Date/Time: Mon, 10 Mar 2025 22:14:07 +0000
Extend Bid Ask Graphs to Full Width
View Count: 440
[2022-04-13 16:07:52]
User429065 - Posts: 128
Is it possible to extend the "Bid Size/Buy Column - Volume Bars" and "Ask Size/Sell Column - Volume Bars" on Trading DOM to the full width for easier reading? Also, an option to turn on-off the numerical stats? Also, put them both on the same column justified right and facing left? Thank you very much!
imageDom Request.JPG / V - Attached On 2022-04-13 16:07:09 UTC - Size: 193.08 KB - 153 views
[2022-04-13 16:39:55]
John - SC Support - Posts: 38547
With regards to the Volume Bars for the Bid/Ask Size column, the issue is that there is a larger depth value somewhere that you are not seeing that will take the full size of the column. You can check this by limiting the number of depth levels and seeing how that changes the volumes displayed. Refer to the following setting:
Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu)
As for the other items, we have set this as a Feature Request.
