Date/Time: Mon, 10 Mar 2025 20:22:46 +0000
Tick chart constantly changing
View Count: 674
[2022-04-12 16:43:27] |
User290496 - Posts: 62 |
Hi, I am running into this issue- Using Denali data. Using a tick chart. I have followed SierraChart recommendations on how to properly setup tick charts. During the day, the chart will sometimes randomly re-draw the bars- and they re-draw with a different appearance (OHLC for each bar will change etc). If I exit SierraChart and log back in, pulling up that same tick chart- the bars could re-draw themselves differently as well. It's a 50/50 chance every time I pull up the same tick chart, that it will look the same as it did earlier. If I enter SIM mode during the day, and then exit- the chart has a chance of again redrawing itself in a different way. I am not changing the session times. I have not seen this sort of issue on other platforms except for when either a session time or 'new bar on start of day' type option is toggled. Date Time Of Last Edit: 2022-04-12 16:44:49
[2022-04-12 20:57:05] |
This cannot possibly be true: During the day, the chart will sometimes randomly re-draw the bars Chart bars within an existing chart do not change. Unless the chart is reloaded and they will only change if the starting Date-Time changes in the chart.Refer to this subsection about the issue you are having: Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent: Differences Due to Chart Duplication or Chart Reloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-12 20:57:27
