Date/Time: Mon, 10 Mar 2025 20:30:56 +0000
trading fill lines
View Count: 727
[2022-04-12 13:06:34] |
User313147 - Posts: 48 |
Hi I have to queries. First one on My footprint chart the fill line is dashed. How do I make it a solid line so I can see it better? Also my fills that I trade on my footprint chart are not displaying on my VWAP chart. How do I enable that? |
Attachment Deleted. ![]() |
[2022-04-12 13:11:39] |
This is controlled through Graphics Settings: Graphics Settings Refer to Chart Trading Order Fills items. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-12 13:12:25
[2022-04-12 13:31:13] |
how do i get my footprint fills to show on VWAP?
[2022-04-12 15:06:32] |
John - SC Support - Posts: 38547 |
We are not understanding your question. Can you give us more information on what you are wanting to do and we can help you from there.
[2022-04-12 15:13:10] |
If I trade via my footprint chart and complete the trade the fill shows on there, however when I then switch to another chart in the same chartbook ie VWAP chart the fill doesnt show and I would like to be able to see it.
[2022-04-12 15:25:53] |
In general, as long as the chart is the same symbol and you have the chart set to show the fills, then they should show up. One option that will stop this is Trade >> Only Orders From Chart. Refer to the information here to see if you can find the reason why the fills are not showing: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-12 16:31:45] |
Ive sorted it I reloaded a new chart in and it has worked!
