Date/Time: Mon, 10 Mar 2025 20:17:22 +0000
Chart settings
View Count: 930
[2022-04-12 15:20:18] |
Ken Smith - Posts: 58 |
When I clik on chart settings I no longer get the settings screen with Advanced 2, 3 and Alerts, I get a black screen now with Gereral1 General 2, Tabs , chart, settings window etc, Have a changed something I shouldnt have? thanks ken |
[2022-04-12 15:36:16] |
John - SC Support - Posts: 38547 |
Refer to the following: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#NewChartSettingsWindow For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-12 16:06:27] |
Are these windows completely black? If so, these color settings need to be adjusted: Settings Windows Interface: Colors and Font Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-12 16:06:36
[2022-04-12 19:31:52] |
Can I link all my charts in a chartbook to switch back and forth between ES and NQ or others. thanks ken |
[2022-04-12 23:18:01] |
Refer to the linking options (symbol in particular) here: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
