Date/Time: Wed, 23 Apr 2025 03:04:39 +0000
pulling and stacking
View Count: 3572
[2022-04-14 00:23:47] |
Steve Leon - Posts: 312 |
i have noticed that when the Globex session starts the pulling and stacking numbers are very negative on the Trade DOM. Not sure if this is accurate/correct ? It does not seem like it would be since it appears that there is stacking on both sides yet cumulative number on both bid and ask is very negative Does it need to be reset ? How do you make changes to this I did not find anything in the support Thank you Steven Leon |
[2022-04-14 15:36:56] |
User578003 - Posts: 17 |
I think it is accurate, when Globex starts initially they will pull their orders and or it could be the brokers of retail will do that to customers depending on their margin and after hours rules, but it is common at least to me. Could be wrong though
[2022-04-14 19:07:59] |
Where in that screenshot of the Sierra Chart trading DOM do you see a very negative pulling/stacking value?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-14 19:08:09
[2022-04-15 00:04:49] |
sorry i attached the wrong image it was this image Thank you |
[2022-04-15 09:44:04] |
Those values do not look correct. We need to look into this.
[2022-04-15 22:06:37] |
Sierra_Chart Engineering - Posts: 19307 |
We are not identifying any issue yet but what you show us in that screenshot clearly looks wrong.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-15 22:57:41
[2022-04-15 22:23:06] |
Thank you very much for looking into it.
[2022-04-26 12:48:57] |
so i noticed the issue agin last evening during Globex I happen to for unrelated reasons, made a copy of the Trade DOM that i sent you previous picture from my main instance because trying to address lagging issues/performance that i have discussed in other threads That copy I placed in a new sub instance and removed all Study subgraphs that i had in the original I noticed that the pulling and stacking numbers were significantly different for the original Trade DOM. The numbers seemed to "make sense" I am attaching a picture of the two Trade DOM's What are your thoughts |
Private File |
[2022-04-29 06:51:59] |
The pulling and stacking sums in this Trading DOM on the right of this screenshot clearly are wrong: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=63751 We have identified one potential issue in the code that perhaps is related to this and fixed it. We are putting out version 2388. As far as why the individual pulling and stacking values can be different at the same price levels in different installations of Sierra Chart, we put together this documentation about this: Global Trade Settings Windows: Bid Market Depth Pulling/Stacking - Left/Center/Right Aligned Different installations of Sierra Chart can show slightly or significantly different values for the pulling and stacking value at the same price level in the two installations of Sierra Chart you are comparing. The information here assumes each installation of Sierra Chart is using the same data feed. The reason for the difference is that the pulling and stacking values are incrementally calculated from the changes in market depth data since the time of connection to the data feed. Each installation of Sierra Chart will have a different connection time to the data feed. Also make sure the Maximum Bid/Ask Market Depth Pulling/Stacking Levels setting is the same between the two installations of Sierra Chart.
[2023-03-28 23:53:54] |
skyfly93 - Posts: 34 |
Hi SC, I've noticed discrepancies between 2 of my SC installations (both version 2484) of the pulling and stacking values and total. See images attached. The max market depth for both installations are set to 25 and the max pulling stacking depth is set to 25. ZN https://www.sierrachart.com/image.php?Image=1680047444167.png https://www.sierrachart.com/image.php?Image=1680047465252.png Let me know if you need further information. I'm observing this discrepancy in the pulling stacking depth across the following instruments I track: ZN, GC, NG, CL, ES. NQ shows the same values. |
[2023-03-30 14:13:26] |
The Pulling/Stacking numbers are going to be accumulated from the time that that symbol started to receive data. Therefore, you can not make comparisons between installations for the Pulling/Stacking data. If they happen to match for one symbol, that is just luck in terms of the timing.
