Date/Time: Mon, 10 Mar 2025 20:34:14 +0000
Potential Bug - In version 2382 - Global Crosshairs no longer work across detached charts
View Count: 555
[2022-04-11 16:22:18]
HumblyTrading - Posts: 192
I ran into a bug using 2382. When using Chart Value / Crosshairs tool, the lines do not show up on detached charts or charts that are on multiple screens.
It also moves in a choppy way compared to prior versions.
I went back to 2366 and it works perfectly in that version.
Thanks,
Mike
[2022-04-11 17:14:13]
John - SC Support - Posts: 38547
The issue of the setting for Use Common Drawing Tool for Charts not working properly when set to Yes has been resolved in the latest Pre-Release. Please update to the latest pre-release using these instructions:
[2022-04-11 18:48:28]
We are confirming that this issue is resolved in version 2383.
Date Time Of Last Edit: 2022-04-11 18:48:43
[2022-04-11 18:56:13]
It works as it is supposed to in 2383.
Thanks!
