Date/Time: Wed, 09 Sep 2026 14:44:05 +0000
Basic Help
View Count: 786
| [2022-04-11 21:25:20] |
| sam147 - Posts: 9 |
Hi, 1. I am looking for Sierra Chart Custom Studies and example. I was looking into https://www.sierrachart.com/downloads/1865/ACS_Source/Studies.cpp but the latest version of Sierra is not able to compile it. I am trying to learn one by one studies present in examples so that i can build my custom studies. I will appreciate if you can provide me the link similar to above which holds all latest examples source codes. I have attached the screen shot as question 1. 2. I am new to Sierra and added data feed for CME only to get /ES and /NQ but i only see two bid and asks depth and others are in %. Am i doing anything wrong. I have attached the screen shot as question2. -Sam |
| [2022-04-11 21:43:21] |
| John - SC Support - Posts: 47812 |
1. The source code for most Sierra Chart studies is available on your local system in a folder named ACS_Source which is located under the main Sierra Chart installation folder. Refer to the information here: How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies 2. You activated the CME Non-Professional Top-Of-Book exchange. Since that is the Top-of-Book, you will only get the 1 level per side (the other numbers you are seeing are the total and Percentage of Bid/Ask for each column). To get the full market depth you would need to activate an exchange that includes the Market Depth (such as CME with Market Depth for nonprofessional Trading accounts). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
