Date/Time: Mon, 10 Mar 2025 20:33:11 +0000
MIT order from chart
View Count: 647
[2022-04-12 17:41:51]
User540504 - Posts: 15
Is there a way to input MIT orders directly from the chart instead of using the drop down trigger price in the trade window? I'd ideally like to right click and set a MIT order from where I have my cursor just like I can with market, limit, and stop-limit order types.
[2022-04-12 17:58:54]
John - SC Support - Posts: 38547
There are "Market if Touched" options in the Chart DOM Settings for the different order types that can be placed in the DOM with the cursor. Refer to the following:
Global Trade Settings Windows: Chart DOM Settings
And you can add Buy/Sell MIT to the Chart Trade Menu so it is available as a right-click option. Refer to the following:
Global Settings Menu: Customize Chart Trade Menu (Global Settings menu)
