Date/Time: Mon, 10 Mar 2025 22:41:54 +0000
Adjacent alerts in Volume at price Threshold Alert V2
View Count: 418
[2022-04-14 10:24:37] |
User878643 - Posts: 9 |
How can I get an alert whenever there's an occurrence of "Highlight adjacent alerts minimum group size" set to 2. The highlight is SG49 I believe. Thanks in advance! |
[2022-04-14 13:58:48] |
John - SC Support - Posts: 38547 |
There is not a way to do this with the way the study is currently built. The source code for the study is available and is in the file Studies8.cpp which is located in the ACS_Source folder under your main Sierra Chart installation. You can modify the study to your needs. Refer to the following: How to Build an Advanced Custom Study from Source Code For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
