Date/Time: Mon, 10 Mar 2025 22:43:12 +0000
question package
View Count: 414
[2022-04-15 16:26:25] |
zeekland nicolas - Posts: 1 |
bonjour j adore sierra chart et je voulais savoir qu est ce que je doit prendre comme pack pour avoir accès au volume profile et voir la profondeur de marché du YM et le cour du prix en temps reel. ainsi que celui le cfd du ym et je traderai avec le carnet d ordre de ninja tradeur merci |
[2022-04-15 17:06:59] |
John - SC Support - Posts: 38547 |
From Google Translate: hello I love sierra chart and I wanted to know what I should take as a pack to have access to the volume profile and see the depth of the YM market and the price in real time. as well as the cfd of the ym and I will trade with the order book of ninja tradeur
thank you The Volume Profile is available in our standard package, and the same is true if you just want to see the Market Depth in the DOM. But, if you want to use the Market Depth Historical Graph, then you would need the Advanced Package. Refer to the differences in the packages here: Description of Service Packages and Pricing: Packages CFD data is included with all Sierra Chart packages at no extra cost. Refer to the information here: Sierra Chart Real Time and Historical Forex and CFD Data Service --- With regards to the YM, since this is part of the CME Group data, it makes things a bit complicated. The CME Group requires that you have a live, funded, futures trading account to which you can connect your Sierra Chart software in order to qualify as a non-professional for the exchanges. Otherwise, you would have to pay the much higher Professional exchange fees. Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If you do not have a futures trading account that you can connect to at least once a month to verify your status as a non-professional, then we recommend the service outlined at at the following link: Easy Solution to CME Funded Trading Account Requirement However you decide to deal with this, you will then need to get the data for the YM from our Denali Exchange Data Feed. Refer to the Setup Instructions for the CME Group data here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
