. | 2022-04-25 10:18:51.033
HD Request # 151 | Receiving historical Daily data for MBT-202203-CMECRYPTO-USD-0.1 starting at 2022-03-23 | 2022-04-25 10:18:51.788
HD Request # 151 | Writing historical Daily data to the file MBT-202203-CMECRYPTO-USD-0.1.dly | 2022-04-25 10:18:51.789
HD Request # 151 | Bytes received: 207 | 2022-04-25 10:18:51.790
HD Request # 151 | Received 4 Daily data records from 2022-03-23 00:00:00 to 2022-03-25 00:00:00 (3.0 days) and wrote 3 records for MBT-202203-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:51.790
HD Request # 151 | Completion time: 2s | 2022-04-25 10:18:51.790
HD Request # 151 | Daily data download complete for MBT-202203-CMECRYPTO-USD-0.1. Unique request ID: 93 | 2022-04-25 10:18:51.790
Removing historical data download ID 93. | 2022-04-25 10:18:51.790
Triggering next historical data download in queue. | 2022-04-25 10:18:51.790
Mapping AUD-198703-GLOBEX to 6AH87. Service code: cme | 2022-04-25 10:18:51.790
HD Request # 152 | Downloading Historical Daily chart data for AUD-198703-GLOBEX. Starting date: 1986-12-11. Service: interactive_brokers.trading | 2022-04-25 10:18:51.791
MBT-202203-CMECRYPTO-USD-0.1[M] Daily #5 | Reloading chart. | 2022-04-25 10:18:51.931
MBT-202203-CMECRYPTO-USD-0.1[M] Daily #5 | StartDateTimeForLoadingOrderFills: 2021-09-24 00:00:00 | 2022-04-25 10:18:51.938
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:18:51.940
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Reloading chart. | 2022-04-25 10:18:51.941
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | StartDateTimeForLoadingOrderFills: 2016-05-26 00:00:00 | 2022-04-25 10:18:52.047
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Reloading chart. | 2022-04-25 10:18:52.207
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | Dates not found while checking for invalid data in continuous contract data files. MBT-202105-CMECRYPTO-USD-0.1 | 2022-04-25 10:18:52.433 *
MBT-202203-CMECRYPTO-USD-0.1 [C] Daily #4 | StartDateTimeForLoadingOrderFills: 2016-05-26 00:00:00 | 2022-04-25 10:18:52.541
HD Request # 152 | Requesting historical Daily data for A6H87 starting at 1986-12-10. SC External HD service. | 2022-04-25 10:18:53.213
HD Request # 152 | Receiving historical Daily data for AUD-198703-GLOBEX starting at 1987-01-13 | 2022-04-25 10:18:54.051
HD Request # 152 | Writing historical Daily data to the file AUD-198703-GLOBEX.dly | 2022-04-25 10:18:54.051
HD Request # 152 | Bytes received: 2120 | 2022-04-25 10:18:54.051
HD Request # 152 | Received 44 Daily data records from 1987-01-13 00:00:00 to 1987-03-16 00:00:00 (63.0 days) and wrote 44 records for AUD-198703-GLOBEX | 2022-04-25 10:18:54.051
HD Request # 152 | Completion time: 3s | 2022-04-25 10:18:54.051
HD Request # 152 | Daily data download complete for AUD-198703-GLOBEX. Unique request ID: 95 | 2022-04-25 10:18:54.051
Removing historical data download ID 95. | 2022-04-25 10:18:54.052
Triggering next historical data download in queue. | 2022-04-25 10:18:54.052
HD Request # 153 | Downloading Historical Daily chart data for AUD-202206-GLOBEX. Starting date: 2022-04-20. Service: interactive_brokers.trading | 2022-04-25 10:18:54.053
HD Request # 153 | Requesting historical Daily data for A6M22 starting at 2022-04-19. SC External HD service. | 2022-04-25 10:18:55.475
HD Request # 153 | Receiving historical Daily data for AUD-202206-GLOBEX starting at 2022-04-20 | 2022-04-25 10:18:56.245
HD Request # 153 | Writing historical Daily data to the file AUD-202206-GLOBEX.dly | 2022-04-25 10:18:56.246
HD Request # 153 | Bytes received: 241 | 2022-04-25 10:18:56.255
HD Request # 153 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for AUD-202206-GLOBEX | 2022-04-25 10:18:56.255
HD Request # 153 | Completion time: 2s | 2022-04-25 10:18:56.256
HD Request # 153 | Daily data download complete for AUD-202206-GLOBEX. Unique request ID: 96 | 2022-04-25 10:18:56.256
Removing historical data download ID 96. | 2022-04-25 10:18:56.256
Triggering next historical data download in queue. | 2022-04-25 10:18:56.256
HD Request # 154 | Downloading Historical Daily chart data for GBP-202206-GLOBEX. Starting date: 2022-04-20. Service: interactive_brokers.trading | 2022-04-25 10:18:56.257
AUD-202206-GLOBEX [C] 16 Day #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:18:56.286
AUD-202206-GLOBEX [C] 16 Day #2 | Reloading chart. | 2022-04-25 10:18:56.287
AUD-202206-GLOBEX [C] 16 Day #2 | Reloading chart. | 2022-04-25 10:18:56.540
AUD-202206-GLOBEX [C] 16 Day #2 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:18:56.541
AUD-202206-GLOBEX [C] 16 Day #2 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:18:56.541
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-200103-GLOBEX.dly has a volume of 0 at 2000-12-15. | 2022-04-25 10:18:57.697
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-200012-GLOBEX.dly has a volume of 0 at 2000-09-15. | 2022-04-25 10:18:57.708
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-200012-GLOBEX.dly has a volume of 0 at 2000-12-14. | 2022-04-25 10:18:57.708
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-200009-GLOBEX.dly has a volume of 0 at 2000-06-16. | 2022-04-25 10:18:57.718
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-200009-GLOBEX.dly has a volume of 0 at 2000-09-14. | 2022-04-25 10:18:57.718
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-200006-GLOBEX.dly has a volume of 0 at 2000-03-10. | 2022-04-25 10:18:57.728
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-200006-GLOBEX.dly has a volume of 0 at 2000-06-15. | 2022-04-25 10:18:57.728
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-200003-GLOBEX.dly has a volume of 0 at 1999-12-10. | 2022-04-25 10:18:57.738
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-200003-GLOBEX.dly has a volume of 0 at 2000-03-09. | 2022-04-25 10:18:57.738
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199912-GLOBEX.dly has a volume of 0 at 1999-09-10. | 2022-04-25 10:18:57.749
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199912-GLOBEX.dly has a volume of 0 at 1999-12-09. | 2022-04-25 10:18:57.749
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199909-GLOBEX.dly has a volume of 0 at 1999-06-11. | 2022-04-25 10:18:57.759
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199909-GLOBEX.dly has a volume of 0 at 1999-09-09. | 2022-04-25 10:18:57.759
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199906-GLOBEX.dly has a volume of 0 at 1999-03-12. | 2022-04-25 10:18:57.769
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199906-GLOBEX.dly has a volume of 0 at 1999-06-10. | 2022-04-25 10:18:57.769
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199903-GLOBEX.dly has a volume of 0 at 1998-12-11. | 2022-04-25 10:18:57.779
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199903-GLOBEX.dly has a volume of 0 at 1999-03-11. | 2022-04-25 10:18:57.779
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199812-GLOBEX.dly has a volume of 0 at 1998-09-11. | 2022-04-25 10:18:57.788
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199812-GLOBEX.dly has a volume of 0 at 1998-12-10. | 2022-04-25 10:18:57.788
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199809-GLOBEX.dly has a volume of 0 at 1998-06-12. | 2022-04-25 10:18:57.800
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199809-GLOBEX.dly has a volume of 0 at 1998-09-10. | 2022-04-25 10:18:57.800
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199806-GLOBEX.dly has a volume of 0 at 1998-03-13. | 2022-04-25 10:18:57.810
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199806-GLOBEX.dly has a volume of 0 at 1998-06-11. | 2022-04-25 10:18:57.810
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199803-GLOBEX.dly has a volume of 0 at 1997-12-12. | 2022-04-25 10:18:57.820
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199803-GLOBEX.dly has a volume of 0 at 1998-03-12. | 2022-04-25 10:18:57.820
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199712-GLOBEX.dly has a volume of 0 at 1997-09-12. | 2022-04-25 10:18:57.831
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199712-GLOBEX.dly has a volume of 0 at 1997-12-11. | 2022-04-25 10:18:57.831
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199709-GLOBEX.dly has a volume of 0 at 1997-06-13. | 2022-04-25 10:18:57.841
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199709-GLOBEX.dly has a volume of 0 at 1997-09-11. | 2022-04-25 10:18:57.841
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199706-GLOBEX.dly has a volume of 0 at 1997-03-14. | 2022-04-25 10:18:57.851
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199706-GLOBEX.dly has a volume of 0 at 1997-06-12. | 2022-04-25 10:18:57.851
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199703-GLOBEX.dly has a volume of 0 at 1996-12-13. | 2022-04-25 10:18:57.861
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199703-GLOBEX.dly has a volume of 0 at 1997-03-13. | 2022-04-25 10:18:57.861
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199612-GLOBEX.dly has a volume of 0 at 1996-09-13. | 2022-04-25 10:18:57.872
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199612-GLOBEX.dly has a volume of 0 at 1996-12-12. | 2022-04-25 10:18:57.872
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199609-GLOBEX.dly has a volume of 0 at 1996-06-14. | 2022-04-25 10:18:57.882
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199609-GLOBEX.dly has a volume of 0 at 1996-09-12. | 2022-04-25 10:18:57.882
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199606-GLOBEX.dly has a volume of 0 at 1996-03-15. | 2022-04-25 10:18:57.892
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199606-GLOBEX.dly has a volume of 0 at 1996-06-13. | 2022-04-25 10:18:57.892
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199603-GLOBEX.dly has a volume of 0 at 1995-12-15. | 2022-04-25 10:18:57.902
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199603-GLOBEX.dly has a volume of 0 at 1996-03-14. | 2022-04-25 10:18:57.902
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199512-GLOBEX.dly has a volume of 0 at 1995-09-15. | 2022-04-25 10:18:57.912
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199512-GLOBEX.dly has a volume of 0 at 1995-12-14. | 2022-04-25 10:18:57.912
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199509-GLOBEX.dly has a volume of 0 at 1995-06-16. | 2022-04-25 10:18:57.921
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199509-GLOBEX.dly has a volume of 0 at 1995-09-14. | 2022-04-25 10:18:57.921
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199506-GLOBEX.dly has a volume of 0 at 1995-03-10. | 2022-04-25 10:18:57.932
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199506-GLOBEX.dly has a volume of 0 at 1995-06-15. | 2022-04-25 10:18:57.932
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199503-GLOBEX.dly has a volume of 0 at 1994-12-16. | 2022-04-25 10:18:57.941
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199503-GLOBEX.dly has a volume of 0 at 1995-03-09. | 2022-04-25 10:18:57.941
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199412-GLOBEX.dly has a volume of 0 at 1994-09-16. | 2022-04-25 10:18:57.951
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199412-GLOBEX.dly has a volume of 0 at 1994-12-15. | 2022-04-25 10:18:57.951
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199409-GLOBEX.dly has a volume of 0 at 1994-06-10. | 2022-04-25 10:18:57.961
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199409-GLOBEX.dly has a volume of 0 at 1994-09-15. | 2022-04-25 10:18:57.961
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199406-GLOBEX.dly has a volume of 0 at 1994-03-11. | 2022-04-25 10:18:57.971
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199406-GLOBEX.dly has a volume of 0 at 1994-06-09. | 2022-04-25 10:18:57.971
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199403-GLOBEX.dly has a volume of 0 at 1993-12-10. | 2022-04-25 10:18:57.981
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199403-GLOBEX.dly has a volume of 0 at 1994-03-10. | 2022-04-25 10:18:57.981
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199312-GLOBEX.dly has a volume of 0 at 1993-09-10. | 2022-04-25 10:18:57.991
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199312-GLOBEX.dly has a volume of 0 at 1993-12-09. | 2022-04-25 10:18:57.991
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199309-GLOBEX.dly has a volume of 0 at 1993-06-11. | 2022-04-25 10:18:58.001
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199309-GLOBEX.dly has a volume of 0 at 1993-09-09. | 2022-04-25 10:18:58.001
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199306-GLOBEX.dly has a volume of 0 at 1993-03-12. | 2022-04-25 10:18:58.011
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199306-GLOBEX.dly has a volume of 0 at 1993-06-10. | 2022-04-25 10:18:58.011
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199303-GLOBEX.dly has a volume of 0 at 1992-12-11. | 2022-04-25 10:18:58.021
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199303-GLOBEX.dly has a volume of 0 at 1993-03-11. | 2022-04-25 10:18:58.021
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199212-GLOBEX.dly has a volume of 0 at 1992-09-11. | 2022-04-25 10:18:58.031
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199212-GLOBEX.dly has a volume of 0 at 1992-12-10. | 2022-04-25 10:18:58.031
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199209-GLOBEX.dly has a volume of 0 at 1992-06-12. | 2022-04-25 10:18:58.041
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199209-GLOBEX.dly has a volume of 0 at 1992-09-10. | 2022-04-25 10:18:58.041
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199206-GLOBEX.dly has a volume of 0 at 1992-03-13. | 2022-04-25 10:18:58.050
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199206-GLOBEX.dly has a volume of 0 at 1992-06-11. | 2022-04-25 10:18:58.050
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199203-GLOBEX.dly has a volume of 0 at 1991-12-13. | 2022-04-25 10:18:58.060
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199203-GLOBEX.dly has a volume of 0 at 1992-03-12. | 2022-04-25 10:18:58.060
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199112-GLOBEX.dly has a volume of 0 at 1991-09-13. | 2022-04-25 10:18:58.070
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199112-GLOBEX.dly has a volume of 0 at 1991-12-12. | 2022-04-25 10:18:58.070
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199109-GLOBEX.dly has a volume of 0 at 1991-06-14. | 2022-04-25 10:18:58.080
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199109-GLOBEX.dly has a volume of 0 at 1991-09-12. | 2022-04-25 10:18:58.080
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199106-GLOBEX.dly has a volume of 0 at 1991-03-15. | 2022-04-25 10:18:58.090
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199106-GLOBEX.dly has a volume of 0 at 1991-06-13. | 2022-04-25 10:18:58.090
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199103-GLOBEX.dly has a volume of 0 at 1990-12-14. | 2022-04-25 10:18:58.100
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199103-GLOBEX.dly has a volume of 0 at 1991-03-14. | 2022-04-25 10:18:58.100
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199012-GLOBEX.dly has a volume of 0 at 1990-09-14. | 2022-04-25 10:18:58.110
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199012-GLOBEX.dly has a volume of 0 at 1990-12-13. | 2022-04-25 10:18:58.110
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199009-GLOBEX.dly has a volume of 0 at 1990-06-15. | 2022-04-25 10:18:58.120
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199009-GLOBEX.dly has a volume of 0 at 1990-09-13. | 2022-04-25 10:18:58.120
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199006-GLOBEX.dly has a volume of 0 at 1990-03-16. | 2022-04-25 10:18:58.130
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199006-GLOBEX.dly has a volume of 0 at 1990-06-14. | 2022-04-25 10:18:58.130
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199003-GLOBEX.dly has a volume of 0 at 1989-12-15. | 2022-04-25 10:18:58.139
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-199003-GLOBEX.dly has a volume of 0 at 1990-03-15. | 2022-04-25 10:18:58.139
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198912-GLOBEX.dly has a volume of 0 at 1989-09-15. | 2022-04-25 10:18:58.150
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198912-GLOBEX.dly has a volume of 0 at 1989-12-14. | 2022-04-25 10:18:58.150
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198909-GLOBEX.dly has a volume of 0 at 1989-06-16. | 2022-04-25 10:18:58.159
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198909-GLOBEX.dly has a volume of 0 at 1989-09-14. | 2022-04-25 10:18:58.159
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198906-GLOBEX.dly has a volume of 0 at 1989-03-10. | 2022-04-25 10:18:58.170
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198906-GLOBEX.dly has a volume of 0 at 1989-06-15. | 2022-04-25 10:18:58.170
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198903-GLOBEX.dly has a volume of 0 at 1988-12-16. | 2022-04-25 10:18:58.179
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198903-GLOBEX.dly has a volume of 0 at 1989-03-09. | 2022-04-25 10:18:58.179
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198812-GLOBEX.dly has a volume of 0 at 1988-09-16. | 2022-04-25 10:18:58.189
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198812-GLOBEX.dly has a volume of 0 at 1988-12-15. | 2022-04-25 10:18:58.189
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198809-GLOBEX.dly has a volume of 0 at 1988-06-10. | 2022-04-25 10:18:58.199
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198809-GLOBEX.dly has a volume of 0 at 1988-09-15. | 2022-04-25 10:18:58.199
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198806-GLOBEX.dly has a volume of 0 at 1988-03-11. | 2022-04-25 10:18:58.209
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198806-GLOBEX.dly has a volume of 0 at 1988-06-09. | 2022-04-25 10:18:58.209
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198803-GLOBEX.dly has a volume of 0 at 1987-12-11. | 2022-04-25 10:18:58.219
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198803-GLOBEX.dly has a volume of 0 at 1988-03-10. | 2022-04-25 10:18:58.219
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198712-GLOBEX.dly has a volume of 0 at 1987-09-11. | 2022-04-25 10:18:58.230
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198712-GLOBEX.dly has a volume of 0 at 1987-12-10. | 2022-04-25 10:18:58.230
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198709-GLOBEX.dly has a volume of 0 at 1987-06-12. | 2022-04-25 10:18:58.240
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198709-GLOBEX.dly has a volume of 0 at 1987-09-10. | 2022-04-25 10:18:58.240
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198706-GLOBEX.dly has a volume of 0 at 1987-03-13. | 2022-04-25 10:18:58.249
AUD-202206-GLOBEX [C] 16 Day #2 | File AUD-198706-GLOBEX.dly has a volume of 0 at 1987-06-11. | 2022-04-25 10:18:58.249
AUD-202206-GLOBEX [C] 16 Day #2 | Dates not found while checking for invalid data in continuous contract data files. AUD-198703-GLOBEX | 2022-04-25 10:18:58.256 *
Restarting the loading process. | 2022-04-25 10:18:58.257
HD Request # 154 | Requesting historical Daily data for B6M22 starting at 2022-04-19. SC External HD service. | 2022-04-25 10:18:59.328
HD Request # 154 | Receiving historical Daily data for GBP-202206-GLOBEX starting at 2022-04-20 | 2022-04-25 10:19:00.168
HD Request # 154 | Writing historical Daily data to the file GBP-202206-GLOBEX.dly | 2022-04-25 10:19:00.169
HD Request # 154 | Bytes received: 232 | 2022-04-25 10:19:00.178
HD Request # 154 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for GBP-202206-GLOBEX | 2022-04-25 10:19:00.178
HD Request # 154 | Completion time: 4s | 2022-04-25 10:19:00.178
HD Request # 154 | Daily data download complete for GBP-202206-GLOBEX. Unique request ID: 97 | 2022-04-25 10:19:00.178
Removing historical data download ID 97. | 2022-04-25 10:19:00.178
Triggering next historical data download in queue. | 2022-04-25 10:19:00.179
HD Request # 155 | Downloading Historical Daily chart data for DIA-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:00.180
GBP-202206-GLOBEX [C] 64 Day #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-04-25 10:19:00.322
GBP-202206-GLOBEX [C] 64 Day #8 | Reloading chart. | 2022-04-25 10:19:00.323
GBP-202206-GLOBEX [C] 64 Day #8 | Reloading chart. | 2022-04-25 10:19:00.570
GBP-202206-GLOBEX [C] 64 Day #8 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:19:00.570
GBP-202206-GLOBEX [C] 64 Day #8 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 10:19:00.570
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-200103-GLOBEX.dly has a volume of 0 at 2000-12-15. | 2022-04-25 10:19:01.758
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-200012-GLOBEX.dly has a volume of 0 at 2000-09-15. | 2022-04-25 10:19:01.768
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-200012-GLOBEX.dly has a volume of 0 at 2000-12-14. | 2022-04-25 10:19:01.768
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-200009-GLOBEX.dly has a volume of 0 at 2000-06-16. | 2022-04-25 10:19:01.778
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-200009-GLOBEX.dly has a volume of 0 at 2000-09-14. | 2022-04-25 10:19:01.778
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-200006-GLOBEX.dly has a volume of 0 at 2000-03-10. | 2022-04-25 10:19:01.789
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-200006-GLOBEX.dly has a volume of 0 at 2000-06-15. | 2022-04-25 10:19:01.789
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-200003-GLOBEX.dly has a volume of 0 at 1999-12-10. | 2022-04-25 10:19:01.799
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-200003-GLOBEX.dly has a volume of 0 at 2000-03-09. | 2022-04-25 10:19:01.799
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199912-GLOBEX.dly has a volume of 0 at 1999-09-10. | 2022-04-25 10:19:01.809
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199912-GLOBEX.dly has a volume of 0 at 1999-12-09. | 2022-04-25 10:19:01.809
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199909-GLOBEX.dly has a volume of 0 at 1999-06-11. | 2022-04-25 10:19:01.819
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199909-GLOBEX.dly has a volume of 0 at 1999-09-09. | 2022-04-25 10:19:01.819
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199906-GLOBEX.dly has a volume of 0 at 1999-03-12. | 2022-04-25 10:19:01.828
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199906-GLOBEX.dly has a volume of 0 at 1999-06-10. | 2022-04-25 10:19:01.828
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199903-GLOBEX.dly has a volume of 0 at 1998-12-11. | 2022-04-25 10:19:01.838
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199903-GLOBEX.dly has a volume of 0 at 1999-03-11. | 2022-04-25 10:19:01.838
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199812-GLOBEX.dly has a volume of 0 at 1998-09-11. | 2022-04-25 10:19:01.848
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199812-GLOBEX.dly has a volume of 0 at 1998-12-10. | 2022-04-25 10:19:01.848
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199809-GLOBEX.dly has a volume of 0 at 1998-06-12. | 2022-04-25 10:19:01.857
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199809-GLOBEX.dly has a volume of 0 at 1998-09-10. | 2022-04-25 10:19:01.857
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199806-GLOBEX.dly has a volume of 0 at 1998-03-13. | 2022-04-25 10:19:01.867
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199806-GLOBEX.dly has a volume of 0 at 1998-06-11. | 2022-04-25 10:19:01.867
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199803-GLOBEX.dly has a volume of 0 at 1997-12-12. | 2022-04-25 10:19:01.877
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199803-GLOBEX.dly has a volume of 0 at 1998-03-12. | 2022-04-25 10:19:01.877
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199712-GLOBEX.dly has a volume of 0 at 1997-09-12. | 2022-04-25 10:19:01.887
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199712-GLOBEX.dly has a volume of 0 at 1997-12-11. | 2022-04-25 10:19:01.887
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199709-GLOBEX.dly has a volume of 0 at 1997-06-13. | 2022-04-25 10:19:01.898
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199709-GLOBEX.dly has a volume of 0 at 1997-09-11. | 2022-04-25 10:19:01.898
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199706-GLOBEX.dly has a volume of 0 at 1997-03-14. | 2022-04-25 10:19:01.908
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199706-GLOBEX.dly has a volume of 0 at 1997-06-12. | 2022-04-25 10:19:01.908
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199703-GLOBEX.dly has a volume of 0 at 1996-12-13. | 2022-04-25 10:19:01.917
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199703-GLOBEX.dly has a volume of 0 at 1997-03-13. | 2022-04-25 10:19:01.917
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199612-GLOBEX.dly has a volume of 0 at 1996-09-13. | 2022-04-25 10:19:01.928
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199612-GLOBEX.dly has a volume of 0 at 1996-12-12. | 2022-04-25 10:19:01.928
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199609-GLOBEX.dly has a volume of 0 at 1996-06-14. | 2022-04-25 10:19:01.938
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199609-GLOBEX.dly has a volume of 0 at 1996-09-12. | 2022-04-25 10:19:01.938
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199606-GLOBEX.dly has a volume of 0 at 1996-03-15. | 2022-04-25 10:19:01.948
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199606-GLOBEX.dly has a volume of 0 at 1996-06-13. | 2022-04-25 10:19:01.948
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199603-GLOBEX.dly has a volume of 0 at 1995-12-15. | 2022-04-25 10:19:01.958
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199603-GLOBEX.dly has a volume of 0 at 1996-03-14. | 2022-04-25 10:19:01.958
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199512-GLOBEX.dly has a volume of 0 at 1995-09-15. | 2022-04-25 10:19:01.968
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199512-GLOBEX.dly has a volume of 0 at 1995-12-14. | 2022-04-25 10:19:01.968
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199509-GLOBEX.dly has a volume of 0 at 1995-06-16. | 2022-04-25 10:19:01.978
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199509-GLOBEX.dly has a volume of 0 at 1995-09-14. | 2022-04-25 10:19:01.978
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199506-GLOBEX.dly has a volume of 0 at 1995-03-10. | 2022-04-25 10:19:01.988
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199506-GLOBEX.dly has a volume of 0 at 1995-06-15. | 2022-04-25 10:19:01.988
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199503-GLOBEX.dly has a volume of 0 at 1994-12-16. | 2022-04-25 10:19:01.997
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199503-GLOBEX.dly has a volume of 0 at 1995-03-09. | 2022-04-25 10:19:01.997
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199412-GLOBEX.dly has a volume of 0 at 1994-09-16. | 2022-04-25 10:19:02.007
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199412-GLOBEX.dly has a volume of 0 at 1994-12-15. | 2022-04-25 10:19:02.007
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199409-GLOBEX.dly has a volume of 0 at 1994-06-10. | 2022-04-25 10:19:02.018
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199409-GLOBEX.dly has a volume of 0 at 1994-09-15. | 2022-04-25 10:19:02.018
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199406-GLOBEX.dly has a volume of 0 at 1994-03-11. | 2022-04-25 10:19:02.028
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199406-GLOBEX.dly has a volume of 0 at 1994-06-09. | 2022-04-25 10:19:02.028
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199403-GLOBEX.dly has a volume of 0 at 1993-12-10. | 2022-04-25 10:19:02.037
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199403-GLOBEX.dly has a volume of 0 at 1994-03-10. | 2022-04-25 10:19:02.037
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199312-GLOBEX.dly has a volume of 0 at 1993-09-10. | 2022-04-25 10:19:02.048
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199312-GLOBEX.dly has a volume of 0 at 1993-12-09. | 2022-04-25 10:19:02.048
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199309-GLOBEX.dly has a volume of 0 at 1993-06-11. | 2022-04-25 10:19:02.057
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199309-GLOBEX.dly has a volume of 0 at 1993-09-09. | 2022-04-25 10:19:02.057
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199306-GLOBEX.dly has a volume of 0 at 1993-03-12. | 2022-04-25 10:19:02.067
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199306-GLOBEX.dly has a volume of 0 at 1993-06-10. | 2022-04-25 10:19:02.067
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199303-GLOBEX.dly has a volume of 0 at 1992-12-11. | 2022-04-25 10:19:02.077
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199303-GLOBEX.dly has a volume of 0 at 1993-03-11. | 2022-04-25 10:19:02.077
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199212-GLOBEX.dly has a volume of 0 at 1992-09-11. | 2022-04-25 10:19:02.087
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199212-GLOBEX.dly has a volume of 0 at 1992-12-10. | 2022-04-25 10:19:02.087
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199209-GLOBEX.dly has a volume of 0 at 1992-06-12. | 2022-04-25 10:19:02.097
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199209-GLOBEX.dly has a volume of 0 at 1992-09-10. | 2022-04-25 10:19:02.097
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199206-GLOBEX.dly has a volume of 0 at 1992-03-13. | 2022-04-25 10:19:02.107
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199206-GLOBEX.dly has a volume of 0 at 1992-06-11. | 2022-04-25 10:19:02.107
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199203-GLOBEX.dly has a volume of 0 at 1991-12-13. | 2022-04-25 10:19:02.117
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199203-GLOBEX.dly has a volume of 0 at 1992-03-12. | 2022-04-25 10:19:02.117
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199112-GLOBEX.dly has a volume of 0 at 1991-09-13. | 2022-04-25 10:19:02.127
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199112-GLOBEX.dly has a volume of 0 at 1991-12-12. | 2022-04-25 10:19:02.127
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199109-GLOBEX.dly has a volume of 0 at 1991-06-14. | 2022-04-25 10:19:02.136
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199109-GLOBEX.dly has a volume of 0 at 1991-09-12. | 2022-04-25 10:19:02.136
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199106-GLOBEX.dly has a volume of 0 at 1991-03-15. | 2022-04-25 10:19:02.146
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199106-GLOBEX.dly has a volume of 0 at 1991-06-13. | 2022-04-25 10:19:02.146
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199103-GLOBEX.dly has a volume of 0 at 1990-12-14. | 2022-04-25 10:19:02.156
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199103-GLOBEX.dly has a volume of 0 at 1991-03-14. | 2022-04-25 10:19:02.156
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199012-GLOBEX.dly has a volume of 0 at 1990-09-14. | 2022-04-25 10:19:02.166
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199012-GLOBEX.dly has a volume of 0 at 1990-12-13. | 2022-04-25 10:19:02.166
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199009-GLOBEX.dly has a volume of 0 at 1990-06-15. | 2022-04-25 10:19:02.176
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199009-GLOBEX.dly has a volume of 0 at 1990-09-13. | 2022-04-25 10:19:02.176
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199006-GLOBEX.dly has a volume of 0 at 1990-03-16. | 2022-04-25 10:19:02.186
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199006-GLOBEX.dly has a volume of 0 at 1990-06-14. | 2022-04-25 10:19:02.186
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199003-GLOBEX.dly has a volume of 0 at 1989-12-15. | 2022-04-25 10:19:02.195
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-199003-GLOBEX.dly has a volume of 0 at 1990-03-15. | 2022-04-25 10:19:02.195
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198912-GLOBEX.dly has a volume of 0 at 1989-09-15. | 2022-04-25 10:19:02.206
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198912-GLOBEX.dly has a volume of 0 at 1989-12-14. | 2022-04-25 10:19:02.206
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198909-GLOBEX.dly has a volume of 0 at 1989-06-16. | 2022-04-25 10:19:02.215
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198909-GLOBEX.dly has a volume of 0 at 1989-09-14. | 2022-04-25 10:19:02.215
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198906-GLOBEX.dly has a volume of 0 at 1989-03-10. | 2022-04-25 10:19:02.226
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198906-GLOBEX.dly has a volume of 0 at 1989-06-15. | 2022-04-25 10:19:02.226
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198903-GLOBEX.dly has a volume of 0 at 1988-12-16. | 2022-04-25 10:19:02.235
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198903-GLOBEX.dly has a volume of 0 at 1989-03-09. | 2022-04-25 10:19:02.235
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198812-GLOBEX.dly has a volume of 0 at 1988-09-16. | 2022-04-25 10:19:02.245
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198812-GLOBEX.dly has a volume of 0 at 1988-12-15. | 2022-04-25 10:19:02.245
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198809-GLOBEX.dly has a volume of 0 at 1988-06-10. | 2022-04-25 10:19:02.256
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198809-GLOBEX.dly has a volume of 0 at 1988-09-15. | 2022-04-25 10:19:02.256
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198806-GLOBEX.dly has a volume of 0 at 1988-03-11. | 2022-04-25 10:19:02.265
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198806-GLOBEX.dly has a volume of 0 at 1988-06-09. | 2022-04-25 10:19:02.265
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198803-GLOBEX.dly has a volume of 0 at 1987-12-11. | 2022-04-25 10:19:02.275
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198803-GLOBEX.dly has a volume of 0 at 1988-03-10. | 2022-04-25 10:19:02.275
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198712-GLOBEX.dly has a volume of 0 at 1987-09-11. | 2022-04-25 10:19:02.285
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198712-GLOBEX.dly has a volume of 0 at 1987-12-10. | 2022-04-25 10:19:02.285
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198709-GLOBEX.dly has a volume of 0 at 1987-06-12. | 2022-04-25 10:19:02.295
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198709-GLOBEX.dly has a volume of 0 at 1987-09-10. | 2022-04-25 10:19:02.295
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198706-GLOBEX.dly has a volume of 0 at 1987-03-13. | 2022-04-25 10:19:02.305
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198706-GLOBEX.dly has a volume of 0 at 1987-06-11. | 2022-04-25 10:19:02.305
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198703-GLOBEX.dly has a volume of 0 at 1986-12-12. | 2022-04-25 10:19:02.315
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198703-GLOBEX.dly has a volume of 0 at 1987-03-12. | 2022-04-25 10:19:02.315
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198612-GLOBEX.dly has a volume of 0 at 1986-09-12. | 2022-04-25 10:19:02.325
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198612-GLOBEX.dly has a volume of 0 at 1986-12-11. | 2022-04-25 10:19:02.325
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198609-GLOBEX.dly has a volume of 0 at 1986-06-13. | 2022-04-25 10:19:02.335
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198609-GLOBEX.dly has a volume of 0 at 1986-09-11. | 2022-04-25 10:19:02.335
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198606-GLOBEX.dly has a volume of 0 at 1986-03-14. | 2022-04-25 10:19:02.345
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198606-GLOBEX.dly has a volume of 0 at 1986-06-12. | 2022-04-25 10:19:02.345
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198603-GLOBEX.dly has a volume of 0 at 1985-12-13. | 2022-04-25 10:19:02.354
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198603-GLOBEX.dly has a volume of 0 at 1986-03-13. | 2022-04-25 10:19:02.354
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198512-GLOBEX.dly has a volume of 0 at 1985-09-13. | 2022-04-25 10:19:02.365
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198512-GLOBEX.dly has a volume of 0 at 1985-12-12. | 2022-04-25 10:19:02.365
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198509-GLOBEX.dly has a volume of 0 at 1985-06-14. | 2022-04-25 10:19:02.374
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198509-GLOBEX.dly has a volume of 0 at 1985-09-12. | 2022-04-25 10:19:02.374
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198506-GLOBEX.dly has a volume of 0 at 1985-03-15. | 2022-04-25 10:19:02.384
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198506-GLOBEX.dly has a volume of 0 at 1985-06-13. | 2022-04-25 10:19:02.384
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198503-GLOBEX.dly has a volume of 0 at 1984-12-14. | 2022-04-25 10:19:02.394
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198503-GLOBEX.dly has a volume of 0 at 1985-03-14. | 2022-04-25 10:19:02.394
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198412-GLOBEX.dly has a volume of 0 at 1984-09-14. | 2022-04-25 10:19:02.404
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198412-GLOBEX.dly has a volume of 0 at 1984-12-13. | 2022-04-25 10:19:02.404
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198409-GLOBEX.dly has a volume of 0 at 1984-06-15. | 2022-04-25 10:19:02.414
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198409-GLOBEX.dly has a volume of 0 at 1984-09-13. | 2022-04-25 10:19:02.414
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198406-GLOBEX.dly has a volume of 0 at 1984-03-16. | 2022-04-25 10:19:02.424
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198406-GLOBEX.dly has a volume of 0 at 1984-06-14. | 2022-04-25 10:19:02.424
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198403-GLOBEX.dly has a volume of 0 at 1983-12-16. | 2022-04-25 10:19:02.433
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198403-GLOBEX.dly has a volume of 0 at 1984-03-15. | 2022-04-25 10:19:02.433
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198312-GLOBEX.dly has a volume of 0 at 1983-09-16. | 2022-04-25 10:19:02.443
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198312-GLOBEX.dly has a volume of 0 at 1983-12-15. | 2022-04-25 10:19:02.443
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198309-GLOBEX.dly has a volume of 0 at 1983-06-10. | 2022-04-25 10:19:02.454
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198309-GLOBEX.dly has a volume of 0 at 1983-09-15. | 2022-04-25 10:19:02.454
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198306-GLOBEX.dly has a volume of 0 at 1983-03-11. | 2022-04-25 10:19:02.464
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198306-GLOBEX.dly has a volume of 0 at 1983-06-09. | 2022-04-25 10:19:02.464
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198303-GLOBEX.dly has a volume of 0 at 1982-12-10. | 2022-04-25 10:19:02.473
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198303-GLOBEX.dly has a volume of 0 at 1983-03-10. | 2022-04-25 10:19:02.473
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198212-GLOBEX.dly has a volume of 0 at 1982-09-10. | 2022-04-25 10:19:02.483
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198212-GLOBEX.dly has a volume of 0 at 1982-12-09. | 2022-04-25 10:19:02.483
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198209-GLOBEX.dly has a volume of 0 at 1982-06-11. | 2022-04-25 10:19:02.493
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198209-GLOBEX.dly has a volume of 0 at 1982-09-09. | 2022-04-25 10:19:02.493
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198206-GLOBEX.dly has a volume of 0 at 1982-03-12. | 2022-04-25 10:19:02.503
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198206-GLOBEX.dly has a volume of 0 at 1982-06-10. | 2022-04-25 10:19:02.503
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198203-GLOBEX.dly has a volume of 0 at 1981-12-11. | 2022-04-25 10:19:02.513
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198203-GLOBEX.dly has a volume of 0 at 1982-03-11. | 2022-04-25 10:19:02.513
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198112-GLOBEX.dly has a volume of 0 at 1981-09-11. | 2022-04-25 10:19:02.523
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198112-GLOBEX.dly has a volume of 0 at 1981-12-10. | 2022-04-25 10:19:02.523
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198109-GLOBEX.dly has a volume of 0 at 1981-06-12. | 2022-04-25 10:19:02.533
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198109-GLOBEX.dly has a volume of 0 at 1981-09-10. | 2022-04-25 10:19:02.533
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198106-GLOBEX.dly has a volume of 0 at 1981-03-13. | 2022-04-25 10:19:02.543
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198106-GLOBEX.dly has a volume of 0 at 1981-06-11. | 2022-04-25 10:19:02.543
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198103-GLOBEX.dly has a volume of 0 at 1980-12-12. | 2022-04-25 10:19:02.553
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198103-GLOBEX.dly has a volume of 0 at 1981-03-12. | 2022-04-25 10:19:02.553
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198012-GLOBEX.dly has a volume of 0 at 1980-09-12. | 2022-04-25 10:19:02.562
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198012-GLOBEX.dly has a volume of 0 at 1980-12-11. | 2022-04-25 10:19:02.562
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198009-GLOBEX.dly has a volume of 0 at 1980-06-13. | 2022-04-25 10:19:02.572
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198009-GLOBEX.dly has a volume of 0 at 1980-09-11. | 2022-04-25 10:19:02.572
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198006-GLOBEX.dly has a volume of 0 at 1980-03-14. | 2022-04-25 10:19:02.582
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198006-GLOBEX.dly has a volume of 0 at 1980-06-12. | 2022-04-25 10:19:02.582
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198003-GLOBEX.dly has a volume of 0 at 1979-12-14. | 2022-04-25 10:19:02.592
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-198003-GLOBEX.dly has a volume of 0 at 1980-03-13. | 2022-04-25 10:19:02.592
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197912-GLOBEX.dly has a volume of 0 at 1979-09-14. | 2022-04-25 10:19:02.602
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197912-GLOBEX.dly has a volume of 0 at 1979-12-13. | 2022-04-25 10:19:02.602
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197909-GLOBEX.dly has a volume of 0 at 1979-06-15. | 2022-04-25 10:19:02.612
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197909-GLOBEX.dly has a volume of 0 at 1979-09-13. | 2022-04-25 10:19:02.612
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197906-GLOBEX.dly has a volume of 0 at 1979-03-16. | 2022-04-25 10:19:02.622
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197906-GLOBEX.dly has a volume of 0 at 1979-06-14. | 2022-04-25 10:19:02.622
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197903-GLOBEX.dly has a volume of 0 at 1978-12-15. | 2022-04-25 10:19:02.632
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197903-GLOBEX.dly has a volume of 0 at 1979-03-15. | 2022-04-25 10:19:02.632
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197812-GLOBEX.dly has a volume of 0 at 1978-09-15. | 2022-04-25 10:19:02.642
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197812-GLOBEX.dly has a volume of 0 at 1978-12-14. | 2022-04-25 10:19:02.642
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197809-GLOBEX.dly has a volume of 0 at 1978-06-16. | 2022-04-25 10:19:02.651
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197809-GLOBEX.dly has a volume of 0 at 1978-09-14. | 2022-04-25 10:19:02.651
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197806-GLOBEX.dly has a volume of 0 at 1978-03-10. | 2022-04-25 10:19:02.662
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197806-GLOBEX.dly has a volume of 0 at 1978-06-15. | 2022-04-25 10:19:02.662
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197803-GLOBEX.dly has a volume of 0 at 1977-12-16. | 2022-04-25 10:19:02.671
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197803-GLOBEX.dly has a volume of 0 at 1978-03-09. | 2022-04-25 10:19:02.671
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197712-GLOBEX.dly has a volume of 0 at 1977-09-16. | 2022-04-25 10:19:02.681
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197712-GLOBEX.dly has a volume of 0 at 1977-12-15. | 2022-04-25 10:19:02.681
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197709-GLOBEX.dly has a volume of 0 at 1977-06-10. | 2022-04-25 10:19:02.692
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197709-GLOBEX.dly has a volume of 0 at 1977-09-15. | 2022-04-25 10:19:02.692
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197706-GLOBEX.dly has a volume of 0 at 1977-03-11. | 2022-04-25 10:19:02.701
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197706-GLOBEX.dly has a volume of 0 at 1977-06-09. | 2022-04-25 10:19:02.701
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197703-GLOBEX.dly has a volume of 0 at 1976-12-10. | 2022-04-25 10:19:02.711
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197703-GLOBEX.dly has a volume of 0 at 1977-03-10. | 2022-04-25 10:19:02.711
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197612-GLOBEX.dly has a volume of 0 at 1976-09-10. | 2022-04-25 10:19:02.721
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197612-GLOBEX.dly has a volume of 0 at 1976-12-09. | 2022-04-25 10:19:02.721
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197609-GLOBEX.dly has a volume of 0 at 1976-06-11. | 2022-04-25 10:19:02.730
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197609-GLOBEX.dly has a volume of 0 at 1976-09-09. | 2022-04-25 10:19:02.730
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197606-GLOBEX.dly has a volume of 0 at 1976-03-12. | 2022-04-25 10:19:02.740
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197606-GLOBEX.dly has a volume of 0 at 1976-06-10. | 2022-04-25 10:19:02.740
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197603-GLOBEX.dly has a volume of 0 at 1975-12-12. | 2022-04-25 10:19:02.750
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197603-GLOBEX.dly has a volume of 0 at 1976-03-11. | 2022-04-25 10:19:02.750
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197512-GLOBEX.dly has a volume of 0 at 1975-09-12. | 2022-04-25 10:19:02.760
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197512-GLOBEX.dly has a volume of 0 at 1975-12-11. | 2022-04-25 10:19:02.760
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197509-GLOBEX.dly has a volume of 0 at 1975-06-13. | 2022-04-25 10:19:02.770
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197509-GLOBEX.dly has a volume of 0 at 1975-09-11. | 2022-04-25 10:19:02.770
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197506-GLOBEX.dly has a volume of 0 at 1975-03-14. | 2022-04-25 10:19:02.779
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197506-GLOBEX.dly has a volume of 0 at 1975-06-12. | 2022-04-25 10:19:02.779
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197503-GLOBEX.dly has a volume of 0 at 1974-12-13. | 2022-04-25 10:19:02.789
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197503-GLOBEX.dly has a volume of 0 at 1975-03-13. | 2022-04-25 10:19:02.789
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197412-GLOBEX.dly has a volume of 0 at 1974-09-13. | 2022-04-25 10:19:02.799
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197412-GLOBEX.dly has a volume of 0 at 1974-12-12. | 2022-04-25 10:19:02.799
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197409-GLOBEX.dly has a volume of 0 at 1974-06-14. | 2022-04-25 10:19:02.809
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197409-GLOBEX.dly has a volume of 0 at 1974-09-12. | 2022-04-25 10:19:02.809
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197406-GLOBEX.dly has a volume of 0 at 1974-03-15. | 2022-04-25 10:19:02.818
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197406-GLOBEX.dly has a volume of 0 at 1974-06-13. | 2022-04-25 10:19:02.818
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197403-GLOBEX.dly has a volume of 0 at 1973-12-14. | 2022-04-25 10:19:02.828
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197403-GLOBEX.dly has a volume of 0 at 1974-03-14. | 2022-04-25 10:19:02.828
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197312-GLOBEX.dly has a volume of 0 at 1973-09-14. | 2022-04-25 10:19:02.838
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197312-GLOBEX.dly has a volume of 0 at 1973-12-13. | 2022-04-25 10:19:02.838
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197309-GLOBEX.dly has a volume of 0 at 1973-06-15. | 2022-04-25 10:19:02.847
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197309-GLOBEX.dly has a volume of 0 at 1973-09-13. | 2022-04-25 10:19:02.847
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197306-GLOBEX.dly has a volume of 0 at 1973-03-16. | 2022-04-25 10:19:02.857
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197306-GLOBEX.dly has a volume of 0 at 1973-06-14. | 2022-04-25 10:19:02.857
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197303-GLOBEX.dly has a volume of 0 at 1972-12-15. | 2022-04-25 10:19:02.867
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197303-GLOBEX.dly has a volume of 0 at 1973-03-15. | 2022-04-25 10:19:02.867
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197212-GLOBEX.dly has a volume of 0 at 1972-09-15. | 2022-04-25 10:19:02.876
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197212-GLOBEX.dly has a volume of 0 at 1972-12-14. | 2022-04-25 10:19:02.876
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197209-GLOBEX.dly has a volume of 0 at 1972-06-16. | 2022-04-25 10:19:02.886
GBP-202206-GLOBEX [C] 64 Day #8 | File GBP-197209-GLOBEX.dly has a volume of 0 at 1972-09-14. | 2022-04-25 10:19:02.886
Restarting the loading process. | 2022-04-25 10:19:02.902
HD Request # 155 | Requesting historical Daily data for DIA starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:02.904
GBP-202206-GLOBEX [C][M] 64 Day #8 | StartDateTimeForLoadingOrderFills: 1972-06-16 00:00:00 | 2022-04-25 10:19:03.608
HD Request # 155 | Receiving historical Daily data for DIA-NQTV starting at 2022-04-20 | 2022-04-25 10:19:03.741
HD Request # 155 | Writing historical Daily data to the file DIA-NQTV.dly | 2022-04-25 10:19:03.741
HD Request # 155 | Bytes received: 208 | 2022-04-25 10:19:03.789
HD Request # 155 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for DIA-NQTV | 2022-04-25 10:19:03.789
HD Request # 155 | Completion time: 3s | 2022-04-25 10:19:03.789
HD Request # 155 | Daily data download complete for DIA-NQTV. Unique request ID: 107 | 2022-04-25 10:19:03.789
Removing historical data download ID 107. | 2022-04-25 10:19:03.789
Triggering next historical data download in queue. | 2022-04-25 10:19:03.789
HD Request # 156 | Downloading Historical Daily chart data for SPY-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:03.791
DIA-NQTV[M] Daily #5 | Reloading chart. | 2022-04-25 10:19:03.954
HD Request # 156 | Requesting historical Daily data for SPY starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:05.228
HD Request # 156 | Receiving historical Daily data for SPY-NQTV starting at 2022-04-20 | 2022-04-25 10:19:06.149
HD Request # 156 | Writing historical Daily data to the file SPY-NQTV.dly | 2022-04-25 10:19:06.149
HD Request # 156 | Bytes received: 209 | 2022-04-25 10:19:06.208
HD Request # 156 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for SPY-NQTV | 2022-04-25 10:19:06.208
HD Request # 156 | Completion time: 3s | 2022-04-25 10:19:06.208
HD Request # 156 | Daily data download complete for SPY-NQTV. Unique request ID: 108 | 2022-04-25 10:19:06.208
Removing historical data download ID 108. | 2022-04-25 10:19:06.208
Triggering next historical data download in queue. | 2022-04-25 10:19:06.208
HD Request # 157 | Downloading Historical Daily chart data for QQQ-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:06.210
SPY-NQTV[M] Daily #1 | Reloading chart. | 2022-04-25 10:19:06.338
SPY-NQTV[M] Daily #1 | Reloading chart. | 2022-04-25 10:19:06.344
SPY-NQTV[M] 4 Day #1 | Reloading chart. | 2022-04-25 10:19:06.350
SPY-NQTV[M] Daily #1 | Reloading chart. | 2022-04-25 10:19:06.356
SPY-NQTV[M] 4 Day #1 | Reloading chart. | 2022-04-25 10:19:06.363
SPY-NQTV[M] Daily #1 | Reloading chart. | 2022-04-25 10:19:06.368
SPY-NQTV[M] Daily #6 | Reloading chart. | 2022-04-25 10:19:06.373
SPY-NQTV[M] 2 Day #1 | Reloading chart. | 2022-04-25 10:19:06.378
SPY-NQTV[M] 2 Day #1 | Reloading chart. | 2022-04-25 10:19:06.387
SPY-NQTV[M] Daily #1 | Reloading chart. | 2022-04-25 10:19:06.397
SPY-NQTV[M] 2 Day #1 | Reloading chart. | 2022-04-25 10:19:06.404
SPY-NQTV[M] Daily #1 | Reloading chart. | 2022-04-25 10:19:06.411
SPY-NQTV[M] Daily #1 | Reloading chart. | 2022-04-25 10:19:06.421
SPY-NQTV[M] Daily #1 | Reloading chart. | 2022-04-25 10:19:06.428
SPY-NQTV[M] Daily #1 | Reloading chart. | 2022-04-25 10:19:06.435
SPY-NQTV[M] Daily #1 | Reloading chart. | 2022-04-25 10:19:06.443
SPY-NQTV[M] Daily #1 | Reloading chart. | 2022-04-25 10:19:06.598
SPY-NQTV[M] 16 Day #1 | Reloading chart. | 2022-04-25 10:19:06.603
SPY-NQTV[M] 4 Day #1 | Reloading chart. | 2022-04-25 10:19:06.608
SPY-NQTV[M] Daily #1 | Reloading chart. | 2022-04-25 10:19:06.613
SPY-NQTV[M] 128 Day #1 | Reloading chart. | 2022-04-25 10:19:06.619
SPY-NQTV[M] 2 Day #1 | Reloading chart. | 2022-04-25 10:19:06.625
SPY-NQTV[M] Daily #1 | Reloading chart. | 2022-04-25 10:19:06.631
SPY-NQTV[M] 2 Day #1 | Reloading chart. | 2022-04-25 10:19:06.636
HD Request # 157 | Requesting historical Daily data for QQQ starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:07.672
HD Request # 157 | Receiving historical Daily data for QQQ-NQTV starting at 2022-04-20 | 2022-04-25 10:19:08.491
HD Request # 157 | Writing historical Daily data to the file QQQ-NQTV.dly | 2022-04-25 10:19:08.491
HD Request # 157 | Bytes received: 206 | 2022-04-25 10:19:08.537
HD Request # 157 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for QQQ-NQTV | 2022-04-25 10:19:08.537
HD Request # 157 | Completion time: 2s | 2022-04-25 10:19:08.537
HD Request # 157 | Daily data download complete for QQQ-NQTV. Unique request ID: 109 | 2022-04-25 10:19:08.537
Removing historical data download ID 109. | 2022-04-25 10:19:08.537
Triggering next historical data download in queue. | 2022-04-25 10:19:08.537
HD Request # 158 | Downloading Historical Daily chart data for QG-202206-NYMEX. Starting date: 2022-04-20. Service: interactive_brokers.trading | 2022-04-25 10:19:08.539
QQQ-NQTV[M] 4 Day #11 | Reloading chart. | 2022-04-25 10:19:08.762
HD Request # 158 | Requesting historical Daily data for QGM22 starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:10.018
HD Request # 158 | Receiving historical Daily data for QG-202206-NYMEX starting at 2022-04-20 | 2022-04-25 10:19:10.865
HD Request # 158 | Writing historical Daily data to the file QG-202206-NYMEX.dly | 2022-04-25 10:19:10.865
HD Request # 158 | Bytes received: 201 | 2022-04-25 10:19:10.876
HD Request # 158 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for QG-202206-NYMEX | 2022-04-25 10:19:10.876
HD Request # 158 | Completion time: 2s | 2022-04-25 10:19:10.876
HD Request # 158 | Daily data download complete for QG-202206-NYMEX. Unique request ID: 119 | 2022-04-25 10:19:10.876
Removing historical data download ID 119. | 2022-04-25 10:19:10.876
Triggering next historical data download in queue. | 2022-04-25 10:19:10.876
HD Request # 159 | Downloading Historical Daily chart data for AJG-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:10.878
QG-202206-NYMEX[M] Daily #2 | Reloading chart. | 2022-04-25 10:19:11.039
QG-202206-NYMEX[M] Daily #2 | StartDateTimeForLoadingOrderFills: 2016-11-28 00:00:00 | 2022-04-25 10:19:11.057
HD Request # 159 | Requesting historical Daily data for AJG starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:12.362
HD Request # 159 | Receiving historical Daily data for AJG-NQTV starting at 2022-04-20 | 2022-04-25 10:19:13.181
HD Request # 159 | Writing historical Daily data to the file AJG-NQTV.dly | 2022-04-25 10:19:13.181
HD Request # 159 | Bytes received: 199 | 2022-04-25 10:19:13.256
HD Request # 159 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for AJG-NQTV | 2022-04-25 10:19:13.256
HD Request # 159 | Completion time: 3s | 2022-04-25 10:19:13.256
HD Request # 159 | Daily data download complete for AJG-NQTV. Unique request ID: 128 | 2022-04-25 10:19:13.256
Removing historical data download ID 128. | 2022-04-25 10:19:13.256
Triggering next historical data download in queue. | 2022-04-25 10:19:13.256
HD Request # 160 | Downloading Historical Daily chart data for ACHC-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:13.258
AJG-NQTV[M] 8 Day #19 | Reloading chart. | 2022-04-25 10:19:13.430
HD Request # 160 | Requesting historical Daily data for ACHC starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:14.687
HD Request # 160 | Receiving historical Daily data for ACHC-NQTV starting at 2022-04-20 | 2022-04-25 10:19:15.452
HD Request # 160 | Writing historical Daily data to the file ACHC-NQTV.dly | 2022-04-25 10:19:15.452
HD Request # 160 | Bytes received: 188 | 2022-04-25 10:19:15.473
HD Request # 160 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for ACHC-NQTV | 2022-04-25 10:19:15.473
HD Request # 160 | Completion time: 2s | 2022-04-25 10:19:15.473
HD Request # 160 | Daily data download complete for ACHC-NQTV. Unique request ID: 129 | 2022-04-25 10:19:15.473
Removing historical data download ID 129. | 2022-04-25 10:19:15.473
Triggering next historical data download in queue. | 2022-04-25 10:19:15.473
HD Request # 161 | Downloading Historical Daily chart data for AMX-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:15.475
ACHC-NQTV[M] 8 Day #11 | Reloading chart. | 2022-04-25 10:19:15.524
HD Request # 161 | Requesting historical Daily data for AMX starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:16.893
HD Request # 161 | Receiving historical Daily data for AMX-NQTV starting at 2022-04-20 | 2022-04-25 10:19:17.702
HD Request # 161 | Writing historical Daily data to the file AMX-NQTV.dly | 2022-04-25 10:19:17.702
HD Request # 161 | Bytes received: 190 | 2022-04-25 10:19:17.745
HD Request # 161 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for AMX-NQTV | 2022-04-25 10:19:17.745
HD Request # 161 | Completion time: 2s | 2022-04-25 10:19:17.745
HD Request # 161 | Daily data download complete for AMX-NQTV. Unique request ID: 130 | 2022-04-25 10:19:17.745
Removing historical data download ID 130. | 2022-04-25 10:19:17.745
Triggering next historical data download in queue. | 2022-04-25 10:19:17.745
HD Request # 162 | Downloading Historical Daily chart data for ACRS-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:17.746
AMX-NQTV[M] 2 Day #20 | Reloading chart. | 2022-04-25 10:19:17.785
HD Request # 162 | Requesting historical Daily data for ACRS starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:19.173
HD Request # 162 | Receiving historical Daily data for ACRS-NQTV starting at 2022-04-20 | 2022-04-25 10:19:19.986
HD Request # 162 | Writing historical Daily data to the file ACRS-NQTV.dly | 2022-04-25 10:19:19.986
HD Request # 162 | Bytes received: 192 | 2022-04-25 10:19:19.999
HD Request # 162 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for ACRS-NQTV | 2022-04-25 10:19:19.999
HD Request # 162 | Completion time: 3s | 2022-04-25 10:19:20.000
HD Request # 162 | Daily data download complete for ACRS-NQTV. Unique request ID: 132 | 2022-04-25 10:19:20.000
Removing historical data download ID 132. | 2022-04-25 10:19:20.000
Triggering next historical data download in queue. | 2022-04-25 10:19:20.000
HD Request # 163 | Downloading Historical Daily chart data for AMH-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:20.001
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | Reloading chart. | 2022-04-25 10:19:20.050
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:19:20.069
HD Request # 163 | Requesting historical Daily data for AMH starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:21.405
HD Request # 163 | Receiving historical Daily data for AMH-NQTV starting at 2022-04-20 | 2022-04-25 10:19:22.237
HD Request # 163 | Writing historical Daily data to the file AMH-NQTV.dly | 2022-04-25 10:19:22.237
HD Request # 163 | Bytes received: 184 | 2022-04-25 10:19:22.254
HD Request # 163 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for AMH-NQTV | 2022-04-25 10:19:22.254
HD Request # 163 | Completion time: 2s | 2022-04-25 10:19:22.255
HD Request # 163 | Daily data download complete for AMH-NQTV. Unique request ID: 133 | 2022-04-25 10:19:22.255
Removing historical data download ID 133. | 2022-04-25 10:19:22.255
Triggering next historical data download in queue. | 2022-04-25 10:19:22.255
HD Request # 164 | Downloading Historical Daily chart data for AMR-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:22.256
AMH-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 10:19:22.329
HD Request # 164 | Requesting historical Daily data for AMR starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:23.679
HD Request # 164 | Receiving historical Daily data for AMR-NQTV starting at 2022-04-20 | 2022-04-25 10:19:24.434
HD Request # 164 | Writing historical Daily data to the file AMR-NQTV.dly | 2022-04-25 10:19:24.435
HD Request # 164 | Bytes received: 190 | 2022-04-25 10:19:24.444
HD Request # 164 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for AMR-NQTV | 2022-04-25 10:19:24.444
HD Request # 164 | Completion time: 2s | 2022-04-25 10:19:24.444
HD Request # 164 | Daily data download complete for AMR-NQTV. Unique request ID: 135 | 2022-04-25 10:19:24.444
Removing historical data download ID 135. | 2022-04-25 10:19:24.444
Triggering next historical data download in queue. | 2022-04-25 10:19:24.444
HD Request # 165 | Downloading Historical Daily chart data for AA-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:24.446
AMR-NQTV[M] Daily #5 | Reloading chart. | 2022-04-25 10:19:24.644
HD Request # 165 | Requesting historical Daily data for AA starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:25.892
HD Request # 165 | Receiving historical Daily data for AA-NQTV starting at 2022-04-20 | 2022-04-25 10:19:26.746
HD Request # 165 | Writing historical Daily data to the file AA-NQTV.dly | 2022-04-25 10:19:26.746
HD Request # 165 | Bytes received: 182 | 2022-04-25 10:19:26.815
HD Request # 165 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for AA-NQTV | 2022-04-25 10:19:26.815
HD Request # 165 | Completion time: 2s | 2022-04-25 10:19:26.815
HD Request # 165 | Daily data download complete for AA-NQTV. Unique request ID: 137 | 2022-04-25 10:19:26.815
Removing historical data download ID 137. | 2022-04-25 10:19:26.815
Triggering next historical data download in queue. | 2022-04-25 10:19:26.815
HD Request # 166 | Downloading Historical Daily chart data for BJ-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:26.816
AA-NQTV[M] Daily #9 | Reloading chart. | 2022-04-25 10:19:26.826
EVH-NQTV[M] 8 Day #10 | Reloading chart. | 2022-04-25 10:19:27.162
HD Request # 166 | Requesting historical Daily data for BJ starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:28.240
HD Request # 166 | Receiving historical Daily data for BJ-NQTV starting at 2022-04-20 | 2022-04-25 10:19:29.064
HD Request # 166 | Writing historical Daily data to the file BJ-NQTV.dly | 2022-04-25 10:19:29.064
HD Request # 166 | Bytes received: 184 | 2022-04-25 10:19:29.071
HD Request # 166 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for BJ-NQTV | 2022-04-25 10:19:29.071
HD Request # 166 | Completion time: 3s | 2022-04-25 10:19:29.072
HD Request # 166 | Daily data download complete for BJ-NQTV. Unique request ID: 138 | 2022-04-25 10:19:29.072
Removing historical data download ID 138. | 2022-04-25 10:19:29.072
Triggering next historical data download in queue. | 2022-04-25 10:19:29.072
HD Request # 167 | Downloading Historical Daily chart data for CLH-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:29.073
BJ-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 10:19:29.270
HD Request # 167 | Requesting historical Daily data for CLH starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:30.517
EVH-NQTV[M] 2 Day #10 | Reloading chart. | 2022-04-25 10:19:30.655
HD Request # 167 | Receiving historical Daily data for CLH-NQTV starting at 2022-04-20 | 2022-04-25 10:19:31.308
HD Request # 167 | Writing historical Daily data to the file CLH-NQTV.dly | 2022-04-25 10:19:31.308
HD Request # 167 | Bytes received: 201 | 2022-04-25 10:19:31.376
HD Request # 167 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for CLH-NQTV | 2022-04-25 10:19:31.376
HD Request # 167 | Completion time: 2s | 2022-04-25 10:19:31.376
HD Request # 167 | Daily data download complete for CLH-NQTV. Unique request ID: 140 | 2022-04-25 10:19:31.376
Removing historical data download ID 140. | 2022-04-25 10:19:31.376
Triggering next historical data download in queue. | 2022-04-25 10:19:31.376
HD Request # 168 | Downloading Historical Daily chart data for CUBE-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:31.377
CLH-NQTV[M] 2 Day #8 | Reloading chart. | 2022-04-25 10:19:31.556
CLH-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 10:19:31.562
HD Request # 168 | Requesting historical Daily data for CUBE starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:32.804
EVH-NQTV[M] 4 Day #10 | Reloading chart. | 2022-04-25 10:19:33.335
HD Request # 168 | Receiving historical Daily data for CUBE-NQTV starting at 2022-04-20 | 2022-04-25 10:19:33.556
HD Request # 168 | Writing historical Daily data to the file CUBE-NQTV.dly | 2022-04-25 10:19:33.556
HD Request # 168 | Bytes received: 189 | 2022-04-25 10:19:33.592
HD Request # 168 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for CUBE-NQTV | 2022-04-25 10:19:33.592
HD Request # 168 | Completion time: 2s | 2022-04-25 10:19:33.592
HD Request # 168 | Daily data download complete for CUBE-NQTV. Unique request ID: 141 | 2022-04-25 10:19:33.592
Removing historical data download ID 141. | 2022-04-25 10:19:33.592
Triggering next historical data download in queue. | 2022-04-25 10:19:33.592
HD Request # 169 | Downloading Historical Daily chart data for COST-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:33.594
CUBE-NQTV[M] 4 Day #10 | Reloading chart. | 2022-04-25 10:19:33.655
EVH-NQTV[M] 2 Day #10 | Reloading chart. | 2022-04-25 10:19:34.798
HD Request # 169 | Requesting historical Daily data for COST starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:35.020
HD Request # 169 | Receiving historical Daily data for COST-NQTV starting at 2022-04-20 | 2022-04-25 10:19:35.874
HD Request # 169 | Writing historical Daily data to the file COST-NQTV.dly | 2022-04-25 10:19:35.874
HD Request # 169 | Bytes received: 205 | 2022-04-25 10:19:35.946
HD Request # 169 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for COST-NQTV | 2022-04-25 10:19:35.946
HD Request # 169 | Completion time: 2s | 2022-04-25 10:19:35.946
HD Request # 169 | Daily data download complete for COST-NQTV. Unique request ID: 144 | 2022-04-25 10:19:35.946
Removing historical data download ID 144. | 2022-04-25 10:19:35.946
Triggering next historical data download in queue. | 2022-04-25 10:19:35.946
HD Request # 170 | Downloading Historical Daily chart data for CALM-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:35.947
COST-NQTV[M] 4 Day #12 | Reloading chart. | 2022-04-25 10:19:36.016
HD Request # 170 | Requesting historical Daily data for CALM starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:37.363
HD Request # 170 | Receiving historical Daily data for CALM-NQTV starting at 2022-04-20 | 2022-04-25 10:19:38.127
HD Request # 170 | Writing historical Daily data to the file CALM-NQTV.dly | 2022-04-25 10:19:38.127
HD Request # 170 | Bytes received: 187 | 2022-04-25 10:19:38.177
HD Request # 170 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for CALM-NQTV | 2022-04-25 10:19:38.177
HD Request # 170 | Completion time: 3s | 2022-04-25 10:19:38.178
HD Request # 170 | Daily data download complete for CALM-NQTV. Unique request ID: 146 | 2022-04-25 10:19:38.178
Removing historical data download ID 146. | 2022-04-25 10:19:38.178
Triggering next historical data download in queue. | 2022-04-25 10:19:38.178
HD Request # 171 | Downloading Historical Daily chart data for DRE-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:38.179
CALM-NQTV[M] Daily #6 | Reloading chart. | 2022-04-25 10:19:38.277
HD Request # 171 | Requesting historical Daily data for DRE starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:39.619
HD Request # 171 | Receiving historical Daily data for DRE-NQTV starting at 2022-04-20 | 2022-04-25 10:19:40.408
HD Request # 171 | Writing historical Daily data to the file DRE-NQTV.dly | 2022-04-25 10:19:40.409
HD Request # 171 | Bytes received: 187 | 2022-04-25 10:19:40.476
HD Request # 171 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for DRE-NQTV | 2022-04-25 10:19:40.476
HD Request # 171 | Completion time: 2s | 2022-04-25 10:19:40.476
HD Request # 171 | Daily data download complete for DRE-NQTV. Unique request ID: 148 | 2022-04-25 10:19:40.476
Removing historical data download ID 148. | 2022-04-25 10:19:40.476
Triggering next historical data download in queue. | 2022-04-25 10:19:40.476
HD Request # 172 | Downloading Historical Daily chart data for DAR-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:40.477
DRE-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 10:19:40.615
DRE-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 10:19:40.620
HD Request # 172 | Requesting historical Daily data for DAR starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:41.895
HD Request # 172 | Receiving historical Daily data for DAR-NQTV starting at 2022-04-20 | 2022-04-25 10:19:42.771
HD Request # 172 | Writing historical Daily data to the file DAR-NQTV.dly | 2022-04-25 10:19:42.771
HD Request # 172 | Bytes received: 187 | 2022-04-25 10:19:42.823
HD Request # 172 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for DAR-NQTV | 2022-04-25 10:19:42.823
HD Request # 172 | Completion time: 2s | 2022-04-25 10:19:42.823
HD Request # 172 | Daily data download complete for DAR-NQTV. Unique request ID: 149 | 2022-04-25 10:19:42.823
Removing historical data download ID 149. | 2022-04-25 10:19:42.823
Triggering next historical data download in queue. | 2022-04-25 10:19:42.823
HD Request # 173 | Downloading Historical Daily chart data for DKL-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:42.825
DAR-NQTV[M] 16 Day #6 | Reloading chart. | 2022-04-25 10:19:43.235
HD Request # 173 | Requesting historical Daily data for DKL starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:44.260
HD Request # 173 | Receiving historical Daily data for DKL-NQTV starting at 2022-04-20 | 2022-04-25 10:19:45.111
HD Request # 173 | Writing historical Daily data to the file DKL-NQTV.dly | 2022-04-25 10:19:45.111
HD Request # 173 | Bytes received: 188 | 2022-04-25 10:19:45.131
HD Request # 173 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for DKL-NQTV | 2022-04-25 10:19:45.131
HD Request # 173 | Completion time: 3s | 2022-04-25 10:19:45.131
HD Request # 173 | Daily data download complete for DKL-NQTV. Unique request ID: 150 | 2022-04-25 10:19:45.131
Removing historical data download ID 150. | 2022-04-25 10:19:45.131
Triggering next historical data download in queue. | 2022-04-25 10:19:45.131
HD Request # 174 | Downloading Historical Daily chart data for EVH-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:45.132
DKL-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 10:19:45.208
HD Request # 174 | Requesting historical Daily data for EVH starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:46.612
HD Request # 174 | Receiving historical Daily data for EVH-NQTV starting at 2022-04-20 | 2022-04-25 10:19:47.368
HD Request # 174 | Writing historical Daily data to the file EVH-NQTV.dly | 2022-04-25 10:19:47.369
HD Request # 174 | Bytes received: 179 | 2022-04-25 10:19:47.383
HD Request # 174 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for EVH-NQTV | 2022-04-25 10:19:47.383
HD Request # 174 | Completion time: 2s | 2022-04-25 10:19:47.383
HD Request # 174 | Daily data download complete for EVH-NQTV. Unique request ID: 151 | 2022-04-25 10:19:47.383
Removing historical data download ID 151. | 2022-04-25 10:19:47.383
Triggering next historical data download in queue. | 2022-04-25 10:19:47.383
HD Request # 175 | Downloading Historical Daily chart data for EW-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:47.384
EVH-NQTV[M] 2 Day #10 | Reloading chart. | 2022-04-25 10:19:47.515
HD Request # 175 | Requesting historical Daily data for EW starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:48.829
HD Request # 175 | Receiving historical Daily data for EW-NQTV starting at 2022-04-20 | 2022-04-25 10:19:49.588
HD Request # 175 | Writing historical Daily data to the file EW-NQTV.dly | 2022-04-25 10:19:49.588
HD Request # 175 | Bytes received: 200 | 2022-04-25 10:19:49.632
HD Request # 175 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for EW-NQTV | 2022-04-25 10:19:49.632
HD Request # 175 | Completion time: 2s | 2022-04-25 10:19:49.632
HD Request # 175 | Daily data download complete for EW-NQTV. Unique request ID: 152 | 2022-04-25 10:19:49.632
Removing historical data download ID 152. | 2022-04-25 10:19:49.632
Triggering next historical data download in queue. | 2022-04-25 10:19:49.632
HD Request # 176 | Downloading Historical Daily chart data for EXR-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:49.633
EW-NQTV[M] 4 Day #19 | Reloading chart. | 2022-04-25 10:19:49.803
HD Request # 176 | Requesting historical Daily data for EXR starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:51.044
HD Request # 176 | Receiving historical Daily data for EXR-NQTV starting at 2022-04-20 | 2022-04-25 10:19:51.864
HD Request # 176 | Writing historical Daily data to the file EXR-NQTV.dly | 2022-04-25 10:19:51.864
HD Request # 176 | Bytes received: 200 | 2022-04-25 10:19:51.900
HD Request # 176 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for EXR-NQTV | 2022-04-25 10:19:51.900
HD Request # 176 | Completion time: 2s | 2022-04-25 10:19:51.900
HD Request # 176 | Daily data download complete for EXR-NQTV. Unique request ID: 154 | 2022-04-25 10:19:51.900
Removing historical data download ID 154. | 2022-04-25 10:19:51.900
Triggering next historical data download in queue. | 2022-04-25 10:19:51.900
HD Request # 177 | Downloading Historical Daily chart data for FWONK-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:51.902
EXR-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 10:19:52.065
HD Request # 177 | Requesting historical Daily data for FWONK starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:53.318
HD Request # 177 | Receiving historical Daily data for FWONK-NQTV starting at 2022-04-20 | 2022-04-25 10:19:54.149
HD Request # 177 | Writing historical Daily data to the file FWONK-NQTV.dly | 2022-04-25 10:19:54.149
HD Request # 177 | Bytes received: 195 | 2022-04-25 10:19:54.166
HD Request # 177 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for FWONK-NQTV | 2022-04-25 10:19:54.166
HD Request # 177 | Completion time: 3s | 2022-04-25 10:19:54.166
HD Request # 177 | Daily data download complete for FWONK-NQTV. Unique request ID: 157 | 2022-04-25 10:19:54.166
Removing historical data download ID 157. | 2022-04-25 10:19:54.166
Triggering next historical data download in queue. | 2022-04-25 10:19:54.166
HD Request # 178 | Downloading Historical Daily chart data for FR-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:54.168
FWONK-NQTV[M] 16 Day #3 | Reloading chart. | 2022-04-25 10:19:54.352
HD Request # 178 | Requesting historical Daily data for FR starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:55.599
HD Request # 178 | Receiving historical Daily data for FR-NQTV starting at 2022-04-20 | 2022-04-25 10:19:56.389
HD Request # 178 | Writing historical Daily data to the file FR-NQTV.dly | 2022-04-25 10:19:56.390
HD Request # 178 | Bytes received: 176 | 2022-04-25 10:19:56.445
HD Request # 178 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for FR-NQTV | 2022-04-25 10:19:56.445
HD Request # 178 | Completion time: 2s | 2022-04-25 10:19:56.446
HD Request # 178 | Daily data download complete for FR-NQTV. Unique request ID: 158 | 2022-04-25 10:19:56.446
Removing historical data download ID 158. | 2022-04-25 10:19:56.446
Triggering next historical data download in queue. | 2022-04-25 10:19:56.446
HD Request # 179 | Downloading Historical Daily chart data for GCBC-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:56.447
FR-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 10:19:56.526
HD Request # 179 | Requesting historical Daily data for GCBC starting at 2022-04-19. SC External HD service. | 2022-04-25 10:19:57.869
HD Request # 179 | Receiving historical Daily data for GCBC-NQTV starting at 2022-04-20 | 2022-04-25 10:19:58.681
HD Request # 179 | Writing historical Daily data to the file GCBC-NQTV.dly | 2022-04-25 10:19:58.681
HD Request # 179 | Bytes received: 185 | 2022-04-25 10:19:58.714
HD Request # 179 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for GCBC-NQTV | 2022-04-25 10:19:58.714
HD Request # 179 | Completion time: 2s | 2022-04-25 10:19:58.714
HD Request # 179 | Daily data download complete for GCBC-NQTV. Unique request ID: 161 | 2022-04-25 10:19:58.714
Removing historical data download ID 161. | 2022-04-25 10:19:58.714
Triggering next historical data download in queue. | 2022-04-25 10:19:58.714
HD Request # 180 | Downloading Historical Daily chart data for GNK-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:19:58.715
GCBC-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 10:19:58.720
HD Request # 180 | Requesting historical Daily data for GNK starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:00.140
HD Request # 180 | Receiving historical Daily data for GNK-NQTV starting at 2022-04-20 | 2022-04-25 10:20:00.904
HD Request # 180 | Writing historical Daily data to the file GNK-NQTV.dly | 2022-04-25 10:20:00.904
HD Request # 180 | Bytes received: 183 | 2022-04-25 10:20:00.919
HD Request # 180 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for GNK-NQTV | 2022-04-25 10:20:00.919
HD Request # 180 | Completion time: 2s | 2022-04-25 10:20:00.919
HD Request # 180 | Daily data download complete for GNK-NQTV. Unique request ID: 162 | 2022-04-25 10:20:00.919
Removing historical data download ID 162. | 2022-04-25 10:20:00.919
Triggering next historical data download in queue. | 2022-04-25 10:20:00.919
HD Request # 181 | Downloading Historical Daily chart data for HESM. Starting date: 2022-04-20. Service: interactive_brokers.trading | 2022-04-25 10:20:00.921
GNK-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 10:20:00.945
Opened cached Intraday file: C:\SierraChart\Data\TMST-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:20:00.984
HD Request # 181 | Requesting historical Daily data for HESM starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:02.339
HD Request # 181 | Receiving historical Daily data for HESM starting at 2022-04-20 | 2022-04-25 10:20:03.091
HD Request # 181 | Writing historical Daily data to the file HESM.dly | 2022-04-25 10:20:03.091
HD Request # 181 | Bytes received: 185 | 2022-04-25 10:20:03.103
HD Request # 181 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for HESM | 2022-04-25 10:20:03.103
HD Request # 181 | Completion time: 3s | 2022-04-25 10:20:03.103
HD Request # 181 | Daily data download complete for HESM. Unique request ID: 164 | 2022-04-25 10:20:03.103
Removing historical data download ID 164. | 2022-04-25 10:20:03.103
Triggering next historical data download in queue. | 2022-04-25 10:20:03.103
HD Request # 182 | Downloading Historical Daily chart data for HESM-NQTV. Starting date: 1972-04-25. Service: nasdaq_exchange.data | 2022-04-25 10:20:03.104
HD Request # 182 | Requesting historical Daily data for HESM starting at 1972-04-24. SC External HD service. | 2022-04-25 10:20:04.528
HESM-NQTV Daily #4 | Reloading chart. | 2022-04-25 10:20:04.819
HESM-NQTV Daily #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\HESM-NQTV.dly | 2022-04-25 10:20:04.825
Historical Daily data request for HESM-NQTV is discarded because a matching download is in progress and the new one is not for earlier data. | 2022-04-25 10:20:05.299
HESM-NQTV[M] Daily #4 | Reloading chart. | 2022-04-25 10:20:05.373
HESM-NQTV[M] Daily #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\HESM-NQTV.dly | 2022-04-25 10:20:05.386
HD Request # 182 | Receiving historical Daily data for HESM-NQTV starting at 2017-04-05 | 2022-04-25 10:20:05.395
HD Request # 182 | Writing historical Daily data to the file HESM-NQTV.dly | 2022-04-25 10:20:05.395
HD Request # 182 | Bytes received: 58587 | 2022-04-25 10:20:05.441
HD Request # 182 | Received 1272 Daily data records from 2017-04-05 00:00:00 to 2022-04-22 00:00:00 (5.1years) and wrote 1272 records for HESM-NQTV | 2022-04-25 10:20:05.441
HD Request # 182 | Completion time: 2s | 2022-04-25 10:20:05.441
HD Request # 182 | Daily data download complete for HESM-NQTV. Unique request ID: 165 | 2022-04-25 10:20:05.441
Removing historical data download ID 165. | 2022-04-25 10:20:05.441
Triggering next historical data download in queue. | 2022-04-25 10:20:05.441
HD Request # 183 | Downloading Historical Daily chart data for HCC-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:05.442
HESM-NQTV[M] Daily #4 | Reloading chart. | 2022-04-25 10:20:05.641
HD Request # 183 | Requesting historical Daily data for HCC starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:06.848
HD Request # 183 | Receiving historical Daily data for HCC-NQTV starting at 2022-04-20 | 2022-04-25 10:20:07.604
HD Request # 183 | Writing historical Daily data to the file HCC-NQTV.dly | 2022-04-25 10:20:07.604
HD Request # 183 | Bytes received: 187 | 2022-04-25 10:20:07.614
HD Request # 183 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for HCC-NQTV | 2022-04-25 10:20:07.614
HD Request # 183 | Completion time: 2s | 2022-04-25 10:20:07.614
HD Request # 183 | Daily data download complete for HCC-NQTV. Unique request ID: 168 | 2022-04-25 10:20:07.614
Removing historical data download ID 168. | 2022-04-25 10:20:07.614
Triggering next historical data download in queue. | 2022-04-25 10:20:07.614
HD Request # 184 | Downloading Historical Daily chart data for HZNP-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:07.616
HCC-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 10:20:07.913
HD Request # 184 | Requesting historical Daily data for HZNP starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:09.053
HD Request # 184 | Receiving historical Daily data for HZNP-NQTV starting at 2022-04-20 | 2022-04-25 10:20:09.810
HD Request # 184 | Writing historical Daily data to the file HZNP-NQTV.dly | 2022-04-25 10:20:09.810
HD Request # 184 | Bytes received: 204 | 2022-04-25 10:20:09.833
HD Request # 184 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for HZNP-NQTV | 2022-04-25 10:20:09.833
HD Request # 184 | Completion time: 2s | 2022-04-25 10:20:09.833
HD Request # 184 | Daily data download complete for HZNP-NQTV. Unique request ID: 169 | 2022-04-25 10:20:09.833
Removing historical data download ID 169. | 2022-04-25 10:20:09.833
Triggering next historical data download in queue. | 2022-04-25 10:20:09.833
HD Request # 185 | Downloading Historical Daily chart data for HCA-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:09.835
HZNP-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 10:20:09.902
HD Request # 185 | Requesting historical Daily data for HCA starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:11.511
HD Request # 185 | Receiving historical Daily data for HCA-NQTV starting at 2022-04-20 | 2022-04-25 10:20:12.330
HD Request # 185 | Writing historical Daily data to the file HCA-NQTV.dly | 2022-04-25 10:20:12.331
HD Request # 185 | Bytes received: 200 | 2022-04-25 10:20:12.355
HD Request # 185 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for HCA-NQTV | 2022-04-25 10:20:12.355
HD Request # 185 | Completion time: 3s | 2022-04-25 10:20:12.355
HD Request # 185 | Daily data download complete for HCA-NQTV. Unique request ID: 170 | 2022-04-25 10:20:12.355
Removing historical data download ID 170. | 2022-04-25 10:20:12.355
Triggering next historical data download in queue. | 2022-04-25 10:20:12.355
HD Request # 186 | Downloading Historical Daily chart data for IT-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:12.356
HCA-NQTV[M] 16 Day #6 | Reloading chart. | 2022-04-25 10:20:12.414
HD Request # 186 | Requesting historical Daily data for IT starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:13.763
HD Request # 186 | Receiving historical Daily data for IT-NQTV starting at 2022-04-20 | 2022-04-25 10:20:14.596
HD Request # 186 | Writing historical Daily data to the file IT-NQTV.dly | 2022-04-25 10:20:14.596
HD Request # 186 | Bytes received: 196 | 2022-04-25 10:20:14.654
HD Request # 186 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for IT-NQTV | 2022-04-25 10:20:14.654
HD Request # 186 | Completion time: 2s | 2022-04-25 10:20:14.654
HD Request # 186 | Daily data download complete for IT-NQTV. Unique request ID: 171 | 2022-04-25 10:20:14.654
Removing historical data download ID 171. | 2022-04-25 10:20:14.654
Triggering next historical data download in queue. | 2022-04-25 10:20:14.654
HD Request # 187 | Downloading Historical Daily chart data for KO-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:14.655
IT-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 10:20:14.687
HD Request # 187 | Requesting historical Daily data for KO starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:16.072
HD Request # 187 | Receiving historical Daily data for KO-NQTV starting at 2022-04-20 | 2022-04-25 10:20:16.838
HD Request # 187 | Writing historical Daily data to the file KO-NQTV.dly | 2022-04-25 10:20:16.839
HD Request # 187 | Bytes received: 183 | 2022-04-25 10:20:16.923
HD Request # 187 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for KO-NQTV | 2022-04-25 10:20:16.923
HD Request # 187 | Completion time: 2s | 2022-04-25 10:20:16.923
HD Request # 187 | Daily data download complete for KO-NQTV. Unique request ID: 172 | 2022-04-25 10:20:16.923
Removing historical data download ID 172. | 2022-04-25 10:20:16.923
Triggering next historical data download in queue. | 2022-04-25 10:20:16.923
HD Request # 188 | Downloading Historical Daily chart data for LAC-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:16.925
KO-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 10:20:16.994
HD Request # 188 | Requesting historical Daily data for LAC starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:18.333
HD Request # 188 | Receiving historical Daily data for LAC-NQTV starting at 2022-04-20 | 2022-04-25 10:20:19.155
HD Request # 188 | Writing historical Daily data to the file LAC-NQTV.dly | 2022-04-25 10:20:19.156
HD Request # 188 | Bytes received: 193 | 2022-04-25 10:20:19.182
HD Request # 188 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for LAC-NQTV | 2022-04-25 10:20:19.182
HD Request # 188 | Completion time: 3s | 2022-04-25 10:20:19.182
HD Request # 188 | Daily data download complete for LAC-NQTV. Unique request ID: 174 | 2022-04-25 10:20:19.182
Removing historical data download ID 174. | 2022-04-25 10:20:19.182
Triggering next historical data download in queue. | 2022-04-25 10:20:19.182
HD Request # 189 | Downloading Historical Daily chart data for LLY-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:19.184
LAC-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 10:20:19.335
HD Request # 189 | Requesting historical Daily data for LLY starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:20.599
HD Request # 189 | Receiving historical Daily data for LLY-NQTV starting at 2022-04-20 | 2022-04-25 10:20:21.451
HD Request # 189 | Writing historical Daily data to the file LLY-NQTV.dly | 2022-04-25 10:20:21.452
HD Request # 189 | Bytes received: 199 | 2022-04-25 10:20:21.519
HD Request # 189 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for LLY-NQTV | 2022-04-25 10:20:21.519
HD Request # 189 | Completion time: 2s | 2022-04-25 10:20:21.519
HD Request # 189 | Daily data download complete for LLY-NQTV. Unique request ID: 175 | 2022-04-25 10:20:21.519
Removing historical data download ID 175. | 2022-04-25 10:20:21.519
Triggering next historical data download in queue. | 2022-04-25 10:20:21.520
HD Request # 190 | Downloading Historical Daily chart data for LSI-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:21.521
LLY-NQTV[M] 4 Day #5 | Reloading chart. | 2022-04-25 10:20:21.679
HD Request # 190 | Requesting historical Daily data for LSI starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:22.928
HD Request # 190 | Receiving historical Daily data for LSI-NQTV starting at 2022-04-20 | 2022-04-25 10:20:23.689
HD Request # 190 | Writing historical Daily data to the file LSI-NQTV.dly | 2022-04-25 10:20:23.690
HD Request # 190 | Bytes received: 196 | 2022-04-25 10:20:23.744
HD Request # 190 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for LSI-NQTV | 2022-04-25 10:20:23.744
HD Request # 190 | Completion time: 2s | 2022-04-25 10:20:23.744
HD Request # 190 | Daily data download complete for LSI-NQTV. Unique request ID: 177 | 2022-04-25 10:20:23.744
Removing historical data download ID 177. | 2022-04-25 10:20:23.744
Triggering next historical data download in queue. | 2022-04-25 10:20:23.744
HD Request # 191 | Downloading Historical Daily chart data for MGP-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:23.746
LSI-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 10:20:23.828
HD Request # 191 | Requesting historical Daily data for MGP starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:25.165
HD Request # 191 | Receiving historical Daily data for MGP-NQTV starting at 2022-04-20 | 2022-04-25 10:20:26.000
HD Request # 191 | Writing historical Daily data to the file MGP-NQTV.dly | 2022-04-25 10:20:26.001
HD Request # 191 | Bytes received: 183 | 2022-04-25 10:20:26.014
HD Request # 191 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for MGP-NQTV | 2022-04-25 10:20:26.014
HD Request # 191 | Completion time: 3s | 2022-04-25 10:20:26.014
HD Request # 191 | Daily data download complete for MGP-NQTV. Unique request ID: 178 | 2022-04-25 10:20:26.014
Removing historical data download ID 178. | 2022-04-25 10:20:26.014
Triggering next historical data download in queue. | 2022-04-25 10:20:26.014
HD Request # 192 | Downloading Historical Daily chart data for NEM-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:26.015
MGP-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 10:20:26.061
HD Request # 192 | Requesting historical Daily data for NEM starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:27.450
HD Request # 192 | Receiving historical Daily data for NEM-NQTV starting at 2022-04-20 | 2022-04-25 10:20:28.209
HD Request # 192 | Writing historical Daily data to the file NEM-NQTV.dly | 2022-04-25 10:20:28.209
HD Request # 192 | Bytes received: 188 | 2022-04-25 10:20:28.279
HD Request # 192 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for NEM-NQTV | 2022-04-25 10:20:28.279
HD Request # 192 | Completion time: 2s | 2022-04-25 10:20:28.279
HD Request # 192 | Daily data download complete for NEM-NQTV. Unique request ID: 179 | 2022-04-25 10:20:28.279
Removing historical data download ID 179. | 2022-04-25 10:20:28.279
Triggering next historical data download in queue. | 2022-04-25 10:20:28.279
HD Request # 193 | Downloading Historical Daily chart data for NSA-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:28.281
NEM-NQTV[M] 8 Day #10 | Reloading chart. | 2022-04-25 10:20:28.332
HD Request # 193 | Requesting historical Daily data for NSA starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:29.706
HD Request # 193 | Receiving historical Daily data for NSA-NQTV starting at 2022-04-20 | 2022-04-25 10:20:30.527
HD Request # 193 | Writing historical Daily data to the file NSA-NQTV.dly | 2022-04-25 10:20:30.527
HD Request # 193 | Bytes received: 187 | 2022-04-25 10:20:30.542
HD Request # 193 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for NSA-NQTV | 2022-04-25 10:20:30.542
HD Request # 193 | Completion time: 2s | 2022-04-25 10:20:30.542
HD Request # 193 | Daily data download complete for NSA-NQTV. Unique request ID: 180 | 2022-04-25 10:20:30.542
Removing historical data download ID 180. | 2022-04-25 10:20:30.542
Triggering next historical data download in queue. | 2022-04-25 10:20:30.542
HD Request # 194 | Downloading Historical Daily chart data for NVO-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:30.543
NSA-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 10:20:30.642
HD Request # 194 | Requesting historical Daily data for NVO starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:31.985
HD Request # 194 | Receiving historical Daily data for NVO-NQTV starting at 2022-04-20 | 2022-04-25 10:20:32.748
HD Request # 194 | Writing historical Daily data to the file NVO-NQTV.dly | 2022-04-25 10:20:32.748
HD Request # 194 | Bytes received: 204 | 2022-04-25 10:20:32.817
HD Request # 194 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for NVO-NQTV | 2022-04-25 10:20:32.817
HD Request # 194 | Completion time: 2s | 2022-04-25 10:20:32.817
HD Request # 194 | Daily data download complete for NVO-NQTV. Unique request ID: 181 | 2022-04-25 10:20:32.817
Removing historical data download ID 181. | 2022-04-25 10:20:32.817
Triggering next historical data download in queue. | 2022-04-25 10:20:32.817
HD Request # 195 | Downloading Historical Daily chart data for ORLY-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:32.819
NVO-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 10:20:32.955
HD Request # 195 | Requesting historical Daily data for ORLY starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:34.229
HD Request # 195 | Receiving historical Daily data for ORLY-NQTV starting at 2022-04-20 | 2022-04-25 10:20:35.063
HD Request # 195 | Writing historical Daily data to the file ORLY-NQTV.dly | 2022-04-25 10:20:35.063
HD Request # 195 | Bytes received: 202 | 2022-04-25 10:20:35.122
HD Request # 195 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for ORLY-NQTV | 2022-04-25 10:20:35.122
HD Request # 195 | Completion time: 3s | 2022-04-25 10:20:35.122
HD Request # 195 | Daily data download complete for ORLY-NQTV. Unique request ID: 182 | 2022-04-25 10:20:35.122
Removing historical data download ID 182. | 2022-04-25 10:20:35.122
Triggering next historical data download in queue. | 2022-04-25 10:20:35.122
HD Request # 196 | Downloading Historical Daily chart data for OLN-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:35.123
ORLY-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 10:20:35.259
HD Request # 196 | Requesting historical Daily data for OLN starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:36.536
HD Request # 196 | Receiving historical Daily data for OLN-NQTV starting at 2022-04-20 | 2022-04-25 10:20:37.370
HD Request # 196 | Writing historical Daily data to the file OLN-NQTV.dly | 2022-04-25 10:20:37.370
HD Request # 196 | Bytes received: 190 | 2022-04-25 10:20:37.439
HD Request # 196 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for OLN-NQTV | 2022-04-25 10:20:37.439
HD Request # 196 | Completion time: 2s | 2022-04-25 10:20:37.439
HD Request # 196 | Daily data download complete for OLN-NQTV. Unique request ID: 184 | 2022-04-25 10:20:37.439
Removing historical data download ID 184. | 2022-04-25 10:20:37.439
Triggering next historical data download in queue. | 2022-04-25 10:20:37.439
HD Request # 197 | Downloading Historical Daily chart data for PFE-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:37.441
OLN-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 10:20:37.594
HD Request # 197 | Requesting historical Daily data for PFE starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:38.884
HD Request # 197 | Receiving historical Daily data for PFE-NQTV starting at 2022-04-20 | 2022-04-25 10:20:39.642
HD Request # 197 | Writing historical Daily data to the file PFE-NQTV.dly | 2022-04-25 10:20:39.642
HD Request # 197 | Bytes received: 187 | 2022-04-25 10:20:39.712
HD Request # 197 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for PFE-NQTV | 2022-04-25 10:20:39.712
HD Request # 197 | Completion time: 2s | 2022-04-25 10:20:39.712
HD Request # 197 | Daily data download complete for PFE-NQTV. Unique request ID: 186 | 2022-04-25 10:20:39.712
Removing historical data download ID 186. | 2022-04-25 10:20:39.712
Triggering next historical data download in queue. | 2022-04-25 10:20:39.712
HD Request # 198 | Downloading Historical Daily chart data for PFG-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:39.714
PFE-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 10:20:39.798
HD Request # 198 | Requesting historical Daily data for PFG starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:41.133
HD Request # 198 | Receiving historical Daily data for PFG-NQTV starting at 2022-04-20 | 2022-04-25 10:20:41.962
HD Request # 198 | Writing historical Daily data to the file PFG-NQTV.dly | 2022-04-25 10:20:41.962
HD Request # 198 | Bytes received: 187 | 2022-04-25 10:20:42.005
HD Request # 198 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for PFG-NQTV | 2022-04-25 10:20:42.005
HD Request # 198 | Completion time: 3s | 2022-04-25 10:20:42.005
HD Request # 198 | Daily data download complete for PFG-NQTV. Unique request ID: 187 | 2022-04-25 10:20:42.005
Removing historical data download ID 187. | 2022-04-25 10:20:42.005
Triggering next historical data download in queue. | 2022-04-25 10:20:42.005
HD Request # 199 | Downloading Historical Daily chart data for PWR-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:42.007
PFG-NQTV[M] 64 Day #14 | Reloading chart. | 2022-04-25 10:20:42.094
HD Request # 199 | Requesting historical Daily data for PWR starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:43.420
HD Request # 199 | Receiving historical Daily data for PWR-NQTV starting at 2022-04-20 | 2022-04-25 10:20:44.252
HD Request # 199 | Writing historical Daily data to the file PWR-NQTV.dly | 2022-04-25 10:20:44.252
HD Request # 199 | Bytes received: 205 | 2022-04-25 10:20:44.302
HD Request # 199 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for PWR-NQTV | 2022-04-25 10:20:44.302
HD Request # 199 | Completion time: 2s | 2022-04-25 10:20:44.302
HD Request # 199 | Daily data download complete for PWR-NQTV. Unique request ID: 189 | 2022-04-25 10:20:44.302
Removing historical data download ID 189. | 2022-04-25 10:20:44.302
Triggering next historical data download in queue. | 2022-04-25 10:20:44.302
HD Request # 200 | Downloading Historical Daily chart data for PAYX-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:44.304
PWR-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 10:20:44.389
HD Request # 200 | Requesting historical Daily data for PAYX starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:45.720
HD Request # 200 | Receiving historical Daily data for PAYX-NQTV starting at 2022-04-20 | 2022-04-25 10:20:46.541
HD Request # 200 | Writing historical Daily data to the file PAYX-NQTV.dly | 2022-04-25 10:20:46.541
HD Request # 200 | Bytes received: 207 | 2022-04-25 10:20:46.611
HD Request # 200 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for PAYX-NQTV | 2022-04-25 10:20:46.611
HD Request # 200 | Completion time: 2s | 2022-04-25 10:20:46.611
HD Request # 200 | Daily data download complete for PAYX-NQTV. Unique request ID: 190 | 2022-04-25 10:20:46.611
Removing historical data download ID 190. | 2022-04-25 10:20:46.611
Triggering next historical data download in queue. | 2022-04-25 10:20:46.611
HD Request # 201 | Downloading Historical Daily chart data for PG-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:46.612
PAYX-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 10:20:46.701
HD Request # 201 | Requesting historical Daily data for PG starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:48.029
HD Request # 201 | Receiving historical Daily data for PG-NQTV starting at 2022-04-20 | 2022-04-25 10:20:48.839
HD Request # 201 | Writing historical Daily data to the file PG-NQTV.dly | 2022-04-25 10:20:48.839
HD Request # 201 | Bytes received: 195 | 2022-04-25 10:20:48.923
HD Request # 201 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for PG-NQTV | 2022-04-25 10:20:48.923
HD Request # 201 | Completion time: 2s | 2022-04-25 10:20:48.923
HD Request # 201 | Daily data download complete for PG-NQTV. Unique request ID: 191 | 2022-04-25 10:20:48.923
Removing historical data download ID 191. | 2022-04-25 10:20:48.923
Triggering next historical data download in queue. | 2022-04-25 10:20:48.923
HD Request # 202 | Downloading Historical Daily chart data for PLD-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:48.924
PG-NQTV[M] 4 Day #7 | Reloading chart. | 2022-04-25 10:20:48.987
HD Request # 202 | Requesting historical Daily data for PLD starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:50.360
HD Request # 202 | Receiving historical Daily data for PLD-NQTV starting at 2022-04-20 | 2022-04-25 10:20:51.180
HD Request # 202 | Writing historical Daily data to the file PLD-NQTV.dly | 2022-04-25 10:20:51.180
HD Request # 202 | Bytes received: 203 | 2022-04-25 10:20:51.234
HD Request # 202 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for PLD-NQTV | 2022-04-25 10:20:51.234
HD Request # 202 | Completion time: 3s | 2022-04-25 10:20:51.234
HD Request # 202 | Daily data download complete for PLD-NQTV. Unique request ID: 192 | 2022-04-25 10:20:51.234
Removing historical data download ID 192. | 2022-04-25 10:20:51.234
Triggering next historical data download in queue. | 2022-04-25 10:20:51.234
HD Request # 203 | Downloading Historical Daily chart data for REXR-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:51.236
PLD-NQTV[M] 2 Day #8 | Reloading chart. | 2022-04-25 10:20:51.240
HD Request # 203 | Requesting historical Daily data for REXR starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:52.652
HD Request # 203 | Receiving historical Daily data for REXR-NQTV starting at 2022-04-20 | 2022-04-25 10:20:53.402
HD Request # 203 | Writing historical Daily data to the file REXR-NQTV.dly | 2022-04-25 10:20:53.403
HD Request # 203 | Bytes received: 192 | 2022-04-25 10:20:53.422
HD Request # 203 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for REXR-NQTV | 2022-04-25 10:20:53.422
HD Request # 203 | Completion time: 2s | 2022-04-25 10:20:53.422
HD Request # 203 | Daily data download complete for REXR-NQTV. Unique request ID: 193 | 2022-04-25 10:20:53.422
Removing historical data download ID 193. | 2022-04-25 10:20:53.423
Triggering next historical data download in queue. | 2022-04-25 10:20:53.423
HD Request # 204 | Downloading Historical Daily chart data for RADA-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:53.424
REXR-NQTV[M] Daily #6 | Reloading chart. | 2022-04-25 10:20:53.465
HD Request # 204 | Requesting historical Daily data for RADA starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:54.847
HD Request # 204 | Receiving historical Daily data for RADA-NQTV starting at 2022-04-20 | 2022-04-25 10:20:55.623
HD Request # 204 | Writing historical Daily data to the file RADA-NQTV.dly | 2022-04-25 10:20:55.624
HD Request # 204 | Bytes received: 184 | 2022-04-25 10:20:55.677
HD Request # 204 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for RADA-NQTV | 2022-04-25 10:20:55.677
HD Request # 204 | Completion time: 2s | 2022-04-25 10:20:55.678
HD Request # 204 | Daily data download complete for RADA-NQTV. Unique request ID: 195 | 2022-04-25 10:20:55.678
Removing historical data download ID 195. | 2022-04-25 10:20:55.678
Triggering next historical data download in queue. | 2022-04-25 10:20:55.678
HD Request # 205 | Downloading Historical Daily chart data for SWCH-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:55.679
RADA-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 10:20:55.768
HD Request # 205 | Requesting historical Daily data for SWCH starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:57.100
HD Request # 205 | Receiving historical Daily data for SWCH-NQTV starting at 2022-04-20 | 2022-04-25 10:20:57.908
HD Request # 205 | Writing historical Daily data to the file SWCH-NQTV.dly | 2022-04-25 10:20:57.908
HD Request # 205 | Bytes received: 191 | 2022-04-25 10:20:57.917
HD Request # 205 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for SWCH-NQTV | 2022-04-25 10:20:57.917
HD Request # 205 | Completion time: 2s | 2022-04-25 10:20:57.917
HD Request # 205 | Daily data download complete for SWCH-NQTV. Unique request ID: 196 | 2022-04-25 10:20:57.917
Removing historical data download ID 196. | 2022-04-25 10:20:57.917
Triggering next historical data download in queue. | 2022-04-25 10:20:57.917
HD Request # 206 | Downloading Historical Daily chart data for SMPL-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:20:57.919
SWCH-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 10:20:58.126
HD Request # 206 | Requesting historical Daily data for SMPL starting at 2022-04-19. SC External HD service. | 2022-04-25 10:20:59.328
HD Request # 206 | Receiving historical Daily data for SMPL-NQTV starting at 2022-04-20 | 2022-04-25 10:21:00.071
HD Request # 206 | Writing historical Daily data to the file SMPL-NQTV.dly | 2022-04-25 10:21:00.071
HD Request # 206 | Bytes received: 191 | 2022-04-25 10:21:00.082
HD Request # 206 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for SMPL-NQTV | 2022-04-25 10:21:00.082
HD Request # 206 | Completion time: 3s | 2022-04-25 10:21:00.082
HD Request # 206 | Daily data download complete for SMPL-NQTV. Unique request ID: 197 | 2022-04-25 10:21:00.082
Removing historical data download ID 197. | 2022-04-25 10:21:00.082
Triggering next historical data download in queue. | 2022-04-25 10:21:00.082
HD Request # 207 | Downloading Historical Daily chart data for STLD-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:21:00.083
SMPL-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 10:21:00.180
HD Request # 207 | Requesting historical Daily data for STLD starting at 2022-04-19. SC External HD service. | 2022-04-25 10:21:01.504
HD Request # 207 | Receiving historical Daily data for STLD-NQTV starting at 2022-04-20 | 2022-04-25 10:21:02.253
HD Request # 207 | Writing historical Daily data to the file STLD-NQTV.dly | 2022-04-25 10:21:02.253
HD Request # 207 | Bytes received: 196 | 2022-04-25 10:21:02.303
HD Request # 207 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for STLD-NQTV | 2022-04-25 10:21:02.303
HD Request # 207 | Completion time: 2s | 2022-04-25 10:21:02.304
HD Request # 207 | Daily data download complete for STLD-NQTV. Unique request ID: 198 | 2022-04-25 10:21:02.304
Removing historical data download ID 198. | 2022-04-25 10:21:02.304
Triggering next historical data download in queue. | 2022-04-25 10:21:02.304
HD Request # 208 | Downloading Historical Daily chart data for TXT-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:21:02.305
STLD-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 10:21:02.456
HD Request # 208 | Requesting historical Daily data for TXT starting at 2022-04-19. SC External HD service. | 2022-04-25 10:21:03.730
HD Request # 208 | Receiving historical Daily data for TXT-NQTV starting at 2022-04-20 | 2022-04-25 10:21:04.544
HD Request # 208 | Writing historical Daily data to the file TXT-NQTV.dly | 2022-04-25 10:21:04.544
HD Request # 208 | Bytes received: 184 | 2022-04-25 10:21:04.613
HD Request # 208 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for TXT-NQTV | 2022-04-25 10:21:04.613
HD Request # 208 | Completion time: 2s | 2022-04-25 10:21:04.613
HD Request # 208 | Daily data download complete for TXT-NQTV. Unique request ID: 199 | 2022-04-25 10:21:04.613
Removing historical data download ID 199. | 2022-04-25 10:21:04.613
Triggering next historical data download in queue. | 2022-04-25 10:21:04.613
HD Request # 209 | Downloading Historical Daily chart data for TSN-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:21:04.614
TXT-NQTV[M] 2 Day #13 | Reloading chart. | 2022-04-25 10:21:04.694
HD Request # 209 | Requesting historical Daily data for TSN starting at 2022-04-19. SC External HD service. | 2022-04-25 10:21:06.026
HD Request # 209 | Receiving historical Daily data for TSN-NQTV starting at 2022-04-20 | 2022-04-25 10:21:06.775
HD Request # 209 | Writing historical Daily data to the file TSN-NQTV.dly | 2022-04-25 10:21:06.775
HD Request # 209 | Bytes received: 188 | 2022-04-25 10:21:06.846
HD Request # 209 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for TSN-NQTV | 2022-04-25 10:21:06.847
HD Request # 209 | Completion time: 2s | 2022-04-25 10:21:06.847
HD Request # 209 | Daily data download complete for TSN-NQTV. Unique request ID: 201 | 2022-04-25 10:21:06.847
Removing historical data download ID 201. | 2022-04-25 10:21:06.847
Triggering next historical data download in queue. | 2022-04-25 10:21:06.847
HD Request # 210 | Downloading Historical Daily chart data for TSLA-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:21:06.848
TSN-NQTV[M] 4 Day #7 | Reloading chart. | 2022-04-25 10:21:07.017
HD Request # 210 | Requesting historical Daily data for TSLA starting at 2022-04-19. SC External HD service. | 2022-04-25 10:21:08.262
HD Request # 210 | Receiving historical Daily data for TSLA-NQTV starting at 2022-04-20 | 2022-04-25 10:21:09.080
HD Request # 210 | Writing historical Daily data to the file TSLA-NQTV.dly | 2022-04-25 10:21:09.081
HD Request # 210 | Bytes received: 215 | 2022-04-25 10:21:09.106
HD Request # 210 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for TSLA-NQTV | 2022-04-25 10:21:09.106
HD Request # 210 | Completion time: 3s | 2022-04-25 10:21:09.106
HD Request # 210 | Daily data download complete for TSLA-NQTV. Unique request ID: 204 | 2022-04-25 10:21:09.106
Removing historical data download ID 204. | 2022-04-25 10:21:09.106
Triggering next historical data download in queue. | 2022-04-25 10:21:09.106
HD Request # 211 | Downloading Historical Daily chart data for TMST-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:21:09.108
TSLA-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 10:21:09.115
HD Request # 211 | Requesting historical Daily data for TMST starting at 2022-04-19. SC External HD service. | 2022-04-25 10:21:10.520
HD Request # 211 | Receiving historical Daily data for TMST-NQTV starting at 2022-04-20 | 2022-04-25 10:21:11.290
HD Request # 211 | Writing historical Daily data to the file TMST-NQTV.dly | 2022-04-25 10:21:11.290
HD Request # 211 | Bytes received: 192 | 2022-04-25 10:21:11.306
HD Request # 211 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for TMST-NQTV | 2022-04-25 10:21:11.306
HD Request # 211 | Completion time: 2s | 2022-04-25 10:21:11.306
HD Request # 211 | Daily data download complete for TMST-NQTV. Unique request ID: 205 | 2022-04-25 10:21:11.306
Removing historical data download ID 205. | 2022-04-25 10:21:11.306
Triggering next historical data download in queue. | 2022-04-25 10:21:11.306
HD Request # 212 | Downloading Historical Daily chart data for TNET-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:21:11.307
TMST-NQTV[M] Daily #4 | Reloading chart. | 2022-04-25 10:21:11.452
HD Request # 212 | Requesting historical Daily data for TNET starting at 2022-04-19. SC External HD service. | 2022-04-25 10:21:12.716
HD Request # 212 | Receiving historical Daily data for TNET-NQTV starting at 2022-04-20 | 2022-04-25 10:21:13.464
HD Request # 212 | Writing historical Daily data to the file TNET-NQTV.dly | 2022-04-25 10:21:13.464
HD Request # 212 | Bytes received: 185 | 2022-04-25 10:21:13.481
HD Request # 212 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for TNET-NQTV | 2022-04-25 10:21:13.481
HD Request # 212 | Completion time: 2s | 2022-04-25 10:21:13.481
HD Request # 212 | Daily data download complete for TNET-NQTV. Unique request ID: 207 | 2022-04-25 10:21:13.481
Removing historical data download ID 207. | 2022-04-25 10:21:13.481
Triggering next historical data download in queue. | 2022-04-25 10:21:13.481
HD Request # 213 | Downloading Historical Daily chart data for VIRT-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:21:13.483
TNET-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 10:21:13.488
HD Request # 213 | Requesting historical Daily data for VIRT starting at 2022-04-19. SC External HD service. | 2022-04-25 10:21:14.900
HD Request # 213 | Receiving historical Daily data for VIRT-NQTV starting at 2022-04-20 | 2022-04-25 10:21:15.668
HD Request # 213 | Writing historical Daily data to the file VIRT-NQTV.dly | 2022-04-25 10:21:15.668
HD Request # 213 | Bytes received: 193 | 2022-04-25 10:21:15.682
HD Request # 213 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for VIRT-NQTV | 2022-04-25 10:21:15.682
HD Request # 213 | Completion time: 2s | 2022-04-25 10:21:15.682
HD Request # 213 | Daily data download complete for VIRT-NQTV. Unique request ID: 209 | 2022-04-25 10:21:15.682
Removing historical data download ID 209. | 2022-04-25 10:21:15.682
Triggering next historical data download in queue. | 2022-04-25 10:21:15.682
HD Request # 214 | Downloading Historical Daily chart data for VET-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:21:15.684
VIRT-NQTV[M] 2 Day #4 | Reloading chart. | 2022-04-25 10:21:15.834
HD Request # 214 | Requesting historical Daily data for VET starting at 2022-04-19. SC External HD service. | 2022-04-25 10:21:17.104
HD Request # 214 | Receiving historical Daily data for VET-NQTV starting at 2022-04-20 | 2022-04-25 10:21:17.921
HD Request # 214 | Writing historical Daily data to the file VET-NQTV.dly | 2022-04-25 10:21:17.921
HD Request # 214 | Bytes received: 187 | 2022-04-25 10:21:17.945
HD Request # 214 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for VET-NQTV | 2022-04-25 10:21:17.945
HD Request # 214 | Completion time: 2s | 2022-04-25 10:21:17.945
HD Request # 214 | Daily data download complete for VET-NQTV. Unique request ID: 211 | 2022-04-25 10:21:17.945
Removing historical data download ID 211. | 2022-04-25 10:21:17.945
Triggering next historical data download in queue. | 2022-04-25 10:21:17.945
HD Request # 215 | Downloading Historical Daily chart data for WCN-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:21:17.946
VET-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 10:21:17.953
HD Request # 215 | Requesting historical Daily data for WCN starting at 2022-04-19. SC External HD service. | 2022-04-25 10:21:19.369
HD Request # 215 | Receiving historical Daily data for WCN-NQTV starting at 2022-04-20 | 2022-04-25 10:21:20.131
HD Request # 215 | Writing historical Daily data to the file WCN-NQTV.dly | 2022-04-25 10:21:20.131
HD Request # 215 | Bytes received: 203 | 2022-04-25 10:21:20.178
HD Request # 215 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for WCN-NQTV | 2022-04-25 10:21:20.178
HD Request # 215 | Completion time: 3s | 2022-04-25 10:21:20.178
HD Request # 215 | Daily data download complete for WCN-NQTV. Unique request ID: 212 | 2022-04-25 10:21:20.178
Removing historical data download ID 212. | 2022-04-25 10:21:20.178
Triggering next historical data download in queue. | 2022-04-25 10:21:20.178
HD Request # 216 | Downloading Historical Daily chart data for WMT-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:21:20.179
WCN-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 10:21:20.284
HD Request # 216 | Requesting historical Daily data for WMT starting at 2022-04-19. SC External HD service. | 2022-04-25 10:21:21.618
HD Request # 216 | Receiving historical Daily data for WMT-NQTV starting at 2022-04-20 | 2022-04-25 10:21:22.426
HD Request # 216 | Writing historical Daily data to the file WMT-NQTV.dly | 2022-04-25 10:21:22.426
HD Request # 216 | Bytes received: 205 | 2022-04-25 10:21:22.494
HD Request # 216 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for WMT-NQTV | 2022-04-25 10:21:22.494
HD Request # 216 | Completion time: 2s | 2022-04-25 10:21:22.494
HD Request # 216 | Daily data download complete for WMT-NQTV. Unique request ID: 214 | 2022-04-25 10:21:22.494
Removing historical data download ID 214. | 2022-04-25 10:21:22.494
Triggering next historical data download in queue. | 2022-04-25 10:21:22.494
HD Request # 217 | Downloading Historical Daily chart data for XOM-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:21:22.496
WMT-NQTV[M] 2 Day #4 | Reloading chart. | 2022-04-25 10:21:22.666
HD Request # 217 | Requesting historical Daily data for XOM starting at 2022-04-19. SC External HD service. | 2022-04-25 10:21:23.903
HD Request # 217 | Receiving historical Daily data for XOM-NQTV starting at 2022-04-20 | 2022-04-25 10:21:24.722
HD Request # 217 | Writing historical Daily data to the file XOM-NQTV.dly | 2022-04-25 10:21:24.723
HD Request # 217 | Bytes received: 186 | 2022-04-25 10:21:24.791
HD Request # 217 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for XOM-NQTV | 2022-04-25 10:21:24.791
HD Request # 217 | Completion time: 2s | 2022-04-25 10:21:24.791
HD Request # 217 | Daily data download complete for XOM-NQTV. Unique request ID: 215 | 2022-04-25 10:21:24.791
Removing historical data download ID 215. | 2022-04-25 10:21:24.791
Triggering next historical data download in queue. | 2022-04-25 10:21:24.791
HD Request # 218 | Downloading Historical Daily chart data for XEC-NQTV. Starting date: 2021-09-28. Service: nasdaq_exchange.data | 2022-04-25 10:21:24.793
XOM-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 10:21:24.806
HD Request # 218 | Requesting historical Daily data for XEC starting at 2021-09-27. SC External HD service. | 2022-04-25 10:21:26.212
HD Request # 218 | Receiving historical Daily data for XEC-NQTV starting at 2021-09-28 | 2022-04-25 10:21:26.974
HD Request # 218 | Writing historical Daily data to the file XEC-NQTV.dly | 2022-04-25 10:21:26.975
HD Request # 218 | Bytes received: 184 | 2022-04-25 10:21:27.013
HD Request # 218 | Received 4 Daily data records from 2021-09-28 00:00:00 to 2021-09-30 00:00:00 (3.0 days) and wrote 3 records for XEC-NQTV | 2022-04-25 10:21:27.013
HD Request # 218 | Completion time: 3s | 2022-04-25 10:21:27.013
HD Request # 218 | Daily data download complete for XEC-NQTV. Unique request ID: 217 | 2022-04-25 10:21:27.013
Removing historical data download ID 217. | 2022-04-25 10:21:27.013
Triggering next historical data download in queue. | 2022-04-25 10:21:27.013
HD Request # 219 | Downloading Historical Daily chart data for X-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 10:21:27.015
XEC-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 10:21:27.102
HD Request # 219 | Requesting historical Daily data for X starting at 2022-04-19. SC External HD service. | 2022-04-25 10:21:28.428
HD Request # 219 | Receiving historical Daily data for X-NQTV starting at 2022-04-20 | 2022-04-25 10:21:29.177
HD Request # 219 | Writing historical Daily data to the file X-NQTV.dly | 2022-04-25 10:21:29.177
HD Request # 219 | Bytes received: 180 | 2022-04-25 10:21:29.246
HD Request # 219 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for X-NQTV | 2022-04-25 10:21:29.246
HD Request # 219 | Completion time: 2s | 2022-04-25 10:21:29.246
HD Request # 219 | Daily data download complete for X-NQTV. Unique request ID: 218 | 2022-04-25 10:21:29.246
Removing historical data download ID 218. | 2022-04-25 10:21:29.246
Triggering next historical data download in queue. | 2022-04-25 10:21:29.246
No download requests in the queue to start downloads for. | 2022-04-25 10:21:29.246
X-NQTV[M] 8 Day #5 | Reloading chart. | 2022-04-25 10:21:29.391
Opened cached Intraday file: C:\SierraChart\Data\GCBC-NQTV.scid. Thread ID: 19936 | 2022-04-25 10:21:51.887
HESM-NQTV[M] 2 Day #4 | Reloading chart. | 2022-04-25 10:32:56.689
HESM-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 10:32:57.709
HESM-NQTV[M] 2 Day #4 | Reloading chart. | 2022-04-25 10:33:01.448
HESM-NQTV[M] Daily #4 | Reloading chart. | 2022-04-25 10:33:05.288
HESM-NQTV[M] 2 Day #4 | Reloading chart. | 2022-04-25 10:33:13.930
AJG-NQTV[M] 8 Day #19 | Reloading chart. | 2022-04-25 10:33:24.399
AJG-NQTV[M] 16 Day #19 | Reloading chart. | 2022-04-25 10:33:25.802
AJG-NQTV[M] 32 Day #19 | Reloading chart. | 2022-04-25 10:33:26.708
AJG-NQTV[M] 64 Day #19 | Reloading chart. | 2022-04-25 10:33:27.800
AJG-NQTV[M] 8 Day #19 | Reloading chart. | 2022-04-25 10:33:29.225
AJG-NQTV[M] 4 Day #19 | Reloading chart. | 2022-04-25 10:33:32.920
Saved Chartbook: MACRO.Cht. Time: 0.0221 seconds. | 2022-04-25 10:33:37.693
Saved Chartbook: SCREENING.Cht. Time: 0.0007 seconds. | 2022-04-25 10:33:37.694
Saved Chartbook: ACTION.Cht. Time: 0.0010 seconds. | 2022-04-25 10:33:37.696
Saved Chartbook: AGGS.Cht. Time: 0.0074 seconds. | 2022-04-25 10:33:37.704
Saved Chartbook: INDICES.Cht. Time: 0.0327 seconds. | 2022-04-25 10:33:37.737
Saved Chartbook: METALS.Cht. Time: 0.0117 seconds. | 2022-04-25 10:33:37.750
Saved Chartbook: ENERGY.Cht. Time: 0.0219 seconds. | 2022-04-25 10:33:37.772
Saved Chartbook: CRYPTO.Cht. Time: 0.0132 seconds. | 2022-04-25 10:33:37.786
Saved Chartbook: FOREX.Cht. Time: 0.0126 seconds. | 2022-04-25 10:33:37.800
Saved Chartbook: AAA.Cht. Time: 0.0236 seconds. | 2022-04-25 10:33:37.824
Saved Chartbook: BBB.Cht. Time: 0.0023 seconds. | 2022-04-25 10:33:37.827
Saved Chartbook: CCC.Cht. Time: 0.0227 seconds. | 2022-04-25 10:33:37.851
Saved Chartbook: DDD.Cht. Time: 0.0042 seconds. | 2022-04-25 10:33:37.855
Saved Chartbook: EEE.Cht. Time: 0.0050 seconds. | 2022-04-25 10:33:37.861
Saved Chartbook: FFF.Cht. Time: 0.0128 seconds. | 2022-04-25 10:33:37.874
Saved Chartbook: GGG.Cht. Time: 0.0037 seconds. | 2022-04-25 10:33:37.879
Saved Chartbook: HHH.Cht. Time: 0.0135 seconds. | 2022-04-25 10:33:37.893
Saved Chartbook: III.Cht. Time: 0.0017 seconds. | 2022-04-25 10:33:37.895
Saved Chartbook: KKK.Cht. Time: 0.0028 seconds. | 2022-04-25 10:33:37.899
Saved Chartbook: LLL.Cht. Time: 0.0117 seconds. | 2022-04-25 10:33:37.912
Saved Chartbook: MMM.Cht. Time: 0.0017 seconds. | 2022-04-25 10:33:37.914
Saved Chartbook: NNN.Cht. Time: 0.0037 seconds. | 2022-04-25 10:33:37.918
Saved Chartbook: OOO.Cht. Time: 0.0030 seconds. | 2022-04-25 10:33:37.922
Saved Chartbook: PPP.Cht. Time: 0.0141 seconds. | 2022-04-25 10:33:37.937
Saved Chartbook: RRR.Cht. Time: 0.0032 seconds. | 2022-04-25 10:33:37.941
Saved Chartbook: SSS.Cht. Time: 0.0035 seconds. | 2022-04-25 10:33:37.945
Saved Chartbook: TTT.Cht. Time: 0.0160 seconds. | 2022-04-25 10:33:37.961
Saved Chartbook: UUU.Cht. Time: 0.0016 seconds. | 2022-04-25 10:33:37.964
Saved Chartbook: VVV.Cht. Time: 0.0034 seconds. | 2022-04-25 10:33:37.968
Saved Chartbook: WWW.Cht. Time: 0.0039 seconds. | 2022-04-25 10:33:37.972
Saved Chartbook: XXX.Cht. Time: 0.0040 seconds. | 2022-04-25 10:33:37.977
Saved Chartbook: ZZZ.Cht. Time: 0.0019 seconds. | 2022-04-25 10:33:37.979
ACHC-NQTV[M] 8 Day #11 | Reloading chart. | 2022-04-25 10:33:41.114
ACHC-NQTV[M] 16 Day #11 | Reloading chart. | 2022-04-25 10:33:42.112
ACHC-NQTV[M] 32 Day #11 | Reloading chart. | 2022-04-25 10:33:42.847
ACHC-NQTV[M] 64 Day #11 | Reloading chart. | 2022-04-25 10:33:43.873
ACHC-NQTV[M] 8 Day #11 | Reloading chart. | 2022-04-25 10:33:45.197
ACHC-NQTV[M] 4 Day #11 | Reloading chart. | 2022-04-25 10:33:47.804
ACHC-NQTV[M] 8 Day #11 | Reloading chart. | 2022-04-25 10:33:53.319
AMX-NQTV[M] 4 Day #20 | Reloading chart. | 2022-04-25 10:33:57.727
AMX-NQTV[M] 8 Day #20 | Reloading chart. | 2022-04-25 10:33:58.804
AMX-NQTV[M] 16 Day #20 | Reloading chart. | 2022-04-25 10:33:59.748
AMX-NQTV[M] 32 Day #20 | Reloading chart. | 2022-04-25 10:34:00.304
AMX-NQTV[M] 4 Day #20 | Reloading chart. | 2022-04-25 10:34:01.785
AMX-NQTV[M] 4 Day #20 | Reloading chart. | 2022-04-25 10:34:16.291
AMX-NQTV[M] 8 Day #20 | Reloading chart. | 2022-04-25 10:34:17.033
AMX-NQTV[M] 16 Day #20 | Reloading chart. | 2022-04-25 10:34:19.141
AMX-NQTV[M] 4 Day #20 | Reloading chart. | 2022-04-25 10:34:21.461
AMX-NQTV[M] 8 Day #20 | Reloading chart. | 2022-04-25 10:34:25.850
AMX-NQTV[M] 4 Day #20 | Reloading chart. | 2022-04-25 10:34:27.385
AMX-NQTV[M] 2 Day #20 | Reloading chart. | 2022-04-25 10:34:28.330
AMX-NQTV[M] 8 Day #20 | Reloading chart. | 2022-04-25 10:34:33.008
AMX-NQTV[M] 16 Day #20 | Reloading chart. | 2022-04-25 10:34:34.515
USOil[M] 4 Day #13 | Reloading chart. | 2022-04-25 10:34:54.498
USOil[M] 8 Day #13 | Reloading chart. | 2022-04-25 10:34:57.093
USOil[M] 16 Day #13 | Reloading chart. | 2022-04-25 10:34:58.115
AMH-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 10:35:20.936
AMH-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 10:35:21.519
AMH-NQTV[M] 16 Day #6 | Reloading chart. | 2022-04-25 10:35:23.116
AMH-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 10:35:23.912
AMH-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 10:35:25.246
AMH-NQTV[M] 16 Day #6 | Reloading chart. | 2022-04-25 10:35:37.614
AMH-NQTV[M] 32 Day #6 | Reloading chart. | 2022-04-25 10:35:38.295
AMH-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 10:35:43.183
AMH-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 10:35:45.634
AMH-NQTV[M] 2 Day #6 | Reloading chart. | 2022-04-25 10:35:53.021
AMH-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 10:35:55.002
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD Daily #2 | Reloading chart. | 2022-04-25 10:36:08.272
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD Daily #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:36:08.294
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 4 Day #2 | Reloading chart. | 2022-04-25 10:36:12.095
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 4 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:36:12.115
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | Reloading chart. | 2022-04-25 10:36:13.404
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:36:13.424
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 4 Day #2 | Reloading chart. | 2022-04-25 10:36:31.972
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 4 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:36:32.003
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | Reloading chart. | 2022-04-25 10:36:33.478
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:36:33.498
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 256 Min #8 | Reloading chart. | 2022-04-25 10:36:40.276
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 256 Min #8 | StartDateTimeForLoadingOrderFills: 2021-10-18 09:30:00 | 2022-04-25 10:36:40.308
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 128 Min #8 | Reloading chart. | 2022-04-25 10:37:10.209
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 128 Min #8 | StartDateTimeForLoadingOrderFills: 2021-10-18 09:30:00 | 2022-04-25 10:37:10.242
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 32 Min #8 | Reloading chart. | 2022-04-25 10:37:12.729
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 32 Min #8 | StartDateTimeForLoadingOrderFills: 2021-10-18 09:30:00 | 2022-04-25 10:37:12.786
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD Daily #2 | Reloading chart. | 2022-04-25 10:37:50.846
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD Daily #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:37:50.881
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | Reloading chart. | 2022-04-25 10:37:53.551
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:37:53.587
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 4 Day #2 | Reloading chart. | 2022-04-25 10:37:57.378
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 4 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:37:57.398
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | Reloading chart. | 2022-04-25 10:37:59.492
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:37:59.512
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD Daily #2 | Reloading chart. | 2022-04-25 10:38:00.680
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD Daily #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:38:00.703
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | Reloading chart. | 2022-04-25 10:38:01.671
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:38:01.692
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 4 Day #2 | Reloading chart. | 2022-04-25 10:38:05.900
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 4 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:38:05.920
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | Reloading chart. | 2022-04-25 10:38:06.319
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:38:06.339
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 16 Day #2 | Reloading chart. | 2022-04-25 10:38:13.166
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 16 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:38:13.185
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 32 Day #2 | Reloading chart. | 2022-04-25 10:38:15.496
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 32 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:38:15.515
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 8 Day #2 | Reloading chart. | 2022-04-25 10:38:15.980
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 8 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:38:16.011
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 32 Day #2 | Reloading chart. | 2022-04-25 10:38:24.587
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 32 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:38:24.607
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 8 Day #2 | Reloading chart. | 2022-04-25 10:38:26.186
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 8 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:38:26.217
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 32 Day #2 | Reloading chart. | 2022-04-25 10:38:31.112
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 32 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:38:31.132
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 8 Day #2 | Reloading chart. | 2022-04-25 10:38:34.761
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 8 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:38:34.781
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | Reloading chart. | 2022-04-25 10:38:36.931
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:38:36.951
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 4 Day #2 | Reloading chart. | 2022-04-25 10:38:43.531
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 4 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 10:38:43.561
AMR-NQTV[M] Daily #5 | Reloading chart. | 2022-04-25 10:39:04.397
AMR-NQTV[M] 4 Day #5 | Reloading chart. | 2022-04-25 10:39:07.230
AMR-NQTV[M] 2 Day #5 | Reloading chart. | 2022-04-25 10:39:09.179
AMR-NQTV[M] Daily #5 | Reloading chart. | 2022-04-25 10:39:11.103
AMR-NQTV[M] 2 Day #5 | Reloading chart. | 2022-04-25 10:39:12.629
AMR-NQTV[M] 4 Day #5 | Reloading chart. | 2022-04-25 10:39:13.109
AMR-NQTV[M] 8 Day #5 | Reloading chart. | 2022-04-25 10:39:13.496
AMR-NQTV[M] Daily #5 | Reloading chart. | 2022-04-25 10:39:15.244
AA-NQTV[M] 2 Day #9 | Reloading chart. | 2022-04-25 10:39:23.287
AA-NQTV[M] 4 Day #9 | Reloading chart. | 2022-04-25 10:39:25.832
AA-NQTV[M] 8 Day #9 | Reloading chart. | 2022-04-25 10:39:26.312
AA-NQTV[M] 2 Day #9 | Reloading chart. | 2022-04-25 10:39:27.073
BJ-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 10:39:33.463
BJ-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 10:39:34.568
BJ-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 10:39:35.433
BJ-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 10:39:36.105
BJ-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 10:39:37.627
BJ-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 10:39:41.046
BJ-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 10:39:51.667
BJ-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 10:39:53.594
BJ-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 10:39:56.035
BJ-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 10:39:56.888
BJ-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 10:39:59.950
BJ-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 10:40:01.138
BJ-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 10:40:01.745
BJ-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 10:40:06.352
BJ-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 10:40:08.973
BJ-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 10:40:10.990
BJ-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 10:40:11.387
BJ-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 10:40:12.201
BJ-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 10:40:15.766
BJ-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 10:40:18.150
CLH-NQTV[M] 8 Day #8 | Reloading chart. | 2022-04-25 10:40:29.574
CLH-NQTV[M] 16 Day #8 | Reloading chart. | 2022-04-25 10:40:32.034
CLH-NQTV[M] 32 Day #8 | Reloading chart. | 2022-04-25 10:40:32.714
CLH-NQTV[M] 64 Day #8 | Reloading chart. | 2022-04-25 10:40:33.519
CLH-NQTV[M] 4 Day #8 | Reloading chart. | 2022-04-25 10:40:35.148
CLH-NQTV[M] 2 Day #8 | Reloading chart. | 2022-04-25 10:40:43.880
COST-NQTV[M] 4 Day #12 | Reloading chart. | 2022-04-25 10:41:20.342
COST-NQTV[M] 8 Day #12 | Reloading chart. | 2022-04-25 10:41:24.281
COST-NQTV[M] 16 Day #12 | Reloading chart. | 2022-04-25 10:41:27.031
COST-NQTV[M] 32 Day #12 | Reloading chart. | 2022-04-25 10:41:28.318
COST-NQTV[M] 64 Day #12 | Reloading chart. | 2022-04-25 10:41:29.299
COST-NQTV[M] 32 Day #12 | Reloading chart. | 2022-04-25 10:41:31.883
SWCH-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 10:41:42.055
SWCH-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 10:41:43.130
SWCH-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 10:41:52.188
SWCH-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 10:41:53.731
SWCH-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 10:41:55.976
SWCH-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 10:41:59.855
SWCH-NQTV[M] 16 Day #3 | Reloading chart. | 2022-04-25 10:42:00.501
SWCH-NQTV[M] 32 Day #3 | Reloading chart. | 2022-04-25 10:42:00.992
SWCH-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 10:42:02.163
SWCH-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 10:42:02.613
SWCH-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 10:42:07.895
SWCH-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 10:42:31.752
SWCH-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 10:42:32.848
SWCH-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 10:42:36.348
SWCH-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 10:42:39.560
ZW-202207-ECBOT[M] 512 Min #11 | Reloading chart. | 2022-04-25 10:43:14.773
ZW-202207-ECBOT[M] 512 Min #11 | StartDateTimeForLoadingOrderFills: 2021-10-11 04:32:00 | 2022-04-25 10:43:14.936
ZW-202207-ECBOT[M] 128 Min #11 | Reloading chart. | 2022-04-25 10:43:18.271
ZW-202207-ECBOT[M] 128 Min #11 | StartDateTimeForLoadingOrderFills: 2021-10-11 10:56:00 | 2022-04-25 10:43:18.414
ZW-202207-ECBOT[M] 512 Min #11 | Reloading chart. | 2022-04-25 10:43:25.085
ZW-202207-ECBOT[M] 512 Min #11 | StartDateTimeForLoadingOrderFills: 2021-10-11 04:32:00 | 2022-04-25 10:43:25.228
LSI-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 10:44:08.198
LSI-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 10:44:08.805
LSI-NQTV[M] 16 Day #4 | Reloading chart. | 2022-04-25 10:44:09.820
LSI-NQTV[M] 32 Day #4 | Reloading chart. | 2022-04-25 10:44:10.518
LSI-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 10:44:13.854
LSI-NQTV[M] 2 Day #4 | Reloading chart. | 2022-04-25 10:44:15.254
LSI-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 10:44:18.853
LSI-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 10:44:20.272
LSI-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 10:44:25.276
LSI-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 10:44:26.412
LSI-NQTV[M] 16 Day #4 | Reloading chart. | 2022-04-25 10:44:27.195
LSI-NQTV[M] 32 Day #4 | Reloading chart. | 2022-04-25 10:44:28.895
LSI-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 10:44:31.564
LSI-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 10:44:41.878
LSI-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 10:45:26.757
NVDA Daily #6 | Reloading chart. | 2022-04-25 10:45:44.094
Added historical Daily data request for NVDA to the queue. | 2022-04-25 10:45:44.587
Triggering next historical data download in queue. | 2022-04-25 10:45:44.587
Interactive Brokers | Starting real-time market data updates for: NVDA. ID: 182 | 2022-04-25 10:45:44.587
Interactive Brokers | Subscribing to real-time True Data for symbol: NVDA SecurityType: STK Exchange: SMART Currency: | 2022-04-25 10:45:44.587
Interactive Brokers | Subscribing to Symbol: NVDA, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2022-04-25 10:45:44.587
Interactive Brokers | Requesting security definition data for: NVDA. ID: 182 | 2022-04-25 10:45:44.587
HD Request # 220 | Downloading Historical Daily chart data for NVDA. Starting date: 2022-04-08. Service: interactive_brokers.trading | 2022-04-25 10:45:44.635
Symbol Error - NVDA is unknown, unavailable, or improperly formatted. The contract description specified for NVDA is ambiguous;
you must specify the currency. | 2022-04-25 10:45:45.035
Interactive Brokers | Market data type is Live for NVDA | 2022-04-25 10:45:45.083
HD Request # 220 | Requesting historical Daily data for NVDA starting at 2022-04-07. SC External HD service. | 2022-04-25 10:45:46.051
HD Request # 220 | Receiving historical Daily data for NVDA starting at 2022-04-08 | 2022-04-25 10:45:47.090
HD Request # 220 | Writing historical Daily data to the file NVDA.dly | 2022-04-25 10:45:47.090
HD Request # 220 | Bytes received: 574 | 2022-04-25 10:45:47.136
HD Request # 220 | Received 11 Daily data records from 2022-04-08 00:00:00 to 2022-04-22 00:00:00 (15.0 days) and wrote 10 records for NVDA | 2022-04-25 10:45:47.136
HD Request # 220 | Completion time: 3s | 2022-04-25 10:45:47.136
HD Request # 220 | Daily data download complete for NVDA. Unique request ID: 221 | 2022-04-25 10:45:47.136
Removing historical data download ID 221. | 2022-04-25 10:45:47.136
Triggering next historical data download in queue. | 2022-04-25 10:45:47.136
No download requests in the queue to start downloads for. | 2022-04-25 10:45:47.136
NVDA Daily #6 | Reloading chart. | 2022-04-25 10:45:47.258
NVDA 8 Day #6 | Reloading chart. | 2022-04-25 10:45:49.052
NVDA 32 Day #6 | Reloading chart. | 2022-04-25 10:45:57.219
NVDA 8 Day #6 | Reloading chart. | 2022-04-25 10:46:10.292
NVDA 16 Day #6 | Reloading chart. | 2022-04-25 10:46:23.999
NVDA 32 Day #6 | Reloading chart. | 2022-04-25 10:46:28.006
NVDA 64 Day #6 | Reloading chart. | 2022-04-25 10:46:29.415
NVDA 32 Day #6 | Reloading chart. | 2022-04-25 10:46:34.083
NVDA 8 Day #6 | Reloading chart. | 2022-04-25 10:46:35.575
NVDA 4 Day #6 | Reloading chart. | 2022-04-25 10:46:50.054
NVDA 8 Day #6 | Reloading chart. | 2022-04-25 10:47:29.790
NVDA 16 Day #6 | Reloading chart. | 2022-04-25 10:47:34.827
NVDA 32 Day #6 | Reloading chart. | 2022-04-25 10:47:37.121
NVDA 16 Day #6 | Reloading chart. | 2022-04-25 10:47:40.828
NVDA 8 Day #6 | Reloading chart. | 2022-04-25 10:47:52.756
NVDA 4 Day #6 | Reloading chart. | 2022-04-25 10:47:57.945
LSI-NQTV[M] 2 Day #4 | Reloading chart. | 2022-04-25 10:48:17.845
LSI-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 10:48:21.387
MU-NQTV Daily #3 | Reloading chart. | 2022-04-25 10:50:32.811
Enabling compression for file: C:\SierraChart\Data\MU-NQTV.dly. This may take a while. | 2022-04-25 10:50:32.813
File compression enabled. C:\SierraChart\Data\MU-NQTV.dly. CompressionState=0 | 2022-04-25 10:50:32.813
MU-NQTV Daily #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\MU-NQTV.dly | 2022-04-25 10:50:32.816
Added historical Daily data request for MU-NQTV to the queue. | 2022-04-25 10:50:33.099
Triggering next historical data download in queue. | 2022-04-25 10:50:33.099
Mapping MU-NQTV to MU-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 10:50:33.100
SC Data - All Services | Starting real-time market data updates for: MU-NQTV (MU-NQTV). ID: 183 Service code: nasdaq_exchange.data | 2022-04-25 10:50:33.100
SC Data - All Services | Requesting security definition data for: MU-NQTV (MU-NQTV). ID: 183 | 2022-04-25 10:50:33.100
HD Request # 221 | Downloading Historical Daily chart data for MU-NQTV. Starting date: 1972-04-25. Service: nasdaq_exchange.data | 2022-04-25 10:50:33.101
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 183. Symbol: MU-NQTV | 2022-04-25 10:50:33.101
SC Data - All Services | Received security definition for symbol MU-NQTV | 2022-04-25 10:50:33.407
HD Request # 221 | Requesting historical Daily data for MU starting at 1972-04-24. SC External HD service. | 2022-04-25 10:50:34.514
HD Request # 221 | Receiving historical Daily data for MU-NQTV starting at 1989-05-16 | 2022-04-25 10:50:35.379
HD Request # 221 | Writing historical Daily data to the file MU-NQTV.dly | 2022-04-25 10:50:35.379
HD Request # 221 | Bytes received: 382191 | 2022-04-25 10:50:35.959
HD Request # 221 | Received 8299 Daily data records from 1989-05-16 00:00:00 to 2022-04-22 00:00:00 (33.0years) and wrote 8299 records for MU-NQTV | 2022-04-25 10:50:35.959
HD Request # 221 | Completion time: 2s | 2022-04-25 10:50:35.959
HD Request # 221 | Daily data download complete for MU-NQTV. Unique request ID: 222 | 2022-04-25 10:50:35.959
Removing historical data download ID 222. | 2022-04-25 10:50:35.959
Triggering next historical data download in queue. | 2022-04-25 10:50:35.959
No download requests in the queue to start downloads for. | 2022-04-25 10:50:35.959
MU-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 10:50:36.174
MU-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 10:50:42.274
Saved Chartbook: MACRO.Cht. Time: 0.0213 seconds. | 2022-04-25 10:53:38.009
Saved Chartbook: SCREENING.Cht. Time: 0.0007 seconds. | 2022-04-25 10:53:38.010
Saved Chartbook: ACTION.Cht. Time: 0.0010 seconds. | 2022-04-25 10:53:38.011
Saved Chartbook: AGGS.Cht. Time: 0.0073 seconds. | 2022-04-25 10:53:38.019
Saved Chartbook: INDICES.Cht. Time: 0.0332 seconds. | 2022-04-25 10:53:38.053
Saved Chartbook: METALS.Cht. Time: 0.0117 seconds. | 2022-04-25 10:53:38.065
Saved Chartbook: ENERGY.Cht. Time: 0.0222 seconds. | 2022-04-25 10:53:38.088
Saved Chartbook: CRYPTO.Cht. Time: 0.0050 seconds. | 2022-04-25 10:53:38.094
Saved Chartbook: FOREX.Cht. Time: 0.0136 seconds. | 2022-04-25 10:53:38.108
Saved Chartbook: AAA.Cht. Time: 0.0237 seconds. | 2022-04-25 10:53:38.132
Saved Chartbook: BBB.Cht. Time: 0.0022 seconds. | 2022-04-25 10:53:38.135
Saved Chartbook: CCC.Cht. Time: 0.0213 seconds. | 2022-04-25 10:53:38.157
Saved Chartbook: DDD.Cht. Time: 0.0114 seconds. | 2022-04-25 10:53:38.169
Saved Chartbook: EEE.Cht. Time: 0.0115 seconds. | 2022-04-25 10:53:38.181
Saved Chartbook: FFF.Cht. Time: 0.0036 seconds. | 2022-04-25 10:53:38.185
Saved Chartbook: GGG.Cht. Time: 0.0033 seconds. | 2022-04-25 10:53:38.189
Saved Chartbook: HHH.Cht. Time: 0.0142 seconds. | 2022-04-25 10:53:38.204
Saved Chartbook: III.Cht. Time: 0.0019 seconds. | 2022-04-25 10:53:38.207
Saved Chartbook: KKK.Cht. Time: 0.0030 seconds. | 2022-04-25 10:53:38.210
Saved Chartbook: LLL.Cht. Time: 0.0041 seconds. | 2022-04-25 10:53:38.215
Saved Chartbook: MMM.Cht. Time: 0.0021 seconds. | 2022-04-25 10:53:38.218
Saved Chartbook: NNN.Cht. Time: 0.0030 seconds. | 2022-04-25 10:53:38.221
Saved Chartbook: OOO.Cht. Time: 0.0035 seconds. | 2022-04-25 10:53:38.225
Saved Chartbook: PPP.Cht. Time: 0.0136 seconds. | 2022-04-25 10:53:38.240
Saved Chartbook: RRR.Cht. Time: 0.0029 seconds. | 2022-04-25 10:53:38.243
Saved Chartbook: SSS.Cht. Time: 0.0034 seconds. | 2022-04-25 10:53:38.247
Saved Chartbook: TTT.Cht. Time: 0.0219 seconds. | 2022-04-25 10:53:38.270
Saved Chartbook: UUU.Cht. Time: 0.0012 seconds. | 2022-04-25 10:53:38.271
Saved Chartbook: VVV.Cht. Time: 0.0032 seconds. | 2022-04-25 10:53:38.275
Saved Chartbook: WWW.Cht. Time: 0.0039 seconds. | 2022-04-25 10:53:38.280
Saved Chartbook: XXX.Cht. Time: 0.0127 seconds. | 2022-04-25 10:53:38.293
Saved Chartbook: ZZZ.Cht. Time: 0.0013 seconds. | 2022-04-25 10:53:38.295
AJG-NQTV[M] 8 Day #19 | Reloading chart. | 2022-04-25 11:03:26.695
AJG-NQTV[M] 32 Day #19 | Reloading chart. | 2022-04-25 11:03:28.333
AJG-NQTV[M] 8 Day #19 | Reloading chart. | 2022-04-25 11:03:29.866
AJG-NQTV[M] 4 Day #19 | Reloading chart. | 2022-04-25 11:03:30.245
AJG-NQTV[M] Daily #19 | Reloading chart. | 2022-04-25 11:03:37.749
AJG-NQTV[M] 4 Day #19 | Reloading chart. | 2022-04-25 11:03:38.941
AJG-NQTV[M] 8 Day #19 | Reloading chart. | 2022-04-25 11:03:40.542
AJG-NQTV[M] 16 Day #19 | Reloading chart. | 2022-04-25 11:03:48.788
AJG-NQTV[M] 32 Day #19 | Reloading chart. | 2022-04-25 11:03:49.522
AJG-NQTV[M] 4 Day #19 | Reloading chart. | 2022-04-25 11:03:50.610
AJG-NQTV[M] Daily #19 | Reloading chart. | 2022-04-25 11:03:54.218
AJG-NQTV[M] 4 Day #19 | Reloading chart. | 2022-04-25 11:03:56.906
AJG-NQTV[M] 2 Day #19 | Reloading chart. | 2022-04-25 11:03:57.880
AJG-NQTV[M] 4 Day #19 | Reloading chart. | 2022-04-25 11:03:59.015
TSLA-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 11:04:14.839
TSLA-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 11:04:16.869
TSLA-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 11:04:23.151
TSLA-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 11:04:33.196
TSLA-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 11:04:36.856
TSLA-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 11:04:38.214
TSLA-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 11:04:38.982
TSLA-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 11:04:46.482
TSLA-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 11:04:48.668
TSLA-NQTV[M] 64 Day #2 | Reloading chart. | 2022-04-25 11:04:53.794
TSLA-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 11:04:57.753
TSLA-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 11:04:58.961
TSLA-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 11:04:59.877
TSLA-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 11:05:04.882
AJG-NQTV[M] 8 Day #19 | Reloading chart. | 2022-04-25 11:05:36.036
AJG-NQTV[M] 16 Day #19 | Reloading chart. | 2022-04-25 11:05:37.253
AJG-NQTV[M] 32 Day #19 | Reloading chart. | 2022-04-25 11:05:37.850
AJG-NQTV[M] 64 Day #19 | Reloading chart. | 2022-04-25 11:05:38.897
AJG-NQTV[M] 8 Day #19 | Reloading chart. | 2022-04-25 11:05:40.999
AJG-NQTV[M] 4 Day #19 | Reloading chart. | 2022-04-25 11:05:53.617
AJG-NQTV[M] 4 Day #19 | Reloading chart. | 2022-04-25 11:05:58.860
AJG-NQTV[M] 8 Day #19 | Reloading chart. | 2022-04-25 11:06:10.930
AJG-NQTV[M] 2 Day #19 | Reloading chart. | 2022-04-25 11:06:12.738
AJG-NQTV[M] 8 Day #19 | Reloading chart. | 2022-04-25 11:06:14.625
AJG-NQTV[M] 16 Day #19 | Reloading chart. | 2022-04-25 11:06:15.694
AJG-NQTV[M] 32 Day #19 | Reloading chart. | 2022-04-25 11:06:16.237
AJG-NQTV[M] 64 Day #19 | Reloading chart. | 2022-04-25 11:06:18.458
AJG-NQTV[M] 8 Day #19 | Reloading chart. | 2022-04-25 11:06:19.098
AJG-NQTV[M] 16 Day #19 | Reloading chart. | 2022-04-25 11:06:22.814
USOil[M] 4 Day #13 | Reloading chart. | 2022-04-25 11:06:50.252
USOil[M] 16 Day #13 | Reloading chart. | 2022-04-25 11:06:59.777
USOil[M] 32 Day #13 | Reloading chart. | 2022-04-25 11:07:02.466
USOil[M] 4 Day #13 | Reloading chart. | 2022-04-25 11:07:07.360
USOil[M] 2 Day #13 | Reloading chart. | 2022-04-25 11:07:12.046
USOil[M] 4 Day #13 | Reloading chart. | 2022-04-25 11:07:14.625
USOil[M] 16 Day #13 | Reloading chart. | 2022-04-25 11:07:19.466
USOil[M] 2 Day #13 | Reloading chart. | 2022-04-25 11:07:22.138
USOil[M] 4 Day #13 | Reloading chart. | 2022-04-25 11:07:25.433
USOil[M] 2 Day #13 | Reloading chart. | 2022-04-25 11:07:45.339
USOil[M] 8 Day #13 | Reloading chart. | 2022-04-25 11:07:46.901
USOil[M] 4 Day #13 | Reloading chart. | 2022-04-25 11:08:04.532
USOil[M] 8 Day #13 | Reloading chart. | 2022-04-25 11:08:09.947
USOil[M] 2 Day #13 | Reloading chart. | 2022-04-25 11:08:17.092
USOil[M] 4 Day #13 | Reloading chart. | 2022-04-25 11:08:19.946
USOil[M] 16 Day #13 | Reloading chart. | 2022-04-25 11:08:34.053
USOil[M] 32 Day #13 | Reloading chart. | 2022-04-25 11:08:34.926
USOil[M] 4 Day #13 | Reloading chart. | 2022-04-25 11:08:37.128
USOil[M] 8 Day #13 | Reloading chart. | 2022-04-25 11:08:53.032
USOil[M] 4 Day #13 | Reloading chart. | 2022-04-25 11:08:56.290
AJG-NQTV[M] 8 Day #19 | Reloading chart. | 2022-04-25 11:09:14.845
AJG-NQTV[M] 16 Day #19 | Reloading chart. | 2022-04-25 11:09:16.773
AJG-NQTV[M] 32 Day #19 | Reloading chart. | 2022-04-25 11:09:17.508
AJG-NQTV[M] 64 Day #19 | Reloading chart. | 2022-04-25 11:09:18.205
AJG-NQTV[M] 4 Day #19 | Reloading chart. | 2022-04-25 11:09:19.312
AJG-NQTV[M] 8 Day #19 | Reloading chart. | 2022-04-25 11:09:19.764
AJG-NQTV[M] 4 Day #19 | Reloading chart. | 2022-04-25 11:09:23.659
CL-202206-NYMEX [C][M] 4 Day #3 | Reloading chart. | 2022-04-25 11:09:44.022
CL-202206-NYMEX [C][M] 4 Day #3 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 11:09:44.023
CL-202206-NYMEX [C][M] 4 Day #3 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 11:09:44.023
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200102-NYMEX.dly has a volume of 0 at 2000-12-18. | 2022-04-25 11:09:46.010
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-11-17. | 2022-04-25 11:09:46.014
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-12-15. | 2022-04-25 11:09:46.014
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-10-18. | 2022-04-25 11:09:46.018
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-11-16. | 2022-04-25 11:09:46.018
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-09-18. | 2022-04-25 11:09:46.022
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-10-17. | 2022-04-25 11:09:46.022
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-08-18. | 2022-04-25 11:09:46.026
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-09-15. | 2022-04-25 11:09:46.026
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-07-18. | 2022-04-25 11:09:46.031
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-08-17. | 2022-04-25 11:09:46.031
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-06-16. | 2022-04-25 11:09:46.035
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-07-17. | 2022-04-25 11:09:46.035
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-05-18. | 2022-04-25 11:09:46.039
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-06-15. | 2022-04-25 11:09:46.039
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-04-18. | 2022-04-25 11:09:46.043
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-05-17. | 2022-04-25 11:09:46.043
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-03-17. | 2022-04-25 11:09:46.048
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-04-17. | 2022-04-25 11:09:46.048
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-02-18. | 2022-04-25 11:09:46.052
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-03-16. | 2022-04-25 11:09:46.052
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-01-18. | 2022-04-25 11:09:46.056
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-02-17. | 2022-04-25 11:09:46.056
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200002-NYMEX.dly has a volume of 0 at 1999-12-17. | 2022-04-25 11:09:46.060
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200002-NYMEX.dly has a volume of 0 at 2000-01-17. | 2022-04-25 11:09:46.060
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-11-18. | 2022-04-25 11:09:46.064
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-12-16. | 2022-04-25 11:09:46.064
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-10-18. | 2022-04-25 11:09:46.068
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-11-17. | 2022-04-25 11:09:46.068
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-09-17. | 2022-04-25 11:09:46.073
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-10-15. | 2022-04-25 11:09:46.073
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-08-18. | 2022-04-25 11:09:46.077
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-09-16. | 2022-04-25 11:09:46.077
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-07-16. | 2022-04-25 11:09:46.081
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-08-17. | 2022-04-25 11:09:46.081
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-06-18. | 2022-04-25 11:09:46.085
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-07-15. | 2022-04-25 11:09:46.085
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-05-18. | 2022-04-25 11:09:46.090
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-06-17. | 2022-04-25 11:09:46.090
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-04-16. | 2022-04-25 11:09:46.094
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-05-17. | 2022-04-25 11:09:46.094
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-03-18. | 2022-04-25 11:09:46.098
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-04-15. | 2022-04-25 11:09:46.098
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-02-18. | 2022-04-25 11:09:46.102
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-03-17. | 2022-04-25 11:09:46.102
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-01-18. | 2022-04-25 11:09:46.106
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-02-17. | 2022-04-25 11:09:46.106
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199902-NYMEX.dly has a volume of 0 at 1998-12-18. | 2022-04-25 11:09:46.110
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199902-NYMEX.dly has a volume of 0 at 1999-01-15. | 2022-04-25 11:09:46.110
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-11-18. | 2022-04-25 11:09:46.114
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-12-17. | 2022-04-25 11:09:46.114
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-10-16. | 2022-04-25 11:09:46.119
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-11-17. | 2022-04-25 11:09:46.119
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-09-18. | 2022-04-25 11:09:46.123
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-10-15. | 2022-04-25 11:09:46.123
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-08-18. | 2022-04-25 11:09:46.127
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-09-17. | 2022-04-25 11:09:46.127
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-07-17. | 2022-04-25 11:09:46.131
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-08-17. | 2022-04-25 11:09:46.131
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-06-18. | 2022-04-25 11:09:46.135
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-07-16. | 2022-04-25 11:09:46.135
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-05-18. | 2022-04-25 11:09:46.140
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-06-17. | 2022-04-25 11:09:46.140
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-04-17. | 2022-04-25 11:09:46.144
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-05-15. | 2022-04-25 11:09:46.144
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-03-18. | 2022-04-25 11:09:46.148
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-04-16. | 2022-04-25 11:09:46.148
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-02-18. | 2022-04-25 11:09:46.152
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-03-17. | 2022-04-25 11:09:46.152
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-01-16. | 2022-04-25 11:09:46.156
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-02-17. | 2022-04-25 11:09:46.156
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199802-NYMEX.dly has a volume of 0 at 1997-12-18. | 2022-04-25 11:09:46.160
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199802-NYMEX.dly has a volume of 0 at 1998-01-15. | 2022-04-25 11:09:46.160
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-11-18. | 2022-04-25 11:09:46.164
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-12-17. | 2022-04-25 11:09:46.164
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-10-17. | 2022-04-25 11:09:46.168
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-11-17. | 2022-04-25 11:09:46.168
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-09-18. | 2022-04-25 11:09:46.172
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-10-16. | 2022-04-25 11:09:46.172
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-08-18. | 2022-04-25 11:09:46.177
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-09-17. | 2022-04-25 11:09:46.177
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-07-18. | 2022-04-25 11:09:46.181
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-08-15. | 2022-04-25 11:09:46.181
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-06-18. | 2022-04-25 11:09:46.185
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-07-17. | 2022-04-25 11:09:46.185
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-05-16. | 2022-04-25 11:09:46.189
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-06-17. | 2022-04-25 11:09:46.189
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-04-18. | 2022-04-25 11:09:46.194
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-05-15. | 2022-04-25 11:09:46.194
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-03-18. | 2022-04-25 11:09:46.198
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-04-17. | 2022-04-25 11:09:46.198
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-02-18. | 2022-04-25 11:09:46.202
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-03-17. | 2022-04-25 11:09:46.202
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-01-17. | 2022-04-25 11:09:46.206
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-02-17. | 2022-04-25 11:09:46.206
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199702-NYMEX.dly has a volume of 0 at 1996-12-18. | 2022-04-25 11:09:46.210
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199702-NYMEX.dly has a volume of 0 at 1997-01-16. | 2022-04-25 11:09:46.210
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-11-18. | 2022-04-25 11:09:46.214
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-12-17. | 2022-04-25 11:09:46.214
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-10-18. | 2022-04-25 11:09:46.218
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-11-15. | 2022-04-25 11:09:46.218
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-09-18. | 2022-04-25 11:09:46.223
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-10-17. | 2022-04-25 11:09:46.223
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-08-16. | 2022-04-25 11:09:46.227
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-09-17. | 2022-04-25 11:09:46.227
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-07-18. | 2022-04-25 11:09:46.231
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-08-15. | 2022-04-25 11:09:46.231
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-06-18. | 2022-04-25 11:09:46.235
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-07-17. | 2022-04-25 11:09:46.235
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-05-17. | 2022-04-25 11:09:46.239
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-06-17. | 2022-04-25 11:09:46.239
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-04-18. | 2022-04-25 11:09:46.244
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-05-16. | 2022-04-25 11:09:46.244
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-03-18. | 2022-04-25 11:09:46.248
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-04-17. | 2022-04-25 11:09:46.248
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-02-16. | 2022-04-25 11:09:46.252
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-03-15. | 2022-04-25 11:09:46.252
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-01-18. | 2022-04-25 11:09:46.256
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-02-15. | 2022-04-25 11:09:46.256
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199602-NYMEX.dly has a volume of 0 at 1995-12-18. | 2022-04-25 11:09:46.260
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199602-NYMEX.dly has a volume of 0 at 1996-01-17. | 2022-04-25 11:09:46.260
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-11-17. | 2022-04-25 11:09:46.264
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-12-15. | 2022-04-25 11:09:46.264
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-10-18. | 2022-04-25 11:09:46.268
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-11-16. | 2022-04-25 11:09:46.268
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-09-18. | 2022-04-25 11:09:46.273
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-10-17. | 2022-04-25 11:09:46.273
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-08-18. | 2022-04-25 11:09:46.277
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-09-15. | 2022-04-25 11:09:46.277
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-07-18. | 2022-04-25 11:09:46.281
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-08-17. | 2022-04-25 11:09:46.281
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-06-16. | 2022-04-25 11:09:46.285
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-07-17. | 2022-04-25 11:09:46.285
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-05-18. | 2022-04-25 11:09:46.289
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-06-15. | 2022-04-25 11:09:46.289
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-04-18. | 2022-04-25 11:09:46.294
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-05-17. | 2022-04-25 11:09:46.294
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-03-17. | 2022-04-25 11:09:46.298
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-04-17. | 2022-04-25 11:09:46.298
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-02-17. | 2022-04-25 11:09:46.302
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-03-16. | 2022-04-25 11:09:46.302
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-01-18. | 2022-04-25 11:09:46.306
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-02-16. | 2022-04-25 11:09:46.306
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199502-NYMEX.dly has a volume of 0 at 1994-12-16. | 2022-04-25 11:09:46.310
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199502-NYMEX.dly has a volume of 0 at 1995-01-17. | 2022-04-25 11:09:46.310
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-11-18. | 2022-04-25 11:09:46.314
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-12-15. | 2022-04-25 11:09:46.314
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-10-18. | 2022-04-25 11:09:46.318
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-11-17. | 2022-04-25 11:09:46.318
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-09-16. | 2022-04-25 11:09:46.322
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-10-17. | 2022-04-25 11:09:46.322
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-08-18. | 2022-04-25 11:09:46.326
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-09-15. | 2022-04-25 11:09:46.326
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-07-18. | 2022-04-25 11:09:46.331
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-08-17. | 2022-04-25 11:09:46.331
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-06-17. | 2022-04-25 11:09:46.335
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-07-15. | 2022-04-25 11:09:46.335
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-05-18. | 2022-04-25 11:09:46.339
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-06-16. | 2022-04-25 11:09:46.339
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-04-18. | 2022-04-25 11:09:46.343
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-05-17. | 2022-04-25 11:09:46.343
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-03-18. | 2022-04-25 11:09:46.347
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-04-15. | 2022-04-25 11:09:46.347
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-02-18. | 2022-04-25 11:09:46.351
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-03-17. | 2022-04-25 11:09:46.351
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-01-18. | 2022-04-25 11:09:46.356
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-02-17. | 2022-04-25 11:09:46.356
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199402-NYMEX.dly has a volume of 0 at 1993-12-17. | 2022-04-25 11:09:46.360
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199402-NYMEX.dly has a volume of 0 at 1994-01-17. | 2022-04-25 11:09:46.360
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-11-18. | 2022-04-25 11:09:46.364
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-12-16. | 2022-04-25 11:09:46.364
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-10-18. | 2022-04-25 11:09:46.368
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-11-17. | 2022-04-25 11:09:46.368
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-09-17. | 2022-04-25 11:09:46.372
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-10-15. | 2022-04-25 11:09:46.372
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-08-18. | 2022-04-25 11:09:46.376
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-09-16. | 2022-04-25 11:09:46.376
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-07-16. | 2022-04-25 11:09:46.381
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-08-17. | 2022-04-25 11:09:46.381
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-06-18. | 2022-04-25 11:09:46.385
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-07-15. | 2022-04-25 11:09:46.385
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-05-18. | 2022-04-25 11:09:46.389
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-06-17. | 2022-04-25 11:09:46.389
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-04-16. | 2022-04-25 11:09:46.393
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-05-17. | 2022-04-25 11:09:46.393
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-03-18. | 2022-04-25 11:09:46.397
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-04-15. | 2022-04-25 11:09:46.397
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-02-18. | 2022-04-25 11:09:46.401
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-03-17. | 2022-04-25 11:09:46.401
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-01-18. | 2022-04-25 11:09:46.406
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-02-17. | 2022-04-25 11:09:46.406
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199302-NYMEX.dly has a volume of 0 at 1992-12-18. | 2022-04-25 11:09:46.410
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199302-NYMEX.dly has a volume of 0 at 1993-01-15. | 2022-04-25 11:09:46.410
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-11-18. | 2022-04-25 11:09:46.414
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-12-17. | 2022-04-25 11:09:46.414
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-10-16. | 2022-04-25 11:09:46.418
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-11-17. | 2022-04-25 11:09:46.418
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-09-18. | 2022-04-25 11:09:46.422
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-10-15. | 2022-04-25 11:09:46.422
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-08-18. | 2022-04-25 11:09:46.427
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-09-17. | 2022-04-25 11:09:46.427
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-07-17. | 2022-04-25 11:09:46.431
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-08-17. | 2022-04-25 11:09:46.431
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-06-18. | 2022-04-25 11:09:46.435
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-07-16. | 2022-04-25 11:09:46.435
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-05-18. | 2022-04-25 11:09:46.439
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-06-17. | 2022-04-25 11:09:46.439
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-04-17. | 2022-04-25 11:09:46.444
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-05-15. | 2022-04-25 11:09:46.444
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-03-18. | 2022-04-25 11:09:46.448
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-04-16. | 2022-04-25 11:09:46.448
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-02-18. | 2022-04-25 11:09:46.452
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-03-17. | 2022-04-25 11:09:46.452
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-01-17. | 2022-04-25 11:09:46.456
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-02-17. | 2022-04-25 11:09:46.456
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199202-NYMEX.dly has a volume of 0 at 1991-12-18. | 2022-04-25 11:09:46.460
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199202-NYMEX.dly has a volume of 0 at 1992-01-16. | 2022-04-25 11:09:46.460
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-11-18. | 2022-04-25 11:09:46.464
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-12-17. | 2022-04-25 11:09:46.464
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-10-18. | 2022-04-25 11:09:46.468
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-11-15. | 2022-04-25 11:09:46.468
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-09-18. | 2022-04-25 11:09:46.473
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-10-17. | 2022-04-25 11:09:46.473
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-08-16. | 2022-04-25 11:09:46.477
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-09-17. | 2022-04-25 11:09:46.477
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-07-18. | 2022-04-25 11:09:46.481
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-08-15. | 2022-04-25 11:09:46.481
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-06-18. | 2022-04-25 11:09:46.485
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-07-17. | 2022-04-25 11:09:46.485
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-05-17. | 2022-04-25 11:09:46.489
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-06-17. | 2022-04-25 11:09:46.489
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-04-18. | 2022-04-25 11:09:46.493
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-05-16. | 2022-04-25 11:09:46.493
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-03-18. | 2022-04-25 11:09:46.498
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-04-17. | 2022-04-25 11:09:46.498
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-02-18. | 2022-04-25 11:09:46.502
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-03-15. | 2022-04-25 11:09:46.502
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-01-18. | 2022-04-25 11:09:46.506
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-02-15. | 2022-04-25 11:09:46.506
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199102-NYMEX.dly has a volume of 0 at 1990-12-18. | 2022-04-25 11:09:46.510
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199102-NYMEX.dly has a volume of 0 at 1991-01-17. | 2022-04-25 11:09:46.510
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-11-16. | 2022-04-25 11:09:46.514
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-12-17. | 2022-04-25 11:09:46.514
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-10-18. | 2022-04-25 11:09:46.518
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-11-15. | 2022-04-25 11:09:46.518
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-09-18. | 2022-04-25 11:09:46.522
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-10-17. | 2022-04-25 11:09:46.522
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-08-17. | 2022-04-25 11:09:46.526
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-09-17. | 2022-04-25 11:09:46.526
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-07-18. | 2022-04-25 11:09:46.531
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-08-16. | 2022-04-25 11:09:46.531
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-06-18. | 2022-04-25 11:09:46.535
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-07-17. | 2022-04-25 11:09:46.535
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-05-18. | 2022-04-25 11:09:46.539
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-06-15. | 2022-04-25 11:09:46.539
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-04-18. | 2022-04-25 11:09:46.543
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-05-17. | 2022-04-25 11:09:46.543
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-03-16. | 2022-04-25 11:09:46.547
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-04-17. | 2022-04-25 11:09:46.547
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-02-16. | 2022-04-25 11:09:46.551
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-03-15. | 2022-04-25 11:09:46.551
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-01-18. | 2022-04-25 11:09:46.555
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-02-15. | 2022-04-25 11:09:46.555
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199002-NYMEX.dly has a volume of 0 at 1989-12-18. | 2022-04-25 11:09:46.560
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199002-NYMEX.dly has a volume of 0 at 1990-01-17. | 2022-04-25 11:09:46.560
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-11-17. | 2022-04-25 11:09:46.564
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-12-15. | 2022-04-25 11:09:46.564
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-10-18. | 2022-04-25 11:09:46.568
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-11-16. | 2022-04-25 11:09:46.568
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-09-18. | 2022-04-25 11:09:46.573
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-10-17. | 2022-04-25 11:09:46.573
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-08-18. | 2022-04-25 11:09:46.577
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-09-15. | 2022-04-25 11:09:46.577
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-07-18. | 2022-04-25 11:09:46.581
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-08-17. | 2022-04-25 11:09:46.581
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-06-16. | 2022-04-25 11:09:46.586
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-07-17. | 2022-04-25 11:09:46.586
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-05-18. | 2022-04-25 11:09:46.590
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-06-15. | 2022-04-25 11:09:46.590
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-04-18. | 2022-04-25 11:09:46.594
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-05-17. | 2022-04-25 11:09:46.594
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-03-17. | 2022-04-25 11:09:46.598
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-04-17. | 2022-04-25 11:09:46.598
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-02-17. | 2022-04-25 11:09:46.602
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-03-16. | 2022-04-25 11:09:46.602
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-01-18. | 2022-04-25 11:09:46.607
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-02-16. | 2022-04-25 11:09:46.607
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198902-NYMEX.dly has a volume of 0 at 1988-12-16. | 2022-04-25 11:09:46.611
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198902-NYMEX.dly has a volume of 0 at 1989-01-17. | 2022-04-25 11:09:46.611
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-11-18. | 2022-04-25 11:09:46.615
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-12-15. | 2022-04-25 11:09:46.615
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-10-18. | 2022-04-25 11:09:46.619
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-11-17. | 2022-04-25 11:09:46.619
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-09-16. | 2022-04-25 11:09:46.623
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-10-17. | 2022-04-25 11:09:46.623
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-08-18. | 2022-04-25 11:09:46.628
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-09-15. | 2022-04-25 11:09:46.628
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-07-18. | 2022-04-25 11:09:46.632
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-08-17. | 2022-04-25 11:09:46.632
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-06-17. | 2022-04-25 11:09:46.636
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-07-15. | 2022-04-25 11:09:46.636
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-05-18. | 2022-04-25 11:09:46.641
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-06-16. | 2022-04-25 11:09:46.641
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-04-18. | 2022-04-25 11:09:46.645
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-05-17. | 2022-04-25 11:09:46.645
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-03-18. | 2022-04-25 11:09:46.649
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-04-15. | 2022-04-25 11:09:46.649
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-02-18. | 2022-04-25 11:09:46.653
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-03-17. | 2022-04-25 11:09:46.653
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-01-18. | 2022-04-25 11:09:46.658
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-02-17. | 2022-04-25 11:09:46.658
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198802-NYMEX.dly has a volume of 0 at 1987-12-18. | 2022-04-25 11:09:46.662
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198802-NYMEX.dly has a volume of 0 at 1988-01-15. | 2022-04-25 11:09:46.662
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-11-18. | 2022-04-25 11:09:46.666
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-12-17. | 2022-04-25 11:09:46.666
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-10-16. | 2022-04-25 11:09:46.670
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-11-17. | 2022-04-25 11:09:46.670
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-09-18. | 2022-04-25 11:09:46.674
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-10-15. | 2022-04-25 11:09:46.674
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-08-18. | 2022-04-25 11:09:46.679
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-09-17. | 2022-04-25 11:09:46.679
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-07-17. | 2022-04-25 11:09:46.683
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-08-17. | 2022-04-25 11:09:46.683
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-06-18. | 2022-04-25 11:09:46.687
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-07-16. | 2022-04-25 11:09:46.687
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-05-18. | 2022-04-25 11:09:46.691
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-06-17. | 2022-04-25 11:09:46.691
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-04-17. | 2022-04-25 11:09:46.695
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-05-15. | 2022-04-25 11:09:46.695
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-03-18. | 2022-04-25 11:09:46.700
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-04-16. | 2022-04-25 11:09:46.700
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-02-18. | 2022-04-25 11:09:46.704
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-03-17. | 2022-04-25 11:09:46.704
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-01-16. | 2022-04-25 11:09:46.708
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-02-17. | 2022-04-25 11:09:46.708
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198702-NYMEX.dly has a volume of 0 at 1986-12-18. | 2022-04-25 11:09:46.712
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198702-NYMEX.dly has a volume of 0 at 1987-01-15. | 2022-04-25 11:09:46.712
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-11-18. | 2022-04-25 11:09:46.716
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-12-17. | 2022-04-25 11:09:46.716
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-10-17. | 2022-04-25 11:09:46.721
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-11-17. | 2022-04-25 11:09:46.721
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-09-18. | 2022-04-25 11:09:46.725
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-10-16. | 2022-04-25 11:09:46.725
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-08-18. | 2022-04-25 11:09:46.729
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-09-17. | 2022-04-25 11:09:46.729
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-07-18. | 2022-04-25 11:09:46.733
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-08-15. | 2022-04-25 11:09:46.733
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-06-18. | 2022-04-25 11:09:46.737
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-07-17. | 2022-04-25 11:09:46.737
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-05-16. | 2022-04-25 11:09:46.742
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-06-17. | 2022-04-25 11:09:46.742
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-04-18. | 2022-04-25 11:09:46.745
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-05-15. | 2022-04-25 11:09:46.745
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-03-18. | 2022-04-25 11:09:46.750
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-04-17. | 2022-04-25 11:09:46.750
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-02-18. | 2022-04-25 11:09:46.754
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-03-17. | 2022-04-25 11:09:46.754
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-01-17. | 2022-04-25 11:09:46.758
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-02-17. | 2022-04-25 11:09:46.758
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198602-NYMEX.dly has a volume of 0 at 1985-12-18. | 2022-04-25 11:09:46.762
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198602-NYMEX.dly has a volume of 0 at 1986-01-16. | 2022-04-25 11:09:46.762
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-11-18. | 2022-04-25 11:09:46.766
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-12-17. | 2022-04-25 11:09:46.766
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-10-18. | 2022-04-25 11:09:46.770
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-11-15. | 2022-04-25 11:09:46.770
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-09-18. | 2022-04-25 11:09:46.775
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-10-17. | 2022-04-25 11:09:46.775
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-08-16. | 2022-04-25 11:09:46.779
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-09-17. | 2022-04-25 11:09:46.779
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-07-18. | 2022-04-25 11:09:46.783
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-08-15. | 2022-04-25 11:09:46.783
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-06-18. | 2022-04-25 11:09:46.788
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-07-17. | 2022-04-25 11:09:46.788
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-05-17. | 2022-04-25 11:09:46.792
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-06-17. | 2022-04-25 11:09:46.792
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-04-18. | 2022-04-25 11:09:46.796
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-05-16. | 2022-04-25 11:09:46.796
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-03-18. | 2022-04-25 11:09:46.800
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-04-17. | 2022-04-25 11:09:46.800
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-02-18. | 2022-04-25 11:09:46.805
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-03-15. | 2022-04-25 11:09:46.805
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-01-18. | 2022-04-25 11:09:46.809
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-02-15. | 2022-04-25 11:09:46.809
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198502-NYMEX.dly has a volume of 0 at 1984-12-18. | 2022-04-25 11:09:46.812
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198502-NYMEX.dly has a volume of 0 at 1985-01-17. | 2022-04-25 11:09:46.812
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-11-16. | 2022-04-25 11:09:46.816
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-12-17. | 2022-04-25 11:09:46.816
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-10-18. | 2022-04-25 11:09:46.819
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-11-15. | 2022-04-25 11:09:46.819
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-09-18. | 2022-04-25 11:09:46.823
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-10-17. | 2022-04-25 11:09:46.823
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-08-17. | 2022-04-25 11:09:46.828
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-09-17. | 2022-04-25 11:09:46.828
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-07-18. | 2022-04-25 11:09:46.832
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-08-16. | 2022-04-25 11:09:46.832
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-06-18. | 2022-04-25 11:09:46.836
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-07-17. | 2022-04-25 11:09:46.836
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-05-18. | 2022-04-25 11:09:46.840
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-06-15. | 2022-04-25 11:09:46.840
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-04-18. | 2022-04-25 11:09:46.844
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-05-17. | 2022-04-25 11:09:46.844
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-03-16. | 2022-04-25 11:09:46.848
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-04-17. | 2022-04-25 11:09:46.848
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-02-17. | 2022-04-25 11:09:46.851
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-03-15. | 2022-04-25 11:09:46.851
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-01-18. | 2022-04-25 11:09:46.856
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-02-16. | 2022-04-25 11:09:46.856
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198402-NYMEX.dly has a volume of 0 at 1983-12-16. | 2022-04-25 11:09:46.860
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198402-NYMEX.dly has a volume of 0 at 1984-01-17. | 2022-04-25 11:09:46.860
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-11-18. | 2022-04-25 11:09:46.863
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-12-15. | 2022-04-25 11:09:46.863
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-10-18. | 2022-04-25 11:09:46.867
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-11-17. | 2022-04-25 11:09:46.867
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-09-16. | 2022-04-25 11:09:46.871
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-10-17. | 2022-04-25 11:09:46.871
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-08-18. | 2022-04-25 11:09:46.875
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-09-15. | 2022-04-25 11:09:46.875
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-07-18. | 2022-04-25 11:09:46.880
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-08-17. | 2022-04-25 11:09:46.880
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-06-17. | 2022-04-25 11:09:46.884
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-07-15. | 2022-04-25 11:09:46.884
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-05-18. | 2022-04-25 11:09:46.888
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-06-16. | 2022-04-25 11:09:46.888
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-04-18. | 2022-04-25 11:09:46.892
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-05-17. | 2022-04-25 11:09:46.892
CL-202206-NYMEX [C][M] 16 Day #10 | Reloading chart. | 2022-04-25 11:09:50.055
CL-202206-NYMEX [C][M] 16 Day #10 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 11:09:50.055
CL-202206-NYMEX [C][M] 16 Day #10 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 11:09:50.055
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200102-NYMEX.dly has a volume of 0 at 2000-12-18. | 2022-04-25 11:09:51.737
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-11-17. | 2022-04-25 11:09:51.741
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-12-15. | 2022-04-25 11:09:51.741
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-10-18. | 2022-04-25 11:09:51.745
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-11-16. | 2022-04-25 11:09:51.745
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-09-18. | 2022-04-25 11:09:51.749
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-10-17. | 2022-04-25 11:09:51.749
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-08-18. | 2022-04-25 11:09:51.753
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-09-15. | 2022-04-25 11:09:51.753
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-07-18. | 2022-04-25 11:09:51.758
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-08-17. | 2022-04-25 11:09:51.758
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-06-16. | 2022-04-25 11:09:51.762
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-07-17. | 2022-04-25 11:09:51.762
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-05-18. | 2022-04-25 11:09:51.766
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-06-15. | 2022-04-25 11:09:51.766
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-04-18. | 2022-04-25 11:09:51.770
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-05-17. | 2022-04-25 11:09:51.770
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-03-17. | 2022-04-25 11:09:51.775
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-04-17. | 2022-04-25 11:09:51.775
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-02-18. | 2022-04-25 11:09:51.779
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-03-16. | 2022-04-25 11:09:51.779
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-01-18. | 2022-04-25 11:09:51.783
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-02-17. | 2022-04-25 11:09:51.783
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200002-NYMEX.dly has a volume of 0 at 1999-12-17. | 2022-04-25 11:09:51.787
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200002-NYMEX.dly has a volume of 0 at 2000-01-17. | 2022-04-25 11:09:51.787
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-11-18. | 2022-04-25 11:09:51.791
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-12-16. | 2022-04-25 11:09:51.791
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-10-18. | 2022-04-25 11:09:51.795
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-11-17. | 2022-04-25 11:09:51.795
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-09-17. | 2022-04-25 11:09:51.800
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-10-15. | 2022-04-25 11:09:51.800
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-08-18. | 2022-04-25 11:09:51.804
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-09-16. | 2022-04-25 11:09:51.804
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-07-16. | 2022-04-25 11:09:51.809
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-08-17. | 2022-04-25 11:09:51.809
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-06-18. | 2022-04-25 11:09:51.813
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-07-15. | 2022-04-25 11:09:51.813
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-05-18. | 2022-04-25 11:09:51.817
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-06-17. | 2022-04-25 11:09:51.817
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-04-16. | 2022-04-25 11:09:51.821
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-05-17. | 2022-04-25 11:09:51.821
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-03-18. | 2022-04-25 11:09:51.825
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-04-15. | 2022-04-25 11:09:51.825
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-02-18. | 2022-04-25 11:09:51.829
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-03-17. | 2022-04-25 11:09:51.829
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-01-18. | 2022-04-25 11:09:51.834
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-02-17. | 2022-04-25 11:09:51.834
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199902-NYMEX.dly has a volume of 0 at 1998-12-18. | 2022-04-25 11:09:51.838
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199902-NYMEX.dly has a volume of 0 at 1999-01-15. | 2022-04-25 11:09:51.838
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-11-18. | 2022-04-25 11:09:51.842
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-12-17. | 2022-04-25 11:09:51.842
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-10-16. | 2022-04-25 11:09:51.846
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-11-17. | 2022-04-25 11:09:51.846
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-09-18. | 2022-04-25 11:09:51.850
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-10-15. | 2022-04-25 11:09:51.850
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-08-18. | 2022-04-25 11:09:51.855
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-09-17. | 2022-04-25 11:09:51.855
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-07-17. | 2022-04-25 11:09:51.859
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-08-17. | 2022-04-25 11:09:51.859
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-06-18. | 2022-04-25 11:09:51.863
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-07-16. | 2022-04-25 11:09:51.863
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-05-18. | 2022-04-25 11:09:51.867
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-06-17. | 2022-04-25 11:09:51.867
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-04-17. | 2022-04-25 11:09:51.871
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-05-15. | 2022-04-25 11:09:51.871
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-03-18. | 2022-04-25 11:09:51.876
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-04-16. | 2022-04-25 11:09:51.876
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-02-18. | 2022-04-25 11:09:51.880
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-03-17. | 2022-04-25 11:09:51.880
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-01-16. | 2022-04-25 11:09:51.884
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-02-17. | 2022-04-25 11:09:51.884
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199802-NYMEX.dly has a volume of 0 at 1997-12-18. | 2022-04-25 11:09:51.888
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199802-NYMEX.dly has a volume of 0 at 1998-01-15. | 2022-04-25 11:09:51.888
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-11-18. | 2022-04-25 11:09:51.892
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-12-17. | 2022-04-25 11:09:51.892
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-10-17. | 2022-04-25 11:09:51.896
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-11-17. | 2022-04-25 11:09:51.896
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-09-18. | 2022-04-25 11:09:51.900
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-10-16. | 2022-04-25 11:09:51.900
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-08-18. | 2022-04-25 11:09:51.904
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-09-17. | 2022-04-25 11:09:51.904
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-07-18. | 2022-04-25 11:09:51.909
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-08-15. | 2022-04-25 11:09:51.909
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-06-18. | 2022-04-25 11:09:51.913
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-07-17. | 2022-04-25 11:09:51.913
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-05-16. | 2022-04-25 11:09:51.917
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-06-17. | 2022-04-25 11:09:51.917
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-04-18. | 2022-04-25 11:09:51.921
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-05-15. | 2022-04-25 11:09:51.921
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-03-18. | 2022-04-25 11:09:51.925
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-04-17. | 2022-04-25 11:09:51.925
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-02-18. | 2022-04-25 11:09:51.929
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-03-17. | 2022-04-25 11:09:51.929
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-01-17. | 2022-04-25 11:09:51.934
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-02-17. | 2022-04-25 11:09:51.934
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199702-NYMEX.dly has a volume of 0 at 1996-12-18. | 2022-04-25 11:09:51.938
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199702-NYMEX.dly has a volume of 0 at 1997-01-16. | 2022-04-25 11:09:51.938
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-11-18. | 2022-04-25 11:09:51.942
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-12-17. | 2022-04-25 11:09:51.942
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-10-18. | 2022-04-25 11:09:51.946
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-11-15. | 2022-04-25 11:09:51.946
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-09-18. | 2022-04-25 11:09:51.950
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-10-17. | 2022-04-25 11:09:51.950
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-08-16. | 2022-04-25 11:09:51.954
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-09-17. | 2022-04-25 11:09:51.954
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-07-18. | 2022-04-25 11:09:51.959
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-08-15. | 2022-04-25 11:09:51.959
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-06-18. | 2022-04-25 11:09:51.963
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-07-17. | 2022-04-25 11:09:51.963
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-05-17. | 2022-04-25 11:09:51.967
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-06-17. | 2022-04-25 11:09:51.967
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-04-18. | 2022-04-25 11:09:51.972
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-05-16. | 2022-04-25 11:09:51.972
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-03-18. | 2022-04-25 11:09:51.976
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-04-17. | 2022-04-25 11:09:51.976
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-02-16. | 2022-04-25 11:09:51.980
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-03-15. | 2022-04-25 11:09:51.980
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-01-18. | 2022-04-25 11:09:51.984
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-02-15. | 2022-04-25 11:09:51.984
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199602-NYMEX.dly has a volume of 0 at 1995-12-18. | 2022-04-25 11:09:51.989
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199602-NYMEX.dly has a volume of 0 at 1996-01-17. | 2022-04-25 11:09:51.989
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-11-17. | 2022-04-25 11:09:51.992
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-12-15. | 2022-04-25 11:09:51.992
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-10-18. | 2022-04-25 11:09:51.997
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-11-16. | 2022-04-25 11:09:51.997
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-09-18. | 2022-04-25 11:09:52.001
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-10-17. | 2022-04-25 11:09:52.001
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-08-18. | 2022-04-25 11:09:52.005
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-09-15. | 2022-04-25 11:09:52.005
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-07-18. | 2022-04-25 11:09:52.009
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-08-17. | 2022-04-25 11:09:52.009
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-06-16. | 2022-04-25 11:09:52.014
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-07-17. | 2022-04-25 11:09:52.014
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-05-18. | 2022-04-25 11:09:52.018
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-06-15. | 2022-04-25 11:09:52.018
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-04-18. | 2022-04-25 11:09:52.022
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-05-17. | 2022-04-25 11:09:52.022
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-03-17. | 2022-04-25 11:09:52.026
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-04-17. | 2022-04-25 11:09:52.026
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-02-17. | 2022-04-25 11:09:52.030
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-03-16. | 2022-04-25 11:09:52.030
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-01-18. | 2022-04-25 11:09:52.034
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-02-16. | 2022-04-25 11:09:52.034
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199502-NYMEX.dly has a volume of 0 at 1994-12-16. | 2022-04-25 11:09:52.038
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199502-NYMEX.dly has a volume of 0 at 1995-01-17. | 2022-04-25 11:09:52.038
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-11-18. | 2022-04-25 11:09:52.042
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-12-15. | 2022-04-25 11:09:52.042
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-10-18. | 2022-04-25 11:09:52.046
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-11-17. | 2022-04-25 11:09:52.046
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-09-16. | 2022-04-25 11:09:52.051
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-10-17. | 2022-04-25 11:09:52.051
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-08-18. | 2022-04-25 11:09:52.055
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-09-15. | 2022-04-25 11:09:52.055
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-07-18. | 2022-04-25 11:09:52.059
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-08-17. | 2022-04-25 11:09:52.059
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-06-17. | 2022-04-25 11:09:52.063
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-07-15. | 2022-04-25 11:09:52.063
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-05-18. | 2022-04-25 11:09:52.067
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-06-16. | 2022-04-25 11:09:52.067
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-04-18. | 2022-04-25 11:09:52.072
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-05-17. | 2022-04-25 11:09:52.072
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-03-18. | 2022-04-25 11:09:52.076
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-04-15. | 2022-04-25 11:09:52.076
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-02-18. | 2022-04-25 11:09:52.080
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-03-17. | 2022-04-25 11:09:52.080
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-01-18. | 2022-04-25 11:09:52.084
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-02-17. | 2022-04-25 11:09:52.084
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199402-NYMEX.dly has a volume of 0 at 1993-12-17. | 2022-04-25 11:09:52.088
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199402-NYMEX.dly has a volume of 0 at 1994-01-17. | 2022-04-25 11:09:52.088
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-11-18. | 2022-04-25 11:09:52.092
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-12-16. | 2022-04-25 11:09:52.092
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-10-18. | 2022-04-25 11:09:52.096
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-11-17. | 2022-04-25 11:09:52.096
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-09-17. | 2022-04-25 11:09:52.100
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-10-15. | 2022-04-25 11:09:52.100
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-08-18. | 2022-04-25 11:09:52.104
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-09-16. | 2022-04-25 11:09:52.104
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-07-16. | 2022-04-25 11:09:52.109
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-08-17. | 2022-04-25 11:09:52.109
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-06-18. | 2022-04-25 11:09:52.113
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-07-15. | 2022-04-25 11:09:52.113
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-05-18. | 2022-04-25 11:09:52.117
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-06-17. | 2022-04-25 11:09:52.117
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-04-16. | 2022-04-25 11:09:52.122
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-05-17. | 2022-04-25 11:09:52.122
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-03-18. | 2022-04-25 11:09:52.126
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-04-15. | 2022-04-25 11:09:52.126
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-02-18. | 2022-04-25 11:09:52.130
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-03-17. | 2022-04-25 11:09:52.130
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-01-18. | 2022-04-25 11:09:52.134
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-02-17. | 2022-04-25 11:09:52.134
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199302-NYMEX.dly has a volume of 0 at 1992-12-18. | 2022-04-25 11:09:52.138
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199302-NYMEX.dly has a volume of 0 at 1993-01-15. | 2022-04-25 11:09:52.138
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-11-18. | 2022-04-25 11:09:52.142
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-12-17. | 2022-04-25 11:09:52.142
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-10-16. | 2022-04-25 11:09:52.147
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-11-17. | 2022-04-25 11:09:52.147
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-09-18. | 2022-04-25 11:09:52.151
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-10-15. | 2022-04-25 11:09:52.151
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-08-18. | 2022-04-25 11:09:52.156
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-09-17. | 2022-04-25 11:09:52.156
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-07-17. | 2022-04-25 11:09:52.160
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-08-17. | 2022-04-25 11:09:52.160
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-06-18. | 2022-04-25 11:09:52.164
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-07-16. | 2022-04-25 11:09:52.164
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-05-18. | 2022-04-25 11:09:52.168
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-06-17. | 2022-04-25 11:09:52.168
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-04-17. | 2022-04-25 11:09:52.172
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-05-15. | 2022-04-25 11:09:52.172
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-03-18. | 2022-04-25 11:09:52.176
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-04-16. | 2022-04-25 11:09:52.176
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-02-18. | 2022-04-25 11:09:52.180
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-03-17. | 2022-04-25 11:09:52.180
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-01-17. | 2022-04-25 11:09:52.185
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-02-17. | 2022-04-25 11:09:52.185
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199202-NYMEX.dly has a volume of 0 at 1991-12-18. | 2022-04-25 11:09:52.189
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199202-NYMEX.dly has a volume of 0 at 1992-01-16. | 2022-04-25 11:09:52.189
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-11-18. | 2022-04-25 11:09:52.193
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-12-17. | 2022-04-25 11:09:52.193
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-10-18. | 2022-04-25 11:09:52.197
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-11-15. | 2022-04-25 11:09:52.197
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-09-18. | 2022-04-25 11:09:52.201
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-10-17. | 2022-04-25 11:09:52.201
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-08-16. | 2022-04-25 11:09:52.206
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-09-17. | 2022-04-25 11:09:52.206
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-07-18. | 2022-04-25 11:09:52.210
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-08-15. | 2022-04-25 11:09:52.210
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-06-18. | 2022-04-25 11:09:52.214
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-07-17. | 2022-04-25 11:09:52.214
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-05-17. | 2022-04-25 11:09:52.218
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-06-17. | 2022-04-25 11:09:52.218
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-04-18. | 2022-04-25 11:09:52.222
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-05-16. | 2022-04-25 11:09:52.222
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-03-18. | 2022-04-25 11:09:52.227
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-04-17. | 2022-04-25 11:09:52.227
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-02-18. | 2022-04-25 11:09:52.231
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-03-15. | 2022-04-25 11:09:52.231
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-01-18. | 2022-04-25 11:09:52.235
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-02-15. | 2022-04-25 11:09:52.235
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199102-NYMEX.dly has a volume of 0 at 1990-12-18. | 2022-04-25 11:09:52.239
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199102-NYMEX.dly has a volume of 0 at 1991-01-17. | 2022-04-25 11:09:52.239
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-11-16. | 2022-04-25 11:09:52.243
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-12-17. | 2022-04-25 11:09:52.243
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-10-18. | 2022-04-25 11:09:52.247
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-11-15. | 2022-04-25 11:09:52.247
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-09-18. | 2022-04-25 11:09:52.251
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-10-17. | 2022-04-25 11:09:52.251
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-08-17. | 2022-04-25 11:09:52.255
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-09-17. | 2022-04-25 11:09:52.255
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-07-18. | 2022-04-25 11:09:52.260
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-08-16. | 2022-04-25 11:09:52.260
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-06-18. | 2022-04-25 11:09:52.264
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-07-17. | 2022-04-25 11:09:52.264
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-05-18. | 2022-04-25 11:09:52.268
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-06-15. | 2022-04-25 11:09:52.268
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-04-18. | 2022-04-25 11:09:52.272
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-05-17. | 2022-04-25 11:09:52.272
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-03-16. | 2022-04-25 11:09:52.276
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-04-17. | 2022-04-25 11:09:52.276
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-02-16. | 2022-04-25 11:09:52.280
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-03-15. | 2022-04-25 11:09:52.280
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-01-18. | 2022-04-25 11:09:52.284
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-02-15. | 2022-04-25 11:09:52.284
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199002-NYMEX.dly has a volume of 0 at 1989-12-18. | 2022-04-25 11:09:52.288
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199002-NYMEX.dly has a volume of 0 at 1990-01-17. | 2022-04-25 11:09:52.288
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-11-17. | 2022-04-25 11:09:52.293
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-12-15. | 2022-04-25 11:09:52.293
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-10-18. | 2022-04-25 11:09:52.297
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-11-16. | 2022-04-25 11:09:52.297
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-09-18. | 2022-04-25 11:09:52.301
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-10-17. | 2022-04-25 11:09:52.301
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-08-18. | 2022-04-25 11:09:52.305
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-09-15. | 2022-04-25 11:09:52.305
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-07-18. | 2022-04-25 11:09:52.310
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-08-17. | 2022-04-25 11:09:52.310
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-06-16. | 2022-04-25 11:09:52.314
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-07-17. | 2022-04-25 11:09:52.314
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-05-18. | 2022-04-25 11:09:52.318
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-06-15. | 2022-04-25 11:09:52.318
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-04-18. | 2022-04-25 11:09:52.322
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-05-17. | 2022-04-25 11:09:52.322
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-03-17. | 2022-04-25 11:09:52.326
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-04-17. | 2022-04-25 11:09:52.326
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-02-17. | 2022-04-25 11:09:52.330
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-03-16. | 2022-04-25 11:09:52.330
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-01-18. | 2022-04-25 11:09:52.334
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-02-16. | 2022-04-25 11:09:52.334
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198902-NYMEX.dly has a volume of 0 at 1988-12-16. | 2022-04-25 11:09:52.338
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198902-NYMEX.dly has a volume of 0 at 1989-01-17. | 2022-04-25 11:09:52.338
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-11-18. | 2022-04-25 11:09:52.342
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-12-15. | 2022-04-25 11:09:52.342
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-10-18. | 2022-04-25 11:09:52.347
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-11-17. | 2022-04-25 11:09:52.347
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-09-16. | 2022-04-25 11:09:52.351
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-10-17. | 2022-04-25 11:09:52.351
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-08-18. | 2022-04-25 11:09:52.355
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-09-15. | 2022-04-25 11:09:52.355
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-07-18. | 2022-04-25 11:09:52.359
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-08-17. | 2022-04-25 11:09:52.359
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-06-17. | 2022-04-25 11:09:52.363
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-07-15. | 2022-04-25 11:09:52.363
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-05-18. | 2022-04-25 11:09:52.368
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-06-16. | 2022-04-25 11:09:52.368
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-04-18. | 2022-04-25 11:09:52.372
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-05-17. | 2022-04-25 11:09:52.372
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-03-18. | 2022-04-25 11:09:52.376
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-04-15. | 2022-04-25 11:09:52.376
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-02-18. | 2022-04-25 11:09:52.380
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-03-17. | 2022-04-25 11:09:52.380
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-01-18. | 2022-04-25 11:09:52.384
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-02-17. | 2022-04-25 11:09:52.384
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198802-NYMEX.dly has a volume of 0 at 1987-12-18. | 2022-04-25 11:09:52.388
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198802-NYMEX.dly has a volume of 0 at 1988-01-15. | 2022-04-25 11:09:52.388
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-11-18. | 2022-04-25 11:09:52.392
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-12-17. | 2022-04-25 11:09:52.392
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-10-16. | 2022-04-25 11:09:52.397
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-11-17. | 2022-04-25 11:09:52.397
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-09-18. | 2022-04-25 11:09:52.401
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-10-15. | 2022-04-25 11:09:52.401
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-08-18. | 2022-04-25 11:09:52.405
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-09-17. | 2022-04-25 11:09:52.405
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-07-17. | 2022-04-25 11:09:52.409
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-08-17. | 2022-04-25 11:09:52.409
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-06-18. | 2022-04-25 11:09:52.413
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-07-16. | 2022-04-25 11:09:52.413
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-05-18. | 2022-04-25 11:09:52.418
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-06-17. | 2022-04-25 11:09:52.418
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-04-17. | 2022-04-25 11:09:52.422
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-05-15. | 2022-04-25 11:09:52.422
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-03-18. | 2022-04-25 11:09:52.426
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-04-16. | 2022-04-25 11:09:52.426
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-02-18. | 2022-04-25 11:09:52.430
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-03-17. | 2022-04-25 11:09:52.430
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-01-16. | 2022-04-25 11:09:52.434
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-02-17. | 2022-04-25 11:09:52.434
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198702-NYMEX.dly has a volume of 0 at 1986-12-18. | 2022-04-25 11:09:52.438
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198702-NYMEX.dly has a volume of 0 at 1987-01-15. | 2022-04-25 11:09:52.438
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-11-18. | 2022-04-25 11:09:52.442
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-12-17. | 2022-04-25 11:09:52.442
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-10-17. | 2022-04-25 11:09:52.446
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-11-17. | 2022-04-25 11:09:52.446
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-09-18. | 2022-04-25 11:09:52.451
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-10-16. | 2022-04-25 11:09:52.451
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-08-18. | 2022-04-25 11:09:52.455
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-09-17. | 2022-04-25 11:09:52.455
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-07-18. | 2022-04-25 11:09:52.459
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-08-15. | 2022-04-25 11:09:52.459
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-06-18. | 2022-04-25 11:09:52.463
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-07-17. | 2022-04-25 11:09:52.463
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-05-16. | 2022-04-25 11:09:52.467
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-06-17. | 2022-04-25 11:09:52.467
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-04-18. | 2022-04-25 11:09:52.471
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-05-15. | 2022-04-25 11:09:52.471
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-03-18. | 2022-04-25 11:09:52.476
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-04-17. | 2022-04-25 11:09:52.476
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-02-18. | 2022-04-25 11:09:52.480
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-03-17. | 2022-04-25 11:09:52.480
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-01-17. | 2022-04-25 11:09:52.484
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-02-17. | 2022-04-25 11:09:52.484
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198602-NYMEX.dly has a volume of 0 at 1985-12-18. | 2022-04-25 11:09:52.488
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198602-NYMEX.dly has a volume of 0 at 1986-01-16. | 2022-04-25 11:09:52.488
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-11-18. | 2022-04-25 11:09:52.492
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-12-17. | 2022-04-25 11:09:52.492
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-10-18. | 2022-04-25 11:09:52.496
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-11-15. | 2022-04-25 11:09:52.496
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-09-18. | 2022-04-25 11:09:52.500
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-10-17. | 2022-04-25 11:09:52.500
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-08-16. | 2022-04-25 11:09:52.504
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-09-17. | 2022-04-25 11:09:52.504
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-07-18. | 2022-04-25 11:09:52.508
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-08-15. | 2022-04-25 11:09:52.508
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-06-18. | 2022-04-25 11:09:52.512
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-07-17. | 2022-04-25 11:09:52.512
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-05-17. | 2022-04-25 11:09:52.517
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-06-17. | 2022-04-25 11:09:52.517
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-04-18. | 2022-04-25 11:09:52.521
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-05-16. | 2022-04-25 11:09:52.521
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-03-18. | 2022-04-25 11:09:52.525
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-04-17. | 2022-04-25 11:09:52.525
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-02-18. | 2022-04-25 11:09:52.529
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-03-15. | 2022-04-25 11:09:52.529
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-01-18. | 2022-04-25 11:09:52.533
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-02-15. | 2022-04-25 11:09:52.533
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198502-NYMEX.dly has a volume of 0 at 1984-12-18. | 2022-04-25 11:09:52.536
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198502-NYMEX.dly has a volume of 0 at 1985-01-17. | 2022-04-25 11:09:52.536
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-11-16. | 2022-04-25 11:09:52.540
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-12-17. | 2022-04-25 11:09:52.540
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-10-18. | 2022-04-25 11:09:52.543
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-11-15. | 2022-04-25 11:09:52.543
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-09-18. | 2022-04-25 11:09:52.547
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-10-17. | 2022-04-25 11:09:52.547
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-08-17. | 2022-04-25 11:09:52.551
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-09-17. | 2022-04-25 11:09:52.551
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-07-18. | 2022-04-25 11:09:52.556
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-08-16. | 2022-04-25 11:09:52.556
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-06-18. | 2022-04-25 11:09:52.560
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-07-17. | 2022-04-25 11:09:52.560
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-05-18. | 2022-04-25 11:09:52.563
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-06-15. | 2022-04-25 11:09:52.563
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-04-18. | 2022-04-25 11:09:52.567
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-05-17. | 2022-04-25 11:09:52.567
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-03-16. | 2022-04-25 11:09:52.571
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-04-17. | 2022-04-25 11:09:52.571
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-02-17. | 2022-04-25 11:09:52.575
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-03-15. | 2022-04-25 11:09:52.575
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-01-18. | 2022-04-25 11:09:52.579
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-02-16. | 2022-04-25 11:09:52.579
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198402-NYMEX.dly has a volume of 0 at 1983-12-16. | 2022-04-25 11:09:52.583
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198402-NYMEX.dly has a volume of 0 at 1984-01-17. | 2022-04-25 11:09:52.583
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-11-18. | 2022-04-25 11:09:52.586
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-12-15. | 2022-04-25 11:09:52.586
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-10-18. | 2022-04-25 11:09:52.590
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-11-17. | 2022-04-25 11:09:52.591
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-09-16. | 2022-04-25 11:09:52.595
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-10-17. | 2022-04-25 11:09:52.595
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-08-18. | 2022-04-25 11:09:52.599
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-09-15. | 2022-04-25 11:09:52.599
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-07-18. | 2022-04-25 11:09:52.603
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-08-17. | 2022-04-25 11:09:52.603
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-06-17. | 2022-04-25 11:09:52.607
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-07-15. | 2022-04-25 11:09:52.607
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-05-18. | 2022-04-25 11:09:52.611
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-06-16. | 2022-04-25 11:09:52.611
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-04-18. | 2022-04-25 11:09:52.615
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-05-17. | 2022-04-25 11:09:52.615
Added historical Daily data request for CL-202206-NYMEX to the queue. | 2022-04-25 11:09:52.891
Triggering next historical data download in queue. | 2022-04-25 11:09:52.892
HD Request # 222 | Downloading Historical Daily chart data for CL-202206-NYMEX. Starting date: 2022-04-20. Service: interactive_brokers.trading | 2022-04-25 11:09:52.905
HD Request # 222 | Requesting historical Daily data for CLM22 starting at 2022-04-19. SC External HD service. | 2022-04-25 11:09:54.322
HD Request # 222 | Receiving historical Daily data for CL-202206-NYMEX starting at 2022-04-20 | 2022-04-25 11:09:55.330
HD Request # 222 | Writing historical Daily data to the file CL-202206-NYMEX.dly | 2022-04-25 11:09:55.330
HD Request # 222 | Bytes received: 234 | 2022-04-25 11:09:55.348
HD Request # 222 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for CL-202206-NYMEX | 2022-04-25 11:09:55.348
HD Request # 222 | Completion time: 3s | 2022-04-25 11:09:55.349
HD Request # 222 | Daily data download complete for CL-202206-NYMEX. Unique request ID: 223 | 2022-04-25 11:09:55.349
Removing historical data download ID 223. | 2022-04-25 11:09:55.349
Triggering next historical data download in queue. | 2022-04-25 11:09:55.349
No download requests in the queue to start downloads for. | 2022-04-25 11:09:55.349
CL-202206-NYMEX [C][M] 2 Day #6 | Reloading chart. | 2022-04-25 11:09:55.465
CL-202206-NYMEX [C][M] 2 Day #6 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 11:09:55.465
CL-202206-NYMEX [C][M] 2 Day #6 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 11:09:55.465
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200102-NYMEX.dly has a volume of 0 at 2000-12-18. | 2022-04-25 11:09:57.166
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-11-17. | 2022-04-25 11:09:57.171
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-12-15. | 2022-04-25 11:09:57.171
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-10-18. | 2022-04-25 11:09:57.175
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-11-16. | 2022-04-25 11:09:57.175
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-09-18. | 2022-04-25 11:09:57.179
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-10-17. | 2022-04-25 11:09:57.179
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-08-18. | 2022-04-25 11:09:57.183
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-09-15. | 2022-04-25 11:09:57.183
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-07-18. | 2022-04-25 11:09:57.188
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-08-17. | 2022-04-25 11:09:57.188
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-06-16. | 2022-04-25 11:09:57.192
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-07-17. | 2022-04-25 11:09:57.192
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-05-18. | 2022-04-25 11:09:57.196
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-06-15. | 2022-04-25 11:09:57.196
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-04-18. | 2022-04-25 11:09:57.200
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-05-17. | 2022-04-25 11:09:57.200
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-03-17. | 2022-04-25 11:09:57.205
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-04-17. | 2022-04-25 11:09:57.205
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-02-18. | 2022-04-25 11:09:57.209
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-03-16. | 2022-04-25 11:09:57.209
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-01-18. | 2022-04-25 11:09:57.213
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-02-17. | 2022-04-25 11:09:57.213
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200002-NYMEX.dly has a volume of 0 at 1999-12-17. | 2022-04-25 11:09:57.217
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200002-NYMEX.dly has a volume of 0 at 2000-01-17. | 2022-04-25 11:09:57.217
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-11-18. | 2022-04-25 11:09:57.221
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-12-16. | 2022-04-25 11:09:57.221
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-10-18. | 2022-04-25 11:09:57.226
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-11-17. | 2022-04-25 11:09:57.226
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-09-17. | 2022-04-25 11:09:57.230
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-10-15. | 2022-04-25 11:09:57.230
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-08-18. | 2022-04-25 11:09:57.234
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-09-16. | 2022-04-25 11:09:57.234
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-07-16. | 2022-04-25 11:09:57.239
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-08-17. | 2022-04-25 11:09:57.239
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-06-18. | 2022-04-25 11:09:57.243
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-07-15. | 2022-04-25 11:09:57.243
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-05-18. | 2022-04-25 11:09:57.248
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-06-17. | 2022-04-25 11:09:57.248
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-04-16. | 2022-04-25 11:09:57.252
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-05-17. | 2022-04-25 11:09:57.252
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-03-18. | 2022-04-25 11:09:57.256
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-04-15. | 2022-04-25 11:09:57.256
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-02-18. | 2022-04-25 11:09:57.260
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-03-17. | 2022-04-25 11:09:57.260
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-01-18. | 2022-04-25 11:09:57.265
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-02-17. | 2022-04-25 11:09:57.265
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199902-NYMEX.dly has a volume of 0 at 1998-12-18. | 2022-04-25 11:09:57.268
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199902-NYMEX.dly has a volume of 0 at 1999-01-15. | 2022-04-25 11:09:57.268
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-11-18. | 2022-04-25 11:09:57.273
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-12-17. | 2022-04-25 11:09:57.273
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-10-16. | 2022-04-25 11:09:57.277
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-11-17. | 2022-04-25 11:09:57.277
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-09-18. | 2022-04-25 11:09:57.282
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-10-15. | 2022-04-25 11:09:57.282
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-08-18. | 2022-04-25 11:09:57.286
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-09-17. | 2022-04-25 11:09:57.286
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-07-17. | 2022-04-25 11:09:57.290
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-08-17. | 2022-04-25 11:09:57.290
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-06-18. | 2022-04-25 11:09:57.294
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-07-16. | 2022-04-25 11:09:57.294
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-05-18. | 2022-04-25 11:09:57.299
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-06-17. | 2022-04-25 11:09:57.299
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-04-17. | 2022-04-25 11:09:57.303
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-05-15. | 2022-04-25 11:09:57.303
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-03-18. | 2022-04-25 11:09:57.307
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-04-16. | 2022-04-25 11:09:57.307
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-02-18. | 2022-04-25 11:09:57.311
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-03-17. | 2022-04-25 11:09:57.311
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-01-16. | 2022-04-25 11:09:57.315
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-02-17. | 2022-04-25 11:09:57.315
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199802-NYMEX.dly has a volume of 0 at 1997-12-18. | 2022-04-25 11:09:57.319
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199802-NYMEX.dly has a volume of 0 at 1998-01-15. | 2022-04-25 11:09:57.319
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-11-18. | 2022-04-25 11:09:57.324
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-12-17. | 2022-04-25 11:09:57.324
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-10-17. | 2022-04-25 11:09:57.328
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-11-17. | 2022-04-25 11:09:57.328
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-09-18. | 2022-04-25 11:09:57.332
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-10-16. | 2022-04-25 11:09:57.332
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-08-18. | 2022-04-25 11:09:57.336
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-09-17. | 2022-04-25 11:09:57.336
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-07-18. | 2022-04-25 11:09:57.341
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-08-15. | 2022-04-25 11:09:57.341
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-06-18. | 2022-04-25 11:09:57.345
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-07-17. | 2022-04-25 11:09:57.345
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-05-16. | 2022-04-25 11:09:57.349
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-06-17. | 2022-04-25 11:09:57.349
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-04-18. | 2022-04-25 11:09:57.354
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-05-15. | 2022-04-25 11:09:57.354
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-03-18. | 2022-04-25 11:09:57.358
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-04-17. | 2022-04-25 11:09:57.358
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-02-18. | 2022-04-25 11:09:57.362
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-03-17. | 2022-04-25 11:09:57.362
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-01-17. | 2022-04-25 11:09:57.366
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-02-17. | 2022-04-25 11:09:57.366
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199702-NYMEX.dly has a volume of 0 at 1996-12-18. | 2022-04-25 11:09:57.370
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199702-NYMEX.dly has a volume of 0 at 1997-01-16. | 2022-04-25 11:09:57.370
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-11-18. | 2022-04-25 11:09:57.375
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-12-17. | 2022-04-25 11:09:57.375
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-10-18. | 2022-04-25 11:09:57.379
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-11-15. | 2022-04-25 11:09:57.379
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-09-18. | 2022-04-25 11:09:57.383
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-10-17. | 2022-04-25 11:09:57.383
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-08-16. | 2022-04-25 11:09:57.388
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-09-17. | 2022-04-25 11:09:57.388
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-07-18. | 2022-04-25 11:09:57.392
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-08-15. | 2022-04-25 11:09:57.392
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-06-18. | 2022-04-25 11:09:57.396
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-07-17. | 2022-04-25 11:09:57.396
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-05-17. | 2022-04-25 11:09:57.400
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-06-17. | 2022-04-25 11:09:57.400
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-04-18. | 2022-04-25 11:09:57.405
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-05-16. | 2022-04-25 11:09:57.405
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-03-18. | 2022-04-25 11:09:57.409
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-04-17. | 2022-04-25 11:09:57.409
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-02-16. | 2022-04-25 11:09:57.413
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-03-15. | 2022-04-25 11:09:57.413
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-01-18. | 2022-04-25 11:09:57.418
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-02-15. | 2022-04-25 11:09:57.418
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199602-NYMEX.dly has a volume of 0 at 1995-12-18. | 2022-04-25 11:09:57.422
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199602-NYMEX.dly has a volume of 0 at 1996-01-17. | 2022-04-25 11:09:57.422
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-11-17. | 2022-04-25 11:09:57.426
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-12-15. | 2022-04-25 11:09:57.426
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-10-18. | 2022-04-25 11:09:57.430
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-11-16. | 2022-04-25 11:09:57.430
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-09-18. | 2022-04-25 11:09:57.434
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-10-17. | 2022-04-25 11:09:57.434
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-08-18. | 2022-04-25 11:09:57.438
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-09-15. | 2022-04-25 11:09:57.438
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-07-18. | 2022-04-25 11:09:57.443
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-08-17. | 2022-04-25 11:09:57.443
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-06-16. | 2022-04-25 11:09:57.447
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-07-17. | 2022-04-25 11:09:57.447
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-05-18. | 2022-04-25 11:09:57.451
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-06-15. | 2022-04-25 11:09:57.451
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-04-18. | 2022-04-25 11:09:57.456
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-05-17. | 2022-04-25 11:09:57.456
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-03-17. | 2022-04-25 11:09:57.460
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-04-17. | 2022-04-25 11:09:57.460
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-02-17. | 2022-04-25 11:09:57.464
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-03-16. | 2022-04-25 11:09:57.464
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-01-18. | 2022-04-25 11:09:57.468
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-02-16. | 2022-04-25 11:09:57.468
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199502-NYMEX.dly has a volume of 0 at 1994-12-16. | 2022-04-25 11:09:57.473
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199502-NYMEX.dly has a volume of 0 at 1995-01-17. | 2022-04-25 11:09:57.473
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-11-18. | 2022-04-25 11:09:57.477
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-12-15. | 2022-04-25 11:09:57.477
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-10-18. | 2022-04-25 11:09:57.481
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-11-17. | 2022-04-25 11:09:57.481
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-09-16. | 2022-04-25 11:09:57.485
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-10-17. | 2022-04-25 11:09:57.485
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-08-18. | 2022-04-25 11:09:57.489
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-09-15. | 2022-04-25 11:09:57.489
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-07-18. | 2022-04-25 11:09:57.494
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-08-17. | 2022-04-25 11:09:57.494
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-06-17. | 2022-04-25 11:09:57.498
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-07-15. | 2022-04-25 11:09:57.498
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-05-18. | 2022-04-25 11:09:57.503
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-06-16. | 2022-04-25 11:09:57.503
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-04-18. | 2022-04-25 11:09:57.507
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-05-17. | 2022-04-25 11:09:57.507
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-03-18. | 2022-04-25 11:09:57.511
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-04-15. | 2022-04-25 11:09:57.511
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-02-18. | 2022-04-25 11:09:57.515
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-03-17. | 2022-04-25 11:09:57.515
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-01-18. | 2022-04-25 11:09:57.519
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-02-17. | 2022-04-25 11:09:57.519
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199402-NYMEX.dly has a volume of 0 at 1993-12-17. | 2022-04-25 11:09:57.524
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199402-NYMEX.dly has a volume of 0 at 1994-01-17. | 2022-04-25 11:09:57.524
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-11-18. | 2022-04-25 11:09:57.528
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-12-16. | 2022-04-25 11:09:57.528
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-10-18. | 2022-04-25 11:09:57.532
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-11-17. | 2022-04-25 11:09:57.532
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-09-17. | 2022-04-25 11:09:57.536
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-10-15. | 2022-04-25 11:09:57.536
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-08-18. | 2022-04-25 11:09:57.540
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-09-16. | 2022-04-25 11:09:57.540
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-07-16. | 2022-04-25 11:09:57.545
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-08-17. | 2022-04-25 11:09:57.545
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-06-18. | 2022-04-25 11:09:57.549
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-07-15. | 2022-04-25 11:09:57.549
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-05-18. | 2022-04-25 11:09:57.553
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-06-17. | 2022-04-25 11:09:57.553
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-04-16. | 2022-04-25 11:09:57.558
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-05-17. | 2022-04-25 11:09:57.558
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-03-18. | 2022-04-25 11:09:57.562
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-04-15. | 2022-04-25 11:09:57.562
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-02-18. | 2022-04-25 11:09:57.566
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-03-17. | 2022-04-25 11:09:57.566
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-01-18. | 2022-04-25 11:09:57.571
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-02-17. | 2022-04-25 11:09:57.571
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199302-NYMEX.dly has a volume of 0 at 1992-12-18. | 2022-04-25 11:09:57.575
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199302-NYMEX.dly has a volume of 0 at 1993-01-15. | 2022-04-25 11:09:57.575
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-11-18. | 2022-04-25 11:09:57.579
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-12-17. | 2022-04-25 11:09:57.579
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-10-16. | 2022-04-25 11:09:57.583
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-11-17. | 2022-04-25 11:09:57.583
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-09-18. | 2022-04-25 11:09:57.587
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-10-15. | 2022-04-25 11:09:57.587
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-08-18. | 2022-04-25 11:09:57.592
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-09-17. | 2022-04-25 11:09:57.592
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-07-17. | 2022-04-25 11:09:57.596
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-08-17. | 2022-04-25 11:09:57.596
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-06-18. | 2022-04-25 11:09:57.600
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-07-16. | 2022-04-25 11:09:57.600
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-05-18. | 2022-04-25 11:09:57.605
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-06-17. | 2022-04-25 11:09:57.605
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-04-17. | 2022-04-25 11:09:57.609
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-05-15. | 2022-04-25 11:09:57.609
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-03-18. | 2022-04-25 11:09:57.613
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-04-16. | 2022-04-25 11:09:57.613
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-02-18. | 2022-04-25 11:09:57.617
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-03-17. | 2022-04-25 11:09:57.617
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-01-17. | 2022-04-25 11:09:57.621
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-02-17. | 2022-04-25 11:09:57.621
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199202-NYMEX.dly has a volume of 0 at 1991-12-18. | 2022-04-25 11:09:57.626
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199202-NYMEX.dly has a volume of 0 at 1992-01-16. | 2022-04-25 11:09:57.626
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-11-18. | 2022-04-25 11:09:57.630
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-12-17. | 2022-04-25 11:09:57.630
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-10-18. | 2022-04-25 11:09:57.634
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-11-15. | 2022-04-25 11:09:57.634
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-09-18. | 2022-04-25 11:09:57.638
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-10-17. | 2022-04-25 11:09:57.638
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-08-16. | 2022-04-25 11:09:57.642
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-09-17. | 2022-04-25 11:09:57.642
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-07-18. | 2022-04-25 11:09:57.647
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-08-15. | 2022-04-25 11:09:57.647
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-06-18. | 2022-04-25 11:09:57.651
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-07-17. | 2022-04-25 11:09:57.651
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-05-17. | 2022-04-25 11:09:57.655
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-06-17. | 2022-04-25 11:09:57.655
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-04-18. | 2022-04-25 11:09:57.659
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-05-16. | 2022-04-25 11:09:57.659
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-03-18. | 2022-04-25 11:09:57.663
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-04-17. | 2022-04-25 11:09:57.663
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-02-18. | 2022-04-25 11:09:57.667
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-03-15. | 2022-04-25 11:09:57.668
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-01-18. | 2022-04-25 11:09:57.672
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-02-15. | 2022-04-25 11:09:57.672
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199102-NYMEX.dly has a volume of 0 at 1990-12-18. | 2022-04-25 11:09:57.676
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199102-NYMEX.dly has a volume of 0 at 1991-01-17. | 2022-04-25 11:09:57.676
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-11-16. | 2022-04-25 11:09:57.680
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-12-17. | 2022-04-25 11:09:57.680
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-10-18. | 2022-04-25 11:09:57.684
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-11-15. | 2022-04-25 11:09:57.684
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-09-18. | 2022-04-25 11:09:57.688
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-10-17. | 2022-04-25 11:09:57.688
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-08-17. | 2022-04-25 11:09:57.693
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-09-17. | 2022-04-25 11:09:57.693
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-07-18. | 2022-04-25 11:09:57.697
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-08-16. | 2022-04-25 11:09:57.697
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-06-18. | 2022-04-25 11:09:57.701
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-07-17. | 2022-04-25 11:09:57.701
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-05-18. | 2022-04-25 11:09:57.705
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-06-15. | 2022-04-25 11:09:57.705
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-04-18. | 2022-04-25 11:09:57.709
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-05-17. | 2022-04-25 11:09:57.709
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-03-16. | 2022-04-25 11:09:57.714
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-04-17. | 2022-04-25 11:09:57.714
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-02-16. | 2022-04-25 11:09:57.718
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-03-15. | 2022-04-25 11:09:57.718
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-01-18. | 2022-04-25 11:09:57.722
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-02-15. | 2022-04-25 11:09:57.722
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199002-NYMEX.dly has a volume of 0 at 1989-12-18. | 2022-04-25 11:09:57.726
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199002-NYMEX.dly has a volume of 0 at 1990-01-17. | 2022-04-25 11:09:57.726
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-11-17. | 2022-04-25 11:09:57.730
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-12-15. | 2022-04-25 11:09:57.730
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-10-18. | 2022-04-25 11:09:57.735
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-11-16. | 2022-04-25 11:09:57.735
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-09-18. | 2022-04-25 11:09:57.739
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-10-17. | 2022-04-25 11:09:57.739
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-08-18. | 2022-04-25 11:09:57.743
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-09-15. | 2022-04-25 11:09:57.743
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-07-18. | 2022-04-25 11:09:57.748
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-08-17. | 2022-04-25 11:09:57.748
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-06-16. | 2022-04-25 11:09:57.752
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-07-17. | 2022-04-25 11:09:57.752
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-05-18. | 2022-04-25 11:09:57.756
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-06-15. | 2022-04-25 11:09:57.756
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-04-18. | 2022-04-25 11:09:57.761
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-05-17. | 2022-04-25 11:09:57.761
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-03-17. | 2022-04-25 11:09:57.765
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-04-17. | 2022-04-25 11:09:57.765
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-02-17. | 2022-04-25 11:09:57.769
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-03-16. | 2022-04-25 11:09:57.769
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-01-18. | 2022-04-25 11:09:57.773
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-02-16. | 2022-04-25 11:09:57.773
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198902-NYMEX.dly has a volume of 0 at 1988-12-16. | 2022-04-25 11:09:57.778
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198902-NYMEX.dly has a volume of 0 at 1989-01-17. | 2022-04-25 11:09:57.778
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-11-18. | 2022-04-25 11:09:57.782
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-12-15. | 2022-04-25 11:09:57.782
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-10-18. | 2022-04-25 11:09:57.786
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-11-17. | 2022-04-25 11:09:57.786
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-09-16. | 2022-04-25 11:09:57.790
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-10-17. | 2022-04-25 11:09:57.790
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-08-18. | 2022-04-25 11:09:57.794
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-09-15. | 2022-04-25 11:09:57.794
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-07-18. | 2022-04-25 11:09:57.799
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-08-17. | 2022-04-25 11:09:57.799
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-06-17. | 2022-04-25 11:09:57.803
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-07-15. | 2022-04-25 11:09:57.803
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-05-18. | 2022-04-25 11:09:57.808
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-06-16. | 2022-04-25 11:09:57.808
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-04-18. | 2022-04-25 11:09:57.812
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-05-17. | 2022-04-25 11:09:57.812
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-03-18. | 2022-04-25 11:09:57.816
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-04-15. | 2022-04-25 11:09:57.816
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-02-18. | 2022-04-25 11:09:57.820
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-03-17. | 2022-04-25 11:09:57.820
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-01-18. | 2022-04-25 11:09:57.825
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-02-17. | 2022-04-25 11:09:57.825
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198802-NYMEX.dly has a volume of 0 at 1987-12-18. | 2022-04-25 11:09:57.829
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198802-NYMEX.dly has a volume of 0 at 1988-01-15. | 2022-04-25 11:09:57.829
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-11-18. | 2022-04-25 11:09:57.833
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-12-17. | 2022-04-25 11:09:57.833
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-10-16. | 2022-04-25 11:09:57.838
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-11-17. | 2022-04-25 11:09:57.838
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-09-18. | 2022-04-25 11:09:57.842
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-10-15. | 2022-04-25 11:09:57.842
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-08-18. | 2022-04-25 11:09:57.846
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-09-17. | 2022-04-25 11:09:57.846
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-07-17. | 2022-04-25 11:09:57.850
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-08-17. | 2022-04-25 11:09:57.850
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-06-18. | 2022-04-25 11:09:57.855
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-07-16. | 2022-04-25 11:09:57.855
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-05-18. | 2022-04-25 11:09:57.859
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-06-17. | 2022-04-25 11:09:57.859
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-04-17. | 2022-04-25 11:09:57.863
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-05-15. | 2022-04-25 11:09:57.863
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-03-18. | 2022-04-25 11:09:57.867
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-04-16. | 2022-04-25 11:09:57.867
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-02-18. | 2022-04-25 11:09:57.871
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-03-17. | 2022-04-25 11:09:57.871
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-01-16. | 2022-04-25 11:09:57.876
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-02-17. | 2022-04-25 11:09:57.876
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198702-NYMEX.dly has a volume of 0 at 1986-12-18. | 2022-04-25 11:09:57.880
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198702-NYMEX.dly has a volume of 0 at 1987-01-15. | 2022-04-25 11:09:57.880
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-11-18. | 2022-04-25 11:09:57.884
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-12-17. | 2022-04-25 11:09:57.884
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-10-17. | 2022-04-25 11:09:57.888
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-11-17. | 2022-04-25 11:09:57.888
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-09-18. | 2022-04-25 11:09:57.892
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-10-16. | 2022-04-25 11:09:57.892
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-08-18. | 2022-04-25 11:09:57.897
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-09-17. | 2022-04-25 11:09:57.897
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-07-18. | 2022-04-25 11:09:57.901
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-08-15. | 2022-04-25 11:09:57.901
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-06-18. | 2022-04-25 11:09:57.905
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-07-17. | 2022-04-25 11:09:57.905
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-05-16. | 2022-04-25 11:09:57.909
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-06-17. | 2022-04-25 11:09:57.909
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-04-18. | 2022-04-25 11:09:57.913
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-05-15. | 2022-04-25 11:09:57.913
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-03-18. | 2022-04-25 11:09:57.918
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-04-17. | 2022-04-25 11:09:57.918
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-02-18. | 2022-04-25 11:09:57.922
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-03-17. | 2022-04-25 11:09:57.922
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-01-17. | 2022-04-25 11:09:57.926
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-02-17. | 2022-04-25 11:09:57.926
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198602-NYMEX.dly has a volume of 0 at 1985-12-18. | 2022-04-25 11:09:57.930
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198602-NYMEX.dly has a volume of 0 at 1986-01-16. | 2022-04-25 11:09:57.930
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-11-18. | 2022-04-25 11:09:57.934
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-12-17. | 2022-04-25 11:09:57.934
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-10-18. | 2022-04-25 11:09:57.938
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-11-15. | 2022-04-25 11:09:57.938
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-09-18. | 2022-04-25 11:09:57.942
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-10-17. | 2022-04-25 11:09:57.942
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-08-16. | 2022-04-25 11:09:57.946
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-09-17. | 2022-04-25 11:09:57.946
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-07-18. | 2022-04-25 11:09:57.950
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-08-15. | 2022-04-25 11:09:57.950
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-06-18. | 2022-04-25 11:09:57.955
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-07-17. | 2022-04-25 11:09:57.955
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-05-17. | 2022-04-25 11:09:57.959
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-06-17. | 2022-04-25 11:09:57.959
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-04-18. | 2022-04-25 11:09:57.963
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-05-16. | 2022-04-25 11:09:57.963
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-03-18. | 2022-04-25 11:09:57.967
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-04-17. | 2022-04-25 11:09:57.967
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-02-18. | 2022-04-25 11:09:57.971
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-03-15. | 2022-04-25 11:09:57.971
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-01-18. | 2022-04-25 11:09:57.975
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-02-15. | 2022-04-25 11:09:57.975
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198502-NYMEX.dly has a volume of 0 at 1984-12-18. | 2022-04-25 11:09:57.979
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198502-NYMEX.dly has a volume of 0 at 1985-01-17. | 2022-04-25 11:09:57.979
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-11-16. | 2022-04-25 11:09:57.982
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-12-17. | 2022-04-25 11:09:57.982
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-10-18. | 2022-04-25 11:09:57.986
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-11-15. | 2022-04-25 11:09:57.986
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-09-18. | 2022-04-25 11:09:57.990
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-10-17. | 2022-04-25 11:09:57.990
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-08-17. | 2022-04-25 11:09:57.994
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-09-17. | 2022-04-25 11:09:57.994
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-07-18. | 2022-04-25 11:09:57.998
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-08-16. | 2022-04-25 11:09:57.998
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-06-18. | 2022-04-25 11:09:58.002
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-07-17. | 2022-04-25 11:09:58.002
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-05-18. | 2022-04-25 11:09:58.006
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-06-15. | 2022-04-25 11:09:58.006
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-04-18. | 2022-04-25 11:09:58.010
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-05-17. | 2022-04-25 11:09:58.010
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-03-16. | 2022-04-25 11:09:58.014
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-04-17. | 2022-04-25 11:09:58.014
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-02-17. | 2022-04-25 11:09:58.018
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-03-15. | 2022-04-25 11:09:58.018
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-01-18. | 2022-04-25 11:09:58.022
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-02-16. | 2022-04-25 11:09:58.022
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198402-NYMEX.dly has a volume of 0 at 1983-12-16. | 2022-04-25 11:09:58.026
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198402-NYMEX.dly has a volume of 0 at 1984-01-17. | 2022-04-25 11:09:58.026
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-11-18. | 2022-04-25 11:09:58.029
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-12-15. | 2022-04-25 11:09:58.029
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-10-18. | 2022-04-25 11:09:58.033
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-11-17. | 2022-04-25 11:09:58.033
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-09-16. | 2022-04-25 11:09:58.037
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-10-17. | 2022-04-25 11:09:58.037
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-08-18. | 2022-04-25 11:09:58.041
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-09-15. | 2022-04-25 11:09:58.041
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-07-18. | 2022-04-25 11:09:58.046
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-08-17. | 2022-04-25 11:09:58.046
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-06-17. | 2022-04-25 11:09:58.050
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-07-15. | 2022-04-25 11:09:58.050
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-05-18. | 2022-04-25 11:09:58.054
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-06-16. | 2022-04-25 11:09:58.054
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-04-18. | 2022-04-25 11:09:58.058
CL-202206-NYMEX [C][M] 2 Day #6 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-05-17. | 2022-04-25 11:09:58.058
CL-202206-NYMEX [C][M] 16 Day #10 | Reloading chart. | 2022-04-25 11:09:58.383
CL-202206-NYMEX [C][M] 16 Day #10 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 11:09:58.383
CL-202206-NYMEX [C][M] 16 Day #10 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 11:09:58.383
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200102-NYMEX.dly has a volume of 0 at 2000-12-18. | 2022-04-25 11:10:00.130
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-11-17. | 2022-04-25 11:10:00.134
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-12-15. | 2022-04-25 11:10:00.134
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-10-18. | 2022-04-25 11:10:00.138
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-11-16. | 2022-04-25 11:10:00.138
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-09-18. | 2022-04-25 11:10:00.143
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-10-17. | 2022-04-25 11:10:00.143
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-08-18. | 2022-04-25 11:10:00.147
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-09-15. | 2022-04-25 11:10:00.147
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-07-18. | 2022-04-25 11:10:00.152
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-08-17. | 2022-04-25 11:10:00.152
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-06-16. | 2022-04-25 11:10:00.156
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-07-17. | 2022-04-25 11:10:00.156
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-05-18. | 2022-04-25 11:10:00.160
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-06-15. | 2022-04-25 11:10:00.160
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-04-18. | 2022-04-25 11:10:00.164
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-05-17. | 2022-04-25 11:10:00.164
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-03-17. | 2022-04-25 11:10:00.169
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-04-17. | 2022-04-25 11:10:00.169
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-02-18. | 2022-04-25 11:10:00.173
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-03-16. | 2022-04-25 11:10:00.173
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-01-18. | 2022-04-25 11:10:00.177
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-02-17. | 2022-04-25 11:10:00.177
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200002-NYMEX.dly has a volume of 0 at 1999-12-17. | 2022-04-25 11:10:00.181
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200002-NYMEX.dly has a volume of 0 at 2000-01-17. | 2022-04-25 11:10:00.181
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-11-18. | 2022-04-25 11:10:00.185
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-12-16. | 2022-04-25 11:10:00.185
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-10-18. | 2022-04-25 11:10:00.190
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-11-17. | 2022-04-25 11:10:00.190
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-09-17. | 2022-04-25 11:10:00.195
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-10-15. | 2022-04-25 11:10:00.195
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-08-18. | 2022-04-25 11:10:00.199
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-09-16. | 2022-04-25 11:10:00.199
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-07-16. | 2022-04-25 11:10:00.204
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-08-17. | 2022-04-25 11:10:00.204
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-06-18. | 2022-04-25 11:10:00.208
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-07-15. | 2022-04-25 11:10:00.208
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-05-18. | 2022-04-25 11:10:00.213
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-06-17. | 2022-04-25 11:10:00.213
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-04-16. | 2022-04-25 11:10:00.217
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-05-17. | 2022-04-25 11:10:00.217
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-03-18. | 2022-04-25 11:10:00.221
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-04-15. | 2022-04-25 11:10:00.221
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-02-18. | 2022-04-25 11:10:00.225
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-03-17. | 2022-04-25 11:10:00.225
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-01-18. | 2022-04-25 11:10:00.230
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-02-17. | 2022-04-25 11:10:00.230
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199902-NYMEX.dly has a volume of 0 at 1998-12-18. | 2022-04-25 11:10:00.234
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199902-NYMEX.dly has a volume of 0 at 1999-01-15. | 2022-04-25 11:10:00.234
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-11-18. | 2022-04-25 11:10:00.238
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-12-17. | 2022-04-25 11:10:00.238
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-10-16. | 2022-04-25 11:10:00.243
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-11-17. | 2022-04-25 11:10:00.243
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-09-18. | 2022-04-25 11:10:00.247
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-10-15. | 2022-04-25 11:10:00.247
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-08-18. | 2022-04-25 11:10:00.252
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-09-17. | 2022-04-25 11:10:00.252
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-07-17. | 2022-04-25 11:10:00.256
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-08-17. | 2022-04-25 11:10:00.256
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-06-18. | 2022-04-25 11:10:00.260
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-07-16. | 2022-04-25 11:10:00.260
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-05-18. | 2022-04-25 11:10:00.265
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-06-17. | 2022-04-25 11:10:00.265
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-04-17. | 2022-04-25 11:10:00.269
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-05-15. | 2022-04-25 11:10:00.269
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-03-18. | 2022-04-25 11:10:00.273
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-04-16. | 2022-04-25 11:10:00.273
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-02-18. | 2022-04-25 11:10:00.277
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-03-17. | 2022-04-25 11:10:00.277
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-01-16. | 2022-04-25 11:10:00.282
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-02-17. | 2022-04-25 11:10:00.282
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199802-NYMEX.dly has a volume of 0 at 1997-12-18. | 2022-04-25 11:10:00.286
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199802-NYMEX.dly has a volume of 0 at 1998-01-15. | 2022-04-25 11:10:00.286
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-11-18. | 2022-04-25 11:10:00.290
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-12-17. | 2022-04-25 11:10:00.290
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-10-17. | 2022-04-25 11:10:00.295
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-11-17. | 2022-04-25 11:10:00.295
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-09-18. | 2022-04-25 11:10:00.299
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-10-16. | 2022-04-25 11:10:00.299
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-08-18. | 2022-04-25 11:10:00.303
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-09-17. | 2022-04-25 11:10:00.303
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-07-18. | 2022-04-25 11:10:00.308
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-08-15. | 2022-04-25 11:10:00.308
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-06-18. | 2022-04-25 11:10:00.312
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-07-17. | 2022-04-25 11:10:00.312
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-05-16. | 2022-04-25 11:10:00.316
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-06-17. | 2022-04-25 11:10:00.316
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-04-18. | 2022-04-25 11:10:00.321
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-05-15. | 2022-04-25 11:10:00.321
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-03-18. | 2022-04-25 11:10:00.325
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-04-17. | 2022-04-25 11:10:00.325
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-02-18. | 2022-04-25 11:10:00.330
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-03-17. | 2022-04-25 11:10:00.330
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-01-17. | 2022-04-25 11:10:00.334
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-02-17. | 2022-04-25 11:10:00.334
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199702-NYMEX.dly has a volume of 0 at 1996-12-18. | 2022-04-25 11:10:00.338
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199702-NYMEX.dly has a volume of 0 at 1997-01-16. | 2022-04-25 11:10:00.338
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-11-18. | 2022-04-25 11:10:00.342
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-12-17. | 2022-04-25 11:10:00.342
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-10-18. | 2022-04-25 11:10:00.347
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-11-15. | 2022-04-25 11:10:00.347
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-09-18. | 2022-04-25 11:10:00.351
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-10-17. | 2022-04-25 11:10:00.351
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-08-16. | 2022-04-25 11:10:00.355
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-09-17. | 2022-04-25 11:10:00.355
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-07-18. | 2022-04-25 11:10:00.360
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-08-15. | 2022-04-25 11:10:00.360
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-06-18. | 2022-04-25 11:10:00.364
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-07-17. | 2022-04-25 11:10:00.364
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-05-17. | 2022-04-25 11:10:00.368
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-06-17. | 2022-04-25 11:10:00.368
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-04-18. | 2022-04-25 11:10:00.373
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-05-16. | 2022-04-25 11:10:00.373
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-03-18. | 2022-04-25 11:10:00.378
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-04-17. | 2022-04-25 11:10:00.378
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-02-16. | 2022-04-25 11:10:00.382
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-03-15. | 2022-04-25 11:10:00.382
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-01-18. | 2022-04-25 11:10:00.386
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-02-15. | 2022-04-25 11:10:00.386
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199602-NYMEX.dly has a volume of 0 at 1995-12-18. | 2022-04-25 11:10:00.390
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199602-NYMEX.dly has a volume of 0 at 1996-01-17. | 2022-04-25 11:10:00.390
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-11-17. | 2022-04-25 11:10:00.394
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-12-15. | 2022-04-25 11:10:00.394
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-10-18. | 2022-04-25 11:10:00.398
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-11-16. | 2022-04-25 11:10:00.398
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-09-18. | 2022-04-25 11:10:00.403
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-10-17. | 2022-04-25 11:10:00.403
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-08-18. | 2022-04-25 11:10:00.407
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-09-15. | 2022-04-25 11:10:00.407
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-07-18. | 2022-04-25 11:10:00.412
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-08-17. | 2022-04-25 11:10:00.412
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-06-16. | 2022-04-25 11:10:00.416
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-07-17. | 2022-04-25 11:10:00.416
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-05-18. | 2022-04-25 11:10:00.420
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-06-15. | 2022-04-25 11:10:00.420
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-04-18. | 2022-04-25 11:10:00.425
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-05-17. | 2022-04-25 11:10:00.425
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-03-17. | 2022-04-25 11:10:00.429
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-04-17. | 2022-04-25 11:10:00.429
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-02-17. | 2022-04-25 11:10:00.433
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-03-16. | 2022-04-25 11:10:00.433
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-01-18. | 2022-04-25 11:10:00.437
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-02-16. | 2022-04-25 11:10:00.437
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199502-NYMEX.dly has a volume of 0 at 1994-12-16. | 2022-04-25 11:10:00.442
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199502-NYMEX.dly has a volume of 0 at 1995-01-17. | 2022-04-25 11:10:00.442
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-11-18. | 2022-04-25 11:10:00.446
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-12-15. | 2022-04-25 11:10:00.446
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-10-18. | 2022-04-25 11:10:00.450
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-11-17. | 2022-04-25 11:10:00.450
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-09-16. | 2022-04-25 11:10:00.455
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-10-17. | 2022-04-25 11:10:00.455
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-08-18. | 2022-04-25 11:10:00.459
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-09-15. | 2022-04-25 11:10:00.459
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-07-18. | 2022-04-25 11:10:00.464
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-08-17. | 2022-04-25 11:10:00.464
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-06-17. | 2022-04-25 11:10:00.468
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-07-15. | 2022-04-25 11:10:00.468
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-05-18. | 2022-04-25 11:10:00.472
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-06-16. | 2022-04-25 11:10:00.472
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-04-18. | 2022-04-25 11:10:00.476
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-05-17. | 2022-04-25 11:10:00.476
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-03-18. | 2022-04-25 11:10:00.480
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-04-15. | 2022-04-25 11:10:00.480
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-02-18. | 2022-04-25 11:10:00.485
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-03-17. | 2022-04-25 11:10:00.485
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-01-18. | 2022-04-25 11:10:00.489
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-02-17. | 2022-04-25 11:10:00.489
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199402-NYMEX.dly has a volume of 0 at 1993-12-17. | 2022-04-25 11:10:00.493
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199402-NYMEX.dly has a volume of 0 at 1994-01-17. | 2022-04-25 11:10:00.493
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-11-18. | 2022-04-25 11:10:00.497
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-12-16. | 2022-04-25 11:10:00.497
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-10-18. | 2022-04-25 11:10:00.502
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-11-17. | 2022-04-25 11:10:00.502
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-09-17. | 2022-04-25 11:10:00.506
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-10-15. | 2022-04-25 11:10:00.506
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-08-18. | 2022-04-25 11:10:00.510
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-09-16. | 2022-04-25 11:10:00.510
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-07-16. | 2022-04-25 11:10:00.515
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-08-17. | 2022-04-25 11:10:00.515
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-06-18. | 2022-04-25 11:10:00.519
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-07-15. | 2022-04-25 11:10:00.519
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-05-18. | 2022-04-25 11:10:00.524
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-06-17. | 2022-04-25 11:10:00.524
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-04-16. | 2022-04-25 11:10:00.528
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-05-17. | 2022-04-25 11:10:00.528
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-03-18. | 2022-04-25 11:10:00.532
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-04-15. | 2022-04-25 11:10:00.532
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-02-18. | 2022-04-25 11:10:00.536
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-03-17. | 2022-04-25 11:10:00.536
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-01-18. | 2022-04-25 11:10:00.541
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-02-17. | 2022-04-25 11:10:00.541
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199302-NYMEX.dly has a volume of 0 at 1992-12-18. | 2022-04-25 11:10:00.545
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199302-NYMEX.dly has a volume of 0 at 1993-01-15. | 2022-04-25 11:10:00.545
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-11-18. | 2022-04-25 11:10:00.549
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-12-17. | 2022-04-25 11:10:00.549
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-10-16. | 2022-04-25 11:10:00.554
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-11-17. | 2022-04-25 11:10:00.554
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-09-18. | 2022-04-25 11:10:00.558
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-10-15. | 2022-04-25 11:10:00.558
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-08-18. | 2022-04-25 11:10:00.563
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-09-17. | 2022-04-25 11:10:00.563
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-07-17. | 2022-04-25 11:10:00.567
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-08-17. | 2022-04-25 11:10:00.567
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-06-18. | 2022-04-25 11:10:00.572
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-07-16. | 2022-04-25 11:10:00.572
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-05-18. | 2022-04-25 11:10:00.576
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-06-17. | 2022-04-25 11:10:00.576
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-04-17. | 2022-04-25 11:10:00.580
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-05-15. | 2022-04-25 11:10:00.580
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-03-18. | 2022-04-25 11:10:00.585
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-04-16. | 2022-04-25 11:10:00.585
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-02-18. | 2022-04-25 11:10:00.589
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-03-17. | 2022-04-25 11:10:00.589
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-01-17. | 2022-04-25 11:10:00.593
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-02-17. | 2022-04-25 11:10:00.593
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199202-NYMEX.dly has a volume of 0 at 1991-12-18. | 2022-04-25 11:10:00.597
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199202-NYMEX.dly has a volume of 0 at 1992-01-16. | 2022-04-25 11:10:00.597
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-11-18. | 2022-04-25 11:10:00.602
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-12-17. | 2022-04-25 11:10:00.602
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-10-18. | 2022-04-25 11:10:00.606
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-11-15. | 2022-04-25 11:10:00.606
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-09-18. | 2022-04-25 11:10:00.610
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-10-17. | 2022-04-25 11:10:00.610
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-08-16. | 2022-04-25 11:10:00.615
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-09-17. | 2022-04-25 11:10:00.615
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-07-18. | 2022-04-25 11:10:00.619
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-08-15. | 2022-04-25 11:10:00.619
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-06-18. | 2022-04-25 11:10:00.623
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-07-17. | 2022-04-25 11:10:00.623
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-05-17. | 2022-04-25 11:10:00.628
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-06-17. | 2022-04-25 11:10:00.628
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-04-18. | 2022-04-25 11:10:00.632
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-05-16. | 2022-04-25 11:10:00.632
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-03-18. | 2022-04-25 11:10:00.636
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-04-17. | 2022-04-25 11:10:00.636
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-02-18. | 2022-04-25 11:10:00.640
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-03-15. | 2022-04-25 11:10:00.640
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-01-18. | 2022-04-25 11:10:00.645
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-02-15. | 2022-04-25 11:10:00.645
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199102-NYMEX.dly has a volume of 0 at 1990-12-18. | 2022-04-25 11:10:00.649
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199102-NYMEX.dly has a volume of 0 at 1991-01-17. | 2022-04-25 11:10:00.649
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-11-16. | 2022-04-25 11:10:00.653
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-12-17. | 2022-04-25 11:10:00.653
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-10-18. | 2022-04-25 11:10:00.657
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-11-15. | 2022-04-25 11:10:00.657
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-09-18. | 2022-04-25 11:10:00.662
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-10-17. | 2022-04-25 11:10:00.662
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-08-17. | 2022-04-25 11:10:00.666
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-09-17. | 2022-04-25 11:10:00.666
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-07-18. | 2022-04-25 11:10:00.670
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-08-16. | 2022-04-25 11:10:00.670
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-06-18. | 2022-04-25 11:10:00.675
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-07-17. | 2022-04-25 11:10:00.675
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-05-18. | 2022-04-25 11:10:00.679
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-06-15. | 2022-04-25 11:10:00.679
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-04-18. | 2022-04-25 11:10:00.683
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-05-17. | 2022-04-25 11:10:00.683
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-03-16. | 2022-04-25 11:10:00.688
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-04-17. | 2022-04-25 11:10:00.688
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-02-16. | 2022-04-25 11:10:00.692
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-03-15. | 2022-04-25 11:10:00.692
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-01-18. | 2022-04-25 11:10:00.696
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-02-15. | 2022-04-25 11:10:00.696
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199002-NYMEX.dly has a volume of 0 at 1989-12-18. | 2022-04-25 11:10:00.700
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199002-NYMEX.dly has a volume of 0 at 1990-01-17. | 2022-04-25 11:10:00.700
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-11-17. | 2022-04-25 11:10:00.704
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-12-15. | 2022-04-25 11:10:00.704
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-10-18. | 2022-04-25 11:10:00.709
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-11-16. | 2022-04-25 11:10:00.709
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-09-18. | 2022-04-25 11:10:00.713
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-10-17. | 2022-04-25 11:10:00.713
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-08-18. | 2022-04-25 11:10:00.717
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-09-15. | 2022-04-25 11:10:00.717
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-07-18. | 2022-04-25 11:10:00.722
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-08-17. | 2022-04-25 11:10:00.722
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-06-16. | 2022-04-25 11:10:00.727
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-07-17. | 2022-04-25 11:10:00.727
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-05-18. | 2022-04-25 11:10:00.731
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-06-15. | 2022-04-25 11:10:00.731
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-04-18. | 2022-04-25 11:10:00.735
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-05-17. | 2022-04-25 11:10:00.735
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-03-17. | 2022-04-25 11:10:00.740
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-04-17. | 2022-04-25 11:10:00.740
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-02-17. | 2022-04-25 11:10:00.744
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-03-16. | 2022-04-25 11:10:00.744
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-01-18. | 2022-04-25 11:10:00.748
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-02-16. | 2022-04-25 11:10:00.748
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198902-NYMEX.dly has a volume of 0 at 1988-12-16. | 2022-04-25 11:10:00.753
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198902-NYMEX.dly has a volume of 0 at 1989-01-17. | 2022-04-25 11:10:00.753
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-11-18. | 2022-04-25 11:10:00.757
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-12-15. | 2022-04-25 11:10:00.757
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-10-18. | 2022-04-25 11:10:00.761
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-11-17. | 2022-04-25 11:10:00.761
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-09-16. | 2022-04-25 11:10:00.765
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-10-17. | 2022-04-25 11:10:00.765
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-08-18. | 2022-04-25 11:10:00.770
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-09-15. | 2022-04-25 11:10:00.770
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-07-18. | 2022-04-25 11:10:00.775
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-08-17. | 2022-04-25 11:10:00.775
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-06-17. | 2022-04-25 11:10:00.779
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-07-15. | 2022-04-25 11:10:00.779
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-05-18. | 2022-04-25 11:10:00.783
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-06-16. | 2022-04-25 11:10:00.783
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-04-18. | 2022-04-25 11:10:00.788
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-05-17. | 2022-04-25 11:10:00.788
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-03-18. | 2022-04-25 11:10:00.792
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-04-15. | 2022-04-25 11:10:00.792
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-02-18. | 2022-04-25 11:10:00.796
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-03-17. | 2022-04-25 11:10:00.796
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-01-18. | 2022-04-25 11:10:00.800
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-02-17. | 2022-04-25 11:10:00.800
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198802-NYMEX.dly has a volume of 0 at 1987-12-18. | 2022-04-25 11:10:00.805
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198802-NYMEX.dly has a volume of 0 at 1988-01-15. | 2022-04-25 11:10:00.805
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-11-18. | 2022-04-25 11:10:00.809
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-12-17. | 2022-04-25 11:10:00.809
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-10-16. | 2022-04-25 11:10:00.814
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-11-17. | 2022-04-25 11:10:00.814
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-09-18. | 2022-04-25 11:10:00.818
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-10-15. | 2022-04-25 11:10:00.818
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-08-18. | 2022-04-25 11:10:00.822
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-09-17. | 2022-04-25 11:10:00.822
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-07-17. | 2022-04-25 11:10:00.827
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-08-17. | 2022-04-25 11:10:00.827
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-06-18. | 2022-04-25 11:10:00.831
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-07-16. | 2022-04-25 11:10:00.831
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-05-18. | 2022-04-25 11:10:00.835
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-06-17. | 2022-04-25 11:10:00.835
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-04-17. | 2022-04-25 11:10:00.840
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-05-15. | 2022-04-25 11:10:00.840
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-03-18. | 2022-04-25 11:10:00.844
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-04-16. | 2022-04-25 11:10:00.844
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-02-18. | 2022-04-25 11:10:00.848
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-03-17. | 2022-04-25 11:10:00.848
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-01-16. | 2022-04-25 11:10:00.853
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-02-17. | 2022-04-25 11:10:00.853
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198702-NYMEX.dly has a volume of 0 at 1986-12-18. | 2022-04-25 11:10:00.857
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198702-NYMEX.dly has a volume of 0 at 1987-01-15. | 2022-04-25 11:10:00.857
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-11-18. | 2022-04-25 11:10:00.861
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-12-17. | 2022-04-25 11:10:00.861
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-10-17. | 2022-04-25 11:10:00.865
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-11-17. | 2022-04-25 11:10:00.865
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-09-18. | 2022-04-25 11:10:00.870
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-10-16. | 2022-04-25 11:10:00.870
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-08-18. | 2022-04-25 11:10:00.874
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-09-17. | 2022-04-25 11:10:00.874
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-07-18. | 2022-04-25 11:10:00.879
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-08-15. | 2022-04-25 11:10:00.879
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-06-18. | 2022-04-25 11:10:00.883
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-07-17. | 2022-04-25 11:10:00.883
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-05-16. | 2022-04-25 11:10:00.887
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-06-17. | 2022-04-25 11:10:00.887
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-04-18. | 2022-04-25 11:10:00.891
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-05-15. | 2022-04-25 11:10:00.891
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-03-18. | 2022-04-25 11:10:00.896
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-04-17. | 2022-04-25 11:10:00.896
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-02-18. | 2022-04-25 11:10:00.900
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-03-17. | 2022-04-25 11:10:00.900
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-01-17. | 2022-04-25 11:10:00.904
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-02-17. | 2022-04-25 11:10:00.904
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198602-NYMEX.dly has a volume of 0 at 1985-12-18. | 2022-04-25 11:10:00.908
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198602-NYMEX.dly has a volume of 0 at 1986-01-16. | 2022-04-25 11:10:00.908
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-11-18. | 2022-04-25 11:10:00.913
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-12-17. | 2022-04-25 11:10:00.913
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-10-18. | 2022-04-25 11:10:00.917
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-11-15. | 2022-04-25 11:10:00.917
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-09-18. | 2022-04-25 11:10:00.921
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-10-17. | 2022-04-25 11:10:00.921
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-08-16. | 2022-04-25 11:10:00.926
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-09-17. | 2022-04-25 11:10:00.926
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-07-18. | 2022-04-25 11:10:00.930
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-08-15. | 2022-04-25 11:10:00.930
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-06-18. | 2022-04-25 11:10:00.934
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-07-17. | 2022-04-25 11:10:00.934
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-05-17. | 2022-04-25 11:10:00.938
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-06-17. | 2022-04-25 11:10:00.938
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-04-18. | 2022-04-25 11:10:00.943
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-05-16. | 2022-04-25 11:10:00.943
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-03-18. | 2022-04-25 11:10:00.947
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-04-17. | 2022-04-25 11:10:00.947
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-02-18. | 2022-04-25 11:10:00.951
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-03-15. | 2022-04-25 11:10:00.951
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-01-18. | 2022-04-25 11:10:00.955
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-02-15. | 2022-04-25 11:10:00.955
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198502-NYMEX.dly has a volume of 0 at 1984-12-18. | 2022-04-25 11:10:00.959
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198502-NYMEX.dly has a volume of 0 at 1985-01-17. | 2022-04-25 11:10:00.959
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-11-16. | 2022-04-25 11:10:00.962
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-12-17. | 2022-04-25 11:10:00.962
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-10-18. | 2022-04-25 11:10:00.966
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-11-15. | 2022-04-25 11:10:00.966
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-09-18. | 2022-04-25 11:10:00.970
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-10-17. | 2022-04-25 11:10:00.970
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-08-17. | 2022-04-25 11:10:00.974
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-09-17. | 2022-04-25 11:10:00.974
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-07-18. | 2022-04-25 11:10:00.979
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-08-16. | 2022-04-25 11:10:00.979
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-06-18. | 2022-04-25 11:10:00.983
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-07-17. | 2022-04-25 11:10:00.983
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-05-18. | 2022-04-25 11:10:00.987
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-06-15. | 2022-04-25 11:10:00.987
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-04-18. | 2022-04-25 11:10:00.991
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-05-17. | 2022-04-25 11:10:00.991
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-03-16. | 2022-04-25 11:10:00.995
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-04-17. | 2022-04-25 11:10:00.995
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-02-17. | 2022-04-25 11:10:00.999
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-03-15. | 2022-04-25 11:10:00.999
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-01-18. | 2022-04-25 11:10:01.003
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-02-16. | 2022-04-25 11:10:01.003
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198402-NYMEX.dly has a volume of 0 at 1983-12-16. | 2022-04-25 11:10:01.007
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198402-NYMEX.dly has a volume of 0 at 1984-01-17. | 2022-04-25 11:10:01.007
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-11-18. | 2022-04-25 11:10:01.011
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-12-15. | 2022-04-25 11:10:01.011
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-10-18. | 2022-04-25 11:10:01.015
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-11-17. | 2022-04-25 11:10:01.015
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-09-16. | 2022-04-25 11:10:01.019
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-10-17. | 2022-04-25 11:10:01.019
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-08-18. | 2022-04-25 11:10:01.023
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-09-15. | 2022-04-25 11:10:01.023
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-07-18. | 2022-04-25 11:10:01.028
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-08-17. | 2022-04-25 11:10:01.028
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-06-17. | 2022-04-25 11:10:01.032
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-07-15. | 2022-04-25 11:10:01.032
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-05-18. | 2022-04-25 11:10:01.036
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-06-16. | 2022-04-25 11:10:01.036
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-04-18. | 2022-04-25 11:10:01.040
CL-202206-NYMEX [C][M] 16 Day #10 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-05-17. | 2022-04-25 11:10:01.040
CL-202206-NYMEX [C][M] 4 Day #3 | Reloading chart. | 2022-04-25 11:10:01.324
CL-202206-NYMEX [C][M] 4 Day #3 | Limiting the number of years to 59 years to load data for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 11:10:01.325
CL-202206-NYMEX [C][M] 4 Day #3 | Limiting the number of years to download historical data to 59 years for the continuous futures chart. Reason: Account level limitation. | 2022-04-25 11:10:01.325
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200102-NYMEX.dly has a volume of 0 at 2000-12-18. | 2022-04-25 11:10:03.077
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-11-17. | 2022-04-25 11:10:03.081
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200101-NYMEX.dly has a volume of 0 at 2000-12-15. | 2022-04-25 11:10:03.081
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-10-18. | 2022-04-25 11:10:03.085
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200012-NYMEX.dly has a volume of 0 at 2000-11-16. | 2022-04-25 11:10:03.085
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-09-18. | 2022-04-25 11:10:03.089
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200011-NYMEX.dly has a volume of 0 at 2000-10-17. | 2022-04-25 11:10:03.089
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-08-18. | 2022-04-25 11:10:03.093
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200010-NYMEX.dly has a volume of 0 at 2000-09-15. | 2022-04-25 11:10:03.093
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-07-18. | 2022-04-25 11:10:03.098
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200009-NYMEX.dly has a volume of 0 at 2000-08-17. | 2022-04-25 11:10:03.098
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-06-16. | 2022-04-25 11:10:03.102
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200008-NYMEX.dly has a volume of 0 at 2000-07-17. | 2022-04-25 11:10:03.102
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-05-18. | 2022-04-25 11:10:03.107
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200007-NYMEX.dly has a volume of 0 at 2000-06-15. | 2022-04-25 11:10:03.107
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-04-18. | 2022-04-25 11:10:03.111
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200006-NYMEX.dly has a volume of 0 at 2000-05-17. | 2022-04-25 11:10:03.111
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-03-17. | 2022-04-25 11:10:03.115
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200005-NYMEX.dly has a volume of 0 at 2000-04-17. | 2022-04-25 11:10:03.115
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-02-18. | 2022-04-25 11:10:03.119
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200004-NYMEX.dly has a volume of 0 at 2000-03-16. | 2022-04-25 11:10:03.119
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-01-18. | 2022-04-25 11:10:03.124
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200003-NYMEX.dly has a volume of 0 at 2000-02-17. | 2022-04-25 11:10:03.124
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200002-NYMEX.dly has a volume of 0 at 1999-12-17. | 2022-04-25 11:10:03.128
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200002-NYMEX.dly has a volume of 0 at 2000-01-17. | 2022-04-25 11:10:03.128
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-11-18. | 2022-04-25 11:10:03.132
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-200001-NYMEX.dly has a volume of 0 at 1999-12-16. | 2022-04-25 11:10:03.132
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-10-18. | 2022-04-25 11:10:03.137
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199912-NYMEX.dly has a volume of 0 at 1999-11-17. | 2022-04-25 11:10:03.137
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-09-17. | 2022-04-25 11:10:03.141
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199911-NYMEX.dly has a volume of 0 at 1999-10-15. | 2022-04-25 11:10:03.141
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-08-18. | 2022-04-25 11:10:03.145
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199910-NYMEX.dly has a volume of 0 at 1999-09-16. | 2022-04-25 11:10:03.145
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-07-16. | 2022-04-25 11:10:03.150
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199909-NYMEX.dly has a volume of 0 at 1999-08-17. | 2022-04-25 11:10:03.150
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-06-18. | 2022-04-25 11:10:03.155
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199908-NYMEX.dly has a volume of 0 at 1999-07-15. | 2022-04-25 11:10:03.155
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-05-18. | 2022-04-25 11:10:03.159
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199907-NYMEX.dly has a volume of 0 at 1999-06-17. | 2022-04-25 11:10:03.159
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-04-16. | 2022-04-25 11:10:03.163
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199906-NYMEX.dly has a volume of 0 at 1999-05-17. | 2022-04-25 11:10:03.163
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-03-18. | 2022-04-25 11:10:03.167
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199905-NYMEX.dly has a volume of 0 at 1999-04-15. | 2022-04-25 11:10:03.168
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-02-18. | 2022-04-25 11:10:03.172
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199904-NYMEX.dly has a volume of 0 at 1999-03-17. | 2022-04-25 11:10:03.172
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-01-18. | 2022-04-25 11:10:03.176
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199903-NYMEX.dly has a volume of 0 at 1999-02-17. | 2022-04-25 11:10:03.176
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199902-NYMEX.dly has a volume of 0 at 1998-12-18. | 2022-04-25 11:10:03.180
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199902-NYMEX.dly has a volume of 0 at 1999-01-15. | 2022-04-25 11:10:03.180
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-11-18. | 2022-04-25 11:10:03.184
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199901-NYMEX.dly has a volume of 0 at 1998-12-17. | 2022-04-25 11:10:03.184
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-10-16. | 2022-04-25 11:10:03.189
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199812-NYMEX.dly has a volume of 0 at 1998-11-17. | 2022-04-25 11:10:03.189
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-09-18. | 2022-04-25 11:10:03.193
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199811-NYMEX.dly has a volume of 0 at 1998-10-15. | 2022-04-25 11:10:03.193
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-08-18. | 2022-04-25 11:10:03.198
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199810-NYMEX.dly has a volume of 0 at 1998-09-17. | 2022-04-25 11:10:03.198
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-07-17. | 2022-04-25 11:10:03.202
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199809-NYMEX.dly has a volume of 0 at 1998-08-17. | 2022-04-25 11:10:03.202
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-06-18. | 2022-04-25 11:10:03.206
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199808-NYMEX.dly has a volume of 0 at 1998-07-16. | 2022-04-25 11:10:03.206
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-05-18. | 2022-04-25 11:10:03.211
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199807-NYMEX.dly has a volume of 0 at 1998-06-17. | 2022-04-25 11:10:03.211
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-04-17. | 2022-04-25 11:10:03.215
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199806-NYMEX.dly has a volume of 0 at 1998-05-15. | 2022-04-25 11:10:03.215
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-03-18. | 2022-04-25 11:10:03.219
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199805-NYMEX.dly has a volume of 0 at 1998-04-16. | 2022-04-25 11:10:03.219
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-02-18. | 2022-04-25 11:10:03.223
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199804-NYMEX.dly has a volume of 0 at 1998-03-17. | 2022-04-25 11:10:03.223
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-01-16. | 2022-04-25 11:10:03.228
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199803-NYMEX.dly has a volume of 0 at 1998-02-17. | 2022-04-25 11:10:03.228
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199802-NYMEX.dly has a volume of 0 at 1997-12-18. | 2022-04-25 11:10:03.232
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199802-NYMEX.dly has a volume of 0 at 1998-01-15. | 2022-04-25 11:10:03.232
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-11-18. | 2022-04-25 11:10:03.236
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199801-NYMEX.dly has a volume of 0 at 1997-12-17. | 2022-04-25 11:10:03.236
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-10-17. | 2022-04-25 11:10:03.240
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199712-NYMEX.dly has a volume of 0 at 1997-11-17. | 2022-04-25 11:10:03.240
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-09-18. | 2022-04-25 11:10:03.245
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199711-NYMEX.dly has a volume of 0 at 1997-10-16. | 2022-04-25 11:10:03.245
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-08-18. | 2022-04-25 11:10:03.249
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199710-NYMEX.dly has a volume of 0 at 1997-09-17. | 2022-04-25 11:10:03.249
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-07-18. | 2022-04-25 11:10:03.254
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199709-NYMEX.dly has a volume of 0 at 1997-08-15. | 2022-04-25 11:10:03.254
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-06-18. | 2022-04-25 11:10:03.258
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199708-NYMEX.dly has a volume of 0 at 1997-07-17. | 2022-04-25 11:10:03.258
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-05-16. | 2022-04-25 11:10:03.262
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199707-NYMEX.dly has a volume of 0 at 1997-06-17. | 2022-04-25 11:10:03.262
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-04-18. | 2022-04-25 11:10:03.267
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199706-NYMEX.dly has a volume of 0 at 1997-05-15. | 2022-04-25 11:10:03.267
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-03-18. | 2022-04-25 11:10:03.271
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199705-NYMEX.dly has a volume of 0 at 1997-04-17. | 2022-04-25 11:10:03.271
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-02-18. | 2022-04-25 11:10:03.275
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199704-NYMEX.dly has a volume of 0 at 1997-03-17. | 2022-04-25 11:10:03.275
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-01-17. | 2022-04-25 11:10:03.280
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199703-NYMEX.dly has a volume of 0 at 1997-02-17. | 2022-04-25 11:10:03.280
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199702-NYMEX.dly has a volume of 0 at 1996-12-18. | 2022-04-25 11:10:03.284
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199702-NYMEX.dly has a volume of 0 at 1997-01-16. | 2022-04-25 11:10:03.284
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-11-18. | 2022-04-25 11:10:03.288
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199701-NYMEX.dly has a volume of 0 at 1996-12-17. | 2022-04-25 11:10:03.288
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-10-18. | 2022-04-25 11:10:03.292
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199612-NYMEX.dly has a volume of 0 at 1996-11-15. | 2022-04-25 11:10:03.292
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-09-18. | 2022-04-25 11:10:03.297
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199611-NYMEX.dly has a volume of 0 at 1996-10-17. | 2022-04-25 11:10:03.297
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-08-16. | 2022-04-25 11:10:03.301
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199610-NYMEX.dly has a volume of 0 at 1996-09-17. | 2022-04-25 11:10:03.301
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-07-18. | 2022-04-25 11:10:03.305
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199609-NYMEX.dly has a volume of 0 at 1996-08-15. | 2022-04-25 11:10:03.305
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-06-18. | 2022-04-25 11:10:03.309
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199608-NYMEX.dly has a volume of 0 at 1996-07-17. | 2022-04-25 11:10:03.309
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-05-17. | 2022-04-25 11:10:03.314
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199607-NYMEX.dly has a volume of 0 at 1996-06-17. | 2022-04-25 11:10:03.314
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-04-18. | 2022-04-25 11:10:03.319
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199606-NYMEX.dly has a volume of 0 at 1996-05-16. | 2022-04-25 11:10:03.319
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-03-18. | 2022-04-25 11:10:03.323
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199605-NYMEX.dly has a volume of 0 at 1996-04-17. | 2022-04-25 11:10:03.323
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-02-16. | 2022-04-25 11:10:03.327
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199604-NYMEX.dly has a volume of 0 at 1996-03-15. | 2022-04-25 11:10:03.327
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-01-18. | 2022-04-25 11:10:03.331
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199603-NYMEX.dly has a volume of 0 at 1996-02-15. | 2022-04-25 11:10:03.331
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199602-NYMEX.dly has a volume of 0 at 1995-12-18. | 2022-04-25 11:10:03.336
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199602-NYMEX.dly has a volume of 0 at 1996-01-17. | 2022-04-25 11:10:03.336
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-11-17. | 2022-04-25 11:10:03.340
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199601-NYMEX.dly has a volume of 0 at 1995-12-15. | 2022-04-25 11:10:03.340
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-10-18. | 2022-04-25 11:10:03.344
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199512-NYMEX.dly has a volume of 0 at 1995-11-16. | 2022-04-25 11:10:03.344
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-09-18. | 2022-04-25 11:10:03.348
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199511-NYMEX.dly has a volume of 0 at 1995-10-17. | 2022-04-25 11:10:03.348
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-08-18. | 2022-04-25 11:10:03.352
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199510-NYMEX.dly has a volume of 0 at 1995-09-15. | 2022-04-25 11:10:03.352
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-07-18. | 2022-04-25 11:10:03.357
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199509-NYMEX.dly has a volume of 0 at 1995-08-17. | 2022-04-25 11:10:03.357
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-06-16. | 2022-04-25 11:10:03.361
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199508-NYMEX.dly has a volume of 0 at 1995-07-17. | 2022-04-25 11:10:03.361
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-05-18. | 2022-04-25 11:10:03.366
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199507-NYMEX.dly has a volume of 0 at 1995-06-15. | 2022-04-25 11:10:03.366
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-04-18. | 2022-04-25 11:10:03.370
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199506-NYMEX.dly has a volume of 0 at 1995-05-17. | 2022-04-25 11:10:03.370
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-03-17. | 2022-04-25 11:10:03.374
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199505-NYMEX.dly has a volume of 0 at 1995-04-17. | 2022-04-25 11:10:03.374
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-02-17. | 2022-04-25 11:10:03.378
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199504-NYMEX.dly has a volume of 0 at 1995-03-16. | 2022-04-25 11:10:03.378
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-01-18. | 2022-04-25 11:10:03.383
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199503-NYMEX.dly has a volume of 0 at 1995-02-16. | 2022-04-25 11:10:03.383
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199502-NYMEX.dly has a volume of 0 at 1994-12-16. | 2022-04-25 11:10:03.387
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199502-NYMEX.dly has a volume of 0 at 1995-01-17. | 2022-04-25 11:10:03.387
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-11-18. | 2022-04-25 11:10:03.391
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199501-NYMEX.dly has a volume of 0 at 1994-12-15. | 2022-04-25 11:10:03.391
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-10-18. | 2022-04-25 11:10:03.395
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199412-NYMEX.dly has a volume of 0 at 1994-11-17. | 2022-04-25 11:10:03.395
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-09-16. | 2022-04-25 11:10:03.400
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199411-NYMEX.dly has a volume of 0 at 1994-10-17. | 2022-04-25 11:10:03.400
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-08-18. | 2022-04-25 11:10:03.404
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199410-NYMEX.dly has a volume of 0 at 1994-09-15. | 2022-04-25 11:10:03.404
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-07-18. | 2022-04-25 11:10:03.409
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199409-NYMEX.dly has a volume of 0 at 1994-08-17. | 2022-04-25 11:10:03.409
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-06-17. | 2022-04-25 11:10:03.413
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199408-NYMEX.dly has a volume of 0 at 1994-07-15. | 2022-04-25 11:10:03.413
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-05-18. | 2022-04-25 11:10:03.417
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199407-NYMEX.dly has a volume of 0 at 1994-06-16. | 2022-04-25 11:10:03.417
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-04-18. | 2022-04-25 11:10:03.422
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199406-NYMEX.dly has a volume of 0 at 1994-05-17. | 2022-04-25 11:10:03.422
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-03-18. | 2022-04-25 11:10:03.426
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199405-NYMEX.dly has a volume of 0 at 1994-04-15. | 2022-04-25 11:10:03.426
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-02-18. | 2022-04-25 11:10:03.430
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199404-NYMEX.dly has a volume of 0 at 1994-03-17. | 2022-04-25 11:10:03.430
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-01-18. | 2022-04-25 11:10:03.435
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199403-NYMEX.dly has a volume of 0 at 1994-02-17. | 2022-04-25 11:10:03.435
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199402-NYMEX.dly has a volume of 0 at 1993-12-17. | 2022-04-25 11:10:03.439
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199402-NYMEX.dly has a volume of 0 at 1994-01-17. | 2022-04-25 11:10:03.439
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-11-18. | 2022-04-25 11:10:03.443
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199401-NYMEX.dly has a volume of 0 at 1993-12-16. | 2022-04-25 11:10:03.443
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-10-18. | 2022-04-25 11:10:03.447
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199312-NYMEX.dly has a volume of 0 at 1993-11-17. | 2022-04-25 11:10:03.447
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-09-17. | 2022-04-25 11:10:03.451
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199311-NYMEX.dly has a volume of 0 at 1993-10-15. | 2022-04-25 11:10:03.451
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-08-18. | 2022-04-25 11:10:03.456
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199310-NYMEX.dly has a volume of 0 at 1993-09-16. | 2022-04-25 11:10:03.456
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-07-16. | 2022-04-25 11:10:03.461
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199309-NYMEX.dly has a volume of 0 at 1993-08-17. | 2022-04-25 11:10:03.461
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-06-18. | 2022-04-25 11:10:03.465
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199308-NYMEX.dly has a volume of 0 at 1993-07-15. | 2022-04-25 11:10:03.465
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-05-18. | 2022-04-25 11:10:03.469
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199307-NYMEX.dly has a volume of 0 at 1993-06-17. | 2022-04-25 11:10:03.469
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-04-16. | 2022-04-25 11:10:03.473
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199306-NYMEX.dly has a volume of 0 at 1993-05-17. | 2022-04-25 11:10:03.473
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-03-18. | 2022-04-25 11:10:03.478
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199305-NYMEX.dly has a volume of 0 at 1993-04-15. | 2022-04-25 11:10:03.478
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-02-18. | 2022-04-25 11:10:03.482
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199304-NYMEX.dly has a volume of 0 at 1993-03-17. | 2022-04-25 11:10:03.482
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-01-18. | 2022-04-25 11:10:03.487
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199303-NYMEX.dly has a volume of 0 at 1993-02-17. | 2022-04-25 11:10:03.487
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199302-NYMEX.dly has a volume of 0 at 1992-12-18. | 2022-04-25 11:10:03.491
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199302-NYMEX.dly has a volume of 0 at 1993-01-15. | 2022-04-25 11:10:03.491
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-11-18. | 2022-04-25 11:10:03.495
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199301-NYMEX.dly has a volume of 0 at 1992-12-17. | 2022-04-25 11:10:03.495
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-10-16. | 2022-04-25 11:10:03.500
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199212-NYMEX.dly has a volume of 0 at 1992-11-17. | 2022-04-25 11:10:03.500
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-09-18. | 2022-04-25 11:10:03.504
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199211-NYMEX.dly has a volume of 0 at 1992-10-15. | 2022-04-25 11:10:03.504
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-08-18. | 2022-04-25 11:10:03.509
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199210-NYMEX.dly has a volume of 0 at 1992-09-17. | 2022-04-25 11:10:03.509
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-07-17. | 2022-04-25 11:10:03.513
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199209-NYMEX.dly has a volume of 0 at 1992-08-17. | 2022-04-25 11:10:03.513
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-06-18. | 2022-04-25 11:10:03.517
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199208-NYMEX.dly has a volume of 0 at 1992-07-16. | 2022-04-25 11:10:03.517
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-05-18. | 2022-04-25 11:10:03.522
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199207-NYMEX.dly has a volume of 0 at 1992-06-17. | 2022-04-25 11:10:03.522
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-04-17. | 2022-04-25 11:10:03.526
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199206-NYMEX.dly has a volume of 0 at 1992-05-15. | 2022-04-25 11:10:03.526
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-03-18. | 2022-04-25 11:10:03.530
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199205-NYMEX.dly has a volume of 0 at 1992-04-16. | 2022-04-25 11:10:03.530
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-02-18. | 2022-04-25 11:10:03.535
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199204-NYMEX.dly has a volume of 0 at 1992-03-17. | 2022-04-25 11:10:03.535
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-01-17. | 2022-04-25 11:10:03.539
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199203-NYMEX.dly has a volume of 0 at 1992-02-17. | 2022-04-25 11:10:03.539
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199202-NYMEX.dly has a volume of 0 at 1991-12-18. | 2022-04-25 11:10:03.543
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199202-NYMEX.dly has a volume of 0 at 1992-01-16. | 2022-04-25 11:10:03.543
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-11-18. | 2022-04-25 11:10:03.547
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199201-NYMEX.dly has a volume of 0 at 1991-12-17. | 2022-04-25 11:10:03.547
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-10-18. | 2022-04-25 11:10:03.552
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199112-NYMEX.dly has a volume of 0 at 1991-11-15. | 2022-04-25 11:10:03.552
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-09-18. | 2022-04-25 11:10:03.556
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199111-NYMEX.dly has a volume of 0 at 1991-10-17. | 2022-04-25 11:10:03.556
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-08-16. | 2022-04-25 11:10:03.560
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199110-NYMEX.dly has a volume of 0 at 1991-09-17. | 2022-04-25 11:10:03.560
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-07-18. | 2022-04-25 11:10:03.565
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199109-NYMEX.dly has a volume of 0 at 1991-08-15. | 2022-04-25 11:10:03.565
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-06-18. | 2022-04-25 11:10:03.569
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199108-NYMEX.dly has a volume of 0 at 1991-07-17. | 2022-04-25 11:10:03.569
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-05-17. | 2022-04-25 11:10:03.573
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199107-NYMEX.dly has a volume of 0 at 1991-06-17. | 2022-04-25 11:10:03.573
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-04-18. | 2022-04-25 11:10:03.578
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199106-NYMEX.dly has a volume of 0 at 1991-05-16. | 2022-04-25 11:10:03.578
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-03-18. | 2022-04-25 11:10:03.582
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199105-NYMEX.dly has a volume of 0 at 1991-04-17. | 2022-04-25 11:10:03.582
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-02-18. | 2022-04-25 11:10:03.586
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199104-NYMEX.dly has a volume of 0 at 1991-03-15. | 2022-04-25 11:10:03.586
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-01-18. | 2022-04-25 11:10:03.591
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199103-NYMEX.dly has a volume of 0 at 1991-02-15. | 2022-04-25 11:10:03.591
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199102-NYMEX.dly has a volume of 0 at 1990-12-18. | 2022-04-25 11:10:03.595
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199102-NYMEX.dly has a volume of 0 at 1991-01-17. | 2022-04-25 11:10:03.595
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-11-16. | 2022-04-25 11:10:03.599
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199101-NYMEX.dly has a volume of 0 at 1990-12-17. | 2022-04-25 11:10:03.599
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-10-18. | 2022-04-25 11:10:03.603
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199012-NYMEX.dly has a volume of 0 at 1990-11-15. | 2022-04-25 11:10:03.603
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-09-18. | 2022-04-25 11:10:03.608
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199011-NYMEX.dly has a volume of 0 at 1990-10-17. | 2022-04-25 11:10:03.608
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-08-17. | 2022-04-25 11:10:03.612
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199010-NYMEX.dly has a volume of 0 at 1990-09-17. | 2022-04-25 11:10:03.612
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-07-18. | 2022-04-25 11:10:03.616
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199009-NYMEX.dly has a volume of 0 at 1990-08-16. | 2022-04-25 11:10:03.616
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-06-18. | 2022-04-25 11:10:03.621
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199008-NYMEX.dly has a volume of 0 at 1990-07-17. | 2022-04-25 11:10:03.621
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-05-18. | 2022-04-25 11:10:03.625
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199007-NYMEX.dly has a volume of 0 at 1990-06-15. | 2022-04-25 11:10:03.625
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-04-18. | 2022-04-25 11:10:03.629
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199006-NYMEX.dly has a volume of 0 at 1990-05-17. | 2022-04-25 11:10:03.629
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-03-16. | 2022-04-25 11:10:03.634
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199005-NYMEX.dly has a volume of 0 at 1990-04-17. | 2022-04-25 11:10:03.634
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-02-16. | 2022-04-25 11:10:03.638
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199004-NYMEX.dly has a volume of 0 at 1990-03-15. | 2022-04-25 11:10:03.638
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-01-18. | 2022-04-25 11:10:03.642
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199003-NYMEX.dly has a volume of 0 at 1990-02-15. | 2022-04-25 11:10:03.642
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199002-NYMEX.dly has a volume of 0 at 1989-12-18. | 2022-04-25 11:10:03.646
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199002-NYMEX.dly has a volume of 0 at 1990-01-17. | 2022-04-25 11:10:03.646
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-11-17. | 2022-04-25 11:10:03.650
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-199001-NYMEX.dly has a volume of 0 at 1989-12-15. | 2022-04-25 11:10:03.650
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-10-18. | 2022-04-25 11:10:03.655
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198912-NYMEX.dly has a volume of 0 at 1989-11-16. | 2022-04-25 11:10:03.655
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-09-18. | 2022-04-25 11:10:03.660
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198911-NYMEX.dly has a volume of 0 at 1989-10-17. | 2022-04-25 11:10:03.660
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-08-18. | 2022-04-25 11:10:03.664
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198910-NYMEX.dly has a volume of 0 at 1989-09-15. | 2022-04-25 11:10:03.664
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-07-18. | 2022-04-25 11:10:03.669
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198909-NYMEX.dly has a volume of 0 at 1989-08-17. | 2022-04-25 11:10:03.669
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-06-16. | 2022-04-25 11:10:03.673
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198908-NYMEX.dly has a volume of 0 at 1989-07-17. | 2022-04-25 11:10:03.673
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-05-18. | 2022-04-25 11:10:03.677
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198907-NYMEX.dly has a volume of 0 at 1989-06-15. | 2022-04-25 11:10:03.677
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-04-18. | 2022-04-25 11:10:03.681
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198906-NYMEX.dly has a volume of 0 at 1989-05-17. | 2022-04-25 11:10:03.681
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-03-17. | 2022-04-25 11:10:03.686
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198905-NYMEX.dly has a volume of 0 at 1989-04-17. | 2022-04-25 11:10:03.686
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-02-17. | 2022-04-25 11:10:03.690
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198904-NYMEX.dly has a volume of 0 at 1989-03-16. | 2022-04-25 11:10:03.690
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-01-18. | 2022-04-25 11:10:03.694
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198903-NYMEX.dly has a volume of 0 at 1989-02-16. | 2022-04-25 11:10:03.694
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198902-NYMEX.dly has a volume of 0 at 1988-12-16. | 2022-04-25 11:10:03.698
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198902-NYMEX.dly has a volume of 0 at 1989-01-17. | 2022-04-25 11:10:03.698
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-11-18. | 2022-04-25 11:10:03.702
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198901-NYMEX.dly has a volume of 0 at 1988-12-15. | 2022-04-25 11:10:03.702
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-10-18. | 2022-04-25 11:10:03.707
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198812-NYMEX.dly has a volume of 0 at 1988-11-17. | 2022-04-25 11:10:03.707
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-09-16. | 2022-04-25 11:10:03.711
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198811-NYMEX.dly has a volume of 0 at 1988-10-17. | 2022-04-25 11:10:03.711
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-08-18. | 2022-04-25 11:10:03.715
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198810-NYMEX.dly has a volume of 0 at 1988-09-15. | 2022-04-25 11:10:03.715
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-07-18. | 2022-04-25 11:10:03.720
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198809-NYMEX.dly has a volume of 0 at 1988-08-17. | 2022-04-25 11:10:03.720
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-06-17. | 2022-04-25 11:10:03.724
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198808-NYMEX.dly has a volume of 0 at 1988-07-15. | 2022-04-25 11:10:03.724
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-05-18. | 2022-04-25 11:10:03.729
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198807-NYMEX.dly has a volume of 0 at 1988-06-16. | 2022-04-25 11:10:03.729
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-04-18. | 2022-04-25 11:10:03.733
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198806-NYMEX.dly has a volume of 0 at 1988-05-17. | 2022-04-25 11:10:03.733
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-03-18. | 2022-04-25 11:10:03.737
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198805-NYMEX.dly has a volume of 0 at 1988-04-15. | 2022-04-25 11:10:03.737
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-02-18. | 2022-04-25 11:10:03.742
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198804-NYMEX.dly has a volume of 0 at 1988-03-17. | 2022-04-25 11:10:03.742
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-01-18. | 2022-04-25 11:10:03.746
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198803-NYMEX.dly has a volume of 0 at 1988-02-17. | 2022-04-25 11:10:03.746
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198802-NYMEX.dly has a volume of 0 at 1987-12-18. | 2022-04-25 11:10:03.750
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198802-NYMEX.dly has a volume of 0 at 1988-01-15. | 2022-04-25 11:10:03.750
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-11-18. | 2022-04-25 11:10:03.754
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198801-NYMEX.dly has a volume of 0 at 1987-12-17. | 2022-04-25 11:10:03.755
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-10-16. | 2022-04-25 11:10:03.759
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198712-NYMEX.dly has a volume of 0 at 1987-11-17. | 2022-04-25 11:10:03.759
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-09-18. | 2022-04-25 11:10:03.764
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198711-NYMEX.dly has a volume of 0 at 1987-10-15. | 2022-04-25 11:10:03.764
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-08-18. | 2022-04-25 11:10:03.768
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198710-NYMEX.dly has a volume of 0 at 1987-09-17. | 2022-04-25 11:10:03.768
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-07-17. | 2022-04-25 11:10:03.772
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198709-NYMEX.dly has a volume of 0 at 1987-08-17. | 2022-04-25 11:10:03.772
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-06-18. | 2022-04-25 11:10:03.777
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198708-NYMEX.dly has a volume of 0 at 1987-07-16. | 2022-04-25 11:10:03.777
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-05-18. | 2022-04-25 11:10:03.781
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198707-NYMEX.dly has a volume of 0 at 1987-06-17. | 2022-04-25 11:10:03.781
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-04-17. | 2022-04-25 11:10:03.785
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198706-NYMEX.dly has a volume of 0 at 1987-05-15. | 2022-04-25 11:10:03.785
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-03-18. | 2022-04-25 11:10:03.790
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198705-NYMEX.dly has a volume of 0 at 1987-04-16. | 2022-04-25 11:10:03.790
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-02-18. | 2022-04-25 11:10:03.794
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198704-NYMEX.dly has a volume of 0 at 1987-03-17. | 2022-04-25 11:10:03.794
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-01-16. | 2022-04-25 11:10:03.799
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198703-NYMEX.dly has a volume of 0 at 1987-02-17. | 2022-04-25 11:10:03.799
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198702-NYMEX.dly has a volume of 0 at 1986-12-18. | 2022-04-25 11:10:03.803
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198702-NYMEX.dly has a volume of 0 at 1987-01-15. | 2022-04-25 11:10:03.803
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-11-18. | 2022-04-25 11:10:03.807
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198701-NYMEX.dly has a volume of 0 at 1986-12-17. | 2022-04-25 11:10:03.807
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-10-17. | 2022-04-25 11:10:03.812
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198612-NYMEX.dly has a volume of 0 at 1986-11-17. | 2022-04-25 11:10:03.812
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-09-18. | 2022-04-25 11:10:03.816
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198611-NYMEX.dly has a volume of 0 at 1986-10-16. | 2022-04-25 11:10:03.816
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-08-18. | 2022-04-25 11:10:03.820
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198610-NYMEX.dly has a volume of 0 at 1986-09-17. | 2022-04-25 11:10:03.820
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-07-18. | 2022-04-25 11:10:03.825
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198609-NYMEX.dly has a volume of 0 at 1986-08-15. | 2022-04-25 11:10:03.825
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-06-18. | 2022-04-25 11:10:03.829
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198608-NYMEX.dly has a volume of 0 at 1986-07-17. | 2022-04-25 11:10:03.829
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-05-16. | 2022-04-25 11:10:03.833
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198607-NYMEX.dly has a volume of 0 at 1986-06-17. | 2022-04-25 11:10:03.833
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-04-18. | 2022-04-25 11:10:03.837
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198606-NYMEX.dly has a volume of 0 at 1986-05-15. | 2022-04-25 11:10:03.837
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-03-18. | 2022-04-25 11:10:03.842
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198605-NYMEX.dly has a volume of 0 at 1986-04-17. | 2022-04-25 11:10:03.842
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-02-18. | 2022-04-25 11:10:03.846
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198604-NYMEX.dly has a volume of 0 at 1986-03-17. | 2022-04-25 11:10:03.846
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-01-17. | 2022-04-25 11:10:03.850
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198603-NYMEX.dly has a volume of 0 at 1986-02-17. | 2022-04-25 11:10:03.850
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198602-NYMEX.dly has a volume of 0 at 1985-12-18. | 2022-04-25 11:10:03.854
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198602-NYMEX.dly has a volume of 0 at 1986-01-16. | 2022-04-25 11:10:03.854
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-11-18. | 2022-04-25 11:10:03.859
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198601-NYMEX.dly has a volume of 0 at 1985-12-17. | 2022-04-25 11:10:03.859
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-10-18. | 2022-04-25 11:10:03.863
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198512-NYMEX.dly has a volume of 0 at 1985-11-15. | 2022-04-25 11:10:03.863
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-09-18. | 2022-04-25 11:10:03.867
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198511-NYMEX.dly has a volume of 0 at 1985-10-17. | 2022-04-25 11:10:03.867
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-08-16. | 2022-04-25 11:10:03.872
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198510-NYMEX.dly has a volume of 0 at 1985-09-17. | 2022-04-25 11:10:03.872
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-07-18. | 2022-04-25 11:10:03.876
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198509-NYMEX.dly has a volume of 0 at 1985-08-15. | 2022-04-25 11:10:03.876
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-06-18. | 2022-04-25 11:10:03.880
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198508-NYMEX.dly has a volume of 0 at 1985-07-17. | 2022-04-25 11:10:03.880
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-05-17. | 2022-04-25 11:10:03.885
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198507-NYMEX.dly has a volume of 0 at 1985-06-17. | 2022-04-25 11:10:03.885
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-04-18. | 2022-04-25 11:10:03.889
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198506-NYMEX.dly has a volume of 0 at 1985-05-16. | 2022-04-25 11:10:03.889
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-03-18. | 2022-04-25 11:10:03.893
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198505-NYMEX.dly has a volume of 0 at 1985-04-17. | 2022-04-25 11:10:03.893
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-02-18. | 2022-04-25 11:10:03.897
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198504-NYMEX.dly has a volume of 0 at 1985-03-15. | 2022-04-25 11:10:03.897
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-01-18. | 2022-04-25 11:10:03.901
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198503-NYMEX.dly has a volume of 0 at 1985-02-15. | 2022-04-25 11:10:03.901
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198502-NYMEX.dly has a volume of 0 at 1984-12-18. | 2022-04-25 11:10:03.905
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198502-NYMEX.dly has a volume of 0 at 1985-01-17. | 2022-04-25 11:10:03.905
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-11-16. | 2022-04-25 11:10:03.909
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198501-NYMEX.dly has a volume of 0 at 1984-12-17. | 2022-04-25 11:10:03.909
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-10-18. | 2022-04-25 11:10:03.912
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198412-NYMEX.dly has a volume of 0 at 1984-11-15. | 2022-04-25 11:10:03.912
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-09-18. | 2022-04-25 11:10:03.916
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198411-NYMEX.dly has a volume of 0 at 1984-10-17. | 2022-04-25 11:10:03.916
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-08-17. | 2022-04-25 11:10:03.921
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198410-NYMEX.dly has a volume of 0 at 1984-09-17. | 2022-04-25 11:10:03.921
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-07-18. | 2022-04-25 11:10:03.925
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198409-NYMEX.dly has a volume of 0 at 1984-08-16. | 2022-04-25 11:10:03.925
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-06-18. | 2022-04-25 11:10:03.929
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198408-NYMEX.dly has a volume of 0 at 1984-07-17. | 2022-04-25 11:10:03.929
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-05-18. | 2022-04-25 11:10:03.933
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198407-NYMEX.dly has a volume of 0 at 1984-06-15. | 2022-04-25 11:10:03.933
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-04-18. | 2022-04-25 11:10:03.937
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198406-NYMEX.dly has a volume of 0 at 1984-05-17. | 2022-04-25 11:10:03.937
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-03-16. | 2022-04-25 11:10:03.941
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198405-NYMEX.dly has a volume of 0 at 1984-04-17. | 2022-04-25 11:10:03.941
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-02-17. | 2022-04-25 11:10:03.945
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198404-NYMEX.dly has a volume of 0 at 1984-03-15. | 2022-04-25 11:10:03.945
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-01-18. | 2022-04-25 11:10:03.949
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198403-NYMEX.dly has a volume of 0 at 1984-02-16. | 2022-04-25 11:10:03.949
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198402-NYMEX.dly has a volume of 0 at 1983-12-16. | 2022-04-25 11:10:03.953
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198402-NYMEX.dly has a volume of 0 at 1984-01-17. | 2022-04-25 11:10:03.953
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-11-18. | 2022-04-25 11:10:03.957
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198401-NYMEX.dly has a volume of 0 at 1983-12-15. | 2022-04-25 11:10:03.957
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-10-18. | 2022-04-25 11:10:03.961
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198312-NYMEX.dly has a volume of 0 at 1983-11-17. | 2022-04-25 11:10:03.961
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-09-16. | 2022-04-25 11:10:03.965
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198311-NYMEX.dly has a volume of 0 at 1983-10-17. | 2022-04-25 11:10:03.965
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-08-18. | 2022-04-25 11:10:03.969
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198310-NYMEX.dly has a volume of 0 at 1983-09-15. | 2022-04-25 11:10:03.969
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-07-18. | 2022-04-25 11:10:03.974
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198309-NYMEX.dly has a volume of 0 at 1983-08-17. | 2022-04-25 11:10:03.974
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-06-17. | 2022-04-25 11:10:03.978
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198308-NYMEX.dly has a volume of 0 at 1983-07-15. | 2022-04-25 11:10:03.978
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-05-18. | 2022-04-25 11:10:03.982
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198307-NYMEX.dly has a volume of 0 at 1983-06-16. | 2022-04-25 11:10:03.982
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-04-18. | 2022-04-25 11:10:03.986
CL-202206-NYMEX [C][M] 4 Day #3 | File CL-198306-NYMEX.dly has a volume of 0 at 1983-05-17. | 2022-04-25 11:10:03.986
USOil[M] 4 Day #13 | Reloading chart. | 2022-04-25 11:10:45.906
USOil[M] 2 Day #13 | Reloading chart. | 2022-04-25 11:10:48.536
USOil[M] 8 Day #13 | Reloading chart. | 2022-04-25 11:10:50.714
USOil[M] 16 Day #13 | Reloading chart. | 2022-04-25 11:10:56.668
USOil[M] 32 Day #13 | Reloading chart. | 2022-04-25 11:10:57.907
USOil[M] 4 Day #13 | Reloading chart. | 2022-04-25 11:10:59.422
USOil[M] 2 Day #13 | Reloading chart. | 2022-04-25 11:11:20.922
USOil[M] 4 Day #13 | Reloading chart. | 2022-04-25 11:11:22.748
USOil[M] 8 Day #13 | Reloading chart. | 2022-04-25 11:11:33.575
USOil[M] 4 Day #13 | Reloading chart. | 2022-04-25 11:11:48.721
USOil[M] 16 Day #13 | Reloading chart. | 2022-04-25 11:11:56.166
USOil[M] 4 Day #13 | Reloading chart. | 2022-04-25 11:12:07.464
USOil[M] 2 Day #13 | Reloading chart. | 2022-04-25 11:12:14.556
USOil[M] 8 Day #13 | Reloading chart. | 2022-04-25 11:12:21.238
USOil[M] Daily #13 | Reloading chart. | 2022-04-25 11:12:22.282
USOil[M] 4 Day #13 | Reloading chart. | 2022-04-25 11:12:24.156
USOil[M] Daily #13 | Reloading chart. | 2022-04-25 11:12:25.498
USOil[M] 2 Day #13 | Reloading chart. | 2022-04-25 11:12:27.122
USOil[M] 4 Day #13 | Reloading chart. | 2022-04-25 11:12:28.952
USOil[M] 8 Day #13 | Reloading chart. | 2022-04-25 11:12:30.311
USOil[M] 16 Day #13 | Reloading chart. | 2022-04-25 11:12:31.595
USOil[M] 2 Day #13 | Reloading chart. | 2022-04-25 11:12:35.515
USOil[M] 4 Day #13 | Reloading chart. | 2022-04-25 11:12:36.701
USOil[M] Daily #13 | Reloading chart. | 2022-04-25 11:12:38.167
USOil[M] 4 Day #13 | Reloading chart. | 2022-04-25 11:12:50.466
USOil[M] Daily #13 | Reloading chart. | 2022-04-25 11:12:56.225
Saved Chartbook: MACRO.Cht. Time: 0.0211 seconds. | 2022-04-25 11:13:38.308
Saved Chartbook: SCREENING.Cht. Time: 0.0007 seconds. | 2022-04-25 11:13:38.309
Saved Chartbook: ACTION.Cht. Time: 0.0011 seconds. | 2022-04-25 11:13:38.310
Saved Chartbook: AGGS.Cht. Time: 0.0072 seconds. | 2022-04-25 11:13:38.318
Saved Chartbook: INDICES.Cht. Time: 0.0310 seconds. | 2022-04-25 11:13:38.350
Saved Chartbook: METALS.Cht. Time: 0.0119 seconds. | 2022-04-25 11:13:38.363
Saved Chartbook: ENERGY.Cht. Time: 0.0223 seconds. | 2022-04-25 11:13:38.386
Saved Chartbook: CRYPTO.Cht. Time: 0.0120 seconds. | 2022-04-25 11:13:38.398
Saved Chartbook: FOREX.Cht. Time: 0.0123 seconds. | 2022-04-25 11:13:38.411
Saved Chartbook: AAA.Cht. Time: 0.0230 seconds. | 2022-04-25 11:13:38.435
Saved Chartbook: BBB.Cht. Time: 0.0023 seconds. | 2022-04-25 11:13:38.438
Saved Chartbook: CCC.Cht. Time: 0.0072 seconds. | 2022-04-25 11:13:38.446
Saved Chartbook: DDD.Cht. Time: 0.0111 seconds. | 2022-04-25 11:13:38.458
Saved Chartbook: EEE.Cht. Time: 0.0122 seconds. | 2022-04-25 11:13:38.471
Saved Chartbook: FFF.Cht. Time: 0.0105 seconds. | 2022-04-25 11:13:38.482
Saved Chartbook: GGG.Cht. Time: 0.0121 seconds. | 2022-04-25 11:13:38.495
Saved Chartbook: HHH.Cht. Time: 0.0128 seconds. | 2022-04-25 11:13:38.508
Saved Chartbook: III.Cht. Time: 0.0017 seconds. | 2022-04-25 11:13:38.510
Saved Chartbook: KKK.Cht. Time: 0.0031 seconds. | 2022-04-25 11:13:38.514
Saved Chartbook: LLL.Cht. Time: 0.0125 seconds. | 2022-04-25 11:13:38.527
Saved Chartbook: MMM.Cht. Time: 0.0017 seconds. | 2022-04-25 11:13:38.529
Saved Chartbook: NNN.Cht. Time: 0.0041 seconds. | 2022-04-25 11:13:38.534
Saved Chartbook: OOO.Cht. Time: 0.0029 seconds. | 2022-04-25 11:13:38.538
Saved Chartbook: PPP.Cht. Time: 0.0131 seconds. | 2022-04-25 11:13:38.551
Saved Chartbook: RRR.Cht. Time: 0.0029 seconds. | 2022-04-25 11:13:38.555
Saved Chartbook: SSS.Cht. Time: 0.0035 seconds. | 2022-04-25 11:13:38.559
Saved Chartbook: TTT.Cht. Time: 0.0219 seconds. | 2022-04-25 11:13:38.582
Saved Chartbook: UUU.Cht. Time: 0.0012 seconds. | 2022-04-25 11:13:38.583
Saved Chartbook: VVV.Cht. Time: 0.0032 seconds. | 2022-04-25 11:13:38.587
Saved Chartbook: WWW.Cht. Time: 0.0037 seconds. | 2022-04-25 11:13:38.591
Saved Chartbook: XXX.Cht. Time: 0.0128 seconds. | 2022-04-25 11:13:38.605
Saved Chartbook: ZZZ.Cht. Time: 0.0014 seconds. | 2022-04-25 11:13:38.607
TSLA-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 11:13:46.219
TSLA-NQTV[M] 64 Day #2 | Reloading chart. | 2022-04-25 11:13:48.321
TSLA-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 11:13:56.036
TSLA-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 11:13:59.152
TSLA-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 11:14:10.345
TSLA-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 11:14:23.767
TSLA-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 11:14:33.977
TSLA-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 11:14:36.877
TSLA-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 11:14:37.561
TSLA-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 11:14:38.220
TSLA-NQTV[M] 64 Day #2 | Reloading chart. | 2022-04-25 11:14:39.838
TSLA-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 11:14:41.580
TSLA-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 11:14:42.741
TSLA-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 11:14:46.811
TSLA-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 11:14:49.570
NVDA-NQTV Daily #5 | Reloading chart. | 2022-04-25 11:15:20.612
Added historical Daily data request for NVDA-NQTV to the queue. | 2022-04-25 11:15:20.980
Triggering next historical data download in queue. | 2022-04-25 11:15:20.980
Mapping NVDA-NQTV to NVDA-NQTV. Service code: nasdaq_exchange.data | 2022-04-25 11:15:20.981
SC Data - All Services | Starting real-time market data updates for: NVDA-NQTV (NVDA-NQTV). ID: 184 Service code: nasdaq_exchange.data | 2022-04-25 11:15:20.981
SC Data - All Services | Requesting security definition data for: NVDA-NQTV (NVDA-NQTV). ID: 184 | 2022-04-25 11:15:20.981
HD Request # 223 | Downloading Historical Daily chart data for NVDA-NQTV. Starting date: 2022-04-20. Service: nasdaq_exchange.data | 2022-04-25 11:15:21.030
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 184. Symbol: NVDA-NQTV | 2022-04-25 11:15:21.030
SC Data - All Services | Received security definition for symbol NVDA-NQTV | 2022-04-25 11:15:21.303
HD Request # 223 | Requesting historical Daily data for NVDA starting at 2022-04-19. SC External HD service. | 2022-04-25 11:15:22.460
HD Request # 223 | Receiving historical Daily data for NVDA-NQTV starting at 2022-04-20 | 2022-04-25 11:15:23.345
HD Request # 223 | Writing historical Daily data to the file NVDA-NQTV.dly | 2022-04-25 11:15:23.345
HD Request # 223 | Bytes received: 204 | 2022-04-25 11:15:23.390
HD Request # 223 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for NVDA-NQTV | 2022-04-25 11:15:23.390
HD Request # 223 | Completion time: 2s | 2022-04-25 11:15:23.391
HD Request # 223 | Daily data download complete for NVDA-NQTV. Unique request ID: 224 | 2022-04-25 11:15:23.391
Removing historical data download ID 224. | 2022-04-25 11:15:23.391
Triggering next historical data download in queue. | 2022-04-25 11:15:23.391
No download requests in the queue to start downloads for. | 2022-04-25 11:15:23.391
NVDA-NQTV[M] Daily #5 | Reloading chart. | 2022-04-25 11:15:23.595
NVDA-NQTV[M] 4 Day #5 | Reloading chart. | 2022-04-25 11:15:24.025
NVDA-NQTV[M] Daily #5 | Reloading chart. | 2022-04-25 11:15:37.110
NVDA-NQTV[M] 2 Day #5 | Reloading chart. | 2022-04-25 11:15:41.049
NVDA-NQTV[M] 8 Day #5 | Reloading chart. | 2022-04-25 11:15:51.332
NVDA-NQTV[M] 4 Day #5 | Reloading chart. | 2022-04-25 11:15:53.753
TSLA-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 11:16:15.134
TSLA-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 11:16:17.041
AJG-NQTV[M] 8 Day #19 | Reloading chart. | 2022-04-25 11:22:50.312
AJG-NQTV[M] 16 Day #19 | Reloading chart. | 2022-04-25 11:22:51.839
AJG-NQTV[M] 32 Day #19 | Reloading chart. | 2022-04-25 11:22:52.558
AJG-NQTV[M] 64 Day #19 | Reloading chart. | 2022-04-25 11:22:53.340
AJG-NQTV[M] 32 Day #19 | Reloading chart. | 2022-04-25 11:22:55.658
AJG-NQTV[M] 64 Day #19 | Reloading chart. | 2022-04-25 11:22:59.376
AJG-NQTV[M] 8 Day #19 | Reloading chart. | 2022-04-25 11:23:04.303
AJG-NQTV[M] 4 Day #19 | Reloading chart. | 2022-04-25 11:23:05.422
AJG-NQTV[M] 8 Day #19 | Reloading chart. | 2022-04-25 11:23:11.070
AJG-NQTV[M] 4 Day #19 | Reloading chart. | 2022-04-25 11:23:13.842
AJG-NQTV[M] 2 Day #19 | Reloading chart. | 2022-04-25 11:23:14.798
ACHC-NQTV[M] 8 Day #11 | Reloading chart. | 2022-04-25 11:23:25.474
ACHC-NQTV[M] 16 Day #11 | Reloading chart. | 2022-04-25 11:23:26.501
ACHC-NQTV[M] 32 Day #11 | Reloading chart. | 2022-04-25 11:23:28.400
ACHC-NQTV[M] 64 Day #11 | Reloading chart. | 2022-04-25 11:23:29.405
ACHC-NQTV[M] 8 Day #11 | Reloading chart. | 2022-04-25 11:23:30.333
ACHC-NQTV[M] 32 Day #11 | Reloading chart. | 2022-04-25 11:23:33.546
ACHC-NQTV[M] 64 Day #11 | Reloading chart. | 2022-04-25 11:23:35.609
ACHC-NQTV[M] 8 Day #11 | Reloading chart. | 2022-04-25 11:23:37.063
AMX-NQTV[M] 4 Day #20 | Reloading chart. | 2022-04-25 11:23:40.429
AMX-NQTV[M] 16 Day #20 | Reloading chart. | 2022-04-25 11:23:43.740
AMX-NQTV[M] 32 Day #20 | Reloading chart. | 2022-04-25 11:23:45.765
AMX-NQTV[M] 8 Day #20 | Reloading chart. | 2022-04-25 11:23:50.510
AMX-NQTV[M] 4 Day #20 | Reloading chart. | 2022-04-25 11:23:55.580
AMX-NQTV[M] 2 Day #20 | Reloading chart. | 2022-04-25 11:24:04.058
AMX-NQTV[M] 4 Day #20 | Reloading chart. | 2022-04-25 11:24:14.011
AMX-NQTV[M] 2 Day #20 | Reloading chart. | 2022-04-25 11:24:18.880
AMH-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 11:24:28.539
AMH-NQTV[M] 16 Day #6 | Reloading chart. | 2022-04-25 11:24:30.251
AMH-NQTV[M] 32 Day #6 | Reloading chart. | 2022-04-25 11:24:30.822
AMH-NQTV[M] 64 Day #6 | Reloading chart. | 2022-04-25 11:24:31.408
AMH-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 11:24:32.729
AMH-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 11:24:33.151
AMH-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 11:24:37.420
AMH-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 11:24:38.088
AMH-NQTV[M] Daily #6 | Reloading chart. | 2022-04-25 11:24:41.561
AMH-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 11:24:43.606
AMR-NQTV[M] Daily #5 | Reloading chart. | 2022-04-25 11:24:53.057
AMR-NQTV[M] 2 Day #5 | Reloading chart. | 2022-04-25 11:24:54.796
AMR-NQTV[M] 4 Day #5 | Reloading chart. | 2022-04-25 11:24:55.620
AMR-NQTV[M] 8 Day #5 | Reloading chart. | 2022-04-25 11:24:56.621
AMR-NQTV[M] Daily #5 | Reloading chart. | 2022-04-25 11:24:58.259
AMR-NQTV[M] 4 Day #5 | Reloading chart. | 2022-04-25 11:25:02.831
AMR-NQTV[M] 2 Day #5 | Reloading chart. | 2022-04-25 11:25:03.870
AMR-NQTV[M] Daily #5 | Reloading chart. | 2022-04-25 11:25:05.854
CLH-NQTV[M] 8 Day #8 | Reloading chart. | 2022-04-25 11:25:37.658
CLH-NQTV[M] 16 Day #8 | Reloading chart. | 2022-04-25 11:25:39.568
CLH-NQTV[M] 32 Day #8 | Reloading chart. | 2022-04-25 11:25:40.104
CLH-NQTV[M] 64 Day #8 | Reloading chart. | 2022-04-25 11:25:40.870
CLH-NQTV[M] 8 Day #8 | Reloading chart. | 2022-04-25 11:25:43.517
CLH-NQTV[M] 4 Day #8 | Reloading chart. | 2022-04-25 11:25:45.736
CLH-NQTV[M] 2 Day #8 | Reloading chart. | 2022-04-25 11:25:50.785
CUBE-NQTV[M] 8 Day #10 | Reloading chart. | 2022-04-25 11:26:05.475
CUBE-NQTV[M] 4 Day #10 | Reloading chart. | 2022-04-25 11:26:07.092
CUBE-NQTV[M] 16 Day #10 | Reloading chart. | 2022-04-25 11:26:10.086
CUBE-NQTV[M] 32 Day #10 | Reloading chart. | 2022-04-25 11:26:10.638
CUBE-NQTV[M] 64 Day #10 | Reloading chart. | 2022-04-25 11:26:13.989
CUBE-NQTV[M] 8 Day #10 | Reloading chart. | 2022-04-25 11:26:15.568
CUBE-NQTV[M] 4 Day #10 | Reloading chart. | 2022-04-25 11:26:16.322
CUBE-NQTV[M] Daily #10 | Reloading chart. | 2022-04-25 11:26:23.305
CUBE-NQTV[M] 2 Day #10 | Reloading chart. | 2022-04-25 11:26:26.864
CUBE-NQTV[M] 4 Day #10 | Reloading chart. | 2022-04-25 11:26:32.126
COST-NQTV[M] 4 Day #12 | Reloading chart. | 2022-04-25 11:26:37.610
COST-NQTV[M] 8 Day #12 | Reloading chart. | 2022-04-25 11:26:40.606
COST-NQTV[M] 16 Day #12 | Reloading chart. | 2022-04-25 11:26:41.889
COST-NQTV[M] 32 Day #12 | Reloading chart. | 2022-04-25 11:26:42.639
COST-NQTV[M] 4 Day #12 | Reloading chart. | 2022-04-25 11:26:44.363
COST-NQTV[M] 8 Day #12 | Reloading chart. | 2022-04-25 11:26:48.460
COST-NQTV[M] 4 Day #12 | Reloading chart. | 2022-04-25 11:26:49.561
COST-NQTV[M] 2 Day #12 | Reloading chart. | 2022-04-25 11:26:51.088
COST-NQTV[M] 16 Day #12 | Reloading chart. | 2022-04-25 11:26:53.157
COST-NQTV[M] 4 Day #12 | Reloading chart. | 2022-04-25 11:26:56.519
COST-NQTV[M] 32 Day #12 | Reloading chart. | 2022-04-25 11:26:58.034
COST-NQTV[M] 4 Day #12 | Reloading chart. | 2022-04-25 11:27:00.525
CALM-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 11:27:14.544
CALM-NQTV[M] Daily #6 | Reloading chart. | 2022-04-25 11:27:20.079
CALM-NQTV[M] 128 Min #7 | Reloading chart. | 2022-04-25 11:27:24.066
CALM-NQTV[M] 256 Min #7 | Reloading chart. | 2022-04-25 11:27:29.932
CALM-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 11:27:42.238
CALM-NQTV[M] 2 Day #6 | Reloading chart. | 2022-04-25 11:27:43.880
CALM-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 11:27:45.394
CALM-NQTV[M] 2 Day #6 | Reloading chart. | 2022-04-25 11:27:49.154
CALM-NQTV[M] Daily #6 | Reloading chart. | 2022-04-25 11:27:49.608
CALM-NQTV[M] 2 Day #6 | Reloading chart. | 2022-04-25 11:27:50.341
CALM-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 11:27:53.211
CALM-NQTV[M] Daily #6 | Reloading chart. | 2022-04-25 11:28:00.879
CALM-NQTV[M] 128 Min #7 | Reloading chart. | 2022-04-25 11:28:08.520
CALM-NQTV[M] 64 Min #7 | Reloading chart. | 2022-04-25 11:28:30.879
CALM-NQTV 64 Min #9 | Reloading chart. | 2022-04-25 11:28:43.488
CALM-NQTV[M] 128 Min #7 | Reloading chart. | 2022-04-25 11:28:55.744
CALM-NQTV[M] 256 Min #7 | Reloading chart. | 2022-04-25 11:28:58.271
CALM-NQTV[M] 128 Min #7 | Reloading chart. | 2022-04-25 11:28:59.776
CALM-NQTV[M] 64 Min #9 | Reloading chart. | 2022-04-25 11:29:18.009
Saved Chartbook: MACRO.Cht. Time: 0.0220 seconds. | 2022-04-25 11:33:38.620
Saved Chartbook: SCREENING.Cht. Time: 0.0007 seconds. | 2022-04-25 11:33:38.621
Saved Chartbook: ACTION.Cht. Time: 0.0011 seconds. | 2022-04-25 11:33:38.623
Saved Chartbook: AGGS.Cht. Time: 0.0072 seconds. | 2022-04-25 11:33:38.631
Saved Chartbook: INDICES.Cht. Time: 0.0335 seconds. | 2022-04-25 11:33:38.665
Saved Chartbook: METALS.Cht. Time: 0.0117 seconds. | 2022-04-25 11:33:38.677
Saved Chartbook: ENERGY.Cht. Time: 0.0229 seconds. | 2022-04-25 11:33:38.701
Saved Chartbook: CRYPTO.Cht. Time: 0.0126 seconds. | 2022-04-25 11:33:38.714
Saved Chartbook: FOREX.Cht. Time: 0.0134 seconds. | 2022-04-25 11:33:38.728
Saved Chartbook: AAA.Cht. Time: 0.0222 seconds. | 2022-04-25 11:33:38.751
Saved Chartbook: BBB.Cht. Time: 0.0024 seconds. | 2022-04-25 11:33:38.754
Saved Chartbook: CCC.Cht. Time: 0.0244 seconds. | 2022-04-25 11:33:38.779
Saved Chartbook: DDD.Cht. Time: 0.0113 seconds. | 2022-04-25 11:33:38.791
Saved Chartbook: EEE.Cht. Time: 0.0115 seconds. | 2022-04-25 11:33:38.803
Saved Chartbook: FFF.Cht. Time: 0.0035 seconds. | 2022-04-25 11:33:38.807
Saved Chartbook: GGG.Cht. Time: 0.0034 seconds. | 2022-04-25 11:33:38.811
Saved Chartbook: HHH.Cht. Time: 0.0140 seconds. | 2022-04-25 11:33:38.826
Saved Chartbook: III.Cht. Time: 0.0017 seconds. | 2022-04-25 11:33:38.828
Saved Chartbook: KKK.Cht. Time: 0.0031 seconds. | 2022-04-25 11:33:38.831
Saved Chartbook: LLL.Cht. Time: 0.0041 seconds. | 2022-04-25 11:33:38.836
Saved Chartbook: MMM.Cht. Time: 0.0024 seconds. | 2022-04-25 11:33:38.839
Saved Chartbook: NNN.Cht. Time: 0.0034 seconds. | 2022-04-25 11:33:38.843
Saved Chartbook: OOO.Cht. Time: 0.0031 seconds. | 2022-04-25 11:33:38.847
Saved Chartbook: PPP.Cht. Time: 0.0063 seconds. | 2022-04-25 11:33:38.854
Saved Chartbook: RRR.Cht. Time: 0.0030 seconds. | 2022-04-25 11:33:38.857
Saved Chartbook: SSS.Cht. Time: 0.0033 seconds. | 2022-04-25 11:33:38.861
Saved Chartbook: TTT.Cht. Time: 0.0227 seconds. | 2022-04-25 11:33:38.885
Saved Chartbook: UUU.Cht. Time: 0.0013 seconds. | 2022-04-25 11:33:38.886
Saved Chartbook: VVV.Cht. Time: 0.0030 seconds. | 2022-04-25 11:33:38.890
Saved Chartbook: WWW.Cht. Time: 0.0037 seconds. | 2022-04-25 11:33:38.894
Saved Chartbook: XXX.Cht. Time: 0.0047 seconds. | 2022-04-25 11:33:38.900
Saved Chartbook: ZZZ.Cht. Time: 0.0015 seconds. | 2022-04-25 11:33:38.901
Saved Chartbook: MACRO.Cht. Time: 0.0217 seconds. | 2022-04-25 11:53:38.920
Saved Chartbook: SCREENING.Cht. Time: 0.0008 seconds. | 2022-04-25 11:53:38.921
Saved Chartbook: ACTION.Cht. Time: 0.0011 seconds. | 2022-04-25 11:53:38.923
Saved Chartbook: AGGS.Cht. Time: 0.0074 seconds. | 2022-04-25 11:53:38.931
Saved Chartbook: INDICES.Cht. Time: 0.0331 seconds. | 2022-04-25 11:53:38.965
Saved Chartbook: METALS.Cht. Time: 0.0116 seconds. | 2022-04-25 11:53:38.977
Saved Chartbook: ENERGY.Cht. Time: 0.0224 seconds. | 2022-04-25 11:53:39.000
Saved Chartbook: CRYPTO.Cht. Time: 0.0134 seconds. | 2022-04-25 11:53:39.014
Saved Chartbook: FOREX.Cht. Time: 0.0120 seconds. | 2022-04-25 11:53:39.027
Saved Chartbook: AAA.Cht. Time: 0.0217 seconds. | 2022-04-25 11:53:39.049
Saved Chartbook: BBB.Cht. Time: 0.0024 seconds. | 2022-04-25 11:53:39.052
Saved Chartbook: CCC.Cht. Time: 0.0231 seconds. | 2022-04-25 11:53:39.076
Saved Chartbook: DDD.Cht. Time: 0.0114 seconds. | 2022-04-25 11:53:39.088
Saved Chartbook: EEE.Cht. Time: 0.0120 seconds. | 2022-04-25 11:53:39.101
Saved Chartbook: FFF.Cht. Time: 0.0121 seconds. | 2022-04-25 11:53:39.113
Saved Chartbook: GGG.Cht. Time: 0.0034 seconds. | 2022-04-25 11:53:39.117
Saved Chartbook: HHH.Cht. Time: 0.0132 seconds. | 2022-04-25 11:53:39.131
Saved Chartbook: III.Cht. Time: 0.0017 seconds. | 2022-04-25 11:53:39.134
Saved Chartbook: KKK.Cht. Time: 0.0029 seconds. | 2022-04-25 11:53:39.137
Saved Chartbook: LLL.Cht. Time: 0.0043 seconds. | 2022-04-25 11:53:39.142
Saved Chartbook: MMM.Cht. Time: 0.0022 seconds. | 2022-04-25 11:53:39.145
Saved Chartbook: NNN.Cht. Time: 0.0035 seconds. | 2022-04-25 11:53:39.149
Saved Chartbook: OOO.Cht. Time: 0.0029 seconds. | 2022-04-25 11:53:39.152
Saved Chartbook: PPP.Cht. Time: 0.0060 seconds. | 2022-04-25 11:53:39.159
Saved Chartbook: RRR.Cht. Time: 0.0032 seconds. | 2022-04-25 11:53:39.163
Saved Chartbook: SSS.Cht. Time: 0.0035 seconds. | 2022-04-25 11:53:39.167
Saved Chartbook: TTT.Cht. Time: 0.0067 seconds. | 2022-04-25 11:53:39.174
Saved Chartbook: UUU.Cht. Time: 0.0028 seconds. | 2022-04-25 11:53:39.178
Saved Chartbook: VVV.Cht. Time: 0.0030 seconds. | 2022-04-25 11:53:39.181
Saved Chartbook: WWW.Cht. Time: 0.0039 seconds. | 2022-04-25 11:53:39.186
Saved Chartbook: XXX.Cht. Time: 0.0039 seconds. | 2022-04-25 11:53:39.191
Saved Chartbook: ZZZ.Cht. Time: 0.0025 seconds. | 2022-04-25 11:53:39.193
AJG-NQTV[M] 8 Day #19 | Reloading chart. | 2022-04-25 11:54:00.866
AJG-NQTV[M] 32 Day #19 | Reloading chart. | 2022-04-25 11:54:04.150
AJG-NQTV[M] 4 Day #19 | Reloading chart. | 2022-04-25 11:54:06.253
AJG-NQTV[M] 2 Day #19 | Reloading chart. | 2022-04-25 11:54:08.777
ACHC-NQTV[M] 8 Day #11 | Reloading chart. | 2022-04-25 11:54:23.958
ACHC-NQTV[M] 16 Day #11 | Reloading chart. | 2022-04-25 11:54:24.861
ACHC-NQTV[M] 32 Day #11 | Reloading chart. | 2022-04-25 11:54:26.077
ACHC-NQTV[M] 64 Day #11 | Reloading chart. | 2022-04-25 11:54:27.282
ACHC-NQTV[M] 8 Day #11 | Reloading chart. | 2022-04-25 11:54:28.643
ACHC-NQTV[M] 4 Day #11 | Reloading chart. | 2022-04-25 11:54:30.577
ACHC-NQTV[M] 2 Day #11 | Reloading chart. | 2022-04-25 11:54:32.504
ACHC-NQTV[M] 4 Day #11 | Reloading chart. | 2022-04-25 11:54:35.068
ACHC-NQTV[M] 2 Day #11 | Reloading chart. | 2022-04-25 11:54:38.022
AMX-NQTV[M] 4 Day #20 | Reloading chart. | 2022-04-25 11:54:41.992
AMX-NQTV[M] 8 Day #20 | Reloading chart. | 2022-04-25 11:54:44.517
AMX-NQTV[M] 16 Day #20 | Reloading chart. | 2022-04-25 11:54:46.638
AMX-NQTV[M] 32 Day #20 | Reloading chart. | 2022-04-25 11:54:47.362
AMX-NQTV[M] 4 Day #20 | Reloading chart. | 2022-04-25 11:54:49.148
AJG-NQTV[M] 64 Day #19 | Reloading chart. | 2022-04-25 11:55:05.192
AJG-NQTV[M] 128 Day #19 | Reloading chart. | 2022-04-25 11:55:24.158
AJG-NQTV[M] 64 Day #19 | Reloading chart. | 2022-04-25 11:55:25.465
BILI Daily #3 | Reloading chart. | 2022-04-25 11:55:54.540
Added historical Daily data request for BILI to the queue. | 2022-04-25 11:55:54.791
Triggering next historical data download in queue. | 2022-04-25 11:55:54.791
Interactive Brokers | Starting real-time market data updates for: BILI. ID: 185 | 2022-04-25 11:55:54.791
Interactive Brokers | Subscribing to real-time True Data for symbol: BILI SecurityType: STK Exchange: SMART Currency: | 2022-04-25 11:55:54.791
Interactive Brokers | Subscribing to Symbol: BILI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2022-04-25 11:55:54.791
Interactive Brokers | Requesting security definition data for: BILI. ID: 185 | 2022-04-25 11:55:54.791
HD Request # 224 | Downloading Historical Daily chart data for BILI. Starting date: 2022-04-20. Service: interactive_brokers.trading | 2022-04-25 11:55:54.838
Interactive Brokers | Market data type is Live for BILI | 2022-04-25 11:55:55.251
HD Request # 224 | Requesting historical Daily data for BILI starting at 2022-04-19. SC External HD service. | 2022-04-25 11:55:56.261
HD Request # 224 | Receiving historical Daily data for BILI starting at 2022-04-20 | 2022-04-25 11:55:57.268
HD Request # 224 | Writing historical Daily data to the file BILI.dly | 2022-04-25 11:55:57.268
HD Request # 224 | Bytes received: 191 | 2022-04-25 11:55:57.277
HD Request # 224 | Received 4 Daily data records from 2022-04-20 00:00:00 to 2022-04-22 00:00:00 (3.0 days) and wrote 3 records for BILI | 2022-04-25 11:55:57.277
HD Request # 224 | Completion time: 3s | 2022-04-25 11:55:57.277
HD Request # 224 | Daily data download complete for BILI. Unique request ID: 225 | 2022-04-25 11:55:57.277
Removing historical data download ID 225. | 2022-04-25 11:55:57.277
Triggering next historical data download in queue. | 2022-04-25 11:55:57.277
No download requests in the queue to start downloads for. | 2022-04-25 11:55:57.277
BILI Daily #3 | Reloading chart. | 2022-04-25 11:55:57.327
BILI 4 Day #3 | Reloading chart. | 2022-04-25 11:56:05.971
BILI 8 Day #3 | Reloading chart. | 2022-04-25 11:56:09.219
BILI 32 Day #3 | Reloading chart. | 2022-04-25 11:56:22.030
BILI 16 Day #3 | Reloading chart. | 2022-04-25 11:56:26.776
BILI 32 Day #3 | Reloading chart. | 2022-04-25 11:56:30.484
BILI 64 Day #3 | Reloading chart. | 2022-04-25 11:56:39.462
BILI 8 Day #3 | Reloading chart. | 2022-04-25 11:56:40.692
BILI 32 Day #3 | Reloading chart. | 2022-04-25 11:56:45.612
APPS Daily #4 | Reloading chart. | 2022-04-25 11:56:58.834
Added historical Daily data request for APPS to the queue. | 2022-04-25 11:56:59.077
Triggering next historical data download in queue. | 2022-04-25 11:56:59.077
Interactive Brokers | Starting real-time market data updates for: APPS. ID: 186 | 2022-04-25 11:56:59.077
Interactive Brokers | Subscribing to real-time True Data for symbol: APPS SecurityType: STK Exchange: SMART Currency: | 2022-04-25 11:56:59.078
Interactive Brokers | Subscribing to Symbol: APPS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2022-04-25 11:56:59.078
Interactive Brokers | Requesting security definition data for: APPS. ID: 186 | 2022-04-25 11:56:59.078
HD Request # 225 | Downloading Historical Daily chart data for APPS. Starting date: 2022-04-08. Service: interactive_brokers.trading | 2022-04-25 11:56:59.126
Symbol Error - APPS is unknown, unavailable, or improperly formatted. The contract description specified for APPS is ambiguous;
you must specify the currency. | 2022-04-25 11:56:59.525
Interactive Brokers | Market data type is Live for APPS | 2022-04-25 11:56:59.573
HD Request # 225 | Requesting historical Daily data for APPS starting at 2022-04-07. SC External HD service. | 2022-04-25 11:57:00.536
HD Request # 225 | Receiving historical Daily data for APPS starting at 2022-04-08 | 2022-04-25 11:57:01.365
HD Request # 225 | Writing historical Daily data to the file APPS.dly | 2022-04-25 11:57:01.365
HD Request # 225 | Bytes received: 526 | 2022-04-25 11:57:01.390
HD Request # 225 | Received 11 Daily data records from 2022-04-08 00:00:00 to 2022-04-22 00:00:00 (15.0 days) and wrote 10 records for APPS | 2022-04-25 11:57:01.390
HD Request # 225 | Completion time: 2s | 2022-04-25 11:57:01.390
HD Request # 225 | Daily data download complete for APPS. Unique request ID: 226 | 2022-04-25 11:57:01.390
Removing historical data download ID 226. | 2022-04-25 11:57:01.390
Triggering next historical data download in queue. | 2022-04-25 11:57:01.390
No download requests in the queue to start downloads for. | 2022-04-25 11:57:01.390
APPS Daily #4 | Reloading chart. | 2022-04-25 11:57:01.457
APPS 4 Day #4 | Reloading chart. | 2022-04-25 11:57:08.762
APPS 8 Day #4 | Reloading chart. | 2022-04-25 11:57:10.718
APPS 16 Day #4 | Reloading chart. | 2022-04-25 11:57:13.663
APPS 4 Day #4 | Reloading chart. | 2022-04-25 11:57:17.548
APPS 16 Day #4 | Reloading chart. | 2022-04-25 11:57:20.876
APPS 32 Day #4 | Reloading chart. | 2022-04-25 11:57:21.819
APPS 64 Day #4 | Reloading chart. | 2022-04-25 11:57:26.442
APPS 16 Day #4 | Reloading chart. | 2022-04-25 11:57:30.118
APPS 64 Day #4 | Reloading chart. | 2022-04-25 11:57:35.098
APPS 16 Day #4 | Reloading chart. | 2022-04-25 11:57:39.284
FWONK-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 11:57:49.731
FWONK-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 11:57:52.659
FWONK-NQTV[M] 16 Day #3 | Reloading chart. | 2022-04-25 11:57:53.721
FWONK-NQTV[M] 32 Day #3 | Reloading chart. | 2022-04-25 11:57:54.403
FWONK-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 11:57:55.586
FWONK-NQTV[M] 32 Day #3 | Reloading chart. | 2022-04-25 11:57:59.388
FWONK-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 11:58:02.036
FWONK-NQTV[M] 32 Day #3 | Reloading chart. | 2022-04-25 11:58:03.466
FWONK-NQTV[M] 16 Day #3 | Reloading chart. | 2022-04-25 11:58:04.514
FWONK-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 11:58:07.114
FWONK-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 11:58:08.216
FWONK-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 11:58:13.701
FWONK-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 11:58:18.251
FWONK-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 11:58:19.608
ACHC-NQTV[M] 8 Day #11 | Reloading chart. | 2022-04-25 12:02:25.509
ACHC-NQTV[M] 4 Day #11 | Reloading chart. | 2022-04-25 12:02:26.570
ACHC-NQTV[M] 2 Day #11 | Reloading chart. | 2022-04-25 12:02:28.848
ACHC-NQTV[M] 4 Day #11 | Reloading chart. | 2022-04-25 12:02:33.617
AMH-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 12:02:52.845
AMH-NQTV[M] 16 Day #6 | Reloading chart. | 2022-04-25 12:02:54.012
AMH-NQTV[M] 32 Day #6 | Reloading chart. | 2022-04-25 12:02:54.522
AMH-NQTV[M] 64 Day #6 | Reloading chart. | 2022-04-25 12:02:55.758
AMH-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 12:02:58.080
AMH-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 12:02:59.790
AMH-NQTV[M] Daily #6 | Reloading chart. | 2022-04-25 12:03:08.215
AMH-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 12:03:12.113
AMH-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 12:03:12.549
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 8 Day #2 | Reloading chart. | 2022-04-25 12:03:28.916
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 8 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 12:03:28.935
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 32 Day #2 | Reloading chart. | 2022-04-25 12:03:31.402
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 32 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 12:03:31.421
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 8 Day #2 | Reloading chart. | 2022-04-25 12:03:33.626
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 8 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 12:03:33.646
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 4 Day #2 | Reloading chart. | 2022-04-25 12:03:34.044
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 4 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 12:03:34.064
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | Reloading chart. | 2022-04-25 12:03:35.534
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 12:03:35.554
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD Daily #2 | Reloading chart. | 2022-04-25 12:03:39.053
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD Daily #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 12:03:39.087
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | Reloading chart. | 2022-04-25 12:03:51.792
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 12:03:51.811
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 44 Day #2 | Reloading chart. | 2022-04-25 12:03:55.739
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 44 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 12:03:55.757
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | Reloading chart. | 2022-04-25 12:03:56.790
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 12:03:56.811
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 4 Day #2 | Reloading chart. | 2022-04-25 12:03:58.927
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 4 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 12:03:58.947
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | Reloading chart. | 2022-04-25 12:04:07.773
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 2 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 12:04:07.793
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 4 Day #2 | Reloading chart. | 2022-04-25 12:04:08.698
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 4 Day #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 12:04:08.730
AMR-NQTV[M] Daily #5 | Reloading chart. | 2022-04-25 12:04:17.260
AMR-NQTV[M] 4 Day #5 | Reloading chart. | 2022-04-25 12:04:19.495
AMR-NQTV[M] 8 Day #5 | Reloading chart. | 2022-04-25 12:04:21.346
AMR-NQTV[M] Daily #5 | Reloading chart. | 2022-04-25 12:04:23.584
AMR-NQTV[M] 2 Day #5 | Reloading chart. | 2022-04-25 12:04:24.305
AMR-NQTV[M] Daily #5 | Reloading chart. | 2022-04-25 12:04:26.147
AA-NQTV[M] 2 Day #9 | Reloading chart. | 2022-04-25 12:04:30.491
AA-NQTV[M] 8 Day #9 | Reloading chart. | 2022-04-25 12:04:35.542
AA-NQTV[M] 2 Day #9 | Reloading chart. | 2022-04-25 12:04:37.031
BJ-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:09:09.941
BJ-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 12:09:11.407
BJ-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 12:09:12.375
BJ-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 12:09:13.077
BJ-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:09:14.697
BJ-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 12:09:15.265
BJ-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 12:09:20.031
BJ-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 12:09:23.386
AMH-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 12:09:50.028
AMH-NQTV[M] 16 Day #6 | Reloading chart. | 2022-04-25 12:09:51.259
AMH-NQTV[M] 32 Day #6 | Reloading chart. | 2022-04-25 12:09:52.551
AMH-NQTV[M] 64 Day #6 | Reloading chart. | 2022-04-25 12:10:00.272
AMH-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 12:10:02.124
AMH-NQTV[M] 2 Day #6 | Reloading chart. | 2022-04-25 12:10:02.701
AMH-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 12:10:03.665
AMH-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 12:10:54.503
AMH-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 12:11:01.983
AMH-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 12:11:03.383
AMH-NQTV[M] 16 Day #6 | Reloading chart. | 2022-04-25 12:11:06.126
AMH-NQTV[M] 32 Day #6 | Reloading chart. | 2022-04-25 12:11:06.760
AMH-NQTV[M] 64 Day #6 | Reloading chart. | 2022-04-25 12:11:07.780
AMH-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 12:11:09.431
AMH-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 12:11:16.004
AMH-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 12:11:17.072
AMH-NQTV[M] Daily #6 | Reloading chart. | 2022-04-25 12:11:26.142
AMH-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 12:11:27.670
AMR-NQTV[M] Daily #5 | Reloading chart. | 2022-04-25 12:11:50.011
AMR-NQTV[M] 4 Day #5 | Reloading chart. | 2022-04-25 12:11:51.790
AMR-NQTV[M] 8 Day #5 | Reloading chart. | 2022-04-25 12:11:53.063
AMR-NQTV[M] 2 Day #5 | Reloading chart. | 2022-04-25 12:11:54.917
AMR-NQTV[M] Daily #5 | Reloading chart. | 2022-04-25 12:11:56.090
BJ-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:12:20.117
BJ-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 12:12:21.192
BJ-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 12:12:22.002
BJ-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 12:12:22.658
BJ-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:12:24.103
BJ-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 12:12:31.779
BJ-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 12:12:32.620
BJ-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 12:12:33.190
BJ-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:12:34.769
BJ-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 12:12:37.002
BJ-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 12:12:37.650
BJ-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 12:12:38.263
BJ-NQTV[M] 64 Day #2 | Reloading chart. | 2022-04-25 12:12:39.533
BJ-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 12:12:44.464
BJ-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:12:45.756
BJ-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 12:12:46.588
BJ-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 12:12:50.605
BJ-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 12:12:52.447
CLH-NQTV[M] 8 Day #8 | Reloading chart. | 2022-04-25 12:13:10.683
CLH-NQTV[M] 16 Day #8 | Reloading chart. | 2022-04-25 12:13:12.837
CLH-NQTV[M] 32 Day #8 | Reloading chart. | 2022-04-25 12:13:13.496
CLH-NQTV[M] 64 Day #8 | Reloading chart. | 2022-04-25 12:13:18.355
CLH-NQTV[M] 8 Day #8 | Reloading chart. | 2022-04-25 12:13:19.868
CLH-NQTV[M] 4 Day #8 | Reloading chart. | 2022-04-25 12:13:25.232
CLH-NQTV[M] 2 Day #8 | Reloading chart. | 2022-04-25 12:13:32.030
CLH-NQTV[M] 4 Day #8 | Reloading chart. | 2022-04-25 12:13:34.072
Saved Chartbook: MACRO.Cht. Time: 0.0214 seconds. | 2022-04-25 12:13:39.277
Saved Chartbook: SCREENING.Cht. Time: 0.0008 seconds. | 2022-04-25 12:13:39.278
Saved Chartbook: ACTION.Cht. Time: 0.0011 seconds. | 2022-04-25 12:13:39.279
Saved Chartbook: AGGS.Cht. Time: 0.0076 seconds. | 2022-04-25 12:13:39.288
Saved Chartbook: INDICES.Cht. Time: 0.0328 seconds. | 2022-04-25 12:13:39.321
Saved Chartbook: METALS.Cht. Time: 0.0120 seconds. | 2022-04-25 12:13:39.334
Saved Chartbook: ENERGY.Cht. Time: 0.0225 seconds. | 2022-04-25 12:13:39.357
Saved Chartbook: CRYPTO.Cht. Time: 0.0133 seconds. | 2022-04-25 12:13:39.371
Saved Chartbook: FOREX.Cht. Time: 0.0049 seconds. | 2022-04-25 12:13:39.377
Saved Chartbook: AAA.Cht. Time: 0.0056 seconds. | 2022-04-25 12:13:39.383
Saved Chartbook: BBB.Cht. Time: 0.0028 seconds. | 2022-04-25 12:13:39.387
Saved Chartbook: CCC.Cht. Time: 0.0230 seconds. | 2022-04-25 12:13:39.410
Saved Chartbook: DDD.Cht. Time: 0.0109 seconds. | 2022-04-25 12:13:39.422
Saved Chartbook: EEE.Cht. Time: 0.0116 seconds. | 2022-04-25 12:13:39.434
Saved Chartbook: FFF.Cht. Time: 0.0113 seconds. | 2022-04-25 12:13:39.446
Saved Chartbook: GGG.Cht. Time: 0.0035 seconds. | 2022-04-25 12:13:39.450
Saved Chartbook: HHH.Cht. Time: 0.0132 seconds. | 2022-04-25 12:13:39.464
Saved Chartbook: III.Cht. Time: 0.0018 seconds. | 2022-04-25 12:13:39.466
Saved Chartbook: KKK.Cht. Time: 0.0031 seconds. | 2022-04-25 12:13:39.470
Saved Chartbook: LLL.Cht. Time: 0.0115 seconds. | 2022-04-25 12:13:39.482
Saved Chartbook: MMM.Cht. Time: 0.0019 seconds. | 2022-04-25 12:13:39.485
Saved Chartbook: NNN.Cht. Time: 0.0038 seconds. | 2022-04-25 12:13:39.489
Saved Chartbook: OOO.Cht. Time: 0.0032 seconds. | 2022-04-25 12:13:39.493
Saved Chartbook: PPP.Cht. Time: 0.0132 seconds. | 2022-04-25 12:13:39.507
Saved Chartbook: RRR.Cht. Time: 0.0030 seconds. | 2022-04-25 12:13:39.510
Saved Chartbook: SSS.Cht. Time: 0.0036 seconds. | 2022-04-25 12:13:39.515
Saved Chartbook: TTT.Cht. Time: 0.0212 seconds. | 2022-04-25 12:13:39.537
Saved Chartbook: UUU.Cht. Time: 0.0013 seconds. | 2022-04-25 12:13:39.538
Saved Chartbook: VVV.Cht. Time: 0.0034 seconds. | 2022-04-25 12:13:39.542
Saved Chartbook: WWW.Cht. Time: 0.0044 seconds. | 2022-04-25 12:13:39.547
Saved Chartbook: XXX.Cht. Time: 0.0042 seconds. | 2022-04-25 12:13:39.552
Saved Chartbook: ZZZ.Cht. Time: 0.0018 seconds. | 2022-04-25 12:13:39.554
CUBE-NQTV[M] 8 Day #10 | Reloading chart. | 2022-04-25 12:13:41.678
CUBE-NQTV[M] 16 Day #10 | Reloading chart. | 2022-04-25 12:13:43.033
CUBE-NQTV[M] 32 Day #10 | Reloading chart. | 2022-04-25 12:13:43.754
CUBE-NQTV[M] 64 Day #10 | Reloading chart. | 2022-04-25 12:13:44.572
CUBE-NQTV[M] 4 Day #10 | Reloading chart. | 2022-04-25 12:13:56.331
CUBE-NQTV[M] 8 Day #10 | Reloading chart. | 2022-04-25 12:14:05.739
CUBE-NQTV[M] 8 Day #10 | Reloading chart. | 2022-04-25 12:14:37.651
CUBE-NQTV[M] 16 Day #10 | Reloading chart. | 2022-04-25 12:14:39.169
CUBE-NQTV[M] 32 Day #10 | Reloading chart. | 2022-04-25 12:14:40.862
CUBE-NQTV[M] 64 Day #10 | Reloading chart. | 2022-04-25 12:14:42.383
CUBE-NQTV[M] 8 Day #10 | Reloading chart. | 2022-04-25 12:14:48.363
CUBE-NQTV[M] 4 Day #10 | Reloading chart. | 2022-04-25 12:14:49.930
CUBE-NQTV[M] Daily #10 | Reloading chart. | 2022-04-25 12:14:56.673
CUBE-NQTV[M] 4 Day #10 | Reloading chart. | 2022-04-25 12:15:02.156
COST-NQTV[M] 4 Day #12 | Reloading chart. | 2022-04-25 12:15:12.130
COST-NQTV[M] 8 Day #12 | Reloading chart. | 2022-04-25 12:15:13.608
COST-NQTV[M] 16 Day #12 | Reloading chart. | 2022-04-25 12:15:14.365
COST-NQTV[M] 32 Day #12 | Reloading chart. | 2022-04-25 12:15:14.949
COST-NQTV[M] 4 Day #12 | Reloading chart. | 2022-04-25 12:15:16.815
COST-NQTV[M] 2 Day #12 | Reloading chart. | 2022-04-25 12:15:19.213
COST-NQTV[M] 4 Day #12 | Reloading chart. | 2022-04-25 12:15:23.308
COST-NQTV[M] 2 Day #12 | Reloading chart. | 2022-04-25 12:15:31.103
COST-NQTV[M] Daily #12 | Reloading chart. | 2022-04-25 12:15:34.471
COST-NQTV[M] 2 Day #12 | Reloading chart. | 2022-04-25 12:15:37.200
COST-NQTV[M] Daily #12 | Reloading chart. | 2022-04-25 12:15:40.905
COST-NQTV[M] 128 Min #2 | Reloading chart. | 2022-04-25 12:15:49.183
CALM-NQTV[M] 2 Day #6 | Reloading chart. | 2022-04-25 12:16:00.500
CALM-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 12:16:07.313
CALM-NQTV[M] Daily #6 | Reloading chart. | 2022-04-25 12:16:09.765
CALM-NQTV[M] Daily #6 | Reloading chart. | 2022-04-25 12:16:15.117
CALM-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 12:16:21.072
CALM-NQTV[M] Daily #6 | Reloading chart. | 2022-04-25 12:16:22.277
CALM-NQTV[M] 256 Min #7 | Reloading chart. | 2022-04-25 12:16:49.911
CALM-NQTV[M] 128 Min #7 | Reloading chart. | 2022-04-25 12:16:56.863
CALM-NQTV[M] 256 Min #7 | Reloading chart. | 2022-04-25 12:17:01.231
CALM-NQTV[M] 128 Min #7 | Reloading chart. | 2022-04-25 12:17:04.303
CALM-NQTV[M] 256 Min #7 | Reloading chart. | 2022-04-25 12:17:17.340
CALM-NQTV[M] 1 Day #7 | Reloading chart. | 2022-04-25 12:17:20.365
CALM-NQTV[M] 256 Min #7 | Reloading chart. | 2022-04-25 12:17:24.392
CALM-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 12:17:29.560
CALM-NQTV[M] 2 Day #6 | Reloading chart. | 2022-04-25 12:17:30.114
CALM-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 12:17:32.627
CALM-NQTV[M] 128 Min #7 | Reloading chart. | 2022-04-25 12:17:45.048
CALM-NQTV[M] 32 Min #9 | Reloading chart. | 2022-04-25 12:17:52.057
CALM-NQTV[M] 2 Day #6 | Reloading chart. | 2022-04-25 12:18:06.203
CALM-NQTV[M] Daily #6 | Reloading chart. | 2022-04-25 12:18:25.211
CALM-NQTV[M] 2 Day #6 | Reloading chart. | 2022-04-25 12:18:26.773
CALM-NQTV[M] Daily #6 | Reloading chart. | 2022-04-25 12:19:05.778
CALM-NQTV[M] 2 Day #6 | Reloading chart. | 2022-04-25 12:19:07.437
CALM-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 12:19:08.185
CALM-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 12:19:09.068
CALM-NQTV[M] Daily #6 | Reloading chart. | 2022-04-25 12:19:10.001
CALM-NQTV[M] 2 Day #6 | Reloading chart. | 2022-04-25 12:19:20.451
CALM-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 12:19:21.630
CALM-NQTV[M] Daily #6 | Reloading chart. | 2022-04-25 12:19:25.847
CALM-NQTV[M] 64 Min #9 | Reloading chart. | 2022-04-25 12:19:39.535
DAR-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 12:19:54.019
DAR-NQTV[M] 16 Day #6 | Reloading chart. | 2022-04-25 12:19:56.803
DAR-NQTV[M] 32 Day #6 | Reloading chart. | 2022-04-25 12:19:57.538
DAR-NQTV[M] 64 Day #6 | Reloading chart. | 2022-04-25 12:19:58.401
DAR-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 12:20:02.169
DAR-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 12:20:04.601
DAR-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 12:20:06.028
DAR-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 12:20:09.228
DRE-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 12:30:02.368
DRE-NQTV[M] 16 Day #3 | Reloading chart. | 2022-04-25 12:30:03.646
DRE-NQTV[M] 32 Day #3 | Reloading chart. | 2022-04-25 12:30:04.227
DRE-NQTV[M] 64 Day #3 | Reloading chart. | 2022-04-25 12:30:04.844
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:30:07.586
DRE-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 12:30:10.259
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:30:18.990
DRE-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 12:30:27.893
DRE-NQTV[M] 16 Day #3 | Reloading chart. | 2022-04-25 12:30:31.375
DRE-NQTV[M] 32 Day #3 | Reloading chart. | 2022-04-25 12:30:32.611
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:30:34.691
DRE-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 12:30:35.904
DRE-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 12:30:36.487
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:30:42.572
DRE-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 12:30:44.262
DRE-NQTV[M] 16 Day #3 | Reloading chart. | 2022-04-25 12:30:48.447
DRE-NQTV[M] 32 Day #3 | Reloading chart. | 2022-04-25 12:30:50.839
DRE-NQTV[M] 64 Day #3 | Reloading chart. | 2022-04-25 12:30:52.020
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:30:54.567
DRE-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 12:30:55.620
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:30:58.576
DRE-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 12:31:00.850
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:31:14.165
DRE-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 12:31:20.555
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:31:21.600
DRE-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 12:31:21.965
DRE-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 12:31:25.512
Saved Chartbook: MACRO.Cht. Time: 0.0213 seconds. | 2022-04-25 12:33:39.594
Saved Chartbook: SCREENING.Cht. Time: 0.0007 seconds. | 2022-04-25 12:33:39.595
Saved Chartbook: ACTION.Cht. Time: 0.0011 seconds. | 2022-04-25 12:33:39.597
Saved Chartbook: AGGS.Cht. Time: 0.0216 seconds. | 2022-04-25 12:33:39.619
Saved Chartbook: INDICES.Cht. Time: 0.0310 seconds. | 2022-04-25 12:33:39.651
Saved Chartbook: METALS.Cht. Time: 0.0126 seconds. | 2022-04-25 12:33:39.664
Saved Chartbook: ENERGY.Cht. Time: 0.0235 seconds. | 2022-04-25 12:33:39.688
Saved Chartbook: CRYPTO.Cht. Time: 0.0120 seconds. | 2022-04-25 12:33:39.701
Saved Chartbook: FOREX.Cht. Time: 0.0120 seconds. | 2022-04-25 12:33:39.714
Saved Chartbook: AAA.Cht. Time: 0.0127 seconds. | 2022-04-25 12:33:39.727
Saved Chartbook: BBB.Cht. Time: 0.0022 seconds. | 2022-04-25 12:33:39.730
Saved Chartbook: CCC.Cht. Time: 0.0227 seconds. | 2022-04-25 12:33:39.753
Saved Chartbook: DDD.Cht. Time: 0.0114 seconds. | 2022-04-25 12:33:39.765
Saved Chartbook: EEE.Cht. Time: 0.0058 seconds. | 2022-04-25 12:33:39.772
Saved Chartbook: FFF.Cht. Time: 0.0041 seconds. | 2022-04-25 12:33:39.777
Saved Chartbook: GGG.Cht. Time: 0.0035 seconds. | 2022-04-25 12:33:39.781
Saved Chartbook: HHH.Cht. Time: 0.0133 seconds. | 2022-04-25 12:33:39.795
Saved Chartbook: III.Cht. Time: 0.0032 seconds. | 2022-04-25 12:33:39.799
Saved Chartbook: KKK.Cht. Time: 0.0035 seconds. | 2022-04-25 12:33:39.803
Saved Chartbook: LLL.Cht. Time: 0.0043 seconds. | 2022-04-25 12:33:39.808
Saved Chartbook: MMM.Cht. Time: 0.0031 seconds. | 2022-04-25 12:33:39.811
Saved Chartbook: NNN.Cht. Time: 0.0034 seconds. | 2022-04-25 12:33:39.815
Saved Chartbook: OOO.Cht. Time: 0.0033 seconds. | 2022-04-25 12:33:39.819
Saved Chartbook: PPP.Cht. Time: 0.0140 seconds. | 2022-04-25 12:33:39.834
Saved Chartbook: RRR.Cht. Time: 0.0030 seconds. | 2022-04-25 12:33:39.838
Saved Chartbook: SSS.Cht. Time: 0.0034 seconds. | 2022-04-25 12:33:39.842
Saved Chartbook: TTT.Cht. Time: 0.0212 seconds. | 2022-04-25 12:33:39.864
Saved Chartbook: UUU.Cht. Time: 0.0013 seconds. | 2022-04-25 12:33:39.865
Saved Chartbook: VVV.Cht. Time: 0.0031 seconds. | 2022-04-25 12:33:39.869
Saved Chartbook: WWW.Cht. Time: 0.0041 seconds. | 2022-04-25 12:33:39.874
Saved Chartbook: XXX.Cht. Time: 0.0117 seconds. | 2022-04-25 12:33:39.886
Saved Chartbook: ZZZ.Cht. Time: 0.0021 seconds. | 2022-04-25 12:33:39.889
DRE-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 12:34:30.165
DRE-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 12:34:35.741
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:34:43.977
DRE-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 12:34:45.667
DRE-NQTV[M] 16 Day #3 | Reloading chart. | 2022-04-25 12:34:46.722
DRE-NQTV[M] 32 Day #3 | Reloading chart. | 2022-04-25 12:34:47.440
DRE-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 12:34:53.837
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:35:00.574
DRE-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 12:35:06.618
DRE-NQTV[M] 16 Day #3 | Reloading chart. | 2022-04-25 12:35:11.729
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:35:13.697
DRE-NQTV[M] 16 Day #3 | Reloading chart. | 2022-04-25 12:35:22.670
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:35:28.997
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:35:30.923
DRE-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 12:35:32.032
DRE-NQTV[M] 16 Day #3 | Reloading chart. | 2022-04-25 12:35:32.957
DRE-NQTV[M] 32 Day #3 | Reloading chart. | 2022-04-25 12:35:34.058
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:35:36.004
DRE-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 12:35:40.457
DRE-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 12:35:42.904
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:35:45.211
DRE-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 12:35:52.147
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:35:53.730
DRE-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 12:35:54.856
DRE-NQTV[M] 16 Day #3 | Reloading chart. | 2022-04-25 12:35:55.819
DRE-NQTV[M] 32 Day #3 | Reloading chart. | 2022-04-25 12:35:56.553
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:35:58.321
DRE-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 12:35:58.691
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:36:05.850
DRE-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 12:36:09.678
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:36:45.695
DRE-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 12:36:46.630
DRE-NQTV[M] 16 Day #3 | Reloading chart. | 2022-04-25 12:36:50.011
DRE-NQTV[M] 32 Day #3 | Reloading chart. | 2022-04-25 12:36:50.643
DRE-NQTV[M] 64 Day #3 | Reloading chart. | 2022-04-25 12:36:54.537
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:36:56.845
DRE-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 12:36:59.472
DRE-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 12:37:02.817
DRE-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 12:37:13.282
DRE-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 12:37:19.809
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:37:22.827
DRE-NQTV[M] 16 Day #3 | Reloading chart. | 2022-04-25 12:37:24.588
DRE-NQTV[M] 32 Day #3 | Reloading chart. | 2022-04-25 12:37:25.867
DRE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:37:26.860
DRE-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 12:37:27.511
EVH-NQTV[M] 8 Day #10 | Reloading chart. | 2022-04-25 12:37:44.441
EVH-NQTV[M] 16 Day #10 | Reloading chart. | 2022-04-25 12:37:45.803
EVH-NQTV[M] 32 Day #10 | Reloading chart. | 2022-04-25 12:37:47.315
EVH-NQTV[M] 64 Day #10 | Reloading chart. | 2022-04-25 12:37:48.259
EVH-NQTV[M] 8 Day #10 | Reloading chart. | 2022-04-25 12:37:49.495
EVH-NQTV[M] 4 Day #10 | Reloading chart. | 2022-04-25 12:37:53.137
EVH-NQTV[M] 2 Day #10 | Reloading chart. | 2022-04-25 12:37:56.664
EVH-NQTV[M] 4 Day #10 | Reloading chart. | 2022-04-25 12:37:59.960
EW-NQTV[M] 8 Day #19 | Reloading chart. | 2022-04-25 12:38:12.681
EW-NQTV[M] 16 Day #19 | Reloading chart. | 2022-04-25 12:38:13.949
EW-NQTV[M] 32 Day #19 | Reloading chart. | 2022-04-25 12:38:14.747
EW-NQTV[M] 64 Day #19 | Reloading chart. | 2022-04-25 12:38:15.826
EW-NQTV[M] 4 Day #19 | Reloading chart. | 2022-04-25 12:38:17.069
EW-NQTV[M] 2 Day #19 | Reloading chart. | 2022-04-25 12:38:20.941
EW-NQTV 2 Day #3 | Reloading chart. | 2022-04-25 12:38:36.539
EW-NQTV[M] 10 Day 960 Min #3 | Reloading chart. | 2022-04-25 12:38:58.100
Added historical Intraday data request for EW-NQTV to the queue. | 2022-04-25 12:38:58.351
Intraday data recording state for symbol EW-NQTV is set to download 'Pending'. | 2022-04-25 12:38:58.351
Triggering next historical data download in queue. | 2022-04-25 12:38:58.351
HD Request # 226 | Downloading Intraday chart data for EW-NQTV to the file EW-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 12:38:58.363
HD Request # 226 | Download start date-time: 2022-04-21 12:13:53.000000. File last date-time: 2022-04-21 12:13:53.162001 | 2022-04-25 12:38:58.364
HD Request # 226 | Using server: ds25.sierracharts.com port 10150 | 2022-04-25 12:38:58.364
Socket (2) | Creating socket. | 2022-04-25 12:38:58.364
Socket (2) | New receive buffer size: 5242880 | 2022-04-25 12:38:58.364
Socket (2) | Connecting to IP: 38.65.8.115. | 2022-04-25 12:38:58.364
HD Request # 226 | Setting DTC encoding to Binary VLS | 2022-04-25 12:38:58.822
HD Request # 226 | Sending historical data logon request message. | 2022-04-25 12:38:58.822
HD Request # 226 | Requesting Intraday data. Start date-time: 2022-04-21 12:13:53. Record interval: 0. Symbol: EW-NQTV | 2022-04-25 12:38:59.526
HD Request # 226 | Decompressing data. | 2022-04-25 12:38:59.760
HD Request # 226 | Receiving Intraday data for EW-NQTV starting at 2022-04-21 12:13:53.162000 | 2022-04-25 12:39:00.681
Socket (2) | CloseSocket call. | 2022-04-25 12:39:00.912
Historical data download thread signaled to stop. | 2022-04-25 12:39:00.912
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-04-25 12:39:00.912
HD Request # 226 | Timestamp of first Intraday data file record written: 2022-04-21 12:14:02.445000 | 2022-04-25 12:39:00.912
HD Request # 226 | Received 14080 Intraday data records from 2022-04-21 12:13:53.162000 to 2022-04-25 12:38:28.605002 (4.0 days) and wrote 14078 records for EW-NQTV | 2022-04-25 12:39:00.912
HD Request # 226 | Completion time: 2s | 2022-04-25 12:39:00.912
HD Request # 226 | Intraday data download complete for EW-NQTV. Unique request ID: 227 | 2022-04-25 12:39:00.912
Removing historical data download ID 227. | 2022-04-25 12:39:00.912
Real-time Intraday chart data file updates started for EW-NQTV | 2022-04-25 12:39:00.912
Intraday chart data file opened for EW-NQTV | 2022-04-25 12:39:00.912
HD Request # 226 | Enabling Intraday chart updating for symbol. | 2022-04-25 12:39:00.912
Triggering next historical data download in queue. | 2022-04-25 12:39:00.913
No download requests in the queue to start downloads for. | 2022-04-25 12:39:00.913
Socket (2) | Socket gracefully closed by remote side. | 2022-04-25 12:39:01.140
Socket (2) | Closed. | 2022-04-25 12:39:01.141
EW-NQTV[M] 256 Min #3 | Reloading chart. | 2022-04-25 12:39:01.542
Opened cached Intraday file: C:\SierraChart\Data\EW-NQTV.scid. Thread ID: 19936 | 2022-04-25 12:39:04.102
EXR-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 12:39:19.142
EXR-NQTV[M] 16 Day #6 | Reloading chart. | 2022-04-25 12:39:21.158
EXR-NQTV[M] 32 Day #6 | Reloading chart. | 2022-04-25 12:39:21.852
EXR-NQTV[M] 64 Day #6 | Reloading chart. | 2022-04-25 12:39:22.661
EXR-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 12:39:24.475
EXR-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 12:39:27.618
EXR-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 12:39:30.440
EXR-NQTV[M] 16 Day #6 | Reloading chart. | 2022-04-25 12:39:31.660
EXR-NQTV[M] 32 Day #6 | Reloading chart. | 2022-04-25 12:39:33.010
EXR-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 12:39:35.503
FWONK-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:39:45.180
FWONK-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 12:39:46.113
FWONK-NQTV[M] 16 Day #3 | Reloading chart. | 2022-04-25 12:39:46.979
FWONK-NQTV[M] 32 Day #3 | Reloading chart. | 2022-04-25 12:39:47.534
FWONK-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:39:48.501
FWONK-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 12:39:50.088
FWONK-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 12:39:54.280
FR-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 12:40:01.553
FR-NQTV[M] 16 Day #4 | Reloading chart. | 2022-04-25 12:40:02.515
FR-NQTV[M] 32 Day #4 | Reloading chart. | 2022-04-25 12:40:03.301
FR-NQTV[M] 64 Day #4 | Reloading chart. | 2022-04-25 12:40:04.082
FR-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 12:40:05.612
FR-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 12:40:07.751
GCBC-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 12:40:27.123
GCBC-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 12:40:30.127
GCBC-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:40:36.498
GCBC-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 12:40:38.929
GCBC-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 12:40:41.998
GCBC-NQTV[M] 256 Min #3 | Reloading chart. | 2022-04-25 12:40:49.782
GCBC-NQTV[M] 64 Min #3 | Reloading chart. | 2022-04-25 12:41:07.717
GCBC-NQTV[M] 256 Min #3 | Reloading chart. | 2022-04-25 12:41:09.727
GCBC-NQTV[M] 256 Min #3 | Reloading chart. | 2022-04-25 12:41:12.090
GCBC-NQTV[M] 64 Min #3 | Reloading chart. | 2022-04-25 12:41:12.741
GCBC-NQTV[M] 256 Min #3 | Reloading chart. | 2022-04-25 12:41:14.913
HZNP-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:41:43.613
HZNP-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 12:41:44.030
HZNP-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 12:41:45.914
HZNP-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 12:41:46.530
HZNP-NQTV[M] 64 Day #2 | Reloading chart. | 2022-04-25 12:41:47.416
HZNP-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:41:48.993
HZNP-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 12:41:51.388
HZNP-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:41:54.304
HCA-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 12:42:05.009
LLY-NQTV[M] 8 Day #5 | Reloading chart. | 2022-04-25 12:42:24.648
LLY-NQTV[M] 16 Day #5 | Reloading chart. | 2022-04-25 12:42:26.808
LLY-NQTV[M] 32 Day #5 | Reloading chart. | 2022-04-25 12:42:27.786
LLY-NQTV[M] 64 Day #5 | Reloading chart. | 2022-04-25 12:42:28.722
LLY-NQTV[M] 8 Day #5 | Reloading chart. | 2022-04-25 12:42:30.480
LLY-NQTV[M] 4 Day #5 | Reloading chart. | 2022-04-25 12:42:32.362
LLY-NQTV[M] 8 Day #5 | Reloading chart. | 2022-04-25 12:42:37.973
LLY-NQTV[M] 4 Day #5 | Reloading chart. | 2022-04-25 12:42:39.322
LAC-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:42:59.254
LAC-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 12:43:01.758
LAC-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 12:43:02.953
LAC-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 12:43:03.523
LAC-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:43:06.507
LAC-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:45:58.248
LAC-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 12:46:02.180
LAC-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 12:46:03.160
LAC-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 12:46:04.128
LAC-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:46:06.128
LAC-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 12:46:07.085
LAC-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 12:46:17.240
LAC-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 12:46:20.720
LAC-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 12:46:24.539
LSI-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 12:46:38.104
LSI-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 12:46:39.495
LSI-NQTV[M] 16 Day #4 | Reloading chart. | 2022-04-25 12:46:41.916
LSI-NQTV[M] 32 Day #4 | Reloading chart. | 2022-04-25 12:46:43.039
LSI-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 12:46:44.828
LSI-NQTV[M] 2 Day #4 | Reloading chart. | 2022-04-25 12:46:46.664
LSI-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 12:47:38.364
LSI-NQTV[M] 2 Day #4 | Reloading chart. | 2022-04-25 12:48:01.406
LSI-NQTV[M] Daily #4 | Reloading chart. | 2022-04-25 12:48:10.569
MGP-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:52:39.380
MGP-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 12:52:40.261
MGP-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 12:52:43.258
MGP-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 12:52:44.106
MGP-NQTV[M] 64 Day #2 | Reloading chart. | 2022-04-25 12:52:45.129
MGP-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 12:52:46.287
MGP-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 12:52:48.665
MGP-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:52:51.226
NEM-NQTV[M] 8 Day #10 | Reloading chart. | 2022-04-25 12:53:14.112
NEM-NQTV[M] 16 Day #10 | Reloading chart. | 2022-04-25 12:53:15.032
NEM-NQTV[M] 16 Day #10 | Reloading chart. | 2022-04-25 12:53:19.990
NEM-NQTV[M] 32 Day #10 | Reloading chart. | 2022-04-25 12:53:20.510
NEM-NQTV[M] 64 Day #10 | Reloading chart. | 2022-04-25 12:53:22.237
NEM-NQTV[M] 128 Day #10 | Reloading chart. | 2022-04-25 12:53:23.540
NEM-NQTV[M] 16 Day #10 | Reloading chart. | 2022-04-25 12:53:26.146
NEM-NQTV[M] 64 Day #10 | Reloading chart. | 2022-04-25 12:53:29.913
NSA-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:53:36.503
Saved Chartbook: MACRO.Cht. Time: 0.0140 seconds. | 2022-04-25 12:53:39.924
Saved Chartbook: SCREENING.Cht. Time: 0.0008 seconds. | 2022-04-25 12:53:39.925
Saved Chartbook: ACTION.Cht. Time: 0.0012 seconds. | 2022-04-25 12:53:39.927
Saved Chartbook: AGGS.Cht. Time: 0.0075 seconds. | 2022-04-25 12:53:39.935
Saved Chartbook: INDICES.Cht. Time: 0.0331 seconds. | 2022-04-25 12:53:39.969
Saved Chartbook: METALS.Cht. Time: 0.0117 seconds. | 2022-04-25 12:53:39.981
Saved Chartbook: ENERGY.Cht. Time: 0.0223 seconds. | 2022-04-25 12:53:40.004
Saved Chartbook: CRYPTO.Cht. Time: 0.0137 seconds. | 2022-04-25 12:53:40.018
Saved Chartbook: FOREX.Cht. Time: 0.0133 seconds. | 2022-04-25 12:53:40.032
Saved Chartbook: AAA.Cht. Time: 0.0128 seconds. | 2022-04-25 12:53:40.046
Saved Chartbook: BBB.Cht. Time: 0.0023 seconds. | 2022-04-25 12:53:40.049
Saved Chartbook: CCC.Cht. Time: 0.0070 seconds. | 2022-04-25 12:53:40.056
Saved Chartbook: DDD.Cht. Time: 0.0042 seconds. | 2022-04-25 12:53:40.061
Saved Chartbook: EEE.Cht. Time: 0.0142 seconds. | 2022-04-25 12:53:40.076
Saved Chartbook: FFF.Cht. Time: 0.0113 seconds. | 2022-04-25 12:53:40.088
Saved Chartbook: GGG.Cht. Time: 0.0106 seconds. | 2022-04-25 12:53:40.099
Saved Chartbook: HHH.Cht. Time: 0.0133 seconds. | 2022-04-25 12:53:40.113
Saved Chartbook: III.Cht. Time: 0.0017 seconds. | 2022-04-25 12:53:40.116
Saved Chartbook: KKK.Cht. Time: 0.0029 seconds. | 2022-04-25 12:53:40.119
Saved Chartbook: LLL.Cht. Time: 0.0127 seconds. | 2022-04-25 12:53:40.132
Saved Chartbook: MMM.Cht. Time: 0.0017 seconds. | 2022-04-25 12:53:40.135
Saved Chartbook: NNN.Cht. Time: 0.0038 seconds. | 2022-04-25 12:53:40.139
Saved Chartbook: OOO.Cht. Time: 0.0027 seconds. | 2022-04-25 12:53:40.142
Saved Chartbook: PPP.Cht. Time: 0.0155 seconds. | 2022-04-25 12:53:40.159
Saved Chartbook: RRR.Cht. Time: 0.0031 seconds. | 2022-04-25 12:53:40.162
Saved Chartbook: SSS.Cht. Time: 0.0034 seconds. | 2022-04-25 12:53:40.166
Saved Chartbook: TTT.Cht. Time: 0.0210 seconds. | 2022-04-25 12:53:40.188
Saved Chartbook: UUU.Cht. Time: 0.0011 seconds. | 2022-04-25 12:53:40.190
Saved Chartbook: VVV.Cht. Time: 0.0032 seconds. | 2022-04-25 12:53:40.193
Saved Chartbook: WWW.Cht. Time: 0.0039 seconds. | 2022-04-25 12:53:40.198
Saved Chartbook: XXX.Cht. Time: 0.0128 seconds. | 2022-04-25 12:53:40.211
Saved Chartbook: ZZZ.Cht. Time: 0.0020 seconds. | 2022-04-25 12:53:40.214
NEM-NQTV[M] 16 Day #10 | Reloading chart. | 2022-04-25 12:53:43.087
NEM-NQTV[M] 8 Day #10 | Reloading chart. | 2022-04-25 12:53:47.814
NEM-NQTV[M] 16 Day #10 | Reloading chart. | 2022-04-25 12:53:54.336
NSA-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:53:59.242
NSA-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 12:54:00.927
NSA-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 12:54:02.553
NSA-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 12:54:03.216
NSA-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:54:04.834
NSA-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 12:54:07.344
NSA-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:54:11.112
NSA-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 12:54:12.159
NVO-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:54:23.230
NVO-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 12:54:24.018
NVO-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 12:54:25.919
ORLY-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:54:37.635
ORLY-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 12:54:38.593
ORLY-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 12:54:39.523
ORLY-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 12:54:40.070
ORLY-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 12:54:41.539
ORLY-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 12:54:43.158
ORLY-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:54:46.095
ORLY-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 12:54:52.180
ORLY-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 12:54:58.334
ORLY-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:54:59.304
ORLY-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 12:55:02.251
ORLY-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 12:55:06.396
ORLY-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 12:55:07.760
ORLY-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 12:55:08.483
ORLY-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 12:55:12.766
ORLY-NQTV[M] 128 Min #3 | Reloading chart. | 2022-04-25 12:55:17.290
ORLY-NQTV[M] 32 Min #3 | Reloading chart. | 2022-04-25 12:55:27.997
ORLY-NQTV[M] 128 Min #3 | Reloading chart. | 2022-04-25 12:55:35.816
ORLY-NQTV[M] 256 Min #3 | Reloading chart. | 2022-04-25 12:55:39.503
ORLY-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:55:52.384
ORLY-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 12:55:54.152
ORLY-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 12:55:55.873
ORLY-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 12:55:59.551
ORLY-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 12:56:01.112
ORLY-NQTV[M] 64 Min #3 | Reloading chart. | 2022-04-25 12:56:14.043
ORLY-NQTV[M] 256 Min #3 | Reloading chart. | 2022-04-25 12:56:17.036
OLN-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 12:56:22.684
ORLY-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 12:59:56.267
ORLY-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 12:59:58.531
ORLY-NQTV[M] 128 Min #3 | Reloading chart. | 2022-04-25 13:00:20.433
ORLY-NQTV[M] 256 Min #3 | Reloading chart. | 2022-04-25 13:00:24.567
Added historical Daily data request for WHEATF to the queue. | 2022-04-25 13:00:34.026
Triggering next historical data download in queue. | 2022-04-25 13:00:34.026
HD Request # 227 | Downloading Historical Daily chart data for WHEATF. Starting date: 2022-04-21. Service: fxcm | 2022-04-25 13:00:34.027
HD Request # 227 | Using server: ds4.sierracharts.com port 10149 | 2022-04-25 13:00:34.027
Socket (2) | Creating socket. | 2022-04-25 13:00:34.028
Socket (2) | New receive buffer size: 5242880 | 2022-04-25 13:00:34.028
Socket (2) | Connecting to IP: 192.81.56.146. | 2022-04-25 13:00:34.028
HD Request # 227 | Setting DTC encoding to Binary VLS | 2022-04-25 13:00:34.503
HD Request # 227 | Sending historical data logon request message. | 2022-04-25 13:00:34.503
HD Request # 227 | Requesting historical Daily data starting at 2022-04-21. | 2022-04-25 13:00:35.271
HD Request # 227 | Decompressing data. | 2022-04-25 13:00:35.506
HD Request # 227 | Receiving historical Daily data for WHEATF starting at 2022-04-21 | 2022-04-25 13:00:35.507
HD Request # 227 | Writing historical Daily data to the file WHEATF.dly | 2022-04-25 13:00:35.507
Socket (2) | CloseSocket call. | 2022-04-25 13:00:35.513
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-04-25 13:00:35.513
Historical data download thread signaled to stop. | 2022-04-25 13:00:35.528
HD Request # 227 | Received 3 Daily data records from 2022-04-21 00:00:00 to 2022-04-25 00:00:00 (5.0 days) and wrote 3 records for WHEATF | 2022-04-25 13:00:35.528
HD Request # 227 | Completion time: 1s | 2022-04-25 13:00:35.528
HD Request # 227 | Daily data download complete for WHEATF. Unique request ID: 228 | 2022-04-25 13:00:35.528
Removing historical data download ID 228. | 2022-04-25 13:00:35.528
Triggering next historical data download in queue. | 2022-04-25 13:00:35.528
No download requests in the queue to start downloads for. | 2022-04-25 13:00:35.528
WHEATF[M] 2 Day #4 | Reloading chart. | 2022-04-25 13:00:35.602
Socket (2) | Socket gracefully closed by remote side. | 2022-04-25 13:00:35.744
Socket (2) | Closed. | 2022-04-25 13:00:35.744
ORLY-NQTV[M] 128 Min #3 | Reloading chart. | 2022-04-25 13:00:37.866
ORLY-NQTV[M] 32 Min #3 | Reloading chart. | 2022-04-25 13:00:38.658
PFE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 13:00:54.884
PFE-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 13:00:58.321
PFE-NQTV[M] 16 Day #3 | Reloading chart. | 2022-04-25 13:00:59.671
PFE-NQTV[M] 32 Day #3 | Reloading chart. | 2022-04-25 13:01:00.596
PFE-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 13:01:03.009
PFE-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 13:01:08.422
PFE-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 13:01:09.372
PFE-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 13:01:11.513
PFE-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 13:01:11.975
PFE-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 13:01:15.323
PFE-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 13:01:23.030
PFE-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 13:01:30.010
PFE-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 13:01:31.767
PFE-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 13:01:37.388
PFE-NQTV[M] 128 Min #5 | Reloading chart. | 2022-04-25 13:01:51.293
PFG-NQTV[M] 4 Min #6 | Reloading chart. | 2022-04-25 13:01:58.708
PFG-NQTV[M] 256 Min #6 | Reloading chart. | 2022-04-25 13:02:01.854
PFG-NQTV[M] 4 Day #14 | Reloading chart. | 2022-04-25 13:02:17.062
PFG-NQTV[M] 8 Day #14 | Reloading chart. | 2022-04-25 13:02:18.877
PFG-NQTV[M] 16 Day #14 | Reloading chart. | 2022-04-25 13:02:19.968
PFG-NQTV[M] 32 Day #14 | Reloading chart. | 2022-04-25 13:02:20.819
PFG-NQTV[M] 4 Day #14 | Reloading chart. | 2022-04-25 13:02:22.625
PFG-NQTV[M] 8 Day #14 | Reloading chart. | 2022-04-25 13:02:24.342
PFG-NQTV[M] 2 Day #14 | Reloading chart. | 2022-04-25 13:02:25.066
PFG-NQTV[M] 4 Day #14 | Reloading chart. | 2022-04-25 13:02:32.698
PFG-NQTV[M] 2 Day #14 | Reloading chart. | 2022-04-25 13:02:34.678
PFG-NQTV[M] 4 Day #14 | Reloading chart. | 2022-04-25 13:02:37.194
PFG-NQTV[M] 8 Day #14 | Reloading chart. | 2022-04-25 13:02:38.388
PFG-NQTV[M] 4 Day #14 | Reloading chart. | 2022-04-25 13:02:39.771
PFG-NQTV[M] 16 Day #14 | Reloading chart. | 2022-04-25 13:02:41.383
PFG-NQTV[M] 32 Day #14 | Reloading chart. | 2022-04-25 13:02:41.987
PFG-NQTV[M] 4 Day #14 | Reloading chart. | 2022-04-25 13:02:44.727
PFG-NQTV[M] 8 Day #14 | Reloading chart. | 2022-04-25 13:02:45.315
PFG-NQTV[M] Daily #14 | Reloading chart. | 2022-04-25 13:02:53.165
PAYX-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 13:03:06.884
PAYX-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 13:03:07.454
PAYX-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 13:03:08.687
PAYX-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 13:03:10.009
PAYX-NQTV[M] 64 Day #2 | Reloading chart. | 2022-04-25 13:03:18.246
PAYX-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 13:03:19.912
PAYX-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 13:03:22.816
PAYX-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 13:03:23.999
PAYX-NQTV[M] 64 Day #2 | Reloading chart. | 2022-04-25 13:03:24.806
PAYX-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 13:03:26.080
PAYX-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 13:03:28.100
PAYX-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 13:03:36.482
PAYX-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 13:03:38.378
PAYX-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 13:03:40.184
PAYX-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 13:03:41.362
PAYX-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 13:03:42.672
PAYX-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 13:03:47.456
PAYX-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 13:03:56.685
PAYX-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 13:03:57.689
PAYX-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 13:03:58.937
PAYX-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 13:04:04.517
PAYX-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 13:04:07.073
PAYX-NQTV Daily #6 | Reloading chart. | 2022-04-25 13:04:16.870
Enabling compression for file: C:\SierraChart\Data\PAYX-NQTV.scid. This may take a while. | 2022-04-25 13:04:28.830
File compression enabled. C:\SierraChart\Data\PAYX-NQTV.scid. CompressionState=0 | 2022-04-25 13:04:28.830
PAYX-NQTV[M] 10 Day 960 Min #6 | Reloading chart. | 2022-04-25 13:04:28.831
PAYX-NQTV[M] 10 Day 960 Min #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\PAYX-NQTV.scid | 2022-04-25 13:04:28.837
Added historical Intraday data request for PAYX-NQTV to the queue. | 2022-04-25 13:04:29.102
Intraday data recording state for symbol PAYX-NQTV is set to download 'Pending'. | 2022-04-25 13:04:29.102
Triggering next historical data download in queue. | 2022-04-25 13:04:29.102
HD Request # 228 | Downloading Intraday chart data for PAYX-NQTV to the file PAYX-NQTV.scid. Service: nasdaq_exchange.data | 2022-04-25 13:04:29.102
HD Request # 228 | Download start date-time: 2021-10-21 13:04:29.000000. File last date-time: 00:00:00.000000 | 2022-04-25 13:04:29.102
HD Request # 228 | Using server: ds25.sierracharts.com port 10150 | 2022-04-25 13:04:29.102
Socket (2) | Creating socket. | 2022-04-25 13:04:29.102
Socket (2) | New receive buffer size: 5242880 | 2022-04-25 13:04:29.102
Socket (2) | Connecting to IP: 38.65.8.115. | 2022-04-25 13:04:29.102
HD Request # 228 | Setting DTC encoding to Binary VLS | 2022-04-25 13:04:29.557
HD Request # 228 | Sending historical data logon request message. | 2022-04-25 13:04:29.557
HD Request # 228 | Requesting Intraday data. Start date-time: 2021-10-21 13:04:29. Record interval: 0. Symbol: PAYX-NQTV | 2022-04-25 13:04:30.260
HD Request # 228 | Decompressing data. | 2022-04-25 13:04:30.490
HD Request # 228 | Receiving Intraday data for PAYX-NQTV starting at 2021-10-21 13:04:51.305000 | 2022-04-25 13:04:31.185
PAYX-NQTV[M] 256 Min #6 | Reloading chart. | 2022-04-25 13:04:31.547
PAYX-NQTV[M] 256 Min #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\PAYX-NQTV.scid | 2022-04-25 13:04:31.560
HD Request # 228 | Timestamp of first Intraday data file record written: 2021-10-21 13:04:51.305000 | 2022-04-25 13:04:32.158
Socket (2) | CloseSocket call. | 2022-04-25 13:04:38.117
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-04-25 13:04:38.117
Historical data download thread signaled to stop. | 2022-04-25 13:04:38.137
HD Request # 228 | Received 886086 Intraday data records from 2021-10-21 13:04:51.305000 to 2022-04-25 13:04:26.064000 (186.0 days) and wrote 886086 records for PAYX-NQTV | 2022-04-25 13:04:38.138
HD Request # 228 | Completion time: 9s | 2022-04-25 13:04:38.138
HD Request # 228 | Intraday data download complete for PAYX-NQTV. Unique request ID: 229 | 2022-04-25 13:04:38.138
Removing historical data download ID 229. | 2022-04-25 13:04:38.138
Real-time Intraday chart data file updates started for PAYX-NQTV | 2022-04-25 13:04:38.138
Intraday chart data file opened for PAYX-NQTV | 2022-04-25 13:04:38.138
HD Request # 228 | Enabling Intraday chart updating for symbol. | 2022-04-25 13:04:38.138
Triggering next historical data download in queue. | 2022-04-25 13:04:38.138
No download requests in the queue to start downloads for. | 2022-04-25 13:04:38.138
Socket (2) | Socket gracefully closed by remote side. | 2022-04-25 13:04:38.343
Socket (2) | Closed. | 2022-04-25 13:04:38.343
PAYX-NQTV[M] 256 Min #6 | Reloading chart. | 2022-04-25 13:05:01.769
Opened cached Intraday file: C:\SierraChart\Data\PAYX-NQTV.scid. Thread ID: 19936 | 2022-04-25 13:05:07.520
PAYX-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 13:05:11.548
PAYX-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 13:05:13.144
PAYX-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 13:05:14.321
PAYX-NQTV[M] 128 Min #6 | Reloading chart. | 2022-04-25 13:05:24.361
PWR-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 13:05:38.178
PWR-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 13:05:38.894
PWR-NQTV[M] 16 Day #4 | Reloading chart. | 2022-04-25 13:05:42.079
PWR-NQTV[M] 32 Day #4 | Reloading chart. | 2022-04-25 13:05:44.290
PWR-NQTV[M] 64 Day #4 | Reloading chart. | 2022-04-25 13:05:45.646
PWR-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 13:05:47.510
PWR-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 13:05:49.373
PWR-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 13:05:49.743
PWR-NQTV[M] 16 Day #4 | Reloading chart. | 2022-04-25 13:05:51.764
PWR-NQTV[M] 32 Day #4 | Reloading chart. | 2022-04-25 13:05:52.456
PWR-NQTV[M] 64 Day #4 | Reloading chart. | 2022-04-25 13:05:53.336
PWR-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 13:05:55.509
PWR-NQTV[M] 2 Day #4 | Reloading chart. | 2022-04-25 13:05:57.285
PG-NQTV[M] 4 Day #7 | Reloading chart. | 2022-04-25 13:06:03.168
PG-NQTV[M] 8 Day #7 | Reloading chart. | 2022-04-25 13:06:04.167
PG-NQTV[M] 16 Day #7 | Reloading chart. | 2022-04-25 13:06:06.430
PG-NQTV[M] 32 Day #7 | Reloading chart. | 2022-04-25 13:06:07.285
PG-NQTV[M] 4 Day #7 | Reloading chart. | 2022-04-25 13:06:08.400
PG-NQTV[M] 2 Day #7 | Reloading chart. | 2022-04-25 13:06:10.827
PLD-NQTV[M] 4 Day #8 | Reloading chart. | 2022-04-25 13:06:15.573
PLD-NQTV[M] 8 Day #8 | Reloading chart. | 2022-04-25 13:06:21.448
PLD-NQTV[M] 16 Day #8 | Reloading chart. | 2022-04-25 13:06:22.608
PLD-NQTV[M] 32 Day #8 | Reloading chart. | 2022-04-25 13:06:23.331
PLD-NQTV[M] 4 Day #8 | Reloading chart. | 2022-04-25 13:06:24.731
PLD-NQTV[M] 2 Day #8 | Reloading chart. | 2022-04-25 13:06:26.408
PLD-NQTV[M] 4 Day #8 | Reloading chart. | 2022-04-25 13:06:29.634
Saved Chartbook: MACRO.Cht. Time: 0.0227 seconds. | 2022-04-25 13:13:40.254
Saved Chartbook: SCREENING.Cht. Time: 0.0007 seconds. | 2022-04-25 13:13:40.255
Saved Chartbook: ACTION.Cht. Time: 0.0011 seconds. | 2022-04-25 13:13:40.257
Saved Chartbook: AGGS.Cht. Time: 0.0222 seconds. | 2022-04-25 13:13:40.280
Saved Chartbook: INDICES.Cht. Time: 0.0313 seconds. | 2022-04-25 13:13:40.312
Saved Chartbook: METALS.Cht. Time: 0.0119 seconds. | 2022-04-25 13:13:40.324
Saved Chartbook: ENERGY.Cht. Time: 0.0217 seconds. | 2022-04-25 13:13:40.346
Saved Chartbook: CRYPTO.Cht. Time: 0.0133 seconds. | 2022-04-25 13:13:40.360
Saved Chartbook: FOREX.Cht. Time: 0.0125 seconds. | 2022-04-25 13:13:40.374
Saved Chartbook: AAA.Cht. Time: 0.0127 seconds. | 2022-04-25 13:13:40.387
Saved Chartbook: BBB.Cht. Time: 0.0023 seconds. | 2022-04-25 13:13:40.390
Saved Chartbook: CCC.Cht. Time: 0.0233 seconds. | 2022-04-25 13:13:40.414
Saved Chartbook: DDD.Cht. Time: 0.0034 seconds. | 2022-04-25 13:13:40.418
Saved Chartbook: EEE.Cht. Time: 0.0143 seconds. | 2022-04-25 13:13:40.433
Saved Chartbook: FFF.Cht. Time: 0.0110 seconds. | 2022-04-25 13:13:40.445
Saved Chartbook: GGG.Cht. Time: 0.0036 seconds. | 2022-04-25 13:13:40.449
Saved Chartbook: HHH.Cht. Time: 0.0120 seconds. | 2022-04-25 13:13:40.462
Saved Chartbook: III.Cht. Time: 0.0027 seconds. | 2022-04-25 13:13:40.465
Saved Chartbook: KKK.Cht. Time: 0.0029 seconds. | 2022-04-25 13:13:40.468
Saved Chartbook: LLL.Cht. Time: 0.0114 seconds. | 2022-04-25 13:13:40.480
Saved Chartbook: MMM.Cht. Time: 0.0018 seconds. | 2022-04-25 13:13:40.483
Saved Chartbook: NNN.Cht. Time: 0.0038 seconds. | 2022-04-25 13:13:40.487
Saved Chartbook: OOO.Cht. Time: 0.0030 seconds. | 2022-04-25 13:13:40.491
Saved Chartbook: PPP.Cht. Time: 0.0130 seconds. | 2022-04-25 13:13:40.505
Saved Chartbook: RRR.Cht. Time: 0.0030 seconds. | 2022-04-25 13:13:40.508
Saved Chartbook: SSS.Cht. Time: 0.0035 seconds. | 2022-04-25 13:13:40.512
Saved Chartbook: TTT.Cht. Time: 0.0065 seconds. | 2022-04-25 13:13:40.519
Saved Chartbook: UUU.Cht. Time: 0.0017 seconds. | 2022-04-25 13:13:40.522
Saved Chartbook: VVV.Cht. Time: 0.0032 seconds. | 2022-04-25 13:13:40.525
Saved Chartbook: WWW.Cht. Time: 0.0035 seconds. | 2022-04-25 13:13:40.531
Saved Chartbook: XXX.Cht. Time: 0.0039 seconds. | 2022-04-25 13:13:40.536
Saved Chartbook: ZZZ.Cht. Time: 0.0017 seconds. | 2022-04-25 13:13:40.538
PLD-NQTV[M] 4 Day #8 | Reloading chart. | 2022-04-25 13:18:19.680
PLD-NQTV[M] 8 Day #8 | Reloading chart. | 2022-04-25 13:18:21.987
PLD-NQTV[M] 16 Day #8 | Reloading chart. | 2022-04-25 13:18:22.967
PLD-NQTV[M] 32 Day #8 | Reloading chart. | 2022-04-25 13:18:23.610
PLD-NQTV[M] 4 Day #8 | Reloading chart. | 2022-04-25 13:18:24.792
PLD-NQTV[M] 8 Day #8 | Reloading chart. | 2022-04-25 13:18:26.053
PLD-NQTV[M] 4 Day #8 | Reloading chart. | 2022-04-25 13:18:28.937
PLD-NQTV[M] 2 Day #8 | Reloading chart. | 2022-04-25 13:18:30.958
PLD-NQTV[M] 4 Day #8 | Reloading chart. | 2022-04-25 13:18:35.879
PLD-NQTV[M] 2 Day #8 | Reloading chart. | 2022-04-25 13:18:37.850
REXR-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 13:18:48.930
REXR-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 13:18:50.252
REXR-NQTV[M] 16 Day #6 | Reloading chart. | 2022-04-25 13:18:51.234
REXR-NQTV[M] 32 Day #6 | Reloading chart. | 2022-04-25 13:18:51.850
REXR-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 13:18:53.205
RADA-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 13:18:58.689
RADA-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 13:19:04.777
RADA-NQTV[M] 64 Day #2 | Reloading chart. | 2022-04-25 13:19:05.688
RADA-NQTV[M] 64 Day #2 | Reloading chart. | 2022-04-25 13:19:07.870
RADA-NQTV[M] 12 Day #2 | Reloading chart. | 2022-04-25 13:19:09.624
RADA-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 13:19:10.728
RADA-NQTV[M] 32 Day #2 | Reloading chart. | 2022-04-25 13:19:16.163
RADA-NQTV[M] 64 Day #2 | Reloading chart. | 2022-04-25 13:19:16.822
RADA-NQTV[M] 128 Day #2 | Reloading chart. | 2022-04-25 13:19:17.894
RADA-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 13:19:19.724
RADA-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 13:19:23.777
SWCH-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 13:19:41.032
SWCH-NQTV[M] 8 Day #3 | Reloading chart. | 2022-04-25 13:19:43.038
SWCH-NQTV[M] 16 Day #3 | Reloading chart. | 2022-04-25 13:19:43.912
SWCH-NQTV[M] 32 Day #3 | Reloading chart. | 2022-04-25 13:19:44.454
SWCH-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 13:19:45.456
SWCH-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 13:19:49.421
SWCH-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 13:19:52.142
SWCH-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 13:19:58.862
SWCH-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 13:20:03.543
SWCH-NQTV[M] 2 Day #3 | Reloading chart. | 2022-04-25 13:20:10.649
SWCH-NQTV[M] 4 Day #3 | Reloading chart. | 2022-04-25 13:20:11.333
SWCH-NQTV[M] Daily #3 | Reloading chart. | 2022-04-25 13:20:24.848
STLD-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 13:20:38.658
STLD-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 13:20:39.512
STLD-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 13:20:44.752
STLD-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 13:20:45.257
STLD-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 13:20:46.426
STLD-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 13:20:47.982
STLD-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 13:20:48.833
STLD-NQTV[M] Daily #2 | Reloading chart. | 2022-04-25 13:20:50.675
SMPL-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 13:20:55.942
SMPL-NQTV[M] 16 Day #4 | Reloading chart. | 2022-04-25 13:20:56.604
SMPL-NQTV[M] 32 Day #4 | Reloading chart. | 2022-04-25 13:20:57.318
SMPL-NQTV[M] 64 Day #4 | Reloading chart. | 2022-04-25 13:20:58.087
SMPL-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 13:20:59.100
SMPL-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 13:21:00.640
SMPL-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 13:21:02.403
TXT-NQTV[M] 8 Day #13 | Reloading chart. | 2022-04-25 13:21:09.512
TXT-NQTV[M] 16 Day #13 | Reloading chart. | 2022-04-25 13:21:11.206
TXT-NQTV[M] 32 Day #13 | Reloading chart. | 2022-04-25 13:21:11.890
TXT-NQTV[M] 64 Day #13 | Reloading chart. | 2022-04-25 13:21:12.566
TXT-NQTV[M] 8 Day #13 | Reloading chart. | 2022-04-25 13:21:15.123
TXT-NQTV[M] 4 Day #13 | Reloading chart. | 2022-04-25 13:21:16.982
TSN-NQTV[M] 4 Day #7 | Reloading chart. | 2022-04-25 13:21:24.028
TSN-NQTV[M] 8 Day #7 | Reloading chart. | 2022-04-25 13:21:25.082
TSN-NQTV[M] 16 Day #7 | Reloading chart. | 2022-04-25 13:21:26.165
TSN-NQTV[M] 32 Day #7 | Reloading chart. | 2022-04-25 13:21:26.694
TSN-NQTV[M] 4 Day #7 | Reloading chart. | 2022-04-25 13:21:28.048
TSN-NQTV[M] 2 Day #7 | Reloading chart. | 2022-04-25 13:21:28.898
TSN-NQTV[M] Daily #7 | Reloading chart. | 2022-04-25 13:21:32.045
TSN-NQTV[M] 2 Day #7 | Reloading chart. | 2022-04-25 13:21:34.790
TSLA-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 13:21:44.396
TSLA-NQTV[M] 2 Day #2 | Reloading chart. | 2022-04-25 13:21:46.505
TSLA-NQTV[M] 8 Day #2 | Reloading chart. | 2022-04-25 13:21:48.719
TSLA-NQTV[M] 16 Day #2 | Reloading chart. | 2022-04-25 13:21:50.334
TSLA-NQTV[M] 4 Day #2 | Reloading chart. | 2022-04-25 13:21:53.889
TMST-NQTV[M] Daily #4 | Reloading chart. | 2022-04-25 13:22:04.967
TMST-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 13:22:06.990
TMST-NQTV[M] Daily #4 | Reloading chart. | 2022-04-25 13:22:09.061
TMST-NQTV[M] 128 Min #8 | Reloading chart. | 2022-04-25 13:22:27.819
TMST-NQTV[M] 256 Min #8 | Reloading chart. | 2022-04-25 13:22:45.167
TMST-NQTV[M] 128 Min #8 | Reloading chart. | 2022-04-25 13:22:54.709
TMST-NQTV[M] 32 Min #8 | Reloading chart. | 2022-04-25 13:22:55.435
TNET-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 13:23:03.013
TNET-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 13:23:03.471
TNET-NQTV[M] 16 Day #6 | Reloading chart. | 2022-04-25 13:23:05.151
TNET-NQTV[M] 32 Day #6 | Reloading chart. | 2022-04-25 13:23:05.658
TMST-NQTV[M] 2 Day #4 | Reloading chart. | 2022-04-25 13:23:20.621
TMST-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 13:23:23.078
TMST-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 13:23:23.923
TMST-NQTV[M] 16 Day #4 | Reloading chart. | 2022-04-25 13:23:28.564
TMST-NQTV[M] 2 Day #4 | Reloading chart. | 2022-04-25 13:23:31.680
TMST-NQTV[M] Daily #4 | Reloading chart. | 2022-04-25 13:23:37.541
TMST-NQTV[M] 2 Day #4 | Reloading chart. | 2022-04-25 13:23:38.839
TMST-NQTV[M] 2 Day #4 | Reloading chart. | 2022-04-25 13:23:47.134
TMST-NQTV[M] Daily #4 | Reloading chart. | 2022-04-25 13:23:47.854
TMST-NQTV[M] 256 Min #8 | Reloading chart. | 2022-04-25 13:23:52.396
TMST-NQTV[M] 128 Min #8 | Reloading chart. | 2022-04-25 13:23:57.184
TMST-NQTV[M] 32 Min #8 | Reloading chart. | 2022-04-25 13:23:59.101
TNET-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 13:24:13.365
TNET-NQTV[M] 16 Day #6 | Reloading chart. | 2022-04-25 13:24:15.215
TNET-NQTV[M] 32 Day #6 | Reloading chart. | 2022-04-25 13:24:15.945
TNET-NQTV[M] 64 Day #6 | Reloading chart. | 2022-04-25 13:24:17.006
TNET-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 13:24:18.412
TNET-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 13:24:20.214
TNET-NQTV[M] 16 Day #6 | Reloading chart. | 2022-04-25 13:24:29.546
TNET-NQTV[M] 3 Day #6 | Reloading chart. | 2022-04-25 13:24:30.329
TNET-NQTV[M] 264 Day #6 | Reloading chart. | 2022-04-25 13:24:31.130
TNET-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 13:24:32.122
TNET-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 13:24:33.581
TNET-NQTV[M] 64 Day #6 | Reloading chart. | 2022-04-25 13:24:39.211
TNET-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 13:24:41.776
TNET-NQTV[M] 4 Min #9 | Reloading chart. | 2022-04-25 13:24:47.135
TNET-NQTV[M] 128 Min #9 | Reloading chart. | 2022-04-25 13:24:51.842
VIRT-NQTV[M] Daily #4 | Reloading chart. | 2022-04-25 13:25:04.414
VIRT-NQTV[M] 2 Day #4 | Reloading chart. | 2022-04-25 13:25:05.391
VIRT-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 13:25:05.950
VIRT-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 13:25:08.110
VIRT-NQTV[M] 16 Day #4 | Reloading chart. | 2022-04-25 13:25:10.210
VIRT-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 13:25:11.463
VIRT-NQTV[M] 2 Day #4 | Reloading chart. | 2022-04-25 13:25:11.926
VIRT-NQTV[M] Daily #4 | Reloading chart. | 2022-04-25 13:25:15.940
VIRT-NQTV[M] 2 Day #4 | Reloading chart. | 2022-04-25 13:25:22.705
VIRT-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 13:25:28.935
VIRT-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 13:25:31.371
VIRT-NQTV[M] 16 Day #4 | Reloading chart. | 2022-04-25 13:25:33.825
VIRT-NQTV[M] 2 Day #4 | Reloading chart. | 2022-04-25 13:25:36.057
VIRT-NQTV[M] Daily #4 | Reloading chart. | 2022-04-25 13:25:39.232
WCN-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 13:25:55.099
WCN-NQTV[M] 16 Day #6 | Reloading chart. | 2022-04-25 13:25:56.222
WCN-NQTV[M] 32 Day #6 | Reloading chart. | 2022-04-25 13:25:56.976
WCN-NQTV[M] 64 Day #6 | Reloading chart. | 2022-04-25 13:25:57.616
WCN-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 13:25:59.061
WCN-NQTV[M] 8 Day #6 | Reloading chart. | 2022-04-25 13:26:00.037
WCN-NQTV[M] 4 Day #6 | Reloading chart. | 2022-04-25 13:26:02.572
WCN-NQTV[M] 2 Day #6 | Reloading chart. | 2022-04-25 13:26:07.524
WMT-NQTV[M] Daily #4 | Reloading chart. | 2022-04-25 13:26:24.814
WMT-NQTV[M] 4 Day #4 | Reloading chart. | 2022-04-25 13:26:25.983
WMT-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 13:26:27.009
WMT-NQTV[M] 16 Day #4 | Reloading chart. | 2022-04-25 13:26:30.319
WMT-NQTV[M] 32 Day #4 | Reloading chart. | 2022-04-25 13:26:31.862
WMT-NQTV[M] 64 Day #4 | Reloading chart. | 2022-04-25 13:26:32.649
WMT-NQTV[M] 128 Day #4 | Reloading chart. | 2022-04-25 13:26:35.310
WMT-NQTV[M] 16 Day #4 | Reloading chart. | 2022-04-25 13:26:38.035
WMT-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 13:26:41.649
WMT-NQTV[M] 16 Day #4 | Reloading chart. | 2022-04-25 13:26:48.057
WMT-NQTV[M] 8 Day #4 | Reloading chart. | 2022-04-25 13:26:49.896
AA-NQTV[M] 8 Day #9 | Reloading chart. | 2022-04-25 13:27:20.928
AA-NQTV[M] 16 Day #9 | Reloading chart. | 2022-04-25 13:27:25.691
AA-NQTV[M] 2 Day #9 | Reloading chart. | 2022-04-25 13:27:37.934
AA-NQTV[M] 4 Day #9 | Reloading chart. | 2022-04-25 13:27:38.877
AA-NQTV[M] 2 Day #9 | Reloading chart. | 2022-04-25 13:27:40.406
AA-NQTV[M] 4 Day #9 | Reloading chart. | 2022-04-25 13:27:43.756
AA-NQTV[M] 4 Day #9 | Reloading chart. | 2022-04-25 13:28:00.260
AA-NQTV[M] 2 Day #9 | Reloading chart. | 2022-04-25 13:28:01.490
AA-NQTV[M] Daily #9 | Reloading chart. | 2022-04-25 13:28:04.448
AA-NQTV[M] 4 Day #9 | Reloading chart. | 2022-04-25 13:28:11.236
AA-NQTV[M] 8 Day #9 | Reloading chart. | 2022-04-25 13:28:12.264
AA-NQTV[M] 16 Day #9 | Reloading chart. | 2022-04-25 13:28:14.779
AA-NQTV[M] 2 Day #9 | Reloading chart. | 2022-04-25 13:28:22.352
BILI Daily #3 | Reloading chart. | 2022-04-25 13:28:34.194
APPS Daily #5 | Reloading chart. | 2022-04-25 13:28:40.032
APPS 4 Day #5 | Reloading chart. | 2022-04-25 13:28:43.626
APPS 88 Day #5 | Reloading chart. | 2022-04-25 13:28:44.601
APPS 4 Day #5 | Reloading chart. | 2022-04-25 13:28:45.563
APPS 8 Day #5 | Reloading chart. | 2022-04-25 13:28:47.785
APPS 4 Day #5 | Reloading chart. | 2022-04-25 13:28:49.967
APPS 8 Day #5 | Reloading chart. | 2022-04-25 13:28:52.734
APPS 16 Day #5 | Reloading chart. | 2022-04-25 13:28:53.886
APPS 4 Day #5 | Reloading chart. | 2022-04-25 13:29:05.288
APPS 2 Day #5 | Reloading chart. | 2022-04-25 13:29:11.509
APPS 4 Day #5 | Reloading chart. | 2022-04-25 13:29:15.295
APPS 2 Day #5 | Reloading chart. | 2022-04-25 13:29:16.709
APPS 4 Day #5 | Reloading chart. | 2022-04-25 13:29:22.046
APPS 4 Day #5 | Reloading chart. | 2022-04-25 13:29:30.861
APPS 8 Day #5 | Reloading chart. | 2022-04-25 13:29:36.613
APPS 16 Day #5 | Reloading chart. | 2022-04-25 13:29:41.094
APPS 8 Day #5 | Reloading chart. | 2022-04-25 13:29:44.340
APPS 16 Day #5 | Reloading chart. | 2022-04-25 13:29:46.005
APPS 4 Day #5 | Reloading chart. | 2022-04-25 13:29:47.646
APPS 8 Day #5 | Reloading chart. | 2022-04-25 13:29:51.881
APPS 4 Day #5 | Reloading chart. | 2022-04-25 13:29:53.940
APPS Daily #5 | Reloading chart. | 2022-04-25 13:29:55.008
APPS Daily #7 | Reloading chart. | 2022-04-25 13:30:20.203
Enabling compression for file: C:\SierraChart\Data\APPS-nqtv.scid. This may take a while. | 2022-04-25 13:30:36.580
File compression enabled. C:\SierraChart\Data\APPS-nqtv.scid. CompressionState=0 | 2022-04-25 13:30:36.580
APPS-nqtv 10 Day 960 Min #7 | Reloading chart. | 2022-04-25 13:30:36.581
APPS-nqtv 10 Day 960 Min #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\APPS-nqtv.scid | 2022-04-25 13:30:36.590
Mapping APPS-nqtv to APPS-nqtv. Service code: nasdaq_exchange.data | 2022-04-25 13:30:37.105
SC Data - All Services | Starting real-time market data updates for: APPS-nqtv (APPS-nqtv). ID: 187 Service code: nasdaq_exchange.data | 2022-04-25 13:30:37.105
SC Data - All Services | Requesting security definition data for: APPS-nqtv (APPS-nqtv). ID: 187 | 2022-04-25 13:30:37.105
Added historical Intraday data request for APPS-nqtv to the queue. | 2022-04-25 13:30:37.105
Intraday data recording state for symbol APPS-nqtv is set to download 'Pending'. | 2022-04-25 13:30:37.105
Triggering next historical data download in queue. | 2022-04-25 13:30:37.105
Delaying start of download for APPS-nqtv | 2022-04-25 13:30:37.106
Message from IB: Error validating request.-'bR' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 187. Symbol: APPS-nqtv | 2022-04-25 13:30:37.107
SC Data - All Services | Received security definition for symbol APPS-nqtv | 2022-04-25 13:30:37.395
HD Request # 229 | Downloading Intraday chart data for APPS-nqtv to the file APPS-nqtv.scid. Service: nasdaq_exchange.data | 2022-04-25 13:30:42.807
HD Request # 229 | Download start date-time: 2021-10-21 13:30:42.000000. File last date-time: 00:00:00.000000 | 2022-04-25 13:30:42.808
HD Request # 229 | Using server: ds25.sierracharts.com port 10149 | 2022-04-25 13:30:42.808
Socket (2) | Creating socket. | 2022-04-25 13:30:42.808
Socket (2) | New receive buffer size: 5242880 | 2022-04-25 13:30:42.808
Socket (2) | Connecting to IP: 38.65.8.115. | 2022-04-25 13:30:42.808
HD Request # 229 | Setting DTC encoding to Binary VLS | 2022-04-25 13:30:43.271
HD Request # 229 | Sending historical data logon request message. | 2022-04-25 13:30:43.271
HD Request # 229 | Requesting Intraday data. Start date-time: 2021-10-21 13:30:42. Record interval: 0. Symbol: APPS-nqtv | 2022-04-25 13:30:43.974
HD Request # 229 | Decompressing data. | 2022-04-25 13:30:44.204
HD Request # 229 | Receiving Intraday data for APPS-nqtv starting at 2021-10-21 13:30:47.872000 | 2022-04-25 13:30:44.898
HD Request # 229 | Timestamp of first Intraday data file record written: 2021-10-21 13:30:47.872000 | 2022-04-25 13:30:46.067
Socket (2) | CloseSocket call. | 2022-04-25 13:30:59.581
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-04-25 13:30:59.581
Historical data download thread signaled to stop. | 2022-04-25 13:30:59.594
HD Request # 229 | Received 1448600 Intraday data records from 2021-10-21 13:30:47.872000 to 2022-04-25 13:30:43.093000 (186.0 days) and wrote 1448600 records for APPS-nqtv | 2022-04-25 13:30:59.594
HD Request # 229 | Completion time: 17s | 2022-04-25 13:30:59.595
HD Request # 229 | Intraday data download complete for APPS-nqtv. Unique request ID: 230 | 2022-04-25 13:30:59.595
Removing historical data download ID 230. | 2022-04-25 13:30:59.595
Real-time Intraday chart data file updates started for APPS-nqtv | 2022-04-25 13:30:59.595
Intraday chart data file opened for APPS-nqtv | 2022-04-25 13:30:59.595
HD Request # 229 | Enabling Intraday chart updating for symbol. | 2022-04-25 13:30:59.595
Triggering next historical data download in queue. | 2022-04-25 13:30:59.595
No download requests in the queue to start downloads for. | 2022-04-25 13:30:59.595
Socket (2) | Socket gracefully closed by remote side. | 2022-04-25 13:30:59.807
Socket (2) | Closed. | 2022-04-25 13:30:59.808
APPS-nqtv[M] 128 Min #7 | Reloading chart. | 2022-04-25 13:31:02.692
APPS-nqtv[M] 256 Min #7 | Reloading chart. | 2022-04-25 13:31:04.501
Opened cached Intraday file: C:\SierraChart\Data\APPS-nqtv.scid. Thread ID: 19936 | 2022-04-25 13:31:05.799
APPS-nqtv[M] 1 Day #7 | Reloading chart. | 2022-04-25 13:31:15.195
APPS-nqtv[M] 256 Min #7 | Reloading chart. | 2022-04-25 13:31:31.728
APPS-nqtv[M] 64 Min #7 | Reloading chart. | 2022-04-25 13:31:37.087
Saved Chartbook: MACRO.Cht. Time: 0.0219 seconds. | 2022-04-25 13:33:40.566
Saved Chartbook: SCREENING.Cht. Time: 0.0007 seconds. | 2022-04-25 13:33:40.567
Saved Chartbook: ACTION.Cht. Time: 0.0011 seconds. | 2022-04-25 13:33:40.569
Saved Chartbook: AGGS.Cht. Time: 0.0101 seconds. | 2022-04-25 13:33:40.580
Saved Chartbook: INDICES.Cht. Time: 0.0108 seconds. | 2022-04-25 13:33:40.591
Saved Chartbook: METALS.Cht. Time: 0.0043 seconds. | 2022-04-25 13:33:40.596
Saved Chartbook: ENERGY.Cht. Time: 0.0241 seconds. | 2022-04-25 13:33:40.621
Saved Chartbook: CRYPTO.Cht. Time: 0.0128 seconds. | 2022-04-25 13:33:40.634
Saved Chartbook: FOREX.Cht. Time: 0.0120 seconds. | 2022-04-25 13:33:40.647
Saved Chartbook: AAA.Cht. Time: 0.0221 seconds. | 2022-04-25 13:33:40.670
Saved Chartbook: BBB.Cht. Time: 0.0024 seconds. | 2022-04-25 13:33:40.673
Saved Chartbook: CCC.Cht. Time: 0.0219 seconds. | 2022-04-25 13:33:40.695
Saved Chartbook: DDD.Cht. Time: 0.0035 seconds. | 2022-04-25 13:33:40.699
Saved Chartbook: EEE.Cht. Time: 0.0130 seconds. | 2022-04-25 13:33:40.713
Saved Chartbook: FFF.Cht. Time: 0.0107 seconds. | 2022-04-25 13:33:40.724
Saved Chartbook: GGG.Cht. Time: 0.0035 seconds. | 2022-04-25 13:33:40.729
Saved Chartbook: HHH.Cht. Time: 0.0130 seconds. | 2022-04-25 13:33:40.742
Saved Chartbook: III.Cht. Time: 0.0017 seconds. | 2022-04-25 13:33:40.744
Saved Chartbook: KKK.Cht. Time: 0.0030 seconds. | 2022-04-25 13:33:40.748
Saved Chartbook: LLL.Cht. Time: 0.0113 seconds. | 2022-04-25 13:33:40.760
Saved Chartbook: MMM.Cht. Time: 0.0016 seconds. | 2022-04-25 13:33:40.762
Saved Chartbook: NNN.Cht. Time: 0.0029 seconds. | 2022-04-25 13:33:40.766
Saved Chartbook: OOO.Cht. Time: 0.0030 seconds. | 2022-04-25 13:33:40.769
Saved Chartbook: PPP.Cht. Time: 0.0128 seconds. | 2022-04-25 13:33:40.783
Saved Chartbook: RRR.Cht. Time: 0.0029 seconds. | 2022-04-25 13:33:40.786
Saved Chartbook: SSS.Cht. Time: 0.0033 seconds. | 2022-04-25 13:33:40.790
Saved Chartbook: TTT.Cht. Time: 0.0138 seconds. | 2022-04-25 13:33:40.804
Saved Chartbook: UUU.Cht. Time: 0.0013 seconds. | 2022-04-25 13:33:40.806
Saved Chartbook: VVV.Cht. Time: 0.0031 seconds. | 2022-04-25 13:33:40.810
Saved Chartbook: WWW.Cht. Time: 0.0044 seconds. | 2022-04-25 13:33:40.815
Saved Chartbook: XXX.Cht. Time: 0.0115 seconds. | 2022-04-25 13:33:40.827
Saved Chartbook: ZZZ.Cht. Time: 0.0015 seconds. | 2022-04-25 13:33:40.829
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 128 Min #8 | Reloading chart. | 2022-04-25 13:36:45.506
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD 128 Min #8 | StartDateTimeForLoadingOrderFills: 2021-10-18 09:30:00 | 2022-04-25 13:36:45.538
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD Daily #2 | Reloading chart. | 2022-04-25 13:36:58.842
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD Daily #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 13:36:58.864
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD Daily #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 13:37:30.099
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD Daily #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 13:38:31.920
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD Daily #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 13:38:33.000
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD Daily #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 13:38:33.950
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD Daily #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 13:38:49.544
ACRS-NQTV[M]/ACRSn-CFD-SMART-USD Daily #2 | StartDateTimeForLoadingOrderFills: 2015-10-07 00:00:00 | 2022-04-25 13:39:04.711
[2022-04-25 17:46:38]
michelh - Posts: 159
https://www.sierrachart.com/image.php?Image=165090876582.png
[2022-04-25 17:53:18]
Here is what fixes it.
For the charts where I have an open trade, I had the symbol for interactive brokers to trade it since I cannot trade the NQTV symbol.
It only happens in charts I am trading.
Now I am short this stock ACRS.
But the IB symbol is ACRSn-CFD-SMART-USD
I do not trade the stock directly; I trade CFD since I am not US resident.
Now here is what is Interesteing. If I go into chart and DELETE the trade symbol "ACRSn-CFD-SMART-USD" then the daily bar magically appears when I do a delete data and download. BUT now I cannot see my order fills and orders. So I have to use intraday if I want to see my orders and fills.
So the error only happens to me when I put in an IB symbol in the chart settings so I can manage my trade form the chart. Otherwise your feed works fine.
[2022-04-25 17:59:02]
John - SC Support - Posts: 38547
Please enable the option for Use as Trade Only Symbol. Refer to the following:
Chart Settings: Use as Trade Only Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu)
Let us know if that resolves your issue.
[2022-04-25 18:23:27]
yes thanks it fixes it. the daily bar now appears.
FYI
I cannot use the chart to drag my orders with the mouse.
maybe because I am trading CFD and not stock directly?
either way, I am grateful to be able to see my orders on the chart and I will use IB TWS to modify orders.
[2022-04-25 21:16:47]
If you have entered the order from Sierra Chart, then, in general, you should be able to modify the attached orders on the chart. But refer to the following information related to this:
Interactive Brokers Trading Service: Orders Not Responded to from Trader Workstation
