Date/Time: Mon, 10 Mar 2025 22:09:39 +0000
Transact
View Count: 388
[2022-04-15 16:11:35]
User180435 - Posts: 8
do we have a date to where tranact and sierra will no long er be linked ? need to know when I need to switch to sierra data
[2022-04-15 16:34:36]
John - SC Support - Posts: 38547
Any version of Sierra Chart from 2354 onwards no longer supports TransAct. You can continue to use a Sierra Chart version prior to that point for as long as possible. But, we do not give any support, and should there be a change on the TransAct side that breaks the connectivity, then there is nothing we can do.
Therefore, if you want to continue to use Sierra Chart, we recommend moving to a new broker as soon as possible. If you are only trading instruments from the CME Group, then we recommend using our Teton Order Routing Service. The list of brokers supporting this service can be found in Step #2 here:
Sierra Chart Teton Futures Order Routing: Setup Instructions
[2022-04-15 16:59:35]
We think the date is going to be September 2022.
We will be shutting down the historical data at that time and effectively makes it impossible for our Sierra Chart users to continue with Transact unless you are using the Denali Exchange Data Feed.
And if you update to our newer versions, you cannot connect to Transact and you would have to move to our Teton Order routing.
Let us know if you need help with any of this and we can help you get transitioned the Denali data feed and our Teton order routing.
