Date/Time: Wed, 23 Sep 2026 05:30:56 +0000
Use Single Click for Edit Control
View Count: 679
[2022-04-11 22:13:02]
User900285 - Posts: 101
Regarding the settings windows I wanted to share one small thing.
For example in any study when you select an input where the value needs to be set to a number, the old input value gets highlighted right away and the user can type in the new value.
Maybe it would be good to add the option to enable this with the settings windows.
Right now (version 2383) when you click on an input value it places the spacer to the left of the value.
[2022-04-14 13:58:56]
Thank you. This will be implemented in an upcoming release.
These Settings Windows give us a tremendous amount of flexibility and users are going to see in the latest prerelease which is 2384, and the next release, various improvements to make the appearance and usability, improved.
Users will see over time, that these new Settings Windows are much better and highly customizable.
