Date/Time: Mon, 10 Mar 2025 22:12:41 +0000
quick update from laptop to dusty PC Sierra version
View Count: 403
[2022-04-15 16:09:48] |
moneylovesdwayne - Posts: 5 |
Hi, I have everything working except the global graphic settings and am wondering where to copy that file from to the other install please? In short, I don't want to do a full copy over as I don't need to, I just want to find the file where global graphic settings are stored and copy it please if feasible... thanks dwayne |
[2022-04-15 16:22:54] |
John - SC Support - Posts: 38547 |
Global Graphic Settings are stored in the file named Sierra4.config. You will find this file in the main Sierra Chart installation folder. The information on what is stored in what files can be found here: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
