Date/Time: Tue, 29 Sep 2026 05:51:42 +0000
Searched, but to be certain, there is currently no way to copy Chart Graphics settings
View Count: 814
| [2022-04-15 01:49:03] |
| dbtrade - Posts: 24 |
I played around with a chart and DOM until I had just the look I wanted, only to later realize there doesn't appear to be a way to copy those setting to the Global graphics settings. Just making sure I am not missing something and that copying the individual chart graphics settings to the global graphics settings is not supported. |
| [2022-04-15 14:02:24] |
| John - SC Support - Posts: 48044 |
You are correct, there is not a way to copy the chart graphics settings to the Global Graphics Settings. Just keep in mind, however, that you can use that chart as a template and duplicate it in order to get a different chart. Refer to the information here: Using Chart Templates: Duplicating Charts / Template Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-04-16 17:21:25] |
Duplicate is obviously not ideal for changing over densely populated chartbooks. Ideally, the two windows could both be open to facilitate copying from local to global. Will there be an update to the settings windows similar to the chart settings window that will allow this? |
| [2022-04-16 18:46:29] |
| caligola - Posts: 116 |
1) detach the chart with the custom Chart Graphics settings2) open the Graphics settings - Global 3) open the Chart Graphics settings of the chart at point #1 4) now you can put both windows (Graphics settings - Global and Chart Graphics settings) side by side |
| [2022-04-16 21:04:55] |
Awesome workaround. Thanks!
