Date/Time: Mon, 10 Mar 2025 20:17:07 +0000
Fix Chart Scale
View Count: 637
[2022-04-12 10:28:19]
User551971 - Posts: 34
What do I have to set so that my chart always looks the same no matter which symbol I open?
I have set my scaling in the chart MSFT as I would like it. If I now also MNTS change it looks completely different. If I change back to MSFT the chart also looks completely different again.
imageMNTS.png / V - Attached On 2022-04-12 10:27:44 UTC - Size: 29.32 KB - 144 views
imageMSFT.png / V - Attached On 2022-04-12 10:27:47 UTC - Size: 32.95 KB - 135 views
[2022-04-12 17:17:07]
Disable the Logarithmic Scale on the charts that are using a logarithmic scale:
Chart Menu: Logarithmic Scale (Chart menu)
Also refer to the information here which may be helpful as well:
Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales.
Date Time Of Last Edit: 2022-04-12 17:17:27
