Date/Time: Mon, 10 Mar 2025 22:35:17 +0000
How to edit limit order stop settings & Trade multiple accounts simultaneously
View Count: 621
[2022-04-15 21:05:52]
User576648 - Posts: 26
1) How to edit limit order stop settings when I set it by right click & then clicking on buy or sell limit. by default, it's set up to 5 points on ES. check the Pic down below for more info.
2) How to trade multiple accounts simultaneously using "rithmic" order routing putting in mind I got multiple charts open for the same pair & I execute on different ones every time & only got a "trade window" open on one chart? Do I have to enable "Order Allocation to Trade Accounts" through the "trade window" on each chart and then remove it or do I need to keep it open on all charts?
image2222.JPG / V - Attached On 2022-04-15 21:05:42 UTC - Size: 12.36 KB - 129 views
[2022-04-18 14:03:46]
John - SC Support - Posts: 38547
1) Any order you place manually is going to use the order setup that exists in the Trade Window for that chart at that time. Therefore, in this case, you need to adjust the Stop settings on the Targets tab on the Trade Window. Refer to the following:
Basic Trading and the Trade Window: Targets tab (Attached Orders)
2) If the accounts are part of the same Rithmic login - that is you have access to the accounts through the one login and they are not separate logins, then you can do either of the following:
- If you are wanting to place the exact same trades on multiple accounts, then you would want to use the Order Allocation to Trade Accounts feature.
- If you are wanting to trade both accounts within Sierra Chart at the same time, but different orders, then refer to the following for how to change your Trade Account:
Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM)
If the accounts are under different logins, then the only option is to trade each one separate, and the easiest way to do that is to have multiple Sierra Chart installations, one for each account. Refer to the following for how to install another Sierra Chart:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
