Date/Time: Mon, 10 Mar 2025 22:19:46 +0000
High/Low
View Count: 428
[2022-04-14 14:45:31]
User996274 - Posts: 96
would the hi/lo indicator work on other indicators?
for instance say a macd would the hi/lo "record and save" the extreme, like it does in the price graph?
Or is there another way to document the extremes and lock that number, even as the indicator pulls back?
thnx
[2022-04-14 15:01:02]
John - SC Support - Posts: 38547
Yes, you can do this. Refer to the following for how to base a study on another study:
Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study
