Date/Time: Mon, 10 Mar 2025 20:09:11 +0000
How to have label column beside the price like the pic down below
View Count: 1737
[2022-04-12 12:33:17] |
User576648 - Posts: 26 |
How to have a label column beside the price column like the pic down below? To be more specific how can I have "level" columns like the pic down below?
Date Time Of Last Edit: 2022-04-12 12:33:42
[2022-04-12 14:44:26] |
John - SC Support - Posts: 38547 |
What that person has called a "Level" column is our "Label Column". Refer to the following for how to add this column to your DOM: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) Then refer to the following for how to add a Label or Value for a Subgraph to that column: Chart Studies: Subgraphs Tab >> Name and Value Labels For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-13 00:01:49] |
Is there a way to remove the buy & sell labels & just keep the "Label Columns" on the left sie of the price? IF so how?
[2022-04-13 14:02:54] |
The only way to do what you are asking is to do the following: - Ensure that the option for Trade >> Trading Chart DOM On is not enabled (no check mark). - Ensure that the option for Trade >> Show Market Data Columns is enabled (has a check mark). - Go to Trade >> Customize Chart/Trade DOM columns and add the Buy Order Column and Sell Order Column to the list of displayed columns. This will remove the Size or Size/BuySell columns if they were there previously. - Add the Label column if not already there. - Select OK to close that window. You should have it without the Buy/Sell columns and just the Label column. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
