Date/Time: Mon, 10 Mar 2025 22:37:34 +0000
Installation on an additional computer running on Windows 7 32 bits
View Count: 406
[2022-04-15 16:26:04] |
User57584 - Posts: 30 |
I'd like to install Sierra on a second computer as my license allows to do so. This PC is presently running on Windows 7 32bits and I cannot install Sierra. Does it require 64 bits version or is there a way to use another Sierra Chart version, compatible with this computer ? Thank you very much in advance. Best regards Jean-Marie Boulay |
[2022-04-15 16:59:47] |
John - SC Support - Posts: 38547 |
Sierra Chart requires a 64-bit computer at this time. There are no versions available that can run on a 32-bit system.
