Date/Time: Fri, 02 Oct 2026 07:04:21 +0000
New Menus - align with the documentation
View Count: 766
| [2022-04-14 13:34:23] |
| Technical - Posts: 158 |
Is there a rosetta stone document to help us translate the new menu style to the old documentation? For instance, the documentation tells one to go to Chart >> Chart Settings >> Advanced Settings 3 however Advanced Settings 3 no longer appears to exist. |
| [2022-04-14 14:18:24] |
| John - SC Support - Posts: 48086 |
We are working on getting it updated.
| [2022-04-14 14:19:06] |
This is actively being worked on now.
