Date/Time: Mon, 10 Mar 2025 22:09:55 +0000
weekend open issue
View Count: 667
[2022-04-13 14:18:35] |
User124472 - Posts: 3 |
Hello, I am having an issue with the weekend open, this issue is seen in all markets such as fx and es futures. When markets opens on sunday/ monday it opens with a 'hard open' e.g. at 00:00:00 instead of it continuing on from the Friday candle, this is seen when viewing through intraday timeframes. I have turned off 'new bar at session start' and I am still having this problem. I am not sure whether this is by design or whether it can be resolved? Hope this makes sense looking forward hearing from you kind regards |
[2022-04-13 14:47:54] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-13 16:21:54] |
I have attached chart, this illustration is seen in all markets when viewing at intraday timeframes. thank you |
Attachment Deleted. ![]() |
[2022-04-15 19:16:52] |
This is not supported with the time frame per bar that you are using: instead of it continuing on from the Friday candle
And do understand how the Session Times work: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-15 19:18:59
[2022-04-17 09:37:54] |
Thank you for the reply, could this ever be implemented into the future in Sierra charts?
[2022-04-17 18:20:19] |
No, what you are looking for fundamentally makes no sense. You cannot have a chart bar that exists in time, longer than its time length from the starting time of the bar.
