Date/Time: Mon, 10 Mar 2025 22:07:09 +0000
Equities data
View Count: 608
[2022-04-15 16:13:12] |
jakeybleez - Posts: 56 |
hello, i cancelled my equties data because i could not get the platform to run like it does with futures. i was wondering if you could help me figure it out so i could sign up for equities again! basically anytime i load a TPO chart there is horrible lag.. would you be able to recommend to me which settings to adjust to make it run the best without losing any data? i hope you had a great holiday weekend! - Jake https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=63428 |
[2022-04-15 16:50:23] |
John - SC Support - Posts: 38547 |
There is no reason why there would be any difference in the way the chart behaves simply because it is an equities chart instead of a futures chart. In terms of performance, refer to the following: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.48 - Basic Steps to Resolve Performance Issue in Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-15 17:14:06] |
The problem most likely is related to this: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.23 - Chart Tick Size and Volume at Price Processing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-15 17:32:22] |
thanks. is there a tick size for the chart and my tpo that you would recommend as a max to make sure i dont lose too much data?
[2022-04-15 17:41:16] |
The Tick Size is determined by the instrument and is not something you should change. As to the Letter/Block Price Increment in Ticks, that is something you will have to figure out for yourself, in terms of the tradeoff of the larger letters/blocks versus the underlying data and what you want to see. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
