Date/Time: Mon, 10 Mar 2025 23:09:03 +0000
How can i trade realtime NES contracts?
View Count: 689
[2022-04-12 17:11:22]
Galmik - Posts: 37
Hi John,
I was wondering if i could trade Nifty Futures NES with Sierra. As far as i can see there are no realtime data. Is there a way to receive realtime data?
Thank You
Mike
[2022-04-12 17:34:48]
John - SC Support - Posts: 38547
The only data that we know of for the Nifty 50 (NSE) is from Global Data Feeds. Refer to the information here:
Global Data Feeds (India) Data Service
But the above is just data. You would have to check and see if Rithmic, CQG, or Interactive Brokers have support for trading this. If so, then you could use Sierra Chart in connection with one of them.
[2022-04-19 07:20:22]
Galmik - Posts: 37
Can we connect Teton when i find the broker that supports Nifty?
Also please tell me which broker you think is reliable to connect with teton.
I have AMP now but they support CQG which i hate
Can you please help me on that?
[2022-04-19 15:18:42]
No, you can not do this. The Teton Order Routing Service only works with the CME Group and FairX with upcoming support for EUREX.
Any of the brokers that are currently supporting the Teton Order Routing Service are reliable. It is your personal choice as to which to go with. Refer to the list at step #2 at the following link:
Sierra Chart Teton Futures Order Routing: Setup Instructions
