Date/Time: Tue, 26 Nov 2024 09:51:20 +0000
TPO and Volume Profile
View Count: 1387
[2014-04-24 12:37:32]
Discount - Posts: 73
Is there some way to have the labels of each line show up on the TPO and Volume Profile Charts. I do understand in the settings>subgraphs> there is the draw style, and the name label and value label, but when I click on draw style to visible, and put a check in the name label and value label, nothing shows on my TPO or Volume profile charts. Is there some other setting somewhere I need to check to so these labels show up on my TPO and Volume Profile charts?
[2014-04-25 02:08:02]
We need to know what lines you are referring to. Can you post an image of the chart by following these instructions:
https://www.sierrachart.com/index.php?l=PostingInformation.php#Image
[2014-04-25 02:33:50]
http://www.sierrachart.com/image.php?l=1398393072184.png
[2014-04-25 02:34:44]
The lines I would like to label are the ones I have added circles on. Thanks
[2014-04-28 18:06:25]
Here is the documentation to enable Value labels for the Point of Control and Value Area lines:
http://www.sierrachart.com/index.php?l=doc/doc_TPOVolProfileCharts.html#POCAndValueAreaExtensionLineLabels
What are the short orange and green lines?
Date Time Of Last Edit: 2014-04-29 09:11:11
[2014-04-28 18:27:10]
You are asking me what the orange and green lines are, that is a good question. I got this chart book from another confused newbie to sierra charts, so I have no idea. When I asked about labels, I was hoping to be able to label what the lines were not as in price. I can guestimate on the price, but I would like the names of the lines to show up. Can Sierra Charts do that, label with names for the lines?
[2014-04-30 01:05:42]
We need to make a correction. We indicated in our prior response that you could use name and value labels. You can only use Value labels.
Date Time Of Last Edit: 2014-04-30 03:26:00
[2014-04-30 02:43:05]
What???
You are saying two things here. I am going to quote you: "We indicated in our prior response that you could use "name AND value labels". Then you say, and I am quoting: "You can only use Value labels".
Now English is my main language. And your statements are very confusing, as you are saying one thing, and then saying another.
Please be more clear for those of us that have a hard time understanding your English. Thanks
[2014-04-30 03:25:05]
Yes, this is correct. We made a correction. You can only use the Value labels for the Point of Control and Value Area lines.
