Date/Time: Mon, 10 Mar 2025 23:06:45 +0000
alerts from multiple chartbooks at once
View Count: 493
[2022-04-15 18:25:50] |
jakeybleez - Posts: 56 |
hello, i can't seem to find a setting that toggles the option to stop alerts from every chartbook i have open on, and just for the one that is being used. i found this is the manual that said "The chart does not have to be visible, even if it is in another chartbook which is loaded but not visible. The chart only needs to be open but can be open in the background", but couldnt find anything about how to change it |
[2022-04-15 20:35:35] |
John - SC Support - Posts: 38547 |
There is not a way to turn off Alerts from specific Chartbooks.
[2022-04-19 11:20:37] |
Also refer to: Global Settings Menu: Mute All Alert Sounds (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
