Date/Time: Wed, 16 Sep 2026 11:12:28 +0000
dom recenter line
View Count: 882
| [2022-04-14 20:04:06] |
| Gtrader510 - Posts: 76 |
hello support while using dom recenter line doesnt follow the price it lags only reset when scroll up or down and stop again.
| [2022-04-14 20:25:15] |
| John - SC Support - Posts: 47903 |
We are not understanding what you are trying to state is the issue. The Trade DOM Recenter Line is going to be in a static position (it will not move). It shows where the center of the window is located and where the price will recenter to when the command is given to recenter. If there is something not working given the above, then please let us know exactly what it is and how you are setup so we can see if we can reproduce the issue. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
