Date/Time: Mon, 10 Mar 2025 23:20:44 +0000
Manage Chart Drawings Window
View Count: 840
[2022-04-13 04:47:00] |
Profile Trader - Posts: 177 |
SC, I have a study that takes and draws lines and boxes onto a chart. The number of these items is HIGH. (1,000s a day) So I need to go in every day or so and blow off these items out of the manage chart drawing window. By clicking select multiple and highlighting and hitting delete... Here is my question. If the study is running each time I select one it updates and unhighlights the line and then I can't scroll down and select a multiple items to hit delete. So as of now I have to turn off the study go in and delete and then turn back on the study too be able to blow off said items.. Am I missing something or a suggestion to complete the task in a different way to not have to remove and reinstall the study each time? Thanks, Doug |
[2022-04-18 14:21:20] |
Sierra_Chart Engineering - Posts: 18736 |
We would have to look at the Manage Chart Drawings window and implement support for maintaining the selection when drawings are added.
[2022-04-19 10:03:58] |
Maintaining the selection of rows in the Manage Chart Drawings window when drawings are added, will be supported in the next release.
