Date/Time: Mon, 10 Mar 2025 22:34:10 +0000
Deribit - Volatility Index_No Data
View Count: 435
[2022-04-15 16:03:28]
User662810 - Posts: 2
could I please for any help? Thank you in advance.
Primary symbol: BTC-VIX-DBIT
I am able to see correctly whole data feed from Deribit (Find Symbol_Deribit), but I am not able to get Indexes data. For example BTC-VIX-DBIT, ETH-VIX-DBIT, BTC-DERIBIT-INDEX-DBIT.
I am not getting any error. SC process:
1) searching
2) downloading
3) downloaded, but 0 data (screen - attachment PNG)
Any idea how to fix it? Could anybody try to check the connection? Just for clafiry where is the problem (My client, SC, Deribit)?
Date Time Of Last Edit: 2022-04-15 16:14:20
imageUnbenannt.PNG / V - Attached On 2022-04-15 16:08:01 UTC - Size: 26.53 KB - 123 views
[2022-04-15 16:25:23]
There is no data available for those symbols and it is not something we are going to research as to why. It is not a problem on the Sierra Chart side though.
