Date/Time: Mon, 10 Mar 2025 22:39:50 +0000
is there a way to show a ratio of candle spread and cumulative delta bar
View Count: 508
[2022-04-14 13:05:04] |
User487407 - Posts: 4 |
Are there any built in study that can do that
[2022-04-14 14:17:34] |
John - SC Support - Posts: 38547 |
You can always put together a collection of Arithmetic Studies or use the Spreadsheet Formula and enter the formula you want using the Alerts syntax. Refer to the following for the Arithmetic Studies: Using the Basic Arithmetic Studies And refer to the following for the Spreadsheet Formula: Spreadsheet Formula For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
