Date/Time: Mon, 10 Mar 2025 20:43:39 +0000
Viewing CME data and Crypto BTC Data at 1 time
View Count: 562
[2022-04-11 23:54:03] |
Ryan Bailey - Posts: 53 |
I trade CME futures full time. I do however trade BTC through various crypto exchanges that you guy support in the data section. Is there a way I can be connected to my CME data and still have a separate chart book open with data coming from said crypto exchange? (Connected to 2 data feeds at 1 time in 2 different chart books)
[2022-04-12 14:03:26] |
John - SC Support - Posts: 38547 |
The way that you need to do this depends on what trading service you are connected to. It appears that you are connected to Rithmic, in which case, the way to do this is to have a second Sierra Chart installation where the Global Settings >> Data/Trade Service Settings >> Current Selected Service is set to SC Data - All Services. You will then have access to the Crypto data that we have available. Refer to the information at the following link for how to install another Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-12 20:59:25] |
Thanks. I do execute through Rithmic and use Sierra Denali for the data. I will try a second instance as you have suggested and see what happens. Thanks so much!!
