Date/Time: Mon, 10 Mar 2025 23:27:26 +0000
Second instance not connecting
View Count: 438
[2022-04-14 13:23:53] |
User276793 - Posts: 55 |
HI I am trying to open a second instance but i keep getting "Sub Instance Disconnected" over and over See the image attached any ideas? |
[2022-04-14 13:29:46] |
another image
[2022-04-14 14:00:23] |
And did you start this sub instance with File >> New Instance? How many instances of Sierra Chart are you currently running not including this sub instance? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-14 14:00:41
[2022-04-20 12:53:56] |
Yes i used file new instance. I only ever ran one instance for years, was trying to open a second one.
