Date/Time: Sun, 04 Oct 2026 04:41:06 +0000
Scale - Is there a way to show only the last 3 digits on the price scale for index USD-X?
View Count: 1514
| [2022-04-13 17:48:09] |
| HumblyTrading - Posts: 222 |
Hello SC Team, Is there a way to only show the last 3 or 4 digits on the scale. For example, when using the scale for USD-X index, it needs to be set to 0.000001 in order to see 3 significant figures. This makes the scale different in width from my other charts, so that the symmetry of stacking them on top of each other gets disfigured. Thank you for any help, Mike T https://www.sierrachart.com/image.php?Image=1649871890134.png |
| [2022-04-13 18:02:10] |
| John - SC Support - Posts: 48095 |
Refer to the following setting to see if this will work for what you want: Chart Settings: Limit Price Displayed to N Right Characters (Chart >> Chart Settings >> Display >> Chart Display Items menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-04-13 19:09:01] |
Thank you That was a good idea, but didn't quite have the desired effect. Instead of truncating the numbers and shrinking the column width of the price scale, it truncates the numbers, but keeps the larger column width. This is the effect. https://www.sierrachart.com/image.php?Image=1649876835903.png |
| [2022-04-18 20:06:04] |
Have a look at this setting and see if it helps: Chart Scale and Scale Adjusting: Include in Scale Width Calculation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
