Date/Time: Mon, 10 Mar 2025 20:31:54 +0000
Stock Trading via Sierra
View Count: 734
[2022-04-12 20:26:05] |
sam147 - Posts: 9 |
Thank you. One last question Can i use Sierra for Stop Loss, Trailing Stop, OCO with Interactive Brokers during Pre Market and Post Market Hours for Stock Trading? If yes it ll be on Server Side or Client Side? As per my understanding limit order/oco,stop limit does not work after hours from broker platform. |
[2022-04-12 23:16:17] |
Yes this is all supported with Interactive Brokers and the orders will be server-side if these options are enabled: Global Trade Settings Windows: Use Server Side OCO Orders (if supported) (Global Settings >> General Trade Settings >> General) Global Trade Settings Windows: Use Server Side Bracket Orders (if supported) (Global Settings >> General Trade Settings >> General) Here are the Interactive Brokers set up instructions: Interactive Brokers Trading Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
