Date/Time: Tue, 22 Sep 2026 09:26:37 +0000
Custom DLL Study- Distribution - Service Level Access
View Count: 1072
| [2022-04-13 16:34:29] |
| DayTraderEsad - Posts: 121 |
I have a custom study DLL file and I just can't figure out how to add the service level, where does the code need to be added. I used this link: Advanced Custom Study Interface and Language (ACSIL): Redistributing and Allowing Use Only by a Defined List of Users I looked at this as well ACSIL Interface Members - Variables and Arrays: sc.DLLNameUserServiceLevel I still can't figure out how add so I can start using the service level option, as I do not want everyone in the list to have access to certain studies. I basically need to know how to do the python equivalent of If nameuserservicelevel == 0: Do study Else: Do not do study thank you for your help |
| [2022-04-14 14:43:14] |
We will put together an example.
| [2022-04-15 22:03:15] |
Here is an example: if (sc.DLLNameUserServiceLevel == 100)//Any number can be used.
{ // Perform some action like executing the study } else return;// Do nothing and return Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
